[cgma-dev] r3495 - cgm/branches/merge-cubit12/geom/ACIS_SRC
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Tue Jan 26 19:06:46 CST 2010
Author: kraftche
Date: 2010-01-26 19:06:43 -0600 (Tue, 26 Jan 2010)
New Revision: 3495
Modified:
   cgm/branches/merge-cubit12/geom/ACIS_SRC/
   cgm/branches/merge-cubit12/geom/ACIS_SRC/AcisModifyEngine.cpp
   cgm/branches/merge-cubit12/geom/ACIS_SRC/AcisModifyEngine.hpp
Log:
merge with trunk
Property changes on: cgm/branches/merge-cubit12/geom/ACIS_SRC
___________________________________________________________________
Added: svn:mergeinfo
   + /cgm/trunk/geom/ACIS_SRC:3427-3493
Modified: cgm/branches/merge-cubit12/geom/ACIS_SRC/AcisModifyEngine.cpp
--- cgm/branches/merge-cubit12/geom/ACIS_SRC/AcisModifyEngine.cpp	2010-01-27 00:51:03 UTC (rev 3494)
+++ cgm/branches/merge-cubit12/geom/ACIS_SRC/AcisModifyEngine.cpp	2010-01-27 01:06:43 UTC (rev 3495)
@@ -1,4 +1,5 @@
+// Filename      : AcisModifyEngine.cpp
 // Purpose       : Performs all acis-based geometry modification or creation
@@ -233,13 +234,13 @@
 #ifdef ACIS_IGES_TRANSLATOR
 #if CUBIT_ACIS_VERSION < 1100
-#include "igeshusk/igs_api/routines.hxx"
+   #include "igeshusk/igs_api/routines.hxx"
 #else
 #include "acisiges_api.hxx"
 #endif
 #endif
 #ifdef ACIS_PROE_TRANSLATOR
-#include "proe/proehusk/api/proeapi.hxx"
+   #include "proe/proehusk/api/proeapi.hxx"
 #endif
 #ifdef ACIS_LOCAL_OPS
@@ -252,13 +253,13 @@
 #ifdef ACIS_STEP_TRANSLATOR
-#include "stephusk/include/acis_inc.hxx"
-#include "stephusk/include/stpapi.hxx"
-#include "stephusk/util/apiinit.hxx"
-#include "stephusk/stepwrit/api/apiwrite.hxx"
-#include "stephusk/stepread/api/apiread.hxx"
-#include "stephusk/util/stphead.hxx"
-#include "stephusk/util/stp_res.hxx"
+   #include "stephusk/include/acis_inc.hxx"
+   #include "stephusk/include/stpapi.hxx"
+   #include "stephusk/util/apiinit.hxx"
+   #include "stephusk/stepwrit/api/apiwrite.hxx"
+   #include "stephusk/stepread/api/apiread.hxx"
+   #include "stephusk/util/stphead.hxx"
+   #include "stephusk/util/stp_res.hxx"
 #else
 #include "acisstep_api.hxx"
 #endif
@@ -334,51 +335,51 @@
 AcisModifyEngine::~AcisModifyEngine()
-  api_terminate_booleans();
-  api_terminate_covering();
-  api_terminate_sweeping();
-  api_terminate_skinning();
-  api_terminate_offsetting();
-  api_terminate_shelling ();
+   api_terminate_booleans();
+   api_terminate_covering();
+   api_terminate_sweeping();
+   api_terminate_skinning();
+   api_terminate_offsetting();
+   api_terminate_shelling ();
-  api_terminate_face_removal();
+   api_terminate_face_removal();
 #endif
-  instance_ = 0;
+   instance_ = 0;
 AcisModifyEngine::AcisModifyEngine()
   assert( !instance_ );
-  // add this modify engine to geometrymodifytool
+    // add this modify engine to geometrymodifytool
   GeometryModifyTool::instance()->add_gme(this);
-  API_BEGIN;
-  //initialize the correct modules
-  api_initialize_booleans();
-  api_initialize_covering();
-  api_initialize_sweeping();
-  api_initialize_skinning();
-  api_initialize_offsetting();
-  api_initialize_shelling ();
+   API_BEGIN;
+     //initialize the correct modules
+   api_initialize_booleans();
+   api_initialize_covering();
+   api_initialize_sweeping();
+   api_initialize_skinning();
+   api_initialize_offsetting();
+   api_initialize_shelling ();
-  api_initialize_face_removal();
+   api_initialize_face_removal();
 #endif
-  API_END;
+   API_END;
 CubitString AcisModifyEngine::identify()
-  CubitString number_string = get_major_version();
-  number_string += ".";
-  number_string += CubitString(get_minor_version());
-  number_string += CubitString(get_point_version());
-  CubitString version_string = "ACIS Version ";
-  version_string += number_string;
-  return version_string;
+   CubitString number_string = get_major_version();
+   number_string += ".";
+   number_string += CubitString(get_minor_version());
+   number_string += CubitString(get_point_version());
+   CubitString version_string = "ACIS Version ";
+   version_string += number_string;
+   return version_string;
@@ -393,7 +394,7 @@
 const type_info& AcisModifyEngine::entity_type_info() const
-  return typeid(AcisModifyEngine);
+   return typeid(AcisModifyEngine);
@@ -408,20 +409,20 @@
 BodySM* AcisModifyEngine::sphere(double radius) const
-  BODY* BODYPtr = NULL;
+   BODY* BODYPtr = NULL;
-  // Create a BODY that represents the cuboid
-  outcome result = api_make_sphere ( radius, BODYPtr );
-  if (!result.ok())
+     // Create a BODY that represents the cuboid
+   outcome result = api_make_sphere ( radius, BODYPtr );
+   if (!result.ok())
       PRINT_ERROR("In AcisModifyEngine::sphere, Line# %d\n"
                   "       Problems creating a sphere\n", __LINE__ );
       return NULL ;
-  // Build a Body from the BODY and return it.
-  BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges(BODYPtr);
-  return this_bodysm;
+     // Build a Body from the BODY and return it.
+   BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges(BODYPtr);
+   return this_bodysm;
@@ -436,31 +437,31 @@
 BodySM* AcisModifyEngine::brick(double width, double depth,
                                 double height) const
-  outcome result = api_make_cuboid ( width, depth, height, BODYPtr );
-  if (!result.ok())
+   outcome result = api_make_cuboid ( width, depth, height, BODYPtr );
+   if (!result.ok())
       PRINT_ERROR("In AcisModifyEngine::brick, Line# %d\n"
                   "       Problems creating a brick\n", __LINE__);
       return NULL ;
 BodySM* AcisModifyEngine::brick( const CubitVector &center,
                                  const CubitVector axes[3],
                                  const CubitVector &extension ) const
-  BODY* BODY_ptr;
+   BODY* BODY_ptr;
-  BODY_ptr = make_brick_BODY( center, axes, extension );
+   BODY_ptr = make_brick_BODY( center, axes, extension );
-  BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges( BODY_ptr );
+   BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges( BODY_ptr );
@@ -476,20 +477,20 @@
 BodySM* AcisModifyEngine::prism( double height, int sides,
                                  double major, double minor) const
-  // Create a BODY that represents the prism
-  outcome result = api_make_prism ( height, major, minor, sides, BODYPtr );
-  if (!result.ok())
+     // Create a BODY that represents the prism
+   outcome result = api_make_prism ( height, major, minor, sides, BODYPtr );
+   if (!result.ok())
       PRINT_ERROR("In AcisModifyEngine::prism, Line# %d\n"
                   "       Problems creating a prism\n", __LINE__);
       return NULL ;
@@ -505,19 +506,19 @@
 BodySM* AcisModifyEngine::pyramid( double height, int sides, double major,
                                    double minor, double top ) const
-  // Create a BODY that represents the pyramid
-  outcome result = api_make_pyramid ( height, major, minor, top,
-				      sides, BODYPtr );
-  if (!result.ok())
+     // Create a BODY that represents the pyramid
+   outcome result = api_make_pyramid ( height, major, minor, top,
+                                       sides, BODYPtr );
+   if (!result.ok())
       PRINT_ERROR("In AcisModifyEngine::pyramid, Line# %d\n"
                   "       Problems creating a pyramid\n", __LINE__);
       return NULL ;
@@ -533,23 +534,21 @@
 BodySM* AcisModifyEngine::cylinder( double hi, double r1, double r2,
                                     double r3 ) const
-  // Create a BODY that represents the cylinder
-  outcome result = api_make_frustum ( hi, r1, r2, r3, BODYPtr );
-  if (!result.ok())
+     // Create a BODY that represents the cylinder
+   outcome result = api_make_frustum ( hi, r1, r2, r3, BODYPtr );
+   if (!result.ok())
       PRINT_ERROR("In AcisModifyEngine::cylinder, Line# %d\n"
                   "       Problems creating a cylinder\n", __LINE__);
       return NULL ;
 // Purpose       : Create a torus and return a pointer to the Body.
@@ -562,18 +561,18 @@
 BodySM* AcisModifyEngine::torus( double r1, double r2 ) const
-  // Create a BODY that represents the torus
-  outcome result = api_make_torus ( r1, r2, BODYPtr );
-  if (!result.ok())
+     // Create a BODY that represents the torus
+   outcome result = api_make_torus ( r1, r2, BODYPtr );
+   if (!result.ok())
       PRINT_ERROR("In AcisModifyEngine::torus, Line# %d\n"
                   "       Problems creating a torus\n", __LINE__);
       return NULL ;
@@ -590,13 +589,13 @@
                                         const CubitVector& p3,
                                         const CubitVector& p4 ) const
-  BODY* new_BODY = make_planar_quad_BODY( p1, p2, p3, p4 );
+   BODY* new_BODY = make_planar_quad_BODY( p1, p2, p3, p4 );
-  // Build a VGI Body (i.e, the entire VGI structure) from this
-  // ACIS BODY.
-  BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges(new_BODY);
+   // Build a VGI Body (i.e, the entire VGI structure) from this
+   // ACIS BODY.
+   BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges(new_BODY);
@@ -612,138 +611,138 @@
 BodySM* AcisModifyEngine::copy_body ( BodySM* OSMEPtr) const
-  // Make sure that we have a valid pointer
-  assert(OSMEPtr != NULL) ;
+     // Make sure that we have a valid pointer
+   assert(OSMEPtr != NULL) ;
-  BodyACIS* bodyACISPtr = CAST_TO(OSMEPtr, BodyACIS) ;
+   BodyACIS* bodyACISPtr = CAST_TO(OSMEPtr, BodyACIS) ;
-  // Make sure that we have a valid BodyACIS
-  assert(bodyACISPtr != NULL) ;
+     // Make sure that we have a valid BodyACIS
+   assert(bodyACISPtr != NULL) ;
-  // Get the ACIS BODY
-  BODY* BODY_ptr = bodyACISPtr->get_BODY_ptr() ;
+     // Get the ACIS BODY
+   BODY* BODY_ptr = bodyACISPtr->get_BODY_ptr() ;
-  // Construct a new BODY from what we have
-  BODY* new_BODY_ptr = this->copy_BODY(BODY_ptr) ;
+     // Construct a new BODY from what we have
+   BODY* new_BODY_ptr = this->copy_BODY(BODY_ptr) ;
-  // Build a VGI Body and return it.
-  BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges(new_BODY_ptr);
+     // Build a VGI Body and return it.
+   BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges(new_BODY_ptr);
 CubitStatus AcisModifyEngine::imprint_BODYs (BODY* body1_ptr,
                                              BODY* body2_ptr) const
-  CpuTimer imprint_BODYs_timer;
+   CpuTimer imprint_BODYs_timer;
-  // Imprints the 2 input ACIS BODYs. If something goes wrong, state is
-  // restored and CUBIT_FALSE is returned.
+     // Imprints the 2 input ACIS BODYs. If something goes wrong, state is
+     // restored and CUBIT_FALSE is returned.
-  CubitStatus status = CUBIT_FAILURE;
+   CubitStatus status = CUBIT_FAILURE;
-  // Use the BEGIN/END pair so that a roll-back is done by ACIS if something
-  // goes wrong in the api_imprint or api_check_entity operations
-  if ( GeometryModifyTool::get_all_edges_imprint() )
+     // Use the BEGIN/END pair so that a roll-back is done by ACIS if something
+     // goes wrong in the api_imprint or api_check_entity operations
+   if ( GeometryModifyTool::get_all_edges_imprint() )
       api_set_int_option("all_free_edges", TRUE );
-  outcome result = api_imprint(body1_ptr, body2_ptr);
+   outcome result = api_imprint(body1_ptr, body2_ptr);
-  //Gets rid of sliver curves/surfaces that could get produced by the imprint.
-  AcisModifyEngine::instance()->cleanup_slivers( body1_ptr );
-  AcisModifyEngine::instance()->cleanup_slivers( body2_ptr );
+   //Gets rid of sliver curves/surfaces that could get produced by the imprint.
+   AcisModifyEngine::instance()->cleanup_slivers( body1_ptr );
+   AcisModifyEngine::instance()->cleanup_slivers( body2_ptr );
       api_set_int_option("all_free_edges", FALSE );
-  if (DEBUG_FLAG(18))
+   if (DEBUG_FLAG(18))
       if (result.ok())
-	  status = CUBIT_SUCCESS;
+         status = CUBIT_SUCCESS;
-	  // Now that the imprint operation has apparently succeeded (:-)
-	  // test the resulting BODYs for correctness. The output of the
-	  // api_check_entity procedure is sent to the file whose pointer
-	  // is debug_file_ptr (an ACIS global file pointer).
+           // Now that the imprint operation has apparently succeeded (:-)
+           // test the resulting BODYs for correctness. The output of the
+           // api_check_entity procedure is sent to the file whose pointer
+           // is debug_file_ptr (an ACIS global file pointer).
-	  // MJP Note:
-	  // I do this test here because there are bugs in the imprint
-	  // operation that result in invalid BODYs even though the api_imprint
-	  // call may return a successful status. I've been told that the imprint
-	  // operation will be a lot more stable in Version 2 -- and where have
-	  // we heard this kind of stuff before?? :-)
+           // MJP Note:
+           // I do this test here because there are bugs in the imprint
+           // operation that result in invalid BODYs even though the api_imprint
+           // call may return a successful status. I've been told that the imprint
+           // operation will be a lot more stable in Version 2 -- and where have
+           // we heard this kind of stuff before?? :-)
-	  FILE* save_dfp = NULL;
+         FILE* save_dfp = NULL;
-	  // Save the original value of the ACIS Debug File Pointer
-	  save_dfp = debug_file_ptr;
+           // Save the original value of the ACIS Debug File Pointer
+         save_dfp = debug_file_ptr;
-	  // Check the first entity and save the results of the check in the file,
-	  // api_check_entity_output.txt
-	  debug_file_ptr = fopen ("api_check_entity_output.txt", "w");
-	  result = api_check_entity (body1_ptr, (ENTITY_LIST *)NULL);
-	  if (debug_file_ptr) fclose (debug_file_ptr);
+           // Check the first entity and save the results of the check in the file,
+           // api_check_entity_output.txt
+         debug_file_ptr = fopen ("api_check_entity_output.txt", "w");
+         result = api_check_entity (body1_ptr, (ENTITY_LIST *)NULL);
+         if (debug_file_ptr) fclose (debug_file_ptr);
-	  if (result.ok())
+         if (result.ok())
               // Check the second entity and save the results of the check in the
               // file, api_check_entity_output.txt
-	      debug_file_ptr = fopen("api_check_entity_output.txt", "w");
-	      result = api_check_entity (body2_ptr, (ENTITY_LIST *)NULL);
+            debug_file_ptr = fopen("api_check_entity_output.txt", "w");
+            result = api_check_entity (body2_ptr, (ENTITY_LIST *)NULL);
-	      if (result.ok())
+            if (result.ok())
-	      else
-		  status = CUBIT_FAILURE;
-		  AcisQueryEngine::instance()->ACIS_API_error (result);
-	  else
-	  // Restore the original value of the ACIS Debug File Pointer
-	  debug_file_ptr = save_dfp;
+            else
+               status = CUBIT_FAILURE;
+               AcisQueryEngine::instance()->ACIS_API_error (result);
+         else
+           // Restore the original value of the ACIS Debug File Pointer
+         debug_file_ptr = save_dfp;
       else
-  if (result.ok())
-  else
-      // mieht just be no overlap, check smaller boxes
-      SPAbox box1 = get_body_box(body1_ptr);
-      SPAbox box2 = get_body_box(body2_ptr);
+   if (result.ok())
+   else
+       // mieht just be no overlap, check smaller boxes
+     SPAbox box1 = get_body_box(body1_ptr);
+     SPAbox box2 = get_body_box(body2_ptr);
-      if (!body1_ptr || !body2_ptr || (box1 && box2))
-	  if (DEBUG_FLAG(95))
-	      PRINT_DEBUG_95( "Bodies were not "
-			      "imprinted.\n");
-	      AcisQueryEngine::instance()->ACIS_API_error(result, "imprint Bodies");
-  PRINT_DEBUG_3( "CPU time taken to imprint two BODYs: "
-		 "%f secs\n", imprint_BODYs_timer.cpu_secs() ) ;
+     if (!body1_ptr || !body2_ptr || (box1 && box2))
+       if (DEBUG_FLAG(95))
+         PRINT_DEBUG_95( "Bodies were not "
+                         "imprinted.\n");
+         AcisQueryEngine::instance()->ACIS_API_error(result, "imprint Bodies");
+   PRINT_DEBUG_3( "CPU time taken to imprint two BODYs: "
+               "%f secs\n", imprint_BODYs_timer.cpu_secs() ) ;
-  return status;
+   return status;
@@ -760,40 +759,40 @@
 BODY* AcisModifyEngine::copy_BODY (BODY* body_ptr,
                                    bool remove_attribs ) const
-  // If the input pointer is NULL, return a NULL pointer
-  if (body_ptr == NULL)
+     // If the input pointer is NULL, return a NULL pointer
+   if (body_ptr == NULL)
       PRINT_ERROR("Cannot copy ACIS BODY - input pointer is NULL.\n");
       return (BODY *) NULL;
-  BODY* new_body_ptr = NULL;
+   BODY* new_body_ptr = NULL;
-  if( remove_attribs )
-    ATTRIB_CUBIT_OWNER::set_copyable( false );
+   if( remove_attribs )
+     ATTRIB_CUBIT_OWNER::set_copyable( false );
-  outcome result = api_copy_body(body_ptr, new_body_ptr);
+   outcome result = api_copy_body(body_ptr, new_body_ptr);
-  if (!result.ok())
+   if (!result.ok())
-  // Before returning this new BODY, first make sure that all the CUBIT
-  // OWNER attributes are cleaned out of it
-    ATTRIB_CUBIT_OWNER::set_copyable( true );
-    if ( remove_attribs )
-    AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(new_body_ptr);
-  // Also make sure that any healing attributes are removed from it
+     // Before returning this new BODY, first make sure that all the CUBIT
+     // OWNER attributes are cleaned out of it
+     ATTRIB_CUBIT_OWNER::set_copyable( true );
+   if ( remove_attribs )
+     AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(new_body_ptr);
+   // Also make sure that any healing attributes are removed from it
 #ifdef ACIS_HEALER
-  AcisHealerTool::instance()->end_BODY_for_healing( new_body_ptr );
+   AcisHealerTool::instance()->end_BODY_for_healing( new_body_ptr );
 #endif
-  return new_body_ptr;
+   return new_body_ptr;
 CubitStatus AcisModifyEngine::surface_intersection( Surface *surface1_ptr,
@@ -801,42 +800,42 @@
                                                     DLIList<Curve*> &intersect_graph,
                                                     const double ) const
-  //First make sure the entities are ACIS.
+      //First make sure the entities are ACIS.
   SurfaceACIS *surf_ACIS_1= CAST_TO(surface1_ptr,SurfaceACIS);
   SurfaceACIS *surf_ACIS_2= CAST_TO(surface2_ptr,SurfaceACIS);
   if ( !surf_ACIS_1 || !surf_ACIS_2 )
-      PRINT_ERROR("In AcisModifyEngine::surface_intersection\n"
-		  "Not all entities are from the same engine.\n");
-      return CUBIT_FAILURE;
-  //Get the original bodies.
+    PRINT_ERROR("In AcisModifyEngine::surface_intersection\n"
+                "Not all entities are from the same engine.\n");
+    return CUBIT_FAILURE;
+    //Get the original bodies.
   FACE* FACE1_ptr =  surf_ACIS_1->get_FACE_ptr();
   FACE* FACE2_ptr =  surf_ACIS_2->get_FACE_ptr();
   BODY* intersect_BODY = NULL;
-  //Now get the intersection.
+    //Now get the intersection.
   CubitBoolean intersecting = CUBIT_FALSE;
   CubitStatus ret = FACE_intersection(FACE1_ptr, FACE2_ptr,
                                       intersect_BODY, intersecting);
   if ( ret != CUBIT_SUCCESS )
     return ret;
   if ( !intersecting )
       //No intersection, we should have caught this before, but
       //just return with an empty edge list.
-      return CUBIT_SUCCESS;
+    return CUBIT_SUCCESS;
   ret = convert_WIRE( intersect_BODY, intersect_graph );
     return ret;
-  //Okay we should have our fill of curves.
-  //Delete the intersection graph wire, which should
-  //be fine since we copied the curves.
+    //Okay we should have our fill of curves.
+    //Delete the intersection graph wire, which should
+    //be fine since we copied the curves.
   api_del_entity(intersect_BODY);
-  //return sucess!
+    //return sucess!
@@ -844,7 +843,7 @@
                                              const CubitVector &point_2,
                                              const CubitVector &point_3,
                                              BodySM *body_to_trim_to,
-                                             DLIList<BodySM*>& midplane_bodies ) const
+                                             BodySM *&midplane_body ) const
   DLIList<BodySM*> body_list;
@@ -855,33 +854,32 @@
   BODY *sheet_BODY = this->create_infinite_plane_cutting_tool(
-							      point_1, point_2, point_3, super_box, CUBIT_TRUE);
+    point_1, point_2, point_3, super_box, CUBIT_TRUE);
   BODY* BODY_to_trim_to = AcisQueryEngine::get_BODY(body_to_trim_to);
   bool delete_attribs = CUBIT_TRUE;
   BODY* BODY_copy = this->copy_BODY(BODY_to_trim_to, delete_attribs);
   if (BODY_copy == NULL)
-      PRINT_ERROR("Cannot make a copy of the parent ACIS BODY of volume.\n"
-		  "       mid plane creation failed.\n" );
+    PRINT_ERROR("Cannot make a copy of the parent ACIS BODY of volume.\n"
+                "       mid plane creation failed.\n" );
   outcome result = api_intersect( BODY_copy, sheet_BODY );
   if ( !result.ok() )
-      api_del_entity(BODY_copy);
-      api_del_entity(sheet_BODY);
-      PRINT_ERROR("Problems creating midplane.\n");
+    api_del_entity(BODY_copy);
+    api_del_entity(sheet_BODY);
+    PRINT_ERROR("Problems creating midplane.\n");
   //Create a new cubit body for the imprinted body.
-  BodySM* midplane_body = AcisQueryEngine::instance()->
+  midplane_body = AcisQueryEngine::instance()->
     populate_topology_bridges(sheet_BODY);
-  midplane_bodies.append(midplane_body);
@@ -893,48 +891,48 @@
 // Date       : 03/07/06
 CubitStatus AcisModifyEngine::get_spheric_mid_surface( Surface *surface_ptr1,
-						       Surface *surface_ptr2,
-						       BodySM *body_to_trim_to,
-						       DLIList<BodySM*> &midsurface_bodies) const
+				  Surface *surface_ptr2,
+				  BodySM *body_to_trim_to,
+				  BodySM *&midsurface_body ) const
   SurfaceACIS *surf_ACIS1 = CAST_TO(surface_ptr1, SurfaceACIS );
   FACE* FACE1_ptr = make_FACE( surf_ACIS1->get_FACE_ptr() );
   int surface_type = (&(FACE1_ptr->geometry()->equation()))->type();
   if( surface_type != sphere_type )
-      PRINT_ERROR( "In AcisModifyEngine::get_spheric_mid_surface\n"
-		   "       The CGM sphere is not an ASIS sphere (%d %d).\n", surface_type, SPHERE_SURFACE_TYPE );
+    PRINT_ERROR( "In AcisModifyEngine::get_spheric_mid_surface\n"
+		 "       The CGM sphere is not an ASIS sphere (%d %d).\n", surface_type, SPHERE_SURFACE_TYPE );
   SurfaceACIS *surf_ACIS2 = CAST_TO(surface_ptr2, SurfaceACIS );
   FACE* FACE2_ptr = make_FACE( surf_ACIS2->get_FACE_ptr() );
   surface_type = (&(FACE2_ptr->geometry()->equation()))->type();
-  //   surface const* acis_surface1 = &(FACE1_ptr->geometry()->equation());
-  //   sphere const* sphere_surface1 = (sphere *)acis_surface1;
+//   surface const* acis_surface1 = &(FACE1_ptr->geometry()->equation());
+//   sphere const* sphere_surface1 = (sphere *)acis_surface1;
   SURFACE const* acis_SURFACE1 = FACE1_ptr->geometry();
   SPHERE const* SPHERE_SURFACE1 = (SPHERE *)acis_SURFACE1;
   SPAposition center1 = SPHERE_SURFACE1->centre();
-  //   surface const* acis_surface2 = &(FACE2_ptr->geometry()->equation());
-  //   sphere const* sphere_surface2 = (sphere *)acis_surface2;
+//   surface const* acis_surface2 = &(FACE2_ptr->geometry()->equation());
+//   sphere const* sphere_surface2 = (sphere *)acis_surface2;
   SURFACE const* acis_SURFACE2 = FACE2_ptr->geometry();
   SPHERE const* SPHERE_SURFACE2 = (SPHERE *)acis_SURFACE2;
   SPAposition center2 = SPHERE_SURFACE2->centre();
   if ( center1 != center2 )
-		   "       Not supported yet: spheres do not have the same center.\n" );
+ 		 "       Not supported yet: spheres do not have the same center.\n" );
   CubitBox bounding_box = GeometryQueryTool::instance()->model_bounding_box();
@@ -958,56 +956,55 @@
 				    new_FACE_ptr );
   if (!result.ok() || new_FACE_ptr == NULL ||
       new_FACE_ptr->geometry() == NULL )
-		   "       ACIS api_make_spface function failed.\n");
+		 "       ACIS api_make_spface function failed.\n");
   FACE *face_list[1];
   face_list[0] = new_FACE_ptr;
   result = api_sheet_from_ff( 1, face_list, sheet_BODY );
   if ( !result.ok() || sheet_BODY == NULL || sheet_BODY->lump() == NULL
-       || sheet_BODY->lump()->shell() == NULL ||
-       sheet_BODY->lump()->shell()->first_face() == NULL )
-		   "       ACIS api_sheet_from_ff function failed.\n");
+      || sheet_BODY->lump()->shell() == NULL ||
+      sheet_BODY->lump()->shell()->first_face() == NULL )
+		 "       ACIS api_sheet_from_ff function failed.\n");
   result = api_body_to_2d( sheet_BODY );
   if ( !result.ok() )
-		   "       ACIS api_body_to_2d function failed.\n");
+		 "       ACIS api_body_to_2d function failed.\n");
   if ( BODY_copy == NULL )
-		   "       Cannot make a copy of the parent ACIS BODY of volume.\n" );
+		 "       Cannot make a copy of the parent ACIS BODY of volume.\n" );
   if ( !result.ok() )
-      api_del_entity( BODY_copy );
-      api_del_entity( sheet_BODY );
-		   "       ACIS api_intersect function failed.\n" );
+    api_del_entity( BODY_copy );
+    api_del_entity( sheet_BODY );
+		 "       ACIS api_intersect function failed.\n" );
-  BodySM* midsurface_body = AcisQueryEngine::instance()->populate_topology_bridges(sheet_BODY);
+  midsurface_body = AcisQueryEngine::instance()->populate_topology_bridges(sheet_BODY);
-  midsurface_bodies.append(midsurface_body);
@@ -1019,28 +1016,28 @@
 // Date       : 03/07/06
 CubitStatus AcisModifyEngine::get_conic_mid_surface( Surface *surface_ptr1,
-						     DLIList<BodySM*> &midsurface_bodies ) const
   if( surface_type != cone_type )
-      PRINT_ERROR( "In AcisModifyEngine::get_conic_mid_surface\n"
-		   "       The CGM cone is not an ASIS cone (%d %d).\n", surface_type, CONE_SURFACE_TYPE );
+    PRINT_ERROR( "In AcisModifyEngine::get_conic_mid_surface\n"
+		 "       The CGM cone is not an ASIS cone (%d %d).\n", surface_type, CONE_SURFACE_TYPE );
   cone const* cone_surface1 = (cone *)acis_surface1;
@@ -1055,34 +1052,34 @@
   if ( ( sine_angle1 != 0.0 ) || ( fabs( cosine_angle1 ) != 1.0 )
        ( sine_angle2 != 0.0 ) || ( fabs( cosine_angle2 ) != 1.0 ) )
+    if( ( sine_angle1 != sine_angle2 ) || ( cosine_angle1 != cosine_angle2 ) )
-      if( ( sine_angle1 != sine_angle2 ) || ( cosine_angle1 != cosine_angle2 ) )
-		       "       Not supported yet: cones do not have the same major angle.\n" );
+		   "       Not supported yet: cones do not have the same major angle.\n" );
   ellipse const* base1 = &cone_surface1->base;
   double ratio1 = base1->radius_ratio;
   ellipse const* base2 = &cone_surface2->base;
   double ratio2 = base2->radius_ratio;
   if( ratio1 != ratio2 )
-		   "       Not supported yet: cones do not have the same radius ratios.\n" );
+		 "       Not supported yet: cones do not have the same radius ratios.\n" );
   SPAunit_vector normal1 = base1->normal;
   SPAunit_vector normal2 = base2->normal;
   if ( ( normal1 != normal2 ) && ( - normal1 != normal2 ) )
-		   "       Not supported yet: cones do not have the same axis of symmetry.\n" );
+		 "       Not supported yet: cones do not have the same axis of symmetry.\n" );
   SPAposition const centre1 = base1->centre;
   SPAposition const centre2 = base2->centre;
@@ -1092,72 +1089,72 @@
 			centre2.y() - centre1.y(),
 			centre2.z() - centre1.z() );
   if ( ! c1_to_c2.about_equal( null_vec ) )
+    CubitVector comm_dir( normal1.x(), normal1.y(), normal1.z() );
+    c1_to_c2.normalize();
+    if ( ( ! c1_to_c2.about_equal( comm_dir ) ) && ( ! (-c1_to_c2).about_equal( comm_dir ) ) )
-      CubitVector comm_dir( normal1.x(), normal1.y(), normal1.z() );
-      c1_to_c2.normalize();
-      if ( ( ! c1_to_c2.about_equal( comm_dir ) ) && ( ! (-c1_to_c2).about_equal( comm_dir ) ) )
-	  CubitVector const point_1( ( centre1.x() + centre2.x() ) * .5,
-				     ( centre1.y() + centre2.y() ) * .5,
-				     ( centre1.z() + centre2.z() ) * .5 );
-	  CubitVector const point_2 = point_1 + comm_dir;
-	  CubitVector const point_3 = point_1 + ( comm_dir * c1_to_c2 );
-	  CubitStatus ret = this->get_mid_plane( point_1, point_2, point_3,
-						 body_to_trim_to, midsurface_bodies );
+      CubitVector const point_1( ( centre1.x() + centre2.x() ) * .5,
+				 ( centre1.y() + centre2.y() ) * .5,
+				 ( centre1.z() + centre2.z() ) * .5 );
+      CubitVector const point_2 = point_1 + comm_dir;
+      CubitVector const point_3 = point_1 + ( comm_dir * c1_to_c2 );
+      CubitStatus ret = this->get_mid_plane( point_1, point_2, point_3,
+					     body_to_trim_to, midsurface_body );
-	  return ret;
+      return ret;
   BODY *sheet_BODY;
   CubitBoolean cylinder = CUBIT_FALSE;
   if ( ( sine_angle1 == 0.0 ) && ( fabs( cosine_angle1 ) == 1.0 ) )
-      cylinder = CUBIT_TRUE;
+    cylinder = CUBIT_TRUE;
   double const st_ang = 0.;
   double const end_ang = 2. * CUBIT_PI;
   double const height = 2. * (bounding_box.diagonal()).length();
   CubitVector center_vec;
   CubitVector temp_norm( normal1.x(), normal1.y(), normal1.z());
   if ( ! cylinder )
+    if ( sine_angle1 > 0.0 && cosine_angle1 > 0.0 )
-      if ( sine_angle1 > 0.0 && cosine_angle1 > 0.0 )
-	  sine_angle1 = - sine_angle1;
-	  temp_norm *= - 1.0;
-      else if ( sine_angle1 < 0.0 && cosine_angle1 < 0.0 )
-	  cosine_angle1 = - cosine_angle1;
-      //make center of surface along axis, 1/2 height of
-      //bounding box of entire model.
-      CubitVector root_vec( centre1.x(), centre1.y(), centre1.z() );
-      center_vec = root_vec + ( -.5 * height) * temp_norm;
+      sine_angle1 = - sine_angle1;
+      temp_norm *= - 1.0;
-  else
+    else if ( sine_angle1 < 0.0 && cosine_angle1 < 0.0 )
-      center_vec = .5 * height * temp_norm;
-      center_vec = root_vec - center_vec;
+      cosine_angle1 = - cosine_angle1;
+    //make center of surface along axis, 1/2 height of
+    //bounding box of entire model.
+    CubitVector root_vec( centre1.x(), centre1.y(), centre1.z() );
+    center_vec = root_vec + ( -.5 * height) * temp_norm;
+  else
+    center_vec = .5 * height * temp_norm;
+    center_vec = root_vec - center_vec;
   SPAposition const center ( center_vec.x(), center_vec.y(), center_vec.z() );
   SPAvector const major_axis1 = base1->major_axis;
   SPAvector const major_axis2 = base2->major_axis;
   SPAvector newmajor_axis;
   if ( cosine_angle1 * cosine_angle2 < 0. )
-      newmajor_axis = ( major_axis1 - major_axis2 ) * .5;
+     newmajor_axis = ( major_axis1 - major_axis2 ) * .5;
   else
-      newmajor_axis = ( major_axis1 + major_axis2 ) * .5;
+     newmajor_axis = ( major_axis1 + major_axis2 ) * .5;
   FACE *new_FACE_ptr = NULL;
   outcome result = api_make_cnface( center,
@@ -1172,55 +1169,54 @@
 				    new_FACE_ptr );
-		   "       ACIS api_make_cnface function failed.\n");
+		 "       ACIS api_make_cnface function failed.\n");
   FACE *face_list[1];
   if ( !result.ok() )
   if ( !result.ok() )
@@ -1233,64 +1229,64 @@
 // Date       : 03/07/06
 CubitStatus AcisModifyEngine::get_toric_mid_surface( Surface *surface_ptr1,
   if( surface_type != torus_type )
-      PRINT_ERROR( "In AcisModifyEngine::get_toric_mid_surface\n"
-		   "       The CGM cone is not an ASIS torus (%d %d).\n", surface_type, CONE_SURFACE_TYPE );
+    PRINT_ERROR( "In AcisModifyEngine::get_toric_mid_surface\n"
+		 "       The CGM cone is not an ASIS torus (%d %d).\n", surface_type, CONE_SURFACE_TYPE );
-  //   torus const* torus_surface1 = (torus *)acis_surface1;
+//   torus const* torus_surface1 = (torus *)acis_surface1;
   TORUS const* TORUS_SURFACE1 = (TORUS *)acis_SURFACE1;
   double major_radius1 = TORUS_SURFACE1->major_radius();
-  //   torus const* torus_surface2 = (torus *)acis_surface2;
+//   torus const* torus_surface2 = (torus *)acis_surface2;
   TORUS const* TORUS_SURFACE2 = (TORUS *)acis_SURFACE2;
   double major_radius2 = TORUS_SURFACE2->major_radius();
   if ( major_radius1 != major_radius2 )
-		   "       Not supported yet: torii do not have the same radii.\n" );
+ 		 "       Not supported yet: torii do not have the same radii.\n" );
   SPAposition center1 = TORUS_SURFACE1->centre();
   SPAposition center2 = TORUS_SURFACE2->centre();
-		   "       Not supported yet: torii do not have the same center.\n" );
+ 		 "       Not supported yet: torii do not have the same center.\n" );
   SPAunit_vector normal1 = TORUS_SURFACE1->normal();
   SPAunit_vector normal2 = TORUS_SURFACE2->normal();
-		   "       Not supported yet: torii do not have the same axis of symmetry.\n" );
+		 "       Not supported yet: torii do not have the same axis of symmetry.\n" );
@@ -1314,55 +1310,54 @@
 				    new_FACE_ptr );
-		   "       ACIS api_make_trface function failed.\n");
+		 "       ACIS api_make_trface function failed.\n");
   FACE *face_list[1];
   if ( !result.ok() )
   if ( !result.ok() )
@@ -1384,8 +1379,8 @@
                                              CubitBoolean keep_old_body,
                                              CubitBoolean preview )
-  return AcisTweakTool::instance()->tweak_chamfer( curve_list, left_offset,
-						   new_bodysm_list, right_offset, keep_old_body, preview );
+    return AcisTweakTool::instance()->tweak_chamfer( curve_list, left_offset,
+      new_bodysm_list, right_offset, keep_old_body, preview );
@@ -1412,8 +1407,8 @@
   return AcisTweakTool::instance()->tweak_chamfer( ref_vertex_list, offset1,
-						   new_bodysm_list, edge1, offset2, edge2, offset3, edge3, keep_old_body,
-						   preview );
+    new_bodysm_list, edge1, offset2, edge2, offset3, edge3, keep_old_body,
+    preview );
@@ -1430,8 +1425,8 @@
-  return AcisTweakTool::instance()->tweak_fillet( curve_list, radius,
-						  new_bodysm_list, keep_old_body, preview );
+    return AcisTweakTool::instance()->tweak_fillet( curve_list, radius,
+      new_bodysm_list, keep_old_body, preview );
@@ -1451,7 +1446,7 @@
   return AcisTweakTool::instance()->tweak_fillet( curve_ptr, start_radius,
-						  end_radius, new_bodysm_ptr, keep_old_body, preview );
+    end_radius, new_bodysm_ptr, keep_old_body, preview );
@@ -1470,7 +1465,7 @@
   return AcisTweakTool::instance()->tweak_fillet( ref_vertex_list, radius,
@@ -1486,8 +1481,8 @@
                                           CubitBoolean preview ) const
-  return AcisTweakTool::instance()->tweak_move( surface_list, delta,
+   return AcisTweakTool::instance()->tweak_move( surface_list, delta,
@@ -1504,7 +1499,7 @@
   return AcisTweakTool::instance()->tweak_move( curve_list, delta,
@@ -1521,8 +1516,8 @@
-  return AcisTweakTool::instance()->tweak_offset( surface_list,
-						  offset_distance, new_bodysm_list, keep_old_body, preview );
+   return AcisTweakTool::instance()->tweak_offset( surface_list,
+     offset_distance, new_bodysm_list, keep_old_body, preview );
@@ -1540,7 +1535,7 @@
   return AcisTweakTool::instance()->tweak_offset( curve_list, offset_distance,
@@ -1558,8 +1553,8 @@
-  return AcisTweakTool::instance()->tweak_remove( ref_face_list,
-						  new_bodysm_list, extend_adjoining, keep_surface, keep_old_body, preview );
+   return AcisTweakTool::instance()->tweak_remove( ref_face_list,
+     new_bodysm_list, extend_adjoining, keep_surface, keep_old_body, preview );
@@ -1574,7 +1569,7 @@
   return AcisTweakTool::instance()->tweak_remove( curve_list, new_bodysm_list,
-						  keep_old_body, preview );
+    keep_old_body, preview );
@@ -1592,8 +1587,8 @@
-  return AcisTweakTool::instance()->tweak_target( surface_list, target_face_list,
-						  new_bodysm_list, reverse_flg, keep_old_body, preview );
+   return AcisTweakTool::instance()->tweak_target( surface_list, target_face_list,
+     new_bodysm_list, reverse_flg, keep_old_body, preview );
@@ -1613,7 +1608,7 @@
   return AcisTweakTool::instance()->tweak_target( curve_list, target_surf_list,
-						  new_body_list, reverse_flg, keep_old_bodies, preview );
+    new_body_list, reverse_flg, keep_old_bodies, preview );
@@ -1635,7 +1630,7 @@
   return AcisTweakTool::instance()->tweak_target( curve_list, target_curve_list,
@@ -1648,8 +1643,8 @@
                                                   DLIList<DLIList<CubitVector*>*> &vec_lists_v,
                                                   double net_tol, CubitBoolean heal ) const
-  return AcisSurfaceTool::instance()->create_net_surface( new_body, vec_lists_u, vec_lists_v,
-							  net_tol, heal );
+   return AcisSurfaceTool::instance()->create_net_surface( new_body, vec_lists_u, vec_lists_v,
+                                                           net_tol, heal );
@@ -1660,7 +1655,7 @@
 CubitStatus AcisModifyEngine::create_net_surface( DLIList<Curve*>& u_curves, DLIList<Curve*>& v_curves,
                                                   BodySM *& new_body, double net_tol, CubitBoolean heal ) const
-  return AcisSurfaceTool::instance()->create_net_surface( u_curves, v_curves, new_body, net_tol, heal );
+   return AcisSurfaceTool::instance()->create_net_surface( u_curves, v_curves, new_body, net_tol, heal );
@@ -1670,7 +1665,7 @@
 CubitStatus AcisModifyEngine::create_offset_surface( Surface* ref_face_ptr, BodySM*& new_body, double offset_distance ) const
-  return AcisSurfaceTool::instance()->create_offset_surface( ref_face_ptr, new_body, offset_distance );
+   return AcisSurfaceTool::instance()->create_offset_surface( ref_face_ptr, new_body, offset_distance );
@@ -1680,7 +1675,7 @@
 CubitStatus AcisModifyEngine::create_offset_body( BodySM* body_ptr, BodySM*& new_body, double offset_distance ) const
-  return AcisSurfaceTool::instance()->create_offset_body( body_ptr, new_body, offset_distance );
+   return AcisSurfaceTool::instance()->create_offset_body( body_ptr, new_body, offset_distance );
@@ -1690,7 +1685,7 @@
 CubitStatus AcisModifyEngine::create_skin_surface( DLIList<Curve*>& curves, BodySM*& new_body ) const
-  return AcisSurfaceTool::instance()->create_skin_surface( curves, new_body );
+   return AcisSurfaceTool::instance()->create_skin_surface( curves, new_body );
@@ -1705,9 +1700,9 @@
                                              CubitBoolean align_direction, CubitBoolean perpendicular,
                                              CubitBoolean simplify_option ) const
-  return AcisSurfaceTool::instance()->loft_surfaces( face1, takeoff1, face2, takeoff2, new_body,
-						     arc_length_option, twist_option, align_direction,
-						     perpendicular, simplify_option );
+   return AcisSurfaceTool::instance()->loft_surfaces( face1, takeoff1, face2, takeoff2, new_body,
+                                                      arc_length_option, twist_option, align_direction,
+                                                      perpendicular, simplify_option );
@@ -1722,9 +1717,9 @@
-  return AcisSurfaceTool::instance()->loft_surfaces_to_body( face1, takeoff1, face2, takeoff2, new_body,
+   return AcisSurfaceTool::instance()->loft_surfaces_to_body( face1, takeoff1, face2, takeoff2, new_body,
@@ -1735,7 +1730,7 @@
 CubitStatus AcisModifyEngine::create_surface( DLIList<CubitVector*>& vec_list, BodySM *&new_body, Surface *ref_face_ptr,
                                               CubitBoolean project_points ) const
-  return AcisSurfaceTool::instance()->create_surface( vec_list, new_body, ref_face_ptr, project_points );
+   return AcisSurfaceTool::instance()->create_surface( vec_list, new_body, ref_face_ptr, project_points );
@@ -1747,7 +1742,7 @@
                                                    Surface *ref_face1, double leg1, Surface *ref_face2, double leg2,
                                                    BodySM *&new_body ) const
-  return AcisSurfaceTool::instance()->create_weld_surface( root, ref_face1, leg1, ref_face2, leg2, new_body );
+   return AcisSurfaceTool::instance()->create_weld_surface( root, ref_face1, leg1, ref_face2, leg2, new_body );
@@ -1771,38 +1766,38 @@
                                                  BODY *&intersect_graph,
                                                  CubitBoolean &interfering ) const
-  // Make sure we have 2 non-NULL, valid BODYs first.
+    // Make sure we have 2 non-NULL, valid BODYs first.
   if ( FACE1_ptr == NULL || !IS_ENTITY_TYPE( FACE1_ptr, FACE ) ||
        FACE2_ptr == NULL || !IS_ENTITY_TYPE( FACE2_ptr, FACE ) )
-      PRINT_ERROR("BUG: In AcisModifyEngine::BODY_intersection\n"
-		  "     One or both input FACE's are NULL or invalid.\n");
-      assert(0);
-  //make copies to make sure nothing bad happens to the FACES.
+    PRINT_ERROR("BUG: In AcisModifyEngine::BODY_intersection\n"
+                "     One or both input FACE's are NULL or invalid.\n");
+    assert(0);
+    //make copies to make sure nothing bad happens to the FACES.
   FACE* copy_1 = make_FACE(FACE1_ptr);
   FACE* copy_2 = make_FACE(FACE2_ptr);
   intersect_graph = NULL;
-  // Create the intersection graph between the given bodies
+    // Create the intersection graph between the given bodies
   outcome result = api_fafa_int(copy_1, copy_2,
                                 intersect_graph);
   if (!result.ok() || intersect_graph == NULL )
       // Find out if the returned "slice" is empty
-      interfering = CUBIT_FALSE;
+    interfering = CUBIT_FALSE;
   else
-      interfering = CUBIT_TRUE;
-  //now delete the copies.
+    interfering = CUBIT_TRUE;
+    //now delete the copies.
   api_delent(copy_1);
   api_delent(copy_2);
-  //return success.
+    //return success.
@@ -1812,101 +1807,101 @@
 CubitStatus AcisModifyEngine::convert_WIRE( BODY *wire_BODY,
                                             DLIList <Curve*> &curve_list ) const
-  //Now get the edges from the wire body (int_graph), and create
-  //ref edges.
-  DLIList <EDGE*> EDGE_list;
-  WIRE *cur_WIRE = NULL;
-  LUMP *cur_LUMP = NULL;
-  // Make sure the wire is OK, and get the appropriate entity
-  // Get a WIRE if it's there
-  if ( wire_BODY->wire() == NULL ||
-       wire_BODY->wire()->coedge() == NULL ||
-       wire_BODY->wire()->coedge()->edge() == NULL )
+    //Now get the edges from the wire body (int_graph), and create
+    //ref edges.
+    DLIList <EDGE*> EDGE_list;
+    WIRE *cur_WIRE = NULL;
+    LUMP *cur_LUMP = NULL;
+    // Make sure the wire is OK, and get the appropriate entity
+    // Get a WIRE if it's there
+    if ( wire_BODY->wire() == NULL ||
+        wire_BODY->wire()->coedge() == NULL ||
+        wire_BODY->wire()->coedge()->edge() == NULL )
-      // If there was no WIRE, see if there's a lump
-      if(wire_BODY->lump() != NULL &&
-	 wire_BODY->lump()->shell() != NULL &&
-	 wire_BODY->lump()->shell()->wire() != NULL &&
-	 wire_BODY->lump()->shell()->wire()->coedge() != NULL &&
-	 wire_BODY->lump()->shell()->wire()->coedge()->edge() != NULL )
+        // If there was no WIRE, see if there's a lump
+        if(wire_BODY->lump() != NULL &&
+            wire_BODY->lump()->shell() != NULL &&
+            wire_BODY->lump()->shell()->wire() != NULL &&
+            wire_BODY->lump()->shell()->wire()->coedge() != NULL &&
+            wire_BODY->lump()->shell()->wire()->coedge()->edge() != NULL )
-	  cur_LUMP = wire_BODY->lump();
+            cur_LUMP = wire_BODY->lump();
-      else
+        else
-	  PRINT_ERROR("Non-existent wire body in convert_WIRE function.\n");
+            PRINT_ERROR("Non-existent wire body in convert_WIRE function.\n");
-  else
+    else
-      cur_WIRE = wire_BODY->wire();
+        cur_WIRE = wire_BODY->wire();
-  LUMP *start_LUMP = cur_LUMP;
-  do{
-    if((wire_BODY->wire() == NULL ||
-	wire_BODY->wire()->coedge()->edge() == NULL ) &&
-       wire_BODY->lump() != NULL &&
-	cur_WIRE = cur_LUMP->shell()->wire();
+    LUMP *start_LUMP = cur_LUMP;
+    do{
+        if((wire_BODY->wire() == NULL ||
+            wire_BODY->wire()->coedge()->edge() == NULL ) &&
+            wire_BODY->lump() != NULL &&
+            cur_WIRE = cur_LUMP->shell()->wire();
-    WIRE *start_WIRE = cur_WIRE;
+        WIRE *start_WIRE = cur_WIRE;
-    if (cur_WIRE != NULL){
-      do {
-	COEDGE *start_COEDGE = cur_WIRE->coedge();
-	COEDGE *cur_COEDGE = start_COEDGE;
-	do{
-	  EDGE *cur_EDGE = cur_COEDGE->edge();
-	  //Just get one of the edges.  Often you have two coedges
-	  //for the same edge.
-	  if ( EDGE_list.move_to(cur_EDGE) )
-	      // additional check to avoid an infinite loop
-	      if(cur_COEDGE == cur_COEDGE->next())
-		break;
+        if (cur_WIRE != NULL){
+            do {
+                COEDGE *start_COEDGE = cur_WIRE->coedge();
+                COEDGE *cur_COEDGE = start_COEDGE;
+                do{
+                    EDGE *cur_EDGE = cur_COEDGE->edge();
+                    //Just get one of the edges.  Often you have two coedges
+                    //for the same edge.
+                    if ( EDGE_list.move_to(cur_EDGE) )
+                        // additional check to avoid an infinite loop
+                        if(cur_COEDGE == cur_COEDGE->next())
+                            break;
-	      cur_COEDGE = cur_COEDGE->next();
-	      continue;
-	  else
-	      EDGE_list.append(cur_EDGE);
-	  EDGE *new_EDGE_ptr = NULL;
-	  outcome result = api_edge(cur_EDGE, new_EDGE_ptr);
-	  if ( !result.ok() || new_EDGE_ptr == NULL )
-	      PRINT_ERROR("In AcisModifyEngine::body_intersection\n"
-			  "       Cannot copy curve in intersection graph.\n");
-	  // Create a new CurveACIS object
-	  // Use the new EDGE to create a new CurveACIS
-	  Curve *new_curve =
-	    AcisQueryEngine::instance()->populate_topology_bridges(new_EDGE_ptr);
-	  curve_list.append(new_curve);
-	} while (cur_COEDGE && (cur_COEDGE != start_COEDGE));
-	cur_WIRE = cur_WIRE->next();
-      } while (cur_WIRE && (cur_WIRE != start_WIRE));
+                        cur_COEDGE = cur_COEDGE->next();
+                        continue;
+                    else
+                        EDGE_list.append(cur_EDGE);
+                    EDGE *new_EDGE_ptr = NULL;
+                    outcome result = api_edge(cur_EDGE, new_EDGE_ptr);
+                    if ( !result.ok() || new_EDGE_ptr == NULL )
+                        PRINT_ERROR("In AcisModifyEngine::body_intersection\n"
+                            "       Cannot copy curve in intersection graph.\n");
+                    // Create a new CurveACIS object
+                    // Use the new EDGE to create a new CurveACIS
+                    Curve *new_curve =
+                        AcisQueryEngine::instance()->populate_topology_bridges(new_EDGE_ptr);
+                    curve_list.append(new_curve);
+                } while (cur_COEDGE && (cur_COEDGE != start_COEDGE));
+                cur_WIRE = cur_WIRE->next();
+            } while (cur_WIRE && (cur_WIRE != start_WIRE));
-    //we may not have a lump, ACIS sometimes will return a wire
-    //as the intersection and other times a LUMP...
-    if (cur_LUMP)
-	cur_LUMP = cur_LUMP->next();
-  }while (cur_LUMP && (start_LUMP != cur_LUMP));
-  //At this point we are done!
+        //we may not have a lump, ACIS sometimes will return a wire
+        //as the intersection and other times a LUMP...
+        if (cur_LUMP)
+            cur_LUMP = cur_LUMP->next();
+    }while (cur_LUMP && (start_LUMP != cur_LUMP));
+    //At this point we are done!
@@ -1920,62 +1915,62 @@
 CubitBoolean AcisModifyEngine::BODYs_interfering (
-						  BODY* body1_ptr,
-						  BODY* body2_ptr) const
+    BODY* body1_ptr,
+    BODY* body2_ptr) const
-  CpuTimer timer;
+   CpuTimer timer;
-  // Efficient algorithm to test interference between 2 ACIS BODYs. The
-  // entire intersection boolean operation is *not* performed if api_slice
-  // is used.
+     // Efficient algorithm to test interference between 2 ACIS BODYs. The
+     // entire intersection boolean operation is *not* performed if api_slice
+     // is used.
-  CubitBoolean interfering = CUBIT_TRUE;
+   CubitBoolean interfering = CUBIT_TRUE;
-  // Use the NOP pair to ensure that the roll-back is done by ACIS after
-  // the test, so that the input BODYs are unaffected by this operation.
-  API_NOP_BEGIN;
+     // Use the NOP pair to ensure that the roll-back is done by ACIS after
+     // the test, so that the input BODYs are unaffected by this operation.
+   API_NOP_BEGIN;
-  BODY* slice = NULL;
+   BODY* slice = NULL;
-  if ( body1_ptr == NULL || !IS_ENTITY_TYPE( body1_ptr, BODY ) ||
-       body2_ptr == NULL || !IS_ENTITY_TYPE( body2_ptr, BODY ) )
+   if ( body1_ptr == NULL || !IS_ENTITY_TYPE( body1_ptr, BODY ) ||
+        body2_ptr == NULL || !IS_ENTITY_TYPE( body2_ptr, BODY ) )
       PRINT_ERROR("BUG: In AcisModifyEngine::BODYs_interfering\n"
                   "     One or both input BODYs are NULL or invalid.\n");
       assert(0);
       return CUBIT_FALSE;
-  outcome status = api_slice(body1_ptr, body2_ptr,
-			     *(SPAunit_vector *)NULL_REF, slice);
+   outcome status = api_slice(body1_ptr, body2_ptr,
+                              *(SPAunit_vector *)NULL_REF, slice);
-  if (!status.ok() || slice == NULL )
-  else
+   if (!status.ok() || slice == NULL )
+   else
-  // Set the result variable to true so that the API_NOP_END
-  // can roll back the bulletin board to ensure that the
-  // ENTITYs that were modified within this NOP block will be
-  // returned to their original state.
-  result = outcome(0);
+     // Set the result variable to true so that the API_NOP_END
+     // can roll back the bulletin board to ensure that the
+     // ENTITYs that were modified within this NOP block will be
+     // returned to their original state.
+   result = outcome(0);
-  API_NOP_END;
+   API_NOP_END;
-  PRINT_DEBUG_3( "CPU time taken to check if two BODYs are "
-		 "interfering: %f secs\n", timer.cpu_secs());
+   PRINT_DEBUG_3( "CPU time taken to check if two BODYs are "
+               "interfering: %f secs\n", timer.cpu_secs());
-  // Return the interference status
-  return interfering;
+     // Return the interference status
+   return interfering;
 CubitStatus AcisModifyEngine::stitch_FACEs( DLIList<FACE*> &faces,
-					    FACE *&result_FACE,
-					    BODY *&stitched_BODY )const
+                                                    FACE *&result_FACE,
+                                                    BODY *&stitched_BODY ) const
   //Make copies of each FACE
   ENTITY_LIST copied_FACES;
@@ -1985,62 +1980,62 @@
   BODY *master = NULL;
   for( i=faces.size(); i--;)
-      FACE *tmp_FACE = faces.get_and_step();
-      ENTITY *new_FACE = NULL;
-      result = api_copy_entity( (ENTITY*)tmp_FACE, new_FACE );
+    FACE *tmp_FACE = faces.get_and_step();
+    ENTITY *new_FACE = NULL;
+    result = api_copy_entity( (ENTITY*)tmp_FACE, new_FACE );
-      FACE *face_list[1];
-      face_list[0] = (FACE*)new_FACE;
-      result = api_sheet_from_ff( 1, face_list, sheet_BODY_ptr );
-      result = api_body_to_2d( sheet_BODY_ptr );
+    FACE *face_list[1];
+    face_list[0] = (FACE*)new_FACE;
+    result = api_sheet_from_ff( 1, face_list, sheet_BODY_ptr );
+    result = api_body_to_2d( sheet_BODY_ptr );
-      if( !result.ok() )
-	  PRINT_ERROR("Problems copying surface(s)\n");
-	  //delete all other surface
-	  for(i=0; i<copied_FACES.count(); i++)
-	    api_delent( copied_FACES[i]);
+    if( !result.ok() )
+      PRINT_ERROR("Problems copying surface(s)\n");
+      //delete all other surface
+      for(i=0; i<copied_FACES.count(); i++)
+        api_delent( copied_FACES[i]);
+    else
+      if( master == NULL )
+        master = sheet_BODY_ptr;
       else
-	  if( master == NULL )
-	    master = sheet_BODY_ptr;
-	  else
-	    copied_FACES.add( sheet_BODY_ptr );
+        copied_FACES.add( sheet_BODY_ptr );
   //stitch together to form a sheet body.
   for( i=0; i<copied_FACES.count(); i++ )
+    result = api_unite((BODY*)copied_FACES[i], master );
-      result = api_unite((BODY*)copied_FACES[i], master );
-	  PRINT_ERROR("Problems stitching surfaces\n");
-	  for(; i<copied_FACES.count(); i++)
+      PRINT_ERROR("Problems stitching surfaces\n");
+      for(; i<copied_FACES.count(); i++)
 #else
   exact_stitch_options stitch_opts;
   result = api_stitch( master, copied_FACES, &stitch_opts );
 #endif
   if( !result.ok() )
-      api_delent( master );
-      stitched_BODY = NULL;
-      result_FACE = NULL;
+    api_delent( master );
+    stitched_BODY = NULL;
+    result_FACE = NULL;
   copied_FACES.clear();
   stitched_BODY = master;
@@ -2050,16 +2045,17 @@
   api_get_faces( master, copied_FACES );
   if( copied_FACES.count() != 1 )
   else
     result_FACE = (FACE*)copied_FACES[0];
 CubitStatus AcisModifyEngine::trim_up_to_next_surface( BODY *&tool_BODY,
                                                        DLIList<BodySM*> &blank_bodies,
                                                        VERTEX *surf_VERT )
@@ -2072,17 +2068,17 @@
   int i;
   for( i=blank_bodies.size()-1; i--; )
-      blank_BODY = AcisQueryEngine::get_BODY( blank_bodies.get_and_step() );
-      BODY *copy_blank_BODY = this->copy_BODY(blank_BODY, true );
-      result = api_unite( copy_blank_BODY, master_blank_BODY);
+    blank_BODY = AcisQueryEngine::get_BODY( blank_bodies.get_and_step() );
+    BODY *copy_blank_BODY = this->copy_BODY(blank_BODY, true );
+    result = api_unite( copy_blank_BODY, master_blank_BODY);
-	  PRINT_ERROR("Problems uniting blank volumes with 'up_to_next' option.\n");
+      PRINT_ERROR("Problems uniting blank volumes with 'up_to_next' option.\n");
   //get all the cells
   generic_graph *boolean_graph;
@@ -2093,10 +2089,10 @@
   gvertex **vertex_array = boolean_graph->get_vertices( num_verts );
   ENTITY_LIST common_vertices;
   for(i=num_verts; i--; )
-      if( vertex_array[i]->is_kind(0) && vertex_array[i]->is_kind(1) )
-	common_vertices.add( vertex_array[i]->get_entity() );
+    if( vertex_array[i]->is_kind(0) && vertex_array[i]->is_kind(1) )
+      common_vertices.add( vertex_array[i]->get_entity() );
   ENTITY *vertex_to_keep = NULL;
@@ -2104,35 +2100,35 @@
   if( common_vertices.count() == 1 )
     vertex_to_keep = common_vertices[0];
   else
+    SPAposition point_on_surf = surf_VERT->geometry()->coords();
+    SPAposition dummy_pos;
+    double min_distance = -1, tmp_distance = 0;
+    for( i=common_vertices.count(); i--; )
-      SPAposition point_on_surf = surf_VERT->geometry()->coords();
-      SPAposition dummy_pos;
-      double min_distance = -1, tmp_distance = 0;
-      for( i=common_vertices.count(); i--; )
-	  if( is_CELL( common_vertices[i] ) )
-	      CELL *tmp_cell = NULL;
-	      tmp_cell = static_cast<CELL*>( common_vertices[i] );
-	      BODY *tmp_body = NULL;
-	      api_ct_copy_cell( tmp_cell, tmp_body );
+      if( is_CELL( common_vertices[i] ) )
+        CELL *tmp_cell = NULL;
+        tmp_cell = static_cast<CELL*>( common_vertices[i] );
+        BODY *tmp_body = NULL;
+        api_ct_copy_cell( tmp_cell, tmp_body );
-	      api_entity_point_distance( tmp_body, point_on_surf, dummy_pos, tmp_distance );
-	      api_delent( tmp_body );
+        api_entity_point_distance( tmp_body, point_on_surf, dummy_pos, tmp_distance );
+        api_delent( tmp_body );
-	      if( min_distance < 0 )
-		  min_distance = tmp_distance;
-		  vertex_to_keep = common_vertices[i];
-	      else if( tmp_distance < min_distance )
+        if( min_distance < 0 )
+          min_distance = tmp_distance;
+          vertex_to_keep = common_vertices[i];
+        else if( tmp_distance < min_distance )
   ENTITY_LIST ent_list;
   if( vertex_to_keep )
@@ -2161,95 +2157,95 @@
 // Creation Date :
 CubitStatus AcisModifyEngine::sweep_FACE_along_vector(
-						      FACE *& FACE_ptr,
-						      const CubitVector& sweep_vector,
-						      bool& volume_is_negative,
-						      bool primary_side,
-						      double draft_angle,
-						      int draft_type,
-						      bool rigid,
-						      FACE *to_FACE,
-                                                      BODY *to_BODY) const
+    FACE *& FACE_ptr,
+    const CubitVector& sweep_vector,
+    bool& volume_is_negative,
+    bool primary_side,
+    double draft_angle,
+    int draft_type,
+    bool rigid,
+    FACE *to_FACE,
+    BODY *to_BODY) const
-  // Make sure the distance of the sweep is not zero
-  if ( sweep_vector.length() < (1.0E5 * CUBIT_DBL_MIN) )
+     // Make sure the distance of the sweep is not zero
+   if ( sweep_vector.length() < (1.0E5 * CUBIT_DBL_MIN) )
       PRINT_WARNING("Distance of sweep is almost zero. No sweep was performed.\n");
-  // Make sure the draft angle is reasonable
-  if (draft_angle >= CUBIT_PI/2.0 || draft_angle <= -(CUBIT_PI/2.0))
+     // Make sure the draft angle is reasonable
+   if (draft_angle >= CUBIT_PI/2.0 || draft_angle <= -(CUBIT_PI/2.0))
       PRINT_ERROR("Draft angle cannot be greater than %e radians\n",
                   CUBIT_PI/2.0);
-  // Make sure the draft type is either 0 or 1 (this is an ACISism, of course!)
-  if ( !(draft_type == 0 || draft_type == 1) )
+     // Make sure the draft type is either 0 or 1 (this is an ACISism, of course!)
+   if ( !(draft_type == 0 || draft_type == 1) )
       PRINT_ERROR("Draft type must be either 0 or 1\n");
-  // Sweep ho!!
-  CubitStatus sweep_status = CUBIT_SUCCESS;
-  SPAvector ACIS_sweep_vector;
-  ACIS_sweep_vector.set_x(sweep_vector.x());
-  ACIS_sweep_vector.set_y(sweep_vector.y());
-  ACIS_sweep_vector.set_z(sweep_vector.z());
+     // Sweep ho!!
+   CubitStatus sweep_status = CUBIT_SUCCESS;
+   SPAvector ACIS_sweep_vector;
+   ACIS_sweep_vector.set_x(sweep_vector.x());
+   ACIS_sweep_vector.set_y(sweep_vector.y());
+   ACIS_sweep_vector.set_z(sweep_vector.z());
-  logical ACIS_primary_side = CUBIT_TRUE;
-  if (!primary_side)
-    ACIS_primary_side = CUBIT_FALSE;
+   logical ACIS_primary_side = CUBIT_TRUE;
+   if (!primary_side)
+      ACIS_primary_side = CUBIT_FALSE;
-  // Turn off the merge option in ACIS so FACEs used to sweep won't be
-  // "simplified" in their topology (i.e., 5-sided squared faces won't
-  // be reduced to 4-sided square faces) -- in other words, turn on
-  // non-regularized booleans.
-  outcome result = api_set_int_option ( "merge",
-					CUBIT_FALSE );
-  if (!result.ok())
+     // Turn off the merge option in ACIS so FACEs used to sweep won't be
+     // "simplified" in their topology (i.e., 5-sided squared faces won't
+     // be reduced to 4-sided square faces) -- in other words, turn on
+     // non-regularized booleans.
+   outcome result = api_set_int_option ( "merge",
+                                 CUBIT_FALSE );
+   if (!result.ok())
       PRINT_WARNING("In AcisModifyEngine::sweep_FACE_along_vector.\n"
                     "         Error in api_set_int_option.\n");
       AcisQueryEngine::instance()->ACIS_API_error(result);
-      // As the problem is not really serious, continue and make sure that
-      // the value of result is set to "OK" so no rollback occurs
+        // As the problem is not really serious, continue and make sure that
+        // the value of result is set to "OK" so no rollback occurs
-  sweep_options ACIS_sweep_options;
-  ACIS_sweep_options.set_draft_angle(draft_angle);
-  ACIS_sweep_options.set_gap_type(draft_type);
-  ACIS_sweep_options.set_which_side(ACIS_primary_side);
-  ACIS_sweep_options.set_rigid(rigid);
-  FACE *FACE_to_sweep_to = NULL;
-  if( to_FACE )
-      //get face type
-      SURFACE *SURFACE_ptr = to_FACE->geometry();
-      int type = SURFACE_ptr->identity();
+   sweep_options ACIS_sweep_options;
+   ACIS_sweep_options.set_draft_angle(draft_angle);
+   ACIS_sweep_options.set_gap_type(draft_type);
+   ACIS_sweep_options.set_which_side(ACIS_primary_side);
+   ACIS_sweep_options.set_rigid(rigid);
-      //if face is planar...vector must not be parallel to surf normal
-      if (type == PLANE_TYPE)
-	  FACE_to_sweep_to = make_FACE( to_FACE, true );
-      //vector must intersect surf
-      else
-	  FACE_to_sweep_to = make_FACE( to_FACE );
+   FACE *FACE_to_sweep_to = NULL;
+   if( to_FACE )
+     //get face type
+     SURFACE *SURFACE_ptr = to_FACE->geometry();
+     int type = SURFACE_ptr->identity();
-      SPAtransf trans = get_face_trans(FACE_to_sweep_to);
-      surface *eq_surf = FACE_to_sweep_to->geometry()->trans_surface(trans );
-      ACIS_sweep_options.set_to_face( eq_surf );
+     //if face is planar...vector must not be parallel to surf normal
+     if (type == PLANE_TYPE)
+        FACE_to_sweep_to = make_FACE( to_FACE, true );
+     //vector must intersect surf
+     else
+        FACE_to_sweep_to = make_FACE( to_FACE );
+     SPAtransf trans = get_face_trans(FACE_to_sweep_to);
+     surface *eq_surf = FACE_to_sweep_to->geometry()->trans_surface(trans );
+     ACIS_sweep_options.set_to_face( eq_surf );
   else if(to_BODY)
       ACIS_sweep_options.set_sweep_to_body(to_BODY);
@@ -2258,187 +2254,186 @@
       //body.
       ACIS_sweep_options.set_bool_type(INTERSECT);
-  BODY* BODYptr = NULL;
-  result = api_sweep_with_options (FACE_ptr, ACIS_sweep_vector,
-				   &ACIS_sweep_options, BODYptr);
+   BODY* BODYptr = NULL;
+   result = api_sweep_with_options (FACE_ptr, ACIS_sweep_vector,
+                                    &ACIS_sweep_options, BODYptr);
-  if (BODYptr)
-      //when setting the sweep to end at a face, result is BODYptr.
-      if( to_FACE || to_BODY)
-	  //swept body & to_FACE must intersect some
-          if(to_FACE)
-	    tmp_body = AcisQueryEngine::instance()->get_BODY_of_ENTITY( FACE_to_sweep_to );
-	  else
-	    tmp_body = to_BODY;
-	  if ( !BODYs_interfering( tmp_body, BODYptr ) )
-	      PRINT_ERROR("Terminating surface must intersect swept tool volume.\n");
-	      if (to_FACE)
-	  FACE_ptr = BODYptr->lump()->shell()->first_face();
-      else
-	  PRINT_ERROR("Error during ACIS sweep operation, api_sweep_with_options\n");
-	  PRINT_ERROR("API wants to create a new volume.\n");
-	  api_delent( BODYptr );
-	  sweep_status = CUBIT_FAILURE;
+   if (BODYptr)
+     //when setting the sweep to end at a face, result is BODYptr.
+     if( to_FACE || to_BODY )
+       //swept body & to_FACE must intersect some
+       if(to_FACE)
+         tmp_body = AcisQueryEngine::instance()->get_BODY_of_ENTITY( FACE_to_sweep_to );
+       else
+         tmp_body = to_BODY;
+       if ( !BODYs_interfering( tmp_body, BODYptr ) )
+        PRINT_ERROR("Terminating surface must intersect swept tool volume.\n");
+	if (to_FACE)
+       FACE_ptr = BODYptr->lump()->shell()->first_face();
+     else
+        PRINT_ERROR("Error during ACIS sweep operation, api_sweep_with_options\n");
+        PRINT_ERROR("API wants to create a new volume.\n");
+	api_delent( BODYptr );
+        sweep_status = CUBIT_FAILURE;
-  if (!result.ok())
-      if(rigid)
+   if (!result.ok())
+     if(rigid)
         PRINT_WARNING("Because surface is not planar, the 'rigid' keyword will be ignored.\n");
-      PRINT_DEBUG_99("api_sweep_with_options failed, reverting to api_sw_face_vec.\n");
+     PRINT_DEBUG_99("api_sweep_with_options failed, reverting to api_sw_face_vec.\n");
-      result = api_sw_face_vec (FACE_ptr, ACIS_primary_side, ACIS_sweep_vector,
-				draft_angle, draft_type);
+     result = api_sw_face_vec (FACE_ptr, ACIS_primary_side, ACIS_sweep_vector,
+                               draft_angle, draft_type);
-      if (!result.ok())
+     if (!result.ok())
-	  PRINT_INFO("in sweep_FACE_along_vector\n");
-	  AcisQueryEngine::instance()->ACIS_API_error(result);
+       PRINT_INFO("in sweep_FACE_along_vector\n");
+       AcisQueryEngine::instance()->ACIS_API_error(result);
-  if( FACE_to_sweep_to )
-    api_delent( FACE_to_sweep_to );
+   if( FACE_to_sweep_to )
+     api_delent( FACE_to_sweep_to );
-  if (!result.ok())
+   if (!result.ok())
-  // Now set the option back to its default
-  result = api_set_int_option ( "merge",
-				CUBIT_TRUE );
-  if (!result.ok())
+     // Now set the option back to its default
+   result = api_set_int_option ( "merge",
+                                 CUBIT_TRUE );
+   if (!result.ok())
-  // Finally, check to make sure that the volume of the swept BODY is positive.
-  // Note that ACIS allows the creation of swept solids that have
-  // negative volume (all the surface normals point inward -- i.e.,
-  // the swept solid is topologically identical to a void)
-  if ( AcisQueryEngine::instance()->volume(AcisQueryEngine::instance()->get_BODY_of_ENTITY(FACE_ptr)) < 0.0)
+     // Finally, check to make sure that the volume of the swept BODY is positive.
+     // Note that ACIS allows the creation of swept solids that have
+     // negative volume (all the surface normals point inward -- i.e.,
+     // the swept solid is topologically identical to a void)
+   if ( AcisQueryEngine::instance()->volume(AcisQueryEngine::instance()->get_BODY_of_ENTITY(FACE_ptr)) < 0.0)
       volume_is_negative = true;
-      // Set the value of result such that the API_END macro performs
-      // a bulletin board rollback operation to the corresponding API_BEGIN
-      //result = outcome(API_FAILED);
+        // Set the value of result such that the API_END macro performs
+        // a bulletin board rollback operation to the corresponding API_BEGIN
+        //result = outcome(API_FAILED);
-  return sweep_status;
+   return sweep_status;
 CubitStatus AcisModifyEngine::sweep_FACE_perpendicular(
-						       FACE *& FACE_ptr,
-						       double distance,
-						       int draft_type,
-						       bool rigid,
-						       FACE *to_FACE,
+    FACE *& FACE_ptr,
+    double distance,
+    int draft_type,
+    bool rigid,
+    FACE *to_FACE,
-  if ( distance < (1.0E5 * CUBIT_DBL_MIN) )
+   if ( distance < (1.0E5 * CUBIT_DBL_MIN) )
                   CUBIT_PI/2.0);
-  // Sweep ho!!
+     // Sweep ho!!
-  logical ACIS_primary_side = CUBIT_FALSE;
-    ACIS_primary_side = CUBIT_TRUE;
+   logical ACIS_primary_side = CUBIT_FALSE;
+      ACIS_primary_side = CUBIT_TRUE;
-					CUBIT_FALSE );
-  if (!result.ok())
+                                 CUBIT_FALSE );
+   if (!result.ok())
       PRINT_WARNING("In AcisModifyEngine::sweep_FACE_perpendicular.\n"
-  if( to_FACE )//mutually exclusive with sweep_to_body
-      //get face type
+   if( to_FACE )//mutually exclusive with sweep_to_body
+     //get face type
-      else
+     else
   else if(to_BODY)//mutually exclusive with to_face
@@ -2449,168 +2444,168 @@
-  result = api_sweep_with_options (FACE_ptr, distance,
+   result = api_sweep_with_options (FACE_ptr, distance,
-  if (BODYptr)
-	  if(to_FACE)
-	  else
-	      if(to_FACE)
-      else
-	  PRINT_ERROR("API wants to create a new volume \n");
+   if (BODYptr)
+     if( to_FACE || to_BODY)
+       if(to_FACE)
+       else
+        if(to_FACE)
+     else
+        PRINT_ERROR("API wants to create a new volume \n");
-  if (!result.ok())
+   if (!result.ok())
       PRINT_ERROR("Error during ACIS sweep operation,  api_sweep_with_options \n");
       PRINT_INFO("in sweep_FACE_perpendicular\n");
       PRINT_INFO("If face is not planar, perpendicular doesn't make sense.\n"
                  "Try sweeping along a vector instead.\n");
-				CUBIT_TRUE );
-  if (!result.ok())
+                                 CUBIT_TRUE );
+   if (!result.ok())
       volume_is_negative = CUBIT_TRUE;
 CubitStatus AcisModifyEngine::sweep_EDGE_along_vector(
-						      EDGE* EDGE_ptr,
-						      BODY *&BODYptr,
-						      int draft_type,
-						      bool rigid,
-						      FACE *to_FACE,
+    EDGE* EDGE_ptr,
+    BODY *&BODYptr,
+    int draft_type,
+    bool rigid,
+    FACE *to_FACE,
+    BODY* to_BODY) const
                   CUBIT_PI/2.0);
-  // Sweep ho!!
+     // Sweep ho!!
-  // Turn off the merge option in ACIS so EDGEs used to sweep won't be
-					CUBIT_FALSE );
-  if (!result.ok())
+     // Turn off the merge option in ACIS so EDGEs used to sweep won't be
+                                 CUBIT_FALSE );
+   if (!result.ok())
       PRINT_WARNING("In AcisModifyEngine::sweep_EDGE_along_vector.\n"
-  EDGE *copied_EDGE_ptr = NULL;
-  result = api_edge( EDGE_ptr, copied_EDGE_ptr);
+   EDGE *copied_EDGE_ptr = NULL;
+   result = api_edge( EDGE_ptr, copied_EDGE_ptr);
-      //get face type
+     //get face type
-      else
+     else
@@ -2621,52 +2616,52 @@
-      PRINT_ERROR( "Unable to copy edge\n");
-  ATTRIB_CUBIT_OWNER::remove_cubit_owner( (ENTITY *)copied_EDGE_ptr,
-					  CUBIT_TRUE );
-  result = api_sweep_with_options (copied_EDGE_ptr, ACIS_sweep_vector,
+     PRINT_ERROR( "Unable to copy edge\n");
+   ATTRIB_CUBIT_OWNER::remove_cubit_owner( (ENTITY *)copied_EDGE_ptr,
+                                           CUBIT_TRUE );
+   result = api_sweep_with_options (copied_EDGE_ptr, ACIS_sweep_vector,
-  if (BODYptr)
-      sweep_status = CUBIT_SUCCESS;
-  if (!result.ok())
+   if (BODYptr)
+       sweep_status = CUBIT_SUCCESS;
+   if (!result.ok())
       if ( copied_EDGE_ptr != NULL )
         api_delent(copied_EDGE_ptr);
-				CUBIT_TRUE );
-  if (!result.ok())
+                                 CUBIT_TRUE );
+   if (!result.ok())
@@ -2681,69 +2676,69 @@
 // Creation Date : 8/7/98
 CubitStatus AcisModifyEngine::sweep_FACE_along_WIRE(
-						    FACE *& FACE_ptr,
-						    BODY* wire_BODY_ptr,
-						    int draft_type,
-						    bool rigid,
-						    FACE *to_FACE,
-						    BODY *to_BODY ) const
+    FACE *& FACE_ptr,
+    BODY* wire_BODY_ptr,
+    int draft_type,
+    bool rigid,
+    FACE *to_FACE,
+    BODY *to_BODY ) const
                   CUBIT_PI/2.0);
-  outcome result = api_set_int_option ( "merge", CUBIT_FALSE );
+   outcome result = api_set_int_option ( "merge", CUBIT_FALSE );
-  if (!result.ok())
-      PRINT_WARNING("In AcisModifyEngine::sweep_FACE_along_WIRE.\n"
-		    "         Error in api_set_int_option.\n");
+   if (!result.ok())
+     PRINT_WARNING("In AcisModifyEngine::sweep_FACE_along_WIRE.\n"
+                   "         Error in api_set_int_option.\n");
-  if( to_FACE )//mutually exclusive with sweep_to_body.
-      //get face type
+   if( to_FACE )//mutually exclusive with sweep_to_body.
+     //get face type
-      else
+     else
@@ -2754,179 +2749,179 @@
-  // Do the real work!!
-  result = api_sweep_with_options (FACE_ptr, (EDGE*)wire_BODY_ptr, &ACIS_sweep_options, BODYptr);
+   // Do the real work!!
+   result = api_sweep_with_options (FACE_ptr, (EDGE*)wire_BODY_ptr, &ACIS_sweep_options, BODYptr);
-  if (BODYptr)
-	  if(to_FACE)
-	  else
+   if (BODYptr)
+       if(to_FACE)
+       else
-	      if(to_FACE)
-      else
+        if(to_FACE)
+     else
-  if (!result.ok())
+   if (!result.ok())
-  result = api_set_int_option ( "merge", CUBIT_TRUE );
-  if (!result.ok())
+   result = api_set_int_option ( "merge", CUBIT_TRUE );
+   if (!result.ok())
 CubitStatus AcisModifyEngine::sweep_EDGE_along_WIRE(
-						    EDGE* EDGE_ptr,
-						    BODY *&BODYptr,
-						    int draft_type,
-						    bool rigid,
-						    FACE *to_FACE,
+    EDGE* EDGE_ptr,
+    BODY *&BODYptr,
+    int draft_type,
+    bool rigid,
+    FACE *to_FACE,
                   CUBIT_PI/2.0);
-  if (!result.ok())
+   if (!result.ok())
       PRINT_WARNING("In AcisModifyEngine::sweep_EDGE_along_WIRE.\n"
-  result = api_edge( EDGE_ptr, copied_EDGE_ptr );
+   result = api_edge( EDGE_ptr, copied_EDGE_ptr );
-  //if edge-to-sweep has start or end vertex coincident w/
-  //end vertex on path wire, flip all edges in path wire
-  SPAposition end_coords;
-  get_wire_end_position(wire_BODY_ptr, end_coords);
+   //if edge-to-sweep has start or end vertex coincident w/
+   //end vertex on path wire, flip all edges in path wire
+   SPAposition end_coords;
+   get_wire_end_position(wire_BODY_ptr, end_coords);
-  SPAposition tmp_coords = EDGE_ptr->start()->geometry()->coords();
-  CubitVector start_coord( tmp_coords.x(), tmp_coords.y(), tmp_coords.z() );
+   SPAposition tmp_coords = EDGE_ptr->start()->geometry()->coords();
+   CubitVector start_coord( tmp_coords.x(), tmp_coords.y(), tmp_coords.z() );
-  tmp_coords = EDGE_ptr->end()->geometry()->coords();
-  CubitVector end_coord( tmp_coords.x(), tmp_coords.y(), tmp_coords.z() );
+   tmp_coords = EDGE_ptr->end()->geometry()->coords();
+   CubitVector end_coord( tmp_coords.x(), tmp_coords.y(), tmp_coords.z() );
-  CubitVector wire_end_coord( end_coords.x(), end_coords.y(), end_coords.z() );
+   CubitVector wire_end_coord( end_coords.x(), end_coords.y(), end_coords.z() );
-  if ( (GeometryQueryTool::instance()->about_spatially_equal(start_coord, wire_end_coord,
-							     GeometryQueryTool::get_geometry_factor())) ||
-       (GeometryQueryTool::instance()->about_spatially_equal(end_coord, wire_end_coord,
-							     GeometryQueryTool::get_geometry_factor())) )
-      //reverse all edges in wire body
-      ENTITY_LIST EDGE_list;
-      api_get_edges( wire_BODY_ptr, EDGE_list );
+   if ( (GeometryQueryTool::instance()->about_spatially_equal(start_coord, wire_end_coord,
+                                       GeometryQueryTool::get_geometry_factor())) ||
+        (GeometryQueryTool::instance()->about_spatially_equal(end_coord, wire_end_coord,
+                                       GeometryQueryTool::get_geometry_factor())) )
+     //reverse all edges in wire body
+     ENTITY_LIST EDGE_list;
+     api_get_edges( wire_BODY_ptr, EDGE_list );
-      EDGE_list.init();
-      ENTITY *tmp_ent = NULL;
-      while( (tmp_ent = EDGE_list.next()) != NULL )
-	  EDGE *tmp_edge = (EDGE*)tmp_ent;
-	  VERTEX *old_start = tmp_edge->start();
-	  VERTEX *old_end = tmp_edge->end();
-	  tmp_edge->set_sense( tmp_edge->sense() == FORWARD ? REVERSED : FORWARD );
-	  tmp_edge->set_start( old_end );
-	  tmp_edge->set_end( old_start );
+     EDGE_list.init();
+     ENTITY *tmp_ent = NULL;
+     while( (tmp_ent = EDGE_list.next()) != NULL )
+       EDGE *tmp_edge = (EDGE*)tmp_ent;
+       VERTEX *old_start = tmp_edge->start();
+       VERTEX *old_end = tmp_edge->end();
+       tmp_edge->set_sense( tmp_edge->sense() == FORWARD ? REVERSED : FORWARD );
+       tmp_edge->set_start( old_end );
+       tmp_edge->set_end( old_start );
-					  CUBIT_TRUE );
+                                           CUBIT_TRUE );
-      //get face type
+     //get face type
-      else
+     else
-  else if(to_BODY)//mutually exclusive with to_face
+   else if(to_BODY)//mutually exclusive with to_face
       //Creates one body out of the fixed body and the result of the sweep up
@@ -2935,41 +2930,41 @@
-  result = api_sweep_with_options (copied_EDGE_ptr, wire_BODY_ptr, &ACIS_sweep_options, BODYptr);
+   result = api_sweep_with_options (copied_EDGE_ptr, wire_BODY_ptr, &ACIS_sweep_options, BODYptr);
-  if (BODYptr)
+   if (BODYptr)
-  if (!result.ok())
+   if (!result.ok())
-  if (!result.ok())
+   if (!result.ok())
@@ -3013,60 +3008,60 @@
   if (!primary_side) ACIS_primary_side = CUBIT_FALSE;
-  if (angle == 0.0)
+   if (angle == 0.0)
       PRINT_ERROR("The angle of the sweep must be > 0.0. Nothing done.\n");
                   CUBIT_PI/2.0);
-  // Make sure we have a reasonable number of steps
-  if (steps < 0)
+     // Make sure we have a reasonable number of steps
+   if (steps < 0)
       PRINT_WARNING("Number of steps must be a positive number.\n"
                     "         It is set to 0 and the sweep operation will proceed.\n");
       steps = 0;
-					CUBIT_FALSE );
-  if (!result.ok())
+                                         CUBIT_FALSE );
+   if (!result.ok())
       PRINT_WARNING("In AcisModifyEngine::sweep_FACE_about_axis.\n"
-  ACIS_sweep_options.set_steps(steps);
-  ACIS_sweep_options.set_sweep_angle(angle);
+   ACIS_sweep_options.set_steps(steps);
+   ACIS_sweep_options.set_sweep_angle(angle);
@@ -3149,11 +3144,11 @@
-				CUBIT_TRUE );
-  if (!result.ok())
+                                 CUBIT_TRUE );
+   if (!result.ok())
@@ -3161,12 +3156,12 @@
   if(BODYptr)
       new_BODY_ptr = BODYptr;
@@ -3189,7 +3184,7 @@
 CubitStatus AcisModifyEngine::sweep_EDGE_about_axis(
@@ -3206,101 +3201,101 @@
 						    FACE *to_FACE,
-  // Sweep ho!!
+     // Sweep ho!!
-  // Convert the Cubit point and SPAvector into an ACIS point and SPAvector
-  // before calling the member function that calls the ACIS API
-  // function.
-  SPAunit_vector ACIS_axis_unit_vector(
-				       axis_unit_vector.x(),
-				       axis_unit_vector.y(),
-				       axis_unit_vector.z() );
-  SPAposition ACIS_point( point.x(), point.y(),  point.z() );
-  if (angle == 0.0)
+     // Convert the Cubit point and SPAvector into an ACIS point and SPAvector
+     // before calling the member function that calls the ACIS API
+     // function.
+   SPAunit_vector ACIS_axis_unit_vector(
+       axis_unit_vector.x(),
+       axis_unit_vector.y(),
+       axis_unit_vector.z() );
+   SPAposition ACIS_point( point.x(), point.y(),  point.z() );
+   if (angle == 0.0)
                   CUBIT_PI/2.0);
-  if (steps < 0)
+   if (steps < 0)
       steps = 0;
-					CUBIT_FALSE );
-  if (!result.ok())
+                                         CUBIT_FALSE );
+   if (!result.ok())
       PRINT_WARNING("In AcisModifyEngine::sweep_EDGE_about_axis.\n"
-					  CUBIT_TRUE );
+                                           CUBIT_TRUE );
-      //get face type
+   if( to_FACE )
+     //get face type
-      else
+     else
   else if(to_BODY)//utually exclusive with to_face
@@ -3310,66 +3305,66 @@
-  if(make_solid)
-      ACIS_sweep_options.set_close_to_axis(TRUE);
-      EDGE* EDGES[1];
-      EDGES[0] = copied_EDGE_ptr;
-      BODY* EDGE_BODY_ptr = NULL;
+   if(make_solid)
+     ACIS_sweep_options.set_close_to_axis(TRUE);
+     EDGE* EDGES[1];
+     EDGES[0] = copied_EDGE_ptr;
+     BODY* EDGE_BODY_ptr = NULL;
-      result = api_make_ewire(1, EDGES, EDGE_BODY_ptr);
+     result = api_make_ewire(1, EDGES, EDGE_BODY_ptr);
-      //     WIRE* WIRE_ptr = EDGE_BODY_ptr->lump()->shell()->wire();
-      result = api_sweep_with_options(EDGE_BODY_ptr,
-				      ACIS_point, ACIS_axis_unit_vector,
-      BODYptr = EDGE_BODY_ptr;
+//     WIRE* WIRE_ptr = EDGE_BODY_ptr->lump()->shell()->wire();
+     result = api_sweep_with_options(EDGE_BODY_ptr,
+                                     ACIS_point, ACIS_axis_unit_vector,
+     BODYptr = EDGE_BODY_ptr;
-  else {
-    result = api_sweep_with_options(copied_EDGE_ptr,
+   else {
+     result = api_sweep_with_options(copied_EDGE_ptr,
-  if (BODYptr)
-  if (!result.ok())
+   if (BODYptr)
+   if (!result.ok())
-				CUBIT_TRUE );
-  if (!result.ok())
+                                 CUBIT_TRUE );
+   if (!result.ok())
@@ -3386,168 +3381,168 @@
                                                 const CubitVector& V3,
                                                 const CubitVector& V4 ) const
-  GeometryQueryTool* GT_ptr = GeometryQueryTool::instance();
-  BODY* Body1 = NULL;
+   GeometryQueryTool* GT_ptr = GeometryQueryTool::instance();
+   BODY* Body1 = NULL;
-  // Debug info
-  PRINT_DEBUG_18(
-		 "Debug output from AcisModifyEngine::make_planar_quad_BODY\n");
+     // Debug info
+   PRINT_DEBUG_18(
+               "Debug output from AcisModifyEngine::make_planar_quad_BODY\n");
-  // First make sure that none of the points have the same coordinates.
