[cgma-dev] [Fwd: PyTAPS Multiple Geometry Load Failure]
Tim Tautges tautges at mcs.anl.gov
Mon Apr 12 17:05:57 CDT 2010
Yep, my bad.
- tim
Jed Brown wrote:
> On Mon, 12 Apr 2010 16:33:05 -0500, Tim Tautges <tautges at mcs.anl.gov> wrote:
>> CGM uses a number of singleton classes, and here I'm taking thread
>> safe to mean you can have multiple instances (I guess they could be in
>> the same thread, for that matter).  Because of the statics used in
>> singletons, you can't use two copies of cgm simultaneously.
> That's what I thought, but this is a rather unconventional definition of
> "thread-safe" which normally refers to calling the library from
> concurrent threads.
> Jed
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the cgma-dev mailing list
