[cgma-dev] r3274 - in cgm/trunk: itaps test
hongjun at mcs.anl.gov
Tue Nov 3 13:22:32 CST 2009
Author: hongjun
Date: 2009-11-03 13:22:32 -0600 (Tue, 03 Nov 2009)
New Revision: 3274
Added:
cgm/trunk/test/Moto.brep
Modified:
cgm/trunk/itaps/Makefile.am
cgm/trunk/itaps/partest.cpp
Log:
o partest can deal with default input cases
o "Moto.brep" geometry file is added for default test
o removed partest from TESTS and added to check_PROGRAMS
o partest prints out memory usage
Modified: cgm/trunk/itaps/Makefile.am
--- cgm/trunk/itaps/Makefile.am 2009-11-03 19:06:17 UTC (rev 3273)
+++ cgm/trunk/itaps/Makefile.am 2009-11-03 19:22:32 UTC (rev 3274)
@@ -24,9 +24,6 @@
if build_OCC
TESTS += testgeom_occ
endif
-if build_parallel
- TESTS += partest
-endif
SUBDIRS = . $(SIDL_DIR)
@@ -74,12 +71,13 @@
chaman_CPPFLAGS = $(CPPFLAGS) -DSRCDIR=$(srcdir)
chaman_LDFLAGS = $(CGM_EXT_LTFLAGS) $(CGM_EXT_LDFLAGS)
-if build_parallel
- partest_SOURCES = partest.cpp
- partest_LDADD = $(testgeom_LDADD)
- partest_CPPFLAGS = $(testgeom_CPPFLAGS) -DFORCE_OCC
- partest_LDFLAGS = $(testgeom_LDFLAGS)
- INCLUDES += -I$(top_srcdir)/geom/parallel
+if USE_MPI
+check_PROGRAMS += partest
+partest_SOURCES = partest.cpp
+partest_LDADD = $(testgeom_LDADD)
+partest_CPPFLAGS = $(testgeom_CPPFLAGS) -DFORCE_OCC
+partest_LDFLAGS = $(testgeom_LDFLAGS)
+INCLUDES += -I$(top_srcdir)/geom/parallel
endif
Modified: cgm/trunk/itaps/partest.cpp
--- cgm/trunk/itaps/partest.cpp 2009-11-03 19:06:17 UTC (rev 3273)
+++ cgm/trunk/itaps/partest.cpp 2009-11-03 19:22:32 UTC (rev 3274)
@@ -1,8 +1,15 @@
// Test parallel iGeom
+// July 09
+// Author : Hongjun Kim
+// read OCC geometry file and distribute it to remote processors
+// with various methods
#include <iostream>
#include <stdio.h>
#include <string.h>
+#include <sys/resource.h>
+#include <unistd.h>
+#include <fcntl.h>
#include <stdlib.h>
#include "CGMmpi.h"
@@ -11,6 +18,8 @@
#define IGEOM_ASSERT(ierr) if (ierr!=0) printf("igeom assert\n");
#define IGEOM_NULL 0
+void util_getrusage(struct rusage &r_usage);
int main(int argc, char* argv[]){
int rank, size;
MPI_Init(&argc, &argv);
@@ -34,13 +43,13 @@
nMethod = atoi(argv[2]);
else {
- if (rank == 0) printf("Usage: %s [<filename>] [<send_methond>]\n", argv[0]);
- if (argc != 1 || argc != 2) return 1;
if (rank == 0) {
- printf(" No file specified. Defaulting to: %s\n", "Moto.brep");
- printf(" No send method specified. Defaulting to: read_delete\n");
+ printf("Usage: %s [<filename>] [<send_methond>]\n", argv[0]);
+ printf("No file specified. Defaulting to: %s\n", "Moto.brep");
+ printf("No send method specified. Defaulting to: read_delete\n");
- filename = "../../../test_files/Moto.brep";
+ filename = "../test/Moto.brep";
+ nMethod = 1;
// set geometry send method
@@ -59,14 +68,78 @@
// do body partitioning with round robin distribution
options += "PARTITION=GEOM_DIMENSION;PARTITION_VAL=3;PARTITION_DISTRIBUTE;";
+ struct rusage r_usage;
+ long int rss_before, rss_after, size_before, size_after;
+ static size_t pagesize = getpagesize();
+ //if (rank == 0) {
+ util_getrusage(r_usage);
+ rss_before = r_usage.ru_maxrss*pagesize;
+ size_before = r_usage.ru_idrss*pagesize;
double tStart = MPI_Wtime();
iGeom_load(igeom, filename, options.c_str(), &ierr, strlen(filename), options.length());
MPI_Barrier(MPI_COMM_WORLD);
double tEnd = MPI_Wtime();
+ rss_after = r_usage.ru_maxrss*pagesize;
+ size_after = r_usage.ru_idrss*pagesize;
+ printf("proc=%d, rss_before=%ld, size_before=%ld\n", rank, rss_before, size_before);
+ printf("proc=%d, rss_after=%ld, size_after=%ld\n", rank, rss_after, size_after);
IGEOM_ASSERT(ierr);
printf("Done. Geometry load time is %f\n", tEnd - tStart);
MPI_Finalize();
+ getrusage(RUSAGE_SELF, &r_usage);
+ // this machine doesn't return rss - try going to /proc
+ // print the file name to open
+ if (r_usage.ru_maxrss == 0) {
+ char file_str[4096], dum_str[4096];
+ int file_ptr = -1, file_len;
+ file_ptr = open("/proc/self/stat", O_RDONLY);
+ file_len = read(file_ptr, file_str, sizeof(file_str)-1);
+ if (file_len == 0) return;
+ close(file_ptr);
+ file_str[file_len] = '\0';
+ // read the preceeding fields and the ones we really want...
+ int dum_int;
+ unsigned int dum_uint, vm_size, rss;
+ static int page_size = getpagesize();
+ int num_fields = sscanf(file_str,
+ "%d " // pid
+ "%s " // comm
+ "%c " // state
+ "%d %d %d %d %d " // ppid, pgrp, session, tty, tpgid
+ "%u %u %u %u %u " // flags, minflt, cminflt, majflt, cmajflt
+ "%d %d %d %d %d %d " // utime, stime, cutime, cstime, counter, priority
+ "%u %u " // timeout, itrealvalue
+ "%d " // starttime
+ "%u %u", // vsize, rss
+ &dum_int,
+ dum_str,
+ dum_str,
+ &dum_int, &dum_int, &dum_int, &dum_int, &dum_int,
+ &dum_uint, &dum_uint, &dum_uint, &dum_uint, &dum_uint,
+ &dum_int, &dum_int, &dum_int, &dum_int, &dum_int, &dum_int,
+ &dum_int,
+ &vm_size, &rss);
+ if (num_fields == 24) {
+ r_usage.ru_maxrss = rss/page_size;
+ r_usage.ru_idrss = vm_size/page_size;
Added: cgm/trunk/test/Moto.brep
--- cgm/trunk/test/Moto.brep (rev 0)
+++ cgm/trunk/test/Moto.brep 2009-11-03 19:22:32 UTC (rev 3274)
@@ -0,0 +1,44244 @@
+DBRep_DrawableShape
+CASCADE Topology V1, (c) Matra-Datavision
+Locations 0
+Curve2ds 3496
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 3 0.96723987468831463 0.0099477560291677675 0.97832514694115569 0.009833484695045195 0.98924645466573013 0.0097255205025104444 1 0.0096244293994268895
+6 0 1 1 0 1 1
+6 0 11 0.96723987468831463 0.0099477560291677744 0.89016349190216548 0.010742272241670675 0.80727992366457835 0.011759655013147005 0.71899694264426095 0.01295380246888281 0.62593452933080118 0.014247607786324158 0.52943928793017148 0.015620622660918803 0.43038490186370187 0.01699754704790734 0.33467801078941428 0.018322444311456881 0.24252161526690008 0.019599089282289452 0.15571470180636748 0.020696478139780764 0.074706247383803118 0.021555372794693429 1.0547118733938987e-15 0.022116995684133119
+6 0 1 1 0 1 1
+6 0 1 0 0.022116995684133126 0 1
+6 0 1 0.022116999205405663 0 1 0
+6 0 1 0 1 0.5 1
+6 0 1 0.5 1 0.75 1
+6 0 1 0.75 1 0.7578125 1
+6 0 1 0.7578125 1 0.765625 1
+6 0 1 0.765625 1 0.78125 1
+6 0 1 0.78125 1 0.8125 1
+6 0 1 0.8125 1 0.875 1
+6 0 1 0.875 1 1 1
+6 0 1 1 1 1 0.0096244293994268704
+6 0 1 1 0 0.0096244253465462837 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 3 0.0093199948370597755 0.90377876541882918 0.0093886992355641553 0.59566811258533137 0.0094895678010971252 0.29398254859088219 0.0096244253465462455 -2.2204460492503131e-16
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 0 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 1 0 1 0.49999999999999806
+6 0 1 0.022116999205396622 0.99999999999999822 0.022116999205401125 0.50000000000002109
+6 0 1 1 0.49999999999999806 1 1
+6 0 1 0.022116999205401125 0.50000000000002109 0.022116999205405628 4.3964831775156199e-14
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 3 0.0092996260036778324 1 0.0093060697121294545 0.96785823942187277 0.0093128630355876225 0.93578398581508959 0.0093199948370597755 0.90377876541882929
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 1 1 0
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 1 0.49999989495897446 1 1
+6 0 7 0.010204283354970121 0.49549698249305546 0.0098589455537452658 0.42276634698916571 0.0095755125843776379 0.35012336387806253 0.0093586691753028313 0.27782401541655261 0.0092149637522914111 0.20620759023270741 0.0091523897217510239 0.13570882616603533 0.0091791131033570963 0.066833852288248508 0.0092996260036778446 8.3266726846886741e-17
+6 0 1 1 0 1 0.49999989495897446
+6 0 7 0.013827451348314462 1 0.013140802181006378 0.92921647398059082 0.012512910598683504 0.85787125038845469 0.011940188334605506 0.78600481620937201 0.011421326525780774 0.71369586392627782 0.010956863789277058 0.64104590589362154 0.010549621156194976 0.56822761799694521 0.010204283354970121 0.4954969824930554
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 3 0.43443141578834882 1 0.42899977911522541 0.99106159235266211 0.42342733207851269 0.98269264864612249 0.4176677827406205 0.97515126314325484
+6 0 1 1 0 1 1
+6 0 4 0.4176677827406205 0.97515126314325451 0.4008948785822995 0.95319256580326706 0.38447122400188816 0.93118818667035441 0.36824635456512067 0.90998039529549524 0.35172911681679603 0.88998035225226935
+6 0 1 1 0 1 1
+6 0 4 0.30794996113692763 0.842087587233602 0.3193184735315589 0.85298129366244024 0.33032410154023528 0.86471556180641196 0.34108538587199355 0.87709278732397555 0.35172929234529882 0.88998056306365458
+6 0 1 1 0 1 1
+6 0 7 0.30794996113692796 0.84208758723360189 0.29526467446343346 0.82993278867672127 0.28084879197102641 0.82260135132205636 0.26466693252778695 0.82139967009796189 0.24849080174988716 0.82702955022054692 0.23291420108668559 0.83698832482617025 0.21812872862413812 0.85171654620619752 0.20449943047491476 0.87072280726427831
+6 0 1 1 0 1 1
+6 0 5 0.15471291844833851 0.99999999999999989 0.16091166248283767 0.96661356149824185 0.16950911570926419 0.93669645836730053 0.17985774973394261 0.91074577051415451 0.19163032737469921 0.88866886921211374 0.20449973162130125 0.87072238734305141
+6 0 1 1 0 1 1
+6 0 1 0.02079464553093192 1 0.15471291844833854 1
+6 0 1 1 0.01039732338946231 1 0.077356583265610082
+6 0 10 0.020794645531117047 1 0.020649635875008718 0.90212751132198565 0.022191475654739997 0.80528052589316412 0.025044068655951275 0.70933453423236181 0.028894450888278356 0.61644720068301473 0.03524987080656064 0.52502197927881755 0.04251671308148959 0.44582446498956863 0.049154527478789053 0.36892851392853815 0.055630804406006776 0.29643404270704421 0.061226488094865923 0.22508301126581115 0.065584205412176494 0.15241149368721627
+6 0 1 1 0 1 1
+6 0 4 0.065584205412176244 0.15241149368721491 0.067782444954504334 0.11573978081675657 0.069557880909128234 0.07858146065440115 0.0708691986328049 0.040413081209855643 0.071463414591152227 -6.9388939039072284e-17
+6 0 1 1 0 1 1
+6 0 6 1 0 0.841065936243242 0 0.68382824419135346 0 0.5283271360007521 0 0.37449315127284044 0 0.22221295354078532 0 0.071463424675792447 0
+6 0 1 0.51312867619913904 1 0.037643241407493533 1
+6 0 1 1 1 1 0
+6 0 1 0 1 0 0
+6 0 1 0.43443141578834887 1 1 1
+6 0 1 1 0.21721566355309926 1 0.50000000001237566
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 0 0
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 0 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 0 0
+6 0 1 1 0 1 1
+6 0 7 0.78683520237994964 0.24393030012690228 0.82072209519804384 0.24550714031032186 0.85622186370922271 0.24517198923566325 0.89168887080567383 0.24272498007164114 0.9244388950984207 0.23829269659972893 0.95376984884941995 0.23240985272533221 0.97914071277566506 0.22528526224612114 0.99999999999999978 0.21721566355309938
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 0 0
+6 0 1 1 0 1 1
+6 0 6 0.24486977343178082 0.22900195729635939 0.3338224399771495 0.23138343652070523 0.42421920189558915 0.23307580512715653 0.51606208676167076 0.23466506747209553 0.60872717858458814 0.23679286513474349 0.69940066802393996 0.23986165860667194 0.78683520237994964 0.24393030012690214
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 0 0
+6 0 1 1 0 1 1
+6 0 6 0.13132491144873057 0.21114109906593775 0.14521162475222135 0.21588170595510572 0.1612453465268211 0.22014929340793696 0.17942761783742855 0.22379267371440739 0.19983012025589611 0.22663843028690298 0.22194838834918407 0.22838806188379632 0.24486977343178101 0.22900195729635939
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 0 0
+6 0 1 1 0 1 1
+6 0 5 0.079594698962867971 0.17784058818835788 0.083643972203259517 0.18511201006964809 0.090908958248363703 0.19222630270296046 0.10121549550786711 0.19905241781796265 0.11466085548454155 0.20545237079893613 0.13132491144873049 0.2111410990659377
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 0 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 5 0.079594698962867971 0.17784058818835791 0.070620699508604987 0.16172551937237772 0.064517643638648009 0.14537998795527399 0.061887587554822147 0.12887155361816283 0.063757882641093569 0.11226769737621348 0.072400617662330746 0.095795333122279003
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 6 0.072400617662330746 0.095795333122279003 0.075828558357799863 0.089261812583002934 0.082462024721611127 0.082795528150453587 0.092525816765393898 0.076499644319072982 0.1062672240081874 0.070487919994751347 0.12399228748417296 0.064923430878140953 0.14557646207606953 0.060016937280077121
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 6 0.14557646207606958 0.060016937280077093 0.16716063666796616 0.05511044368201326 0.19260654128191984 0.05086220638967532 0.22174505327902111 0.047474951251035923 0.25415432541507532 0.045218859676800734 0.28782212824314246 0.044300155390734341 0.32089531929949427 0.044673189692853332
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 3 0.99014546190915653 0.076300933958143177 0.99347271161389128 0.07663556637231933 0.99675803454175327 0.076987725817989419 1 0.077356583265610054
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 8 0.32089531929949422 0.044673189692853318 0.40873488241906525 0.045663933546544209 0.49800993501548385 0.047251720528021089 0.58796673836931412 0.049632216743390883 0.67734327338894451 0.053003143843580666 0.76228498759505336 0.057435699135147275 0.8428587851965641 0.062814479474554458 0.91875787956292732 0.069118295340369756 0.99014546190915598 0.076300933958143177
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 0 0
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 0 0
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 0 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 0 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 0 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 0 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 0 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0.0092996260036778411 1 1 1
+6 0 1 0.0092996260036778411 0 1 0
+6 0 1 1 1 0.02211699920539667 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0.0096244293994268704 1 1
+6 0 1 0.0096244253465462837 0 1 0
+6 0 1 0.875 1 1 1
+6 0 1 0.5 1 0.75 1
+6 0 1 0 1 0.5 1
+6 0 1 1 0 1 1
+6 0 1 1 1 0.013827451348314423 1
+6 0 1 1 0 0.013827451348314201 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0.32904398326450834 1 0 1
+6 0 1 0.32904398326450834 0.99999999999912292 0.32904398326446382 0.12288861419141306
+6 0 4 0.32904398390575412 0.12288861481042802 0.37930354939102628 0.13002829543631719 0.42991708730303169 0.14070052579683587 0.4798164627425725 0.15451459555681396 0.52811770590446483 0.17153020945780129
+6 0 4 0.32904398390575401 0.12288861481042802 0.37930354939102617 0.13002829543631719 0.42991708730303158 0.14070052579683587 0.47981646274257239 0.15451459555681396 0.52811770590446472 0.17153020945780129
+6 0 1 0.52811770536161218 0.17153020864079016 0.52811770555986892 0.99999999999917155
+6 0 1 0.62831259332781675 1 0.52811770555986903 1
+6 0 1 0.62831259332781675 0.99999999999921352 0.62831259332781675 0.21356836409993818
+6 0 4 0.62831259560942643 0.21356836422020542 0.67133786284109442 0.2348760326740186 0.71200761797725198 0.25925783217798037 0.74954430621441048 0.28695102365440461 0.78303922308497032 0.31831686240027046
+6 0 4 0.62831259560942632 0.21356836422020536 0.67133786284109431 0.23487603267401855 0.71200761797725187 0.25925783217798032 0.74954430621441037 0.28695102365440456 0.7830392230849702 0.31831686240027041
+6 0 1 0.78303922222148159 0.31831686293192374 0.78303922222147959 0.99999999999931832
+6 0 1 1 1 0.78303922222147959 1
+6 0 1 1 0 1 1
+6 0 3 0.014060917442871964 0.021372715656846942 0.013982144130556946 0.014256752567554855 0.013904323287103428 0.0071324604419958464 0.013827451348314214 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 7 0.037643241407493519 1.0000000000000002 0.030850921313786309 0.8703811025731909 0.026466641223271269 0.73708052787748091 0.02286097157270171 0.60044833064970138 0.020068731672548346 0.46047969799034061 0.017691916590826563 0.31728906273134849 0.015714598127599462 0.17075787345858076 0.014060917442871967 0.021372715656847202
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 1 0.51312867619913904 1
+6 0 5 1.0000000000000142 0 0.79644081819991264 0 0.59378262169967566 0 0.39324352294344767 0 0.19528782178199441 0 8.3266726846886741e-17 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 14 1.0000000000000142 1.5631940186722204e-13 0.99999999999968936 0.052244618944868648 0.96416527546717101 0.085952972545336181 0.91925086198246786 0.1186256406783974 0.84724480765558796 0.13992634563060599 0.77831403094064067 0.16890001601495513 0.68085741788554222 0.18643947059580199 0.5987146585297729 0.21929210025525966 0.49545055801956062 0.24517393792190861 0.40541616897076005 0.28328320504196269 0.31535419562506511 0.32628209404815084 0.24165164583071139 0.38087992090972983 0.186785310087942 0.44845477308156956 0.15615509113701501 0.52809185834606887 0.15011644856390627 0.6279470195491379
+6 0 8 0.67440236386565544 0.89244649839132806 0.52423365878260852 0.87130770436442517 0.40667729479075232 0.85023199281601991 0.31347578623201006 0.82533629669506714 0.24304831558463644 0.79469769626337872 0.19263506351560991 0.75812777938681286 0.16116781477841302 0.7170803007587192 0.14738381901799955 0.67313386104330908 0.15011644873497548 0.6279470197062812
+6 0 9 0.99999999999999978 0.99999999999987199 0.99999999999999878 0.98577691276907964 0.9998513970596602 0.97146952104660411 0.98767800149650065 0.95710119081350298 0.95666316787735284 0.94242468999782114 0.90452113434087678 0.92739576897723242 0.83902522612046981 0.9135591989735713 0.76841686464070014 0.90375686300079106 0.70714997382117395 0.89705628007636562 0.67440236385498409 0.89244649815444743
+6 0 1 0 1 0.99999999999999978 1
+6 0 1 1 0.50000000001237566 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 1 0.75286515021156863 1
+6 0 6 0.71369478965873878 0.58697090224753512 0.71454976228632083 0.65528868721892608 0.72048332948673377 0.72203438916786344 0.72843759779362161 0.78824962830973788 0.73743259594968502 0.85531599302717587 0.74646288799236327 0.92508810432198429 0.75286515021170108 0.99999999999955014
+6 0 13 2.2204460492503131e-12 0.30755495307513847 0.17352892534273159 0.30755495307512754 0.31373130094102436 0.30752086436215642 0.41421608839256019 0.32484790142037384 0.50714452034742208 0.33792819458327134 0.56377370041776953 0.36364089199471294 0.62390893890480503 0.38396766650373571 0.65440482015139689 0.4120190055827373 0.68585965608542121 0.43762404356349721 0.70106641062167341 0.46613306258171455 0.71158664584657572 0.4947277605054492 0.71387939117727151 0.52457903471462719 0.71329908795805486 0.55535180518452876 0.71369478962939548 0.58697090225226956
+6 0 1 0 0.011908595778587898 0 0.30755495307513575
+6 0 11 0.95397584345326503 0.010491941856618166 0.87120536616001154 0.010673892752811715 0.78519950666598604 0.010853320412606145 0.69552526067339904 0.011046012918819272 0.60346006506657801 0.01123887782541156 0.50750135224056692 0.011487069429432652 0.41610177404648008 0.011680871885095707 0.32771290475188025 0.011798885652249689 0.24226455537869551 0.011880315725519487 0.15960422877967992 0.011908311140016305 0.078963233399340665 0.011908595819141481 -2.1649348980190553e-15 0.011908595778585326
+6 0 1 1 0 1 1
+6 0 3 0.95397584345326492 0.010491941856618166 0.96947101250166046 0.01045788702638448 0.9848099923867798 0.01042652514769441 1 0.010397323389462265
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 5 0.84413881969947868 0.094298167916497644 0.86149349276980325 0.097846208346349536 0.87768210386177703 0.10470992607269058 0.8929662210787348 0.11434621615691352 0.90735417753623071 0.12664814019346859 0.92088656430438254 0.14199304994745249
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 6 0.92088624772980321 0.14199269084226657 0.94092948655356601 0.16472040246203812 0.95690861659974147 0.19127560076212174 0.97005483471393383 0.22074763283332985 0.98031130463896976 0.25322768723073424 0.98767771764547485 0.28909072455349094 0.99116433903238454 0.32864736470664657
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 4 0.99116433901930445 0.32864736470900191 0.9944380380483625 0.3657883444979923 0.99681383683431724 0.40305665305766036 0.99832179234177254 0.4403676814262607 0.9989776056984716 0.4776035506106221
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 4 0.99897759385977924 0.47760293588379155 0.99999999999999967 0.53565233264785717 0.99895306907195025 0.59355293473543613 0.9959017428041459 0.65125714603441809 0.99073089028662331 0.70864863663351874
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 8 0.9907308903633778 0.70864863664399269 0.99013857134915084 0.715222808121733 0.98944973608835063 0.72168833513158726 0.98866895025313528 0.72805007811332756 0.9878002143082939 0.73431190482945385 0.9868470449648461 0.74047698175533738 0.9858125385278832 0.74654797349076563 0.98469942048086312 0.75252717752071741 0.98351008440262033 0.75841661341380939
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 8 0.98351008440262033 0.75841661341380939 0.9753479527106601 0.79883441644707509 0.96359614102169333 0.83502436315704776 0.94902829972578862 0.86763921668885491 0.93168185631744693 0.89671527276195284 0.91145044191091562 0.92303021128939355 0.88756190025634796 0.94470102499662911 0.85916176481421425 0.9627076158073733 0.82309162526072766 0.96848737290260145
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 5 0.82309162537129954 0.9684873741739326 0.69395611875372143 0.98917961073976468 0.56208935602281285 1.0000000000000004 0.42777386849570914 0.99976428663053274 0.29141944582574808 0.98662659580804479 0.15461711198475409 0.95877393161219182
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 9 0.15461711197975453 0.9587739314106134 0.13669128359554544 0.95512427087918528 0.121296991492141 0.94859090306773597 0.10770608185363506 0.94038448592120882 0.095557375406217129 0.93095448636658296 0.084614351577616584 0.92055324200673361 0.074706161676420482 0.9093434214235584 0.065708055289363021 0.89742800436370296 0.057530280537035967 0.88486875285325017 0.050110610081799185 0.87169965395602611
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 9 0.050110610081799185 0.87169965395602589 0.041739414099043873 0.85684170191488884 0.034333234628219828 0.84120745458001567 0.027802702051760757 0.82484572347077267 0.022103046424605494 0.80776031466262344 0.017220433812549858 0.78993460431502738 0.013165781147464759 0.77134574265546385 0.0099647674361743668 0.75198356787140475 0.0077012634996961021 0.73173311549621778 0.0064825285426070283 0.71057482452429099
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 5 0.0064825285579246088 0.71057482449508336 0.0011153015035525338 0.61739512937741492 -7.1123662515049091e-17 0.52322522362365087 0.003350495497270011 0.42815568865689069 0.01162416901657384 0.33217617154091034 0.026779330890915016 0.23543763474478091
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 10 0.026779330905148446 0.23543763477533164 0.03024191884164619 0.21333521889356727 0.034714365946843129 0.19263598851529673 0.040035076894506333 0.17312834399071325 0.046122642753313729 0.1547628284036589 0.052915688200553715 0.13742321080585587 0.060388152222285697 0.12105213062810569 0.068536333851113615 0.10561999450033228 0.077375832628593294 0.09111749211114116 0.086942576193524315 0.077562028344334802 0.097298315390811768 0.065017266191555512
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 10 0.097298315390811796 0.065017266191555498 0.10632428713549365 0.054083361177377581 0.11594963623318652 0.043917257191819103 0.1262152493311737 0.034561106958268355 0.13717691566224152 0.02608375877790043 0.14890809106114855 0.018590586531913443 0.16150462057208267 0.012239067535972387 0.17509156500027265 0.0072598004557675334 0.18983433764121019 0.0039856186811510382 0.20597296862279058 0.0029521736088955457 0.22398914969358008 0.0055252623156838449
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 4 0.83754342169812646 0.093153683130772269 0.83920624429240298 0.093391169089756018 0.84085960779754954 0.093661407604071933 0.84250373315400418 0.093963886011782891 0.84413881969947868 0.094298167916497672
+6 0 1 0 1 1 1
+6 0 6 0.22398914977214826 0.0055252626461736575 0.33640030066665427 0.021579933819380961 0.44528121588835712 0.037130424914921571 0.54941611753711106 0.052003042574911285 0.64891309256765506 0.066213328500838636 0.74461987267563956 0.079882254745027137 0.83754342175600938 0.09315368745309352
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0.52811770555986892 1 0.32904398326450829 1
+6 0 1 0.78303922222147948 1 0.62831259332781664 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0.079624113278292219 1 1 1
+6 0 1 0 0.37129524112559037 0 0.1417973170245248
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0.97134816195252016 0 0
+6 0 3 0.040037729475801191 0.98560130010267966 0.026761767458220925 0.98082734834941843 0.013410581161755628 0.97607765688735071 0 0.97134816195252016
+6 0 1 0 0.49999651892954117 0 1
+6 0 3 0.079624113278292191 1 0.066514429232076691 0.99517346390039541 0.053313691493381457 0.99037525185594077 0.040037729475801191 0.98560130010267955
+6 0 1 0 0 0 0.49999651892954117
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 3 0.59365894354314375 0.47334002819639887 0.5958589566068847 0.46420742103676199 0.59798884362813376 0.45504102159793136 0.60008958973520043 0.44586140239574651
+6 0 1 1 0 0 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 7 6.591949208711867e-17 0.37129524112559043 0.065478262001162163 0.33992467489229444 0.13384674110162531 0.31062439222489652 0.20459410390980404 0.28293069814445082 0.27774354946291491 0.25724499628312542 0.35271105680835613 0.23417877365850323 0.43012600727348238 0.21695419423369811 0.50753379696535872 0.21041862046751908
+6 0 1 0 0 0 1
+6 0 7 0.59365894352687421 0.4733400280492962 0.58311670751146349 0.51710237526162683 0.5712920749110062 0.56024461135702364 0.55803521867949268 0.60257214389050351 0.54295950635296919 0.64381081426484699 0.52578410496938099 0.68334014840456336 0.50579554698449636 0.72051615262474267 0.48238169312013374 0.75266724932128892
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 7 0.50753379696535905 0.21041862046751916 0.54623769181129722 0.20715083358442968 0.58494104647028322 0.20654556840403121 0.62330454220482368 0.20922074293638449 0.66084681344463925 0.21573350170809766 0.69655857892832795 0.22688830511944566 0.72874213210198946 0.24225963239196113 0.75638581001258298 0.2610072746820129
+6 0 1 0 0 0 1
+6 0 6 0.48238169312013357 0.75266724932128903 0.46872361169925536 0.77142205572760769 0.45386208873569717 0.78841736365107218 0.43771927294531704 0.80308656303795101 0.42007663781969634 0.81455750007496941 0.40140279577474758 0.82146168668153563 0.3824653581660073 0.82363550760308668
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 6 0.75638581001258276 0.26100727468201262 0.78863676757494183 0.28287952402040634 0.81453948729921244 0.30948020569215962 0.83213857622701604 0.33932567671863401 0.84113045383565077 0.36986208470484883 0.84318298851843465 0.40021819764773547 0.83959133667428698 0.42988690274460278
+6 0 1 0 0 0 1
+6 0 6 0.38246535816600735 0.82363550760308657 0.36352792055726707 0.82580932852463762 0.34431916967554205 0.82324689137399487 0.32557618416358258 0.81567425856833842 0.30814428993943871 0.80383078048253209 0.29225161061800597 0.78864153936247772 0.27797408033071785 0.77084121333246014
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 8 0.83959133667428665 0.42988690274460295 0.83420385890806503 0.47438996038990394 0.81674784494786168 0.51743843713502935 0.7912193216704928 0.55769154156425527 0.76160822546965856 0.59598334075261716 0.72891397593959661 0.6330139663160852 0.69437270062159862 0.66936259973523671 0.65832670886900724 0.70553925316110422 0.62089286047259307 0.74156559657246646
+6 0 1 0 0 0 1
+6 0 7 0.27797408033071785 0.77084121333246036 0.2534983141239382 0.74032636870957313 0.2336326753256262 0.70234359256454604 0.218656554932636 0.66040591710352292 0.20733993069096424 0.61655023919527285 0.19953604660430108 0.57116892806276964 0.19525406290377237 0.52502603726463803 0.19466756239111899 0.47878111826730008
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 7 0.6208928604725934 0.74156559657246668 0.57811131944812 0.7827385604711663 0.53347345670171575 0.82370795733816837 0.48711252543845551 0.8645463110644046 0.43847715400184972 0.90450446291042219 0.38613309051459305 0.94062095288000191 0.3304209180386074 0.97268827572083705 0.27164568794048066 1.0000000000000002
+6 0 1 0 0 0 1
+6 0 7 0.19466756239111901 0.47878111826729997 0.19408106187846563 0.43253619926996201 0.19719682232954053 0.38620624288569916 0.20407751280265507 0.34044082684406701 0.21519058120604095 0.29620999180204721 0.22951826164079198 0.25439527589970234 0.2463241466759013 0.21457260258727953 0.26538393094468649 0.17706717824493357
+6 0 5 0.31220746812925504 0.099914920427589704 0.30186727230750543 0.11407246753754344 0.29201895472614525 0.12895477059709817 0.28266444808513419 0.14446810071554714 0.27378958115059737 0.1605271796672442 0.2653840581540246 0.17706729072202201
+6 0 1 0 0 0 1
+6 0 5 0.60008974896649403 0.44586095218606986 0.60757243614997325 0.41316621891577016 0.61473859754482874 0.38032757159494168 0.62226340108668043 0.34764816669510329 0.63007009445026774 0.31510596166609411 0.63797487405731557 0.28261214449728278
+6 0 1 1 0 1 1
+6 0 3 0.63794287672988037 0.28265307261192324 0.6399644678528601 0.27425605439709977 0.64198124310460136 0.26585699272859276 0.64397429216761404 0.257447877863412
+6 0 1 1 0 1 1
+6 0 7 0.64461525238322981 0.233407465778391 0.64584351593318312 0.23647323831357844 0.64628476923598011 0.24017012783730063 0.64619986112526695 0.24368266203540642 0.64594773817877316 0.24724012861348735 0.64542338370940389 0.25069735604085686 0.64476657050726827 0.25410481704870819 0.64397423110525676 0.25744784834851692
+6 0 1 1 0 1 1
+6 0 6 0.63721977132970997 0.22838456258653062 0.63866505277751684 0.22823945432861883 0.64011994250101245 0.22839153796037059 0.64157951187897777 0.22886794263049207 0.64292027581855038 0.23004572607404031 0.64389876531242363 0.23161909846619835 0.6446152523832297 0.23340746577839103
+6 0 1 1 0 1 1
+6 0 5 0.62900245446244518 0.23215116451227635 0.63054337866123888 0.23100748051484624 0.63213462976418344 0.22999666916034187 0.6337742097080219 0.22916281063157129 0.635485433592342 0.22855869249602467 0.63721977132971019 0.22838456258653053
+6 0 1 1 0 1 1
+6 0 5 0.55494518853282582 0.30215081310187469 0.56886585627112607 0.28635267658404673 0.58317893265748044 0.27125209890424051 0.59793889714458115 0.25701465182034022 0.61320943231218306 0.2438727929439086 0.62900245359054097 0.23215113820371497
+6 0 1 1 0 1 1
+6 0 7 0.46242288223872924 0.27610761450798327 0.47033452160316647 0.29468491244087724 0.48147811566090781 0.3104743431717763 0.49573556664944313 0.3218068508119053 0.51196537260694208 0.3265319875605166 0.52829800840014363 0.3243758742841672 0.54300227519053434 0.31570446478095465 0.55494516793914817 0.30215078862095129
+6 0 1 1 0 1 1
+6 0 7 0.3269921160134 0.093644050738355092 0.35237127832048304 0.10732791757954753 0.37592590317982361 0.12783591635905378 0.39689252642427503 0.15322256755745023 0.41580881164196504 0.1811476680108407 0.43288681214895586 0.21136944110391415 0.44837416393625024 0.24311991731843158 0.46242283365959175 0.27610748797385154
+6 0 1 1 0 1 1
+6 0 6 0.32699213558342349 0.09364397208147783 0.32445299654430426 0.092274932668834117 0.32160481474471331 0.092011506024302053 0.31880885319754504 0.093148557559449716 0.31637753424108606 0.094927764477769544 0.31416260369224852 0.097237919957706226 0.31220736444168601 0.099914973140458802
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 7 1.0020873020266663e-12 0.083589874125380798 0.13792827095774207 0.083589696200194463 0.2810596523432865 0.084375819243695707 0.42810315020664114 0.085828186822611147 0.57710033145233464 0.087927166353593336 0.72366999753909456 0.090761141025435838 0.86526152226313213 0.094667201888169114 0.9999999998792829 0.10012821417723705
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 1 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 6 0.99999999999947187 0.73610789735797821 0.91188543674279587 0.73610789912704933 0.82572089323811915 0.73026705220543853 0.74240323682676379 0.71730410225700447 0.66257074935916382 0.69613975652548066 0.58652386840106874 0.66687404028648722 0.5141945061456199 0.6304449466092451
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 6 7.8270723236073536e-13 0.94920657447072454 0.12738097312032073 0.94920657654300788 0.25902975780262905 0.94680457690717967 0.39432392843324371 0.94254412013368138 0.5333490600587224 0.93738035994289481 0.67630999978694661 0.93223408059977553 0.82482522042656603 0.92771369290566663
+6 0 1 0 0 1 0
+6 0 1 1 1 0 1
+6 0 1 1 0 1 1
+6 0 5 0.82482502082372067 0.92771366366786556 0.85547599603630209 0.91354034951617424 0.88881539817491473 0.90007892191087524 0.92427547885399131 0.88736772195221736 0.96144579680520748 0.87540503515804491 0.99999999990333754 0.86417718880647376
+6 0 1 0 0 0 1
+6 0 7 0.79974312316712293 0.99999999999999978 0.79481120522555393 0.96846111839419191 0.78869046215523164 0.93718586776433777 0.78163550795958869 0.90512700088933307 0.77365328045403503 0.8712837327876044 0.76492022635010626 0.8353475699698647 0.75511231231832365 0.79473344346006014 0.74503415223227532 0.75027386638904692
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 1 0 1
+6 0 1 1 0 0 0
+6 0 1 0 0 0 1
+6 0 8 0.54341690593377523 0.28308933515330748 0.62394528927138759 0.28026018571388772 0.69597990241838814 0.27526032656122285 0.75588395766601502 0.26935272338234278 0.8125972511203331 0.26314152000791774 0.86321806251403144 0.25646671667378801 0.91139667650972966 0.2496648309837271 0.95671257028782319 0.24267717471273181 0.99999999999999978 0.23557856307783845
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 8 0.22188725796418277 0.27684638713617848 0.2557795751583562 0.27936979301951653 0.2919722076567966 0.28162321569356474 0.33086399631796481 0.28349223609560226 0.37207336961793497 0.28491782185259318 0.41682279413857298 0.28558980825672831 0.46076090898609368 0.28537697955328356 0.50315271426496921 0.28450390987301744 0.54341690593377534 0.28308933515330759
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 5 -2.7755575615628914e-17 0.25219928645636958 0.037183405098153641 0.25763574247748261 0.076957263383380214 0.26293510123010067 0.11996494400682292 0.26800933924366843 0.16765955045350522 0.27280893772283765 0.22188725796418274 0.27684638713617854
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 5 0.43645754576540552 0.57967323957785044 0.43094655703493506 0.5620564612224338 0.42263785382337504 0.54458169468255235 0.41124793698244622 0.52736118968125822 0.39640270475210532 0.5105596844878183 0.37782378578842024 0.49445707037131925
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 8 0.51419436075726188 0.63044473059710326 0.53163139639403467 0.55254771963008742 0.53894111231089892 0.46994966028360985 0.53706448606296819 0.3868520451033074 0.52903236096868944 0.30572065505325013 0.51615512002543296 0.226219451082252 0.49966069804541713 0.14890736355382897 0.48040771331486615 0.073551548369608949 0.45897593681062493 6.030453914007694e-13
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 1 1 0 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 0 0
+6 0 1 0 0 0 1
+6 0 9 1.0000000000000149 0.097822312820071464 0.96946911075869568 0.098356967417326122 0.9438037834019436 0.098575327007919142 0.915299023025262 0.099027526642995606 0.88904210731154243 0.098895451171709864 0.8610050379288956 0.099017505681134987 0.8346155707216012 0.098988950811176493 0.8070616935671926 0.099053897750815453 0.77915719522563454 0.09909032771014803 0.75003035868059298 0.099098860505289266
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 8 0.20892985665338631 0.43367577953299252 0.18718666784425758 0.42652475147569957 0.16345367812019848 0.42054948758192401 0.13973491242885833 0.41540795565025546 0.11317080660163514 0.41150855527339225 0.086640803102928043 0.40835437394763524 0.058818397482737192 0.40613709402087012 0.029938067363855105 0.40493192829424113 4.5471593157486723e-10 0.40492358602791312
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0.45897593681062476 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 0.73610789735797821
+6 0 1 1 0.23557856307783853 1 1
+6 0 6 0.86960426275168068 0.78415535207908749 0.80190042529308247 0.72965355328949499 0.74035368419405956 0.67542713029759383 0.69070028995435517 0.62122129246654612 0.65750758785420949 0.56711734798580704 0.63866314676176561 0.51266722209282189 0.63029012338915646 0.45740753539564855
+6 0 1 1 1 0 1
+6 0 1 1 0 0 0
+6 0 1 0 1 0 0.25219928645636958
+6 0 7 0.37735176506403856 0.29488501957951885 0.38369434110836725 0.32334910548648965 0.38954789703118492 0.35183026861778155 0.39374860588057892 0.38037307449925334 0.39530570492080608 0.40898382392023741 0.39352824345910559 0.43762769740470092 0.38769105707189933 0.46615628440542545 0.37782373020670507 0.49445708046264647
+6 0 1 1 0 0.39877927311875827 0
+6 0 1 0 1 0 0.39877927102854349
+6 0 1 1 0.53348830340565334 1 0
+6 0 6 0.43645756884159259 0.57967323886915101 0.52643479937919013 0.56574842913846179 0.61824685363073717 0.55374469515672164 0.71188622227570308 0.54404823572133409 0.80721472838498431 0.53711388150076156 0.90360864224716531 0.53348830340589537 0.99999999999228217 0.53348830340565345
+6 0 1 1 0 1 1
+6 0 8 0.37735176506393436 0.29488501957905272 0.36993033051881641 0.26157925407169907 0.36185501375146023 0.22829751236717702 0.35490979451113708 0.19496554041583261 0.35091718007812817 0.16157530682222354 0.3525917551819423 0.12780176801514143 0.36141845890758845 0.094508618975093703 0.37450195627105254 0.061485827524917713 0.38754815125160291 0.02846159356974072
+6 0 1 0 0 0 1
+6 0 2 0.39877927311875827 2.8467771082075696e-14 0.39316906451867806 0.014231180898735441 0.38754770464443256 0.028461647989424809
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 5 0.523169082257674 3.4179603591866226e-13 0.54647233965427056 0.067472431114970213 0.5717076035623837 0.1257031669599265 0.5983660197217866 0.17440399549246804 0.62605009010167734 0.2137947134683397 0.65444629814346555 0.24387932341454913
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 5 0.38054019687502166 0.88612420105410028 0.30316308903050171 0.88479341598235517 0.22690722986912917 0.88366537431619985 0.151434848180174 0.88276928537898536 0.07610720260164712 0.88211966972537703 9.6625737966427039e-10 0.88172013714794761
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0.55539572855366082 0 1
+6 0 6 0.60978716079925976 0.44403895266962345 0.68550460026242899 0.45363928340930304 0.75809535761034341 0.46469116689883144 0.82651190581751011 0.47733068021434161 0.88974370671844483 0.49146283697358528 0.9475390877737605 0.50680969328689407 0.99999999896582248 0.52316908193506273
+6 0 1 0 0 0 0.55539572855366082
+6 0 6 1.5962786648060501e-12 0.39877927102854344 0.10540388973431254 0.4028394803726133 0.20997171043435675 0.40818749034466989 0.31342670543569745 0.41462490671549168 0.41573689448507156 0.42231876981240679 0.51520158499109847 0.43204630205697769 0.60978715342018597 0.44403895173401919
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 9 0.8388610711532225 0.96511159088229281 0.84209147008990037 0.94995236017068196 0.83023059411062161 0.93542034983101152 0.80204404697760234 0.92210642576297086 0.75820490741284519 0.91051992824227634 0.69631284895239542 0.90109524258701001 0.62179897122221639 0.89452105733116249 0.54294082089281515 0.89017923376315322 0.46198967141137881 0.88752432427885386 0.38054019553154572 0.88612420122102775
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 2 0.83886107121152897 0.96511159088078446 0.83514698912855578 0.98256174536208718 0.83190975038817261 0.99999999999996525
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 0 0
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 8 0.6302901233525311 0.45740753515389182 0.62207506417006353 0.40319036908207817 0.62344597485847852 0.3482285361247327 0.63155433901776847 0.29209579579257516 0.64162945796793891 0.23477569523740904 0.65170994954501382 0.17483788754874074 0.65829776600125312 0.11503266577332638 0.66111479401449946 0.056483664040767483 0.66381575267637594 4.6863207758818248e-13
+6 0 1 1 0.52316908225736891 1 1
+6 0 1 0.52316908225767389 0 1 0
+6 0 1 1 1 0 1
+6 0 1 1 1 0 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 9 0.1208513537780123 7.3924200094666048e-13 0.12085135390938297 0.076378501920000563 0.12085037525901923 0.15534366814172115 0.12081373090405131 0.23011148524835606 0.12070620267078731 0.28727752386762651 0.12059828002014807 0.34710752013659602 0.12045217650292087 0.39782788602338121 0.12029454835457029 0.44719717317399277 0.12011920821461151 0.49398901093142 0.11993197827028723 0.53928291528680317
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 7 0.99999999999982681 0.35094808783363185 0.97519174729118385 0.35094808994840321 0.95038388673200946 0.35099860789676951 0.92557257771987678 0.3485565414127697 0.90078152524172894 0.34472745389564002 0.87600899355016459 0.33970136670909062 0.85125142149009947 0.33367581040979327 0.82651707712974576 0.32655381672234485
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 5 0.11993197827028114 0.53928291528425942 0.11976347132105825 0.58004742904218864 0.11958408377343431 0.61945472654777223 0.1193949565885339 0.65833713466217958 0.11919993624566241 0.69720126318762876 0.11900126658339366 0.73739521462627289
+6 0 1 0 0 0 1
+6 0 4 0.82651707712948563 0.32655381672226369 0.80487204591118888 0.32032135818381657 0.78325145996846679 0.31314568637290557 0.76165374078244796 0.30507652809755526 0.74009119766567688 0.29566643386363112
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 5 0.11900126658203797 0.73739521498185856 0.11890193175136442 0.75749219060875617 0.11880203501354401 0.77792056804720022 0.11870140901287268 0.79888471764689517 0.11860178270986385 0.82054778573263298 0.11850597052020721 0.84363952198397274
+6 0 1 0 0 0 1
+6 0 4 0.74009119766554765 0.29566643386358227 0.72931120842501396 0.29096194636204525 0.71854223449439014 0.28591374376620871 0.70778715887321186 0.28048051302861782 0.69705555946702857 0.27442450807747326
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 5 0.11850597052007647 0.84363952204115611 0.11845806442317543 0.85518539066684984 0.11841077932325285 0.86708721798612853 0.11836537769425849 0.87946057334320415 0.11832285773936399 0.89239736682492676 0.1182851552557088 0.90633910385703731
+6 0 1 0 0 0 1
+6 0 4 0.69705555946696429 0.27442450807743379 0.69168995030011582 0.27139661312436481 0.68633097187431158 0.26820937670894834 0.68098029377801128 0.26483815247572051 0.67564294857827989 0.26117901850798209
+6 0 1 0 1 1 1
+6 0 6 0.11827985989880931 0.99999999999988576 0.11819593391958522 0.98083778938308575 0.11818862603392158 0.96411897065612795 0.11819735567326704 0.94844897435510822 0.118216819648788 0.93379293111031758 0.11824877185265076 0.91979306739721012 0.11828515525428389 0.90633910438338572
+6 0 1 0 0 1 0
+6 0 6 0.65444625887032459 0.24387928178800572 0.65792873595637602 0.24756719380579031 0.66145842319004633 0.25055925107282317 0.66498417931168285 0.25353097884616127 0.66853096395513434 0.25616933163275424 0.67208426361805973 0.25873928404615237 0.67564294857823759 0.26117901850794689
+6 0 1 1 0.35094808783363185 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 0.70167151050987309 1
+6 0 1 0 0.1417973170245248 0 0.042302179402676165
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 1 0.27164568794048072 1
+6 0 1 1 0.50000000002162814 1 0.86417718877838712
+6 0 1 1 0.20275427064907062 1 1
+6 0 1 0 0.20275427064913532 0 1
