[cgma-dev] r4079 - cgm/trunk/geom/OCC
jiangtao_ma at yahoo.com
Wed Aug 11 12:20:39 CDT 2010
Author: janehu
Date: 2010-08-11 12:20:39 -0500 (Wed, 11 Aug 2010)
New Revision: 4079
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Take account for intersect function to get lower dimensional shapes.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2010-08-11 17:17:43 UTC (rev 4078)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2010-08-11 17:20:39 UTC (rev 4079)
@@ -3506,8 +3506,37 @@
TopoDS_Shape* from_shape = shape_list.get_and_step();
BodySM* from_body = from_bodies.get_and_step();
BRepAlgoAPI_Common intersector(*from_shape, *tool_shape);
- TopoDS_Shape common_shape = intersector.Shape();
- check_operation(common_shape, from_shape, is_volume[i], has_changed,
+ TopTools_ListOfShape shapes;
+ shapes.Assign(intersector.Modified(*tool_shape));
+ if (shapes.IsEmpty())
+ PRINT_INFO("The %d body did not have common part with the tool_body.\n", i+1);
+ continue;
+ if ( shapes.Extent() > 1)
+ PRINT_ERROR("Tool has multiple intersection with the shape, make it simpler. \n");
+ continue;
+ TopoDS_Shape common_shape = shapes.First();
+ if (is_volume[i] == CUBIT_TRUE &&
+ (common_shape.TShape()->ShapeType() == TopAbs_SHELL ||
+ common_shape.TShape()->ShapeType() == TopAbs_FACE ||
+ common_shape.TShape()->ShapeType() == TopAbs_EDGE ||
+ common_shape.TShape()->ShapeType() == TopAbs_VERTEX))
+ has_changed = CUBIT_TRUE;
+ *from_shape = common_shape;
+ else if(is_volume[i] == CUBIT_FALSE &&
+ (common_shape.TShape()->ShapeType() == TopAbs_EDGE ||
+ else
+ check_operation(common_shape, from_shape, is_volume[i], has_changed,
&intersector, keep_old);
if(from_shape->IsNull() )
More information about the cgma-dev
