[cgma-dev] CGMA check for *cubit* failed.
Nightly Test kraftche at cae.wisc.edu
Sat Jan 23 02:17:45 CST 2010
Making check in compat
make[1]: Entering directory `/home/jason/cgm/test/cubit/compat'
make[1]: Nothing to be done for `check'.
make[1]: Leaving directory `/home/jason/cgm/test/cubit/compat'
Making check in util
make[1]: Entering directory `/home/jason/cgm/test/cubit/util'
make[1]: Leaving directory `/home/jason/cgm/test/cubit/util'
Making check in geom
make[1]: Entering directory `/home/jason/cgm/test/cubit/geom'
Making check in .
make[2]: Entering directory `/home/jason/cgm/test/cubit/geom'
make[2]: Nothing to be done for `check-am'.
make[2]: Leaving directory `/home/jason/cgm/test/cubit/geom'
Making check in Cholla
make[2]: Entering directory `/home/jason/cgm/test/cubit/geom/Cholla'
make[2]: Nothing to be done for `check'.
make[2]: Leaving directory `/home/jason/cgm/test/cubit/geom/Cholla'
Making check in facetbool
make[2]: Entering directory `/home/jason/cgm/test/cubit/geom/facetbool'
make[2]: Leaving directory `/home/jason/cgm/test/cubit/geom/facetbool'
make[2]: Entering directory `/home/jason/cgm/test/cubit/geom/facet'
make[2]: Leaving directory `/home/jason/cgm/test/cubit/geom/facet'
Making check in virtual
make[2]: Entering directory `/home/jason/cgm/test/cubit/geom/virtual'
make[2]: Leaving directory `/home/jason/cgm/test/cubit/geom/virtual'
make[1]: Leaving directory `/home/jason/cgm/test/cubit/geom'
Making check in init
make[1]: Entering directory `/home/jason/cgm/test/cubit/init'
make[1]: Leaving directory `/home/jason/cgm/test/cubit/init'
Making check in .
make[1]: Entering directory `/home/jason/cgm/test/cubit'
make[1]: Leaving directory `/home/jason/cgm/test/cubit'
Making check in itaps
make[1]: Entering directory `/home/jason/cgm/test/cubit/itaps'
make  check-recursive
make[2]: Entering directory `/home/jason/cgm/test/cubit/itaps'
Making check in .
make[3]: Entering directory `/home/jason/cgm/test/cubit/itaps'
make  chaman  testgeom
make[4]: Entering directory `/home/jason/cgm/test/cubit/itaps'
make[4]: `testgeom' is up to date.
make[4]: Leaving directory `/home/jason/cgm/test/cubit/itaps'
make  check-TESTS
Using default input file: ../../trunk/itaps/testgeom.sat
ITAPS GEOMETRY INTERFACE TEST PROGRAM:
   gLoad: Read 1 ACIS Entities from the input file
Constructed 1 Volume: 1
Model contents:
vertices: 36
edges: 60
faces: 33
regions: 1
Success
   tags: Tags defined on model: GLOBAL_ID, NAME
Success
   gentity sets: Success
   topology adjacencies: Success
   construct: Created swept volume 3
Success
   primitives: Success
   transforms: Success
   booleans: Updated volume(s): 10
Destroyed volume(s): 11
Updated volume(s): 12
Destroyed volume(s): 13
Success
   mesh size: Read 1 ACIS Entities from the input file
ERROR: Attribute type -1 not recognized.
Success
   save entset:
Exported:   2 Volumes
Read 2 ACIS Entities from the input file
WARNING: Entity name 'Group 1' is invalid. Changed to 'Group_1'
Constructed 2 Volumes: 2, 3
Success
   shutdown: Success
TSTT TEST SUMMARY:
   Number Tests:           11
   Number Successful:      11
   Number Not Implemented: 0
   Number Failed:          0
PASS: testgeom
All 1 tests passed
make[3]: Leaving directory `/home/jason/cgm/test/cubit/itaps'
make[2]: Leaving directory `/home/jason/cgm/test/cubit/itaps'
make[1]: Leaving directory `/home/jason/cgm/test/cubit/itaps'
Making check in test
make[1]: Entering directory `/home/jason/cgm/test/cubit/test'
make  init sheet brick_facet  webcut brick_acis
make[2]: Entering directory `/home/jason/cgm/test/cubit/test'
make[2]: `init' is up to date.
make[2]: `sheet' is up to date.
make[2]: `brick_facet' is up to date.
make[2]: `webcut' is up to date.
make[2]: `brick_acis' is up to date.
make[2]: Leaving directory `/home/jason/cgm/test/cubit/test'
make  check-TESTS
ERROR: initialize_cgma() called again, but default engines differ.
PASS: init
Success (16AcisModifyEngine)
Success (17FacetModifyEngine)
PASS: sheet
ERROR: Option not supported for mesh based geometry.
FAIL: brick_facet
===================../../trunk/test/webcut.cpp:146===================
      Creating the new (webcut) volumes...
Created volume(s): 2
Exported:   2 Volumes
===================../../trunk/test/webcut.cpp:184===================
Exported:   2 Volumes
===================../../trunk/test/webcut.cpp:218===================
Exported:   2 Volumes
===================../../trunk/test/webcut.cpp:255===================
Read 3 ACIS Entities from the input file
Constructed 2 Free Curves: 4375, 4376
CPU time taken to WEBCUT this body: 6.320000 secs
Exported:   2 Volumes
            2 Curves
===================../../trunk/test/webcut.cpp:304===================
Constructed 2 Free Curves: 13, 14
Exported:   2 Volumes
            2 Curves
===================../../trunk/test/webcut.cpp:347===================
Exported:   2 Volumes
            2 Curves
===================../../trunk/test/webcut.cpp:401===================
Read 5 ACIS Entities from the input file
Constructed 4 Free Curves: 13 to 16
Exported:   2 Volumes
            4 Curves
===================../../trunk/test/webcut.cpp:441===================
Constructed 2 Volumes: 1, 2
Created volume(s): 3
Exported:   3 Volumes
===================../../trunk/test/webcut.cpp:477===================
Exported:   3 Volumes
===================../../trunk/test/webcut.cpp:515===================
Exported:   3 Volumes
===================../../trunk/test/webcut.cpp:548===================
Exported:   3 Volumes
===================../../trunk/test/webcut.cpp:592===================
Exported:   3 Volumes
PASS: webcut
PASS: brick_acis
1 of 5 tests failed
make[2]: *** [check-TESTS] Error 1
make[1]: *** [check-am] Error 2
make[1]: Leaving directory `/home/jason/cgm/test/cubit/test'
make: *** [check-recursive] Error 1
More information about the cgma-dev mailing list