-  if ( (GT_ptr->about_spatially_equal(V1, V2,
-       (GT_ptr->about_spatially_equal(V1, V3,
-       (GT_ptr->about_spatially_equal(V1, V4,
-       (GT_ptr->about_spatially_equal(V2, V3,
-       (GT_ptr->about_spatially_equal(V2, V4,
-       (GT_ptr->about_spatially_equal(V3, V4,
+     // First make sure that none of the points have the same coordinates.
+   if ( (GT_ptr->about_spatially_equal(V1, V2,
+        (GT_ptr->about_spatially_equal(V1, V3,
+        (GT_ptr->about_spatially_equal(V1, V4,
+        (GT_ptr->about_spatially_equal(V2, V3,
+        (GT_ptr->about_spatially_equal(V2, V4,
+        (GT_ptr->about_spatially_equal(V3, V4,
       PRINT_ERROR("In AcisModifyEngine::make_planar_quad_BODY.\n"
                   "       Some of the input points are spatially equivalent.\n"
                   "       Cannot create a planar quadrilateral ACIS BODY.\n");
       return NULL;
-  // Make sure that the 4 input points are coplanar.
-  // If the 4 points are coplanar, then the scalar triple product
-  // of the 3 vectors joining points 1 and 2, 2 and 3, and 3 and 4, will
-  // equal zero.
-  //     For 4 coplanar points, Vector12 . (Vector23 * Vector34) = 0
+     // Make sure that the 4 input points are coplanar.
+     // If the 4 points are coplanar, then the scalar triple product
+     // of the 3 vectors joining points 1 and 2, 2 and 3, and 3 and 4, will
+     // equal zero.
+     //     For 4 coplanar points, Vector12 . (Vector23 * Vector34) = 0
-  CubitVector vector12 = V2 - V1;
-  CubitVector vector23 = V3 - V2;
-  CubitVector vector34 = V4 - V3;
+   CubitVector vector12 = V2 - V1;
+   CubitVector vector23 = V3 - V2;
+   CubitVector vector34 = V4 - V3;
-  // normalize the vectors
-  vector12.normalize();
-  vector23.normalize();
-  vector34.normalize();
+     // normalize the vectors
+   vector12.normalize();
+   vector23.normalize();
+   vector34.normalize();
-  double tripleProd = vector12 % (vector23 * vector34);
+   double tripleProd = vector12 % (vector23 * vector34);
-  // MJP Note:
-  // The following tests to make sure that tripleProd is "0.0". But this
-  // cannot be tested exactly, so we have to approximate the notion of zero.
-  // I have run into a case where a not-so-large (size about 2000 units)
-  // set of 4 points results in a tripleProd value of approximately
-  // -3.5E-6 whose fabs is 3.5E-6 which is larger than SPAresabs (1E-6).
-  // I have put in an arbitrary factor of 100 here!!!!!!! This raises
-  // our notion of "zero" from 1E-6 to 1E-4......:-)
-  if (fabs(tripleProd) > 100.0 * GEOMETRY_RESABS)
+     // MJP Note:
+     // The following tests to make sure that tripleProd is "0.0". But this
+     // cannot be tested exactly, so we have to approximate the notion of zero.
+     // I have run into a case where a not-so-large (size about 2000 units)
+     // set of 4 points results in a tripleProd value of approximately
+     // -3.5E-6 whose fabs is 3.5E-6 which is larger than SPAresabs (1E-6).
+     // I have put in an arbitrary factor of 100 here!!!!!!! This raises
+     // our notion of "zero" from 1E-6 to 1E-4......:-)
+   if (fabs(tripleProd) > 100.0 * GEOMETRY_RESABS)
                   "       The 4 input points are not coplanar.\n"
       return NULL;
-  // Initialize the bulletin board (this is done so that if there is an
-  // error while building this body, ACIS will automatically roll its
-  // state back to what it was before this next statement was executed.
-  int success = CUBIT_TRUE;
-  API_BEGIN;
+     // Initialize the bulletin board (this is done so that if there is an
+     // error while building this body, ACIS will automatically roll its
+     // state back to what it was before this next statement was executed.
+   int success = CUBIT_TRUE;
+   API_BEGIN;
-  // Create an ACIS Body using the direct interface (it's tons of fun :-)
+         // Create an ACIS Body using the direct interface (it's tons of fun :-)
-  // Create ACIS points
-  APOINT* P1 = new APOINT (V1.x(), V1.y(), V1.z());
-  APOINT* P2 = new APOINT (V2.x(), V2.y(), V2.z());
-  APOINT* P3 = new APOINT (V3.x(), V3.y(), V3.z());
-  APOINT* P4 = new APOINT (V4.x(), V4.y(), V4.z());
+         // Create ACIS points
+   APOINT* P1 = new APOINT (V1.x(), V1.y(), V1.z());
+   APOINT* P2 = new APOINT (V2.x(), V2.y(), V2.z());
+   APOINT* P3 = new APOINT (V3.x(), V3.y(), V3.z());
+   APOINT* P4 = new APOINT (V4.x(), V4.y(), V4.z());
-  // Create ACIS straight lines between the 4 input points
-  STRAIGHT* S1 = new STRAIGHT(      P1->coords(),
-				    normalise(P2->coords() - P1->coords()) );
-  STRAIGHT* S2 = new STRAIGHT(      P2->coords(),
-				    normalise(P3->coords() - P2->coords()) );
-  STRAIGHT* S3 = new STRAIGHT(      P3->coords(),
-				    normalise(P4->coords() - P3->coords()) );
-  STRAIGHT* S4 = new STRAIGHT(      P4->coords(),
-				    normalise(P1->coords() - P4->coords()) );
+     // Create ACIS straight lines between the 4 input points
+   STRAIGHT* S1 = new STRAIGHT(      P1->coords(),
+                                     normalise(P2->coords() - P1->coords()) );
+   STRAIGHT* S2 = new STRAIGHT(      P2->coords(),
+                                     normalise(P3->coords() - P2->coords()) );
+   STRAIGHT* S3 = new STRAIGHT(      P3->coords(),
+                                     normalise(P4->coords() - P3->coords()) );
+   STRAIGHT* S4 = new STRAIGHT(      P4->coords(),
+                                     normalise(P1->coords() - P4->coords()) );
-  // Compute the unit SPAvector of the plane containing the 4 points
-  CubitVector planeNormal;
-  planeNormal = (vector12 * vector23);
-  planeNormal.normalize();
+     // Compute the unit SPAvector of the plane containing the 4 points
+   CubitVector planeNormal;
+   planeNormal = (vector12 * vector23);
+   planeNormal.normalize();
-  // Create an ACIS surface
-  PLANE* Plane1 = new PLANE( P1->coords(),
-			     SPAunit_vector(planeNormal.x(),
-					    planeNormal.y(),
-					    planeNormal.z() ) );
+     // Create an ACIS surface
+   PLANE* Plane1 = new PLANE( P1->coords(),
+                              SPAunit_vector(planeNormal.x(),
+                                          planeNormal.y(),
+                                          planeNormal.z() ) );
-  // Create ACIS vertices
-  VERTEX* Vertex1 = new VERTEX (P1);
-  VERTEX* Vertex2 = new VERTEX (P2);
-  VERTEX* Vertex3 = new VERTEX (P3);
-  VERTEX* Vertex4 = new VERTEX (P4);
+     // Create ACIS vertices
+   VERTEX* Vertex1 = new VERTEX (P1);
+   VERTEX* Vertex2 = new VERTEX (P2);
+   VERTEX* Vertex3 = new VERTEX (P3);
+   VERTEX* Vertex4 = new VERTEX (P4);
-  // Create ACIS edges
-  EDGE* Edge1 = new EDGE (Vertex1, Vertex2, S1, FORWARD);
-  EDGE* Edge2 = new EDGE (Vertex2, Vertex3, S2, FORWARD);
-  EDGE* Edge3 = new EDGE (Vertex3, Vertex4, S3, FORWARD);
-  EDGE* Edge4 = new EDGE (Vertex4, Vertex1, S4, FORWARD);
+     // Create ACIS edges
+   EDGE* Edge1 = new EDGE (Vertex1, Vertex2, S1, FORWARD);
+   EDGE* Edge2 = new EDGE (Vertex2, Vertex3, S2, FORWARD);
+   EDGE* Edge3 = new EDGE (Vertex3, Vertex4, S3, FORWARD);
+   EDGE* Edge4 = new EDGE (Vertex4, Vertex1, S4, FORWARD);
-  // Create an ACIS loop of coedges
-  COEDGE* Coedge1 = new COEDGE (Edge1, FORWARD, NULL, NULL);
-  COEDGE* Coedge2 = new COEDGE (Edge2, FORWARD, Coedge1, NULL);
-  COEDGE* Coedge3 = new COEDGE (Edge3, FORWARD, Coedge2, NULL);
-  /*COEDGE* Coedge4 =*/ new COEDGE (Edge4, FORWARD, Coedge3, Coedge1);
-  LOOP* Loop1 = new LOOP (Coedge1, NULL);
+     // Create an ACIS loop of coedges
+   COEDGE* Coedge1 = new COEDGE (Edge1, FORWARD, NULL, NULL);
+   COEDGE* Coedge2 = new COEDGE (Edge2, FORWARD, Coedge1, NULL);
+   COEDGE* Coedge3 = new COEDGE (Edge3, FORWARD, Coedge2, NULL);
+ /*COEDGE* Coedge4 =*/ new COEDGE (Edge4, FORWARD, Coedge3, Coedge1);
+   LOOP* Loop1 = new LOOP (Coedge1, NULL);
-  // Create an ACIS face
-  FACE* Face1 = new FACE (Loop1, NULL, Plane1, FORWARD);
+     // Create an ACIS face
+   FACE* Face1 = new FACE (Loop1, NULL, Plane1, FORWARD);
-  // Create an ACIS shell
-  SHELL* Shell1 = new SHELL (Face1, NULL, NULL);
+     // Create an ACIS shell
+   SHELL* Shell1 = new SHELL (Face1, NULL, NULL);
-  // Create an ACIS lump
-  LUMP* Lump1 = new LUMP (Shell1, NULL);
+     // Create an ACIS lump
+   LUMP* Lump1 = new LUMP (Shell1, NULL);
-  // Create the ACIS body
-  Body1 = new BODY (Lump1);
+     // Create the ACIS body
+   Body1 = new BODY (Lump1);
-  // Make sure all's well with this BODY and then 2D-it!
-  if (Body1 != NULL)
-      // Finally, make sure this BODY consists of a DOUBLE-SIDED,
-      // BOTH_OUTSIDE FACE
+     // Make sure all's well with this BODY and then 2D-it!
+   if (Body1 != NULL)
+        // Finally, make sure this BODY consists of a DOUBLE-SIDED,
+        // BOTH_OUTSIDE FACE
       result = api_body_to_2d(Body1);
       if (!result.ok())
-	  PRINT_ERROR("In AcisModifyEngine::make_planar_quad_BODY.\n"
-		      "  Unable to convert FACE to a 2D BODY using api_body_to2d.\n");
-	  success = CUBIT_FALSE;
+         PRINT_ERROR("In AcisModifyEngine::make_planar_quad_BODY.\n"
+                     "  Unable to convert FACE to a 2D BODY using api_body_to2d.\n");
+         success = CUBIT_FALSE;
-  // Scream bloody murder....only if necessary, of course :-)
-  if (Body1 == NULL)
+     // Scream bloody murder....only if necessary, of course :-)
+   if (Body1 == NULL)
                   "       Problem creating a Planar Quadrilateral ACIS BODY.\n");
-  // Terminate the bulletin board
-  API_END;
+     // Terminate the bulletin board
+   API_END;
-  if (success)
-      // Debug info
-      PRINT_DEBUG_18("  Successfully created a planar quadrilateral ACIS BODY.\n");
-      return Body1;
+   if (success)
+       // Debug info
+     PRINT_DEBUG_18("  Successfully created a planar quadrilateral ACIS BODY.\n");
+     return Body1;
-  else
-      return NULL;
+   else
+     return NULL;
@@ -3565,55 +3560,55 @@
                                    const CubitVector axes[3],
                                    const CubitVector &extension ) const
-  BODY* BODY_ptr = NULL;
+   BODY* BODY_ptr = NULL;
-  double width = 2.0*extension.x();
-  double depth = 2.0*extension.y();
-  double height = 2.0*extension.z();
+   double width = 2.0*extension.x();
+   double depth = 2.0*extension.y();
+   double height = 2.0*extension.z();
-  // Create a BODY that represents the cuboid
-  outcome result = api_make_cuboid ( width, depth, height, BODY_ptr );
-  if (!result.ok())
+     // Create a BODY that represents the cuboid
+   outcome result = api_make_cuboid ( width, depth, height, BODY_ptr );
+   if (!result.ok())
       PRINT_ERROR("In AcisGeometryEngine::make_brick_BODY, Line# %d\n"
                   "     Problems creating a brick\n", __LINE__);
       return NULL ;
-  // Transform the brick into SPAposition
+   // Transform the brick into SPAposition
-  SPAposition brick_center( center.x(), center.y(), center.z() );
-  SPAunit_vector x_axis_this( axes[0].x(), axes[0].y(), axes[0].z() );
-  SPAunit_vector y_axis_this( axes[1].x(), axes[1].y(), axes[1].z() );
+   SPAposition brick_center( center.x(), center.y(), center.z() );
+   SPAunit_vector x_axis_this( axes[0].x(), axes[0].y(), axes[0].z() );
+   SPAunit_vector y_axis_this( axes[1].x(), axes[1].y(), axes[1].z() );
-  SPAtransf transformation = coordinate_transf( brick_center, x_axis_this, y_axis_this );
+   SPAtransf transformation = coordinate_transf( brick_center, x_axis_this, y_axis_this );
-  // Concatenate the input transformation to the existing one
-  result = api_apply_transf ( BODY_ptr, transformation );
-  if (!result.ok())
+   // Concatenate the input transformation to the existing one
+   result = api_apply_transf ( BODY_ptr, transformation );
+   if (!result.ok())
       AcisQueryEngine::instance()->ACIS_API_error ( result );
       return NULL;
-  TRANSFORM* identity = new TRANSFORM(scale_transf(1.0));
-  result = api_change_body_trans ( BODY_ptr, identity, FALSE );
-  identity->lose();
-  if (!result.ok())
+   TRANSFORM* identity = new TRANSFORM(scale_transf(1.0));
+   result = api_change_body_trans ( BODY_ptr, identity, FALSE );
+   identity->lose();
+   if (!result.ok())
       return NULL;
-  //The bounding SPAbox does not get re-computed, so we need
-  //to do it.
-  AcisQueryEngine::instance()->clear_bounding_box( BODY_ptr );
-  AcisQueryEngine::instance()->bounding_box( BODY_ptr );
+     //The bounding SPAbox does not get re-computed, so we need
+     //to do it.
+   AcisQueryEngine::instance()->clear_bounding_box( BODY_ptr );
+   AcisQueryEngine::instance()->bounding_box( BODY_ptr );
-  return BODY_ptr;
+   return BODY_ptr;
@@ -3913,15 +3908,15 @@
   VERTEX* VERTEX_ptr = NULL;
   API_BEGIN;
-  // Create a new ACIS VERTEX -- it is not attached to a BODY
-  APOINT* APOINT_ptr = new APOINT ( point.x(), point.y(), point.z() );
+      // Create a new ACIS VERTEX -- it is not attached to a BODY
+    APOINT* APOINT_ptr = new APOINT ( point.x(), point.y(), point.z() );
-  if ( APOINT_ptr != NULL )
+    if ( APOINT_ptr != NULL )
       VERTEX_ptr = new VERTEX ( APOINT_ptr );
-  else
+    else
       PRINT_ERROR("In AcisModifyEngine::make_VERTEX\n"
                   "       ACIS could not make an APOINT object.\n"
@@ -3929,8 +3924,8 @@
-  // Complain if ACIS wasn't able to create the VERTEX
-  if ( VERTEX_ptr == NULL && status == CUBIT_SUCCESS)
+      // Complain if ACIS wasn't able to create the VERTEX
+    if ( VERTEX_ptr == NULL && status == CUBIT_SUCCESS)
                   "       ACIS could not make a VERTEX object.\n");
@@ -3966,59 +3961,59 @@
 // Creation Date : 03-27-97
 EDGE* AcisModifyEngine::make_EDGE( GeometryType EDGE_type,
-				   VERTEX* start_VERTEX,
-				   VERTEX* end_VERTEX,
-				   SPAposition* intermediate_point_ptr,
+                                     VERTEX* start_VERTEX,
+                                     VERTEX* end_VERTEX,
+                                     SPAposition* intermediate_point_ptr,
                                    bool sense ) const
-  // Make sure the input VERTEX'es are non-NULL -- these are needed by
-  // all the EDGE generation routines.
-  if ( start_VERTEX == NULL || end_VERTEX == NULL )
+     // Make sure the input VERTEX'es are non-NULL -- these are needed by
+     // all the EDGE generation routines.
+   if ( start_VERTEX == NULL || end_VERTEX == NULL )
       PRINT_ERROR("In AcisModifyEngine::make_EDGE\n"
                   "       An input end VERTEX is invalid (NULL).\n");
       assert (start_VERTEX != NULL && end_VERTEX != NULL);
       return (EDGE *)NULL;
-  // Make a straight EDGE
-  if ( EDGE_type == STRAIGHT_CURVE_TYPE )
+     // Make a straight EDGE
+   if ( EDGE_type == STRAIGHT_CURVE_TYPE )
       return make_straight_EDGE(start_VERTEX, end_VERTEX);
-  // Make a parabolic EDGE
-  else if ( EDGE_type == PARABOLA_CURVE_TYPE )
+     // Make a parabolic EDGE
+   else if ( EDGE_type == PARABOLA_CURVE_TYPE )
       return make_parabolic_EDGE( start_VERTEX,
                                   end_VERTEX,
                                   intermediate_point_ptr);
-  // Make an elliptical EDGE
-  else if ( EDGE_type == ELLIPSE_CURVE_TYPE )
+     // Make an elliptical EDGE
+   else if ( EDGE_type == ELLIPSE_CURVE_TYPE )
       return make_elliptical_EDGE( start_VERTEX,
                                    end_VERTEX,
                                    sense);
-  else if (EDGE_type == ARC_CURVE_TYPE)
-      return make_circular_EDGE(start_VERTEX,
-				end_VERTEX,
-				intermediate_point_ptr);
+   else if (EDGE_type == ARC_CURVE_TYPE)
+     return make_circular_EDGE(start_VERTEX,
+                               end_VERTEX,
+                               intermediate_point_ptr);
-  // OOps!!!!
-  else
+     // OOps!!!!
+   else
                   "       Invalid curve type.\n");
       assert (0 == 1);
 // This function will create a supper cone using the info
@@ -4028,110 +4023,110 @@
 // in cubit.
 FACE* AcisModifyEngine::make_type_FACE( CONE *CONE_ptr ) const
-  //Given this lets create another face that is extended from it.
-  CubitBox bounding_box = GeometryQueryTool::instance()->model_bounding_box();
+     //Given this lets create another face that is extended from it.
+   CubitBox bounding_box = GeometryQueryTool::instance()->model_bounding_box();
-  BODY *sheet_body;
-  CubitBoolean cylinder = CUBIT_FALSE;
+   BODY *sheet_body;
+   CubitBoolean cylinder = CUBIT_FALSE;
-  double const st_ang = 0.0;
-  double const end_ang = 2*CUBIT_PI;
-  double cost = CONE_ptr->cosine_angle();
-  double sint = CONE_ptr->sine_angle();
-  if ( sint == 0.0 && fabs(cost) == 1.0 )
-      //This is a cylinder.
-  SPAvector major_a = CONE_ptr->major_axis();
-  SPAunit_vector normal_a = CONE_ptr->direction();
-  double const radius_ratio = CONE_ptr->radius_ratio();
-  double const height = 2*(bounding_box.diagonal()).length();
-  SPAposition root = CONE_ptr->root_point();
-  CubitVector elipse_radius, center_vec;
-  CubitVector temp_norm( normal_a.x(), normal_a.y(), normal_a.z());
-  if ( !cylinder )
-      if ( sint > 0.0 && cost > 0.0 )
-	  sint = -sint;
-	  temp_norm *= -1.0;
-      else if ( sint < 0.0 && cost < 0.0 )
-	  cost = -cost;
-      //First we need to calculate the new radius.
-      //Also calc the old height to find the new center SPAposition.
-      double theta_rad = acos(cost);
-      elipse_radius.set(major_a.x(), major_a.y(), major_a.z() );
-      double old_radius = elipse_radius.length();
-      double old_height = old_radius/tan(theta_rad);
+   double const st_ang = 0.0;
+   double const end_ang = 2*CUBIT_PI;
+   double cost = CONE_ptr->cosine_angle();
+   double sint = CONE_ptr->sine_angle();
+   if ( sint == 0.0 && fabs(cost) == 1.0 )
+       //This is a cylinder.
+   SPAvector major_a = CONE_ptr->major_axis();
+   SPAunit_vector normal_a = CONE_ptr->direction();
+   double const radius_ratio = CONE_ptr->radius_ratio();
+   double const height = 2*(bounding_box.diagonal()).length();
+   SPAposition root = CONE_ptr->root_point();
+   CubitVector elipse_radius, center_vec;
+   CubitVector temp_norm( normal_a.x(), normal_a.y(), normal_a.z());
+   if ( !cylinder )
+     if ( sint > 0.0 && cost > 0.0 )
+       sint = -sint;
+       temp_norm *= -1.0;
+     else if ( sint < 0.0 && cost < 0.0 )
+       cost = -cost;
+       //First we need to calculate the new radius.
+       //Also calc the old height to find the new center SPAposition.
+     double theta_rad = acos(cost);
+     elipse_radius.set(major_a.x(), major_a.y(), major_a.z() );
+     double old_radius = elipse_radius.length();
+     double old_height = old_radius/tan(theta_rad);
-      CubitVector root_vec( root.x(), root.y(), root.z() );
-      center_vec = root_vec + (-0.5*height)*temp_norm;
+     CubitVector root_vec( root.x(), root.y(), root.z() );
+     center_vec = root_vec + (-0.5*height)*temp_norm;
-      //calculate new radius
-      double new_radius = (old_height+ 0.5*height) * tan (theta_rad );
-      elipse_radius.normalize();
-      elipse_radius *= new_radius;
-  else
-      center_vec = .5*height*temp_norm;
-  SPAvector const major_axis(elipse_radius.x(), elipse_radius.y(), elipse_radius.z() );
+     //calculate new radius
+     double new_radius = (old_height+ 0.5*height) * tan (theta_rad );
+     elipse_radius.normalize();
+     elipse_radius *= new_radius;
+   else
+     center_vec = .5*height*temp_norm;
+   SPAvector const major_axis(elipse_radius.x(), elipse_radius.y(), elipse_radius.z() );
-  SPAunit_vector const normal_axis(temp_norm.x(), temp_norm.y(), temp_norm.z());
-  SPAposition const center ( center_vec.x(), center_vec.y(), center_vec.z() );
+   SPAunit_vector const normal_axis(temp_norm.x(), temp_norm.y(), temp_norm.z());
+   SPAposition const center ( center_vec.x(), center_vec.y(), center_vec.z() );
-  FACE *new_FACE_ptr = NULL;
-  outcome result = api_make_cnface( center, normal_axis, major_axis,
-				    radius_ratio, sint, cost, st_ang,
-				    end_ang, height, new_FACE_ptr );
-  if (!result.ok() || new_FACE_ptr == NULL ||
-      new_FACE_ptr->geometry() == NULL )
+   FACE *new_FACE_ptr = NULL;
+   outcome result = api_make_cnface( center, normal_axis, major_axis,
+                             radius_ratio, sint, cost, st_ang,
+                             end_ang, height, new_FACE_ptr );
+   if (!result.ok() || new_FACE_ptr == NULL ||
+       new_FACE_ptr->geometry() == NULL )
       PRINT_ERROR("In AcisModifyEngine::make_type_FACE(cone)\n"
                   "       ACIS api_make_cnface function failed.\n\n");
       AcisQueryEngine::instance()->ACIS_API_error (result);
       return (FACE *)NULL;
-  face_list[0] = new_FACE_ptr;
-  result = api_sheet_from_ff( 1, face_list, sheet_body );
-  if (!result.ok() || sheet_body == NULL || sheet_body->lump() == NULL
-      || sheet_body->lump()->shell() == NULL ||
-      sheet_body->lump()->shell()->first_face() == NULL )
+   face_list[0] = new_FACE_ptr;
+   result = api_sheet_from_ff( 1, face_list, sheet_body );
+   if (!result.ok() || sheet_body == NULL || sheet_body->lump() == NULL
+       || sheet_body->lump()->shell() == NULL ||
+       sheet_body->lump()->shell()->first_face() == NULL )
                   "       ACIS api_sheet_from_ff function failed.\n\n");
-  result =  api_body_to_2d( sheet_body );
-  if (!result.ok())
+   result =  api_body_to_2d( sheet_body );
+   if (!result.ok())
                   "       ACIS api_body_to_2d function failed.\n\n");
-  int debug_flg = 0;
-  // Save the BODY being cut, if debug is on
-  if (debug_flg)
+   int debug_flg = 0;
+     // Save the BODY being cut, if debug is on
+   if (debug_flg)
       AcisQueryEngine::instance()->save_ENTITY_as_sat_file(sheet_body, "cone_sheet.sat", "w");
-  return sheet_body->lump()->shell()->first_face();
+   return sheet_body->lump()->shell()->first_face();
 // This function will create a sphere face using the info
 // from the existing sphere.  It is actually a face or sheet
@@ -4139,73 +4134,73 @@
 // will be the grand sphere itself, not a section of it.
 FACE* AcisModifyEngine::make_type_FACE( SPHERE *SPHERE_ptr ) const
-  BODY *sheet_body;
+   BODY *sheet_body;
-  BODY *sphere_body;
-  SPAposition const center = SPHERE_ptr->centre();
-  double const radius = SPHERE_ptr->radius();
+   BODY *sphere_body;
+   SPAposition const center = SPHERE_ptr->centre();
+   double const radius = SPHERE_ptr->radius();
-  //make a sphere body then move it to the give place.
-  outcome result = api_make_sphere( radius, sphere_body );
-  if (!result.ok() || sphere_body == NULL ||
-      sphere_body->lump() == NULL ||
-      sphere_body->lump()->shell() == NULL ||
-      sphere_body->lump()->shell()->first_face() == NULL )
+     //make a sphere body then move it to the give place.
+   outcome result = api_make_sphere( radius, sphere_body );
+   if (!result.ok() || sphere_body == NULL ||
+       sphere_body->lump() == NULL ||
+       sphere_body->lump()->shell() == NULL ||
+       sphere_body->lump()->shell()->first_face() == NULL )
       PRINT_ERROR("In AcisModifyEngine::make_type_FACE(sphere)\n"
                   "       ACIS api_make_sphere function failed.\n\n");
-  //now move the body.
-  SPAvector translation_vector( center.x(), center.y(), center.z() );
-  result = api_apply_transf ( sphere_body,
-			      translate_transf (translation_vector) );
-  if ( !result.ok() )
+     //now move the body.
+   SPAvector translation_vector( center.x(), center.y(), center.z() );
+   result = api_apply_transf ( sphere_body,
+                               translate_transf (translation_vector) );
+   if ( !result.ok() )
                   "       ACIS api_aply_transf function failed.\n\n");
       AcisQueryEngine::instance()->ACIS_API_error ( result, "transforming body" );
       return (FACE*)NULL;
-  result = api_change_body_trans ( sphere_body, identity, FALSE );
-  identity->lose();
-  if (!result.ok())
+   result = api_change_body_trans ( sphere_body, identity, FALSE );
+   identity->lose();
+   if (!result.ok())
       return (FACE*)NULL;
-  //to do it.
-  AcisQueryEngine::instance()->clear_bounding_box( sphere_body );
-  AcisQueryEngine::instance()->bounding_box(sphere_body);
+     //to do it.
+   AcisQueryEngine::instance()->clear_bounding_box( sphere_body );
+   AcisQueryEngine::instance()->bounding_box(sphere_body);
-  face_list[0] = sphere_body->lump()->shell()->first_face();
+   face_list[0] = sphere_body->lump()->shell()->first_face();
-  if (!result.ok())
+   if (!result.ok())
-  AcisQueryEngine::instance()->delete_ACIS_BODY(sphere_body, CUBIT_TRUE);
+   AcisQueryEngine::instance()->delete_ACIS_BODY(sphere_body, CUBIT_TRUE);
 // This function will create a torus face using the info
 // from the existing torus.  It is actually a face or sheet
@@ -4214,66 +4209,66 @@
 FACE* AcisModifyEngine::make_type_FACE( TORUS *TORUS_ptr ) const
   if ( TORUS_ptr == NULL )
-      PRINT_ERROR("NULL pointer passed to make face from. (torus).\n");
-      return (FACE*)NULL;
+    PRINT_ERROR("NULL pointer passed to make face from. (torus).\n");
+    return (FACE*)NULL;
-  BODY *sheet_body;
-  SPAposition const center = TORUS_ptr->centre();
-  SPAunit_vector const normal = TORUS_ptr->normal();
-  double const uf = 0.0;
-  double const ut = 2*CUBIT_PI;
-  double const vf = 0.0;
-  double const vt = 2*CUBIT_PI;
-  double const major_radius = TORUS_ptr->major_radius();
-  double const minor_radius = TORUS_ptr->minor_radius();
-  CubitVector temp_center(center.x(), center.y(), center.z());
-  CubitVector temp_normal(normal.x(), normal.y(), normal.z());
-  temp_normal.normalize();
-  CubitVector temp_point = temp_center + major_radius*temp_normal;
-  SPAposition const point(temp_point.x(), temp_point.y(), temp_point.z());
+   BODY *sheet_body;
+   SPAposition const center = TORUS_ptr->centre();
+   SPAunit_vector const normal = TORUS_ptr->normal();
+   double const uf = 0.0;
+   double const ut = 2*CUBIT_PI;
+   double const vf = 0.0;
+   double const vt = 2*CUBIT_PI;
+   double const major_radius = TORUS_ptr->major_radius();
+   double const minor_radius = TORUS_ptr->minor_radius();
+   CubitVector temp_center(center.x(), center.y(), center.z());
+   CubitVector temp_normal(normal.x(), normal.y(), normal.z());
+   temp_normal.normalize();
+   CubitVector temp_point = temp_center + major_radius*temp_normal;
+   SPAposition const point(temp_point.x(), temp_point.y(), temp_point.z());
-  //make a torus body then move it to the give place.
-  outcome result = api_make_trface( center, normal, major_radius,
-				    minor_radius, point,
-				    uf, ut, vf, vt, new_FACE_ptr );
-  if (!result.ok() || new_FACE_ptr == NULL )
+     //make a torus body then move it to the give place.
+   outcome result = api_make_trface( center, normal, major_radius,
+                                     minor_radius, point,
+                                     uf, ut, vf, vt, new_FACE_ptr );
+   if (!result.ok() || new_FACE_ptr == NULL )
       PRINT_ERROR("In AcisModifyEngine::make_type_FACE(torus)\n"
                   "       ACIS api_make_trface function failed.\n\n");
-  if (!result.ok())
+   if (!result.ok())
-  if (debug_flg)
+   if (debug_flg)
       AcisQueryEngine::instance()->save_ENTITY_as_sat_file(sheet_body, "torus_sheet.sat", "w");
 // This function will create a spline face using the info
 // from the existing spline.  It is actually a face or sheet
@@ -4281,36 +4276,36 @@
 // will be the grand spline itself, not a section of it.
 FACE* AcisModifyEngine::make_type_FACE( SPLINE *SPLINE_ptr ) const
-  BODY *sheet_body;
-  PRINT_WARNING("Extents of spline will be only as far as\n"
-		"the spline definition, this really isn't an infinite surface.\n");
+   BODY *sheet_body;
+   PRINT_WARNING("Extents of spline will be only as far as\n"
+                 "the spline definition, this really isn't an infinite surface.\n");
-  //use the geometry to make the spline body.
-  surface const *this_spline = &(SPLINE_ptr->equation());
+     //use the geometry to make the spline body.
+   surface const *this_spline = &(SPLINE_ptr->equation());
-  //make a spline body then move it to the give place.
-  outcome result = api_make_spline( *((spline*)this_spline), sheet_body );
-      sheet_body->lump() == NULL ||
-      sheet_body->lump()->shell() == NULL ||
-      sheet_body->lump()->shell()->first_face() == NULL ||
-      sheet_body->lump()->shell()->first_face()->geometry() == NULL )
+     //make a spline body then move it to the give place.
+   outcome result = api_make_spline( *((spline*)this_spline), sheet_body );
+       sheet_body->lump() == NULL ||
+       sheet_body->lump()->shell() == NULL ||
+       sheet_body->lump()->shell()->first_face() == NULL ||
+       sheet_body->lump()->shell()->first_face()->geometry() == NULL )
       PRINT_ERROR("In AcisModifyEngine::make_type_FACE(spline)\n"
                   "       ACIS api_make_spline function failed.\n\n");
-  if (!result.ok())
+   if (!result.ok())
 // This function will create a plane face using the info
 // from the existing plane.  It is actually a face or sheet
@@ -4318,37 +4313,37 @@
 // will be the grand plane itself, not a section of it.
 FACE* AcisModifyEngine::make_type_FACE( PLANE *PLANE_ptr ) const
-  //first lets find 3 points.
-  SPAposition point_1, point_2, point_3;
-  SPApar_pos const pos_1( 0, 1 );
-  SPApar_pos const pos_2( 1, 0 );
-  SPApar_pos const pos_3( 0, 0 );
-  PLANE_ptr->equation().eval( pos_1, point_1 );
-  PLANE_ptr->equation().eval( pos_2, point_2 );
-  PLANE_ptr->equation().eval( pos_3, point_3 );
+     //first lets find 3 points.
+   SPAposition point_1, point_2, point_3;
+   SPApar_pos const pos_1( 0, 1 );
+   SPApar_pos const pos_2( 1, 0 );
+   SPApar_pos const pos_3( 0, 0 );
+   PLANE_ptr->equation().eval( pos_1, point_1 );
+   PLANE_ptr->equation().eval( pos_2, point_2 );
+   PLANE_ptr->equation().eval( pos_3, point_3 );
-  CubitBox cubit_super_box = GeometryQueryTool::instance()->model_bounding_box();
-  SPAbox super_box = AcisQueryEngine::bounding_box(cubit_super_box);
+   CubitBox cubit_super_box = GeometryQueryTool::instance()->model_bounding_box();
+   SPAbox super_box = AcisQueryEngine::bounding_box(cubit_super_box);
-  CubitVector vec_1( point_1.x(), point_1.y(), point_1.z() );
-  CubitVector vec_2( point_2.x(), point_2.y(), point_2.z() );
-  CubitVector vec_3( point_3.x(), point_3.y(), point_3.z() );
+   CubitVector vec_1( point_1.x(), point_1.y(), point_1.z() );
+   CubitVector vec_2( point_2.x(), point_2.y(), point_2.z() );
+   CubitVector vec_3( point_3.x(), point_3.y(), point_3.z() );
-  BODY *sheet_body = this->create_infinite_plane_cutting_tool(
-							      vec_1, vec_2, vec_3, super_box, CUBIT_TRUE );
-  if (sheet_body == NULL ||
-      //webcut_failed(refbody_cleanup_list, BODY_cleanup_list);
+   BODY *sheet_body = this->create_infinite_plane_cutting_tool(
+       vec_1, vec_2, vec_3, super_box, CUBIT_TRUE );
+   if (sheet_body == NULL ||
+        //webcut_failed(refbody_cleanup_list, BODY_cleanup_list);
       PRINT_ERROR("In AcisModifyEngine::make_type_FACE(plane)"
                   "       Cannot create infinite plane cutting tool using \n"
                   "       the give surface. \n");
       return (FACE*)NULL;
 // Purpose       : Create a face from the face pointer.  This will create
@@ -4360,66 +4355,66 @@
 // Creation Date : 10/6/97
 FACE* AcisModifyEngine::make_FACE(FACE* FACE_ptr,
-				  CubitBoolean extended_from) const
+                                    CubitBoolean extended_from) const
   if (FACE_ptr == NULL)
     return NULL;
   if (extended_from == CUBIT_TRUE)
       // We need to get the type of surface.
       // For some reason I can't get it to cast on the fly.
-      SURFACE *SURFACE_ptr = FACE_ptr->geometry();
-      if (type == CONE_TYPE)
-	return make_type_FACE((CONE*)SURFACE_ptr);
-      else if (type == SPHERE_TYPE)
-	return make_type_FACE((SPHERE*)SURFACE_ptr);
-      else if (type == TORUS_TYPE)
-	return make_type_FACE((TORUS*)SURFACE_ptr);
-      else if (type == SPLINE_TYPE)
-	return make_type_FACE((SPLINE*)SURFACE_ptr);
-      else if (type == PLANE_TYPE)
-	return make_type_FACE((PLANE*)SURFACE_ptr);
-      else
-	return NULL;
+    SURFACE *SURFACE_ptr = FACE_ptr->geometry();
+    if (type == CONE_TYPE)
+      return make_type_FACE((CONE*)SURFACE_ptr);
+    else if (type == SPHERE_TYPE)
+      return make_type_FACE((SPHERE*)SURFACE_ptr);
+    else if (type == TORUS_TYPE)
+      return make_type_FACE((TORUS*)SURFACE_ptr);
+    else if (type == SPLINE_TYPE)
+      return make_type_FACE((SPLINE*)SURFACE_ptr);
+    else if (type == PLANE_TYPE)
+      return make_type_FACE((PLANE*)SURFACE_ptr);
+    else
+      return NULL;
   FACE *face_list[1];
   BODY *sheet_body;
   face_list[0] = FACE_ptr;
-  // Make a FACE from copy_FACE.
+    // Make a FACE from copy_FACE.
   outcome rc = api_sheet_from_ff(1, face_list, sheet_body);
-  // Now check to see if we created the sheet successfully.
+    // Now check to see if we created the sheet successfully.
   if (!rc.ok())
-      PRINT_ERROR("In AcisModifyEngine::make_FACE\n"
-		  "       ACIS api_sheet_from_ff function failed.\n\n");
-      AcisQueryEngine::instance()->ACIS_API_error (rc);
-      return (FACE *)NULL;
+    PRINT_ERROR("In AcisModifyEngine::make_FACE\n"
+                "       ACIS api_sheet_from_ff function failed.\n\n");
+    AcisQueryEngine::instance()->ACIS_API_error (rc);
+    return (FACE *)NULL;
-  // Convert the FACE to a true sheet BODY.
+    // Convert the FACE to a true sheet BODY.
   outcome rc_2 =  api_body_to_2d(sheet_body);
   if (!rc_2.ok())
-		  "       ACIS api_body_to_2d function failed.\n\n");
-      AcisQueryEngine::instance()->ACIS_API_error (rc_2);
+                "       ACIS api_body_to_2d function failed.\n\n");
+    AcisQueryEngine::instance()->ACIS_API_error (rc_2);
-  // Make sure we were successful
+    // Make sure we were successful
   if ( sheet_body->lump() == NULL ||
@@ -4440,26 +4435,26 @@
                                    DLIList<EDGE*>& input_EDGE_list,
                                    Surface *old_surface_ptr) const
-  // Make sure a supported type of surface is being requested.
+    // Make sure a supported type of surface is being requested.
   if ( FACE_type != PLANE_SURFACE_TYPE  &&
        FACE_type != BEST_FIT_SURFACE_TYPE)
-      PRINT_WARNING("In AcisGeometryEngine::make_FACE\n"
-		    "         At this time, cannot make a FACE that isn't"
-		    " planar or best fit.\n");
+    PRINT_WARNING("In AcisGeometryEngine::make_FACE\n"
+                  "         At this time, cannot make a FACE that isn't"
+                  " planar or best fit.\n");
-  // Set the FACE pointer, if requested.
+    // Set the FACE pointer, if requested.
   FACE *fit_FACE = NULL;
   if ( old_surface_ptr != NULL )
-      SurfaceACIS *surf_ACIS = CAST_TO(old_surface_ptr, SurfaceACIS );
-      fit_FACE = surf_ACIS->get_FACE_ptr();
+    SurfaceACIS *surf_ACIS = CAST_TO(old_surface_ptr, SurfaceACIS );
+    fit_FACE = surf_ACIS->get_FACE_ptr();
-  // Copy the original EDGEs and put them into an array.
-  // Also initialize variables that will be used/returned by ACIS.
+    // Copy the original EDGEs and put them into an array.
+    // Also initialize variables that will be used/returned by ACIS.
   int edge_count = input_EDGE_list.size();
   FACE* FACE_ptr = NULL;
   BODY* wire_BODY = NULL;
@@ -4469,12 +4464,12 @@
   int i;
   for (i = 0 ; i < edge_count ; i++)
-      copy_single_entity( (ENTITY *)input_EDGE_list.get_and_step(), temp_ENTITY_ptr);
-      EDGEs[i] = (EDGE*)temp_ENTITY_ptr;
+    copy_single_entity( (ENTITY *)input_EDGE_list.get_and_step(), temp_ENTITY_ptr);
+    EDGEs[i] = (EDGE*)temp_ENTITY_ptr;
       // Deactivate the RefEntities attached to the EDGE and its VERTEXes.
-      mark_owners_deactivated_flag(EDGEs[i], CUBIT_TRUE, CUBIT_TRUE);
+    mark_owners_deactivated_flag(EDGEs[i], CUBIT_TRUE, CUBIT_TRUE);
   // Make a wire BODY from the copied EDGEs.
   // Coincident VERTEXes will be deleted by ACIS.
@@ -4487,116 +4482,116 @@
     wire_BODYs.add( wireBODYs[i] );
   if ( !result.ok() || wire_BODYs.count() == 0 )
+    PRINT_ERROR("In AcisGeometryEngine::make_FACE\n"
+                "       ACIS api_make_ewire function failed.\n\n");
+    AcisQueryEngine::instance()->ACIS_API_error (result);
+    if (wire_BODYs.count())
+      for(i=0; i<wire_BODYs.count(); i++ )
+        api_delent(wire_BODYs[i]);
+    else
-      PRINT_ERROR("In AcisGeometryEngine::make_FACE\n"
-		  "       ACIS api_make_ewire function failed.\n\n");
-      AcisQueryEngine::instance()->ACIS_API_error (result);
-      if (wire_BODYs.count())
-	for(i=0; i<wire_BODYs.count(); i++ )
-	  api_delent(wire_BODYs[i]);
-      else
-	  while (edge_count--)
-	    api_delent(EDGEs[edge_count]);
-      delete [] EDGEs;
+      while (edge_count--)
+        api_delent(EDGEs[edge_count]);
-  // Check to make sure the wire is closed
+    delete [] EDGEs;
+    // Check to make sure the wire is closed
+    result = api_closed_wire( (BODY*)wire_BODYs[i] );
-      result = api_closed_wire( (BODY*)wire_BODYs[i] );
-	  PRINT_ERROR( "ACIS reports that a closed loop was not found\n" );
-	  // Delete the wire BODY.  This will also delete
-	  // each copied EDGE
-	  // Delete the array
-	  delete [] EDGEs;
+      PRINT_ERROR( "ACIS reports that a closed loop was not found\n" );
+        // Delete the wire BODY.  This will also delete
+        // each copied EDGE
+        // Delete the array
+      delete [] EDGEs;
   //check planarity & co-planarity
   if( wire_BODYs.count() > 1 )
+    CubitVector master_centroid;
+    CubitVector master_normal;
-      CubitVector master_centroid;
-      CubitVector master_normal;
-	  SPAposition centroid;
-	  SPAunit_vector normal;
+      SPAposition centroid;
+      SPAunit_vector normal;
-	  if( !is_planar_wire( (WIRE*)wire_BODYs[i], centroid, normal ) )
-	      PRINT_ERROR( "Multiple loops must be planar.\n" );
-	      delete [] EDGEs;
-	  //make the plane
-	  if( i==0 )
-	      master_centroid.set( centroid.x(), centroid.y(), centroid.z() );
-	      master_normal.set( normal.x(), normal.y(), normal.z() );
-	  else
-	      CubitVector tmp_centroid( centroid.x(), centroid.y(), centroid.z() );
-	      CubitVector tmp_normal( normal.x(), normal.y(), normal.z() );
-	      CubitVector tmp_vec( tmp_centroid - master_centroid );
-	      tmp_vec.normalize();
-	      double dot = master_normal % tmp_vec;
-	      tmp_normal = tmp_normal * master_normal;
+      if( !is_planar_wire( (WIRE*)wire_BODYs[i], centroid, normal ) )
+        PRINT_ERROR( "Multiple loops must be planar.\n" );
+        delete [] EDGEs;
+      //make the plane
+      if( i==0 )
+        master_centroid.set( centroid.x(), centroid.y(), centroid.z() );
+        master_normal.set( normal.x(), normal.y(), normal.z() );
+      else
+        CubitVector tmp_centroid( centroid.x(), centroid.y(), centroid.z() );
+        CubitVector tmp_normal( normal.x(), normal.y(), normal.z() );
+        CubitVector tmp_vec( tmp_centroid - master_centroid );
+        tmp_vec.normalize();
+        double dot = master_normal % tmp_vec;
+        tmp_normal = tmp_normal * master_normal;
-	      if( tmp_normal.length() > GEOMETRY_RESABS ||
-		  fabs(dot) > GEOMETRY_RESABS )
-		  PRINT_ERROR( "Multiple loops must be co-planar.\n" );
-		  delete [] EDGEs;
+        if( tmp_normal.length() > GEOMETRY_RESABS ||
+            fabs(dot) > GEOMETRY_RESABS )
+          PRINT_ERROR( "Multiple loops must be co-planar.\n" );
+          delete [] EDGEs;
   //check intersecting
-	  ENTITY *ent1 = wire_BODYs[i];
+      ENTITY *ent1 = wire_BODYs[i];
-	  int j;
-	  for(j=0; j<wire_BODYs.count(); j++ )
-	      if( i==j )
-		continue;
+      int j;
+      for(j=0; j<wire_BODYs.count(); j++ )
+        if( i==j )
+          continue;
-	      ENTITY *ent2 = wire_BODYs[j];
-	      logical touching = FALSE;
+        ENTITY *ent2 = wire_BODYs[j];
+        logical touching = FALSE;
-	      api_entity_entity_touch( ent1, ent2, touching );
+        api_entity_entity_touch( ent1, ent2, touching );
-	      if( touching )
-		  PRINT_ERROR( "Multiple loops cannot intersect.\n" );
-		  delete [] EDGEs;
+        if( touching )
+          PRINT_ERROR( "Multiple loops cannot intersect.\n" );
+          delete [] EDGEs;
   //sort wires so that the outermost is first
   wire_BODYs.init();
@@ -4604,256 +4599,256 @@
   ENTITY *outermost_wire= NULL;
   double longest_diagonal = 0.0;
-	  SPAbox tmp_box;
-	  CubitBox tmp_cbox;
-	  ENTITY *tmp_wire = wire_BODYs.next();
-	  if(i==0)
-	      tmp_box = AcisQueryEngine::instance()->bounding_box( (BODY*)tmp_wire);
-	      outermost_wire = tmp_wire;
-	      tmp_cbox = AcisQueryEngine::bounding_box( tmp_box );
-	      longest_diagonal = tmp_cbox.diagonal().length();
-	  else
+      SPAbox tmp_box;
+      CubitBox tmp_cbox;
+      ENTITY *tmp_wire = wire_BODYs.next();
+      if(i==0)
+        tmp_box = AcisQueryEngine::instance()->bounding_box( (BODY*)tmp_wire);
+        outermost_wire = tmp_wire;
+        tmp_cbox = AcisQueryEngine::bounding_box( tmp_box );
+        longest_diagonal = tmp_cbox.diagonal().length();
+      else
-	      if( tmp_cbox.diagonal().length() > longest_diagonal )
+        if( tmp_cbox.diagonal().length() > longest_diagonal )
-      //now that we found the outermost, put it first in the list
-      wire_BODYs.clear();
-      tmp_wire_BODYs.remove( outermost_wire );
-      wire_BODYs.add( outermost_wire );
+    //now that we found the outermost, put it first in the list
+    wire_BODYs.clear();
+    tmp_wire_BODYs.remove( outermost_wire );
+    wire_BODYs.add( outermost_wire );
-      tmp_wire_BODYs.init();
-      for(i=0; i<tmp_wire_BODYs.count(); i++ )
-	wire_BODYs.add( tmp_wire_BODYs.next() );
+    tmp_wire_BODYs.init();
+    for(i=0; i<tmp_wire_BODYs.count(); i++ )
+      wire_BODYs.add( tmp_wire_BODYs.next() );
-  // Use the WIRE to make a FACE.
-  // Note that the call to api_cover_wires creates not
-  // only the FACE but the entire topological data
-  // structure above FACE (till BODY).
+    // Use the WIRE to make a FACE.
+    // Note that the call to api_cover_wires creates not
+    // only the FACE but the entire topological data
+    // structure above FACE (till BODY).
   ENTITY_LIST acis_FACE_list;
   if ( fit_FACE != NULL )
-      wire_BODY = static_cast<BODY*>(wire_BODYs[0]);
-      outcome result_2 = api_cover_wires ( wire_BODY,
-					   fit_FACE->geometry()->equation(),
-					   acis_FACE_list );
+    wire_BODY = static_cast<BODY*>(wire_BODYs[0]);
+    outcome result_2 = api_cover_wires ( wire_BODY,
+                                         fit_FACE->geometry()->equation(),
+                                         acis_FACE_list );
       // Now check to see if we covered the wire successfully
-      if ( !result_2.ok() || acis_FACE_list.count() ==  0 ||
-	   wire_BODY == NULL )
-	  PRINT_ERROR("Error in constructing surface on top of another"
-		      "surface, the edges must fit the surface...\n");
-	  AcisQueryEngine::instance()->ACIS_API_error (result_2);
-	  acis_FACE_list.clear();
-	  if (wire_BODY)
-	    api_delent(wire_BODY);
-	  else
-	    // TO DO: Delete each EDGE in EDGEs
-	    void (0);
-	  delete [] EDGEs;
+    if ( !result_2.ok() || acis_FACE_list.count() ==  0 ||
+         wire_BODY == NULL )
+      PRINT_ERROR("Error in constructing surface on top of another"
+                  "surface, the edges must fit the surface...\n");
+      AcisQueryEngine::instance()->ACIS_API_error (result_2);
+      acis_FACE_list.clear();
+      if (wire_BODY)
+        api_delent(wire_BODY);
+      else
+          // TO DO: Delete each EDGE in EDGEs
+        void (0);
+      delete [] EDGEs;
   else
+    outcome surface_creation;
+    bool valid_loops = true;
+    outcome loop_check;
+    //can create non-planar surfs with one wire
+    if( wire_BODYs.count() == 1 )
-      outcome surface_creation;
-      bool valid_loops = true;
-      outcome loop_check;
+      surface_creation = api_cover_wires ( wire_BODY,
+                                           *(surface*)NULL_REF,
+                                           acis_FACE_list );
+    else
+      wire_BODY = NULL;
+      surface_creation = api_cover_wire_loops( wire_BODYs,
+                                               wire_BODY);
+      //check all nested in largest
+      //check doubly nested
+      api_get_faces( wire_BODY, acis_FACE_list);
+      loop_check = api_check_face_loops( static_cast<FACE*>(acis_FACE_list[0]) );
+      if( !loop_check.ok() )
+        valid_loops = false;
-      //can create non-planar surfs with one wire
-      if( wire_BODYs.count() == 1 )
-	  surface_creation = api_cover_wires ( wire_BODY,
-					       *(surface*)NULL_REF,
-					       acis_FACE_list );
-      else
-	  wire_BODY = NULL;
-	  surface_creation = api_cover_wire_loops( wire_BODYs,
-						   wire_BODY);
-	  //check all nested in largest
-	  //check doubly nested
-	  api_get_faces( wire_BODY, acis_FACE_list);
-	  loop_check = api_check_face_loops( static_cast<FACE*>(acis_FACE_list[0]) );
-	  if( !loop_check.ok() )
-	    valid_loops = false;
-      if ( !surface_creation.ok() || wire_BODY == NULL ||
-	   !valid_loops || acis_FACE_list.count() != 1 )
-		      "       problem covering wires.\n\n");
-	  if( !surface_creation.ok() )
-	    AcisQueryEngine::instance()->ACIS_API_error (surface_creation);
-	  if( !valid_loops )
-	    AcisQueryEngine::instance()->ACIS_API_error( loop_check );
-	  if (wire_BODY)
-	  else
-	      // TO DO: delete each EDGE in EDGEs
-	      void(0);
-	      wire_BODYs.init();
-	      ENTITY *ent_to_del;
-	      while( (ent_to_del = wire_BODYs.next())!=NULL )
-		api_delent( ent_to_del );
-	  delete [] EDGEs;
-  if (acis_FACE_list.count() != 1)
+    if ( !surface_creation.ok() || wire_BODY == NULL ||
+         !valid_loops || acis_FACE_list.count() != 1 )
-      PRINT_ERROR("ACIS api_cover_wires function created "
-		  "more than one FACE.\n"
-		  "       At this time, we cannot deal with this.\n");
+                  "       problem covering wires.\n\n");
+      if( !surface_creation.ok() )
+        AcisQueryEngine::instance()->ACIS_API_error (surface_creation);
+      if( !valid_loops )
+        AcisQueryEngine::instance()->ACIS_API_error( loop_check );
       if (wire_BODY)
       else
-	void(0);
+          // TO DO: delete each EDGE in EDGEs
+        void(0);
+        wire_BODYs.init();
+        ENTITY *ent_to_del;
+        while( (ent_to_del = wire_BODYs.next())!=NULL )
+          api_delent( ent_to_del );
       delete [] EDGEs;
+  if (acis_FACE_list.count() != 1)
+    PRINT_ERROR("ACIS api_cover_wires function created "
+                "more than one FACE.\n"
+                "       At this time, we cannot deal with this.\n");
+    if (wire_BODY)
+    else
+      void(0);
+    delete [] EDGEs;
-  //make this a 2d body.
+    //make this a 2d body.
   outcome result_2 = api_body_to_2d( wire_BODY );
   if ( !result_2.ok() )
-      if (wire_BODY)
-      else
+    if (wire_BODY)
+    else
-	void(0);
-      delete [] EDGEs;
+      void(0);
+    delete [] EDGEs;
   FACE_ptr = (FACE*) acis_FACE_list[0];
   if ( FACE_ptr == NULL || FACE_ptr->geometry() == NULL )
-		  "FACE or FACE's geometry was NULL.\n");
-      if (wire_BODY)
-      else
+                "FACE or FACE's geometry was NULL.\n");
+    if (wire_BODY)
+    else
-	void(0);
-      delete [] EDGEs;
+      void(0);
+    delete [] EDGEs;
   if ( !result.ok() )
-      if (wire_BODY)
-      else
+    if (wire_BODY)
+    else
-	void(0);
-      delete [] EDGEs;
+      void(0);
+    delete [] EDGEs;
-  // This will reactivate all the RefEntities that need to be kept.
+    // This will reactivate all the RefEntities that need to be kept.
   mark_owners_deactivated_flag(FACE_ptr, CUBIT_FALSE, CUBIT_TRUE);
-  // Where coincident vertices were merged by ACIS,
-  // make sure the lower ID is used.
+    // Where coincident vertices were merged by ACIS,
+    // make sure the lower ID is used.
   input_EDGE_list.reset();
   for (i = 0; i < input_EDGE_list.size(); i++)
       // get the copy and original EDGE
-      EDGE* cur_EDGE_new = EDGEs[i];
-      EDGE* cur_EDGE_old = input_EDGE_list.get_and_step();
+    EDGE* cur_EDGE_new = EDGEs[i];
+    EDGE* cur_EDGE_old = input_EDGE_list.get_and_step();
       // If the original start RefVertex is deactivated,
       // see if we need to swap it with the replacement RefVertex
-      VERTEX* cur_VERT_new = cur_EDGE_new->start();
-      VERTEX* cur_VERT_old = cur_EDGE_old->start();
+    VERTEX* cur_VERT_new = cur_EDGE_new->start();
+    VERTEX* cur_VERT_old = cur_EDGE_old->start();
-      for (int j = 2; j--; )
-	  RefVertex* ref_vert_old =
-	    CAST_TO(ATTRIB_CUBIT_OWNER::get_topology_entity(cur_VERT_old),
-		    RefVertex);
+    for (int j = 2; j--; )
+      RefVertex* ref_vert_old =
+        CAST_TO(ATTRIB_CUBIT_OWNER::get_topology_entity(cur_VERT_old),
+                RefVertex);
-	  AcisBridge* bridge = ATTRIB_CUBIT_OWNER::cubit_owner(cur_VERT_old);
+      AcisBridge* bridge = ATTRIB_CUBIT_OWNER::cubit_owner(cur_VERT_old);
-	  if (ref_vert_old && bridge_deactivated(bridge))
-	      RefVertex* ref_vert_new =
-		CAST_TO(ATTRIB_CUBIT_OWNER::get_topology_entity(cur_VERT_new),
-			RefVertex);
-	      if (ref_vert_new && ref_vert_old->id() < ref_vert_new->id())
-		  int id_old = ref_vert_old->id();
-		  int id_new = ref_vert_new->id();
-		  ref_vert_old->set_id(0);
-		  ref_vert_new->set_id(id_old);
-		  ref_vert_old->set_id(id_new);
+      if (ref_vert_old && bridge_deactivated(bridge))
+        RefVertex* ref_vert_new =
+          CAST_TO(ATTRIB_CUBIT_OWNER::get_topology_entity(cur_VERT_new),
+                  RefVertex);
+        if (ref_vert_new && ref_vert_old->id() < ref_vert_new->id())
+          int id_old = ref_vert_old->id();
+          int id_new = ref_vert_new->id();
+          ref_vert_old->set_id(0);
+          ref_vert_new->set_id(id_old);
+          ref_vert_old->set_id(id_new);
-	    PointACIS* ref_vert_old =
-	    CAST_TO(ATTRIB_CUBIT_OWNER::cubit_owner(cur_VERT_old),PointACIS);
+      PointACIS* ref_vert_old =
+        CAST_TO(ATTRIB_CUBIT_OWNER::cubit_owner(cur_VERT_old),PointACIS);
-	    if (ref_vert_old && bridge_deactivated(ref_vert_old) && ref_vert_old->owner())
-	    //RefVertex* ref_vert_new =
-	    //  CAST_TO(ATTRIB_CUBIT_OWNER::get_topology_entity(cur_VERT_new),
-	    //          RefVertex);
-	    PointACIS* ref_vert_new =
-	    CAST_TO(ATTRIB_CUBIT_OWNER::cubit_owner(cur_VERT_new),PointACIS);
-	    if (ref_vert_new)
-	    ref_vert_old->owner()->swap_bridge(ref_vert_old,ref_vert_new,true);
-	  cur_VERT_new = cur_EDGE_new->end();
-	  cur_VERT_old = cur_EDGE_old->end();
+      if (ref_vert_old && bridge_deactivated(ref_vert_old) && ref_vert_old->owner())
+        //RefVertex* ref_vert_new =
+        //  CAST_TO(ATTRIB_CUBIT_OWNER::get_topology_entity(cur_VERT_new),
+        //          RefVertex);
+        PointACIS* ref_vert_new =
+          CAST_TO(ATTRIB_CUBIT_OWNER::cubit_owner(cur_VERT_new),PointACIS);
+        if (ref_vert_new)
+          ref_vert_old->owner()->swap_bridge(ref_vert_old,ref_vert_new,true);
+      cur_VERT_new = cur_EDGE_new->end();
+      cur_VERT_old = cur_EDGE_old->end();
-  // Get rid of the stuff we aren't using.  This will delete the RefVertices
-  // that correspond to the VERTEXes deleted by ACIS in api_make_ewire.
-  // We also delete the original ACIS EDGEs since they are no longer
-  // being used.
+    // Get rid of the stuff we aren't using.  This will delete the RefVertices
+    // that correspond to the VERTEXes deleted by ACIS in api_make_ewire.
+    // We also delete the original ACIS EDGEs since they are no longer
+    // being used.
   for (i = input_EDGE_list.size(); i--; )
-      AcisQueryEngine::instance()->unhook_ENTITY_from_VGI(input_EDGE_list.get());
-      api_delent(input_EDGE_list.get_and_step());
+    AcisQueryEngine::instance()->unhook_ENTITY_from_VGI(input_EDGE_list.get());
+    api_delent(input_EDGE_list.get_and_step());
   //GeometryQueryTool::instance()->cleanout_deactivated_geometry();
   delete [] EDGEs;
@@ -4871,35 +4866,35 @@
 EDGE* AcisModifyEngine::make_straight_EDGE( VERTEX* start_VERTEX,
-					    VERTEX* end_VERTEX ) const
+                                              VERTEX* end_VERTEX ) const
-  EDGE* EDGE_ptr = NULL;
-  outcome result = api_mk_ed_line ( start_VERTEX->geometry()->coords(),
-				    end_VERTEX->geometry()->coords(),
-				    EDGE_ptr );
-  if (!result.ok() || EDGE_ptr == NULL)
+   EDGE* EDGE_ptr = NULL;
+   outcome result = api_mk_ed_line ( start_VERTEX->geometry()->coords(),
+                             end_VERTEX->geometry()->coords(),
+                             EDGE_ptr );
+   if (!result.ok() || EDGE_ptr == NULL)
       PRINT_ERROR("In AcisModifyEngine::make_straight_EDGE\n"
                   "       ACIS api_mk_ed_line function failed.\n\n");
-  else
-      // Switch the end VERTEXes of the new EDGE to the input VERTEXes. Keep
-      // in mind that the back links (from the VERTEX back to the EDGE)
-      // need to be modified as well.
+   else
+        // Switch the end VERTEXes of the new EDGE to the input VERTEXes. Keep
+        // in mind that the back links (from the VERTEX back to the EDGE)
+        // need to be modified as well.
       EDGE_ptr->set_start(start_VERTEX);
       start_VERTEX->add_edge(EDGE_ptr);
       EDGE_ptr->set_end(end_VERTEX);
       end_VERTEX->add_edge(EDGE_ptr);
-      // Return the newly created EDGE
+        // Return the newly created EDGE
       return EDGE_ptr;
@@ -4913,87 +4908,87 @@
 EDGE* AcisModifyEngine::make_parabolic_EDGE(
-					    VERTEX* from,
-					    VERTEX* to,
-					    SPAposition* peak_ptr ) const
+    VERTEX* from,
+    VERTEX* to,
+    SPAposition* peak_ptr ) const
-  if ( peak_ptr == NULL )
+   if ( peak_ptr == NULL )
       PRINT_ERROR("In AcisModifyEngine::make_parabolic_EDGE\n"
                   "       Input parabola tip is invalid (NULL pointer).\n");
       assert ( peak_ptr != NULL );
-  // Convert positions to CubitVectors (legacy code!!!)
-  SPAposition from_position = from->geometry()->coords();
-  SPAposition to_position = to->geometry()->coords();
+     // Convert positions to CubitVectors (legacy code!!!)
+   SPAposition from_position = from->geometry()->coords();
+   SPAposition to_position = to->geometry()->coords();
-  CubitVector from_vec( from_position.x(),
-			from_position.y(),
-			from_position.z() );
-  CubitVector to_vec( to_position.x(),
-		      to_position.y(),
-		      to_position.z() );
-  CubitVector peak_vec( peak_ptr->x(),
-			peak_ptr->y(),
-			peak_ptr->z() );
+   CubitVector from_vec( from_position.x(),
+                         from_position.y(),
+                         from_position.z() );
+   CubitVector to_vec( to_position.x(),
+                       to_position.y(),
+                       to_position.z() );
+   CubitVector peak_vec( peak_ptr->x(),
+                         peak_ptr->y(),
+                         peak_ptr->z() );
-  CubitVector width_vec, midpoint_vec, height_vec;
-  width_vec = to_vec - from_vec;
-  midpoint_vec = (from_vec + to_vec)/2.0;
-  height_vec = peak_vec - midpoint_vec;
+   CubitVector width_vec, midpoint_vec, height_vec;
+   width_vec = to_vec - from_vec;
+   midpoint_vec = (from_vec + to_vec)/2.0;
+   height_vec = peak_vec - midpoint_vec;
-  // rho = 0.5 is a (spline) parabola -
-  // see ACIS Geometric Modeler API Reference 3-138 ver. 1.7
-  double rho = 0.5;
-  // Find the focus of this parabola.
-  // Since for a parabola with its peak at the origin, y = (1/(4*a))*x^2,
-  // and since we have restricted this parabola to be symmetric (per the FastQ
-  // method, see the FastQ file getwt.f), we can use the following relationship
-  // to determine "a", the distance the focus lies from the peak on the line
-  // formed by the peak and the midpoint of the start and end points
-  //double a = width_vec.length_squared()/(16. * height_vec.length());
-  CubitVector height_vec_unit = height_vec;
-  height_vec_unit.normalize();
+     // rho = 0.5 is a (spline) parabola -
+     // see ACIS Geometric Modeler API Reference 3-138 ver. 1.7
+   double rho = 0.5;
+     // Find the focus of this parabola.
+     // Since for a parabola with its peak at the origin, y = (1/(4*a))*x^2,
+     // and since we have restricted this parabola to be symmetric (per the FastQ
+     // method, see the FastQ file getwt.f), we can use the following relationship
+     // to determine "a", the distance the focus lies from the peak on the line
+     // formed by the peak and the midpoint of the start and end points
+   //double a = width_vec.length_squared()/(16. * height_vec.length());
+   CubitVector height_vec_unit = height_vec;
+   height_vec_unit.normalize();
-  // See Geometric Modeling by M. E. Mortenson, pg. 82, Fig 2.28 c, we need p2
-  // as the center_vec from which to get the tangents
-  // Our approach assumes that midpoint_vec, peak, and center_vec will all lie
-  // on the same line, a valid assumption with the restrictions from FastQ
-  CubitVector vec_E_C = peak_vec - midpoint_vec;
-  CubitVector center_vec = ((2./rho)*vec_E_C + to_vec + from_vec)/2.;
+     // See Geometric Modeling by M. E. Mortenson, pg. 82, Fig 2.28 c, we need p2
+     // as the center_vec from which to get the tangents
+     // Our approach assumes that midpoint_vec, peak, and center_vec will all lie
+     // on the same line, a valid assumption with the restrictions from FastQ
+   CubitVector vec_E_C = peak_vec - midpoint_vec;
+   CubitVector center_vec = ((2./rho)*vec_E_C + to_vec + from_vec)/2.;
-  SPAvector start_tan = SPAvector ( center_vec.x() - from_vec.x(),
-				    center_vec.y() - from_vec.y(),
-				    center_vec.z() - from_vec.z() );
+   SPAvector start_tan = SPAvector ( center_vec.x() - from_vec.x(),
+                               center_vec.y() - from_vec.y(),
+                               center_vec.z() - from_vec.z() );
-  SPAvector   end_tan = SPAvector ( center_vec.x() - to_vec.x(),
-				    center_vec.y() - to_vec.y(),
-				    center_vec.z() - to_vec.z() );
+   SPAvector   end_tan = SPAvector ( center_vec.x() - to_vec.x(),
+                               center_vec.y() - to_vec.y(),
+                               center_vec.z() - to_vec.z() );
-  SPAunit_vector start_tan_unit = normalise( start_tan );
-  SPAunit_vector   end_tan_unit = normalise( end_tan );
+   SPAunit_vector start_tan_unit = normalise( start_tan );
+   SPAunit_vector   end_tan_unit = normalise( end_tan );
-  outcome result = api_mk_ed_conic ( from_position,
-				     start_tan_unit,
-				     to_position,
-				     end_tan_unit,
-				     rho,
-				     EDGE_ptr );
+   outcome result = api_mk_ed_conic ( from_position,
+                                      start_tan_unit,
+                                      to_position,
+                                      end_tan_unit,
+                                      rho,
+                                      EDGE_ptr );
       PRINT_ERROR("ACIS api_mk_ed_conic function failed\n");
-  else
-      // Switch the end VERTEXes of the EDGE to the input VERTEXes. Keep
+   else
+        // Switch the end VERTEXes of the EDGE to the input VERTEXes. Keep
       EDGE_ptr->set_start ( from );
       from->add_edge( EDGE_ptr );
@@ -5001,7 +4996,7 @@
       to->add_edge( EDGE_ptr );
       return EDGE_ptr;
@@ -5021,94 +5016,94 @@
 EDGE* AcisModifyEngine::make_elliptical_EDGE( VERTEX* from,
-					      VERTEX* to,
-					      SPAposition* ctr_ptr,
-					      bool sense ) const
+                                                VERTEX* to,
+                                                SPAposition* ctr_ptr,
+                                                bool sense ) const
-  if ( ctr_ptr == NULL )
+   if ( ctr_ptr == NULL )
       PRINT_ERROR("In AcisModifyEngine::make_elliptical_EDGE\n"
                   "       Input ellipse center is invalid (NULL pointer).\n");
-		      to_position.y(),
-  CubitVector ctr_vec( ctr_ptr->x(),
-		       ctr_ptr->y(),
-		       ctr_ptr->z() );
+                       to_position.y(),
+   CubitVector ctr_vec( ctr_ptr->x(),
+                        ctr_ptr->y(),
+                        ctr_ptr->z() );
-  // delta_vee_1 gives major axis of ellipse (circle)
-  SPAvector delta_vee_1 = from_position - *ctr_ptr;
-  SPAvector delta_vee_2 = to_position   - *ctr_ptr;
-  if ( delta_vee_1.len() < CUBIT_RESABS*.000001 )
-      PRINT_ERROR("Zero length distance to center point.\n");
-      return (EDGE*) NULL;
-  if ( delta_vee_2.len() < CUBIT_RESABS*.000001 )
-  SPAunit_vector normal = normalise( delta_vee_1 * delta_vee_2 );
-  // Since this is a normalised SPAvector, its length should be 1.0.
-  // If it is not, then the delta_vee_1 and delta_vee_2
-  // vectors are collinear and we have to manually set the normal
-  // SPAvector. Assume that this is being done in FASTQ and set the normal
-  // to be the Z axis.
-  if (normal.len() == 0.0)
-      // The start and end vertex are in the same SPAposition, or they are
-      // 180 degrees opposed.
+     // delta_vee_1 gives major axis of ellipse (circle)
+   SPAvector delta_vee_1 = from_position - *ctr_ptr;
+   SPAvector delta_vee_2 = to_position   - *ctr_ptr;
+   if ( delta_vee_1.len() < CUBIT_RESABS*.000001 )
+     PRINT_ERROR("Zero length distance to center point.\n");
+     return (EDGE*) NULL;
+   if ( delta_vee_2.len() < CUBIT_RESABS*.000001 )
+   SPAunit_vector normal = normalise( delta_vee_1 * delta_vee_2 );
+     // Since this is a normalised SPAvector, its length should be 1.0.
+     // If it is not, then the delta_vee_1 and delta_vee_2
+     // vectors are collinear and we have to manually set the normal
+     // SPAvector. Assume that this is being done in FASTQ and set the normal
+     // to be the Z axis.
+   if (normal.len() == 0.0)
+        // The start and end vertex are in the same SPAposition, or they are
+        // 180 degrees opposed.
       normal.set_x(0.0);
       normal.set_y(0.0);
       normal.set_z(1.0);
-  double radius_ratio = delta_vee_2.len() / delta_vee_1.len();
+   double radius_ratio = delta_vee_2.len() / delta_vee_1.len();
-  // if radius_ratio is not 1.0, then this code probably won't produce
-  // the intended geometry since delta_vee_1 does not necessarily
-  // represent the major axis of an ellipse unless it is circular
-  outcome result;
-  if ( radius_ratio <= 0.999 || radius_ratio > 1.001 )
+     // if radius_ratio is not 1.0, then this code probably won't produce
+     // the intended geometry since delta_vee_1 does not necessarily
+     // represent the major axis of an ellipse unless it is circular
+   outcome result;
+   if ( radius_ratio <= 0.999 || radius_ratio > 1.001 )
       EDGE_ptr = make_spiral_EDGE(from, to, ctr_ptr, sense);
-  else
+   else
       PRINT_DEBUG_5( "radius ratio = %f\n", radius_ratio);
-      // Calculate the included angle between from and to on the
-      // circular ellipse
+        // Calculate the included angle between from and to on the
+        // circular ellipse
       CubitVector cubit_normal (normal.x(), normal.y(), normal.z());
       CubitVector cubit_from = from_vec - ctr_vec;
       CubitVector cubit_to = to_vec - ctr_vec;
       double incl_angle = cubit_normal.vector_angle ( cubit_from,
                                                       cubit_to );
       if (incl_angle == 0.0)
-	incl_angle = 2.0 * CUBIT_PI;
+          incl_angle = 2.0 * CUBIT_PI;
       double start_angle = 0.0;
       double end_angle = incl_angle;
       if (radius_ratio > 1.0)
-	  delta_vee_1 = delta_vee_2;
-	  radius_ratio = 1.0 / radius_ratio;
-	  start_angle = -incl_angle;
-	  end_angle = 0.0;
+         delta_vee_1 = delta_vee_2;
+         radius_ratio = 1.0 / radius_ratio;
+         start_angle = -incl_angle;
+         end_angle = 0.0;
       result = api_mk_ed_ellipse ( *ctr_ptr,
@@ -5118,26 +5113,26 @@
                                    start_angle,
                                    end_angle,
                                    EDGE_ptr );
       PRINT_ERROR("In AGE:make_elliptical_EDGE.\n"
                   "ACIS api_mk_ed_ellipse function failed\n");
       if ( from == NULL || to == NULL )
-	  PRINT_ERROR("In AGE:make_elliptical_EDGE.\n"
-		      "       Input VERTEX is NULL\n");
+         PRINT_ERROR("In AGE:make_elliptical_EDGE.\n"
+                     "       Input VERTEX is NULL\n");
-  else
+   else
@@ -5145,7 +5140,7 @@
       return EDGE_ptr ;
@@ -5158,30 +5153,30 @@
 // Creation Date : 12/10/99
 EDGE* AcisModifyEngine::make_circular_EDGE( VERTEX* from,
-					    VERTEX* to,
-					    SPAposition* third_pt ) const
+                                              VERTEX* to,
+                                              SPAposition* third_pt ) const
   assert (from != NULL);
   assert (to != NULL);
   assert (third_pt != NULL);
-  // get the 3 points
+    // get the 3 points
   SPAposition start_pt = from->geometry()->coords();
   SPAposition end_pt = to->geometry()->coords();
-  // create the arc
+    // create the arc
   EDGE *e_arc;
   outcome result = api_curve_arc_3pt(start_pt, *third_pt, end_pt,
                                      FALSE, e_arc);
   if (!result.ok())
-      AcisQueryEngine::instance()->ACIS_API_error(result);
-      return NULL;
+    AcisQueryEngine::instance()->ACIS_API_error(result);
+    return NULL;
   e_arc->set_start(from);
   from->add_edge(e_arc);
   e_arc->set_end (to);
@@ -5204,91 +5199,91 @@
 EDGE* AcisModifyEngine::make_spiral_EDGE( VERTEX* from,
-					  VERTEX* to,
-					  bool sense) const
+                                            VERTEX* to,
+                                            bool sense) const
       PRINT_ERROR("In AcisModifyEngine::make_spiral_EDGE\n"
                   "       Input spiral center is invalid (NULL pointer).\n");
-  // NOTE: This function assumes that vertices from, to, and ctr lie in the
-  // X-Y plane.
-  if (from_position.z() != to_position.z() ||
-      from_position.z() != ctr_ptr->z()) {
-    PRINT_ERROR("In AcisModifyEngine::make_spiral_EDGE\n"
-		"       Points must be in the constant-z plane.\n");
-    return (EDGE *)NULL;
+     // NOTE: This function assumes that vertices from, to, and ctr lie in the
+     // X-Y plane.
+   if (from_position.z() != to_position.z() ||
+       from_position.z() != ctr_ptr->z()) {
+      PRINT_ERROR("In AcisModifyEngine::make_spiral_EDGE\n"
+                  "       Points must be in the constant-z plane.\n");
+      return (EDGE *)NULL;
-		      to_position.y(),
-  //CubitVector ctr_vec( ctr_ptr->x(),
-  //                     ctr_ptr->y(),
-  //                     ctr_ptr->z() );
+                       to_position.y(),
+   //CubitVector ctr_vec( ctr_ptr->x(),
+   //                     ctr_ptr->y(),
+   //                     ctr_ptr->z() );
-  CubitVector side1( delta_vee_1.x(),
-		     delta_vee_1.y(),
-		     delta_vee_1.z()) ;
+   CubitVector side1( delta_vee_1.x(),
+                      delta_vee_1.y(),
+                      delta_vee_1.z()) ;
-  CubitVector side2( delta_vee_2.x(),
-		     delta_vee_2.y(),
-		     delta_vee_2.z()) ;
+   CubitVector side2( delta_vee_2.x(),
+                      delta_vee_2.y(),
+                      delta_vee_2.z()) ;
-  CubitVector center( ctr_ptr->x(),
-		      ctr_ptr->y(),
-		      ctr_ptr->z()) ;
+   CubitVector center( ctr_ptr->x(),
+                       ctr_ptr->y(),
+                       ctr_ptr->z()) ;
-  // Calcualate parameters for the spiral. See FASTQ source, arcpar.f
-  double radius1 = side1.length();
-  double radius2 = side2.length();
+     // Calcualate parameters for the spiral. See FASTQ source, arcpar.f
+   double radius1 = side1.length();
+   double radius2 = side2.length();
-  double theta1 = atan2(side1.y(), side1.x());
-  double theta2 = atan2(side2.y(), side2.x());
-  if (sense && theta2 <= theta1)
+   double theta1 = atan2(side1.y(), side1.x());
+   double theta2 = atan2(side2.y(), side2.x());
+   if (sense && theta2 <= theta1)
       theta2 += 2.0 * CUBIT_PI;
-  if (!sense && theta1 <= theta2)
+   if (!sense && theta1 <= theta2)
       theta1 += 2.0 * CUBIT_PI;
-  double total_angle = theta2 - theta1;
+   double total_angle = theta2 - theta1;
-  double xk = log(radius2 / radius1) / (theta2 - theta1);
-  double xa = radius2 / exp(xk * theta2);
+   double xk = log(radius2 / radius1) / (theta2 - theta1);
+   double xa = radius2 / exp(xk * theta2);
-  // Calculate points at 2.0 degree intervals
-  int number_points = int(total_angle * 180.0 / CUBIT_PI / 2.0 + 0.5);
-  number_points = number_points < 20 ? 20 : number_points;
+     // Calculate points at 2.0 degree intervals
+   int number_points = int(total_angle * 180.0 / CUBIT_PI / 2.0 + 0.5);
+   number_points = number_points < 20 ? 20 : number_points;
-  SPAposition *pos_array = new SPAposition [number_points];
+   SPAposition *pos_array = new SPAposition [number_points];
-  pos_array[0].set_x(from_vec.x());
-  pos_array[0].set_y(from_vec.y());
-  pos_array[0].set_z(from_vec.z());
+   pos_array[0].set_x(from_vec.x());
+   pos_array[0].set_y(from_vec.y());
+   pos_array[0].set_z(from_vec.z());
-  pos_array[number_points - 1].set_x(to_vec.x());
-  pos_array[number_points - 1].set_y(to_vec.y());
-  pos_array[number_points - 1].set_z(to_vec.z());
+   pos_array[number_points - 1].set_x(to_vec.x());
+   pos_array[number_points - 1].set_y(to_vec.y());
+   pos_array[number_points - 1].set_z(to_vec.z());
-  for (int i=1; i < number_points-1; i++)
+   for (int i=1; i < number_points-1; i++)
       double theta = theta1 + total_angle * ((double)i/(double)number_points);
       double radius = xa * exp(xk * theta);
       double x = center.x() + radius * cos(theta);
@@ -5297,49 +5292,49 @@
       pos_array[i].set_x(x);
       pos_array[i].set_y(y);
       pos_array[i].set_z(to_vec.z());
-  // calculate default tangent directions using up to three points
-  // at the ends of the point array.
-  SPAunit_vector uv1(0, 0, 0);
-  SPAunit_vector uv2(0, 0, 0);
+     // calculate default tangent directions using up to three points
+     // at the ends of the point array.
+   SPAunit_vector uv1(0, 0, 0);
+   SPAunit_vector uv2(0, 0, 0);
-  outcome result;
+   outcome result;
-  // fifth SPAparameter 0.0 -> interpolate the sequence of points.
-  result = api_mk_ed_cubic(number_points, pos_array,
-			   uv1, uv2, 0.0, EDGE_ptr);
+     // fifth SPAparameter 0.0 -> interpolate the sequence of points.
+   result = api_mk_ed_cubic(number_points, pos_array,
+                            uv1, uv2, 0.0, EDGE_ptr);
-  // Free memory
-  delete [] pos_array;
+     // Free memory
+   delete [] pos_array;
-  if ( !result.ok() || EDGE_ptr == NULL )
+   if ( !result.ok() || EDGE_ptr == NULL )
       PRINT_ERROR("ACIS api_mk_ed_cubic function failed\n");
-	  PRINT_ERROR("In AGE:make_spiral_EDGE.\n"
+         PRINT_ERROR("In AGE:make_spiral_EDGE.\n"
-  else
+   else
       EDGE_ptr->set_end ( to );
-  return EDGE_ptr;
+   return EDGE_ptr;
 // Purpose       : Create a curve on a surface.
@@ -5353,17 +5348,17 @@
 // Creation Date : 05/15/97
 EDGE* AcisModifyEngine::make_surface_EDGE( VERTEX* from_VERTEX,
-					   VERTEX* to_VERTEX,
-					   FACE *FACE_ptr,
-					   const CubitVector &plane_normal,
-					   const CubitVector *third_point) const
+                                             VERTEX* to_VERTEX,
+                                             FACE *FACE_ptr,
+                                             const CubitVector &plane_normal,
+                                             const CubitVector *third_point) const
-  //Now create a cutting plane using the normal passed in.  This
-  //normal should point sort of tangential to the surface.  We
-  //want the plane to intersect the surface.
+    //Now create a cutting plane using the normal passed in.  This
+    //normal should point sort of tangential to the surface.  We
+    //want the plane to intersect the surface.
   SPAposition const plane_point = from_VERTEX->geometry()->coords();
   SPAunit_vector const normal_vector( plane_normal.x(), plane_normal.y(),
-				      plane_normal.z() );
+                                   plane_normal.z() );
   plane const new_plane( plane_point, normal_vector );
@@ -5373,35 +5368,35 @@
   new_plane.eval( pos_2, point_2 );
   new_plane.eval( pos_3, point_3 );
-  // Get the size of the model so we can create an "infinite"
-  // cutting plane
+    // Get the size of the model so we can create an "infinite"
+    // cutting plane
-  // Create the infinite plane, get a FACE
+    // Create the infinite plane, get a FACE
-      PRINT_ERROR("In AcisModifyEngine::make_surface_EDGE"
-		  "       Cannot create infinite plane cutting tool using \n"
-		  "       the give surface. \n");
-      return (EDGE*)NULL;
+    PRINT_ERROR("In AcisModifyEngine::make_surface_EDGE"
+                "       Cannot create infinite plane cutting tool using \n"
+                "       the give surface. \n");
+    return (EDGE*)NULL;
   FACE *FACE_1 = sheet_body->lump()->shell()->first_face();
-  // Copy the FACE
+    // Copy the FACE
   FACE *FACE_2 = make_FACE( FACE_ptr );
-  // Now we can create a body representing the intersection
-  // of the infinite plane and the passed in surface
+    // Now we can create a body representing the intersection
+    // of the infinite plane and the passed in surface
   EDGE* new_EDGE = NULL;
   BODY *intersect_BODY = NULL;
   LUMP *cur_LUMP = NULL;
@@ -5409,199 +5404,199 @@
   COEDGE *cur_COEDGE;
   WIRE *cur_WIRE;
-  // Get the intersection
+    // Get the intersection
   outcome result_1 = api_fafa_int ( FACE_1, FACE_2, intersect_BODY );
-  // for some reason a NULL body still returns an ok result. - KGM
+    // for some reason a NULL body still returns an ok result. - KGM
   if (intersect_BODY == NULL)
-  // Make sure it was OK, and get the appropriate entity
-  // Get a WIRE if it's there
+    // Make sure it was OK, and get the appropriate entity
+    // Get a WIRE if it's there
   if ( !result_1.ok() || intersect_BODY->wire() == NULL ||
        intersect_BODY->wire()->coedge() == NULL ||
        intersect_BODY->wire()->coedge()->edge() == NULL )
       // If there was no WIRE, see if there is a lump
-      if ( result_1.ok() && intersect_BODY->lump() != NULL &&
-	   intersect_BODY->lump()->shell() != NULL &&
-	   intersect_BODY->lump()->shell()->wire() != NULL &&
-	   intersect_BODY->lump()->shell()->wire()->coedge() != NULL &&
-	   intersect_BODY->lump()->shell()->wire()->coedge()->edge() != NULL )
-	  PRINT_DEBUG_18( "Using wire from lumps.\n");
-	  cur_LUMP = intersect_BODY->lump();
-	  cur_WIRE = cur_LUMP->shell()->wire();
-      else
-	  PRINT_ERROR("ACIS api_fafa_int function failed\n");
-	  AcisQueryEngine::instance()->ACIS_API_error (result_1);
+    if ( result_1.ok() && intersect_BODY->lump() != NULL &&
+         intersect_BODY->lump()->shell() != NULL &&
+         intersect_BODY->lump()->shell()->wire() != NULL &&
+         intersect_BODY->lump()->shell()->wire()->coedge() != NULL &&
+         intersect_BODY->lump()->shell()->wire()->coedge()->edge() != NULL )
+      PRINT_DEBUG_18( "Using wire from lumps.\n");
+      cur_LUMP = intersect_BODY->lump();
+      cur_WIRE = cur_LUMP->shell()->wire();
-  else
+    else
-      PRINT_DEBUG_18( "Using wire straight from BODY\n");
-      cur_WIRE = intersect_BODY->wire();
+      PRINT_ERROR("ACIS api_fafa_int function failed\n");
+      AcisQueryEngine::instance()->ACIS_API_error (result_1);
+  else
+    PRINT_DEBUG_18( "Using wire straight from BODY\n");
+    cur_WIRE = intersect_BODY->wire();
-  // Now find an EDGE that the points lie on.
-  // Start by going through each LUMP, if LUMPs are being used.
+    // Now find an EDGE that the points lie on.
+    // Start by going through each LUMP, if LUMPs are being used.
   LUMP* start_LUMP = cur_LUMP;
   CURVE *geometry = NULL;
   do
-      PRINT_DEBUG_18( "**New Lump check**\n");
+    PRINT_DEBUG_18( "**New Lump check**\n");
       // Now go through the wires, coedges, and edges
       // to find an edge that the points lie on
-      WIRE* start_WIRE = cur_WIRE;
+    WIRE* start_WIRE = cur_WIRE;
+    do
+        // Get the first coedge in this wire
+      COEDGE* start_COEDGE = cur_WIRE->coedge();
+      cur_COEDGE = start_COEDGE;
+        // Check it and loop through the rest
       do
-	  // Get the first coedge in this wire
-	  COEDGE* start_COEDGE = cur_WIRE->coedge();
-	  cur_COEDGE = start_COEDGE;
-	  // Check it and loop through the rest
-	  do
-	      PRINT_DEBUG_18( "  **New CoEdge check**\n");
-	      cur_EDGE =  cur_COEDGE->edge();
-	      geometry = cur_EDGE->geometry();
-	      // See if this is close enough to
-	      // the start and end points
-	      if (geometry != NULL)
-		  SPAposition new_point;
-		  // Make sure start vertex is on curve
-		  geometry->equation().point_perp(from_VERTEX->geometry()->coords(),
-						  new_point);
-		  PRINT_DEBUG_18( "\n\tNew Point 1: (%g, %g, %g)\n"
-				  "\t  From Vert: (%g, %g, %g)\n",
-				  new_point.x(),
-				  new_point.y(),
-				  new_point.z(),
-				  from_VERTEX->geometry()->coords().x(),
-				  from_VERTEX->geometry()->coords().y(),
-				  from_VERTEX->geometry()->coords().z());
-		  if (AcisQueryEngine::instance()->about_spatially_equal(from_VERTEX->geometry()->coords(),
-									 new_point, 1.0))
-		      // Make sure end vertex is on curve
-		      geometry->equation().point_perp(to_VERTEX->geometry()->coords(),
-						      new_point);
-		      PRINT_DEBUG_18( "\tNew Point 2: (%g, %g, %g)\n"
-				      "\t    To Vert: (%g, %g, %g) \n",
-				      new_point.x(),
-				      new_point.y(),
-				      new_point.z(),
-				      to_VERTEX->geometry()->coords().x(),
-				      to_VERTEX->geometry()->coords().y(),
-				      to_VERTEX->geometry()->coords().z());
-		      if (AcisQueryEngine::instance()->about_spatially_equal(to_VERTEX->geometry()->coords(),
-									     new_point, 1.0))
-			  // You found it!!!