+6 0 8 1.0916493403678729e-12 0.042302179406968753 0.13643928943352218 0.054215551718812274 0.26671826550557787 0.067531160513346247 0.39283271397645619 0.082792110388996948 0.51647557417270284 0.099859648892197284 0.63850613714493631 0.12018489415053335 0.75981758144456724 0.14342903664732257 0.88042650682470003 0.17066219638072133 0.99999999999904332 0.2027542706488151
+6 0 6 0.99999999999889722 0.25661792561730157 0.81622341469285509 0.25738378363577707 0.66422356115319703 0.2590164546381733 0.52792314312579602 0.2608408686086563 0.39197771810398108 0.26289895419922188 0.24186510353883442 0.26554993847324787 0.063812297494645037 0.26862657762685599
+6 0 2 6.3965468392965935e-14 0.26949763607866589 0.031980364292715828 0.26917719985037603 0.063812297493514678 0.26862657762687547
+6 0 1 0 0.26949763607866589 0 1
+6 0 1 1 0.26949763607867527 1 1
+6 0 1 1 1 1 0.25661792561730157
+6 0 1 0 1 0 0.25661792561729413
+6 0 1 1 0.10012821418210464 1 0.50000000002162814
+6 0 1 0.79974312316712304 1 0 1
+6 0 1 0 0.9492065744707241 0 0.59710075196099632
+6 0 5 0.20570943450472803 0.56994850199576064 0.17112553726582688 0.5807571290840684 0.13195795180767669 0.58860408489677163 0.090873324264616709 0.59395166384447162 0.047011624700869288 0.59710561091542214 1.9221857406465093e-07 0.5971007519805841
+6 0 1 1 0 1 1
+6 0 5 0.20570943450472801 0.56994850199576075 0.22538005259992785 0.56380077451094801 0.2410793630240895 0.55747263581432804 0.25378937226854209 0.55115751117368939 0.26410557606973617 0.54484029366139175 0.27232194856233932 0.53855600575093288
+6 0 1 1 0 1 0.14321670048904145
+6 0 6 0.27232195586818075 0.5385560001630646 0.29840690226651445 0.51860493993137191 0.30417411285060736 0.49897249917027475 0.29797418830667821 0.48052400270311107 0.27883909751216357 0.4632271900213551 0.25009905546512462 0.44721575657356288 0.20892991574409769 0.4336757994033873
+6 0 1 1 0.14321670048904145 1 0.68882896767203994
+6 0 6 0.20892985665338631 0.43367577953299241 0.18545120673189211 0.42595398279885954 0.15775814454308196 0.41908682294782046 0.1268053766397505 0.41280280413509823 0.089973278680268984 0.4082807788488878 0.048743983563494533 0.40493716855196604 2.417163691426083e-13 0.40492358602778644
+6 0 1 1 0.68882896767203994 1 1
+6 0 1 0 0.40492358602778555 0 0.083589874125380825
+6 0 9 0.74503415223227987 0.75027386638904658 0.73954179464361347 0.72604445413225482 0.73397269839828205 0.70071128515822934 0.72842466281573748 0.6744259789818976 0.72306183837171845 0.64739586692190321 0.71815412244575416 0.62057068465630094 0.713633433267294 0.59436334163710669 0.70932283256321704 0.56889891098385181 0.70503308487809746 0.54419334306670508 0.70058353928756911 0.52021672673932362
+6 0 1 0 0 0 0.70068280457908771
+6 0 10 7.6083583877561978e-13 0.202754270649388 0.074961107196847565 0.2228729219951463 0.14905813065513207 0.24471712084647812 0.22211416264562583 0.2684939909813962 0.2943191409303042 0.29417414243505136 0.36503127782834977 0.32265215851810353 0.43543736530762472 0.35298757075191689 0.50338294253075344 0.38813056262809714 0.57139463550953529 0.42597742173652114 0.63687646989541546 0.46986432512299442 0.70058353940521922 0.52021672683227882
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 0.50000003610968857
+6 0 6 0.99999999999999978 0.97134787560463776 0.91943145344811472 0.95731103223546998 0.83800437130867578 0.94341934920997705 0.75596143173382446 0.92963844480275948 0.67342258333048777 0.91594720415745812 0.59044282395288916 0.90233327199044588 0.50703666312353757 0.88879023601661866
+6 0 1 0 0.50000003610968857 0 1
+6 0 6 0.50703666312353757 0.88879023601661877 0.42363050229418597 0.87524720004279155 0.33979794001308139 0.86177506026214923 0.25555348580273268 0.84836740438958769 0.17087116085393406 0.83502376313852544 0.08570896044675376 0.82174679364669467 -2.9143354396410359e-16 0.80854115362403034
+6 0 1 0 1 0 0.25048572751575571
+6 0 1 1 1 1 0.25048572751584419
+6 0 1 1 1 0 1
+6 0 1 1 0 0 0
+6 0 6 8.0714081251986869e-13 0.25048572751575565 0.13450955396287187 0.25795681060948916 0.28288071036741619 0.26348561390965114 0.44221022923929076 0.26745450813358879 0.61338482953947571 0.26986234956948119 0.79765503509074209 0.27069824624938182 0.99999999999878608 0.26949763607867522
+6 0 4 0.99999999999900768 0.25528929497408703 0.75192183239651456 0.2552892949740877 0.50644158863404387 0.25551275655080885 0.25827811669601108 0.25594839791046131 1.0333400801698644e-12 0.25661792561729418
+6 0 1 1 0.25528929497408703 1 1
+6 0 1 0 0.25528929497408681 0 1
+6 0 14 0.2723219558681807 0.5385560001630646 0.27948909676436168 0.5330742154767879 0.28552023580830627 0.52743003746296435 0.29046511257007074 0.52158148978989494 0.29431415097824565 0.51547881770708437 0.2969885897210971 0.50906982033120163 0.29832151947799557 0.50230486084394166 0.29803746411076282 0.4951384175452776 0.29576686818088205 0.48752332883518279 0.29114255686428403 0.4794056059913035 0.28388996266314637 0.47076246674748995 0.27346514210613715 0.46173440696772283 0.25814191319072333 0.45263006524734756 0.2371666668080526 0.44296246837547237 0.20892985504088657 0.43367577943895208
+6 0 10 -1.9896029268551274e-12 0.59710075196069567 0.046495868488377459 0.59710556782689295 0.086509355899140161 0.59436341567633955 0.12268179732989595 0.59017255634031973 0.15320980206763563 0.58489460671728088 0.18225388009298157 0.57863352104293708 0.2059883919446619 0.57182844782298003 0.22744741214785844 0.56425275523645346 0.24551613066303152 0.55617090479402365 0.26051502182559305 0.54758652799300322 0.27232195276047499 0.53855600253999047
+6 0 1 1 0 1 0.50113657614995633
+6 0 1 1 0.40984677673476289 1 0
+6 0 1 1 0.40984674758220785 1 0
+6 0 9 5.6507851475817716e-07 0.70068280457908771 0.10281484004928694 0.66111146884894134 0.20400239275881335 0.62401268820499978 0.30254223154921278 0.58901199113017877 0.39947470779697425 0.55583327980068165 0.5000078656555117 0.52515781296166386 0.60172327581835527 0.49436937710291684 0.715441945378684 0.46543392150001806 0.840016121388796 0.43492134081500217 0.99999999999855671 0.40984677673476277
+6 0 1 0 0 0 1
+6 0 5 0.99999999999987055 0.80859039523281151 0.97413996833708838 0.80367957234914844 0.94818391672586644 0.79877974066596413 0.92211843773856961 0.79389180237933032 0.89593006174058076 0.78901671235962456 0.86960421676351163 0.78415532030961432
+6 0 1 1 0 1 0.97134787560463776
+6 0 1 0 0.80854115362403056 0 0
+6 0 3 0.92086154920023666 0.24222221076571773 0.94536532930547723 0.24515965450163721 0.97171360135485152 0.24791749600733831 0.99999999999991518 0.25048572751584419
+6 0 7 0.9208615490959311 0.24222221076581352 0.81208709481097385 0.22918263736202271 0.70085415430014286 0.2168625664437844 0.58738640352589189 0.20557031622344299 0.47033341345233615 0.19517547956896927 0.34241222930256543 0.18579642978725816 0.19705722378860058 0.17679965258556096 1.3793410857942945e-12 0.17077636877328828
+6 0 1 0 0.88172013714287445 0 0.17077636877328817
+6 0 1 0.11827985989880931 1 0.8292236312267981 1
+6 0 1 0.83190975038817261 1 1 1
+6 0 1 0.66381575267637571 0 1 0
+6 0 2 0.99999999999900002 0.25528929497408681 0.50015382757105153 0.25528929497407277 1.0001999228848035e-12 0.25528929497408687
+6 0 1 0 1 1 1
+6 0 1 1 1 1 0.25528929497408681
+6 0 1 0 0.75 0 1
+6 0 11 0.20589806613823336 0.087671981796134002 0.18984780686718922 0.089056197811421212 0.17348274640507477 0.090360144212063773 0.15667691029349951 0.091582517675883254 0.13988265385006779 0.092721449117648597 0.12109955762119613 0.093772707253416715 0.10474412634813654 0.094721019083892771 0.083569209872391595 0.095557659028549249 0.065991265668292068 0.096251682649940801 0.044392633174711982 0.096838439279472346 0.024359131148309111 0.097395737133897223 -2.1910835056038191e-09 0.097822312338422535
+6 0 1 0 0.5 0 0.75
+6 0 6 0.37275534427001122 0.068677333916096983 0.34562138954916094 0.072289581554513996 0.31851867845418225 0.075808421474959448 0.29122651993252113 0.079177011152369692 0.26359474576480413 0.082302201153050536 0.23532354146848095 0.085134252434774127 0.20589806613823333 0.087671981796134002
+6 0 1 0 0 0 0.5
+6 0 10 0.75001076090018171 0.034546640460149547 0.6980685908808637 0.034552950203759522 0.65380232055028997 0.036313028139605005 0.61250590851069642 0.039189000191452918 0.57538618102975203 0.042420597172414004 0.5383967179908804 0.046877537343517933 0.5045864550195418 0.050847223259304089 0.47079914164800707 0.055403189416902698 0.43791849376788078 0.059883395959934096 0.40531608993503154 0.064342636749996671 0.37275534427001095 0.068677333916097275
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 1 1 0.53617608721011278 1
+6 0 1 1 0 0.53617608721294319 0
+6 0 1 0 0.85035292048073785 0 0
+6 0 14 0.53617608721011278 0.99999999999971345 0.50094555515436501 0.97952533217836946 0.46523240471920629 0.96041689124348062 0.42915181184666351 0.94299354943622082 0.39232916537126661 0.92604349634282745 0.355550902854332 0.91388237250709847 0.31754768763217556 0.89539521434503699 0.27997313342068458 0.89188518069585487 0.24108986759788606 0.87147563022656527 0.20253851183480895 0.87118177022039167 0.16266894761803113 0.85996175935420349 0.12290484649783151 0.85652822410734697 0.082382460247201195 0.85216817350682872 0.041454921951277118 0.85035292048103439 5.6903093348381617e-13 0.8503529204811423
+6 0 9 0.9999999999995528 0.40984674758220779 0.95032422622844936 0.35046637583022305 0.90115013079717732 0.29517288631325539 0.85184510648946865 0.24422195541697189 0.8021836135262026 0.19599067428373959 0.75197364446419068 0.14985876838198289 0.7002524312608297 0.10838230226434784 0.64725790242761838 0.068992442438365428 0.59262759264296316 0.032807504010039901 0.53617608721294296 2.9529850786857992e-13
+6 0 1 1 0 1 0.8085903952328114
+6 0 1 0.1208513537780123 0 0.83832398192148028 0
+6 0 8 0.82922363122679821 0.99999999999894185 0.83467700908092868 0.86775485090710658 0.83667282957361577 0.74879684890365239 0.83791940644068552 0.63603279252110723 0.83835726167564428 0.52150553887378992 0.83843460968541805 0.4010890450512814 0.83831980124991934 0.27268627492108755 0.83832398192147684 0.13773116921565398 0.83832398192147695 1.1016465517599272e-12
+6 0 1 0 1 1 1
+6 0 1 0 1 0 0.25528929497408681
+6 0 1 1 1 1 0.25528929497408703
+6 0 1 1 0 1 0.40984677673476289
+6 0 1 1 0 1 0.40984674758220785
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 14 0.99999999856640187 0.012120678490362025 0.83473770713968576 0.012120678217188794 0.76292579308555131 0.011923285260374646 0.65865027067261761 0.013579574621012972 0.65608487416589267 0.0070000104109501932 0.53717636562729554 0.0231819710151056 0.5636573499034051 -0.0044728227056417859 0.4964620805636647 0.030875916162499805 0.43560935824064451 -0.0044168669997141537 0.45713866701068984 0.023154548905409435 0.34168718435745538 0.0069827560338397397 0.33760056467920441 0.013598174354957009 0.23478198734947767 0.011918487959925821 0.16305567105080482 0.012120677436482038 1.3373605001198996e-10 0.01212067712545031
+6 0 1 1 0 1 1
+6 0 1 1.0000000000000002 0.051842220155791013 0.99999999999999989 0.012120677893318943
+6 0 1 -3.4694469519536142e-17 0.051842220155786371 -1.9435340381339372e-16 0.012120677893318152
+6 0 8 1.000000000000002 0.051842220155791013 0.96662732315925159 0.047813090226383699 0.93697838369530462 0.044160821483077234 0.90518093238463304 0.041341995632858057 0.87566367403927703 0.03855194618862786 0.84472220593180025 0.03669023956422425 0.81440944462121134 0.035265763245813583 0.78289791457275526 0.034542645592758693 0.75001076100808095 0.034546640557229356
+6 0 1 0 0 0 1
+6 0 1 -1.2079226507921703e-13 0.012120677890550269 2.6147972675971687e-12 0.097822312819999979
+6 0 1 1.0000000000010221 0.01212067789472826 1.0000000000000002 0.097822312820071158
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 14 4.5372311463509618e-10 0.012120678031152465 0.1640598460805742 0.012120677910449526 0.23581205083302054 0.01192090929905958 0.33933357070163189 0.013587815172517165 0.34267279525080907 0.0069985196974307537 0.45990316005901055 0.023145274298191999 0.43591401616405184 -0.0044007705881584022 0.5000369354500841 0.03082129684917586 0.56408217289343998 -0.0044002093447988236 0.54015861281578015 0.023144964908402961 0.65734118217937354 0.0069983952362487681 0.660705892495692 0.013587977046511095 0.76420758519244059 0.011920866138900858 0.83596306668624398 0.012120678096199579 0.99999999837184195 0.012120678253397361
+6 0 1 1 0 1 1
+6 0 14 -1.3353655958781019e-09 0.051842219979405968 0.075686373763768897 0.060979941869900606 0.12579999518554638 0.069733427052815586 0.20111579023090007 0.078016807904654747 0.21553310010082191 0.080171122478945339 0.31227539070512023 0.094462183632762847 0.29524741978599822 0.085060674913957218 0.40762890965726101 0.10095970546353129 0.39698845327886889 0.092320007874689053 0.48064023007964418 0.10071235715067928 0.50794493964296583 0.097968294036915177 0.5648013900156803 0.098930420430097685 0.61758312510971469 0.098923562643700197 0.67662856588732512 0.099120363437126463 0.75003035981572497 0.099098859941285228
+6 0 1 0 0 0 1
+6 0 1 0.53617608721011278 1 1 1
+6 0 1 0.53617608721294319 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 1 0 1
+6 0 1 1 0 0 0
+6 0 1 0 0 0 1
+6 0 14 0.49803245446592825 0.001048263720399234 0.74831427765023761 1.0487458520971188e-09 0.85843435182980787 0.14250171930946828 0.93653988663202103 0.18603421115602248 0.95652045532105867 0.34835666981658958 0.99111805697495159 0.3268811006772474 0.98623122883727343 0.47663695412281937 1.0000000000035214 0.49754915665248978 0.98614188513566603 0.53132135083632237 0.99042593271600454 0.67006367304603587 0.95597520123618496 0.65592078277302979 0.93576556690573554 0.81283788593085815 0.85792222151362096 0.85830415118330317 0.74885903423691391 0.99792538353761595 0.50193978847458931 0.99895956145889153
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 14 0.49803245314363664 0.0010482627799095479 0.24958375420099799 0.0020888462632423655 0.14056172657325947 0.14343142582725249 0.062717403828934093 0.18829655321230485 0.043168850020232408 0.34784386062264772 0.0085650509718939172 0.33040492475872796 0.013598348180832415 0.474588074008372 -2.6389779250735046e-11 0.50207392010198326 0.013811170966005593 0.52963852800979416 0.0099348471610850586 0.67369764350180872 0.044385244105535099 0.65607625241692114 0.065207897330837761 0.81538038114764055 0.14339408358167172 0.85961453755379647 0.25352599736374476 1.0000000005717262 0.50193978872439671 0.99895956317704682
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 1 1 0 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 1 1 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 1 1 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 1 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0.77651590271071647 0.48977235386972218 1 0.23435497468696231
+6 0 1 0.33359764624430055 1 0 1
+6 0 9 0.77651590345800403 0.48977235331371821 0.77820477792640808 0.47045389041302049 0.7805865563492046 0.45112730573233178 0.78333364345499013 0.43177805316527057 0.78618380330786475 0.41242375977241785 0.78889451341737782 0.39311528377555205 0.79125500470995636 0.37389757999260947 0.79314272947286779 0.35475290560981415 0.79439047183486144 0.33553481687009312 0.7947961113581451 0.31582619032088188
+6 0 10 0.79479611140348772 0.31582619033608827 0.79502357017629854 0.30477475241640173 0.79224020562425856 0.29681489754350066 0.78917879319598816 0.28979203185180458 0.78455678451559729 0.28446096477327865 0.7800937037796426 0.27936547743819212 0.77435719838132921 0.27589737392572822 0.76835672869899052 0.27255740731131151 0.76129831126647896 0.27081836980382623 0.75305497575199831 0.26984780781127959 0.74287366423648027 0.27259115471702816
+6 0 10 0.7428736642358893 0.27259115471693013 0.67566651195078253 0.29070007251063607 0.61184974866580821 0.29900792949639499 0.54781584618581536 0.3004967993234357 0.48614799826893834 0.29413120555052341 0.42461579624582163 0.28233636694699582 0.36535049915373319 0.26423559363217231 0.30686210812209069 0.24144600088816376 0.24964522763678401 0.21356926516064295 0.19317836897747326 0.18083901074029973 0.13721933986993951 0.14276570602732019
+6 0 10 0.13721933986972129 0.14276570602556693 0.12627005753164738 0.13531605277939432 0.11668610017128893 0.13444223531424979 0.10853723642635518 0.13398366598254535 0.10139721459446142 0.13687973954082394 0.094542589625031911 0.13862204861247907 0.089142462356076577 0.14351742984287463 0.082909890556685795 0.14794680480417491 0.078500569210746274 0.1550522652799104 0.073609404175108958 0.16382223958389525 0.073045484370448027 0.1775208945607748
+6 0 7 0.073045484370347788 0.17752089456215173 0.067507451647201386 0.31204995154378012 0.094864800865019194 0.43980617181295834 0.1350006269338121 0.55175731822457308 0.18413412678826899 0.65661391885170883 0.2419416066571671 0.75375790768161532 0.30944547904078556 0.84656042242414453 0.3896720089012683 0.93189213310209795
+6 0 1 0.33007891681607082 1.0000000000000002 0.38967184765279078 0.93189193147630589
+6 0 1 1 1 0.91104485019850046 1
+6 0 10 0.03517623572153121 -2.3341829864296604e-16 0.011619762948683002 0.10687816063341411 5.8980598183211441e-17 0.21665575020056096 0.00068124460688883184 0.32767990868149949 0.013790436982085876 0.43824011143304942 0.039207497740235957 0.54661198960510071 0.076564492675210261 0.65110330807071459 0.12525416196843336 0.75009965196221295 0.18444748787535559 0.84210713293453843 0.25311912036138129 0.92578978951892998 0.33007891670575795 0.99999999989362831
+6 0 1 0 0.83588382382272197 0 0.50000000001962919
+6 0 13 0.035176235720115301 2.2737367544323206e-13 0.1071002574166121 0.04538977669268171 0.17639729815106092 0.085705929278388687 0.24444214524627011 0.12041532520955867 0.30830075926740269 0.15526046805631308 0.3829516350612604 0.17447387301123407 0.43629568294215737 0.21465385228997447 0.5290355490159786 0.21222294662058466 0.5789529821651882 0.24894724122940148 0.67786403919467642 0.23825553762547708 0.74148657528232298 0.23710784361606843 0.81016548234770736 0.20324493460469539 0.85371702452149667 0.18480495329645277 0.90664077977786273 0.14433125191110896
+6 0 1 0.90664077976706203 0.14433125190060414 0.93873866455303501 0.1752823574774417
+6 0 2 0.73434699673314152 0.11155969134018436 0.68665937583982672 0.11159258432032401 0.63897147629963169 0.11162551635029543
+6 0 1 0.90664077976706203 0.14433125190060414 1 0.23435497468696226
+6 0 1 0 0 0.12159084833269633 0
+6 0 1 0.083996442398284771 0 0.12159084833269633 0
+6 0 2 0.27490285856355007 0.11187749915319753 0.23416570761992825 0.11190575824685291 0.19342835141650747 0.11193404611900352
+6 0 8 0.12159084833269633 1.350002683427054e-12 0.12301320062365628 0.16872986562252298 0.13431334838647041 0.30940397027922473 0.15061898765406498 0.42106672679115187 0.17368631774524129 0.49839187950983982 0.1986861650171558 0.55568500480454552 0.22425514462566482 0.59806329398566438 0.25018741209248452 0.63124514038227963 0.27846295243678071 0.65839135553992023
+6 0 10 0.27846295233910101 0.6583913554459212 0.34837078345733197 0.72550706757996852 0.42311473929558474 0.74817331333661852 0.49804320628951448 0.76219480466196721 0.5723827186620809 0.7627988106414143 0.64509272226829961 0.76063224054281142 0.71610858823711132 0.75065405713595978 0.78601789722641069 0.7372795307636314 0.8555803981715675 0.71830706980154224 0.92621693042432152 0.69307658125026328 0.99999999999926248 0.66017565293687452
+6 0 1 1 1 1 0.66017565293855518
+6 0 1 0 0.50000000001962919 0 0.33008782647961898
+6 0 6 0.92856699320271674 0.77587213070626904 0.92722109572488476 0.81351271657983315 0.92422807037526489 0.85046591014149897 0.92066846333128138 0.88730038812848033 0.91701804647656693 0.92439339554936739 0.91371429726293929 0.96195115110621787 0.91104485019850001 0.99999999999977129
+6 0 10 0.92856699320080183 0.77587213070495842 0.92887139789651407 0.76735887372889611 0.92520431910614287 0.76149072776898408 0.92156747777572312 0.75658270950531825 0.91621971782769873 0.75309266557124965 0.91137971099823456 0.74947299810892209 0.9050031617344968 0.74749918011063743 0.89837952823649825 0.74495109439462248 0.89042158669729132 0.74426691193319261 0.88105932428743794 0.74377871097806769 0.86955749398159266 0.74729320361687812
+6 0 8 0.47102618178861944 0.80332139205245434 0.52314212554669903 0.80956847397095211 0.57432936809428536 0.80803017363176977 0.6247927348718274 0.80315953561977182 0.67457290849018103 0.7955378954885719 0.72375692442233852 0.78608939917315868 0.77246908104632572 0.77494820477108917 0.82098875617828559 0.76213383633030529 0.86955749328119769 0.74729320116399189
+6 0 6 0.43156156868699225 0.83375154326048795 0.43566040285873159 0.82218576685055911 0.44126982358132921 0.81417169747314688 0.44749680133913655 0.80809231023955597 0.45452670180796062 0.80432998137951406 0.46220308130043569 0.8022637765217614 0.47102618178767608 0.80332139205250996
+6 0 6 0.43156156868802631 0.83375154326335998 0.41971607240325037 0.86717625764672568 0.40562613330466746 0.89597456733001535 0.38939027812036753 0.9218673270706188 0.37154130678326774 0.94676500150299581 0.35265528690126696 0.97226938464163326 0.33359764624430061 0.99999999999983336
+6 0 1 0 1 0 0
+6 0 10 1.1148304501773509e-12 0.33008782647961904 0.11143634505425995 0.32274608806553551 0.2128970968805437 0.31544437155218646 0.30208792432307197 0.30786689079547247 0.38539812190754391 0.30055245915607742 0.46752569009359074 0.29363671783384965 0.54958569792557666 0.28696136463445504 0.63825453764061624 0.28064468272232579 0.73544843380966296 0.27436639716953148 0.85470650226051181 0.26892647609790038 0.99999999999860889 0.26377866739887817
+6 0 1 1 0.85851307686909573 1 0.26377866739887823
+6 0 1 1 0.85851307686909573 1 0.26414285910479485
+6 0 1 1 0.85850872198775185 1 0.26414285911298063
+6 0 9 0.99999999999865641 0.85851307686909573 0.85069258372857559 0.85707405772719503 0.72708419262087076 0.85543814209726599 0.62025498865822859 0.85355580520056418 0.52262756906020735 0.85129049966713854 0.42737973126411094 0.84888171683388591 0.33076665812977663 0.84599269205560723 0.22868623945190567 0.84274976989165973 0.11820051565243972 0.8394928691810829 1.0650647030985283e-12 0.83588382382272219
+6 0 14 0.73434699668087178 0.11155969185314002 0.72216022996813101 0.2311560390295902 0.72127375053285669 0.31784787167182676 0.69874082794988857 0.37453860697737107 0.67581652756122934 0.41832722682228435 0.65335599196139216 0.44969163464427403 0.62958874612175808 0.47188312123414766 0.60583277558395188 0.48813330034579888 0.58354596332249375 0.50017451016240333 0.56302938952280024 0.50891694944571575 0.54391490613567517 0.51504775025005067 0.52575145586820971 0.51915413514004249 0.50818282218627198 0.52166604458896837 0.49089809619932667 0.52281219919120581 0.47357199150686641 0.52261110687680634
+6 0 14 0.47357199150689017 0.52261110687681578 0.45624588681442224 0.52241001456241254 0.43887840341643436 0.52086167533136973 0.42114425491241925 0.51798459711373512 0.40270377739189894 0.5135870751752265 0.38314324428085589 0.50725819933180316 0.36190502914977635 0.49839380616635309 0.33842474756258956 0.48627888643547623 0.31272835425432804 0.47007550340875537 0.28612526304686225 0.44832179003493489 0.26020075747925497 0.41795669695760324 0.23322177394368093 0.37504506072541599 0.2042471361876636 0.31872783409436312 0.19952962184626333 0.23637569598997793 0.19342835144853376 0.11193404725810385
+6 0 14 0.27490285856548385 0.11187749924429292 0.27658904818516439 0.19131824596283525 0.29690754757519794 0.25476769108458092 0.32373391141767227 0.30343441354675255 0.35744317691399391 0.34013116900224011 0.38985936716929187 0.36349720378404005 0.42902639556503602 0.38112166590011032 0.46472087137973128 0.38162789451852025 0.49956373721176117 0.38125509585636996 0.53839297689066012 0.36353891533294536 0.56916530614710414 0.34035894981925613 0.60101782874130016 0.30366647243346789 0.62506086212041723 0.25507107526206702 0.64196779011787009 0.19161467569608917 0.63897147630849793 0.11162551658356251
+6 0 6 0.99999999999909439 0.26414285911298069 0.84900789569624302 0.25822755173639095 0.6905818024624899 0.25410842625097707 0.52587611389518185 0.25140091338720089 0.35532034929975742 0.24999486486673625 0.17877737686739453 0.24999999999999986 1.0725864640903637e-12 0.24999999999999989
+6 0 1 0 0.86190910562161849 0 0.24999999999999989
+6 0 8 1.0358802642160443e-12 0.86190910562161849 0.12940506836722518 0.86190910562161849 0.25764786149767938 0.86190926883159635 0.38457934422182877 0.86181315861924479 0.51032413736235216 0.86156279847195205 0.63472234529527227 0.86115432462941821 0.75785569946266373 0.86054167010134586 0.87964867519565093 0.85969797332258735 0.99999999999903744 0.85850872198775174
+6 0 1 0 1 0 0
+6 0 1 0 1 0.33359764624430055 1
+6 0 1 1 0.23435497468696231 0.77651590271071647 0.48977235386972218
+6 0 1 0 0.15700865344247639 0 1
+6 0 1 1 0.15700865344247639 1 1
+6 0 1 1 1 0 1
+6 0 1 1 1 1 0.16082982007914459
+6 0 1 0 1 0 0.16082982007914393
+6 0 8 0.62195267696746392 0.14650094983098949 0.66242494954704012 0.15239258022662414 0.70144806442487262 0.15721481956753636 0.74016122926792083 0.16119650306560385 0.78027470697518486 0.16409690837721791 0.82170374349121444 0.16650342407848018 0.86982810244667219 0.16719274325837735 0.92393996406191126 0.16683055576435901 1.0000000000000022 0.16082982007914487
+6 0 1 0 0 1 0
+6 0 2 0.62195267677951105 0.14650094986962769 0.61473105358389479 0.073250570667889411 0.60763544520398205 1.3877787807814457e-17
+6 0 1 0 0 1 0
+6 0 1 0.3615388820026661 0 0.60763544520398205 0
+6 0 2 0.37449592832841216 0.14991626423758603 0.36807362253145925 0.074958056630587772 0.3615388820026661 1.3877787807814457e-17
+6 0 1 0 0 1 0
+6 0 6 0.37449592819482957 0.14991626421014798 0.31335702621486999 0.15667009944649757 0.25570625709661293 0.16119976688518781 0.19819142400116749 0.16392207496750361 0.13832097534501148 0.16443203161825715 0.075339996548365415 0.16281459464881157 -1.8041124150158794e-16 0.1570086534424763
+6 0 1 0 0 1 0
+6 0 1 1 1 0 1
+6 0 8 0.62208014733282213 0.10403971973885177 0.66614416875745019 0.11150974090174023 0.70868505180260999 0.11881090321199099 0.75011012216946871 0.12587785630392967 0.79355900585311645 0.1327515844130254 0.83630615985472312 0.13952877316266005 0.88450549114848986 0.14577806216439237 0.93427294736120658 0.15194351645323378 1 0.15700865344247639
+6 0 1 0 1 1 1
+6 0 2 0.62208014977202897 0.10403972023999933 0.6265602917298162 0.052019822845279347 0.63109580666709297 6.9388939039072284e-18
+6 0 1 0 1 1 1
+6 0 1 0.63109580666709297 0 0.38442907385303182 0
+6 0 2 0.3746234011301805 0.10061678950698398 0.37955517796006477 0.050308438596756641 0.38442907385303171 2.0816681711721685e-17
+6 0 1 0 1 1 1
+6 0 11 0.37462340109225417 0.10061678951478098 0.34457896428486479 0.10676307554241921 0.31503681445199572 0.1128101052242978 0.28559173219254202 0.11874679901429752 0.25612262928056101 0.124624373830128 0.22567177576755337 0.13030828856605195 0.19535780978053105 0.13602817670691875 0.16229829280672697 0.141421129587257 0.12918040821991078 0.14685108299091518 0.091480225885669023 0.151889724196211 0.051445265072527051 0.15677105999379098 -5.620504062164855e-16 0.16082982007914395
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 1 0.16082982007914459 1 1
+6 0 1 0 0.16082982007914393 0 1
+6 0 1 1 1 0 1
+6 0 1 0 1 0 0.15700865344247639
+6 0 1 1 1 1 0.15700865344247639
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 1 1 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 0 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0.82235357075427984 0
+6 0 1 1 1 0 1
+6 0 1 0.82235357075427984 0 1 0
+6 0 1 1 1 0 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0.88675185078395002 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 0 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0.42943022607340992 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0.88675185078395002 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 0 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 1 1 0 1
+6 0 1 1 1 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0.42943022607340992 0 0.79398549216321301 0
+6 0 1 0 0 1 0
+6 0 1 0.79398549216321301 0 1 0
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0.41342386845584767 0
+6 0 1 1 1 0 1
+6 0 1 0.41342386845584767 0 1 0
+6 0 1 1 1 0 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 1 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0.36660438051115907 0
+6 0 1 0 0 1 0
+6 0 1 0.36660438051115907 0 1 0
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0.76955134566755168 0
+6 0 1 1 1 0 1
+6 0 1 0.76955134566755168 0 1 0
+6 0 1 1 1 0 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 1 1 0 1
+6 0 1 1 1 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 1 0 1
+6 0 1 1 1 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 0 0
+6 0 6 0.38755111791794894 0.77990387497446312 0.44393667968867251 0.80183171045220392 0.50192468451124783 0.81891693626219919 0.56077229324135902 0.83295238887591316 0.62029367047260453 0.84475603236763064 0.68035525133101071 0.85487956203583015 0.74078155618261099 0.86367399505185738
+6 0 1 0 1 1 1
+6 0 10 0.74078155618320274 0.86367399505214781 0.77057206708517834 0.86800970039240188 0.7941169927074373 0.86617789603680129 0.81430999607881216 0.86421019441443925 0.83091347472657562 0.85939139645523677 0.84653265785509069 0.85558594899193308 0.85873812985916909 0.84932518985735261 0.87131179598911124 0.84333690466254652 0.88039520006887739 0.83531988172071525 0.8888873067248183 0.8258977625737246 0.88888744920436591 0.81267336835174731
+6 0 1 0 1 1 1
+6 0 4 0.88888744927407881 0.81267336835086845 0.88888948752109498 0.62349113561359437 0.88888929501979619 0.48572793415674492 0.88888960389577765 0.34788261124261771 0.88888906343449292 0.15798930133581751
+6 0 1 0 1 1 1
+6 0 10 0.88888906342982177 0.15798930133493705 0.8888890274779867 0.14535749671608805 0.88113481416026063 0.13613907561239125 0.87245278698812478 0.12828928078778967 0.86058945842441659 0.12220242713360213 0.84875682481956849 0.11611316526929701 0.83377169970278109 0.11200329259950052 0.81778476678624268 0.10732680181009971 0.79835742466399606 0.10496593532103406 0.77588343605138921 0.10296985533599198 0.74739042049802429 0.10614133722074277
+6 0 1 0 1 1 1
+6 0 6 0.74739042054189997 0.10614133741468469 0.68828513613797859 0.11272018965224159 0.62938021739479189 0.12026488931101899 0.57078132360043654 0.1290238035735316 0.51256402782892696 0.13940219712792876 0.45480382249834772 0.15195687166251681 0.39793353864030828 0.16803564332620052
+6 0 1 0 1 1 1
+6 0 8 0.39793353865190917 0.16803564337698673 0.38254673923150567 0.17238590889018046 0.36962422975979187 0.17856861838475291 0.3586012338140685 0.18613930768258213 0.34950056760918802 0.19499461767570894 0.34207014076054582 0.20504349065606831 0.33670256082306455 0.21631459344453483 0.33333352904069802 0.22883939772761017 0.33333354732532428 0.24304366465115101
+6 0 1 0 1 1 1
+6 0 4 0.33333354734844722 0.24304366465176608 0.33333370906960691 0.3686753037277829 0.33333340635263131 0.47577763722409466 0.33333358053180573 0.58285360922294804 0.33333311045857894 0.70836503242273263
+6 0 1 0 1 1 1
+6 0 8 0.33333311045847913 0.70836503242333515 0.33333306305895949 0.72102089784511447 0.33600893132980275 0.73242849351751704 0.34044298688907559 0.74283205507814121 0.34659429749414261 0.75231378820867345 0.354248147105306 0.76083458642044177 0.36353066523638289 0.76837276381093056 0.37449308775928503 0.77482572349786039 0.38755111834291434 0.77990387363292646
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 0 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 0 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 0 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 0 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 0 0
+6 0 1 1 1 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 0 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 0 0
+6 0 1 1 1 0 1
+6 0 1 1 0 0 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 0 0
+6 0 1 1 1 0 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 0 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 0 0
+6 0 1 1 1 0 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 0 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 0 0
+6 0 1 1 1 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 0 0
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 0 0
+6 0 1 1 1 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 0 0
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 0 0
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 14 1.9554136088117957e-11 0.66666666682060993 0.071105645738108625 0.66666666681994402 0.13556858594734714 0.6657962911806814 0.19419430387866304 0.66428056918618872 0.24764085629607963 0.66227918748587278 0.29645916188210719 0.65990660175421156 0.34112000146830368 0.65724609800508937 0.38203222925726082 0.65435952072249737 0.41955522284358776 0.65129393094374066 0.45400758598776336 0.6480861144800536 0.48567342660998536 0.64476560367177949 0.51480706626718886 0.64135668556233572 0.54163672715730826 0.63787972940374493 0.56636753935526829 0.63435206464069438 0.58918408000958689 0.63078856737189359
+6 0 1 0 0 1 0
+6 0 14 0.58918408000958677 0.63078856737189348 0.61200062066390548 0.6272250701030927 0.63290288977458276 0.62362574032854168 0.65207546449013687 0.62000545414694985 0.66968236903267919 0.61637663431104894 0.68586961389451762 0.61274983668895 0.70076726699537195 0.60913404520279879 0.71449126852908373 0.60553683324349694 0.72714507025310193 0.60196447641206408 0.73882112136240508 0.59842205690763894 0.74960220232636321 0.594913574381157 0.75956260522662866 0.59144206476223027 0.76876916327780809 0.58800972270277785 0.77728213777684896 0.58461802167947174 0.78515597523863867 0.58126782639684405
+6 0 1 0 0 1 0
+6 0 14 0.78515597523863856 0.58126782639684416 0.80090365016221787 0.57456743583158887 0.81409477693679233 0.56803306822904731 0.82516492768146066 0.56167164122547653 0.83445663800236003 0.55548033210289716 0.8422436353318381 0.54945017468853652 0.84874675918523301 0.54356916349665629 0.8541432062950336 0.53782417926927562 0.85857188854284539 0.53220120361700263 0.8621383076309449 0.52668457105527577 0.86491989502793032 0.52125630367913689 0.86697103558334332 0.51589607788771941 0.86832675611404975 0.51058180249983209 0.86900456965063366 0.50529050256648811 0.86900447538369907 0.49999920318556412
+6 0 1 0 0 1 0
+6 0 14 0.86900447538369952 0.49999920318555802 0.86900438111676759 0.49470790380462065 0.86832637904631516 0.48941660497610379 0.86697046836294644 0.48410233179788437 0.86491913441728596 0.47874210941470319 0.86213734866628011 0.47331384683282429 0.8585707243194074 0.46779722073682478 0.8541418277246916 0.4621742536136994 0.8487451548860564 0.4564292804887975 0.84224179182137482 0.45054828361230392 0.83445454024318799 0.44451814450461391 0.82516255981871833 0.43832685860305326 0.81409212305684719 0.43196546080660703 0.80090069540914954 0.42543112961340179 0.78515270817556948 0.41873078396602753
+6 0 1 0 0 1 0
+6 0 14 0.78515270817556959 0.41873078396602764 0.77727871455875586 0.41538061114233044 0.76876558104546766 0.41198893470509068 0.75955886154819763 0.40855661952213218 0.74959829534496114 0.40508513923905759 0.73881704998259923 0.40157668868066493 0.72714083438015298 0.39803430395092365 0.71448686937911277 0.39446198487303524 0.70076270749907466 0.3908648138111811 0.68586489922075911 0.38724906651685659 0.66967750725954189 0.38362231650640893 0.65207046744688513 0.37999354778755617 0.63289777406391445 0.37637331625316345 0.61199540884266856 0.37277404459052027 0.58917880184723892 0.36921060870177785
+6 0 1 0 0 1 0
+6 0 14 0.58917880184723892 0.36921060870177785 0.5663621948520956 0.36564717281308012 0.5416313460828166 0.36211957269828227 0.51480168560350037 0.35864268425953494 0.48566809181029935 0.35523383661385055 0.45400235231255981 0.35191339851354064 0.41955015669385254 0.3487056562778138 0.38202740936511187 0.34564014123119302 0.34111551971879434 0.34275363779182805 0.29645512341507319 0.34009320511764018 0.24763737835959948 0.33772068518852788 0.19419151265747595 0.33571936071440317 0.13556661024619354 0.33420368304491643 0.071104605930044112 0.33333333320600572 -9.9675110665220501e-09 0.33333333321102609
+6 0 1 0 0 1 0
+6 0 1 0 0.33333333320927439 0 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 0 0.66666666682060993
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 2.7427854297980123e-13 0.66666666672100439 0.053192950245445229 0.66666666672077945 0.10352088693159392 0.66630527671959261 0.15110439401284265 0.66563893595305601 0.19606672219551 0.6647057290051841 0.23853279741206829 0.66353228236042738 0.27862781421905763 0.66213832553786278 0.31647577498847185 0.6605396219426164 0.35219816989466246 0.65874978194261791 0.38591288775119403 0.6567813260232126 0.41773338401328819 0.65464625832152235 0.44776809586454774 0.65235633173317664 0.47612007560858233 0.64992312827432397 0.50288680597278734 0.64735803711824846 0.52816015994100229 0.64467218355768441
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 0.52816015994100218 0.64467218355768419 0.55343351389827122 0.64198632999828331 0.57721349146084389 0.63917971403449847 0.59959196561244021 0.6362634609590494 0.62065519959323434 0.63324843218410642 0.64048380673251248 0.63014515420360484 0.65915285481020991 0.62696369848125821 0.67673207756405274 0.62371356551536195 0.69328615496850177 0.62040359716325078 0.70887502954401271 0.61704192423539406 0.7235542337484181 0.61363594724082282 0.73737521114695814 0.61019234403376965 0.75038562051989111 0.60671709694492171 0.76262961703095167 0.60321553242734249 0.77414810810307055 0.59969236744327092
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 0.77414810810307066 0.59969236744327092 0.79718509025091622 0.59264603747402422 0.81732005064208613 0.5855133056387809 0.8348802486601804 0.57833190763546982 0.85014097983590509 0.57112982730882023 0.86333376387011662 0.56392678102793714 0.87465291392161837 0.55673613348005291 0.88426018590071365 0.54956650583530575 0.89228810843487549 0.54242264345325919 0.8988427582081997 0.53530580026339603 0.90400622976167333 0.52821408630349276 0.90783867495393911 0.52114302988448158 0.91037972501444153 0.51408636355120108 0.91164920165861019 0.50703692189495031 0.91164711727595227 0.49998753930409695
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 0.91164711727595127 0.49998753930409612 0.91164503289329313 0.49293815671324287 0.91037138748380853 0.48588883318778681 0.90782619343700466 0.47883240311609576 0.90398965381646634 0.47176170068360612 0.89882216254794878 0.46467045762343134 0.89226359368037966 0.45755420090502458 0.88423187973064388 0.45041103844714819 0.87462097266424199 0.44324222097174015 0.86329837460858494 0.43605248928943569 0.85010236314169707 0.42885045858360921 0.83483866215623581 0.42164948608445696 0.81727579380681059 0.41446927893488911 0.79713851123510937 0.40733780933086344 0.77409961348330691 0.40029279816750268
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 0.77409961348330725 0.40029279816750285 0.76258016460920242 0.39677029258637181 0.75033531194029857 0.39326940161540025 0.73732415535688656 0.38979484036647633 0.72350254760803989 0.38635193324518557 0.70882283852765859 0.38294666031475216 0.69323359397220552 0.37958569691788269 0.67667929183490361 0.37627644078488315 0.65910000101349198 0.3730270196616865 0.64043105417145274 0.36984627204643994 0.62060273159241941 0.36674369479133095 0.59953998106795925 0.36372935545880147 0.57716220654558115 0.36081377644782531 0.55338316388602593 0.35800781497182815 0.52811100107333586 0.35532259212108958
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 0.52811100107333564 0.35532259212108958 0.50283883824972897 0.35263736926919109 0.47607355527169753 0.35007288504265549 0.44772330012316464 0.34764026053177677 0.4176906129113454 0.34535088070370323 0.38587246607681686 0.3432163234648391 0.35216044905636773 0.34124833780772806 0.31644113474212593 0.33945892427525715 0.27859666407490047 0.33786060012627778 0.2385055774763469 0.33646697282335214 0.19604390310015157 0.33529380293126587 0.15108647545091516 0.33436081656082273 0.10350839413550286 0.3336946349484417 0.053186427505452688 0.33333333327833248 5.957602466910572e-12 0.3333333332782949
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 14 1.9554136088117957e-11 0.66666666682060993 0.071105645738108597 0.66666666681994402 0.13556858594734708 0.6657962911806814 0.19419430387866296 0.66428056918618872 0.24764085629607951 0.66227918748587278 0.29645916188210708 0.65990660175421156 0.34112000146830357 0.65724609800508937 0.38203222925726071 0.65435952072249748 0.41955522284358759 0.65129393094374077 0.4540075859877632 0.64808611448005371 0.48567342660998519 0.6447656036717796 0.51480706626718864 0.64135668556233583 0.54163672715730804 0.63787972940374504 0.56636753935526807 0.63435206464069449 0.58918408000958666 0.6307885673718937
+6 0 1 0 0 1 0
+6 0 14 0.58918408000958677 0.63078856737189359 0.61200062066390537 0.62722507010309281 0.63290288977458264 0.62362574032854179 0.65207546449013665 0.62000545414694996 0.66968236903267886 0.61637663431104905 0.68586961389451728 0.61274983668895011 0.70076726699537162 0.6091340452027989 0.7144912685290834 0.60553683324349705 0.7271450702531016 0.60196447641206419 0.73882112136240474 0.59842205690763906 0.74960220232636288 0.59491357438115722 0.75956260522662833 0.59144206476223049 0.76876916327780775 0.58800972270277818 0.77728213777684863 0.58461802167947219 0.78515597523863823 0.5812678263968446
+6 0 1 0 0 1 0
+6 0 14 0.78515597523863789 0.58126782639684427 0.80090365016221698 0.57456743583158898 0.814094776936791 0.56803306822904731 0.82516492768145877 0.5616716412254763 0.83445663800235759 0.55548033210289671 0.84224363533183499 0.54945017468853585 0.84874675918522924 0.54356916349665529 0.85414320629502916 0.53782417926927428 0.85857188854284028 0.53220120361700096 0.86213830763093913 0.52668457105527378 0.8649198950279241 0.52125630367913445 0.86697103558333688 0.51589607788771663 0.86832675611404353 0.51058180249982899 0.86900456965062833 0.50529050256648467 0.86900447538369585 0.49999920318556051
+6 0 1 0 0 1 0
+6 0 14 0.86900447538369952 0.49999920318555802 0.86900438111676759 0.49470790380462065 0.86832637904631516 0.48941660497610379 0.86697046836294644 0.48410233179788437 0.86491913441728596 0.47874210941470319 0.86213734866628011 0.47331384683282429 0.8585707243194074 0.46779722073682478 0.8541418277246916 0.4621742536136994 0.8487451548860564 0.4564292804887975 0.84224179182137482 0.45054828361230392 0.83445454024318799 0.44451814450461391 0.82516255981871833 0.43832685860305326 0.81409212305684731 0.43196546080660703 0.80090069540914965 0.42543112961340185 0.78515270817556959 0.41873078396602759
+6 0 1 0 0 1 0
+6 0 14 0.7851527081755697 0.41873078396602764 0.77727871455875597 0.41538061114233044 0.76876558104546777 0.41198893470509068 0.75955886154819774 0.40855661952213218 0.74959829534496125 0.40508513923905759 0.73881704998259934 0.40157668868066493 0.72714083438015309 0.39803430395092365 0.71448686937911288 0.39446198487303524 0.70076270749907488 0.3908648138111811 0.68586489922075933 0.38724906651685659 0.66967750725954212 0.38362231650640893 0.65207046744688535 0.37999354778755617 0.63289777406391468 0.37637331625316345 0.61199540884266879 0.37277404459052027 0.58917880184723914 0.36921060870177785
+6 0 1 0 0 1 0
+6 0 14 0.58917880184723925 0.36921060870177785 0.56636219485209593 0.36564717281308012 0.54163134608281693 0.36211957269828227 0.5148016856035007 0.35864268425953494 0.48566809181029968 0.35523383661385055 0.45400235231256014 0.35191339851354064 0.41955015669385287 0.3487056562778138 0.3820274093651122 0.34564014123119302 0.34111551971879461 0.34275363779182805 0.29645512341507346 0.34009320511764018 0.24763737835959973 0.33772068518852788 0.19419151265747617 0.33571936071440317 0.13556661024619374 0.33420368304491643 0.071104605930044265 0.33333333320600572 -9.9675109554997476e-09 0.33333333321102609
