[cgma-dev] r3462 - cgm/trunk/test
kraftche at cae.wisc.edu
Fri Jan 22 09:17:29 CST 2010
Author: kraftche
Date: 2010-01-22 09:17:29 -0600 (Fri, 22 Jan 2010)
New Revision: 3462
Modified:
cgm/trunk/test/hollow_acis.cpp
Log:
clean up CGM initialization and remove a lot of unnecessary #includes
Modified: cgm/trunk/test/hollow_acis.cpp
--- cgm/trunk/test/hollow_acis.cpp 2010-01-22 01:24:38 UTC (rev 3461)
+++ cgm/trunk/test/hollow_acis.cpp 2010-01-22 15:17:29 UTC (rev 3462)
@@ -10,27 +10,14 @@
-#include "CpuTimer.hpp"
#include "GeometryModifyTool.hpp"
#include "GeometryQueryTool.hpp"
-#include "AcisQueryEngine.hpp"
-#include "MergeTool.hpp"
-#include "CubitUtil.hpp"
-#include "CubitMessage.hpp"
-#include "CubitDefines.h"
-#include "RefEntity.hpp"
#include "Body.hpp"
#include "RefVolume.hpp"
#include "RefFace.hpp"
#include "RefEdge.hpp"
#include "RefVertex.hpp"
-#include "CubitObserver.hpp"
-#include "CastTo.hpp"
-#include "AcisModifyEngine.hpp"
-#include "AppUtil.hpp"
-#include "RefEntityFactory.hpp"
-#include "RefEdge.hpp"
+#include "InitCGMA.hpp"
#define STRINGIFY(S) XSTRINGIFY(S)
#define XSTRINGIFY(S) #S
@@ -48,25 +35,10 @@
// main program - initialize, then send to proper function
int main (int argc, char **argv)
+ // Start up CGM
+ CubitStatus status = InitCGMA::initialize_cgma("ACIS");
+ if (CUBIT_SUCCESS != status) return 1;
- CubitObserver::init_static_observers();
- // Initialize the GeometryTool
- CGMApp::instance()->startup( argc, argv );
- GeometryQueryTool::instance();
- AcisQueryEngine::instance();
- AcisModifyEngine::instance();
- // If there aren't any file arguments, print usage and exit
- //if (argc == 1) {
- // PRINT_INFO("Usage: mergechk <geom_file> [<geom_file> ...]\n");
- // exit(0);
- CubitStatus status = CUBIT_SUCCESS;
//Do hollow operation to make thick body.
status = hollow();
if (status == CUBIT_FAILURE)
More information about the cgma-dev
