[cgma-dev] r3519 - cgm/trunk/itaps
kraftche at cae.wisc.edu
Mon Feb 1 15:57:27 CST 2010
Author: kraftche
Date: 2010-02-01 15:57:27 -0600 (Mon, 01 Feb 2010)
New Revision: 3519
Modified:
cgm/trunk/itaps/iGeom_CGMA.cc
Log:
Fix use of stale pointers in iGeom_mergeEnts when input array contains
entities of mixed dimension:
Need to merge entities of lowest dimension first, proceeding to highest
dimension last. Otherwise lists of lower-dimension entities can contain
stale handles resulting from deleting those entities as a part of merging
parent entities.
Modified: cgm/trunk/itaps/iGeom_CGMA.cc
--- cgm/trunk/itaps/iGeom_CGMA.cc 2010-02-01 20:16:09 UTC (rev 3518)
+++ cgm/trunk/itaps/iGeom_CGMA.cc 2010-02-01 21:57:27 UTC (rev 3519)
@@ -5996,13 +5996,13 @@
CubitStatus status = CUBIT_SUCCESS, temp_status;
- if (bods.size() != 0) {
- temp_status = MergeTool::instance()->merge_bodies(bods);
+ if (verts.size() != 0) {
+ temp_status = MergeTool::instance()->merge_refvertices(verts, false);
if (CUBIT_SUCCESS != temp_status) status = temp_status;
- if (vols.size() != 0) {
- temp_status = MergeTool::instance()->merge_volumes(vols, false);
+ if (edges.size() != 0) {
+ temp_status = MergeTool::instance()->merge_refedges(edges, true, false);
@@ -6011,13 +6011,13 @@
- if (edges.size() != 0) {
- temp_status = MergeTool::instance()->merge_refedges(edges, true, false);
+ if (vols.size() != 0) {
+ temp_status = MergeTool::instance()->merge_volumes(vols, false);
- if (verts.size() != 0) {
- temp_status = MergeTool::instance()->merge_refvertices(verts, false);
+ if (bods.size() != 0) {
+ temp_status = MergeTool::instance()->merge_bodies(bods);
More information about the cgma-dev
