[cgma-dev] WARNING: turning off anonymous access for a bit
Tim Tautges
tautges at mcs.anl.gov
Fri Dec 17 09:37:59 CST 2010
Hi all,
We have to do a bit of repo maintenance that requires turning off anonymous access. This should only be for an hour
or two. If you need to checkout or update cgm and have an ANL login, that will work, otherwise please be patient and
we'll have it back up asap.
- tim
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
More information about the cgma-dev
