[cgma-dev] buildbot failure in Fathom on cgm-distcheck
cgma-dev at lists.mcs.anl.gov
Sun Jan 24 00:25:15 CST 2010
The Fathomatic has detected a failed build of cgm-distcheck on Fathom.
Full details are available at:
http://gnep.mcs.anl.gov:8010/builders/cgm-distcheck/builds/3
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed compile
LOG EXCERPT:
make check-recursive
make[4]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/cgm-distcheck/build/cgma-10.2.3/_build/itaps'
Making check in .
make[5]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/cgm-distcheck/build/cgma-10.2.3/_build/itaps'
make chaman
make[6]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/cgm-distcheck/build/cgma-10.2.3/_build/itaps'
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../itaps -I.. -I../geom/parallel -I../../util -I../../geom -I../../init -I. -DSRCDIR=../../itaps -Wall -pipe -pedantic -O2 -DNDEBUG -Wno-long-long -MT chaman-chaman.o -MD -MP -MF .deps/chaman-chaman.Tpo -c -o chaman-chaman.o `test -f 'chaman.cc' || echo '../../itaps/'`chaman.cc
mv -f .deps/chaman-chaman.Tpo .deps/chaman-chaman.Po
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -O2 -DNDEBUG -Wno-long-long -o chaman chaman-chaman.o libiGeom.la -lm
c++ -Wall -pipe -pedantic -O2 -DNDEBUG -Wno-long-long -o chaman chaman-chaman.o ./.libs/libiGeom.a /nfs/mcs-homes15/jvporter/buildslave1/cgm-distcheck/build/cgma-10.2.3/_build/.libs/libcgm.a -ldl -lm
./.libs/libiGeom.a(iGeom_CGMA.o): In function `iGeom_load_cub_geometry(char const*, int*)':
iGeom_CGMA.cc:(.text+0xd72d): warning: the use of `tmpnam' is dangerous, better use `mkstemp'
make check-TESTS
All 0 tests passed
Making check in test
make[3]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/cgm-distcheck/build/cgma-10.2.3/_build/test'
make init sheet brick_facet
make[4]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/cgm-distcheck/build/cgma-10.2.3/_build/test'
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../test -I.. -I../geom/parallel -I../itaps -I../../geom -I../../util -I../../init -I../../geom/ACIS -I../../geom/virtual -I../../geom/facet -I../../geom/Cholla -I../../geom/OCC -I../../test -DSRCDIR=../../test -Wall -pipe -pedantic -O2 -DNDEBUG -MT init.o -MD -MP -MF .deps/init.Tpo -c -o init.o ../../test/init.cpp
mv -f .deps/init.Tpo .deps/init.Po
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o init init.o ../libcgm.la -lm
mkdir .libs
c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o init init.o ../.libs/libcgm.a -ldl -lm
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../test -I.. -I../geom/parallel -I../itaps -I../../geom -I../../util -I../../init -I../../geom/ACIS -I../../geom/virtual -I../../geom/facet -I../../geom/Cholla -I../../geom/OCC -I../../test -DSRCDIR=../../test -Wall -pipe -pedantic -O2 -DNDEBUG -MT sheet.o -MD -MP -MF .deps/sheet.Tpo -c -o sheet.o ../../test/sheet.cpp
mv -f .deps/sheet.Tpo .deps/sheet.Po
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o sheet sheet.o ../libcgm.la -lm
c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o sheet sheet.o ../.libs/libcgm.a -ldl -lm
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../test -I.. -I../geom/parallel -I../itaps -I../../geom -I../../util -I../../init -I../../geom/ACIS -I../../geom/virtual -I../../geom/facet -I../../geom/Cholla -I../../geom/OCC -I../../test '-DTEST_ENGINE="FACET"' -Wall -pipe -pedantic -O2 -DNDEBUG -MT brick_facet-brick.o -MD -MP -MF .deps/brick_facet-brick.Tpo -c -o brick_facet-brick.o `test -f 'brick.cpp' || echo '../../test/'`brick.cpp
mv -f .deps/brick_facet-brick.Tpo .deps/brick_facet-brick.Po
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o brick_facet brick_facet-brick.o ../libcgm.la -lm
c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o brick_facet brick_facet-brick.o ../.libs/libcgm.a -ldl -lm
make check-TESTS
ERROR: initialize_cgma() called again, but default engines differ.
PASS: init
Facet-based geometry modification is a beta capability.
ERROR: This capability is currently disabled.
To enable this capability, issue the command 'set facet_modify on'.
ERROR: In GeometryModifyTool::sphere
Problems building a volume from the sphere.
Sphere creation failed for engine (17FacetModifyEngine)
FAIL: sheet
Geometry engine set to: Facet Geometry Engine version 10.0.0
PASS: brick_facet
1 of 3 tests failed
sincerely,
-The Fathomatic
More information about the cgma-dev
