[cgma-dev] r3903 - cgm/trunk/itaps
sjackson at cae.wisc.edu
Fri May 14 14:34:53 CDT 2010
Author: sjackson
Date: 2010-05-14 14:34:52 -0500 (Fri, 14 May 2010)
New Revision: 3903
Modified:
cgm/trunk/itaps/iGeom_CGMA.cc
Log:
Workaround to allow iGeom to export .step and .iges files
Background:
The import and export functions of the AcisQueryEngine accept optional
log file names, and will, for some file formats, always write a default
log file if no name is provided. AcisQueryEngine misuses strcpy as follows:
char* log_filename = NULL;
if( {no user-provided log name} )
strcpy( log_filename, "default_logfile" ); // writes to null pointer
This means that importing or exporting .step or .iges files from iGeom
results in a segfault. This checkin works around this problem for exporting
files only. (Fixing .step/.iges import would require changing iGeom to use
GeometryQueryTool::import_solid_model() instead of the simpler
GeometryQueryTool::read_geometry_file() currently used.)
Fixing the bugs in AcisQueryEngine would be more appropriate than this
workaround, however:
* This is the only way to fix CGM when built against Cubit 10, and
* AcisQueryEngine may see an overhaul when CGM is upgraded for Cubit 12.
Modified: cgm/trunk/itaps/iGeom_CGMA.cc
--- cgm/trunk/itaps/iGeom_CGMA.cc 2010-05-14 16:41:09 UTC (rev 3902)
+++ cgm/trunk/itaps/iGeom_CGMA.cc 2010-05-14 19:34:52 UTC (rev 3903)
@@ -501,12 +501,24 @@
ERROR(iBase_FAILURE, "Unknown geometry file extension and no file type.");
+ * Work around AcisQueryEngine log file handling bug:
+ * If the export format is iges or step, be sure the log file name is not null
+ const char* logfile_name = NULL;
+ if( file_type == "IGES" ){
+ logfile_name = "igeom_iges_export.log";
+ else if( file_type == "STEP" ){
+ logfile_name = "igeom_step_export.log";
// process options (none right now...)
DLIList<RefEntity*> bodies;
int num_ents_exported;
CubitString cubit_version(" (iGeom)");
CubitStatus status = gqt->export_solid_model(bodies, name, file_type.c_str(),
- num_ents_exported, cubit_version);
+ num_ents_exported, cubit_version, logfile_name );
if (CUBIT_SUCCESS != status)
ERROR(iBase_FAILURE, "Trouble saving geometry file.");
More information about the cgma-dev