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 1 0 1
+6 0 1 1 0 0 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 14 1.9554136088117957e-11 0.66666666682060993 0.071105645738108639 0.66666666681994402 0.13556858594734716 0.6657962911806814 0.1941943038786631 0.66428056918618872 0.24764085629607968 0.66227918748587278 0.2964591618821073 0.65990660175421156 0.34112000146830379 0.65724609800508937 0.38203222925726094 0.65435952072249737 0.41955522284358787 0.65129393094374066 0.45400758598776347 0.6480861144800536 0.48567342660998547 0.64476560367177949 0.51480706626718897 0.64135668556233572 0.54163672715730837 0.63787972940374482 0.5663675393552684 0.63435206464069427 0.58918408000958711 0.63078856737189348
+6 0 1 0 0 1 0
+6 0 14 0.589184080009587 0.63078856737189348 0.61200062066390559 0.6272250701030927 0.63290288977458287 0.62362574032854168 0.65207546449013687 0.62000545414694985 0.66968236903267908 0.61637663431104894 0.6858696138945175 0.61274983668895 0.70076726699537184 0.60913404520279879 0.71449126852908362 0.60553683324349694 0.72714507025310171 0.60196447641206408 0.73882112136240485 0.59842205690763894 0.74960220232636299 0.594913574381157 0.75956260522662844 0.59144206476223027 0.76876916327780787 0.58800972270277785 0.77728213777684874 0.58461802167947174 0.78515597523863834 0.58126782639684405
+6 0 1 0 0 1 0
+6 0 14 0.78515597523863867 0.58126782639684405 0.80090365016221798 0.57456743583158865 0.81409477693679222 0.56803306822904698 0.82516492768146033 0.56167164122547608 0.83445663800235947 0.5554803321028966 0.84224363533183733 0.54945017468853585 0.84874675918523212 0.54356916349665552 0.85414320629503271 0.53782417926927473 0.8585718885428445 0.53220120361700163 0.86213830763094412 0.52668457105527478 0.86491989502792987 0.52125630367913589 0.86697103558334354 0.51589607788771863 0.86832675611405108 0.51058180249983165 0.86900456965063699 0.50529050256648822 0.86900447538370595 0.49999920318556512
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 14 0.7851527081755697 0.41873078396602764 0.77727871455875597 0.41538061114233044 0.76876558104546777 0.41198893470509068 0.75955886154819774 0.40855661952213218 0.74959829534496125 0.40508513923905759 0.73881704998259934 0.40157668868066493 0.72714083438015309 0.39803430395092365 0.71448686937911288 0.39446198487303524 0.70076270749907477 0.3908648138111811 0.68586489922075922 0.38724906651685659 0.669677507259542 0.38362231650640893 0.65207046744688524 0.37999354778755617 0.63289777406391456 0.37637331625316345 0.61199540884266856 0.37277404459052027 0.58917880184723892 0.36921060870177785
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0.66666666672081099 0 1
+6 0 1 1 1 0 1
+6 0 1 1 0 0 0
+6 0 1 1 1 1 0
+6 0 1 1 1 1 0
+6 0 1 1 0 0 0
+6 0 1 1 1 0 1
+6 0 1 0 0 0 0.3333333332782949
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 2.7450790870175648e-13 0.66666666672100428 0.0531929502454455 0.66666666672077934 0.10352088693159422 0.6663052767195925 0.15110439401284298 0.6656389359530559 0.19606672219551036 0.66470572900518399 0.23853279741206868 0.66353228236042727 0.27862781421905802 0.66213832553786267 0.31647577498847224 0.66053962194261617 0.35219816989466285 0.65874978194261768 0.38591288775119448 0.65678132602321238 0.41773338401328863 0.65464625832152212 0.44776809586454824 0.65235633173317642 0.47612007560858283 0.64992312827432375 0.50288680597278779 0.64735803711824824 0.52816015994100274 0.64467218355768419
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 0.52816015994100252 0.64467218355768419 0.55343351389827156 0.64198632999828331 0.57721349146084422 0.63917971403449847 0.59959196561244066 0.6362634609590494 0.62065519959323479 0.63324843218410631 0.64048380673251293 0.63014515420360473 0.65915285481021035 0.6269636984812581 0.67673207756405318 0.62371356551536183 0.69328615496850221 0.62040359716325066 0.70887502954401316 0.61704192423539395 0.72355423374841854 0.61363594724082271 0.73737521114695859 0.61019234403376954 0.75038562051989155 0.6067170969449216 0.76262961703095211 0.60321553242734238 0.774148108103071 0.59969236744327081
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 0.77414810810307111 0.59969236744327081 0.79718509025091666 0.59264603747402411 0.81732005064208657 0.58551330563878079 0.83488024866018073 0.57833190763546971 0.85014097983590542 0.57112982730882011 0.86333376387011684 0.56392678102793703 0.87465291392161848 0.55673613348005291 0.88426018590071376 0.54956650583530575 0.8922881084348756 0.54242264345325919 0.89884275820819981 0.53530580026339603 0.90400622976167344 0.52821408630349287 0.90783867495393922 0.52114302988448169 0.91037972501444164 0.51408636355120119 0.9116492016586103 0.50703692189495042 0.91164711727595238 0.49998753930409706
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 0.91164711727595427 0.49998753930409523 0.91164503289329524 0.4929381567132422 0.91037138748380997 0.48588883318778631 0.90782619343700566 0.47883240311609537 0.90398965381646701 0.47176170068360584 0.89882216254794922 0.46467045762343112 0.89226359368038 0.45755420090502447 0.8842318797306441 0.45041103844714814 0.87462097266424221 0.44324222097174015 0.86329837460858505 0.43605248928943574 0.85010236314169718 0.42885045858360926 0.83483866215623592 0.42164948608445701 0.8172757938068107 0.41446927893488916 0.79713851123510948 0.40733780933086344 0.77409961348330703 0.40029279816750268
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 0.77409961348330725 0.40029279816750279 0.76258016460920242 0.39677029258637175 0.75033531194029857 0.39326940161540019 0.73732415535688656 0.38979484036647627 0.72350254760803989 0.38635193324518552 0.70882283852765859 0.38294666031475211 0.69323359397220552 0.37958569691788263 0.67667929183490361 0.37627644078488309 0.65910000101349198 0.37302701966168644 0.64043105417145274 0.36984627204643988 0.6206027315924193 0.3667436947913309 0.59953998106795903 0.36372935545880142 0.57716220654558092 0.36081377644782525 0.55338316388602571 0.3580078149718281 0.52811100107333564 0.35532259212108952
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 1 0 1
+6 0 1 1 0 0 0
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 2.7426837562545403e-13 0.66666666672100461 0.053192950245445431 0.66666666672077968 0.10352088693159431 0.66630527671959283 0.1511043940128432 0.66563893595305623 0.19606672219551069 0.66470572900518432 0.23853279741206912 0.66353228236042761 0.27862781421905858 0.662138325537863 0.3164757749884729 0.66053962194261651 0.35219816989466357 0.65874978194261802 0.38591288775119525 0.65678132602321271 0.41773338401328947 0.65464625832152246 0.44776809586454908 0.65235633173317664 0.47612007560858366 0.64992312827432397 0.50288680597278868 0.64735803711824846 0.52816015994100374 0.64467218355768441
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 0.5281601599410034 0.64467218355768396 0.55343351389827233 0.64198632999828309 0.57721349146084477 0.63917971403449825 0.59959196561244099 0.63626346095904918 0.62065519959323501 0.6332484321841062 0.64048380673251293 0.63014515420360462 0.65915285481021024 0.62696369848125799 0.67673207756405296 0.62371356551536172 0.69328615496850199 0.62040359716325055 0.70887502954401294 0.61704192423539383 0.72355423374841821 0.6136359472408226 0.73737521114695814 0.61019234403376943 0.75038562051989111 0.60671709694492149 0.76262961703095156 0.60321553242734227 0.77414810810307044 0.5996923674432707
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 0.77414810810307066 0.59969236744327092 0.79718509025091622 0.59264603747402422 0.81732005064208613 0.5855133056387809 0.8348802486601804 0.57833190763546982 0.85014097983590509 0.57112982730882023 0.86333376387011662 0.56392678102793714 0.87465291392161826 0.55673613348005291 0.88426018590071354 0.54956650583530575 0.89228810843487538 0.54242264345325919 0.89884275820819959 0.53530580026339603 0.90400622976167322 0.52821408630349276 0.907838674953939 0.52114302988448158 0.91037972501444142 0.51408636355120108 0.91164920165861008 0.50703692189495031 0.91164711727595216 0.49998753930409695
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 0.91164711727595249 0.49998753930409645 0.91164503289329402 0.49293815671324287 0.91037138748380908 0.48588883318778664 0.90782619343700499 0.47883240311609548 0.90398965381646657 0.47176170068360584 0.898822162547949 0.46467045762343107 0.89226359368037989 0.45755420090502436 0.88423187973064399 0.45041103844714803 0.8746209726642421 0.44324222097174004 0.86329837460858494 0.43605248928943563 0.85010236314169707 0.42885045858360921 0.83483866215623581 0.42164948608445701 0.81727579380681059 0.41446927893488916 0.79713851123510937 0.4073378093308635 0.7740996134833068 0.40029279816750274
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 0.77409961348330691 0.40029279816750268 0.76258016460920208 0.39677029258637164 0.75033531194029823 0.39326940161540008 0.73732415535688622 0.38979484036647616 0.72350254760803956 0.38635193324518541 0.70882283852765826 0.382946660314752 0.69323359397220519 0.37958569691788258 0.67667929183490327 0.37627644078488309 0.65910000101349164 0.3730270196616865 0.64043105417145241 0.36984627204643999 0.62060273159241908 0.36674369479133101 0.59953998106795892 0.36372935545880153 0.57716220654558092 0.36081377644782536 0.55338316388602571 0.35800781497182821 0.52811100107333575 0.35532259212108963
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 0.52811100107333564 0.35532259212108958 0.50283883824972897 0.35263736926919109 0.47607355527169753 0.35007288504265549 0.44772330012316464 0.34764026053177677 0.4176906129113454 0.34535088070370323 0.38587246607681686 0.3432163234648391 0.35216044905636773 0.34124833780772806 0.31644113474212593 0.33945892427525715 0.27859666407490047 0.33786060012627778 0.2385055774763469 0.33646697282335214 0.19604390310015157 0.33529380293126587 0.15108647545091516 0.33436081656082273 0.10350839413550283 0.3336946349484417 0.053186427505452646 0.33333333327833248 5.9575469557593408e-12 0.3333333332782949
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 0 0
+6 0 1 1 1 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 1 1 0
+6 0 1 1 1 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 1 1 1 0
+6 0 1 1 1 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 14 1.9554136088117957e-11 0.66666666682060993 0.071105645738108653 0.66666666681994402 0.13556858594734719 0.6657962911806814 0.19419430387866313 0.66428056918618872 0.24764085629607971 0.66227918748587278 0.2964591618821073 0.65990660175421156 0.34112000146830379 0.65724609800508937 0.38203222925726094 0.65435952072249737 0.41955522284358787 0.65129393094374066 0.45400758598776347 0.6480861144800536 0.48567342660998547 0.64476560367177949 0.51480706626718897 0.64135668556233572 0.54163672715730837 0.63787972940374482 0.5663675393552684 0.63435206464069427 0.589184080009587 0.63078856737189348
+6 0 1 0 0 1 0
+6 0 14 0.58918408000958722 0.63078856737189348 0.61200062066390581 0.6272250701030927 0.63290288977458309 0.62362574032854168 0.65207546449013709 0.62000545414694985 0.6696823690326793 0.61637663431104894 0.68586961389451773 0.61274983668895 0.70076726699537206 0.60913404520279879 0.71449126852908384 0.60553683324349694 0.72714507025310204 0.60196447641206408 0.73882112136240519 0.59842205690763894 0.74960220232636332 0.59491357438115711 0.75956260522662877 0.59144206476223038 0.7687691632778082 0.58800972270277807 0.77728213777684907 0.58461802167947197 0.78515597523863867 0.58126782639684427
+6 0 1 0 0 1 0
+6 0 14 0.78515597523863856 0.58126782639684405 0.80090365016221776 0.57456743583158865 0.81409477693679211 0.56803306822904698 0.82516492768146021 0.56167164122547597 0.83445663800235947 0.55548033210289638 0.84224363533183744 0.54945017468853552 0.84874675918523224 0.54356916349665507 0.85414320629503282 0.53782417926927406 0.85857188854284461 0.53220120361700074 0.86213830763094412 0.52668457105527355 0.86491989502792976 0.52125630367913423 0.8669710355833431 0.51589607788771641 0.86832675611405019 0.51058180249982887 0.86900456965063511 0.50529050256648467 0.86900447538370229 0.49999920318556079
+6 0 1 0 0 1 0
+6 0 14 0.86900447538369952 0.49999920318555802 0.86900438111676759 0.49470790380462037 0.86832637904631504 0.48941660497610323 0.86697046836294622 0.48410233179788353 0.86491913441728552 0.47874210941470202 0.86213734866627934 0.47331384683282279 0.85857072431940618 0.46779722073682295 0.85414182772468983 0.46217425361369724 0.84874515488605395 0.45642928048879494 0.84224179182137149 0.45054828361230098 0.83445454024318355 0.44451814450461052 0.82516255981871245 0.43832685860304943 0.81409212305683953 0.4319654608066027 0.80090069540913966 0.42543112961339696 0.78515270817555671 0.41873078396602215
+6 0 1 0 0 1 0
+6 0 14 0.78515270817555671 0.41873078396602215 0.77727871455877429 0.4153806111423386 0.76876558104552262 0.41198893470511289 0.75955886154829477 0.40855661952216871 0.74959829534510714 0.40508513923910877 0.73881704998280151 0.40157668868073104 0.72714083438041999 0.39803430395100492 0.71448686937945405 0.39446198487313183 0.7007627074995012 0.39086481381129312 0.68586489922128335 0.38724906651698404 0.66967750726017794 0.38362231650655165 0.65207046744764929 0.37999354778771383 0.63289777406482528 0.37637331625333559 0.61199540884374737 0.37277404459070612 0.58917880184851024 0.36921060870197642
+6 0 1 0 0 1 0
+6 0 14 0.58917880184851035 0.36921060870197636 0.56636219485337524 0.36564717281326259 0.54163134608409802 0.36211957269844824 0.5148016856047759 0.3586426842596841 0.48566809181155968 0.35523383661398261 0.45400235231379393 0.35191339851365544 0.4195501566950473 0.34870565627791128 0.38202740936625174 0.34564014123127335 0.34111551971986087 0.3427536377918915 0.29645512341604469 0.34009320511768731 0.24763737836045036 0.33772068518855969 0.19419151265817594 0.33571936071442121 0.13556661024670669 0.33420368304492332 0.071104605930327136 0.33333333320600567 -9.9675110387664745e-09 0.33333333321102604
+6 0 1 0 0 1 0
+6 0 1 1 0 0 0
+6 0 1 1 1 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 2.7418087483182389e-13 0.66666666672100428 0.053192950236764069 0.66666666672077934 0.10352088691516684 0.66630527671971052 0.15110439398954573 0.66563893595338219 0.19606672216615856 0.66470572900579328 0.23853279737741595 0.66353228236138495 0.2786278141797966 0.66213832553922769 0.31647577494523438 0.6605396219444426 0.35219816984802332 0.65874978194495459 0.38591288770167392 0.65678132602610373 0.41773338396135723 0.65464625832500667 0.44776809581062954 0.65235633173728735 0.47612007555305791 0.64992312827908894 0.5028868059159991 0.64735803712369033 0.52816015988325782 0.64467218356382083
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 0.52816015988325771 0.64467218356382061 0.55343351385192274 0.64198633000380156 0.5772134914247391 0.63917971403929819 0.59959196558552674 0.63626346096304143 0.62065519957455229 0.63324843218721283 0.64048380672118688 0.63014515420575856 0.65915285480544361 0.62696369848240241 0.67673207756511877 0.62371356551544954 0.69328615497473711 0.62040359716224347 0.70887502955481174 0.61704192423326132 0.72355423376322703 0.61363594723754111 0.73737521116526994 0.61019234402932132 0.75038562054124103 0.6067170969392941 0.76262961705491283 0.60321553242052728 0.77414810812925028 0.59969236743526311
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 0.77414810812925039 0.59969236743526333 0.79718509027216367 0.59264603746649747 0.81732005065919122 0.58551330563178572 0.83488024867380684 0.57833190762903908 0.85014097984661419 0.57112982730297335 0.86333376387838601 0.56392678102268401 0.87465291392785716 0.55673613347539719 0.88426018590527522 0.54956650583124667 0.89228810843806794 0.54242264344979307 0.89884275821029547 0.53530580026051777 0.90400622976291778 0.52821408630119693 0.90783867495455794 0.52114302988276318 0.9103797250146477 0.51408636355005666 0.91164920165861008 0.5070369218943781 0.91164711727595227 0.49998753930409695
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 0.91164711727595238 0.49998753930409673 0.91164503289329402 0.49293815671381591 0.9103713874840158 0.48588883318893222 0.90782619343762494 0.47883240311781528 0.90398965381771268 0.47176170068590323 0.8988221625500471 0.46467045762631093 0.89226359368357544 0.45755420090849219 0.88423187973520967 0.45041103845120894 0.874620972670486 0.44324222097639765 0.86329837461686043 0.43605248929469065 0.85010236315241339 0.42885045858945803 0.83483866216987079 0.4216494860908897 0.81727579382392557 0.41446927894188634 0.79713851125636837 0.40733780933839225 0.77409961350949996 0.40029279817551228
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 0.77409961350949963 0.40029279817551228 0.76258016463317768 0.39677029259318924 0.75033531196166425 0.39326940162103058 0.73732415537521612 0.38979484037092793 0.72350254762286881 0.38635193324847111 0.70882283853848027 0.38294666031688929 0.69323359397846651 0.37958569691889499 0.67667929183599873 0.3762764407848011 0.65910000100875854 0.37302701966054835 0.64043105416016433 0.36984627204429277 0.62060273157377921 0.36674369478823143 0.59953998104109296 0.36372935545481672 0.57716220650952965 0.3608137764430332 0.5533831638397374 0.35800781496631773 0.52811100101565889 0.3553225921149612
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 0.52811100101565922 0.35532259211496137 0.50283883819300812 0.35263736926375649 0.47607355521623934 0.35007288503789691 0.4477233000693111 0.34764026052767161 0.41769061285947712 0.34535088070022363 0.38587246602735681 0.34321632346195186 0.35216044900978549 0.34124833780539449 0.31644113469894142 0.33945892427343333 0.27859666403568778 0.33786060012491476 0.23850557744173745 0.33646697282239602 0.19604390307083663 0.33529380293065758 0.15108647542764733 0.33436081656049704 0.10350839411909636 0.33369463494832402 0.053186427496782457 0.33333333327833259 5.9575400168654369e-12 0.33333333327829501
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 14 0.589184080009587 0.63078856737189348 0.61200062066390593 0.62722507010309259 0.63290288977458353 0.62362574032854146 0.65207546449013776 0.62000545414694963 0.66968236903268019 0.61637663431104861 0.68586961389451873 0.61274983668894967 0.70076726699537317 0.60913404520279835 0.71449126852908507 0.6055368332434965 0.72714507025310327 0.60196447641206352 0.73882112136240641 0.59842205690763839 0.74960220232636454 0.59491357438115644 0.75956260522662999 0.5914420647622296 0.76876916327780942 0.58800972270277718 0.77728213777685029 0.58461802167947108 0.78515597523863989 0.58126782639684338
+6 0 1 0 0 1 0
+6 0 14 0.78515597523864 0.5812678263968436 0.80090365016221898 0.57456743583158831 0.81409477693679311 0.56803306822904664 0.8251649276814611 0.56167164122547564 0.83445663800236025 0.55548033210289605 0.8422436353318381 0.54945017468853508 0.84874675918523301 0.54356916349665452 0.85414320629503371 0.53782417926927339 0.85857188854284561 0.53220120361699985 0.86213830763094534 0.52668457105527244 0.8649198950279311 0.52125630367913289 0.86697103558334443 0.51589607788771485 0.86832675611405141 0.51058180249982699 0.86900456965063622 0.50529050256648256 0.86900447538370296 0.49999920318555841
+6 0 1 0 0 1 0
+6 0 14 0.86900447538369952 0.49999920318555802 0.86900438111676759 0.49470790380462037 0.86832637904631504 0.48941660497610323 0.86697046836294622 0.48410233179788353 0.86491913441728552 0.47874210941470202 0.86213734866627934 0.47331384683282279 0.85857072431940606 0.46779722073682295 0.85414182772468972 0.46217425361369724 0.84874515488605373 0.45642928048879494 0.84224179182137127 0.45054828361230098 0.83445454024318333 0.44451814450461052 0.82516255981871223 0.43832685860304943 0.81409212305683931 0.4319654608066027 0.80090069540913933 0.42543112961339696 0.78515270817555638 0.41873078396602215
+6 0 1 0 0 1 0
+6 0 14 0.78515270817555649 0.41873078396602215 0.77727871455877406 0.4153806111423386 0.76876558104552228 0.41198893470511283 0.75955886154829444 0.40855661952216865 0.7495982953451068 0.40508513923910872 0.73881704998280107 0.40157668868073093 0.72714083438041954 0.39803430395100481 0.7144868693794536 0.39446198487313172 0.70076270749950065 0.39086481381129301 0.68586489922128269 0.38724906651698388 0.66967750726017716 0.38362231650655143 0.65207046744764829 0.3799935477877136 0.63289777406482417 0.37637331625333537 0.61199540884374604 0.3727740445907059 0.58917880184850868 0.3692106087019762
+6 0 1 0 0 1 0
+6 0 14 0.58917880184850868 0.36921060870197625 0.56636219485337358 0.36564717281326253 0.54163134608409635 0.36211957269844824 0.51480168560477424 0.35864268425968415 0.48566809181155807 0.35523383661398272 0.45400235231379238 0.35191339851365561 0.41955015669504581 0.3487056562779115 0.38202740936625029 0.34564014123127357 0.34111551971985954 0.34275363779189172 0.29645512341604352 0.34009320511768754 0.24763737836044936 0.33772068518855991 0.19419151265817514 0.33571936071442143 0.1355666102467061 0.33420368304492359 0.071104605930326845 0.33333333320600594 -9.9675109693775354e-09 0.33333333321102632
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 1 0 1
+6 0 1 1 0 0 0
+6 0 1 1 1 0 1
+6 0 1 1 0 0 0
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 14 0.58918408000958677 0.63078856737189348 0.61200062066390548 0.6272250701030927 0.63290288977458276 0.62362574032854168 0.65207546449013676 0.62000545414694985 0.66968236903267897 0.61637663431104894 0.68586961389451739 0.61274983668895 0.70076726699537173 0.60913404520279879 0.71449126852908351 0.60553683324349694 0.72714507025310171 0.60196447641206408 0.73882112136240485 0.59842205690763894 0.74960220232636299 0.594913574381157 0.75956260522662844 0.59144206476223027 0.76876916327780787 0.58800972270277785 0.77728213777684874 0.58461802167947174 0.78515597523863834 0.58126782639684405
+6 0 1 0 0 1 0
+6 0 14 0.78515597523863923 0.58126782639684427 0.80090365016221832 0.57456743583158887 0.81409477693679244 0.5680330682290472 0.82516492768146033 0.5616716412254763 0.83445663800235936 0.55548033210289682 0.8422436353318371 0.54945017468853596 0.84874675918523168 0.54356916349665552 0.85414320629503193 0.5378241792692745 0.85857188854284316 0.53220120361700107 0.86213830763094179 0.52668457105527366 0.86491989502792599 0.521256303679134 0.86697103558333699 0.51589607788771552 0.86832675611404053 0.51058180249982699 0.86900456965062012 0.50529050256648145 0.86900447538367942 0.49999920318555557
+6 0 1 0 0 1 0
+6 0 14 0.86900447538369952 0.49999920318555802 0.86900438111676759 0.49470790380462032 0.86832637904631504 0.48941660497610312 0.86697046836294622 0.48410233179788337 0.86491913441728552 0.47874210941470186 0.86213734866627934 0.47331384683282257 0.85857072431940606 0.46779722073682267 0.85414182772468972 0.46217425361369691 0.84874515488605373 0.45642928048879461 0.84224179182137127 0.45054828361230065 0.83445454024318322 0.44451814450461019 0.825162559818712 0.43832685860304904 0.81409212305683898 0.43196546080660225 0.80090069540913889 0.42543112961339652 0.78515270817555571 0.4187307839660217
+6 0 1 0 0 1 0
+6 0 14 0.78515270817555582 0.41873078396602176 0.77727871455877329 0.41538061114233821 0.76876558104552151 0.4119889347051125 0.75955886154829366 0.40855661952216832 0.74959829534510591 0.40508513923910838 0.73881704998280018 0.40157668868073065 0.72714083438041854 0.39803430395100453 0.71448686937945249 0.39446198487313144 0.70076270749949954 0.39086481381129273 0.68586489922128158 0.38724906651698365 0.66967750726017605 0.38362231650655126 0.65207046744764718 0.37999354778771344 0.63289777406482306 0.3763733162533352 0.61199540884374504 0.37277404459070579 0.58917880184850779 0.36921060870197608
+6 0 1 0 0 1 0
+6 0 14 0.5891788018485079 0.36921060870197603 0.5663621948533728 0.36564717281326231 0.54163134608409558 0.36211957269844802 0.51480168560477346 0.35864268425968393 0.48566809181155729 0.3552338366139825 0.4540023523137916 0.35191339851365538 0.41955015669504503 0.34870565627791128 0.38202740936624957 0.34564014123127335 0.34111551971985887 0.3427536377918915 0.29645512341604285 0.34009320511768731 0.24763737836044875 0.33772068518855969 0.19419151265817461 0.33571936071442121 0.13556661024670569 0.33420368304492337 0.071104605930326553 0.33333333320600572 -9.9675111081554135e-09 0.33333333321102609
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 1 0 1
+6 0 1 1 0 0 0
+6 0 1 1 1 1 0
+6 0 1 1 1 1 0
+6 0 1 1 0 0 0
+6 0 1 1 1 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 2.7443460926765111e-13 0.66666666672100439 0.053192950236764285 0.66666666672077945 0.10352088691516703 0.66630527671971063 0.15110439398954592 0.6656389359533823 0.19606672216615875 0.66470572900579339 0.23853279737741614 0.66353228236138506 0.27862781417979676 0.6621383255392278 0.31647577494523454 0.66053962194444271 0.35219816984802349 0.6587497819449547 0.38591288770167409 0.65678132602610395 0.4177333839613574 0.65464625832500689 0.44776809581062971 0.65235633173728758 0.47612007555305808 0.64992312827908916 0.50288680591599932 0.64735803712369056 0.52816015988325804 0.64467218356382106
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 0.5281601598832576 0.64467218356382072 0.55343351385192274 0.64198633000380168 0.57721349142473921 0.6391797140392983 0.59959196558552696 0.63626346096304154 0.62065519957455262 0.63324843218721283 0.64048380672118732 0.63014515420575856 0.65915285480544417 0.62696369848240241 0.67673207756511944 0.62371356551544954 0.69328615497473778 0.62040359716224347 0.70887502955481241 0.61704192423326132 0.72355423376322769 0.61363594723754111 0.73737521116527072 0.61019234402932121 0.7503856205412418 0.60671709693929399 0.76262961705491361 0.60321553242052706 0.77414810812925117 0.59969236743526289
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 0.77414810812925139 0.59969236743526322 0.79718509027216444 0.59264603746649736 0.81732005065919178 0.58551330563178572 0.83488024867380728 0.57833190762903919 0.85014097984661452 0.57112982730297346 0.86333376387838623 0.56392678102268412 0.87465291392785738 0.5567361334753973 0.88426018590527533 0.54956650583124678 0.89228810843806794 0.5424226434497933 0.89884275821029536 0.53530580026051799 0.90400622976291767 0.52821408630119715 0.90783867495455783 0.5211430298827634 0.91037972501464759 0.51408636355005688 0.91164920165860996 0.50703692189437832 0.91164711727595216 0.49998753930409723
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 0.91164711727595149 0.49998753930409623 0.91164503289329335 0.49293815671381541 0.91037138748401536 0.48588883318893183 0.90782619343762472 0.478832403117815 0.90398965381771268 0.47176170068590312 0.89882216255004721 0.46467045762631098 0.89226359368357566 0.45755420090849241 0.88423187973521 0.45041103845120933 0.87462097267048655 0.44324222097639815 0.86329837461686121 0.43605248929469126 0.8501023631524145 0.42885045858945869 0.83483866216987224 0.42164948609089048 0.81727579382392745 0.41446927894188723 0.79713851125637081 0.40733780933839325 0.77409961350950307 0.40029279817551339
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 0.77409961350950252 0.40029279817551305 0.76258016463318057 0.39677029259318997 0.75033531196166714 0.39326940162103124 0.737324155375219 0.38979484037092854 0.72350254762287158 0.38635193324847167 0.70882283853848294 0.38294666031688979 0.69323359397846906 0.37958569691889543 0.67667929183600117 0.37627644078480149 0.65910000100876076 0.37302701966054869 0.64043105416016632 0.36984627204429305 0.62060273157378099 0.36674369478823166 0.59953998104109452 0.36372935545481688 0.57716220650953087 0.36081377644303331 0.55338316383973829 0.35800781496631778 0.52811100101565933 0.3553225921149612
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 2.741237780081354e-13 0.66666666672100439 0.053192950236764423 0.66666666672077945 0.10352088691516756 0.66630527671971063 0.15110439398954678 0.6656389359533823 0.19606672216615992 0.66470572900579339 0.23853279737741756 0.66353228236138506 0.27862781417979843 0.6621383255392278 0.31647577494523638 0.66053962194444271 0.35219816984802549 0.6587497819449547 0.3859128877016762 0.65678132602610384 0.41773338396135962 0.65464625832500678 0.44776809581063204 0.65235633173728746 0.47612007555306046 0.64992312827908905 0.50288680591600177 0.64735803712369044 0.52816015988326059 0.64467218356382083
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 0.52816015988326048 0.64467218356382061 0.55343351385192607 0.64198633000380156 0.57721349142474287 0.63917971403929807 0.59959196558553096 0.63626346096304132 0.62065519957455684 0.63324843218721261 0.64048380672119176 0.63014515420575823 0.65915285480544872 0.62696369848240197 0.6767320775651241 0.62371356551544899 0.69328615497474255 0.6204035971622428 0.70887502955481729 0.61704192423326054 0.72355423376323269 0.61363594723754022 0.73737521116527571 0.61019234402932032 0.7503856205412468 0.60671709693929299 0.76262961705491861 0.60321553242052606 0.77414810812925605 0.59969236743526189
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 0.77414810812925605 0.59969236743526189 0.79718509027216822 0.59264603746649613 0.81732005065919477 0.5855133056317845 0.83488024867380961 0.57833190762903797 0.8501409798466163 0.57112982730297235 0.86333376387838756 0.56392678102268312 0.87465291392785838 0.55673613347539641 0.88426018590527611 0.549566505831246 0.89228810843806849 0.54242264344979263 0.89884275821029569 0.53530580026051744 0.90400622976291789 0.52821408630119671 0.90783867495455794 0.52114302988276306 0.91037972501464759 0.51408636355005666 0.91164920165860996 0.50703692189437821 0.91164711727595216 0.49998753930409723
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 0.91164711727595238 0.49998753930409207 0.91164503289329413 0.49293815671381197 0.91037138748401591 0.48588883318892895 0.90782619343762494 0.47883240311781256 0.90398965381771257 0.47176170068590101 0.89882216255004688 0.4646704576263091 0.892263593683575 0.45755420090849069 0.884231879735209 0.45041103845120767 0.87462097267048511 0.44324222097639654 0.86329837461685932 0.43605248929468965 0.85010236315241205 0.42885045858945708 0.83483866216986924 0.42164948609088881 0.81727579382392379 0.41446927894188551 0.79713851125636626 0.40733780933839148 0.77409961350949752 0.40029279817551155
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 0.77409961350949741 0.40029279817551144 0.76258016463317546 0.39677029259318847 0.75033531196166203 0.39326940162102986 0.73732415537521401 0.38979484037092726 0.72350254762286681 0.3863519332484705 0.70882283853847838 0.38294666031688873 0.69323359397846473 0.37958569691889449 0.67667929183599707 0.37627644078480066 0.65910000100875699 0.37302701966054796 0.64043105416016299 0.36984627204429243 0.6206027315737781 0.36674369478823116 0.59953998104109207 0.36372935545481649 0.57716220650952899 0.36081377644303303 0.55338316383973696 0.35800781496631762 0.52811100101565867 0.35532259211496109
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 14 0.52811100101565878 0.35532259211496131 0.50283883819300768 0.35263736926375644 0.47607355521623895 0.35007288503789685 0.44772330006931071 0.34764026052767155 0.41769061285947673 0.34535088070022357 0.38587246602735648 0.3432163234619518 0.35216044900978516 0.34124833780539449 0.31644113469894114 0.33945892427343333 0.27859666403568756 0.33786060012491476 0.23850557744173728 0.33646697282239602 0.19604390307083652 0.33529380293065758 0.15108647542764728 0.33436081656049704 0.10350839411909638 0.33369463494832402 0.05318642749678254 0.33333333327833259 5.9576996114252267e-12 0.33333333327829501
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 1 1 0
+6 0 1 1 1 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 1 1 0
+6 0 1 1 1 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 1 1 0
+6 0 1 1 1 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 14 0.03899179738652947 0.96908906053917931 0.059534136003094318 0.95071682004675595 0.077077155669134312 0.93146078548855005 0.094501030510710432 0.91202953910872286 0.11268553997100439 0.89265645686440509 0.13120745107574647 0.87325631394298908 0.1498846669922668 0.85379742618292065 0.16873848575157394 0.83429617737918504 0.18781406652452656 0.81477252051556326 0.2071280484979417 0.79523629080657698 0.22667646908014621 0.77568927658683517 0.2464511190263898 0.75612960806417395 0.26645021971992366 0.7365544971303033 0.28668298140380688 0.71696123094094366 0.30717000336257738 0.69734707516987759
+6 0 11 0.63127543708679212 0.41847091558581345 0.59723619966357633 0.4443449426946377 0.56461147763508823 0.46992023838429636 0.53252335227008762 0.49565942584881356 0.50253629085867646 0.52063924204630263 0.47193025322316157 0.54628237443076388 0.44349050251040179 0.57121962236377666 0.41494963749312508 0.59655565282538325 0.38736654092639589 0.6217359760952833 0.36018689015453093 0.64696361915694489 0.33347018923551586 0.6721674300792515 0.3071700057530255 0.69734707288127007
+6 0 1 0 0 0.50140622536670632 0
+6 0 7 0.63127543598470992 0.4184709151222209 0.64374182503265687 0.44366283595627676 0.65815296488736008 0.46836391862674348 0.67503472770525319 0.49242649776127501 0.69512763572357739 0.51564480451531503 0.71970586553218063 0.53761101836666669 0.7525047577691103 0.55738254406477261 0.78665561341502444 0.57720711806243263
+6 0 14 0.78665561372370085 0.57720711815943559 0.80401129794862392 0.58728209401311104 0.82126645052630154 0.59711940130922703 0.83749159512172411 0.60689960300454548 0.85263793223294926 0.61692255139270658 0.8668264681190303 0.62696448091830859 0.88013094533235481 0.63704308683539634 0.89258958547811773 0.64716883544234627 0.9042163186572717 0.65730801197118272 0.91500263593904185 0.66742280895691519 0.92491775258596087 0.67748275351984644 0.93390774946730082 0.68745716439645799 0.94189350690341722 0.69730799245610242 0.94876775166000482 0.70698693923082667 0.95439137186241263 0.71643441295716315
+6 0 14 0.95439137186241241 0.71643441295716359 0.96001499206482011 0.72588188668350029 0.96438798771304812 0.73509788736144921 0.96737124693244536 0.74402282322754287 0.96879381920801555 0.75258580922279938 0.9684492302987322 0.760703623034514 0.96609106507191433 0.76828149865001794 0.96142797302781158 0.7752133169212424 0.95411808533569664 0.78137241761043519 0.94376199382858073 0.7865870465403032 0.92988989950896794 0.79064061109913042 0.91193303393636016 0.79341433264940342 0.88920283147093582 0.79502098467451399 0.86101310975897927 0.7946199167279725 0.8262743349285927 0.7947320385079526
+6 0 8 0.82627433497593628 0.79473203805771264 0.75552057054620392 0.79496040048428285 0.68797478466892281 0.79752469878792631 0.62322442187540761 0.80248083144153326 0.5607489363508471 0.80990855485653357 0.50041866098491317 0.82014016736884154 0.44238518547513528 0.83390384456996591 0.38658221184376163 0.85169881117531998 0.33583361362974457 0.87694050767526199
+6 0 10 0.3358336136279183 0.87694050767338527 0.30877752032601691 0.89039785860893672 0.28392716142952934 0.9055068932072472 0.26040295039895855 0.92139223077859322 0.23735379867604442 0.93671958664772759 0.21319491405260657 0.95097210710616276 0.18811810598539044 0.96247824164567131 0.15776553365058676 0.96970487083474144 0.12331932168550036 0.97358980609404733 0.083873009136408549 0.97364408062184671 0.0389917973204503 0.96908905969609183
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 0 0
+6 0 1 0 0 1 0
+6 0 1 1 1 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 1 1 1 0
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 0 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 0 0
+6 0 1 1 1 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 0 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 1 0 0 0
+6 0 1 1 1 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 0 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 0 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 6 0.38755111791794894 0.77990387497446312 0.44393667968867251 0.80183171045220392 0.50192468451124783 0.81891693626219919 0.56077229324135902 0.83295238887591316 0.62029367047260453 0.84475603236763064 0.68035525133101071 0.85487956203583015 0.74078155618261099 0.86367399505185738
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 10 0.74078155618320274 0.86367399505214781 0.77057206708517834 0.86800970039240188 0.7941169927074373 0.86617789603680129 0.81430999607881216 0.86421019441443925 0.83091347472657562 0.85939139645523677 0.84653265785509069 0.85558594899193308 0.85873812985916909 0.84932518985735261 0.87131179598911124 0.84333690466254652 0.88039520006887739 0.83531988172071525 0.8888873067248183 0.8258977625737246 0.88888744920436591 0.81267336835174731
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 4 0.88888744927407881 0.81267336835086845 0.88888948752109498 0.62349113561359437 0.88888929501979619 0.48572793415674492 0.88888960389577765 0.34788261124261771 0.88888906343449292 0.15798930133581751
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 10 0.88888906342982177 0.15798930133493705 0.8888890274779867 0.14535749671608805 0.88113481416026063 0.13613907561239125 0.87245278698812478 0.12828928078778967 0.86058945842441659 0.12220242713360213 0.84875682481956849 0.11611316526929701 0.83377169970278109 0.11200329259950052 0.81778476678624268 0.10732680181009971 0.79835742466399606 0.10496593532103406 0.77588343605138921 0.10296985533599198 0.74739042049802429 0.10614133722074277
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 6 0.74739042054189997 0.10614133741468469 0.68828513613797859 0.11272018965224159 0.62938021739479189 0.12026488931101899 0.57078132360043654 0.1290238035735316 0.51256402782892696 0.13940219712792876 0.45480382249834772 0.15195687166251681 0.39793353864030828 0.16803564332620052
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 8 0.39793353865190917 0.16803564337698673 0.38254673923150567 0.17238590889018046 0.36962422975979187 0.17856861838475291 0.3586012338140685 0.18613930768258213 0.34950056760918802 0.19499461767570894 0.34207014076054582 0.20504349065606831 0.33670256082306455 0.21631459344453483 0.33333352904069802 0.22883939772761017 0.33333354732532428 0.24304366465115101
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 4 0.33333354734844722 0.24304366465176608 0.33333370906960691 0.3686753037277829 0.33333340635263131 0.47577763722409466 0.33333358053180573 0.58285360922294804 0.33333311045857894 0.70836503242273263
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 8 0.33333311045847913 0.70836503242333515 0.33333306305895949 0.72102089784511447 0.33600893132980275 0.73242849351751704 0.34044298688907559 0.74283205507814121 0.34659429749414261 0.75231378820867345 0.354248147105306 0.76083458642044177 0.36353066523638289 0.76837276381093056 0.37449308775928503 0.77482572349786039 0.38755111834291434 0.77990387363292646
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 0 0
+6 0 1 1 1 0 1
+6 0 1 1 0 0 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 0 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 0 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0.46866856075558883 1 0.055845110571641543
+6 0 1 0.53404394581871251 0.46866856075558877 0.99999999993666866 0.46866856075558883
+6 0 1 1 0 1 1
+6 0 5 0.53404394584498938 0.46866856075558894 0.52783333905300545 0.46866856161090714 0.52162331898944425 0.46817148784594914 0.51573931268534023 0.46717657668177826 0.51050873431696986 0.46574184339282515 0.50614420291600226 0.46396233779741636
+6 0 1 1 0 1 1
+6 0 5 0.50614420291600248 0.46396233779741641 0.50177967151503489 0.46218283220200768 0.49828161535940146 0.46005866285577612 0.49587242087675582 0.45768200501403855 0.49466778543028733 0.45518105635847933 0.49466779254649457 0.45267974064351174
+6 0 1 1 0 1 1
+6 0 1 0.49466779254649429 0.45267974064371175 0.494667792546375 0.071833930770230814
+6 0 1 1 0 1 1
+6 0 5 0.49466779254649523 0.071833930684353522 0.49466778573897663 0.069332614724068389 0.49587246773551974 0.066831671844075069 0.49828155429082049 0.064454982940238909 0.50177968892917635 0.062330858824515195 0.50614420594987564 0.060551332012077456
+6 0 1 1 0 1 1
+6 0 5 0.50614420594987586 0.06055133201207747 0.51050872297057515 0.058771805199639732 0.51573932274044698 0.057337145688287121 0.52162333126278337 0.056342149786778532 0.52783334058486742 0.055845109731285293 0.53404394584415138 0.055845110571641619
+6 0 1 1 0 1 1
+6 0 1 0.53404394584381443 0.055845110571641612 0.99999999981409826 0.055845110571641599
+6 0 1 1 0 1 1
+6 0 1 0.99999999981409826 0.055845110571641599 0.53404394584381443 0.055845110571641612
+6 0 1 1 1 1 0
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 0 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 0 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 0 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 0 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 0 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 0 0
+6 0 1 0 0 0 1
+6 0 1 1 0 0 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 0 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 0 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 1 0 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 0 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 0 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0.99999999997750288 0.21476361440244793 0.83865243778372667 0.2147636144024479
+6 0 1 1 0 1 1
+6 0 3 0.82929523095291002 0.21226202944131217 0.83239327746972114 0.21392591315580173 0.83552325908778891 0.21476255956652932 0.83865348429939579 0.21476361457889417
+6 0 1 1 0 1 1
+6 0 4 0.82929591936767977 0.2122623992457473 0.77858264433971358 0.18501431750741959 0.72849553963346314 0.14236496801271412 0.67947051253952029 0.08220253150954214 0.63323593290505076 -4.163336342344337e-17
+6 0 1 1 0 1 1
+6 0 1 0.63323593290505087 0 1 0
+6 0 1 1 0.63323593290505709 1 1
+6 0 1 1 0 1 0.21476361440244796
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 0 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 4 0.99999999999999978 0.63323593290505709 0.98216506357005151 0.62906946486719029 0.96381227771773148 0.62493059157992703 0.94489764014638122 0.62082319382568896 0.92539628454856115 0.61675077373059939
+6 0 1 1 0 1 1
+6 0 3 0.92539628454856127 0.61675077373059939 0.90088421485925763 0.61163315907415949 0.87531673979501134 0.60657815184157571 0.84853428515826002 0.60160425531865835
+6 0 1 1 0 1 1
+6 0 3 0.84853164225272359 0.60160376446175279 0.82705266482474016 0.59761432120880675 0.80479244730607791 0.59367839531675692 0.78165697183660476 0.58980670780424449
+6 0 1 1 0 1 1
+6 0 8 0.78165980081704645 0.58980718062104542 0.77817417761445962 0.58922392242275856 0.77363990589143583 0.5887163827908507 0.76809149073108163 0.58834099975319298 0.76236478255245099 0.58801782145961978 0.75594794798549725 0.58788267336770283 0.74965125303313584 0.58779743443112253 0.74329217925564772 0.5878442059594281 0.73714996809552114 0.5879913897141249
+6 0 1 1 0 1 1
+6 0 5 0.73714996809552102 0.5879913897141249 0.73223619916741978 0.58810913671788234 0.72745687500626544 0.58829843755120226 0.72295529416453697 0.58856371989013478 0.71883637068140704 0.5888981226215918 0.71531635362520474 0.58929843952345373
+6 0 1 1 0 1 1
+6 0 6 0.71531635362520485 0.58929843952345373 0.71238300607836957 0.58963203694167199 0.70984192268072888 0.59000980519263735 0.70786718506070279 0.59042827753651539 0.70634988391389641 0.59087634228274133 0.70568295230520495 0.59134462727903692 0.70568295299407102 0.59181200486301311
+6 0 1 1 0 1 1
+6 0 1 0.7056829529940708 0.59181200486307084 0.7056829529940708 1.0000000000245761
+6 0 1 1 0 1 1
+6 0 1 0.7056829529940708 1 1 1
+6 0 1 1 0 0.63323593290505087 0
+6 0 1 1 1 1 0.63323593290505709
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 0 0
