[cgma-dev] r4458 - cgm/branches/merge-cubit12/geom/OCC
jiangtao_ma at yahoo.com jiangtao_ma at yahoo.com
Fri Jan 21 08:54:13 CST 2011
Author: janehu
Date: 2011-01-21 08:54:12 -0600 (Fri, 21 Jan 2011)
New Revision: 4458
Modified:
   cgm/branches/merge-cubit12/geom/OCC/OCCModifyEngine.cpp
   cgm/branches/merge-cubit12/geom/OCC/OCCModifyEngine.hpp
Log:
Added function for Imprint_type = INCLUDE_NEIGHBORS and given neighbor_imprint_list for webcuts.
Modified: cgm/branches/merge-cubit12/geom/OCC/OCCModifyEngine.cpp
--- cgm/branches/merge-cubit12/geom/OCC/OCCModifyEngine.cpp	2011-01-20 23:30:04 UTC (rev 4457)
+++ cgm/branches/merge-cubit12/geom/OCC/OCCModifyEngine.cpp	2011-01-21 14:54:12 UTC (rev 4458)
@@ -4864,6 +4864,20 @@
   CubitStatus stat;
   DLIList<BodySM*> new_BodySMs;
+  if(preview)
+    TopoDS_Face* p_face;
+    stat = get_3_point_plane(v1, v2, v3, p_face);
+    if(!stat)
+      return stat;
+    GfxPreview::clear();
+    OCCDrawTool::instance()->draw_TopoDS_Shape(p_face, CUBIT_BLUE, CUBIT_TRUE);
+    GfxPreview::flush();
+    delete p_face;
+    return CUBIT_SUCCESS;
   stat = OCCModifyEngine::instance()->section(webcut_body_list, v1, v2, v3, new_BodySMs, true, true,false);
   if(stat == CUBIT_FAILURE)
@@ -4878,9 +4892,9 @@
     return stat;
+  BodySM* new_body1, *new_body2;
   if(imprint_type > NO_IMPRINT)
-    BodySM* new_body1, *new_body2;
     for(int i = 0; i < new_BodySMs.size()-1; i ++)
       BodySM* body1 = new_BodySMs[i];
@@ -4897,6 +4911,51 @@
   results_list = new_BodySMs;
+  //now imprint with the neighbors
+  if( imprint_type == INCLUDE_NEIGHBORS  )
+    // Loop over all the neighboring Bodies
+    DLIList<TopoDS_Shape*> shape_list1, shape_list2;
+    DLIList<CubitBoolean> is_volume;
+    stat = get_shape_list(neighbor_imprint_list,shape_list1,is_volume,false);
+    if (!stat)
+      	PRINT_WARNING("Can't imprint using neighouring bodies.\n");
More information about the cgma-dev mailing list
