[cgma-dev] [MOAB-dev] Floating point exceptions in MOAB
Tim Tautges
tautges at mcs.anl.gov
Wed Apr 28 14:15:38 CDT 2010
I'd like to hear the case for why division by zero be allowed anywhere. This was always considered a no-no in any
analysis code I've worked on. The proper way to handle this has always been to test for zero before dividing. The case
for calling finite() has more to do with overflow, I'd think, though I'm not certain. I do *not* think that having MOAB
control exception generation is the right approach.
- tim
Steve Jackson wrote:
> MOAB divides by zero sometimes. I discovered this because a CGM dependency enabled floating point exceptions without
> my knowledge, and that caused my program to abort when a zero division occurred inside MOAB.
> The particular zero division I ran into occurs in GeomUtil.cpp, in the function segment_box_intersect(). (Only the
> KD tree code calls this function.) This zero division is not a bug: the result is checked using finite(), and
> discarded if infinite. Grepping the code for other occurrences of finite() suggests that this idiom exists in a
> handful of other places in MOAB. (Most of these places are geometry-related: KD trees, BSP trees, oriented boxes.)
> Code like this isn't inherently buggy, but it does lead to unexpected behavior when floating point exceptions are
> enabled.
> The library that silently enabled floating point exceptions was CGM, or rather, one of CGM's dependencies.
> Specifically, in a CGM built against Cubit 10.2 (with ACIS 16.0), one of the Cubit/ACIS shared libraries that CGM
> links to enables floating point exceptions. (I'm not sure which library it is specifically.) This does not occur
> when I build CGM against ACIS 16.7.
> So the situation is this: if I build CGM against Cubit 10.2, and then build MOAB against that CGM installation,
> certain MOAB functions may crash unless the calling program first disables floating point exceptions (e.g. by calling
> feholdexcept()). More generally, any program that enables floating point exceptions may encounter those exceptions
> when calling into MOAB. Is this mentioned in the MOAB documentation? ~S
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
More information about the cgma-dev
