[cgma-dev] r4259 - cgm/trunk/geom/OCC
jiangtao_ma at yahoo.com jiangtao_ma at yahoo.com
Wed Nov 10 11:52:45 CST 2010
Author: janehu
Date: 2010-11-10 11:52:44 -0600 (Wed, 10 Nov 2010)
New Revision: 4259
Modified:
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Fix for mcnp2cad/tests/hexlat. The qualified points could be more than 2, so change to use a DLIList instead of using an array of two.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2010-11-09 21:38:43 UTC (rev 4258)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2010-11-10 17:52:44 UTC (rev 4259)
@@ -2704,7 +2704,7 @@
   gp_Pnt pt1(0,0,0), pt2(0,0,0);
   gp_Pnt intsec_pnt[2] = {pt1, pt2} ;
-  for(int j = 0; j < edge_list->size(); j++)
+  for(int kk = 0; kk < edge_list->size(); kk++)
     TopoDS_Edge* edge = edge_list->get_and_step();
     BRepAdaptor_Curve acurve(*edge);
@@ -2720,7 +2720,9 @@
       double lower_bound2 = acurve2.FirstParameter();
       double upper_bound2 = acurve2.LastParameter();
       BRepExtrema_DistShapeShape distShapeShape(*edge, from_edge);
-      CubitBoolean qualified[2] = {CUBIT_FALSE, CUBIT_FALSE};
+      DLIList<CubitBoolean> qualified;
+      //CubitBoolean qualified[2] = {CUBIT_FALSE, CUBIT_FALSE};
       if (distShapeShape.IsDone() && distShapeShape.Value() < TOL)
         newP[0] = distShapeShape.PointOnShape1(1);
@@ -2737,7 +2739,7 @@
 		if ((newVal[j]-lower_bound) >= -TOL &&
                     (upper_bound - newVal[j]) >= -TOL)
-		  qualified[j] = CUBIT_TRUE;
+		  qualified.append(CUBIT_TRUE);
 		  break;
@@ -2746,9 +2748,9 @@
         for(int j = 0; j < distShapeShape.NbSolution(); j++)
-	  if (qualified[j])
+	  if (qualified.get())
-	    qualified[j] = CUBIT_FALSE;
+	    qualified.change_to( CUBIT_FALSE );
 	    Extrema_ExtPC ext(newP[j], acurve2, Precision::Approximation());
 	    double newVal;
 	    if (ext.IsDone() && (ext.NbExt() > 0)) {
@@ -2758,17 +2760,18 @@
                   if ((newVal-lower_bound2) >= -TOL &&
                       (upper_bound2 - newVal) >= -TOL)
+		    qualified.change_to( CUBIT_TRUE);
More information about the cgma-dev mailing list
