[cgma-dev] Link error building parallel CGM with OCC
hongjun at mcs.anl.gov
Fri Oct 8 15:06:16 CDT 2010
It looks your link doesn't have "libcgm" in the link library list after "libiGeom", but I don't know why.
Can you tell me how your "libiGeom_la_LIBADD" in itaps directory is defined?
Hong-Jun
----- "Robert Smith" <smithrm at mcs.anl.gov> wrote:
> Has anyone encountered a problem building a parallel version of CGM
> with OCC (the patched version)?
> This is built on the new Ubuntu 10 release installed on the ANL
> compute servers (thrash specifically). It is using MPI compiled with
> GCC 4.4.3.
> The issue comes during make check. It first appears in the src/itaps
> directory when building chaman. But it occurs in all 3 link steps
> taken in that directory.
> The log lines for the compile and link are below.
> make[3]: Entering directory `/nfs/fathom/libs/cgm/cgm-4.0.1/parallel/
> src/itaps'
> make chaman testgeom_occ partest
> make[4]: Entering directory `/nfs/fathom/libs/cgm/cgm-4.0.1/parallel/
> src/itaps'
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -
> DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -
> DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -
> DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -DSRCDIR=. -I../util -
> I../geom -I../init -I../geom/parallel -DUSE_MPI -Wall -pipe -
> pedantic -O2 -DNDEBUG -MT chaman.o -MD -MP -MF .deps/chaman.Tpo -c -o
> chaman.o chaman.cc
> mv -f .deps/chaman.Tpo .deps/chaman.Po
> /bin/sh ../libtool --tag=CXX --mode=link /home/fathom/3rdparty/
> mpich2/mpich2-1.2.1/gcc/bin/mpicxx -Wall -pipe -pedantic -O2 -
> DNDEBUG -L/home/fathom/3rdparty/occ/OpenCASCADE6.3.0/gcc/lib -o
> chaman chaman.o libiGeom.la -lm
> libtool: link: /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/
> mpicxx -Wall -pipe -pedantic -O2 -DNDEBUG -o .libs/chaman chaman.o
> -L/
> home/fathom/3rdparty/occ/OpenCASCADE6.3.0/gcc/lib ./.libs/libiGeom.so
> lm -Wl,-rpath -Wl,/home/fathom/libs/cgm/cgm-4.0.1/parallel/gcc_optocc/
> lib
> ./.libs/libiGeom.so: undefined reference to
> `CGMReadParallel::CGMReadParallel(GeometryQueryTool*,
> CGMParallelComm*)'
> `CGMReadParallel::load_file(char const*, char const*, char const*, int
> const*, int)'
> collect2: ld returned 1 exit status
> make[4]: *** [chaman] Error 1
> I've looked at .libs/libiGeom.so. It does have undefined references to
> the above routines. But it also has a dependency on the libcgm.so.0
> shared library that exists in the main CGM source directory
> (in .libs). And that shared library has definitions for the
> routines.
> --Bob
More information about the cgma-dev
