[cgma-dev] r3501 - in cgm/branches/merge-cubit12/geom: . ACIS_SRC ACIS_SRC/gtcAttrib/src facet
kraftche at cae.wisc.edu
Thu Jan 28 11:10:24 CST 2010
Author: kraftche
Date: 2010-01-28 11:10:23 -0600 (Thu, 28 Jan 2010)
New Revision: 3501
Modified:
cgm/branches/merge-cubit12/geom/ACIS_SRC/AcisModifyEngine.cpp
cgm/branches/merge-cubit12/geom/ACIS_SRC/AcisModifyEngine.hpp
cgm/branches/merge-cubit12/geom/ACIS_SRC/AcisQueryEngine.cpp
cgm/branches/merge-cubit12/geom/ACIS_SRC/AcisQueryEngine.hpp
cgm/branches/merge-cubit12/geom/ACIS_SRC/gtcAttrib/src/attrib_gtc.C
cgm/branches/merge-cubit12/geom/GfxPreview.cpp
cgm/branches/merge-cubit12/geom/facet/FacetModifyEngine.cpp
Log:
fix build issues
Modified: cgm/branches/merge-cubit12/geom/ACIS_SRC/AcisModifyEngine.cpp
--- cgm/branches/merge-cubit12/geom/ACIS_SRC/AcisModifyEngine.cpp 2010-01-28 07:11:34 UTC (rev 3500)
+++ cgm/branches/merge-cubit12/geom/ACIS_SRC/AcisModifyEngine.cpp 2010-01-28 17:10:23 UTC (rev 3501)
@@ -4776,9 +4776,10 @@
// Return the FACE
return new_BODY_ptr->lump()->shell()->first_face();
-#endif
+#else
FACE* AcisModifyEngine::make_type_FACE( FACE *FACE_ptr, CubitBox *limit_box_ptr ) const
@@ -5019,6 +5020,8 @@
+#endif
// This function will create a plane face using the info
// from the existing plane. It is actually a face or sheet
// body that will result from this. The new face or sheet
@@ -14090,6 +14093,12 @@
if (expand)
+#if CUBIT_ACIS_VERSION < 1900
+ PRINT_ERROR("Imprint expanded feature not available w/out ACIS 19 or newer'\n"
+ "%s:%d\n",__FILE__,__LINE__);
+ api_delent( trim_tool );
+ return CUBIT_FAILURE;
+#else
SPAposition trim_tool_box_high(0,0,0);
SPAposition trim_tool_box_low(0,0,0);
@@ -14105,6 +14114,7 @@
PRINT_ERROR( "Unable to extend the trimming surface\n" );
+#endif
ENTITY_LIST trim_tool_faces;
@@ -19412,6 +19422,12 @@
CubitStatus AcisModifyEngine::tighten_gaps_in_body(BODY*& body,
const double& desired_gap_tightness)const
+ PRINT_ERROR("api_tighten_gaps not available w/out ACIS 19.\n"
+ "%s:%d\n", __FILE__, __LINE__ );
+#else
// Make the careful option OFF to enable failsafe behavior.
// Note: By default the "careful" option is already OFF
option_header *careful_opt = find_option("careful");
@@ -19437,6 +19453,7 @@
//handle_problems_reported_by_outcome(result_of_gap_tightening);
return CUBIT_SUCCESS;
+#endif
bool AcisModifyEngine::handle_fatal_problem_reported_by_outcome(const outcome& api_outcome)const
Modified: cgm/branches/merge-cubit12/geom/ACIS_SRC/AcisModifyEngine.hpp
--- cgm/branches/merge-cubit12/geom/ACIS_SRC/AcisModifyEngine.hpp 2010-01-28 07:11:34 UTC (rev 3500)
+++ cgm/branches/merge-cubit12/geom/ACIS_SRC/AcisModifyEngine.hpp 2010-01-28 17:10:23 UTC (rev 3501)
@@ -2044,9 +2044,6 @@
CubitStatus imprint( BODY *BODY_ptr, FACE *FACE_ptr, EDGE *EDGE_ptr ) const;
//- Imprint given FACE with given EDGE. BODY_ptr is BODY that FACE_ptr is on.
