[cgma-dev] Linking to iGeom
Steve Jackson
sjackson at cae.wisc.edu
Tue Jan 12 13:59:57 CST 2010
I am trying to learn the most correct and robust way to specify linker flags in makefiles when building programs against CGM's iGeom interface.
A CGM installation comes with a makefile include, iGeom-Defs.inc. This file exports the make variables IGEOM_LDFLAGS and IGEOM_LTFLAGS. IGEOM_LTFLAGS is a collection of one or more -R{directory} flags, indicating rpaths to external library dependencies (usually the ACIS libraries). I want to find the best way to use the IGEOM_LTFLAGS variable in my own makefiles.
In a standard GNU/Linux/gcc setup, -R is a linker option, not a compiler option. Some version of gcc recognize -R as a linker option and will pass it through on a linking step, but other versions will not. (I'm using gcc 4.3.2, and on my system, gcc -R causes an error.) So `gcc $(IGEOM_LTFLAGS)` is not a good choice.
The more robust way to pass options through gcc to the linker is to use the prefix argument '-Wl,{args}'. Using this method, `gcc -Wl,($IGEOM_LTFLAGS)` works if IGEOM_LTFLAGS specifies only one -R path. But in some cases (such as a cubit-based installation), IGEOM_LTFLAGS has multiple -R paths, separated by spaces. So `gcc -Wl,$(IGEOM_LTFLAGS)` is also not a good choice.
Here is a third option, which changes the IGEOM_LTFLAGS from a linker-compatible list of arguments to a gcc-compatible list of arguments:
comma:= ,
empty:=
space:= $(empty) $(empty)
FIXED_LTFLAGS = $(subst $(space), $(comma),$(strip $(IGEOM_LTFLAGS)))
The above snippet converts spaces to commas, changing "-R/path/the/first -R/path/the/second" to "-R/path/the/first,-R/path/the/second". This new format is compatible with gcc's -Wl syntax. So, in a makefile with the above commands, `gcc -Wl,$(FIXED_LTFLAGS)` works.
But this last option seems convoluted. Am I missing something easier?
~S
More information about the cgma-dev