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 0 0 1 0
+6 0 1 0 1 1 1
+6 0 1 0 1 1 1
+6 0 1 1 0 1 1
+6 0 1 0 0 0 1
+6 0 1 0 0 1 0
+6 0 1 0 0 0 1
+6 0 1 1 0 1 1
+6 0 1 0 0 1 0
+Curves 1875
+6 0 8 -1255.4487902081305 100.94413300620994 -107.70704981638278 -1286.9712777261971 100.94413300620994 -162.30561916932061 -1334.8296189943305 100.94413300620994 -207.47268231181715 -1395.731597276641 100.94413300620994 -237.5059505626138 -1463.9999228622421 100.94413300620994 -248.08217576252255 -1532.2682517007599 100.94413300620994 -237.50597155984127 -1593.1702392203724 100.94413300620994 -207.47272204061227 -1641.0285943804961 100.94413300620994 -162.30567361786447 -1672.5510986913935 100.94413300620994 -107.7071139602721
+6 0 1 -1255.4487902081337 100.94413300620994 -107.70704981638067 -1277.0249585801328 80.646240234375028 -95.250043198726573
+6 0 8 -1277.0249585801328 80.646240234375028 -95.250043198726644 -1305.2862093918868 80.646240234375028 -144.19998488082297 -1348.1932485067002 80.646240234375028 -184.69418009325591 -1402.7944635923827 80.646240234375028 -211.62028428725631 -1463.9999228622419 80.646240234375028 -221.10232139713321 -1525.2053853850177 80.646240234375028 -211.62030528448378 -1579.8066097080025 80.646240234375028 -184.69421982205102 -1622.7136627148063 80.646240234375028 -144.20003932936683 -1650.9749303193914 80.646240234375028 -95.250107342615991
+6 0 1 -1672.5510986913901 100.94413300620994 -107.70711396027042 -1650.9749303193912 80.646240234375028 -95.250107342615991
+6 0 6 -1672.5510986913935 100.94413300620994 -107.70711396027207 -1673.7215242809923 102.04521697559167 -108.3828594894934 -1674.9915920576095 102.86508422575187 -109.11613346221237 -1676.3294976022296 103.37381023676267 -109.88857358854904 -1677.6988809799068 103.55419576962458 -110.67918745027477 -1679.0618953268429 103.40455151353103 -111.4661241503877 -1680.3826504488979 102.93757104604563 -112.22866247563979
+6 0 8 -1247.617238450626 102.93757104604563 -112.22859833175045 -1280.32346460192 102.93757104604563 -168.87746314032032 -1329.9789914691 102.93757104604563 -215.74064796759959 -1393.167972347766 102.93757104604563 -246.90173074553138 -1463.9999228622421 102.93757104604563 -257.8751159282408 -1534.831876629635 102.93757104604563 -246.90175174275885 -1598.0208667456029 102.93757104604563 -215.74068769639473 -1647.6764075047734 102.93757104604563 -168.87751758886421 -1680.3826504488982 102.93757104604563 -112.22866247563979
+6 0 6 -1255.4487902081305 100.94413300620994 -107.70704981638278 -1254.2783646185317 102.04521697559167 -108.38279534560409 -1253.0082968419144 102.86508422575187 -109.11606931832307 -1251.6703912972944 103.37381023676267 -109.88850944465973 -1250.3010079196172 103.55419576962458 -110.67912330638545 -1248.9379935726811 103.40455151353103 -111.46606000649838 -1247.617238450626 102.93757104604563 -112.22859833175046
+6 0 8 -1463.9999999999998 100.94413300620994 253.51411323530817 -1400.9550081710368 100.94413300620994 253.51412293065368 -1337.9100134412333 100.94413300620994 234.65111518071362 -1281.4494510362165 100.94413300620994 196.92508897290361 -1238.1560085441504 100.94413300620994 143.09109734190113 -1213.1811056400254 100.94413300620994 78.680888192495232 -1208.7396689220682 100.94413300620994 10.921595099934464 -1223.9263026900676 100.94413300620994 -53.108480463443684 -1255.4487902081335 100.94413300620994 -107.7070498163807
+6 0 1 -1464 100.94413300620994 253.51411323530812 -1463.9999999999998 80.646240234375028 228.6000999999996
+6 0 8 -1463.9999999999995 80.646240234375028 228.60009999999966 -1407.4774815836604 80.646240234375028 228.60010969534511 -1350.9549602664806 80.646240234375028 211.68862142696057 -1300.3356624666883 80.646240234375028 177.86563418226163 -1261.5212478149786 80.646240234375028 129.60117015920835 -1239.1301833862383 80.646240234375028 71.854676707783341 -1235.1482452596836 80.646240234375028 11.10558663512947 -1248.7637077683785 80.646240234375028 -46.300101516630185 -1277.0249585801328 80.646240234375028 -95.250043198726473
+6 0 8 -1672.5510986913935 100.94413300620994 -107.70711396027218 -1704.0736030022908 100.94413300620994 -53.108554302679806 -1719.2602564639619 100.94413300620994 10.921516589757147 -1714.8188405866692 100.94413300620994 78.680811048364447 -1689.8439574931349 100.94413300620994 143.09102787927654 -1646.5505315587423 100.94413300620994 196.92503282600219 -1590.0899807570868 100.94413300620994 234.65107639933501 -1527.0449918289635 100.94413300620994 253.51410353996636 -1463.9999999999995 100.94413300620994 253.51411323531184
+6 0 8 -1650.9749303193912 80.646240234375028 -95.250107342615934 -1679.2361979239763 80.646240234375028 -46.3001753558651 -1692.8516801263427 80.646240234375028 11.105508124952387 -1688.8697628404525 80.646240234375028 71.854599563651732 -1666.4787182223031 80.646240234375028 129.60110069658191 -1627.6643201282675 80.646240234375028 177.86557803535749 -1577.0450339318375 80.646240234375028 211.68858264557861 -1520.5225184163387 80.646240234375028 228.60009030465406 -1463.9999999999995 80.646240234375028 228.60009999999949
+6 0 8 -1463.9999999999995 102.93757104604563 262.55721026604732 -1398.5875309045807 102.93757104604563 262.55721996139278 -1333.1750589083215 102.93757104604563 242.98586466975377 -1274.5942791738698 102.93757104604563 203.84314337854593 -1229.6750735828937 102.93757104604563 147.98756742476215 -1203.7623088488031 102.93757104604563 81.158613969774095 -1199.1540868639242 102.93757104604563 10.85481126667996 -1214.911012299332 102.93757104604563 -55.579733523180479 -1247.617238450626 102.93757104604563 -112.22859833175032
+6 0 6 -1463.9999999999995 100.94413300620994 253.51411323531181 -1463.9999999999995 102.04521697559167 254.86560429375444 -1463.9999999999995 102.86508422575187 256.3321522391924 -1463.9999999999995 103.37381023676267 257.87703249186569 -1463.9999999999995 103.55419576962458 259.45826021531713 -1463.9999999999995 103.40455151353103 261.03213361554299 -1463.9999999999995 102.93757104604563 262.55721026604715
+6 0 3 -1680.3826504488925 102.93757104604559 -112.22866247563599 -1727.9645887158258 86.113986261320491 -139.70010734261388 -1727.9645887158258 43.056993130660238 -139.70010734261388 -1727.9645887158258 -7.1054273576010019e-15 -139.70010734261385
+6 0 8 -1200.0353001836986 1.4210854715202004e-14 -139.70004319872612 -1239.9335337831249 1.4210854715202004e-14 -208.80583031587446 -1300.5081705375771 1.4210854715202004e-14 -265.9740938551974 -1377.5922286277053 1.4210854715202004e-14 -303.98740756619594 -1463.9999228622428 1.4210854715202004e-14 -317.37380646175052 -1550.407620349697 1.4210854715202004e-14 -303.9874285634229 -1627.4916876771272 1.4210854715202004e-14 -265.97413358399149 -1688.0663383235694 1.4210854715202004e-14 -208.80588476441693 -1727.9645887158263 1.4210854715202004e-14 -139.70010734261382
+6 0 3 -1247.6172384506317 102.93757104604559 -112.22859833174789 -1200.0353001836986 86.113986261320491 -139.70004319872612 -1200.0353001836986 43.056993130660238 -139.70004319872612 -1200.0353001836986 -7.1054273576010019e-15 -139.70004319872612
+6 0 8 -1680.3826504488929 102.93757104604559 -112.22866247563616 -1713.0888933930169 102.93757104604559 -55.579807362413121 -1728.8458385220956 102.93757104604559 10.854732756503495 -1724.2376373778814 102.93757104604559 81.158536825641306 -1698.3248924543818 102.93757104604559 147.98749796213275 -1653.4057034210807 102.93757104604559 203.84308723163733 -1594.8249352899929 102.93757104604559 242.98582588836621 -1529.4124690954163 102.93757104604559 262.5572005706955 -1463.9999999999993 102.93757104604559 262.55721026604084
+6 0 8 -1463.9999999999986 -1.4210854715202004e-14 317.50009999999702 -1384.2035160083158 -1.4210854715202004e-14 317.50010969534225 -1304.4070291157923 -1.4210854715202004e-14 293.62506721063352 -1232.9445047149761 -1.4210854715202004e-14 245.87497153328644 -1178.1476960889652 -1.4210854715202004e-14 177.73691269151612 -1146.5367906698484 -1.4210854715202004e-14 96.212462635696212 -1140.9152361398724 -1.4210854715202004e-14 10.449054613396029 -1160.1370665842726 -1.4210854715202004e-14 -70.594256081577711 -1200.0353001836988 -1.4210854715202004e-14 -139.70004319872606
+6 0 3 -1463.9999999999989 102.93757104604559 262.5572102660409 -1463.9999999999986 86.113986261320491 317.50009999999702 -1463.9999999999986 43.056993130660238 317.50009999999702 -1463.9999999999986 -7.1054273576010019e-15 317.50009999999702
+6 0 8 -1727.9645887158263 -1.4210854715202004e-14 -139.70010734261405 -1767.8628391080831 -1.4210854715202004e-14 -70.594329920810949 -1787.0846892461543 -1.4210854715202004e-14 10.448976103220716 -1781.4631555568424 -1.4210854715202004e-14 96.212385491566337 -1749.8522699483158 -1.4210854715202004e-14 177.73684322889122 -1695.0554778799785 -1.4210854715202004e-14 245.87491538638352 -1623.5929650825244 -1.4210854715202004e-14 293.62502842925232 -1543.796483991682 -1.4210854715202004e-14 317.50009030465151 -1463.9999999999991 -1.4210854715202004e-14 317.50009999999673
+6 0 8 -1247.617238450626 -102.93757104604563 -112.22859833175045 -1280.32346460192 -102.93757104604563 -168.87746314032032 -1329.9789914691 -102.93757104604563 -215.74064796759959 -1393.167972347766 -102.93757104604563 -246.90173074553138 -1463.9999228622421 -102.93757104604563 -257.8751159282408 -1534.831876629635 -102.93757104604563 -246.90175174275885 -1598.0208667456029 -102.93757104604563 -215.74068769639473 -1647.6764075047734 -102.93757104604563 -168.87751758886421 -1680.3826504488982 -102.93757104604563 -112.22866247563979
+6 0 3 -1247.6172384506317 -102.93757104604559 -112.22859833174789 -1200.0353001836986 -86.113986261320491 -139.70004319872612 -1200.0353001836986 -43.056993130660238 -139.70004319872612 -1200.0353001836986 7.1054273576010019e-15 -139.70004319872612
+6 0 3 -1680.3826504488925 -102.93757104604559 -112.22866247563599 -1727.9645887158258 -86.113986261320491 -139.70010734261388 -1727.9645887158258 -43.056993130660238 -139.70010734261388 -1727.9645887158258 7.1054273576010019e-15 -139.70010734261385
+6 0 8 -1463.9999999999989 -102.93757104604559 262.5572102660409 -1398.5875309045819 -102.93757104604559 262.55721996138618 -1333.1750589083242 -102.93757104604559 242.98586466974749 -1274.5942791738742 -102.93757104604559 203.84314337854047 -1229.6750735828994 -102.93757104604559 147.98756742475797 -1203.7623088488094 -102.93757104604559 81.158613969771537 -1199.1540868639311 -102.93757104604559 10.854811266679164 -1214.9110122993386 -102.93757104604559 -55.57973352317957 -1247.6172384506317 -102.93757104604559 -112.22859833174792
+6 0 3 -1463.9999999999991 -102.93757104604559 262.55721026604078 -1463.9999999999989 -86.113986261320491 317.50009999999691 -1463.9999999999989 -43.056993130660238 317.50009999999691 -1463.9999999999989 7.1054273576010019e-15 317.50009999999691
+6 0 8 -1680.3826504488929 -102.93757104604559 -112.22866247563616 -1713.0888933930169 -102.93757104604559 -55.579807362413121 -1728.8458385220956 -102.93757104604559 10.854732756503495 -1724.2376373778814 -102.93757104604559 81.158536825641306 -1698.3248924543818 -102.93757104604559 147.98749796213275 -1653.4057034210807 -102.93757104604559 203.84308723163733 -1594.8249352899929 -102.93757104604559 242.98582588836621 -1529.4124690954163 -102.93757104604559 262.5572005706955 -1463.9999999999993 -102.93757104604559 262.55721026604084
+6 0 8 -1255.4487902081305 -100.94413300620994 -107.70704981638278 -1286.9712777261971 -100.94413300620994 -162.30561916932061 -1334.8296189943305 -100.94413300620994 -207.47268231181715 -1395.731597276641 -100.94413300620994 -237.5059505626138 -1463.9999228622421 -100.94413300620994 -248.08217576252255 -1532.2682517007599 -100.94413300620994 -237.50597155984127 -1593.1702392203724 -100.94413300620994 -207.47272204061227 -1641.0285943804961 -100.94413300620994 -162.30567361786447 -1672.5510986913935 -100.94413300620994 -107.7071139602721
+6 0 6 -1255.4487902081305 -100.94413300620994 -107.70704981638278 -1254.2783646185317 -102.04521697559167 -108.38279534560409 -1253.0082968419144 -102.86508422575187 -109.11606931832307 -1251.6703912972944 -103.37381023676267 -109.88850944465973 -1250.3010079196172 -103.55419576962458 -110.67912330638545 -1248.9379935726811 -103.40455151353103 -111.46606000649838 -1247.617238450626 -102.93757104604563 -112.22859833175046
+6 0 6 -1672.5510986913935 -100.94413300620994 -107.70711396027207 -1673.7215242809923 -102.04521697559167 -108.3828594894934 -1674.9915920576095 -102.86508422575187 -109.11613346221237 -1676.3294976022296 -103.37381023676267 -109.88857358854904 -1677.6988809799068 -103.55419576962458 -110.67918745027477 -1679.0618953268429 -103.40455151353103 -111.4661241503877 -1680.3826504488979 -102.93757104604563 -112.22866247563979
+6 0 8 -1463.9999999999995 -100.94413300620994 253.51411323531192 -1400.9550081710356 -100.94413300620994 253.51412293065738 -1337.9100134412311 -100.94413300620994 234.65111518071697 -1281.4494510362133 -100.94413300620994 196.92508897290634 -1238.1560085441467 -100.94413300620994 143.09109734190298 -1213.1811056400215 -100.94413300620994 78.68088819249607 -1208.7396689220643 -100.94413300620994 10.921595099934265 -1223.9263026900639 -100.94413300620994 -53.108480463444849 -1255.4487902081305 -100.94413300620994 -107.70704981638266
+6 0 6 -1463.9999999999995 -100.94413300620994 253.51411323531192 -1463.9999999999995 -102.04521697559167 254.86560429375456 -1463.9999999999995 -102.86508422575187 256.33215223919251 -1463.9999999999995 -103.37381023676267 257.8770324918658 -1463.9999999999995 -103.55419576962458 259.45826021531724 -1463.9999999999995 -103.40455151353103 261.0321336155431 -1463.9999999999995 -102.93757104604563 262.55721026604726
+6 0 8 -1672.5510986913901 -100.94413300620994 -107.70711396027036 -1704.073603002287 -100.94413300620994 -53.108554302678868 -1719.2602564639578 -100.94413300620994 10.921516589757061 -1714.8188405866654 -100.94413300620994 78.680811048363296 -1689.8439574931315 -100.94413300620994 143.09102787927441 -1646.5505315587395 -100.94413300620994 196.92503282599927 -1590.089980757085 -100.94413300620994 234.65107639933154 -1527.0449918289626 -100.94413300620994 253.5141035399626 -1463.9999999999995 -100.94413300620994 253.51411323530812
+6 0 1 -1672.5510986913901 -100.94413300620994 -107.70711396027042 -1650.9749303193912 -80.646240234375028 -95.250107342615991
+6 0 8 -1277.0249585801328 -80.646240234375028 -95.250043198726644 -1305.2862093918868 -80.646240234375028 -144.19998488082297 -1348.1932485067002 -80.646240234375028 -184.69418009325591 -1402.7944635923827 -80.646240234375028 -211.62028428725631 -1463.9999228622419 -80.646240234375028 -221.10232139713321 -1525.2053853850177 -80.646240234375028 -211.62030528448378 -1579.8066097080025 -80.646240234375028 -184.69421982205102 -1622.7136627148063 -80.646240234375028 -144.20003932936683 -1650.9749303193914 -80.646240234375028 -95.250107342615991
+6 0 1 -1255.4487902081337 -100.94413300620994 -107.70704981638067 -1277.0249585801328 -80.646240234375028 -95.250043198726573
+6 0 8 -1463.9999999999995 -80.646240234375028 228.60009999999966 -1407.4774815836604 -80.646240234375028 228.60010969534511 -1350.9549602664806 -80.646240234375028 211.68862142696057 -1300.3356624666883 -80.646240234375028 177.86563418226163 -1261.5212478149786 -80.646240234375028 129.60117015920835 -1239.1301833862383 -80.646240234375028 71.854676707783341 -1235.1482452596836 -80.646240234375028 11.10558663512947 -1248.7637077683785 -80.646240234375028 -46.300101516630185 -1277.0249585801328 -80.646240234375028 -95.250043198726473
+6 0 1 -1463.9999999999998 -100.94413300620994 253.51411323530817 -1463.9999999999995 -80.646240234375028 228.60009999999966
+6 0 8 -1650.9749303193912 -80.646240234375028 -95.250107342615934 -1679.2361979239763 -80.646240234375028 -46.3001753558651 -1692.8516801263427 -80.646240234375028 11.105508124952387 -1688.8697628404525 -80.646240234375028 71.854599563651732 -1666.4787182223031 -80.646240234375028 129.60110069658191 -1627.6643201282675 -80.646240234375028 177.86557803535749 -1577.0450339318375 -80.646240234375028 211.68858264557861 -1520.5225184163387 -80.646240234375028 228.60009030465406 -1463.9999999999995 -80.646240234375028 228.60009999999949
+6 0 8 186.97488467706268 59.531249999999993 -107.95000000000199 158.71364076414397 59.531249999999993 -156.89991034227356 115.80661792501961 59.531249999999993 -197.39407627900849 61.205427771363695 59.531249999999993 -224.32015653457702 -5.6843418860808015e-13 59.531249999999993 -233.80217801408082 -61.20542777136481 59.531249999999993 -224.32015653457671 -115.80661792502059 59.531249999999993 -197.39407627900792 -158.71364076414474 59.531249999999993 -156.89991034227276 -186.97488467706322 59.531249999999993 -107.95000000000104
+6 0 3 186.97488467706268 59.531249999999993 -107.95000000000199 252.96602044543698 109.6472266284147 -146.05000000000192 252.96602044543698 54.823613314207357 -146.05000000000192 252.96602044543698 2.8421709430404007e-14 -146.05000000000192
+6 0 8 252.96602044543698 2.1316282072803006e-14 -146.05000000000192 214.73021985737071 2.1316282072803006e-14 -212.27634928660444 156.67954189855567 2.1316282072803006e-14 -267.06257378924568 82.807343455374451 2.1316282072803006e-14 -303.49197648795604 -4.1211478674085811e-13 2.1316282072803006e-14 -316.32059378375533 -82.807343455375275 2.1316282072803006e-14 -303.49197648795581 -156.67954189855641 2.1316282072803006e-14 -267.06257378924533 -214.73021985737131 2.1316282072803006e-14 -212.27634928660393 -252.96602044543741 2.1316282072803006e-14 -146.05000000000132
+6 0 3 -186.97488467706319 59.531249999999993 -107.95000000000107 -252.96602044543738 109.6472266284147 -146.05000000000121 -252.96602044543738 54.823613314207357 -146.05000000000121 -252.96602044543738 2.8421709430404007e-14 -146.05000000000121
+6 0 8 5.6843418860808015e-13 59.531249999999993 215.90000000000305 56.522487825837722 59.531249999999993 215.9000000000029 113.04497565167483 59.531249999999993 198.98851118892955 163.66424025416373 59.531249999999993 165.16553356678304 202.47862562032583 59.531249999999993 116.9010890070399 224.86966802552769 59.531249999999993 59.154622967792839 228.8515935766944 59.531249999999993 -1.5944349099222208 215.23612858998132 59.531249999999993 -59.00008965773042 186.97488467706259 59.531249999999993 -107.95000000000199
+6 0 3 5.6843418860808015e-13 59.531249999999993 215.90000000000305 4.5474735088646412e-13 109.6472266284147 292.10000000000309 4.5474735088646412e-13 54.823613314207357 292.10000000000309 4.5474735088646412e-13 2.8421709430404007e-14 292.10000000000309
+6 0 8 4.5474735088646412e-13 2.1316282072803006e-14 292.10000000000309 76.471601176132793 2.1316282072803006e-14 292.10000000000298 152.94320235226508 2.1316282072803006e-14 269.21975043208039 221.42808975563219 2.1316282072803006e-14 223.45925129623532 273.94166995691023 2.1316282072803006e-14 158.16029689187724 304.23543321100681 2.1316282072803006e-14 80.032725191719749 309.62274425082063 2.1316282072803006e-14 -2.1571766428356369 291.20182103350311 2.1316282072803006e-14 -79.823650713399431 252.96602044543681 2.1316282072803006e-14 -146.05000000000197
+6 0 3 -186.97488467706319 -59.531249999999993 -107.95000000000107 -252.96602044543738 -109.6472266284147 -146.05000000000121 -252.96602044543738 -54.823613314207357 -146.05000000000121 -252.96602044543738 -2.8421709430404007e-14 -146.05000000000121
+6 0 3 186.97488467706268 -59.531249999999993 -107.95000000000199 252.96602044543698 -109.6472266284147 -146.05000000000192 252.96602044543698 -54.823613314207357 -146.05000000000192 252.96602044543698 -2.8421709430404007e-14 -146.05000000000192
+6 0 8 186.97488467706268 -59.531249999999993 -107.95000000000199 158.71364076414397 -59.531249999999993 -156.89991034227356 115.80661792501961 -59.531249999999993 -197.39407627900849 61.205427771363695 -59.531249999999993 -224.32015653457702 -5.6843418860808015e-13 -59.531249999999993 -233.80217801408082 -61.20542777136481 -59.531249999999993 -224.32015653457671 -115.80661792502059 -59.531249999999993 -197.39407627900792 -158.71364076414474 -59.531249999999993 -156.89991034227276 -186.97488467706322 -59.531249999999993 -107.95000000000104
+6 0 8 -186.97488467706319 59.531249999999993 -107.95000000000107 -215.23612858998166 59.531249999999993 -59.000089657729362 -228.85159357669443 59.531249999999993 -1.594434909921091 -224.86966802552743 59.531249999999993 59.154622967793955 -202.47862562032532 59.531249999999993 116.90108900704088 -163.66424025416296 59.531249999999993 165.16553356678384 -113.04497565167392 59.531249999999993 198.98851118893009 -56.522487825836748 59.531249999999993 215.90000000000313 3.836930773104541e-13 59.531249999999993 215.90000000000296
+6 0 8 -252.96602044543738 2.1316282072803006e-14 -146.05000000000121 -291.20182103350351 2.1316282072803006e-14 -79.823650713398592 -309.6227442508208 2.1316282072803006e-14 -2.1571766428347559 -304.23543321100675 2.1316282072803006e-14 80.032725191720615 -273.94166995690995 2.1316282072803006e-14 158.16029689187798 -221.42808975563173 2.1316282072803006e-14 223.45925129623595 -152.94320235226451 2.1316282072803006e-14 269.21975043208079 -76.471601176132154 2.1316282072803006e-14 292.10000000000315 1.7053025658242404e-13 2.1316282072803006e-14 292.10000000000304
+6 0 3 5.6843418860808015e-13 -59.531249999999993 215.90000000000305 4.5474735088646412e-13 -109.6472266284147 292.10000000000309 4.5474735088646412e-13 -54.823613314207357 292.10000000000309 4.5474735088646412e-13 -2.8421709430404007e-14 292.10000000000309
+6 0 8 5.6843418860808015e-13 -59.531249999999993 215.90000000000305 56.522487825837722 -59.531249999999993 215.9000000000029 113.04497565167483 -59.531249999999993 198.98851118892955 163.66424025416373 -59.531249999999993 165.16553356678304 202.47862562032583 -59.531249999999993 116.9010890070399 224.86966802552769 -59.531249999999993 59.154622967792839 228.8515935766944 -59.531249999999993 -1.5944349099222208 215.23612858998132 -59.531249999999993 -59.00008965773042 186.97488467706259 -59.531249999999993 -107.95000000000199
+6 0 8 -186.97488467706319 -59.531249999999993 -107.95000000000107 -215.23612858998166 -59.531249999999993 -59.000089657729362 -228.85159357669443 -59.531249999999993 -1.594434909921091 -224.86966802552743 -59.531249999999993 59.154622967793955 -202.47862562032532 -59.531249999999993 116.90108900704088 -163.66424025416296 -59.531249999999993 165.16553356678384 -113.04497565167392 -59.531249999999993 198.98851118893009 -56.522487825836748 -59.531249999999993 215.90000000000313 3.836930773104541e-13 -59.531249999999993 215.90000000000296
+6 0 5 -316.20643815364701 -204.77996328310027 -108.91672863601244 -316.4465005389763 -205.00799258105656 -108.05012173534749 -316.684980422693 -205.22252443519886 -107.17887935483914 -316.92177285913169 -205.42332993834077 -106.30324647768506 -317.15677382223845 -205.61018242650164 -105.42346415393791 -317.38988019336466 -205.78285668776223 -104.5397692000348
+6 0 10 -316.20643612917343 -204.77995943860236 -108.91672690359879 -313.14627347795641 -201.87325046549114 -119.96358682453248 -309.85799625667295 -197.01841110676287 -130.34283569124273 -306.49361632869153 -190.52864205028081 -139.74549144009268 -303.22396178258151 -182.78790678286026 -148.06714178687773 -300.17092054219654 -173.97193947631845 -155.31434776600548 -297.47313996001139 -164.25186153349111 -161.44075398218138 -295.28171513788857 -153.71661711905452 -166.36554430275754 -293.78009071594624 -142.43146799987048 -169.94319216265524 -293.23564142193175 -130.63936447650838 -171.84067327161316 -293.74356994954246 -118.80076509921592 -171.84068273570816
+6 0 9 -293.74357295897227 -118.80076617477917 -171.84068273582764 -386.60351837667787 -151.98873954978916 -171.84056739150554 -481.36648286949344 -179.96628196910137 -171.84074256407203 -577.67989282608096 -202.25005026610725 -171.84063565670411 -675.49004440101692 -218.50837628536885 -171.84061699618022 -774.06807064393024 -228.18955322536556 -171.8406468025839 -873.24670020319718 -231.02038399545276 -171.8407130983494 -972.19521611533867 -226.7072918450925 -171.84060055458903 -1070.4057342682495 -215.32825003553967 -171.84066964379522 -1167.3345381169638 -197.14210218568488 -171.84064868506132
+6 0 6 -1167.3345381169638 -197.14210218568485 -171.8406486850613 -1167.3345363925575 -208.76614011912207 -171.84064506130528 -1166.3412775019513 -219.11688750818331 -169.75202864332726 -1164.8153302219348 -228.16966310743763 -166.55397154332897 -1162.8581232511078 -236.26872251059353 -162.53310371417669 -1160.5051955516542 -243.56679407381327 -157.79837921261776 -1157.7293948484078 -250.13401205641134 -152.35908271715081
+6 0 6 -1157.729394848408 -250.13401205641136 -152.35908271715084 -1156.3414944967847 -253.41762104771041 -149.63943446941735 -1154.8478758942133 -256.51851664385401 -146.74364322320687 -1153.2447952509699 -259.44481516893592 -143.67287328228875 -1151.5283552145111 -262.19746587900704 -140.42431214617739 -1149.6877785208728 -264.769283721948 -136.99174912927219 -1147.7173768123801 -267.14524659831125 -133.37325288415474
+6 0 13 -1147.7173768123796 -267.14524659831125 -133.37325288415474 -1147.6889575569687 -267.17951529364342 -133.32106303446554 -1147.6605139203575 -267.2137472073187 -133.26883826642668 -1147.6321446669258 -267.24769705220552 -133.21369981313518 -1147.5953989422774 -267.28239218227225 -133.1853514985539 -1147.6215821999901 -267.30881134424038 -133.04848696400171 -1147.4356201773314 -267.3816506602455 -133.17148837078022 -1147.6627129544775 -267.32590970748578 -132.88413975636988 -1147.3727749677435 -267.47705897774284 -133.03960420308556 -1147.5190081479936 -267.42041004305025 -132.86945347977408 -1147.416591926728 -267.49482857819976 -132.85501541096022 -1147.4038571594426 -267.51990576023405 -132.79733281194916 -1147.375166278307 -267.55376708899422 -132.74475750231301 -1147.3464508428358 -267.58759126776562 -132.69214719264855
+6 0 13 -1147.3464508428387 -267.58759126776494 -132.69214719264747 -1147.3177354073691 -267.62141544653559 -132.63953688298233 -1147.2889954175646 -267.65520247531674 -132.58689157328843 -1147.2484620101475 -267.69501773913055 -132.53858879672785 -1147.263918010415 -267.70543926379776 -132.46600958918074 -1147.1502259218194 -267.78562844092659 -132.45294781937588 -1147.2243850033231 -267.75622855073357 -132.36158604096215 -1147.1100996331247 -267.85568767724357 -132.31593943456963 -1147.1329160309594 -267.83368116606499 -132.28868088201935 -1147.0788702653722 -267.90227875857812 -132.20490211903797 -1147.0605029422934 -267.92232751873718 -132.1675990964811 -1147.0288661362044 -267.95778916775868 -132.1114675259806 -1146.9998770078087 -267.99120367017167 -132.05847327494541 -1146.9708631720339 -268.02458064060352 -132.0054439600116
+6 0 13 -1146.9708631720378 -268.02458064060284 -132.00544396001195 -1146.9128355004937 -268.09133458146556 -131.89938533014464 -1146.8547089994413 -268.15793839440204 -131.7931864446833 -1146.7947340182779 -268.2189631948728 -131.67931225158915 -1146.7346304808657 -268.31297967689733 -131.63593129884626 -1146.7058696435718 -268.31320873755828 -131.30606679000772 -1146.5644108926201 -268.47113412655875 -131.65851348424164 -1146.6371004785367 -268.46161065162568 -130.94306889177017 -1146.4420697812332 -268.55658837260501 -131.37199325544202 -1146.4767853207188 -268.62545978876841 -130.9548217980514 -1146.3790020234433 -268.68345836724291 -130.95770521792022 -1146.3270797400337 -268.75062565102968 -130.83090441285393 -1146.2679497208837 -268.81571220096976 -130.72329920664333 -1146.2087195574068 -268.88064535329147 -130.61555335018298
+6 0 13 -1146.2087195574049 -268.88064535329164 -130.61555335017852 -1146.0902592304474 -269.01051165793513 -130.40006163725226 -1145.9713983261759 -269.13976437210539 -130.18400732332006 -1145.8553472290237 -269.26659415666444 -129.97302236305575 -1145.7332163787303 -269.41037711822452 -129.76283465240007 -1145.58787665878 -269.48106384623964 -129.44872476617658 -1145.5485093243356 -269.72206658299126 -129.49417361363052 -1145.3074933905614 -269.70220295054963 -128.88201009383198 -1145.2984405356167 -269.95274289441085 -129.02879687959961 -1145.0999684262601 -270.00719469744877 -128.59397909882713 -1145.0185006036966 -270.15478137219588 -128.44616890459884 -1144.8837821420539 -270.27485660406273 -128.21467021668701 -1144.7608477520239 -270.39782725028334 -127.99297837767006 -1144.6375022635455 -270.52015500165527 -127.77072224520822
+6 0 13 -1144.6375022635455 -270.52015500165629 -127.77072224520039 -1144.3908112865893 -270.76481050440168 -127.32620998026508 -1144.1424759158404 -271.0068944277549 -126.87944054153293 -1143.8958707466734 -271.2528249641735 -126.4378999189649 -1143.6444089795204 -271.4342825490383 -125.92768997868107 -1143.3759260205509 -271.88040695075642 -125.66407566286748 -1143.1276302292076 -271.63607338167452 -124.85886256949175 -1142.9373994768698 -272.55379295972239 -124.80723939624042 -1142.5157205201599 -272.11238656199316 -124.03328086224309 -1142.4398632598711 -272.77393660063495 -123.73384131525519 -1142.0684603140423 -272.80790824663745 -123.21523287719222 -1141.834801003881 -273.06688159178748 -122.75782658750019 -1141.5696028512014 -273.28185059985384 -122.28852643792052 -1141.3026948488632 -273.49396118356668 -121.8169782393369
+6 0 13 -1141.3026948488621 -273.493961183566 -121.81697823934751 -1140.7688788441837 -273.91818235099191 -120.87388184219517 -1140.2282234408692 -274.33096982100568 -119.9217932490474 -1139.6298769295215 -274.75092900007485 -118.99055591650504 -1139.3888384057511 -275.0120948337044 -117.82868690925443 -1137.8818815586972 -275.76323746233658 -117.39291416505307 -1139.1613441076618 -275.46177746698777 -115.51141760883564 -1136.0296342810191 -276.6642047810405 -115.47948458231609 -1137.9523639683321 -276.15975010850383 -113.70530828860194 -1135.7264451538613 -277.11524102022088 -113.19502744635089 -1135.7490713846589 -277.11842476541295 -111.92025339525543 -1135.0520787058952 -277.49190494401745 -110.95949400684016 -1134.4396852991804 -277.77595496074008 -109.92028540650978 -1133.8202930076031 -278.0455047900727 -108.87285806196536
+6 0 7 -1133.8202930075636 -278.04550479007861 -108.87285806195578 -1016.6567539574046 -295.93511441939222 -112.43134541261628 -897.956759326358 -303.93645574657023 -114.95720357312229 -778.86192810199623 -301.96011509016733 -115.86604802095123 -660.61265176542076 -290.56347096909877 -115.28387111258668 -543.82494002045337 -270.47413621358709 -113.06627024300681 -429.21504938200587 -242.0430794588184 -109.3505401219486 -317.38988019258272 -205.78285669015415 -104.53976920029615
+6 0 5 -309.78843540966716 -195.40683228639682 -104.2103540631517 -310.02293610882492 -195.61649367693423 -103.49019229246917 -310.25545286292714 -195.81421813519194 -102.76617629847468 -310.48587793622721 -195.99980297750787 -102.03850117763828 -310.71410231934794 -196.17304467643444 -101.30736697321541 -310.9400159218917 -196.33373964713471 -100.57297897111363
+6 0 7 -309.78843540966716 -195.40683228639682 -104.2103540631517 -309.638159749078 -197.23535506427714 -104.67185710321915 -309.88492271052507 -199.06387784316118 -105.26264475463886 -310.5374969776384 -200.78551791125903 -105.95573705527222 -311.5699311651955 -202.29332980718351 -106.71282959672202 -312.91983400027681 -203.49619459604827 -107.4881703417654 -314.49861099167993 -204.33376994774403 -108.23606625882728 -316.20643815364701 -204.7799632831003 -108.91672863601242
+6 0 7 -310.94001361478712 -196.33373916212486 -100.57298647091373 -310.83258940908922 -198.15550870655824 -100.9221953681013 -311.11013383651795 -199.97727825135166 -101.38982894126188 -311.77869386571172 -201.69632962914847 -101.95619441020864 -312.81183363252205 -203.2098903765615 -102.59159518027157 -314.14940748817327 -204.42984647839094 -103.25904052398431 -315.70704844364479 -205.29664303957429 -103.92008115635038 -317.38987567278053 -205.78285568131903 -104.5397753315341
+6 0 8 -285.26768282415264 -118.80076617477651 -156.5341304666162 -283.85469985729651 -118.80076617477579 -158.79101407592057 -283.12850946284374 -118.80076617477506 -161.47788273299992 -283.24176858707142 -118.80076617477441 -164.35090550147311 -284.2433356272025 -118.80076617477391 -167.1013620306027 -286.04310502937312 -118.80076617477364 -169.40981990405825 -288.41814446144531 -118.80076617477361 -171.03039855179134 -291.08085921344997 -118.80076617477381 -171.84068604327041 -293.74357295896624 -118.8007661747742 -171.84068273582758
+6 0 10 -309.78843825184066 -195.40683554247929 -104.21035585324884 -306.79940777454573 -192.7342321189457 -113.38979684553559 -303.52290483565531 -188.33838763545199 -122.01482760372051 -300.11378234986734 -182.50046532951472 -129.83029844028346 -296.74162182167026 -175.5619699255854 -136.744446326081 -293.52693037017974 -167.67742022719204 -142.7766563546478 -290.60836293192568 -159.01633891935919 -147.87114421310346 -288.12340079086658 -149.64102798294996 -151.97438329033983 -286.25703316904452 -139.63693106647753 -154.95362204791721 -285.26768795752696 -129.21818042464182 -156.53412216112531 -285.26768282411314 -118.80075657039086 -156.53413046669147
+6 0 1 -309.78843825184066 -195.40683554247929 -104.21035585324884 -309.78843825184066 0 -104.21035585324884
+6 0 1 -310.94001592189176 -196.33373964713473 -100.5729789711136 -310.94001592189176 0 -100.5729789711136
+6 0 5 -309.78843540966716 0 -104.2103540631517 -310.02293610882492 0 -103.49019229246917 -310.25545286292714 0 -102.76617629847468 -310.48587793622721 0 -102.03850117763828 -310.71410231934794 0 -101.30736697321541 -310.9400159218917 0 -100.57297897111363
+6 0 5 -323.47580030578422 -210.30789928940203 -79.95890783014994 -322.50465082332346 -209.50647587798207 -84.950243843897596 -321.40966236848391 -208.65183966083708 -89.908776467310219 -320.19123968248897 -207.74523695069212 -94.829580906345427 -318.85061776719846 -206.78826126621843 -99.708028234820603 -317.38987567278048 -205.78285568131901 -104.53977533153407
+6 0 7 -316.85092502631062 -200.870823904182 -77.118625623185864 -316.7955605635878 -202.66468060997531 -77.397901651739289 -317.11773026744555 -204.4585373231059 -77.752021112893004 -317.82040857848722 -206.15574161205336 -78.165935001874772 -318.87612185914992 -207.65959570658401 -78.618550865604689 -320.22623175555788 -208.88656979781163 -79.084728687685015 -321.78973846881991 -209.77884221916116 -79.539055114143949 -323.47580030578422 -210.30789928940203 -79.95890783014994
+6 0 5 -316.85092502631062 -200.870823904182 -77.118625623185864 -315.90595761020541 -200.06724247449421 -81.885343012204387 -314.84159249818191 -199.21031476064593 -86.61841401977162 -313.65828291428062 -198.30129262103424 -91.313409021742515 -312.35715933820734 -197.34178174731645 -95.966204582687709 -310.94001361478712 -196.33373916212486 -100.57298647091373
+6 0 10 -309.78843825184066 0 -104.21035585324884 -306.79940777454573 0 -113.38979684553559 -303.52290483565531 0 -122.01482760372051 -300.11378234986734 0 -129.83029844028346 -296.74162182167026 0 -136.744446326081 -293.52693037017974 0 -142.7766563546478 -290.60836293192568 0 -147.87114421310346 -288.12340079086658 0 -151.97438329033983 -286.25703316904452 0 -154.95362204791721 -285.26768795752696 0 -156.53412216112531 -285.26768282411314 0 -156.53413046669147
+6 0 1 -285.26768282411314 -118.80075657039089 -156.53413046669147 -285.26768282411314 0 -156.53413046669147
+6 0 8 -285.26768282415264 7.1054273528455211e-15 -156.5341304666162 -283.85469985729651 7.3479838357848286e-13 -158.79101407592057 -283.12850946284374 1.4624913398045055e-12 -161.47788273299992 -283.24176858707142 2.111565241781529e-12 -164.35090550147311 -284.2433356272025 2.60342338177202e-12 -167.1013620306027 -286.04310502937312 2.8771406731661983e-12 -169.40981990405825 -288.41814446144531 2.9080922804021624e-12 -171.03039855179134 -291.08085921344997 2.7096308181274956e-12 -171.84068604327041 -293.74357295896624 2.3234759811865555e-12 -171.84068273582758
+6 0 1 -293.7435729589663 2.3234759811865567e-12 -171.84068273582756 -293.7435729589663 -59.400383087385705 -171.84068273582756
+6 0 1 -293.7435729589663 -59.400383087385705 -171.84068273582756 -293.7435729589663 -118.8007661747742 -171.84068273582756
+6 0 5 -316.85092502631062 0 -77.118625623185864 -315.90595761020541 0 -81.885343012204387 -314.84159249818191 0 -86.61841401977162 -313.65828291428062 0 -91.313409021742515 -312.35715933820734 0 -95.966204582687709 -310.94001361478712 0 -100.57298647091373
+6 0 1 -316.85092502630556 -200.87082390417444 -77.118625623183533 -316.85092502630556 0 -77.118625623183533
+6 0 1 -310.94001361478712 196.33373916212486 -100.57298647091373 -310.94001361478712 0 -100.57298647091373
+6 0 5 -309.78843540966716 195.40683228639682 -104.2103540631517 -310.02293610882492 195.61649367693423 -103.49019229246917 -310.25545286292714 195.81421813519194 -102.76617629847468 -310.48587793622721 195.99980297750787 -102.03850117763828 -310.71410231934794 196.17304467643444 -101.30736697321541 -310.9400159218917 196.33373964713471 -100.57297897111363
+6 0 1 -309.78843825184066 195.40683554247929 -104.21035585324884 -309.78843825184066 0 -104.21035585324884
+6 0 5 -323.96682687943911 -210.7183877435659 -77.363030951164248 -323.8712960935386 -210.63744343677178 -77.882892382083426 -323.77442872279283 -210.55592139791023 -78.402416121201838 -323.67622408804976 -210.47382266557381 -78.92159683938074 -323.57668150927111 -210.39114828120029 -79.440429194251379 -323.47580030578973 -210.30789928940959 -79.958907830152128
+6 0 7 -317.32883271750734 -201.2824176360331 -74.639313893227097 -317.27797470024973 -203.07384551209043 -74.910858659921402 -317.60387824430939 -204.86527339226024 -75.252967652270073 -318.30926390162506 -206.56057298046409 -75.651068144782244 -319.36658986674166 -208.06357162092291 -76.084912570784184 -320.71737528878418 -209.29113824312742 -76.530504932809819 -322.28094166040552 -210.18560932708985 -76.96368758945259 -323.96682687943752 -210.71838774356362 -77.363030951163694
+6 0 5 -317.32883271750575 -201.28241763603086 -74.639313893226401 -317.23582959584058 -201.2012553474305 -75.135882817809232 -317.14153684372849 -201.11951346696316 -75.632103391089956 -317.04595488332063 -201.03719335784982 -76.127970672294197 -316.94908413681367 -200.95429638284139 -76.623479726236738 -316.85092502630562 -200.87082390417442 -77.118625623183547
+6 0 10 -309.78843825184066 195.40683554247929 -104.21035585324884 -306.79940777454573 192.7342321189457 -113.38979684553559 -303.52290483565531 188.33838763545199 -122.01482760372051 -300.11378234986734 182.50046532951472 -129.83029844028346 -296.74162182167026 175.5619699255854 -136.744446326081 -293.52693037017974 167.67742022719204 -142.7766563546478 -290.60836293192568 159.01633891935919 -147.87114421310346 -288.12340079086658 149.64102798294996 -151.97438329033983 -286.25703316904452 139.63693106647753 -154.95362204791721 -285.26768795752696 129.21818042464182 -156.53412216112531 -285.26768282411314 118.80075657039086 -156.53413046669147
+6 0 1 -285.26768282415264 -7.1054273528455211e-15 -156.5341304666162 -285.26768282415264 118.80076617477651 -156.5341304666162
+6 0 8 -285.26768282411314 118.80075657039089 -156.53413046669147 -283.85470005730917 118.80075924973934 -158.79101375780368 -283.12850969968173 118.80076192908783 -161.47788203039045 -283.24177064400726 118.80076431896488 -164.35090803710236 -284.24333667329694 118.80076612997156 -167.10135958350745 -286.043101693898 118.80076713779221 -169.40981449768125 -288.41814241714405 118.800767251758 -171.03039712120912 -291.08085657987874 118.80076652102829 -171.84068524115366 -293.74356994954235 118.80076509921591 -171.84068273570816
+6 0 1 -293.7435729589663 59.400383087385705 -171.84068273582756 -293.7435729589663 118.8007661747742 -171.84068273582756
+6 0 1 -293.7435729589663 -2.3234759811865567e-12 -171.84068273582756 -293.7435729589663 59.400383087385705 -171.84068273582756
+6 0 5 -317.32883271750575 0 -74.639313893226401 -317.23582959584058 0 -75.135882817809232 -317.14153684372849 0 -75.632103391089956 -317.04595488332063 0 -76.127970672294197 -316.94908413681367 0 -76.623479726236738 -316.85092502630562 0 -77.118625623183547
+6 0 1 -317.32883271750575 -201.28241763603086 -74.639313893226401 -317.32883271750575 0 -74.639313893226401
+6 0 1 -316.85092502631062 200.870823904182 -77.118625623185864 -316.85092502631062 0 -77.118625623185864
+6 0 5 -316.85092502631062 200.870823904182 -77.118625623185864 -315.90595761020541 200.06724247449421 -81.885343012204387 -314.84159249818191 199.21031476064593 -86.61841401977162 -313.65828291428062 198.30129262103424 -91.313409021742515 -312.35715933820734 197.34178174731645 -95.966204582687709 -310.94001361478712 196.33373916212486 -100.57298647091373
+6 0 7 -310.94001592189176 196.33373964713473 -100.5729789711136 -310.83259166177237 198.15550952005088 -100.92218808162497 -311.11013619393282 199.97727939930721 -101.38982190415813 -311.7786965757229 201.69633115681293 -101.95618768496949 -312.81183657544443 203.20989180953848 -102.59158859939322 -314.14941099475908 204.42984802755825 -103.25903419692639 -315.70705247713289 205.29664440532446 -103.92007497036965 -317.38988019336455 205.78285668776232 -104.53976920003478
+6 0 5 -316.20643815364701 204.77996328310027 -108.91672863601244 -316.4465005389763 205.00799258105656 -108.05012173534749 -316.684980422693 205.22252443519886 -107.17887935483914 -316.92177285913169 205.42332993834077 -106.30324647768506 -317.15677382223845 205.61018242650164 -105.42346415393791 -317.38988019336466 205.78285668776223 -104.5397692000348
+6 0 8 -309.78843825184066 195.40683554247929 -104.21035585324884 -309.65695002083908 197.00679595927855 -104.61417282244714 -309.82324200664073 198.60675669714399 -105.11495374663804 -310.29279476507986 200.13991152092638 -105.69583410953841 -311.0537201002785 201.53941938083318 -106.33428402420074 -312.07614116940402 202.74438835574628 -107.0035768122432 -313.31452285215556 203.70557544819854 -107.67513893429675 -314.71208561862443 204.38953636763728 -108.32114566471583 -316.20643612917337 204.77995943860239 -108.91672690359877
+6 0 9 -320.4817956915133 -217.12508300189464 38.189116723612898 -323.32507051317492 -217.6143480818647 25.544882454678113 -325.63505960707471 -217.83080241711062 12.768686989014229 -327.37396803893114 -217.75858390849558 -0.1143370801338861 -328.50342303162142 -217.38311423910952 -13.072387973086775 -328.98648403117721 -216.69231809336159 -26.065942898036941 -328.79084154862193 -215.67832396480406 -39.047301198975859 -327.89330891345793 -214.33950432099874 -51.961733052413237 -326.28435986136981 -212.68202745791439 -64.751689591143133 -323.96682687943741 -210.71838774356365 -77.363030951163708
+6 0 9 -278.62999153678902 -204.2814951977212 145.81267994068594 -284.7982214544582 -206.49607135168455 134.63953473009721 -290.64849197438161 -208.54922292531876 123.25607556730002 -296.1592332419728 -210.42700059562335 111.66555465778977 -301.30562435543476 -212.11447395040815 99.871619083633163 -306.05959121036756 -213.59589250809893 87.880404962676778 -310.3899138582143 -214.85471891142092 75.700787773379858 -314.26196315784671 -215.87374273762399 63.3456135503396 -317.63852206449349 -216.63581812749615 50.833345679895466 -320.48179569151335 -217.12508300189464 38.189116723612905
+6 0 7 -273.13409248915633 -194.82218095784921 140.86584214689375 -272.98032926594055 -196.63452061040437 141.14219839851404 -273.17162057074614 -198.44686026367236 141.61054124784906 -273.71645757114021 -200.1590180708636 142.25558964627004 -274.59478689967352 -201.6707622009298 143.04617052851108 -275.75651308586788 -202.89587040103328 143.93719315245468 -277.1292330395861 -203.77544226958398 144.87661087814604 -278.62999153678902 -204.2814951977212 145.81267994068594
