[cgma-dev] buildbot failure in Fathom on cgm-cubit
cgma-dev at lists.mcs.anl.gov
Sat Jan 23 00:18:43 CST 2010
The Fathomatic has detected a failed build of cgm-cubit on Fathom.
Full details are available at:
http://gnep.mcs.anl.gov:8010/builders/cgm-cubit/builds/3
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed test
LOG EXCERPT:
===================webcut.cpp:477===================
Read 2 ACIS Entities from the input file
Constructed 2 Volumes: 1, 2
Creating the new (webcut) volumes...
Created volume(s): 3
Updated volume(s): 1
Exported: 3 Volumes
===================webcut.cpp:515===================
Exported: 3 Volumes
===================webcut.cpp:548===================
Exported: 3 Volumes
===================webcut.cpp:592===================
Exported: 3 Volumes
PASS: webcut
PASS: brick_acis
1 of 5 tests failed
sincerely,
-The Fathomatic
More information about the cgma-dev