-			  cur_WIRE = NULL;
-			  start_LUMP = NULL;
-			  break;
-	      cur_COEDGE = cur_COEDGE->next();
-	      geometry = NULL; // Make sure you indicate we haven't found geom
-	    }while (cur_COEDGE != NULL && cur_COEDGE != start_COEDGE);
-	  // You break out of this do-while loop when
-	  //   a) You find the correct EDGE
-	  //   b) There are no more COEDGEs in this WIRE
-	  //   c) You loop through all of the COEDGES in this WIRE
+        PRINT_DEBUG_18( "  **New CoEdge check**\n");
+        cur_EDGE =  cur_COEDGE->edge();
+        geometry = cur_EDGE->geometry();
+          // See if this is close enough to
+          // the start and end points
+        if (geometry != NULL)
+          SPAposition new_point;
+            // Make sure start vertex is on curve
+          geometry->equation().point_perp(from_VERTEX->geometry()->coords(),
+                                          new_point);
+          PRINT_DEBUG_18( "\n\tNew Point 1: (%g, %g, %g)\n"
+                     "\t  From Vert: (%g, %g, %g)\n",
+                     new_point.x(),
+                     new_point.y(),
+                     new_point.z(),
+                     from_VERTEX->geometry()->coords().x(),
+                     from_VERTEX->geometry()->coords().y(),
+                     from_VERTEX->geometry()->coords().z());
+          if (AcisQueryEngine::instance()->about_spatially_equal(from_VERTEX->geometry()->coords(),
+                                          new_point, 1.0))
+              // Make sure end vertex is on curve
+            geometry->equation().point_perp(to_VERTEX->geometry()->coords(),
+                                            new_point);
+            PRINT_DEBUG_18( "\tNew Point 2: (%g, %g, %g)\n"
+                       "\t    To Vert: (%g, %g, %g) \n",
+                       new_point.x(),
+                       new_point.y(),
+                       new_point.z(),
+                       to_VERTEX->geometry()->coords().x(),
+                       to_VERTEX->geometry()->coords().y(),
+                       to_VERTEX->geometry()->coords().z());
+            if (AcisQueryEngine::instance()->about_spatially_equal(to_VERTEX->geometry()->coords(),
+                                            new_point, 1.0))
+                // You found it!!!
+              cur_WIRE = NULL;
+              start_LUMP = NULL;
+              break;
+        cur_COEDGE = cur_COEDGE->next();
+        geometry = NULL; // Make sure you indicate we haven't found geom
+      }while (cur_COEDGE != NULL && cur_COEDGE != start_COEDGE);
+        // You break out of this do-while loop when
+        //   a) You find the correct EDGE
+        //   b) There are no more COEDGEs in this WIRE
+        //   c) You loop through all of the COEDGES in this WIRE
-	  // Print out some debug diagnostics
-	  if (DEBUG_FLAG(18))
-	      if (cur_COEDGE == NULL)
-		PRINT_INFO("Exit loop because CoEdge was NULL\n");
-	      else if (cur_COEDGE == start_COEDGE)
-		PRINT_INFO("Exit loop because cur_COEDGE == start_COEDGE\n");
-	      else
-		PRINT_INFO("Exit loop for Other Reason!!!\n");
+        // Print out some debug diagnostics
+      if (DEBUG_FLAG(18))
+        if (cur_COEDGE == NULL)
+          PRINT_INFO("Exit loop because CoEdge was NULL\n");
+        else if (cur_COEDGE == start_COEDGE)
+          PRINT_INFO("Exit loop because cur_COEDGE == start_COEDGE\n");
+        else
+          PRINT_INFO("Exit loop for Other Reason!!!\n");
-	  // cur_WIRE is NULL if the correct EDGE has been found
-	  if (cur_WIRE)
-	    cur_WIRE = cur_WIRE->next();
-	}while (cur_WIRE && cur_WIRE != start_WIRE);
+        // cur_WIRE is NULL if the correct EDGE has been found
+      if (cur_WIRE)
+        cur_WIRE = cur_WIRE->next();
+    }while (cur_WIRE && cur_WIRE != start_WIRE);
       //   b) There are no more WIREs in this WIRE list
       //   c) You loop through all the WIREs
-	  if (cur_WIRE == NULL)
-	    PRINT_DEBUG_18( "Exit loop because Wire was NULL\n");
-	  else if (cur_WIRE == start_WIRE)
-	    PRINT_DEBUG_18( "Exit loop because cur_WIRE == start_WIRE\n");
-	  else
-	    PRINT_DEBUG_18( "Exit loop for Other Reason!!!\n");
+      if (cur_WIRE == NULL)
+        PRINT_DEBUG_18( "Exit loop because Wire was NULL\n");
+      else if (cur_WIRE == start_WIRE)
+        PRINT_DEBUG_18( "Exit loop because cur_WIRE == start_WIRE\n");
+      else
+        PRINT_DEBUG_18( "Exit loop for Other Reason!!!\n");
       // If we are using lumps, go to the next lump
       // and get its first wire.
-      if (start_LUMP)
-	  cur_LUMP = cur_LUMP->next();
-	  if (cur_LUMP)
+    if (start_LUMP)
+      cur_LUMP = cur_LUMP->next();
+      if (cur_LUMP)
-    }while (start_LUMP && cur_LUMP && start_LUMP != cur_LUMP);
-  //   b) There are no more LUMPs in the BODY
-  //   c) You looped through all the LUMPs in the BODY
-  //   d) We weren't using LUMPs to start with
+  }while (start_LUMP && cur_LUMP && start_LUMP != cur_LUMP);
+    //   b) There are no more LUMPs in the BODY
+    //   c) You looped through all the LUMPs in the BODY
+    //   d) We weren't using LUMPs to start with
   if (DEBUG_FLAG(18))
-      if (start_LUMP == NULL)
-	PRINT_INFO("Exit loop because start_LUMP was NULL\n");
-      else if (cur_LUMP == NULL)
-	PRINT_INFO("Exit loop because cur_LUMP == NULL\n");
-      else if (cur_LUMP == start_LUMP)
-	PRINT_INFO("Exit loop because cur_WIRE == start_WIRE\n");
-      else
+    if (start_LUMP == NULL)
+      PRINT_INFO("Exit loop because start_LUMP was NULL\n");
+    else if (cur_LUMP == NULL)
+      PRINT_INFO("Exit loop because cur_LUMP == NULL\n");
+    else if (cur_LUMP == start_LUMP)
+      PRINT_INFO("Exit loop because cur_WIRE == start_WIRE\n");
+    else
-  // Make sure you found something valid
+    // Make sure you found something valid
   if ( geometry == NULL )
-      PRINT_ERROR("ACIS failed to find geometry for new curve.\n");
+    PRINT_ERROR("ACIS failed to find geometry for new curve.\n");
   PRINT_DEBUG_18( " The EDGE coords:\n"
-		  "   start: (%g, %g, %g)\n"
-		  "     end: (%g, %g, %g)\n",
-		  cur_EDGE->end_pos().x(),
-		  cur_EDGE->end_pos().y(),
-		  cur_EDGE->end_pos().z(),
-		  cur_EDGE->start_pos().x(),
-		  cur_EDGE->start_pos().y(),
-		  cur_EDGE->start_pos().z());
+             "   start: (%g, %g, %g)\n"
+             "     end: (%g, %g, %g)\n",
+             cur_EDGE->end_pos().x(),
+             cur_EDGE->end_pos().y(),
+             cur_EDGE->end_pos().z(),
+             cur_EDGE->start_pos().x(),
+             cur_EDGE->start_pos().y(),
+             cur_EDGE->start_pos().z());
-  // Handle special stuff for periodic curves
+    // Handle special stuff for periodic curves
   int periodic = geometry->equation().periodic();
   double period = 0.0;
   if ( periodic )
-      period = geometry->equation().param_period();
+    period = geometry->equation().param_period();
   double start_param, end_param;
   start_param = cur_EDGE->start_param();
@@ -5616,32 +5611,32 @@
   // If periodic get the params in the range of the curve's param range.
   if(periodic)
+    // forward param range
+    if(curve_range > 0.0)
-      // forward param range
-      if(curve_range > 0.0)
-	  while(v1_param < start_param - GEOMETRY_RESABS)
-	    v1_param += period;
-	  while(v1_param > end_param + GEOMETRY_RESABS)
-	    v1_param -= period;
-	  while(v2_param < start_param - GEOMETRY_RESABS)
-	    v2_param += period;
-	  while(v2_param > end_param + GEOMETRY_RESABS)
-	    v2_param -= period;
-      // reversed param range (will this ever happen?)
-      else
-	  while(v1_param < end_param - GEOMETRY_RESABS)
-	  while(v1_param > start_param + GEOMETRY_RESABS)
-	  while(v2_param < end_param - GEOMETRY_RESABS)
-	  while(v2_param > start_param + GEOMETRY_RESABS)
+      while(v1_param < start_param - GEOMETRY_RESABS)
+        v1_param += period;
+      while(v1_param > end_param + GEOMETRY_RESABS)
+        v1_param -= period;
+      while(v2_param < start_param - GEOMETRY_RESABS)
+        v2_param += period;
+      while(v2_param > end_param + GEOMETRY_RESABS)
+        v2_param -= period;
+    // reversed param range (will this ever happen?)
+    else
+      while(v1_param < end_param - GEOMETRY_RESABS)
+      while(v1_param > start_param + GEOMETRY_RESABS)
+      while(v2_param < end_param - GEOMETRY_RESABS)
+      while(v2_param > start_param + GEOMETRY_RESABS)
   double new_param_range = v2_param-v1_param;
@@ -5652,34 +5647,34 @@
   if(curve_range*new_param_range < 0.0)
     sense_int = 0;  /* REVERSED */
-  //if we have a third point and we are periodic... use
-  //it to nail down the direction.
+    //if we have a third point and we are periodic... use
+    //it to nail down the direction.
   if ( third_point != NULL && periodic )
-      SPAposition const some_point( third_point->x(),
-				    third_point->y(),
-				    third_point->z() );
-      SPAposition closest_point;
-      geometry->equation().point_perp( some_point, closest_point );
-      double some_param = geometry->equation().param( closest_point );
-      int val1 = (curve_range > 0.0);
-      int val2 = (sense_int == 1);
+    SPAposition const some_point( third_point->x(),
+                               third_point->y(),
+                               third_point->z() );
+    SPAposition closest_point;
+    geometry->equation().point_perp( some_point, closest_point );
+    double some_param = geometry->equation().param( closest_point );
+    int val1 = (curve_range > 0.0);
+    int val2 = (sense_int == 1);
-      // val1 will equal val2 for two cases.  In either case v1_param will
-      // be less than v2_param.
-      if (val1 == val2)
-	  if ( some_param < v1_param || some_param > v2_param )
-	    sense_int = !sense_int;
-      // val1 will NOT equal val2 for two cases.  In either case v1_param will
-      // be greater than v2_param.
-      else
-	  if ( some_param < v2_param || some_param > v1_param )
+    // val1 will equal val2 for two cases.  In either case v1_param will
+    // be less than v2_param.
+    if (val1 == val2)
+      if ( some_param < v1_param || some_param > v2_param )
+        sense_int = !sense_int;
+    // val1 will NOT equal val2 for two cases.  In either case v1_param will
+    // be greater than v2_param.
+    else
+      if ( some_param < v2_param || some_param > v1_param )
   REVBIT sense;
   if(sense_int == 0)
@@ -5687,13 +5682,13 @@
   else
     sense = FORWARD;
-  // Actually create the new EDGE
+    // Actually create the new EDGE
   API_BEGIN;
   new_EDGE = new EDGE ( from_VERTEX, to_VERTEX, geometry, sense );
   API_END;
-  //Delete the body and the sheet_body and the other body associated with
-  //this other face...
+    //Delete the body and the sheet_body and the other body associated with
+    //this other face...
   AcisQueryEngine::instance()->delete_ACIS_BODY(intersect_BODY, CUBIT_TRUE);
   AcisQueryEngine::instance()->delete_ACIS_BODY(sheet_body, CUBIT_TRUE);
   AcisQueryEngine::instance()->delete_ACIS_BODY(AcisQueryEngine::instance()->get_BODY_of_ENTITY(FACE_2), CUBIT_TRUE);
@@ -5713,34 +5708,34 @@
 EDGE* AcisModifyEngine::make_spline_EDGE( VERTEX* from_VERTEX,
-					  SPAposition* pos_array,
-					  int number_points ) const
+                                            SPAposition* pos_array,
+                                            int number_points ) const
-  // Create the spline curve and attach it to the EDGE
+    // Create the spline curve and attach it to the EDGE
   outcome result = api_curve_spline(number_points, pos_array, 0, 0, EDGE_ptr,
                                     FALSE, from_VERTEX == to_VERTEX);
   if (result.ok() == FALSE || EDGE_ptr == NULL)
-      PRINT_ERROR("In AcisModifyEngine::make_spline_EDGE\n"
-		  "       ACIS function, api_mk_ed_cubic, failed\n");
+    PRINT_ERROR("In AcisModifyEngine::make_spline_EDGE\n"
+                "       ACIS function, api_mk_ed_cubic, failed\n");
   else
-      EDGE_ptr->set_start ( from_VERTEX );
-      from_VERTEX->add_edge( EDGE_ptr );
+    EDGE_ptr->set_start ( from_VERTEX );
+    from_VERTEX->add_edge( EDGE_ptr );
-      EDGE_ptr->set_end ( to_VERTEX );
-      to_VERTEX->add_edge( EDGE_ptr );
+    EDGE_ptr->set_end ( to_VERTEX );
+    to_VERTEX->add_edge( EDGE_ptr );
-      return EDGE_ptr;
+    return EDGE_ptr;
@@ -5761,26 +5756,26 @@
   leftoverBody = 0;
-  // chops the blank with the  tool, returing the body formed by subtracting the tool from the blank,
-  // and the body formed by intersecting the tool with the blank,
-  // simultaneously.
+    // chops the blank with the  tool, returing the body formed by subtracting the tool from the blank,
+	// and the body formed by intersecting the tool with the blank,
+	// simultaneously.
   if (bodysms.size() <= 1)
-      PRINT_WARNING("There is only one volume in the list. Nothing modified\n");
-      return CUBIT_FAILURE;
+    PRINT_WARNING("There is only one volume in the list. Nothing modified\n");
+    return CUBIT_FAILURE;
-  // Create new acis bodies that are copies of the original acis bodies.
-  // If something goes wrong in the choping, we can then delete our copies
-  // and the originals are intact.  If everything goes fine, we will delete
-  // the originals at that time.
+    // Create new acis bodies that are copies of the original acis bodies.
+    // If something goes wrong in the choping, we can then delete our copies
+    // and the originals are intact.  If everything goes fine, we will delete
+    // the originals at that time.
-  // pass in keep_old to the delete_owner_attrib flag; if we're not keeping
-  // old bodies, we want to keep the owner attrib, so we can pick up entities
-  // that didn't change
+    // pass in keep_old to the delete_owner_attrib flag; if we're not keeping
+    // old bodies, we want to keep the owner attrib, so we can pick up entities
+    // that didn't change
   bool delete_attribs =
-    (GeometryModifyTool::instance()->get_new_ids() || keep_old);
+      (GeometryModifyTool::instance()->get_new_ids() || keep_old);
   DLIList<BODY*> old_BODY_list;
   DLIList<BodySM*> old_BodySM_list;
@@ -5792,56 +5787,56 @@
   BODY *blank_BODY = this->copy_BODY(BODYPtr, delete_attribs);
   if (blank_BODY == NULL)
-      return CUBIT_FAILURE; // Nothing to clean up at this point.
+    return CUBIT_FAILURE; // Nothing to clean up at this point.
   BODY* outside_BODY=NULL;
   BODY* leftovers_BODY=NULL;
-  // get the tool Body
+ // get the tool Body
   BodySMPtr = bodysms.get_and_step();
   BODYPtr =  AcisQueryEngine::get_BODY(BodySMPtr);
   BODY *tool_BODY = this->copy_BODY(BODYPtr, delete_attribs);
   if (tool_BODY == NULL)
-      AcisQueryEngine::instance()->delete_ACIS_BODY(blank_BODY, CUBIT_TRUE);
+    AcisQueryEngine::instance()->delete_ACIS_BODY(blank_BODY, CUBIT_TRUE);
   // Chop the blank_BODY using the tool_BODY.
   // If this is successful, the result is blank_BODY and outside_BODY, leftovers_BODY
   outcome result = api_boolean_chop_body(tool_BODY, blank_BODY, nonreg,outside_BODY, leftovers_BODY);
   if (!result.ok() || blank_BODY == NULL ||
-      tool_BODY == NULL || blank_BODY->lump() == NULL )
+       tool_BODY == NULL || blank_BODY->lump() == NULL )
-      if( !result.ok() )
-	  PRINT_ERROR("In AcisModifyEngine::chop\n");
-	  AcisQueryEngine::instance()->ACIS_API_error(result, "chop Bodies");
-	  if (blank_BODY != NULL)
-	  if (tool_BODY != NULL)
-	    AcisQueryEngine::instance()->delete_ACIS_BODY(tool_BODY, CUBIT_TRUE);
+    if( !result.ok() )
+      PRINT_ERROR("In AcisModifyEngine::chop\n");
+      AcisQueryEngine::instance()->ACIS_API_error(result, "chop Bodies");
+      if (blank_BODY != NULL)
+      if (tool_BODY != NULL)
+        AcisQueryEngine::instance()->delete_ACIS_BODY(tool_BODY, CUBIT_TRUE);
-      if( blank_BODY->lump() == NULL )
-	  PRINT_ERROR("Bodies do not intersect\n");
-	  if (leftovers_BODY != NULL)
-	    AcisQueryEngine::instance()->delete_ACIS_BODY(leftovers_BODY, CUBIT_TRUE);
-	  if (outside_BODY != NULL)
-	    AcisQueryEngine::instance()->delete_ACIS_BODY(outside_BODY, CUBIT_TRUE);
+    if( blank_BODY->lump() == NULL )
+      PRINT_ERROR("Bodies do not intersect\n");
+      if (leftovers_BODY != NULL)
+        AcisQueryEngine::instance()->delete_ACIS_BODY(leftovers_BODY, CUBIT_TRUE);
+      if (outside_BODY != NULL)
+        AcisQueryEngine::instance()->delete_ACIS_BODY(outside_BODY, CUBIT_TRUE);
   BodySM* intersectBody = get_new_Body(BodySMPtr, BODYPtr, blank_BODY, keep_old);
   intersectBodies.append( intersectBody );
   BodySM* outsideBody =  get_new_Body(old_BodySM_list, old_BODY_list, outside_BODY, keep_old);
@@ -5873,60 +5868,60 @@
   DLIList<SurfaceACIS*> copied_ref_face_list(ref_face_list.size());
   CAST_LIST(ref_face_list, copied_ref_face_list, SurfaceACIS);
   if (ref_face_list.size() != copied_ref_face_list.size())
-      PRINT_ERROR("Non-ACIS surface at %s:%d\n", __FILE__, __LINE__ );
+    PRINT_ERROR("Non-ACIS surface at %s:%d\n", __FILE__, __LINE__ );
   // Loop on FACEs.  We will work on reversing surfaces from one body at a time.
   copied_ref_face_list.reset();
   while( copied_ref_face_list.size() )
-      BODY *copied_BODY_ptr;
+    BODY *copied_BODY_ptr;
 #ifdef BOYD07
-      DLIList<SurfaceACIS*> reverse_face_list;
+    DLIList<SurfaceACIS*> reverse_face_list;
 #endif
-      DLIList<FACE*> reverse_FACE_list;
-      if( get_copied_FACES_of_body( copied_ref_face_list, reverse_FACE_list,
-				    copied_BODY_ptr ) == CUBIT_FAILURE )
-	break;
+    DLIList<FACE*> reverse_FACE_list;
+    if( get_copied_FACES_of_body( copied_ref_face_list, reverse_FACE_list,
+      copied_BODY_ptr ) == CUBIT_FAILURE )
+      break;
-      // Get original Body and BODY
-      BodySM *body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY( copied_BODY_ptr );
-      BODY *BODY_ptr = AcisQueryEngine::get_BODY(body_ptr);
+    // Get original Body and BODY
+    BodySM *body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY( copied_BODY_ptr );
+    BODY *BODY_ptr = AcisQueryEngine::get_BODY(body_ptr);
-      // Now cleanout the owner attributes from the copied BODY, if required
-      if( delete_attribs )
-	AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copied_BODY_ptr);
+    // Now cleanout the owner attributes from the copied BODY, if required
+    if( delete_attribs )
+      AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copied_BODY_ptr);
-      reverse_FACE_list.reset();
-      for( i=reverse_FACE_list.size(); i--; )
-	  FACE *FACE_ptr = reverse_FACE_list.get_and_step();
-	  result = api_reverse_face( FACE_ptr );
+    reverse_FACE_list.reset();
+    for( i=reverse_FACE_list.size(); i--; )
+      FACE *FACE_ptr = reverse_FACE_list.get_and_step();
+      result = api_reverse_face( FACE_ptr );
-	  if (!result.ok())
-	      //TODO: get ref_face from FACE
-	      //PRINT_INFO("Surface %d did not reverse\n", ref_face->id());
-	      PRINT_INFO("Surface did not reverse\n");
+      if (!result.ok())
+        //TODO: get ref_face from FACE
+        //PRINT_INFO("Surface %d did not reverse\n", ref_face->id());
+         PRINT_INFO("Surface did not reverse\n");
-      BodySM* new_body_ptr = get_new_Body( body_ptr, BODY_ptr, copied_BODY_ptr, CUBIT_FALSE );
+    BodySM* new_body_ptr = get_new_Body( body_ptr, BODY_ptr, copied_BODY_ptr, CUBIT_FALSE );
-      if( new_body_ptr!=NULL && new_body_ptr!=body_ptr )
-	  PRINT_INFO( "Created new volume\n" );
-      else if( new_body_ptr!=NULL && new_body_ptr==body_ptr )
-	  PRINT_INFO( "Modified volume\n" );
-      else
-	PRINT_WARNING( "Volume was not modified\n" );
+    if( new_body_ptr!=NULL && new_body_ptr!=body_ptr )
+      PRINT_INFO( "Created new volume\n" );
+    else if( new_body_ptr!=NULL && new_body_ptr==body_ptr )
+      PRINT_INFO( "Modified volume\n" );
+    else
+      PRINT_WARNING( "Volume was not modified\n" );
   return CUBIT_SUCCESS;
@@ -6066,2006 +6061,2006 @@
   PRINT_ERROR( "This function is not available in ACIS versions below 800\n" );
 #else
-  CubitStatus AcisModifyEngine::thicken( DLIList<BodySM*>& bodies,
-					 DLIList<BodySM*>& new_body_list,
-					 double depth,
-					 bool both) const
-      if (bodies.size() < 1)
-	  PRINT_WARNING("There are no volumes in the list. Nothing modified\n");
+CubitStatus AcisModifyEngine::thicken( DLIList<BodySM*>& bodies,
+                                       DLIList<BodySM*>& new_body_list,
+                                       double depth,
+                                       bool both) const
+   if (bodies.size() < 1)
+      PRINT_WARNING("There are no volumes in the list. Nothing modified\n");
-      SPAposition box_l(0,0,0);
-      SPAposition box_h(0,0,0);
+   SPAposition box_l(0,0,0);
+   SPAposition box_h(0,0,0);
-      BODY* in_out_BODY;
-      DLIList<BODY*> old_BODY_list;
-      DLIList<BodySM*> old_Body_list;
+   BODY* in_out_BODY;
+   DLIList<BODY*> old_BODY_list;
+   DLIList<BodySM*> old_Body_list;
-      for(int i = bodies.size(); i >= 1 ; i-- ){
+   for(int i = bodies.size(); i >= 1 ; i-- ){
-	BodySM* BodyPtr = bodies.get_and_step();
-	BodySM* new_bodysm;
-	BodyACIS* acis_body = dynamic_cast<BodyACIS*>(BodyPtr);
-	if (!acis_body)
-	    PRINT_ERROR("Non-ACIS BodySM passed to AcisModifyEngine::thicken.\n");
-	    continue;
+      BodySM* BodyPtr = bodies.get_and_step();
+      BodySM* new_bodysm;
+      BodyACIS* acis_body = dynamic_cast<BodyACIS*>(BodyPtr);
+      if (!acis_body)
+        PRINT_ERROR("Non-ACIS BodySM passed to AcisModifyEngine::thicken.\n");
+        continue;
-	BODY* BODYPtr =  AcisQueryEngine::get_BODY(BodyPtr);
+      BODY* BODYPtr =  AcisQueryEngine::get_BODY(BodyPtr);
-	in_out_BODY = this->copy_BODY(BODYPtr, CUBIT_FALSE);
+      in_out_BODY = this->copy_BODY(BODYPtr, CUBIT_FALSE);
-	if (in_out_BODY == NULL)
+      if (in_out_BODY == NULL)
-	if( !acis_body->is_sheet_body() )
-	    PRINT_WARNING("Only surface volumes should be thickened\n"
-			  "       results may be different than expected\n");
+      if( !acis_body->is_sheet_body() )
+         PRINT_WARNING("Only surface volumes should be thickened\n"
+            "       results may be different than expected\n");
-	outcome result = api_sheet_thicken(in_out_BODY, depth, both, box_l, box_h);
+      outcome result = api_sheet_thicken(in_out_BODY, depth, both, box_l, box_h);
-	if (!result.ok())//
-	    if(result.error_number() == 41000)               // checking surface normals
-		PRINT_ERROR("In AcisModifyEngine::thicken\n"
-			    "       Surface normals may not be consistent\n"
-			    "       use: validate normal reverse\n");
+      if (!result.ok())//
+         if(result.error_number() == 41000)               // checking surface normals
+            PRINT_ERROR("In AcisModifyEngine::thicken\n"
+                "       Surface normals may not be consistent\n"
+                "       use: validate normal reverse\n");
-	    PRINT_ERROR("In AcisModifyEngine::thicken \n");
-	new_bodysm = get_new_Body(BodyPtr, BODYPtr, in_out_BODY, CUBIT_FALSE);
-	if (new_bodysm)
-	  new_body_list.append(new_bodysm);
+         PRINT_ERROR("In AcisModifyEngine::thicken \n");
-      return CUBIT_SUCCESS;
+      new_bodysm = get_new_Body(BodyPtr, BODYPtr, in_out_BODY, CUBIT_FALSE);
+      if (new_bodysm)
+        new_body_list.append(new_bodysm);
+  return CUBIT_SUCCESS;
 #endif
-  // Purpose       : Boolean Operation of a list of Bodies: unite
-  // Special Notes :
-  // Creator       : Malcolm J. Panthaki
-  // Creation Date : 10/31/96
-  CubitStatus AcisModifyEngine::unite(DLIList<BodySM*> &bodies,
-				      DLIList<BodySM*> &newBodies,
+// Purpose       : Boolean Operation of a list of Bodies: unite
+// Special Notes :
+// Creator       : Malcolm J. Panthaki
+// Creation Date : 10/31/96
+CubitStatus AcisModifyEngine::unite(DLIList<BodySM*> &bodies,
+                                    DLIList<BodySM*> &newBodies,
                                       bool keep_old) const
-      // Union all bodies in the bodies list into a single body.
-      if (bodies.size() <= 1)
+    // Union all bodies in the bodies list into a single body.
+  if (bodies.size() <= 1)
-      // If something goes wrong in the unioning, we can then delete our copies
+    // If something goes wrong in the unioning, we can then delete our copies
-      bool delete_attribs =
+   bool delete_attribs =
-      // check if the boolean operation is regularized or nonregularized
-      BOOL_TYPE bool_type = UNION;
-      CubitBoolean boolean_regularize = GeometryModifyTool::instance()->boolean_regularize();
+   // check if the boolean operation is regularized or nonregularized
+     BOOL_TYPE bool_type = UNION;
+	CubitBoolean boolean_regularize = GeometryModifyTool::instance()->boolean_regularize();
-      if (boolean_regularize == FALSE)
+	if (boolean_regularize == FALSE)
-	  bool_type = NONREG_UNION;
+		bool_type = NONREG_UNION;
-      old_Body_list.append(BodyPtr);
-      old_BODY_list.append(BODYPtr);
+  old_Body_list.append(BodyPtr);
+  old_BODY_list.append(BODYPtr);
-      BODY *master = this->copy_BODY(BODYPtr, delete_attribs);
-      if (master == NULL)
+  BODY *master = this->copy_BODY(BODYPtr, delete_attribs);
+  if (master == NULL)
-      // Note: one iteration less because we already pulled out one body above
-      for (int i = 1; i < bodies.size(); i++)
-	  BodyPtr = bodies.get_and_step();
-	  BODYPtr =  AcisQueryEngine::get_BODY(BodyPtr);
+    // Note: one iteration less because we already pulled out one body above
+  for (int i = 1; i < bodies.size(); i++)
+    BodyPtr = bodies.get_and_step();
+    BODYPtr =  AcisQueryEngine::get_BODY(BodyPtr);
-	  BODY *copy = this->copy_BODY(BODYPtr, delete_attribs);
-	  if (copy == NULL)
-	      AcisQueryEngine::instance()->delete_ACIS_BODY(master, CUBIT_TRUE);
+    BODY *copy = this->copy_BODY(BODYPtr, delete_attribs);
+    if (copy == NULL)
+      AcisQueryEngine::instance()->delete_ACIS_BODY(master, CUBIT_TRUE);
-	  // Do the union of the master and the copy.
-	  // If this is successful, the result is master and copy will be deleted
-	  // outcome result = api_unite(copy, master);
-	  // replaced with the api_boolean call in order to do nonregularize boolean operation
+	// Do the union of the master and the copy.
+    // If this is successful, the result is master and copy will be deleted
+    // outcome result = api_unite(copy, master);
+	// replaced with the api_boolean call in order to do nonregularize boolean operation
-	  outcome result = api_boolean (copy,master,bool_type);
+	 outcome result = api_boolean (copy,master,bool_type);
-	  if (!result.ok() || (master && master->lump() == NULL))
-	      // If there are no LUMPs in the resulting BODY, return with a failure
-	      if (master && master->lump() == NULL)
-		PRINT_ERROR("Unite produced volume with no volume - "
-			    "check for (and remove) co-incident surfaces\n");
-	      else
-		PRINT_ERROR("In AcisModifyEngine::unite\n");
+    if (!result.ok() || (master && master->lump() == NULL))
+      // If there are no LUMPs in the resulting BODY, return with a failure
+      if (master && master->lump() == NULL)
+        PRINT_ERROR("Unite produced volume with no volume - "
+                    "check for (and remove) co-incident surfaces\n");
+      else
+        PRINT_ERROR("In AcisModifyEngine::unite\n");
-	      AcisQueryEngine::instance()->ACIS_API_error(result, "unite Bodies");
-	      if (master != NULL) AcisQueryEngine::instance()->delete_ACIS_BODY(master, CUBIT_TRUE);
-	      if (copy   != NULL) AcisQueryEngine::instance()->delete_ACIS_BODY(copy, CUBIT_TRUE);
+      AcisQueryEngine::instance()->ACIS_API_error(result, "unite Bodies");
+      if (master != NULL) AcisQueryEngine::instance()->delete_ACIS_BODY(master, CUBIT_TRUE);
+      if (copy   != NULL) AcisQueryEngine::instance()->delete_ACIS_BODY(copy, CUBIT_TRUE);
-	  else {
+    else {
-	  //For nonregularized boolean, find all internal surfaces and delete
+		//For nonregularized boolean, find all internal surfaces and delete
-	  if ( bool_type == NONREG_UNION)
-	      outcome result1;
-	      // ENTITY_LIST FACES;
-	      DLIList<FACE*>  FACE_list ;
-	      FACE *this_FACE;
-	      AcisQueryEngine::instance()->get_FACEs(master,FACE_list);
-	      // loop through all faces
-	      for( int i = 0; i< FACE_list.size(); i++)
-		  this_FACE = FACE_list.get_and_step();
-		  assert( this_FACE != NULL );
-		  // Make sure this is a DOUBLE_SIDED FACE
-		  if (this_FACE->sides() == DOUBLE_SIDED)
-		      if (this_FACE->cont()==BOTH_INSIDE)
-			  // found internal faces
-			  // Now we have the FACE - unhook it  from the BODY.  Keep track of new
-			  // BODIES that are created as this is done.
-			  PRINT_INFO( " Unhooking and deleting each internal surface...\n" );
-			  BODY *new_BODY_ptr;
-			  result1 = api_unhook_face( this_FACE, new_BODY_ptr );
-			  if( !result1.ok() )
-			      AcisModifyEngine::instance()->get_acis_query_engine()->ACIS_API_error( result1 );
-			      PRINT_ERROR( " Face unhooking during rebuild of volume didn't work\n" );
-			  AcisQueryEngine::instance()->delete_ACIS_BODY (new_BODY_ptr);
+	if ( bool_type == NONREG_UNION)
+		  outcome result1;
+		  // ENTITY_LIST FACES;
+          DLIList<FACE*>  FACE_list ;
+		  FACE *this_FACE;
+          AcisQueryEngine::instance()->get_FACEs(master,FACE_list);
+		   // loop through all faces
+		  for( int i = 0; i< FACE_list.size(); i++)
+			  this_FACE = FACE_list.get_and_step();
+			  assert( this_FACE != NULL );
+			  // Make sure this is a DOUBLE_SIDED FACE
+			  if (this_FACE->sides() == DOUBLE_SIDED)
+				  if (this_FACE->cont()==BOTH_INSIDE)
+					  // found internal faces
+					  // Now we have the FACE - unhook it  from the BODY.  Keep track of new
+					  // BODIES that are created as this is done.
+					   PRINT_INFO( " Unhooking and deleting each internal surface...\n" );
+					   BODY *new_BODY_ptr;
+					   result1 = api_unhook_face( this_FACE, new_BODY_ptr );
+					   if( !result1.ok() )
+						   AcisModifyEngine::instance()->get_acis_query_engine()->ACIS_API_error( result1 );
+						   PRINT_ERROR( " Face unhooking during rebuild of volume didn't work\n" );
+					   AcisQueryEngine::instance()->delete_ACIS_BODY (new_BODY_ptr);
-	      // heal the leftover body
-	      //		   PRINT_INFO(" Healing the leftover volume...\n");
-	      //		   if( AcisHealerTool::instance()->init_BODY_for_healing( master ) == CUBIT_SUCCESS )
-	      //			   int percent_before, percent_after, number_splines_simplified;
-	      //			   if( AcisHealerTool::instance()->heal_BODY( master, percent_before,
-	      //				   percent_after, number_splines_simplified ) == CUBIT_FAILURE )
-	      //				   PRINT_ERROR( "Error healing the combined volume\n" );
-	      //			   else
-	      //				   PRINT_INFO( "Successfully healed the combined volume!\n" );
-	      //			   AcisHealerTool::instance()->end_BODY_for_healing( master );
+		 // heal the leftover body
+//		   PRINT_INFO(" Healing the leftover volume...\n");
+//		   if( AcisHealerTool::instance()->init_BODY_for_healing( master ) == CUBIT_SUCCESS )
+//			   int percent_before, percent_after, number_splines_simplified;
+//			   if( AcisHealerTool::instance()->heal_BODY( master, percent_before,
+//				   percent_after, number_splines_simplified ) == CUBIT_FAILURE )
+//				   PRINT_ERROR( "Error healing the combined volume\n" );
+//			   else
+//				   PRINT_INFO( "Successfully healed the combined volume!\n" );
+//			   AcisHealerTool::instance()->end_BODY_for_healing( master );
-      AcisQueryEngine::instance()->clear_bounding_box( master );
-      AcisQueryEngine::instance()->bounding_box( master );
-      BodySM *newBodyPtr = get_new_Body(old_Body_list, old_BODY_list, master, keep_old);
-      newBodies.append( newBodyPtr );
+  AcisQueryEngine::instance()->clear_bounding_box( master );
+  AcisQueryEngine::instance()->bounding_box( master );
+  BodySM *newBodyPtr = get_new_Body(old_Body_list, old_BODY_list, master, keep_old);
+  newBodies.append( newBodyPtr );
-  CubitStatus AcisModifyEngine::subtract( DLIList<BodySM*> &tool_body_list,
-					  DLIList<BodySM*> &from_bodies,
-					  DLIList<BodySM*> &new_from_bodies,
-					  bool imprint,
-					  bool keep_old) const
-      BOOL_TYPE bool_type = SUBTRACTION;
+CubitStatus AcisModifyEngine::subtract( DLIList<BodySM*> &tool_body_list,
+                                        DLIList<BodySM*> &from_bodies,
+                                        DLIList<BodySM*> &new_from_bodies,
+                                        bool imprint,
+                                        bool keep_old) const
+     BOOL_TYPE bool_type = SUBTRACTION;
-	  bool_type = NONREG_SUBTRACTION;
+		bool_type = NONREG_SUBTRACTION;
-      int ii;
-      DLIList<CubitBox*> tool_boxes;
+  int ii;
+  DLIList<CubitBox*> tool_boxes;
-      CubitBox tool_box;
+  CubitBox tool_box;
-      DLIList<BODY*> tool_BODY_list;
-      DLIList<BODY*> tool_BODY_list_copy;
+  DLIList<BODY*> tool_BODY_list;
+  DLIList<BODY*> tool_BODY_list_copy;
-      // get acis bodies, and copy them
-      tool_body_list.reset();
+  // get acis bodies, and copy them
+  tool_body_list.reset();
-      for (ii = tool_body_list.size(); ii > 0; ii--) {
-	CubitBox *temp_box = new CubitBox(
-					  AcisQueryEngine::instance()->bounding_box(tool_body_list.get()));
-	tool_boxes.append(temp_box);
+  for (ii = tool_body_list.size(); ii > 0; ii--) {
+    CubitBox *temp_box = new CubitBox(
+	    AcisQueryEngine::instance()->bounding_box(tool_body_list.get()));
+    tool_boxes.append(temp_box);
-	BODY *BODYPtr1 = AcisQueryEngine::get_BODY(tool_body_list.get_and_step());
-	tool_BODY_list.append(BODYPtr1);
+    BODY *BODYPtr1 = AcisQueryEngine::get_BODY(tool_body_list.get_and_step());
+    tool_BODY_list.append(BODYPtr1);
-	BODYPtr1 = this->copy_BODY(BODYPtr1, delete_attribs);
-	tool_BODY_list_copy.append(BODYPtr1);
+    BODYPtr1 = this->copy_BODY(BODYPtr1, delete_attribs);
+    tool_BODY_list_copy.append(BODYPtr1);
-      if (tool_BODY_list.size() != tool_body_list.size())
-	  for(ii = tool_boxes.size(); ii>0; ii--)
-	    delete tool_boxes.get_and_step();
+  if (tool_BODY_list.size() != tool_body_list.size())
+    for(ii = tool_boxes.size(); ii>0; ii--)
+       delete tool_boxes.get_and_step();
-      DLIList<BODY*> from_BODY_list;
-      DLIList<BODY*> from_BODY_list_copy;
+  DLIList<BODY*> from_BODY_list;
+  DLIList<BODY*> from_BODY_list_copy;
-      from_bodies.reset();
+  from_bodies.reset();
-      for (ii = from_bodies.size(); ii > 0; ii--) {
-	BODY *BODYPtr1 = AcisQueryEngine::get_BODY(from_bodies.get_and_step());
-	from_BODY_list.append(BODYPtr1);
+  for (ii = from_bodies.size(); ii > 0; ii--) {
+    BODY *BODYPtr1 = AcisQueryEngine::get_BODY(from_bodies.get_and_step());
+    from_BODY_list.append(BODYPtr1);
-	from_BODY_list_copy.append(BODYPtr1);
+    from_BODY_list_copy.append(BODYPtr1);
-      if (from_BODY_list.size() != from_bodies.size())
+  if (from_BODY_list.size() != from_bodies.size())
-      // now, subtract the tool from the list of bodies
-      tool_BODY_list.reset();
-      tool_BODY_list_copy.reset();
-      tool_boxes.reset();
+  // now, subtract the tool from the list of bodies
+  tool_BODY_list.reset();
+  tool_BODY_list_copy.reset();
+  tool_boxes.reset();
-      from_BODY_list.reset();
-      from_BODY_list_copy.reset();
+  from_BODY_list.reset();
+  from_BODY_list_copy.reset();
-      int fraction_remaining = 10;
-      CubitStatus sub_stat = CUBIT_SUCCESS;
+  int fraction_remaining = 10;
+  CubitStatus sub_stat = CUBIT_SUCCESS;
-      // subtract the tool body from each body in the list
-      CubitMessage* cmi = CubitMessage::instance();
-      for (ii = 1; ii <= from_BODY_list.size(); ii++)
-	  BODY *from_BODY = from_BODY_list.get();
-	  BODY *from_BODY_copy = from_BODY_list_copy.get();
-	  BodySM *from_Body = from_bodies.get();
-	  CubitBox box1 = AcisQueryEngine::instance()->bounding_box(from_Body);
+    // subtract the tool body from each body in the list
+  CubitMessage* cmi = CubitMessage::instance();
+  for (ii = 1; ii <= from_BODY_list.size(); ii++)
+    BODY *from_BODY = from_BODY_list.get();
+    BODY *from_BODY_copy = from_BODY_list_copy.get();
+    BodySM *from_Body = from_bodies.get();
+    CubitBox box1 = AcisQueryEngine::instance()->bounding_box(from_Body);
-	  for(int jj = tool_BODY_list.size(); jj>0; jj--)
-	      if (cmi->Interrupt())
-		  PRINT_ERROR("Subtraction interrupted.  Aborting...\n");
-		  while (tool_boxes.size())
-		    delete tool_boxes.pop();
-		  while (tool_BODY_list_copy.size())
-		    AcisQueryEngine::instance()->delete_ACIS_BODY(tool_BODY_list_copy.pop(),CUBIT_TRUE);
-		  while (from_BODY_list_copy.size())
-		    AcisQueryEngine::instance()->delete_ACIS_BODY(from_BODY_list_copy.pop(),CUBIT_TRUE);
+    for(int jj = tool_BODY_list.size(); jj>0; jj--)
+      if (cmi->Interrupt())
+        PRINT_ERROR("Subtraction interrupted.  Aborting...\n");
+        while (tool_boxes.size())
+          delete tool_boxes.pop();
+        while (tool_BODY_list_copy.size())
+          AcisQueryEngine::instance()->delete_ACIS_BODY(tool_BODY_list_copy.pop(),CUBIT_TRUE);
+        while (from_BODY_list_copy.size())
+          AcisQueryEngine::instance()->delete_ACIS_BODY(from_BODY_list_copy.pop(),CUBIT_TRUE);
-	      tool_box = *tool_boxes.get();
-	      BODY* tool_BODY = tool_BODY_list.get();
-	      BODY *tool_BODY_copy = tool_BODY_list_copy.get();
+      tool_box = *tool_boxes.get();
+      BODY* tool_BODY = tool_BODY_list.get();
+      BODY *tool_BODY_copy = tool_BODY_list_copy.get();
-	      // first, check bounding SPAbox; if they don't intersect, don't do the subtract
-	      if ( tool_box.overlap( SPAresabs, box1 ) )
-		  // the bodies overlap; proceed with the subtract
+        // first, check bounding SPAbox; if they don't intersect, don't do the subtract
+      if ( tool_box.overlap( SPAresabs, box1 ) )
+          // the bodies overlap; proceed with the subtract
-		  // Subtract body1 from body2.
-		  // outcome result = api_subtract( tool_BODY_copy, from_BODY_copy );
-		  outcome result = api_boolean( tool_BODY_copy, from_BODY_copy, bool_type );
-		  // We may or may not get an error if the resulting BODY is
-		  // empty (body1 totally encloses body2).
-		  // Also check the result.
-		  if (from_BODY_copy == NULL ||
-		      (from_BODY_copy->lump() == NULL && from_BODY_copy->wire() == NULL) ||
-		      !result.ok())
-		      if (!result.ok())
-			  PRINT_ERROR("Subtraction operation failed.\n");
-			  AcisQueryEngine::instance()->ACIS_API_error(result, "subtract Bodies");
-			  if (tool_BODY_copy != NULL)
-			      AcisQueryEngine::instance()->delete_ACIS_BODY(tool_BODY_copy, CUBIT_TRUE);
-		      else
-				    "       Empty volume created. Original volume is probably\n"
-				    "       completely enclosed by the subtracting volume.\n");
-		      if (from_BODY_copy != NULL)
-			  AcisQueryEngine::instance()->delete_ACIS_BODY(from_BODY_copy, CUBIT_TRUE);
+          // Subtract body1 from body2.
+         // outcome result = api_subtract( tool_BODY_copy, from_BODY_copy );
+        outcome result = api_boolean( tool_BODY_copy, from_BODY_copy, bool_type );
+          // We may or may not get an error if the resulting BODY is
+          // empty (body1 totally encloses body2).
+          // Also check the result.
+        if (from_BODY_copy == NULL ||
+            (from_BODY_copy->lump() == NULL && from_BODY_copy->wire() == NULL) ||
+            !result.ok())
+          if (!result.ok())
+            PRINT_ERROR("Subtraction operation failed.\n");
+            AcisQueryEngine::instance()->ACIS_API_error(result, "subtract Bodies");
+            if (tool_BODY_copy != NULL)
+              AcisQueryEngine::instance()->delete_ACIS_BODY(tool_BODY_copy, CUBIT_TRUE);
+          else
+                         "       Empty volume created. Original volume is probably\n"
+                         "       completely enclosed by the subtracting volume.\n");
+          if (from_BODY_copy != NULL)
+            AcisQueryEngine::instance()->delete_ACIS_BODY(from_BODY_copy, CUBIT_TRUE);
-		      // we had an error, so copy the original body into the copy list
-		      from_BODY_copy = this->copy_BODY(from_BODY);
-		      from_BODY_list_copy.change_to(from_BODY_copy);
-		      tool_BODY_copy = this->copy_BODY(tool_BODY);
-		      tool_BODY_list_copy.change_to(tool_BODY_copy);
-		      sub_stat = CUBIT_FAILURE;
-		  else
-		      // else subtract was successful; make another tool body
-		      if( imprint )
-			imprint_BODYs( tool_BODY_copy, from_BODY_copy );
+            // we had an error, so copy the original body into the copy list
+          from_BODY_copy = this->copy_BODY(from_BODY);
+          from_BODY_list_copy.change_to(from_BODY_copy);
+          tool_BODY_copy = this->copy_BODY(tool_BODY);
+          tool_BODY_list_copy.change_to(tool_BODY_copy);
+          sub_stat = CUBIT_FAILURE;
+        else
+          // else subtract was successful; make another tool body
+          if( imprint )
+            imprint_BODYs( tool_BODY_copy, from_BODY_copy );
-		  if ( bool_type == NONREG_SUBTRACTION)
-		      outcome result1;
-		      FACE *this_FACE;
-		      AcisQueryEngine::instance()->get_FACEs(from_BODY_copy,FACE_list);
+	if ( bool_type == NONREG_SUBTRACTION)
+		  outcome result1;
+		  FACE *this_FACE;
+          AcisQueryEngine::instance()->get_FACEs(from_BODY_copy,FACE_list);
-		      //			   else
-		      //				   PRINT_INFO( "Successfully healed the combined volume.\n" );
-		  // done with this j iteration; write out count, if necessary
-		  if (from_bodies.size() * tool_body_list.size() > 1)
-		      int frac_done = (10 * ii) / (from_bodies.size()* tool_body_list.size());
-		      if ((10 - frac_done) < fraction_remaining)
-			  PRINT_INFO("%d ", fraction_remaining);
-			  fraction_remaining--;
-	      tool_boxes.step();
-	      tool_BODY_list.step();
-	      tool_BODY_list_copy.step();
-	  // done with iteration over ii; step the lists
-	  from_BODY_list_copy.step();
-	  from_BODY_list.step();
-	  from_bodies.step();
+//			   else
+//				   PRINT_INFO( "Successfully healed the combined volume.\n" );
-      // ok, we're done with all the imprints; construct new Body's for the new BODY's
+           // done with this j iteration; write out count, if necessary
+        if (from_bodies.size() * tool_body_list.size() > 1)
+          int frac_done = (10 * ii) / (from_bodies.size()* tool_body_list.size());
+          if ((10 - frac_done) < fraction_remaining)
+            PRINT_INFO("%d ", fraction_remaining);
+            fraction_remaining--;
+      tool_boxes.step();
+      tool_BODY_list.step();
+      tool_BODY_list_copy.step();
-      for (ii = 0; ii< from_BODY_list_copy.size(); ii++)
-	  BODY *old_BODY = from_BODY_list.get();
-	  BODY *new_BODY = from_BODY_list_copy.get();
-	  BodySM *new_body = NULL;
-	  if (old_BODY != new_BODY)
-	    new_body = get_new_Body(from_bodies.get(), old_BODY, new_BODY, keep_old);
+      // done with iteration over ii; step the lists
+    from_BODY_list_copy.step();
+    from_BODY_list.step();
+    from_bodies.step();
-	  if (new_body)
-	      new_from_bodies.append(new_body);
-	      from_bodies.change_to(NULL);
+    // ok, we're done with all the imprints; construct new Body's for the new BODY's
-	  // now step all the lists
+  for (ii = 0; ii< from_BODY_list_copy.size(); ii++)
+      BODY *old_BODY = from_BODY_list.get();
+      BODY *new_BODY = from_BODY_list_copy.get();
-      from_bodies.remove_all_with_value(NULL);
-      new_from_bodies.reset();
+      BodySM *new_body = NULL;
+      if (old_BODY != new_BODY)
+         new_body = get_new_Body(from_bodies.get(), old_BODY, new_BODY, keep_old);
-      for(ii = tool_BODY_list_copy.size(); ii>0; ii--)
-	AcisQueryEngine::instance()->delete_ACIS_BODY(tool_BODY_list_copy.get_and_step(), CUBIT_TRUE);
+      if (new_body)
+        new_from_bodies.append(new_body);
+        from_bodies.change_to(NULL);
-      if (sub_stat == CUBIT_SUCCESS && !keep_old)
-	AcisQueryEngine::instance()->delete_solid_model_entities(tool_body_list);
+      // now step all the lists
+  from_bodies.remove_all_with_value(NULL);
+  new_from_bodies.reset();
+  for(ii = tool_BODY_list_copy.size(); ii>0; ii--)
+     AcisQueryEngine::instance()->delete_ACIS_BODY(tool_BODY_list_copy.get_and_step(), CUBIT_TRUE);
-  // Purpose       : Boolean Operation of two Bodys: imprint
-  // Creation Date : 10/30/96
-  CubitStatus AcisModifyEngine::imprint(BodySM* BodyPtr1,
-					BodySM* BodyPtr2,
-					BodySM*& newBodyPtr1,
-					BodySM*& newBodyPtr2,
-      // There are two many places things can go wrong. When they do, in
-      // addition to returning a CUBIT_FAILURE, we should return some sensible
-      // values through the output arguments. Before any of the output Body's can
-      // be created, the most sensible for these is NULL.
-      newBodyPtr1 = NULL ;
-      newBodyPtr2 = NULL ;
+  if (sub_stat == CUBIT_SUCCESS && !keep_old)
+    AcisQueryEngine::instance()->delete_solid_model_entities(tool_body_list);
-      // first, check bounding SPAbox; if they don't intersect, imprint will fail
-      AcisQueryEngine* aqe = AcisQueryEngine::instance();
-      BODY* BODYPtr1 =  aqe->get_BODY(BodyPtr1);
-      BODY* BODYPtr2 =  aqe->get_BODY(BodyPtr2);
-      if( (BODYPtr1 == NULL) || (BODYPtr2 == NULL) )
-      CubitBox box1 = aqe->bounding_box(aqe->bounding_box(BODYPtr1));
-      CubitBox box2 = aqe->bounding_box(aqe->bounding_box(BODYPtr2));
-      if (! box1.overlap(SPAresabs, box2))
+// Purpose       : Boolean Operation of two Bodys: imprint
+// Special Notes :
+// Creation Date : 10/30/96
+CubitStatus AcisModifyEngine::imprint(BodySM* BodyPtr1,
+                                      BodySM* BodyPtr2,
+                                      BodySM*& newBodyPtr1,
+                                      BodySM*& newBodyPtr2,
+    // There are two many places things can go wrong. When they do, in
+    // addition to returning a CUBIT_FAILURE, we should return some sensible
+    // values through the output arguments. Before any of the output Body's can
+    // be created, the most sensible for these is NULL.
+  newBodyPtr1 = NULL ;
+  newBodyPtr2 = NULL ;
-      // Make copies of the ACIS bodies. This is required because if the ultimate
-      // result is a body with no LUMPs, then we need to be able to restore
-      // the original BODY's and their Bodies.
-      BODY* BODYPtr1Save;
-      BODY* BODYPtr2Save;
+    // first, check bounding SPAbox; if they don't intersect, imprint will fail
+  AcisQueryEngine* aqe = AcisQueryEngine::instance();
+  BODY* BODYPtr1 =  aqe->get_BODY(BodyPtr1);
+  BODY* BODYPtr2 =  aqe->get_BODY(BodyPtr2);
-      BODYPtr1Save = this->copy_BODY(BODYPtr1, delete_attribs);
-      if (BODYPtr1Save == NULL)
-	  PRINT_ERROR("Copy of volume failed.\n       Imprint failed.\n");
-      BODYPtr2Save = this->copy_BODY(BODYPtr2, delete_attribs);
-      if (BODYPtr2Save == NULL)
-	  AcisQueryEngine::instance()->delete_ACIS_BODY(BODYPtr1Save, CUBIT_TRUE);
+  if( (BODYPtr1 == NULL) || (BODYPtr2 == NULL) )
-      // Keep track of the number of curves/surfaces/vertices in each body.  That
-      // way we can tell if they really changed.
-      int num_vol1_bef, num_face1_bef, num_edge1_bef, num_vertex1_bef;
-      if( AcisQueryEngine::instance()->number_ENTITIES( BODYPtr1Save, num_vol1_bef, num_face1_bef, num_edge1_bef,
-							num_vertex1_bef ) == CUBIT_FAILURE )
-	  PRINT_ERROR( "Unable to count number of entities in volume\n" );
-      int num_vol2_bef, num_face2_bef, num_edge2_bef, num_vertex2_bef;
-      if( AcisQueryEngine::instance()->number_ENTITIES( BODYPtr2Save, num_vol2_bef, num_face2_bef, num_edge2_bef,
-							num_vertex2_bef ) == CUBIT_FAILURE )
+  CubitBox box1 = aqe->bounding_box(aqe->bounding_box(BODYPtr1));
+  CubitBox box2 = aqe->bounding_box(aqe->bounding_box(BODYPtr2));
+  if (! box1.overlap(SPAresabs, box2))
-      // Now, imprint the 2 BODYs
-      if ( GeometryModifyTool::get_all_edges_imprint() )
-	  api_set_int_option("all_free_edges", TRUE );
+    // Make copies of the ACIS bodies. This is required because if the ultimate
+    // result is a body with no LUMPs, then we need to be able to restore
+    // the original BODY's and their Bodies.
+  BODY* BODYPtr1Save;
+  BODY* BODYPtr2Save;
-      outcome result = api_imprint( BODYPtr1Save, BODYPtr2Save );
+  BODYPtr1Save = this->copy_BODY(BODYPtr1, delete_attribs);
+  if (BODYPtr1Save == NULL)
+    PRINT_ERROR("Copy of volume failed.\n       Imprint failed.\n");
+  BODYPtr2Save = this->copy_BODY(BODYPtr2, delete_attribs);
+  if (BODYPtr2Save == NULL)
+    AcisQueryEngine::instance()->delete_ACIS_BODY(BODYPtr1Save, CUBIT_TRUE);
-      //Gets rid of sliver curves/surfaces that could get produced by the imprint.
-      AcisModifyEngine::instance()->cleanup_slivers( BODYPtr1Save );
-      AcisModifyEngine::instance()->cleanup_slivers( BODYPtr2Save );
+    // Keep track of the number of curves/surfaces/vertices in each body.  That
+    // way we can tell if they really changed.
+  int num_vol1_bef, num_face1_bef, num_edge1_bef, num_vertex1_bef;
+  if( AcisQueryEngine::instance()->number_ENTITIES( BODYPtr1Save, num_vol1_bef, num_face1_bef, num_edge1_bef,
+                       num_vertex1_bef ) == CUBIT_FAILURE )
+     PRINT_ERROR( "Unable to count number of entities in volume\n" );
+  int num_vol2_bef, num_face2_bef, num_edge2_bef, num_vertex2_bef;
+  if( AcisQueryEngine::instance()->number_ENTITIES( BODYPtr2Save, num_vol2_bef, num_face2_bef, num_edge2_bef,
+                       num_vertex2_bef ) == CUBIT_FAILURE )
-	  api_set_int_option("all_free_edges", FALSE );
+    // Now, imprint the 2 BODYs
+  if ( GeometryModifyTool::get_all_edges_imprint() )
+    api_set_int_option("all_free_edges", TRUE );
-      if (!result.ok())
-	  // might just be no overlap, check smaller boxes
-	  if (!BODYPtr1Save || !BODYPtr2Save ||
-	      box1.overlap(SPAresabs,box2) == CUBIT_TRUE)
-	      if (DEBUG_FLAG(95))
-		  AcisQueryEngine::instance()->ACIS_API_error(result, "imprint Bodies");
+  outcome result = api_imprint( BODYPtr1Save, BODYPtr2Save );
-	      if (BODYPtr1Save != NULL)
-	      if (BODYPtr2Save != NULL)
-		  AcisQueryEngine::instance()->delete_ACIS_BODY(BODYPtr2Save, CUBIT_TRUE);
+   //Gets rid of sliver curves/surfaces that could get produced by the imprint.
+   AcisModifyEngine::instance()->cleanup_slivers( BODYPtr1Save );
+   AcisModifyEngine::instance()->cleanup_slivers( BODYPtr2Save );
+    api_set_int_option("all_free_edges", FALSE );
-      // Compare body 1 before & after imprint
-      int num_vol1_aft, num_face1_aft, num_edge1_aft, num_vertex1_aft;
-	  number_ENTITIES( BODYPtr1Save, num_vol1_aft, num_face1_aft, num_edge1_aft,
-			   num_vertex1_aft ) == CUBIT_FAILURE )
+  if (!result.ok())
+      // might just be no overlap, check smaller boxes
+    if (!BODYPtr1Save || !BODYPtr2Save ||
+        box1.overlap(SPAresabs,box2) == CUBIT_TRUE)
+      if (DEBUG_FLAG(95))
+        AcisQueryEngine::instance()->ACIS_API_error(result, "imprint Bodies");
-      // Only create a new Body1 if it changed
-      if( num_vol1_bef != num_vol1_aft ||
-	  num_face1_bef != num_face1_aft ||
-	  num_edge1_bef != num_edge1_aft ||
-	  num_vertex1_bef != num_vertex1_aft ||
-	  GeometryModifyTool::instance()->get_group_imprint() == CUBIT_FALSE)
-	  DLIList<EDGE*> new_edges = AcisModifyEngine::instance()->find_new_EDGES(BODYPtr2Save);
+      if (BODYPtr1Save != NULL)
+      if (BODYPtr2Save != NULL)
+        AcisQueryEngine::instance()->delete_ACIS_BODY(BODYPtr2Save, CUBIT_TRUE);
-	  newBodyPtr1 = AcisQueryEngine::instance()->populate_topology_bridges(BODYPtr1Save);
-	  if (newBodyPtr1 == NULL )
-	      PRINT_ERROR("Problems creating topology for imprinted volume.\n") ;
-	  // Add a imprint feature to the topo edges
-	  for (int edge_count = new_edges.size(); edge_count--; )
-	      CubitSimpleAttrib *tmp_attrib = new CubitSimpleAttrib( "SOURCE_FEATURE", "IMPRINT" );
-	      new ATTRIB_SNL_SIMPLE( new_edges[edge_count], tmp_attrib );
-	      delete tmp_attrib;
+    // Compare body 1 before & after imprint
+  int num_vol1_aft, num_face1_aft, num_edge1_aft, num_vertex1_aft;
+      number_ENTITIES( BODYPtr1Save, num_vol1_aft, num_face1_aft, num_edge1_aft,
+                       num_vertex1_aft ) == CUBIT_FAILURE )
-	  //BodyPtr1->switch_entity_names(newBodyPtr1);
-	  if (GeometryModifyTool::get_old_names())
-	      Body* model_ent = dynamic_cast<Body*>(BodyPtr1->topology_entity());
-	      if (model_ent)
-		  Body* new_model_ent = dynamic_cast<Body*>(newBodyPtr1->topology_entity());
-		  if (!new_model_ent)
-		    new_model_ent = GeometryQueryTool::instance()->make_Body(newBodyPtr1);
-		  model_ent->switch_entity_names(new_model_ent);
+  // Only create a new Body1 if it changed
+  if( num_vol1_bef != num_vol1_aft ||
+      num_face1_bef != num_face1_aft ||
+      num_edge1_bef != num_edge1_aft ||
+      num_vertex1_bef != num_vertex1_aft ||
+      GeometryModifyTool::instance()->get_group_imprint() == CUBIT_FALSE)
+      DLIList<EDGE*> new_edges = AcisModifyEngine::instance()->find_new_EDGES(BODYPtr2Save);
-	  if (keep_old == CUBIT_FALSE)
-	    AcisQueryEngine::instance()->delete_solid_model_entities(BodyPtr1);
-      else
+      newBodyPtr1 = AcisQueryEngine::instance()->populate_topology_bridges(BODYPtr1Save);
+      if (newBodyPtr1 == NULL )
+          PRINT_ERROR("Problems creating topology for imprinted volume.\n") ;
-      // Compare body 2 before & after imprint
-      int num_vol2_aft, num_face2_aft, num_edge2_aft, num_vertex2_aft;
-      if( AcisQueryEngine::instance()->number_ENTITIES( BODYPtr2Save, num_vol2_aft, num_face2_aft, num_edge2_aft,
-							num_vertex2_aft ) == CUBIT_FAILURE )
-	  PRINT_ERROR( "Unable to count number of entities in volume.\n");
+      // Add a imprint feature to the topo edges
+      for (int edge_count = new_edges.size(); edge_count--; )
+          CubitSimpleAttrib *tmp_attrib = new CubitSimpleAttrib( "SOURCE_FEATURE", "IMPRINT" );
+          new ATTRIB_SNL_SIMPLE( new_edges[edge_count], tmp_attrib );
+          delete tmp_attrib;
-      // Only create a new Body2 if it changed
-      if( num_vol2_bef != num_vol2_aft ||
-	  num_face2_bef != num_face2_aft ||
-	  num_edge2_bef != num_edge2_aft ||
-	  num_vertex2_bef != num_vertex2_aft ||
+     //BodyPtr1->switch_entity_names(newBodyPtr1);
+     if (GeometryModifyTool::get_old_names())
+       Body* model_ent = dynamic_cast<Body*>(BodyPtr1->topology_entity());
+       if (model_ent)
+         Body* new_model_ent = dynamic_cast<Body*>(newBodyPtr1->topology_entity());
+         if (!new_model_ent)
+           new_model_ent = GeometryQueryTool::instance()->make_Body(newBodyPtr1);
+         model_ent->switch_entity_names(new_model_ent);
-	  newBodyPtr2 = AcisQueryEngine::instance()->populate_topology_bridges(BODYPtr2Save);
-	  if (newBodyPtr2 == NULL )
-	      PRINT_ERROR("Problems creating topology for imprinted volume.\n" ) ;
+     if (keep_old == CUBIT_FALSE)
+       AcisQueryEngine::instance()->delete_solid_model_entities(BodyPtr1);
+  else
+  // Compare body 2 before & after imprint
+  int num_vol2_aft, num_face2_aft, num_edge2_aft, num_vertex2_aft;
+  if( AcisQueryEngine::instance()->number_ENTITIES( BODYPtr2Save, num_vol2_aft, num_face2_aft, num_edge2_aft,
+                       num_vertex2_aft ) == CUBIT_FAILURE )
+     PRINT_ERROR( "Unable to count number of entities in volume.\n");
-	      Body* model_ent = dynamic_cast<Body*>(BodyPtr2->topology_entity());
-	      if (model_ent)
-		  Body* new_model_ent = dynamic_cast<Body*>(newBodyPtr2->topology_entity());
-		    new_model_ent = GeometryQueryTool::instance()->make_Body(newBodyPtr2);
+  // Only create a new Body2 if it changed
+  if( num_vol2_bef != num_vol2_aft ||
+      num_face2_bef != num_face2_aft ||
+      num_edge2_bef != num_edge2_aft ||
+      num_vertex2_bef != num_vertex2_aft ||
-	    AcisQueryEngine::instance()->delete_solid_model_entities(BodyPtr2);
-	  //actuate_mesh_intervals( newBodyPtr2 );
-      else
+      newBodyPtr2 = AcisQueryEngine::instance()->populate_topology_bridges(BODYPtr2Save);
+      if (newBodyPtr2 == NULL )
+          PRINT_ERROR("Problems creating topology for imprinted volume.\n" ) ;
-      // All's well with the world :-)
+       Body* model_ent = dynamic_cast<Body*>(BodyPtr2->topology_entity());
+       if (model_ent)
+         Body* new_model_ent = dynamic_cast<Body*>(newBodyPtr2->topology_entity());
+           new_model_ent = GeometryQueryTool::instance()->make_Body(newBodyPtr2);
-  BodySM *AcisModifyEngine::get_new_Body(  BodySM *old_Body,
-					   BODY *old_BODY,
-					   BODY *new_BODY,
-					   const bool keep_old,
-					   const bool topology_check,
-					   const bool delete_old) const
-      if (topology_check)
-	  // must do topology check between old & new bodies.  In the case
-	  // of a topology check, we know there's only one old and new body
-	  int num_vol_bef, num_face_bef, num_edge_bef, num_vertex_bef;
-	  CubitStatus status1 = AcisQueryEngine::instance()->number_ENTITIES( old_BODY, num_vol_bef,
-									      num_face_bef, num_edge_bef,
-									      num_vertex_bef );
+       AcisQueryEngine::instance()->delete_solid_model_entities(BodyPtr2);
+     //actuate_mesh_intervals( newBodyPtr2 );
+  else
-	  int num_vol_aft, num_face_aft, num_edge_aft, num_vertex_aft;
-	  CubitStatus status2 = AcisQueryEngine::instance()->number_ENTITIES( new_BODY, num_vol_aft,
-									      num_face_aft, num_edge_aft,
-									      num_vertex_aft );
+    // All's well with the world :-)
-	  if( status1 == CUBIT_FAILURE  ||
-	      status2 == CUBIT_FAILURE )
-	      return 0;
+BodySM *AcisModifyEngine::get_new_Body(  BodySM *old_Body,
+                                       BODY *old_BODY,
+                                       BODY *new_BODY,
+                                       const bool keep_old,
+                                       const bool topology_check,
+                                       const bool delete_old) const
+  if (topology_check)
+      // must do topology check between old & new bodies.  In the case
+      // of a topology check, we know there's only one old and new body
+    int num_vol_bef, num_face_bef, num_edge_bef, num_vertex_bef;
+    CubitStatus status1 = AcisQueryEngine::instance()->number_ENTITIES( old_BODY, num_vol_bef,
+                                           num_face_bef, num_edge_bef,
+                                           num_vertex_bef );
-	  if( num_vol_bef == num_vol_aft &&
-	      num_face_bef == num_face_aft &&
-	      num_edge_bef == num_edge_aft &&
-	      num_vertex_bef == num_vertex_aft)
-	      AcisQueryEngine::instance()->delete_ACIS_BODY(new_BODY, CUBIT_TRUE);
-	      return 0;
+    int num_vol_aft, num_face_aft, num_edge_aft, num_vertex_aft;
+    CubitStatus status2 = AcisQueryEngine::instance()->number_ENTITIES( new_BODY, num_vol_aft,
+                                           num_face_aft, num_edge_aft,
+                                           num_vertex_aft );
-      // convert input to list-based version and pass to overloaded version of
-      // get_new_body
-      DLIList<BodySM*> Body_list(1);
-      if(old_Body != NULL)
-	Body_list.append(old_Body);
-      DLIList<BODY*> BODY_list(1);
-      if(old_BODY != NULL)
-	BODY_list.append(old_BODY);
+    if( status1 == CUBIT_FAILURE  ||
+        status2 == CUBIT_FAILURE )
-      return get_new_Body(Body_list, BODY_list, new_BODY, keep_old, delete_old);
+      return 0;
-  BodySM *AcisModifyEngine::get_new_Body(DLIList<BodySM*> &old_Body_list,
-					 DLIList<BODY*> &old_BODY_list,
-					 BODY *new_BODY,
+    if( num_vol_bef == num_vol_aft &&
+        num_face_bef == num_face_aft &&
+        num_edge_bef == num_edge_aft &&
+        num_vertex_bef == num_vertex_aft)
-      DLIList<BODY*> new_BODY_list;
-      new_BODY_list.append(new_BODY);
-      DLIList<BodySM*> new_Body_list;
-      CubitStatus status = get_new_Body(old_Body_list, old_BODY_list,
-					new_BODY_list, new_Body_list,
-					keep_old, delete_old);
+      AcisQueryEngine::instance()->delete_ACIS_BODY(new_BODY, CUBIT_TRUE);
+      return 0;
-      if (status == CUBIT_FAILURE ||
-	  new_Body_list.size() == 0) return NULL;
+    // convert input to list-based version and pass to overloaded version of
+    // get_new_body
+  DLIList<BodySM*> Body_list(1);
+  if(old_Body != NULL)
+     Body_list.append(old_Body);
+  DLIList<BODY*> BODY_list(1);
+  if(old_BODY != NULL)
+     BODY_list.append(old_BODY);
-      assert(new_Body_list.size() == 1);
+  return get_new_Body(Body_list, BODY_list, new_BODY, keep_old, delete_old);
-      return new_Body_list.get();
+BodySM *AcisModifyEngine::get_new_Body(DLIList<BodySM*> &old_Body_list,
+                                       DLIList<BODY*> &old_BODY_list,
+                                       BODY *new_BODY,
+  DLIList<BODY*> new_BODY_list;
+  new_BODY_list.append(new_BODY);
+  DLIList<BodySM*> new_Body_list;
+  CubitStatus status = get_new_Body(old_Body_list, old_BODY_list,
+                                    new_BODY_list, new_Body_list,
+                                    keep_old, delete_old);
-  CubitStatus AcisModifyEngine::get_new_Body( BodySM *old_Body,
-					      BODY *old_BODY,
-					      DLIList<BODY*> &new_BODY_list,
-					      DLIList<BodySM*> &new_Body_list,
-      old_BODY_list.append(old_BODY);
-      old_Body_list.append(old_Body);
-      return get_new_Body(old_Body_list, old_BODY_list,
+  if (status == CUBIT_FAILURE ||
+      new_Body_list.size() == 0) return NULL;
-  CubitStatus AcisModifyEngine::get_new_Body(DLIList<BodySM*> &old_Body_list,
+  assert(new_Body_list.size() == 1);
+  return new_Body_list.get();
+CubitStatus AcisModifyEngine::get_new_Body( BodySM *old_Body,
+                                             BODY *old_BODY,
+                                             DLIList<BODY*> &new_BODY_list,
+                                             DLIList<BodySM*> &new_Body_list,
+  old_BODY_list.append(old_BODY);
+  old_Body_list.append(old_Body);
+  return get_new_Body(old_Body_list, old_BODY_list,
+CubitStatus AcisModifyEngine::get_new_Body(DLIList<BodySM*> &old_Body_list,
-      assert(old_Body_list.size() == old_BODY_list.size());
+  assert(old_Body_list.size() == old_BODY_list.size());
-      //&& old_Body_list.size() > 0); It's possible now to have no
-      //old bodies, so don't stress over this
+       //&& old_Body_list.size() > 0); It's possible now to have no
+       //old bodies, so don't stress over this
-      // Only create a new Body if it changed
-      BodySM *new_Body = NULL;
+    // Only create a new Body if it changed
+  BodySM *new_Body = NULL;
-      // body changed; need to build a new vgi body around
-      // old_BODY, either by reusing old_Body or creating new one
+    // body changed; need to build a new vgi body around
+    // old_BODY, either by reusing old_Body or creating new one
-      if (GeometryModifyTool::instance()->get_new_ids() == CUBIT_FALSE &&
-	  keep_old == CUBIT_FALSE)
-	  // if we're reusing old refentities, prepare by marking
-	  // deactivated the ones that don't get reused, then delete
-	  // those
-	  int num_deactivd = 0;
-	  int i;
-	  for (i = old_BODY_list.size(); i > 0; i--)
-	    num_deactivd += mark_owners_deactivated_flag(old_BODY_list.get_and_step(),
-							 CUBIT_TRUE);
+  if (GeometryModifyTool::instance()->get_new_ids() == CUBIT_FALSE &&
+      keep_old == CUBIT_FALSE)
+      // if we're reusing old refentities, prepare by marking
+      // deactivated the ones that don't get reused, then delete
+      // those
+    int num_deactivd = 0;
+    int i;
+    for (i = old_BODY_list.size(); i > 0; i--)
+      num_deactivd += mark_owners_deactivated_flag(old_BODY_list.get_and_step(),
+                                                   CUBIT_TRUE);
-	  int num_reactivd =  0;
-	  for (i = new_BODY_list.size(); i > 0; i--)
-	    num_reactivd =  mark_owners_deactivated_flag(new_BODY_list.get_and_step(),
-							 CUBIT_FALSE);
-	  if (DEBUG_FLAG(99))
-	      PRINT_DEBUG_99( "Number of entities deactivated = %d,"
-			      " reactivated = %d\n", num_deactivd, num_reactivd);
-	      print_deleted_reused(old_BODY_list, new_BODY_list);
+    int num_reactivd =  0;
+    for (i = new_BODY_list.size(); i > 0; i--)
+      num_reactivd =  mark_owners_deactivated_flag(new_BODY_list.get_and_step(),
+                                                   CUBIT_FALSE);
+    if (DEBUG_FLAG(99))
+      PRINT_DEBUG_99( "Number of entities deactivated = %d,"
+                      " reactivated = %d\n", num_deactivd, num_reactivd);
+      print_deleted_reused(old_BODY_list, new_BODY_list);
-	  // ok, now unhook the old body from the vgi data (only done if
-	  // we aren't keeping old geometry)
-		AcisQueryEngine::instance()->delete_ACIS_BODY(old_BODY_list.get_and_step(), CUBIT_FALSE);
+      // ok, now unhook the old body from the vgi data (only done if
+      // we aren't keeping old geometry)
+        AcisQueryEngine::instance()->delete_ACIS_BODY(old_BODY_list.get_and_step(), CUBIT_FALSE);
-	  // now cleanout the deactivated geometry; automatically unhooks
-	  // from the dag
-	  cleanout_deactivated_geometry();
-      // now delete the old body, either obeying or not obeying the
-      // deactivated flags (which is opposite of the
-      // create_new_refents flag)
-      if (GeometryModifyTool::instance()->get_new_ids() && !keep_old && delete_old)
-	  for (int i = old_Body_list.size(); i > 0; i--)
-	      BodySM *old_Body = old_Body_list.get_and_step();
-	      AcisQueryEngine::instance()->delete_solid_model_entities(old_Body);
+      // now cleanout the deactivated geometry; automatically unhooks
+      // from the dag
+    cleanout_deactivated_geometry();
+    // now delete the old body, either obeying or not obeying the
+    // deactivated flags (which is opposite of the
+    // create_new_refents flag)
+  if (GeometryModifyTool::instance()->get_new_ids() && !keep_old && delete_old)
+    for (int i = old_Body_list.size(); i > 0; i--)
+      BodySM *old_Body = old_Body_list.get_and_step();
+      AcisQueryEngine::instance()->delete_solid_model_entities(old_Body);
-      int i;
-	  new_Body = AcisQueryEngine::instance()->populate_topology_bridges(new_BODY_list.get_and_step());
-	  if (new_Body != NULL)
-	    new_Body_list.append(new_Body);
-	  else
-	      PRINT_ERROR("Problems creating new Body from new BODY.\n"
-			  "       get_new_Body failed.\n") ;
-      if( keep_old && GeometryModifyTool::get_old_names() )
-	  // switch names with the first body only
-	  old_Body_list.reset();
-	  BodySM* old_bodysm = old_Body_list.get();
-	  Body* body = dynamic_cast<Body*>(old_bodysm->topology_entity());
-	  if (body)
-	      Body* new_body = dynamic_cast<Body*>(new_Body->topology_entity());
-	      if (!new_body)
-		new_body = GeometryQueryTool::instance()->make_Body(new_Body);
-	      body->switch_entity_names(new_body);
+  int i;
+    new_Body = AcisQueryEngine::instance()->populate_topology_bridges(new_BODY_list.get_and_step());
+    if (new_Body != NULL)
+      new_Body_list.append(new_Body);
+    else
+      PRINT_ERROR("Problems creating new Body from new BODY.\n"
+                  "       get_new_Body failed.\n") ;
-  CubitStatus AcisModifyEngine::get_new_Body( DLIList<TopologyBridge*> &old_entity_list,
+  if( keep_old && GeometryModifyTool::get_old_names() )
+      // switch names with the first body only
+    old_Body_list.reset();
+    BodySM* old_bodysm = old_Body_list.get();
+    Body* body = dynamic_cast<Body*>(old_bodysm->topology_entity());
+    if (body)
-      assert(old_entity_list.size() > 0 || keep_old );
+      Body* new_body = dynamic_cast<Body*>(new_Body->topology_entity());
+      if (!new_body)
+        new_body = GeometryQueryTool::instance()->make_Body(new_Body);
+      body->switch_entity_names(new_body);
-      // don't do a topology check in this version of get_new_Body
-      // need to build a new body or bodies
+CubitStatus AcisModifyEngine::get_new_Body( DLIList<TopologyBridge*> &old_entity_list,
+  assert(old_entity_list.size() > 0 || keep_old );
-	  // those
-	  int i, j, num_deactivd = 0, num_reactivd = 0;
+    // don't do a topology check in this version of get_new_Body
-	  ENTITY_LIST old_ENTITY_list, tmp_ENTITY_list;
-	  old_entity_list.reset();
-	  for (i = old_entity_list.size(); i--; )
-	      tmp_ENTITY_list.clear();
-	      TopologyBridge* geom_ptr = old_entity_list.get_and_step();
-	      AcisBridge* bridge_ptr = dynamic_cast<AcisBridge*>(geom_ptr);
-	      if (!bridge_ptr)
-		  PRINT_ERROR("Non-ACIS geometry at %s:%d\n",__FILE__,__LINE__);
-		  continue;
-	      ENTITY* ENTITY_ptr = bridge_ptr->ENTITY_ptr();
-	      if (!ENTITY_ptr)
-		continue;
+    // need to build a new body or bodies
-	      old_ENTITY_list.add(ENTITY_ptr);
+      // those
+    int i, j, num_deactivd = 0, num_reactivd = 0;
+    ENTITY_LIST old_ENTITY_list, tmp_ENTITY_list;
+    old_entity_list.reset();
+    for (i = old_entity_list.size(); i--; )
+      tmp_ENTITY_list.clear();
+      TopologyBridge* geom_ptr = old_entity_list.get_and_step();
+      AcisBridge* bridge_ptr = dynamic_cast<AcisBridge*>(geom_ptr);
+      if (!bridge_ptr)
+        PRINT_ERROR("Non-ACIS geometry at %s:%d\n",__FILE__,__LINE__);
+        continue;
+      ENTITY* ENTITY_ptr = bridge_ptr->ENTITY_ptr();
+      if (!ENTITY_ptr)
+        continue;
-	      CubitStatus stat = AcisQueryEngine::instance()->
-		get_child_ENTITYs( ENTITY_ptr, tmp_ENTITY_list, true);
-	      if (!stat)
-		  PRINT_ERROR("AcisQueryEngine::get_child_ENTITYs failed at %s:%d\n",__FILE__,__LINE__);
-		  continue;
+      old_ENTITY_list.add(ENTITY_ptr);
-	      for (j = 0; j < tmp_ENTITY_list.count(); j++)
-		  old_ENTITY_list.add( tmp_ENTITY_list[j] );
-	  for (i = 0; i < old_ENTITY_list.count(); i++)
-	      // mark the owners deactivated, but don't recurse, since we've got all
-	      // the lower order topology already
-	      num_deactivd += mark_owners_deactivated_flag(old_ENTITY_list[i],
-							   CUBIT_TRUE,
-							   CUBIT_FALSE);
+      CubitStatus stat = AcisQueryEngine::instance()->
+        get_child_ENTITYs( ENTITY_ptr, tmp_ENTITY_list, true);
+      if (!stat)
+        PRINT_ERROR("AcisQueryEngine::get_child_ENTITYs failed at %s:%d\n",__FILE__,__LINE__);
+        continue;
+      for (j = 0; j < tmp_ENTITY_list.count(); j++)
+        old_ENTITY_list.add( tmp_ENTITY_list[j] );
-	    num_reactivd += mark_owners_deactivated_flag(new_BODY_list.get_and_step(),
-							 CUBIT_FALSE);
+    for (i = 0; i < old_ENTITY_list.count(); i++)
+         // mark the owners deactivated, but don't recurse, since we've got all
+         // the lower order topology already
+       num_deactivd += mark_owners_deactivated_flag(old_ENTITY_list[i],
+                                                    CUBIT_TRUE,
+                                                    CUBIT_FALSE);
-	      ENTITY_LIST to_be_deleted;
-		  // need to check to make sure the old entity isn't in the new body
-		  ENTITY *this_ENTITY = old_ENTITY_list[i];
-		  BODY *this_BODY = AcisQueryEngine::instance()->get_BODY_of_ENTITY(this_ENTITY);
-		  //if the entity is not in the new body, add it to a list of
-		  //entities to be deleted
-		  if (!new_BODY_list.move_to(this_BODY))
-		    to_be_deleted.add(this_ENTITY);
-	      //delete the ENTITYs in the list
-	      AcisQueryEngine::instance()->delete_ACIS_ENTITY(to_be_deleted);
-	  // from the dag
+      num_reactivd += mark_owners_deactivated_flag(new_BODY_list.get_and_step(),
+                                                   CUBIT_FALSE);
+      ENTITY_LIST to_be_deleted;
+          // need to check to make sure the old entity isn't in the new body
+        ENTITY *this_ENTITY = old_ENTITY_list[i];
+        BODY *this_BODY = AcisQueryEngine::instance()->get_BODY_of_ENTITY(this_ENTITY);
+	        //if the entity is not in the new body, add it to a list of
+          //entities to be deleted
+        if (!new_BODY_list.move_to(this_BODY))
+          to_be_deleted.add(this_ENTITY);
+      //delete the ENTITYs in the list
+      AcisQueryEngine::instance()->delete_ACIS_ENTITY(to_be_deleted);
-      int i;
-	  for (i = old_entity_list.size(); i > 0; i--)
-	      TopologyBridge *old_entity = old_entity_list.get_and_step();
-	      if (BodySM* bod_ptr = dynamic_cast<BodySM*>(old_entity))
-		AcisQueryEngine::instance()->delete_solid_model_entities(bod_ptr);
-	      else
-									 dynamic_cast<GeometryEntity*>(old_entity),true);
+      // from the dag
-	  BodySM *new_Body = AcisQueryEngine::instance()->populate_topology_bridges(new_BODY_list.get_and_step());
-	  else
+  int i;
+    for (i = old_entity_list.size(); i > 0; i--)
+      TopologyBridge *old_entity = old_entity_list.get_and_step();
+      if (BodySM* bod_ptr = dynamic_cast<BodySM*>(old_entity))
+        AcisQueryEngine::instance()->delete_solid_model_entities(bod_ptr);
+      else
+          dynamic_cast<GeometryEntity*>(old_entity),true);
-  int AcisModifyEngine::mark_owners_deactivated_flag(ENTITY *this_ENTITY,
+    BodySM *new_Body = AcisQueryEngine::instance()->populate_topology_bridges(new_BODY_list.get_and_step());
+    else
+int AcisModifyEngine::mark_owners_deactivated_flag(ENTITY *this_ENTITY,
                                                      bool flag,
                                                      bool recurse) const
-      // marks as deactivated all the owners of the input BODY,
-      // along with all its children
-      // order is important here; entities must be put in the
-      // deactivated list from lower order to higher order, that saves
-      // work when removing the DAG nodes from the DAG
-      // (not sure it's absolutely necessary though, since the
-      // remove_from_DAG() function calls that function recursively for
-      // lower order entities)
+    // marks as deactivated all the owners of the input BODY,
+    // along with all its children
+    // order is important here; entities must be put in the
+    // deactivated list from lower order to higher order, that saves
+    // work when removing the DAG nodes from the DAG
+    // (not sure it's absolutely necessary though, since the
+    // remove_from_DAG() function calls that function recursively for
+    // lower order entities)
-      int num_deactivated = 0;
+  int num_deactivated = 0;
-      // if we're not recursing, set the skip flag to true
-      CubitBoolean skip = (recurse ? CUBIT_FALSE : CUBIT_TRUE);
-      ENTITY_LIST ENTITIES;
-      outcome result;
+    // if we're not recursing, set the skip flag to true
+  CubitBoolean skip = (recurse ? CUBIT_FALSE : CUBIT_TRUE);
+  ENTITY_LIST ENTITIES;
+  outcome result;
-      // vertices
-      if (IS_ENTITY_TYPE( this_ENTITY, VERTEX )) skip = CUBIT_TRUE;
-      if (!skip) {
-	result = api_get_vertices( this_ENTITY, ENTITIES);
-	num_deactivated += mark_owners_deactivated_flag( ENTITIES, flag );
-	ENTITIES.clear();
+    // vertices
+  if (IS_ENTITY_TYPE( this_ENTITY, VERTEX )) skip = CUBIT_TRUE;
+  if (!skip) {
+    result = api_get_vertices( this_ENTITY, ENTITIES);
+    num_deactivated += mark_owners_deactivated_flag( ENTITIES, flag );
+    ENTITIES.clear();
-      // edges
-      if (IS_ENTITY_TYPE( this_ENTITY, EDGE )) skip = CUBIT_TRUE;
-      if (!skip) {
-	result = api_get_edges( this_ENTITY, ENTITIES);
-	ENTITIES.clear();
+    // edges
+  if (IS_ENTITY_TYPE( this_ENTITY, EDGE )) skip = CUBIT_TRUE;
+  if (!skip) {
+    result = api_get_edges( this_ENTITY, ENTITIES);
+    ENTITIES.clear();
-      // coedges
-      if (IS_ENTITY_TYPE( this_ENTITY, COEDGE )) skip = CUBIT_TRUE;
-      if (!skip) {
-	result = api_get_coedges( this_ENTITY, ENTITIES);
-	ENTITIES.clear();
+    // coedges
+  if (IS_ENTITY_TYPE( this_ENTITY, COEDGE )) skip = CUBIT_TRUE;
+  if (!skip) {
+    result = api_get_coedges( this_ENTITY, ENTITIES);
+    ENTITIES.clear();
-      // loops
-      if (IS_ENTITY_TYPE( this_ENTITY, LOOP )) skip = CUBIT_TRUE;
-      if (!skip) {
-	result = api_get_loops( this_ENTITY, ENTITIES);
-	ENTITIES.clear();
+    // loops
+  if (IS_ENTITY_TYPE( this_ENTITY, LOOP )) skip = CUBIT_TRUE;
+  if (!skip) {
+    result = api_get_loops( this_ENTITY, ENTITIES);
+    ENTITIES.clear();
-      // faces
-      if (IS_ENTITY_TYPE( this_ENTITY, FACE )) skip = CUBIT_TRUE;
-      if (!skip) {
-	result = api_get_faces( this_ENTITY, ENTITIES);
-	ENTITIES.clear();
+    // faces
+  if (IS_ENTITY_TYPE( this_ENTITY, FACE )) skip = CUBIT_TRUE;
+  if (!skip) {
+    result = api_get_faces( this_ENTITY, ENTITIES);
+    ENTITIES.clear();
-      // shells
-      if (IS_ENTITY_TYPE( this_ENTITY, SHELL )) skip = CUBIT_TRUE;
-      if (!skip) {
-	result = api_get_shells( this_ENTITY, ENTITIES);
-	ENTITIES.clear();
+    // shells
+  if (IS_ENTITY_TYPE( this_ENTITY, SHELL )) skip = CUBIT_TRUE;
+  if (!skip) {
+    result = api_get_shells( this_ENTITY, ENTITIES);
+    ENTITIES.clear();
-      // volumes
-      if (IS_ENTITY_TYPE( this_ENTITY, LUMP )) skip = CUBIT_TRUE;
-      if (!skip) {
-	result = api_get_lumps( this_ENTITY, ENTITIES);
-	ENTITIES.clear();
+    // volumes
+  if (IS_ENTITY_TYPE( this_ENTITY, LUMP )) skip = CUBIT_TRUE;
+  if (!skip) {
+    result = api_get_lumps( this_ENTITY, ENTITIES);
+    ENTITIES.clear();
-      // now, finally, do the entity itself
-      ENTITIES.add(this_ENTITY);
+    // now, finally, do the entity itself
+  ENTITIES.add(this_ENTITY);
-      return num_deactivated;
+  return num_deactivated;
-  int AcisModifyEngine::mark_owners_deactivated_flag( ENTITY_LIST& ENTITIES,
-						      bool flag ) const
+int AcisModifyEngine::mark_owners_deactivated_flag( ENTITY_LIST& ENTITIES,
+                                                    bool flag ) const
+  for (int i = 0; i < ENTITIES.count(); i++)
+    AcisBridge *acis_bridge = ATTRIB_CUBIT_OWNER::cubit_owner(ENTITIES[i]);
+    if (acis_bridge != NULL)
+      if (flag == false)
+          // if bridge was deactivated, re-activate it and...
+        if (reactivate_bridge(acis_bridge))
+              // ...and get the pointers between
+              // ACIS and the TB right.
+          acis_bridge->ENTITY_ptr(ENTITIES[i]);
+          num_deactivated++;
+        else // bridge was already reactivated
+            // if we're reactivating an entity and it has already been reactivated,
+            // that means another acis entity is using it - make this acis entity
+            // get a new one
+          ATTRIB_CUBIT_OWNER::remove_cubit_owner(ENTITIES[i]);
-      for (int i = 0; i < ENTITIES.count(); i++)
-	  AcisBridge *acis_bridge = ATTRIB_CUBIT_OWNER::cubit_owner(ENTITIES[i]);
-	  if (acis_bridge != NULL)
-	      if (flag == false)
-		  // if bridge was deactivated, re-activate it and...
-		  if (reactivate_bridge(acis_bridge))
-		      // ...and get the pointers between
-		      // ACIS and the TB right.
-		      acis_bridge->ENTITY_ptr(ENTITIES[i]);
-		      num_deactivated++;
-		  else // bridge was already reactivated
-		      // if we're reactivating an entity and it has already been reactivated,
-		      // that means another acis entity is using it - make this acis entity
-		      // get a new one
-		      ATTRIB_CUBIT_OWNER::remove_cubit_owner(ENTITIES[i]);
-	      // if flag is true and acis_bridge is NOT deactivated,
-	      // deactivate it.
