[cgma-dev] r3468 - cgm/trunk/geom/facet
kraftche at cae.wisc.edu
Fri Jan 22 09:42:47 CST 2010
Author: kraftche
Date: 2010-01-22 09:42:47 -0600 (Fri, 22 Jan 2010)
New Revision: 3468
Modified:
cgm/trunk/geom/facet/FacetModifyEngine.cpp
Log:
remove bogus diagnostic output
Modified: cgm/trunk/geom/facet/FacetModifyEngine.cpp
--- cgm/trunk/geom/facet/FacetModifyEngine.cpp 2010-01-22 15:42:23 UTC (rev 3467)
+++ cgm/trunk/geom/facet/FacetModifyEngine.cpp 2010-01-22 15:42:47 UTC (rev 3468)
@@ -877,13 +877,6 @@
goto end_brick;
- PRINT_INFO("Body successfully created.\n");
- PRINT_INFO(" Number of vertices = %d\n", gti->num_ref_vertices());
- PRINT_INFO(" Number of edges = %d\n", gti->num_ref_edges());
- PRINT_INFO(" Number of faces = %d\n", gti->num_ref_faces());
- PRINT_INFO(" Number of volumes = %d\n", gti->num_ref_volumes());
- PRINT_INFO(" Number of bodies = %d\n", gti->num_bodies());
return rv;
end_brick:
More information about the cgma-dev
