[cgma-dev] buildbot failure in Fathom on cgm-cubit
cgma-dev at lists.mcs.anl.gov cgma-dev at lists.mcs.anl.gov
Mon Jan 25 00:18:53 CST 2010
The Fathomatic has detected a failed build of cgm-cubit on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/cgm-cubit/builds/5
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed test
LOG EXCERPT:
===================webcut.cpp:477===================
Read 2 ACIS Entities from the input file
Constructed 2 Volumes: 1, 2
      Creating the new (webcut) volumes...
Created volume(s): 3
Updated volume(s): 1
Exported:   3 Volumes
===================webcut.cpp:515===================
Exported:   3 Volumes
===================webcut.cpp:548===================
Exported:   3 Volumes
===================webcut.cpp:592===================
Exported:   3 Volumes
PASS: webcut
PASS: brick_acis
1 of 5 tests failed
sincerely,
 -The Fathomatic
More information about the cgma-dev mailing list