+6 0 9 -273.13409248915633 -194.82218095784921 140.86584214689375 -285.2493475660101 -199.26352300438296 119.09128230012169 -296.09354029987423 -203.05785911199212 96.52349583539177 -305.49475470310466 -206.09210185932895 73.19949474775153 -313.24109198563792 -208.24130601273563 49.164299892548875 -319.05706525379736 -209.36476850345596 24.538321739078381 -322.64432543680834 -209.31092543701226 -0.53981765980208607 -323.62095023305426 -207.93018742008687 -25.716488820016988 -321.8411622882212 -205.22024849027659 -50.546760922325404 -317.32883271750728 -201.2824176360331 -74.639313893227083
+6 0 10 -316.20643612917343 204.77995943860236 -108.91672690359879 -313.14627347795641 201.87325046549114 -119.96358682453248 -309.85799625667295 197.01841110676287 -130.34283569124273 -306.49361632869153 190.52864205028081 -139.74549144009268 -303.22396178258151 182.78790678286026 -148.06714178687773 -300.17092054219654 173.97193947631845 -155.31434776600548 -297.47313996001139 164.25186153349111 -161.44075398218138 -295.28171513788857 153.71661711905452 -166.36554430275754 -293.78009071594624 142.43146799987048 -169.94319216265524 -293.23564142193175 130.63936447650838 -171.84067327161316 -293.74356994954246 118.80076509921592 -171.84068273570816
+6 0 1 -317.32883271750575 201.28241763603086 -74.639313893226401 -317.32883271750575 0 -74.639313893226401
+6 0 5 -317.32883271750575 201.28241763603086 -74.639313893226401 -317.23582959584058 201.2012553474305 -75.135882817809232 -317.14153684372849 201.11951346696316 -75.632103391089956 -317.04595488332063 201.03719335784982 -76.127970672294197 -316.94908413681367 200.95429638284139 -76.623479726236738 -316.85092502630562 200.87082390417442 -77.118625623183547
+6 0 7 -316.85092502631062 200.870823904182 -77.118625623185864 -316.7955605635878 202.66468060997531 -77.397901651739289 -317.11773026744555 204.4585373231059 -77.752021112893004 -317.82040857848722 206.15574161205336 -78.165935001874772 -318.87612185914992 207.65959570658401 -78.618550865604689 -320.22623175555788 208.88656979781163 -79.084728687685015 -321.78973846881991 209.77884221916116 -79.539055114143949 -323.47580030578422 210.30789928940203 -79.95890783014994
+6 0 5 -323.47580030578422 210.30789928940203 -79.95890783014994 -322.50465082332346 209.50647587798207 -84.950243843897596 -321.40966236848391 208.65183966083708 -89.908776467310219 -320.19123968248897 207.74523695069212 -94.829580906345427 -318.85061776719846 206.78826126621843 -99.708028234820603 -317.38987567278048 205.78285568131901 -104.53977533153407
+6 0 7 -317.32883271750575 201.28241763603086 -74.639313893226401 -317.27797470018066 203.07384551199317 -74.910858659893165 -317.60387824191906 204.86527338890807 -75.252967651296373 -318.30926384509888 206.56057291323782 -75.651068123647704 -319.36658991103582 208.06357169701383 -76.08491259101848 -320.71737529113199 209.29113824651054 -76.53050493378025 -322.28094166047379 210.18560932718779 -76.963687589480628 -323.96682687943911 210.71838774356593 -77.363030951164234
+6 0 5 -323.96682687943911 210.7183877435659 -77.363030951164248 -323.8712960935386 210.63744343677178 -77.882892382083426 -323.77442872279283 210.55592139791023 -78.402416121201838 -323.67622408804976 210.47382266557381 -78.92159683938074 -323.57668150927111 210.39114828120029 -79.440429194251379 -323.47580030578973 210.30789928940959 -79.958907830152128
+6 0 5 -34.358790302547504 -139.63163068914147 477.69186808626966 -34.29061420731658 -139.90632791864556 476.52092667548965 -34.225124143408358 -140.13482995498282 475.34755783281076 -34.157713885738467 -140.31680235270318 474.17488607618333 -34.083990611446531 -140.45239752428276 473.00572230601557 -33.999875944408352 -140.54225606832352 471.8427278806389
+6 0 6 -33.999876004040836 -140.54225595501973 471.84272787188684 -33.727360011400862 -140.83295726634026 468.07976308763193 -33.603294679633436 -140.98564025288582 464.3165061081209 -33.60000372446455 -140.99873569956759 460.57505204249918 -33.682950665646075 -140.88073394593212 456.86717328572968 -33.818783225007877 -140.63889286956305 453.19585548768748 -33.973723777458751 -140.27781719733821 449.5625160456342
+6 0 5 -34.509202236337359 -138.15819038376185 435.75601051812765 -34.45113392759891 -138.72430240742329 438.46782843902992 -34.350404147017905 -139.21999231783096 441.20527944425453 -34.225157574300638 -139.64515378152001 443.96713003981301 -34.093471508258858 -139.99861361326145 446.75296638660444 -33.973721473615846 -140.27782305619027 449.56257379590983
+6 0 10 -34.50920223565398 -138.1581903847225 435.75601051791261 -34.565818843014235 -137.60548484491244 433.10836972845806 -34.337450478221044 -136.83061147776348 430.53066931435751 -33.788492238002718 -135.84272002842633 428.06424651737257 -32.892258084382988 -134.65778400262863 425.77545611268187 -31.714010937693789 -133.33139483679935 423.71261348331166 -30.326733495434191 -131.89764017981324 421.87296950909854 -28.791377134001117 -130.37094714051651 420.21845971537869 -27.131261673376052 -128.75797394095378 418.7602665881567 -25.387516004644958 -127.06211288351344 417.4775175961916 -23.583587009739119 -125.28273095270234 416.37026832279491
+6 0 7 -11.054505326196171 -111.46526743086991 412.64856964631463 -12.770727059096902 -113.72015824878395 412.58059164315307 -14.56009947756135 -115.87342273089918 412.74886082471335 -16.385425707706755 -117.92973773788434 413.12205410782877 -18.221695688633258 -119.89426672994469 413.67909376005952 -20.048859229583144 -121.77238432549201 414.40765358217806 -21.845533310462734 -123.5683295464374 415.30344782211654 -23.583643625726857 -125.28278775010698 416.37030282037563
+6 0 8 -7.4656661518002343 -97.980315564695715 379.92805336760523 -7.5928863059462994 -99.665937735306045 384.09350383384879 -7.8131627449813497 -101.35155990591637 388.23545638389021 -8.1259019462101385 -103.0371820765267 392.35506628923991 -8.5304945976454132 -104.72280424713703 396.45334042591452 -9.0263137333102872 -106.40842641774736 400.53114727121033 -9.6127128607013166 -108.09404858835769 404.58922678232562 -10.289024151198378 -109.77967075896802 408.62820005648018 -11.054556745843367 -111.46529292957835 412.64857869464072
+6 0 12 -7.4656659664160241 -97.980315285412019 379.92805342629589 -12.580898769473119 -103.00688835936552 377.30124891242792 -18.031766428146803 -107.59929465435188 374.77694060095001 -23.75728032526667 -111.82800959752898 372.28636919676018 -29.722263347304764 -115.65689975398681 369.79042996638003 -35.908977289554585 -119.14128450888994 367.31856916122302 -42.324638791008979 -122.21683198146664 364.82332359144698 -48.828632224781245 -124.76641587356893 362.23161525447392 -55.281142888494131 -126.97674196703848 359.52540742430818 -61.706875775586226 -128.89983507675876 356.74879879526941 -68.055066671082031 -130.61280152060877 353.88787929200038 -74.303712981984205 -132.20398448020308 350.96622120302015 -80.415410045478296 -133.75949378479842 347.99545348933452
+6 0 6 -80.415410045294976 -133.7594937840615 347.99545348868344 -82.882572643572274 -134.38747653318055 346.79613985540385 -85.324323194752679 -135.00887448296777 345.58655032813846 -87.737014643962979 -135.63210494608239 344.36860607764629 -90.117239598417882 -136.26573334960074 343.14493153870689 -92.459360791011974 -136.91904992138964 341.91724537727271 -94.753041543911692 -137.60264637648004 340.68475145762187
+6 0 5 -313.75750323429349 -173.62366029293838 358.23074660924942 -268.77411693122991 -166.89656718327984 355.05036674787607 -224.39088609021937 -160.91313669662321 351.5974283794074 -180.62840577955401 -154.6149359010476 347.99072349531542 -137.41996349033909 -147.10217960240846 344.32476418024538 -94.753055650611827 -137.60264386929208 340.68475305383549
+6 0 3 -136.32744173928495 -196.58177896335116 594.49203619044442 -151.15496347301413 -269.48678633711421 544.52165163321888 -244.59065761705725 -149.47019566886306 392.35831773885911 -313.75750194863338 -173.62366946880476 358.2307458646697
+6 0 8 -34.35874715064493 -139.63162176055033 477.69188796372373 -42.798428388612535 -146.75039141121195 493.59827698172057 -52.643404368387138 -153.86916106187357 509.18819976485781 -63.819064942347211 -160.98793071253519 524.44230202991253 -76.240428225220711 -168.10670036319681 539.32804899153984 -89.81153263521044 -175.22547001385843 553.8087153751809 -104.42627142755609 -182.34423966452005 567.84940362830798 -119.97100673008121 -189.46300931518167 581.41934813029798 -136.3274417450115 -196.58177896584328 594.49203619502123
+6 0 9 -273.13409248915633 194.82218095784921 140.86584214689375 -285.2493475660101 199.26352300438296 119.09128230012169 -296.09354029987423 203.05785911199212 96.52349583539177 -305.49475470310466 206.09210185932895 73.19949474775153 -313.24109198563792 208.24130601273563 49.164299892548875 -319.05706525379736 209.36476850345596 24.538321739078381 -322.64432543680834 209.31092543701226 -0.53981765980208607 -323.62095023305426 207.93018742008687 -25.716488820016988 -321.8411622882212 205.22024849027659 -50.546760922325404 -317.32883271750728 201.2824176360331 -74.639313893227083
+6 0 7 -273.13409248915661 194.82218095784944 140.86584214689373 -272.98032926594624 196.63452061041397 141.14219839851893 -273.17162057106486 198.44686026421596 141.61054124813478 -273.71645758350445 200.15901808849722 142.25558965667068 -274.59478689021483 201.67076218100249 143.04617051926897 -275.75651308555325 202.8958704004869 143.93719315217049 -277.1292330395807 203.77544226957463 144.87661087814115 -278.62999153678902 204.28149519772123 145.81267994068594
+6 0 9 -278.62999153678902 204.2814951977212 145.81267994068594 -284.7982214544582 206.49607135168455 134.63953473009721 -290.64849197438161 208.54922292531876 123.25607556730002 -296.1592332419728 210.42700059562335 111.66555465778977 -301.30562435543476 212.11447395040815 99.871619083633163 -306.05959121036756 213.59589250809893 87.880404962676778 -310.3899138582143 214.85471891142092 75.700787773379858 -314.26196315784671 215.87374273762399 63.3456135503396 -317.63852206449349 216.63581812749615 50.833345679895466 -320.48179569151335 217.12508300189464 38.189116723612905
+6 0 9 -320.4817956915133 217.12508300189464 38.189116723612898 -323.32507051317492 217.6143480818647 25.544882454678113 -325.63505960707471 217.83080241711062 12.768686989014229 -327.37396803893114 217.75858390849558 -0.1143370801338861 -328.50342303162142 217.38311423910952 -13.072387973086775 -328.98648403117721 216.69231809336159 -26.065942898036941 -328.79084154862193 215.67832396480406 -39.047301198975859 -327.89330891345793 214.33950432099874 -51.961733052413237 -326.28435986136981 212.68202745791439 -64.751689591143133 -323.96682687943741 210.71838774356365 -77.363030951163708
+6 0 5 -16.606510994248268 -106.93972034396965 420.34682837281952 -18.738408156836872 -108.92909308502851 420.4381820900731 -21.0348405277464 -110.81767455324831 420.82656237463061 -23.37788980764363 -112.6301242247303 421.46332404163712 -25.721207449671255 -114.36569527554879 422.33903563084675 -27.971618427495201 -116.03319449982922 423.48475710136421
+6 0 7 -16.60656305100165 -106.93973691840851 420.34682913393948 -15.247470656095761 -107.95887351819775 420.39362978882747 -13.888378257903423 -109.00009028635482 419.95961017748073 -12.660072685030379 -109.96531236349998 419.04031712423205 -11.693664103654603 -110.75305213267792 417.70032309496492 -11.087711295544942 -111.28297227746012 416.07628682972671 -10.880253281264524 -111.51868338857544 414.33817320497229 -11.054556756727662 -111.46529292133577 412.64857869602395
+6 0 8 -27.971565508486442 -116.03315610316049 423.48472978526212 -26.484556867557089 -117.03715922808671 424.17456165867424 -24.997543329640685 -118.3828090026098 424.36716067641385 -23.681389650192585 -119.95475884652824 423.98323488907363 -22.707003372672983 -121.5826298031136 423.02352576460652 -22.204251439466795 -123.06847064961183 421.58827263528252 -22.219095237510714 -124.23959786359893 419.86231593240063 -22.712254065940947 -124.98892953157527 418.05832774492154 -23.583587009739134 -125.28273095270242 416.37026832279474
+6 0 8 -38.442757264327575 -125.6818036630418 438.57205112772903 -36.21603690141206 -125.68439606531021 438.58345093637519 -33.98931643791714 -126.4763729470238 438.41533903796369 -32.10594602893373 -128.05735102285848 438.06595389268773 -30.909137322329531 -130.25700632081544 437.57218044081037 -30.632286134923476 -132.7314818281678 437.01095756586915 -31.280335703970501 -135.06867457034636 436.4759738320887 -32.667314470533896 -136.94017692837051 436.04291282124188 -34.50920223565398 -138.15819038472253 435.75601051791261
+6 0 8 -27.97156577868795 -116.0331554894704 423.48473028757149 -30.05694981259122 -117.57913133100853 424.54694879536265 -32.073220905452914 -119.06461139277904 425.81676023551421 -33.947937084578676 -120.49951637861221 427.31615272351837 -35.654661170034124 -121.85539123947756 429.06941991354267 -37.066608783696736 -123.13785339465556 431.09648418395869 -38.000290756379819 -124.23900231328859 433.45822106002299 -38.425388369842892 -125.09142976885845 435.97594196404935 -38.442757260272018 -125.68180366298387 438.57205112776415
+6 0 5 -38.442757260314359 -125.68180366155485 438.57205112811948 -38.456928426054965 -126.25011636973501 441.07114846769633 -38.438931908052112 -126.7594268491807 443.58632756419536 -38.406946079737899 -127.21052087623191 446.11470172711472 -38.378552067822078 -127.60393548243539 448.6537674808219 -38.370950384253881 -127.93965552933948 451.20111679305325
+6 0 8 -38.370950384253888 -127.93965552933948 451.20111679305325 -36.216373463337654 -127.93886402336064 451.1951098688553 -34.061795577271305 -128.68949419361149 451.09007164153763 -32.218249687519048 -130.19169943865003 450.88686410776904 -30.996706951403816 -132.29399721076362 450.60633348039909 -30.614836236261908 -134.69071101581758 450.28938284502982 -31.097005601303049 -137.00838687552928 449.98529953350146 -32.297310708485796 -138.93534699030883 449.73474631652982 -33.973721473615839 -140.27782305619021 449.56257379590983
+6 0 8 -39.397452338435848 -129.14574688288408 471.03845733812932 -37.443178046916806 -129.14313378470939 471.28606526321067 -35.488900755181533 -129.77404400857898 471.54036193436554 -33.77044267076559 -131.03882651985739 471.77146886748022 -32.523640781885192 -132.83080576746195 471.94837580373382 -31.924995632949617 -134.93532609775036 472.04645130073789 -32.029162436178993 -137.07897805619481 472.05588323727972 -32.770257225248962 -139.00959629273393 471.98235787504478 -33.999876004040829 -140.54225595501973 471.84272787188684
+6 0 6 -39.397452338435848 -129.14574688288408 471.03845733812932 -38.959211285482795 -129.18047845662304 467.74866610985998 -38.656084324560254 -129.12002251494496 464.43785229895951 -38.473134722766801 -128.96416668325045 461.11924240231639 -38.384677846596539 -128.71547298816981 457.80284446842131 -38.36118750567028 -128.37381202973322 454.49536570065686 -38.370950400308594 -127.93964850496354 451.20106442617322
+6 0 8 -40.021144853065948 -128.79173811216748 475.37790691687883 -38.116506372608491 -128.759074002912 475.5901950688197 -36.21186753071612 -129.31923504576693 475.89369949697561 -34.524823455975834 -130.47596446818065 476.26416914701952 -33.272931250328064 -132.13827010287048 476.66278065121298 -32.622002397967087 -134.11868512051598 477.04177040834071 -32.63148623909423 -136.17344176128165 477.35684759314483 -33.25254624419069 -138.07053707367757 477.57788672009457 -34.358790302547511 -139.6316306891415 477.69186808626966
+6 0 5 -40.021144853065948 -128.79173811216748 475.37790691687883 -39.900397710009635 -128.92405438820785 474.51796769214792 -39.780934831392052 -129.02575047854174 473.65182101904088 -39.659584862579131 -129.09659186898381 472.78184227483069 -39.532959251891633 -129.13654483453928 471.91006743790132 -39.397452399782757 -129.14574677916761 471.03845732912373
+6 0 10 -29.727320377057946 -117.16625635375637 504.60593211599002 -31.071383854858109 -120.5635661920174 503.76468087945887 -32.251025263755494 -123.90701465989967 502.37914598106778 -33.232671712223542 -127.09560318998268 500.4474894114818 -34.005854308953133 -130.03665500610524 498.01923337544173 -34.548974446302417 -132.62256630264548 495.16610985272195 -34.884156989860323 -134.82559794303813 491.99571566895639 -35.023794172750051 -136.62805890058198 488.59827224568636 -34.976472534500331 -138.02625613639239 485.03747530142203 -34.753069622075003 -139.02491896288993 481.38311758727093 -34.358747150646288 -139.63162176054323 477.69188796372202
+6 0 7 -35.568095716008983 -112.64804699763897 495.2800949963202 -33.677180111598318 -113.36922521805059 495.11228769763903 -31.786264266506297 -114.24616759161172 495.61390087562472 -30.155020928942804 -115.17980161458178 496.80782569740541 -29.044891695574822 -116.03855682858978 498.58034454251276 -28.62212967468222 -116.69382593343212 500.66600474235025 -28.88798319693645 -117.07397210495053 502.75909270827066 -29.727320322740713 -117.16625638448774 504.60593215421267
+6 0 10 -35.568095630307504 -112.64804701144766 495.28009490391821 -36.886033560129007 -114.96625309318358 494.74068336270517 -38.041207852907689 -117.26030456497163 493.82394541675473 -39.000850671402553 -119.49378269080151 492.52090674725429 -39.753918132534565 -121.62592371477916 490.80061710357245 -40.277463727707662 -123.49631371991134 488.78231171513517 -40.598175635169355 -125.18006222006457 486.40009288541796 -40.721773783866247 -126.52974101221413 483.83887513801301 -40.661575949602963 -127.5961151562741 481.10066830396147 -40.426143296962643 -128.34796117273453 478.2620512576803 -40.021106745728879 -128.7917345555492 475.37793002302698
+6 0 7 -13.244107433710266 -37.256166894002426 513.0476837176144 -14.251052356417217 -48.84601620598518 513.55015173013442 -15.411814898047222 -60.523279677135406 513.42898251464669 -16.93868348642669 -72.218682409168338 512.70597254154359 -19.038946537067989 -83.868454267182727 511.39862702386199 -21.893340045145308 -95.316741093693381 509.55342204775792 -25.480815111292443 -106.4327529676558 507.26376557929768 -29.727320322740717 -117.16625638448777 504.60593215421278
+6 0 7 -19.323704737760004 -37.194229928492078 502.6059250478105 -17.249101176890914 -37.376383355160826 502.6141755268676 -15.174497555438135 -37.525828084340922 503.34455697459623 -13.39949524512974 -37.616267300855377 504.79568688568054 -12.226021544516943 -37.628222270247171 506.81113767691232 -11.839850284279393 -37.559800388993764 509.07184125683165 -12.228066977321456 -37.4275360227834 511.23784331340624 -13.244107440865719 -37.256166893556717 513.04768371355533
+6 0 7 -19.323704752184224 -37.19422992968795 502.60592506491372 -20.323551678060465 -48.246590580238419 503.10653838988878 -21.480321293091507 -59.324737256134902 503.03186583247219 -23.001532805420723 -70.366134600355878 502.4084618023864 -25.080050330638596 -81.319211284189421 501.26614427711854 -27.887241884327569 -92.065241174870096 499.65039788167593 -31.4041981702442 -102.52028670986658 497.63667217944118 -35.568095716008983 -112.648046997639 495.2800949963202
+6 0 9 -7.8557272118926749 -19.587331847074168 504.48117843502439 -8.7282533636212687 -21.045771211874865 506.07369581108924 -9.5623034892277108 -22.644109973602703 507.55654504232399 -10.347916438771367 -24.381725824092044 508.91263809360436 -11.069251500686967 -26.260254606204267 510.11884797354435 -11.718777342724213 -28.271120194011729 511.15326518382932 -12.269400884835925 -30.403612372531505 511.98608136291728 -12.718200563845391 -32.637092576756515 512.59187382779157 -13.042041273320988 -34.933354424619736 512.94702109518187 -13.24410744086572 -37.25616689355671 513.04768371355533
+6 0 7 -14.037858895078889 -24.607201894381994 496.44272783807384 -12.291458844587384 -25.08439417250975 496.95786614299345 -10.545057436481201 -25.128389679734273 497.87429224249041 -9.0047694840459016 -24.682935195908058 499.1311467255095 -7.8776560916867489 -23.767722928008421 500.59670032189774 -7.3067796499822872 -22.498919054008287 502.08493306024781 -7.3204997481477188 -21.047992175043905 503.42146335572704 -7.8557272118926855 -19.587331847074196 504.48117843502507
+6 0 9 -14.037858895078896 -24.607201894381969 496.44272783807361 -14.891619296528024 -25.705564968610005 497.62843243564259 -15.70784160895187 -26.894615842663907 498.71828189185089 -16.478217809351801 -28.17145084177335 499.70078090671331 -17.183681533967214 -29.52755316142748 500.56033393163625 -17.821323143937633 -30.961861732637477 501.28903670362149 -18.363191088736162 -32.465012631003233 501.86959847486241 -18.80251885874404 -34.01559554263261 502.28703652004015 -19.123469384950106 -35.595504107172026 502.53351124620576 -19.323704737760007 -37.194229928492085 502.6059250478105
+6 0 7 0.65801684601483679 -11.361801140743037 487.37786005027601 -0.57129492912020408 -11.855408378330562 490.08403767571508 -1.8179071266544411 -12.572820160116731 492.7389559349723 -3.0712270670804869 -13.513367553184198 495.32385328691817 -4.3189461876058797 -14.679412220814108 497.81786340124404 -5.546313799263884 -16.076662425365821 500.19837465515707 -6.7339078739559284 -17.712195520901876 502.43365609437024 -7.8557272118926882 -19.5873318470742 504.48117843502502
+6 0 7 -5.7181839263646301 -18.199087263369609 483.21112289684015 -4.2208551753306303 -18.321231821939769 483.86864682750257 -2.7235264206194643 -18.002706893633409 484.60803147583971 -1.3603815553147931 -17.232605191170968 485.37034529320999 -0.26587511423412358 -16.058951173144237 486.08558636030722 0.45650798005283222 -14.592713117692586 486.68612906647337 0.76139594104049313 -12.978696755838602 487.12446193399131 0.65801719783327794 -11.361800804120907 487.37786027263405
+6 0 7 -5.7181836133926129 -18.199086884286448 483.21112311235152 -6.9181489100715332 -18.59730675769686 485.35480471481736 -8.135180571372425 -19.172687841589958 487.44513591622575 -9.3598407891388113 -19.925064533204015 489.47171361377264 -10.579109129142731 -20.848058013593569 491.40755245894115 -11.778458804727677 -21.938433322174838 493.22927283717098 -12.940166950358586 -23.195020798945951 494.91825049834222 -14.037858895078891 -24.607201894381998 496.44272783807378
+6 0 6 -5.7181839263646301 -18.199087263369609 483.21112289684015 -2.6155665943422681 -16.981888936021772 476.65874725421008 0.29029118954656496 -16.066592452889239 469.96892968491636 2.9776430867361356 -15.478561261332059 463.15681192665454 5.4219910559138764 -15.244600028524658 456.25473696035095 7.6031662675656335 -15.427208255963787 449.30479390142165 9.4995959555508005 -16.095088723516607 442.37551491903065
+6 0 6 0.65801719783327783 -11.361800804120909 487.37786027263405 3.8365592271244977 -10.085544594252919 480.38081609253015 6.8160799422998544 -9.1259143880355733 473.22664245139617 9.5737318030555478 -8.5090453379288356 465.93067969178611 12.084133007297586 -8.2618924592265159 458.51213805366359 14.325751737508606 -8.4532156960853726 451.00057688828326 16.275579533502999 -9.1691331706917847 443.4601487523355
+6 0 7 9.4995959541939978 -16.095088726156845 442.37551492134628 10.991743322032354 -16.058240530604269 442.75781600761252 12.483890692255907 -15.627548253557167 443.10215632372791 13.85798283934483 -14.805952450525027 443.37829152794581 14.995798030502488 -13.642954141570595 443.56042196484896 15.803020744840405 -12.234956320918162 443.63345051922937 16.230803607885143 -10.703224794913663 443.59643404175318 16.275579534266285 -9.1691331699569663 443.46014875246169
+6 0 7 9.4995959561621337 -16.095088726108443 442.37551492185059 10.27327923367112 -16.329780159547088 439.94058459330108 10.995197313642704 -16.792287365228333 437.5203818796785 11.65754127297798 -17.483142672887336 435.15431402244383 12.253608090455561 -18.404715757177655 432.87175835145064 12.776763158541312 -19.55321111065631 430.71290648344973 13.21900321085867 -20.915390416286314 428.72832353454908 13.569119665319541 -22.47001981945666 426.95722234662929
+6 0 7 16.275579534266285 -9.169133169956968 443.46014875246181 17.071088320257548 -9.4611967344734218 440.383908533019 17.81360980363727 -10.036340322689345 437.32086835311844 18.495088374932891 -10.899453675499686 434.30312034261766 19.108600632090454 -12.060419026246615 431.36629697938747 19.647367225078391 -13.526458622666222 428.55426453170452 20.103180530579717 -15.304000911476283 425.92146323073524 20.464446763912168 -17.382301785281584 423.53295362568264
+6 0 7 13.569119665290897 -22.470019828989134 426.95722234941513 14.999290021244205 -22.362910715498302 427.07924568538346 16.429460462399547 -21.996300434853165 426.97348524176613 17.760879996538208 -21.377595885764617 426.63152531844293 18.894700172739942 -20.541006513530991 426.06846211459867 19.749439394791853 -19.546653525072969 425.32475997332841 20.277007277985543 -18.468746315077244 424.45829357151291 20.464446763912161 -17.382301785281587 423.53295362568309
+6 0 7 13.569119665290897 -22.470019828989134 426.95722234941513 13.91923610549996 -24.024649463393718 425.18612123240308 14.177166153290989 -25.771261497735555 423.62907278740505 14.332636252411508 -27.687824551852213 422.33052864091883 14.37095093592982 -29.729863529004835 421.33284388591176 14.276869180631051 -31.876943078403258 420.66079027120691 14.044308563135919 -34.040369124664394 420.32952872938404 13.68630496254543 -36.203227399723716 420.32952878093175
+6 0 7 20.464446763912164 -17.382301785281591 423.53295362568304 20.825712997244612 -19.460602659086891 421.14444402063043 21.092373516632822 -21.839623300245339 419.00017405671696 21.253787147383999 -24.506753793506387 417.16253409711339 21.294512106866634 -27.438336634538963 415.708382080609 21.198652320526257 -30.5685265891196 414.70729385388967 20.958655172469349 -33.790464369858775 414.20151699403721 20.588225703657944 -37.004673740388689 414.17874845420977
+6 0 7 13.686304969104579 -36.203227412627321 420.32952879794681 15.125812257636801 -36.370382017055647 420.329528734782 16.565319887591933 -36.537536661129771 419.97950805500437 17.904071637580145 -36.692991601149714 419.2794819987347 19.041204243361939 -36.82503466367271 418.26610425269138 19.893835480389264 -36.924041621319915 417.01323691657296 20.413588790452515 -36.984395021150576 415.61722426196923 20.588225694904036 -37.004673739372237 414.17874846422012
+6 0 3 -15.799639988582662 -106.18558155641682 420.3295284400715 -16.06840867657246 -106.43727123033514 420.32952843986419 -16.337472981393091 -106.68864546708754 420.33529854477837 -16.606563063487162 -106.939736909046 420.34682913351037
+6 0 7 -15.799640023409577 -106.18558160289922 420.32952880859347 -14.465032464268194 -107.18554939286349 420.3295288085435 -13.130424901558564 -108.18551718550131 419.86600998393055 -11.919500759094388 -109.09281396368934 418.93901667721366 -10.956218058192768 -109.81456296543409 417.61270435899183 -10.334957512026477 -110.28004851666358 416.0170227339222 -10.094831910002396 -110.45996497669348 414.31234317570954 -10.223914016867198 -110.36324894339859 412.65249476803058
+6 0 5 -10.223913988498131 -110.3632489646543 412.65249476461571 -10.390061809216247 -110.5840209756356 412.64649754193402 -10.55622442465488 -110.80462841530679 412.64314057286055 -10.722377015984884 -111.02505430351088 412.64239057910191 -10.88849554788237 -111.24528154249582 412.64421432477701 -11.054556756727663 -111.4652929213358 412.648578696024
+6 0 7 13.686304975710939 -36.203227413394352 420.32952880859307 12.418543614771419 -47.121047048457882 420.32952880859307 10.293672678766825 -57.935923620035581 420.32952954297508 7.0403839252150018 -68.558774651835392 420.32952819415453 2.4282691448990814 -78.699127628000483 420.32952829237161 -3.0613866820009532 -88.257852934395459 420.32952941465794 -9.2090792109000574 -97.389531824623191 420.32952880859381 -15.799640023409868 -106.18558160289895 420.32952880859381
+6 0 9 20.58822569490404 -37.004673739372244 414.17874846422018 19.56796303802453 -45.8575118138207 414.11603636342574 18.020296718846573 -54.730195421727103 414.02045540160447 15.820932269577023 -63.552141527511665 413.88515701006611 12.846497497858962 -72.225533437320522 413.70208285524143 9.1308320890922587 -80.563894706114823 413.48673874995433 4.8298574045697924 -88.493365345953691 413.2635216777503 0.10753781981496147 -96.07631783827587 413.04752956366764 -4.9425939531873047 -103.34525640479107 412.84186156191879 -10.223914016867194 -110.36324894339859 412.65249476803069
+6 0 8 -34.35874715064493 139.63162176055033 477.69188796372373 -42.798428388612535 146.75039141121195 493.59827698172057 -52.643404368387138 153.86916106187357 509.18819976485781 -63.819064942347211 160.98793071253519 524.44230202991253 -76.240428225220711 168.10670036319681 539.32804899153984 -89.81153263521044 175.22547001385843 553.8087153751809 -104.42627142755609 182.34423966452005 567.84940362830798 -119.97100673008121 189.46300931518167 581.41934813029798 -136.3274417450115 196.58177896584328 594.49203619502123
+6 0 3 -313.75750194863252 173.62366946881164 358.2307458646705 -244.59065761705642 149.47019566886991 392.35831773885985 -151.15496347301416 269.48678633711415 544.52165163321888 -136.32744173928501 196.58177896335101 594.49203619044454
+6 0 5 -313.75750323429349 173.62366029293838 358.23074660924942 -268.77411693122991 166.89656718327984 355.05036674787607 -224.39088609021937 160.91313669662321 351.5974283794074 -180.62840577955401 154.6149359010476 347.99072349531542 -137.41996349033909 147.10217960240846 344.32476418024538 -94.753055650611827 137.60264386929208 340.68475305383549
+6 0 6 -80.415410045294976 133.7594937840615 347.99545348868344 -82.882572643572274 134.38747653318055 346.79613985540385 -85.324323194752679 135.00887448296777 345.58655032813846 -87.737014643962979 135.63210494608239 344.36860607764629 -90.117239598417882 136.26573334960074 343.14493153870689 -92.459360791011974 136.91904992138964 341.91724537727271 -94.753041543911692 137.60264637648004 340.68475145762187
+6 0 12 -7.4656659664160241 97.980315285412019 379.92805342629589 -12.580898769473119 103.00688835936552 377.30124891242792 -18.031766428146803 107.59929465435188 374.77694060095001 -23.75728032526667 111.82800959752898 372.28636919676018 -29.722263347304764 115.65689975398681 369.79042996638003 -35.908977289554585 119.14128450888994 367.31856916122302 -42.324638791008979 122.21683198146664 364.82332359144698 -48.828632224781245 124.76641587356893 362.23161525447392 -55.281142888494131 126.97674196703848 359.52540742430818 -61.706875775586226 128.89983507675876 356.74879879526941 -68.055066671082031 130.61280152060877 353.88787929200038 -74.303712981984205 132.20398448020308 350.96622120302015 -80.415410045478296 133.75949378479842 347.99545348933452
+6 0 10 -7.4656658231323378 97.980315439028629 379.9280534474633 -7.5674411696677746 99.32881069000338 383.26040839428595 -7.7271172446933081 100.67730594097813 386.5781433823459 -7.9444166775496337 102.02580119195288 389.88179801842421 -8.2190571745129279 103.37429644292763 393.17186202864576 -8.5507509843252834 104.72279169390238 396.44877762685695 -8.9392043902936074 106.07128694487713 399.71294183347499 -9.3841172292952191 107.41978219585188 402.96470874347705 -9.8851824380283428 108.76827744682663 406.20439174219734 -10.442085626845731 110.11677269780138 409.43226566760069 -11.054504681509622 111.46526794877613 412.6485689177004
+6 0 7 -11.054505326196171 111.46526743086991 412.64856964631463 -12.770727059096902 113.72015824878395 412.58059164315307 -14.56009947756135 115.87342273089918 412.74886082471335 -16.385425707706755 117.92973773788434 413.12205410782877 -18.221695688633258 119.89426672994469 413.67909376005952 -20.048859229583144 121.77238432549201 414.40765358217806 -21.845533310462734 123.5683295464374 415.30344782211654 -23.583643625726857 125.28278775010698 416.37030282037563
+6 0 10 -34.50920223565398 138.1581903847225 435.75601051791261 -34.565818843014235 137.60548484491244 433.10836972845806 -34.337450478221044 136.83061147776348 430.53066931435751 -33.788492238002718 135.84272002842633 428.06424651737257 -32.892258084382988 134.65778400262863 425.77545611268187 -31.714010937693789 133.33139483679935 423.71261348331166 -30.326733495434191 131.89764017981324 421.87296950909854 -28.791377134001117 130.37094714051651 420.21845971537869 -27.131261673376052 128.75797394095378 418.7602665881567 -25.387516004644958 127.06211288351344 417.4775175961916 -23.583587009739119 125.28273095270234 416.37026832279491
+6 0 5 -34.509202236337359 138.15819038376185 435.75601051812765 -34.45113392759891 138.72430240742329 438.46782843902992 -34.350404147017905 139.21999231783096 441.20527944425453 -34.225157574300638 139.64515378152001 443.96713003981301 -34.093471508258858 139.99861361326145 446.75296638660444 -33.973721473615846 140.27782305619027 449.56257379590983
+6 0 6 -33.999876004040836 140.54225595501973 471.84272787188684 -33.727360011400862 140.83295726634026 468.07976308763193 -33.603294679633436 140.98564025288582 464.3165061081209 -33.60000372446455 140.99873569956759 460.57505204249918 -33.682950665646075 140.88073394593212 456.86717328572968 -33.818783225007877 140.63889286956305 453.19585548768748 -33.973723777458751 140.27781719733821 449.5625160456342
+6 0 5 -34.358790302547504 139.63163068914147 477.69186808626966 -34.29061420731658 139.90632791864556 476.52092667548965 -34.225124143408358 140.13482995498282 475.34755783281076 -34.157713885738467 140.31680235270318 474.17488607618333 -34.083990611446531 140.45239752428276 473.00572230601557 -33.999875944408352 140.54225606832352 471.8427278806389
+6 0 7 -16.60656305100165 106.93973691840851 420.34682913393948 -15.247470656095761 107.95887351819775 420.39362978882747 -13.888378257903423 109.00009028635482 419.95961017748073 -12.660072685030379 109.96531236349998 419.04031712423205 -11.693664103654603 110.75305213267792 417.70032309496492 -11.087711295544942 111.28297227746012 416.07628682972671 -10.880253281264524 111.51868338857544 414.33817320497229 -11.054556756727662 111.46529292133577 412.64857869602395
+6 0 5 -10.223913988498131 110.3632489646543 412.65249476461571 -10.390061809216247 110.5840209756356 412.64649754193402 -10.55622442465488 110.80462841530679 412.64314057286055 -10.722377015984884 111.02505430351088 412.64239057910191 -10.88849554788237 111.24528154249582 412.64421432477701 -11.054556756727663 111.4652929213358 412.648578696024
+6 0 7 -15.799640019991951 106.18558153288312 420.32952844003808 -14.465032505747359 107.18554930657885 420.32952844811547 -13.130424959200477 108.18551710447767 419.86600962025818 -11.919500368674774 109.0928142341417 418.93901553806228 -10.956218829556493 109.81456237794762 417.61270488847958 -10.33495763956476 110.28004841965671 416.01702266678052 -10.094831956559974 110.45996494348869 414.31234313539449 -10.223913988498131 110.3632489646543 412.65249476461565
+6 0 5 -15.799640019991951 106.18558153288312 420.32952844003808 -15.960898412836441 106.33659744999154 420.32952844019195 -16.122250044865815 106.48751522092711 420.33125985588339 -16.283664830585931 106.63834064755412 420.33472089378978 -16.445112581361943 106.7890793691422 420.33991065751547 -16.60656305100165 106.93973691840851 420.34682913393937
+6 0 9 20.58822569490404 37.004673739372244 414.17874846422018 19.56796303802453 45.8575118138207 414.11603636342574 18.020296718846573 54.730195421727103 414.02045540160447 15.820932269577023 63.552141527511665 413.88515701006611 12.846497497858962 72.225533437320522 413.70208285524143 9.1308320890922587 80.563894706114823 413.48673874995433 4.8298574045697924 88.493365345953691 413.2635216777503 0.10753781981496147 96.07631783827587 413.04752956366764 -4.9425939531873047 103.34525640479107 412.84186156191879 -10.223914016867194 110.36324894339859 412.65249476803069
+6 0 7 13.686304969104579 36.203227412627321 420.32952879794681 15.125812257636801 36.370382017055647 420.329528734782 16.565319887591933 36.537536661129771 419.97950805500437 17.904071637580145 36.692991601149714 419.2794819987347 19.041204243361939 36.82503466367271 418.26610425269138 19.893835480389264 36.924041621319915 417.01323691657296 20.413588790452515 36.984395021150576 415.61722426196923 20.588225694904036 37.004673739372237 414.17874846422012
+6 0 9 13.686304969104579 36.203227412627321 420.32952879794681 12.700262730534627 44.694864286920563 420.32952879866531 11.214731091279502 53.128795244400536 420.32953283575284 9.1142241216476556 61.455224183097549 420.32952207832437 6.3020289993312488 69.609149352762088 420.32953112358126 2.7947580594995536 77.477278748059589 420.32953408856031 -1.2868376816841263 85.03174222962086 420.32952079238459 -5.8057968637457478 92.309014368970438 420.32953288625151 -10.673666874359112 99.344195616476043 420.32952880770461 -15.799640023409573 106.18558160289922 420.32952880859352
+6 0 7 20.464446763912164 17.382301785281591 423.53295362568304 20.825712997244612 19.460602659086891 421.14444402063043 21.092373516632822 21.839623300245339 419.00017405671696 21.253787147383999 24.506753793506387 417.16253409711339 21.294512106866634 27.438336634538963 415.708382080609 21.198652320526257 30.5685265891196 414.70729385388967 20.958655172469349 33.790464369858775 414.20151699403721 20.588225703657944 37.004673740388689 414.17874845420977
+6 0 7 13.569119665290897 22.470019828989127 426.95722234941474 14.999290021244205 22.362910715498295 427.07924568538306 16.429460462399547 21.996300434853158 426.97348524176573 17.760879996538208 21.377595885764617 426.63152531844253 18.894700172739938 20.541006513530974 426.06846211459828 19.749439394791853 19.546653525072966 425.32475997332807 20.277007277985547 18.46874631507724 424.45829357151257 20.464446763912168 17.382301785281587 423.53295362568275
+6 0 7 13.569119665319601 22.47001981945666 426.95722234662952 13.919236119780468 24.024649222627005 425.18612115870968 14.177309577877114 25.771202377572614 423.6289904091384 14.332285693252963 27.688018014826458 422.33066555660429 14.371291247885832 29.729627186050074 421.33277181360324 14.276739134122421 31.877055663682142 420.66079128950548 14.044307756684708 34.040369081702316 420.32952878131897 13.686304977682807 36.203227401481442 420.32952878131317
+6 0 7 16.275579534266285 9.169133169956968 443.46014875246181 17.071088320257548 9.4611967344734218 440.383908533019 17.81360980363727 10.036340322689345 437.32086835311844 18.495088374932891 10.899453675499686 434.30312034261766 19.108600632090454 12.060419026246615 431.36629697938747 19.647367225078391 13.526458622666222 428.55426453170452 20.103180530579717 15.304000911476283 425.92146323073524 20.464446763912168 17.382301785281584 423.53295362568264
+6 0 7 9.4995959555507987 16.095088723516611 442.37551491903071 10.991743333277231 16.058240517059939 442.75781600733177 12.483890835387596 15.627548099200302 443.10215634450884 13.857984004082722 14.805950943038058 443.3782916829694 14.995796558283015 13.642955329607304 443.56042169819824 15.803020594931454 12.234956466679517 443.63345049434196 16.230803596063431 10.703224805880492 443.59643403973536 16.275579533502995 9.1691331706917847 443.4601487523355
+6 0 7 9.4995959561621337 16.095088726108443 442.37551492185059 10.27327923367112 16.329780159547088 439.94058459330108 10.995197313642704 16.792287365228333 437.5203818796785 11.65754127297798 17.483142672887336 435.15431402244383 12.253608090455561 18.404715757177655 432.87175835145064 12.776763158541312 19.55321111065631 430.71290648344973 13.21900321085867 20.915390416286314 428.72832353454908 13.569119665319541 22.47001981945666 426.95722234662929
+6 0 6 0.65801719783327783 11.361800804120909 487.37786027263405 3.8365592271244977 10.085544594252919 480.38081609253015 6.8160799422998544 9.1259143880355733 473.22664245139617 9.5737318030555478 8.5090453379288356 465.93067969178611 12.084133007297586 8.2618924592265159 458.51213805366359 14.325751737508606 8.4532156960853726 451.00057688828326 16.275579533502999 9.1691331706917847 443.4601487523355
+6 0 7 -5.7181836133926129 18.199086884286448 483.21112311235152 -4.2208538601678702 18.321230187626764 483.86864773078503 -2.7235219390497338 18.002700997021226 484.60803460867146 -1.3603730044777855 17.232589539201808 485.3703520862237 -0.26588967089578497 16.058960300145301 486.08557805237893 0.45650248846224173 14.592717916851875 486.6861256803013 0.7613944194240293 12.978698165662523 487.12446098079948 0.65801684601483679 11.361801140743037 487.37786005027613
+6 0 6 -5.7181839244957891 18.199087263522426 483.21112289766074 -2.6155170149532725 16.98189298213785 476.65876902649694 0.29031446989240361 16.066717345411782 469.96866245150119 2.9770512264784337 15.478337232002151 463.15736418107821 5.4225267926886662 15.24472522131073 456.2543570893809 7.6032663617241854 15.427205780110409 449.30481955033105 9.4995959567733923 16.095088724221359 442.37551491941457
+6 0 7 -5.7181836133926129 18.199086884286448 483.21112311235152 -6.9181489100715332 18.59730675769686 485.35480471481736 -8.135180571372425 19.172687841589958 487.44513591622575 -9.3598407891388113 19.925064533204015 489.47171361377264 -10.579109129142731 20.848058013593569 491.40755245894115 -11.778458804727677 21.938433322174838 493.22927283717098 -12.940166950358586 23.195020798945951 494.91825049834222 -14.037858895078891 24.607201894381998 496.44272783807378
+6 0 7 0.65801684601483679 11.361801140743037 487.37786005027601 -0.57129492912020408 11.855408378330562 490.08403767571508 -1.8179071266544411 12.572820160116731 492.7389559349723 -3.0712270670804869 13.513367553184198 495.32385328691817 -4.3189461876058797 14.679412220814108 497.81786340124404 -5.546313799263884 16.076662425365821 500.19837465515707 -6.7339078739559284 17.712195520901876 502.43365609437024 -7.8557272118926882 19.5873318470742 504.48117843502502
+6 0 7 -14.037858895078889 24.607201894381994 496.44272783807384 -12.291458844587384 25.08439417250975 496.95786614299345 -10.545057436481201 25.128389679734273 497.87429224249041 -9.0047694840459016 24.682935195908058 499.1311467255095 -7.8776560916867489 23.767722928008421 500.59670032189774 -7.3067796499822872 22.498919054008287 502.08493306024781 -7.3204997481477188 21.047992175043905 503.42146335572704 -7.8557272118926855 19.587331847074196 504.48117843502507
+6 0 7 -19.323704384938566 37.194229959470533 502.60592504921021 -19.065723885319635 35.138772347224396 502.51282372117896 -18.602378714149225 33.114982945151425 502.12191162959812 -17.93802626013786 31.149664147616122 501.43685339830654 -17.11354846251308 29.298079249980244 500.49337894767342 -16.169898178112717 27.588594285674791 499.32773335600422 -15.13555048412608 26.01938399324164 497.96720440490304 -14.037858916483017 24.607201913344849 496.44272780859097
+6 0 9 -7.8557272118926749 19.587331847074168 504.48117843502439 -8.7282533636212687 21.045771211874865 506.07369581108924 -9.5623034892277108 22.644109973602703 507.55654504232399 -10.347916438771367 24.381725824092044 508.91263809360436 -11.069251500686967 26.260254606204267 510.11884797354435 -11.718777342724213 28.271120194011729 511.15326518382932 -12.269400884835925 30.403612372531505 511.98608136291728 -12.718200563845391 32.637092576756515 512.59187382779157 -13.042041273320988 34.933354424619736 512.94702109518187 -13.24410744086572 37.25616689355671 513.04768371355533
+6 0 7 -19.323704752184224 37.19422992968795 502.60592506491372 -17.249101191335377 37.376383355431699 502.61417553973627 -15.174497568434361 37.525828083819789 503.3445569831897 -13.399495254580749 37.616267299798309 504.79568689201545 -12.22602155152655 37.62822226902783 506.81113767776935 -11.839850285577045 37.559800388059777 509.07184125803383 -12.228066974027675 37.427536022433884 511.23784331535791 -13.244107433710264 37.256166894002412 513.04768371761452