- EDGE* project_EDGE( EDGE* EDGE_in_ptr, FACE* FACE_ptr, bool print_error = true ) const;
- //- Projects a EDGE to a FACE returning the newly created EDGE
//HEADER- Functions for geometry and topology queries.
CubitBoolean BODYs_interfering (BODY* body1_ptr, BODY* body2_ptr ) const;
@@ -2133,12 +2130,6 @@
DLIList<Curve*>& curves,
bool& start_flag ) const;
- CubitStatus curve_surface_intersection( Surface *surface,
- Curve* curve,
- DLIList<Curve*> &new_curves ) const;
- //Intersects input surface with input curve to produce intersection curve(s).
- //If intersection results is nothing or a point, CUBIT_FAILURE is returned.
CubitStatus embed_curves_into_surface( Surface *surface,
DLIList<Curve*> &curves_to_imprint,
DLIList<TopologyBridge*> &temporary_bridges,
Modified: cgm/branches/merge-cubit12/geom/ACIS_SRC/AcisQueryEngine.cpp
--- cgm/branches/merge-cubit12/geom/ACIS_SRC/AcisQueryEngine.cpp 2010-01-28 07:11:34 UTC (rev 3500)
+++ cgm/branches/merge-cubit12/geom/ACIS_SRC/AcisQueryEngine.cpp 2010-01-28 17:10:23 UTC (rev 3501)
@@ -4401,8 +4401,8 @@
CubitStatus
-AcisQueryEngine::fire_ray( CubitVector &origin,
- CubitVector &direction,
+AcisQueryEngine::fire_ray( const CubitVector &origin,
+ const CubitVector &direction,
DLIList<TopologyBridge*> &at_entity_list,
DLIList<double> &ray_params,
int max_hits,
@@ -6692,8 +6692,8 @@
#endif
CubitStatus
DLIList<ENTITY*> &at_ENTITY_list,
DLIList<ENTITY*> *hit_ENTITY_list,
Modified: cgm/branches/merge-cubit12/geom/ACIS_SRC/AcisQueryEngine.hpp
--- cgm/branches/merge-cubit12/geom/ACIS_SRC/AcisQueryEngine.hpp 2010-01-28 07:11:34 UTC (rev 3500)
+++ cgm/branches/merge-cubit12/geom/ACIS_SRC/AcisQueryEngine.hpp 2010-01-28 17:10:23 UTC (rev 3501)
@@ -417,8 +417,8 @@
//- Gets the minimum distance between two entities and the closest positions
//- on those entities. Supports vertices, curves, surfaces, volumes and bodies.
- virtual CubitStatus fire_ray( CubitVector &origin,
+ virtual CubitStatus fire_ray( const CubitVector &origin,
int max_hits = 0,
@@ -885,8 +885,8 @@
//- Clear any refinements set on objects in .SAT file after
//- import.
- CubitStatus fire_ray( CubitVector &origin,
+ CubitStatus fire_ray( const CubitVector &origin,
Modified: cgm/branches/merge-cubit12/geom/ACIS_SRC/gtcAttrib/src/attrib_gtc.C
--- cgm/branches/merge-cubit12/geom/ACIS_SRC/gtcAttrib/src/attrib_gtc.C 2010-01-28 07:11:34 UTC (rev 3500)
+++ cgm/branches/merge-cubit12/geom/ACIS_SRC/gtcAttrib/src/attrib_gtc.C 2010-01-28 17:10:23 UTC (rev 3501)
@@ -22,5 +22,5 @@
#define ATTRIB_GTC_NAME "gtc"
-MASTER_ATTRIB_DEFN( "gtc master attribute" );
+MASTER_ATTRIB_DEFN( "gtc master attribute" )
Modified: cgm/branches/merge-cubit12/geom/GfxPreview.cpp
--- cgm/branches/merge-cubit12/geom/GfxPreview.cpp 2010-01-28 07:11:34 UTC (rev 3500)
+++ cgm/branches/merge-cubit12/geom/GfxPreview.cpp 2010-01-28 17:10:23 UTC (rev 3501)
@@ -3,6 +3,10 @@
#include "GfxPreview.hpp"
#include "GMem.hpp"
