[cgma-dev] Link error building parallel CGM with OCC
Robert Smith
smithrm at mcs.anl.gov
Fri Oct 8 16:22:49 CDT 2010
Yes, this is an in source build. Also, I'm using --enable-shared and
--enable-static to get both types of libraries out of the build. I'm
not sure if that's a contributing factor.
--Bob
On Oct 8, 2010, at 4:15 PM, Tim Tautges wrote:
> I don't see this problem in parallel either. I've (double/triple/
> quadruple) checked I don't have any local mods. Can you try an
> autoreconf? Also, these are all out of source builds, is the one
> you're doing an in source build?
> - tim
> On 10/08/2010 04:09 PM, Tim Tautges wrote:
>> I don't see this problem, in serial at least (will try building in
>> parallel next).
>> - tim
>> On 10/08/2010 03:43 PM, Robert Smith wrote:
>>> You're right it isn't explicitly in the link line.
>>> It's defined as follows in the Makefile:
>>> libiGeom_la_LIBADD = $(top_builddir)/libcgm.la
>>> --Bob
>>> On Oct 8, 2010, at 3:06 PM, hongjun at mcs.anl.gov wrote:
>>>> It looks your link doesn't have "libcgm" in the link library list
>>>> after "libiGeom", but I don't know why.
>>>> Can you tell me how your "libiGeom_la_LIBADD" in itaps directory is
>>>> defined?
>>>> Hong-Jun
>>>> ----- "Robert Smith" <smithrm at mcs.anl.gov> wrote:
>>>>> Has anyone encountered a problem building a parallel version of
>>>>> CGM
>>>>> with OCC (the patched version)?
>>>>> This is built on the new Ubuntu 10 release installed on the ANL
>>>>> compute servers (thrash specifically). It is using MPI compiled
>>>>> with
>>>>> GCC 4.4.3.
>>>>> The issue comes during make check. It first appears in the src/
>>>>> itaps
>>>>> directory when building chaman. But it occurs in all 3 link steps
>>>>> taken in that directory.
>>>>> The log lines for the compile and link are below.
>>>>> make[3]: Entering directory `/nfs/fathom/libs/cgm/cgm-4.0.1/
>>>>> parallel/
>>>>> src/itaps'
>>>>> make chaman testgeom_occ partest
>>>>> make[4]: Entering directory `/nfs/fathom/libs/cgm/cgm-4.0.1/
>>>>> parallel/
>>>>> src/itaps'
>>>>> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -
>>>>> DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -
>>>>> DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -
>>>>> DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -DSRCDIR=. -I../
>>>>> util -
>>>>> I../geom -I../init -I../geom/parallel -DUSE_MPI -Wall -pipe -
>>>>> pedantic -O2 -DNDEBUG -MT chaman.o -MD -MP -MF .deps/chaman.Tpo -
>>>>> c -o
>>>>> chaman.o chaman.cc
>>>>> mv -f .deps/chaman.Tpo .deps/chaman.Po
>>>>> /bin/sh ../libtool --tag=CXX --mode=link /home/fathom/3rdparty/
>>>>> mpich2/mpich2-1.2.1/gcc/bin/mpicxx -Wall -pipe -pedantic -O2 -
>>>>> DNDEBUG -L/home/fathom/3rdparty/occ/OpenCASCADE6.3.0/gcc/lib -o
>>>>> chaman chaman.o libiGeom.la -lm
>>>>> libtool: link: /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/
>>>>> mpicxx -Wall -pipe -pedantic -O2 -DNDEBUG -o .libs/chaman chaman.o
>>>>> -L/
>>>>> home/fathom/3rdparty/occ/OpenCASCADE6.3.0/gcc/lib ./.libs/
>>>>> libiGeom.so
>>>>> lm -Wl,-rpath -Wl,/home/fathom/libs/cgm/cgm-4.0.1/parallel/
>>>>> gcc_optocc/
>>>>> lib
>>>>> ./.libs/libiGeom.so: undefined reference to
>>>>> `CGMReadParallel::CGMReadParallel(GeometryQueryTool*,
>>>>> CGMParallelComm*)'
>>>>> `CGMReadParallel::load_file(char const*, char const*, char
>>>>> const*, int
>>>>> const*, int)'
>>>>> collect2: ld returned 1 exit status
>>>>> make[4]: *** [chaman] Error 1
>>>>> I've looked at .libs/libiGeom.so. It does have undefined
>>>>> references to
>>>>> the above routines. But it also has a dependency on the
>>>>> libcgm.so.0
>>>>> shared library that exists in the main CGM source directory
>>>>> (in .libs). And that shared library has definitions for the
>>>>> routines.
>>>>> --Bob
> "You will keep in perfect peace him whose mind is
> steadfast, because he trusts in you." Isaiah 26:3
> Tim Tautges Argonne National Laboratory
> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
> phone: (608) 263-8485 1500 Engineering Dr.
> fax: (608) 263-4499 Madison, WI 53706
More information about the cgma-dev