+6 0 8 -40.021106745724808 128.79173455553911 475.37793002302612 -40.527402413834629 128.23701781508848 478.98308155309326 -40.761835254206503 127.18538099758963 482.51647275348313 -40.70770276214904 125.64179000561398 485.84463959098696 -40.356665031807694 123.60132397424952 488.87890870272912 -39.659850961439524 121.16806698419215 491.39886333564607 -38.600669138128339 118.40132247662251 493.32817987217788 -37.215515892960688 115.54580528055598 494.60583020127854 -35.568095680464978 112.64804698697162 495.28009488539317
+6 0 7 -35.568095716008983 112.64804699763897 495.2800949963202 -33.677180111598318 113.36922521805059 495.11228769763903 -31.786264266506297 114.24616759161172 495.61390087562472 -30.155020928942804 115.17980161458178 496.80782569740541 -29.044891695574822 116.03855682858978 498.58034454251276 -28.62212967468222 116.69382593343212 500.66600474235025 -28.88798319693645 117.07397210495053 502.75909270827066 -29.727320322740713 117.16625638448774 504.60593215421267
+6 0 10 -29.727320377057946 117.16625635375637 504.60593211599002 -31.071383854858109 120.5635661920174 503.76468087945887 -32.251025263755494 123.90701465989967 502.37914598106778 -33.232671712223542 127.09560318998268 500.4474894114818 -34.005854308953133 130.03665500610524 498.01923337544173 -34.548974446302417 132.62256630264548 495.16610985272195 -34.884156989860323 134.82559794303813 491.99571566895639 -35.023794172750051 136.62805890058198 488.59827224568636 -34.976472534500331 138.02625613639239 485.03747530142203 -34.753069622075003 139.02491896288993 481.38311758727093 -34.358747150646288 139.63162176054323 477.69188796372202
+6 0 8 -40.021144853065948 128.79173811216748 475.37790691687883 -38.116506372608491 128.759074002912 475.5901950688197 -36.21186753071612 129.31923504576693 475.89369949697561 -34.524823455975834 130.47596446818065 476.26416914701952 -33.272931250328064 132.13827010287048 476.66278065121298 -32.622002397967087 134.11868512051598 477.04177040834071 -32.63148623909423 136.17344176128165 477.35684759314483 -33.25254624419069 138.07053707367757 477.57788672009457 -34.358790302547511 139.6316306891415 477.69186808626966
+6 0 7 -19.323704752184224 37.19422992968795 502.60592506491372 -20.323551678060465 48.246590580238419 503.10653838988878 -21.480321293091507 59.324737256134902 503.03186583247219 -23.001532805420723 70.366134600355878 502.4084618023864 -25.080050330638596 81.319211284189421 501.26614427711854 -27.887241884327569 92.065241174870096 499.65039788167593 -31.4041981702442 102.52028670986658 497.63667217944118 -35.568095716008983 112.648046997639 495.2800949963202
+6 0 7 -13.244107433710266 37.256166894002426 513.0476837176144 -14.251052356417217 48.84601620598518 513.55015173013442 -15.411814898047222 60.523279677135406 513.42898251464669 -16.93868348642669 72.218682409168338 512.70597254154359 -19.038946537067989 83.868454267182727 511.39862702386199 -21.893340045145308 95.316741093693381 509.55342204775792 -25.480815111292443 106.4327529676558 507.26376557929768 -29.727320322740717 117.16625638448777 504.60593215421278
+6 0 5 -40.021144853065948 128.79173811216748 475.37790691687883 -39.900397710009635 128.92405438820785 474.51796769214792 -39.780934831392052 129.02575047854174 473.65182101904088 -39.659584862579131 129.09659186898381 472.78184227483069 -39.532959251891633 129.13654483453928 471.91006743790132 -39.397452399782757 129.14574677916761 471.03845732912373
+6 0 8 -39.397452338435848 129.14574688288408 471.03845733812932 -37.443178046916806 129.14313378470939 471.28606526321067 -35.488900755181533 129.77404400857898 471.54036193436554 -33.77044267076559 131.03882651985739 471.77146886748022 -32.523640781885192 132.83080576746195 471.94837580373382 -31.924995632949617 134.93532609775036 472.04645130073789 -32.029162436178993 137.07897805619481 472.05588323727972 -32.770257225248962 139.00959629273393 471.98235787504478 -33.999876004040829 140.54225595501973 471.84272787188684
+6 0 6 -39.397452338435848 129.14574688288408 471.03845733812932 -38.959211285482795 129.18047845662304 467.74866610985998 -38.656084324560254 129.12002251494496 464.43785229895951 -38.473134722766801 128.96416668325045 461.11924240231639 -38.384677846596539 128.71547298816981 457.80284446842131 -38.36118750567028 128.37381202973322 454.49536570065686 -38.370950400308594 127.93964850496354 451.20106442617322
+6 0 8 -38.370950384253888 127.93965552933948 451.20111679305325 -36.216373463337654 127.93886402336064 451.1951098688553 -34.061795577271305 128.68949419361149 451.09007164153763 -32.218249687519048 130.19169943865003 450.88686410776904 -30.996706951403816 132.29399721076362 450.60633348039909 -30.614836236261908 134.69071101581758 450.28938284502982 -31.097005601303049 137.00838687552928 449.98529953350146 -32.297310708485796 138.93534699030883 449.73474631652982 -33.973721473615839 140.27782305619021 449.56257379590983
+6 0 8 -38.442757260314359 125.68180366155485 438.57205112811948 -36.216036898575041 125.68439606255414 438.58345093702485 -33.989316474635281 126.47637281921821 438.41533906681519 -32.105947164549242 128.05734722123555 438.06595475105718 -30.909135323291522 130.25700572496632 437.57218058703012 -30.632284885224887 132.73148559802397 437.01095671526139 -31.280335663378118 135.06867469837456 436.47597380315705 -32.667314470592551 136.94017693034399 436.04291282077298 -34.509202236337352 138.15819038376185 435.75601051812765
+6 0 4 -38.442757260272202 125.68180366153105 438.57205112812494 -38.460431416844095 126.392194592227 441.69592300551955 -38.424666048076759 127.00422243447639 444.84657340882222 -38.380397833878241 127.52000545261599 448.01693000072908 -38.370950386165184 127.93965552230544 451.20111679398542
+6 0 8 -27.97156577868795 116.0331554894704 423.48473028757149 -30.05694981259122 117.57913133100853 424.54694879536265 -32.073220905452914 119.06461139277904 425.81676023551421 -33.947937084578676 120.49951637861221 427.31615272351837 -35.654661170034124 121.85539123947756 429.06941991354267 -37.066608783696736 123.13785339465556 431.09648418395869 -38.000290756379819 124.23900231328859 433.45822106002299 -38.425388369842892 125.09142976885845 435.97594196404935 -38.442757260272018 125.68180366298387 438.57205112776415
+6 0 8 -27.971618437120824 116.03319449333357 423.48475709689359 -26.484608964888118 117.03719301430604 424.17459410543029 -24.99759947147766 118.38282809419137 424.36720847126657 -23.681461388292696 119.95473273584794 423.98332862104439 -22.707018040787933 121.58268282640459 423.02359239133494 -22.204258918296773 123.06858880673605 421.58826258678732 -22.219134659187027 124.23966877732671 419.8623373825294 -22.712305270011441 124.98898770739086 418.05835978142017 -23.583643625726854 125.28278775010696 416.37030282037574
+6 0 5 -16.606510994248268 106.93972034396965 420.34682837281952 -18.738408156836872 108.92909308502851 420.4381820900731 -21.0348405277464 110.81767455324831 420.82656237463061 -23.37788980764363 112.6301242247303 421.46332404163712 -25.721207449671255 114.36569527554879 422.33903563084675 -27.971618427495201 116.03319449982922 423.48475710136421
+6 0 12 -1133.8186489049076 -278.04658795639875 -108.85882812117912 -1132.1670464295737 -278.76743667731034 -106.05757924703556 -1130.5043010459967 -279.46156670942821 -103.26448365212751 -1128.8305215080716 -280.1296373135304 -100.47956327246227 -1127.1458149643395 -280.77228552290478 -97.702836776530546 -1125.4502869765565 -281.39012731051861 -94.93431981375879 -1123.7440415383321 -281.98375866549776 -92.174025239405978 -1122.0271810937643 -282.55375658822118 -89.421963318671445 -1120.2998065560264 -283.10068001226574 -86.678141912439727 -1118.5620173258803 -283.62507066048943 -83.94256664678754 -1116.813911310109 -284.12745384170489 -81.215241068113556 -1115.0555849398686 -284.60833919365638 -78.49616678551871 -1113.2871331889705 -285.06822137736339 -75.785343601860276
+6 0 8 -323.96682687944616 -210.71838774354569 -77.363030951162386 -418.78683562494581 -242.48294178090515 -80.592067159558852 -515.48153962317826 -268.48571071455416 -83.038520481777212 -613.70021821493867 -288.3709455061242 -84.464176120434232 -713.08477227223534 -301.86009709896854 -84.787605910020801 -813.29664686668195 -308.57739484777062 -84.022194089736928 -913.85825829622445 -308.11809387703727 -82.193552450293396 -1014.0851964540066 -300.24457322528303 -79.351550158201491 -1113.2871331889698 -285.06822137736333 -75.78534360186022
+6 0 9 -1167.3345381169638 0 -171.84064868506127 -1070.4057342682486 0 -171.84066964379517 -972.19521611533673 0 -171.84060055458897 -873.2467002031924 0 -171.84071309834934 -774.06807064393024 0 -171.84064680258385 -675.49004440100862 0 -171.84061699618016 -577.67989282607653 0 -171.84063565670405 -481.36648286948684 0 -171.84074256407197 -386.60351837667042 0 -171.84056739150549 -293.74357295896402 0 -171.84068273582758
+6 0 1 -1167.3345381169638 -197.14210218568485 -171.8406486850613 -1167.3345381169638 0 -171.8406486850613
+6 0 9 -293.74356994954593 118.80076509921587 -171.84068273583139 -386.60351564681139 151.98873874383139 -171.84056739150051 -481.36648044223631 179.96628140757599 -171.84074256407476 -577.67989071143188 202.25004991432007 -171.84063565670425 -675.49004262808285 218.50837611176644 -171.84061699618019 -774.06806921406087 228.18955318410366 -171.84064680258234 -873.24669913468381 231.0203840421928 -171.8407130983509 -972.1952154080434 226.70729192704246 -171.84060055458852 -1070.4057339192173 215.3282501010265 -171.84066964379528 -1167.3345381169638 197.14210218568496 -171.8406486850613
+6 0 1 -1167.3345381169638 197.14210218568485 -171.8406486850613 -1167.3345381169638 0 -171.8406486850613
+6 0 8 -317.38987566822107 205.78285569518158 -104.53977533304011 -415.23686784044014 237.51054875323035 -108.74937936667416 -515.17201910133485 263.3662736863875 -112.14023740283342 -616.81613573987511 283.02969258231383 -114.44840082368142 -719.73919525025997 296.26207059786168 -115.57592612185698 -823.52371771670926 302.70170387016015 -115.52730823987852 -927.62832447920755 301.93570675398945 -114.32016772215998 -1031.3043845067834 293.69840580850843 -111.9962541239091 -1133.8186489049074 278.0465879563987 -108.85882812117912
+6 0 13 -1141.3026948488621 273.493961183566 -121.81697823934751 -1140.7688788441837 273.91818235099191 -120.87388184219517 -1140.2282234408692 274.33096982100568 -119.9217932490474 -1139.6298769295215 274.75092900007485 -118.99055591650504 -1139.3888384057511 275.0120948337044 -117.82868690925443 -1137.8818815586972 275.76323746233658 -117.39291416505307 -1139.1613441076618 275.46177746698777 -115.51141760883564 -1136.0296342810191 276.6642047810405 -115.47948458231609 -1137.9523639683321 276.15975010850383 -113.70530828860194 -1135.7264451538613 277.11524102022088 -113.19502744635089 -1135.7490713846589 277.11842476541295 -111.92025339525543 -1135.0520787058952 277.49190494401745 -110.95949400684016 -1134.4396852991804 277.77595496074008 -109.92028540650978 -1133.8202930076031 278.0455047900727 -108.87285806196536
+6 0 13 -1144.6375022635455 270.52015500165629 -127.77072224520039 -1144.3908112865893 270.76481050440168 -127.32620998026508 -1144.1424759158404 271.0068944277549 -126.87944054153293 -1143.8958707466734 271.2528249641735 -126.4378999189649 -1143.6444089795204 271.4342825490383 -125.92768997868107 -1143.3759260205509 271.88040695075642 -125.66407566286748 -1143.1276302292076 271.63607338167452 -124.85886256949175 -1142.9373994768698 272.55379295972239 -124.80723939624042 -1142.5157205201599 272.11238656199316 -124.03328086224309 -1142.4398632598711 272.77393660063495 -123.73384131525519 -1142.0684603140423 272.80790824663745 -123.21523287719222 -1141.834801003881 273.06688159178748 -122.75782658750019 -1141.5696028512014 273.28185059985384 -122.28852643792052 -1141.3026948488632 273.49396118356668 -121.8169782393369
+6 0 13 -1146.2087195574049 268.88064535329164 -130.61555335017852 -1146.0902592304474 269.01051165793513 -130.40006163725226 -1145.9713983261759 269.13976437210539 -130.18400732332006 -1145.8553472290237 269.26659415666444 -129.97302236305575 -1145.7332163787303 269.41037711822452 -129.76283465240007 -1145.58787665878 269.48106384623964 -129.44872476617658 -1145.5485093243356 269.72206658299126 -129.49417361363052 -1145.3074933905614 269.70220295054963 -128.88201009383198 -1145.2984405356167 269.95274289441085 -129.02879687959961 -1145.0999684262601 270.00719469744877 -128.59397909882713 -1145.0185006036966 270.15478137219588 -128.44616890459884 -1144.8837821420539 270.27485660406273 -128.21467021668701 -1144.7608477520239 270.39782725028334 -127.99297837767006 -1144.6375022635455 270.52015500165527 -127.77072224520822
+6 0 13 -1146.9708631720378 268.02458064060284 -132.00544396001195 -1146.9128355004937 268.09133458146556 -131.89938533014464 -1146.8547089994413 268.15793839440204 -131.7931864446833 -1146.7947340182779 268.2189631948728 -131.67931225158915 -1146.7346304808657 268.31297967689733 -131.63593129884626 -1146.7058696435718 268.31320873755828 -131.30606679000772 -1146.5644108926201 268.47113412655875 -131.65851348424164 -1146.6371004785367 268.46161065162568 -130.94306889177017 -1146.4420697812332 268.55658837260501 -131.37199325544202 -1146.4767853207188 268.62545978876841 -130.9548217980514 -1146.3790020234433 268.68345836724291 -130.95770521792022 -1146.3270797400337 268.75062565102968 -130.83090441285393 -1146.2679497208837 268.81571220096976 -130.72329920664333 -1146.2087195574068 268.88064535329147 -130.61555335018298
+6 0 13 -1147.3464508428387 267.58759126776494 -132.69214719264747 -1147.3177354073691 267.62141544653559 -132.63953688298233 -1147.2889954175646 267.65520247531674 -132.58689157328843 -1147.2484620101475 267.69501773913055 -132.53858879672785 -1147.263918010415 267.70543926379776 -132.46600958918074 -1147.1502259218194 267.78562844092659 -132.45294781937588 -1147.2243850033231 267.75622855073357 -132.36158604096215 -1147.1100996331247 267.85568767724357 -132.31593943456963 -1147.1329160309594 267.83368116606499 -132.28868088201935 -1147.0788702653722 267.90227875857812 -132.20490211903797 -1147.0605029422934 267.92232751873718 -132.1675990964811 -1147.0288661362044 267.95778916775868 -132.1114675259806 -1146.9998770078087 267.99120367017167 -132.05847327494541 -1146.9708631720339 268.02458064060352 -132.0054439600116
+6 0 13 -1147.7173768123796 267.14524659831125 -133.37325288415474 -1147.6889575569687 267.17951529364342 -133.32106303446554 -1147.6605139203575 267.2137472073187 -133.26883826642668 -1147.6321446669258 267.24769705220552 -133.21369981313518 -1147.5953989422774 267.28239218227225 -133.1853514985539 -1147.6215821999901 267.30881134424038 -133.04848696400171 -1147.4356201773314 267.3816506602455 -133.17148837078022 -1147.6627129544775 267.32590970748578 -132.88413975636988 -1147.3727749677435 267.47705897774284 -133.03960420308556 -1147.5190081479936 267.42041004305025 -132.86945347977408 -1147.416591926728 267.49482857819976 -132.85501541096022 -1147.4038571594426 267.51990576023405 -132.79733281194916 -1147.375166278307 267.55376708899422 -132.74475750231301 -1147.3464508428358 267.58759126776562 -132.69214719264855
+6 0 6 -1157.729394848408 250.13401205641136 -152.35908271715084 -1156.3414944967847 253.41762104771041 -149.63943446941735 -1154.8478758942133 256.51851664385401 -146.74364322320687 -1153.2447952509699 259.44481516893592 -143.67287328228875 -1151.5283552145111 262.19746587900704 -140.42431214617739 -1149.6877785208728 264.769283721948 -136.99174912927219 -1147.7173768123801 267.14524659831125 -133.37325288415474
+6 0 6 -1167.3345381169638 197.14210218568485 -171.8406486850613 -1167.3345363925575 208.76614011912207 -171.84064506130528 -1166.3412775019513 219.11688750818331 -169.75202864332726 -1164.8153302219348 228.16966310743763 -166.55397154332897 -1162.8581232511078 236.26872251059353 -162.53310371417669 -1160.5051955516542 243.56679407381327 -157.79837921261776 -1157.7293948484078 250.13401205641134 -152.35908271715081
+6 0 12 -1113.2871331889701 -285.06822137736327 -75.785343601860248 -1097.3710674308868 -289.20716103072647 -51.387934948934401 -1080.6348458395191 -272.95566293897588 -33.928528719397768 -1063.1477043231891 -247.88784365568395 -19.645183150475162 -1044.9693171487404 -222.98766662689201 -5.6000608359102628 -1026.1508764447838 -204.68994247222986 10.312832663020199 -1006.7361339954552 -196.89548323461432 29.365929439703642 -986.76244720545742 -200.98462341530006 51.995591884835832 -966.26216896734104 -215.8252827768697 77.80081494873896 -945.26358298070136 -237.77736646755332 105.54298581823754 -923.79136690071573 -260.69573715392357 133.14596238486263 -901.86687951464262 -275.93264326387663 157.69609507629701 -879.5084372893632 -272.33972282567686 175.44214357515679
+6 0 8 -879.5084372893632 -272.33972282567686 175.44214357515679 -803.1327170994972 -279.25893989832065 170.86454375861024 -726.50296937070527 -282.45918425947298 166.29255357593203 -650.08553512024184 -281.30905450638232 161.92006258062085 -574.23546052550375 -275.44450372470254 157.85460009824655 -499.12526650448427 -264.79232138890268 154.17237503357663 -424.77904967506373 -249.35144915546698 150.93576676788584 -351.22740081015331 -229.14606348903072 148.16568549591369 -278.62999153648974 -204.28149519859522 145.81267994069384
+6 0 1 -273.13409248915661 -194.82218095784944 140.86584214689373 -273.13409248915661 0 140.86584214689373
+6 0 9 -303.47800298573486 0 73.437629699697538 -300.79334313106989 0 81.234499621883415 -297.91710500436716 0 88.962737527762187 -294.85854834386373 0 96.618056726693439 -291.62649238549625 0 104.19699166089254 -288.22922544411813 0 111.69676309681117 -284.67446970782032 0 119.11514920104302 -280.96937821933687 0 126.45038373461618 -277.12054427790986 0 133.70105424108044 -273.13409248915633 0 140.86584214689375
+6 0 10 -303.47800298573486 -1.7990048428181166e-10 73.437629699697524 -303.47800298573452 -17.989215185243797 73.437629699698476 -303.47800298573418 -35.978430370307677 73.437629699699428 -303.47800298573384 -53.96764555537154 73.437629699700381 -303.4780029857335 -71.956860740435388 73.437629699701333 -303.47800298573316 -89.946075925499215 73.437629699702285 -303.47800298573281 -107.93529111056303 73.437629699703237 -303.47800298573247 -125.92450629562683 73.437629699704189 -303.47800298573213 -143.91372148069061 73.437629699705141 -303.47800298573179 -161.90293666575437 73.437629699706093 -303.47800298573145 -179.8921518508181 73.437629699707045
+6 0 4 -303.47800303282185 -179.89215173586189 73.437629562945631 -307.16859942830035 -179.36841068331182 62.71928846033029 -310.45658963643064 -177.90742052739262 51.771078972547478 -313.20248694237722 -175.52989453098223 40.840237969565777 -315.39315901965097 -172.2561023696843 30.173820375726731
+6 0 10 -315.39315899503032 -172.25610253658965 30.173820495605483 -315.39315899592953 -155.03049228305633 30.173820491227357 -315.39315899682873 -137.80488202949891 30.17382048684923 -315.39315899772794 -120.57927177591739 30.173820482471104 -315.39315899862714 -103.35366152231178 30.173820478092978 -315.39315899952635 -86.128051268682086 30.173820473714851 -315.39315900042556 -68.902441015028302 30.173820469336725 -315.39315900132476 -51.676830761350423 30.173820464958599 -315.39315900222397 -34.451220507648458 30.173820460580473 -315.39315900312317 -17.225610253922397 30.173820456202346 -315.39315900402238 -1.7224621728928469e-10 30.17382045182422
+6 0 9 -319.13536194508737 0 7.9238576889037855 -318.8112842737624 0 10.407443150980654 -318.46363570570901 0 12.888820699335843 -318.09268477260986 0 15.367702990548413 -317.69870480726814 0 17.843813075941611 -317.28197300975847 0 20.316884501542766 -316.84276956270372 0 22.786661320420976 -316.3813768058651 0 25.252898027324058 -315.89807847470911 0 27.715359427514596 -315.39315900402215 0 30.173820451824206
+6 0 1 -319.13536194508742 -1.6370904631912708e-10 7.9238576889038086 -319.13536194508742 -163.70963387535281 7.9238576889038086
+6 0 4 -319.13536201150566 -163.70963384714432 7.9238571799042479 -320.38783862828728 -159.21423592216647 -1.6745602180968557 -321.1539071245432 -153.91799976284511 -10.78711629851666 -321.48824083373165 -147.83934371737465 -19.196754333089189 -321.53737922823751 -140.99530887819665 -26.687215998155473
+6 0 10 -321.5373792269707 -140.99530877742333 -26.687215805053693 -321.5373792269707 -126.8957778996951 -26.687215805053647 -321.5373792269707 -112.79624702196688 -26.687215805053601 -321.5373792269707 -98.69671614423865 -26.687215805053555 -321.5373792269707 -84.597185266510422 -26.687215805053508 -321.5373792269707 -70.497654388782195 -26.687215805053462 -321.5373792269707 -56.39812351105396 -26.687215805053416 -321.5373792269707 -42.298592633325725 -26.68721580505337 -321.5373792269707 -28.199061755597491 -26.687215805053324 -321.5373792269707 -14.099530877869258 -26.687215805053278 -321.5373792269707 -1.4102496947998588e-10 -26.687215805053231
+6 0 9 -317.32883271750734 0 -74.639313893227111 -318.30783125076243 0 -69.412174861990081 -319.15820364172987 0 -64.15030993122204 -319.87970610012422 0 -58.857715564080628 -320.47247073785553 0 -53.538507012870767 -320.93703753624345 0 -48.196848654670752 -321.27434603075801 0 -42.836886538758186 -321.48570406180153 0 -37.462689918654554 -321.572744810308 0 -32.078204251700519 -321.5373792269707 0 -26.687215805053253
+6 0 5 -275.94009696839424 -203.31188628574654 150.62032632904629 -276.48326725231078 -203.50843174974958 149.66229222932978 -277.02386110699689 -203.70367818268892 148.70250784212999 -277.56185927339493 -203.89761277223897 147.74097587049718 -278.09724249879963 -204.09022271130289 146.77769900857572 -278.62999153678908 -204.28149519772126 145.81267994068591
+6 0 7 -270.49197116902371 -193.84990939061382 145.55102986806097 -270.33023900545396 -195.66622501116342 145.83403453738239 -270.51343403112111 -197.48254093819835 146.3141591644771 -271.05054274870741 -199.1978430693394 146.97565980056774 -271.92184069742143 -200.71106089172429 147.78637302017083 -273.07732467567058 -201.93535185518022 148.69977253843336 -274.44446878384525 -202.8115716003941 149.66218594615032 -275.94009695718529 -203.31188626477879 150.62032631830698
+6 0 5 -270.49197115662895 -193.84990937058819 145.551029856838 -271.02558562556226 -194.04699351326767 144.61729285660672 -271.5566244256525 -194.24277570467757 143.68190184134107 -272.0850681270411 -194.4372429843589 142.74486055323121 -272.6108972948428 -194.63038239007531 141.80617273828958 -273.13409248915667 -194.82218095784944 140.86584214689373
+6 0 8 -94.753067378241539 -137.60264083471304 340.68475444739266 -122.62070021536412 -146.21136426856725 323.20659657171922 -149.01567114032423 -155.36991383287761 303.49085598143682 -174.00646150243318 -164.58597985984835 281.9686410715849 -197.64495274077689 -173.59480335021829 258.80544298939071 -219.83540295669519 -182.19092446148119 234.0620418127703 -240.47460187167701 -190.16416578881748 207.78038973671903 -259.31107836669679 -197.2946957929318 179.95029046062805 -275.94009695718535 -203.31188626477874 150.62032631830704
+6 0 12 -879.50843728936331 -272.33972282567686 175.44214357515688 -854.66572370571953 -268.34758900545489 195.15997524055663 -829.28726340700609 -264.18181885086028 214.21802816146885 -803.39818186219577 -259.93177683192181 232.63078481846955 -777.01896756361486 -255.67353739582043 250.41023474320207 -750.16594036263268 -251.4732784859068 267.56573348090234 -722.85169980508999 -247.38987646983776 284.10366376490305 -695.08589915777213 -243.47695229191049 300.02679755204247 -666.87638683230716 -239.78284241757561 315.33401709656113 -638.22930513955998 -236.34670437943171 330.02171921931341 -609.14420078717467 -233.19702886980113 344.08597195093233 -579.60432082572288 -230.37879404221388 357.51530369025903 -549.61730957030261 -227.91457393853958 370.28786144860089
+6 0 6 -549.61730957030659 -227.91457393852542 370.28786144860055 -509.60778492945394 -213.47234633986898 369.22188285517922 -469.73996167228421 -202.02838089328168 367.68125640967781 -430.15729540053428 -192.97177066313884 365.73703198035503 -390.9445774584749 -185.62376054007137 363.46779538633621 -352.14129301610194 -179.36380902305584 360.94452700814679 -313.75750323429389 -173.62366029293489 358.23074660924902
+6 0 10 -321.5373792269707 140.99530877742333 -26.687215805053693 -321.5373792269707 126.8957778996951 -26.687215805053647 -321.5373792269707 112.79624702196688 -26.687215805053601 -321.5373792269707 98.69671614423865 -26.687215805053555 -321.5373792269707 84.597185266510422 -26.687215805053508 -321.5373792269707 70.497654388782195 -26.687215805053462 -321.5373792269707 56.39812351105396 -26.687215805053416 -321.5373792269707 42.298592633325725 -26.68721580505337 -321.5373792269707 28.199061755597491 -26.687215805053324 -321.5373792269707 14.099530877869258 -26.687215805053278 -321.5373792269707 1.4102496947998588e-10 -26.687215805053231
+6 0 4 -319.13536201150572 163.70963384714432 7.9238571799042443 -320.38783862828734 159.21423592216647 -1.6745602180968593 -321.15390712454325 153.91799976284511 -10.787116298516663 -321.48824083373171 147.83934371737465 -19.196754333089189 -321.53737922823757 140.99530887819665 -26.687215998155473
+6 0 1 -319.13536194508742 1.6370904631912708e-10 7.9238576889038086 -319.13536194508742 163.70963387535281 7.9238576889038086
+6 0 10 -315.39315899503032 172.25610253658965 30.173820495605483 -315.39315899592953 155.03049228305633 30.173820491227357 -315.39315899682873 137.80488202949891 30.17382048684923 -315.39315899772794 120.57927177591739 30.173820482471104 -315.39315899862714 103.35366152231178 30.173820478092978 -315.39315899952635 86.128051268682086 30.173820473714851 -315.39315900042556 68.902441015028302 30.173820469336725 -315.39315900132476 51.676830761350423 30.173820464958599 -315.39315900222397 34.451220507648458 30.173820460580473 -315.39315900312317 17.225610253922397 30.173820456202346 -315.39315900402238 1.7224621728928469e-10 30.17382045182422
+6 0 4 -303.47800303282185 179.89215173586189 73.437629562945631 -307.16859942830035 179.36841068331182 62.71928846033029 -310.45658963643064 177.90742052739262 51.771078972547478 -313.20248694237722 175.52989453098223 40.840237969565777 -315.39315901965097 172.2561023696843 30.173820375726731
+6 0 10 -303.47800298573486 1.7988099898502696e-10 73.437629699697524 -303.47800298573452 17.989215185243779 73.437629699698476 -303.47800298573418 35.978430370307663 73.437629699699428 -303.47800298573384 53.967645555371526 73.437629699700381 -303.4780029857335 71.956860740435374 73.437629699701333 -303.47800298573316 89.946075925499201 73.437629699702285 -303.47800298573281 107.93529111056301 73.437629699703237 -303.47800298573247 125.9245062956268 73.437629699704189 -303.47800298573213 143.91372148069058 73.437629699705141 -303.47800298573179 161.90293666575434 73.437629699706093 -303.47800298573145 179.89215185081807 73.437629699707045
+6 0 1 -273.13409248915661 194.82218095784944 140.86584214689373 -273.13409248915661 0 140.86584214689373
+6 0 8 -323.96682687944616 210.71838774354569 -77.363030951162386 -418.78683562494581 242.48294178090515 -80.592067159558852 -515.48153962317826 268.48571071455416 -83.038520481777212 -613.70021821493867 288.3709455061242 -84.464176120434232 -713.08477227223534 301.86009709896854 -84.787605910020801 -813.29664686668195 308.57739484777062 -84.022194089736928 -913.85825829622445 308.11809387703727 -82.193552450293396 -1014.0851964540066 300.24457322528303 -79.351550158201491 -1113.2871331889698 285.06822137736333 -75.78534360186022
+6 0 12 -1133.8186489049076 278.04658795639875 -108.85882812117912 -1132.1670464295737 278.76743667731034 -106.05757924703556 -1130.5043010459967 279.46156670942821 -103.26448365212751 -1128.8305215080716 280.1296373135304 -100.47956327246227 -1127.1458149643395 280.77228552290478 -97.702836776530546 -1125.4502869765565 281.39012731051861 -94.93431981375879 -1123.7440415383321 281.98375866549776 -92.174025239405978 -1122.0271810937643 282.55375658822118 -89.421963318671445 -1120.2998065560264 283.10068001226574 -86.678141912439727 -1118.5620173258803 283.62507066048943 -83.94256664678754 -1116.813911310109 284.12745384170489 -81.215241068113556 -1115.0555849398686 284.60833919365638 -78.49616678551871 -1113.2871331889705 285.06822137736339 -75.785343601860276
+6 0 7 -91.74190981369739 -127.93047920613498 331.0115701532867 -91.264546832466323 -130.07496161270504 331.30715453096445 -91.089000639529516 -132.21944402283654 332.09016711185137 -91.253557534950133 -134.1918408841442 333.33685614810969 -91.760376837403911 -135.81981383840025 334.96499979655238 -92.566816655513165 -136.96639129524627 336.83761210524682 -93.595335681765334 -137.56177434925436 338.7947522654506 -94.753041543911706 -137.60264637648007 340.68475145762181
+6 0 8 -91.741926937081303 -127.93047339795018 331.01155955044339 -119.23737068512601 -136.58213023278222 313.98630854953871 -145.30929585190469 -145.7730903052325 294.77885814566383 -170.00479376955252 -155.01842650217625 273.78035327995099 -193.35428490192953 -164.05267344281998 251.15775415633223 -215.25870174845909 -172.67163773521077 226.9819541209676 -235.61223966885962 -180.66691000393081 201.30600917941231 -254.15550383477762 -187.81622947588619 174.13714368405769 -270.49197116902383 -193.84990939061379 145.55102986806097
+6 0 13 -549.61730957021462 -227.91457393853307 370.28786144862613 -529.30877202568558 -226.24569450039402 378.93800555817882 -508.84129529724754 -226.93998423468597 387.27111381405507 -487.31051114978095 -224.21837836106673 394.90412774044512 -463.92619064852511 -222.37822406182184 401.82672446813064 -438.64478746010991 -215.38130802467032 407.88022499722717 -410.85461341583596 -212.67162214266639 413.94668533423282 -381.5402894509952 -206.93761356811771 419.83272241932991 -350.4153330335343 -206.8438537829262 427.26754760352975 -319.00451262420444 -205.49528058977523 436.48231139604871 -287.9487476455281 -208.96634543247541 449.36893392258588 -258.91632971995921 -213.60868123489476 467.12119338740308 -233.5132260615315 -223.25243430573516 491.64923883836622 -213.77448017655399 -232.12033657737649 524.90864501377189
+6 0 8 -317.05760091197112 -296.1675488549443 667.6929645619756 -277.75585980428241 -281.24178583700177 645.85627333213051 -247.47759334566945 -268.6366774481059 625.19297387622385 -225.48037474817204 -259.00698716366446 605.68440749735578 -211.0129586376849 -251.41662581894656 587.31436357444647 -203.36574272896357 -245.33409365773235 570.07196418289527 -201.76116972664212 -240.20883119279287 553.93422866516073 -205.48024510962696 -235.84663542063853 538.88427115495358 -213.77448017443535 -232.12033657705291 524.90864501648548
+6 0 9 -401.10223388671869 -297.27716739680983 729.70868408981767 -401.10223388671869 -304.49210649763052 725.5523648163105 -401.10251499755572 -311.16671068276446 721.20474292255267 -398.01684521824507 -316.08305221962166 715.71965645435648 -390.15910416119937 -318.37056658736668 708.65263200858487 -377.20227258263645 -317.33698365477665 700.01815309583856 -360.26255400814665 -312.48636105097853 690.36269567385636 -341.77468433255069 -305.80931181427502 680.67004758459655 -325.62821547049845 -299.422441895026 672.45493834168667 -317.05760092109074 -296.16754889995036 667.69296448785269
+6 0 8 -136.32744174501144 -196.58177896584334 594.49203619502123 -165.24777591083415 -209.1687025197061 617.60627269779548 -196.70571904586959 -221.75562607356886 639.16594120464413 -230.0473626970188 -234.34254962743162 659.02448770987269 -264.57326351066979 -246.92947318129438 677.07692507657873 -299.58807825532676 -259.51639673515712 693.26192410357908 -334.45808721705595 -272.10332028901985 707.49719582781131 -368.59441432880999 -284.69024384288258 719.63086769899792 -401.10223388671869 -297.27716739674531 729.70868408985496
+6 0 8 -879.5084372893632 272.33972282567686 175.44214357515679 -803.1327170994972 279.25893989832065 170.86454375861024 -726.50296937070527 282.45918425947298 166.29255357593203 -650.08553512024184 281.30905450638232 161.92006258062085 -574.23546052550375 275.44450372470254 157.85460009824655 -499.12526650448427 264.79232138890268 154.17237503357663 -424.77904967506373 249.35144915546698 150.93576676788584 -351.22740081015331 229.14606348903072 148.16568549591369 -278.62999153648974 204.28149519859522 145.81267994069384
+6 0 12 -1113.2871331889701 285.06822137736327 -75.785343601860248 -1097.3710674308868 289.20716103072647 -51.387934948934401 -1080.6348458395191 272.95566293897588 -33.928528719397768 -1063.1477043231891 247.88784365568395 -19.645183150475162 -1044.9693171487404 222.98766662689201 -5.6000608359102628 -1026.1508764447838 204.68994247222986 10.312832663020199 -1006.7361339954552 196.89548323461432 29.365929439703642 -986.76244720545742 200.98462341530006 51.995591884835832 -966.26216896734104 215.8252827768697 77.80081494873896 -945.26358298070136 237.77736646755332 105.54298581823754 -923.79136690071573 260.69573715392357 133.14596238486263 -901.86687951464262 275.93264326387663 157.69609507629701 -879.5084372893632 272.33972282567686 175.44214357515679
+6 0 7 -77.897694258319675 -124.06131943852613 339.24594120204245 -77.507084713274978 -126.09106599032039 339.46877808301292 -77.366339270060379 -128.12081264203016 340.1296006145588 -77.503017128516078 -130.00729259468807 341.21266014407377 -77.918335701606068 -131.60708870813431 342.65596640481976 -78.581754378954003 -132.80255936230199 344.35338531799812 -79.437127517994753 -133.52553961571934 346.17602173656536 -80.415410045294976 -133.75949378406153 347.99545348868349
+6 0 6 -77.897694258319675 -124.06131943852613 339.24594120204245 -80.235318351649198 -124.67125335161347 337.91236233863145 -82.563351364034901 -125.28263456767996 336.5613315531333 -84.880085390590764 -125.90412726530943 335.19411251546728 -87.183800503910362 -126.54510351362271 333.81205210564485 -89.472210694914267 -127.21630074138861 332.41697364931122 -91.74190981369739 -127.93047920613498 331.01157015328675
+6 0 4 -401.10223388671881 -297.27716739674537 729.70868408985507 -401.10223388671881 -279.77600424097676 739.79060172167135 -401.10223388671881 -262.06089054620185 748.21145722047549 -401.10223388671881 -244.15826362958035 755.176503756633 -401.10223388671881 -226.09456080827201 760.89099450050958
+6 0 7 -171.24821807098894 -155.88520260558568 652.982055780476 -201.90980911201282 -164.36557631505295 673.89205305969233 -233.64527631140453 -173.46588419955702 692.54805500189855 -266.00475701422857 -183.08500103097739 709.28301146287106 -298.90087955128189 -193.17569116755416 724.36079394844057 -332.34685684699303 -203.76544087946485 737.98527477892799 -366.55330874705362 -214.84491880905566 750.19022564291026 -401.10223388647688 -226.09456080824322 760.89099450041863
+6 0 13 -38.416478886585082 -3.3287506084889174e-10 552.0840448332774 -38.416478886585644 -29.20491248156689 552.08404483327911 -38.402004286212538 -52.794846199772323 552.07217072684728 -45.826427612825768 -69.276222162863633 558.42025108629525 -51.908065547705263 -87.032098753202192 562.45793627935234 -63.157600789100009 -97.529388129825449 571.67660547627588 -72.507067301453958 -111.87150130395311 578.2716574427443 -85.111302638033706 -119.54443245797189 588.48647985901334 -97.048686081842192 -129.58153157256396 597.55267985445005 -110.46006436415539 -136.04049194002556 608.16388978794851 -124.26709075972713 -142.34612037119123 618.86420882310665 -139.02835044743028 -147.05371423650362 630.20249040671604 -154.6921515329268 -151.30613065603717 641.6914705727803 -171.24821807534349 -155.88520260314124 652.98205578409795
+6 0 8 23.801769921783269 0 396.26714625329788 22.520756526055326 0 417.55921747093555 19.124496213706131 0 438.35903571621884 13.742574199429436 0 458.6534476331625 6.5045756979189981 0 478.42929986578122 -2.4599140761314278 0 497.67343905808974 -13.021309908028087 0 516.37271185410282 -25.050026583077226 0 534.51396489783519 -38.416478886585089 0 552.08404483330162
+6 0 11 -4.0093281353064096 -94.430306724078335 381.70727835321185 2.0337988363725801 -87.936170903057501 384.8232583685886 7.6199186604793319 -80.747622460596688 387.69801785418423 12.604874320602676 -72.796147726139992 390.26739483829419 16.773794624074526 -64.184452963200869 392.43692819433613 20.033695154516572 -54.731908657877547 394.17117940192071 21.814040850387777 -45.244631341684723 395.1635133603458 23.072829312979017 -35.907261581781199 395.84858060688754 23.603133808773659 -26.648251355167847 396.15260678341616 23.803079937879698 -17.595293234572175 396.26796243096362 23.801769915736045 -8.7049494807832062 396.26714627255006 23.801769921783222 -1.0302869668521453e-13 396.26714625329589
+6 0 5 -4.0093281348429999 -94.43030672489607 381.70727835411486 -4.6881140672097468 -95.159755451881438 381.35728123715865 -5.3734483827265631 -95.879361456446247 381.00425081664957 -6.0650234139663901 -96.589243898034752 380.64829648427241 -6.7625317228970179 -97.289522108951928 380.28952757962293 -7.4656661573385046 -97.980315559149801 379.92805336761404
+6 0 6 -10.592833309239722 -91.668175629322064 373.21445625540161 -9.5668822484824698 -92.925772864993391 373.6990890750177 -8.6879784984706525 -94.183371817515152 374.49501966629811 -8.0090896336428639 -95.376057695025509 375.57725320001543 -7.5706498617836493 -96.438682889737237 376.89377033880169 -7.3908025369769588 -97.318157080570444 378.37083246367075 -7.4656661573385037 -97.980315559149801 379.92805336761398
+6 0 12 -10.592833236353517 -91.66817574232924 373.21445633981972 -15.285575703057653 -96.347069627771646 370.99772609837277 -20.318674854527945 -100.5948555265075 368.62244144069115 -25.616884369370727 -104.42830574731289 366.11863751524407 -31.110578397597017 -107.85419734039846 363.49852657410258 -36.796987997190712 -110.8779917083708 360.77104474156391 -42.592860933889227 -113.50527415614201 357.94145655030241 -48.468587396053351 -115.76193976295055 355.02200263942979 -54.398597975204659 -117.72103923362781 352.02312154947026 -60.311906069096075 -119.46809153089103 348.94547248926062 -66.224966066929198 -121.04845931528966 345.79081896436526 -72.093343284370007 -122.55047809436093 342.55723483369781 -77.897694258123948 -124.06131943780454 339.24594120137806
+6 0 5 -270.49197115662895 193.84990937058819 145.551029856838 -271.02558562556226 194.04699351326767 144.61729285660672 -271.5566244256525 194.24277570467757 143.68190184134107 -272.0850681270411 194.4372429843589 142.74486055323121 -272.6108972948428 194.63038239007531 141.80617273828958 -273.13409248915667 194.82218095784944 140.86584214689373
+6 0 7 -270.49197116902371 193.84990939061382 145.55102986806097 -270.33023900545396 195.66622501116342 145.83403453738239 -270.51343403112111 197.48254093819835 146.3141591644771 -271.05054274870741 199.1978430693394 146.97565980056774 -271.92184069742143 200.71106089172429 147.78637302017083 -273.07732467567058 201.93535185518022 148.69977253843336 -274.44446878384525 202.8115716003941 149.66218594615032 -275.94009695718529 203.31188626477879 150.62032631830698
+6 0 5 -275.94009696839424 203.31188628574654 150.62032632904629 -276.48326725231078 203.50843174974958 149.66229222932978 -277.02386110699689 203.70367818268892 148.70250784212999 -277.56185927339493 203.89761277223897 147.74097587049718 -278.09724249879963 204.09022271130289 146.77769900857572 -278.62999153678908 204.28149519772126 145.81267994068591
+6 0 6 -549.61730957030659 227.91457393852542 370.28786144860055 -509.60778492945394 213.47234633986898 369.22188285517922 -469.73996167228421 202.02838089328168 367.68125640967781 -430.15729540053428 192.97177066313884 365.73703198035503 -390.9445774584749 185.62376054007137 363.46779538633621 -352.14129301610194 179.36380902305584 360.94452700814679 -313.75750323429389 173.62366029293489 358.23074660924902
+6 0 12 -879.50843728936331 272.33972282567686 175.44214357515688 -854.66572370571953 268.34758900545489 195.15997524055663 -829.28726340700609 264.18181885086028 214.21802816146885 -803.39818186219577 259.93177683192181 232.63078481846955 -777.01896756361486 255.67353739582043 250.41023474320207 -750.16594036263268 251.4732784859068 267.56573348090234 -722.85169980508999 247.38987646983776 284.10366376490305 -695.08589915777213 243.47695229191049 300.02679755204247 -666.87638683230716 239.78284241757561 315.33401709656113 -638.22930513955998 236.34670437943171 330.02171921931341 -609.14420078717467 233.19702886980113 344.08597195093233 -579.60432082572288 230.37879404221388 357.51530369025903 -549.61730957030261 227.91457393853958 370.28786144860089
+6 0 8 -94.753067378241539 137.60264083471304 340.68475444739266 -122.62070021536412 146.21136426856725 323.20659657171922 -149.01567114032423 155.36991383287761 303.49085598143682 -174.00646150243318 164.58597985984835 281.9686410715849 -197.64495274077689 173.59480335021829 258.80544298939071 -219.83540295669519 182.19092446148119 234.0620418127703 -240.47460187167701 190.16416578881748 207.78038973671903 -259.31107836669679 197.2946957929318 179.95029046062805 -275.94009695718535 203.31188626477874 150.62032631830704
+6 0 6 -7.3705776686861304 -88.316183198325675 374.73750698739832 -6.2805766605641038 -89.5410706622161 375.25316505503281 -5.3421838320956558 -90.76595815786257 376.08929344691069 -4.6133405973206907 -91.925746897658172 377.21851071676622 -4.1387126734800566 -92.955075999422476 378.58476982782298 -3.93863435634294 -93.801071116212867 380.10933602664636 -4.0093281353064087 -94.430306724078321 381.70727835321185
+6 0 5 -7.3705776691107987 -88.31618319752782 374.73750698645989 -8.0020100576756423 -89.002130814898194 374.43878872901689 -8.6402172324954556 -89.680230795276813 374.13703399381274 -9.2849342459749504 -90.350556305486222 373.83233311886693 -9.9358952267790634 -91.013180290359273 373.5247768308692 -10.592833309239722 -91.668175629322079 373.21445625540161
+6 0 11 -7.3705776686861304 -88.316183198325675 374.73750698739832 -1.7837368076844244 -82.209328387678596 377.38053163661533 3.3152147470705478 -75.544745001581475 379.77548998561161 7.8055812183475259 -68.290481570208357 381.87125582990643 11.520316689468123 -60.478719585693504 383.59533793196982 14.38025128334127 -52.100549736668242 384.9153212096964 16.12304903704683 -43.483855314677136 385.71807667812004 17.266603419322529 -34.830392352875556 386.24464873956094 17.808757556441776 -26.110912108094844 386.49417041270607 18.001522808237727 -17.410625379038329 386.58290296598148 18.001352809715694 -8.7049494548246802 386.5828289401336 18.001352771883859 -4.6185277824406512e-14 386.58282892272018
+6 0 6 18.00135277188398 -1.2789769243681803e-13 386.58282892272013 19.817312855284609 -1.7807977314987511e-13 387.41877063540028 21.432734480947598 -2.1312655326185861e-13 388.69035257282763 22.717082279535923 -2.3665735983304653e-13 390.3375822093347 23.563170667128521 -2.5492228589915161e-13 392.24730710667114 23.921828059631562 -2.7227803164597369e-13 394.27162736963697 23.80176992178324 -2.8711303896433032e-13 396.26714625329595
+6 0 8 -136.32744174501144 196.58177896584334 594.49203619502123 -165.24777591083415 209.1687025197061 617.60627269779548 -196.70571904586959 221.75562607356886 639.16594120464413 -230.0473626970188 234.34254962743162 659.02448770987269 -264.57326351066979 246.92947318129438 677.07692507657873 -299.58807825532676 259.51639673515712 693.26192410357908 -334.45808721705595 272.10332028901985 707.49719582781131 -368.59441432880999 284.69024384288258 719.63086769899792 -401.10223388671869 297.27716739674531 729.70868408985496
+6 0 5 -4.0093281348429999 94.43030672489607 381.70727835411486 -4.6881140672097468 95.159755451881438 381.35728123715865 -5.3734483827265631 95.879361456446247 381.00425081664957 -6.0650234139663901 96.589243898034752 380.64829648427241 -6.7625317228970179 97.289522108951928 380.28952757962293 -7.4656661573385046 97.980315559149801 379.92805336761404
