[cgma-dev] CGMA check for *64-acis* failed.
Nightly Test kraftche at cae.wisc.edu
Wed Jan 27 02:13:14 CST 2010
Making check in compat
make[1]: Entering directory `/home/jason/cgm/test/64-acis/compat'
make[1]: Nothing to be done for `check'.
make[1]: Leaving directory `/home/jason/cgm/test/64-acis/compat'
Making check in util
make[1]: Entering directory `/home/jason/cgm/test/64-acis/util'
make[1]: Leaving directory `/home/jason/cgm/test/64-acis/util'
Making check in geom
make[1]: Entering directory `/home/jason/cgm/test/64-acis/geom'
Making check in .
make[2]: Entering directory `/home/jason/cgm/test/64-acis/geom'
make[2]: Nothing to be done for `check-am'.
make[2]: Leaving directory `/home/jason/cgm/test/64-acis/geom'
Making check in Cholla
make[2]: Entering directory `/home/jason/cgm/test/64-acis/geom/Cholla'
make[2]: Nothing to be done for `check'.
make[2]: Leaving directory `/home/jason/cgm/test/64-acis/geom/Cholla'
Making check in facetbool
make[2]: Entering directory `/home/jason/cgm/test/64-acis/geom/facetbool'
make[2]: Leaving directory `/home/jason/cgm/test/64-acis/geom/facetbool'
make[2]: Entering directory `/home/jason/cgm/test/64-acis/geom/facet'
make[2]: Leaving directory `/home/jason/cgm/test/64-acis/geom/facet'
Making check in virtual
make[2]: Entering directory `/home/jason/cgm/test/64-acis/geom/virtual'
make[2]: Leaving directory `/home/jason/cgm/test/64-acis/geom/virtual'
Making check in ACIS
make[2]: Entering directory `/home/jason/cgm/test/64-acis/geom/ACIS'
/bin/sh ../../libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER   -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../trunk/geom/ACIS -I../.. -I../../geom/parallel -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/ACIS/gtcAttrib/incl -I/opt/acis16.7/include -I../../../trunk/compat/new  -isystem /opt/acis16.7/include  -Wall -pipe -pedantic -g -MT AcisEdgeTool.lo -MD -MP -MF .deps/AcisEdgeTool.Tpo -c -o AcisEdgeTool.lo ../../../trunk/geom/ACIS/AcisEdgeTool.cpp
 c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../trunk/geom/ACIS -I../.. -I../../geom/parallel -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/ACIS/gtcAttrib/incl -I/opt/acis16.7/include -I../../../trunk/compat/new -isystem /opt/acis16.7/include -Wall -pipe -pedantic -g -MT AcisEdgeTool.lo -MD -MP -MF .deps/AcisEdgeTool.Tpo -c ../../../trunk/geom/ACIS/AcisEdgeTool.cpp -o AcisEdgeTool.o
In file included from ../../../trunk/geom/ACIS/AcisEdgeTool.cpp:32:
../../../trunk/geom/ACIS/AcisModifyEngine.hpp: In static member function ‘static AcisModifyEngine* AcisModifyEngine::instance()’:
../../../trunk/geom/ACIS/AcisModifyEngine.hpp:137: error: cannot allocate an object of abstract type ‘AcisModifyEngine’
../../../trunk/geom/ACIS/AcisModifyEngine.hpp:84: note:   because the following virtual functions are pure within ‘AcisModifyEngine’:
../../../trunk/geom/GeometryModifyEngine.hpp:535: note: 	virtual CubitStatus GeometryModifyEngine::webcut(DLIList<BodySM*>&, const CubitVector&, const CubitVector&, const CubitVector&, DLIList<BodySM*>&, bool) const
../../../trunk/geom/GeometryModifyEngine.hpp:555: note: 	virtual CubitStatus GeometryModifyEngine::webcut(DLIList<BodySM*>&, const BodySM*, DLIList<BodySM*>&, bool) const
../../../trunk/geom/GeometryModifyEngine.hpp:720: note: 	virtual CubitStatus GeometryModifyEngine::get_mid_plane(const CubitVector&, const CubitVector&, const CubitVector&, BodySM*, BodySM*&) const
../../../trunk/geom/GeometryModifyEngine.hpp:728: note: 	virtual CubitStatus GeometryModifyEngine::get_spheric_mid_surface(Surface*, Surface*, BodySM*, BodySM*&) const
../../../trunk/geom/GeometryModifyEngine.hpp:733: note: 	virtual CubitStatus GeometryModifyEngine::get_conic_mid_surface(Surface*, Surface*, BodySM*, BodySM*&) const
../../../trunk/geom/GeometryModifyEngine.hpp:738: note: 	virtual CubitStatus GeometryModifyEngine::get_toric_mid_surface(Surface*, Surface*, BodySM*, BodySM*&) const
../../../trunk/geom/ACIS/AcisEdgeTool.cpp: In member function ‘CubitStatus AcisEdgeTool::create_curve_combine(DLIList<Curve*>&, Curve*&)’:
../../../trunk/geom/ACIS/AcisEdgeTool.cpp:67: warning: unused variable ‘AQE’
../../../trunk/geom/ACIS/AcisEdgeTool.cpp:68: warning: unused variable ‘GQT’
make[2]: *** [AcisEdgeTool.lo] Error 1
make[2]: Leaving directory `/home/jason/cgm/test/64-acis/geom/ACIS'
make[1]: *** [check-recursive] Error 1
make[1]: Leaving directory `/home/jason/cgm/test/64-acis/geom'
make: *** [check-recursive] Error 1
More information about the cgma-dev mailing list
