[cgma-dev] r3476 - in cgm/branches/merge-cubit12: . init
kraftche at cae.wisc.edu
Mon Jan 25 16:01:12 CST 2010
Author: kraftche
Date: 2010-01-25 16:01:12 -0600 (Mon, 25 Jan 2010)
New Revision: 3476
Modified:
cgm/branches/merge-cubit12/configure.ac
cgm/branches/merge-cubit12/init/InitCGMA.cpp
Log:
detect and initialize proprietary CAT code in libcubiti19
Modified: cgm/branches/merge-cubit12/configure.ac
--- cgm/branches/merge-cubit12/configure.ac 2010-01-25 15:39:53 UTC (rev 3475)
+++ cgm/branches/merge-cubit12/configure.ac 2010-01-25 22:01:12 UTC (rev 3476)
@@ -136,6 +136,19 @@
break],
[AC_MSG_RESULT(no)])
done
+ if test "x$CUBIT_LIBS" = "xno"; then
+ AC_MSG_ERROR("Cubit library not found in $CUBIT_BIN_DIR")
+ fi
+ # Test for CAT-proprietary code that must be initialized in Cubit12
+ AC_MSG_CHECKING([For AcisTweekToolCAT in ${CUBIT_LIBS}])
+ AC_LINK_IFELSE([AC_LANG_PROGRAM(
+ [class AcisTweakToolCAT{ public: static AcisTweakToolCAT* instance(); };],
+ [AcisTweakToolCAT::instance();])],
+ [CUBIT_CAT_DEFINES=-DACIS_TWEAK_TOOL_CAT; AC_MSG_RESULT([yes])],
+ [CUBIT_CAT_DEFINES=; AC_MSG_RESULT([no])])
LIBS="$old_LIBS"
LDFLAGS="$old_LDFLAGS"
LD_LIBRARY_PATH="$old_LD_LIBRARY_PATH"
@@ -146,13 +159,10 @@
export PATH
AC_LANG_POP([C++])
- if test "x$CUBIT_LIBS" = "xno"; then
- AC_MSG_ERROR("Cubit library not found in $CUBIT_BIN_DIR")
- fi
CGM_EXT_LIBS="$CGM_EXT_LIBS $CUBIT_LIBS"
CGM_EXT_LDFLAGS="$CGM_EXT_LDFLAGS $CUBIT_LDFLAGS"
CGM_EXT_LTFLAGS="$CGM_EXT_LTFLAGS $CUBIT_LTFLAGS"
- CUBIT_CGM="-DCUBIT_CGM"
+ CUBIT_CGM="-DCUBIT_CGM $CUBIT_CAT_DEFINES"
dnl AC_DEFINE( HAVE_ACIS, "Have CGM ACIS Implementation" )
HAVE_ACIS_DEF=-DHAVE_ACIS
fi
Modified: cgm/branches/merge-cubit12/init/InitCGMA.cpp
--- cgm/branches/merge-cubit12/init/InitCGMA.cpp 2010-01-25 15:39:53 UTC (rev 3475)
+++ cgm/branches/merge-cubit12/init/InitCGMA.cpp 2010-01-25 22:01:12 UTC (rev 3476)
@@ -31,6 +31,14 @@
char dummyvar[4096];
+#ifdef ACIS_TWEAK_TOOL_CAT
+class AcisTweakToolCAT
+ public:
+ static AcisTweakToolCAT* instance();
+#endif
#elif defined(HAVE_ACIS)
# include "AcisQueryEngine.hpp"
# include "AcisModifyEngine.hpp"
@@ -87,6 +95,10 @@
// without the complete definition of AcisModifyEngine.
// But it shouldn't matter, as ACIS is the default for
// Cubit anyway.
+ AcisTweakToolCAT::instance();
+#endif
AcisQueryEngine::instance();
AcisModifyEngine::instance();
More information about the cgma-dev