-	      else if (deactivate_bridge(acis_bridge))
+        // if flag is true and acis_bridge is NOT deactivated,
+        // deactivate it.
+      else if (deactivate_bridge(acis_bridge))
-  void AcisModifyEngine::print_deleted_reused(DLIList<BODY*> &old_BODY_list,
+void AcisModifyEngine::print_deleted_reused(DLIList<BODY*> &old_BODY_list,
                                               DLIList<BODY*> &new_BODY_list) const
-      // print out what's saved and what's not
-      DLIList<TopologyBridge*> deact_list, react_list;
-      int i;
-	AcisQueryEngine::instance()->get_all_cubit_owners(old_BODY_list.get_and_step(), deact_list);
-	AcisQueryEngine::instance()->get_all_cubit_owners(new_BODY_list.get_and_step(), react_list);
-      for (i = react_list.size(); i > 0; i--)
-	deact_list.remove(react_list.get_and_step());
-      PRINT_DEBUG_99( "Deleted entities:\n");
-      for (i = deact_list.size(); i > 0; i--) {
-	TopologyBridge* bridge = deact_list.get_and_step();
-	TopologyEntity *entity = bridge->topology_entity();
-	BasicTopologyEntity *bte = CAST_TO(entity, BasicTopologyEntity);
-	GroupingEntity *grpe = CAST_TO(entity, GroupingEntity);
-	SenseEntity *se = CAST_TO(entity, SenseEntity);
-	if (bte != NULL) {
-	  PRINT_DEBUG_99( "%s %d\n",
-			  bte->class_name(),
-			  bte->id());
-	else if (se != NULL) {
-	  PRINT_DEBUG_99( "%s (lower BTE: %d)\n",
-			  entity->class_name(),
-			  (se->get_basic_topology_entity_ptr() ?
-			   se->get_basic_topology_entity_ptr()->id() : 0));
-	else if (grpe != NULL) {
-	  PRINT_DEBUG_99( "%s (upper BTE: %d)\n",
-			  (grpe->get_basic_topology_entity_ptr() ?
-			   grpe->get_basic_topology_entity_ptr()->id() : 0));
-      PRINT_DEBUG_99( "ReUsed entities:\n");
-      for (i = react_list.size(); i > 0; i--) {
-	TopologyBridge* bridge = react_list.get_and_step();
-			  bte->id());
+    // print out what's saved and what's not
+  DLIList<TopologyBridge*> deact_list, react_list;
+  int i;
+    AcisQueryEngine::instance()->get_all_cubit_owners(old_BODY_list.get_and_step(), deact_list);
+    AcisQueryEngine::instance()->get_all_cubit_owners(new_BODY_list.get_and_step(), react_list);
+  for (i = react_list.size(); i > 0; i--)
+    deact_list.remove(react_list.get_and_step());
+  PRINT_DEBUG_99( "Deleted entities:\n");
+  for (i = deact_list.size(); i > 0; i--) {
+    TopologyBridge* bridge = deact_list.get_and_step();
+    TopologyEntity *entity = bridge->topology_entity();
+    BasicTopologyEntity *bte = CAST_TO(entity, BasicTopologyEntity);
+    GroupingEntity *grpe = CAST_TO(entity, GroupingEntity);
+    SenseEntity *se = CAST_TO(entity, SenseEntity);
+    if (bte != NULL) {
+      PRINT_DEBUG_99( "%s %d\n",
+                      bte->class_name(),
+                      bte->id());
+    else if (se != NULL) {
+      PRINT_DEBUG_99( "%s (lower BTE: %d)\n",
+                      entity->class_name(),
+                      (se->get_basic_topology_entity_ptr() ?
+                      se->get_basic_topology_entity_ptr()->id() : 0));
+    else if (grpe != NULL) {
+      PRINT_DEBUG_99( "%s (upper BTE: %d)\n",
+                      (grpe->get_basic_topology_entity_ptr() ?
+                       grpe->get_basic_topology_entity_ptr()->id() : 0));
+  PRINT_DEBUG_99( "ReUsed entities:\n");
+  for (i = react_list.size(); i > 0; i--) {
+    TopologyBridge* bridge = react_list.get_and_step();
+                      bte->id());
-  // Purpose       : Imprint multiple bodies at once
-  // Creator       : Tim Tautges
-  // Creation Date : 12/8/98
-  CubitStatus AcisModifyEngine::imprint(DLIList<BodySM*> &from_body_list,
-					DLIList<BodySM*> &new_from_body_list,
-					bool keep_old,
-					DLIList<TopologyBridge*> *new_tbs,
-					DLIList<TopologyBridge*> *att_tbs) const
+// Purpose       : Imprint multiple bodies at once
+// Special Notes :
+// Creator       : Tim Tautges
+// Creation Date : 12/8/98
+CubitStatus AcisModifyEngine::imprint(DLIList<BodySM*> &from_body_list,
+                                      DLIList<BodySM*> &new_from_body_list,
+                                      bool keep_old,
+                                      DLIList<TopologyBridge*> *new_tbs,
+                                      DLIList<TopologyBridge*> *att_tbs) const
-      CubitStatus success = CUBIT_SUCCESS;
+  CubitStatus success = CUBIT_SUCCESS;
-      from_body_list.reset();
-      int i, j;
+  from_body_list.reset();
+  int i, j;
-      // pass in keep_old to the delete_owner_attrib flag; if we're not keeping
-      // old bodies, we want to keep the owner attrib, so we can pick up entities
-      // that didn't change
-	(GeometryModifyTool::instance()->get_new_ids() || keep_old);
+    // pass in keep_old to the delete_owner_attrib flag; if we're not keeping
+    // old bodies, we want to keep the owner attrib, so we can pick up entities
+    // that didn't change
+      (GeometryModifyTool::instance()->get_new_ids() || keep_old);
-      const int num_bodies = from_body_list.size();
-      for (i = 0; i < num_bodies; i++) {
-	BODY *BODYPtr1 = AcisQueryEngine::get_BODY(from_body_list.next(i));
-	//BODY *BODYPtr1Save = this->copy_BODY(BODYPtr1, delete_attribs);
-	//from_BODY_list_copy.append(BODYPtr1Save);
-	from_BODY_list_copy.append(NULL);
+  const int num_bodies = from_body_list.size();
+  for (i = 0; i < num_bodies; i++) {
+    BODY *BODYPtr1 = AcisQueryEngine::get_BODY(from_body_list.next(i));
+    //BODY *BODYPtr1Save = this->copy_BODY(BODYPtr1, delete_attribs);
+    //from_BODY_list_copy.append(BODYPtr1Save);
+    from_BODY_list_copy.append(NULL);
-      if (from_BODY_list.is_in_list(NULL))
-	return CUBIT_FAILURE;
+  if (from_BODY_list.is_in_list(NULL))
+    return CUBIT_FAILURE;
-      // set the free_edges acis option
+  // set the free_edges acis option
       // total number of imprints to be done
-      int total_imprints = (from_body_list.size() *
-			    (from_body_list.size()-1))/2;
+  int total_imprints = (from_body_list.size() *
+                        (from_body_list.size()-1))/2;
-      if( num_bodies > 2 )
-	  char message[128];
-	  sprintf(message, "Imprinting %d ACIS Bodies", from_BODY_list.size() );
-	  AppUtil::instance()->progress_tool()->start(0, total_imprints, message);
+  if( num_bodies > 2 )
+     char message[128];
+     sprintf(message, "Imprinting %d ACIS Bodies", from_BODY_list.size() );
+     AppUtil::instance()->progress_tool()->start(0, total_imprints, message);
-      // imprint each body with each one later in the list
-      for (i = 0; success && i < num_bodies - 1; i++) {
-	//BODY *BODY_Ptr1 = from_BODY_list_copy.next(i);
-	BodySM *Body_Ptr1 = from_body_list.next(i);
-	CubitBox box1 = AcisQueryEngine::instance()->bounding_box(Body_Ptr1);
+    // imprint each body with each one later in the list
+  for (i = 0; success && i < num_bodies - 1; i++) {
+    //BODY *BODY_Ptr1 = from_BODY_list_copy.next(i);
+    BodySM *Body_Ptr1 = from_body_list.next(i);
+    CubitBox box1 = AcisQueryEngine::instance()->bounding_box(Body_Ptr1);
-	for (j = i + 1; j < num_bodies; j++) {
+    for (j = i + 1; j < num_bodies; j++) {
-	  if (CubitMessage::instance()->Interrupt())
-	      success = CUBIT_FAILURE;
-	      break;
+      if (CubitMessage::instance()->Interrupt())
+        success = CUBIT_FAILURE;
+        break;
-	  //BODY *BODY_Ptr2 = from_BODY_list_copy.next(j);
-	  BodySM *Body_Ptr2 = from_body_list.next(j);
-	  CubitBox box2 = AcisQueryEngine::instance()->bounding_box(Body_Ptr2);
+      //BODY *BODY_Ptr2 = from_BODY_list_copy.next(j);
+      BodySM *Body_Ptr2 = from_body_list.next(j);
+      CubitBox box2 = AcisQueryEngine::instance()->bounding_box(Body_Ptr2);
-	  if (box1.overlap(SPAresabs, box2))
-		  TopologyEntity *te1 = Body_Ptr1->topology_entity();
-		  TopologyEntity *te2 = Body_Ptr2->topology_entity();
-		  RefEntity *ref1 = CAST_TO(te1, RefEntity );
-		  RefEntity *ref2 = CAST_TO(te2, RefEntity );
-		  PRINT_INFO("Imprinting bodies %d and %d\n", ref1->id(), ref2->id() );
+      if (box1.overlap(SPAresabs, box2))
+          TopologyEntity *te1 = Body_Ptr1->topology_entity();
+          TopologyEntity *te2 = Body_Ptr2->topology_entity();
+          RefEntity *ref1 = CAST_TO(te1, RefEntity );
+          RefEntity *ref2 = CAST_TO(te2, RefEntity );
+          PRINT_INFO("Imprinting bodies %d and %d\n", ref1->id(), ref2->id() );
-	      BODY* BODY_Ptr1 = from_BODY_list_copy.next(i);
-	      BODY* BODY_Ptr2 = from_BODY_list_copy.next(j);
-	      if (!BODY_Ptr1)
-		BODY_Ptr1 = from_BODY_list.next(i);
-	      if (!BODY_Ptr2)
-		BODY_Ptr2 = from_BODY_list.next(j);
+        BODY* BODY_Ptr1 = from_BODY_list_copy.next(i);
+        BODY* BODY_Ptr2 = from_BODY_list_copy.next(j);
+        if (!BODY_Ptr1)
+          BODY_Ptr1 = from_BODY_list.next(i);
+        if (!BODY_Ptr2)
+          BODY_Ptr2 = from_BODY_list.next(j);
-	      BODY_Ptr1 = copy_BODY(BODY_Ptr1, delete_attribs);
-	      BODY_Ptr2 = copy_BODY(BODY_Ptr2, delete_attribs);
-	      // the bodies overlap; proceed with the imprint
-	      outcome result = api_imprint(BODY_Ptr1, BODY_Ptr2);
+        BODY_Ptr1 = copy_BODY(BODY_Ptr1, delete_attribs);
+        BODY_Ptr2 = copy_BODY(BODY_Ptr2, delete_attribs);
+        // the bodies overlap; proceed with the imprint
+        outcome result = api_imprint(BODY_Ptr1, BODY_Ptr2);
-	      AcisModifyEngine::instance()->cleanup_slivers( BODY_Ptr1 );
-	      AcisModifyEngine::instance()->cleanup_slivers( BODY_Ptr2 );
+        AcisModifyEngine::instance()->cleanup_slivers( BODY_Ptr1 );
+        AcisModifyEngine::instance()->cleanup_slivers( BODY_Ptr2 );
-	      if (result.ok())
-		  from_BODY_list_copy.step(i);
-		  if (from_BODY_list_copy.get())
-		    api_delent(from_BODY_list_copy.get());
-		  from_BODY_list_copy.change_to(BODY_Ptr1);
+        if (result.ok())
+          from_BODY_list_copy.step(i);
+          if (from_BODY_list_copy.get())
+            api_delent(from_BODY_list_copy.get());
+          from_BODY_list_copy.change_to(BODY_Ptr1);
-		  from_BODY_list_copy.step(j);
-		  from_BODY_list_copy.change_to(BODY_Ptr2);
-	      else
-		  if (DEBUG_FLAG(95)) {
+          from_BODY_list_copy.step(j);
+          from_BODY_list_copy.change_to(BODY_Ptr2);
+        else
+          if (DEBUG_FLAG(95)) {
-		  if (BODY_Ptr1)
-		    api_delent(BODY_Ptr1);
-		  if (BODY_Ptr2)
-		    api_delent(BODY_Ptr2);
-	    } // if overlap
+          if (BODY_Ptr1)
+            api_delent(BODY_Ptr1);
+          if (BODY_Ptr2)
+            api_delent(BODY_Ptr2);
+      } // if overlap
-	    AppUtil::instance()->progress_tool()->step();
-	AppUtil::instance()->progress_tool()->end();
+        AppUtil::instance()->progress_tool()->step();
-      if( CubitMessage::instance()->Interrupt() )
-	PRINT_INFO("Imprint aborted.\n");
+      AppUtil::instance()->progress_tool()->end();
-      // new_ENTITIES will hold new entities that were created by
-      // the imprint operation.  att_ENTITIES will hold entities
-      // from the original bodies that had composite attributes
-      // on them.  At the end we will compare the new entities
-      // with the ones that had attributes and if we find matches
-      // we will put a composite attribute on the new entity.
-      // This is how we are handling the imprinting of bodies
-      // with composites.
-      DLIList<ENTITY*> new_ENTITIES;
-      DLIList<ENTITY*> att_ENTITIES;
+  if( CubitMessage::instance()->Interrupt() )
+    PRINT_INFO("Imprint aborted.\n");
-      // Create/update ACIS Bridges.
-      for ( i = 0; i < num_bodies; i++ )
-	  BodySM* from_body = from_body_list.next(i);
-	  BODY*   from_BODY = from_BODY_list.next(i);
-	  BODY* new_BODY = from_BODY_list_copy.next(i);
-	  if (new_BODY)
-	      // Get the new entities (just edges for now)
-	      // created by the imprint operation.
-	      DLIList<ENTITY*> cur_new_ENTITIES;
-	      if(new_tbs)
-		get_new_ENTITIES(new_BODY, cur_new_ENTITIES);
+  // new_ENTITIES will hold new entities that were created by
+  // the imprint operation.  att_ENTITIES will hold entities
+  // from the original bodies that had composite attributes
+  // on them.  At the end we will compare the new entities
+  // with the ones that had attributes and if we find matches
+  // we will put a composite attribute on the new entity.
+  // This is how we are handling the imprinting of bodies
+  // with composites.
+  DLIList<ENTITY*> new_ENTITIES;
+  DLIList<ENTITY*> att_ENTITIES;
-	      DLIList<EDGE*> new_edges = AcisModifyEngine::instance()->find_new_EDGES(new_BODY);
+  // Create/update ACIS Bridges.
+  for ( i = 0; i < num_bodies; i++ )
+    BodySM* from_body = from_body_list.next(i);
+    BODY*   from_BODY = from_BODY_list.next(i);
+    BODY* new_BODY = from_BODY_list_copy.next(i);
+    if (new_BODY)
+      // Get the new entities (just edges for now)
+      // created by the imprint operation.
+      DLIList<ENTITY*> cur_new_ENTITIES;
+      if(new_tbs)
+        get_new_ENTITIES(new_BODY, cur_new_ENTITIES);
-	      BodySM* new_body = get_new_Body( from_body, from_BODY, new_BODY, keep_old, true );
-	      if (new_body)
-		  // Add the new entities to the list we are
-		  // accumulating.
-		  if(new_tbs)
-		    new_ENTITIES += cur_new_ENTITIES;
+      DLIList<EDGE*> new_edges = AcisModifyEngine::instance()->find_new_EDGES(new_BODY);
-		  // Get entities with composite attributes.
-		  if(att_tbs)
-		    get_att_ENTITIES(new_BODY, att_ENTITIES, "COMPOSITE_GEOM");
+      BodySM* new_body = get_new_Body( from_body, from_BODY, new_BODY, keep_old, true );
+      if (new_body)
+        // Add the new entities to the list we are
+        // accumulating.
+        if(new_tbs)
+          new_ENTITIES += cur_new_ENTITIES;
-		  new_from_body_list.append(new_body);
-	      else
-		  if(att_tbs)
-		    get_att_ENTITIES(from_BODY, att_ENTITIES, "COMPOSITE_GEOM");
+        // Get entities with composite attributes.
+        if(att_tbs)
+          get_att_ENTITIES(new_BODY, att_ENTITIES, "COMPOSITE_GEOM");
-      // Convert the new_ENTITIES/att_ENTITIES lists into
-      // topology bridge lists.
-      if(new_tbs)
-	  for(i=new_ENTITIES.size(); i--;)
-	      ENTITY *cur_ENT = new_ENTITIES.get_and_step();
-	      AcisBridge *acis_bridge = ATTRIB_CUBIT_OWNER::cubit_owner(cur_ENT);
-	      if(dynamic_cast<TopologyBridge*>(acis_bridge))
-		new_tbs->append_unique(dynamic_cast<TopologyBridge*>(acis_bridge));
-      if(att_tbs)
-	  for(i=att_ENTITIES.size(); i--;)
-	      ENTITY *cur_ENT = att_ENTITIES.get_and_step();
-		att_tbs->append_unique(dynamic_cast<TopologyBridge*>(acis_bridge));
+        new_from_body_list.append(new_body);
+      else
+        if(att_tbs)
+          get_att_ENTITIES(from_BODY, att_ENTITIES, "COMPOSITE_GEOM");
+  // Convert the new_ENTITIES/att_ENTITIES lists into
+  // topology bridge lists.
+  if(new_tbs)
+    for(i=new_ENTITIES.size(); i--;)
+      ENTITY *cur_ENT = new_ENTITIES.get_and_step();
+      AcisBridge *acis_bridge = ATTRIB_CUBIT_OWNER::cubit_owner(cur_ENT);
+      if(dynamic_cast<TopologyBridge*>(acis_bridge))
+        new_tbs->append_unique(dynamic_cast<TopologyBridge*>(acis_bridge));
+  if(att_tbs)
+    for(i=att_ENTITIES.size(); i--;)
+      ENTITY *cur_ENT = att_ENTITIES.get_and_step();
+        att_tbs->append_unique(dynamic_cast<TopologyBridge*>(acis_bridge));
-      PRINT_INFO("Group imprint finished.\n");
-      // reset the free_edges acis option
+  PRINT_INFO("Group imprint finished.\n");
-      return success;
+  // reset the free_edges acis option
-  // Purpose       : Projects an EDGE to a FACE
-  // Special Notes :
-  // Creator       : Eric Nielsen
-  // Creation Date : 06/14/00
-  EDGE* AcisModifyEngine::project_EDGE(EDGE* EDGE_in_ptr, FACE* FACE_ptr, bool print_error ) const
-      curve* in_crv=NULL;
-      surface *in_srf=NULL;
-      curve * out_crv = NULL;
-      EDGE * new_EDGE = NULL;
+  return success;
-      if(FACE_ptr && FACE_ptr->geometry())
-	  SPAtransf t= get_owner_transf(FACE_ptr);
-	  in_srf = FACE_ptr->geometry()->trans_surface(t);
+// Purpose       : Projects an EDGE to a FACE
+// Special Notes :
+// Creator       : Eric Nielsen
+// Creation Date : 06/14/00
+EDGE* AcisModifyEngine::project_EDGE(EDGE* EDGE_in_ptr, FACE* FACE_ptr, bool print_error ) const
+  curve* in_crv=NULL;
+  surface *in_srf=NULL;
+  curve * out_crv = NULL;
+  EDGE * new_EDGE = NULL;
-      if(EDGE_in_ptr && EDGE_in_ptr->geometry())
-	  SPAtransf t= get_owner_transf(EDGE_in_ptr);
-	  in_crv = EDGE_in_ptr->geometry()->trans_curve(t);
+  if(FACE_ptr && FACE_ptr->geometry())
+    SPAtransf t= get_owner_transf(FACE_ptr);
+    in_srf = FACE_ptr->geometry()->trans_surface(t);
-      if(in_crv && in_srf)
-	  // create the curve
-	  SPAinterval in_range = EDGE_in_ptr->param_range();
+  if(EDGE_in_ptr && EDGE_in_ptr->geometry())
+    SPAtransf t= get_owner_transf(EDGE_in_ptr);
+    in_crv = EDGE_in_ptr->geometry()->trans_curve(t);
-	  if( EDGE_in_ptr->sense() )
-	    in_range.negate();
+  if(in_crv && in_srf)
+    // create the curve
+    SPAinterval in_range = EDGE_in_ptr->param_range();
-	  outcome result = api_project_curve_to_surface(*in_crv, in_range, *in_srf, out_crv);
+    if( EDGE_in_ptr->sense() )
+      in_range.negate();
-	  if (!result.ok() || out_crv == NULL) //out_crv check added 6/18/04 by aga at cat
-	    //api CAN return a null curve in some failures- if so we'll end the fcn here and return
-	      if( print_error )
-		  AcisQueryEngine::instance()->ACIS_API_error (result);
-		  PRINT_ERROR( "api_project_curve_to_surface failed ");
-	      return (EDGE *)NULL;
+    outcome result = api_project_curve_to_surface(*in_crv, in_range, *in_srf, out_crv);
-	  // create the CURVE
-	  CURVE *the_curve=make_curve(*out_crv);
+    if (!result.ok() || out_crv == NULL) //out_crv check added 6/18/04 by aga at cat
+    //api CAN return a null curve in some failures- if so we'll end the fcn here and return
+      if( print_error )
+        AcisQueryEngine::instance()->ACIS_API_error (result);
+        PRINT_ERROR( "api_project_curve_to_surface failed ");
+      return (EDGE *)NULL;
-	  // get ends of the edge
-	  SPAposition pt0=out_crv->eval_position(in_range.start_pt());
-	  SPAposition pt1=out_crv->eval_position(in_range.end_pt());
+    // create the CURVE
+    CURVE *the_curve=make_curve(*out_crv);
-	  ACIS_DELETE out_crv;
+    // get ends of the edge
+    SPAposition pt0=out_crv->eval_position(in_range.start_pt());
+    SPAposition pt1=out_crv->eval_position(in_range.end_pt());
-	  // create the vertices
-	  VERTEX *svert= ACIS_NEW VERTEX( ACIS_NEW APOINT(pt0));
+    ACIS_DELETE out_crv;
-	  // -- check for a closed edge
-	  VERTEX *evert= NULL;
-	  if ( pt0 != pt1 )
-	    evert = ACIS_NEW VERTEX( ACIS_NEW APOINT(pt1));
-	  else
-	    evert = svert;
+    // create the vertices
+    VERTEX *svert= ACIS_NEW VERTEX( ACIS_NEW APOINT(pt0));
-	  // make the edge
-	  new_EDGE= ACIS_NEW EDGE(svert,evert,the_curve,FORWARD,EDGE_cvty_unknown,in_range);
+    // -- check for a closed edge
+    VERTEX *evert= NULL;
+    if ( pt0 != pt1 )
+      evert = ACIS_NEW VERTEX( ACIS_NEW APOINT(pt1));
+    else
+      evert = svert;
-      if(in_crv)
-	ACIS_DELETE in_crv;
-      if(in_srf)
-	ACIS_DELETE in_srf;
+    // make the edge
+    new_EDGE= ACIS_NEW EDGE(svert,evert,the_curve,FORWARD,EDGE_cvty_unknown,in_range);
-      if(new_EDGE)
-	  ENTITY *edge_entity = (ENTITY*)new_EDGE;
-	  api_simplify_entity( edge_entity );
-	  return new_EDGE;
-      else
+  if(in_crv)
+    ACIS_DELETE in_crv;
+  if(in_srf)
+    ACIS_DELETE in_srf;
-  // Purpose       : Projects a list of RefEdges on to a list of RefFaces
-  //                 returning a list of new RefEdges
-  CubitStatus AcisModifyEngine::project_edges( DLIList<Surface*> &ref_face_list,
-					       DLIList<Curve*> &ref_edge_list_in,
-					       DLIList<Curve*> &ref_edge_list_new,
-					       bool print_error ) const
-      Curve* ref_edge = NULL;
-      Surface* ref_face = NULL;
-      EDGE *new_EDGE_ptr = NULL;
+  if(new_EDGE)
+    ENTITY *edge_entity = (ENTITY*)new_EDGE;
+    api_simplify_entity( edge_entity );
+    return new_EDGE;
+  else
-      for(int j=0; j< ref_face_list.size(); j++)
-	  ref_face = ref_face_list.get_and_step();
+// Purpose       : Projects a list of RefEdges on to a list of RefFaces
+//                 returning a list of new RefEdges
+// Special Notes :
+CubitStatus AcisModifyEngine::project_edges( DLIList<Surface*> &ref_face_list,
+                                             DLIList<Curve*> &ref_edge_list_in,
+                                             DLIList<Curve*> &ref_edge_list_new,
+                                             bool print_error ) const
+  Curve* ref_edge = NULL;
+  Surface* ref_face = NULL;
+  EDGE *new_EDGE_ptr = NULL;
-	  FACE *FACE_ptr = AcisQueryEngine::get_FACE( ref_face );
+  for(int j=0; j< ref_face_list.size(); j++)
+    ref_face = ref_face_list.get_and_step();
-	  for(int i=0; i< ref_edge_list_in.size(); i++)
-	      ref_edge = ref_edge_list_in.get_and_step();
+    FACE *FACE_ptr = AcisQueryEngine::get_FACE( ref_face );
-	      EDGE *EDGE_ptr = AcisQueryEngine::get_EDGE(ref_edge);
+    for(int i=0; i< ref_edge_list_in.size(); i++)
+      ref_edge = ref_edge_list_in.get_and_step();
-	      new_EDGE_ptr = project_EDGE(EDGE_ptr,FACE_ptr, print_error );
+      EDGE *EDGE_ptr = AcisQueryEngine::get_EDGE(ref_edge);
-	      if (!new_EDGE_ptr)
-		  if( print_error )
-		    PRINT_ERROR( "Unable to project curve on surface\n" );
-		  continue;
-	      else{
-		Curve *curve_ptr = AcisQueryEngine::instance()->populate_topology_bridges(new_EDGE_ptr);
-		ref_edge_list_new.append(curve_ptr);
+      new_EDGE_ptr = project_EDGE(EDGE_ptr,FACE_ptr, print_error );
+      if (!new_EDGE_ptr)
+        if( print_error )
+          PRINT_ERROR( "Unable to project curve on surface\n" );
+        continue;
+      else{
+        Curve *curve_ptr = AcisQueryEngine::instance()->populate_topology_bridges(new_EDGE_ptr);
+        ref_edge_list_new.append(curve_ptr);
-      if (ref_edge_list_new.size() == ref_edge_list_in.size())
-	return CUBIT_SUCCESS;
-      else
-  //                 and imprint the faces with the new RefEdges
-  CubitStatus AcisModifyEngine::imprint_projected_edges(DLIList<Surface*> &ref_face_list,
-							DLIList<BodySM*>& new_body_list,
-							bool keep_old_body,
-							bool keep_free_edges) const
-      CubitStatus status;
+  if (ref_edge_list_new.size() == ref_edge_list_in.size())
+    return CUBIT_SUCCESS;
+  else
-      DLIList<Curve*> ref_edge_list_new;
+//                 and imprint the faces with the new RefEdges
+// Special Notes :
+CubitStatus AcisModifyEngine::imprint_projected_edges(DLIList<Surface*> &ref_face_list,
+                                                      DLIList<BodySM*>& new_body_list,
+                                                      bool keep_old_body,
+                                                      bool keep_free_edges) const
+  CubitStatus status;
-      project_edges(ref_face_list, ref_edge_list_in, ref_edge_list_new);
+  DLIList<Curve*> ref_edge_list_new;
-      // imprint Surface with curves
-      status = imprint(ref_face_list, ref_edge_list_new, new_body_list, keep_old_body );
+  project_edges(ref_face_list, ref_edge_list_in, ref_edge_list_new);
-      if (keep_free_edges)
-	return  status;
+  // imprint Surface with curves
+  status = imprint(ref_face_list, ref_edge_list_new, new_body_list, keep_old_body );
-      PRINT_INFO( "Removing projected curves \n");
-      for(int i=0; i< ref_edge_list_new.size();i++){
-	// Now delete this RefEdge and its underlying solid model entities
+  if (keep_free_edges)
+    return  status;
-	Curve* ref_edge = ref_edge_list_new.get_and_step();
-	status = AcisQueryEngine::instance()->
-	  delete_solid_model_entities( ref_edge );
-	if (status == CUBIT_FAILURE)
-	    PRINT_ERROR("In GeometryQueryTool::delete_geometry\n"
-			"       Could not delete RefEdge.\n"
-			"       The Model database is likely corrupted "
-			"due to\n       this unsuccessful deletion.\n" );
-      return status;
+  PRINT_INFO( "Removing projected curves \n");
+  for(int i=0; i< ref_edge_list_new.size();i++){
+    // Now delete this RefEdge and its underlying solid model entities
-  //                 and imprint the bodies with the new RefEdges
-							DLIList<BodySM*> &body_list,
+    Curve* ref_edge = ref_edge_list_new.get_and_step();
+    status = AcisQueryEngine::instance()->
+      delete_solid_model_entities( ref_edge );
+    if (status == CUBIT_FAILURE)
+      PRINT_ERROR("In GeometryQueryTool::delete_geometry\n"
+        "       Could not delete RefEdge.\n"
+        "       The Model database is likely corrupted "
+        "due to\n       this unsuccessful deletion.\n" );
+  return status;
+//                 and imprint the bodies with the new RefEdges
+// Special Notes :
+                                                      DLIList<BodySM*> &body_list,
-      // imprint bodies with curves
-      status = imprint(body_list,ref_edge_list_new,new_body_list, keep_old_body );
-	return  status;
+  // imprint bodies with curves
+  status = imprint(body_list,ref_edge_list_new,new_body_list, keep_old_body );
+    return  status;
-	    PRINT_ERROR("In GeometryModifyTool::delete_geometry\n"
-      return status;
+      PRINT_ERROR("In GeometryModifyTool::delete_geometry\n"
+  return status;
-  // Purpose       : Boolean Operation of body with list of bodies.
-  // Special Notes : INTERSECTION
-  // Creator       : David White
-  // Creation Date : 11/24/97
-  CubitStatus AcisModifyEngine::intersect( BodySM* tool_body,
+// Purpose       : Boolean Operation of body with list of bodies.
+// Special Notes : INTERSECTION
+// Creator       : David White
+// Creation Date : 11/24/97
+CubitStatus AcisModifyEngine::intersect( BodySM* tool_body,
                                            DLIList<BodySM*> &from_bodies,
                                            DLIList<BodySM*> &new_from_bodies,
                                            bool keep_old) const
-      bool delete_attribs =
+  bool delete_attribs =
-      int ii;
-      CubitBox tool_box = AcisQueryEngine::instance()->bounding_box(tool_body);
+  int ii;
+  CubitBox tool_box = AcisQueryEngine::instance()->bounding_box(tool_body);
-      DLIList<BODY*> from_BODY_list;
-      DLIList<BODY*> from_BODY_list_copy;
+  DLIList<BODY*> from_BODY_list;
+  DLIList<BODY*> from_BODY_list_copy;
-      // get acis bodies, and copy them
-      from_bodies.reset();
+  // get acis bodies, and copy them
+  from_bodies.reset();
-      for (ii = from_bodies.size(); ii > 0; ii--) {
-	BODY *BODYPtr1 = AcisQueryEngine::get_BODY(from_bodies.get_and_step());
-	from_BODY_list.append(BODYPtr1);
-	BODYPtr1 = this->copy_BODY(BODYPtr1, delete_attribs);
-	from_BODY_list_copy.append(BODYPtr1);
+  for (ii = from_bodies.size(); ii > 0; ii--) {
+    BODY *BODYPtr1 = AcisQueryEngine::get_BODY(from_bodies.get_and_step());
+    from_BODY_list.append(BODYPtr1);
+    BODYPtr1 = this->copy_BODY(BODYPtr1, delete_attribs);
+    from_BODY_list_copy.append(BODYPtr1);
-      if (from_BODY_list.size() != from_bodies.size())
+  if (from_BODY_list.size() != from_bodies.size())
-      // check if the boolean operation is regularized or nonregularized
-      BOOL_TYPE bool_type = INTERSECTION;
-      CubitBoolean boolean_regularize = GeometryModifyTool::instance()->boolean_regularize();
+    // check if the boolean operation is regularized or nonregularized
+  BOOL_TYPE bool_type = INTERSECTION;
+  CubitBoolean boolean_regularize = GeometryModifyTool::instance()->boolean_regularize();
-      if (boolean_regularize == FALSE)
-	  bool_type = NONREG_INTERSECTION;
+  if (boolean_regularize == FALSE)
+    bool_type = NONREG_INTERSECTION;
-      // now, intersect the tool with the list of bodies
-      from_BODY_list.reset();
-      from_BODY_list_copy.reset();
+  // now, intersect the tool with the list of bodies
+  from_BODY_list.reset();
+  from_BODY_list_copy.reset();
-      CubitStatus int_stat = CUBIT_SUCCESS;
+  CubitStatus int_stat = CUBIT_SUCCESS;
-      // intersect the tool body with each body in the list
-      for (ii = 1; ii <= from_BODY_list.size(); ii++) {
-	BODY *from_BODY = from_BODY_list.get();
-	BODY *from_BODY_copy = from_BODY_list_copy.get();
-	BodySM *from_Body = from_bodies.get();
-	CubitBox box1 = AcisQueryEngine::instance()->bounding_box(from_Body);
+    // intersect the tool body with each body in the list
+  for (ii = 1; ii <= from_BODY_list.size(); ii++) {
+    BODY *from_BODY = from_BODY_list.get();
+    BODY *from_BODY_copy = from_BODY_list_copy.get();
+    BodySM *from_Body = from_bodies.get();
+    CubitBox box1 = AcisQueryEngine::instance()->bounding_box(from_Body);
-	// first, check bounding SPAbox; if they don't intersect, don't do the intersection
+      // first, check bounding SPAbox; if they don't intersect, don't do the intersection
-	if (from_Body == tool_body) {
-	  PRINT_ERROR("Can't intersect volume with itself.\n");
+    if (from_Body == tool_body) {
+      PRINT_ERROR("Can't intersect volume with itself.\n");
-	else if (tool_box.overlap(SPAresabs, box1)) {
+    else if (tool_box.overlap(SPAresabs, box1)) {
-	  // the bodies overlap; proceed with the intersect
-	  BODY* tool_BODY = AcisQueryEngine::get_BODY(tool_body);
-	  BODY *tool_BODY_copy = this->copy_BODY(tool_BODY);
+        // the bodies overlap; proceed with the intersect
+      BODY* tool_BODY = AcisQueryEngine::get_BODY(tool_body);
+      BODY *tool_BODY_copy = this->copy_BODY(tool_BODY);
-	  // Intersect body1 with body2.
-	  //outcome result = api_intersect( tool_BODY_copy, from_BODY_copy );
-	  outcome result = api_boolean(tool_BODY_copy, from_BODY_copy, bool_type );
+        // Intersect body1 with body2.
+        //outcome result = api_intersect( tool_BODY_copy, from_BODY_copy );
+       outcome result = api_boolean(tool_BODY_copy, from_BODY_copy, bool_type );
-	  // We may or may not get an error if the resulting BODY is
-	  // empty
-	  // Also check the result.
-	  if (from_BODY_copy == NULL ||
-	      (from_BODY_copy->lump() == NULL && from_BODY_copy->wire() == NULL) ||
-	      !result.ok())
-	      if (!result.ok())
-		  PRINT_ERROR("Intersection operation failed.\n");
-		  AcisQueryEngine::instance()->ACIS_API_error(result, "intersect Bodies");
-		  int_stat = CUBIT_FAILURE;
+        // We may or may not get an error if the resulting BODY is
+        // empty
+        // Also check the result.
+      if (from_BODY_copy == NULL ||
+          (from_BODY_copy->lump() == NULL && from_BODY_copy->wire() == NULL) ||
+          !result.ok())
+        if (!result.ok())
+          PRINT_ERROR("Intersection operation failed.\n");
+          AcisQueryEngine::instance()->ACIS_API_error(result, "intersect Bodies");
+          int_stat = CUBIT_FAILURE;
-		  //I might need to take this out.  Not sure. CDE 10/17/2003
-		  if (tool_BODY_copy != NULL)
-		      AcisQueryEngine::instance()->delete_ACIS_BODY(tool_BODY_copy, CUBIT_TRUE);
-	      else
-			    "       Empty volume created and will be deleted.\n");
-	      if (from_BODY_copy != NULL)
-		  AcisQueryEngine::instance()->delete_ACIS_BODY(from_BODY_copy, CUBIT_TRUE);
+          //I might need to take this out.  Not sure. CDE 10/17/2003
+          if (tool_BODY_copy != NULL)
+            AcisQueryEngine::instance()->delete_ACIS_BODY(tool_BODY_copy, CUBIT_TRUE);
+        else
+                      "       Empty volume created and will be deleted.\n");
+        if (from_BODY_copy != NULL)
+          AcisQueryEngine::instance()->delete_ACIS_BODY(from_BODY_copy, CUBIT_TRUE);
-	      // we had an error, so put the original body into the copy list
-	      from_BODY_list_copy.change_to(from_BODY);
+          // we had an error, so put the original body into the copy list
+        from_BODY_list_copy.change_to(from_BODY);
-	  if ( bool_type == NONREG_INTERSECTION)
-	      outcome result1;
-	      // ENTITY_LIST FACES;
-	      DLIList<FACE*>  FACE_list ;
-	      FACE *this_FACE;
-	      AcisQueryEngine::instance()->get_FACEs(from_BODY_copy,FACE_list);
-	      // loop through all faces
-	      for( int i = 0; i< FACE_list.size(); i++)
-		  this_FACE = FACE_list.get_and_step();
-		  assert( this_FACE != NULL );
-		  // Make sure this is a DOUBLE_SIDED FACE
-		  if (this_FACE->sides() == DOUBLE_SIDED)
+      if ( bool_type == NONREG_INTERSECTION)
+		    outcome result1;
+		    // ENTITY_LIST FACES;
+            DLIList<FACE*>  FACE_list ;
+		    FACE *this_FACE;
+            AcisQueryEngine::instance()->get_FACEs(from_BODY_copy,FACE_list);
+		     // loop through all faces
+		    for( int i = 0; i< FACE_list.size(); i++)
-		      if (this_FACE->cont()==BOTH_INSIDE)
-			  // found internal faces
-			  // Now we have the FACE - unhook it  from the BODY.  Keep track of new
-			  // BODIES that are created as this is done.
-			  PRINT_INFO( " Unhooking and deleting each internal surface...\n" );
-			  BODY *new_BODY_ptr;
-			  result1 = api_unhook_face( this_FACE, new_BODY_ptr );
-			  if( !result1.ok() )
+			    this_FACE = FACE_list.get_and_step();
+			    assert( this_FACE != NULL );
+			    // Make sure this is a DOUBLE_SIDED FACE
+			    if (this_FACE->sides() == DOUBLE_SIDED)
-			      AcisModifyEngine::instance()->get_acis_query_engine()->ACIS_API_error( result1 );
-			      PRINT_ERROR( " Face unhooking during rebuild of volume didn't work\n" );
+				    if (this_FACE->cont()==BOTH_INSIDE)
+					    // found internal faces
+					    // Now we have the FACE - unhook it  from the BODY.  Keep track of new
+					    // BODIES that are created as this is done.
+					     PRINT_INFO( " Unhooking and deleting each internal surface...\n" );
+					     BODY *new_BODY_ptr;
+					     result1 = api_unhook_face( this_FACE, new_BODY_ptr );
+					     if( !result1.ok() )
+						     AcisModifyEngine::instance()->get_acis_query_engine()->ACIS_API_error( result1 );
+						     PRINT_ERROR( " Face unhooking during rebuild of volume didn't work\n" );
+					     AcisQueryEngine::instance()->delete_ACIS_BODY (new_BODY_ptr);
-			  AcisQueryEngine::instance()->delete_ACIS_BODY (new_BODY_ptr);
-	      // heal the leftover body
-	      //		   PRINT_INFO(" Healing the leftover volume...\n");
-	      //		   if( AcisHealerTool::instance()->init_BODY_for_healing( master ) == CUBIT_SUCCESS )
-	      //			   int percent_before, percent_after, number_splines_simplified;
-	      //			   if( AcisHealerTool::instance()->heal_BODY( master, percent_before,
-	      //				   percent_after, number_splines_simplified ) == CUBIT_FAILURE )
-	      //				   PRINT_ERROR( "Error healing the combined volume\n" );
-	      //			   else
-	      //				   PRINT_INFO( "Successfully healed the combined volume.\n" );
-	      //			   AcisHealerTool::instance()->end_BODY_for_healing( master );
+		 // heal the leftover body
+//		   PRINT_INFO(" Healing the leftover volume...\n");
+//		   if( AcisHealerTool::instance()->init_BODY_for_healing( master ) == CUBIT_SUCCESS )
+//			   int percent_before, percent_after, number_splines_simplified;
+//			   if( AcisHealerTool::instance()->heal_BODY( master, percent_before,
+//				   percent_after, number_splines_simplified ) == CUBIT_FAILURE )
+//				   PRINT_ERROR( "Error healing the combined volume\n" );
+//			   else
+//				   PRINT_INFO( "Successfully healed the combined volume.\n" );
+//			   AcisHealerTool::instance()->end_BODY_for_healing( master );
-	  // done with this j iteration; write out count, if necessary
-	  //      if (from_bodies.size() > 1) {
-	  //        int frac_done = (10 * ii) / from_bodies.size();
-	  //        if ((10 - frac_done) < fraction_remaining) {
-	  //          PRINT_INFO("%d ", fraction_remaining);
-	  //          fraction_remaining--;
+      // done with this j iteration; write out count, if necessary
+//      if (from_bodies.size() > 1) {
+//        int frac_done = (10 * ii) / from_bodies.size();
+//        if ((10 - frac_done) < fraction_remaining) {
+//          PRINT_INFO("%d ", fraction_remaining);
+//          fraction_remaining--;
-	else {
+    else {
-	// done with iteration over ii; step the lists
-	from_BODY_list_copy.step();
-	from_BODY_list.step();
-	from_bodies.step();
+      // done with iteration over ii; step the lists
+    from_BODY_list_copy.step();
+    from_BODY_list.step();
+    from_bodies.step();
-      //  PRINT_INFO("\n");
+//  PRINT_INFO("\n");
-      // ok, we're done; construct new Body's for the new BODY's
+    // ok, we're done; construct new Body's for the new BODY's
-      for (ii = from_BODY_list_copy.size(); ii > 0; ii--) {
+  for (ii = from_BODY_list_copy.size(); ii > 0; ii--) {
-	BODY *old_BODY = from_BODY_list.get();
-	BODY *new_BODY = from_BODY_list_copy.get();
+    BODY *old_BODY = from_BODY_list.get();
+    BODY *new_BODY = from_BODY_list_copy.get();
-	BodySM *new_body = NULL;
-	if (old_BODY != new_BODY)
-	  new_body = get_new_Body(from_bodies.get(), old_BODY, new_BODY, keep_old);
-	else if (!keep_old && int_stat == CUBIT_SUCCESS) {
-	  //GeometryQueryTool::instance()->delete_Body(from_bodies.get());
-	  AcisQueryEngine::instance()->delete_solid_model_entities(from_bodies.get());
-	  from_bodies.change_to(NULL);
+    BodySM *new_body = NULL;
+    if (old_BODY != new_BODY)
+      new_body = get_new_Body(from_bodies.get(), old_BODY, new_BODY, keep_old);
+    else if (!keep_old && int_stat == CUBIT_SUCCESS) {
+      //GeometryQueryTool::instance()->delete_Body(from_bodies.get());
+      AcisQueryEngine::instance()->delete_solid_model_entities(from_bodies.get());
+      from_bodies.change_to(NULL);
-	if (new_body) {
-	  new_from_bodies.append(new_body);
+    if (new_body) {
+      new_from_bodies.append(new_body);
-	// now step all the lists
+      // now step all the lists
-      from_bodies.remove_all_with_value(NULL);
-      new_from_bodies.reset();
+  from_bodies.remove_all_with_value(NULL);
+  new_from_bodies.reset();
-      if (int_stat == CUBIT_SUCCESS && !keep_old )
-	//GeometryQueryTool::instance()->delete_Body(tool_body);
-	AcisQueryEngine::instance()->delete_solid_model_entities(tool_body);
-      // write the message about bodies kept and not kept
-      //NOTE TO JS:
-      PRINT_INFO("Intersect finished; \n"
-      "Old bodies retained: ");
-      if (from_bodies.size() > 0) {
+  if (int_stat == CUBIT_SUCCESS && !keep_old )
+    //GeometryQueryTool::instance()->delete_Body(tool_body);
+    AcisQueryEngine::instance()->delete_solid_model_entities(tool_body);
+    // write the message about bodies kept and not kept
+//NOTE TO JS:
+  PRINT_INFO("Intersect finished; \n"
+             "Old bodies retained: ");
+  if (from_bodies.size() > 0) {
       PRINT_INFO("%d ", from_bodies.get_and_step()->id());
-      else {
-      PRINT_INFO(" (none)");
+  else {
+    PRINT_INFO(" (none)");
-      PRINT_INFO("\n");
+  PRINT_INFO("\n");
-      //NOTE TO JS:
-      PRINT_INFO("New bodies created: ");
-      if (new_from_bodies.size() > 0) {
-      for (ii = new_from_bodies.size(); ii > 0; ii--)
+//NOTE TO JS:
+  PRINT_INFO("New bodies created: ");
+  if (new_from_bodies.size() > 0) {
+    for (ii = new_from_bodies.size(); ii > 0; ii--)
       PRINT_INFO("%d ", new_from_bodies.get_and_step()->id());
-      else {
-      PRINT_INFO("\n");
+  else {
+  PRINT_INFO("\n");
   // Purpose       : Perform a rotational sweep
@@ -8092,19 +8087,19 @@
 						 BodySM* stop_body) const
-      DLIList<FACE*> FACEs_to_be_swept_list;
-      DLIList<EDGE*> EDGEs_to_be_swept_list;
-      DLIList<Surface*> ref_faces_list;
-      DLIList<Curve*> ref_edges_list;
+  DLIList<FACE*> FACEs_to_be_swept_list;
+  DLIList<EDGE*> EDGEs_to_be_swept_list;
+  DLIList<Surface*> ref_faces_list;
+  DLIList<Curve*> ref_edges_list;
-      // First get the ACIS FACEs associated with the input RefFaces
-      //DLIList<FACE*> temp_faces;
-      int i;
-      for (i = ref_ent_list.size(); i > 0; i--)
-	  GeometryEntity *ref_ent = ref_ent_list.get_and_step();
-	  Surface *ref_face = CAST_TO(ref_ent, Surface);
-	  Curve* ref_edge = CAST_TO(ref_ent, Curve);
+    // First get the ACIS FACEs associated with the input RefFaces
+  //DLIList<FACE*> temp_faces;
+  int i;
+  for (i = ref_ent_list.size(); i > 0; i--)
+    GeometryEntity *ref_ent = ref_ent_list.get_and_step();
+    Surface *ref_face = CAST_TO(ref_ent, Surface);
+    Curve* ref_edge = CAST_TO(ref_ent, Curve);
 	  if(ref_face != NULL)
@@ -8157,102 +8152,102 @@
       ref_faces_list.reset();
       // Next, call ACIS to do the real work for each of the FACEs in the list!!
-      FACEs_to_be_swept_list.reset();
-      EDGEs_to_be_swept_list.reset();
-      FACE* FACE_ptr = NULL;
-      FACE* copied_FACE_ptr = NULL;
-      EDGE* copied_EDGE_ptr = NULL;
-      Surface* refface_ptr = NULL;
-      BodySM* body_ptr = NULL;
-      BODY* BODY_ptr = NULL;
-      BODY* copy_of_original_BODY_ptr = NULL;
-      bool primary_side = true;
-      bool skip_loop = false;
-      CubitStatus sweep_status = CUBIT_FAILURE;
-      for (i = 0; i < FACEs_to_be_swept_list.size(); i++)
-	  skip_loop = CUBIT_FALSE;
-	  copied_FACE_ptr = NULL;
+  FACEs_to_be_swept_list.reset();
+  EDGEs_to_be_swept_list.reset();
+  FACE* FACE_ptr = NULL;
+  FACE* copied_FACE_ptr = NULL;
+  EDGE* copied_EDGE_ptr = NULL;
+  Surface* refface_ptr = NULL;
+  BodySM* body_ptr = NULL;
+  BODY* BODY_ptr = NULL;
+  BODY* copy_of_original_BODY_ptr = NULL;
+  bool primary_side = true;
+  bool skip_loop = false;
+  CubitStatus sweep_status = CUBIT_FAILURE;
+  for (i = 0; i < FACEs_to_be_swept_list.size(); i++)
+    skip_loop = CUBIT_FALSE;
+    copied_FACE_ptr = NULL;
-	  // Get the RefFace we're going to sweep
-	  GeometryEntity* ref_ent = ref_ent_list.get_and_step();
-	  refface_ptr = CAST_TO(ref_ent, Surface);
-	  if(make_solid)
-	      PRINT_WARNING("The make_solid option is ignored for surface\n");
+      // Get the RefFace we're going to sweep
+    GeometryEntity* ref_ent = ref_ent_list.get_and_step();
+    refface_ptr = CAST_TO(ref_ent, Surface);
+    if(make_solid)
+      PRINT_WARNING("The make_solid option is ignored for surface\n");
-	  // Get the FACE we're going to sweep
-	  FACE_ptr = FACEs_to_be_swept_list.get_and_step();
+      // Get the FACE we're going to sweep
+    FACE_ptr = FACEs_to_be_swept_list.get_and_step();
-	  // If the FACE is DOUBLE-SIDED; deal with the switchside option
-	  if (FACE_ptr->sides() && switchside)
-	      primary_side = CUBIT_FALSE;
+      // If the FACE is DOUBLE-SIDED; deal with the switchside option
+    if (FACE_ptr->sides() && switchside)
+      primary_side = CUBIT_FALSE;
-	  // Make sure the FACE has a plane surface as it's underlying geometry
-	  if (FACE_ptr->geometry()->equation().type() != plane_type)
-	      PRINT_ERROR("One of the surfaces being swept is not planar.\n"
-			  "       Skipping to the next surface.\n");
-	      skip_loop = CUBIT_TRUE;
+      // Make sure the FACE has a plane surface as it's underlying geometry
+    if (FACE_ptr->geometry()->equation().type() != plane_type)
+      PRINT_ERROR("One of the surfaces being swept is not planar.\n"
+                  "       Skipping to the next surface.\n");
+      skip_loop = CUBIT_TRUE;
-	  // If this FACE is planar, continue
-	  if( !skip_loop )
-	      // Get the associated Body and it's ACIS BODY
-	      body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY(FACE_ptr);
-	      if (body_ptr != NULL)
-		  BODY_ptr = AcisQueryEngine::get_BODY(body_ptr);
+      // If this FACE is planar, continue
+    if( !skip_loop )
+        // Get the associated Body and it's ACIS BODY
+      body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY(FACE_ptr);
+      if (body_ptr != NULL)
+        BODY_ptr = AcisQueryEngine::get_BODY(body_ptr);
-		  // Make sure we have a valid ACIS BODY associated with this Body
-		  // and FACE
-		  if (BODY_ptr == NULL)
-		      PRINT_ERROR("No valid volume associated with the RefFace.\n");
+          // Make sure we have a valid ACIS BODY associated with this Body
+          // and FACE
+        if (BODY_ptr == NULL)
+          PRINT_ERROR("No valid volume associated with the RefFace.\n");
-	      else
-		  PRINT_WARNING("No volume associated with this surface.\n"
-				"         Sweeping will continue with the ACIS BODY.\n");
-		  BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY(FACE_ptr);
+      else
+        PRINT_WARNING("No volume associated with this surface.\n"
+                      "         Sweeping will continue with the ACIS BODY.\n");
+        BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY(FACE_ptr);
-	      // If there were no problems finding an associated ACIS BODY, proceed
-	      if( !skip_loop )
-		  // Make a copy of the original BODY before doing the sweep.
-		  // We will perform the sweep on the copy, not on the original body.
-		  copy_of_original_BODY_ptr = this->copy_BODY(BODY_ptr,
-							      CUBIT_FALSE);
+        // If there were no problems finding an associated ACIS BODY, proceed
+      if( !skip_loop )
+          // Make a copy of the original BODY before doing the sweep.
+          // We will perform the sweep on the copy, not on the original body.
+        copy_of_original_BODY_ptr = this->copy_BODY(BODY_ptr,
+                                                    CUBIT_FALSE);
-		  // Find the FACE in the copied BODY that corresponds to the FACE
-		  // being swept in the original BODY.  Note that when we made a copy
-		  // of the original BODY, all the "parent" attributes were copied
-		  // over to the new BODY.
-		  if (copy_of_original_BODY_ptr)
-		      copied_FACE_ptr = (FACE *) (AcisQueryEngine::instance()->
-						  get_ENTITY_of_entity( copy_of_original_BODY_ptr, refface_ptr) );
+          // Find the FACE in the copied BODY that corresponds to the FACE
+          // being swept in the original BODY.  Note that when we made a copy
+          // of the original BODY, all the "parent" attributes were copied
+          // over to the new BODY.
+        if (copy_of_original_BODY_ptr)
+          copied_FACE_ptr = (FACE *) (AcisQueryEngine::instance()->
+            get_ENTITY_of_entity( copy_of_original_BODY_ptr, refface_ptr) );
-		  if (copied_FACE_ptr)
-		      // Remove all the CUBIT_OWNER attributes from the copied BODY
-		      // as we're going to sweep it.
-		      if (GeometryModifyTool::instance()->get_new_ids() == CUBIT_TRUE)
-			AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copy_of_original_BODY_ptr);
+        if (copied_FACE_ptr)
+            // Remove all the CUBIT_OWNER attributes from the copied BODY
+            // as we're going to sweep it.
+          if (GeometryModifyTool::instance()->get_new_ids() == CUBIT_TRUE)
+            AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copy_of_original_BODY_ptr);
 		      // Rotate the FACE about the axis, sweep_vector.
 		      int reverse_failed = CUBIT_FALSE;
@@ -8436,43 +8431,43 @@
-      for (i = 0; i < EDGEs_to_be_swept_list.size(); i++)
-	  // Get the EDGE we're going to sweep
-	  copied_EDGE_ptr = EDGEs_to_be_swept_list.get_and_step();
+  for (i = 0; i < EDGEs_to_be_swept_list.size(); i++)
+      // Get the EDGE we're going to sweep
+    copied_EDGE_ptr = EDGEs_to_be_swept_list.get_and_step();
-	  BODY* new_BODY_ptr = NULL;
-	  sweep_status = sweep_EDGE_about_axis( copied_EDGE_ptr,
-						new_BODY_ptr,
-						sweep_axis,
-						point,
-						angle,
-						steps,
-						draft_angle,
-						draft_type,
-						make_solid,
-						rigid,
-						stop_FACE);
+    BODY* new_BODY_ptr = NULL;
+    sweep_status = sweep_EDGE_about_axis( copied_EDGE_ptr,
+                                          new_BODY_ptr,
+                                          sweep_axis,
+                                          point,
+                                          angle,
+                                          steps,
+                                          draft_angle,
+                                          draft_type,
+                                          make_solid,
+                                          rigid,
+                                          stop_FACE);
-	  if(sweep_status == CUBIT_FAILURE)
-	      PRINT_ERROR("Problem sweeping curve.\n");
-	      continue;
+    if(sweep_status == CUBIT_FAILURE)
+      PRINT_ERROR("Problem sweeping curve.\n");
+      continue;
-	  BodySM* new_body_ptr = get_new_Body(body_ptr, BODY_ptr,
-					      new_BODY_ptr,
-					      CUBIT_FALSE, CUBIT_FALSE);
-	  if (new_body_ptr)
-	      result_body_list.append(new_body_ptr);
-	      sweep_status = CUBIT_SUCCESS;
-	} // End of i loop, iterating over EDGEs_to_be_swept_list
-      return sweep_status;
+    BodySM* new_body_ptr = get_new_Body(body_ptr, BODY_ptr,
+                                      new_BODY_ptr,
+                                      CUBIT_FALSE, CUBIT_FALSE);
+    if (new_body_ptr)
+      result_body_list.append(new_body_ptr);
+      sweep_status = CUBIT_SUCCESS;
+  } // End of i loop, iterating over EDGEs_to_be_swept_list
+  return sweep_status;
   // Purpose       : Perform a translational sweep operation
@@ -8547,95 +8542,95 @@
-      ref_edges_list.reset();
-      ref_faces_list.reset();
+  ref_edges_list.reset();
+  ref_faces_list.reset();
-      // Now sweep them along the sweep_vector, a distance equal to the length of
-      // the sweep SPAvector, with the input draft angle and draft type.
+    // Now sweep them along the sweep_vector, a distance equal to the length of
+    // the sweep SPAvector, with the input draft angle and draft type.
-	  refface_ptr = ref_faces_list.get_and_step();
+    refface_ptr = ref_faces_list.get_and_step();
-	  // If the FACE is DOUBLE-SIDED and the switchside option is TRUE
+      // If the FACE is DOUBLE-SIDED and the switchside option is TRUE
-	  // Get the associated Body and its ACIS BODY
+      // Get the associated Body and its ACIS BODY
-	      // and FACE
+        // and FACE
-	  else
+    else
-	  if( !skip_loop )
-	      copy_of_original_BODY_ptr = this->copy_BODY(BODY_ptr, CUBIT_FALSE);
+    if( !skip_loop )
+      copy_of_original_BODY_ptr = this->copy_BODY(BODY_ptr, CUBIT_FALSE);
-					      get_ENTITY_of_entity( copy_of_original_BODY_ptr, refface_ptr ));
+          get_ENTITY_of_entity( copy_of_original_BODY_ptr, refface_ptr ));
-		  // Sweep the FACE along the SPAvector, sweep_vector
-		  bool reverse_failed = false;
-		  bool volume_is_negative = false;
+          // Sweep the FACE along the SPAvector, sweep_vector
+        bool reverse_failed = false;
+        bool volume_is_negative = false;
                   //copy stop_BODY
 		   BODY* temp_BODY = NULL;
@@ -8665,80 +8660,80 @@
 			  // not on the original body.
-			      // Find out how many FACEs exist in the BODY that owns
-			      // copied_FACE_ptr
-			      DLIList<FACE*> FACE_list;
-			      if (AcisQueryEngine::instance()->get_FACEs( (ENTITY *)copy_of_original_BODY_ptr, FACE_list ))
-				  // If copied_FACE_ptr is the only FACE in this BODY, then we can
-				  // try reversing the BODY before attempting the sweep again
-				  if (FACE_list.size() == 1)
-				      if (copied_FACE_ptr->sides() == DOUBLE_SIDED)
-					  // Reverse the BODY that this FACE belongs to
-					  if (!api_reverse_body(copy_of_original_BODY_ptr).ok())
-					      reverse_failed = CUBIT_TRUE;
+                // Find out how many FACEs exist in the BODY that owns
+                // copied_FACE_ptr
+              DLIList<FACE*> FACE_list;
+              if (AcisQueryEngine::instance()->get_FACEs( (ENTITY *)copy_of_original_BODY_ptr, FACE_list ))
+                  // If copied_FACE_ptr is the only FACE in this BODY, then we can
+                  // try reversing the BODY before attempting the sweep again
+                if (FACE_list.size() == 1)
+                  if (copied_FACE_ptr->sides() == DOUBLE_SIDED)
+                      // Reverse the BODY that this FACE belongs to
+                    if (!api_reverse_body(copy_of_original_BODY_ptr).ok())
+                      reverse_failed = CUBIT_TRUE;
-				      // The single FACE in this BODY is *not* DOUBLE_SIDED.
-				      // Cannot do the reversal and sweep.
-				      else
+                    // The single FACE in this BODY is *not* DOUBLE_SIDED.
+                    // Cannot do the reversal and sweep.
+                  else
-				  // More than 1 FACE in this BODY. Cannot do the reversal and sweep.
-				  else
+                  // More than 1 FACE in this BODY. Cannot do the reversal and sweep.
+                else
-			      // Couldn't get the FACES of the BODY being swept. Cannot do
-			      // the reversal and sweep.
-			      else
+                // Couldn't get the FACES of the BODY being swept. Cannot do
+                // the reversal and sweep.
+              else
-			  // Couldn't find the FACE in the copied BODY that corresponds to
-			  // the FACE being swept in the original BODY.  Cannot do the
-			  // reversal and sweep.
-			  else
+              // Couldn't find the FACE in the copied BODY that corresponds to
+              // the FACE being swept in the original BODY.  Cannot do the
+              // reversal and sweep.
+            else
-		      // The sweep failed for reasons other than the creation of a negative
-		      // volume.  Doesn't make sense to do the reversal and sweep.
-		      else
+            // The sweep failed for reasons other than the creation of a negative
+            // volume.  Doesn't make sense to do the reversal and sweep.
+          else
 		      // If reverse was successful, then try the sweep again
 		      if ( reverse_failed == CUBIT_FALSE )
@@ -8764,87 +8759,87 @@
 			      // Delete the BODY created by this sweep
 			      AcisQueryEngine::instance()->delete_ACIS_BODY( copy_of_original_BODY_ptr, CUBIT_TRUE );
-		      else
-		    } // End of if branch for initial sweep attemp
+          else
+        } // End of if branch for initial sweep attemp
-	      // There were problems getting the FACE in the copied BODY, corresponding
-	      // to the FACE being swept in the original BODY. We can't proceed with the
-	      // sweep of this RefFace.
-	      else
-		} // End of if branch if copied_FACE_ptr exists
+        // There were problems getting the FACE in the copied BODY, corresponding
+        // to the FACE being swept in the original BODY. We can't proceed with the
+        // sweep of this RefFace.
+      else
+      } // End of if branch if copied_FACE_ptr exists
-	      // As all went well (apparently :-), create a new Body using the new
-	      // swept solid and get rid of the original Body and its associated
-	      // ACIS BODY.
-	      if( !skip_loop )
-						      copy_of_original_BODY_ptr,
-		  if (new_body_ptr)
+        // As all went well (apparently :-), create a new Body using the new
+        // swept solid and get rid of the original Body and its associated
+        // ACIS BODY.
+      if( !skip_loop )
+                                          copy_of_original_BODY_ptr,
+        if (new_body_ptr)
-		} // End of if branch if skip_loop != TRUE of final new_body_ptr construction
-	      else
-		  // Get rid of the copied body, if it exists
-		  if( copy_of_original_BODY_ptr )
-		      AcisQueryEngine::instance()->delete_ACIS_BODY( copy_of_original_BODY_ptr);
+      } // End of if branch if skip_loop != TRUE of final new_body_ptr construction
+      else
+          // Get rid of the copied body, if it exists
+        if( copy_of_original_BODY_ptr )
+          AcisQueryEngine::instance()->delete_ACIS_BODY( copy_of_original_BODY_ptr);
-		      copy_of_original_BODY_ptr = NULL;
-	    } // End of if branch if skip_loop != TRUE for problems finding assoc. ACIS BODY
-	} // End of i loop, iterating over FACEs_to_be_swept_list
+          copy_of_original_BODY_ptr = NULL;
+    } // End of if branch if skip_loop != TRUE for problems finding assoc. ACIS BODY
+  } // End of i loop, iterating over FACEs_to_be_swept_list
-      //Now we iterate over the EDGEs
+    //Now we iterate over the EDGEs
-	  sweep_status = sweep_EDGE_along_vector( copied_EDGE_ptr,
-						  new_BODY_ptr,
-						  sweep_vector,
-						  draft_angle,
-						  draft_type,
-						  rigid,
-						  stop_FACE);
-	      continue;
+    sweep_status = sweep_EDGE_along_vector( copied_EDGE_ptr,
+                                            new_BODY_ptr,
+                                            sweep_vector,
+                                            draft_angle,
+                                            draft_type,
+                                            rigid,
+                                            stop_FACE);
+      continue;
-					      new_BODY_ptr,
-	  if (new_body_ptr)
+                                      new_BODY_ptr,
+    if (new_body_ptr)
   CubitStatus AcisModifyEngine::sweep_perpendicular(
 						    DLIList<GeometryEntity*>& ref_ent_list,
@@ -8874,130 +8869,130 @@
 	  stop_BODY = bodyACISPtr->get_BODY_ptr() ;
-      // DLIList<FACE*> temp_faces;
-      int i;
+  int i;
-	  if(ref_face != NULL)
-	      //SurfaceACIS::get_FACEs_of_RefFace( ref_face, temp_faces);
-	      //if (temp_faces.size() > 1) {
-	      //  PRINT_ERROR("Surface %d cannot be swept as the number of ACIS FACEs associated \n"
-	      //              "       with it is not 1.\n",
-	      //              ref_face->id());
-	      //  return CUBIT_FAILURE;
-	      //if (temp_faces.size() > 0)
-	      //   FACEs_to_be_swept_list += temp_faces;
-	      //temp_faces.clean_out();
-	      FACE* FACE_ptr = AcisQueryEngine::get_FACE(ref_face);
-	      if (!FACE_ptr)
-	      FACEs_to_be_swept_list.append(FACE_ptr);
-	      ref_faces_list.append(ref_face);
-	  else if (ref_edge != NULL)
-	      ref_edges_list.append(ref_edge);
+    if(ref_face != NULL)
+      //SurfaceACIS::get_FACEs_of_RefFace( ref_face, temp_faces);
+      //if (temp_faces.size() > 1) {
+      //  PRINT_ERROR("Surface %d cannot be swept as the number of ACIS FACEs associated \n"
+      //              "       with it is not 1.\n",
+      //              ref_face->id());
+      //  return CUBIT_FAILURE;
+      //if (temp_faces.size() > 0)
+      //   FACEs_to_be_swept_list += temp_faces;
+      //temp_faces.clean_out();
+      FACE* FACE_ptr = AcisQueryEngine::get_FACE(ref_face);
+      if (!FACE_ptr)
+      FACEs_to_be_swept_list.append(FACE_ptr);
+      ref_faces_list.append(ref_face);
+    else if (ref_edge != NULL)
+      ref_edges_list.append(ref_edge);
-      if(ref_edges_list.size())
-	PRINT_ERROR("Curves cannot be swept perpendicularly, please use the vector sweep.\n");
+  if(ref_edges_list.size())
+     PRINT_ERROR("Curves cannot be swept perpendicularly, please use the vector sweep.\n");
-      // Now sweep them perpendicularly, a distance equal to the
-      // distance given with the input draft angle and
-      // draft type.
+    // Now sweep them perpendicularly, a distance equal to the
+    // distance given with the input draft angle and
+    // draft type.
-      bool primary_side = CUBIT_TRUE;
-      int skip_loop = CUBIT_FALSE;
+  bool primary_side = CUBIT_TRUE;
+  int skip_loop = CUBIT_FALSE;
-	      // and FACE
+        // and FACE
-	  else
+    else
-	  if( !skip_loop )
+    if( !skip_loop )
-		  bool reverse_failed = CUBIT_FALSE;
-		  bool volume_is_negative = CUBIT_FALSE;
+        bool reverse_failed = CUBIT_FALSE;
+        bool volume_is_negative = CUBIT_FALSE;
                   //copy stop_BODY
@@ -9022,85 +9017,85 @@
 			  // negative volume).
 			  AcisQueryEngine::instance()->delete_ACIS_BODY(copy_of_original_BODY_ptr, CUBIT_TRUE);
-			  // Make another copy of the original BODY before attempting
-			  // the sweep again. We will perform the sweep on this copy,
-			  // not on the original body.
+              // Make another copy of the original BODY before attempting
+              // the sweep again. We will perform the sweep on this copy,
+              // not on the original body.
-				      else
+                  else
-				  else
+                else
-			      else
+              else
-			  else
+            else
-		      else
+          else
@@ -9123,57 +9118,57 @@
 			      // The attempt to reverse the BODY and sweep it again failed.
 			      PRINT_ERROR("Problem sweeping one of the surfaces.\n");
-			      // Delete the BODY created by this sweep
-			      AcisQueryEngine::instance()->delete_ACIS_BODY( copy_of_original_BODY_ptr, CUBIT_TRUE );
+                // Delete the BODY created by this sweep
+              AcisQueryEngine::instance()->delete_ACIS_BODY( copy_of_original_BODY_ptr, CUBIT_TRUE );
-		      else
+          else
-	      else
+      else
-	      // ACIS BODY.
-	      if( !skip_loop )
-		  if (new_body_ptr)
+        // ACIS BODY.
+      if( !skip_loop )
+        if (new_body_ptr)
-	      else
+      else
   // Purpose       : Perform a face sweep operation along a curve
@@ -9218,333 +9213,333 @@
-      int i;
-	      //       SurfaceACIS::get_FACEs_of_RefFace( ref_face, temp_faces);
-	      //       if (temp_faces.size() > 1) {
-	      //       if (temp_faces.size() > 0)
-	      //       temp_faces.clean_out();
-	      if (!FACE_ptr)
-	      //EDGEs_to_be_swept_list.append(CurveACIS::get_first_EDGE(ref_edge));
-	      EDGEs_to_be_swept_list.append(AcisQueryEngine::get_EDGE(ref_edge));
+//   DLIList<FACE*> temp_faces;
+   int i;
+//       SurfaceACIS::get_FACEs_of_RefFace( ref_face, temp_faces);
+//       if (temp_faces.size() > 1) {
+//         PRINT_ERROR("Surface %d cannot be swept as the number of ACIS FACEs associated \n"
+//                     "       with it is not 1.\n",
+//                     ref_face->id());
+//       if (temp_faces.size() > 0)
+//          FACEs_to_be_swept_list += temp_faces;
+//       temp_faces.clean_out();
+       if (!FACE_ptr)
+       //EDGEs_to_be_swept_list.append(CurveACIS::get_first_EDGE(ref_edge));
+       EDGEs_to_be_swept_list.append(AcisQueryEngine::get_EDGE(ref_edge));
-      // Now sweep them along the EDGE.
+   // Now sweep them along the EDGE.
-      BODY* EDGE_BODY_ptr = NULL;
+   BODY* EDGE_BODY_ptr = NULL;
-      Surface* ref_face_ptr = NULL;
-      BODY* copied_BODY_ptr = NULL;
+   Surface* ref_face_ptr = NULL;
+   BODY* copied_BODY_ptr = NULL;
-      // Get the EDGE to sweep along.  No need to copy it as it is going into
-      // a WIRE body (it's copied into the WIRE body).
-      Curve* ref_edge_ptr = NULL;
+   // Get the EDGE to sweep along.  No need to copy it as it is going into
+   // a WIRE body (it's copied into the WIRE body).
+   Curve* ref_edge_ptr = NULL;
-      // Sweep the FACE along the chain of EDGES.
-      int num_edges = ref_edge_list.size();
-      EDGE** EDGES = new EDGE*[num_edges];
-      ref_edge_list.reset();
-      for( int j=0; j<num_edges; j++ )
-	  ref_edge_ptr = ref_edge_list.get_and_step();
-	  //Curve* curve_ptr = ref_edge_ptr->get_curve_ptr();
-	  //CurveACIS *curve_ACIS = CAST_TO(curve_ptr, CurveACIS);
-	  CurveACIS *curve_ACIS = CAST_TO(ref_edge_ptr, CurveACIS);
-	  EDGE *EDGE_ptr = curve_ACIS->get_EDGE_ptr();
+     // Sweep the FACE along the chain of EDGES.
+   int num_edges = ref_edge_list.size();
+   EDGE** EDGES = new EDGE*[num_edges];
+   ref_edge_list.reset();
+   for( int j=0; j<num_edges; j++ )
+     ref_edge_ptr = ref_edge_list.get_and_step();
+     //Curve* curve_ptr = ref_edge_ptr->get_curve_ptr();
+     //CurveACIS *curve_ACIS = CAST_TO(curve_ptr, CurveACIS);
+     CurveACIS *curve_ACIS = CAST_TO(ref_edge_ptr, CurveACIS);
+     EDGE *EDGE_ptr = curve_ACIS->get_EDGE_ptr();
-	  if (!EDGE_ptr)
-	      PRINT_ERROR("Unable to get ACIS EDGE from Curve\n" );
-	      delete [] EDGES;
+     if (!EDGE_ptr)
+       PRINT_ERROR("Unable to get ACIS EDGE from Curve\n" );
+       delete [] EDGES;
-	  EDGE *copied_EDGE_ptr = NULL;
-	  result = api_edge( EDGE_ptr, copied_EDGE_ptr );
-	  if (!result.ok() || copied_EDGE_ptr == NULL )
-	      PRINT_ERROR( "Unable to copy ACIS curve\n" );
-	      delete [] EDGES;
-	  EDGES[j] = copied_EDGE_ptr;
+     EDGE *copied_EDGE_ptr = NULL;
+     result = api_edge( EDGE_ptr, copied_EDGE_ptr );
+     if (!result.ok() || copied_EDGE_ptr == NULL )
+       PRINT_ERROR( "Unable to copy ACIS curve\n" );
+       delete [] EDGES;
+     EDGES[j] = copied_EDGE_ptr;
-      // Make a WIRE body to sweep along.  If we have to reverse the EDGE
-      // (since ACIS only allows you to sweep from start to end), the wire
-      // will be needed.
-      result = api_make_ewire( num_edges, EDGES, EDGE_BODY_ptr );
-      WIRE* WIRE_ptr = NULL;
-      if (!result.ok())
-	  PRINT_ERROR( "Unable to make ACIS wire body from curve to sweep along\n" );
-      else
-	WIRE_ptr = EDGE_BODY_ptr->lump()->shell()->wire();
+     // Make a WIRE body to sweep along.  If we have to reverse the EDGE
+     // (since ACIS only allows you to sweep from start to end), the wire
+     // will be needed.
+   result = api_make_ewire( num_edges, EDGES, EDGE_BODY_ptr );
+   WIRE* WIRE_ptr = NULL;
+   if (!result.ok())
+     PRINT_ERROR( "Unable to make ACIS wire body from curve to sweep along\n" );
+   else
+      WIRE_ptr = EDGE_BODY_ptr->lump()->shell()->wire();
-	  ref_face_ptr = ref_faces_list.get_and_step();
+      ref_face_ptr = ref_faces_list.get_and_step();
-	      // and FACE
-		  PRINT_ERROR("No valid volume associated with Surface.\n" );
-		  continue;
+         // and FACE
+            PRINT_ERROR("No valid volume associated with Surface.\n" );
+            continue;
-	  else
-	      // This can happen when a Surface entity is created at the SM level for temp use
-	      // This function should only care about the ACIS BODY anyway
-		  PRINT_ERROR("No valid volume associated with Surface\n" );
-		  continue;
+      else
+          // This can happen when a Surface entity is created at the SM level for temp use
+          // This function should only care about the ACIS BODY anyway
+            PRINT_ERROR("No valid volume associated with Surface\n" );
+            continue;
-	  copied_BODY_ptr = this->copy_BODY(BODY_ptr, CUBIT_FALSE);
+      copied_BODY_ptr = this->copy_BODY(BODY_ptr, CUBIT_FALSE);
-	  if( copied_BODY_ptr == NULL )
-	      PRINT_ERROR( "Unable to copy volume before sweeping\n" );
-	      continue;
+      if( copied_BODY_ptr == NULL )
+         PRINT_ERROR( "Unable to copy volume before sweeping\n" );
+         continue;
-	  copied_FACE_ptr = (FACE *) (AcisQueryEngine::instance()->get_ENTITY_of_entity(
-											copied_BODY_ptr, ref_face_ptr ) );
+      copied_FACE_ptr = (FACE *) (AcisQueryEngine::instance()->get_ENTITY_of_entity(
+         copied_BODY_ptr, ref_face_ptr ) );
-	  if( copied_FACE_ptr == NULL )
-	      PRINT_ERROR( "Unable to find FACE to sweep in copied volume\n" );
-	      continue;
+      if( copied_FACE_ptr == NULL )
+         PRINT_ERROR( "Unable to find FACE to sweep in copied volume\n" );
+         continue;
-	    AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copied_BODY_ptr);
+        AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copied_BODY_ptr);
-	  // Check to see if the start of the edge is in the profile of
-	  // the face.  If not, check the end - if this is, we'll need to
-	  // reverse the WIRE body.
-	  // When we support a chain of EDGES, here we will need to get the start
-	  // and end vertices of the WIRE.  This should be the only change needed.
-	  //VERTEX* start_VERTEX_ptr;// copied_EDGE_ptr->start();
-	  //VERTEX* end_VERTEX_ptr;// copied_EDGE_ptr->end();
-	  //if( start_VERTEX_ptr == end_VERTEX_ptr )
-	  //  PRINT_ERROR( "Edge start and end are the same - sweeping not possible\n" );
-	  ENTITY *ent = WIRE_ptr;
+      // Check to see if the start of the edge is in the profile of
+      // the face.  If not, check the end - if this is, we'll need to
+      // reverse the WIRE body.
+      // When we support a chain of EDGES, here we will need to get the start
+      // and end vertices of the WIRE.  This should be the only change needed.
+      //VERTEX* start_VERTEX_ptr;// copied_EDGE_ptr->start();
+      //VERTEX* end_VERTEX_ptr;// copied_EDGE_ptr->end();
+      //if( start_VERTEX_ptr == end_VERTEX_ptr )
+       //  PRINT_ERROR( "Edge start and end are the same - sweeping not possible\n" );
+      ENTITY *ent = WIRE_ptr;
-	  SPAposition acis_start_coords;
-	  get_wire_start_position(ent, acis_start_coords);
-	  CubitVector start_vec( acis_start_coords.x(), acis_start_coords.y(),
-				 acis_start_coords.z() );
+      SPAposition acis_start_coords;
+      get_wire_start_position(ent, acis_start_coords);
+      CubitVector start_vec( acis_start_coords.x(), acis_start_coords.y(),
+        acis_start_coords.z() );
-	  bool start_flg;
-	  Curve* start_curve = find_curve_by_end_coord( start_vec,
-							ref_edge_list, start_flg );
-	  if( !start_curve )
-	      PRINT_ERROR( "unable to find start vertex of sweep chain; aborting\n" );
-	      delete []EDGES;
-	  CubitVector start_position;
-	  start_curve->position_from_fraction( start_flg ? 0.0 : 1.0, start_position);
+      bool start_flg;
+      Curve* start_curve = find_curve_by_end_coord( start_vec,
+                                 ref_edge_list, start_flg );
+      if( !start_curve )
+        PRINT_ERROR( "unable to find start vertex of sweep chain; aborting\n" );
+        delete []EDGES;
+      CubitVector start_position;
+      start_curve->position_from_fraction( start_flg ? 0.0 : 1.0, start_position);
-	  SPAposition acis_end_coords;
-	  get_wire_end_position(ent, acis_end_coords);
-	  CubitVector end_vec( acis_end_coords.x(), acis_end_coords.y(),
-			       acis_end_coords.z() );
+      SPAposition acis_end_coords;
+      get_wire_end_position(ent, acis_end_coords);
+      CubitVector end_vec( acis_end_coords.x(), acis_end_coords.y(),
+        acis_end_coords.z() );
-	  Curve* end_curve = find_curve_by_end_coord( end_vec,
-	  if( !end_curve )
-	      PRINT_ERROR( "unable to find end vertex of sweep chain; aborting\n" );
-	      delete []EDGES;
-	  CubitVector end_position;
-	  end_curve->position_from_fraction( start_flg ? 0.0 : 1.0, end_position );
+      Curve* end_curve = find_curve_by_end_coord( end_vec,
+      if( !end_curve )
+        PRINT_ERROR( "unable to find end vertex of sweep chain; aborting\n" );
+        delete []EDGES;
+      CubitVector end_position;
+      end_curve->position_from_fraction( start_flg ? 0.0 : 1.0, end_position );
-	  //SPAposition pos1, pos2;
-	  double distance1, distance2;
-	  SPAposition acis_closest_point;
-	  (copied_FACE_ptr->geometry()->equation()).point_perp ( acis_start_coords,
-								 acis_closest_point );
-	  CubitVector closest_point_start( acis_closest_point.x(),
-					   acis_closest_point.y(),
-					   acis_closest_point.z() );
-	  distance1 = closest_point_start.distance_between( start_vec );
+      //SPAposition pos1, pos2;
+      double distance1, distance2;
+      SPAposition acis_closest_point;
+      (copied_FACE_ptr->geometry()->equation()).point_perp ( acis_start_coords,
+                                                             acis_closest_point );
+      CubitVector closest_point_start( acis_closest_point.x(),
+                                       acis_closest_point.y(),
+                                       acis_closest_point.z() );
+      distance1 = closest_point_start.distance_between( start_vec );
-	  //VERTEX* close_VERTEX_ptr = NULL;
-	  CubitVector closest_position;
-	  EDGE* start_EDGE_ptr = NULL;
+      //VERTEX* close_VERTEX_ptr = NULL;
+      CubitVector closest_position;
+      EDGE* start_EDGE_ptr = NULL;
-	  if( distance1 > SPAresabs )
-	      // Try the other end
-	      (copied_FACE_ptr->geometry()->equation()).point_perp ( acis_end_coords,
-	      CubitVector closest_point_end( acis_closest_point.x(), acis_closest_point.y(),
-	      distance2 = closest_point_end.distance_between( end_vec );
+      if( distance1 > SPAresabs )
+         // Try the other end
+         (copied_FACE_ptr->geometry()->equation()).point_perp ( acis_end_coords,
+         CubitVector closest_point_end( acis_closest_point.x(), acis_closest_point.y(),
+         distance2 = closest_point_end.distance_between( end_vec );
-	      if( distance2 > SPAresabs )
-		  PRINT_ERROR( "Neither chain end lies in the plane of surface\n" );
-		  continue;
-	      else
-		  //close_VERTEX_ptr = end_VERTEX_ptr;
-		  closest_position = end_position;
-		  start_curve = end_curve;
-		  start_EDGE_ptr = EDGES[ref_edge_list.size()-1];
+         if( distance2 > SPAresabs )
+            PRINT_ERROR( "Neither chain end lies in the plane of surface\n" );
+            continue;
+         else
+            //close_VERTEX_ptr = end_VERTEX_ptr;
+           closest_position = end_position;
+           start_curve = end_curve;
+           start_EDGE_ptr = EDGES[ref_edge_list.size()-1];
-	      // Reverse the WIRE in the BODY
-	      //api_reverse_body( EDGE_BODY_ptr );
-	      api_reverse_wire( WIRE_ptr );
+         // Reverse the WIRE in the BODY
+         //api_reverse_body( EDGE_BODY_ptr );
+         api_reverse_wire( WIRE_ptr );
-	  else
-	      //close_VERTEX_ptr = start_VERTEX_ptr;
-	      closest_position = start_position;
-	      start_EDGE_ptr = EDGES[0];
+      else
+         //close_VERTEX_ptr = start_VERTEX_ptr;
+        closest_position = start_position;
+        start_EDGE_ptr = EDGES[0];
-	  SPAposition acis_closest_position;
-	  SPAunit_vector acis_surface_normal;
+      SPAposition acis_closest_position;
+      SPAunit_vector acis_surface_normal;
-	  //APOINT* acis_point = close_VERTEX_ptr->geometry() ;
-	  //SPAposition acis_curve_position = acis_point->coords() ;
-	  SPAposition acis_curve_position( closest_position.x(),
-					   closest_position.y(), closest_position.z() );
+      //APOINT* acis_point = close_VERTEX_ptr->geometry() ;
+      //SPAposition acis_curve_position = acis_point->coords() ;
+      SPAposition acis_curve_position( closest_position.x(),
+        closest_position.y(), closest_position.z() );
-	  // Need to compute the FACE normal at the start of the sweep
-	  (copied_FACE_ptr->geometry()->equation()).point_perp ( acis_curve_position,
-								 acis_closest_position, acis_surface_normal );
+      // Need to compute the FACE normal at the start of the sweep
+      (copied_FACE_ptr->geometry()->equation()).point_perp ( acis_curve_position,
+         acis_closest_position, acis_surface_normal );
-	  CubitVector surface_normal( acis_surface_normal.x(), acis_surface_normal.y(),
-				      acis_surface_normal.z() );
+      CubitVector surface_normal( acis_surface_normal.x(), acis_surface_normal.y(),
+                                  acis_surface_normal.z() );
-	  // Check to see if SENSE of FACE is REVERSED.  The direction of the
-	  // ACIS face is the direction of sweep.
-	  if( copied_FACE_ptr->sense() == REVERSED )
-	      if( copied_FACE_ptr->geometry()->equation().left_handed_uv() == CUBIT_FALSE )
-		surface_normal *= -1.0;
-	  else
-	      if( copied_FACE_ptr->geometry()->equation().left_handed_uv() )
+      // Check to see if SENSE of FACE is REVERSED.  The direction of the
+      // ACIS face is the direction of sweep.
+      if( copied_FACE_ptr->sense() == REVERSED )
+         if( copied_FACE_ptr->geometry()->equation().left_handed_uv() == CUBIT_FALSE )
+            surface_normal *= -1.0;
+      else
+         if( copied_FACE_ptr->geometry()->equation().left_handed_uv() )
-	  // Get curve tangent at start of the sweep
-	  SPAunit_vector acis_curve_tangent;
+      // Get curve tangent at start of the sweep
+      SPAunit_vector acis_curve_tangent;
-	  (start_EDGE_ptr->geometry()->equation()).point_perp( acis_curve_position,
-							       acis_curve_tangent );
+      (start_EDGE_ptr->geometry()->equation()).point_perp( acis_curve_position,
+         acis_curve_tangent );
-	  CubitVector curve_tangent( acis_curve_tangent.x(), acis_curve_tangent.y(),
-				     acis_curve_tangent.z() );
+      CubitVector curve_tangent( acis_curve_tangent.x(), acis_curve_tangent.y(),
+         acis_curve_tangent.z() );
-	  // Determine if the WIRE has been reversed - ??? there's a better way to
-	  // do this but I don't know it.  I would think you could just go by the
-	  // underlying EDGE but apparently when the WIRE get's reversed, the EDGE
-	  // doesn't change - the sweep uses the WIRE, not the EDGE.
-	  if( closest_position == end_position )
-	    curve_tangent *= -1.0;
+      // Determine if the WIRE has been reversed - ??? there's a better way to
+      // do this but I don't know it.  I would think you could just go by the
+      // underlying EDGE but apparently when the WIRE get's reversed, the EDGE
+      // doesn't change - the sweep uses the WIRE, not the EDGE.
+      if( closest_position == end_position )
+         curve_tangent *= -1.0;
-	  // Make sure the sense is correct based on the underlying EDGE sense
-	  if( start_EDGE_ptr->sense() == REVERSED )
+      // Make sure the sense is correct based on the underlying EDGE sense
+      if( start_EDGE_ptr->sense() == REVERSED )
-	  // Properties of dot product
-	  // angle acute if dot product > 0
-	  // angle obtuse if dot product < 0
-	  // angle 90 deg if dot product = 0
+      // Properties of dot product
+      // angle acute if dot product > 0
+      // angle obtuse if dot product < 0
+      // angle 90 deg if dot product = 0
-	  if( surface_normal%curve_tangent < 0 )
-	      if( FACE_ptr->sides() != DOUBLE_SIDED )
-		  PRINT_ERROR( "Attempting to sweep Surface back into the solid\n"
-			       "       Sweeping of Surface aborted\n" );
-		  api_delent(copied_FACE_ptr);
-		  continue;
-	      api_reverse_face( copied_FACE_ptr );
+      if( surface_normal%curve_tangent < 0 )
+         if( FACE_ptr->sides() != DOUBLE_SIDED )
+            PRINT_ERROR( "Attempting to sweep Surface back into the solid\n"
+               "       Sweeping of Surface aborted\n" );
+            api_delent(copied_FACE_ptr);
+            continue;
+         api_reverse_face( copied_FACE_ptr );
           //copy stop_BODY
@@ -9570,61 +9565,61 @@
-	  // Create a new Body using the new swept solid and delete the
-	  // original Body and its associated ACIS BODY.
-	  BodySM* new_body_ptr = 0;
-	  if(body_ptr)
-	    new_body_ptr = get_new_Body(body_ptr, BODY_ptr, copied_BODY_ptr,
+      // Create a new Body using the new swept solid and delete the
+      // original Body and its associated ACIS BODY.
