[cgma-dev] Problem building CGM in shared mode
Rajeev Jain
jain at mcs.anl.gov
Thu May 6 18:13:12 CDT 2010
I tried putting cubit-dir and cubit-bin-dir in my path in both cases it
doesn't find the linker and comes with /usr/bin/ld: cannot find
-lcubiti19 error in the make step. Since, cubit's bin directory is in
the LD_LIBRARY_PATH the autotools should find the linker, but that
doesn't happen..
Rajeev
On 05/06/2010 05:31 PM, Tim Tautges wrote:
> Doesn't it also have to be in your PATH? I seem to recall that...
> - tim
> Rajeev Jain wrote:
>> On 05/06/2010 04:26 PM, Robert Smith wrote:
>>> Is there some trick to getting CGM to build with --enable-shared?
>>> This also has Cubit turned on.
>>> I tried running the configure as it is done on the buildbot server
>>> and I continually get an error when it tries to link libcgm.la. It
>>> says that '/bin/ld cannot find -lcubiti19'. That makes sense since
>>> there is no -L switch to point to the Cubit install directory in the
>>> link line although the libcubiti19.so file is included explicitly in
>>> the libtool line. And the output of the make is slightly different
>>> on my build than the buildbot build.
>>> Could this be a libtool mismatch? I'm on the ANL Linux cluster
>>> running 1.5.26.
>>> --Bob
>> Adding LDFLAGS=-L/home/rajeev/cubit-32/bin LIBS=-lcubiti19 to the
>> configure script did the trick for cubit-32 using 32 bit
>> ubuntu-10.04, This can be found at
>> http://trac.mcs.anl.gov/projects/ITAPS/ticket/158
Rajeev
More information about the cgma-dev
