[cgma-dev] r4068 - in cgm/trunk: . geom/OCC
kraftche at cae.wisc.edu
Thu Jul 22 13:42:42 CDT 2010
Author: kraftche
Date: 2010-07-22 13:42:42 -0500 (Thu, 22 Jul 2010)
New Revision: 4068
Modified:
cgm/trunk/configure.ac
cgm/trunk/geom/OCC/Makefile.am
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
Log:
o Detect whether or not OCC library is build with IGES/STEP and build accordingly
o Put OCC library list in proper reverse-depends order
o Fix handling of invalid file type in OCCQueryEngine
Modified: cgm/trunk/configure.ac
--- cgm/trunk/configure.ac 2010-07-22 15:21:57 UTC (rev 4067)
+++ cgm/trunk/configure.ac 2010-07-22 18:42:42 UTC (rev 4068)
@@ -304,7 +304,10 @@
CUBIT_OCC_LIB=
HAVE_OCC_DEF=
if test "x$occ_DIR" != "xno"; then
- OCC_LIBS="-lTKMath -lTKXSBase -lTKernel -lTKShHealing -lTKBRep -lTKG3d -lTKBO -lTKFeat -lTKFillet -lTKG2d -lTKOffset -lTKBool -lTKGeomAlgo -lTKGeomBase -lTKPrim -lTKTopAlgo -lTKHLR -lTKIGES -lTKMesh -lTKPrim -lTKSTEP209 -lTKSTEPAttr -lTKSTEPBase -lTKSTEP -lTKSTL -lTKTopAlgo -lTKXSBase -lTKLCAF -lTKBinL"
+ OCC_CORE_LIBS="-lTKMesh -lTKTopAlgo -lTKGeomAlgo -lTKBRep -lTKGeomBase -lTKG3d -lTKG2d -lTKMath -lTKernel"
+ OCC_GEOM_LIBS="-lTKHLR -lTKOffset -lTKShHealing -lTKFillet -lTKFeat -lTKBool -lTKBO -lTKPrim"
+ OCC_LCAF_LIBS="-lTKLCAF -lTKBinL"
+ OCC_LIBS="$OCC_LCAF_LIBS $OCC_GEOM_LIBS $OCC_CORE_LIBS"
CUBIT_OCC_LIB="-lcubit_OCC"
# Set OCC_INC_FLAG and OCC_LIB_FLAG based on --with-occ option
@@ -390,12 +393,28 @@
[AC_MSG_ERROR([OpenCascade config error: libTKernel not found ])],
[-ldl] )
+ HAVE_OCC_DEF="-DHAVE_OCC"
+ # Check for IGES, STEP, and STL support
+ AC_CHECK_LIB( [TKIGES], [igesread],
+ [HAVE_OCC_DEF="$HAVE_OCC_DEF -DHAVE_OCC_IGES"
+ OCC_LIBS="-lTKIGES -lTKXSBase $OCC_LIBS"],
+ [], [$OCC_LIBS] )
+ AC_CHECK_LIB( [TKSTEP], [main],
+ [HAVE_OCC_DEF="$HAVE_OCC_DEF -DHAVE_OCC_STEP"
+ OCC_LIBS="-lTKSTEP -lTKSTEP209 -lTKSTEPAttr -lTKSTEPBase -lTKXSBase $OCC_LIBS"],
+ [], [$OCC_LIBS] )
+ AC_CHECK_LIB( [TKSTL], [main],
+ [HAVE_OCC_DEF="$HAVE_OCC_DEF -DHAVE_OCC_STL"
+ OCC_LIBS="-lTKSTL $OCC_LIBS"],
+ [], [$OCC_LIBS] )
AC_LANG_POP(C++)
# Restore original values of variables
CPPFLAGS="$old_CPPFLAGS"
LDFLAGS="$old_LDFLAGS"
- HAVE_OCC_DEF="-DHAVE_OCC"
# Append to CGM global values
CGM_EXT_LIBS="$CGM_EXT_LIBS $OCC_LIBS"
Modified: cgm/trunk/geom/OCC/Makefile.am
--- cgm/trunk/geom/OCC/Makefile.am 2010-07-22 15:21:57 UTC (rev 4067)
+++ cgm/trunk/geom/OCC/Makefile.am 2010-07-22 18:42:42 UTC (rev 4068)
More information about the cgma-dev