+      BodySM* new_body_ptr = 0;
+      if(body_ptr)
+      new_body_ptr = get_new_Body(body_ptr, BODY_ptr, copied_BODY_ptr,
-	  else // this handles the case of a NULL body sweep surface (typically the result of a SM only entity)
-	    // in this case the caller must properly handle the sweep surface deletion
-	    new_body_ptr = AcisQueryEngine::instance()->populate_topology_bridges(copied_BODY_ptr);
+      else // this handles the case of a NULL body sweep surface (typically the result of a SM only entity)
+           // in this case the caller must properly handle the sweep surface deletion
+          new_body_ptr = AcisQueryEngine::instance()->populate_topology_bridges(copied_BODY_ptr);
-	  if (new_body_ptr)
-      //Now let's iterate over the EDGEs_to_be_swept_list
-	  EDGE *copied_EDGE_ptr = EDGEs_to_be_swept_list.get_and_step();
+      if (new_body_ptr)
+     //Now let's iterate over the EDGEs_to_be_swept_list
+     EDGE *copied_EDGE_ptr = EDGEs_to_be_swept_list.get_and_step();
-	  sweep_status = sweep_EDGE_along_WIRE( copied_EDGE_ptr,
-						EDGE_BODY_ptr,
-						new_BODY_ptr,
-						draft_angle,
-						draft_type,
-						rigid,
-						stop_FACE);
-	  if( sweep_status == CUBIT_FAILURE )
-	      continue;
+      sweep_status = sweep_EDGE_along_WIRE( copied_EDGE_ptr,
+                                            EDGE_BODY_ptr,
+                                            new_BODY_ptr,
+                                            draft_angle,
+                                            draft_type,
+                                            rigid,
+                                            stop_FACE);
+      if( sweep_status == CUBIT_FAILURE )
+        continue;
-	  BodySM* new_body_ptr = get_new_Body(body_ptr, BODY_ptr, new_BODY_ptr,
-	  if (new_body_ptr)
+      BodySM* new_body_ptr = get_new_Body(body_ptr, BODY_ptr, new_BODY_ptr,
+      if (new_body_ptr)
-      delete []EDGES;
+   delete []EDGES;
-      // Remove the created WIRE body
-      api_delent( EDGE_BODY_ptr );
+     // Remove the created WIRE body
+   api_delent( EDGE_BODY_ptr );
   // Purpose       : Sections the list of bodies (cuts in half).  This is
@@ -9649,316 +9644,315 @@
 	(GeometryModifyTool::instance()->get_new_ids() || keep_old);
-      if (keep_both_sides == CUBIT_TRUE )
-	  PRINT_ERROR("keeping both sides of section is not implemented.");
-	  return CUBIT_FAILURE;
+   if (keep_both_sides == CUBIT_TRUE )
+      PRINT_ERROR("keeping both sides of section is not implemented.");
+      return CUBIT_FAILURE;
-      // Compute the super bounding SPAbox
-      SPAbox super_bounding_box;
-      CubitStatus rv =
-	AcisQueryEngine::instance()->create_super_acis_bounding_box (section_body_list,
-								     super_bounding_box);
-      if (rv != CUBIT_SUCCESS)
-	return rv;
+     // Compute the super bounding SPAbox
+   SPAbox super_bounding_box;
+   CubitStatus rv =
+       AcisQueryEngine::instance()->create_super_acis_bounding_box (section_body_list,
+                                                        super_bounding_box);
+   if (rv != CUBIT_SUCCESS)
+      return rv;
-      // Construct a BODY from the given CubitVectors and the size of
-      // the super bounding SPAbox.
-      BODY *cutting_tool_ptr;
-      cutting_tool_ptr = this->create_infinite_plane_cutting_tool(
-								  point_1,
-								  point_2,
-								  point_3,
-								  super_bounding_box );
-      if (cutting_tool_ptr == NULL || cutting_tool_ptr->lump() == NULL )
-	  PRINT_ERROR("failed in sectioning volumes.\n");
+     // Construct a BODY from the given CubitVectors and the size of
+     // the super bounding SPAbox.
+   BODY *cutting_tool_ptr;
+   cutting_tool_ptr = this->create_infinite_plane_cutting_tool(
+       point_1,
+       point_2,
+       point_3,
+       super_bounding_box );
+   if (cutting_tool_ptr == NULL || cutting_tool_ptr->lump() == NULL )
+      PRINT_ERROR("failed in sectioning volumes.\n");
-      // Copy BODYs
-      i = section_body_list.size();
-      DLIList<BODY*>  tool_BODY_list(i);
-      DLIList<BODY*> blank_BODY_list(i);
-      DLIList<BODY*> input_BODY_list(i);
-      section_body_list.reset();
-      tool_BODY_list.append( cutting_tool_ptr );
-      for (i = section_body_list.size(); i > 0; i-- )
-	  BodySM* body_sm = section_body_list.get_and_step();
+    // Copy BODYs
+  i = section_body_list.size();
+  DLIList<BODY*>  tool_BODY_list(i);
+  DLIList<BODY*> blank_BODY_list(i);
+  DLIList<BODY*> input_BODY_list(i);
+  section_body_list.reset();
+  tool_BODY_list.append( cutting_tool_ptr );
+  for (i = section_body_list.size(); i > 0; i-- )
+    BodySM* body_sm = section_body_list.get_and_step();
-	  BODY* input_BODY = AcisQueryEngine::get_BODY( body_sm );
-	  if (!input_BODY) continue;
+    BODY* input_BODY = AcisQueryEngine::get_BODY( body_sm );
+    if (!input_BODY) continue;
-	  //also make sure that the cutting plane and blank body intersect
-	  if ( !BODYs_interfering( input_BODY, cutting_tool_ptr) )
-	      TopologyEntity *topo_entity = body_sm->topology_entity();
-	      RefEntity *ref_entity = CAST_TO(topo_entity, RefEntity);
-	      assert(ref_entity != 0);
-	      PRINT_WARNING("Volume %d does not interect sectioning plane\n", ref_entity->id() );
-	      section_body_list.remove( body_sm );
-	      continue;
+    //also make sure that the cutting plane and blank body intersect
+    if ( !BODYs_interfering( input_BODY, cutting_tool_ptr) )
+      TopologyEntity *topo_entity = body_sm->topology_entity();
+      RefEntity *ref_entity = CAST_TO(topo_entity, RefEntity);
+      assert(ref_entity != 0);
+      PRINT_WARNING("Volume %d does not interect sectioning plane\n", ref_entity->id() );
+      section_body_list.remove( body_sm );
+      continue;
-	  input_BODY_list.append( input_BODY );
+    input_BODY_list.append( input_BODY );
-	  BODY* blank_BODY = copy_BODY( input_BODY, delete_attribs );
-	  if (!blank_BODY) continue;
-	  blank_BODY_list.append( blank_BODY  );
+    BODY* blank_BODY = copy_BODY( input_BODY, delete_attribs );
+    if (!blank_BODY) continue;
+    blank_BODY_list.append( blank_BODY  );
-	  if (i < section_body_list.size()) // not first iteration
-	      BODY* tool_BODY = copy_BODY( cutting_tool_ptr );
-	      if (tool_BODY)
-		tool_BODY_list.append( tool_BODY );
+    if (i < section_body_list.size()) // not first iteration
+      BODY* tool_BODY = copy_BODY( cutting_tool_ptr );
+      if (tool_BODY)
+        tool_BODY_list.append( tool_BODY );
-      if( input_BODY_list.size() == 0 )
-	  PRINT_WARNING("No geometry interects sectioning plane\n");
+  if( input_BODY_list.size() == 0 )
+    PRINT_WARNING("No geometry interects sectioning plane\n");
-      // If there were any errors in the above loop, clean up and exit
-      if ( input_BODY_list.size() < section_body_list.size() ||
-	   blank_BODY_list.size() < section_body_list.size() ||
-	   tool_BODY_list.size() < section_body_list.size() )
-	  if (input_BODY_list.size() < section_body_list.size())
-	    PRINT_ERROR("Internal error: Invalid BodySM at %s:%d\n", __FILE__, __LINE__ );
-	  else
-	    PRINT_ERROR("Internal error: BODY copy failed at %s:%d\n", __FILE__, __LINE__ );
-	  while (tool_BODY_list.size())
-	    api_delent( input_BODY_list.pop() );
-	  while (blank_BODY_list.size())
+    // If there were any errors in the above loop, clean up and exit
+  if ( input_BODY_list.size() < section_body_list.size() ||
+       blank_BODY_list.size() < section_body_list.size() ||
+        tool_BODY_list.size() < section_body_list.size() )
+     if (input_BODY_list.size() < section_body_list.size())
+       PRINT_ERROR("Internal error: Invalid BodySM at %s:%d\n", __FILE__, __LINE__ );
+     else
+       PRINT_ERROR("Internal error: BODY copy failed at %s:%d\n", __FILE__, __LINE__ );
+     while (tool_BODY_list.size())
+       api_delent( input_BODY_list.pop() );
+     while (blank_BODY_list.size())
-      // Deterine which type of Boolean to use.
-      BOOL_TYPE bool_type;
-      CubitBoolean nonreg = !GeometryModifyTool::instance()->boolean_regularize();
-      if (keep_normal_side && !nonreg)
-	bool_type = SUBTRACTION;
-      else if (keep_normal_side && nonreg)
-	bool_type = NONREG_SUBTRACTION;
-      else if (!keep_normal_side && !nonreg)
-	bool_type = INTERSECTION;
-      else
+    // Deterine which type of Boolean to use.
+  BOOL_TYPE bool_type;
+  CubitBoolean nonreg = !GeometryModifyTool::instance()->boolean_regularize();
+  if (keep_normal_side && !nonreg)
+    bool_type = SUBTRACTION;
+  else if (keep_normal_side && nonreg)
+    bool_type = NONREG_SUBTRACTION;
+  else if (!keep_normal_side && !nonreg)
+    bool_type = INTERSECTION;
+  else
-      // Do Boolean for each blank body
-      input_BODY_list.reset();
-      blank_BODY_list.reset();
-      tool_BODY_list.reset();
-      for ( i = input_BODY_list.size(); i--; )
-	  input_BODY_list.step();
-	  BODY* blank_BODY = blank_BODY_list.get_and_step();
-	  BODY*  tool_BODY =  tool_BODY_list.get_and_step();
-	  outcome result = api_boolean( tool_BODY, blank_BODY, bool_type );
-	  if (!result.ok())
-	      PRINT_ERROR("Volume section failed.\n");
-	      blank_BODY_list.back();
-	      BODY *blank = blank_BODY_list.remove();
-	      AcisBridge *tb_ptr = ATTRIB_CUBIT_OWNER::cubit_owner(blank);
-	      if( tb_ptr && keep_old == false )
-		  BodyACIS *body_acis = CAST_TO(tb_ptr, BodyACIS );
-		  if( body_acis )
-		      BodySM *body_sm = CAST_TO(body_acis, BodySM );
+    // Do Boolean for each blank body
+  input_BODY_list.reset();
+  blank_BODY_list.reset();
+  tool_BODY_list.reset();
+  for ( i = input_BODY_list.size(); i--; )
+    input_BODY_list.step();
+    BODY* blank_BODY = blank_BODY_list.get_and_step();
+    BODY*  tool_BODY =  tool_BODY_list.get_and_step();
+    outcome result = api_boolean( tool_BODY, blank_BODY, bool_type );
+    if (!result.ok())
+      PRINT_ERROR("Volume section failed.\n");
+      blank_BODY_list.back();
+      BODY *blank = blank_BODY_list.remove();
+      AcisBridge *tb_ptr = ATTRIB_CUBIT_OWNER::cubit_owner(blank);
+      if( tb_ptr && keep_old == false )
+        BodyACIS *body_acis = CAST_TO(tb_ptr, BodyACIS );
+        if( body_acis )
+          BodySM *body_sm = CAST_TO(body_acis, BodySM );
-	      api_delent( blank );
-	      tool_BODY_list.back();
-	      api_delent( tool_BODY_list.remove() );
-	      input_BODY_list.back();
-	      input_BODY_list.remove();
+      api_delent( blank );
+      tool_BODY_list.back();
+      api_delent( tool_BODY_list.remove() );
+      input_BODY_list.back();
+      input_BODY_list.remove();
-      // If a non-regularized operation, clean up internal surfaces
-      if (nonreg)
+    // If a non-regularized operation, clean up internal surfaces
+  if (nonreg)
-	  for (i = input_BODY_list.size(); i--; )
+    for (i = input_BODY_list.size(); i--; )
-	      FACE_list.clean_out();
-	      AcisQueryEngine::instance()->get_FACEs( blank_BODY, FACE_list );
+      FACE_list.clean_out();
+      AcisQueryEngine::instance()->get_FACEs( blank_BODY, FACE_list );
-	      FACE_list.reset();
-	      for (int j = FACE_list.size(); j--; )
-		  FACE* FACE_ptr = FACE_list.get_and_step();
-		  assert( FACE_ptr != NULL );
+      FACE_list.reset();
+      for (int j = FACE_list.size(); j--; )
+        FACE* FACE_ptr = FACE_list.get_and_step();
+        assert( FACE_ptr != NULL );
-		  if (FACE_ptr->sides() == DOUBLE_SIDED &&
-		      FACE_ptr->cont() == BOTH_INSIDE)
-		      PRINT_INFO("Unhooking and deleting internal surface.\n");
-		      BODY* FACE_BODY_ptr;
-		      outcome result = api_unhook_face( FACE_ptr, FACE_BODY_ptr );
-		      if (!result.ok())
-			  AcisModifyEngine::instance()->get_acis_query_engine()->ACIS_API_error( result );
-		      else
-			  api_delent( FACE_BODY_ptr );
+        if (FACE_ptr->sides() == DOUBLE_SIDED &&
+            FACE_ptr->cont() == BOTH_INSIDE)
+          PRINT_INFO("Unhooking and deleting internal surface.\n");
+          BODY* FACE_BODY_ptr;
+          outcome result = api_unhook_face( FACE_ptr, FACE_BODY_ptr );
+          if (!result.ok())
+            AcisModifyEngine::instance()->get_acis_query_engine()->ACIS_API_error( result );
+          else
+            api_delent( FACE_BODY_ptr );
-      // Create/update AcisBridges
-      if( keep_old == true )
-	  int k;
-	  for( k=blank_BODY_list.size(); k--; )
-	      BodySM *this_bodysm = AcisQueryEngine::instance()->
-		populate_topology_bridges( blank_BODY_list.get_and_step() );
-	      new_body_list.append( this_bodysm );
-      else
-	get_new_Body( section_body_list,
-		      input_BODY_list,
-		      blank_BODY_list,
-		      new_body_list,
-		      keep_old );
-      return CUBIT_SUCCESS;
+    // Create/update AcisBridges
+  if( keep_old == true )
+    int k;
+    for( k=blank_BODY_list.size(); k--; )
+      BodySM *this_bodysm = AcisQueryEngine::instance()->
+            populate_topology_bridges( blank_BODY_list.get_and_step() );
+      new_body_list.append( this_bodysm );
+  else
+    get_new_Body( section_body_list,
+                  input_BODY_list,
+                  blank_BODY_list,
+                  new_body_list,
+                  keep_old );
+  return CUBIT_SUCCESS;
-  // Purpose       : webcuts a list of bodies using a plane.
-  //                 The newly created bodies are merged and imprinted
-  //                 depending on the respective flags.
-  // Creator       : Malcolm J. Panthaki
-  // Creation Date : 12/17/96
-  CubitStatus AcisModifyEngine::webcut( DLIList<BodySM*>& webcut_body_list,
-					const CubitVector &vecVertex1,
-					const CubitVector &vecVertex2,
-					const CubitVector &vecVertex3,
-					DLIList<BodySM*>& results_list,
-					bool imprint )
-      //int webcut_debug_flag = 18;
-      //int webcut_debug_flag_on = DEBUG_FLAG(webcut_debug_flag);
-      BODY* cutting_tool_ptr = NULL;
+// Purpose       : webcuts a list of bodies using a plane.
+//                 The newly created bodies are merged and imprinted
+//                 depending on the respective flags.
+// Special Notes :
+// Creator       : Malcolm J. Panthaki
+// Creation Date : 12/17/96
+CubitStatus AcisModifyEngine::webcut( DLIList<BodySM*>& webcut_body_list,
+                                      const CubitVector &vecVertex1,
+                                      const CubitVector &vecVertex2,
+                                      const CubitVector &vecVertex3,
+                                      DLIList<BodySM*>& results_list,
+                                      bool imprint ) const
+   //int webcut_debug_flag = 18;
+   //int webcut_debug_flag_on = DEBUG_FLAG(webcut_debug_flag);
-      // To be able to create a Cutting Tool of the appropriate ("infinite")
-      // size, first generate the bounding SPAbox that surrounds all the BODYs
-      // being webcut. The procedure, GeometryModifyTool::create_infinite_plane_cutting
-      // _tool, will use the size of this "super" bounding SPAbox to determine an
-      // appropriate "infinite-enough" size for the Cutting Tool.
+   BODY* cutting_tool_ptr = NULL;
-      CubitStatus rv =
-	AcisQueryEngine::instance()->create_super_acis_bounding_box ( webcut_body_list, super_bounding_box );
+     // To be able to create a Cutting Tool of the appropriate ("infinite")
+     // size, first generate the bounding SPAbox that surrounds all the BODYs
+     // being webcut. The procedure, GeometryModifyTool::create_infinite_plane_cutting
+     // _tool, will use the size of this "super" bounding SPAbox to determine an
+     // appropriate "infinite-enough" size for the Cutting Tool.
-      cutting_tool_ptr = this-> create_infinite_plane_cutting_tool(
-								   vecVertex1,
-								   vecVertex2,
-								   vecVertex3,
+   CubitStatus rv =
+       AcisQueryEngine::instance()->create_super_acis_bounding_box ( webcut_body_list, super_bounding_box );
-      if (cutting_tool_ptr == NULL)
-	  //webcut_failed(refbody_cleanup_list, BODY_cleanup_list);
-	  PRINT_ERROR("In AcisModifyEngine::webcut(,Vector,,,),%d"
-		      "       Cannot create infinite plane cutting tool using \n"
-		      "       the vectors. \n", __LINE__ );
+   cutting_tool_ptr = this-> create_infinite_plane_cutting_tool(
+       vecVertex1,
+       vecVertex2,
+       vecVertex3,
-      else
-	  // Use the BODY to perform webcut
-	  CubitStatus stat =
-	    this->webcut(webcut_body_list, cutting_tool_ptr, results_list, imprint) ;
+   if (cutting_tool_ptr == NULL)
+        //webcut_failed(refbody_cleanup_list, BODY_cleanup_list);
+      PRINT_ERROR("In AcisModifyEngine::webcut(,Vector,,,),%d"
+                  "       Cannot create infinite plane cutting tool using \n"
+                  "       the vectors. \n", __LINE__ );
-	  // Delete the BODY that was created to be used as a tool
-	  AcisQueryEngine::instance()->delete_ACIS_BODY(cutting_tool_ptr, CUBIT_TRUE) ;
-	  cutting_tool_ptr = NULL;
+   else
+        // Use the BODY to perform webcut
+      CubitStatus stat =
+          this->webcut(webcut_body_list, cutting_tool_ptr, results_list, imprint) ;
-	  return stat ;
+        // Delete the BODY that was created to be used as a tool
+      AcisQueryEngine::instance()->delete_ACIS_BODY(cutting_tool_ptr, CUBIT_TRUE) ;
+      cutting_tool_ptr = NULL;
-  // Purpose       : webcuts a list of bodies using another Body as the tool.
-  // Special Notes :
-  // Creator       : Jihong Ma
-  // Creation Date : 12/23/96
-				       DLIList<BodySM*>& webcut_body_list,
-				       BodySM const* tool_body,
-				       bool imprint)
-      // check the tool body if it is made of AcisModifyEngine
-      if( !is_modify_engine(tool_body))
-	  PRINT_ERROR("In AcisModifyEngine::webcut() %d, \n"
-		      "   The tool volume is not made of AGE itself.\n", __LINE__);
+      return stat ;
+// Purpose       : webcuts a list of bodies using another Body as the tool.
+// Special Notes :
+// Creator       : Jihong Ma
+// Creation Date : 12/23/96
+                                      BodySM const* tool_body,
+     // check the tool body if it is made of AcisModifyEngine
+   if( !is_modify_engine(tool_body))
+      PRINT_ERROR("In AcisModifyEngine::webcut() %d, \n"
+                  "   The tool volume is not made of AGE itself.\n", __LINE__);
-      BODY* tool_BODY = NULL;
-      //get the ACIS BODY of tool_body
-      tool_BODY = AcisQueryEngine::get_BODY( const_cast<BodySM*>(tool_body) );
-      if( tool_BODY == NULL )
-		      "       There is no underlying tool volume.\n",__LINE__);
+   BODY* tool_BODY = NULL;
-      return this->webcut( webcut_body_list, tool_BODY, results_list, imprint);
+     //get the ACIS BODY of tool_body
+   tool_BODY = AcisQueryEngine::get_BODY( const_cast<BodySM*>(tool_body) );
+   if( tool_BODY == NULL )
+                  "       There is no underlying tool volume.\n",__LINE__);
+   return this->webcut( webcut_body_list, tool_BODY, results_list, imprint );
@@ -10177,5768 +10171,5769 @@
-  // Purpose       : This function creates a Point, given coordinates.  The
-  //                 particular type of Point object that is created depends on
-  //                 the specific GeometryQueryEngine.  For example, this
-  //                 engine, AcisModifyEngine, creates a PointACIS and
-  //                 returns it.
-  // In this routine, a floating ACIS VERTEX is created. This VERTEX
-  // is not a part of any BODY and, hence, does not take part in
-  // any boolean operations.
-  // Creation Date : 03/05/97
-  Point* AcisModifyEngine::make_Point(CubitVector const& point) const
-      // Create a new ACIS VERTEX -- it is not attached to a BODY
-      VERTEX* VERTEX_ptr = this->make_VERTEX( point );
-      if ( VERTEX_ptr == NULL )
-	  PRINT_ERROR("In AcisModifyEngine::make_Point\n"
-		      "       Cannot make Point object.\n");
-	  return (Point *)NULL;
+// Purpose       : This function creates a Point, given coordinates.  The
+//                 particular type of Point object that is created depends on
+//                 the specific GeometryQueryEngine.  For example, this
+//                 engine, AcisModifyEngine, creates a PointACIS and
+//                 returns it.
+// Special Notes :
+// In this routine, a floating ACIS VERTEX is created. This VERTEX
+// is not a part of any BODY and, hence, does not take part in
+// any boolean operations.
+// Creation Date : 03/05/97
+Point* AcisModifyEngine::make_Point(CubitVector const& point) const
+     // Create a new ACIS VERTEX -- it is not attached to a BODY
+   VERTEX* VERTEX_ptr = this->make_VERTEX( point );
+   if ( VERTEX_ptr == NULL )
+      PRINT_ERROR("In AcisModifyEngine::make_Point\n"
+                  "       Cannot make Point object.\n");
+      return (Point *)NULL;
-      // Create a new PointACIS object
-      return AcisQueryEngine::instance()->populate_topology_bridges( VERTEX_ptr );
+     // Create a new PointACIS object
+   return AcisQueryEngine::instance()->populate_topology_bridges( VERTEX_ptr );
-  // This function creates a curve given an existing curve.
-  Curve* AcisModifyEngine::make_Curve(Curve *curve_ptr) const
-      EDGE *EDGE_ptr, *new_EDGE_ptr = NULL;
-      CurveACIS *curve_ACIS = CAST_TO(curve_ptr, CurveACIS);
-      if (!curve_ACIS)
-	  PRINT_ERROR("Cannot create an ACIS curve from the given curve.\n"
-		      "Possible incompatible geometry engines.\n");
-	  return (Curve *)NULL;
-      EDGE_ptr = curve_ACIS->get_EDGE_ptr();
+// This function creates a curve given an existing curve.
+Curve* AcisModifyEngine::make_Curve(Curve *curve_ptr) const
+  EDGE *EDGE_ptr, *new_EDGE_ptr = NULL;
+  CurveACIS *curve_ACIS = CAST_TO(curve_ptr, CurveACIS);
+  if (!curve_ACIS)
+     PRINT_ERROR("Cannot create an ACIS curve from the given curve.\n"
+                 "Possible incompatible geometry engines.\n");
+     return (Curve *)NULL;
+  EDGE_ptr = curve_ACIS->get_EDGE_ptr();
-      outcome result = api_edge( EDGE_ptr, new_EDGE_ptr );
+  outcome result = api_edge( EDGE_ptr, new_EDGE_ptr );
-      if ( !result.ok() || new_EDGE_ptr == NULL )
-	  PRINT_ERROR("In AcisModifyEngine::make_Curve\n"
-		      "       Cannot make Curve object.\n");
+  if ( !result.ok() || new_EDGE_ptr == NULL )
+    PRINT_ERROR("In AcisModifyEngine::make_Curve\n"
+                "       Cannot make Curve object.\n");
-      // Create a new CurveACIS object
-      // Use the new EDGE to create a new CurveACIS
-      return AcisQueryEngine::instance()->populate_topology_bridges(new_EDGE_ptr);
+    // Create a new CurveACIS object
+    // Use the new EDGE to create a new CurveACIS
+  return AcisQueryEngine::instance()->populate_topology_bridges(new_EDGE_ptr);
-  // Purpose       : This function creates a Curve of type, curve_type,
-  //                 given the end points of the curve and an intermediate
-  //                 point.  The particular type of Curve object that is
-  //                 created depends on the specific modeling engine.  For
-  //                 example, if the engine is AcisModifyEngine, then a
-  //                 CurveACIS is created and returned.
-  // Creator       : Raikanta Sahu
-  // Creation Date : 03/29/97
+// Purpose       : This function creates a Curve of type, curve_type,
+//                 given the end points of the curve and an intermediate
+//                 point.  The particular type of Curve object that is
+//                 created depends on the specific modeling engine.  For
+//                 example, if the engine is AcisModifyEngine, then a
+//                 CurveACIS is created and returned.
+// Special Notes :
+// Creator       : Raikanta Sahu
+// Creation Date : 03/29/97
-  Curve* AcisModifyEngine::make_Curve( GeometryType curve_type,
+Curve* AcisModifyEngine::make_Curve( GeometryType curve_type,
                                        Point const* point1_ptr,
                                        Point const* point2_ptr,
                                        CubitVector const* intermediate_point_ptr,
                                        CubitSense sense) const
-      // Extract the VERTEXes from the Points and construct a SPAposition
-      // from the cubit SPAvector.
+     // Extract the VERTEXes from the Points and construct a SPAposition
+     // from the cubit SPAvector.
-      // Cast the Points to  PointACIS
-      PointACIS* pointACIS_ptr1 = CAST_TO(const_cast<Point*>(point1_ptr), PointACIS) ;
-      PointACIS* pointACIS_ptr2 = CAST_TO(const_cast<Point*>(point2_ptr), PointACIS) ;
+     // Cast the Points to  PointACIS
+   PointACIS* pointACIS_ptr1 = CAST_TO(const_cast<Point*>(point1_ptr), PointACIS) ;
+   PointACIS* pointACIS_ptr2 = CAST_TO(const_cast<Point*>(point2_ptr), PointACIS) ;
-      // Make sure that we don't get NULL pointers after the cast down.
-      assert ( pointACIS_ptr1 != NULL && pointACIS_ptr2 != NULL ) ;
+     // Make sure that we don't get NULL pointers after the cast down.
+   assert ( pointACIS_ptr1 != NULL && pointACIS_ptr2 != NULL ) ;
-      // Get a reference to the VERTEX list of the PointACIS
-      VERTEX* VERTEX_ptr1 = pointACIS_ptr1->get_VERTEX_ptr();
-      VERTEX* VERTEX_ptr2 = pointACIS_ptr2->get_VERTEX_ptr();
+     // Get a reference to the VERTEX list of the PointACIS
+   VERTEX* VERTEX_ptr1 = pointACIS_ptr1->get_VERTEX_ptr();
+   VERTEX* VERTEX_ptr2 = pointACIS_ptr2->get_VERTEX_ptr();
-      SPAposition* pos_ptr = NULL ;
-      SPAposition pos ;
+   SPAposition* pos_ptr = NULL ;
+   SPAposition pos ;
-      if ( curve_type != STRAIGHT_CURVE_TYPE )
-	  assert ( intermediate_point_ptr != NULL) ;
+   if ( curve_type != STRAIGHT_CURVE_TYPE )
+      assert ( intermediate_point_ptr != NULL) ;
-	  // Construct a SPAposition from the given intermediate point.
-	  pos = SPAposition (intermediate_point_ptr->x(),
-			     intermediate_point_ptr->y(),
-			     intermediate_point_ptr->z()) ;
-	  pos_ptr = &pos ;
+        // Construct a SPAposition from the given intermediate point.
+      pos = SPAposition (intermediate_point_ptr->x(),
+                      intermediate_point_ptr->y(),
+                      intermediate_point_ptr->z()) ;
+      pos_ptr = &pos ;
-      logical acis_sense = TRUE;
-      if ( sense == CUBIT_REVERSED )
-	  acis_sense = FALSE;
+   logical acis_sense = TRUE;
+   if ( sense == CUBIT_REVERSED )
+      acis_sense = FALSE;
-      // Use the VERTEXes and the SPAposition to make a new EDGE
-      EDGE* EDGE_ptr = this->make_EDGE(curve_type,
-				       VERTEX_ptr1,
-				       VERTEX_ptr2,
-				       pos_ptr,
-				       acis_sense == TRUE) ;
+     // Use the VERTEXes and the SPAposition to make a new EDGE
+   EDGE* EDGE_ptr = this->make_EDGE(curve_type,
+                                    VERTEX_ptr1,
+                                    VERTEX_ptr2,
+                                    pos_ptr,
+                                    acis_sense == TRUE) ;
-      if ( EDGE_ptr == NULL )
+   if ( EDGE_ptr == NULL )
-      return AcisQueryEngine::instance()->populate_topology_bridges(EDGE_ptr);
+   return AcisQueryEngine::instance()->populate_topology_bridges(EDGE_ptr);
-  // Creation Date : 05/16/97
+// Special Notes :
+// Creation Date : 05/16/97
                                        DLIList<CubitVector*>& vector_list,
                                        Surface* ref_face_ptr ) const
-      // We make splines here :-)
-      if ( curve_type != SPLINE_CURVE_TYPE )
-		      "       Can only make spline surves in this routine.\n");
+     // We make splines here :-)
+   if ( curve_type != SPLINE_CURVE_TYPE )
+                  "       Can only make spline surves in this routine.\n");
-      // Extract the VERTEXes from the Points.
+     // Extract the VERTEXes from the Points.
-      // Convert the list of CubitVectors into an array of ACIS position's.
-      // MJP NOTE:
-      // Add the positions of the 2 end VERTEX'es into this list.
-      int number_points = vector_list.size();
-      vector_list.reset();
-      CubitVector* vector_ptr = NULL, on_surf;
-      SPAposition* pos_array = new SPAposition [number_points];
+     // Convert the list of CubitVectors into an array of ACIS position's.
+     // MJP NOTE:
+     // Add the positions of the 2 end VERTEX'es into this list.
+   int number_points = vector_list.size();
+   vector_list.reset();
+   CubitVector* vector_ptr = NULL, on_surf;
+   SPAposition* pos_array = new SPAposition [number_points];
-      // Do the vector_list of points
-      for (int i = 0; i < number_points; i++)
-	  vector_ptr = vector_list.get_and_step();
+     // Do the vector_list of points
+   for (int i = 0; i < number_points; i++)
+      vector_ptr = vector_list.get_and_step();
-	  // If the input RefFace pointer is not NULL, then move this point
-	  // to the surface of the RefFace
-	  if (ref_face_ptr != NULL)
-	      ref_face_ptr->closest_point(*vector_ptr, &on_surf);
-	      *vector_ptr = on_surf;
-	      //ref_face_ptr->move_to_surface(*vector_ptr);
+        // If the input RefFace pointer is not NULL, then move this point
+        // to the surface of the RefFace
+      if (ref_face_ptr != NULL)
+         ref_face_ptr->closest_point(*vector_ptr, &on_surf);
+         *vector_ptr = on_surf;
+         //ref_face_ptr->move_to_surface(*vector_ptr);
-	  // Set the coordinates of the SPAposition object
-	  pos_array[i].set_x(vector_ptr->x());
-	  pos_array[i].set_y(vector_ptr->y());
-	  pos_array[i].set_z(vector_ptr->z());
+        // Set the coordinates of the SPAposition object
+      pos_array[i].set_x(vector_ptr->x());
+      pos_array[i].set_y(vector_ptr->y());
+      pos_array[i].set_z(vector_ptr->z());
-      // Use the VERTEXes and the SPAposition array to make a new EDGE
-      EDGE* EDGE_ptr = this->make_spline_EDGE( VERTEX_ptr1,
-					       VERTEX_ptr2,
-					       pos_array,
-					       number_points );
-      // Free memory
-      delete [] pos_array;
+     // Use the VERTEXes and the SPAposition array to make a new EDGE
+   EDGE* EDGE_ptr = this->make_spline_EDGE( VERTEX_ptr1,
+                                            VERTEX_ptr2,
+                                            pos_array,
+                                            number_points );
+     // Free memory
+   delete [] pos_array;
-  // Purpose       : This function creats a curve that is on a
-  //                 given surface.  The third point is used
-  //                 for curves that could be periodic to dertermine
-  //                 the correct direction.
-  // Creator       : David White
-  // Creation Date : 10/21/97
-  Curve* AcisModifyEngine::make_Curve( Point const* point1_ptr,
-				       Point const* point2_ptr,
-				       Surface* ref_face_ptr,
-				       const CubitVector *third_point) const
+// Purpose       : This function creats a curve that is on a
+//                 given surface.  The third point is used
+//                 for curves that could be periodic to dertermine
+//                 the correct direction.
+// Creator       : David White
+// Creation Date : 10/21/97
+Curve* AcisModifyEngine::make_Curve( Point const* point1_ptr,
+                                     Point const* point2_ptr,
+                                     Surface* ref_face_ptr,
+                                     const CubitVector *third_point) const
-      CubitVector point_1 = point1_ptr->coordinates();
-      CubitVector point_2 = point2_ptr->coordinates();
-      CubitVector surf_norm;
-      ref_face_ptr->closest_point( point_1, NULL, &surf_norm );
+   CubitVector point_1 = point1_ptr->coordinates();
+   CubitVector point_2 = point2_ptr->coordinates();
+   CubitVector surf_norm;
+   ref_face_ptr->closest_point( point_1, NULL, &surf_norm );
-      CubitVector plane_norm;
+   CubitVector plane_norm;
-      CubitVector edge0 = point_2 - point_1;
-      CubitVector edge1 = surf_norm;
+   CubitVector edge0 = point_2 - point_1;
+   CubitVector edge1 = surf_norm;
+   plane_norm = edge0*edge1;
+   if ( plane_norm.length() < CUBIT_RESABS )
+        //try using the normal at point 2.
+      ref_face_ptr->closest_point(point_2, NULL, &surf_norm);
+      edge1 = surf_norm;
+      edge0 = point_1 - point_2;
-	  //try using the normal at point 2.
-	  ref_face_ptr->closest_point(point_2, NULL, &surf_norm);
-	  edge1 = surf_norm;
-	  edge0 = point_1 - point_2;
-	  plane_norm = edge0*edge1;
-	  if ( plane_norm.length() < CUBIT_RESABS )
-	      if ( third_point == NULL )
-		  PRINT_ERROR("Can't create curve on surface.\n"
-			      "\tVertices are on opposite sides of surface.\n"
-			      "\tUnable to infer a plane that will cut the surface.\n"
-			      "\tTry specifying a 3rd vertex in the new curve.\n");
-		  return (Curve*)NULL;
-	      else
-		  // Try getting a normal from the third point
-		  edge0 = point_1 - *third_point;
-				  "\tVertices are on opposite sides of surface\n"
-				  "\tand all three points are colinear.\n"
-				  "\tTry specifying a non-colinear 3rd vertex.\n");
-      plane_norm.normalize();
+         if ( third_point == NULL )
+            PRINT_ERROR("Can't create curve on surface.\n"
+                        "\tVertices are on opposite sides of surface.\n"
+                        "\tUnable to infer a plane that will cut the surface.\n"
+                        "\tTry specifying a 3rd vertex in the new curve.\n");
+            return (Curve*)NULL;
+         else
+             // Try getting a normal from the third point
+           edge0 = point_1 - *third_point;
+                         "\tVertices are on opposite sides of surface\n"
+                         "\tand all three points are colinear.\n"
+                         "\tTry specifying a non-colinear 3rd vertex.\n");
+   plane_norm.normalize();
-      FACE *FACE_ptr = CAST_TO(ref_face_ptr, SurfaceACIS )->get_FACE_ptr();
-      //now using the points, vertices, FACE and plane normal,
-      //creat an edge.
-      EDGE* EDGE_ptr = this->make_surface_EDGE( VERTEX_ptr1,
-						VERTEX_ptr2,
-						FACE_ptr,
-						plane_norm,
-						third_point);
-      // Free memory
+   FACE *FACE_ptr = CAST_TO(ref_face_ptr, SurfaceACIS )->get_FACE_ptr();
+     //now using the points, vertices, FACE and plane normal,
+     //creat an edge.
+   EDGE* EDGE_ptr = this->make_surface_EDGE( VERTEX_ptr1,
+                                             VERTEX_ptr2,
+                                             FACE_ptr,
+                                             plane_norm,
+                                             third_point);
+     // Free memory
-  // Purpose       : Create a surface given a surface. From another surface
-  // Creation Date : 10/6/97
+// Purpose       : Create a surface given a surface. From another surface
+// Special Notes :
+// Creation Date : 10/6/97
-  Surface* AcisModifyEngine::make_Surface( Surface *old_surface_ptr,
+Surface* AcisModifyEngine::make_Surface( Surface *old_surface_ptr,
                                            bool extended_from) const
-      //Get the surface ACIS.
-      SurfaceACIS *surf_ACIS = CAST_TO(old_surface_ptr, SurfaceACIS );
-      if (surf_ACIS == NULL)
-	  PRINT_ERROR("surface is not created from acis.\n");
-	  return (Surface*) NULL;
+     //Get the surface ACIS.
+   SurfaceACIS *surf_ACIS = CAST_TO(old_surface_ptr, SurfaceACIS );
+   if (surf_ACIS == NULL)
+      PRINT_ERROR("surface is not created from acis.\n");
+      return (Surface*) NULL;
-      //Get the acis face.
-      FACE *FACE_ptr = surf_ACIS->get_FACE_ptr();
+     //Get the acis face.
+   FACE *FACE_ptr = surf_ACIS->get_FACE_ptr();
-      //use this to make a FACE.
-      if (FACE_ptr == NULL )
-      FACE *new_FACE_ptr = NULL;
+     //use this to make a FACE.
+   if (FACE_ptr == NULL )
+   FACE *new_FACE_ptr = NULL;
-      new_FACE_ptr = make_FACE( FACE_ptr, extended_from );
-      if (new_FACE_ptr == NULL)
-	  PRINT_ERROR("In AcisModifyEngine::make_Surface\n"
-		      "       Cannot make Surface object.\n");
-	  return (Surface *)NULL;
+   new_FACE_ptr = make_FACE( FACE_ptr, extended_from );
+   if (new_FACE_ptr == NULL)
+     PRINT_ERROR("In AcisModifyEngine::make_Surface\n"
+                 "       Cannot make Surface object.\n");
+     return (Surface *)NULL;
-      //populate the bridges from the body
-      BODY *body_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY(new_FACE_ptr);
-      BodySM *body_sm = AcisQueryEngine::instance()->populate_topology_bridges( body_ptr );
-      DLIList<Surface*> surfs;
-      body_sm->surfaces( surfs );
-      Surface *surface = surfs.get();
+   //populate the bridges from the body
+   BODY *body_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY(new_FACE_ptr);
+   BodySM *body_sm = AcisQueryEngine::instance()->populate_topology_bridges( body_ptr );
+   DLIList<Surface*> surfs;
+   body_sm->surfaces( surfs );
+   Surface *surface = surfs.get();
-      return surface;
+   return surface;
-  // Purpose       : This function creates a Surface of type,
-  //                 surface_type, given the list of curves.
-  Surface* AcisModifyEngine::make_Surface( GeometryType surface_type,
+// Purpose       : This function creates a Surface of type,
+//                 surface_type, given the list of curves.
+// Special Notes :
+Surface* AcisModifyEngine::make_Surface( GeometryType surface_type,
                                            DLIList<Curve*>& curve_list,
                                            bool check_edges ) const
+  DLIList<RefEdge*> copied_ref_edges;
+  int i;
+  if( check_edges )
+    DLIList<RefEdge*> edge_list;
+    for( i=curve_list.size(); i--; )
-      DLIList<RefEdge*> copied_ref_edges;
-      int i;
-      if( check_edges )
-	  DLIList<RefEdge*> edge_list;
-	  for( i=curve_list.size(); i--; )
-	      RefEdge *tmp_ref_edge = NULL;
-	      tmp_ref_edge = CAST_TO( curve_list.get_and_step()->topology_entity(), RefEdge );
-	      if( tmp_ref_edge )
-		edge_list.append( tmp_ref_edge );
+      RefEdge *tmp_ref_edge = NULL;
+      tmp_ref_edge = CAST_TO( curve_list.get_and_step()->topology_entity(), RefEdge );
+      if( tmp_ref_edge )
+        edge_list.append( tmp_ref_edge );
-	  //duplicate curves possibly
+    //duplicate curves possibly
-	  //Modified by J.K. to avoid core dump if vertices are merged.
-	  //If vertices belong to edges other than those we are creating
-	  //the surface from, copy the corresponding edges.  This will
-	  //also pick up the case where edges already belong to a face.
-	  DLIList<RefEdge*> vtx_edges;
-	  DLIList<RefVertex*> vtx_list;
-	  for ( i = edge_list.size(); i > 0; i-- )
-	      RefEdge *ref_edge = edge_list.get();
+    //Modified by J.K. to avoid core dump if vertices are merged.
+    //If vertices belong to edges other than those we are creating
+    //the surface from, copy the corresponding edges.  This will
+    //also pick up the case where edges already belong to a face.
+    DLIList<RefEdge*> vtx_edges;
+    DLIList<RefVertex*> vtx_list;
+    for ( i = edge_list.size(); i > 0; i-- )
+      RefEdge *ref_edge = edge_list.get();
-	      CubitBoolean other_edge = CUBIT_FALSE;
-	      ref_edge->ref_vertices(vtx_list);
-	      while( vtx_list.size() )
-		  vtx_edges.clean_out();
-		  vtx_list.pop()->ref_edges( vtx_edges );
-		  while( vtx_edges.size() )
-		      if( ! edge_list.is_in_list( vtx_edges.pop() ) )
-			  other_edge = CUBIT_TRUE;
-			  vtx_list.clean_out();
-			  break;
+      CubitBoolean other_edge = CUBIT_FALSE;
+      ref_edge->ref_vertices(vtx_list);
+      while( vtx_list.size() )
+        vtx_edges.clean_out();
+        vtx_list.pop()->ref_edges( vtx_edges );
+        while( vtx_edges.size() )
+          if( ! edge_list.is_in_list( vtx_edges.pop() ) )
+            other_edge = CUBIT_TRUE;
+            vtx_list.clean_out();
+            break;
-	      if ( other_edge || (ref_edge->get_parents() > 0) )
-		  RefEdge *replacement_edge = GeometryModifyTool::instance()->make_RefEdge( ref_edge );
-		  if (!replacement_edge)
-		      PRINT_WARNING("Creation of Surface Unsuccessful\n");
-		  edge_list.change_to( replacement_edge );
-		  copied_ref_edges.append( replacement_edge );
-	      edge_list.step();
+      if ( other_edge || (ref_edge->get_parents() > 0) )
+        RefEdge *replacement_edge = GeometryModifyTool::instance()->make_RefEdge( ref_edge );
+        if (!replacement_edge)
+          PRINT_WARNING("Creation of Surface Unsuccessful\n");
+        edge_list.change_to( replacement_edge );
+        copied_ref_edges.append( replacement_edge );
+      edge_list.step();
-	  curve_list.clean_out();
-	  for( i=edge_list.size(); i--; )
-	      Curve *tmp_curve = NULL;
-	      tmp_curve =
-		CAST_TO( edge_list.get_and_step()->bridge_manager()->topology_bridge(), Curve);
-	      if( tmp_curve )
-		curve_list.append( tmp_curve );
+    curve_list.clean_out();
+    for( i=edge_list.size(); i--; )
+      Curve *tmp_curve = NULL;
+      tmp_curve =
+      CAST_TO( edge_list.get_and_step()->bridge_manager()->topology_bridge(), Curve);
+      if( tmp_curve )
+        curve_list.append( tmp_curve );
-      DLIList<EDGE*> EDGE_list ;
-      // List of EDGEs to use to create the FACE from which we can make
-      // a SurfaceACIS.
+   DLIList<EDGE*> EDGE_list ;
+     // List of EDGEs to use to create the FACE from which we can make
+     // a SurfaceACIS.
-      // Extract the EDGEs from the given Curves
-      Curve const* curve_ptr = NULL ;
-      CurveACIS* curveACIS_ptr = NULL ;
-      EDGE* EDGE_ptr = NULL ;
+     // Extract the EDGEs from the given Curves
+   Curve const* curve_ptr = NULL ;
+   CurveACIS* curveACIS_ptr = NULL ;
+   EDGE* EDGE_ptr = NULL ;
-      curve_list.reset() ;
+   curve_list.reset() ;
-      for ( i = 0 ; i < curve_list.size() ; i++ )
-	  curve_ptr = curve_list.get_and_step() ;
-	  curveACIS_ptr = CAST_TO(const_cast<Curve*>(curve_ptr), CurveACIS) ;
+   for ( i = 0 ; i < curve_list.size() ; i++ )
+      curve_ptr = curve_list.get_and_step() ;
+      curveACIS_ptr = CAST_TO(const_cast<Curve*>(curve_ptr), CurveACIS) ;
-	  if ( curveACIS_ptr == NULL )
-			  "       Got a NULL pointer to CurveACIS\n") ;
-	      assert ( curveACIS_ptr != NULL ) ;
+      if ( curveACIS_ptr == NULL )
+                     "       Got a NULL pointer to CurveACIS\n") ;
+         assert ( curveACIS_ptr != NULL ) ;
-	  // Get the EDGE
-	  EDGE_ptr = curveACIS_ptr->get_EDGE_ptr() ;
+        // Get the EDGE
+      EDGE_ptr = curveACIS_ptr->get_EDGE_ptr() ;
-	  // Add the EDGE to the list of EDGEs to be used to make a FACE
-	  EDGE_list.append(EDGE_ptr) ;
+        // Add the EDGE to the list of EDGEs to be used to make a FACE
+      EDGE_list.append(EDGE_ptr) ;
-      // Use the EDGEs to make a FACE
-      FACE* FACE_ptr = this->make_FACE(surface_type, EDGE_list,
-				       old_surface_ptr) ;
+     // Use the EDGEs to make a FACE
+   FACE* FACE_ptr = this->make_FACE(surface_type, EDGE_list,
+                                    old_surface_ptr) ;
-      if (FACE_ptr == NULL)
-	  //delete all the copied ref edges...copied just for creating this surface
-	  for(i=copied_ref_edges.size(); i--; )
-	    GeometryQueryTool::instance()->delete_RefEdge( copied_ref_edges.get_and_step() );
+   if (FACE_ptr == NULL)
+     //delete all the copied ref edges...copied just for creating this surface
+     for(i=copied_ref_edges.size(); i--; )
+       GeometryQueryTool::instance()->delete_RefEdge( copied_ref_edges.get_and_step() );
-      // make the topology bridges for the face
-      Surface *surface = AcisQueryEngine::instance()->populate_topology_bridges(FACE_ptr);
-      return surface;
+     // make the topology bridges for the face
+   Surface *surface = AcisQueryEngine::instance()->populate_topology_bridges(FACE_ptr);
+   return surface;
-      // now generate the body
-      DLIList<BODY*> new_BODIES;
-      DLIList<Body*> new_bodies;
-      new_BODIES.append(AcisQueryEngine::instance()->get_BODY_of_ENTITY(FACE_ptr));
-      CubitStatus success = get_new_Body(old_entities,
-      new_BODIES, new_bodies, CUBIT_FALSE);
+     // now generate the body
+   DLIList<BODY*> new_BODIES;
+   DLIList<Body*> new_bodies;
+   new_BODIES.append(AcisQueryEngine::instance()->get_BODY_of_ENTITY(FACE_ptr));
+   CubitStatus success = get_new_Body(old_entities,
+                                      new_BODIES, new_bodies, CUBIT_FALSE);
-      AcisBridge *tb_ptr = ATTRIB_CUBIT_OWNER::cubit_owner(FACE_ptr);
-      return CAST_TO(tb_ptr, Surface);
+   AcisBridge *tb_ptr = ATTRIB_CUBIT_OWNER::cubit_owner(FACE_ptr);
+   return CAST_TO(tb_ptr, Surface);
-  // Purpose       : This function creates a Lump of type, lump_type,
-  //                 given the list of surfaces.
+// Purpose       : This function creates a Lump of type, lump_type,
+//                 given the list of surfaces.
+// Special Notes :
-  Lump* AcisModifyEngine::make_Lump( DLIList<Surface*>& surface_list ) const
-      // Extract the FACEs of the surface list. Use the FACEs to
-      // create a SHELL.
-      Surface const* surface_ptr = NULL ;
-      SurfaceACIS* surfaceACIS_ptr = NULL ;
-      FACE* first_FACE_ptr = NULL ;
-      FACE* current_FACE_ptr = NULL ;
-      FACE* previous_FACE_ptr = NULL ;
+Lump* AcisModifyEngine::make_Lump( DLIList<Surface*>& surface_list ) const
+     // Extract the FACEs of the surface list. Use the FACEs to
+     // create a SHELL.
+   Surface const* surface_ptr = NULL ;
+   SurfaceACIS* surfaceACIS_ptr = NULL ;
+   FACE* first_FACE_ptr = NULL ;
+   FACE* current_FACE_ptr = NULL ;
+   FACE* previous_FACE_ptr = NULL ;
-      surface_list.reset() ;
-      for ( int i = 0 ; i < surface_list.size() ; i++ )
-	  surface_ptr = surface_list.get_and_step() ;
-	  surfaceACIS_ptr = CAST_TO(const_cast<Surface*>(surface_ptr), SurfaceACIS) ;
+   surface_list.reset() ;
+   for ( int i = 0 ; i < surface_list.size() ; i++ )
+      surface_ptr = surface_list.get_and_step() ;
+      surfaceACIS_ptr = CAST_TO(const_cast<Surface*>(surface_ptr), SurfaceACIS) ;
-	  // Make sure that we have a valid SurfaceACIS pointer
-	  if ( surfaceACIS_ptr == NULL )
-	      PRINT_ERROR("In AcisModifyEngine::make_Lump\n"
-			  "       Got a NULL pointer to SurfaceACIS\n") ;
-	      assert ( surfaceACIS_ptr != NULL ) ;
+        // Make sure that we have a valid SurfaceACIS pointer
+      if ( surfaceACIS_ptr == NULL )
+         PRINT_ERROR("In AcisModifyEngine::make_Lump\n"
+                     "       Got a NULL pointer to SurfaceACIS\n") ;
+         assert ( surfaceACIS_ptr != NULL ) ;
-	  current_FACE_ptr = surfaceACIS_ptr->get_FACE_ptr();
+      current_FACE_ptr = surfaceACIS_ptr->get_FACE_ptr();
-	  // Connect up the previous FACE and the current FACE if
-	  // the current FACE is not the first FACE.
-	  if ( previous_FACE_ptr != NULL )
-	      previous_FACE_ptr->set_next(current_FACE_ptr) ;
-	  else
-	      first_FACE_ptr = current_FACE_ptr ;
+        // Connect up the previous FACE and the current FACE if
+        // the current FACE is not the first FACE.
+      if ( previous_FACE_ptr != NULL )
+         previous_FACE_ptr->set_next(current_FACE_ptr) ;
+      else
+         first_FACE_ptr = current_FACE_ptr ;
-	  previous_FACE_ptr = current_FACE_ptr ;
+      previous_FACE_ptr = current_FACE_ptr ;
-      // Create a new SHELL if the first FACE is not attached to
-      // a SHELL.
-      SHELL* SHELL_ptr = first_FACE_ptr->shell() ;
+     // Create a new SHELL if the first FACE is not attached to
+     // a SHELL.
+   SHELL* SHELL_ptr = first_FACE_ptr->shell() ;
+   if ( SHELL_ptr == NULL )
+      SHELL_ptr = new SHELL(first_FACE_ptr, NULL, NULL) ;
-	  SHELL_ptr = new SHELL(first_FACE_ptr, NULL, NULL) ;
-	  if ( SHELL_ptr == NULL )
-			  "       ACIS cannot make SHELL object.\n"
-			  "       Cannot make Lump object.\n");
-	      return (Lump *)NULL;
+                     "       ACIS cannot make SHELL object.\n"
+                     "       Cannot make Lump object.\n");
+         return (Lump *)NULL;
-      // Create a new LUMP and attach the SHELL to it.
-      LUMP* LUMP_ptr = SHELL_ptr->lump();
-      if (LUMP_ptr == NULL)
-	  LUMP_ptr = new LUMP(SHELL_ptr, NULL) ;
-	  if ( LUMP_ptr == NULL )
-			  "       ACIS cannot make LUMP object.\n"
+     // Create a new LUMP and attach the SHELL to it.
+   LUMP* LUMP_ptr = SHELL_ptr->lump();
+   if (LUMP_ptr == NULL)
+      LUMP_ptr = new LUMP(SHELL_ptr, NULL) ;
+      if ( LUMP_ptr == NULL )
+                     "       ACIS cannot make LUMP object.\n"
-      // Create a LumpACIS using the LUMP_ptr
-      LumpACIS* lumpACIS_ptr = new LumpACIS(LUMP_ptr) ;
-      assert( lumpACIS_ptr != NULL );
+     // Create a LumpACIS using the LUMP_ptr
+   LumpACIS* lumpACIS_ptr = new LumpACIS(LUMP_ptr) ;
+   assert( lumpACIS_ptr != NULL );
-      AcisQueryEngine::instance()->populate_topology_bridges(LUMP_ptr);
-	AcisBridge *tb_ptr = ATTRIB_CUBIT_OWNER::cubit_owner(LUMP_ptr);
+   AcisQueryEngine::instance()->populate_topology_bridges(LUMP_ptr);
+   AcisBridge *tb_ptr = ATTRIB_CUBIT_OWNER::cubit_owner(LUMP_ptr);
-	Lump *this_lump = CAST_TO(tb_ptr, Lump);
-	ShellSM *shellsm = this_lump->shellsm();
+   Lump *this_lump = CAST_TO(tb_ptr, Lump);
+   ShellSM *shellsm = this_lump->shellsm();
-	// Use the SHELL to build VGI Shell and CoFace, using 0 for color
-	Shell* Shell_ptr = GeometryQueryTool::instance()->make_Shell(shellsm) ;
+     // Use the SHELL to build VGI Shell and CoFace, using 0 for color
+   Shell* Shell_ptr = GeometryQueryTool::instance()->make_Shell(shellsm) ;
-	if (Shell_ptr == NULL)
-	"       Could not build a Shell for unknown reasons.\n");
-      // Return the new LumpACIS
-      return lumpACIS_ptr ;
+   if (Shell_ptr == NULL)
+                  "       Could not build a Shell for unknown reasons.\n");
+     // Return the new LumpACIS
+   return lumpACIS_ptr ;
-  BodySM* AcisModifyEngine::make_BodySM( Surface *surface_ptr) const
-      //- given a Surface, make a BodySM
-      // make sure this Surface is the right type
-      SurfaceACIS *sa_ptr = CAST_TO(surface_ptr, SurfaceACIS);
-      assert(sa_ptr != 0);
+BodySM* AcisModifyEngine::make_BodySM( Surface *surface_ptr) const
+    //- given a Surface, make a BodySM
+    // make sure this Surface is the right type
+  SurfaceACIS *sa_ptr = CAST_TO(surface_ptr, SurfaceACIS);
+  assert(sa_ptr != 0);
-      // now, get the acis BODY and populate the topology bridges
-      FACE *face = sa_ptr->get_FACE_ptr();
-      BODY *body_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY(face);
+    // now, get the acis BODY and populate the topology bridges
+  FACE *face = sa_ptr->get_FACE_ptr();
+  BODY *body_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY(face);
-      return AcisQueryEngine::instance()->populate_topology_bridges(body_ptr);
+  return AcisQueryEngine::instance()->populate_topology_bridges(body_ptr);
-  // Purpose       : This function creates a BodySM given a list of Lumps.
+// Purpose       : This function creates a BodySM given a list of Lumps.
+// Special Notes :
-  BodySM* AcisModifyEngine::make_BodySM( DLIList<Lump*>& lump_list ) const
-      // Extract the LUMPs of the lump list. Use the LUMPs to
-      // create a BODY.
-      Lump const* lump_ptr = NULL ;
-      LumpACIS* lumpACIS_ptr = NULL ;
-      LUMP* first_LUMP_ptr = NULL ;
-      LUMP* current_LUMP_ptr = NULL ;
-      LUMP* previous_LUMP_ptr = NULL ;
+BodySM* AcisModifyEngine::make_BodySM( DLIList<Lump*>& lump_list ) const
+     // Extract the LUMPs of the lump list. Use the LUMPs to
+     // create a BODY.
+   Lump const* lump_ptr = NULL ;
+   LumpACIS* lumpACIS_ptr = NULL ;
+   LUMP* first_LUMP_ptr = NULL ;
+   LUMP* current_LUMP_ptr = NULL ;
+   LUMP* previous_LUMP_ptr = NULL ;
-      lump_list.reset() ;
-      for ( int i = 0 ; i < lump_list.size() ; i++ )
-	  lump_ptr = lump_list.get_and_step() ;
-	  lumpACIS_ptr = CAST_TO(const_cast<Lump*>(lump_ptr), LumpACIS) ;
+   lump_list.reset() ;
+   for ( int i = 0 ; i < lump_list.size() ; i++ )
+      lump_ptr = lump_list.get_and_step() ;
+      lumpACIS_ptr = CAST_TO(const_cast<Lump*>(lump_ptr), LumpACIS) ;
-	  // Make sure that we have a valid LumpACIS pointer
-	  if ( lumpACIS_ptr == NULL )
-			  "       Input Lump is not a LumpACIS\n") ;
-	      assert ( lumpACIS_ptr != NULL ) ;
+        // Make sure that we have a valid LumpACIS pointer
+      if ( lumpACIS_ptr == NULL )
+                     "       Input Lump is not a LumpACIS\n") ;
+         assert ( lumpACIS_ptr != NULL ) ;
-	  current_LUMP_ptr = lumpACIS_ptr->get_LUMP_ptr();
+      current_LUMP_ptr = lumpACIS_ptr->get_LUMP_ptr();
-	  // Connect up the previous LUMP and the current LUMP if
-	  // the current LUMP is not the first LUMP.
-	  if ( previous_LUMP_ptr != NULL )
-	      previous_LUMP_ptr->set_next(current_LUMP_ptr) ;
-	  else
-	      first_LUMP_ptr = current_LUMP_ptr ;
+        // Connect up the previous LUMP and the current LUMP if
+        // the current LUMP is not the first LUMP.
+      if ( previous_LUMP_ptr != NULL )
+         previous_LUMP_ptr->set_next(current_LUMP_ptr) ;
+      else
+         first_LUMP_ptr = current_LUMP_ptr ;
-	  previous_LUMP_ptr = current_LUMP_ptr ;
+      previous_LUMP_ptr = current_LUMP_ptr ;
-      // Create a new BODY if the first LUMP is not attached to
-      // a BODY.
-      BODY* BODY_ptr = first_LUMP_ptr->body() ;
+     // Create a new BODY if the first LUMP is not attached to
+     // a BODY.
+   BODY* BODY_ptr = first_LUMP_ptr->body() ;
+   if ( BODY_ptr == NULL )
+      BODY_ptr = new BODY(first_LUMP_ptr) ;
-	  BODY_ptr = new BODY(first_LUMP_ptr) ;
-	  if ( BODY_ptr == NULL )
-	      PRINT_ERROR("In AcisModifyEngine::make_BodySM\n"
-			  "       ACIS cannot make BODY object.\n"
-			  "       Cannot make BodySM object.\n");
-	      return (BodySM *)NULL;
+         PRINT_ERROR("In AcisModifyEngine::make_BodySM\n"
+                     "       ACIS cannot make BODY object.\n"
+                     "       Cannot make BodySM object.\n");
+         return (BodySM *)NULL;
-      // Use the BODY to build VGI Body and CoVolume(s)
-      BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges(BODY_ptr);
+     // Use the BODY to build VGI Body and CoVolume(s)
+   BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges(BODY_ptr);
-      /* Commenting out following section - we shouldn't be making
-	 Body's yet!!!
+     /* Commenting out following section - we shouldn't be making
+        Body's yet!!!
-	 Body* body_ptr = GeometryModifyTool::instance()->make_Body(this_bodysm);
-	 assert( body_ptr != NULL );
+   Body* body_ptr = GeometryModifyTool::instance()->make_Body(this_bodysm);
+   assert( body_ptr != NULL );
-	 // First get the OSME associated with this Body
-	 BodySM* OSME_ptr =
-	 body_ptr->get_body_sm_ptr() ;
+     // First get the OSME associated with this Body
+   BodySM* OSME_ptr =
+       body_ptr->get_body_sm_ptr() ;
-	 // Cast the OSME to BodyACIS
-	 BodyACIS* bodyACIS_ptr = CAST_TO(OSME_ptr, BodyACIS) ;
+     // Cast the OSME to BodyACIS
+   BodyACIS* bodyACIS_ptr = CAST_TO(OSME_ptr, BodyACIS) ;
-	 // Make sure that we have a valid BodyACIS
-	 assert ( bodyACIS_ptr != NULL ) ;
-      // Return the BodyACIS
-      return this_bodysm;
+     // Make sure that we have a valid BodyACIS
+   assert ( bodyACIS_ptr != NULL ) ;
+     // Return the BodyACIS
+   return this_bodysm;
-  CubitStatus AcisModifyEngine::regularize_body( BodySM *body_ptr,
-						 BodySM *&new_body_ptr)
-      CubitBoolean new_ids = GeometryModifyTool::instance()->get_new_ids();
-      CubitBoolean not_new_ids = (new_ids ? CUBIT_FALSE : CUBIT_TRUE);
-      BODY *old_BODY = AcisQueryEngine::get_BODY(body_ptr );
-      if (!old_BODY)
-      BODY *acis_BODY = this->copy_BODY(old_BODY, new_ids);
+CubitStatus AcisModifyEngine::regularize_body( BodySM *body_ptr,
+                                               BodySM *&new_body_ptr)
+  CubitBoolean new_ids = GeometryModifyTool::instance()->get_new_ids();
+  CubitBoolean not_new_ids = (new_ids ? CUBIT_FALSE : CUBIT_TRUE);
-      outcome result = api_clean_entity( (ENTITY*) acis_BODY);
-      //outcome result = api_regularise_entity( (ENTITY*) acis_BODY);
-      if (!result.ok() || acis_BODY == NULL ||
-	  acis_BODY->lump() == NULL )
-	  PRINT_ERROR("found in AcisModifyEngine::regularize_body.\n"
-		      "api_regularise_entity failed.\n");
-	  AcisQueryEngine::instance()->ACIS_API_error (result);
-	  AcisQueryEngine::instance()->delete_ACIS_BODY(acis_BODY, not_new_ids);
+   BODY *old_BODY = AcisQueryEngine::get_BODY(body_ptr );
+   if (!old_BODY)
+   BODY *acis_BODY = this->copy_BODY(old_BODY, new_ids);
-      new_body_ptr = get_new_Body(body_ptr, old_BODY, acis_BODY, false);
+   outcome result = api_clean_entity( (ENTITY*) acis_BODY);
+   //outcome result = api_regularise_entity( (ENTITY*) acis_BODY);
+   if (!result.ok() || acis_BODY == NULL ||
+       acis_BODY->lump() == NULL )
+      PRINT_ERROR("found in AcisModifyEngine::regularize_body.\n"
+                  "api_regularise_entity failed.\n");
+      AcisQueryEngine::instance()->ACIS_API_error (result);
+      AcisQueryEngine::instance()->delete_ACIS_BODY(acis_BODY, not_new_ids);
-      if (new_body_ptr) return CUBIT_SUCCESS;
-      else return CUBIT_FAILURE;
+   new_body_ptr = get_new_Body(body_ptr, old_BODY, acis_BODY, false);
-  // Purpose       : clean RefEntity
-  // Creator       : Lingyun Pan (CAT)
-  // Creation Date : 07/15/01
+   if (new_body_ptr) return CUBIT_SUCCESS;
+   else return CUBIT_FAILURE;
-  CubitStatus AcisModifyEngine::regularize_entity( GeometryEntity *old_refentity_ptr,
+// Purpose       : clean RefEntity
+// Special Notes :
+// Creator       : Lingyun Pan (CAT)
+// Creation Date : 07/15/01
-      BODY *copied_BODY_ptr;
-      SurfaceACIS *ref_face = CAST_TO(old_refentity_ptr, SurfaceACIS);
-      CurveACIS *ref_edge= CAST_TO(old_refentity_ptr, CurveACIS);
-      PointACIS *ref_vertex= CAST_TO(old_refentity_ptr, PointACIS);
+CubitStatus AcisModifyEngine::regularize_entity( GeometryEntity *old_refentity_ptr,
-      DLIList<SurfaceACIS*> reg_face_list;
-      DLIList<FACE*> FACE_list;
+  BODY *copied_BODY_ptr;
+  SurfaceACIS *ref_face = CAST_TO(old_refentity_ptr, SurfaceACIS);
+  CurveACIS *ref_edge= CAST_TO(old_refentity_ptr, CurveACIS);
+  PointACIS *ref_vertex= CAST_TO(old_refentity_ptr, PointACIS);
-      DLIList<CurveACIS*> reg_edge_list;
-      DLIList<EDGE*> EDGE_list;
+  DLIList<SurfaceACIS*> reg_face_list;
+  DLIList<FACE*> FACE_list;
-      DLIList<PointACIS*> reg_vertex_list;
-      DLIList<VERTEX*> VERTEX_list;
+  DLIList<CurveACIS*> reg_edge_list;
+  DLIList<EDGE*> EDGE_list;
-      // get the copied_BODY_ptr and FACE_list to clean
-      if (ref_face)
+  DLIList<PointACIS*> reg_vertex_list;
+  DLIList<VERTEX*> VERTEX_list;
+  // get the copied_BODY_ptr and FACE_list to clean
+  if (ref_face)
 	  reg_face_list.append(ref_face);
-	  if (get_copied_FACES_of_body( reg_face_list, FACE_list, copied_BODY_ptr )== CUBIT_FAILURE )
-	      PRINT_ERROR("Surface has no volume associated with it.\n");
+      if (get_copied_FACES_of_body( reg_face_list, FACE_list, copied_BODY_ptr )== CUBIT_FAILURE )
+         PRINT_ERROR("Surface has no volume associated with it.\n");
-      // get the copied_BODY_ptr and EDGE_list to clean
-      if (ref_edge)
+// get the copied_BODY_ptr and EDGE_list to clean
+  if (ref_edge)
 	  reg_edge_list.append(ref_edge);
-	  if(get_copied_EDGES_of_body( reg_edge_list, EDGE_list, copied_BODY_ptr )== CUBIT_FAILURE )
-	      PRINT_ERROR("Edge has no volume associated with it.\n");
+      if(get_copied_EDGES_of_body( reg_edge_list, EDGE_list, copied_BODY_ptr )== CUBIT_FAILURE )
+         PRINT_ERROR("Edge has no volume associated with it.\n");
-      if (ref_vertex)
+ if (ref_vertex)
 	  reg_vertex_list.append(ref_vertex);
-	  if (get_copied_VERTICES_of_body( reg_vertex_list, VERTEX_list, copied_BODY_ptr )== CUBIT_FAILURE )
-	      PRINT_ERROR("Vertex has no volume associated with it.\n");
+      if (get_copied_VERTICES_of_body( reg_vertex_list, VERTEX_list, copied_BODY_ptr )== CUBIT_FAILURE )
+         PRINT_ERROR("Vertex has no volume associated with it.\n");
-      if (!ref_face && !ref_edge && !ref_vertex)
+  if (!ref_face && !ref_edge && !ref_vertex)
 	  //complain
-	  PRINT_ERROR("RefEntity is neither a RefEdge, RefFace, nor RefVertex.\n");
+      PRINT_ERROR("RefEntity is neither a RefEdge, RefFace, nor RefVertex.\n");
 	  PRINT_ERROR("found in AcisModifyEngine::regularize_refentity.\n"
-		      "api_regularise_refentity aborted.\n");
+					  "api_regularise_refentity aborted.\n");
 	  AcisQueryEngine::instance()->delete_ACIS_BODY(copied_BODY_ptr, not_new_ids);
-      // Get original Body and BODY
-      BodySM *body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY( copied_BODY_ptr );
+  // Get original Body and BODY
+  BodySM *body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY( copied_BODY_ptr );
-      BODY *BODY_ptr =  AcisQueryEngine::get_BODY(body_ptr);
+  BODY *BODY_ptr =  AcisQueryEngine::get_BODY(body_ptr);
-      int i;
-      FACE *acis_FACE;
-      EDGE *acis_EDGE;
-      VERTEX *acis_VERTEX;
+  int i;
+  FACE *acis_FACE;
+  EDGE *acis_EDGE;
+  VERTEX *acis_VERTEX;
-      //clean FACE
-      for (i=0;i<FACE_list.size();i++)
+ //clean FACE
+  for (i=0;i<FACE_list.size();i++)
 	  acis_FACE = FACE_list.get_and_step();
 	  outcome result = api_clean_entity( (ENTITY*) acis_FACE);
 	  if (!result.ok() || acis_FACE == NULL )
-	      PRINT_ERROR("found in AcisModifyEngine::regularize_refentity.\n"
-			  "api_regularise_refentity failed.\n");
-	      AcisQueryEngine::instance()->delete_ACIS_BODY(copied_BODY_ptr, not_new_ids);
+		  PRINT_ERROR("found in AcisModifyEngine::regularize_refentity.\n"
+					  "api_regularise_refentity failed.\n");
+		 AcisQueryEngine::instance()->delete_ACIS_BODY(copied_BODY_ptr, not_new_ids);
-      // clean EDGE
-      for (i=0;i<EDGE_list.size();i++)
+  // clean EDGE
+  for (i=0;i<EDGE_list.size();i++)
 	  acis_EDGE = EDGE_list.get_and_step();
 	  outcome result = api_clean_entity( (ENTITY*) acis_EDGE);
 	  if (!result.ok() || acis_EDGE == NULL )
-      // clean VERTEX
-      for (i=0;i<VERTEX_list.size();i++)
+  // clean VERTEX
+  for (i=0;i<VERTEX_list.size();i++)
 	  acis_VERTEX = VERTEX_list.get_and_step();
 	  outcome result = api_clean_entity( (ENTITY*) acis_VERTEX);
 	  if (!result.ok() || acis_VERTEX == NULL )
-      //rebuild the cubit geometry
-      new_body_ptr = get_new_Body( body_ptr,  BODY_ptr , copied_BODY_ptr , false);
+  //rebuild the cubit geometry
+  new_body_ptr = get_new_Body( body_ptr,  BODY_ptr , copied_BODY_ptr , false);
-  CubitStatus AcisModifyEngine::split_body( BodySM *body_ptr,
-					    DLIList<BodySM*> &new_bodies )
-      bool delete_attribs = GeometryModifyTool::instance()->get_new_ids() != 0;
-      //get the acis body.
-      BODY* acis_BODY = NULL;
-      BODY **new_BODY_list;
-      int n_body;
+CubitStatus AcisModifyEngine::split_body( BodySM *body_ptr,
+                                          DLIList<BodySM*> &new_bodies )
+  bool delete_attribs = GeometryModifyTool::instance()->get_new_ids() != 0;
+     //get the acis body.
+   BODY* acis_BODY = NULL;
+   BODY **new_BODY_list;
+   int n_body;
-      acis_BODY = this->copy_BODY(old_BODY, delete_attribs);
+   acis_BODY = this->copy_BODY(old_BODY, delete_attribs);
-      outcome result = api_separate_body( acis_BODY, n_body, new_BODY_list );
+   outcome result = api_separate_body( acis_BODY, n_body, new_BODY_list );
-      if (!result.ok())
-	  PRINT_ERROR("Error in seperating volumes.\n");
-	  AcisQueryEngine::instance()->delete_ACIS_BODY(acis_BODY, CUBIT_TRUE);
+   if (!result.ok())
+      PRINT_ERROR("Error in seperating volumes.\n");
+      AcisQueryEngine::instance()->delete_ACIS_BODY(acis_BODY, CUBIT_TRUE);
-      DLIList<BODY*> new_BODYs;
-      for (int i = 0; i < n_body; i++)
-	new_BODYs.append(new_BODY_list[i]);
+   DLIList<BODY*> new_BODYs;
+   for (int i = 0; i < n_body; i++)
+     new_BODYs.append(new_BODY_list[i]);
-      CubitStatus status = get_new_Body(body_ptr, old_BODY,
-					new_BODYs, new_bodies,
-					CUBIT_FALSE);
-      return status;
+   CubitStatus status = get_new_Body(body_ptr, old_BODY,
+                                     new_BODYs, new_bodies,
+                                     CUBIT_FALSE);
+   return status;
-  CubitStatus AcisModifyEngine::split_periodic( BodySM *body_ptr,
-						BodySM *&new_body)
+CubitStatus AcisModifyEngine::split_periodic( BodySM *body_ptr,
+                                              BodySM *&new_body)
-      BODY *old_BODY = AcisQueryEngine::get_BODY( body_ptr );
-				  GeometryModifyTool::instance()->get_new_ids());
+   BODY *old_BODY = AcisQueryEngine::get_BODY( body_ptr );
+                               GeometryModifyTool::instance()->get_new_ids());
-      outcome some_result = api_split_periodic_faces( acis_BODY );
+   outcome some_result = api_split_periodic_faces( acis_BODY );
-      if ( acis_BODY == NULL || !some_result.ok() )
-	  if (acis_BODY != NULL )
-	    AcisQueryEngine::instance()->delete_ACIS_BODY( acis_BODY );
+   if ( acis_BODY == NULL || !some_result.ok() )
+      if (acis_BODY != NULL )
+          AcisQueryEngine::instance()->delete_ACIS_BODY( acis_BODY );
-	  PRINT_ERROR("Unable to split periodic surface.\n");
+      PRINT_ERROR("Unable to split periodic surface.\n");
-      new_body = get_new_Body(body_ptr, old_BODY, acis_BODY, false);
+   new_body = get_new_Body(body_ptr, old_BODY, acis_BODY, false);
-      if ( new_body == NULL )
-	  PRINT_ERROR("Can not make a volume out of the split volumes.\n");
+   if ( new_body == NULL )
+      PRINT_ERROR("Can not make a volume out of the split volumes.\n");
-      else return CUBIT_SUCCESS;
+   else return CUBIT_SUCCESS;
-  EDGE *
-    AcisModifyEngine::make_spline_EDGE( DLIList<CubitVector*> &vec_list )
-      int i;
-      EDGE *new_EDGE_ptr = NULL;
+EDGE *
+AcisModifyEngine::make_spline_EDGE( DLIList<CubitVector*> &vec_list )
+  int i;
+  EDGE *new_EDGE_ptr = NULL;
-      // Create a spline
-      int num_pnts = vec_list.size();
-      SPAposition* pos_array = new SPAposition[num_pnts];
+  // Create a spline
+  int num_pnts = vec_list.size();
+  SPAposition* pos_array = new SPAposition[num_pnts];
-      // Fill the vector_list of points
-      vec_list.reset();
-      for( i=0; i<num_pnts; i++)
-	  pos_array[i].set_x(vec_list.get()->x());
-	  pos_array[i].set_y(vec_list.get()->y());
-	  pos_array[i].set_z(vec_list.get()->z());
-	  vec_list.step();
+  // Fill the vector_list of points
+  vec_list.reset();
+  for( i=0; i<num_pnts; i++)
+    pos_array[i].set_x(vec_list.get()->x());
+    pos_array[i].set_y(vec_list.get()->y());
+    pos_array[i].set_z(vec_list.get()->z());
+    vec_list.step();
-      outcome result = api_curve_spline(num_pnts, pos_array, NULL, NULL, new_EDGE_ptr);
-      if( !result.ok() || new_EDGE_ptr == NULL )
-	  get_acis_query_engine()->ACIS_API_error(result);
-	  PRINT_ERROR( "unable to make spline from list of positions\n" );
-	  return NULL;
+  outcome result = api_curve_spline(num_pnts, pos_array, NULL, NULL, new_EDGE_ptr);
+  if( !result.ok() || new_EDGE_ptr == NULL )
+    get_acis_query_engine()->ACIS_API_error(result);
+    PRINT_ERROR( "unable to make spline from list of positions\n" );
+    return NULL;
-      return new_EDGE_ptr;
+  return new_EDGE_ptr;
-  // Purpose       : Reverse the ACIS BODY
-  // Special Notes : Moved from BodyACIS - j.k, 2004-5-25
-  // Creator       : Tim Tautges
-  // Creation Date : 3/18/97
-  CubitStatus AcisModifyEngine::reverse_body( BodySM* body_to_reverse )
-      BODY* body_ptr = AcisQueryEngine::get_BODY( body_to_reverse );
-      if (!body_ptr)
+// Purpose       : Reverse the ACIS BODY
+// Special Notes : Moved from BodyACIS - j.k, 2004-5-25
+// Creator       : Tim Tautges
+// Creation Date : 3/18/97
+CubitStatus AcisModifyEngine::reverse_body( BodySM* body_to_reverse )
+  BODY* body_ptr = AcisQueryEngine::get_BODY( body_to_reverse );
+  if (!body_ptr)
-      outcome result = api_reverse_body( body_ptr );
-      if (!result.ok())
-	  AcisQueryEngine::instance()->ACIS_API_error( result, "reversing BODY." );
+  outcome result = api_reverse_body( body_ptr );
+  if (!result.ok())
+    AcisQueryEngine::instance()->ACIS_API_error( result, "reversing BODY." );
-  void AcisModifyEngine::webcut_cleanup( DLIList<BodySM*>& body_list,
+void AcisModifyEngine::webcut_cleanup( DLIList<BodySM*>& body_list,
                                          ENTITY_LIST& BODY_list) const
-      // This procedure is called by webcut_handler and gets rid of
-      // all the Body's and Acis BODY's created during the execution
-      // of the webcut command. The command was unsuccessful and hence,
-      // these entities need to be removed so the system can be returned
-      // to its state before the command was invoked.
+     // This procedure is called by webcut_handler and gets rid of
+     // all the Body's and Acis BODY's created during the execution
+     // of the webcut command. The command was unsuccessful and hence,
+     // these entities need to be removed so the system can be returned
+     // to its state before the command was invoked.
-      // Delete the Bodies
-      AcisQueryEngine::instance()->delete_solid_model_entities(body_list);
-      //GeometryQueryTool::instance()->delete_Body(body_list, CUBIT_TRUE);
+     // Delete the Bodies
+   AcisQueryEngine::instance()->delete_solid_model_entities(body_list);
+   //GeometryQueryTool::instance()->delete_Body(body_list, CUBIT_TRUE);
-      // Delete the Acis BODYs
-      AcisQueryEngine::instance()->delete_ACIS_BODY(BODY_list);
+     // Delete the Acis BODYs
+   AcisQueryEngine::instance()->delete_ACIS_BODY(BODY_list);
-      return;
+   return;
-  void AcisModifyEngine::webcut_imprint(
-					BODY* cutting_tool_BODY_ptr,
-					DLIList<BodySM*> &old_body_list,
-					DLIList<BODY*>& new_webcut_BODY_list,
-					DLIList<BODY*>& just_webcut_BODY_list,
-					DLIList<BodySM*> &imprinted_Body_from_Model_list,
-					DLIList<BODY*> &imprinted_BODY_from_Model_list) const
-      // This procedure takes care of the imprint operations that are required
-      // by the webcut operation. Each of the BODYs in the new_webcut_BODY_list
-      // is tested against every other BODY in the model as well as every other
-      // BODY in the same list for interference. If interference exists, then
-      // the BODYs are imprinted with each other and new (corresponding) Bodies
-      // are created. Pointers to these new Bodies are inserted into the list,
-      // new_webcut_body_list.
+void AcisModifyEngine::webcut_imprint(
+    BODY* cutting_tool_BODY_ptr,
+    DLIList<BodySM*> &old_body_list,
+    DLIList<BODY*>& new_webcut_BODY_list,
+    DLIList<BODY*>& just_webcut_BODY_list,
+    DLIList<BodySM*> &imprinted_Body_from_Model_list,
+    DLIList<BODY*> &imprinted_BODY_from_Model_list) const
+     // This procedure takes care of the imprint operations that are required
+     // by the webcut operation. Each of the BODYs in the new_webcut_BODY_list
+     // is tested against every other BODY in the model as well as every other
+     // BODY in the same list for interference. If interference exists, then
+     // the BODYs are imprinted with each other and new (corresponding) Bodies
+     // are created. Pointers to these new Bodies are inserted into the list,
+     // new_webcut_body_list.
-      // MJP Note:
-      // Note that this procedure takes care of imprinting the existing Bodies
-      // (i.e., the ones in the model) and creating new Bodies when necessary
-      // to replace these. However, new Body's are *not* created from the list
-      // of ACIS BODYs in the input list, new_webcut_BODY_list. These are simply
-      // returned to the calling routine, where it is expected that new Bodies
-      // will be created, as required.
+     // MJP Note:
+     // Note that this procedure takes care of imprinting the existing Bodies
+     // (i.e., the ones in the model) and creating new Bodies when necessary
+     // to replace these. However, new Body's are *not* created from the list
+     // of ACIS BODYs in the input list, new_webcut_BODY_list. These are simply
+     // returned to the calling routine, where it is expected that new Bodies
+     // will be created, as required.
-      int webcut_debug_flag = 18;
-      int webcut_debug_flag_on = DEBUG_FLAG(webcut_debug_flag);
+   int webcut_debug_flag = 18;
+   int webcut_debug_flag_on = DEBUG_FLAG(webcut_debug_flag);
-      int i = 0;
-      int j = 0;
+   int i = 0;
+   int j = 0;
-      // Make copies of the input BODYs
-      DLIList<BODY*> copy_new_webcut_BODY_list ;
-      DLIList<BODY*> new_results_BODYS;
-      new_webcut_BODY_list.reset() ;
-      for (i = 0; i < new_webcut_BODY_list.size() ; i++)
-	  BODY* old_BODY = new_webcut_BODY_list.get_and_step() ;
-	  BODY* new_BODY = this->copy_BODY(old_BODY,
-					   GeometryModifyTool::instance()->get_new_ids()) ;
+     // Make copies of the input BODYs
+   DLIList<BODY*> copy_new_webcut_BODY_list ;
+   DLIList<BODY*> new_results_BODYS;
+   new_webcut_BODY_list.reset() ;
+   for (i = 0; i < new_webcut_BODY_list.size() ; i++)
+      BODY* old_BODY = new_webcut_BODY_list.get_and_step() ;
+      BODY* new_BODY = this->copy_BODY(old_BODY,
+                                       GeometryModifyTool::instance()->get_new_ids()) ;
-	  // Make sure the the new BODY is a valid BODY
-	  assert( new_BODY != NULL) ;
+        // Make sure the the new BODY is a valid BODY
+      assert( new_BODY != NULL) ;
-	  // Add the new BODY to the backup list
-	  copy_new_webcut_BODY_list.append(new_BODY) ;
+        // Add the new BODY to the backup list
+      copy_new_webcut_BODY_list.append(new_BODY) ;
-      // Loop over each of the new BODYs and imprint it with any other new BODY
-      // that touches it.
-      BODY* first_BODY_ptr = NULL;
-      BODY* second_BODY_ptr = NULL;
-      copy_new_webcut_BODY_list.reset() ;
-      for (i = 0; i < (copy_new_webcut_BODY_list.size() - 1); i++)
-	  // Get the first BODY
-	  first_BODY_ptr = copy_new_webcut_BODY_list.get_and_step();
+     // Loop over each of the new BODYs and imprint it with any other new BODY
+     // that touches it.
+   BODY* first_BODY_ptr = NULL;
+   BODY* second_BODY_ptr = NULL;
+   copy_new_webcut_BODY_list.reset() ;
+   for (i = 0; i < (copy_new_webcut_BODY_list.size() - 1); i++)
+        // Get the first BODY
+      first_BODY_ptr = copy_new_webcut_BODY_list.get_and_step();
-	  for (j = (i + 1); j < copy_new_webcut_BODY_list.size(); j++)
-	      // Get the second BODY
-	      second_BODY_ptr = copy_new_webcut_BODY_list.get_and_step();
+      for (j = (i + 1); j < copy_new_webcut_BODY_list.size(); j++)
+           // Get the second BODY
+         second_BODY_ptr = copy_new_webcut_BODY_list.get_and_step();
-	      // If these BODYs touch, then imprint them
-	      CubitBoolean result_interfer =
-		BODYs_interfering( first_BODY_ptr,second_BODY_ptr );
+           // If these BODYs touch, then imprint them
+         CubitBoolean result_interfer =
+             BODYs_interfering( first_BODY_ptr,second_BODY_ptr );
-	      if ( result_interfer == CUBIT_TRUE )
-		  CubitStatus resultImprint =
-		    imprint_BODYs( first_BODY_ptr, second_BODY_ptr );
+         if ( result_interfer == CUBIT_TRUE )
+            CubitStatus resultImprint =
+                imprint_BODYs( first_BODY_ptr, second_BODY_ptr );
-		  if( resultImprint == CUBIT_FAILURE )
-		      PRINT_WARNING ("Imprint operation failed.\n"
-				     "         Going back to the previous state");
+            if( resultImprint == CUBIT_FAILURE )
+               PRINT_WARNING ("Imprint operation failed.\n"
+                              "         Going back to the previous state");
-		      // Delete the new BODYs and return.
-		      for (int k = 0 ; k < copy_new_webcut_BODY_list.size() ; k++)
-			  first_BODY_ptr = copy_new_webcut_BODY_list.get_and_step() ;
-			  AcisQueryEngine::instance()->delete_ACIS_BODY(first_BODY_ptr) ;
-		      return ;
+                 // Delete the new BODYs and return.
+               for (int k = 0 ; k < copy_new_webcut_BODY_list.size() ; k++)
+                  first_BODY_ptr = copy_new_webcut_BODY_list.get_and_step() ;
+                  AcisQueryEngine::instance()->delete_ACIS_BODY(first_BODY_ptr) ;
+               return ;
-	  // Go to the (i+1)th element of the list
-	  copy_new_webcut_BODY_list.step(i+1) ;
+        // Go to the (i+1)th element of the list
+      copy_new_webcut_BODY_list.step(i+1) ;
-	CDE-- commented out this code.  For now, we've decided that when webcutting
-	with the 'imprint' option, the imprint should occur between bodies involved
-	in the webcut.  This code was imprinting all resulting pieces of the webcut
-	with all the other Bodies in the model.
+  CDE-- commented out this code.  For now, we've decided that when webcutting
+  with the 'imprint' option, the imprint should occur between bodies involved
+  in the webcut.  This code was imprinting all resulting pieces of the webcut
+  with all the other Bodies in the model.
-	// Get the Bodys in the Model
-	DLIList<Body*> Body_in_Model_list_tmp;
-	GeometryQueryTool::instance()->bodies(Body_in_Model_list_tmp);
-	DLIList<BodySM*> Body_in_Model_list;
-	Body_in_Model_list_tmp.reset();
-	for (i = Body_in_Model_list_tmp.size(); i--; )
-	Body_in_Model_list.append( Body_in_Model_list_tmp.get_and_step()->get_body_sm_ptr());
+     // Get the Bodys in the Model
+   DLIList<Body*> Body_in_Model_list_tmp;
+   GeometryQueryTool::instance()->bodies(Body_in_Model_list_tmp);
+   DLIList<BodySM*> Body_in_Model_list;
+   Body_in_Model_list_tmp.reset();
+   for (i = Body_in_Model_list_tmp.size(); i--; )
+    Body_in_Model_list.append( Body_in_Model_list_tmp.get_and_step()->get_body_sm_ptr());
-	// Loop over each of the new BODYs and imprint it with any of the
-	// BODYs already existing in the model, if they touch.
+     // Loop over each of the new BODYs and imprint it with any of the
+     // BODYs already existing in the model, if they touch.
-	// List of new imprinted BODYs -- Bodies need to be created from these
-	DLIList<BODY*> copy_imprinted_BODY_from_Model_list;
+     // List of new imprinted BODYs -- Bodies need to be created from these
+   DLIList<BODY*> copy_imprinted_BODY_from_Model_list;
-	BodySM* model_Body_ptr = NULL;
-	BODY* model_BODY_ptr = NULL;
-	BODY* new_model_BODY_ptr = NULL;
-	BODY* new_BODY_ptr = NULL ;
-	int copy_made = CUBIT_FALSE;
+   BodySM* model_Body_ptr = NULL;
+   BODY* model_BODY_ptr = NULL;
+   BODY* new_model_BODY_ptr = NULL;
+   BODY* new_BODY_ptr = NULL ;
+   int copy_made = CUBIT_FALSE;
-	Body_in_Model_list.reset();
-	// Loop over all the existing Bodies
-	for (i = 0; i < Body_in_Model_list.size(); i++)
+   Body_in_Model_list.reset();
+     // Loop over all the existing Bodies
+   for (i = 0; i < Body_in_Model_list.size(); i++)
         // Get this existing Body's parent ACIS BODY
-	model_Body_ptr = Body_in_Model_list.get_and_step() ;
-	model_BODY_ptr = AcisQueryEngine::get_BODY(model_Body_ptr) ;
+      model_Body_ptr = Body_in_Model_list.get_and_step() ;
+      model_BODY_ptr = AcisQueryEngine::get_BODY(model_Body_ptr) ;
         // Make sure that model_BODY_ptr is not the Cutting Tool as the
         // user is allowed to use an existing Body as a Cutting Tool.
         // If this is the case, then don't involve it in the imprint
         // operations.
