[cgma-dev] buildbot failure in Fathom on cgm-occ
cgma-dev at lists.mcs.anl.gov
Tue Oct 26 00:23:59 CDT 2010
The Fathomatic has detected a failed build of cgm-occ on Fathom.
Full details are available at:
http://gnep.mcs.anl.gov:8010/builders/cgm-occ/builds/280
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed test
LOG EXCERPT:
Constructed 2 Volumes: 30, 31
Updated volume(s): 30
Destroyed volume(s): 31
Exported: 1 OCC Body to unite5.occ
Constructed 2 Volumes: 32, 33
Updated volume(s): 33
Destroyed volume(s): 32
Exported: 1 OCC Body to unite6.occ
PASS: r_w
Geometry engine set to: OpenCascade 6.3
Constructed 1 Volume: 1
done...
PASS: test_occ
Constructed 2 Volumes: 1, 2
Total 0 cuts performed, with from_shape having 8 faces.
Created volume(s): 5
Updated volume(s): 1
PASS: operation
PASS: brick_occ
Surface 2 and 7 consolidated
Consolidated 1 pair of surfaces
Consolidated 0 pair of curves
Consolidated 0 pairs of vertices
Exported: 2 OCC Bodies to merge_test.OCC
Constructed 2 Volumes: 3, 4
PASS: merge_occ
1 of 12 tests failed
sincerely,
-The Fathomatic
More information about the cgma-dev
