[cgma-dev] Fwd: [MOAB-dev] r4392 - MOAB/trunk/tools/vtkMOABReader
Tim Tautges
tautges at mcs.anl.gov
Mon Dec 20 15:43:23 CST 2010
Hi everyone,
Note, this now gives us a geometry viewing ability we haven't had before, at least for OCC models (CUBIT-based CGM
model builds don't work, since the cgm shared library initializes some qt or vtk stuff that conflicts with the vtk in
Paraview, I think). The README file tells how to build and use.
- tim
-------- Original Message --------
Subject: [MOAB-dev] r4392 - MOAB/trunk/tools/vtkMOABReader
Date: Mon, 20 Dec 2010 15:38:12 -0600 (CST)
Reply-To: moab-dev at mcs.anl.gov
Author: tautges
Date: 2010-12-20 15:38:12 -0600 (Mon, 20 Dec 2010)
New Revision: 4392
Modified:
MOAB/trunk/tools/vtkMOABReader/README
Log:
Adding README info on geometry model support.
Modified: MOAB/trunk/tools/vtkMOABReader/README
--- MOAB/trunk/tools/vtkMOABReader/README 2010-12-20 21:36:33 UTC (rev 4391)
+++ MOAB/trunk/tools/vtkMOABReader/README 2010-12-20 21:38:12 UTC (rev 4392)
@@ -10,3 +10,6 @@
the '+' next to the plugin name and check the "Auto Load" box
- you should now be able to read files using MOAB
+Note, this viewer can also view geometric models, at least from the CGM OCC engine; to use,
+build CGM/OCC as shared libraries, link to them from MOAB (with the --with-cgm= configure
+option), and build the vtk viewer as before, but pointing to the CGM-ized MOAB.
More information about the cgma-dev
