[cgma-dev] iGeom and RefVolumes vs Bodies
Tim Tautges
tautges at mcs.anl.gov
Thu Feb 4 12:18:31 CST 2010
Jason Kraftcheck wrote:
> I'm starting a new thread (with a more meaningful subject line) for the
> discussion on Bodies vs RefVolumes in the iGeom API.
> The current iGeom API is broken in that it exposes both Bodies and
> RefVolumes. This is the wrong thing to do because there is only one iBase
> type that both must map to (iBase_REGION). Otherwise which do we return
> when a user asks for regions? Both would definitely be wrong (it would be
> redundant and quite confusing.) I changed a bunch of the query functions in
> our implementation (e.g. getEntities, iterator initialization, etc.) in our
> iGeom interface to return Bodies rather than RefVolumes. I'm not sure if
> this was the right thing to do, though.
> Given the way the interface is currently defined, we have to expose bodies
> rather than volumes. All of the Boolean functions (iGeom_uniteEnts,
> iGeom_subtractEnts, iGeom_intersectEnts) return only one entity handle. All
> of these operations can result in a single Body with multiple RefVolumes.
> (BTW, what is supposed to happen if these are passed surfaces or curves?)
> However, I think that exposing RefVolumes would be better because:
> a) If iBase_FACE means a single, non-disjoint region of a surface, and
> iBase_EDGE means a single, non-disjoint subsection of a curve, then
> presumably iBase_REGION is a single non-disjoint volume.
> b) Having multi-volume bodies w/out any way to get at the individual
> volumes contained in them will make volume meshing very difficult.
> c) We are inconsistent with Cubit. Cubit's GUI hides the existence of
> Bodies, presenting only volumes. So we can set the name on a body,
> but that name will never be visible in the Cubit GUI. Similarly,
> a user can set a name on a volume in Cubit and we'll have no way
> to access that name in iGeom if iGeom exposes only Bodies.
> In summary:
> o We must chose only one entity type (Body or RefVolume) for iGeom
> o RefVolume makes a lot more sense for most things
> o The signature for the Boolean functions must change if we expose
> RefVolumes.
> - jason
I can't see any reason to go with bodies; I think it should be volumes. Therefore, the interface to booleans will have
to change, to allow passing back multiple volumes if that's the result.
- tim
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
More information about the cgma-dev