+6 0 11 -4.0093281353064096 94.430306724078335 381.70727835321185 2.0337988363725801 87.936170903057501 384.8232583685886 7.6199186604793319 80.747622460596688 387.69801785418423 12.604874320602676 72.796147726139992 390.26739483829419 16.773794624074526 64.184452963200869 392.43692819433613 20.033695154516572 54.731908657877547 394.17117940192071 21.814040850387777 45.244631341684723 395.1635133603458 23.072829312979017 35.907261581781199 395.84858060688754 23.603133808773659 26.648251355167847 396.15260678341616 23.803079937879698 17.595293234572175 396.26796243096362 23.801769915736045 8.7049494807832062 396.26714627255006 23.801769921783222 1.0302869668521453e-13 396.26714625329589
+6 0 13 -38.416478886585082 3.3287506084889174e-10 552.0840448332774 -38.416478886585644 29.20491248156689 552.08404483327911 -38.402004286212538 52.794846199772323 552.07217072684728 -45.826427612825768 69.276222162863633 558.42025108629525 -51.908065547705263 87.032098753202192 562.45793627935234 -63.157600789100009 97.529388129825449 571.67660547627588 -72.507067301453958 111.87150130395311 578.2716574427443 -85.111302638033706 119.54443245797189 588.48647985901334 -97.048686081842192 129.58153157256396 597.55267985445005 -110.46006436415539 136.04049194002556 608.16388978794851 -124.26709075972713 142.34612037119123 618.86420882310665 -139.02835044743028 147.05371423650362 630.20249040671604 -154.6921515329268 151.30613065603717 641.6914705727803 -171.24821807534349 155.88520260314124 652.98205578409795
+6 0 7 -171.24821807098894 155.88520260558568 652.982055780476 -201.90980911201282 164.36557631505295 673.89205305969233 -233.64527631140453 173.46588419955702 692.54805500189855 -266.00475701422857 183.08500103097739 709.28301146287106 -298.90087955128189 193.17569116755416 724.36079394844057 -332.34685684699303 203.76544087946485 737.98527477892799 -366.55330874705362 214.84491880905566 750.19022564291026 -401.10223388647688 226.09456080824322 760.89099450041863
+6 0 4 -401.10223388671881 297.27716739674537 729.70868408985507 -401.10223388671881 279.77600424097676 739.79060172167135 -401.10223388671881 262.06089054620185 748.21145722047549 -401.10223388671881 244.15826362958035 755.176503756633 -401.10223388671881 226.09456080827201 760.89099450050958
+6 0 1 -16.606510994248268 -106.93972034396965 420.34682837281952 -87.806808471679688 -106.93972034396965 420.34682837281952
+6 0 3 -27.97156577868795 -116.0331554894704 423.48473028757149 -47.916646676351867 -116.03315548947042 423.48473028757149 -67.861727574015788 -116.03315548947042 423.48473028757149 -87.806808471679702 -116.03315548947043 423.48473028757149
+6 0 5 -87.806808471680085 -106.93972448526205 420.3468285629923 -87.806808471680085 -108.92909587753404 420.43818271507502 -87.806808471680085 -110.81766594174763 420.82678202863201 -87.806808471680071 -112.62999876338364 421.46351128775098 -87.806808471680057 -114.3656963891399 422.33903639145421 -87.806808471680043 -116.03319449982925 423.48475710136427
+6 0 3 -38.442757260272202 -125.68180366153105 438.57205112812494 -54.897440997408026 -125.68180366153103 438.57205112812488 -71.35212473454385 -125.68180366153102 438.57205112812488 -87.806808471679673 -125.68180366153101 438.57205112812483
+6 0 8 -87.806808471679702 -116.03315548947043 423.48473028757144 -87.806808471679702 -117.88549095657697 424.75744423492586 -87.806808471679716 -119.51132277726764 426.23187681427305 -87.806808471679702 -120.95721782677442 427.87488076935534 -87.806808471679688 -122.24061040417105 429.6750150013537 -87.806808471679688 -123.36533239671024 431.63421483385741 -87.806808471679688 -124.32764032457196 433.76163256558334 -87.806808471679673 -125.1127392660224 436.06964831084383 -87.806808471679673 -125.68180366298391 438.57205112776404
+6 0 3 -38.370950386165184 -127.93965552230546 451.20111679398542 -54.849569748003361 -127.93965552230549 451.20111679398542 -71.328189109841517 -127.93965552230549 451.20111679398536 -87.806808471679688 -127.93965552230551 451.20111679398536
+6 0 4 -87.806808471679659 -125.68180366153102 438.57205112812483 -87.806808471679659 -126.39422039474442 441.70483126608406 -87.806808471679673 -127.00658462950695 444.85944295053804 -87.806808471679673 -127.52150285461096 448.02829186624717 -87.806808471679673 -127.93965552230549 451.20111679398536
+6 0 3 -39.397452398214767 -129.14574677040747 471.03845732936662 -55.533904422703074 -129.14574677040747 471.03845732936662 -71.670356447191381 -129.1457467704075 471.03845732936668 -87.806808471679688 -129.1457467704075 471.03845732936668
+6 0 4 -87.806808471679716 -127.93964850494572 451.20106442617526 -87.806808471679716 -128.59153550509782 456.14738553178057 -87.806808471679716 -129.00874931360187 461.10624257345626 -87.806808471679702 -129.19817149278151 466.07277740633157 -87.806808471679702 -129.14574677040744 471.03845732936668
+6 0 3 -40.021144853737212 -128.79173811086469 475.37790691660194 -55.949699393051368 -128.79173811086469 475.37790691660189 -71.878253932365539 -128.79173811086469 475.37790691660194 -87.806808471679702 -128.79173811086469 475.37790691660189
+6 0 4 -87.806808471679716 -129.14574677915772 471.0384573293249 -87.806808471679716 -129.13373635219756 472.17608731218354 -87.806808471679673 -129.06630040048765 473.27597467216276 -87.806808471679716 -128.95102321116599 474.34269411879734 -87.806808471679716 -128.79173811086469 475.37790691660189
+6 0 8 -91.741926937081303 127.93047339795018 331.01155955044339 -119.23737068512601 136.58213023278222 313.98630854953871 -145.30929585190469 145.7730903052325 294.77885814566383 -170.00479376955252 155.01842650217625 273.78035327995099 -193.35428490192953 164.05267344281998 251.15775415633223 -215.25870174845909 172.67163773521077 226.9819541209676 -235.61223966885962 180.66691000393081 201.30600917941231 -254.15550383477762 187.81622947588619 174.13714368405769 -270.49197116902383 193.84990939061379 145.55102986806097
+6 0 7 -91.741926937081303 127.93047339795018 331.01155955044339 -91.264563456402598 130.07495801412153 331.3071442669376 -91.08901740908783 132.21944263373157 332.09015818056611 -91.253575214234516 134.19184117171491 333.33684946708206 -91.76039615848272 135.81981473489364 334.96499596750925 -92.566838119590926 136.96639138381843 336.83761119206889 -93.595359436491748 137.56177220325623 338.79475376938251 -94.753067378241553 137.60264083471304 340.68475444739261
+6 0 9 -401.10223388671869 297.27716739680983 729.70868408981767 -401.10223388671869 304.49210649763052 725.5523648163105 -401.10251499755572 311.16671068276446 721.20474292255267 -398.01684521824507 316.08305221962166 715.71965645435648 -390.15910416119937 318.37056658736668 708.65263200858487 -377.20227258263645 317.33698365477665 700.01815309583856 -360.26255400814665 312.48636105097853 690.36269567385636 -341.77468433255069 305.80931181427502 680.67004758459655 -325.62821547049845 299.422441895026 672.45493834168667 -317.05760092109074 296.16754889995036 667.69296448785269
+6 0 8 -317.05760091197112 296.1675488549443 667.6929645619756 -277.75585980428241 281.24178583700177 645.85627333213051 -247.47759334566945 268.6366774481059 625.19297387622385 -225.48037474817204 259.00698716366446 605.68440749735578 -211.0129586376849 251.41662581894656 587.31436357444647 -203.36574272896357 245.33409365773235 570.07196418289527 -201.76116972664212 240.20883119279287 553.93422866516073 -205.48024510962696 235.84663542063853 538.88427115495358 -213.77448017443535 232.12033657705291 524.90864501648548
+6 0 13 -549.61730957021462 227.91457393853307 370.28786144862613 -529.30877202568558 226.24569450039402 378.93800555817882 -508.84129529724754 226.93998423468597 387.27111381405507 -487.31051114978095 224.21837836106673 394.90412774044512 -463.92619064852511 222.37822406182184 401.82672446813064 -438.64478746010991 215.38130802467032 407.88022499722717 -410.85461341583596 212.67162214266639 413.94668533423282 -381.5402894509952 206.93761356811771 419.83272241932991 -350.4153330335343 206.8438537829262 427.26754760352975 -319.00451262420444 205.49528058977523 436.48231139604871 -287.9487476455281 208.96634543247541 449.36893392258588 -258.91632971995921 213.60868123489476 467.12119338740308 -233.5132260615315 223.25243430573516 491.64923883836622 -213.77448017655399 232.12033657737649 524.90864501377189
+6 0 3 -35.568095680177201 -112.64804701119002 495.28009499264584 -52.980999944011359 -112.64804701119002 495.28009499264579 -70.393904207845523 -112.64804701119 495.28009499264579 -87.806808471679673 -112.64804701119 495.28009499264573
+6 0 8 -87.806808471679688 -128.79173455553914 475.37793002302607 -87.806808471679688 -128.24516277646555 478.93014675262737 -87.806808471679588 -127.25480677223291 482.16499985203268 -87.806808471680043 -125.91392211109705 485.12881185937516 -87.806808471679176 -124.22706388475078 487.82422676563891 -87.806808471680057 -122.18942895009803 490.31897425549448 -87.806808471679588 -119.69655740519028 492.46162178464289 -87.806808471679688 -116.66117480811302 494.3463005214449 -87.806808471679688 -112.64804698697164 495.28009488539323
+6 0 3 -19.323704384938566 -37.194229959470533 502.60592504921021 -42.151405747185606 -37.194229959470533 502.60592504921021 -64.979107109432647 -37.194229959470533 502.60592504921033 -87.806808471679688 -37.194229959470533 502.60592504921033
+6 0 7 -87.806808471679659 -112.64804701118999 495.28009499264573 -87.806808471679659 -102.38555146773037 497.66802304416103 -87.806808471679659 -91.932970182812639 499.67025220486869 -87.806808471679659 -81.296276061431755 501.25689377526669 -87.806808471679659 -70.482617865293435 502.38976325855555 -87.806808471679659 -59.506284292140144 503.02459311340306 -87.806808471679659 -48.394668055076991 503.11324550670878 -87.806808471679659 -37.194229961897669 502.60592506636863
+6 0 3 -14.037858916483001 -24.607201913344849 496.44272780859092 -38.627508768215222 -24.607201913344852 496.44272780859092 -63.217158619947426 -24.607201913344852 496.44272780859092 -87.806808471679645 -24.607201913344856 496.44272780859092
+6 0 7 -87.806808471679673 -37.194229959470526 502.60592504921027 -87.806808471679673 -34.552470672146072 502.48626736494401 -87.806808471679688 -32.354174367661756 501.89166341787626 -87.806808471679688 -30.429979576684072 501.08943066124692 -87.806808471679659 -28.730304385379959 500.10727825174854 -87.806808471679702 -27.207989880539529 498.9977918173953 -87.806808471679688 -25.839216823470572 497.77271062279812 -87.806808471679688 -24.607201913344845 496.44272780859086
+6 0 3 -5.7181839244957891 -18.199087263522426 483.21112289766074 -33.081058773557082 -18.199087263522426 483.21112289766074 -60.443933622618374 -18.199087263522426 483.2111228976608 -87.806808471679673 -18.199087263522426 483.2111228976608
+6 0 6 -87.806808471679645 -24.607201913344852 496.44272780859092 -87.806808471679645 -22.98552009919117 494.69209238591026 -87.806808471679673 -21.607637324764347 492.75488395541271 -87.806808471679616 -20.433592595902283 490.64816161654142 -87.806808471679659 -19.460921100289543 488.37032497400924 -87.806808471679645 -18.698575516213157 485.89994903573648 -87.806808471679645 -18.199087262065973 483.2111229003425
+6 0 3 9.4995959567733905 -16.095088724221359 442.37551491941457 -22.935872186044307 -16.095088724221359 442.37551491941463 -55.371340328861969 -16.095088724221359 442.37551491941457 -87.806808471679659 -16.095088724221359 442.37551491941463
+6 0 6 -87.806808471679673 -18.199087263522426 483.21112289766074 -87.806808471679673 -16.977024603196469 476.63256175450209 -87.806808471679673 -16.068435072039211 469.96302579506221 -87.806808471679673 -15.485793313548701 463.20507927216909 -87.806808471679673 -15.25041406672964 456.35742207975477 -87.806808471679673 -15.41648319652062 449.41606666148925 -87.806808471679673 -16.095088724221359 442.37551491941463
+6 0 3 13.569119665319542 -22.47001981945666 426.95722234662929 -20.222856380346876 -22.47001981945666 426.95722234662935 -54.014832426013271 -22.470019819456663 426.95722234662935 -87.806808471679688 -22.470019819456663 426.95722234662941
+6 0 7 -87.806808471679688 -16.095088726108447 442.37551492185065 -87.806808471679688 -16.360880068833367 439.61792214573427 -87.806808471679645 -16.898102890754345 437.08989772988622 -87.806808471679815 -17.640267814592793 434.7433430088322 -87.806808471679545 -18.570099661978347 432.57027796403162 -87.806808471679759 -19.676062003112456 430.54386925787713 -87.806808471679673 -20.967815710219714 428.66859836778389 -87.806808471679673 -22.470019819456663 426.95722234662935
+6 0 3 13.686304975710939 -36.203227413394352 420.32952880859307 -20.144732840085936 -36.203227413394337 420.32952880859307 -53.975770655882812 -36.203227413394345 420.32952880859307 -87.806808471679688 -36.20322741339433 420.32952880859307
+6 0 7 -87.806808471679688 -22.470019819456656 426.95722234662941 -87.806808471679688 -23.779327787373923 425.4656019690641 -87.806808471679659 -25.248288657239261 424.09805912693599 -87.806808471679688 -26.896613343817201 422.87095918300764 -87.806808471679716 -28.74410136610085 421.78775859741063 -87.806808471679659 -30.856560928122612 420.93959764737565 -87.806808471679673 -33.267604536462308 420.32952878132113 -87.806808471679673 -36.203227401481442 420.32952878131334
+6 0 1 -15.799639988582662 -106.18558155641682 420.3295284400715 -87.806808471679688 -106.18558155641682 420.3295284400715
+6 0 3 -87.806808471679688 -106.18558155641682 420.3295284400715 -87.806808471679688 -106.43727123033514 420.32952843986419 -87.806808471679688 -106.68864546708754 420.33529854477837 -87.806808471679688 -106.939736909046 420.34682913351037
+6 0 7 -87.806808471679688 -36.203227413394337 420.32952880859307 -87.806808471679688 -47.193239454889714 420.32952880859307 -87.806808471679688 -57.895632002658758 420.32952884978044 -87.806808471679688 -68.231181763762933 420.32952883159106 -87.806808471679688 -78.185340037588489 420.32952878045188 -87.806808471679688 -87.789255753406991 420.32952876454874 -87.806808471679673 -97.100798507935878 420.32952880859386 -87.806808471679673 -106.18558160289895 420.32952880859386
+6 0 6 -7.3705776686861304 88.316183198325675 374.73750698739832 -6.2805766605641038 89.5410706622161 375.25316505503281 -5.3421838320956558 90.76595815786257 376.08929344691069 -4.6133405973206907 91.925746897658172 377.21851071676622 -4.1387126734800566 92.955075999422476 378.58476982782298 -3.93863435634294 93.801071116212867 380.10933602664636 -4.0093281353064087 94.430306724078321 381.70727835321185
+6 0 11 -7.3705776686861304 88.316183198325675 374.73750698739832 -1.7837368076844244 82.209328387678596 377.38053163661533 3.3152147470705478 75.544745001581475 379.77548998561161 7.8055812183475259 68.290481570208357 381.87125582990643 11.520316689468123 60.478719585693504 383.59533793196982 14.38025128334127 52.100549736668242 384.9153212096964 16.12304903704683 43.483855314677136 385.71807667812004 17.266603419322529 34.830392352875556 386.24464873956094 17.808757556441776 26.110912108094844 386.49417041270607 18.001522808237727 17.410625379038329 386.58290296598148 18.001352809715694 8.7049494548246802 386.5828289401336 18.001352771883859 4.6185277824406512e-14 386.58282892272018
+6 0 5 -7.3705776691107987 88.31618319752782 374.73750698645989 -8.0020100576756423 89.002130814898194 374.43878872901689 -8.6402172324954556 89.680230795276813 374.13703399381274 -9.2849342459749504 90.350556305486222 373.83233311886693 -9.9358952267790634 91.013180290359273 373.5247768308692 -10.592833309239722 91.668175629322079 373.21445625540161
+6 0 6 -10.592833309239722 91.668175629322064 373.21445625540161 -9.5668822484824698 92.925772864993391 373.6990890750177 -8.6879784984706525 94.183371817515152 374.49501966629811 -8.0090896336428639 95.376057695025509 375.57725320001543 -7.5706498617836493 96.438682889737237 376.89377033880169 -7.3908025369769588 97.318157080570444 378.37083246367075 -7.4656661573385037 97.980315559149801 379.92805336761398
+6 0 6 -77.897694258319675 124.06131943852613 339.24594120204245 -80.235318351649198 124.67125335161347 337.91236233863145 -82.563351364034901 125.28263456767996 336.5613315531333 -84.880085390590764 125.90412726530943 335.19411251546728 -87.183800503910362 126.54510351362271 333.81205210564485 -89.472210694914267 127.21630074138861 332.41697364931122 -91.74190981369739 127.93047920613498 331.01157015328675
+6 0 7 -77.897694258123991 124.06131943780453 339.24594120137812 -77.507084710327817 126.09106597953121 339.46877807302388 -77.366339232018902 128.12081250526546 340.12960048672699 -77.503016715928638 130.00729149391802 341.21265892867842 -77.918335924990643 131.60709005711138 342.65596739954077 -78.581754413211527 132.80255950403028 344.35338544141723 -79.437127520723919 133.52553962679386 346.17602174630093 -80.415410045478353 133.75949378479828 347.99545348933447
+6 0 12 -10.592833236353517 91.66817574232924 373.21445633981972 -15.285575703057653 96.347069627771646 370.99772609837277 -20.318674854527945 100.5948555265075 368.62244144069115 -25.616884369370727 104.42830574731289 366.11863751524407 -31.110578397597017 107.85419734039846 363.49852657410258 -36.796987997190712 110.8779917083708 360.77104474156391 -42.592860933889227 113.50527415614201 357.94145655030241 -48.468587396053351 115.76193976295055 355.02200263942979 -54.398597975204659 117.72103923362781 352.02312154947026 -60.311906069096075 119.46809153089103 348.94547248926062 -66.224966066929198 121.04845931528966 345.79081896436526 -72.093343284370007 122.55047809436093 342.55723483369781 -77.897694258123948 124.06131943780454 339.24594120137806
+6 0 3 -87.806808471679688 106.18558155641682 420.3295284400715 -87.806808471679688 106.43727123033514 420.32952843986419 -87.806808471679688 106.68864546708754 420.33529854477837 -87.806808471679688 106.939736909046 420.34682913351037
+6 0 1 -16.606563063487158 106.939736909046 420.34682913351037 -87.806808471679688 106.939736909046 420.34682913351037
+6 0 3 -15.799640023409872 106.18558160289894 420.32952880859386 -39.80202950616647 106.18558160289894 420.32952880859386 -63.804418988923061 106.18558160289895 420.32952880859392 -87.806808471679659 106.18558160289895 420.32952880859392
+6 0 7 -87.806808471679688 36.203227413394337 420.32952880859307 -87.806808471679688 47.193239454889714 420.32952880859307 -87.806808471679688 57.895632002658758 420.32952884978044 -87.806808471679688 68.231181763762933 420.32952883159106 -87.806808471679688 78.185340037588489 420.32952878045188 -87.806808471679688 87.789255753406991 420.32952876454874 -87.806808471679673 97.100798507935878 420.32952880859386 -87.806808471679673 106.18558160289895 420.32952880859386
+6 0 3 13.686304977682806 36.203227401481449 420.32952878131323 -20.144732838771343 36.203227401481442 420.32952878131329 -53.975770655225503 36.203227401481442 420.32952878131329 -87.806808471679659 36.203227401481435 420.32952878131334
+6 0 7 -87.806808471679688 22.470019819456656 426.95722234662941 -87.806808471679688 23.779327787373923 425.4656019690641 -87.806808471679659 25.248288657239261 424.09805912693599 -87.806808471679688 26.896613343817201 422.87095918300764 -87.806808471679716 28.74410136610085 421.78775859741063 -87.806808471679659 30.856560928122612 420.93959764737565 -87.806808471679673 33.267604536462308 420.32952878132113 -87.806808471679673 36.203227401481442 420.32952878131334
+6 0 3 13.569119665319601 22.47001981945666 426.95722234662952 -20.222856380346837 22.470019819456656 426.95722234662941 -54.014832426013257 22.470019819456656 426.95722234662946 -87.806808471679688 22.470019819456652 426.95722234662935
+6 0 7 -87.806808471679688 16.095088726108447 442.37551492185065 -87.806808471679688 16.360880068833367 439.61792214573427 -87.806808471679645 16.898102890754345 437.08989772988622 -87.806808471679815 17.640267814592793 434.7433430088322 -87.806808471679545 18.570099661978347 432.57027796403162 -87.806808471679759 19.676062003112456 430.54386925787713 -87.806808471679673 20.967815710219714 428.66859836778389 -87.806808471679673 22.470019819456663 426.95722234662935
+6 0 3 9.4995959561621337 16.095088726108443 442.37551492185059 -22.935872186451817 16.095088726108447 442.37551492185059 -55.37134032906576 16.095088726108443 442.37551492185059 -87.806808471679716 16.095088726108447 442.37551492185059
+6 0 6 -87.806808471679673 18.199087263522426 483.21112289766074 -87.806808471679673 16.977024603196469 476.63256175450209 -87.806808471679673 16.068435072039211 469.96302579506221 -87.806808471679673 15.485793313548701 463.20507927216909 -87.806808471679673 15.25041406672964 456.35742207975477 -87.806808471679673 15.41648319652062 449.41606666148925 -87.806808471679673 16.095088724221359 442.37551491941463
+6 0 3 -5.7181839244957891 18.199087263522426 483.21112289766074 -33.081058773557082 18.199087263522426 483.21112289766074 -60.443933622618374 18.199087263522426 483.2111228976608 -87.806808471679673 18.199087263522426 483.2111228976608
+6 0 6 -87.806808471679645 24.607201913344852 496.44272780859092 -87.806808471679645 22.98552009919117 494.69209238591026 -87.806808471679673 21.607637324764347 492.75488395541271 -87.806808471679616 20.433592595902283 490.64816161654142 -87.806808471679659 19.460921100289543 488.37032497400924 -87.806808471679645 18.698575516213157 485.89994903573648 -87.806808471679645 18.199087262065973 483.2111229003425
+6 0 3 -14.037858916483017 24.607201913344845 496.44272780859103 -38.627508768215236 24.607201913344841 496.44272780859103 -63.217158619947455 24.607201913344841 496.44272780859097 -87.806808471679673 24.607201913344838 496.44272780859097
+6 0 7 -87.806808471679673 37.194229959470526 502.60592504921027 -87.806808471679673 34.552470672146072 502.48626736494401 -87.806808471679688 32.354174367661756 501.89166341787626 -87.806808471679688 30.429979576684072 501.08943066124692 -87.806808471679659 28.730304385379959 500.10727825174854 -87.806808471679702 27.207989880539529 498.9977918173953 -87.806808471679688 25.839216823470572 497.77271062279812 -87.806808471679688 24.607201913344845 496.44272780859086
+6 0 3 -19.323704384938566 37.194229959470533 502.60592504921021 -42.151405747185606 37.194229959470533 502.60592504921021 -64.979107109432647 37.194229959470533 502.60592504921033 -87.806808471679688 37.194229959470533 502.60592504921033
+6 0 8 -87.806808471679688 128.79173455553914 475.37793002302607 -87.806808471679688 128.24516277646555 478.93014675262737 -87.806808471679588 127.25480677223291 482.16499985203268 -87.806808471680043 125.91392211109705 485.12881185937516 -87.806808471679176 124.22706388475078 487.82422676563891 -87.806808471680057 122.18942895009803 490.31897425549448 -87.806808471679588 119.69655740519028 492.46162178464289 -87.806808471679688 116.66117480811302 494.3463005214449 -87.806808471679688 112.64804698697164 495.28009488539323
+6 0 3 -35.568095680177201 112.64804701119002 495.28009499264584 -52.980999944011359 112.64804701119002 495.28009499264579 -70.393904207845523 112.64804701119 495.28009499264579 -87.806808471679673 112.64804701119 495.28009499264573
+6 0 3 -40.021144853737212 128.79173811086469 475.37790691660194 -55.949699393051368 128.79173811086469 475.37790691660189 -71.878253932365539 128.79173811086469 475.37790691660194 -87.806808471679702 128.79173811086469 475.37790691660189
+6 0 7 -87.806808471679659 112.64804701118999 495.28009499264573 -87.806808471679659 102.38555146773037 497.66802304416103 -87.806808471679659 91.932970182812639 499.67025220486869 -87.806808471679659 81.296276061431755 501.25689377526669 -87.806808471679659 70.482617865293435 502.38976325855555 -87.806808471679659 59.506284292140144 503.02459311340306 -87.806808471679659 48.394668055076991 503.11324550670878 -87.806808471679659 37.194229961897669 502.60592506636863
+6 0 4 -87.806808471679716 129.14574677915772 471.0384573293249 -87.806808471679716 129.13373635219756 472.17608731218354 -87.806808471679673 129.06630040048765 473.27597467216276 -87.806808471679716 128.95102321116599 474.34269411879734 -87.806808471679716 128.79173811086469 475.37790691660189
+6 0 3 -39.397452398214767 129.14574677040747 471.03845732936662 -55.533904422703074 129.14574677040747 471.03845732936662 -71.670356447191381 129.1457467704075 471.03845732936668 -87.806808471679688 129.1457467704075 471.03845732936668
+6 0 4 -87.806808471679716 127.93964850494572 451.20106442617526 -87.806808471679716 128.59153550509782 456.14738553178057 -87.806808471679716 129.00874931360187 461.10624257345626 -87.806808471679702 129.19817149278151 466.07277740633157 -87.806808471679702 129.14574677040744 471.03845732936668
+6 0 3 -38.370950386165184 127.93965552230546 451.20111679398542 -54.849569748003361 127.93965552230549 451.20111679398542 -71.328189109841517 127.93965552230549 451.20111679398536 -87.806808471679688 127.93965552230551 451.20111679398536
+6 0 4 -87.806808471679659 125.68180366153102 438.57205112812483 -87.806808471679659 126.39422039474442 441.70483126608406 -87.806808471679673 127.00658462950695 444.85944295053804 -87.806808471679673 127.52150285461096 448.02829186624717 -87.806808471679673 127.93965552230549 451.20111679398536
+6 0 3 -38.442757260272025 125.6818036629839 438.57205112776415 -54.897440997407912 125.6818036629839 438.57205112776415 -71.352124734543793 125.68180366298391 438.57205112776404 -87.806808471679688 125.68180366298391 438.57205112776404
+6 0 8 -87.806808471679702 116.03315548947043 423.48473028757144 -87.806808471679702 117.88549095657697 424.75744423492586 -87.806808471679716 119.51132277726764 426.23187681427305 -87.806808471679702 120.95721782677442 427.87488076935534 -87.806808471679688 122.24061040417105 429.6750150013537 -87.806808471679688 123.36533239671024 431.63421483385741 -87.806808471679688 124.32764032457196 433.76163256558334 -87.806808471679673 125.1127392660224 436.06964831084383 -87.806808471679673 125.68180366298391 438.57205112776404
+6 0 1 -27.971618427495198 116.03319449982924 423.48475710136421 -87.806808471679688 116.03319449982924 423.48475710136421
+6 0 5 -87.806808471680085 106.93972448526205 420.3468285629923 -87.806808471680085 108.92909587753404 420.43818271507502 -87.806808471680085 110.81766594174763 420.82678202863201 -87.806808471680071 112.62999876338364 421.46351128775098 -87.806808471680057 114.3656963891399 422.33903639145421 -87.806808471680043 116.03319449982925 423.48475710136427
+6 0 5 -270.49197115662895 0 145.551029856838 -271.02558562556226 0 144.61729285660672 -271.5566244256525 0 143.68190184134107 -272.0850681270411 0 142.74486055323121 -272.6108972948428 0 141.80617273828958 -273.13409248915667 0 140.86584214689373
+6 0 1 -270.49197116902371 -193.84990939061382 145.55102986806097 -270.49197116902371 0 145.55102986806097
+6 0 9 -315.39315900402227 0 30.173820451824195 -314.38995214658405 0 35.05845077708458 -313.30139296976796 0 39.927289087343532 -312.12971241327051 0 44.778570072005792 -310.87715231485504 0 49.610686215365902 -309.54594384823474 0 54.422182070148942 -308.13828996264527 0 59.211745222443177 -306.65635195500681 0 63.978195417126855 -305.10223943298047 0 68.720473341866324 -303.47800298573492 0 73.437629699697538
+6 0 9 -321.53737922697076 0 -26.687215805053249 -321.51215809002304 0 -22.842606298693912 -321.42468233797899 0 -18.99468954473749 -321.27564507895505 0 -15.144838834764354 -321.06581126999686 0 -11.294386283647055 -320.79600894183176 0 -7.4446163005175068 -320.46711981763622 0 -3.596760586601718 -320.08006999275364 0 0.24800532704739719 -319.63582106731292 0 4.0885641457197019 -319.13536194508748 0 7.9238576889037828
+6 0 1 -270.49197116902371 193.84990939061382 145.55102986806097 -270.49197116902371 0 145.55102986806097
+6 0 8 -91.741926937081303 0 331.01155955044339 -119.23737068512601 0 313.98630854953871 -145.30929585190469 0 294.77885814566383 -170.00479376955252 0 273.78035327995099 -193.35428490192953 0 251.15775415633223 -215.25870174845909 0 226.9819541209676 -235.61223966885962 0 201.30600917941231 -254.15550383477762 0 174.13714368405769 -270.49197116902383 0 145.55102986806097
+6 0 1 -91.74190981369739 -127.93047920613498 331.0115701532867 -91.74190981369739 0 331.0115701532867
+6 0 6 -77.897694258319675 0 339.24594120204245 -80.235318351649198 0 337.91236233863145 -82.563351364034901 0 336.5613315531333 -84.880085390590764 0 335.19411251546728 -87.183800503910362 0 333.81205210564485 -89.472210694914267 0 332.41697364931122 -91.74190981369739 0 331.01157015328675
+6 0 1 -77.897694258123991 -124.06131943780453 339.24594120137812 -77.897694258123991 0 339.24594120137812
+6 0 12 -10.592833236353517 0 373.21445633981972 -15.285575703057653 0 370.99772609837277 -20.318674854527945 0 368.62244144069115 -25.616884369370727 0 366.11863751524407 -31.110578397597017 0 363.49852657410258 -36.796987997190712 0 360.77104474156391 -42.592860933889227 0 357.94145655030241 -48.468587396053351 0 355.02200263942979 -54.398597975204659 0 352.02312154947026 -60.311906069096075 0 348.94547248926062 -66.224966066929198 0 345.79081896436526 -72.093343284370007 0 342.55723483369781 -77.897694258123948 0 339.24594120137806
+6 0 1 -10.592833236353517 -91.66817574232924 373.21445633981972 -10.592833236353517 0 373.21445633981972
+6 0 5 -7.3705776691107987 0 374.73750698645989 -8.0020100576756423 0 374.43878872901689 -8.6402172324954556 0 374.13703399381274 -9.2849342459749504 0 373.83233311886693 -9.9358952267790634 0 373.5247768308692 -10.592833309239722 0 373.21445625540161
+6 0 1 -7.3705776691107987 -88.31618319752782 374.73750698645989 -7.3705776691107987 0 374.73750698645989
+6 0 11 -7.3705776686861304 0 374.73750698739832 -1.7837368076844244 0 377.38053163661533 3.3152147470705478 0 379.77548998561161 7.8055812183475259 0 381.87125582990643 11.520316689468123 0 383.59533793196982 14.38025128334127 0 384.9153212096964 16.12304903704683 0 385.71807667812004 17.266603419322529 0 386.24464873956094 17.808757556441776 0 386.49417041270607 18.001522808237727 0 386.58290296598148 18.001352809715694 0 386.5828289401336 18.001352771883859 0 386.58282892272018
+6 0 1 -91.74190981369739 127.93047920613498 331.0115701532867 -91.74190981369739 0 331.0115701532867
+6 0 1 -7.3705776691107987 88.31618319752782 374.73750698645989 -7.3705776691107987 0 374.73750698645989
+6 0 1 -10.592833309239722 91.668175629322064 373.21445625540161 -10.592833309239722 0 373.21445625540161
+6 0 1 -77.897694258319675 124.06131943852613 339.24594120204245 -77.897694258319675 0 339.24594120204245
+6 0 5 -986.58041745656942 -191.24530150611923 417.03458335149816 -986.58129058014867 -188.29597008571699 398.46124527657935 -986.58219187473605 -184.85514502485722 380.79709940325097 -986.58298396780742 -181.24403164837815 364.54027181741873 -986.5835450084104 -177.68923573821047 349.96746902643747 -986.58389113763769 -174.18268314257679 336.76440333881135
+6 0 5 -1357.2998046875 -140.31946347921908 362.68733259059042 -1288.3392033724342 -149.74517052458046 335.46007510878684 -1219.3786020573682 -158.93938475260344 307.97183417148591 -1120.0058707994283 -121.89706507359358 334.64601007881811 -1057.8249739693033 -151.60668166320406 335.89015443149003 -986.58389113763894 -174.18268314342811 336.76440334201658
+6 0 8 -1357.2998046875 -184.19343141626584 452.17426057650368 -1357.2998046875002 -185.05111500606995 439.16105004969597 -1357.2998046875 -183.96924362201995 426.02000600561985 -1357.2998046875 -180.9255888148524 413.08838975297846 -1357.2998046875 -175.96827797494166 400.70808146844314 -1357.2998046875 -169.21708550706694 389.20732168668997 -1357.2998046875 -160.85811750564147 378.88172957645463 -1357.2998046875002 -151.13216676089272 369.9787429651854 -1357.2998046875 -140.31946347921911 362.68733259059042
+6 0 5 -996.77216635433797 -189.2964038667937 424.69852211975831 -1065.6985963393074 -167.62829912229193 421.49186914531657 -1132.2343631122703 -147.33400929148314 414.47817006493057 -1217.8087340121583 -210.13110685848255 422.152306463532 -1287.5542693498292 -197.23905621375533 436.82478128348419 -1357.2998046875 -184.193431416267 452.17426057650363
+6 0 5 -991.70873241065112 -190.27257572426066 420.84514780642047 -992.72738694329144 -190.07732681267055 421.61191409268628 -993.74280264911658 -189.88191627387013 422.38080376433129 -994.75524335394834 -189.68652297894323 423.15163329394881 -995.76495524143206 -189.49130579221674 423.92424809473692 -996.77216635302932 -189.29640386740135 424.6985221216429
+6 0 5 -986.58041744691218 -191.24530150125463 417.03458331173488 -987.61366569570873 -191.05185529954679 417.79162834317503 -988.64283133987203 -190.85765057124527 418.55143447589052 -989.66821297661897 -190.66290648736771 419.31375991332675 -990.69009206194494 -190.46782191716883 420.0783921967502 -991.70873241065112 -190.27257572426066 420.84514780642047
+6 0 6 -996.77226793690636 -189.29639490612192 424.6984683660055 -995.84876733389888 -189.77968832293547 426.04305221291241 -994.82420378957568 -189.93428284722197 427.43637249424648 -993.74666005054303 -189.7349888645125 428.80841559529932 -992.67321689465894 -189.18521930694678 430.08465777328848 -991.66057138090184 -188.32118344067322 431.19954001591901 -990.75582897676838 -187.2012193948342 432.10588064175693
+6 0 5 -980.79218587889761 -189.29743652653508 424.45763435929945 -982.79864942049585 -188.88472830897831 425.96960572513052 -984.79672987615243 -188.46709778507901 427.4921902324765 -986.78810206977846 -188.04635153163181 429.02339863747875 -988.77407965217367 -187.6239962384137 430.56164528350348 -990.75564218545139 -187.20123482450518 432.10576511670246
+6 0 6 -980.79218590463609 -189.29743651965578 424.45763442256685 -981.67262127946049 -190.37172335815933 423.52827439040476 -982.650805038199 -191.19422700217584 422.40046987616677 -983.68250446108743 -191.71095216541224 421.12090550934499 -984.71509746784398 -191.88890600887743 419.75314175988251 -985.69588141791075 -191.72563732719965 418.36869063633554 -986.58041745194168 -191.24530150433361 417.03458335737452
+6 0 5 -856.35179034834869 -207.57772114127016 363.77344702748479 -856.53714865727363 -208.077456573577 362.58232224954196 -856.71057096665015 -208.38188615804836 361.30739966006229 -856.8654714758419 -208.47317590343519 359.99092297407913 -856.99616837592248 -208.34797726754798 358.68118105148363 -857.099023755193 -208.01809895417281 357.42282000739363
+6 0 8 -986.58041745194168 -191.24530150433364 417.03458335737452 -972.13929821371084 -193.94899028140875 406.45381176038427 -957.27731102775647 -196.42497084994412 396.3808184464641 -941.95002993104265 -198.68987348993926 386.91671828105717 -926.11496493506502 -200.74639102379868 378.20604094075117 -909.6867252722916 -202.61555664645311 370.49456797639618 -892.67594755370806 -204.3560737472211 364.07288807403671 -875.01641511818707 -206.0886638575108 359.44564088410806 -857.09902375519357 -208.01809895417267 357.42282000739363
+6 0 8 -980.79218590463609 -189.29743651965578 424.45763442256685 -966.7706838287786 -192.18150747722009 413.89175862417375 -952.37633158699896 -194.84572666441844 403.8005575660157 -937.57501781668896 -197.30644877135057 394.28912284700363 -922.32259483518646 -199.56490329165723 385.49978455570186 -906.54613848383235 -201.64200461550232 377.67021730789156 -890.25674511454247 -203.58764725353691 371.064485023891 -873.39670730411865 -205.50764988704108 366.16992597022181 -856.35179034834937 -207.57772114127013 363.77344702748474
+6 0 5 -792.214116688952 -218.16627834130932 377.18611263472462 -791.67606939797338 -218.50937858499367 376.38281001206502 -791.09049749017345 -218.73141945196656 375.55963323954393 -790.46919290662538 -218.82485323799236 374.73419717763409 -789.8260697254758 -218.78758749914803 373.92498741645392 -789.17540027336474 -218.62325031107312 373.14901685632265
+6 0 8 -857.09902375519312 -208.01809895417281 357.42282000739368 -848.1403280736962 -208.98281650250377 356.41140956903655 -839.11720814567229 -209.99644285058272 356.04962917836713 -830.07721407596023 -211.08461202013891 356.4401585496193 -821.104151310887 -212.27710989752873 357.69291505378845 -812.30543596296684 -213.60544310844048 359.93418099573483 -803.90142279969382 -215.1091429122925 363.28787158546641 -796.13207341203565 -216.79133973181749 367.72509568212064 -789.1754002733644 -218.62325031107312 373.14901685632282
+6 0 8 -856.35179034834869 -207.57772114127016 363.77344702748479 -847.82933187046399 -208.61275676838463 362.5752075561162 -839.26033433089663 -209.68500272377526 362.0005061707231 -830.69258250626945 -210.81654527333814 362.14856470896069 -822.20466190618902 -212.03249469785308 363.1284923920428 -813.90420439345212 -213.35921764866552 365.06637207171082 -805.99736522736396 -214.82938669436578 368.08259142975191 -798.71203258547416 -216.4414046699153 372.15452624169706 -792.21411668895166 -218.16627834130929 377.18611263472445
+6 0 6 -766.91669454458088 -231.9866395936422 435.92481540532015 -766.11458306464431 -232.61239913821191 435.81408717118563 -765.23443833093143 -233.14094836145182 435.71926368950727 -764.2913655469722 -233.56045819733535 435.64243774692045 -763.30298371474737 -233.86228592019296 435.58518052599862 -762.28830041185267 -234.04139538005535 435.54846349136125 -761.26658656866323 -234.0967772379966 435.53258027578187
+6 0 7 -789.17540027336474 -218.62325031107312 373.14901685632265 -781.22491668631187 -220.71686240165099 379.34778391255367 -774.35849339660285 -223.0098198555651 386.86036106739141 -768.86580896812359 -225.45590057837194 395.53217643259677 -764.92559022078387 -227.94019166464085 405.01776355858186 -762.45377921246643 -230.27855973771918 414.98667288141723 -761.29423450626211 -232.35732345337325 425.21164475188459 -761.26658656866266 -234.09677723799666 435.53258027578164
+6 0 7 -792.214116688952 -218.16627834130932 377.18611263472462 -784.78792709292634 -220.13756253718822 382.93649708389887 -778.41257121774902 -222.25902171818464 389.9655361803828 -773.35776418584032 -224.48385676033297 398.12215060291089 -769.79178934189042 -226.70375695789511 407.07029722219198 -767.63139198970657 -228.75498303676753 416.48758223626584 -766.73046356032535 -230.53807867208135 426.15741255619486 -766.91669454458099 -231.98663959364245 435.92481540532009
+6 0 6 -822.27918963051548 -218.41848119959877 561.76339605587043 -821.7295265186084 -219.7788807270727 562.8084800449227 -820.88558496026951 -220.92015770783462 563.98402276405534 -819.77941901443614 -221.76288536577781 565.2290367293308 -818.47206886691276 -222.24872406128443 566.46945969374769 -817.04586087053985 -222.35709456536472 567.63171515824274 -815.58600837106644 -222.10287155577728 568.6560287278254
+6 0 9 -761.26658656866312 -234.09677723799658 435.53258027578187 -761.22357866573077 -236.80259423629971 451.58736886851051 -763.82172555104842 -238.71770673456359 467.86728327544057 -768.46631588989999 -239.57995528001814 483.83924696455529 -774.46651587011797 -239.32961788722258 499.31442911889002 -781.46219045710814 -238.03677237043985 514.31413619678483 -789.21222013860017 -235.68604604510108 528.79243992823115 -797.54313150613746 -232.27255440492246 542.74455572908607 -806.3559983327907 -227.74430775105697 556.07817913076065 -815.58600837106644 -222.10287155577726 568.6560287278254
+6 0 9 -766.91669454458088 -231.9866395936422 435.92481540532015 -767.20638718675639 -234.23995658273728 451.11855317062611 -770.03335145627454 -235.71280962137851 466.54105540329493 -774.83192497018536 -236.18721871468401 481.67965706144196 -780.93928328467814 -235.6242711539669 496.34742183236796 -788.02457277003805 -234.10443426669627 510.55775365366515 -795.83117813022159 -231.62191912752874 524.25200219404826 -804.21100671202191 -228.18978863620615 537.41684644177292 -813.0507976748579 -223.78312233824087 549.95734912758576 -822.27918963051559 -218.41848119959877 561.76339605587032
+6 0 6 -916.81364449549085 -144.16254924802371 633.13065659741983 -916.70169562890646 -144.67552470894077 635.07807693032294 -916.2743913073889 -144.82407932243413 637.10336196363448 -915.53985932403953 -144.57061991889765 639.06407835969753 -914.54515806937593 -143.92219684744322 640.80715168689062 -913.37245293365743 -142.93915648756271 642.20887606708777 -912.11382561718278 -141.71135632112427 643.19704930835417
+6 0 10 -815.58600837106735 -222.10287155577745 568.65602872782574 -823.89301740551548 -217.0255789800257 579.97609336518406 -832.53386996753625 -211.0570777878155 590.69218493830931 -841.46381355657695 -204.2002243725789 600.70119441711256 -850.66444909334575 -196.47943463174778 609.89423043302293 -860.13201475941798 -187.97357553609433 618.0863605434289 -869.87511482248169 -178.91286995797373 625.158618239764 -879.91493895210806 -169.57641224229224 631.13151563681936 -890.28180202776002 -160.16164962992963 636.09909955386593 -901.00653016296496 -150.82477068363829 640.11101044015788 -912.11382561718278 -141.71135632112419 643.19704930835405
+6 0 10 -822.27918963051525 -218.41848119959903 561.76339605587066 -830.58474239060718 -213.59030417482111 572.38883829132669 -839.20120428389282 -207.99543264623628 582.42686696399778 -848.07631243023013 -201.64392039841258 591.79337857390419 -857.18437917298593 -194.56698025336294 600.40419098360337 -866.5045417929324 -186.82548199309338 608.13300752521968 -876.03698412798201 -178.57743916937434 614.90817178463431 -885.80392377207397 -170.02685943455339 620.74789371851762 -895.83632990717592 -161.34338909311435 625.71166156958725 -906.16478659258235 -152.67380035295724 629.83650636352866 -916.81364449549096 -144.16254924802371 633.13065659741983
+6 0 5 -951.86543925528395 -118.58657073894892 639.53852627875085 -944.54503739804238 -123.33568236951518 639.09931916532662 -937.37966356550555 -128.33411238151351 638.21685652921769 -930.37446762112199 -133.50866938219619 636.91001560663631 -923.52253578446687 -138.8003518477359 635.2058939739328 -916.81365206331122 -144.16252430425348 633.1305705057996
+6 0 7 -990.75582897676838 -187.2012193948342 432.10588064175687 -999.15797985146514 -185.40879956017824 438.65299049687354 -1007.4871050055364 -183.61066762319865 445.29773365833154 -1015.8078096030599 -181.88112126082305 451.96954749317655 -1024.141693528238 -180.25816259880904 458.64710731111012 -1032.4866913870014 -178.75124996951027 465.33423120889807 -1040.8270869412215 -177.3487231158982 472.04347066855985 -1049.1444766448062 -176.02328600584735 478.79472919085487
+6 0 8 -1049.1207867878595 -176.01677785876024 478.78580774805306 -1050.245903234357 -175.83374681468848 479.70272161515152 -1051.3702254075911 -175.65143053229176 480.6207690044514 -1052.4936717695375 -175.46968227497337 481.54003730006582 -1053.6161544112085 -175.28834664717982 482.46061398421688 -1054.7375807403603 -175.10725868454628 483.38258774132237 -1055.8578542383523 -174.92624317611495 484.30604895959232 -1056.9768746640125 -174.74511413139248 485.23108986958925 -1058.0945379032166 -174.56367431195883 486.15780446873356
+6 0 11 -1064.5738964958907 -171.10675440908062 493.861425127789 -1064.3838641897851 -171.72997351116942 493.13164528695143 -1064.0108636053869 -172.26883643834961 492.36230811845672 -1063.5187680145009 -172.71501208013152 491.60204105540134 -1062.9531449811439 -173.08663142020106 490.86166540651953 -1062.3478700555072 -173.41111524864556 490.14042137892454 -1061.6922170194225 -173.68505155548812 489.43299573470227 -1061.0153108754876 -173.9202843419971 488.7482877684584 -1060.3108808241091 -174.12213740208264 488.07722298706454 -1059.5882336626805 -174.29536352408948 487.4224224207772 -1058.8484477153527 -174.44126856280167 486.78294110318944 -1058.0945209048957 -174.56365784361259 486.15782174523429
+6 0 10 -1062.8676486468482 -167.32920065833196 496.4563345315816 -1063.2457896464293 -167.66278710900983 496.36620216188442 -1063.6007369706422 -168.01436424520344 496.24593895760745 -1063.9245120374603 -168.38503898155599 496.08924992157017 -1064.2100230064791 -168.77007292433561 495.89604130794299 -1064.4514155314691 -169.18037686625448 495.65261166816515 -1064.616063411469 -169.59014071506908 495.36035247922916 -1064.7139629733783 -170.00525521223818 495.02226408419398 -1064.7264715425422 -170.39532843795544 494.65177933726648 -1064.6784142642489 -170.76398390293193 494.2628040402497 -1064.5738964958907 -171.10675440908076 493.861425127789
