[cgma-dev] AC_PROG_SED
Rajeev Jain
jain at mcs.anl.gov
Tue Jun 8 17:21:11 CDT 2010
There was an error when using autoreconf -fi,
configure.ac:15: error: possibly undefined macro:
AC_PROG_SED
If this token and others are legitimate, please use m4_pattern_allow.
See the Autoconf documentation.
autoreconf: /usr/bin/autoconf failed with exit status: 1
Removing AC_PROG_SED from line 15 worked.
autoreconf (GNU Autoconf) 2.59 was used. AC_PROG_SED checks to make sure you have a Posix-compliant version of
Sed. Not sure why that's important....
http://www.gnu.org/software/hello/manual/autoconf/Particular-Programs.html
Rajeev
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20100608/5b2d0e05/attachment.htm>
More information about the cgma-dev
