[cgma-dev] buildbot failure in Fathom on cgm-cubit
James Porter
jvporter at wisc.edu
Thu Jan 21 12:29:23 CST 2010
Yeah, that's fixed. I kicked off a re-build late last night/early this
morning, and it appears to work as expected now.
- Jim
On Thu, 2010-01-21 at 10:05 -0600, Robert Smith wrote:
> This failure looks like a configure specification issue.
> LD_LIBRARY_PATH should point to the Cubit bin directory. There should
> be no "/lib/" at the end. The location should end at "/bin".
> Also I thought the "--with-cubit" flag on configure should just point
> to the Cubit directory and not to the bin directory.
> So my proposed changes are:
> LD_LIBRARY_PATH=/home/sharp/3rdparty/Cubit/Cubit64/cubit-10.2-
> amd64/bin:$LD_LIBRARY_PATH
> --with-cubit=/home/sharp/3rdparty/Cubit/Cubit64/cubit-10.2-amd64
> --Bob
> On Jan 21, 2010, at 12:17 AM, cgma-dev at lists.mcs.anl.gov wrote:
> > The Fathomatic has detected a failed build of cgm-cubit on Fathom.
> > Full details are available at:
> > http://gnep.mcs.anl.gov:8010/builders/cgm-cubit/builds/0
> > Buildbot URL: http://gnep.mcs.anl.gov:8010/
> > Buildslave for this Build: gnep
> > Build Reason: The Nightly scheduler named 'nightly' triggered this
> > build
> > Build Source Stamp: None
> > Blamelist:
> > BUILD FAILED: failed configure
> > LOG EXCERPT:
> > checking if cc supports -fno-rtti -fno-exceptions... no
> > checking for cc option to produce PIC... -fPIC
> > checking if cc PIC flag -fPIC works... yes
> > checking if cc static flag -static works... yes
> > checking if cc supports -c -o file.o... yes
> > checking whether the cc linker (/usr/bin/ld -m elf_x86_64) supports
> > shared libraries... yes
> > checking dynamic linker characteristics... GNU/Linux ld.so
> > checking how to hardcode library paths into programs... immediate
> > checking whether stripping libraries is possible... yes
> > checking if libtool supports shared libraries... yes
> > checking whether to build shared libraries... no
> > checking whether to build static libraries... yes
> > configure: creating libtool
> > appending configuration tag "CXX" to libtool
> > checking for ld used by c++... /usr/bin/ld -m elf_x86_64
> > checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
> > checking whether the c++ linker (/usr/bin/ld -m elf_x86_64) supports
> > checking for c++ option to produce PIC... -fPIC
> > checking if c++ PIC flag -fPIC works... yes
> > checking if c++ static flag -static works... yes
> > checking if c++ supports -c -o file.o... yes
> > (cached) (cached) checking how to hardcode library paths into
> > appending configuration tag "F77" to libtool
> > checking for gfortran option to produce PIC... -fPIC
> > checking if gfortran PIC flag -fPIC works... yes
> > checking if gfortran static flag -static works... yes
> > checking if gfortran supports -c -o file.o... yes
> > checking whether the gfortran linker (/usr/bin/ld -m elf_x86_64)
> > checking for a sed that does not truncate output... /bin/sed
> > checking whether byte ordering is bigendian... no
> > checking for known C compilers... GNU
> > checking for known compiler/OS combinations... GNU:x86_64
> > checking for known c++ compilers... GNU
> > checking how to get verbose linking output from gfortran... -v
> > checking for Fortran libraries of gfortran... -L/usr/lib/gcc/x86_64-
> > linux-gnu/4.2.4 -L/usr/lib/gcc/x86_64-linux-gnu/4.2.4/../../../../
> > lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/
> > 4.2.4/../../.. -lgfortranbegin -lgfortran -lm
> > checking for dummy main to link with Fortran libraries... none
> > checking for Fortran name-mangling scheme... lower case, underscore,
> > no extra underscore
> > checking for C++-standard library in std:: namespace... yes
> > checking for C++-standard I/O in std:: namespace... yes
> > checking if C++ template definitions should be included... yes
> > checking for AcisQueryEngine::instance_ in /home/sharp/3rdparty/
> > Cubit/Cubit64/cubit-10.2-amd64/bin/lib/*cubiti[0-9][0-9].*... no
> > configure: error: "Cubit library not found in /home/sharp/3rdparty/
> > Cubit/Cubit64/cubit-10.2-amd64/bin/lib"
> > sincerely,
> > -The Fathomatic
More information about the cgma-dev