-	if (model_BODY_ptr == cutting_tool_BODY_ptr || old_body_list.move_to(model_Body_ptr))
-	// Don't do anything
-	continue;
+      if (model_BODY_ptr == cutting_tool_BODY_ptr || old_body_list.move_to(model_Body_ptr))
+           // Don't do anything
+         continue;
         // Loop over all the newly created (by webcutting) ACIS BODYs and test
         // the existing Body against them (for imprinting purposes, if there
         // is interference)
-	copy_made = CUBIT_FALSE;
-	new_model_BODY_ptr = NULL;
-	copy_new_webcut_BODY_list.reset();
+      copy_made = CUBIT_FALSE;
+      new_model_BODY_ptr = NULL;
+      copy_new_webcut_BODY_list.reset();
-	for (j = 0; j < copy_new_webcut_BODY_list.size(); j++)
-	// Get the BODY that we're going to test the existing Body against
-	new_BODY_ptr = copy_new_webcut_BODY_list.get_and_step() ;
+      for (j = 0; j < copy_new_webcut_BODY_list.size(); j++)
+           // Get the BODY that we're going to test the existing Body against
+         new_BODY_ptr = copy_new_webcut_BODY_list.get_and_step() ;
-	// DEBUG stuff
-	if (webcut_debug_flag_on)
-	//Save the two BODYs
-	AcisQueryEngine::instance()->save_ENTITY_as_sat_file(new_BODY_ptr, "BODY1.sat", "w");
-	AcisQueryEngine::instance()->save_ENTITY_as_sat_file(model_BODY_ptr, "BODY2.sat", "w");
+           // DEBUG stuff
+         if (webcut_debug_flag_on)
+              //Save the two BODYs
+            AcisQueryEngine::instance()->save_ENTITY_as_sat_file(new_BODY_ptr, "BODY1.sat", "w");
+            AcisQueryEngine::instance()->save_ENTITY_as_sat_file(model_BODY_ptr, "BODY2.sat", "w");
-	// If these BODYs touch, then ...
-	if ( BODYs_interfering(new_BODY_ptr, model_BODY_ptr) == CUBIT_TRUE )
-	// DEBUG stuff
-	"BODY1_after_test.sat",
-	"w");
-	AcisQueryEngine::instance()->save_ENTITY_as_sat_file(new_model_BODY_ptr,
-	"BODY2_after_test.sat",
-	"w");
+           // If these BODYs touch, then ...
+         if ( BODYs_interfering(new_BODY_ptr, model_BODY_ptr) == CUBIT_TRUE )
+              // DEBUG stuff
+                                             "BODY1_after_test.sat",
+                                             "w");
+               AcisQueryEngine::instance()->save_ENTITY_as_sat_file(new_model_BODY_ptr,
+                                             "BODY2_after_test.sat",
+                                             "w");
-	// Because of the fact that the RefEntity datastructure is
-	// nonmanifold and hence shares underlying ACIS ENTITYs, I have to:
-	//   a) make a copy of the parent ACIS BODY of the Body being
-	//      deactivated (this is done only once for the inner loop)
-	//   b) then all imprinting is done with this copy instead of
-	//     with the original parent ACIS BODY.
-	// deactivateRefStructure takes care of detaching the RefEntities
-	// and their associated ACIS ENTITYs (removing the double links
-	// between them).
-	if (!copy_made) // Make this copy at most once per outer loop iteration
-	// Make a copy of the parent ACIS BODY.
-	new_model_BODY_ptr = this->copy_BODY(model_BODY_ptr,
+              // Because of the fact that the RefEntity datastructure is
+              // nonmanifold and hence shares underlying ACIS ENTITYs, I have to:
+              //   a) make a copy of the parent ACIS BODY of the Body being
+              //      deactivated (this is done only once for the inner loop)
+              //   b) then all imprinting is done with this copy instead of
+              //     with the original parent ACIS BODY.
+              // deactivateRefStructure takes care of detaching the RefEntities
+              // and their associated ACIS ENTITYs (removing the double links
+              // between them).
+            if (!copy_made) // Make this copy at most once per outer loop iteration
+                 // Make a copy of the parent ACIS BODY.
+               new_model_BODY_ptr = this->copy_BODY(model_BODY_ptr,
-	// Make sure a valid copy was made. If not, then we need to exit
-	// this loop (i.e., stop testing this Body for imprinting
-	// and go on to the next one).
-	if (new_model_BODY_ptr == NULL)
-	PRINT_ERROR("Cannot test imprinting for volume.\n" );
-	break;
-	else
-	copy_made = CUBIT_TRUE;
-	if ( results_list.move_to(model_Body_ptr) )
-	new_results_BODYS.append( new_model_BODY_ptr );
-	imprinted_Body_from_Model_list.append(model_Body_ptr) ;
-	imprinted_BODY_from_Model_list.append(model_BODY_ptr) ;
-	copy_imprinted_BODY_from_Model_list.append(new_model_BODY_ptr) ;
+                 // Make sure a valid copy was made. If not, then we need to exit
+                 // this loop (i.e., stop testing this Body for imprinting
+                 // and go on to the next one).
+               if (new_model_BODY_ptr == NULL)
+                  PRINT_ERROR("Cannot test imprinting for volume.\n" );
+                  break;
+               else
+                  copy_made = CUBIT_TRUE;
+                  if ( results_list.move_to(model_Body_ptr) )
+                    new_results_BODYS.append( new_model_BODY_ptr );
+                  imprinted_Body_from_Model_list.append(model_Body_ptr) ;
+                  imprinted_BODY_from_Model_list.append(model_BODY_ptr) ;
+                  copy_imprinted_BODY_from_Model_list.append(new_model_BODY_ptr) ;
-	// Imprint the BODYs (use the new copied BODY). If the imprint
-	// operation fails, the state of these BODYs is left unchanged.
-	if (imprint_BODYs(new_BODY_ptr, new_model_BODY_ptr) ==  CUBIT_SUCCESS )
-	// DEBUG stuff, if the imprint operation succeeded.
-	"BODY1_after_imprint.sat",
-	"w");
-	"BODY2_after_imprint.sat",
-	"w");
+              // Imprint the BODYs (use the new copied BODY). If the imprint
+              // operation fails, the state of these BODYs is left unchanged.
+            if (imprint_BODYs(new_BODY_ptr, new_model_BODY_ptr) ==  CUBIT_SUCCESS )
+                 // DEBUG stuff, if the imprint operation succeeded.
+                                                "BODY1_after_imprint.sat",
+                                                "w");
+                                                "BODY2_after_imprint.sat",
+                                                "w");
-	else
+            else
-	int k;
-	for (k = 0 ; k < copy_new_webcut_BODY_list.size() ; k++)
+               int k;
+               for (k = 0 ; k < copy_new_webcut_BODY_list.size() ; k++)
-	copy_imprinted_BODY_from_Model_list.reset() ;
-	for (k = 0 ; k < copy_imprinted_BODY_from_Model_list.size() ; k++)
-	new_model_BODY_ptr = copy_imprinted_BODY_from_Model_list.get_and_step() ;
-	AcisQueryEngine::instance()->delete_ACIS_BODY(new_model_BODY_ptr) ;
+               copy_imprinted_BODY_from_Model_list.reset() ;
+               for (k = 0 ; k < copy_imprinted_BODY_from_Model_list.size() ; k++)
+                  new_model_BODY_ptr = copy_imprinted_BODY_from_Model_list.get_and_step() ;
+                  AcisQueryEngine::instance()->delete_ACIS_BODY(new_model_BODY_ptr) ;
-	return ;
-	} // Loop over the new (webcut) BODYs
+               return ;
+      } // Loop over the new (webcut) BODYs
-	} // Loop over the existing Bodies in Model
-      // Now that we have come so far successfully, create the final list
-      // of new BODYs that will be used to create VGI Bodys.
-      new_webcut_BODY_list.clean_out() ;
+   } // Loop over the existing Bodies in Model
+     // Now that we have come so far successfully, create the final list
+     // of new BODYs that will be used to create VGI Bodys.
+   new_webcut_BODY_list.clean_out() ;
-      // First the BODYs that were copies of the webcut BODYs
-      for (i = 0 ; i < copy_new_webcut_BODY_list.size() ; i++)
-	  new_webcut_BODY_list.append(new_BODY_ptr) ;
-      just_webcut_BODY_list = new_webcut_BODY_list;
+     // First the BODYs that were copies of the webcut BODYs
+   for (i = 0 ; i < copy_new_webcut_BODY_list.size() ; i++)
+      new_webcut_BODY_list.append(new_BODY_ptr) ;
+   just_webcut_BODY_list = new_webcut_BODY_list;
-      // Then the BODYs that were copies of Model BODYs
-      for (i = 0 ; i < copy_imprinted_BODY_from_Model_list.size() ; i++)
+     // Then the BODYs that were copies of Model BODYs
+   for (i = 0 ; i < copy_imprinted_BODY_from_Model_list.size() ; i++)
       new_BODY_ptr = copy_imprinted_BODY_from_Model_list.get_and_step() ;
-      // now, two important lists:
-      // a) just_webcut_BODY_list: bodies in original bodies-to-be-webcut list
-      //        that were modified, either by webcut or by imprint
-      // b) new_webcut_BODY_list: all bodies modified by webcut or imprint,
-      //        including model bodies affected by imprint
+     // now, two important lists:
+     // a) just_webcut_BODY_list: bodies in original bodies-to-be-webcut list
+     //        that were modified, either by webcut or by imprint
+     // b) new_webcut_BODY_list: all bodies modified by webcut or imprint,
+     //        including model bodies affected by imprint
-      return;
+   return;
-  BODY* AcisModifyEngine::create_infinite_plane_cutting_tool(
-							     const CubitVector &input_p1,
-							     const CubitVector &input_p2,
-							     const CubitVector &input_p3,
-							     const SPAbox& box_to_cut,
-							     bool just_face ) const
-      // Create a plane from the vertices
-      // Note:  The old infinite plane code always swept in the opposite direction
-      //        from the normal of the passed in points, so we create the plane with
-      //        the points in opposite order.
-      CubitPlane p;
-      p.mk_plane_with_points(input_p3, input_p2, input_p1);
+BODY* AcisModifyEngine::create_infinite_plane_cutting_tool(
+    const CubitVector &input_p1,
+    const CubitVector &input_p2,
+    const CubitVector &input_p3,
+    const SPAbox& box_to_cut,
+    bool just_face ) const
+    // Create a plane from the vertices
+    // Note:  The old infinite plane code always swept in the opposite direction
+    //        from the normal of the passed in points, so we create the plane with
+    //        the points in opposite order.
+  CubitPlane p;
+  p.mk_plane_with_points(input_p3, input_p2, input_p1);
-      // Convert it to an ACIS plane
-      SPAunit_vector plane_normal(p.normal().x(),
-				  p.normal().y(),
-				  p.normal().z());
+    // Convert it to an ACIS plane
+  SPAunit_vector plane_normal(p.normal().x(),
+                           p.normal().y(),
+                           p.normal().z());
-      plane the_plane(SPAposition(input_p1.x(),
-				  input_p1.y(),
-				  input_p1.z()),
-		      plane_normal);
+  plane the_plane(SPAposition(input_p1.x(),
+                           input_p1.y(),
+                           input_p1.z()),
+                  plane_normal);
-      if (DEBUG_FLAG(18))
-	PRINT_DEBUG_18(
-		       "plane created with root point (%g %g %g) and\n"
-		       "  normal (%g %g %g).\n",
-		       input_p1.x(),
-		       input_p1.y(),
-		       input_p1.z(),
-		       plane_normal.x(),
-		       plane_normal.y(),
-		       plane_normal.z());
+  if (DEBUG_FLAG(18))
+    PRINT_DEBUG_18(
+                "plane created with root point (%g %g %g) and\n"
+                "  normal (%g %g %g).\n",
+                input_p1.x(),
+                input_p1.y(),
+                input_p1.z(),
+                plane_normal.x(),
+                plane_normal.y(),
+                plane_normal.z());
-      // Need to declare this up here so that it is outside of the API block
-      BODY* infinite_plane_BODY = NULL;
-      API_BEGIN;
+    // Need to declare this up here so that it is outside of the API block
+  BODY* infinite_plane_BODY = NULL;
+  API_BEGIN;
-      // Make a PLANE from it
-      PLANE* the_PLANE = new PLANE(the_plane);
+    // Make a PLANE from it
+  PLANE* the_PLANE = new PLANE(the_plane);
-      // Make a FACE out of it
-      FACE* planar_FACE = new FACE(NULL, NULL, the_PLANE, FORWARD);
+    // Make a FACE out of it
+  FACE* planar_FACE = new FACE(NULL, NULL, the_PLANE, FORWARD);
-      // Get the midpoint and diagonal length of the
-      // SPAbox this needs to fit around.  Make diag length a little
-      // bigger than necessary as a buffer.
-      SPAposition midpoint = box_to_cut.mid();
-      double diag_length = 1.01 * (box_to_cut.high() - midpoint).len();
+    // Get the midpoint and diagonal length of the
+    // SPAbox this needs to fit around.  Make diag length a little
+    // bigger than necessary as a buffer.
+  SPAposition midpoint = box_to_cut.mid();
+  double diag_length = 1.01 * (box_to_cut.high() - midpoint).len();
-      // Get the point on the plane that the SPAbox midpoint projects to.
-      ENTITY_LIST temp_list;
-      double distance;
-      double *dist_ptr = &distance;
-      ENTITY* entity_ptr = planar_FACE;
-      // Test points behind plane
-      result = api_ray_test_ents(midpoint, plane_normal, 1, 1, 1, &entity_ptr,
-				 temp_list, dist_ptr);
-      if (!result.ok())
-	  AcisQueryEngine::instance()->ACIS_API_error(result);
-      if (temp_list.count() < 1)
-	  // Test points in front of plane, if needed
-	  result = api_ray_test_ents(midpoint, -plane_normal, 1, 1, 1, &entity_ptr,
-	  if (!result.ok())
-	  // Indicate that the distance is in front of the plane
-	  distance = -distance;
+    // Get the point on the plane that the SPAbox midpoint projects to.
+  ENTITY_LIST temp_list;
+  double distance;
+  double *dist_ptr = &distance;
+  ENTITY* entity_ptr = planar_FACE;
+    // Test points behind plane
+  result = api_ray_test_ents(midpoint, plane_normal, 1, 1, 1, &entity_ptr,
+                             temp_list, dist_ptr);
+  if (!result.ok())
+    AcisQueryEngine::instance()->ACIS_API_error(result);
+  if (temp_list.count() < 1)
+      // Test points in front of plane, if needed
+    result = api_ray_test_ents(midpoint, -plane_normal, 1, 1, 1, &entity_ptr,
+    if (!result.ok())
+      // Indicate that the distance is in front of the plane
+    distance = -distance;
-	  PRINT_DEBUG_18(
-			 "Midpoint before moving it: %g, %g, %g.\n",
-			 midpoint.x(), midpoint.y(), midpoint.z());
+    PRINT_DEBUG_18(
+                "Midpoint before moving it: %g, %g, %g.\n",
+                midpoint.x(), midpoint.y(), midpoint.z());
-      // Move midpoint from SPAbox to plane
-      midpoint += distance * plane_normal;
+    // Move midpoint from SPAbox to plane
+  midpoint += distance * plane_normal;
-	  PRINT_DEBUG_18(
-			 "just_face = %d.\n"
-			 "The center of the box was %s the plane.\n",
-			 just_face,
-			 distance >= 0 ? "behind" : "in front of");
-	  PRINT_DEBUG_18(
-			 "Distance to center of box was determined to be %g.\n",
-			 distance);
-	  PRINT_DEBUG_18( "Mapped point is %g, %g, %g.\n",
+    PRINT_DEBUG_18(
+                "just_face = %d.\n"
+                "The center of the box was %s the plane.\n",
+                just_face,
+                distance >= 0 ? "behind" : "in front of");
+    PRINT_DEBUG_18(
+                "Distance to center of box was determined to be %g.\n",
+                distance);
+    PRINT_DEBUG_18( "Mapped point is %g, %g, %g.\n",
-      // Get 4 points on the plane that form a square with sides of
-      // length 2*diag_length.
-      SPAvector in_plane_1 = diag_length * normalise(the_plane.u_deriv);
-      SPAvector in_plane_2 = plane_normal * in_plane_1;
-      SPAposition corners[4];
-      corners[0] = midpoint - in_plane_1 - in_plane_2;
-      corners[1] = midpoint + in_plane_1 - in_plane_2;
-      corners[2] = midpoint + in_plane_1 + in_plane_2;
-      corners[3] = midpoint - in_plane_1 + in_plane_2;
+    // Get 4 points on the plane that form a square with sides of
+    // length 2*diag_length.
+  SPAvector in_plane_1 = diag_length * normalise(the_plane.u_deriv);
+  SPAvector in_plane_2 = plane_normal * in_plane_1;
+  SPAposition corners[4];
+  corners[0] = midpoint - in_plane_1 - in_plane_2;
+  corners[1] = midpoint + in_plane_1 - in_plane_2;
+  corners[2] = midpoint + in_plane_1 + in_plane_2;
+  corners[3] = midpoint - in_plane_1 + in_plane_2;
+      // Uncomment this if you want to see the plane before it's swept
+//     GfxDebug::draw_line(
+//       corners[0].x(), corners[0].y(), corners[0].z(),
+//       corners[1].x(), corners[1].y(), corners[1].z(), CUBIT_RED);
+//       corners[2].x(), corners[2].y(), corners[2].z(), CUBIT_GREEN);
+//       corners[3].x(), corners[3].y(), corners[3].z(), CUBIT_BLUE);
+//       corners[0].x(), corners[0].y(), corners[0].z(), CUBIT_CYAN);
+//       midpoint.x(), midpoint.y(), midpoint.z(),
+//       midpoint.x()+plane_normal.x(),
+//       midpoint.y()+plane_normal.y(),
+//       midpoint.z()+plane_normal.z(), CUBIT_BLUE);
+//     GfxDebug::flush();
+    PRINT_DEBUG_18( "Diag length is %g.\n"
+                "Got four corners: (%g %g %g)\n"
+                "                  (%g %g %g).\n"
+                "                  (%g %g %g).\n"
+                "                  (%g %g %g).\n",
+                diag_length,
+                corners[0].x(), corners[0].y(), corners[0].z(),
+                corners[1].x(), corners[1].y(), corners[1].z(),
+                corners[2].x(), corners[2].y(), corners[2].z(),
+                corners[3].x(), corners[3].y(), corners[3].z());
+    // Make some geometry and topology from the corners
+  STRAIGHT* S[4];
+  S[0] = new STRAIGHT(corners[0], normalise(in_plane_1));
+  S[1] = new STRAIGHT(corners[1], normalise(in_plane_2));
+  S[2] = new STRAIGHT(corners[2], normalise(-in_plane_1));
+  S[3] = new STRAIGHT(corners[3], normalise(-in_plane_2));
+  APOINT* P[4];
+  VERTEX* V[4];
+  EDGE*   E[4];
+  COEDGE* CE[4];
+  int i;
+  for ( i = 0; i < 4; i++)
+    P[i] = new APOINT (corners[i]);
+    V[i] = new VERTEX (P[i]);
+  CE[0] = NULL;
+  for (i = 0; i < 4; i++)
+    E[i] = new EDGE(V[i], V[(i+ 1)%4], S[i], FORWARD);
+    CE[i] = new COEDGE(E[i], FORWARD,
+                       i == 0 ? NULL : CE[i-1],
+                       i == 3 ? CE[0] : NULL);
+  LOOP* LOOP1 = new LOOP (CE[0], NULL);
+  FACE* FACE1 = new FACE (LOOP1, NULL, the_PLANE, FORWARD);
+  SHELL* SHELL1 = new SHELL(FACE1, NULL, NULL);
+  LUMP* LUMP1 = new LUMP(SHELL1, NULL);
+  infinite_plane_BODY = new BODY(LUMP1);
+    // At this point we are done with planar_FACE.  It has been replaced by
+    // a FACE that is bounded by a LOOPm FACE1.
+  planar_FACE->lose();
+    // Let's make sure everything went as planned.
+  if (infinite_plane_BODY != NULL)
+    result = api_body_to_2d(infinite_plane_BODY);
+    if (!result.ok() || infinite_plane_BODY == NULL)
+      PRINT_ERROR("Unable to create infinite plane.\n");
+      infinite_plane_BODY = NULL;
+      // Just leave it as a 2D body if we are creating a sheet, or
+      // if the plane never intersects the input box_to_cut.
+    else if (!just_face && distance < diag_length && distance > -diag_length)
+        // Now sweep the FACE to make a 3D body
       if (DEBUG_FLAG(18))
-	  // Uncomment this if you want to see the plane before it's swept
-	  //     GfxDebug::draw_line(
-	  //       corners[0].x(), corners[0].y(), corners[0].z(),
-	  //       corners[1].x(), corners[1].y(), corners[1].z(), CUBIT_RED);
-	  //       corners[2].x(), corners[2].y(), corners[2].z(), CUBIT_GREEN);
-	  //       corners[3].x(), corners[3].y(), corners[3].z(), CUBIT_BLUE);
-	  //       corners[0].x(), corners[0].y(), corners[0].z(), CUBIT_CYAN);
-	  //       midpoint.x(), midpoint.y(), midpoint.z(),
-	  //       midpoint.x()+plane_normal.x(),
-	  //       midpoint.y()+plane_normal.y(),
-	  //       midpoint.z()+plane_normal.z(), CUBIT_BLUE);
-	  //     GfxDebug::flush();
+        PRINT_DEBUG_18(
+                    "Sweeping (%g %g %g).\n",
+                    ((diag_length-distance)*plane_normal).x(),
+                    ((diag_length-distance)*plane_normal).y(),
+                    ((diag_length-distance)*plane_normal).z());
-	  PRINT_DEBUG_18( "Diag length is %g.\n"
-			  "Got four corners: (%g %g %g)\n"
-			  "                  (%g %g %g).\n"
-			  "                  (%g %g %g).\n"
-			  "                  (%g %g %g).\n",
-			  diag_length,
-			  corners[0].x(), corners[0].y(), corners[0].z(),
-			  corners[1].x(), corners[1].y(), corners[1].z(),
-			  corners[2].x(), corners[2].y(), corners[2].z(),
-			  corners[3].x(), corners[3].y(), corners[3].z());
-      // Make some geometry and topology from the corners
-      STRAIGHT* S[4];
-      S[0] = new STRAIGHT(corners[0], normalise(in_plane_1));
-      S[1] = new STRAIGHT(corners[1], normalise(in_plane_2));
-      S[2] = new STRAIGHT(corners[2], normalise(-in_plane_1));
-      S[3] = new STRAIGHT(corners[3], normalise(-in_plane_2));
-      APOINT* P[4];
-      VERTEX* V[4];
-      EDGE*   E[4];
-      COEDGE* CE[4];
-      int i;
-      for ( i = 0; i < 4; i++)
-	  P[i] = new APOINT (corners[i]);
-	  V[i] = new VERTEX (P[i]);
-      CE[0] = NULL;
-      for (i = 0; i < 4; i++)
-	  E[i] = new EDGE(V[i], V[(i+ 1)%4], S[i], FORWARD);
-	  CE[i] = new COEDGE(E[i], FORWARD,
-			     i == 0 ? NULL : CE[i-1],
-			     i == 3 ? CE[0] : NULL);
-      LOOP* LOOP1 = new LOOP (CE[0], NULL);
-      FACE* FACE1 = new FACE (LOOP1, NULL, the_PLANE, FORWARD);
-      SHELL* SHELL1 = new SHELL(FACE1, NULL, NULL);
-      LUMP* LUMP1 = new LUMP(SHELL1, NULL);
-      infinite_plane_BODY = new BODY(LUMP1);
-      // At this point we are done with planar_FACE.  It has been replaced by
-      // a FACE that is bounded by a LOOPm FACE1.
-      planar_FACE->lose();
-      // Let's make sure everything went as planned.
-      if (infinite_plane_BODY != NULL)
-	  result = api_body_to_2d(infinite_plane_BODY);
-	  if (!result.ok() || infinite_plane_BODY == NULL)
-	      PRINT_ERROR("Unable to create infinite plane.\n");
-	      infinite_plane_BODY = NULL;
-	  // Just leave it as a 2D body if we are creating a sheet, or
-	  // if the plane never intersects the input box_to_cut.
-	  else if (!just_face && distance < diag_length && distance > -diag_length)
-	      // Now sweep the FACE to make a 3D body
-		PRINT_DEBUG_18(
-			       "Sweeping (%g %g %g).\n",
-			       ((diag_length-distance)*plane_normal).x(),
-			       ((diag_length-distance)*plane_normal).y(),
-			       ((diag_length-distance)*plane_normal).z());
+        // A negative distance means that it was in front of the plane, so
+        // we need to sweep extra distance.  A positive distance means behind the
+        // plane, so we don't need to sweep as far.
+      sweep_options sweep_ops;
+      logical ACIS_primary_side = true;
+      sweep_ops.set_which_side(ACIS_primary_side);
+      result = api_sweep_with_options(FACE1,
+                                      (diag_length-distance)*plane_normal,
+                                      &sweep_ops,
+                                      infinite_plane_BODY);
+      if (!result.ok())
+        PRINT_ERROR("In GeometryModifyTool::create_infinite_plane_cutting_tool.\n"
+                    "       Problem sweeping the infinite plane.\n");
+    else if (DEBUG_FLAG(18))
+      PRINT_DEBUG_18( "Not sweeping the infinite plane.\n");
-	      // A negative distance means that it was in front of the plane, so
-	      // we need to sweep extra distance.  A positive distance means behind the
-	      // plane, so we don't need to sweep as far.
-	      sweep_options sweep_ops;
-	      logical ACIS_primary_side = true;
-	      sweep_ops.set_which_side(ACIS_primary_side);
-	      result = api_sweep_with_options(FACE1,
-					      (diag_length-distance)*plane_normal,
-					      &sweep_ops,
-					      infinite_plane_BODY);
-	      if (!result.ok())
-		  PRINT_ERROR("In GeometryModifyTool::create_infinite_plane_cutting_tool.\n"
-			      "       Problem sweeping the infinite plane.\n");
-	  else if (DEBUG_FLAG(18))
-	    PRINT_DEBUG_18( "Not sweeping the infinite plane.\n");
+  API_END;
-      API_END;
+  return infinite_plane_BODY;
-      return infinite_plane_BODY;
+// Function: create_solid_bodies_from_surfs
+// Description: This function assumes that the reffaces sent into
+// this function are either sheet bodies, or free surfaces.  This
+// Will have been taken care of in the calling function.  GT?
+// All the surfaces, in ACIS, will be turned into sheet bodies.  They
+// will be united, then the void enclosed.  The result will be healed
+// if the option is specified (default is to heal, from experience).
+// This function will not create new reffaces.
+CubitStatus AcisModifyEngine::create_solid_bodies_from_surfs( DLIList<Surface*> &ref_face_list,
+                                                      DLIList<BodySM*> &new_bodies,
+                                                      bool keep_old,
+                                                      bool heal ) const
+  int ii;
+  Surface* ref_face;
+  outcome rc;
+    //First sort the ref_face_list to sheet_bodies and free faces.
+  DLIList<BodySM*> body_list;
+  DLIList<Surface*> free_faces;
-  // Function: create_solid_bodies_from_surfs
-  // Description: This function assumes that the reffaces sent into
-  // this function are either sheet bodies, or free surfaces.  This
-  // Will have been taken care of in the calling function.  GT?
-  // All the surfaces, in ACIS, will be turned into sheet bodies.  They
-  // will be united, then the void enclosed.  The result will be healed
-  // if the option is specified (default is to heal, from experience).
-  // This function will not create new reffaces.
-  CubitStatus AcisModifyEngine::create_solid_bodies_from_surfs( DLIList<Surface*> &ref_face_list,
-								DLIList<BodySM*> &new_bodies,
-								bool keep_old,
-								bool heal ) const
-      int ii;
-      Surface* ref_face;
-      outcome rc;
-      //First sort the ref_face_list to sheet_bodies and free faces.
-      DLIList<BodySM*> body_list;
-      DLIList<Surface*> free_faces;
+  AcisQueryEngine* aqe = AcisQueryEngine::instance();
-      AcisQueryEngine* aqe = AcisQueryEngine::instance();
+  ref_face_list.reset();
+  for( ii = ref_face_list.size(); ii > 0; ii-- )
+    ref_face = ref_face_list.get_and_step();
+    FACE* FACE_ptr = aqe->get_FACE(ref_face);
+    BodySM* body_ptr = aqe->get_body_sm_of_ENTITY(FACE_ptr);
-      ref_face_list.reset();
-      for( ii = ref_face_list.size(); ii > 0; ii-- )
-	  ref_face = ref_face_list.get_and_step();
-	  FACE* FACE_ptr = aqe->get_FACE(ref_face);
-	  BodySM* body_ptr = aqe->get_body_sm_of_ENTITY(FACE_ptr);
+    if (body_ptr)
+      body_list.append_unique(body_ptr);
+    else
+      free_faces.append_unique(ref_face);
-	  if (body_ptr)
-	    body_list.append_unique(body_ptr);
-	  else
-	    free_faces.append_unique(ref_face);
+    //Now for all of the free_faces, create BODYS for them.
+  DLIList<BODY*> BODY_list, old_BODY_list;
+  for ( ii = free_faces.size(); ii > 0; ii-- )
+    ref_face = free_faces.get_and_step();
+    FACE *acis_FACE = AcisQueryEngine::get_FACE(ref_face);
+    if (!acis_FACE)
+      return CUBIT_FAILURE;
-      //Now for all of the free_faces, create BODYS for them.
-      DLIList<BODY*> BODY_list, old_BODY_list;
-      for ( ii = free_faces.size(); ii > 0; ii-- )
-	  ref_face = free_faces.get_and_step();
-	  FACE *acis_FACE = AcisQueryEngine::get_FACE(ref_face);
-	  if (!acis_FACE)
-	    return CUBIT_FAILURE;
+    FACE *face_list[1];
+    BODY *sheet_body;
+    face_list[0] = acis_FACE;
+    rc = api_sheet_from_ff(1, face_list, sheet_body);
+    if (!rc.ok())
+      PRINT_ERROR("Couldn't build a volume with Surface.\n") ;
+      for (int jj = BODY_list.size(); jj > 0; jj-- )
+        AcisQueryEngine::instance()->delete_ACIS_BODY(BODY_list.remove());
+      AcisQueryEngine::instance()->ACIS_API_error (rc);
+    rc = api_body_to_2d(sheet_body);
+    if (!rc.ok())
+      PRINT_ERROR("Couldn't build a volume with Surface.\n" );
+      // Make sure we were successful
+    if ( sheet_body->lump() == NULL ||
+         sheet_body->lump()->shell() == NULL ||
+         sheet_body->lump()->shell()->first_face() == NULL )
+    BODY_list.append(sheet_body);
+  BODY *first_BODY = NULL;
-	  FACE *face_list[1];
-	  BODY *sheet_body;
-	  face_list[0] = acis_FACE;
-	  rc = api_sheet_from_ff(1, face_list, sheet_body);
-	  if (!rc.ok())
-	      PRINT_ERROR("Couldn't build a volume with Surface.\n") ;
-	      for (int jj = BODY_list.size(); jj > 0; jj-- )
-		AcisQueryEngine::instance()->delete_ACIS_BODY(BODY_list.remove());
-	      AcisQueryEngine::instance()->ACIS_API_error (rc);
-	  rc = api_body_to_2d(sheet_body);
-	  if (!rc.ok())
-	      PRINT_ERROR("Couldn't build a volume with Surface.\n" );
-	  // Make sure we were successful
-	  if ( sheet_body->lump() == NULL ||
-	       sheet_body->lump()->shell() == NULL ||
-	       sheet_body->lump()->shell()->first_face() == NULL )
-	  BODY_list.append(sheet_body);
-      BODY *first_BODY = NULL;
+  for ( ii = body_list.size(); ii > 0; ii-- )
+    BodySM *body_ptr = body_list.get_and_step();
+    if (!BODY_ptr)
-      for ( ii = body_list.size(); ii > 0; ii-- )
-	  BodySM *body_ptr = body_list.get_and_step();
-	  if (!BODY_ptr)
+    if (first_BODY == NULL )
+      first_BODY = BODY_ptr;
+    BODY_list.append(BODY_ptr);
+    old_BODY_list.append(BODY_ptr);
+    //Okay unite all of these bodies into one body.
+  BODY_list.reset();
+  int new_ids = GeometryModifyTool::instance()->get_new_ids();
+  bool delete_attribs = (new_ids || keep_old);
+  BODY *master;
-	  if (first_BODY == NULL )
-	    first_BODY = BODY_ptr;
-	  BODY_list.append(BODY_ptr);
-	  old_BODY_list.append(BODY_ptr);
-      //Okay unite all of these bodies into one body.
-      BODY_list.reset();
-      int new_ids = GeometryModifyTool::instance()->get_new_ids();
-      bool delete_attribs = (new_ids || keep_old);
-      BODY *master;
+  //if we're not healing, we're assuming the surfaces have gaps between each other
+  //less than 1e-6, so we'll use stitching, otherwise we assume the gaps are bigger than
+  //1e-6 and we'll us api_combine_body, and subsequently we'll heal
+  ENTITY_LIST bodies_to_be_stitched;
-      //if we're not healing, we're assuming the surfaces have gaps between each other
-      //less than 1e-6, so we'll use stitching, otherwise we assume the gaps are bigger than
-      //1e-6 and we'll us api_combine_body, and subsequently we'll heal
-      ENTITY_LIST bodies_to_be_stitched;
+  if ( first_BODY )
+    master = this->copy_BODY(first_BODY, delete_attribs);
+    BODY_list.remove(first_BODY);
+  else
+    master = this->copy_BODY(BODY_list.remove(), delete_attribs);
-      if ( first_BODY )
-	  master = this->copy_BODY(first_BODY, delete_attribs);
-	  BODY_list.remove(first_BODY);
-      else
-	master = this->copy_BODY(BODY_list.remove(), delete_attribs);
+  if( !heal )
+    bodies_to_be_stitched.add( master );
-      if( !heal )
-	bodies_to_be_stitched.add( master );
+  for ( ii = BODY_list.size(); ii > 0; ii-- )
+    BODY *BODY_ptr = BODY_list.get_and_step();
+    BODY *copy = this->copy_BODY(BODY_ptr, delete_attribs);
+    if (copy == NULL)
+      AcisQueryEngine::instance()->delete_ACIS_BODY(master);
+    if( !heal )
+      bodies_to_be_stitched.add( copy );
+    else
+      outcome result = api_combine_body(copy, master );
-      for ( ii = BODY_list.size(); ii > 0; ii-- )
-	  BODY *BODY_ptr = BODY_list.get_and_step();
-	  BODY *copy = this->copy_BODY(BODY_ptr, delete_attribs);
-	  if (copy == NULL)
-	      AcisQueryEngine::instance()->delete_ACIS_BODY(master);
-	  if( !heal )
-	    bodies_to_be_stitched.add( copy );
-	  else
-	      outcome result = api_combine_body(copy, master );
+      if (!result.ok() || (!master ))
+        // If there are no LUMPs in the resulting BODY, return with a failure
+        if (master == NULL)
+          PRINT_ERROR("In AcisModifyEngine::create_solid_bodies_from_surfs\n");
-	      if (!result.ok() || (!master ))
-		  // If there are no LUMPs in the resulting BODY, return with a failure
-		  if (master == NULL)
-		    PRINT_ERROR("In AcisModifyEngine::create_solid_bodies_from_surfs\n");
+        AcisQueryEngine::instance()->ACIS_API_error(result, "create body from surfs");
+        if (master != NULL) AcisQueryEngine::instance()->delete_ACIS_BODY(master);
+        if (copy   != NULL) AcisQueryEngine::instance()->delete_ACIS_BODY(copy);
-		  AcisQueryEngine::instance()->ACIS_API_error(result, "create body from surfs");
-		  if (master != NULL) AcisQueryEngine::instance()->delete_ACIS_BODY(master);
-		  if (copy   != NULL) AcisQueryEngine::instance()->delete_ACIS_BODY(copy);
+  if( !heal )
+    ENTITY_LIST dummy_list, resultant_bodies;
+    tolerant_stitch_options stitch_opts;
+    //surfaces better be between GEOMETRY_RESABS or else fail
+    stitch_opts.set_max_stitch_tol( GEOMETRY_RESABS );
+    outcome result = api_stitch( bodies_to_be_stitched, dummy_list, resultant_bodies, &stitch_opts );
-      if( !heal )
-	  ENTITY_LIST dummy_list, resultant_bodies;
-	  tolerant_stitch_options stitch_opts;
-	  //surfaces better be between GEOMETRY_RESABS or else fail
-	  stitch_opts.set_max_stitch_tol( GEOMETRY_RESABS );
-	  outcome result = api_stitch( bodies_to_be_stitched, dummy_list, resultant_bodies, &stitch_opts );
+    master = (BODY*)dummy_list.first();
-	  master = (BODY*)dummy_list.first();
+    // If all went well, delete the old Bodies
+  DLIList<TopologyBridge*> old_entities;
+  body_list.reset() ;
-      // If all went well, delete the old Bodies
-      DLIList<TopologyBridge*> old_entities;
-      body_list.reset() ;
+  CAST_LIST_TO_PARENT(body_list, old_entities);
-      CAST_LIST_TO_PARENT(body_list, old_entities);
+    old_entities.append(free_faces.get_and_step());
-	old_entities.append(free_faces.get_and_step());
+  if (!keep_old )
+    for( ii = body_list.size(); ii > 0; ii--)
+      Body* body_ptr = body_list.get_and_step() ;
+      GeometryModifyTool::instance()->delete_Body(body_ptr) ;
+      RefFace *ref_ptr = free_faces.get_and_step();
+      RefEntity *ref_entity_ptr = CAST_TO(ref_ptr, RefEntity);
+      GeometryModifyTool::instance()->delete_RefEntity(ref_entity_ptr);
-	if (!keep_old )
-	for( ii = body_list.size(); ii > 0; ii--)
-	Body* body_ptr = body_list.get_and_step() ;
-	GeometryModifyTool::instance()->delete_Body(body_ptr) ;
-	RefFace *ref_ptr = free_faces.get_and_step();
-	RefEntity *ref_entity_ptr = CAST_TO(ref_ptr, RefEntity);
-	GeometryModifyTool::instance()->delete_RefEntity(ref_entity_ptr);
-      BODY *new_master = master;
+  BODY *new_master = master;
 #ifdef ACIS_HEALER
-      //  BODY *new_master = master;
-      if ( heal )
+//  BODY *new_master = master;
+  if ( heal )
-	  // Now heal the combined body
-	  PRINT_INFO(" Healing the combined volume...\n");
-	  if( AcisHealerTool::instance()->init_BODY_for_healing( master ) == CUBIT_SUCCESS )
-	      int percent_before, percent_after, number_splines_simplified;
-	      if( AcisHealerTool::instance()->heal_BODY( master, percent_before,
-							 percent_after, number_splines_simplified ) == CUBIT_FAILURE )
-		PRINT_ERROR( "Error healing the combined volume\n" );
-	      else
-		PRINT_INFO( "Healed the combined volume to %d%% good geometry.\n", percent_after );
-	      AcisHealerTool::instance()->end_BODY_for_healing( master );
+      // Now heal the combined body
+    PRINT_INFO(" Healing the combined volume...\n");
+    if( AcisHealerTool::instance()->init_BODY_for_healing( master ) == CUBIT_SUCCESS )
+      int percent_before, percent_after, number_splines_simplified;
+      if( AcisHealerTool::instance()->heal_BODY( master, percent_before,
+                                                 percent_after, number_splines_simplified ) == CUBIT_FAILURE )
+        PRINT_ERROR( "Error healing the combined volume\n" );
+      else
+        PRINT_INFO( "Healed the combined volume to %d%% good geometry.\n", percent_after );
+      AcisHealerTool::instance()->end_BODY_for_healing( master );
 #else
-      PRINT_WARNING("Healer was not included with this version.\n"
-		    " Volume healing is usually required for creating\n"
-		    " volumes out of surfaces.\n");
+  PRINT_WARNING("Healer was not included with this version.\n"
+                " Volume healing is usually required for creating\n"
+                " volumes out of surfaces.\n");
 #endif
-      //Gather all the FACEs from resultant BODY
-      ENTITY_LIST tmp_FACEs;
-      api_get_faces( new_master, tmp_FACEs );
-      FACE **tmp_FACE_array = new FACE*[tmp_FACEs.count()];
-      tmp_FACEs.init();
-      ENTITY *tmp_ent = NULL;
-      while( (tmp_ent = tmp_FACEs.next()) != NULL)
-	tmp_FACE_array[ii++] = static_cast<FACE*>(tmp_ent);
+  //Gather all the FACEs from resultant BODY
+  ENTITY_LIST tmp_FACEs;
+  api_get_faces( new_master, tmp_FACEs );
+  FACE **tmp_FACE_array = new FACE*[tmp_FACEs.count()];
+  tmp_FACEs.init();
+  ENTITY *tmp_ent = NULL;
+  while( (tmp_ent = tmp_FACEs.next()) != NULL)
+    tmp_FACE_array[ii++] = static_cast<FACE*>(tmp_ent);
-      //lets make sure that there are not inappropriate intersections between FACEs
-      ENTITY_LIST insane_ents;
-      logical bad_ints = true;
-      api_check_list_ff_ints( tmp_FACEs.count(), tmp_FACE_array, &insane_ents, bad_ints );
+  //lets make sure that there are not inappropriate intersections between FACEs
+  ENTITY_LIST insane_ents;
+  logical bad_ints = true;
+  api_check_list_ff_ints( tmp_FACEs.count(), tmp_FACE_array, &insane_ents, bad_ints );
-      delete [] tmp_FACE_array;
+  delete [] tmp_FACE_array;
-      if( insane_ents.count() || bad_ints )
-	  PRINT_INFO("Bad surface-surface intersections\n");
-	  insane_ents.init();
-	  while( (tmp_ent=insane_ents.next()) != NULL)
-	      ERROR_ENTITY *error_ent = static_cast<ERROR_ENTITY*>(tmp_ent);
-	      PRINT_ERROR("ACIS error number %d %s\n", error_ent->get_error_id(),
-			  find_err_mess (error_ent->get_error_id()));
-	  api_delent( new_master );
-      //separate the bodies so that you have no multi-volume bodies
-      ENTITY_LIST separated_bodies;
-      int n_bodies;
-      api_separate_body( new_master, n_bodies, new_BODY_list );
-      DLIList<BODY*> new_BODIES;
-      int i;
-      for( i=0; i<n_bodies; i++ )
-	new_BODIES.append( new_BODY_list[i] );
-      CubitStatus success =
-	get_new_Body(old_entities, new_BODIES, new_bodies, keep_old);
-      if ( new_bodies.size() == 0 )
-	  PRINT_ERROR("Problems creating new volume.\n" );
-      return CUBIT_SUCCESS;
+  if( insane_ents.count() || bad_ints )
+    PRINT_INFO("Bad surface-surface intersections\n");
+    insane_ents.init();
+    while( (tmp_ent=insane_ents.next()) != NULL)
+      ERROR_ENTITY *error_ent = static_cast<ERROR_ENTITY*>(tmp_ent);
+      PRINT_ERROR("ACIS error number %d %s\n", error_ent->get_error_id(),
+                              find_err_mess (error_ent->get_error_id()));
+    api_delent( new_master );
-  // Currently no command line to this
-  CubitStatus AcisModifyEngine::webcut_across_translate(
-							DLIList<BodySM*>& body_list,
-							Surface* top_surf_ptr,
-							Surface* bottom_surf_ptr,
-							DLIList<BodySM*>& ,
-							bool  ) const
-      CubitVector top_orig, top_norm, bottom_orig, bottom_norm;
-      double top_orig_pnt[3], top_norm_vec[3], bottom_orig_pnt[3], bottom_norm_vec[3];
-      //CubitVector top_sweep_vector, bottom_sweep_vector;
-      double distance;
-      int i, ii;
-      BodySM* body_ptr;
-      Surface* ref_face_ptr;
-      FACE* FACE_ptr;
-      FACE* copied_FACE_ptr;
-      ENTITY *entity_ptr;
-      DLIList<BODY*> tool_BODY_list;
-      //int volume_is_negative;
-      AgtSide side;
-      AgtOrientation orien;
-      outcome result;
+  //separate the bodies so that you have no multi-volume bodies
+  ENTITY_LIST separated_bodies;
+  int n_bodies;
+  api_separate_body( new_master, n_bodies, new_BODY_list );
-      AnalyticGeometryTool* agt = AnalyticGeometryTool::instance();
+  DLIList<BODY*> new_BODIES;
+  int i;
+  for( i=0; i<n_bodies; i++ )
+    new_BODIES.append( new_BODY_list[i] );
-      // Find top plane
-      if( top_surf_ptr->get_point_normal( top_orig, top_norm ) == CUBIT_FAILURE )
-	  PRINT_ERROR( "Surface is not planar\n" );
+  CubitStatus success =
+    get_new_Body(old_entities, new_BODIES, new_bodies, keep_old);
-      if( bottom_surf_ptr->get_point_normal( bottom_orig, bottom_norm ) == CUBIT_FAILURE )
+  if ( new_bodies.size() == 0 )
+    PRINT_ERROR("Problems creating new volume.\n" );
+  return CUBIT_SUCCESS;
-      top_orig.get_xyz( top_orig_pnt ); top_norm.get_xyz( top_norm_vec );
-      bottom_orig.get_xyz( bottom_orig_pnt ); bottom_norm.get_xyz( bottom_norm_vec );
+// Currently no command line to this
+CubitStatus AcisModifyEngine::webcut_across_translate(
+                                                 DLIList<BodySM*>& body_list,
+                                                 Surface* top_surf_ptr,
+                                                 Surface* bottom_surf_ptr,
+                                                 DLIList<BodySM*>& ,
+                                                 bool  ) const
+   CubitVector top_orig, top_norm, bottom_orig, bottom_norm;
+   double top_orig_pnt[3], top_norm_vec[3], bottom_orig_pnt[3], bottom_norm_vec[3];
+   //CubitVector top_sweep_vector, bottom_sweep_vector;
+   double distance;
+   int i, ii;
+   BodySM* body_ptr;
+   Surface* ref_face_ptr;
+   FACE* FACE_ptr;
+   FACE* copied_FACE_ptr;
+   ENTITY *entity_ptr;
+   DLIList<BODY*> tool_BODY_list;
+   //int volume_is_negative;
+   AgtSide side;
+   AgtOrientation orien;
+   outcome result;
-      // Check distance between planes
-      distance = agt->dist_pln_pln( top_orig_pnt, top_norm_vec, bottom_orig_pnt, bottom_norm_vec,
-				    &side, &orien );
+   AnalyticGeometryTool* agt = AnalyticGeometryTool::instance();
-      if( agt->dbl_eq( distance, 0.0 ) )
-	  PRINT_ERROR( "Distance between planes is 0.0\n" );
+   // Find top plane
+   if( top_surf_ptr->get_point_normal( top_orig, top_norm ) == CUBIT_FAILURE )
+      PRINT_ERROR( "Surface is not planar\n" );
-      double top_bott[3];
-      top_bott[0] = top_norm.x();
-      top_bott[1] = top_norm.y();
-      top_bott[2] = top_norm.z();
-      if( side == AGT_NEG_SIDE ) {
-	agt->reverse_vec( top_bott, top_bott );
+   if( bottom_surf_ptr->get_point_normal( bottom_orig, bottom_norm ) == CUBIT_FAILURE )
-      // Top plane
-      for( i=0; i<body_list.size(); i++ )
-	  body_ptr = body_list.get_and_step();
+   top_orig.get_xyz( top_orig_pnt ); top_norm.get_xyz( top_norm_vec );
+   bottom_orig.get_xyz( bottom_orig_pnt ); bottom_norm.get_xyz( bottom_norm_vec );
-	  DLIList<Surface*> ref_face_list;
-	  AcisQueryEngine::instance()->get_surfs_on_plane( body_ptr, top_orig_pnt, top_norm_vec, ref_face_list );
+   // Check distance between planes
+   distance = agt->dist_pln_pln( top_orig_pnt, top_norm_vec, bottom_orig_pnt, bottom_norm_vec,
+                                 &side, &orien );
-	  if( ref_face_list.size() == 0 )
-	    continue;
+   if( agt->dbl_eq( distance, 0.0 ) )
+      PRINT_ERROR( "Distance between planes is 0.0\n" );
-	  for( ii=0; ii<ref_face_list.size(); ii++ )
-	      ref_face_ptr = ref_face_list.get_and_step();
+   double top_bott[3];
+   top_bott[0] = top_norm.x();
+   top_bott[1] = top_norm.y();
+   top_bott[2] = top_norm.z();
+   if( side == AGT_NEG_SIDE ) {
+      agt->reverse_vec( top_bott, top_bott );
-	      // Copy each surface, reverse and extrude
-	      FACE_ptr = AcisQueryEngine::get_FACE( ref_face_ptr );
+   // Top plane
+   for( i=0; i<body_list.size(); i++ )
+      body_ptr = body_list.get_and_step();
-	      if( FACE_ptr == NULL )
+      DLIList<Surface*> ref_face_list;
+      AcisQueryEngine::instance()->get_surfs_on_plane( body_ptr, top_orig_pnt, top_norm_vec, ref_face_list );
-	      result = api_copy_entity_contents( (ENTITY *)FACE_ptr, entity_ptr);
-	      if( !result.ok() )
-		  PRINT_ERROR( "Unable to copy face off volume\n" );
-		  continue;
+      if( ref_face_list.size() == 0 )
+         continue;
-	      copied_FACE_ptr = (FACE *)entity_ptr;
-	      ATTRIB_CUBIT_OWNER::remove_cubit_owner( (ENTITY *)copied_FACE_ptr,
-						      CUBIT_TRUE );
+      for( ii=0; ii<ref_face_list.size(); ii++ )
+         ref_face_ptr = ref_face_list.get_and_step();
-	      // Create a sheet body from this free-face
-	      BODY* sheet_BODY_ptr;
-	      result = api_sheet_from_ff( 1, &copied_FACE_ptr, sheet_BODY_ptr );
-	      if (!result.ok())
-		  PRINT_ERROR("Error in api_sheet_from_ff\n");
-		  PRINT_ERROR( "Unable to create sheet volume from face\n" );
-		  continue;
-	      if( sheet_BODY_ptr == NULL )
-		  continue;
+         // Copy each surface, reverse and extrude
+         FACE_ptr = AcisQueryEngine::get_FACE( ref_face_ptr );
-	      DLIList<FACE*> sheet_FACE_list;
-	      AcisQueryEngine::instance()->get_FACEs( (ENTITY *)sheet_BODY_ptr, sheet_FACE_list );
-	      if( sheet_FACE_list.size() != 1 )
-		  PRINT_ERROR( "Sheet doesn't have one face\n" );
-		  continue;
-	      FACE* sheet_FACE_ptr = sheet_FACE_list.get();
+         if( FACE_ptr == NULL )
-	      // Get underlying plane normal.  The FACE normal might be reversed
-	      // of this.
-	      surface const* acis_surface = &(sheet_FACE_ptr->geometry()->equation());
-	      SPAposition sheet_surf_orig;
-	      SPAunit_vector sheet_surf_norm;
-	      acis_surface->planar( sheet_surf_orig, sheet_surf_norm );
-	      double sheet_norm[3];
-	      sheet_norm[0] = sheet_surf_norm.x();
-	      sheet_norm[1] = sheet_surf_norm.y();
-	      sheet_norm[2] = sheet_surf_norm.z();
+         result = api_copy_entity_contents( (ENTITY *)FACE_ptr, entity_ptr);
+         if( !result.ok() )
+            PRINT_ERROR( "Unable to copy face off volume\n" );
+            continue;
-	      // Get sheet normal in same direction as ACIS FACE.  The direction of the
-	      // ACIS face is the direction of sweep.
-	      if( sheet_FACE_ptr->sense() == REVERSED )
-		agt->reverse_vec( sheet_norm, sheet_norm );
+         copied_FACE_ptr = (FACE *)entity_ptr;
+         ATTRIB_CUBIT_OWNER::remove_cubit_owner( (ENTITY *)copied_FACE_ptr,
+                                                 CUBIT_TRUE );
-	      // Properties of dot product
-	      // angle acute if dot product > 0
-	      // angle obtuse if dot product < 0
-	      // angle 90 deg if dot product = 0
+         // Create a sheet body from this free-face
+         BODY* sheet_BODY_ptr;
+         result = api_sheet_from_ff( 1, &copied_FACE_ptr, sheet_BODY_ptr );
+         if (!result.ok())
+            PRINT_ERROR("Error in api_sheet_from_ff\n");
+            PRINT_ERROR( "Unable to create sheet volume from face\n" );
+            continue;
+         if( sheet_BODY_ptr == NULL )
+            continue;
-	      if( agt->dot_vec( sheet_norm, top_bott ) < 0.0 )
-		  //PRINT_INFO( "Reversing volume...\n" );
-		  api_reverse_body( sheet_BODY_ptr );
+         DLIList<FACE*> sheet_FACE_list;
+         AcisQueryEngine::instance()->get_FACEs( (ENTITY *)sheet_BODY_ptr, sheet_FACE_list );
+         if( sheet_FACE_list.size() != 1 )
+            PRINT_ERROR( "Sheet doesn't have one face\n" );
+            continue;
+         FACE* sheet_FACE_ptr = sheet_FACE_list.get();
-	      result = api_sw_face_norm( sheet_FACE_ptr, FORWARD, distance+distance*(.50), 0, 0 );
+         // Get underlying plane normal.  The FACE normal might be reversed
+         // of this.
+         surface const* acis_surface = &(sheet_FACE_ptr->geometry()->equation());
+         SPAposition sheet_surf_orig;
+         SPAunit_vector sheet_surf_norm;
+         acis_surface->planar( sheet_surf_orig, sheet_surf_norm );
+         double sheet_norm[3];
+         sheet_norm[0] = sheet_surf_norm.x();
+         sheet_norm[1] = sheet_surf_norm.y();
+         sheet_norm[2] = sheet_surf_norm.z();
-	      if (!result.ok())
-		  PRINT_ERROR("Error during ACIS sweep operation, api_sw_face_norm\n");
-		  continue;
+         // Get sheet normal in same direction as ACIS FACE.  The direction of the
+         // ACIS face is the direction of sweep.
+         if( sheet_FACE_ptr->sense() == REVERSED )
+            agt->reverse_vec( sheet_norm, sheet_norm );
-	      BODY* tool_BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY(sheet_FACE_ptr);
+         // Properties of dot product
+         // angle acute if dot product > 0
+         // angle obtuse if dot product < 0
+         // angle 90 deg if dot product = 0
-	      if (is_BODY(tool_BODY_ptr))
-		  result = api_body_to_2d(tool_BODY_ptr);
-		  if (!result.ok())
-		    PRINT_WARNING("Couldn't turn a tool into a 3D sheet\n" );
+         if( agt->dot_vec( sheet_norm, top_bott ) < 0.0 )
+            //PRINT_INFO( "Reversing volume...\n" );
+            api_reverse_body( sheet_BODY_ptr );
-		  tool_BODY_list.append( tool_BODY_ptr );
+         result = api_sw_face_norm( sheet_FACE_ptr, FORWARD, distance+distance*(.50), 0, 0 );
-		  // Move the body slightly so it overlaps
-		  // Create a SPAvector representing the offsets
-		  double fact = 0.35;
-		  SPAvector translation_vector( -top_bott[0]*distance*fact, -top_bott[1]*distance*fact, -top_bott[2]*distance*fact );
-		  SPAtransf tran_vec = translate_transf (translation_vector);
+         if (!result.ok())
+            PRINT_ERROR("Error during ACIS sweep operation, api_sw_face_norm\n");
+            continue;
-		  // Concatenate the input transformation to the existing one
-		  result = api_apply_transf ( tool_BODY_ptr, tran_vec );
-		  if (!result.ok())
-		      AcisQueryEngine::instance()->ACIS_API_error ( result, "transforming body" );
-		      continue;
-		  TRANSFORM* identity = new TRANSFORM(scale_transf(1.0));
-		  result = api_change_body_trans ( tool_BODY_ptr, identity, FALSE );
-		  identity->lose();
-		  if (!result.ok())
-		      continue;
+         BODY* tool_BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY(sheet_FACE_ptr);
+         if (is_BODY(tool_BODY_ptr))
+            result = api_body_to_2d(tool_BODY_ptr);
+            if (!result.ok())
+              PRINT_WARNING("Couldn't turn a tool into a 3D sheet\n" );
+            tool_BODY_list.append( tool_BODY_ptr );
-	      else
-		  PRINT_ERROR( "Unable to create tool from surface\n" );
+            // Move the body slightly so it overlaps
+            // Create a SPAvector representing the offsets
+            double fact = 0.35;
+            SPAvector translation_vector( -top_bott[0]*distance*fact, -top_bott[1]*distance*fact, -top_bott[2]*distance*fact );
+            SPAtransf tran_vec = translate_transf (translation_vector);
-	  PRINT_INFO( "Got %d tools\n from the top\n", tool_BODY_list.size() );
+            // Concatenate the input transformation to the existing one
+            result = api_apply_transf ( tool_BODY_ptr, tran_vec );
+            if (!result.ok())
+               AcisQueryEngine::instance()->ACIS_API_error ( result, "transforming body" );
+               continue;
+            TRANSFORM* identity = new TRANSFORM(scale_transf(1.0));
+            result = api_change_body_trans ( tool_BODY_ptr, identity, FALSE );
+            identity->lose();
+            if (!result.ok())
+               continue;
-	  // For now just create tools
-	  for( ii=0; ii<tool_BODY_list.size(); ii++ )
-	      BODY *temp_tool_BODY_ptr = tool_BODY_list.get_and_step();
-	      /*BodySM *new_body = */
-	      AcisQueryEngine::instance()->populate_topology_bridges(temp_tool_BODY_ptr);
+         else
+            PRINT_ERROR( "Unable to create tool from surface\n" );
+      PRINT_INFO( "Got %d tools\n from the top\n", tool_BODY_list.size() );
-  // Imprints curves to bodies.
-  CubitStatus AcisModifyEngine::imprint( DLIList<BodySM*> &body_list,
-					 DLIList<Curve*> &ref_edge_list,
-					 DLIList<BodySM*>& new_body_list,
-					 bool keep_old_body,
-					 bool show_messages) const
-      int i, j;
-      outcome result;
-      CubitStatus status = CUBIT_SUCCESS;
-      CubitBoolean imprint_worked = CUBIT_FALSE;
+      // For now just create tools
+      for( ii=0; ii<tool_BODY_list.size(); ii++ )
+         BODY *temp_tool_BODY_ptr = tool_BODY_list.get_and_step();
-      Curve* ref_edge_ptr;
-      BodySM *body_ptr;
+         /*BodySM *new_body = */
+         AcisQueryEngine::instance()->populate_topology_bridges(temp_tool_BODY_ptr);
-      BODY *BODY_ptr;
-      BODY *copied_BODY_ptr;
-      BODY *wire_BODY_ptr;
-      EDGE *EDGE_ptr;
-      EDGE *copied_EDGE_ptr;
-      DLIList<BODY*> ewire_list;
+// Imprints curves to bodies.
+CubitStatus AcisModifyEngine::imprint( DLIList<BodySM*> &body_list,
+                                       DLIList<Curve*> &ref_edge_list,
+                                       DLIList<BodySM*>& new_body_list,
+                                       bool keep_old_body,
+                                       bool show_messages) const
+   int i, j;
+   outcome result;
+   CubitStatus status = CUBIT_SUCCESS;
+   CubitBoolean imprint_worked = CUBIT_FALSE;
-	(GeometryModifyTool::instance()->get_new_ids() || keep_old_body);
+   Curve* ref_edge_ptr;
+   BodySM *body_ptr;
-      // Make wires which can be used to imprint onto the bodies
-      ref_edge_list.reset();
-      for( i=0; i<ref_edge_list.size(); i++ )
-	  ref_edge_ptr = ref_edge_list.get_and_step();
+   BODY *BODY_ptr;
+   BODY *copied_BODY_ptr;
+   BODY *wire_BODY_ptr;
-	  // Get the EDGE pointer
-	  EDGE_ptr = AcisQueryEngine::get_EDGE( ref_edge_ptr );
+   EDGE *EDGE_ptr;
+   EDGE *copied_EDGE_ptr;
-	  if( EDGE_ptr == NULL )
+   DLIList<BODY*> ewire_list;
-	  // Copy the EDGE.  I've found that the ewire will reference
-	  // the original EDGE and that EDGE can get split later when
-	  // doing imprints.  Also note that the copied EDGE will get
-	  // deleted when deleting the ewire.
-	  result = api_edge( EDGE_ptr, copied_EDGE_ptr );
-	  if (!result.ok())
-	      PRINT_ERROR( "Unable to copy curve; aborting\n" );
-	      AcisQueryEngine::instance()->ACIS_API_error (result);
+      (GeometryModifyTool::instance()->get_new_ids() || keep_old_body);
-	  // Remove the CUBIT owner attribute from the EDGE
-	  ATTRIB_CUBIT_OWNER::remove_cubit_owner( (ENTITY *)copied_EDGE_ptr,
-						  CUBIT_TRUE );
+   // Make wires which can be used to imprint onto the bodies
+   ref_edge_list.reset();
+   for( i=0; i<ref_edge_list.size(); i++ )
+      ref_edge_ptr = ref_edge_list.get_and_step();
-	  // Make an ewire from this EDGE
-	  result = api_make_ewire( 1, &copied_EDGE_ptr, wire_BODY_ptr );
-	  if (!result.ok())
-	      PRINT_ERROR( "Unable to make ACIS WIRE from curve; aborting\n" );
-	      for( j=0; j<ewire_list.size(); j++ )
-		api_delent( ewire_list.get_and_step() );
+      // Get the EDGE pointer
+      EDGE_ptr = AcisQueryEngine::get_EDGE( ref_edge_ptr );
-	  ewire_list.append( wire_BODY_ptr );
+      if( EDGE_ptr == NULL )
-      // Loop on bodies, imprinting each with all the ewires
+      // Copy the EDGE.  I've found that the ewire will reference
+      // the original EDGE and that EDGE can get split later when
+      // doing imprints.  Also note that the copied EDGE will get
+      // deleted when deleting the ewire.
+      result = api_edge( EDGE_ptr, copied_EDGE_ptr );
+      if (!result.ok())
+         PRINT_ERROR( "Unable to copy curve; aborting\n" );
+         AcisQueryEngine::instance()->ACIS_API_error (result);
-	  BODY_ptr = AcisQueryEngine::get_BODY(body_ptr);
-	  if( BODY_ptr == NULL )
-	      PRINT_ERROR( "Unable to find ACIS BODY from volume; aborting\n" );
+      // Remove the CUBIT owner attribute from the EDGE
+      ATTRIB_CUBIT_OWNER::remove_cubit_owner( (ENTITY *)copied_EDGE_ptr,
+                                              CUBIT_TRUE );
-	  // Copy the body before working with it
-	  copied_BODY_ptr = copy_BODY( BODY_ptr, delete_attribs );
+      // Make an ewire from this EDGE
+      result = api_make_ewire( 1, &copied_EDGE_ptr, wire_BODY_ptr );
+      if (!result.ok())
+         PRINT_ERROR( "Unable to make ACIS WIRE from curve; aborting\n" );
+         for( j=0; j<ewire_list.size(); j++ )
+            api_delent( ewire_list.get_and_step() );
-	  // Imprint the wire-bodies onto the BODY
-	  api_set_int_option("all_free_edges", TRUE );
-	  ewire_list.reset();
-	      wire_BODY_ptr = ewire_list.get_and_step();
-	      BODY* temp_BODY_ptr = copy_BODY( copied_BODY_ptr, delete_attribs );
+      ewire_list.append( wire_BODY_ptr );
-	      result = api_imprint( wire_BODY_ptr, copied_BODY_ptr );
+   // Loop on bodies, imprinting each with all the ewires
-	      //Gets rid of sliver curves/surfaces that could get produced by the imprint.
-	      AcisModifyEngine::instance()->cleanup_slivers( copied_BODY_ptr );
+      BODY_ptr = AcisQueryEngine::get_BODY(body_ptr);
+      if( BODY_ptr == NULL )
+         PRINT_ERROR( "Unable to find ACIS BODY from volume; aborting\n" );
-	      if( !result.ok() && result.error_number()!=200 )
-		  if ( show_messages )
-		      PRINT_ERROR( "problem imprinting curve onto volume\n" );
-		  //revert back to the old body.
-		  api_delent(copied_BODY_ptr);
-		  copied_BODY_ptr = temp_BODY_ptr;
-		  status = CUBIT_FAILURE;
-	      else
-		imprint_worked = CUBIT_TRUE;
-	  if( imprint_worked )
-	      api_set_int_option("all_free_edges", FALSE );
+      // Copy the body before working with it
+      copied_BODY_ptr = copy_BODY( BODY_ptr, delete_attribs );
-	      DLIList<EDGE*> new_edges = AcisModifyEngine::instance()->find_new_EDGES(copied_BODY_ptr);
+      // Imprint the wire-bodies onto the BODY
+      api_set_int_option("all_free_edges", TRUE );
+      ewire_list.reset();
+         wire_BODY_ptr = ewire_list.get_and_step();
+         BODY* temp_BODY_ptr = copy_BODY( copied_BODY_ptr, delete_attribs );
-	      BodySM* new_body_ptr = get_new_Body( body_ptr, BODY_ptr, copied_BODY_ptr,
-						   keep_old_body, CUBIT_TRUE );
+         result = api_imprint( wire_BODY_ptr, copied_BODY_ptr );
-	      if( new_body_ptr )
-		  // Add a imprint feature to the topo edges
-		  for (int edge_count = new_edges.size(); edge_count--; )
-		      CubitSimpleAttrib *tmp_attrib = new CubitSimpleAttrib( "SOURCE_FEATURE", "IMPRINT" );
-		      new ATTRIB_SNL_SIMPLE( new_edges[edge_count], tmp_attrib );
-		      delete tmp_attrib;
-		  new_body_list.append(new_body_ptr);
+         //Gets rid of sliver curves/surfaces that could get produced by the imprint.
+         AcisModifyEngine::instance()->cleanup_slivers( copied_BODY_ptr );
-      // Free memory
-      for( i=0; i<ewire_list.size(); i++ )
-      if ( imprint_worked && status != CUBIT_SUCCESS )
-	status = CUBIT_SUCCESS;
-      return status;
+         if( !result.ok() && result.error_number()!=200 )
+           if ( show_messages )
+             PRINT_ERROR( "problem imprinting curve onto volume\n" );
+             //revert back to the old body.
+           api_delent(copied_BODY_ptr);
+           copied_BODY_ptr = temp_BODY_ptr;
+           status = CUBIT_FAILURE;
+         else
+           imprint_worked = CUBIT_TRUE;
+      if( imprint_worked )
+          api_set_int_option("all_free_edges", FALSE );
-  // This is a special case - needed because if a curve hangs over
-  // several surfaces on a body and the user wants to split only one
-  // of the surfaces.  This method sometimes works when function to
-  // imprint a curve to a body fails.  The surfaces must be part of
-  // a body, but the curves just have to be valid ACIS EDGEs.
-  CubitStatus AcisModifyEngine::imprint( DLIList<Surface*> &surface_list,
-					 DLIList<Curve*> &curve_list,
-					 bool keep_old_body ) const
-      int i;
+          DLIList<EDGE*> new_edges = AcisModifyEngine::instance()->find_new_EDGES(copied_BODY_ptr);
-      outcome result;
+          BodySM* new_body_ptr = get_new_Body( body_ptr, BODY_ptr, copied_BODY_ptr,
+              keep_old_body, CUBIT_TRUE );
-      // Copy the incoming surface_list since we will be pulling
-      // surfaces out of it.
-      DLIList<SurfaceACIS*> copied_surface_list(surface_list.size());
-      Curve* curve_ptr;
+          if( new_body_ptr )
+              // Add a imprint feature to the topo edges
+              for (int edge_count = new_edges.size(); edge_count--; )
+                  CubitSimpleAttrib *tmp_attrib = new CubitSimpleAttrib( "SOURCE_FEATURE", "IMPRINT" );
+                  new ATTRIB_SNL_SIMPLE( new_edges[edge_count], tmp_attrib );
+                  delete tmp_attrib;
+              new_body_list.append(new_body_ptr);
-      BodySM *body_ptr;
-      BODY *BODY_ptr;
+   // Free memory
+   for( i=0; i<ewire_list.size(); i++ )
+   if ( imprint_worked && status != CUBIT_SUCCESS )
+     status = CUBIT_SUCCESS;
+   return status;
-      EDGE *EDGE_ptr;
+// This is a special case - needed because if a curve hangs over
+// several surfaces on a body and the user wants to split only one
+// of the surfaces.  This method sometimes works when function to
+// imprint a curve to a body fails.  The surfaces must be part of
+// a body, but the curves just have to be valid ACIS EDGEs.
+CubitStatus AcisModifyEngine::imprint( DLIList<Surface*> &surface_list,
+                                       DLIList<Curve*> &curve_list,
+                                       bool keep_old_body ) const
+  int i;
+  outcome result;
-      CAST_LIST( surface_list, copied_surface_list, SurfaceACIS );
-      if (surface_list.size() != copied_surface_list.size())
-	  PRINT_ERROR("Non-ACIS Surface at %s:%d\n", __FILE__, __LINE__ );
+  // Copy the incoming surface_list since we will be pulling
+  // surfaces out of it.
+  DLIList<SurfaceACIS*> copied_surface_list(surface_list.size());
+  Curve* curve_ptr;
-      // Need to copy all of the EDGE's before doing anything, if they are
-      // part of a body being imprinted on they could be invalidated before
-      // subsequent imprints.
-      DLIList<EDGE*> EDGE_list;
-      curve_list.reset();
-      for( i=curve_list.size(); i--; )
-	  curve_ptr = curve_list.get_and_step();
+  BodySM *body_ptr;
+  BODY *BODY_ptr;
-	  EDGE_ptr = AcisQueryEngine::get_EDGE( curve_ptr );
+  EDGE *EDGE_ptr;
-	      PRINT_ERROR("Non-ACIS Curve at %s:%d\n", __FILE__, __LINE__ );
-	  // Copy the EDGE.
-	  if (!result.ok())
-	      PRINT_ERROR( "Unable to copy curve; aborting.\n" );
+  CAST_LIST( surface_list, copied_surface_list, SurfaceACIS );
+  if (surface_list.size() != copied_surface_list.size())
+    PRINT_ERROR("Non-ACIS Surface at %s:%d\n", __FILE__, __LINE__ );
-	  ATTRIB_CUBIT_OWNER::remove_cubit_owner( (ENTITY *)copied_EDGE_ptr, CUBIT_TRUE );
+  // Need to copy all of the EDGE's before doing anything, if they are
+  // part of a body being imprinted on they could be invalidated before
+  // subsequent imprints.
+  DLIList<EDGE*> EDGE_list;
+  curve_list.reset();
+  for( i=curve_list.size(); i--; )
+    curve_ptr = curve_list.get_and_step();
-	  // Add the EDGE to the list
-	  EDGE_list.append( copied_EDGE_ptr );
+    EDGE_ptr = AcisQueryEngine::get_EDGE( curve_ptr );
-      // Loop on FACEs.  We will work on imprinting surfaces from one body at a time.
-      copied_surface_list.reset();
-      while( copied_surface_list.size() )
-	  DLIList<FACE*> imprint_FACE_list;
-	  if( get_copied_FACES_of_body( copied_surface_list, imprint_FACE_list,
-					copied_BODY_ptr ) == CUBIT_FAILURE )
-	    continue;
+      PRINT_ERROR("Non-ACIS Curve at %s:%d\n", __FILE__, __LINE__ );
-	  // Get original Body and BODY
-	  body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY( copied_BODY_ptr );
+    // Copy the EDGE.
+    if (!result.ok())
+      PRINT_ERROR( "Unable to copy curve; aborting.\n" );
-	  // Now cleanout the owner attributes from the copied BODY, if required
-	  if( delete_attribs )
-	    AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copied_BODY_ptr);
+    ATTRIB_CUBIT_OWNER::remove_cubit_owner( (ENTITY *)copied_EDGE_ptr, CUBIT_TRUE );
-	  if( imprint( copied_BODY_ptr, imprint_FACE_list, EDGE_list ) == CUBIT_FAILURE )
-	      // This only fails if there is a serious error - delete the copied Body
-	      api_delent( copied_BODY_ptr );
-	      continue;
+    // Add the EDGE to the list
+    EDGE_list.append( copied_EDGE_ptr );
+  // Loop on FACEs.  We will work on imprinting surfaces from one body at a time.
+  copied_surface_list.reset();
+  while( copied_surface_list.size() )
+    DLIList<FACE*> imprint_FACE_list;
+    if( get_copied_FACES_of_body( copied_surface_list, imprint_FACE_list,
+                                  copied_BODY_ptr ) == CUBIT_FAILURE )
+      continue;
+    // Get original Body and BODY
+    body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY( copied_BODY_ptr );
+    // Now cleanout the owner attributes from the copied BODY, if required
+    if( delete_attribs )
+      AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copied_BODY_ptr);
-	      new_body_list.append( new_body_ptr );
+    if( imprint( copied_BODY_ptr, imprint_FACE_list, EDGE_list ) == CUBIT_FAILURE )
+      // This only fails if there is a serious error - delete the copied Body
+        api_delent( copied_BODY_ptr );
+        continue;
-      // Free the memory allocated when copying edges
-      for( i=0; i<EDGE_list.size(); i++ )
-	  copied_EDGE_ptr = EDGE_list.get_and_step();
-	  api_delent( copied_EDGE_ptr );
-  // Imprint EDGEs to select FACEs.  FACEs must be from same BODY.  Input FACEs
-  // are modified but EDGEs are not.
-  CubitStatus AcisModifyEngine::imprint( BODY *BODY_ptr,
-					 DLIList<FACE*> &FACE_list,
-					 DLIList<EDGE*> &EDGE_list ) const
-      // Imprint the edges to the surfaces on this body
-      outcome result;
-      EDGE *EDGE_ptr;
-      FACE *FACE_ptr;
-      EDGE_list.reset();
-      FACE_list.reset();
-      int i, j;
-      for( i=EDGE_list.size(); i--; )
-	  // Imprint this edge selectively to the given faces on this body
-	  EDGE_ptr = EDGE_list.get_and_step();
-	  // Track the existing FACEs before imprinting this BODY with the edge.
-	  // Needed so we know which new surfaces result from the imprint.  These
-	  // new surfaces will need to be imprinted with subsequent edges.
-	  DLIList<FACE*> FACES_BEFORE;
-	  DLIList<FACE*> FACES_AFTER;
-	  AcisQueryEngine::instance()->get_FACEs( (ENTITY *)BODY_ptr, FACES_BEFORE );
+        new_body_list.append( new_body_ptr );
-	  for( j=FACE_list.size(); j--; )
-	      // Get the FACE to imprint to
-	      FACE_ptr = FACE_list.get_and_step();
+  // Free the memory allocated when copying edges
+  for( i=0; i<EDGE_list.size(); i++ )
+    copied_EDGE_ptr = EDGE_list.get_and_step();
+    api_delent( copied_EDGE_ptr );
-	      if( imprint( BODY_ptr, FACE_ptr, EDGE_ptr ) == CUBIT_FAILURE )
-		  PRINT_ERROR( "Unable to imprint EDGE to FACE\n" );
-		  continue;
-	      // Check against an assumption that if invalid, will
-	      // cause a crash.  The assumption is that the imprinted
-	      // FACE_ptr will remain valid after each imprint.
-	      FACES_AFTER.clean_out();
-	      AcisQueryEngine::instance()->get_FACEs( (ENTITY *)BODY_ptr, FACES_AFTER );
-	      if( !FACES_AFTER.is_in_list( FACE_ptr ) )
-		  PRINT_ERROR( "serious problem in imprint - an imprinted surface disappeared!\n"
-			       "       Model restored - operation aborted\n" );
+// Imprint EDGEs to select FACEs.  FACEs must be from same BODY.  Input FACEs
+// are modified but EDGEs are not.
+CubitStatus AcisModifyEngine::imprint( BODY *BODY_ptr,
+                                       DLIList<FACE*> &FACE_list,
+                                       DLIList<EDGE*> &EDGE_list ) const
+  // Imprint the edges to the surfaces on this body
+  outcome result;
+  EDGE *EDGE_ptr;
+  FACE *FACE_ptr;
+  EDGE_list.reset();
+  FACE_list.reset();
+  int i, j;
+  for( i=EDGE_list.size(); i--; )
+    // Imprint this edge selectively to the given faces on this body
+    EDGE_ptr = EDGE_list.get_and_step();
-	  // End of looping over FACES
+    // Track the existing FACEs before imprinting this BODY with the edge.
+    // Needed so we know which new surfaces result from the imprint.  These
+    // new surfaces will need to be imprinted with subsequent edges.
+    DLIList<FACE*> FACES_BEFORE;
+    DLIList<FACE*> FACES_AFTER;
+    AcisQueryEngine::instance()->get_FACEs( (ENTITY *)BODY_ptr, FACES_BEFORE );
-	  // Find which new surfaces were created - add these to the
-	  // FACE_list so that additional edges will imprint
-	  // on these as well.
-	  DLIList<FACE*> new_FACES;
-	  FACE* after_FACE_ptr;
-	  for( j=FACES_AFTER.size(); j--; )
-	      after_FACE_ptr = FACES_AFTER.get_and_step();
+    for( j=FACE_list.size(); j--; )
+      // Get the FACE to imprint to
+      FACE_ptr = FACE_list.get_and_step();
-	      if( !FACES_BEFORE.is_in_list( after_FACE_ptr ) )
-		new_FACES.append(after_FACE_ptr);
-	  FACE_list += new_FACES;
+      if( imprint( BODY_ptr, FACE_ptr, EDGE_ptr ) == CUBIT_FAILURE )
+        PRINT_ERROR( "Unable to imprint EDGE to FACE\n" );
+        continue;
+      // Check against an assumption that if invalid, will
+      // cause a crash.  The assumption is that the imprinted
+      // FACE_ptr will remain valid after each imprint.
+      FACES_AFTER.clean_out();
+      AcisQueryEngine::instance()->get_FACEs( (ENTITY *)BODY_ptr, FACES_AFTER );
+      if( !FACES_AFTER.is_in_list( FACE_ptr ) )
+        PRINT_ERROR( "serious problem in imprint - an imprinted surface disappeared!\n"
+          "       Model restored - operation aborted\n" );
-					 FACE *FACE_ptr,
-					 EDGE *EDGE_ptr ) const
-      outcome result;
+     // End of looping over FACES
-      BODY* tbody = NULL;
-      BODY* bbody = NULL;    // Blank body
-      FACE* bface = NULL;    // Blank face
-      surface* tsurf = NULL; // Tool surface
-      EDGE* edge = NULL;
+     // Find which new surfaces were created - add these to the
+     // FACE_list so that additional edges will imprint
+     // on these as well.
+     DLIList<FACE*> new_FACES;
+     FACE* after_FACE_ptr;
+     for( j=FACES_AFTER.size(); j--; )
+       after_FACE_ptr = FACES_AFTER.get_and_step();
-      //EXCEPTION_TRY
+       if( !FACES_BEFORE.is_in_list( after_FACE_ptr ) )
+         new_FACES.append(after_FACE_ptr);
+     FACE_list += new_FACES;
-      bbody = BODY_ptr;
-      bface = FACE_ptr;
-      edge = EDGE_ptr;
-      // Get the geometry of the blank face.
-      surface const& bsurf = bface->geometry()->equation();
+                                       FACE *FACE_ptr,
+                                       EDGE *EDGE_ptr ) const
+  outcome result;
-      // Create an empty tool body
-      tbody = ACIS_NEW BODY( (LUMP*) NULL );
+  BODY* tbody = NULL;
+  BODY* bbody = NULL;    // Blank body
+  FACE* bface = NULL;    // Blank face
+  surface* tsurf = NULL; // Tool surface
+  EDGE* edge = NULL;
-      // Create the tool body which consists of a single face
-      // with a "cross surface" geometric support and no loops.
-      const curve &temp_cur = edge->geometry()->equation();
-      SPAinterval cur_range = temp_cur.param_range();
-      SPAinterval edge_range = edge->param_range();
-      if (edge->sense() == REVERSED)
-	edge_range = -edge_range;
-      if (edge_range == cur_range)
-	tsurf = cross_surface( edge->geometry()->equation(),
-			       bsurf, *(pcurve*) NULL_REF);
-      else
-	  // Create using a subsetted copy of the curve
-	  curve* subset_cur = temp_cur.subset(edge_range&cur_range);
-	  tsurf = cross_surface( *subset_cur, bsurf, *(pcurve*) NULL_REF);
-	  ACIS_DELETE subset_cur;
-      if( !tsurf )
-	  PRINT_ERROR( "Unable to make imprint surface on body\n" );
-      FACE* tface = ACIS_NEW FACE( NULL, NULL, make_surface( *tsurf ), FORWARD );
-      ACIS_DELETE tsurf; // SRS Added 10-29-99
-      tbody->set_lump( ACIS_NEW LUMP( ACIS_NEW SHELL( tface, NULL, NULL ), NULL ) );
+  //EXCEPTION_TRY
-      // Now, imprint the two bodies and throw away the tool body. The
-      // resultant blank body will have the edge imprinted on the
-      // selected face.
-      EDGE* ssi_edges[1];
-      FACE* tfaces[1];
-      FACE* bfaces[1];
+  bbody = BODY_ptr;
+  bface = FACE_ptr;
+  edge = EDGE_ptr;
-      ssi_edges[0] = edge;
-      tfaces[0] = tface;
-      bfaces[0] = bface;
+  // Get the geometry of the blank face.
+  surface const& bsurf = bface->geometry()->equation();
-      result = api_boolean_start( tbody, bbody );
+  // Create an empty tool body
+  tbody = ACIS_NEW BODY( (LUMP*) NULL );
-      if( result.ok() )
-	  // If the edge is known to lie on the face, some expensive
-	  // checking can be ommited by changing the last argument from
-	  // TRUE to FALSE.
-	  result = api_update_intersection( tface, *(SPAtransf *)NULL_REF, bface,
-					    *(SPAtransf *)NULL_REF, 1, ssi_edges, TRUE);
+  // Create the tool body which consists of a single face
+  // with a "cross surface" geometric support and no loops.
+  const curve &temp_cur = edge->geometry()->equation();
+  SPAinterval cur_range = temp_cur.param_range();
+  SPAinterval edge_range = edge->param_range();
+  if (edge->sense() == REVERSED)
+    edge_range = -edge_range;
+  if (edge_range == cur_range)
+    tsurf = cross_surface( edge->geometry()->equation(),
+    bsurf, *(pcurve*) NULL_REF);
+  else
+    // Create using a subsetted copy of the curve
+    curve* subset_cur = temp_cur.subset(edge_range&cur_range);
+    tsurf = cross_surface( *subset_cur, bsurf, *(pcurve*) NULL_REF);
+    ACIS_DELETE subset_cur;
+  if( !tsurf )
+    PRINT_ERROR( "Unable to make imprint surface on body\n" );
+  FACE* tface = ACIS_NEW FACE( NULL, NULL, make_surface( *tsurf ), FORWARD );
+  ACIS_DELETE tsurf; // SRS Added 10-29-99
+  tbody->set_lump( ACIS_NEW LUMP( ACIS_NEW SHELL( tface, NULL, NULL ), NULL ) );
-	  if( result.ok() )
-	      result = api_selectively_intersect( 1, tfaces, bfaces );
-	      if( result.ok() )
-		  result = api_imprint_complete( tbody, bbody );
-		      PRINT_ERROR( "problem in completing imprint for curve on surface\n" );
-		      api_delent( tbody );
-	      else
-		  PRINT_ERROR( "problem in selective intersect for curve on surface\n" );
-	  else if( result.error_number()!=200 && result.error_number()!=615
-		   && result.error_number()!=715 )
-	      // Error 200 can occur when the imprint does nothing (curve that's
-	      // a surface boundary, curve away from surface).  Errors 615/715 can occur
-	      // when imprinting a remnant of the same FACE again with the same curve.
-	      // The orignal FACE_ptr remains after an imprint - it lives as one
-	      // of the remnants.  Then, when we attempt to imprint the other pieces
-	      // with the same curves, we are getting error 715.  The same error
-	      // can occur when trying to use one of the surfaces own edges to
-	      // imprint with.  This has been reported to Spatial and logged as r6294.
-	      // It's not fatal so for now we ignore it.
+  // Now, imprint the two bodies and throw away the tool body. The
+  // resultant blank body will have the edge imprinted on the
+  // selected face.
+  EDGE* ssi_edges[1];
+  FACE* tfaces[1];
+  FACE* bfaces[1];
-	      // We get these all the time, and they don't seem to hurt us.
-      else
-	  PRINT_ERROR( "problem starting boolean for curve on surface\n" );
+  ssi_edges[0] = edge;
+  tfaces[0] = tface;
+  bfaces[0] = bface;
-      //EXCEPTION_CATCH(TRUE)
+  result = api_boolean_start( tbody, bbody );
-      // Remove temporary objects
+  if( result.ok() )
+    // If the edge is known to lie on the face, some expensive
+    // checking can be ommited by changing the last argument from
+    // TRUE to FALSE.
+    result = api_update_intersection( tface, *(SPAtransf *)NULL_REF, bface,
+      *(SPAtransf *)NULL_REF, 1, ssi_edges, TRUE);
-      //EXCEPTION_END
+    if( result.ok() )
+      result = api_selectively_intersect( 1, tfaces, bfaces );
+      if( result.ok() )
+        result = api_imprint_complete( tbody, bbody );
+          PRINT_ERROR( "problem in completing imprint for curve on surface\n" );
+          api_delent( tbody );
+      else
+        PRINT_ERROR( "problem in selective intersect for curve on surface\n" );
+    else if( result.error_number()!=200 && result.error_number()!=615
+      && result.error_number()!=715 )
+      // Error 200 can occur when the imprint does nothing (curve that's
+      // a surface boundary, curve away from surface).  Errors 615/715 can occur
+      // when imprinting a remnant of the same FACE again with the same curve.
+      // The orignal FACE_ptr remains after an imprint - it lives as one
+      // of the remnants.  Then, when we attempt to imprint the other pieces
+      // with the same curves, we are getting error 715.  The same error
+      // can occur when trying to use one of the surfaces own edges to
+      // imprint with.  This has been reported to Spatial and logged as r6294.
+      // It's not fatal so for now we ignore it.
+      // We get these all the time, and they don't seem to hurt us.
+  else
+    PRINT_ERROR( "problem starting boolean for curve on surface\n" );
-  //- Imprints a list of Surfaces with list of Curves, sorted per
-  //- Surface (ie., curve_lists_list is same length as surface_list).
-  //- This version is more efficient than the general-purpose one
-  //- above, as we know which curves to imprint with which surfaces.
-  //- All input surfaces must be from the same body.
-					 DLIList<DLIList<Curve*>*> &curve_lists_list,
-					 BodySM*& new_body,
-      // Calling code has already ensured that all the Surfaces are from the
-      // same body
+  //EXCEPTION_CATCH(TRUE)
+  // Remove temporary objects
-      SurfaceACIS* surf_ptr = dynamic_cast<SurfaceACIS*>(surface_list.get());
-      if( surf_ptr == NULL )
-      FACE *FACE_ptr = surf_ptr->get_FACE_ptr();
-      if (!FACE_ptr)
-	  PRINT_ERROR("Invalid SurfaceACIS (no FACE ptr) at %s:%d\n",__FILE__,__LINE__);
-      BODY *BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY( FACE_ptr );
-      BodySM *body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY( FACE_ptr );
-      if( body_ptr == NULL )
+  //EXCEPTION_END
-      int i, j;
-      EDGE *EDGE_ptr;
-      DLIList<DLIList<EDGE*>*> EDGE_lists_list;
-      DLIList<EDGE*> *EDGE_list_ptr;
-      DLIList<SurfaceACIS*> surf_ACIS_list;
-      surface_list.reset();
-      curve_lists_list.reset();
-      for( i=surface_list.size(); i--; )
-	  surf_ptr = dynamic_cast<SurfaceACIS*>(surface_list.get_and_step());
-	  if (!surf_ptr)
-	      PRINT_ERROR("Non-ACIS surface at %s: %d\n",__FILE__,__LINE__);
-	  surf_ACIS_list.append( surf_ptr );
+//- Imprints a list of Surfaces with list of Curves, sorted per
+//- Surface (ie., curve_lists_list is same length as surface_list).
+//- This version is more efficient than the general-purpose one
+//- above, as we know which curves to imprint with which surfaces.
+//- All input surfaces must be from the same body.