#include "CubitVector.hpp"
+#include "Curve.hpp"
+#include "Surface.hpp"
+#include "GeometryQueryEngine.hpp"
+#include "Point.hpp"
#include <assert.h>
GfxPreview* GfxPreview::mInstance = 0;
@@ -76,6 +80,12 @@
mInstance->p_draw_ref_volume(entity, color);
+void GfxPreview::draw_ref_volume_edges(RefVolume* entity, int color)
+ if(!mInstance) return;
+ mInstance->p_draw_ref_volume_edges(entity, color);
void GfxPreview::draw_ref_body(Body* entity, int color)
@@ -187,4 +197,97 @@
mInstance->p_draw_label(label, x, y, z, color);
+void GfxPreview:: draw_cylinder(const CubitVector& axis, const CubitVector& origin,
+ CubitBox& bounding_box, float radius, int color)
+ mInstance->p_draw_cylinder(axis, origin, bounding_box, radius, color);
+void GfxPreview::draw_point(Point *pt, int color)
+ CubitVector v = pt->coordinates();
+ draw_point(v, color);
+ flush();
+void GfxPreview::draw_curve(Curve *curve, int color)
+ int num_divs = 20;
+ double lo, hi;
+ curve->get_param_range(lo, hi);
+ double dv = (hi-lo)/(double)num_divs;
+ int i;
+ double param = lo;
+ for(i=0; i<num_divs; i++)
+ CubitVector p1, p2;
+ curve->position_from_u(param, p1);
+ param += dv;
+ curve->position_from_u(param, p2);
+ draw_line(p1.x(), p1.y(), p1.z(), p2.x(), p2.y(), p2.z(), color);
+ flush();
+ DLIList<Point*> pts;
+ curve->points(pts);
+ for(i=pts.size(); i>0; i--)
+ Point *cur_pt = pts.get_and_step();
+ draw_point(cur_pt, color);
+void GfxPreview::draw_surface(Surface *surf, int color)
+ double ulo, uhi, vlo, vhi;
+ surf->get_param_range_U(ulo, uhi);
+ surf->get_param_range_V(vlo, vhi);
+ double du = (uhi-ulo)/(double)num_divs;
+ double dv = (vhi-vlo)/(double)num_divs;
+ int i, j;
+ double uparam, vparam;
+ uparam = ulo;
+ vparam = vlo;
+ for(j=0; j<num_divs; j++)
+ p1 = surf->position_from_u_v(uparam, vparam);
+ vparam += dv;
+ p2 = surf->position_from_u_v(uparam, vparam);
+ uparam += du;
+ vparam = vlo;
+ uparam = ulo;
+ uparam += du;
+ vparam += dv;
+ flush();
+void GfxPreview::draw_surface_facets_shaded(Surface *surf, int color)
+ GMem g_mem;
+ surf->get_geometry_query_engine()->get_graphics(surf, &g_mem);
+ const float* xyzs = reinterpret_cast<const float*>(g_mem.point_list());
+ GfxPreview::draw_polygons(g_mem.pointListCount, xyzs,
+ g_mem.fListCount, g_mem.facet_list(),
+ color);
+ flush();
Modified: cgm/branches/merge-cubit12/geom/facet/FacetModifyEngine.cpp
--- cgm/branches/merge-cubit12/geom/facet/FacetModifyEngine.cpp 2010-01-28 07:11:34 UTC (rev 3500)
+++ cgm/branches/merge-cubit12/geom/facet/FacetModifyEngine.cpp 2010-01-28 17:10:23 UTC (rev 3501)
@@ -3285,7 +3285,13 @@
+CubitBoolean FacetModifyEngine::bodies_interfering( BodySM* /*body1*/, BodySM* /*body2*/ ) const
+ PRINT_ERROR("Function not implemented in this engine.\n");
+ return CUBIT_FALSE;
CubitStatus FacetModifyEngine::stitch( DLIList<BodySM*> &bodies_to_stitch,
DLIList<BodySM*> &new_bodies,
bool tighten_gaps,
More information about the cgma-dev
