[cgma-dev] r4134 - cgm/trunk
tautges at mcs.anl.gov
Mon Sep 20 22:35:27 CDT 2010
Author: tautges
Date: 2010-09-20 22:35:27 -0500 (Mon, 20 Sep 2010)
New Revision: 4134
Modified:
cgm/trunk/Makefile.am
cgm/trunk/configure.ac
Log:
Adding --enable-igeom, to conform to itaps standard. On by default.
Modified: cgm/trunk/Makefile.am
--- cgm/trunk/Makefile.am 2010-09-21 02:50:52 UTC (rev 4133)
+++ cgm/trunk/Makefile.am 2010-09-21 03:35:27 UTC (rev 4134)
@@ -1,5 +1,4 @@
AUTOMAKE_OPTIONS = foreign
-SUBDIRS = compat util geom init . itaps test cgm_apps
# Don't loose the autoconf include path
ACLOCAL_AMFLAGS = -I m4
@@ -12,6 +11,12 @@
lib_LTLIBRARIES = libcgm.la
+if ENABLE_igeom
+ igeom_DIR = itaps
+else
+ igeom_DIR =
+endif
if build_parallel
CGM_ll_LIB = geom/parallel/libcubit_parallel.la
else
@@ -43,8 +48,8 @@
CORE_CGM_LIBS =
endif
+SUBDIRS = compat util geom init . $(igeom_DIR) test cgm_apps
libcgm_la_LIBADD = init/libcgma_init.la $(CORE_CGM_LIBS) $(CGM_EXT_LIBS) $(CUBIT_FILE)
libcgm_la_SOURCES =
Modified: cgm/trunk/configure.ac
--- cgm/trunk/configure.ac 2010-09-21 02:50:52 UTC (rev 4133)
+++ cgm/trunk/configure.ac 2010-09-21 03:35:27 UTC (rev 4134)
@@ -265,6 +265,39 @@
AM_CONDITIONAL(build_ACIS, test x$ACIS_DIR != xno)
+# iGeom Part 1 of 2
+FORCE_IGEOM=no
+AC_ARG_ENABLE( [igeom],
+[AC_HELP_STRING([--disable-igeom],[Do not build support for iGeom interface])],
+[FORCE_IGEOM=yes],
+[enableval=yes] )
More information about the cgma-dev