+                                       DLIList<DLIList<Curve*>*> &curve_lists_list,
+                                       BodySM*& new_body,
+  // Calling code has already ensured that all the Surfaces are from the
+  // same body
-	  // Make sure there is a FACE associated with this SurfaceACIS
-	  FACE_ptr = surf_ptr->get_FACE_ptr();
-	  if (!FACE_ptr)
-	  EDGE_list_ptr = new DLIList<EDGE*>;
-	  EDGE_lists_list.append( EDGE_list_ptr );
+  SurfaceACIS* surf_ptr = dynamic_cast<SurfaceACIS*>(surface_list.get());
+  if( surf_ptr == NULL )
+  FACE *FACE_ptr = surf_ptr->get_FACE_ptr();
+  if (!FACE_ptr)
+    PRINT_ERROR("Invalid SurfaceACIS (no FACE ptr) at %s:%d\n",__FILE__,__LINE__);
+  BODY *BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY( FACE_ptr );
+  BodySM *body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY( FACE_ptr );
+  if( body_ptr == NULL )
-	  DLIList<Curve*> *curve_list_ptr = curve_lists_list.get_and_step();
-	  curve_list_ptr->reset();
-	  for( j=curve_list_ptr->size(); j--; )
-	      Curve *curve_ptr = curve_list_ptr->get_and_step();
-	      CurveACIS* curve_acis_ptr = dynamic_cast<CurveACIS*>(curve_ptr);
-	      if (!curve_acis_ptr)
-		  PRINT_ERROR("Non-ACIS curve at %s: %d\n",__FILE__,__LINE__);
-	      EDGE_ptr = curve_acis_ptr->get_EDGE_ptr();
-		  PRINT_ERROR("Invalid CurveACIS (no EDGE ptr) at %s:%d\n",__FILE__,__LINE__);
-	      EDGE_list_ptr->append( EDGE_ptr );
+  int i, j;
+  EDGE *EDGE_ptr;
+  DLIList<DLIList<EDGE*>*> EDGE_lists_list;
+  DLIList<EDGE*> *EDGE_list_ptr;
+  DLIList<SurfaceACIS*> surf_ACIS_list;
-      // Copy the BODY and get the corresponding FACEs on the copied BODY that need
-      // to be imprinted
-      DLIList<FACE*> copied_FACE_list;
-      if( get_copied_FACES_of_body( surf_ACIS_list, copied_FACE_list, copied_BODY_ptr )
-	  == CUBIT_FAILURE )
+  surface_list.reset();
+  curve_lists_list.reset();
+  for( i=surface_list.size(); i--; )
+    surf_ptr = dynamic_cast<SurfaceACIS*>(surface_list.get_and_step());
+    if (!surf_ptr)
+      PRINT_ERROR("Non-ACIS surface at %s: %d\n",__FILE__,__LINE__);
+    surf_ACIS_list.append( surf_ptr );
+    // Make sure there is a FACE associated with this SurfaceACIS
+    FACE_ptr = surf_ptr->get_FACE_ptr();
+    if (!FACE_ptr)
-      // Imprint the temporary EDGEs to the FACEs
-      if( imprint( copied_BODY_ptr, copied_FACE_list, EDGE_lists_list ) == CUBIT_FAILURE )
-	  while( EDGE_lists_list.size() ) delete EDGE_lists_list.pop();
-      new_body = get_new_Body( body_ptr, BODY_ptr, copied_BODY_ptr, false);
+    EDGE_list_ptr = new DLIList<EDGE*>;
+    EDGE_lists_list.append( EDGE_list_ptr );
-      for (int edge_count = new_edges.size(); edge_count-- && new_body; )
+    DLIList<Curve*> *curve_list_ptr = curve_lists_list.get_and_step();
+    curve_list_ptr->reset();
+    for( j=curve_list_ptr->size(); j--; )
+      Curve *curve_ptr = curve_list_ptr->get_and_step();
+      CurveACIS* curve_acis_ptr = dynamic_cast<CurveACIS*>(curve_ptr);
+      if (!curve_acis_ptr)
+        PRINT_ERROR("Non-ACIS curve at %s: %d\n",__FILE__,__LINE__);
+      EDGE_ptr = curve_acis_ptr->get_EDGE_ptr();
+        PRINT_ERROR("Invalid CurveACIS (no EDGE ptr) at %s:%d\n",__FILE__,__LINE__);
+      EDGE_list_ptr->append( EDGE_ptr );
-      // Free memory allocated in EDGE_lists_list
+  // Copy the BODY and get the corresponding FACEs on the copied BODY that need
+  // to be imprinted
+  DLIList<FACE*> copied_FACE_list;
+  if( get_copied_FACES_of_body( surf_ACIS_list, copied_FACE_list, copied_BODY_ptr )
+    == CUBIT_FAILURE )
-      return new_body ? CUBIT_SUCCESS : CUBIT_FAILURE;
-  DLIList<EDGE*> AcisModifyEngine::find_new_EDGES(BODY *copied_BODY_ptr)
+  // Imprint the temporary EDGEs to the FACEs
+  if( imprint( copied_BODY_ptr, copied_FACE_list, EDGE_lists_list ) == CUBIT_FAILURE )
+    while( EDGE_lists_list.size() ) delete EDGE_lists_list.pop();
+  new_body = get_new_Body( body_ptr, BODY_ptr, copied_BODY_ptr, false);
+  for (int edge_count = new_edges.size(); edge_count-- && new_body; )
+  // Free memory allocated in EDGE_lists_list
+  return new_body ? CUBIT_SUCCESS : CUBIT_FAILURE;
+DLIList<EDGE*> AcisModifyEngine::find_new_EDGES(BODY *copied_BODY_ptr)
+    DLIList<EDGE*> return_list;
+    ENTITY_LIST edge_list;
+    api_get_edges(copied_BODY_ptr, edge_list);
+    AcisBridge *ab_edge_ptr = NULL;
+    for(int i=0; i<edge_list.count(); i++)
-      DLIList<EDGE*> return_list;
-      ENTITY_LIST edge_list;
-      api_get_edges(copied_BODY_ptr, edge_list);
-      AcisBridge *ab_edge_ptr = NULL;
-      for(int i=0; i<edge_list.count(); i++)
-	  ab_edge_ptr = ATTRIB_CUBIT_OWNER::cubit_owner( edge_list[i] );
-	  if( !ab_edge_ptr )
-	      return_list.append((EDGE*)edge_list[i]);
-	      //AcisDrawTool::instance()->draw_EDGE( (EDGE*)edge_list[i], CUBIT_BLUE );
-      return return_list;
+        ab_edge_ptr = ATTRIB_CUBIT_OWNER::cubit_owner( edge_list[i] );
+        if( !ab_edge_ptr )
+            return_list.append((EDGE*)edge_list[i]);
+            //AcisDrawTool::instance()->draw_EDGE( (EDGE*)edge_list[i], CUBIT_BLUE );
+    // GfxDebug::flush();
+    return return_list;
-  // This version is more efficient if it is known exactly which EDGEs
-  // need to be imprinted with which FACEs (ie., it does not attempt to
-  // imprint all input EDGEs to all input FACEs - only those in corresponding
-  // list positions)
-					 DLIList<DLIList<EDGE*>*> &EDGE_lists_list ) const
-      outcome result;
-      FACE *FACE_ptr = 0;
-      EDGE *EDGE_ptr = 0;
+// This version is more efficient if it is known exactly which EDGEs
+// need to be imprinted with which FACEs (ie., it does not attempt to
+// imprint all input EDGEs to all input FACEs - only those in corresponding
+// list positions)
+                                       DLIList<DLIList<EDGE*>*> &EDGE_lists_list ) const
+  outcome result;
+  FACE *FACE_ptr = 0;
+  EDGE *EDGE_ptr = 0;
-      int i, j, k, m;
+  int i, j, k, m;
-      EDGE_lists_list.reset();
-      for( i=EDGE_lists_list.size(); i--; )
-	  EDGE_list_ptr = EDGE_lists_list.get_and_step();
+  EDGE_lists_list.reset();
+  for( i=EDGE_lists_list.size(); i--; )
+    EDGE_list_ptr = EDGE_lists_list.get_and_step();
-	  DLIList<FACE*> temp_FACE_list;
-	  temp_FACE_list.append( FACE_ptr );
+    DLIList<FACE*> temp_FACE_list;
+    temp_FACE_list.append( FACE_ptr );
-	  EDGE_list_ptr->reset();
-	  for( j=EDGE_list_ptr->size(); j--; )
-	      // Imprint this edge list selectively to the current FACE
-	      EDGE_ptr = EDGE_list_ptr->get_and_step();
+    EDGE_list_ptr->reset();
+    for( j=EDGE_list_ptr->size(); j--; )
+      // Imprint this edge list selectively to the current FACE
+      EDGE_ptr = EDGE_list_ptr->get_and_step();
-	      temp_FACE_list.reset();
-	      for( k=0; k<temp_FACE_list.size(); k++ )
-		  FACE_ptr = temp_FACE_list.get_and_step();
+      temp_FACE_list.reset();
+      for( k=0; k<temp_FACE_list.size(); k++ )
+        FACE_ptr = temp_FACE_list.get_and_step();
-		  FACES_BEFORE.clean_out();
+        FACES_BEFORE.clean_out();
-		      continue;
+          continue;
-		  // temp_FACE_list so that additional edges will imprint
-		  for( m=FACES_AFTER.size(); m--; )
+        // temp_FACE_list so that additional edges will imprint
+        for( m=FACES_AFTER.size(); m--; )
-		  temp_FACE_list += new_FACES;
+        temp_FACE_list += new_FACES;
-		  // Set list back to correct location
-		  temp_FACE_list.move_to( FACE_ptr );
-		  temp_FACE_list.step();
-		} // End of looping over temp_FACE_list
+        // Set list back to correct location
+        temp_FACE_list.move_to( FACE_ptr );
+        temp_FACE_list.step();
+     } // End of looping over temp_FACE_list
-  // Imprints locations to bodies (for splitting curves or putting hardpoints
-  // on surfaces).
-					 DLIList<CubitVector*> &vector_list,
-					 DLIList<TopologyBridge*> *new_tbs,
-					 DLIList<TopologyBridge*> *att_tbs ) const
-      // Until Spatial fixes imprinting with vertices, implement a hack
-      // (Steve Storm, Caterpillar Inc.)
-      int i, j, k;
-      outcome result;
-      double tol = 1e-3;
-      //CubitStatus status = CUBIT_SUCCESS;
+// Imprints locations to bodies (for splitting curves or putting hardpoints
+// on surfaces).
+                                       DLIList<CubitVector*> &vector_list,
+                                       DLIList<TopologyBridge*> *new_tbs,
+                                       DLIList<TopologyBridge*> *att_tbs ) const
+   // Until Spatial fixes imprinting with vertices, implement a hack
+   // (Steve Storm, Caterpillar Inc.)
+   int i, j, k;
+   outcome result;
+   double tol = 1e-3;
+   //CubitStatus status = CUBIT_SUCCESS;
-      CubitVector* vector_ptr;
-      BodySM *body_ptr;
+   CubitVector* vector_ptr;
+   BodySM *body_ptr;
-      VERTEX *VERTEX_ptr;
-      EDGE *EDGE_ptr;
-      FACE *FACE_ptr;
+   VERTEX *VERTEX_ptr;
+   EDGE *EDGE_ptr;
+   FACE *FACE_ptr;
-      BODY *BODY_ptr;
+   BODY *BODY_ptr;
-      //CubitVector vertex_coords;
+   //CubitVector vertex_coords;
-      // Set an option for imprinting
+   // Set an option for imprinting
-      // new_ENTITIES will hold new entities that were created by
-      // the imprint operation.  att_ENTITIES will hold entities
-      // from the original bodies that had composite attributes
-      // on them.  At the end we will compare the new entities
-      // with the ones that had attributes and if we find matches
-      // we will put a composite attribute on the new entity.
-      // This is how we are handling the imprinting of bodies
-      // with composites.
-      DLIList<ENTITY*> new_ENTITIES;
-      DLIList<ENTITY*> att_ENTITIES;
+  // new_ENTITIES will hold new entities that were created by
+  // the imprint operation.  att_ENTITIES will hold entities
+  // from the original bodies that had composite attributes
+  // on them.  At the end we will compare the new entities
+  // with the ones that had attributes and if we find matches
+  // we will put a composite attribute on the new entity.
+  // This is how we are handling the imprinting of bodies
+  // with composites.
+  DLIList<ENTITY*> new_ENTITIES;
+  DLIList<ENTITY*> att_ENTITIES;
-      body_list.reset();
+   body_list.reset();
-	  BODY_ptr = AcisQueryEngine::get_BODY( body_ptr );
+      BODY_ptr = AcisQueryEngine::get_BODY( body_ptr );
-	  // Get all the vertices of the BODY
-	  DLIList<VERTEX*> VERTEX_list;
-	  AcisQueryEngine::instance()->get_VERTICEs( (ENTITY*)BODY_ptr, VERTEX_list );
+      // Get all the vertices of the BODY
+      DLIList<VERTEX*> VERTEX_list;
+      AcisQueryEngine::instance()->get_VERTICEs( (ENTITY*)BODY_ptr, VERTEX_list );
-	  // Get all the FACES of the *original* BODY
-	  DLIList<FACE*> FACE_list;
-	  AcisQueryEngine::instance()->get_FACEs( (ENTITY*)BODY_ptr, FACE_list );
+      // Get all the FACES of the *original* BODY
+      DLIList<FACE*> FACE_list;
+      AcisQueryEngine::instance()->get_FACEs( (ENTITY*)BODY_ptr, FACE_list );
-	  // Loop through the passed-in locations, first checking for coincidence
-	  // w/vertices, then if on curves, then on faces.
-	  vector_list.reset();
-	  for( j=0; j<vector_list.size(); j++ )
-	      vector_ptr = vector_list.get_and_step();
-	      SPAposition test_point( vector_ptr->x(), vector_ptr->y(), vector_ptr->z() );
+      // Loop through the passed-in locations, first checking for coincidence
+      // w/vertices, then if on curves, then on faces.
+      vector_list.reset();
+      for( j=0; j<vector_list.size(); j++ )
+         vector_ptr = vector_list.get_and_step();
+         SPAposition test_point( vector_ptr->x(), vector_ptr->y(), vector_ptr->z() );
-	      CubitBoolean on_vertex = CUBIT_FALSE;
-	      VERTEX_list.reset();
-	      for( k=0; k<VERTEX_list.size(); k++ )
-		  VERTEX_ptr = VERTEX_list.get_and_step();
+         CubitBoolean on_vertex = CUBIT_FALSE;
+         VERTEX_list.reset();
+         for( k=0; k<VERTEX_list.size(); k++ )
+            VERTEX_ptr = VERTEX_list.get_and_step();
-		  SPAposition VERTEX_coords = VERTEX_ptr->geometry()->coords();
+            SPAposition VERTEX_coords = VERTEX_ptr->geometry()->coords();
-		  if (( fabs(VERTEX_coords.x() - vector_ptr->x()) < tol) &&
-		      ( fabs(VERTEX_coords.y() - vector_ptr->y()) < tol) &&
-		      ( fabs(VERTEX_coords.z() - vector_ptr->z()) < tol))
-		      on_vertex = CUBIT_TRUE;
-		      break; // Skip - coincident with a vertex
+            if (( fabs(VERTEX_coords.x() - vector_ptr->x()) < tol) &&
+               ( fabs(VERTEX_coords.y() - vector_ptr->y()) < tol) &&
+               ( fabs(VERTEX_coords.z() - vector_ptr->z()) < tol))
+               on_vertex = CUBIT_TRUE;
+               break; // Skip - coincident with a vertex
-	      if( on_vertex )
-		continue; // No imprinting necessary
+         if( on_vertex )
+            continue; // No imprinting necessary
-	      // Get all the EDGES of the copied BODY
-	      AcisQueryEngine::instance()->get_EDGEs( (ENTITY*)copied_BODY_ptr, EDGE_list );
+         // Get all the EDGES of the copied BODY
+         AcisQueryEngine::instance()->get_EDGEs( (ENTITY*)copied_BODY_ptr, EDGE_list );
-	      // Check the EDGES
-	      CubitBoolean on_edge = CUBIT_FALSE;
-	      for( k=0; k<EDGE_list.size(); k++ )
+         // Check the EDGES
+         CubitBoolean on_edge = CUBIT_FALSE;
+         for( k=0; k<EDGE_list.size(); k++ )
-		  if (EDGE_ptr->geometry() == NULL)
-		    continue; // Check next edge
+            if (EDGE_ptr->geometry() == NULL)
+               continue; // Check next edge
-		  //const curve* acis_curve = &EDGE_ptr->geometry()->equation();
+            //const curve* acis_curve = &EDGE_ptr->geometry()->equation();
-		  SPAtransf ftrans;
+            SPAtransf ftrans;
-		  point_edge_containment pe_rel;
+            point_edge_containment pe_rel;
-		  ENTITY *ENTITY_ptr = NULL;
-		  SPAparameter param;
+            ENTITY *ENTITY_ptr = NULL;
+            SPAparameter param;
-		  pe_rel = sg_point_in_edge( test_point, EDGE_ptr, ftrans, ENTITY_ptr, param );
+            pe_rel = sg_point_in_edge( test_point, EDGE_ptr, ftrans, ENTITY_ptr, param );
-		  if( pe_rel == point_off_edge )
-		  else if( pe_rel == point_on_edge )
-		      on_edge = CUBIT_TRUE;
-		      VERTEX *new_vertex = ACIS_NEW VERTEX( ACIS_NEW APOINT( test_point) );
+            if( pe_rel == point_off_edge )
+            else if( pe_rel == point_on_edge )
+              on_edge = CUBIT_TRUE;
+              VERTEX *new_vertex = ACIS_NEW VERTEX( ACIS_NEW APOINT( test_point) );
-		      API_BEGIN;
-		      sg_split_edge_at_vertex( EDGE_ptr, new_vertex );
-		      API_END;
+              API_BEGIN;
+              sg_split_edge_at_vertex( EDGE_ptr, new_vertex );
+              API_END;
-			  AcisQueryEngine::instance()->ACIS_API_error(result);
-			  PRINT_ERROR( "problem imprinting curve onto volume\n");
+                AcisQueryEngine::instance()->ACIS_API_error(result);
+                PRINT_ERROR( "problem imprinting curve onto volume\n");
-		      break;
+              break;
-	      if( on_edge )
-		continue; // Already imprinted onto the body - check next vertex
+         if( on_edge )
+            continue; // Already imprinted onto the body - check next vertex
-	      // Check the FACES
-	      for( k=0; k<FACE_list.size(); k++ )
+         // Check the FACES
+         for( k=0; k<FACE_list.size(); k++ )
-		  if (FACE_ptr->geometry() == NULL)
-		    continue; // Check next face
+            if (FACE_ptr->geometry() == NULL)
+               continue; // Check next face
-		  SPAtransf ftrans;
+            SPAtransf ftrans;
-		  point_face_containment pf_rel = point_in_face( test_point, FACE_ptr, ftrans );
-		  if( pf_rel == point_outside_face )
-		  else if( pf_rel == point_inside_face )
-		      // Create a short curve normal to the surface at the vertex and imprint it
-		      SPAunit_vector norm;
-		      norm = FACE_ptr->geometry()->equation().point_normal( test_point );
+            point_face_containment pf_rel = point_in_face( test_point, FACE_ptr, ftrans );
+            if( pf_rel == point_outside_face )
+            else if( pf_rel == point_inside_face )
+               // Create a short curve normal to the surface at the vertex and imprint it
+               SPAunit_vector norm;
+               norm = FACE_ptr->geometry()->equation().point_normal( test_point );
-		      if ( FACE_ptr->sense() == REVERSED )
-			norm = -norm;
+               if ( FACE_ptr->sense() == REVERSED )
+                  norm = -norm;
-		      // Find the end point
-		      SPAposition end_point;
-		      end_point.set_x( test_point.x() + (tol * norm.x()) );
-		      end_point.set_y( test_point.y() + (tol * norm.y()) );
-		      end_point.set_z( test_point.z() + (tol * norm.z()) );
+               // Find the end point
+               SPAposition end_point;
+               end_point.set_x( test_point.x() + (tol * norm.x()) );
+               end_point.set_y( test_point.y() + (tol * norm.y()) );
+               end_point.set_z( test_point.z() + (tol * norm.z()) );
-		      // Create the curve
-		      EDGE* new_EDGE_ptr = NULL;
-		      result = api_mk_ed_line ( test_point, end_point, new_EDGE_ptr );
-		      if (!result.ok() || new_EDGE_ptr == NULL)
-			  PRINT_WARNING("Unable to make short normal curve for imprint operation\n" );
-			  continue;
+               // Create the curve
+               EDGE* new_EDGE_ptr = NULL;
+               result = api_mk_ed_line ( test_point, end_point, new_EDGE_ptr );
+               if (!result.ok() || new_EDGE_ptr == NULL)
+                  PRINT_WARNING("Unable to make short normal curve for imprint operation\n" );
+                  continue;
-		      // Create a wire from the short curve
-		      BODY *wire_BODY_ptr = NULL;
-		      result = api_make_ewire( 1, &new_EDGE_ptr, wire_BODY_ptr );
-		      if (!result.ok())
-			  PRINT_WARNING( "Unable to make ACIS WIRE from short imprint curve\n" );
+               // Create a wire from the short curve
+               BODY *wire_BODY_ptr = NULL;
+               result = api_make_ewire( 1, &new_EDGE_ptr, wire_BODY_ptr );
+               if (!result.ok())
+                  PRINT_WARNING( "Unable to make ACIS WIRE from short imprint curve\n" );
-			  if( wire_BODY_ptr )
-			    api_delent( wire_BODY_ptr );
-			  else
-			    api_delent( new_EDGE_ptr );
-			  continue;
+                  if( wire_BODY_ptr )
+                     api_delent( wire_BODY_ptr );
+                  else
+                     api_delent( new_EDGE_ptr );
+                  continue;
-		      // Imprint the wire-body onto the BODY
+               // Imprint the wire-body onto the BODY
-			  PRINT_ERROR( "problem imprinting short curve onto volume\n");
+                  PRINT_ERROR( "problem imprinting short curve onto volume\n");
-		      break; // Done imprinting with this vertex
+               break; // Done imprinting with this vertex
-		  else if( pf_rel == point_boundary_face )
-		      PRINT_WARNING( "Algorithm error - point found on boundary of surface - please report this\n" );
-		      continue;
-		  else if( pf_rel == point_unknown_face )
+            else if( pf_rel == point_boundary_face )
+               PRINT_WARNING( "Algorithm error - point found on boundary of surface - please report this\n" );
+               continue;
+            else if( pf_rel == point_unknown_face )
-	  // Get the new entities (just edges for now)
-	  // created by the imprint operation.
-	  DLIList<ENTITY*> cur_new_ENTITIES;
-	  if(copied_BODY_ptr && new_tbs)
-	    get_new_ENTITIES(copied_BODY_ptr, cur_new_ENTITIES);
+      // Get the new entities (just edges for now)
+      // created by the imprint operation.
+      DLIList<ENTITY*> cur_new_ENTITIES;
+      if(copied_BODY_ptr && new_tbs)
+        get_new_ENTITIES(copied_BODY_ptr, cur_new_ENTITIES);
-					       copied_BODY_ptr, keep_old_body, CUBIT_TRUE );
-	  if (new_body_ptr)
+                               copied_BODY_ptr, keep_old_body, CUBIT_TRUE );
+      if (new_body_ptr)
-	      // Add the new entities to the list we are
-	      // accumulating.
-	      if(new_tbs)
-		new_ENTITIES += cur_new_ENTITIES;
+        // Add the new entities to the list we are
+        // accumulating.
+        if(new_tbs)
+          new_ENTITIES += cur_new_ENTITIES;
-	      // Get entities with composite attributes.
-	      if(copied_BODY_ptr && att_tbs)
-		get_att_ENTITIES(copied_BODY_ptr, att_ENTITIES, "COMPOSITE_GEOM");
+        // Get entities with composite attributes.
+        if(copied_BODY_ptr && att_tbs)
+          get_att_ENTITIES(copied_BODY_ptr, att_ENTITIES, "COMPOSITE_GEOM");
-	  else
-	      if(att_tbs)
-		get_att_ENTITIES(BODY_ptr, att_ENTITIES, "COMPOSITE_GEOM");
+      else
+        if(att_tbs)
+          get_att_ENTITIES(BODY_ptr, att_ENTITIES, "COMPOSITE_GEOM");
-      // Convert the new_ENTITIES/att_ENTITIES lists into
-      // topology bridge lists.
-      if(new_tbs)
-	  for(i=new_ENTITIES.size(); i--;)
-	      ENTITY *cur_ENT = new_ENTITIES.get_and_step();
-	      AcisBridge *acis_bridge = ATTRIB_CUBIT_OWNER::cubit_owner(cur_ENT);
-	      if(dynamic_cast<TopologyBridge*>(acis_bridge))
-		new_tbs->append_unique(dynamic_cast<TopologyBridge*>(acis_bridge));
-      if(att_tbs)
-	  for(i=att_ENTITIES.size(); i--;)
-	      ENTITY *cur_ENT = att_ENTITIES.get_and_step();
-		att_tbs->append_unique(dynamic_cast<TopologyBridge*>(acis_bridge));
+    // Convert the new_ENTITIES/att_ENTITIES lists into
+    // topology bridge lists.
+    if(new_tbs)
+      for(i=new_ENTITIES.size(); i--;)
+        ENTITY *cur_ENT = new_ENTITIES.get_and_step();
+        AcisBridge *acis_bridge = ATTRIB_CUBIT_OWNER::cubit_owner(cur_ENT);
+        if(dynamic_cast<TopologyBridge*>(acis_bridge))
+          new_tbs->append_unique(dynamic_cast<TopologyBridge*>(acis_bridge));
+    if(att_tbs)
+      for(i=att_ENTITIES.size(); i--;)
+        ENTITY *cur_ENT = att_ENTITIES.get_and_step();
+          att_tbs->append_unique(dynamic_cast<TopologyBridge*>(acis_bridge));
-      // When Spatial gets vertex body to body imprinting working, you should be
-      // able to replace all of the above code with this code.
+// When Spatial gets vertex body to body imprinting working, you should be
+// able to replace all of the above code with this code.
 #if 0
-      int i, j;
-      outcome result;
+   int i, j;
+   outcome result;
-      RefVertex* ref_vertex_ptr;
-      Body *body_ptr;
+   RefVertex* ref_vertex_ptr;
+   Body *body_ptr;
-      BODY *BODY_ptr;
+   BODY *BODY_ptr;
-      CubitVector vertex_coords;
-      BODY* vertex_BODY_ptr;
-      DLIList<BODY*> vertex_BODY_list;
+   CubitVector vertex_coords;
+   BODY* vertex_BODY_ptr;
+   DLIList<BODY*> vertex_BODY_list;
-      bool delete_attribs =
-	(GeometryModifyTool::instance()->new_ids() || keep_old_body);
+   bool delete_attribs =
+      (GeometryModifyTool::instance()->new_ids() || keep_old_body);
-      // Create a list of BODYs that consist of single points.  These
-      // will be used for imprinting onto the BODYs.
-      SPAposition acis_position[1];
-      for( i=0; i<vector_list.size(); i++ )
+   // Create a list of BODYs that consist of single points.  These
+   // will be used for imprinting onto the BODYs.
+   SPAposition acis_position[1];
+   for( i=0; i<vector_list.size(); i++ )
-	  acis_position[0].set_x( vector_ptr->x() );
-	  acis_position[0].set_y( vector_ptr->y() );
-	  acis_position[0].set_z( vector_ptr->z() );
+      acis_position[0].set_x( vector_ptr->x() );
+      acis_position[0].set_y( vector_ptr->y() );
+      acis_position[0].set_z( vector_ptr->z() );
-	  result = api_make_wire( NULL, 1, acis_position, vertex_BODY_ptr );
-	      PRINT_ERROR( "unable to make degenerate wire body from location %f, %f, %f; aborting\n",
-			   vector_ptr->x(), vector_ptr->y(), vector_ptr->z() );
-	      for( j=0; j<vertex_BODY_list.size(); j++ )
-		api_delent( vertex_BODY_list.get_and_step() );
-	      return CUBIT_FAILURE;
+      result = api_make_wire( NULL, 1, acis_position, vertex_BODY_ptr );
+         PRINT_ERROR( "unable to make degenerate wire body from location %f, %f, %f; aborting\n",
+                      vector_ptr->x(), vector_ptr->y(), vector_ptr->z() );
+         for( j=0; j<vertex_BODY_list.size(); j++ )
+            api_delent( vertex_BODY_list.get_and_step() );
+         return CUBIT_FAILURE;
-	  vertex_BODY_list.append( vertex_BODY_ptr );
+      vertex_BODY_list.append( vertex_BODY_ptr );
-      // Loop on bodies, imprinting each with all the vertex BODYs.
+   // Loop on bodies, imprinting each with all the vertex BODYs.
-	      //NOTE TO JS
-	      PRINT_ERROR( "Unable to get ACIS BODY from Body %d; aborting\n",
-			   body_ptr->id() );
+//NOTE TO JS
+         PRINT_ERROR( "Unable to get ACIS BODY from Body %d; aborting\n",
+            body_ptr->id() );
-	  vertex_BODY_list.reset();
-	  for( i=0; i<vertex_BODY_list.size(); i++ )
-	      vertex_BODY_ptr = vertex_BODY_list.get_and_step();
+      vertex_BODY_list.reset();
+      for( i=0; i<vertex_BODY_list.size(); i++ )
+         vertex_BODY_ptr = vertex_BODY_list.get_and_step();
-	      result = api_imprint( vertex_BODY_ptr, copied_BODY_ptr );
+         result = api_imprint( vertex_BODY_ptr, copied_BODY_ptr );
-		  //NOTE to JS
-		  PRINT_ERROR( "problem imprinting location %f, %f, %f to body %d\n",
-			       vector_ptr->x(), vector_ptr->y(), vector_ptr->z(),
-			       body_ptr->id() );
+//NOTE to JS
+            PRINT_ERROR( "problem imprinting location %f, %f, %f to body %d\n",
+                         vector_ptr->x(), vector_ptr->y(), vector_ptr->z(),
+                         body_ptr->id() );
-	  Body* new_body_ptr = get_new_Body( body_ptr, BODY_ptr, copied_BODY_ptr,
+      Body* new_body_ptr = get_new_Body( body_ptr, BODY_ptr, copied_BODY_ptr,
-	  if( new_body_ptr!=NULL && new_body_ptr!=body_ptr )
-	      //NOTE TO JS
-	      PRINT_INFO( "Created new body %d\n", new_body_ptr->id() );
-	  else if( new_body_ptr!=NULL && new_body_ptr==body_ptr )
-	      //NOTE TO JS
-	      PRINT_INFO( "Modified body %d\n", body_ptr->id() );
-	  //NOTE TO JS
-	  else
-	    PRINT_WARNING( "Body %d was not modified\n", body_ptr->id() );
+      if( new_body_ptr!=NULL && new_body_ptr!=body_ptr )
+//NOTE TO JS
+         PRINT_INFO( "Created new body %d\n", new_body_ptr->id() );
+      else if( new_body_ptr!=NULL && new_body_ptr==body_ptr )
+//NOTE TO JS
+         PRINT_INFO( "Modified body %d\n", body_ptr->id() );
+//NOTE TO JS
+      else
+         PRINT_WARNING( "Body %d was not modified\n", body_ptr->id() );
-      // Free memory
+   // Free memory
-      return status;
+   return status;
 #endif
-  CubitStatus
-    AcisModifyEngine::offset_curves( DLIList<Curve*>& ref_edge_list,
-				     DLIList<Curve*>& new_curves,
-				     double offset_distance,
-				     const CubitVector& offset_direction,
-				     int gap_type )
-      int i;
+CubitStatus
+AcisModifyEngine::offset_curves( DLIList<Curve*>& ref_edge_list,
+                                 DLIList<Curve*>& new_curves,
+                                 double offset_distance,
+                                 const CubitVector& offset_direction,
+                                 int gap_type )
+   int i;
-      EDGE* EDGE_ptr;
-      outcome result;
+   EDGE* EDGE_ptr;
+   outcome result;
-      // If there's just one curve, and it's linear, all we can do is copy it and move it.
-      // SRS Note (1-12-01) - this code should be moved up into GeometryTool...but, we
-      // would need to be able to move a curve.  When that capability exists move the
-      // code.
+   // If there's just one curve, and it's linear, all we can do is copy it and move it.
+   // SRS Note (1-12-01) - this code should be moved up into GeometryTool...but, we
+   // would need to be able to move a curve.  When that capability exists move the
+   // code.
-      //CubitBoolean move_curve = CUBIT_FALSE;
+   //CubitBoolean move_curve = CUBIT_FALSE;
-      if( ref_edge_list.size() == 1 && (offset_direction.x() || offset_direction.y() ||
-					offset_direction.z()) )
-	  ref_edge_ptr = ref_edge_list.get();
-	  if( AcisQueryEngine::instance()->is_curve_app_straight( ref_edge_ptr ) == CUBIT_TRUE )
+   if( ref_edge_list.size() == 1 && (offset_direction.x() || offset_direction.y() ||
+      offset_direction.z()) )
+      ref_edge_ptr = ref_edge_list.get();
+      if( AcisQueryEngine::instance()->is_curve_app_straight( ref_edge_ptr ) == CUBIT_TRUE )
-	      EDGE_ptr = AcisQueryEngine::get_EDGE(ref_edge_ptr);
+         EDGE_ptr = AcisQueryEngine::get_EDGE(ref_edge_ptr);
-	      // Copy and move the EDGE
-	      EDGE* new_EDGE_ptr2 = copy_and_move_EDGE( EDGE_ptr, offset_direction,
-							offset_distance );
+         // Copy and move the EDGE
+         EDGE* new_EDGE_ptr2 = copy_and_move_EDGE( EDGE_ptr, offset_direction,
+                                                   offset_distance );
-	      Curve *curve_ptr = AcisQueryEngine::instance()->populate_topology_bridges( new_EDGE_ptr2 );
-	      new_curves.append(curve_ptr);
-	      return CUBIT_SUCCESS;
-	  else
-	      PRINT_WARNING( "Direction qualifier ignored - only valid for one straight curve\n" );
-      else if( offset_direction.x() || offset_direction.y() || offset_direction.z() )
+         Curve *curve_ptr = AcisQueryEngine::instance()->populate_topology_bridges( new_EDGE_ptr2 );
+         new_curves.append(curve_ptr);
+      else
+         PRINT_WARNING( "Direction qualifier ignored - only valid for one straight curve\n" );
+   else if( offset_direction.x() || offset_direction.y() || offset_direction.z() )
-      // Create a wire from the given EDGEs
+   // Create a wire from the given EDGEs
-      // Offset the RefEdges
-      DLIList<EDGE*> old_EDGE_list;
-      if( AcisQueryEngine::instance()->get_EDGEs_of_Curves( ref_edge_list, old_EDGE_list )
+   // Offset the RefEdges
+   DLIList<EDGE*> old_EDGE_list;
+   if( AcisQueryEngine::instance()->get_EDGEs_of_Curves( ref_edge_list, old_EDGE_list )
-      DLIList<EDGE*> new_EDGE_list;
-      if( offset_EDGES( old_EDGE_list, offset_distance, gap_type, new_EDGE_list ) == CUBIT_FAILURE )
-	  PRINT_ERROR( "Unable to offset the curves\n" );
+   DLIList<EDGE*> new_EDGE_list;
+   if( offset_EDGES( old_EDGE_list, offset_distance, gap_type, new_EDGE_list ) == CUBIT_FAILURE )
+      PRINT_ERROR( "Unable to offset the curves\n" );
-      // Make free curves from the offset EDGEs
-      new_EDGE_list.reset();
-      for( i=0; i<new_EDGE_list.size(); i++ )
-	  EDGE_ptr = new_EDGE_list.get_and_step();
+   // Make free curves from the offset EDGEs
+   new_EDGE_list.reset();
+   for( i=0; i<new_EDGE_list.size(); i++ )
+      EDGE_ptr = new_EDGE_list.get_and_step();
-	  Curve *curve_ptr = AcisQueryEngine::instance()->populate_topology_bridges( EDGE_ptr );
+      Curve *curve_ptr = AcisQueryEngine::instance()->populate_topology_bridges( EDGE_ptr );
+  return CUBIT_SUCCESS;
-  Curve*
-    AcisModifyEngine::trim_curve( Curve* trim_curve,
-				  const CubitVector& trim_vector,
-				  const CubitVector& keep_vector,
-				  bool keep_old )
-      //api_trim_curve(entity_with_ray &eray1, SPAposition* trim_pt, entity_with_ray *peray2);
-      //The curve is trimmed to either a SPAposition or at its intersection with another curve. To trim
-      //to a SPAposition, specify a SPAposition in trim_pt and NULL for eray2. The curve is trimmed to
-      //the normal projection of the SPAposition onto the curve. To trim to the intersection with
-      //another curve, specify NULL for trim_pt and an entity_with_ray for eray2. The curve
-      //is trimmed to the intersection with the curve given in eray2 that is closest to the ray given
-      //in eray2.
+Curve*
+AcisModifyEngine::trim_curve( Curve* trim_curve,
+                              const CubitVector& trim_vector,
+                              const CubitVector& keep_vector,
+                              bool keep_old )
+  //api_trim_curve(entity_with_ray &eray1, SPAposition* trim_pt, entity_with_ray *peray2);
+   //The curve is trimmed to either a SPAposition or at its intersection with another curve. To trim
+   //to a SPAposition, specify a SPAposition in trim_pt and NULL for eray2. The curve is trimmed to
+   //the normal projection of the SPAposition onto the curve. To trim to the intersection with
+   //another curve, specify NULL for trim_pt and an entity_with_ray for eray2. The curve
+   //is trimmed to the intersection with the curve given in eray2 that is closest to the ray given
+   //in eray2.
-      EDGE* EDGE_ptr = AcisQueryEngine::get_EDGE( trim_curve );
-	return 0;
+   EDGE* EDGE_ptr = AcisQueryEngine::get_EDGE( trim_curve );
+      return 0;
-      ENTITY_LIST edge_VERTS;
-      api_get_vertices( EDGE_ptr, edge_VERTS );
-      VERTEX *start_vertex = static_cast<VERTEX*>(edge_VERTS[0]);
-      VERTEX *end_vertex = static_cast<VERTEX*>(edge_VERTS[1]);
-      SPAposition s_vec = start_vertex->geometry()->coords();
-      SPAposition e_vec = end_vertex->geometry()->coords();
-      CubitVector s_vector( s_vec.x(), s_vec.y(), s_vec.z() );
-      CubitVector e_vector( e_vec.x(), e_vec.y(), e_vec.z() );
+   ENTITY_LIST edge_VERTS;
+   api_get_vertices( EDGE_ptr, edge_VERTS );
+   VERTEX *start_vertex = static_cast<VERTEX*>(edge_VERTS[0]);
+   VERTEX *end_vertex = static_cast<VERTEX*>(edge_VERTS[1]);
+   SPAposition s_vec = start_vertex->geometry()->coords();
+   SPAposition e_vec = end_vertex->geometry()->coords();
+   CubitVector s_vector( s_vec.x(), s_vec.y(), s_vec.z() );
+   CubitVector e_vector( e_vec.x(), e_vec.y(), e_vec.z() );
-      int start = 0, end = 0;
-      if( keep_vector.distance_between( s_vector ) < 0.001 )
-	start = 1;
-      else if( keep_vector.distance_between( e_vector ) < 0.001 )
-	end = 1;
+   int start = 0, end = 0;
+   if( keep_vector.distance_between( s_vector ) < 0.001 )
+     start = 1;
+   else if( keep_vector.distance_between( e_vector ) < 0.001 )
+     end = 1;
-      if( start || end )
-	  double trim_param = trim_curve->u_from_position( trim_vector );
-	  double start_param = trim_curve->start_param();
-	  double end_param = trim_curve->end_param();
+   if( start || end )
+     double trim_param = trim_curve->u_from_position( trim_vector );
+     double start_param = trim_curve->start_param();
+     double end_param = trim_curve->end_param();
-	  //if trim_param is not within start and end params, we are extending
-	  //and we don't need keep_vector
-	  bool within_u_param_range = true;
-	  if( start_param < end_param )
-	      if( trim_param > end_param || trim_param < start_param )
-		within_u_param_range = false;
-	  else
-	      if( trim_param > start_param || trim_param < end_param )
+     //if trim_param is not within start and end params, we are extending
+     //and we don't need keep_vector
+     bool within_u_param_range = true;
+     if( start_param < end_param )
+       if( trim_param > end_param || trim_param < start_param )
+         within_u_param_range = false;
+     else
+       if( trim_param > start_param || trim_param < end_param )
-	  if( within_u_param_range )
-	      double keep_param;
-	      if( start )
-		keep_param = start_param + .95*(trim_param-start_param);
-	      else
-		keep_param = trim_param + .05*(end_param-trim_param);
+     if( within_u_param_range )
+       double keep_param;
+       if( start )
+         keep_param = start_param + .95*(trim_param-start_param);
+       else
+         keep_param = trim_param + .05*(end_param-trim_param);
-	      CubitVector tmp_keep_vec = keep_vector;
-	      trim_curve->position_from_u( keep_param, tmp_keep_vec );
+       CubitVector tmp_keep_vec = keep_vector;
+       trim_curve->position_from_u( keep_param, tmp_keep_vec );
-      // Copy the edge to trim first
-      EDGE* copied_EDGE_ptr;
-      outcome result = api_edge( EDGE_ptr, copied_EDGE_ptr );
+   // Copy the edge to trim first
+   EDGE* copied_EDGE_ptr;
+   outcome result = api_edge( EDGE_ptr, copied_EDGE_ptr );
-      SPAposition trim_pos( trim_vector.x(),trim_vector.y(),trim_vector.z() );
-      SPAposition* ptrim_pos = &trim_pos;
-      entity_with_ray *peray2 = NULL;
+   SPAposition trim_pos( trim_vector.x(),trim_vector.y(),trim_vector.z() );
+   SPAposition* ptrim_pos = &trim_pos;
+   entity_with_ray *peray2 = NULL;
-      SPAposition keep_pos( keep_vector.x(),keep_vector.y(),keep_vector.z() );
-      SPAunit_vector keep_vec( 0.0, 0.0, 0.0 );
-      entity_with_ray eray1( copied_EDGE_ptr, keep_pos, keep_vec );
+   SPAposition keep_pos( keep_vector.x(),keep_vector.y(),keep_vector.z() );
+   SPAunit_vector keep_vec( 0.0, 0.0, 0.0 );
+   entity_with_ray eray1( copied_EDGE_ptr, keep_pos, keep_vec );
-      // Finally, do the real work
-      result = api_trim_curve(eray1, ptrim_pos, peray2);
+   // Finally, do the real work
+   result = api_trim_curve(eray1, ptrim_pos, peray2);
-      if( !result.ok() )
-	  PRINT_ERROR( "Unable to trim curve\n" );
-	  return 0;
+   if( !result.ok() )
+     PRINT_ERROR( "Unable to trim curve\n" );
+     return 0;
-      // Make a free curve from the trimmed EDGE
-      Curve *curve_ptr = AcisQueryEngine::instance()->populate_topology_bridges( copied_EDGE_ptr );
-      if (keep_old)
-	return curve_ptr;
+   // Make a free curve from the trimmed EDGE
+   Curve *curve_ptr = AcisQueryEngine::instance()->populate_topology_bridges( copied_EDGE_ptr );
+   if (keep_old)
+     return curve_ptr;
-      // Delete the old curve (trim_curve), if it is a free curve
-      DLIList<Surface*> surfaces;
-      trim_curve->surfaces( surfaces );
-      if ( surfaces.size() == 0 )
-	    AcisQueryEngine::instance()->delete_solid_model_entities(trim_curve);
+   // Delete the old curve (trim_curve), if it is a free curve
+   DLIList<Surface*> surfaces;
+   trim_curve->surfaces( surfaces );
+   if ( surfaces.size() == 0 )
+      AcisQueryEngine::instance()->delete_solid_model_entities(trim_curve);
-	  if (status == CUBIT_FAILURE)
-	      PRINT_ERROR("In AcisModifyEngine::trim_curve\n"
-			  "       Could not delete Curve.\n"
-			  " The Model database is likely corrupted "
-			  "due to\nthis unsuccessful deletion.\n"  );
+       if (status == CUBIT_FAILURE)
+         PRINT_ERROR("In AcisModifyEngine::trim_curve\n"
+           "       Could not delete Curve.\n"
+           " The Model database is likely corrupted "
+           "due to\nthis unsuccessful deletion.\n"  );
-      return curve_ptr;
+   return curve_ptr;
-  Curve*
-    AcisModifyEngine::create_arc_three( Point* vertex1, Point* vertex2,
-					Point *vertex3, bool full )
-      CubitVector vec1 = vertex1->coordinates();
-      CubitVector vec2 = vertex2->coordinates();
-      CubitVector vec3 = vertex3->coordinates();
+Curve*
+AcisModifyEngine::create_arc_three( Point* vertex1, Point* vertex2,
+                                      Point *vertex3, bool full )
+  CubitVector vec1 = vertex1->coordinates();
+  CubitVector vec2 = vertex2->coordinates();
+  CubitVector vec3 = vertex3->coordinates();
-      SPAposition pos1( vec1.x(), vec1.y(), vec1.z() );
-      SPAposition pos2( vec2.x(), vec2.y(), vec2.z() );
-      SPAposition pos3( vec3.x(), vec3.y(), vec3.z() );
+  SPAposition pos1( vec1.x(), vec1.y(), vec1.z() );
+  SPAposition pos2( vec2.x(), vec2.y(), vec2.z() );
+  SPAposition pos3( vec3.x(), vec3.y(), vec3.z() );
-      EDGE *EDGE_ptr;
+  EDGE *EDGE_ptr;
-      outcome result = api_curve_arc_3pt( pos1, pos2, pos3, full, EDGE_ptr );
-	  PRINT_ERROR( "Unable to create arc from given vertices\n" );
-	  return NULL;
+  outcome result = api_curve_arc_3pt( pos1, pos2, pos3, full, EDGE_ptr );
+    PRINT_ERROR( "Unable to create arc from given vertices\n" );
+    return NULL;
-      //reuse vertices
-      if( full )
-	  PointACIS *acis_point1 = CAST_TO( vertex1, PointACIS );
-	  EDGE_ptr->set_start(acis_point1->get_VERTEX_ptr() );
-	  EDGE_ptr->set_end(acis_point1->get_VERTEX_ptr() );
-	  acis_point1->get_VERTEX_ptr()->add_edge(EDGE_ptr);
-      else
+  //reuse vertices
+  if( full )
+    PointACIS *acis_point1 = CAST_TO( vertex1, PointACIS );
+    EDGE_ptr->set_start(acis_point1->get_VERTEX_ptr() );
+    EDGE_ptr->set_end(acis_point1->get_VERTEX_ptr() );
+    acis_point1->get_VERTEX_ptr()->add_edge(EDGE_ptr);
+  else
-	  PointACIS *acis_point3 = CAST_TO( vertex3, PointACIS );
+    PointACIS *acis_point3 = CAST_TO( vertex3, PointACIS );
-	  EDGE_ptr->set_end(acis_point3->get_VERTEX_ptr() );
-	  acis_point3->get_VERTEX_ptr()->add_edge(EDGE_ptr);
+    EDGE_ptr->set_end(acis_point3->get_VERTEX_ptr() );
+    acis_point3->get_VERTEX_ptr()->add_edge(EDGE_ptr);
-      return AcisQueryEngine::instance()->populate_topology_bridges(EDGE_ptr);
+  return AcisQueryEngine::instance()->populate_topology_bridges(EDGE_ptr);
-  Curve*
-    AcisModifyEngine::create_arc_three( Curve* ref_edge1, Curve* ref_edge2,
-					Curve *ref_edge3, bool full )
-      EDGE* EDGE_ptr1 = AcisQueryEngine::get_EDGE( ref_edge1 );
-      EDGE* EDGE_ptr2 = AcisQueryEngine::get_EDGE( ref_edge2 );
-      EDGE* EDGE_ptr3 = AcisQueryEngine::get_EDGE( ref_edge3 );
-      if( !EDGE_ptr1 || !EDGE_ptr2 || !EDGE_ptr3)
-	return NULL;
+Curve*
+AcisModifyEngine::create_arc_three( Curve* ref_edge1, Curve* ref_edge2,
+                                      Curve *ref_edge3, bool full )
+  EDGE* EDGE_ptr1 = AcisQueryEngine::get_EDGE( ref_edge1 );
+  EDGE* EDGE_ptr2 = AcisQueryEngine::get_EDGE( ref_edge2 );
+  EDGE* EDGE_ptr3 = AcisQueryEngine::get_EDGE( ref_edge3 );
+  if( !EDGE_ptr1 || !EDGE_ptr2 || !EDGE_ptr3)
+    return NULL;
-      SPAposition tang_pos( 0.0, 0.0, 0.0 );
-      SPAunit_vector tang_vec( 0.0, 0.0, 0.0 );
-      entity_with_ray eray1( EDGE_ptr1, tang_pos, tang_vec );
-      entity_with_ray eray2( EDGE_ptr2, tang_pos, tang_vec );
-      entity_with_ray eray3( EDGE_ptr3, tang_pos, tang_vec );
+  SPAposition tang_pos( 0.0, 0.0, 0.0 );
+  SPAunit_vector tang_vec( 0.0, 0.0, 0.0 );
+  entity_with_ray eray1( EDGE_ptr1, tang_pos, tang_vec );
+  entity_with_ray eray2( EDGE_ptr2, tang_pos, tang_vec );
+  entity_with_ray eray3( EDGE_ptr3, tang_pos, tang_vec );
-      EDGE *EDGE_ptr;
+  EDGE *EDGE_ptr;
-      outcome result = api_curve_arc_3curve( eray1, eray2, eray3, full, EDGE_ptr );
-	  PRINT_ERROR( "Unable to create arc from given curves\n" );
-	  return NULL;
+  outcome result = api_curve_arc_3curve( eray1, eray2, eray3, full, EDGE_ptr );
+    PRINT_ERROR( "Unable to create arc from given curves\n" );
+    return NULL;
-  Curve*
-    AcisModifyEngine::create_arc_center_edge( Point* vertex1, Point* vertex2,
-					      Point *vertex3, const CubitVector &normal,
-					      double radius, bool full )
-      CubitVector vec1 = vertex1->coordinates(); // Center of arc
-      CubitVector vec2 = vertex2->coordinates(); // Position on arc
-      CubitVector vec3 = vertex3->coordinates(); // Position on arc
+Curve*
+AcisModifyEngine::create_arc_center_edge( Point* vertex1, Point* vertex2,
+                                          Point *vertex3, const CubitVector &normal,
+                                          double radius, bool full )
+  CubitVector vec1 = vertex1->coordinates(); // Center of arc
+  CubitVector vec2 = vertex2->coordinates(); // Position on arc
+  CubitVector vec3 = vertex3->coordinates(); // Position on arc
-      // Re-adjust vec2 if radius was given
-      if( radius != CUBIT_DBL_MAX )
-	  CubitVector dir1( vec1, vec2 );
-	  vec1.next_point( dir1, radius, vec2 );
+  // Re-adjust vec2 if radius was given
+  if( radius != CUBIT_DBL_MAX )
+    CubitVector dir1( vec1, vec2 );
+    vec1.next_point( dir1, radius, vec2 );
-      EDGE *EDGE_ptr;
-      SPAunit_vector arc_normal;
-      if( normal.length() != 0 )
-	  arc_normal.set_x( normal.x() );
-	  arc_normal.set_y( normal.y() );
-	  arc_normal.set_z( normal.z() );
+  EDGE *EDGE_ptr;
+  SPAunit_vector arc_normal;
+  if( normal.length() != 0 )
+    arc_normal.set_x( normal.x() );
+    arc_normal.set_y( normal.y() );
+    arc_normal.set_z( normal.z() );
-      outcome result;
-      if( full == CUBIT_FALSE )
-	  if( normal.length() != 0.0 )
-	    result = api_curve_arc_center_edge( pos1, pos2, pos3, &arc_normal, EDGE_ptr );
-	  else
-	    result = api_curve_arc_center_edge( pos1, pos2, pos3, NULL, EDGE_ptr );
-      else
-	  if( normal.length() == 0.0 )
-	      CubitVector dir2( vec1, vec3 );
-	      CubitVector tmp_normal = dir1 * dir2; // Cross-product
-	      tmp_normal.normalize();
-	      arc_normal.set_x( tmp_normal.x() );
-	      arc_normal.set_y( tmp_normal.y() );
-	      arc_normal.set_z( tmp_normal.z() );
-	  result = api_curve_arc_center_edge( pos1, pos2, pos2, &arc_normal, EDGE_ptr );
+  outcome result;
+  if( full == CUBIT_FALSE )
+    if( normal.length() != 0.0 )
+      result = api_curve_arc_center_edge( pos1, pos2, pos3, &arc_normal, EDGE_ptr );
+    else
+      result = api_curve_arc_center_edge( pos1, pos2, pos3, NULL, EDGE_ptr );
+  else
+    if( normal.length() == 0.0 )
+      CubitVector dir2( vec1, vec3 );
+      CubitVector tmp_normal = dir1 * dir2; // Cross-product
+      tmp_normal.normalize();
+      arc_normal.set_x( tmp_normal.x() );
+      arc_normal.set_y( tmp_normal.y() );
+      arc_normal.set_z( tmp_normal.z() );
+    result = api_curve_arc_center_edge( pos1, pos2, pos2, &arc_normal, EDGE_ptr );
-	  return NULL;
+    return NULL;
-      //reuse vertices...if possible
-      if( full )
-	  PointACIS *acis_point2 = CAST_TO( vertex2, PointACIS );
-	  EDGE_ptr->set_start(acis_point2->get_VERTEX_ptr() );
-	  EDGE_ptr->set_end(acis_point2->get_VERTEX_ptr() );
-	  acis_point2->get_VERTEX_ptr()->add_edge(EDGE_ptr);
-      else
-	  //reuse vertices only if it is coincident with
-	  //new vertex on new curve
+  //reuse vertices...if possible
+  if( full )
+    PointACIS *acis_point2 = CAST_TO( vertex2, PointACIS );
+    EDGE_ptr->set_start(acis_point2->get_VERTEX_ptr() );
+    EDGE_ptr->set_end(acis_point2->get_VERTEX_ptr() );
+    acis_point2->get_VERTEX_ptr()->add_edge(EDGE_ptr);
+  else
+    //reuse vertices only if it is coincident with
+    //new vertex on new curve
-	  //compare original start vs. new start vertex on EDGE
-	  VERTEX *start_vert = EDGE_ptr->start();
-	  SPAposition temp_pos = start_vert->geometry()->coords();
-	  CubitVector tmp_pos1( temp_pos.x(), temp_pos.y(), temp_pos.z() );
-	  vec2 = vertex2->coordinates();
+    //compare original start vs. new start vertex on EDGE
+    VERTEX *start_vert = EDGE_ptr->start();
+    SPAposition temp_pos = start_vert->geometry()->coords();
+    CubitVector tmp_pos1( temp_pos.x(), temp_pos.y(), temp_pos.z() );
+    vec2 = vertex2->coordinates();
-	  if(tmp_pos1.distance_between( vec2 ) < GEOMETRY_RESABS )
+    if(tmp_pos1.distance_between( vec2 ) < GEOMETRY_RESABS )
-	  //compare original end vs. new end vertex on EDGE
-	  VERTEX *end_vert = EDGE_ptr->end();
-	  temp_pos = end_vert->geometry()->coords();
-	  tmp_pos1.set( temp_pos.x(), temp_pos.y(), temp_pos.z() );
-	  vec3 = vertex3->coordinates();
+    //compare original end vs. new end vertex on EDGE
+    VERTEX *end_vert = EDGE_ptr->end();
+    temp_pos = end_vert->geometry()->coords();
+    tmp_pos1.set( temp_pos.x(), temp_pos.y(), temp_pos.z() );
+    vec3 = vertex3->coordinates();
-	  if(tmp_pos1.distance_between( vec3 ) < GEOMETRY_RESABS )
-	  else
-	      //make sure this point isn't a free vertex
-	      if( !vertex3->topology_entity() )
-		AcisQueryEngine::instance()->delete_solid_model_entities( vertex3 );
+    if(tmp_pos1.distance_between( vec3 ) < GEOMETRY_RESABS )
-  CubitStatus
-    AcisModifyEngine::create_curve_combine( DLIList<Curve*>& curve_list,
-					    Curve *&new_curve_ptr )
+    else
-      CubitStatus result;
+      //make sure this point isn't a free vertex
+      if( !vertex3->topology_entity() )
+        AcisQueryEngine::instance()->delete_solid_model_entities( vertex3 );
-      result = AcisEdgeTool::instance()->create_curve_combine(curve_list,
-							      new_curve_ptr);
-      if (result)
-	  RefEdge* new_ref_edge_ptr = GeometryQueryTool::instance()->make_free_RefEdge( new_curve_ptr );
-	  if (new_ref_edge_ptr)
-	    PRINT_INFO( "Created new \"combined\" curve %d\n", new_ref_edge_ptr->id() );
-	  else
-	    result = CUBIT_FAILURE;
+CubitStatus
+AcisModifyEngine::create_curve_combine( DLIList<Curve*>& curve_list,
+                                    Curve *&new_curve_ptr )
+  CubitStatus result;
-      return result;
+  result = AcisEdgeTool::instance()->create_curve_combine(curve_list,
+                                                          new_curve_ptr);
+  if (result)
+    RefEdge* new_ref_edge_ptr = GeometryQueryTool::instance()->make_free_RefEdge( new_curve_ptr );
-  CubitStatus
-    AcisModifyEngine::get_copied_FACES_of_body( DLIList<SurfaceACIS*>& ref_face_list,
-						DLIList<FACE*>& FACE_list,
-						DLIList<SurfaceACIS*>& removed_ref_faces,
-						BODY*& copied_BODY_ptr ) const
-      int i, num_faces;
+    if (new_ref_edge_ptr)
+      PRINT_INFO( "Created new \"combined\" curve %d\n", new_ref_edge_ptr->id() );
+    else
+      result = CUBIT_FAILURE;
-      // Note: we will be pulling surfaces out of incoming ref_face_list.
-      SurfaceACIS* ref_face_ptr;
-      BodySM *body_ptr;
+  return result;
-      BODY *BODY_ptr;
-      BODY *BODY_ptr2;
-      FACE *FACE_ptr;
+CubitStatus
+AcisModifyEngine::get_copied_FACES_of_body( DLIList<SurfaceACIS*>& ref_face_list,
+                                            DLIList<FACE*>& FACE_list,
+                                            DLIList<SurfaceACIS*>& removed_ref_faces,
+                                            BODY*& copied_BODY_ptr ) const
+  int i, num_faces;
-      copied_BODY_ptr = NULL;
+  // Note: we will be pulling surfaces out of incoming ref_face_list.
+  SurfaceACIS* ref_face_ptr;
+  BodySM *body_ptr;
-      outcome result;
+  BODY *BODY_ptr;
+  BODY *BODY_ptr2;
-      DLIList<SurfaceACIS*> body_face_list;
+  FACE *FACE_ptr;
-      ref_face_list.reset();
-      ref_face_ptr = ref_face_list.remove();
-      removed_ref_faces.append( ref_face_ptr );
+  copied_BODY_ptr = NULL;
-      FACE_ptr = ref_face_ptr->get_FACE_ptr();
-      if (!FACE_ptr)
-	  PRINT_ERROR( "Unable to get Acis FACE from Surface\n"  );
+  outcome result;
-      body_face_list.append_unique( ref_face_ptr );
+  DLIList<SurfaceACIS*> body_face_list;
-      body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY( FACE_ptr );
-	  PRINT_ERROR( "Unable to get volume from FACE\n"  );
+  ref_face_list.reset();
+  ref_face_ptr = ref_face_list.remove();
+  removed_ref_faces.append( ref_face_ptr );
-      BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY( FACE_ptr );
-      if( BODY_ptr == NULL )
+  FACE_ptr = ref_face_ptr->get_FACE_ptr();
+  if (!FACE_ptr)
+    PRINT_ERROR( "Unable to get Acis FACE from Surface\n"  );
-      // Add all remaining faces from this same body to face list
-      num_faces = ref_face_list.size();
-      for( i=0; i<num_faces; i++ )
-	  ref_face_ptr = ref_face_list.get();
+  body_face_list.append_unique( ref_face_ptr );
-	  BODY_ptr2 = AcisQueryEngine::instance()->get_BODY_of_entity( ref_face_ptr );
+  body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY( FACE_ptr );
+    PRINT_ERROR( "Unable to get volume from FACE\n"  );
-	  if( BODY_ptr == BODY_ptr2 )
-	      ref_face_list.remove();
-	  else
-	    ref_face_list.step();
+  BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY( FACE_ptr );
+  if( BODY_ptr == NULL )
-      // Now we have all the faces from this particular BODY.
+  // Add all remaining faces from this same body to face list
+  num_faces = ref_face_list.size();
+  for( i=0; i<num_faces; i++ )
+    ref_face_ptr = ref_face_list.get();
-      // Copy the body before working with it.  Here we keep the
-      // attributes on the BODY so we can get back to the TE's
-      // in CUBIT from the copy (to find which FACE's to correlate
-      // to the RefFace's).
-      copied_BODY_ptr = copy_BODY(BODY_ptr, CUBIT_FALSE);
+    BODY_ptr2 = AcisQueryEngine::instance()->get_BODY_of_entity( ref_face_ptr );
-      // Loop through the copied BODY's FACES to find which one's
-      // match to the original BODY's RefFaces.
-      ENTITY_LIST ENTITIES;
-      result = api_get_faces( copied_BODY_ptr, ENTITIES );
-	  PRINT_ERROR( "Unable to get ACIS FACES from volume\n" );
-	  api_delent( copied_BODY_ptr );
+    if( BODY_ptr == BODY_ptr2 )
+      ref_face_list.remove();
+    else
+      ref_face_list.step();
-      ENTITIES.init();
-      ENTITY* ENTITY_ptr;
-      int index = -1;
-      DLIList<int> index_list;
-      while( (ENTITY_ptr = ENTITIES.next() ) != NULL )
-	  AcisBridge* ab_ptr = ATTRIB_CUBIT_OWNER::cubit_owner(ENTITY_ptr);
-	  ref_face_ptr = CAST_TO( ab_ptr, SurfaceACIS );
-	  if( ref_face_ptr == NULL )
-	      PRINT_ERROR( "Unable to find RefFace from ACIS FACE!\n" );
+  // Now we have all the faces from this particular BODY.
-	  index = body_face_list.where_is_item( ref_face_ptr );
-	  if( index != -1 )
-	      index_list.append( index );
-	      temp_FACE_list.append( (FACE *)ENTITY_ptr );
-	  if( temp_FACE_list.size() == body_face_list.size() )
-	    break;
-      ENTITIES.clear();
+  // Copy the body before working with it.  Here we keep the
+  // attributes on the BODY so we can get back to the TE's
+  // in CUBIT from the copy (to find which FACE's to correlate
+  // to the RefFace's).
+  copied_BODY_ptr = copy_BODY(BODY_ptr, CUBIT_FALSE);
-      if( temp_FACE_list.size() != body_face_list.size() )
-	  PRINT_ERROR( "Internal error correlating FACE lists\n" );
+  // Loop through the copied BODY's FACES to find which one's
+  // match to the original BODY's RefFaces.
+  ENTITY_LIST ENTITIES;
+  result = api_get_faces( copied_BODY_ptr, ENTITIES );
+    PRINT_ERROR( "Unable to get ACIS FACES from volume\n" );
+    api_delent( copied_BODY_ptr );
-      // Re-sort the list into the proper order
-      index_list.reset();
-      for( i=0; i<index_list.size(); i++ )
-	  // Find the FACE with the corresponding index
-	  index = index_list.where_is_item( i );
-	  temp_FACE_list.step( index );
-	  FACE_list.append( temp_FACE_list.get() );
+  ENTITIES.init();
+  ENTITY* ENTITY_ptr;
+  int index = -1;
+  DLIList<int> index_list;
+  while( (ENTITY_ptr = ENTITIES.next() ) != NULL )
+    AcisBridge* ab_ptr = ATTRIB_CUBIT_OWNER::cubit_owner(ENTITY_ptr);
+    ref_face_ptr = CAST_TO( ab_ptr, SurfaceACIS );
+    if( ref_face_ptr == NULL )
+      PRINT_ERROR( "Unable to find RefFace from ACIS FACE!\n" );
-  CubitStatus
+    index = body_face_list.where_is_item( ref_face_ptr );
+    if( index != -1 )
-      DLIList<SurfaceACIS*> removed_faces;
-      return get_copied_FACES_of_body( ref_face_list, FACE_list, removed_faces,
-				       copied_BODY_ptr );
+      index_list.append( index );
+      temp_FACE_list.append( (FACE *)ENTITY_ptr );
+    if( temp_FACE_list.size() == body_face_list.size() )
+      break;
+  ENTITIES.clear();
-  CubitStatus
-    AcisModifyEngine::get_copied_EDGES_of_body( DLIList<CurveACIS*>& ref_edge_list,
-						DLIList<EDGE*>& EDGE_list,
-						DLIList<CurveACIS*>& removed_ref_edges,
-      int i, num_edges;
+  if( temp_FACE_list.size() != body_face_list.size() )
+    PRINT_ERROR( "Internal error correlating FACE lists\n" );
-      // Note: we will be pulling surfaces out of incoming ref_edge_list.
-      CurveACIS* ref_edge_ptr;
-      BodySM *body_ptr;
+  // Re-sort the list into the proper order
+  index_list.reset();
+  for( i=0; i<index_list.size(); i++ )
+    // Find the FACE with the corresponding index
+    index = index_list.where_is_item( i );
+    temp_FACE_list.step( index );
-      BODY *BODY_ptr;
-      BODY *BODY_ptr2;
+    FACE_list.append( temp_FACE_list.get() );
-      EDGE *EDGE_ptr;
+CubitStatus
+  DLIList<SurfaceACIS*> removed_faces;
-      outcome result;
+  return get_copied_FACES_of_body( ref_face_list, FACE_list, removed_faces,
+                                   copied_BODY_ptr );
-      DLIList<CurveACIS*> body_edge_list;
+CubitStatus
+AcisModifyEngine::get_copied_EDGES_of_body( DLIList<CurveACIS*>& ref_edge_list,
+                                            DLIList<EDGE*>& EDGE_list,
+                                            DLIList<CurveACIS*>& removed_ref_edges,
+  int i, num_edges;
-      ref_edge_ptr = ref_edge_list.remove();
-      removed_ref_edges.append( ref_edge_ptr );
+  // Note: we will be pulling surfaces out of incoming ref_edge_list.
+  CurveACIS* ref_edge_ptr;
+  BodySM *body_ptr;
-      EDGE_ptr = ref_edge_ptr->get_EDGE_ptr();
+  BODY *BODY_ptr;
+  BODY *BODY_ptr2;
-      body_edge_list.append_unique( ref_edge_ptr );
+  EDGE *EDGE_ptr;
-      body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY( EDGE_ptr );
-	  PRINT_ERROR( "Unable to get volume from EDGE\n" );
-      BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY( EDGE_ptr );
+  outcome result;
-      // Add all remaining edges from this same body to edge list
-      num_edges = ref_edge_list.size();
-      for( i=0; i<num_edges; i++ )
+  DLIList<CurveACIS*> body_edge_list;
-	  BODY_ptr2 = AcisQueryEngine::instance()->get_BODY_of_entity( ref_edge_ptr );
+  ref_edge_ptr = ref_edge_list.remove();
+  removed_ref_edges.append( ref_edge_ptr );
-	      ref_edge_list.remove();
-	  else
-	    ref_edge_list.step();
+  EDGE_ptr = ref_edge_ptr->get_EDGE_ptr();
-      // Now we have all the edges from this particular BODY.
+  body_edge_list.append_unique( ref_edge_ptr );
-      // in CUBIT from the copy (to find which EDGE's to correlate
-      // to the RefEdge's).
+  body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY( EDGE_ptr );
+    PRINT_ERROR( "Unable to get volume from EDGE\n" );
-      // Loop through the copied BODY's EDGES to find which one's
-      // match to the original BODY's RefEdges.
-      result = api_get_edges(copied_BODY_ptr, ENTITIES);
-	  PRINT_ERROR( "Unable to get ACIS EDGES from volume\n" );
+  BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY( EDGE_ptr );
-      ENTITIES.init();
-      int index = -1;
-      DLIList<EDGE*> temp_EDGE_list;
-	  ref_edge_ptr = CAST_TO( ab_ptr, CurveACIS );
-	  if( ref_edge_ptr == NULL )
-	      PRINT_ERROR( "Unable to find Cubit curve from ACIS EDGE!\n" );
-	  index = body_edge_list.where_is_item( ref_edge_ptr );
-	  if( index != -1 )
-	      temp_EDGE_list.append( (EDGE *)ENTITY_ptr );
-	  if( temp_EDGE_list.size() == body_edge_list.size() )
-	    break;
-      ENTITIES.clear();
+  // Add all remaining edges from this same body to edge list
+  num_edges = ref_edge_list.size();
+  for( i=0; i<num_edges; i++ )
-      if( temp_EDGE_list.size() != body_edge_list.size() )
-	  PRINT_ERROR( "Internal error correlating EDGE lists\n" );
+    BODY_ptr2 = AcisQueryEngine::instance()->get_BODY_of_entity( ref_edge_ptr );
-      temp_EDGE_list.reset();
-	  // Find the EDGE with the corresponding index
-	  temp_EDGE_list.step( index );
-	  EDGE_list.append( temp_EDGE_list.get() );
+      ref_edge_list.remove();
+    else
+      ref_edge_list.step();
-  CubitStatus
-      DLIList<CurveACIS*> removed_edges;
+  // Now we have all the edges from this particular BODY.
-      return get_copied_EDGES_of_body( ref_edge_list, EDGE_list, removed_edges,
+  // in CUBIT from the copy (to find which EDGE's to correlate
+  // to the RefEdge's).
-  // Purpose       :  To get a pointer to a copy of the body along with a list of VERTEXs
-  // Special Notes :
-  // Creator       : Lingyun Pan (CAT)
-  // Creation Date : 07/19/01
+  // Loop through the copied BODY's EDGES to find which one's
+  // match to the original BODY's RefEdges.
+  result = api_get_edges(copied_BODY_ptr, ENTITIES);
+    PRINT_ERROR( "Unable to get ACIS EDGES from volume\n" );
-  CubitStatus
-    AcisModifyEngine::get_copied_VERTICES_of_body(
-						  DLIList<PointACIS*>& ref_vertex_list,
-						  DLIList<VERTEX*>& VERTEX_list,
-						  DLIList<PointACIS*>& removed_ref_vertices,
+  ENTITIES.init();
+  int index = -1;
+  DLIList<EDGE*> temp_EDGE_list;
+    ref_edge_ptr = CAST_TO( ab_ptr, CurveACIS );
+    if( ref_edge_ptr == NULL )
-      int i, num_vertices;
+      PRINT_ERROR( "Unable to find Cubit curve from ACIS EDGE!\n" );
+    index = body_edge_list.where_is_item( ref_edge_ptr );
+    if( index != -1 )
+      temp_EDGE_list.append( (EDGE *)ENTITY_ptr );
+    if( temp_EDGE_list.size() == body_edge_list.size() )
+      break;
+  ENTITIES.clear();
-      // Note: we will be pulling vertices out of incoming ref_vertex_list.
-      PointACIS* ref_vertex_ptr;
-      BodySM *body_ptr;
+  if( temp_EDGE_list.size() != body_edge_list.size() )
+    PRINT_ERROR( "Internal error correlating EDGE lists\n" );
-      BODY *BODY_ptr;
-      BODY *BODY_ptr2;
+  temp_EDGE_list.reset();
+    // Find the EDGE with the corresponding index
+    temp_EDGE_list.step( index );
+    EDGE_list.append( temp_EDGE_list.get() );
-      outcome result;
+CubitStatus
+  DLIList<CurveACIS*> removed_edges;
-      DLIList<PointACIS*> body_vertex_list;
+  return get_copied_EDGES_of_body( ref_edge_list, EDGE_list, removed_edges,
-      ref_vertex_ptr =ref_vertex_list .remove();
-      removed_ref_vertices.append( ref_vertex_ptr);
+// Purpose       :  To get a pointer to a copy of the body along with a list of VERTEXs
+// Special Notes :
+// Creator       : Lingyun Pan (CAT)
+// Creation Date : 07/19/01
-      VERTEX_ptr = ref_vertex_ptr->get_VERTEX_ptr();
+CubitStatus
+AcisModifyEngine::get_copied_VERTICES_of_body(
+                                     DLIList<PointACIS*>& ref_vertex_list,
+                                     DLIList<VERTEX*>& VERTEX_list,
+                                     DLIList<PointACIS*>& removed_ref_vertices,
+  int i, num_vertices;
-      body_vertex_list.append_unique( ref_vertex_ptr );
+  // Note: we will be pulling vertices out of incoming ref_vertex_list.
+  PointACIS* ref_vertex_ptr;
+  BodySM *body_ptr;
-      body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY(VERTEX_ptr );
-	  PRINT_ERROR( "Unable to get volume from VERTEX\n" );
+  BODY *BODY_ptr;
+  BODY *BODY_ptr2;
-      BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY( VERTEX_ptr );
-      // Add all remaining vertex from this same body to vertex list
-      num_vertices = ref_vertex_list.size();
-      for( i=0; i<num_vertices; i++ )
-	  ref_vertex_ptr = ref_vertex_list.get();
-	  BODY_ptr2 = AcisQueryEngine::instance()->get_BODY_of_entity( ref_vertex_ptr );
+  outcome result;
-	      ref_vertex_list.remove();
-	      removed_ref_vertices.append( ref_vertex_ptr );
-	  else
-	    ref_vertex_list.step();
+  DLIList<PointACIS*> body_vertex_list;
-      // Now we have all the vertices from this particular BODY.
+  ref_vertex_ptr =ref_vertex_list .remove();
+  removed_ref_vertices.append( ref_vertex_ptr);
-      // in CUBIT from the copy (to find which VERTICE's to correlate
-      // to the RefVertice's).
+  VERTEX_ptr = ref_vertex_ptr->get_VERTEX_ptr();
-      // Loop through the copied BODY's VERTICEs to find which one's
-      // match to the original BODY's RefVertices.
-      result = api_get_vertices( copied_BODY_ptr, ENTITIES);
-	  PRINT_ERROR( "Unable to get ACIS VERTICES from a volume\n" );
+  body_vertex_list.append_unique( ref_vertex_ptr );
-      ENTITIES.init();
-      int index = -1;
-      DLIList<VERTEX*> temp_VERTEX_list;
-	  ref_vertex_ptr = CAST_TO(ab_ptr, PointACIS);
-	  if( ref_vertex_ptr == NULL )
-	      PRINT_ERROR( "Unable to find RefVertex from ACIS VERTEX!\n" );
-	      VERTEX_list.clean_out();
+  body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY(VERTEX_ptr );
+    PRINT_ERROR( "Unable to get volume from VERTEX\n" );
-	  index = body_vertex_list.where_is_item( ref_vertex_ptr );
-	  if( index != -1 )
-	      temp_VERTEX_list.append( (VERTEX *)ENTITY_ptr );
-	  if( temp_VERTEX_list.size() == body_vertex_list.size() )
-	    break;
-      ENTITIES.clear();
+  BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY( VERTEX_ptr );
-      if( temp_VERTEX_list.size() != body_vertex_list.size() )
-	  PRINT_ERROR( "Internal error correlating VERTEX lists\n" );
+  // Add all remaining vertex from this same body to vertex list
+  num_vertices = ref_vertex_list.size();
+  for( i=0; i<num_vertices; i++ )
+    ref_vertex_ptr = ref_vertex_list.get();
-      temp_VERTEX_list.reset();
-	  // Find the VERTEX with the corresponding index
-	  temp_VERTEX_list.step( index );
+    BODY_ptr2 = AcisQueryEngine::instance()->get_BODY_of_entity( ref_vertex_ptr );
-	  VERTEX_list.append( temp_VERTEX_list.get() );
+      ref_vertex_list.remove();
+      removed_ref_vertices.append( ref_vertex_ptr );
+    else
+      ref_vertex_list.step();
-  CubitStatus
-      DLIList<PointACIS*> removed_vertices;
+  // Now we have all the vertices from this particular BODY.
-      return get_copied_VERTICES_of_body( ref_vertex_list, VERTEX_list,
-					  removed_vertices, copied_BODY_ptr );
+  // in CUBIT from the copy (to find which VERTICE's to correlate
+  // to the RefVertice's).
+  // Loop through the copied BODY's VERTICEs to find which one's
+  // match to the original BODY's RefVertices.
+  result = api_get_vertices( copied_BODY_ptr, ENTITIES);
+    PRINT_ERROR( "Unable to get ACIS VERTICES from a volume\n" );
-  GeometryQueryEngine *AcisModifyEngine::get_gqe()
+  ENTITIES.init();
+  int index = -1;
+  DLIList<VERTEX*> temp_VERTEX_list;
+    ref_vertex_ptr = CAST_TO(ab_ptr, PointACIS);
+    if( ref_vertex_ptr == NULL )
-      return AcisQueryEngine::instance();
+      PRINT_ERROR( "Unable to find RefVertex from ACIS VERTEX!\n" );
+      VERTEX_list.clean_out();
-  CubitBoolean AcisModifyEngine::is_modify_engine(const TopologyBridge *tb_ptr) const
+    index = body_vertex_list.where_is_item( ref_vertex_ptr );
+    if( index != -1 )
-      if (CAST_TO(const_cast<TopologyBridge*>(tb_ptr), AcisBridge)) return CUBIT_TRUE;
-      else return CUBIT_FALSE;
+      temp_VERTEX_list.append( (VERTEX *)ENTITY_ptr );
+    if( temp_VERTEX_list.size() == body_vertex_list.size() )
+      break;
+  ENTITIES.clear();
-  CubitStatus
-    AcisModifyEngine::get_offset_intersections( Curve* ref_edge1,
-						Curve* ref_edge2,
-						DLIList<CubitVector*>& intersection_list,
-						bool ext_first )
-      int i;
-      //int done = 0;
-      bool bounded = !ext_first;
+  if( temp_VERTEX_list.size() != body_vertex_list.size() )
+    PRINT_ERROR( "Internal error correlating VERTEX lists\n" );
-      // Get the ACIS EDGES
-      EDGE* EDGE_ptr1 = AcisQueryEngine::get_EDGE(ref_edge1);
-      EDGE* EDGE_ptr2 = AcisQueryEngine::get_EDGE(ref_edge2);
-      if (!EDGE_ptr1 || !EDGE_ptr2)
+  temp_VERTEX_list.reset();
+    // Find the VERTEX with the corresponding index
+    temp_VERTEX_list.step( index );
-      // Determine which curves are straight.  Use this because some curves,
-      // esp. from IGES, can be "straight" splines.
-      bool straight1, straight2;
-      straight1 = AcisQueryEngine::instance()->is_curve_app_straight( ref_edge1 );
-      straight2 = AcisQueryEngine::instance()->is_curve_app_straight( ref_edge2 );
+    VERTEX_list.append( temp_VERTEX_list.get() );
-      // If first is straight we need to find the plane to offset it in.
-      CubitVector pln_norm;
-      EDGE* offset_EDGE_ptr = NULL;
-      if( straight1 )
-	  // Need to find the plane normal to do offsets in
-	  // Get point normal form
-	  CubitVector orig1, dir1;
-	  if( ref_edge1->get_point_direction( orig1, dir1 ) == CUBIT_FAILURE )
-	      // This must be a straight spline.  Get it from endpoints.
-	      ref_edge1->position_from_fraction( 0.0, orig1 );
-	      CubitVector end_coords;
-	      ref_edge1->position_from_fraction( 1.0, end_coords );
-	      dir1 = end_coords - orig1;
-	      dir1.normalize();
-	  if( straight2 )
-	      CubitVector orig2, dir2;
-	      if( ref_edge2->get_point_direction( orig2, dir2 ) == CUBIT_FAILURE )
-		  ref_edge2->position_from_fraction( 0.0, orig2 );
-		  ref_edge2->position_from_fraction( 1.0, end_coords );
-		  dir2 = end_coords - orig2;
-		  dir2.normalize();
+CubitStatus
+  DLIList<PointACIS*> removed_vertices;
-	      // Find SPAvector from orig1 to orig2
-	      CubitVector vec1 = orig2 - orig1;
-	      vec1.normalize();
+  return get_copied_VERTICES_of_body( ref_vertex_list, VERTEX_list,
+                                      removed_vertices, copied_BODY_ptr );
-	      // Cross dir1 with vec1 to get plane normal.
-	      pln_norm = dir1 * vec1;
-	      // Make sure this isn't a zero SPAvector.
-	      if( pln_norm.length() == 0.0 )
-		  // Cross dir1 with dir2 to get plane normal
-		  pln_norm = dir1 * dir2;
+GeometryQueryEngine *AcisModifyEngine::get_gqe()
+  return AcisQueryEngine::instance();
-		  PRINT_ERROR( "Unable to calculate plane that the curves lie in\n" );
-	  else // EDGE2 is not straight
-	      // Proper normal should be normal to curve, but check to see if EDGE 1 is on
-	      // this plane.
-	      CubitVector orig2;
-	      AcisQueryEngine::instance()->get_EDGE_normal( EDGE_ptr2, pln_norm );
+CubitBoolean AcisModifyEngine::is_modify_engine(const TopologyBridge *tb_ptr) const
-	      double aln_orig[3], aln_vec[3], apln_orig[3], apln_norm[3];
+  if (CAST_TO(const_cast<TopologyBridge*>(tb_ptr), AcisBridge)) return CUBIT_TRUE;
+  else return CUBIT_FALSE;
-	      AnalyticGeometryTool *agt = AnalyticGeometryTool::instance();
+CubitStatus
+AcisModifyEngine::get_offset_intersections( Curve* ref_edge1,
+                                            Curve* ref_edge2,
+                                            DLIList<CubitVector*>& intersection_list,
+                                            bool ext_first )
+   int i;
+   //int done = 0;
+   bool bounded = !ext_first;
-	      agt->copy_pnt( orig1, aln_orig ); agt->copy_pnt( dir1, aln_vec );
-	      ref_edge2->position_from_fraction( 0.0, orig2 ); //
-	      ref_edge2->position_from_u(ref_edge2->start_param(),orig2);
-	      agt->copy_pnt( orig2, apln_orig );
-	      agt->copy_pnt( pln_norm, apln_norm );
+   // Get the ACIS EDGES
+   EDGE* EDGE_ptr1 = AcisQueryEngine::get_EDGE(ref_edge1);
+   EDGE* EDGE_ptr2 = AcisQueryEngine::get_EDGE(ref_edge2);
+   if (!EDGE_ptr1 || !EDGE_ptr2)
-	      if( !agt->is_ln_on_pln( aln_orig,aln_vec, apln_orig, apln_norm ) )
-		  PRINT_ERROR( "Curve does not lie in the plane defined by Curve\n" );
+   // Determine which curves are straight.  Use this because some curves,
+   // esp. from IGES, can be "straight" splines.
+   bool straight1, straight2;
+   straight1 = AcisQueryEngine::instance()->is_curve_app_straight( ref_edge1 );
+   straight2 = AcisQueryEngine::instance()->is_curve_app_straight( ref_edge2 );
-	  // Get offset direction cross of plane normal and edge 1 direction
-	  CubitVector offset_dir = pln_norm*dir1;
+   // If first is straight we need to find the plane to offset it in.
+   CubitVector pln_norm;
+   EDGE* offset_EDGE_ptr = NULL;
+   if( straight1 )
+      // Need to find the plane normal to do offsets in
-	  // Do first side
-	  offset_EDGE_ptr = copy_and_move_EDGE( EDGE_ptr1, offset_dir, offset_distance );
-	  if( offset_EDGE_ptr == NULL )
-	      PRINT_ERROR( "unable to offset Curve for intersection calculation\n" );
+      // Get point normal form
+      CubitVector orig1, dir1;
+      if( ref_edge1->get_point_direction( orig1, dir1 ) == CUBIT_FAILURE )
+        // This must be a straight spline.  Get it from endpoints.
+        ref_edge1->position_from_fraction( 0.0, orig1 );
+        CubitVector end_coords;
+        ref_edge1->position_from_fraction( 1.0, end_coords );
+        dir1 = end_coords - orig1;
+        dir1.normalize();
+      if( straight2 )
+         CubitVector orig2, dir2;
+         if( ref_edge2->get_point_direction( orig2, dir2 ) == CUBIT_FAILURE )
+           ref_edge2->position_from_fraction( 0.0, orig2 );
+           ref_edge2->position_from_fraction( 1.0, end_coords );
+           dir2 = end_coords - orig2;
+           dir2.normalize();
-	  if( AcisQueryEngine::instance()->get_intersections( offset_EDGE_ptr, EDGE_ptr2,
-							      intersection_list, bounded ) ==
-	      CUBIT_FAILURE )
-	      PRINT_ERROR( "unable to calculate intersections of offset Curves\n" );
-	      api_delent( offset_EDGE_ptr );
+         // Find SPAvector from orig1 to orig2
+         CubitVector vec1 = orig2 - orig1;
+         vec1.normalize();
+         // Cross dir1 with vec1 to get plane normal.
+         pln_norm = dir1 * vec1;
-	  // Do second side
-	  if( offset_distance != 0.0 )
-	      offset_dir = -offset_dir;
+         // Make sure this isn't a zero SPAvector.
+         if( pln_norm.length() == 0.0 )
+           // Cross dir1 with dir2 to get plane normal
+           pln_norm = dir1 * dir2;
-	      if( AcisQueryEngine::instance()->get_intersections( offset_EDGE_ptr, EDGE_ptr2, intersection_list, bounded ) == CUBIT_FAILURE )
+            PRINT_ERROR( "Unable to calculate plane that the curves lie in\n" );
+      else // EDGE2 is not straight
+         // Proper normal should be normal to curve, but check to see if EDGE 1 is on
+         // this plane.
+         CubitVector orig2;
+         AcisQueryEngine::instance()->get_EDGE_normal( EDGE_ptr2, pln_norm );
+         double aln_orig[3], aln_vec[3], apln_orig[3], apln_norm[3];
-      else if( offset_distance != 0.0 )
-	  // If there is an offset, offset the first curve to each "side" of the original
-	  // and do the intersections - i.e., try each side.  Note we already handled the
-	  // special case if the first curve is straight.
+         AnalyticGeometryTool *agt = AnalyticGeometryTool::instance();
-	  // Do first side
-	  DLIList<EDGE*> EDGE_list;
+         agt->copy_pnt( orig1, aln_orig ); agt->copy_pnt( dir1, aln_vec );
+         ref_edge2->position_from_fraction( 0.0, orig2 ); //
+         ref_edge2->position_from_u(ref_edge2->start_param(),orig2);
+         agt->copy_pnt( orig2, apln_orig );
+         agt->copy_pnt( pln_norm, apln_norm );
-	  EDGE_list.append( EDGE_ptr1 );
-	  if( offset_EDGES( EDGE_list, offset_distance, 1, new_EDGE_list ) == CUBIT_FAILURE )
+         if( !agt->is_ln_on_pln( aln_orig,aln_vec, apln_orig, apln_norm ) )
+            PRINT_ERROR( "Curve does not lie in the plane defined by Curve\n" );
-	  // Note: the new_EDGE_list can have more curves in it than EDGE_list
-	      offset_EDGE_ptr = new_EDGE_list.get_and_step();
-								  EDGE_ptr2, intersection_list, bounded ) == CUBIT_FAILURE )
+      // Get offset direction cross of plane normal and edge 1 direction
+      CubitVector offset_dir = pln_norm*dir1;
-	  new_EDGE_list.clean_out();
+      // Do first side
+      offset_EDGE_ptr = copy_and_move_EDGE( EDGE_ptr1, offset_dir, offset_distance );
+      if( offset_EDGE_ptr == NULL )
+         PRINT_ERROR( "unable to offset Curve for intersection calculation\n" );
-	  // Do other side
-	  if( offset_EDGES( EDGE_list, -offset_distance, 1, new_EDGE_list ) == CUBIT_FAILURE )
+      if( AcisQueryEngine::instance()->get_intersections( offset_EDGE_ptr, EDGE_ptr2,
+                                              intersection_list, bounded ) ==
+          CUBIT_FAILURE )
+         PRINT_ERROR( "unable to calculate intersections of offset Curves\n" );
+         api_delent( offset_EDGE_ptr );
+      // Do second side
+      if( offset_distance != 0.0 )
+         offset_dir = -offset_dir;
-      else
-	  // Just get the intersections
-	  if( AcisQueryEngine::instance()->get_intersections( EDGE_ptr1, EDGE_ptr2, intersection_list, bounded ) == CUBIT_FAILURE )
-	      PRINT_ERROR( "unable to calculate intersections of Curves\n" );
+         if( AcisQueryEngine::instance()->get_intersections( offset_EDGE_ptr, EDGE_ptr2, intersection_list, bounded ) == CUBIT_FAILURE )
-      // Cull out any points that are not on bounds of RefEdge 2
-      if( bounded == CUBIT_FALSE )
-	  CubitVector *vec_ptr;
-	  for( i=0; i<intersection_list.size(); i++ )
-	      vec_ptr = intersection_list.get();
-	      if( ref_edge2->point_containment( *vec_ptr ) == CUBIT_PNT_OFF )
-		  delete vec_ptr;
-		  intersection_list.remove();
-	      else
-		intersection_list.step();
+  else if( offset_distance != 0.0 )
+     // If there is an offset, offset the first curve to each "side" of the original
+     // and do the intersections - i.e., try each side.  Note we already handled the
+     // special case if the first curve is straight.
+     // Do first side
+     DLIList<EDGE*> EDGE_list;
-  CubitStatus
-    AcisModifyEngine::get_offset_intersections( Curve* ref_edge_ptr,
-						Surface* ref_face_ptr,
-						DLIList<CubitVector*> &intersection_list,
-						bool ext_surf )
-      outcome result;
+     EDGE_list.append( EDGE_ptr1 );
+     if( offset_EDGES( EDGE_list, offset_distance, 1, new_EDGE_list ) == CUBIT_FAILURE )
-      EDGE* EDGE_ptr = AcisQueryEngine::get_EDGE(ref_edge_ptr);
-      FACE* FACE_ptr = AcisQueryEngine::get_FACE(ref_face_ptr);
-      if (!EDGE_ptr || !FACE_ptr)
+     // Note: the new_EDGE_list can have more curves in it than EDGE_list
+        offset_EDGE_ptr = new_EDGE_list.get_and_step();
+                  EDGE_ptr2, intersection_list, bounded ) == CUBIT_FAILURE )
-      // If there is an offset, offset the surface to each "side" of the original
-	  FACE* offset_FACE_ptr = NULL;
+     new_EDGE_list.clean_out();
-	  result = api_offset_face ( FACE_ptr, offset_distance, offset_FACE_ptr );
+     // Do other side
+     if( offset_EDGES( EDGE_list, -offset_distance, 1, new_EDGE_list ) == CUBIT_FAILURE )
-	  if( offset_FACE_ptr == NULL )
-	      PRINT_ERROR( "Unable to offset surface\n" );
-	  // This creates a FACE from the given FACE, only it can be extended out.
