[cgma-dev] buildbot failure in Fathom on cgm-occ
cgma-dev at lists.mcs.anl.gov
Tue Jan 26 00:23:43 CST 2010
The Fathomatic has detected a failed build of cgm-occ on Fathom.
Full details are available at:
http://gnep.mcs.anl.gov:8010/builders/cgm-occ/builds/18
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed test
LOG EXCERPT:
Destroyed volume(s): 28
Exported: 1 OCC Body to unite3.occ
Constructed 2 Volumes: 30, 31
Updated volume(s): 30
Destroyed volume(s): 31
Exported: 1 OCC Body to unite5.occ
Constructed 2 Volumes: 32, 33
Updated volume(s): 33
Destroyed volume(s): 32
Exported: 1 OCC Body to unite6.occ
PASS: r_w
Geometry engine set to: OCC Geometry Engine version 6.2.0
Constructed 1 Volume: 1
Failed to find a parameter with valid range for an apex point
point coords: -8.888841e+01 -4.440892e-16 1.303018e+01
projected coords: 0.000000e+00 0.000000e+00 0.000000e+00
params returned: -1.000000e+300 -1.000000e+300
FAIL: test_occ
Constructed 2 Volumes: 1, 2
The 1 body did not have common part with the tool_body.
Total 0 cuts performed, with from_shape having 8 faces.
Created volume(s): 3
Updated volume(s): 1
PASS: operation
PASS: brick_occ
2 of 9 tests failed
sincerely,
-The Fathomatic
More information about the cgma-dev