-	  FACE* ext_offset_FACE_ptr = make_FACE( offset_FACE_ptr, ext_surf );
-	  BODY *ext_offset_BODY_ptr =
-	    AcisQueryEngine::instance()->get_BODY_of_ENTITY( ext_offset_FACE_ptr );
-	  if( AcisQueryEngine::instance()->get_intersections( EDGE_ptr, ext_offset_FACE_ptr, intersection_list ) == CUBIT_FAILURE )
-	      PRINT_ERROR("Problems finding intersections of curve and surface.\n");
-	      api_delent( offset_FACE_ptr );
-	      api_delent( ext_offset_BODY_ptr );
+  else
+     // Just get the intersections
+     if( AcisQueryEngine::instance()->get_intersections( EDGE_ptr1, EDGE_ptr2, intersection_list, bounded ) == CUBIT_FAILURE )
+        PRINT_ERROR( "unable to calculate intersections of Curves\n" );
-	  api_delent( offset_FACE_ptr ); offset_FACE_ptr = NULL;
-	  api_delent( ext_offset_BODY_ptr ); ext_offset_BODY_ptr = NULL;
-	  ext_offset_FACE_ptr = NULL;
+  // Cull out any points that are not on bounds of RefEdge 2
+  if( bounded == CUBIT_FALSE )
+     CubitVector *vec_ptr;
+     for( i=0; i<intersection_list.size(); i++ )
+        vec_ptr = intersection_list.get();
-	  // Try other side
-	  result = api_offset_face ( FACE_ptr, -offset_distance, offset_FACE_ptr );
+        if( ref_edge2->point_containment( *vec_ptr ) == CUBIT_PNT_OFF )
+           delete vec_ptr;
+           intersection_list.remove();
+        else
+           intersection_list.step();
-	  // This creates a FACE from the given FACE, only it is extended out.
-	  ext_offset_FACE_ptr = make_FACE( offset_FACE_ptr, CUBIT_TRUE );
-	  ext_offset_BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY( ext_offset_FACE_ptr );
+CubitStatus
+AcisModifyEngine::get_offset_intersections( Curve* ref_edge_ptr,
+                                            Surface* ref_face_ptr,
+                                            DLIList<CubitVector*> &intersection_list,
+                                            bool ext_surf )
+   outcome result;
-	      PRINT_ERROR("Problems finding intersections of curve and surface.\n" );
+   EDGE* EDGE_ptr = AcisQueryEngine::get_EDGE(ref_edge_ptr);
+   FACE* FACE_ptr = AcisQueryEngine::get_FACE(ref_face_ptr);
+   if (!EDGE_ptr || !FACE_ptr)
-      else
-	  FACE* ext_FACE_ptr = make_FACE( FACE_ptr, ext_surf );
-	  BODY *ext_BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY( ext_FACE_ptr );
-	  if( AcisQueryEngine::instance()->get_intersections( EDGE_ptr, ext_FACE_ptr, intersection_list ) == CUBIT_FAILURE )
-	      api_delent( ext_BODY_ptr );
+   // If there is an offset, offset the surface to each "side" of the original
+      FACE* offset_FACE_ptr = NULL;
+      result = api_offset_face ( FACE_ptr, offset_distance, offset_FACE_ptr );
-  EDGE *
-    AcisModifyEngine::copy_and_move_EDGE( EDGE *EDGE_ptr,
-					  const CubitVector &input_dir,
-					  double dist )
-      // Setup translation transform
-      SPAtransf tr;
-      CubitVector dir(input_dir);
-      dir.normalize(); // For now, allow this SPAvector to be modified
-      CubitVector delta = dist*dir;
-      SPAvector vec(delta.x(), delta.y(), delta.z() );
-      tr = translate_transf( vec );
+      if( offset_FACE_ptr == NULL )
+         PRINT_ERROR( "Unable to offset surface\n" );
-      EDGE* new_EDGE_ptr;
-      outcome result = api_trans_edge( EDGE_ptr, tr, new_EDGE_ptr );
-      if (!result.ok())
-	  AcisQueryEngine::instance()->ACIS_API_error( result );
-	  return NULL;
+      // This creates a FACE from the given FACE, only it can be extended out.
+      FACE* ext_offset_FACE_ptr = make_FACE( offset_FACE_ptr, ext_surf );
+      BODY *ext_offset_BODY_ptr =
+        AcisQueryEngine::instance()->get_BODY_of_ENTITY( ext_offset_FACE_ptr );
-      // Remove the CUBIT owner attributes from the new edge
-      ATTRIB_CUBIT_OWNER::remove_cubit_owner((ENTITY*)new_EDGE_ptr, CUBIT_TRUE);
+      if( AcisQueryEngine::instance()->get_intersections( EDGE_ptr, ext_offset_FACE_ptr, intersection_list ) == CUBIT_FAILURE )
+         PRINT_ERROR("Problems finding intersections of curve and surface.\n");
+         api_delent( offset_FACE_ptr );
+         api_delent( ext_offset_BODY_ptr );
-      return new_EDGE_ptr;
+      api_delent( offset_FACE_ptr ); offset_FACE_ptr = NULL;
+      api_delent( ext_offset_BODY_ptr ); ext_offset_BODY_ptr = NULL;
+      ext_offset_FACE_ptr = NULL;
-  CubitStatus
-    AcisModifyEngine::offset_EDGES( DLIList<EDGE*> &EDGE_list,
-				    int gap_type,
-				    DLIList<EDGE*> &new_EDGE_list )
-      int i;
-      EDGE *EDGE_ptr = NULL;
-      //ENTITY *ENTITY_ptr = NULL;
-      EDGE *tmp_EDGE_ptr = NULL;
+      // Try other side
+      result = api_offset_face ( FACE_ptr, -offset_distance, offset_FACE_ptr );
-      // Need to create a wire from the EDGEs
+         AcisQueryEngine::instance()->ACIS_API_error(result);
-      // Copy them first
-      int edge_count = EDGE_list.size();
-      EDGE** EDGEs = new EDGE*[edge_count];
+      // This creates a FACE from the given FACE, only it is extended out.
+      ext_offset_FACE_ptr = make_FACE( offset_FACE_ptr, CUBIT_TRUE );
+      ext_offset_BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY( ext_offset_FACE_ptr );
-      EDGE_list.reset();
-      for( i=0; i<EDGE_list.size(); i++ )
-	  EDGE_ptr = EDGE_list.get_and_step();
+         PRINT_ERROR("Problems finding intersections of curve and surface.\n" );
-	  api_edge( EDGE_ptr, tmp_EDGE_ptr );
+   else
+      FACE* ext_FACE_ptr = make_FACE( FACE_ptr, ext_surf );
+      BODY *ext_BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY( ext_FACE_ptr );
+      if( AcisQueryEngine::instance()->get_intersections( EDGE_ptr, ext_FACE_ptr, intersection_list ) == CUBIT_FAILURE )
+         api_delent( ext_BODY_ptr );
-	  EDGEs[i] = tmp_EDGE_ptr;
-	  // Remove the owner attribute from the copied edge & children
-	  ATTRIB_CUBIT_OWNER::remove_cubit_owner(EDGEs[i], CUBIT_TRUE);
+EDGE *
+AcisModifyEngine::copy_and_move_EDGE( EDGE *EDGE_ptr,
+                                      const CubitVector &input_dir,
+                                      double dist )
+   // Setup translation transform
+   SPAtransf tr;
+   CubitVector dir(input_dir);
+   dir.normalize(); // For now, allow this SPAvector to be modified
+   CubitVector delta = dist*dir;
+   SPAvector vec(delta.x(), delta.y(), delta.z() );
+   tr = translate_transf( vec );
-      // The EDGEs are put into the wire so don't delete them.
-      BODY* wire_BODY = NULL;
-      outcome result = api_make_ewire( edge_count, EDGEs, wire_BODY );
+   EDGE* new_EDGE_ptr;
+   outcome result = api_trans_edge( EDGE_ptr, tr, new_EDGE_ptr );
+   if (!result.ok())
+     AcisQueryEngine::instance()->ACIS_API_error( result );
+     return NULL;
-      if( !result.ok() || wire_BODY==NULL )
-	  AcisQueryEngine::instance()->ACIS_API_error(result);
-	  PRINT_ERROR( "unable to make ACIS wire body from curves\n" );
-	  if( wire_BODY )
-	    api_delent( (ENTITY*)wire_BODY );
-	  else
-	      for( i=0; i<edge_count; i++)
-		api_delent( (ENTITY*)EDGEs[i] );
+   // Remove the CUBIT owner attributes from the new edge
+   ATTRIB_CUBIT_OWNER::remove_cubit_owner((ENTITY*)new_EDGE_ptr, CUBIT_TRUE);
-      //The gap type is as follows; 0 = rounded like arcs, 1 = extended like lines, and 2 =
-      //natural like curve extensions. Lines are extend with lines and circles are extended with
-      //circles.
+   return new_EDGE_ptr;
-      law* offset_law = new constant_law( offset_distance );
-      law *twist_law=NULL;
-      BODY* offset_WIRE;
-      logical trim_flg = TRUE;
+CubitStatus
+AcisModifyEngine::offset_EDGES( DLIList<EDGE*> &EDGE_list,
+                                int gap_type,
+                                DLIList<EDGE*> &new_EDGE_list )
+   int i;
+   EDGE *EDGE_ptr = NULL;
+   //ENTITY *ENTITY_ptr = NULL;
+   EDGE *tmp_EDGE_ptr = NULL;
-      // need to check if wire is planar and calculate the
-      // normal to the plane
-      WIRE* this_wire = wire_BODY->wire() ?
-	wire_BODY->wire() : wire_BODY->lump()->shell()->wire();
+   // Need to create a wire from the EDGEs
-      SPAposition centroid;
-      SPAunit_vector normal;
-      if(!is_planar_wire(this_wire, centroid, normal))
-	  PRINT_ERROR("selected curves do not form a planar chain\n");
+   // Copy them first
+   int edge_count = EDGE_list.size();
+   EDGE** EDGEs = new EDGE*[edge_count];
-      // Offset the wire to get the new curves
-      result = api_offset_planar_wire( wire_BODY, offset_law, twist_law,
-				       normal, offset_WIRE, gap_type, trim_flg );
+   EDGE_list.reset();
+   for( i=0; i<EDGE_list.size(); i++ )
+      EDGE_ptr = EDGE_list.get_and_step();
-	  PRINT_ERROR( "unable to offset wire volume\n" );
+      api_edge( EDGE_ptr, tmp_EDGE_ptr );
-      // Copy out the EDGES from the WIRE, then delete the WIRE
-      DLIList<EDGE*> wire_edge_list;
-      AcisQueryEngine::instance()->get_EDGEs( (ENTITY *)offset_WIRE, wire_edge_list );
+      EDGEs[i] = tmp_EDGE_ptr;
-      // Sometimes the function works but we don't get any edges
-      if( !wire_edge_list.size() )
+      // Remove the owner attribute from the copied edge & children
+      ATTRIB_CUBIT_OWNER::remove_cubit_owner(EDGEs[i], CUBIT_TRUE);
-      wire_edge_list.reset();
-      EDGE *new_EDGE_ptr;
-      for( i=0; i<wire_edge_list.size(); i++ )
-	  EDGE_ptr = wire_edge_list.get_and_step();
+   // The EDGEs are put into the wire so don't delete them.
+   BODY* wire_BODY = NULL;
+   outcome result = api_make_ewire( edge_count, EDGEs, wire_BODY );
-	  result = api_edge( EDGE_ptr, new_EDGE_ptr );
-	      PRINT_INFO( "Unable to copy curve from new WIRE\n" );
+   if( !result.ok() || wire_BODY==NULL )
+     PRINT_ERROR( "unable to make ACIS wire body from curves\n" );
+     if( wire_BODY )
+       api_delent( (ENTITY*)wire_BODY );
+     else
+       for( i=0; i<edge_count; i++)
+         api_delent( (ENTITY*)EDGEs[i] );
-	  new_EDGE_list.append( new_EDGE_ptr );
+   //The gap type is as follows; 0 = rounded like arcs, 1 = extended like lines, and 2 =
+   //natural like curve extensions. Lines are extend with lines and circles are extended with
+   //circles.
-      // Delete the WIRE
+   law* offset_law = new constant_law( offset_distance );
+   law *twist_law=NULL;
+   BODY* offset_WIRE;
+   logical trim_flg = TRUE;
+   // need to check if wire is planar and calculate the
+   // normal to the plane
+   WIRE* this_wire = wire_BODY->wire() ?
+      wire_BODY->wire() : wire_BODY->lump()->shell()->wire();
+   SPAposition centroid;
+   SPAunit_vector normal;
+   if(!is_planar_wire(this_wire, centroid, normal))
+      PRINT_ERROR("selected curves do not form a planar chain\n");
+   // Offset the wire to get the new curves
+   result = api_offset_planar_wire( wire_BODY, offset_law, twist_law,
+                                    normal, offset_WIRE, gap_type, trim_flg );
-  Curve* AcisModifyEngine::find_curve_by_end_coord( const CubitVector& coords,
-						    DLIList<Curve*>& curves,
-						    bool& start_flag ) const
-      Curve* curve = 0;
-      CubitVector curve_pt;
-      const double tol = AcisQueryEngine::instance()->get_sme_resabs_tolerance();
-      const double tolsqr = tol*tol;
+      PRINT_ERROR( "unable to offset wire volume\n" );
-      DLIList<Curve*> tmp_list(curves);
-      tmp_list.reset();
-      for ( int i = curves.size(); i--; )
-	  curve = tmp_list.get_and_step();
+   // Copy out the EDGES from the WIRE, then delete the WIRE
+   DLIList<EDGE*> wire_edge_list;
+   AcisQueryEngine::instance()->get_EDGEs( (ENTITY *)offset_WIRE, wire_edge_list );
-	  curve->position_from_fraction( 0.0, curve_pt );
-	  if ( (curve_pt - coords).length_squared() < tolsqr )
-	      start_flag = true;
-	      return curve;
+   // Sometimes the function works but we don't get any edges
+   if( !wire_edge_list.size() )
-	  curve->position_from_fraction( 1.0, curve_pt );
-	      start_flag = false;
-	      return curve;
+   wire_edge_list.reset();
+   EDGE *new_EDGE_ptr;
+   for( i=0; i<wire_edge_list.size(); i++ )
+      EDGE_ptr = wire_edge_list.get_and_step();
-      return 0;
+      result = api_edge( EDGE_ptr, new_EDGE_ptr );
+         PRINT_INFO( "Unable to copy curve from new WIRE\n" );
-  bool AcisModifyEngine::bridge_deactivated(AcisBridge* bridge) const
-      return deactivatedSet.count(bridge) > 0;
+      new_EDGE_list.append( new_EDGE_ptr );
-  CubitStatus AcisModifyEngine::deactivate_bridge( AcisBridge* bridge ) const
+   // Delete the WIRE
+Curve* AcisModifyEngine::find_curve_by_end_coord( const CubitVector& coords,
+                                                  DLIList<Curve*>& curves,
+                                                  bool& start_flag ) const
+  Curve* curve = 0;
+  CubitVector curve_pt;
+  const double tol = AcisQueryEngine::instance()->get_sme_resabs_tolerance();
+  const double tolsqr = tol*tol;
+  DLIList<Curve*> tmp_list(curves);
+  tmp_list.reset();
+  for ( int i = curves.size(); i--; )
+    curve = tmp_list.get_and_step();
+    curve->position_from_fraction( 0.0, curve_pt );
+    if ( (curve_pt - coords).length_squared() < tolsqr )
-      AcisModifyEngine* nonconst = AcisModifyEngine::instance();
-      bool unique = nonconst->deactivatedSet.insert(bridge).second;
-      return (CubitStatus)unique;
+      start_flag = true;
+      return curve;
-  CubitStatus AcisModifyEngine::reactivate_bridge( AcisBridge* bridge ) const
+    curve->position_from_fraction( 1.0, curve_pt );
-      int count = nonconst->deactivatedSet.erase(bridge);
-      return count > 0 ? CUBIT_SUCCESS : CUBIT_FAILURE;
+      start_flag = false;
+      return curve;
-  void AcisModifyEngine::cleanout_deactivated_geometry() const
-      //  std::set<AcisBridge*>::iterator itor = nonconst->deactivatedSet.begin(),
-      //                                  end  = nonconst->deactivatedSet.end();
-      //  for ( ; itor != end; ++itor )
-      //    delete *itor;
+  return 0;
-      nonconst->deactivatedSet.clear();
+bool AcisModifyEngine::bridge_deactivated(AcisBridge* bridge) const
+  return deactivatedSet.count(bridge) > 0;
-  CubitStatus AcisModifyEngine::scale( BodySM *&body, const CubitVector& f )
+CubitStatus AcisModifyEngine::deactivate_bridge( AcisBridge* bridge ) const
+  AcisModifyEngine* nonconst = AcisModifyEngine::instance();
+  bool unique = nonconst->deactivatedSet.insert(bridge).second;
+  return (CubitStatus)unique;
+CubitStatus AcisModifyEngine::reactivate_bridge( AcisBridge* bridge ) const
+  int count = nonconst->deactivatedSet.erase(bridge);
+  return count > 0 ? CUBIT_SUCCESS : CUBIT_FAILURE;
+void AcisModifyEngine::cleanout_deactivated_geometry() const
+//  std::set<AcisBridge*>::iterator itor = nonconst->deactivatedSet.begin(),
+//                                  end  = nonconst->deactivatedSet.end();
+//  for ( ; itor != end; ++itor )
+//    delete *itor;
+  nonconst->deactivatedSet.clear();
+CubitStatus AcisModifyEngine::scale( BodySM *&body, const CubitVector& f )
 #if CUBIT_ACIS_VERSION < 1100
-      api_initialize_operators();
+  api_initialize_operators();
 #elif defined(WIN32) || defined(MACOSX)
-      api_initialize_warp();
+  api_initialize_warp();
 #endif
-      BODY *new_BODY = NULL;
+   BODY *new_BODY = NULL;
-      if( f.x() != f.y() ||
-	  f.x() != f.z() ||
-	  f.y() != f.z() )
-	  BODY *tmp_BODY = AcisQueryEngine::get_BODY( body );
-	  new_BODY = AcisModifyEngine::instance()->copy_BODY(tmp_BODY,
-							     GeometryModifyTool::instance()->get_new_ids());
+  if( f.x() != f.y() ||
+      f.x() != f.z() ||
+      f.y() != f.z() )
+    BODY *tmp_BODY = AcisQueryEngine::get_BODY( body );
+    new_BODY = AcisModifyEngine::instance()->copy_BODY(tmp_BODY,
+                               GeometryModifyTool::instance()->get_new_ids());
-      CubitStatus result = AcisQueryEngine::instance()->transform( new_BODY, scale_transf( f.x(), f.y(), f.z() ) );
+  CubitStatus result = AcisQueryEngine::instance()->transform( new_BODY, scale_transf( f.x(), f.y(), f.z() ) );
-      api_terminate_operators();
+  api_terminate_operators();
-      api_terminate_warp();
+  api_terminate_warp();
 #endif
-      if( new_BODY )
-	  BODY *old_BODY = AcisQueryEngine::get_BODY( body );
-	  BodySM *new_body = get_new_Body( body, old_BODY, new_BODY, false);
-	  body = new_body;
+  if( new_BODY )
+    BODY *old_BODY = AcisQueryEngine::get_BODY( body );
+    BodySM *new_body = get_new_Body( body, old_BODY, new_BODY, false);
+    body = new_body;
-      return result;
+  return result;
-  CubitStatus AcisModifyEngine::tolerant_imprint( DLIList<BodySM*> &bodies_in,
-						  DLIList<BodySM*> &new_bodies,
+CubitStatus AcisModifyEngine::tolerant_imprint( DLIList<BodySM*> &bodies_in,
+                                                 DLIList<BodySM*> &new_bodies,
                                                   DLIList<TopologyBridge*> *new_tbs,
                                                   DLIList<TopologyBridge*> *att_tbs ) const
-      //make sure all bodies are from the same modify engine
-      DLIList<BodySM*> new_body_list;
+  //make sure all bodies are from the same modify engine
+  DLIList<BodySM*> new_body_list;
-      ProgressTool *progress_tool = NULL;
-      if( bodies_in.size() > 2 )
-	  progress_tool = AppUtil::instance()->progress_tool();
-	  progress_tool->start(0, 100, "Tolerant Imprinting" );
+  ProgressTool *progress_tool = NULL;
+  if( bodies_in.size() > 2 )
+     progress_tool = AppUtil::instance()->progress_tool();
+     progress_tool->start(0, 100, "Tolerant Imprinting" );
-      CubitStatus status = imprint_overlapping_curves( bodies_in, new_body_list, progress_tool );
+  CubitStatus status = imprint_overlapping_curves( bodies_in, new_body_list, progress_tool );
-      status = imprint_overlapping_surfaces( bodies_in, new_body_list, progress_tool );
+  status = imprint_overlapping_surfaces( bodies_in, new_body_list, progress_tool );
-      status = imprint_overlapping_curves( bodies_in, new_body_list, progress_tool, new_tbs, att_tbs );
+  status = imprint_overlapping_curves( bodies_in, new_body_list, progress_tool, new_tbs, att_tbs );
-      if( progress_tool )
-	progress_tool->end();
+  if( progress_tool )
+    progress_tool->end();
-      return CUBIT_SUCCESS;
-  CubitStatus AcisModifyEngine::imprint_overlapping_curves( DLIList<BodySM*> &body_sms,
-							    DLIList<BodySM*> &new_body_sms,
-							    ProgressTool *progress_tool,
-							    DLIList<TopologyBridge*> *new_tbs,
-							    DLIList<TopologyBridge*> *att_tbs ) const
-      //find all mergeable curves between the bodies
-      CubitStatus status;
+CubitStatus AcisModifyEngine::imprint_overlapping_curves( DLIList<BodySM*> &body_sms,
+                                                          DLIList<BodySM*> &new_body_sms,
+                                                          ProgressTool *progress_tool,
+                                                          DLIList<TopologyBridge*> *new_tbs,
+                                                          DLIList<TopologyBridge*> *att_tbs ) const
+  //find all mergeable curves between the bodies
+  CubitStatus status;
 #ifdef BOYD16
-      DLIList<RefEntity*> entities;
+  DLIList<RefEntity*> entities;
 #endif
-      DLIList< DLIList<Curve*>* > lists_of_mergeable_curves;
+  DLIList< DLIList<Curve*>* > lists_of_mergeable_curves;
-      status = MergeTool::instance()->find_only_mergeable_curves( body_sms, lists_of_mergeable_curves );
+  status = MergeTool::instance()->find_only_mergeable_curves( body_sms, lists_of_mergeable_curves );
-      int i,j;
-      //increment 4%
-	  for( i=4; i--; )
-	    progress_tool->step();
+  int i,j;
+  //increment 4%
+    for( i=4; i--; )
+      progress_tool->step();
-      //find all overlapping curves between the bodies
-      std::map<Curve*, DLIList<Curve*>* > curve_to_list_map;
-      DLIList< DLIList<Curve*>* > lists_of_overlapping_curves;
-      //for each list, curves 2-n overlap the first curve
+  //find all overlapping curves between the bodies
+  std::map<Curve*, DLIList<Curve*>* > curve_to_list_map;
+  DLIList< DLIList<Curve*>* > lists_of_overlapping_curves;
+  //for each list, curves 2-n overlap the first curve
-      SurfaceOverlapTool::instance()->find_overlapping_curves( body_sms, lists_of_overlapping_curves,
-							       curve_to_list_map );
+  SurfaceOverlapTool::instance()->find_overlapping_curves( body_sms, lists_of_overlapping_curves,
+                                                           curve_to_list_map );
-      //increment 8%
-	  for( i=9; i--; )
+  //increment 8%
+    for( i=9; i--; )
-      //remove idential groups and sub-groups of mergeable curves from
-      //overlapping groups.  For example:  If curves A,B,C,D are in a mergeable group
-      //the following groups will have no need for imprinting, becasue the curves are
-      //mergeable all
-      //A,B,C,D
-      //B,C,D  is a sub-group
-      //C,D  is a sub-group
-      //These groups need not be considered for imprinting
+  //remove idential groups and sub-groups of mergeable curves from
+  //overlapping groups.  For example:  If curves A,B,C,D are in a mergeable group
+  //the following groups will have no need for imprinting, becasue the curves are
+  //mergeable all
+  //A,B,C,D
+  //B,C,D  is a sub-group
+  //C,D  is a sub-group
+  //These groups need not be considered for imprinting
-      std::map<Curve*, DLIList<Curve*>*>::iterator curve_iter;
-      lists_of_mergeable_curves.reset();
+  std::map<Curve*, DLIList<Curve*>*>::iterator curve_iter;
+  lists_of_mergeable_curves.reset();
-      DLIList< DLIList<Curve*>* > lists_to_delete;
+  DLIList< DLIList<Curve*>* > lists_to_delete;
-      for( i=lists_of_mergeable_curves.size(); i--; )
-	  DLIList<Curve*> *mergeable_curve_list = lists_of_mergeable_curves.get_and_step();
+  for( i=lists_of_mergeable_curves.size(); i--; )
+    DLIList<Curve*> *mergeable_curve_list = lists_of_mergeable_curves.get_and_step();
-	  for( j=mergeable_curve_list->size(); j--; )
-	      Curve *tmp_curve = mergeable_curve_list->get_and_step();
-	      curve_iter = curve_to_list_map.find( tmp_curve );
+    for( j=mergeable_curve_list->size(); j--; )
+      Curve *tmp_curve = mergeable_curve_list->get_and_step();
+      curve_iter = curve_to_list_map.find( tmp_curve );
-	      if( curve_iter == curve_to_list_map.end() )
-		continue;
+      if( curve_iter == curve_to_list_map.end() )
+        continue;
-	      DLIList<Curve*>* overlapping_curves = curve_iter->second;
+      DLIList<Curve*>* overlapping_curves = curve_iter->second;
-	      //make sure that list hasn't already been removed
-	      if( lists_to_delete.move_to( overlapping_curves ) )
-		continue;
+      //make sure that list hasn't already been removed
+      if( lists_to_delete.move_to( overlapping_curves ) )
+        continue;
-	      //don't want to perturb the list...make a copy
-	      DLIList<Curve*> copy_list = *mergeable_curve_list;
+      //don't want to perturb the list...make a copy
+      DLIList<Curve*> copy_list = *mergeable_curve_list;
-	      //if the list of overlapping curve is the same as the mergeable curve list,
-	      //remove the list list of overlapping curves
+      //if the list of overlapping curve is the same as the mergeable curve list,
+      //remove the list list of overlapping curves
-	      if( copy_list == *overlapping_curves )
-		  //remove overlapping_curve_list from the list
-		  lists_of_overlapping_curves.move_to( overlapping_curves );
-		  lists_of_overlapping_curves.change_to( NULL );
+      if( copy_list == *overlapping_curves )
+        //remove overlapping_curve_list from the list
+        lists_of_overlapping_curves.move_to( overlapping_curves );
+        lists_of_overlapping_curves.change_to( NULL );
-		  //put in list for deletion
-		  lists_to_delete.append( overlapping_curves );
+        //put in list for deletion
+        lists_to_delete.append( overlapping_curves );
-		  //remove overlapping_curve_list from the map
-		  curve_to_list_map.erase( curve_iter );
-		  continue;
-	      else if (overlapping_curves->size() < copy_list.size() )
-		  //If every curve in overlapping list is in the merge list,
-		  //remove that overlapping list.
-		  int list_size_before = copy_list.size();
-		  copy_list.merge_unique( *overlapping_curves );
-		  if( list_size_before == copy_list.size() )
+        //remove overlapping_curve_list from the map
+        curve_to_list_map.erase( curve_iter );
+        continue;
+      else if (overlapping_curves->size() < copy_list.size() )
+        //If every curve in overlapping list is in the merge list,
+        //remove that overlapping list.
+        int list_size_before = copy_list.size();
+        copy_list.merge_unique( *overlapping_curves );
+        if( list_size_before == copy_list.size() )
-      //clean up lists
-	delete lists_of_mergeable_curves.get_and_step();
-      lists_of_overlapping_curves.remove_all_with_value( NULL );
+  //clean up lists
+    delete lists_of_mergeable_curves.get_and_step();
+  lists_of_overlapping_curves.remove_all_with_value( NULL );
-      for( i=lists_to_delete.size(); i--; )
-	delete lists_to_delete.get_and_step();
+  for( i=lists_to_delete.size(); i--; )
+    delete lists_to_delete.get_and_step();
-      double tolerance = GeometryQueryTool::get_geometry_factor()*GEOMETRY_RESABS;
+  double tolerance = GeometryQueryTool::get_geometry_factor()*GEOMETRY_RESABS;
-      DLIList<BodySM*> imprint_body_order;
-      lists_of_overlapping_curves.reset();
-      //Now setup multi-map for imprinting vertices onto bodies
-      //This is how the curve - vertex imprinting should be done:
-      // -imprint vertices of curve 1 in list onto curves 2 - n
-      // -imprint vertcies of curve 2 - n onto curve 1
-      std::multimap<BodySM*, CubitVector* > body_point_imprint_map;
-      std::multimap<BodySM*, CubitVector* >::iterator tmp_iter, upper_iter;
+  DLIList<BodySM*> imprint_body_order;
+  lists_of_overlapping_curves.reset();
+  //Now setup multi-map for imprinting vertices onto bodies
+  //This is how the curve - vertex imprinting should be done:
+  // -imprint vertices of curve 1 in list onto curves 2 - n
+  // -imprint vertcies of curve 2 - n onto curve 1
+  std::multimap<BodySM*, CubitVector* > body_point_imprint_map;
+  std::multimap<BodySM*, CubitVector* >::iterator tmp_iter, upper_iter;
-      for( i=lists_of_overlapping_curves.size(); i--; )
-	  DLIList<Curve*> *curve_list = lists_of_overlapping_curves.get_and_step();
-	  curve_list->reset();
-	  Curve *first_curve = curve_list->get_and_step();
+  for( i=lists_of_overlapping_curves.size(); i--; )
+    DLIList<Curve*> *curve_list = lists_of_overlapping_curves.get_and_step();
+    curve_list->reset();
+    Curve *first_curve = curve_list->get_and_step();
-	  DLIList<Point*> curve_1_points;
-	  first_curve->points( curve_1_points );
-	  Point *s_point1 = curve_1_points.get_and_step();
-	  Point *e_point1 = curve_1_points.get_and_step();
+    DLIList<Point*> curve_1_points;
+    first_curve->points( curve_1_points );
+    Point *s_point1 = curve_1_points.get_and_step();
+    Point *e_point1 = curve_1_points.get_and_step();
-	  BodySM *first_curve_body = first_curve->bodysm();
+    BodySM *first_curve_body = first_curve->bodysm();
-	  while( curve_list->size() > 1 )
-	      Curve *other_curve = curve_list->pop();
-	      DLIList<Point*> curve_2_points;
-	      other_curve->points( curve_2_points );
-	      Point *s_point2 = curve_2_points.get_and_step();
-	      Point *e_point2 = curve_2_points.get_and_step();
+    while( curve_list->size() > 1 )
+      Curve *other_curve = curve_list->pop();
+      DLIList<Point*> curve_2_points;
+      other_curve->points( curve_2_points );
+      Point *s_point2 = curve_2_points.get_and_step();
+      Point *e_point2 = curve_2_points.get_and_step();
-	      BodySM *other_curve_body = other_curve->bodysm();
+      BodySM *other_curve_body = other_curve->bodysm();
-	      CubitVector close_pt;
-	      first_curve->closest_point_trimmed( s_point2->coordinates(), close_pt );
+      CubitVector close_pt;
+      first_curve->closest_point_trimmed( s_point2->coordinates(), close_pt );
-	      if( close_pt.distance_between( s_point1->coordinates() ) > tolerance &&
-		  close_pt.distance_between( e_point1->coordinates() ) > tolerance )
-		  //are there any other points within tolerance to this point
-		  //to be imprinted onto this body?
-		  tmp_iter = body_point_imprint_map.find( first_curve_body );
-		  bool consider_point = true;
-		  if( tmp_iter != body_point_imprint_map.end() )
-		      CubitVector *tmp_vec = tmp_iter->second;
-		      upper_iter = body_point_imprint_map.upper_bound( tmp_iter->first );
+      if( close_pt.distance_between( s_point1->coordinates() ) > tolerance &&
+          close_pt.distance_between( e_point1->coordinates() ) > tolerance )
+        //are there any other points within tolerance to this point
+        //to be imprinted onto this body?
+        tmp_iter = body_point_imprint_map.find( first_curve_body );
+        bool consider_point = true;
+        if( tmp_iter != body_point_imprint_map.end() )
+          CubitVector *tmp_vec = tmp_iter->second;
+          upper_iter = body_point_imprint_map.upper_bound( tmp_iter->first );
-		      for(; tmp_iter!=upper_iter; ++tmp_iter)
-			  tmp_vec = tmp_iter->second;
-			  if( close_pt.distance_between( *tmp_vec ) < tolerance )
-			      consider_point = false;
-			      break;
+          for(; tmp_iter!=upper_iter; ++tmp_iter)
+            tmp_vec = tmp_iter->second;
+            if( close_pt.distance_between( *tmp_vec ) < tolerance )
+              consider_point = false;
+              break;
-		  if( consider_point )
-		      //imprint body of curve1 with vertex at this location
-		      CubitVector *tmp_vec = new CubitVector( close_pt );
-		      body_point_imprint_map.insert( std::multimap<BodySM*,
-						     CubitVector*>::value_type( first_curve_body, tmp_vec ));
-		      imprint_body_order.append_unique( first_curve_body );
+        if( consider_point )
+          //imprint body of curve1 with vertex at this location
+          CubitVector *tmp_vec = new CubitVector( close_pt );
+          body_point_imprint_map.insert( std::multimap<BodySM*,
+              CubitVector*>::value_type( first_curve_body, tmp_vec ));
+          imprint_body_order.append_unique( first_curve_body );
-	      first_curve->closest_point_trimmed( e_point2->coordinates(), close_pt );
+      first_curve->closest_point_trimmed( e_point2->coordinates(), close_pt );
-			      break;
+              break;
-	      other_curve->closest_point_trimmed( s_point1->coordinates(), close_pt );
+      other_curve->closest_point_trimmed( s_point1->coordinates(), close_pt );
-	      if( close_pt.distance_between( s_point2->coordinates() ) > tolerance &&
-		  close_pt.distance_between( e_point2->coordinates() ) > tolerance )
-		  tmp_iter = body_point_imprint_map.find( other_curve_body );
+      if( close_pt.distance_between( s_point2->coordinates() ) > tolerance &&
+          close_pt.distance_between( e_point2->coordinates() ) > tolerance )
+        tmp_iter = body_point_imprint_map.find( other_curve_body );
-			      break;
+              break;
-						     CubitVector*>::value_type( other_curve_body, tmp_vec ));
-		      imprint_body_order.append_unique( other_curve_body );
+              CubitVector*>::value_type( other_curve_body, tmp_vec ));
+          imprint_body_order.append_unique( other_curve_body );
-	      other_curve->closest_point_trimmed( e_point1->coordinates(), close_pt );
+      other_curve->closest_point_trimmed( e_point1->coordinates(), close_pt );
-		  //Are there already any other points within tolerance to this point
-		  //If so, don't imprint this point.
+        //Are there already any other points within tolerance to this point
+        //If so, don't imprint this point.
-		      for(; tmp_iter!=upper_iter; ++tmp_iter )
-			      break;
+          for(; tmp_iter!=upper_iter; ++tmp_iter )
+              break;
-      //Imprint Vertices-onto-Body
-      imprint_body_order.reset();
-      std::multimap<BodySM*, CubitVector*>::iterator point_iter, last_point_iter;
-      for( i=imprint_body_order.size(); i--; )
-	  BodySM *tmp_body_sm = imprint_body_order.get_and_step();
-	  DLIList<BodySM*> body_to_imprint;
-	  body_to_imprint.append( tmp_body_sm );
+  //Imprint Vertices-onto-Body
+  imprint_body_order.reset();
+  std::multimap<BodySM*, CubitVector*>::iterator point_iter, last_point_iter;
+  for( i=imprint_body_order.size(); i--; )
+    BodySM *tmp_body_sm = imprint_body_order.get_and_step();
+    DLIList<BodySM*> body_to_imprint;
+    body_to_imprint.append( tmp_body_sm );
-	  DLIList<CubitVector*> points_to_imprint;
+    DLIList<CubitVector*> points_to_imprint;
-	  point_iter = body_point_imprint_map.find( tmp_body_sm );
-	  last_point_iter = body_point_imprint_map.upper_bound( point_iter->first );
+    point_iter = body_point_imprint_map.find( tmp_body_sm );
+    last_point_iter = body_point_imprint_map.upper_bound( point_iter->first );
-	  for(; point_iter!=last_point_iter; ++point_iter )
-	    points_to_imprint.append( point_iter->second );
+    for(; point_iter!=last_point_iter; ++point_iter )
+      points_to_imprint.append( point_iter->second );
-	  DLIList<BodySM*> new_bodies;
-	  CubitStatus status = imprint( body_to_imprint, points_to_imprint, new_bodies, false, new_tbs, att_tbs );
-	  if( new_bodies.size() )
-	    new_body_sms.append( new_bodies.get() );
+    DLIList<BodySM*> new_bodies;
+    CubitStatus status = imprint( body_to_imprint, points_to_imprint, new_bodies, false, new_tbs, att_tbs );
+    if( new_bodies.size() )
+      new_body_sms.append( new_bodies.get() );
-	  for( j=points_to_imprint.size(); j--; )
-	    delete points_to_imprint.get_and_step();
+    for( j=points_to_imprint.size(); j--; )
+      delete points_to_imprint.get_and_step();
-      //increment 4%
-	  for( i=4; i--; )
+  //increment 4%
+    for( i=4; i--; )
+  return CUBIT_SUCCESS;
-  CubitStatus AcisModifyEngine::imprint_overlapping_surfaces( DLIList<BodySM*> &body_sms,
-							      ProgressTool *progress_tool) const
-      //Find all mergeable surfaces between the bodies
-      DLIList< DLIList<Surface*>* > lists_of_mergeable_surfaces;
-      CubitStatus status = MergeTool::instance()->
-	find_only_mergeable_surfaces( body_sms, lists_of_mergeable_surfaces );
+CubitStatus AcisModifyEngine::imprint_overlapping_surfaces( DLIList<BodySM*> &body_sms,
+                                                            ProgressTool *progress_tool) const
+  //Find all mergeable surfaces between the bodies
+  DLIList< DLIList<Surface*>* > lists_of_mergeable_surfaces;
+  CubitStatus status = MergeTool::instance()->
+      find_only_mergeable_surfaces( body_sms, lists_of_mergeable_surfaces );
-	progress_tool->percent( 0.24 );
+    progress_tool->percent( 0.24 );
-      //Find all overlapping surfaces between the bodies
-      DLIList<Surface*> overlapping_surfaces1;
-      DLIList<Surface*> overlapping_surfaces2;
-	find_overlapping_surfaces( body_sms, overlapping_surfaces1, overlapping_surfaces2 );
+  //Find all overlapping surfaces between the bodies
+  DLIList<Surface*> overlapping_surfaces1;
+  DLIList<Surface*> overlapping_surfaces2;
+    find_overlapping_surfaces( body_sms, overlapping_surfaces1, overlapping_surfaces2 );
-	progress_tool->percent( 0.57 );
+    progress_tool->percent( 0.57 );
-      //We only want the non-mergeable overlapping surfaces.
-      //Remove mergable surfaces from overlapping pairs.
-      int i, j, k;
-      for( i=lists_of_mergeable_surfaces.size(); i--; )
-	  DLIList<Surface*> *tmp_surface_list = lists_of_mergeable_surfaces.get_and_step();
-	  for( j=tmp_surface_list->size(); j--; )
-	      Surface *tmp_surface = tmp_surface_list->get_and_step();
-	      while( overlapping_surfaces1.move_to( tmp_surface ) )
-		overlapping_surfaces1.change_to(NULL);
-	      while( overlapping_surfaces2.move_to( tmp_surface ) )
-		overlapping_surfaces2.change_to(NULL);
-	  delete tmp_surface_list;
+  //We only want the non-mergeable overlapping surfaces.
+  //Remove mergable surfaces from overlapping pairs.
+  int i, j, k;
+  for( i=lists_of_mergeable_surfaces.size(); i--; )
+    DLIList<Surface*> *tmp_surface_list = lists_of_mergeable_surfaces.get_and_step();
+    for( j=tmp_surface_list->size(); j--; )
+      Surface *tmp_surface = tmp_surface_list->get_and_step();
+      while( overlapping_surfaces1.move_to( tmp_surface ) )
+        overlapping_surfaces1.change_to(NULL);
+      while( overlapping_surfaces2.move_to( tmp_surface ) )
+        overlapping_surfaces2.change_to(NULL);
+    delete tmp_surface_list;
-	progress_tool->percent( 0.59 );
+    progress_tool->percent( 0.59 );
-      //Surface A might be mergeable/overlapping with B and just ever-so-slightly
-      //overlapping with C. Get rid of C or other overlapping surfaces
-      //that might be in the list.
-      overlapping_surfaces1.reset();
-      overlapping_surfaces2.reset();
-      for( i=overlapping_surfaces1.size(); i--; )
-	  Surface *tmp_surface1 = overlapping_surfaces1.get();
-	  Surface *tmp_surface2 = overlapping_surfaces2.get();
+  //Surface A might be mergeable/overlapping with B and just ever-so-slightly
+  //overlapping with C. Get rid of C or other overlapping surfaces
+  //that might be in the list.
+  overlapping_surfaces1.reset();
+  overlapping_surfaces2.reset();
+  for( i=overlapping_surfaces1.size(); i--; )
+    Surface *tmp_surface1 = overlapping_surfaces1.get();
+    Surface *tmp_surface2 = overlapping_surfaces2.get();
-	  if( tmp_surface1 != NULL )
-	      if( tmp_surface2 == NULL )
-	  else
-	      if( tmp_surface2 != NULL )
+    if( tmp_surface1 != NULL )
+      if( tmp_surface2 == NULL )
+    else
+      if( tmp_surface2 != NULL )
-	  overlapping_surfaces1.step();
-	  overlapping_surfaces2.step();
+    overlapping_surfaces1.step();
+    overlapping_surfaces2.step();
-      overlapping_surfaces1.remove_all_with_value(NULL);
-      overlapping_surfaces2.remove_all_with_value(NULL);
+  overlapping_surfaces1.remove_all_with_value(NULL);
+  overlapping_surfaces2.remove_all_with_value(NULL);
-      if ( overlapping_surfaces1.size() != overlapping_surfaces2.size() )
-	  PRINT_ERROR("Number of overlapping pairs of surfaces is wrong.\n");
-	  return CUBIT_FAILURE;
+  if ( overlapping_surfaces1.size() != overlapping_surfaces2.size() )
+    PRINT_ERROR("Number of overlapping pairs of surfaces is wrong.\n");
+    return CUBIT_FAILURE;
-	progress_tool->percent( 0.62 );
+    progress_tool->percent( 0.62 );
-      // Make sure we are working with ACIS surfaces and not
-      // something at some higher level.
-      DLIList<Surface*> surfs_to_append1;
-      DLIList<Surface*> surfs_to_append2;
-      for(j=overlapping_surfaces1.size(); j--;)
-	  Surface *s1 = overlapping_surfaces1.get();
-	  Surface *s2 = overlapping_surfaces2.get();
+  // Make sure we are working with ACIS surfaces and not
+  // something at some higher level.
+  DLIList<Surface*> surfs_to_append1;
+  DLIList<Surface*> surfs_to_append2;
+  for(j=overlapping_surfaces1.size(); j--;)
+    Surface *s1 = overlapping_surfaces1.get();
+    Surface *s2 = overlapping_surfaces2.get();
-	  GeometryQueryEngine *gqe1 = s1->get_geometry_query_engine();
-	  GeometryQueryEngine *gqe2 = s2->get_geometry_query_engine();
+    GeometryQueryEngine *gqe1 = s1->get_geometry_query_engine();
+    GeometryQueryEngine *gqe2 = s2->get_geometry_query_engine();
-	  DLIList<TopologyBridge*> tbs1, tbs2;
-	  gqe1->get_underlying_surfaces(s1, tbs1);
-	  gqe2->get_underlying_surfaces(s2, tbs2);
-	  int num_surfs1 = tbs1.size();
-	  int num_surfs2 = tbs2.size();
-	  if(num_surfs1 > 0 || num_surfs2 > 0)
-	      if(num_surfs1 == 0)
-		  for(k=tbs2.size(); k--;)
-		      surfs_to_append1.append(s1);
-		      surfs_to_append2.append(dynamic_cast<Surface*>(tbs2.get_and_step()));
-	      else if(num_surfs2 == 0)
-		  for(k=tbs1.size(); k--;)
-		      surfs_to_append2.append(s2);
-		      surfs_to_append1.append(dynamic_cast<Surface*>(tbs1.get_and_step()));
-	      else
-		      int u;
-		      Surface *tmp1 = dynamic_cast<Surface*>(tbs1.get_and_step());
-		      for(u=num_surfs2; u--;)
-			  surfs_to_append1.append(tmp1);
+    DLIList<TopologyBridge*> tbs1, tbs2;
+    gqe1->get_underlying_surfaces(s1, tbs1);
+    gqe2->get_underlying_surfaces(s2, tbs2);
+    int num_surfs1 = tbs1.size();
+    int num_surfs2 = tbs2.size();
+    if(num_surfs1 > 0 || num_surfs2 > 0)
+      if(num_surfs1 == 0)
+        for(k=tbs2.size(); k--;)
+          surfs_to_append1.append(s1);
+          surfs_to_append2.append(dynamic_cast<Surface*>(tbs2.get_and_step()));
+      else if(num_surfs2 == 0)
+        for(k=tbs1.size(); k--;)
+          surfs_to_append2.append(s2);
+          surfs_to_append1.append(dynamic_cast<Surface*>(tbs1.get_and_step()));
+      else
+          int u;
+          Surface *tmp1 = dynamic_cast<Surface*>(tbs1.get_and_step());
+          for(u=num_surfs2; u--;)
+            surfs_to_append1.append(tmp1);
-      for(k=surfs_to_append1.size(); k--;)
-	  overlapping_surfaces1.append(surfs_to_append1.get_and_step());
-	  overlapping_surfaces2.append(surfs_to_append2.get_and_step());
+  for(k=surfs_to_append1.size(); k--;)
+    overlapping_surfaces1.append(surfs_to_append1.get_and_step());
+    overlapping_surfaces2.append(surfs_to_append2.get_and_step());
-      //Now that we have non-mergeable overlapping surface pairs, determine which
-      //curves of surface1 to imprint onto surface2 and vice versa.
-      //We eliminate curves between the 2 surfaces that overlap.
-      DLIList<Surface*> surface_ordering_list;
-      std::multimap<Surface*, Curve*> surface_curve_imprint_map;
+  //Now that we have non-mergeable overlapping surface pairs, determine which
+  //curves of surface1 to imprint onto surface2 and vice versa.
+  //We eliminate curves between the 2 surfaces that overlap.
+  DLIList<Surface*> surface_ordering_list;
+  std::multimap<Surface*, Curve*> surface_curve_imprint_map;
-	  Surface *overlapping_surface1 = overlapping_surfaces1.get_and_step();
-	  Surface *overlapping_surface2 = overlapping_surfaces2.get_and_step();
+    Surface *overlapping_surface1 = overlapping_surfaces1.get_and_step();
+    Surface *overlapping_surface2 = overlapping_surfaces2.get_and_step();
-	  //get all the curves of the surfaces
-	  DLIList<Curve*> curves2, curves1;
-	  overlapping_surface2->curves( curves2 );
-	  overlapping_surface1->curves( curves1 );
+    //get all the curves of the surfaces
+    DLIList<Curve*> curves2, curves1;
+    overlapping_surface2->curves( curves2 );
+    overlapping_surface1->curves( curves1 );
-	  // Make sure we are working with ACIS curves
-	  // and not something at some higher level.
-	  DLIList<Curve*> curves_to_remove;
-	  DLIList<Curve*> curves_to_append;
-	  curves2.reset();
-	  for(j=curves2.size(); j--;)
-	      Curve *c = curves2.get_and_step();
-	      GeometryQueryEngine *gqe = c->get_geometry_query_engine();
-	      DLIList<TopologyBridge*> tbs;
-	      gqe->get_underlying_curves(c, tbs);
-	      if(tbs.size() > 0)
-		  curves_to_remove.append(c);
-		  for(k=tbs.size(); k--;)
-		    curves_to_append.append(dynamic_cast<Curve*>(tbs.get_and_step()));
-	  curves2 -= curves_to_remove;
-	  curves2 += curves_to_append;
-	  curves_to_remove.clean_out();
-	  curves_to_append.clean_out();
-	  curves1.reset();
-	  for(j=curves1.size(); j--;)
-	      Curve *c = curves1.get_and_step();
-	  curves1 -= curves_to_remove;
-	  curves1 += curves_to_append;
+    // Make sure we are working with ACIS curves
+    // and not something at some higher level.
+    DLIList<Curve*> curves_to_remove;
+    DLIList<Curve*> curves_to_append;
+    curves2.reset();
+    for(j=curves2.size(); j--;)
+      Curve *c = curves2.get_and_step();
+      GeometryQueryEngine *gqe = c->get_geometry_query_engine();
+      DLIList<TopologyBridge*> tbs;
+      gqe->get_underlying_curves(c, tbs);
+      if(tbs.size() > 0)
+        curves_to_remove.append(c);
+        for(k=tbs.size(); k--;)
+          curves_to_append.append(dynamic_cast<Curve*>(tbs.get_and_step()));
+    curves2 -= curves_to_remove;
+    curves2 += curves_to_append;
+    curves_to_remove.clean_out();
+    curves_to_append.clean_out();
+    curves1.reset();
+    for(j=curves1.size(); j--;)
+      Curve *c = curves1.get_and_step();
+    curves1 -= curves_to_remove;
+    curves1 += curves_to_append;
-	  //Get bounding box for later
-	  CubitBox bb_surf = overlapping_surface1->bounding_box();
+    //Get bounding box for later
+    CubitBox bb_surf = overlapping_surface1->bounding_box();
-	  //remove overlapping curves between the 2 surfaces
-	  for( j=curves2.size(); j--; )
-	      Curve *tmp_curve = curves2.get();
+    //remove overlapping curves between the 2 surfaces
+    for( j=curves2.size(); j--; )
+      Curve *tmp_curve = curves2.get();
-	      int k;
-	      bool overlap = false;
-	      for( k=curves1.size(); k--; )
-		  if( curves1.get() )
-		      Curve *tmp_curve_2 = curves1.get();
+      int k;
+      bool overlap = false;
+      for( k=curves1.size(); k--; )
+        if( curves1.get() )
+          Curve *tmp_curve_2 = curves1.get();
-		      if( SurfaceOverlapTool::instance()->
-			  check_overlap( tmp_curve, tmp_curve_2, NULL))
-			  //They should be about spatially equal too!
-			  //            CubitSense dummy_sense;
-			  //            if( MergeTool::instance()->about_spatially_equal( curves1.get(), curves2.get(),
-			  //                      dummy_sense, GeometryQueryTool::get_geometry_factor() ) )
-			  curves1.change_to(NULL);
-			  curves2.change_to(NULL);
-			  overlap = true;
-			  break;
-		  curves1.step();
-	      if( overlap )
-		  curves2.step();
-		  continue;
+          if( SurfaceOverlapTool::instance()->
+            check_overlap( tmp_curve, tmp_curve_2, NULL))
+            //They should be about spatially equal too!
+//            CubitSense dummy_sense;
+//            if( MergeTool::instance()->about_spatially_equal( curves1.get(), curves2.get(),
+//                      dummy_sense, GeometryQueryTool::get_geometry_factor() ) )
+              curves1.change_to(NULL);
+              curves2.change_to(NULL);
+              overlap = true;
+              break;
+        curves1.step();
+      if( overlap )
+        curves2.step();
+        continue;
-	      double distance;
-	      CubitVector v1, v2;
+      double distance;
+      CubitVector v1, v2;
-	      //bounding box check between curve and surface
-	      CubitBox bb_curve = tmp_curve->bounding_box();
-	      if( bb_surf.overlap( tolerance, bb_curve ) )
-		  //measure distance between curve and surface
-		  overlapping_surface1->get_geometry_query_engine()->entity_entity_distance(
-											    overlapping_surface1, tmp_curve, v1, v2, distance );
+      //bounding box check between curve and surface
+      CubitBox bb_curve = tmp_curve->bounding_box();
+      if( bb_surf.overlap( tolerance, bb_curve ) )
+        //measure distance between curve and surface
+        overlapping_surface1->get_geometry_query_engine()->entity_entity_distance(
+            overlapping_surface1, tmp_curve, v1, v2, distance );
-		  if( distance < tolerance )
-		      //check multimap to make sure that this curve has not already
-		      //been added (from another surface that shares it)
-		      //or that is overlaps another curve in the multimap
-		      std::pair< std::multimap<Surface*, Curve* >::iterator,
-			std::multimap<Surface*, Curve* >::iterator > surface_curve_pair;
-		      surface_curve_pair = surface_curve_imprint_map.equal_range( overlapping_surface1 );
+        if( distance < tolerance )
+          //check multimap to make sure that this curve has not already
+          //been added (from another surface that shares it)
+          //or that is overlaps another curve in the multimap
+          std::pair< std::multimap<Surface*, Curve* >::iterator,
+                     std::multimap<Surface*, Curve* >::iterator > surface_curve_pair;
+          surface_curve_pair = surface_curve_imprint_map.equal_range( overlapping_surface1 );
-		      std::multimap<Surface*, Curve*>::iterator iter = surface_curve_pair.first;
-		      std::multimap<Surface*, Curve*>::iterator end = surface_curve_pair.second;
-		      bool match_found = false;
-		      while( iter != end )
-			  if( iter->second == tmp_curve )
-			      match_found = true;
-			      break;
+          std::multimap<Surface*, Curve*>::iterator iter = surface_curve_pair.first;
+          std::multimap<Surface*, Curve*>::iterator end = surface_curve_pair.second;
+          bool match_found = false;
+          while( iter != end )
+            if( iter->second == tmp_curve )
+              match_found = true;
+              break;
-			  if( SurfaceOverlapTool::instance()->check_overlap( iter->second, tmp_curve, NULL ) )
-			      break;
+            if( SurfaceOverlapTool::instance()->check_overlap( iter->second, tmp_curve, NULL ) )
+              break;
-			  iter++;
+            iter++;
-		      if( match_found == false )
-			  surface_curve_imprint_map.insert( std::multimap<Surface*, Curve*>::value_type(
-													overlapping_surface1, tmp_curve ));
-			  surface_ordering_list.append_unique( overlapping_surface1 );
-	      curves2.step();
+          if( match_found == false )
+            surface_curve_imprint_map.insert( std::multimap<Surface*, Curve*>::value_type(
+                        overlapping_surface1, tmp_curve ));
+            surface_ordering_list.append_unique( overlapping_surface1 );
+      curves2.step();
-	  bb_surf = overlapping_surface2->bounding_box();
-	  curves1.remove_all_with_value( NULL );
-	  curves2.remove_all_with_value( NULL );
-	  //insert body and copied curves into list
-	  for( j=curves1.size(); j--; )
-	      Curve *tmp_curve = curves1.get();
+    bb_surf = overlapping_surface2->bounding_box();
+    curves1.remove_all_with_value( NULL );
+    curves2.remove_all_with_value( NULL );
+    //insert body and copied curves into list
+    for( j=curves1.size(); j--; )
+      Curve *tmp_curve = curves1.get();
-	      double distance;
-		  overlapping_surface2->get_geometry_query_engine()->entity_entity_distance(
-											    overlapping_surface2, tmp_curve, v1, v2, distance );
+      double distance;
+        overlapping_surface2->get_geometry_query_engine()->entity_entity_distance(
+          overlapping_surface2, tmp_curve, v1, v2, distance );
-		      surface_curve_pair = surface_curve_imprint_map.equal_range( overlapping_surface2 );
+          surface_curve_pair = surface_curve_imprint_map.equal_range( overlapping_surface2 );
-			      break;
+              break;
-			      break;
+              break;
-			  iter++;
+            iter++;
-													overlapping_surface2, tmp_curve ));
-			  surface_ordering_list.append_unique( overlapping_surface2 );
+                                overlapping_surface2, tmp_curve ));
+            surface_ordering_list.append_unique( overlapping_surface2 );
-	      curves1.step();
+      curves1.step();
-	progress_tool->percent( 0.64 );
+    progress_tool->percent( 0.64 );
-      //We cannot use the original curves for imprinting....they'll be
-      //getting modified.  Make copies of them here and build a new multimap
-      std::multimap<Surface*, Curve*>::iterator surf_curve_iter, surf_curve_last;
-      std::multimap<Surface*, Curve*> final_surface_curve_imprint_map;
-      for( surf_curve_iter = surface_curve_imprint_map.begin();
-	   surf_curve_iter != surface_curve_imprint_map.end(); )
-	  Surface *tmp_surf = surf_curve_iter->first;
-	  surf_curve_last = surface_curve_imprint_map.upper_bound( tmp_surf );
+  //We cannot use the original curves for imprinting....they'll be
+  //getting modified.  Make copies of them here and build a new multimap
+  std::multimap<Surface*, Curve*>::iterator surf_curve_iter, surf_curve_last;
+  std::multimap<Surface*, Curve*> final_surface_curve_imprint_map;
+  for( surf_curve_iter = surface_curve_imprint_map.begin();
+       surf_curve_iter != surface_curve_imprint_map.end(); )
+    Surface *tmp_surf = surf_curve_iter->first;
+    surf_curve_last = surface_curve_imprint_map.upper_bound( tmp_surf );
-	  for(; surf_curve_iter!=surf_curve_last; ++surf_curve_iter )
-	      Curve *copied_curve = make_Curve( surf_curve_iter->second );
-	      final_surface_curve_imprint_map.insert( std::multimap<Surface*,
-						      Curve*>::value_type( tmp_surf, copied_curve ));
+    for(; surf_curve_iter!=surf_curve_last; ++surf_curve_iter )
+      Curve *copied_curve = make_Curve( surf_curve_iter->second );
+      final_surface_curve_imprint_map.insert( std::multimap<Surface*,
+                  Curve*>::value_type( tmp_surf, copied_curve ));
-	progress_tool->percent( 0.67 );
+    progress_tool->percent( 0.67 );
-      double percentage_per_surface = 0;
-      double delta = 0;
+  double percentage_per_surface = 0;
+  double delta = 0;
-	  if( surface_ordering_list.size() )
-	    percentage_per_surface = 0.16 / surface_ordering_list.size();
-	  else
-	    progress_tool->percent( 0.83 );
+    if( surface_ordering_list.size() )
+      percentage_per_surface = 0.16 / surface_ordering_list.size();
+    else
+      progress_tool->percent( 0.83 );
-      //Now iterate of each surface that will be imprinted with curves.
-      surface_ordering_list.reset();
-      bool print_errors = false;
-      for( i=surface_ordering_list.size(); i--; )
-	      delta += percentage_per_surface;
-	      progress_tool->percent( 0.67 + delta );
+  //Now iterate of each surface that will be imprinted with curves.
+  surface_ordering_list.reset();
+  bool print_errors = false;
+  for( i=surface_ordering_list.size(); i--; )
+      delta += percentage_per_surface;
+      progress_tool->percent( 0.67 + delta );
-	  Surface *tmp_surface = surface_ordering_list.get_and_step();
+    Surface *tmp_surface = surface_ordering_list.get_and_step();
-	  surf_curve_iter = final_surface_curve_imprint_map.find( tmp_surface );
-	  tmp_surface = surf_curve_iter->first;
+    surf_curve_iter = final_surface_curve_imprint_map.find( tmp_surface );
+    tmp_surface = surf_curve_iter->first;
-	  DLIList<Surface*> surface_list;
-	  surface_list.append( tmp_surface );
+    DLIList<Surface*> surface_list;
+    surface_list.append( tmp_surface );
-	  DLIList<Curve*> curves_to_imprint;
-	  surf_curve_last = final_surface_curve_imprint_map.upper_bound( surf_curve_iter->first );
-	  //For each curve that might be imprinted on the surface...
+    DLIList<Curve*> curves_to_imprint;
+    surf_curve_last = final_surface_curve_imprint_map.upper_bound( surf_curve_iter->first );
+    //For each curve that might be imprinted on the surface...
-	      DLIList<Curve*> tmp_curve_list1, tmp_curve_list2;
-	      Curve *original_curve = surf_curve_iter->second;
-	      tmp_curve_list1.append( original_curve );
+       DLIList<Curve*> tmp_curve_list1, tmp_curve_list2;
+       Curve *original_curve = surf_curve_iter->second;
+       tmp_curve_list1.append( original_curve );
-	      //project
-	      CubitStatus projected = project_edges( surface_list, tmp_curve_list1, tmp_curve_list2, print_errors );
+       //project
+       CubitStatus projected = project_edges( surface_list, tmp_curve_list1, tmp_curve_list2, print_errors );
-	      if( projected == CUBIT_FAILURE )
-		  AcisQueryEngine::instance()->delete_solid_model_entities( original_curve );
-		  continue;
+       if( projected == CUBIT_FAILURE )
+         AcisQueryEngine::instance()->delete_solid_model_entities( original_curve );
+         continue;
-	      Curve *projected_curve = tmp_curve_list2.get();
+       Curve *projected_curve = tmp_curve_list2.get();
-	      //if midpoint of projected is far from original curve, continue
-	      CubitVector original_curve_mid_point = original_curve->center_point();
-	      if( original_curve_mid_point.distance_between( projected_curve->center_point() ) > tolerance )
-		  AcisQueryEngine::instance()->delete_solid_model_entities( projected_curve );
-		  continue;
+       //if midpoint of projected is far from original curve, continue
+       CubitVector original_curve_mid_point = original_curve->center_point();
+       if( original_curve_mid_point.distance_between( projected_curve->center_point() ) > tolerance )
+         AcisQueryEngine::instance()->delete_solid_model_entities( projected_curve );
+         continue;
-	      //now intersect
-	      tmp_curve_list1.clean_out();
-	      CubitStatus intersected =  curve_surface_intersection( tmp_surface, projected_curve, tmp_curve_list1 );
+       //now intersect
+       tmp_curve_list1.clean_out();
+       CubitStatus intersected =  curve_surface_intersection( tmp_surface, projected_curve, tmp_curve_list1 );
-	      //delete the curves
+       //delete the curves
-	      if( intersected  == CUBIT_FAILURE)
-		continue;
+       if( intersected  == CUBIT_FAILURE)
+         continue;
-	      curves_to_imprint += tmp_curve_list1;
+       curves_to_imprint += tmp_curve_list1;
-	  //filter out small curves
-	  int j;
-	  for( j=curves_to_imprint.size(); j--; )
-	      Curve *tmp_curve = curves_to_imprint.get();
-	      double curve_length = tmp_curve->measure();
-	      if( curve_length < tolerance )
-		  curves_to_imprint.change_to( NULL );
-		  AcisQueryEngine::instance()->delete_solid_model_entities( tmp_curve );
-	      curves_to_imprint.step();
-	  curves_to_imprint.remove_all_with_value( NULL );
+     //filter out small curves
+     int j;
+     for( j=curves_to_imprint.size(); j--; )
+       Curve *tmp_curve = curves_to_imprint.get();
+       double curve_length = tmp_curve->measure();
+       if( curve_length < tolerance )
+         curves_to_imprint.change_to( NULL );
+         AcisQueryEngine::instance()->delete_solid_model_entities( tmp_curve );
+       curves_to_imprint.step();
+     curves_to_imprint.remove_all_with_value( NULL );
-	  BodySM *new_body_sm = NULL;
+    BodySM *new_body_sm = NULL;
-	  //Now imprint the curves onto the surface
-	  if( curves_to_imprint.size() )
-		GfxDebug::clear();
-		AcisDrawTool::instance()->draw_surface( tmp_surface, 4, true);
-		GfxDebug::mouse_xforms();
-		int kkk;
-		PRINT_INFO("number of curve = %d\n", curves_to_imprint.size() );
-		for( kkk=curves_to_imprint.size(); kkk--; )
-		AcisDrawTool::instance()->draw_curve( curves_to_imprint.get_and_step(), kkk+5 );
-	      status = embed_curves_into_surface( tmp_surface, curves_to_imprint, new_body_sm );
+    //Now imprint the curves onto the surface
+    if( curves_to_imprint.size() )
+      GfxDebug::clear();
+      AcisDrawTool::instance()->draw_surface( tmp_surface, 4, true);
+      GfxDebug::mouse_xforms();
+      int kkk;
+      PRINT_INFO("number of curve = %d\n", curves_to_imprint.size() );
+      for( kkk=curves_to_imprint.size(); kkk--; )
+        AcisDrawTool::instance()->draw_curve( curves_to_imprint.get_and_step(), kkk+5 );
+      status = embed_curves_into_surface( tmp_surface, curves_to_imprint, new_body_sm );
-	  if( new_body_sm == NULL )
-	    continue;
-	  new_body_sms.append_unique( new_body_sm );
+    if( new_body_sm == NULL )
+      continue;
+    new_body_sms.append_unique( new_body_sm );
-	  //Delete all the curves that were imprinted.  We're responsible for deleting them.
-	    AcisQueryEngine::instance()->delete_solid_model_entities( curves_to_imprint.get_and_step() );
+    //Delete all the curves that were imprinted.  We're responsible for deleting them.
+      AcisQueryEngine::instance()->delete_solid_model_entities( curves_to_imprint.get_and_step() );
-  //WARNING!!! Only use this function if you KNOW that the curves you want
-  //to imprint line on the surface.....otherwise you'll get problems.
-  //api_embed_wire_in_faces returns unexpected results if the curve
-  //does not lie on the surface.
-  CubitStatus AcisModifyEngine::embed_curves_into_surface( Surface *surface,
+//WARNING!!! Only use this function if you KNOW that the curves you want
+//to imprint line on the surface.....otherwise you'll get problems.
+//api_embed_wire_in_faces returns unexpected results if the curve
+//does not lie on the surface.
+CubitStatus AcisModifyEngine::embed_curves_into_surface( Surface *surface,
                                                            DLIList<Curve*> &curves_to_imprint,
                                                            BodySM *&new_body ) const
-      if( curves_to_imprint.size() == 0 )
+  if( curves_to_imprint.size() == 0 )
-      BODY *copied_BODY = NULL;
-      DLIList<FACE*> imprint_FACE_list;
-      DLIList<SurfaceACIS*> acis_surfs;
-      SurfaceACIS *tmp_acis_surf = CAST_TO( surface, SurfaceACIS );
+  BODY *copied_BODY = NULL;
+  DLIList<FACE*> imprint_FACE_list;
+  DLIList<SurfaceACIS*> acis_surfs;
+  SurfaceACIS *tmp_acis_surf = CAST_TO( surface, SurfaceACIS );
-      if( tmp_acis_surf == NULL )
+  if( tmp_acis_surf == NULL )
-      FACE *FACE_ptr = tmp_acis_surf->get_FACE_ptr();
-      BODY *BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY( FACE_ptr );
-      BodySM *old_body_sm = AcisQueryEngine::instance()->get_body_sm_of_ENTITY( FACE_ptr );
+  FACE *FACE_ptr = tmp_acis_surf->get_FACE_ptr();
+  BODY *BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY( FACE_ptr );
+  BodySM *old_body_sm = AcisQueryEngine::instance()->get_body_sm_of_ENTITY( FACE_ptr );
-      acis_surfs.append( tmp_acis_surf );
-      if( get_copied_FACES_of_body( acis_surfs, imprint_FACE_list, copied_BODY ) == CUBIT_FAILURE )
+  acis_surfs.append( tmp_acis_surf );
+  if( get_copied_FACES_of_body( acis_surfs, imprint_FACE_list, copied_BODY ) == CUBIT_FAILURE )
-      if( imprint_FACE_list.size() == 0 )
+  if( imprint_FACE_list.size() == 0 )
-      if( tolerance < 0.001 )
-	tolerance = 0.001;
+  if( tolerance < 0.001 )
+    tolerance = 0.001;
-      int i;
-      EDGE *EDGEs[ 1 ];
-      ENTITY_LIST wire_BODYs;
+  int i;
+  EDGE *EDGEs[ 1 ];
+  ENTITY_LIST wire_BODYs;
 #ifdef BOYD16
-      outcome tmp_result;
+  outcome tmp_result;
 #endif
-      for( i=0; i<curves_to_imprint.size(); i++ )
-	  //copy
-	  EDGE *EDGE_ptr = AcisQueryEngine::get_EDGE( curves_to_imprint.get_and_step() );
+  for( i=0; i<curves_to_imprint.size(); i++ )
+    //copy
+    EDGE *EDGE_ptr = AcisQueryEngine::get_EDGE( curves_to_imprint.get_and_step() );
-	  EDGE *copied_EDGE_ptr = NULL;
-	  outcome tmp_result = api_edge( EDGE_ptr, copied_EDGE_ptr );
-	  ATTRIB_CUBIT_OWNER::remove_cubit_owner( (ENTITY *)copied_EDGE_ptr,
-						  CUBIT_TRUE );
-	  EDGEs[0] = copied_EDGE_ptr;
-	  BODY *tmp_BODY = NULL;
-	  tmp_result = api_make_ewire( 1, EDGEs, tmp_BODY );
-	  wire_BODYs.add( (ENTITY*)tmp_BODY );
+    EDGE *copied_EDGE_ptr = NULL;
+    outcome tmp_result = api_edge( EDGE_ptr, copied_EDGE_ptr );
+    ATTRIB_CUBIT_OWNER::remove_cubit_owner( (ENTITY *)copied_EDGE_ptr,
+                                              CUBIT_TRUE );
+    EDGEs[0] = copied_EDGE_ptr;
+    BODY *tmp_BODY = NULL;
+    tmp_result = api_make_ewire( 1, EDGEs, tmp_BODY );
+    wire_BODYs.add( (ENTITY*)tmp_BODY );
-      int number_wire_bodies = wire_BODYs.count();
+  int number_wire_bodies = wire_BODYs.count();
-      if( number_wire_bodies == 0 )
+  if( number_wire_bodies == 0 )
-      BODY *wire_BODY_ptr = (BODY*)wire_BODYs[0];
+  BODY *wire_BODY_ptr = (BODY*)wire_BODYs[0];
-      ENTITY_LIST *face_list = new ENTITY_LIST;
-      FACE* imprint_FACE = imprint_FACE_list.get();
-      face_list->add( (ENTITY*)imprint_FACE );
+  ENTITY_LIST *face_list = new ENTITY_LIST;
+  FACE* imprint_FACE = imprint_FACE_list.get();
+  face_list->add( (ENTITY*)imprint_FACE );
-      ENTITY_LIST temp_face_list;
-      api_get_faces( copied_BODY, temp_face_list );
-      int number_faces_before = temp_face_list.count();
+  ENTITY_LIST temp_face_list;
+  api_get_faces( copied_BODY, temp_face_list );
+  int number_faces_before = temp_face_list.count();
-      API_BEGIN
-	result = api_embed_wire_in_faces( wire_BODY_ptr, copied_BODY, face_list, tolerance );
-      API_END
+  API_BEGIN
+    result = api_embed_wire_in_faces( wire_BODY_ptr, copied_BODY, face_list, tolerance );
+  API_END
-	for(i=1; i<number_wire_bodies; i++ )
+  for(i=1; i<number_wire_bodies; i++ )
 #ifdef BOYD16
-	    bool embedded = false;
+    bool embedded = false;
 #endif
-	    wire_BODY_ptr = (BODY*)wire_BODYs[i];
+    wire_BODY_ptr = (BODY*)wire_BODYs[i];
-	    //get all the faces on the body
-	    ENTITY_LIST FACEs;
-	    api_get_faces( copied_BODY, FACEs );
+    //get all the faces on the body
+    ENTITY_LIST FACEs;
+    api_get_faces( copied_BODY, FACEs );
-	    //if number of faces on body did not change, no face got split, and we can
-	    //split the same FACE again.
-	    if( number_faces_before == FACEs.count()  )
-		continue;
+    //if number of faces on body did not change, no face got split, and we can
+    //split the same FACE again.
+    if( number_faces_before == FACEs.count()  )
+      continue;
-	    //need to determine which face to embed curve onto
-	    //may be able to remove this later on and just embed into body
-	    //just embed the remining wires into the body
-	    //result = api_embed_wire_in_faces( wire_BODY_ptr, copied_BODY, NULL, tolerance );
-	    //if( !result.ok() )
-	    //  AcisQueryEngine::instance()->ACIS_API_error (result);
+    //need to determine which face to embed curve onto
+    //may be able to remove this later on and just embed into body
+    //just embed the remining wires into the body
+    //result = api_embed_wire_in_faces( wire_BODY_ptr, copied_BODY, NULL, tolerance );
+    //if( !result.ok() )
+    //  AcisQueryEngine::instance()->ACIS_API_error (result);
-	    //get midpoint of curve to embed
-	    ENTITY_LIST wire_edge_list;
-	    api_get_edges( wire_BODY_ptr, wire_edge_list );
-	    EDGE *wire_edge = (EDGE*)wire_edge_list[0];
-	    SPAposition mid_point = wire_edge->mid_pos();
+    //get midpoint of curve to embed
+    ENTITY_LIST wire_edge_list;
+    api_get_edges( wire_BODY_ptr, wire_edge_list );
+    EDGE *wire_edge = (EDGE*)wire_edge_list[0];
+    SPAposition mid_point = wire_edge->mid_pos();
-	    //get position at fraction 0.79 along curve
+    //get position at fraction 0.79 along curve
 #ifdef BOYD16
-	    SPAposition start_point = wire_edge->start()->geometry()->coords();
+    SPAposition start_point = wire_edge->start()->geometry()->coords();
 #endif
-	    SPAparameter s_param = wire_edge->start_param();
-	    SPAparameter e_param = wire_edge->end_param();
+    SPAparameter s_param = wire_edge->start_param();
+    SPAparameter e_param = wire_edge->end_param();
-	    //SPAinterval param_interval = wire_edge->param_range();
-	    SPAparameter new_parameter = s_param + ((e_param - s_param ) * 0.79);
+    //SPAinterval param_interval = wire_edge->param_range();
+    SPAparameter new_parameter = s_param + ((e_param - s_param ) * 0.79);
-	    if (wire_edge->sense() == REVERSED )
-	      new_parameter = -(new_parameter);
+    if (wire_edge->sense() == REVERSED )
+      new_parameter = -(new_parameter);
-	    SPAposition point_on_curve;
-	    wire_edge->geometry()->equation().eval(new_parameter, point_on_curve );
+    SPAposition point_on_curve;
+    wire_edge->geometry()->equation().eval(new_parameter, point_on_curve );
-	    //find surface which contains point at parameter 0.79 and midpoint
-	    //loop to find appropriate face
-	    ENTITY *temp_ENT;
-	    FACEs.init();
-	    FACE *embed_FACE = NULL;
-	    while( (temp_ENT = FACEs.next()) != NULL )
-		FACE *tmp_FACE = (FACE*)temp_ENT;
-		SPAposition point1;
-		api_find_cls_ptto_face(mid_point, tmp_FACE, point1 );
-		if ( distance_to_point( point1, mid_point ) < 0.0005 )
-		    api_find_cls_ptto_face(point_on_curve, tmp_FACE, point1 );
+    //find surface which contains point at parameter 0.79 and midpoint
+    //loop to find appropriate face
+    ENTITY *temp_ENT;
+    FACEs.init();
+    FACE *embed_FACE = NULL;
+    while( (temp_ENT = FACEs.next()) != NULL )
+      FACE *tmp_FACE = (FACE*)temp_ENT;
+      SPAposition point1;
+      api_find_cls_ptto_face(mid_point, tmp_FACE, point1 );
+      if ( distance_to_point( point1, mid_point ) < 0.0005 )
+        api_find_cls_ptto_face(point_on_curve, tmp_FACE, point1 );
-		    if ( distance_to_point( point1, point_on_curve ) < 0.0005 )
-			embed_FACE = tmp_FACE;
-			break;
-	    if( embed_FACE )
-		face_list->clear();
-		face_list->add( (ENTITY*)embed_FACE );
+        if ( distance_to_point( point1, point_on_curve ) < 0.0005 )
+          embed_FACE = tmp_FACE;
+          break;
+    if( embed_FACE )
+      face_list->clear();
+      face_list->add( (ENTITY*)embed_FACE );
-      AcisModifyEngine::instance()->cleanup_slivers( copied_BODY );
+  AcisModifyEngine::instance()->cleanup_slivers( copied_BODY );
-      //check to see if anything actually happened
-      int num_vol_bef, num_face_bef, num_edge_bef, num_vertex_bef;
-      CubitStatus status1 = AcisQueryEngine::instance()->number_ENTITIES( BODY_ptr, num_vol_bef,
-									  num_face_bef, num_edge_bef,
-									  num_vertex_bef );
+  //check to see if anything actually happened
+  int num_vol_bef, num_face_bef, num_edge_bef, num_vertex_bef;
+  CubitStatus status1 = AcisQueryEngine::instance()->number_ENTITIES( BODY_ptr, num_vol_bef,
+                                           num_face_bef, num_edge_bef,
+                                           num_vertex_bef );
-      int num_vol_aft, num_face_aft, num_edge_aft, num_vertex_aft;
-      CubitStatus status2 = AcisQueryEngine::instance()->number_ENTITIES( copied_BODY, num_vol_aft,
-									  num_face_aft, num_edge_aft,
-									  num_vertex_aft );
+  int num_vol_aft, num_face_aft, num_edge_aft, num_vertex_aft;
+  CubitStatus status2 = AcisQueryEngine::instance()->number_ENTITIES( copied_BODY, num_vol_aft,
+                                           num_face_aft, num_edge_aft,
+                                           num_vertex_aft );
-      if( status1 == CUBIT_FAILURE  ||
-	  status2 == CUBIT_FAILURE )
+  if( status1 == CUBIT_FAILURE  ||
+      status2 == CUBIT_FAILURE )
-      if( num_vol_bef == num_vol_aft &&
-	  num_face_bef == num_face_aft &&
-	  num_edge_bef == num_edge_aft &&
-	  num_vertex_bef == num_vertex_aft)
-	  AcisQueryEngine::instance()->delete_ACIS_BODY(copied_BODY, CUBIT_TRUE);
+  if( num_vol_bef == num_vol_aft &&
+      num_face_bef == num_face_aft &&
+      num_edge_bef == num_edge_aft &&
+      num_vertex_bef == num_vertex_aft)
+    AcisQueryEngine::instance()->delete_ACIS_BODY(copied_BODY, CUBIT_TRUE);
-      BodySM* new_body_ptr = get_new_Body( old_body_sm, BODY_ptr, copied_BODY,
-					   false, CUBIT_TRUE );
+  BodySM* new_body_ptr = get_new_Body( old_body_sm, BODY_ptr, copied_BODY,
+                                       false, CUBIT_TRUE );
-      new_body = new_body_ptr;
+  new_body = new_body_ptr;
-  CubitStatus AcisModifyEngine::curve_surface_intersection( Surface *surface,
-							    Curve* curve,
-							    DLIList<Curve*> &new_curves ) const
-      FACE *FACE_ptr = AcisQueryEngine::get_FACE( surface );
-      EDGE *EDGE_ptr = AcisQueryEngine::get_EDGE( curve );
+CubitStatus AcisModifyEngine::curve_surface_intersection( Surface *surface,
+                                            Curve* curve,
+                                            DLIList<Curve*> &new_curves ) const
+  FACE *FACE_ptr = AcisQueryEngine::get_FACE( surface );
+  EDGE *EDGE_ptr = AcisQueryEngine::get_EDGE( curve );
-      ENTITY_LIST *ent_list = new ENTITY_LIST;
+  ENTITY_LIST *ent_list = new ENTITY_LIST;
-      outcome result = api_edfa_int( EDGE_ptr, FACE_ptr, ent_list );
+  outcome result = api_edfa_int( EDGE_ptr, FACE_ptr, ent_list );
-      if( !result.ok() || ent_list->count() == 0 )
-	  delete ent_list;
+  if( !result.ok() || ent_list->count() == 0 )
+    delete ent_list;
-      ENTITY *tmp_ent;
-      ent_list->init();
-      while( (tmp_ent=ent_list->next()) != NULL )
-	  if( is_EDGE( tmp_ent ) )
-	      EDGE_ptr = static_cast<EDGE*>(tmp_ent);
-	      Curve *curve_ptr = AcisQueryEngine::instance()->populate_topology_bridges(EDGE_ptr);
-	      new_curves.append( curve_ptr );
-      delete ent_list;
+  ENTITY *tmp_ent;
+  ent_list->init();
+  while( (tmp_ent=ent_list->next()) != NULL )
+    if( is_EDGE( tmp_ent ) )
+      EDGE_ptr = static_cast<EDGE*>(tmp_ent);
+      Curve *curve_ptr = AcisQueryEngine::instance()->populate_topology_bridges(EDGE_ptr);
+      new_curves.append( curve_ptr );
+  delete ent_list;
-      if( new_curves.size() == 0 )
+  if( new_curves.size() == 0 )
-  void AcisModifyEngine::get_new_ENTITIES(ENTITY *top_ENTITY, DLIList<ENTITY*> &new_ENTITIES) const
-      ENTITY_LIST ENTITIES;
-      int i;
+void AcisModifyEngine::get_new_ENTITIES(ENTITY *top_ENTITY, DLIList<ENTITY*> &new_ENTITIES) const
+  ENTITY_LIST ENTITIES;
+  int i;
-      // vertices
-      api_get_vertices( top_ENTITY, ENTITIES);
-      for (i = 0; i < ENTITIES.count(); i++)
-	  if (!ATTRIB_CUBIT_OWNER::cubit_owner(ENTITIES[i]))
-	      new_ENTITIES.append_unique(ENTITIES[i]);
-      ENTITIES.clear();
-      // edges
-      api_get_edges( top_ENTITY, ENTITIES);
-      ENTITIES.clear();
-      // faces
-      api_get_faces( top_ENTITY, ENTITIES);
+  // vertices
+  api_get_vertices( top_ENTITY, ENTITIES);
+  for (i = 0; i < ENTITIES.count(); i++)
+    if (!ATTRIB_CUBIT_OWNER::cubit_owner(ENTITIES[i]))
-      ENTITIES.clear();
+  ENTITIES.clear();
-  void AcisModifyEngine::get_att_ENTITIES(ENTITY *top_ENTITY, DLIList<ENTITY*> &att_ENTITIES, char *att_name) const
+  // edges
+  api_get_edges( top_ENTITY, ENTITIES);
-      int i;
-      // vertices
-	  ATTRIB_SNL_SIMPLE *attribute =
-	    (ATTRIB_SNL_SIMPLE *) find_attrib(ENTITIES[i],
-					      ATTRIB_SNL_TYPE,
-					      ATTRIB_SNL_SIMPLE_TYPE);
-	  for(;attribute != NULL;attribute = (ATTRIB_SNL_SIMPLE *)
-		find_next_attrib(attribute,
-				 ATTRIB_SNL_TYPE,
-				 ATTRIB_SNL_SIMPLE_TYPE))
-	      if( attribute->attribute_name() == att_name )
-		att_ENTITIES.append_unique(ENTITIES[i]);
-      ENTITIES.clear();
+      new_ENTITIES.append_unique(ENTITIES[i]);
+  ENTITIES.clear();
+  // faces
+  api_get_faces( top_ENTITY, ENTITIES);
+  ENTITIES.clear();
-      // edges
-					      ATTRIB_SNL_TYPE,
-				 ATTRIB_SNL_TYPE,
-      ENTITIES.clear();
-      // faces
+void AcisModifyEngine::get_att_ENTITIES(ENTITY *top_ENTITY, DLIList<ENTITY*> &att_ENTITIES, char *att_name) const
+  int i;
+  // vertices
+    ATTRIB_SNL_SIMPLE *attribute =
-      ATTRIB_SNL_TYPE,
-      ATTRIB_SNL_TYPE,
+                                        ATTRIB_SNL_TYPE,
+                                        ATTRIB_SNL_SIMPLE_TYPE);
+    for(;attribute != NULL;attribute = (ATTRIB_SNL_SIMPLE *)
+          find_next_attrib(attribute,
+                          ATTRIB_SNL_TYPE,
+                          ATTRIB_SNL_SIMPLE_TYPE))
-      ENTITIES.clear();
+        att_ENTITIES.append_unique(ENTITIES[i]);
+  ENTITIES.clear();
-  CubitStatus AcisModifyEngine::cleanup_slivers( BODY *body_to_cleanup )
+  // edges
+      (ATTRIB_SNL_SIMPLE *) find_attrib(ENTITIES[i],
+                                        ATTRIB_SNL_TYPE,
+                          ATTRIB_SNL_TYPE,
-      double sliver_curve_tol = GeometryQueryTool::get_sliver_curve_cleanup_tolerance();
-      double sliver_surface_tol = GeometryQueryTool::get_sliver_surface_cleanup_tolerance();
+      if( attribute->attribute_name() == att_name )
+  ENTITIES.clear();
+  // faces
+                                        ATTRIB_SNL_TYPE,
+                          ATTRIB_SNL_TYPE,
+  ENTITIES.clear();
-      ENTITY_LIST dummy_list;
-      api_detect_short_edges( body_to_cleanup, dummy_list, sliver_curve_tol, true );
-      api_detect_sliver_faces( body_to_cleanup, dummy_list, sliver_surface_tol, true );
+CubitStatus AcisModifyEngine::cleanup_slivers( BODY *body_to_cleanup )
+   double sliver_curve_tol = GeometryQueryTool::get_sliver_curve_cleanup_tolerance();
+   double sliver_surface_tol = GeometryQueryTool::get_sliver_surface_cleanup_tolerance();
+   ENTITY_LIST dummy_list;
+   api_detect_short_edges( body_to_cleanup, dummy_list, sliver_curve_tol, true );
+   api_detect_sliver_faces( body_to_cleanup, dummy_list, sliver_surface_tol, true );
-  CubitStatus AcisModifyEngine::remove_curve_slivers( BodySM *body_sm,
-						      double lengthlimit ) const
-      //get the BODY
-      BodyACIS *tmp_body_acis = CAST_TO(body_sm, BodyACIS );
-      BODY *tmp_BODY = tmp_body_acis->get_BODY_ptr();
-      //copy the BODY
-      BODY *copy_BODY = AcisModifyEngine::instance()->copy_BODY( tmp_BODY, false );
+CubitStatus AcisModifyEngine::remove_curve_slivers( BodySM *body_sm,
+                                                    double lengthlimit ) const
+  //get the BODY
+  BodyACIS *tmp_body_acis = CAST_TO(body_sm, BodyACIS );
+  BODY *tmp_BODY = tmp_body_acis->get_BODY_ptr();
-      //remove the slivers
-      ENTITY_LIST removed_curves;
-      outcome result = api_detect_short_edges( copy_BODY, removed_curves, lengthlimit, true );
+  //copy the BODY
+  BODY *copy_BODY = AcisModifyEngine::instance()->copy_BODY( tmp_BODY, false );
-      if( !result.ok() )
-	  PRINT_ERROR("Problem remove sliver curves\n");
-	  AcisQueryEngine::instance()->ACIS_API_error (result);
-	  api_delent( (ENTITY*)copy_BODY );
+  //remove the slivers
+  ENTITY_LIST removed_curves;
+  outcome result = api_detect_short_edges( copy_BODY, removed_curves, lengthlimit, true );
-      TopologyEntity *te = body_sm->topology_entity();
-      RefEntity *ref_ent = CAST_TO( te, RefEntity );
-      PRINT_INFO("Removed %d sliver curves on body %d\n",
-		 removed_curves.count(), ref_ent->id() );
+  if( !result.ok() )
+    PRINT_ERROR("Problem remove sliver curves\n");
+    AcisQueryEngine::instance()->ACIS_API_error (result);
+    api_delent( (ENTITY*)copy_BODY );
-      if( removed_curves.count() == 0 )
+  TopologyEntity *te = body_sm->topology_entity();
+  RefEntity *ref_ent = CAST_TO( te, RefEntity );
+  PRINT_INFO("Removed %d sliver curves on body %d\n",
+            removed_curves.count(), ref_ent->id() );
+  if( removed_curves.count() == 0 )
-      get_new_Body(body_sm, tmp_BODY, copy_BODY, CUBIT_FALSE);
+  get_new_Body(body_sm, tmp_BODY, copy_BODY, CUBIT_FALSE);
   CubitStatus AcisModifyEngine::stitch_surfs(
 					     DLIList<BodySM*>& surf_bodies,
Modified: cgm/branches/merge-cubit12/geom/ACIS_SRC/AcisModifyEngine.hpp
--- cgm/branches/merge-cubit12/geom/ACIS_SRC/AcisModifyEngine.hpp	2010-01-27 00:51:03 UTC (rev 3494)
+++ cgm/branches/merge-cubit12/geom/ACIS_SRC/AcisModifyEngine.hpp	2010-01-27 01:06:43 UTC (rev 3495)
@@ -461,7 +461,7 @@
                       const CubitVector &v2,
                       const CubitVector &v3,
                       DLIList<BodySM*>& results_list,
-                      bool imprint = false )  ;
+                      bool imprint = false ) const;
     //R int
     //R- Number of bodies that were webcut ( >= 0 )
     //I webcut_body_list
@@ -482,7 +482,7 @@
             DLIList<BodySM*>& webcut_body_list,
             BodySM const* tool_body,
-            bool imprint  = false) ;
+            bool imprint  = false) const;
     //R int
@@ -972,7 +972,7 @@
 		                     const CubitVector &point_2,
                                      const CubitVector &point_3,
 		                     BodySM *body_to_trim_to,
-		                     DLIList<BodySM*>& midplane_bodies ) const;
+		                     BodySM *&midsurface_body ) const;
   //- Given 3 points that describe the mid_plane, return a body that
   //- contains the trimmed surfaces defining the mid plane.
   //- These surfaces will be part of the midplane_body and will
@@ -981,17 +981,17 @@
   virtual CubitStatus get_spheric_mid_surface( Surface *surface_ptr1,
 				  Surface *surface_ptr2,
-				  DLIList<BodySM*> &midsurface_bodies ) const;
   virtual CubitStatus get_conic_mid_surface( Surface *surface_ptr1,
   virtual CubitStatus get_toric_mid_surface( Surface *surface_ptr1,
   virtual CubitStatus tweak_chamfer( DLIList<Curve*> &curve_list,
                                      double left_offset,
More information about the cgma-dev mailing list