+6 0 7 -1058.491230325594 -164.67417872184137 496.4078607822733 -1059.1624622915733 -164.97456183602938 496.50886024691852 -1059.8255895695145 -165.29604651769824 496.58779484551422 -1060.4788139729603 -165.64110252376307 496.64127164261924 -1061.1172736659353 -166.01263305989443 496.66360812871585 -1061.7366509623648 -166.41461304254895 496.64877262006371 -1062.3274472188748 -166.85264858593504 496.58509505972052 -1062.8676486468482 -167.32920065833196 496.4563345315816
+6 0 5 -1007.392856646776 -151.39116648706039 488.57730488654369 -1017.9779091583341 -152.5504732856879 490.22297331980423 -1028.4683088002546 -154.38304228981872 491.84404759473472 -1038.7955476773486 -156.9572835589353 493.42830525242852 -1048.8599449806056 -160.36406482632742 494.95867275778693 -1058.4912368055216 -164.67416056703678 496.40786927471169
+6 0 10 -970.19406942959301 -132.03283789677465 524.79854772238514 -969.44629782627658 -134.42615379854311 518.67819738746221 -969.76057849888105 -136.79558936118258 512.48367803205679 -971.23857445435556 -139.12792143522495 506.42696101094481 -973.96231283265877 -141.41609127965688 500.76269070867221 -977.86415609738708 -143.64467824875001 495.84373799129258 -982.78047352273427 -145.79649906329109 491.92618060705888 -988.45314601693565 -147.78307233240827 489.19206279385293 -994.63980026953243 -149.46094946500344 487.75657099268579 -1001.0360091107659 -150.69496035859405 487.589016658584 -1007.3928533894435 -151.39115042443942 488.5773180767851
+6 0 8 -958.85170143669188 -114.17197968682677 635.63669784992749 -964.00756093619054 -111.17544247545597 622.84568426662292 -967.99360592220296 -110.39204353783197 608.9511351749893 -970.71010952834979 -111.55097345287187 594.63906341538404 -972.32815378096814 -114.0437018448451 580.35936676007805 -973.00603743899137 -117.55882370535805 566.1823424317771 -972.81217325920363 -121.84888228117512 552.1791152038021 -971.85383352297151 -126.72058839458741 538.38344691126304 -970.19407917400747 -132.03281481057741 524.7986052936468
+6 0 10 -958.8517310144174 -114.17195471901805 635.63671697516838 -958.49801473681271 -114.37753106458074 636.51423692627111 -958.01507669598925 -114.66702945196042 637.31202146244698 -957.40753417780263 -115.03894232850055 637.99597579773535 -956.71333302000903 -115.4724576045564 638.54707243203461 -955.95195602477008 -115.95333874841076 638.96273639560309 -955.16488565355939 -116.45539193911164 639.25951524442723 -954.35099193601377 -116.97798895877051 639.46076505933036 -953.52595826254185 -117.51041706893079 639.56412322248252 -952.6959211493031 -118.04779202353936 639.58837833908933 -951.86538894739692 -118.58659913230451 639.53855077512094
+6 0 7 -497.91964893460181 -7.4876993494399358e-11 618.52248840150958 -497.91956308993343 -20.601574319409419 618.52243921908973 -498.27920010297112 -41.389102442843544 616.92858456146189 -498.92179751868781 -62.178248783727469 613.46056787057705 -499.79816638318027 -82.684428051261662 607.85776232047601 -500.88619917579626 -102.36776609384908 600.22382088550933 -502.27539931961326 -121.07666826256839 590.95050530958861 -504.08517893959117 -138.77628525870716 580.39872152863643
+6 0 6 -497.91964891133961 -5.8938639559136252e-14 618.52248837093975 -494.53866015078154 -3.8634713194855382e-14 616.58534900472137 -491.45959982832983 -2.8227691529282418e-14 614.12122988956321 -488.78513370299237 -1.7031469580295206e-14 611.18894816961313 -486.60273669219413 -7.0980039749684864e-15 607.87410451900337 -484.97380081675823 -3.9314180155253938e-16 604.28257790811745 -483.93001613052223 1.400817349520943e-14 600.52836594660653
+6 0 8 -483.93001613052223 1.4008173495209443e-14 600.52836594660664 -483.92994788629369 -17.151368569347401 600.52836678158155 -484.16734337496968 -34.285569388837274 599.35482299264356 -484.58132372853908 -51.30503455869993 596.85118756283237 -485.12402873121113 -68.08080910547703 592.88262516588031 -485.75677423340125 -84.422728830460258 587.39216966293213 -486.51946301153095 -100.1862423466589 580.49888169668282 -487.48209076128484 -115.32307774385487 572.37262963981766 -488.74250075376426 -129.82956305966718 563.19500009910553
+6 0 6 -504.08517894036487 -138.77628526661439 580.39872152386783 -500.31789282448381 -138.03053245948681 578.58367264788535 -496.87913285356456 -136.93126699913671 576.23198668812563 -493.90481798668674 -135.5053840385508 573.40913061124684 -491.51130957198609 -133.80114700494897 570.21305470829179 -489.7780896095328 -131.88449391698455 566.76540753298571 -488.74250075376443 -129.82956305966721 563.19500009910541
+6 0 10 -962.75722820414126 -108.65464220286081 638.67004920255079 -961.96730577277413 -109.14304984400323 640.49404976339838 -960.93840573772923 -109.68545631576251 642.20770326266654 -959.69044967919501 -110.26874310644111 643.74929574535065 -958.27793891934289 -110.87566900919742 645.05584422931281 -956.77731018028283 -111.47737797223284 646.12697937272446 -955.21831668143329 -112.07324984462007 646.98816890643388 -953.63734029059958 -112.6518223562245 647.65635655968413 -952.03975347143285 -113.21252971428657 648.15581300163387 -950.44527914345997 -113.75168371240319 648.49902201684688 -948.85936033769019 -114.26802971900702 648.70208985965314
+6 0 6 -975.82839307373638 -5.6672888604225591e-11 657.27349502153186 -975.82839360716525 -18.90592852140524 657.27349532012192 -974.61361487494332 -37.717759211068596 656.23933552824212 -972.42393899475701 -56.237916061124835 653.96990463240923 -969.58109554597229 -74.321588234225885 650.28141271841764 -966.31786073508079 -91.821781198349314 645.14775812000278 -962.75723105906718 -108.65463952439433 638.67005078498767
+6 0 8 -962.79144943151505 -9.7170535506840849e-15 669.33533616730335 -964.64558926955738 -2.7700606565483898e-14 668.78912978094718 -966.51546744403151 -3.5419715585615396e-14 668.01520938670899 -968.38823607901259 -3.5858541574740632e-14 666.98926788072936 -970.22264207093269 -3.1390173663506388e-14 665.66553291447042 -972.00321051281207 -2.4902838347987529e-14 664.0383434848294 -973.61726342122506 -1.8129273658932497e-14 661.9979419241746 -974.90474416436405 -1.9856884962265336e-14 659.69685701869764 -975.82839307127244 -3.8693630547911893e-14 657.27349502793754
+6 0 6 -962.79144941062043 -5.9877436342503643e-11 669.33533617349099 -962.7914503881002 -19.480017704921075 669.33533589296917 -961.51878443949818 -39.069065670153648 668.21282538767719 -959.21089758304606 -58.56789105511762 665.71406353253781 -956.18532221092266 -77.759643295907594 661.60154153270207 -952.69236931703767 -96.377121298175311 655.87537000910038 -948.85936035125872 -114.26802965505392 648.70208116504921
+6 0 6 -951.86543925308661 -118.58657615609889 639.53852627889682 -951.87347687225292 -118.66032210626427 641.39252247562342 -951.65618496867114 -118.38810337555282 643.26125747829371 -951.21303919009063 -117.76531255003125 645.02993107482268 -950.56695315895934 -116.82330777843097 646.58159315921216 -949.76371848640815 -115.62943303266088 647.82375789591788 -948.85934706004525 -114.26800930943244 648.70208134672043
+6 0 5 -948.85934705780164 -114.26800930980895 648.70208342798719 -941.14651608256634 -119.37171370877704 648.49578486222151 -933.61724856735054 -124.74123485345018 647.81875463258064 -926.27534832896436 -130.29586210378375 646.69160545677971 -919.11156028657422 -135.96979269060412 645.14116031412402 -912.11385977492148 -141.71132581042386 643.19695655786199
+6 0 9 -504.08525565637393 -138.77631739686004 580.39886155965166 -504.97126574905735 -147.44167473338314 575.23291171101744 -505.95892464291103 -155.97961153174859 569.70510141708075 -507.06226051143193 -164.37715188409155 563.77031500569592 -508.29256245839099 -172.62008581949428 557.37003370929563 -509.6670542236343 -180.65855411075327 550.40187279727866 -511.20328370154471 -188.4181579808853 542.7693301089954 -512.93944907152218 -195.82458911714704 534.30133491125787 -514.93719419216677 -202.55844286528512 524.76595479850334 -517.16342521475008 -208.22457291448245 514.29852713637297
+6 0 9 -488.74252946237357 -129.82958003949014 563.1951353141626 -489.44773172367468 -137.94623537921191 558.06007945123042 -490.24458542804462 -145.86936809578592 552.60097033181046 -491.13238579830409 -153.56126473655766 546.78914595278559 -492.10883613705306 -160.9908688133666 540.58070462031583 -493.17480439763921 -168.06554914995158 533.92273744273075 -494.33008537169576 -174.72771794235848 526.75229694226709 -495.58317030297303 -180.82552709643286 518.98648091147857 -496.94949000066231 -186.1454212940186 510.56866026912712 -498.45723017994925 -190.4971457482815 501.57074294508953
+6 0 6 -498.4572301799497 -190.49714574828153 501.57074294508823 -499.53333756360121 -194.72823363411635 503.99928094807814 -501.57165614708038 -198.69535565807971 506.46138377845494 -504.5185236758287 -202.18735639556627 508.83586102201411 -508.23969622770363 -205.01450258510829 510.99835000633374 -512.53171370126574 -207.04649321767408 512.84343797785061 -517.16342521475042 -208.22457291448254 514.29852713637217
+6 0 11 -1069.0502061463187 -172.3932246873602 493.95994249952633 -1069.053722562418 -173.63911699248925 492.53121647632736 -1068.8595626515723 -174.67793652927509 491.05127628895349 -1068.5195940840208 -175.49461872932616 489.6108701490071 -1068.1045078789653 -176.15902848504376 488.21746685993929 -1067.6169123158554 -176.69690238062825 486.86870035982469 -1067.0867001650108 -177.13194411933964 485.56350618495458 -1066.5095304137938 -177.47675765392975 484.29439701542299 -1065.9076273228086 -177.74751691681894 483.06570459828009 -1065.2711572025382 -177.95059430439332 481.86951085151748 -1064.6130087712545 -178.09403184685675 480.70648097427335 -1063.9324841412592 -178.18354221590403 479.57442086582887
+6 0 5 -1069.0502061463192 -172.39322468736029 493.95994249952622 -1068.1236434108616 -172.29594016209654 494.08751197908009 -1067.1958277316164 -172.1153551914351 494.14244070197611 -1066.2838337252117 -171.85325241597215 494.12236897781776 -1065.4047548931837 -171.51454442741729 494.02767301088386 -1064.5738964958905 -171.10675440908074 493.861425127789
+6 0 6 -1063.9324957131 -178.18353067905062 479.57442316600697 -1062.9130549852234 -178.35245967353072 480.86415038384064 -1061.8446994526394 -178.19733741037098 482.15766019259161 -1060.7775219457421 -177.70984381500296 483.39157488063688 -1059.765807638267 -176.908310221184 484.50199677090137 -1058.8589615532831 -175.83869767331259 485.43589368069729 -1058.0945379032169 -174.56367431195883 486.15780446873356
+6 0 10 -1066.2730847791713 -164.30496789283359 499.41187802731179 -1066.7418007802764 -165.06198204544205 499.17280956041708 -1067.1919938826329 -165.85161026281321 498.87693954281582 -1067.6161372960942 -166.6719687973463 498.51498954591915 -1068.0101641372125 -167.52574370549291 498.07985028297725 -1068.3551810423919 -168.39830787428295 497.56145718181187 -1068.6485919632603 -169.29032103253502 496.94809823987902 -1068.853028873355 -170.14952931558381 496.25754338527344 -1068.9863944471902 -170.95976607825193 495.51592834186806 -1069.0482721174649 -171.70798391953932 494.74574181228564 -1069.0502061463194 -172.39322468736029 493.95994249952622
+6 0 6 -1066.2730847791713 -164.3049678928335 499.41187802731213 -1065.656305182669 -164.92387772558223 499.13561296737839 -1065.0471543063725 -165.50826465710986 498.7649794563506 -1064.4549620873263 -166.04876194523766 498.3041398425766 -1063.8888445915179 -166.53691357494114 497.75969419750072 -1063.357274008639 -166.96555612894733 497.14030711847681 -1062.867648646848 -167.32920065833201 496.4563345315816
+6 0 7 -1061.1536100771793 -158.00839316453602 499.99571324713463 -1061.9139842056077 -158.75715664960234 500.09331896751206 -1062.6705476500833 -159.54667732102277 500.1481524761025 -1063.4213066148964 -160.38182772135241 500.15302741399535 -1064.1638154781758 -161.26724619966396 500.09904507433765 -1064.8936214820314 -162.21166728875119 499.97244816771041 -1065.6034904918779 -163.22351910339282 499.75340440859014 -1066.2730847791709 -164.30496789283347 499.41187802731213
+6 0 6 -1061.1536166606386 -158.00837876517375 499.99571451386777 -1060.5783919091807 -159.25640164255958 499.9218744158336 -1060.0321035141772 -160.50442348883391 499.62261688260594 -1059.5343570716936 -161.70990913671366 499.10045531016499 -1059.1031423109662 -162.83025333190577 498.37074127176334 -1058.7524682735825 -163.82794497799884 497.46124450550957 -1058.4912369863059 -164.67414646538467 496.40786929271712
+6 0 5 -1007.8562696243526 -143.11770120665915 493.15420312502943 -1018.874454470975 -144.51727633428595 494.56855255311888 -1029.8037822015742 -146.62766296726656 495.97149562798825 -1040.5739527925557 -149.52041084882674 497.35400737009149 -1051.0824460769163 -153.29006153622899 498.7029297509992 -1061.1536165933521 -158.00837873365032 499.99571574534872
+6 0 6 -1007.8562700524346 -143.11769561694484 493.15420469747363 -1007.6524988890427 -144.74832591562108 493.12804645923353 -1007.4899965944252 -146.37896451783052 492.78038232823246 -1007.3786706743861 -147.93033532123775 492.11247784605439 -1007.3250962922909 -149.32295705501068 491.1517615925971 -1007.330829362728 -150.49114550207531 489.95111073626782 -1007.3928533894436 -151.39115042443945 488.57731807678499
+6 0 10 -978.37243038513066 -126.19521751422829 521.78813449874497 -977.68784325685783 -128.70385323319385 517.06970566589644 -977.86656756359639 -131.10433169529745 512.27528288176677 -978.99917321726264 -133.37097266374082 507.56518364568433 -981.13433430122245 -135.48816211849726 503.14318745850841 -984.24106244245775 -137.45445968055228 499.26931648151771 -988.15150978347697 -139.25670834340758 496.15982104614636 -992.68307246314487 -140.83915594512754 493.95157360305797 -997.62595812690063 -142.07949739969277 492.73604364229305 -1002.7505033759528 -142.86265096230909 492.49880569561248 -1007.8562700524344 -143.11769561694487 493.15420469747369
+6 0 6 -978.37243941871236 -126.19519197464878 521.78818983153269 -977.74950219435334 -127.79004615312705 522.46278076256488 -976.74572562667038 -129.24437881196576 523.11791598595732 -975.39901231058479 -130.46101780568878 523.71249843481883 -973.78643511792575 -131.35668747401724 524.20721666595148 -972.01449018314213 -131.88363396157445 524.57381124947619 -970.19407912982547 -132.03281461715247 524.79860513128028
+6 0 8 -962.75721946759234 -108.65467445857597 638.67001256198557 -968.60800926145407 -105.26361004264258 624.93244697858756 -973.26582471891982 -104.22777313819907 610.1194882359614 -976.60099768409032 -105.27655370195789 594.94912899907513 -978.78398992507334 -107.74230504597581 579.90607817964781 -979.96050852921394 -111.31301648707492 564.99583060251723 -980.22339296492612 -115.70749483798284 550.33925004153969 -979.67069691013148 -120.7178764190121 535.93587235210953 -978.37243942293401 -126.1951919717666 521.78818977107437
+6 0 6 -962.75722820414126 -108.65464220286081 638.67004920255079 -962.49351185110504 -109.82452017179855 638.26747147540857 -962.05693200486189 -110.93513138474889 637.80590121770695 -961.4550921754709 -111.95276793475104 637.29694010749199 -960.70389986758084 -112.84656564859274 636.75502452075318 -959.82674879301101 -113.59186770357043 636.19624265768095 -958.8517310144174 -114.17195471901805 635.63671697516838
+6 0 6 -504.08525565637393 138.77631739686004 580.39886155965166 -500.31795233433274 138.03056176346675 578.58380946602165 -496.87916737400673 136.93128573615127 576.23210666187572 -493.90487085607322 135.50541122506789 573.40927221884806 -491.5113717345651 133.80118635440655 570.21322282369624 -489.77812851502568 131.88452002929546 566.76555491527927 -488.74252946237357 129.82958003949017 563.19513531416271
+6 0 7 -483.9300160827533 2.824574341780961e-14 600.52836588643413 -483.93001073122207 19.601564071044233 600.5283466384144 -484.24570150806551 39.180075536142056 598.96274147634631 -484.78518033085624 58.580838801491694 595.58807808500853 -485.45862441368547 77.578979929916187 590.17005928770789 -486.25786693518472 95.831039826378145 582.76945881637448 -487.30207090151958 113.25071502664083 573.68371273724631 -488.7425007536898 129.82956305962392 563.1950000990222
+6 0 7 -497.91964893460181 7.4876993494399358e-11 618.52248840150958 -497.91956308993343 20.601574319409419 618.52243921908973 -498.27920010297112 41.389102442843544 616.92858456146189 -498.92179751868781 62.178248783727469 613.46056787057705 -499.79816638318027 82.684428051261662 607.85776232047601 -500.88619917579626 102.36776609384908 600.22382088550933 -502.27539931961326 121.07666826256839 590.95050530958861 -504.08517893959117 138.77628525870716 580.39872152863643
+6 0 2 -474.94940661927239 -8.9350185236702906e-15 559.45768389054319 -474.94940661927234 -63.559583646673381 559.45768389054319 -488.74250075368985 -129.82956305962392 563.19500009902231
+6 0 7 -483.93001608275335 4.2148359455373985e-15 600.52836588643402 -483.93001073122213 4.5318876379770885e-15 600.52834663841429 -483.46148521658017 7.9107882199256984e-15 598.84467398393554 -482.46063672571609 -2.8074272197650288e-14 595.23692189518954 -480.89288853819238 2.1579715321232556e-14 589.43937858560844 -478.9178052188164 -2.3816798194676232e-14 581.42196561329899 -476.82762070344506 -8.9318898259723177e-15 571.37308927859988 -474.94940661927239 -8.9350185236694071e-15 559.45768389054319
+6 0 6 -916.81364449549085 144.16254924802371 633.13065659741983 -916.70169562890646 144.67552470894077 635.07807693032294 -916.2743913073889 144.82407932243413 637.10336196363448 -915.53985932403953 144.57061991889765 639.06407835969753 -914.54515806937593 143.92219684744322 640.80715168689062 -913.37245293365743 142.93915648756271 642.20887606708777 -912.11382561718278 141.71135632112427 643.19704930835417
+6 0 5 -948.85934705780164 114.26800930980895 648.70208342798719 -941.14651608256634 119.37171370877704 648.49578486222151 -933.61724856735054 124.74123485345018 647.81875463258064 -926.27534832896436 130.29586210378375 646.69160545677971 -919.11156028657422 135.96979269060412 645.14116031412402 -912.11385977492148 141.71132581042386 643.19695655786199
+6 0 6 -951.86543925308661 118.58657615609889 639.53852627889682 -951.87347687225292 118.66032210626427 641.39252247562342 -951.65618496867114 118.38810337555282 643.26125747829371 -951.21303919009063 117.76531255003125 645.02993107482268 -950.56695315895934 116.82330777843097 646.58159315921216 -949.76371848640815 115.62943303266088 647.82375789591788 -948.85934706004525 114.26800930943244 648.70208134672043
+6 0 5 -951.86543925528395 118.58657073894892 639.53852627875085 -944.54503739804238 123.33568236951518 639.09931916532662 -937.37966356550555 128.33411238151351 638.21685652921769 -930.37446762112199 133.50866938219619 636.91001560663631 -923.52253578446687 138.8003518477359 635.2058939739328 -916.81365206331122 144.16252430425348 633.1305705057996
+6 0 6 -962.79144941062043 5.9877436342503643e-11 669.33533617349099 -962.7914503881002 19.480017704921075 669.33533589296917 -961.51878443949818 39.069065670153648 668.21282538767719 -959.21089758304606 58.56789105511762 665.71406353253781 -956.18532221092266 77.759643295907594 661.60154153270207 -952.69236931703767 96.377121298175311 655.87537000910038 -948.85936035125872 114.26802965505392 648.70208116504921
+6 0 6 -975.82839307373638 5.6672888604225591e-11 657.27349502153186 -975.82839360716525 18.90592852140524 657.27349532012192 -974.61361487494332 37.717759211068596 656.23933552824212 -972.42393899475701 56.237916061124835 653.96990463240923 -969.58109554597229 74.321588234225885 650.28141271841764 -966.31786073508079 91.821781198349314 645.14775812000278 -962.75723105906718 108.65463952439433 638.67005078498767
+6 0 8 -948.85936033758901 114.26802971886093 648.70208985990621 -950.84175885943739 113.62259722940054 648.44825505517895 -952.83808457463999 112.94053508892985 647.9681227320923 -954.83476854342337 112.2244795882594 647.23505147486708 -956.78833067275116 111.4830920065309 646.19673121393907 -958.68256687204416 110.72142484306465 644.84487978356663 -960.39883262267392 109.96187542126269 643.05277402515162 -961.76982697653898 109.26514912152426 640.95005214449566 -962.75723035780811 108.6546395244463 638.67005078496754
+6 0 9 -698.1987442049392 36.266876442455938 685.19143698548089 -694.88550000819725 32.963610130248505 685.11079305557553 -692.00091205362298 29.337652962674937 685.07843462053131 -689.54746289269065 25.760794435945339 685.00908451415739 -687.52160821837128 21.795369750114524 685.0307613139438 -685.85996360382273 17.794375595900931 685.01068804720944 -684.56682252954738 13.557434241015553 685.01603291494825 -683.65062602699697 9.2176924866896286 685.00586038640677 -683.15722771473816 4.694372274011875 685.0004404446214 -683.15313923511508 -0.0016866232395491565 684.99915578902937
+6 0 9 -698.19874420498513 36.266876443234025 685.19143698572248 -698.18445097949677 36.287889476599958 684.90608235500372 -698.13763759604251 36.341422667561929 684.62475136723356 -698.05872825159236 36.426852386475204 684.35591284026725 -697.94943389886544 36.542268251942886 684.10787621630686 -697.81272929730937 36.684507098172766 683.88832336959115 -697.65272131557913 36.849295787364177 683.7038501025902 -697.47441609943314 37.031493478616753 683.55959219756403 -697.28341463807385 37.225402617842185 683.45898343740657 -697.0855881535889 37.425096617807583 683.40366555733544
+6 0 8 -697.08558823058252 37.425096643730569 683.40366555827586 -693.211443149101 33.576989642031315 683.31136013731509 -689.97877734136807 29.371140941962054 683.27290873802883 -687.18353824306587 25.156122767016811 683.21153357313267 -685.08328759497078 20.426358530585119 683.23511584789821 -683.36640422144421 15.679610321828889 683.21579756214101 -682.16620576227331 10.679261830350804 683.21112734130327 -681.51119519359463 5.4563171881631591 683.20525921555247 -681.50648887104751 4.1437338893501874e-08 683.20443339017231
+6 0 9 -683.15313923607573 -0.001686623344866689 684.99915579951721 -683.1276526416674 -0.0016209767561521618 684.70929848320725 -683.05472401259692 -0.0015151672372029326 684.42361266248736 -682.93513364984642 -0.0013712048195466358 684.15097264728399 -682.77159834585996 -0.0011927386013461556 683.90008228203737 -682.56872772340444 -0.00098494324814586308 683.67896889074643 -682.33281148939272 -0.0007542605497405933 683.49448777279554 -682.07145135508654 -0.00050802328528397529 683.35192102215524 -681.79308564294013 -0.00025400722872367059 683.25472300334911 -681.5064888353487 1.295560991777453e-08 683.2044333818269
+6 0 8 -978.37243942715986 -126.19519196888918 521.78818971050225 -984.04906110582419 -110.71017352279785 522.51404477605854 -989.12134874130049 -95.097905840249268 523.16560502000561 -993.52249518977317 -79.369031571090318 523.73366956751556 -997.18074857418992 -63.542330320821641 524.20820330038509 -1000.0213266092795 -47.646687723167098 524.57874838022474 -1001.97119603756 -31.722708876107141 524.83469635303436 -1002.9679796954752 -15.821495521198093 524.96541500493106 -1002.9679796950066 -8.8817841970012523e-14 524.96541501342278
+6 0 5 -1002.9679796950066 -8.5265128291212022e-14 524.96541501342278 -1001.4682631976843 -6.6892590919844437e-14 552.14941510552251 -998.10449580335876 -5.1854438141208523e-14 579.30559645774451 -992.77662799581367 -3.8517331184414618e-14 606.10058576408699 -985.38461025883294 -2.5247931278664648e-14 632.20100971854811 -975.82839307620043 -1.0412899653095086e-14 657.27349501512606
+6 0 7 -1063.9324841405937 -178.1835498900883 479.57442086676792 -1080.9469243398116 -175.64790242742492 482.36559733504691 -1098.0763729117332 -174.10753448664042 485.32727545916629 -1115.3777504744135 -173.54575193569195 488.44319184807193 -1132.8141310276469 -173.77804943710436 491.63632760310014 -1150.3916198915085 -174.65154294392639 494.78686884085448 -1168.1627796476289 -175.96873740435072 497.85190011612627 -1186.1770002819585 -177.4416062525741 500.81840824036914
+6 0 7 -1186.1770003278468 -177.44160575830952 500.81840824792602 -1185.7923462790143 -176.519327199196 504.46506058170132 -1185.5053822630675 -174.7917097118949 507.91833949997806 -1185.338558987492 -172.31261130248603 510.96538463140655 -1185.3058066832414 -169.20628685171675 513.41009185359735 -1185.409101509111 -165.66016104711528 515.10495613464548 -1185.6381426846981 -161.89420672683994 515.97517107106876 -1185.9733651956269 -158.12825347020183 516.01820227193957
+6 0 7 -1185.9733651955637 -158.12825347019623 516.01820231546162 -1168.1708721452994 -156.51748768685363 513.73298542569307 -1150.3576891818993 -155.03105380881436 511.44637040685973 -1132.505993773756 -153.96393647356896 509.15490954078842 -1114.6117253728255 -153.56864409544755 506.85783765302597 -1096.6968201055454 -154.02013949510217 504.55822566319006 -1078.8539757173899 -155.50247844647143 502.26782234014723 -1061.1536102145137 -158.0083928177134 499.99571480509206
+6 0 1 -1370.4053730055325 2.0463630789890885e-12 539.692814594933 -1370.4053730055323 -152.68650658282161 539.692814594933
+6 0 1 -1036.7420384605266 -6.192141993442095e-12 496.86212508227902 -1370.4053730055316 -6.1959326558280736e-12 539.69281459493288
+6 0 6 -1007.8562700676007 -143.11769534628456 493.15420432650012 -1016.5653615745774 -120.26700448616192 494.27214610537368 -1024.0729561247333 -96.950345968257153 495.23585526569411 -1030.137457794282 -73.169605050985012 496.01433403981565 -1034.4744619292644 -48.959904773659645 496.57104454957346 -1036.7420384830159 -24.479627809520899 496.86212508283512 -1036.7420384614413 -9.7380592478657491e-10 496.86212508240686
+6 0 8 -1185.9733651957097 -158.12825347020944 516.01820231548049 -1206.8040238862932 -160.01300703638483 518.69212966544887 -1227.6196448246747 -162.06405234607666 521.36406167864686 -1248.4667566776841 -163.827272052551 524.04037981680688 -1269.3501131497667 -164.84164561962808 526.72053561715074 -1290.4734802168275 -164.41662477013566 529.43261333000396 -1311.296162543666 -162.17447906784747 532.105169531667 -1331.9498602988165 -158.85199323245183 534.75647312243245 -1352.6044387496568 -155.53877091903684 537.40779781425567
+6 0 5 -1370.405373005176 -152.68650657912542 539.69281459488718 -1366.8450959183133 -153.25645274458819 539.23579967385911 -1363.2848546361661 -153.82662698435121 538.77878965536991 -1359.724655180695 -154.39706590356141 538.32178468170594 -1356.1645033312855 -154.96780613699241 537.86478554809855 -1352.6044047102887 -155.53888434028462 537.40779353585242
+6 0 8 -1002.9679796950104 1.9895196601282805e-13 524.96541501340016 -1003.2852094759322 1.34781075189494e-12 519.21527863573715 -1004.8764118947356 2.5082792985488464e-12 513.32892207041834 -1007.8734944362639 3.949919756353536e-12 507.6320314083535 -1012.3533265743642 4.6103505933560647e-12 502.63770959361773 -1017.9625527984377 5.8655481265696668e-12 498.90463198523162 -1024.2615710577245 6.1583813445612445e-12 496.69862654148773 -1030.6688071331794 6.3903465852277472e-12 496.08253482375034 -1036.742038462356 6.252581785659569e-12 496.86212508253482
+6 0 5 -1395.9209712992051 -121.09636869193949 563.16809104775484 -1396.8848122767597 -115.17825502685025 567.66998511452812 -1397.7165423468177 -108.76915809723417 571.55484206886706 -1398.4122300464967 -101.99916705632705 574.80424522918747 -1398.9750205621842 -94.968623225499655 577.43289887213928 -1399.4047780076592 -87.757099786813541 579.44020354862323
+6 0 7 -1395.9209712992024 -121.09636869195451 563.16809104774279 -1396.5876571290294 -123.57371806182337 566.28203729530787 -1398.1828734827827 -126.05106743369477 569.1971881606072 -1400.6622735741798 -128.36376756055631 571.70659303538207 -1403.8891790208731 -130.34702884038043 573.62288469942348 -1407.640735461586 -131.86388462413933 574.81372151400933 -1411.6499829512616 -132.83104774836067 575.2267708460804 -1415.6510057402995 -133.22247960627175 574.88473448687841
+6 0 5 -1415.6510057727119 -133.22247977053127 574.88473436128106 -1416.344103383266 -125.92646557018485 580.44018728830099 -1416.9106076887376 -118.11817792231388 585.15187939055033 -1417.3246543849561 -109.97131680757097 589.03725694817172 -1417.5713164188262 -101.58659656907173 592.14895302667617 -1417.6346486032351 -93.034909092643929 594.49851718514151
+6 0 7 -1399.4047780148821 -87.75709967539828 579.44020357963541 -1400.1533609217586 -88.774941381960815 582.93667341478306 -1401.6903419768596 -89.7927831287072 586.26434989823963 -1403.9734558435778 -90.753184059388332 589.22591757359987 -1406.8938201340734 -91.598671465836077 591.63820904738691 -1410.281271258272 -92.279980544712117 593.36066508223917 -1413.9312134883103 -92.763827587294614 594.31751257294843 -1417.6346485948502 -93.034909038664935 594.49851719872993
+6 0 6 -1389.6898951605569 -141.19233153083741 550.31233862385852 -1391.4753175927187 -138.75422015603306 552.46795924441142 -1392.9456610264747 -135.94744486590599 554.73443762356612 -1394.0848682555936 -132.73769109999427 557.01794441668289 -1394.9205370037776 -129.14833937680834 559.21374677717108 -1395.5149748647354 -125.25101233385644 561.27176887373093 -1395.9209712952011 -121.09636873290609 563.16809102905245
+6 0 6 -1370.405373006176 -152.68650658282942 539.69281459316312 -1374.2700757451669 -151.65537266979217 540.18890706659693 -1378.0266006930281 -150.29649396643862 541.28354688743093 -1381.5516919659301 -148.66295424920466 542.93918037393951 -1384.7375528156622 -146.70837417074009 545.09976489970438 -1387.459560990116 -144.23799901000604 547.61955612184227 -1389.6898950735572 -141.19233164964075 550.31233851882007
+6 0 7 -1370.4053730067612 -152.68650658283727 539.69281459138551 -1370.9622558650076 -156.22250084021897 539.7642988242759 -1371.6143418864347 -159.75849531051506 539.09412342303858 -1372.3324825956363 -163.10942055100085 537.67856206640033 -1373.0800561515707 -166.09012301955977 535.57200321027665 -1373.8167670401797 -168.53993767223861 532.88799403852067 -1374.5045028573311 -170.34603994945169 529.78273685886847 -1375.1114928763584 -171.45060411049039 526.4316198760481
+6 0 9 -1375.1114928765742 -171.45060411215067 526.43161987682822 -1382.8496167280186 -170.22873479698939 527.37673857826496 -1390.2688506548632 -168.44391256710912 530.0349494130752 -1397.0730184230824 -166.16004962984306 534.39316194359162 -1403.0017287576431 -163.27690393065961 540.16644076783746 -1407.8445371067467 -159.58487800588645 547.45619644752367 -1411.2591064607436 -154.27802217333345 555.15935075600385 -1413.5275458045908 -147.98983038286448 562.41225094766833 -1414.9218398531452 -140.90264784130133 569.03719974989565 -1415.6510057301159 -133.22247971356467 574.88473440518135
+6 0 7 -1352.6044047102887 -155.53888434028465 537.40779353585242 -1353.160219613598 -159.06092611664886 537.47914070878142 -1353.810497265388 -162.5829678952789 536.81459602739449 -1354.526371163003 -165.9221032208041 535.41046954440174 -1355.2716185906684 -168.89534940536342 533.32028305535084 -1356.0063898248279 -171.34372161504703 530.65580260017782 -1356.692957327688 -173.15516990677958 527.57091376931396 -1357.2998046877181 -174.27169649051092 524.23866174257205
+6 0 5 -1375.1114928778582 -171.45060411895486 526.43161987221629 -1371.5482248593382 -172.01325159120441 525.99641287690565 -1367.9854370067781 -172.57666218767187 525.55943673290153 -1364.4231144288965 -173.14085920071892 525.12076856765498 -1360.8612420568463 -173.70586398969795 524.68048489251066 -1357.2998046877178 -174.27169649051092 524.23866174257205
+6 0 2 -474.94942832544319 -1.5936470892929933e-14 559.45782159448595 -474.94942832544319 63.55959122098033 559.45782159448606 -488.74252727267918 129.82957885422601 563.19513301095765
+6 0 6 -517.16342521475019 208.22457291448242 514.29852713637297 -512.53171370126552 207.04649321767397 512.84343797785164 -508.2396962277034 205.01450258510818 510.99835000633476 -504.51852367582853 202.18735639556618 508.83586102201519 -501.57165614708009 198.69535565807968 506.46138377845602 -499.53333756360087 194.72823363411635 503.99928094807922 -498.45723017994931 190.49714574828153 501.57074294508948
+6 0 9 -488.74252946237357 129.82958003949014 563.1951353141626 -489.44773172367468 137.94623537921191 558.06007945123042 -490.24458542804462 145.86936809578592 552.60097033181046 -491.13238579830409 153.56126473655766 546.78914595278559 -492.10883613705306 160.9908688133666 540.58070462031583 -493.17480439763921 168.06554914995158 533.92273744273075 -494.33008537169576 174.72771794235848 526.75229694226709 -495.58317030297303 180.82552709643286 518.98648091147857 -496.94949000066231 186.1454212940186 510.56866026912712 -498.45723017994925 190.4971457482815 501.57074294508953
+6 0 9 -504.08525565637393 138.77631739686004 580.39886155965166 -504.97126574905735 147.44167473338314 575.23291171101744 -505.95892464291103 155.97961153174859 569.70510141708075 -507.06226051143193 164.37715188409155 563.77031500569592 -508.29256245839099 172.62008581949428 557.37003370929563 -509.6670542236343 180.65855411075327 550.40187279727866 -511.20328370154471 188.4181579808853 542.7693301089954 -512.93944907152218 195.82458911714704 534.30133491125787 -514.93719419216677 202.55844286528512 524.76595479850334 -517.16342521475008 208.22457291448245 514.29852713637297
+6 0 10 -822.27918963051525 218.41848119959903 561.76339605587066 -830.58474239060718 213.59030417482111 572.38883829132669 -839.20120428389282 207.99543264623628 582.42686696399778 -848.07631243023013 201.64392039841258 591.79337857390419 -857.18437917298593 194.56698025336294 600.40419098360337 -866.5045417929324 186.82548199309338 608.13300752521968 -876.03698412798201 178.57743916937434 614.90817178463431 -885.80392377207397 170.02685943455339 620.74789371851762 -895.83632990717592 161.34338909311435 625.71166156958725 -906.16478659258235 152.67380035295724 629.83650636352866 -916.81364449549096 144.16254924802371 633.13065659741983
+6 0 6 -822.27918963051548 218.41848119959877 561.76339605587043 -821.7295265186084 219.7788807270727 562.8084800449227 -820.88558496026951 220.92015770783462 563.98402276405534 -819.77941901443614 221.76288536577781 565.2290367293308 -818.47206886691276 222.24872406128443 566.46945969374769 -817.04586087053985 222.35709456536472 567.63171515824274 -815.58600837106644 222.10287155577728 568.6560287278254
+6 0 10 -815.58600837106735 222.10287155577745 568.65602872782574 -823.89301740551548 217.0255789800257 579.97609336518406 -832.53386996753625 211.0570777878155 590.69218493830931 -841.46381355657695 204.2002243725789 600.70119441711256 -850.66444909334575 196.47943463174778 609.89423043302293 -860.13201475941798 187.97357553609433 618.0863605434289 -869.87511482248169 178.91286995797373 625.158618239764 -879.91493895210806 169.57641224229224 631.13151563681936 -890.28180202776002 160.16164962992963 636.09909955386593 -901.00653016296496 150.82477068363829 640.11101044015788 -912.11382561718278 141.71135632112419 643.19704930835405
+6 0 9 -766.91669454458088 231.9866395936422 435.92481540532015 -767.20638718675639 234.23995658273728 451.11855317062611 -770.03335145627454 235.71280962137851 466.54105540329493 -774.83192497018536 236.18721871468401 481.67965706144196 -780.93928328467814 235.6242711539669 496.34742183236796 -788.02457277003805 234.10443426669627 510.55775365366515 -795.83117813022159 231.62191912752874 524.25200219404826 -804.21100671202191 228.18978863620615 537.41684644177292 -813.0507976748579 223.78312233824087 549.95734912758576 -822.27918963051559 218.41848119959877 561.76339605587032
+6 0 5 -766.91669454458111 231.98663959364239 435.92481540532009 -765.95416076865706 232.737551047126 435.79194152435855 -764.87457711206866 233.34264701861491 435.68292477208138 -763.70815398187563 233.77826937605599 435.60195072175918 -762.49264318049029 234.03031900846716 435.551640134477 -761.26658656866277 234.09677723799663 435.53258027578164
+6 0 9 -761.26658656866312 234.09677723799658 435.53258027578187 -761.22357866573077 236.80259423629971 451.58736886851051 -763.82172555104842 238.71770673456359 467.86728327544057 -768.46631588989999 239.57995528001814 483.83924696455529 -774.46651587011797 239.32961788722258 499.31442911889002 -781.46219045710814 238.03677237043985 514.31413619678483 -789.21222013860017 235.68604604510108 528.79243992823115 -797.54313150613746 232.27255440492246 542.74455572908607 -806.3559983327907 227.74430775105697 556.07817913076065 -815.58600837106644 222.10287155577726 568.6560287278254
+6 0 7 -792.214116688952 218.16627834130932 377.18611263472462 -784.78792709292634 220.13756253718822 382.93649708389887 -778.41257121774902 222.25902171818464 389.9655361803828 -773.35776418584032 224.48385676033297 398.12215060291089 -769.79178934189042 226.70375695789511 407.07029722219198 -767.63139198970657 228.75498303676753 416.48758223626584 -766.73046356032535 230.53807867208135 426.15741255619486 -766.91669454458099 231.98663959364245 435.92481540532009
+6 0 5 -792.214116688952 218.16627834130932 377.18611263472462 -791.67606939797338 218.50937858499367 376.38281001206502 -791.09049749017345 218.73141945196656 375.55963323954393 -790.46919290662538 218.82485323799236 374.73419717763409 -789.8260697254758 218.78758749914803 373.92498741645392 -789.17540027336474 218.62325031107312 373.14901685632265
+6 0 7 -789.17540027336474 218.62325031107312 373.14901685632265 -781.22491668631187 220.71686240165099 379.34778391255367 -774.35849339660285 223.0098198555651 386.86036106739141 -768.86580896812359 225.45590057837194 395.53217643259677 -764.92559022078387 227.94019166464085 405.01776355858186 -762.45377921246643 230.27855973771918 414.98667288141723 -761.29423450626211 232.35732345337325 425.21164475188459 -761.26658656866266 234.09677723799666 435.53258027578164
+6 0 8 -856.35179034834869 207.57772114127016 363.77344702748479 -847.82933187046399 208.61275676838463 362.5752075561162 -839.26033433089663 209.68500272377526 362.0005061707231 -830.69258250626945 210.81654527333814 362.14856470896069 -822.20466190618902 212.03249469785308 363.1284923920428 -813.90420439345212 213.35921764866552 365.06637207171082 -805.99736522736396 214.82938669436578 368.08259142975191 -798.71203258547416 216.4414046699153 372.15452624169706 -792.21411668895166 218.16627834130929 377.18611263472445
+6 0 5 -856.35179034834869 207.57772114127016 363.77344702748479 -856.53714865727363 208.077456573577 362.58232224954196 -856.71057096665015 208.38188615804836 361.30739966006229 -856.8654714758419 208.47317590343519 359.99092297407913 -856.99616837592248 208.34797726754798 358.68118105148363 -857.099023755193 208.01809895417281 357.42282000739363
+6 0 8 -857.09902375519312 208.01809895417281 357.42282000739368 -848.1403280736962 208.98281650250377 356.41140956903655 -839.11720814567229 209.99644285058272 356.04962917836713 -830.07721407596023 211.08461202013891 356.4401585496193 -821.104151310887 212.27710989752873 357.69291505378845 -812.30543596296684 213.60544310844048 359.93418099573483 -803.90142279969382 215.1091429122925 363.28787158546641 -796.13207341203565 216.79133973181749 367.72509568212064 -789.1754002733644 218.62325031107312 373.14901685632282
+6 0 8 -980.79218590463609 189.29743651965578 424.45763442256685 -966.7706838287786 192.18150747722009 413.89175862417375 -952.37633158699896 194.84572666441844 403.8005575660157 -937.57501781668896 197.30644877135057 394.28912284700363 -922.32259483518646 199.56490329165723 385.49978455570186 -906.54613848383235 201.64200461550232 377.67021730789156 -890.25674511454247 203.58764725353691 371.064485023891 -873.39670730411865 205.50764988704108 366.16992597022181 -856.35179034834937 207.57772114127013 363.77344702748474
+6 0 6 -980.79218590463609 189.29743651965578 424.45763442256685 -981.67262127946049 190.37172335815933 423.52827439040476 -982.650805038199 191.19422700217584 422.40046987616677 -983.68250446108743 191.71095216541224 421.12090550934499 -984.71509746784398 191.88890600887743 419.75314175988251 -985.69588141791075 191.72563732719965 418.36869063633554 -986.58041745194168 191.24530150433361 417.03458335737452
+6 0 8 -986.58041745194168 191.24530150433364 417.03458335737452 -972.13929821371084 193.94899028140875 406.45381176038427 -957.27731102775647 196.42497084994412 396.3808184464641 -941.95002993104265 198.68987348993926 386.91671828105717 -926.11496493506502 200.74639102379868 378.20604094075117 -909.6867252722916 202.61555664645311 370.49456797639618 -892.67594755370806 204.3560737472211 364.07288807403671 -875.01641511818707 206.0886638575108 359.44564088410806 -857.09902375519357 208.01809895417267 357.42282000739363
+6 0 10 -958.8517310144174 114.17195471901805 635.63671697516838 -958.49801473681271 114.37753106458074 636.51423692627111 -958.01507669598925 114.66702945196042 637.31202146244698 -957.40753417780263 115.03894232850055 637.99597579773535 -956.71333302000903 115.4724576045564 638.54707243203461 -955.95195602477008 115.95333874841076 638.96273639560309 -955.16488565355939 116.45539193911164 639.25951524442723 -954.35099193601377 116.97798895877051 639.46076505933036 -953.52595826254185 117.51041706893079 639.56412322248252 -952.6959211493031 118.04779202353936 639.58837833908933 -951.86538894739692 118.58659913230451 639.53855077512094
+6 0 8 -958.85170143669188 114.17197968682677 635.63669784992749 -964.00756093619054 111.17544247545597 622.84568426662292 -967.99360592220296 110.39204353783197 608.9511351749893 -970.71010952834979 111.55097345287187 594.63906341538404 -972.32815378096814 114.0437018448451 580.35936676007805 -973.00603743899137 117.55882370535805 566.1823424317771 -972.81217325920363 121.84888228117512 552.1791152038021 -971.85383352297151 126.72058839458741 538.38344691126304 -970.19407917400747 132.03281481057741 524.7986052936468
+6 0 10 -970.19406942959301 132.03283789677465 524.79854772238514 -969.44629782627658 134.42615379854311 518.67819738746221 -969.76057849888105 136.79558936118258 512.48367803205679 -971.23857445435556 139.12792143522495 506.42696101094481 -973.96231283265877 141.41609127965688 500.76269070867221 -977.86415609738708 143.64467824875001 495.84373799129258 -982.78047352273427 145.79649906329109 491.92618060705888 -988.45314601693565 147.78307233240827 489.19206279385293 -994.63980026953243 149.46094946500344 487.75657099268579 -1001.0360091107659 150.69496035859405 487.589016658584 -1007.3928533894435 151.39115042443942 488.5773180767851
+6 0 5 -1007.392856646776 151.39116648706039 488.57730488654369 -1017.9779091583341 152.5504732856879 490.22297331980423 -1028.4683088002546 154.38304228981872 491.84404759473472 -1038.7955476773486 156.9572835589353 493.42830525242852 -1048.8599449806056 160.36406482632742 494.95867275778693 -1058.4912368055216 164.67416056703678 496.40786927471169
+6 0 7 -1058.491230325594 164.67417872184137 496.4078607822733 -1059.1624622915733 164.97456183602938 496.50886024691852 -1059.8255895695145 165.29604651769824 496.58779484551422 -1060.4788139729603 165.64110252376307 496.64127164261924 -1061.1172736659353 166.01263305989443 496.66360812871585 -1061.7366509623648 166.41461304254895 496.64877262006371 -1062.3274472188748 166.85264858593504 496.58509505972052 -1062.8676486468482 167.32920065833196 496.4563345315816
+6 0 10 -1062.8676486468482 167.32920065833196 496.4563345315816 -1063.2457896464293 167.66278710900983 496.36620216188442 -1063.6007369706422 168.01436424520344 496.24593895760745 -1063.9245120374603 168.38503898155599 496.08924992157017 -1064.2100230064791 168.77007292433561 495.89604130794299 -1064.4514155314691 169.18037686625448 495.65261166816515 -1064.616063411469 169.59014071506908 495.36035247922916 -1064.7139629733783 170.00525521223818 495.02226408419398 -1064.7264715425422 170.39532843795544 494.65177933726648 -1064.6784142642489 170.76398390293193 494.2628040402497 -1064.5738964958907 171.10675440908076 493.861425127789
+6 0 11 -1064.5738964958907 171.10675440908062 493.861425127789 -1064.3838641897851 171.72997351116942 493.13164528695143 -1064.0108636053869 172.26883643834961 492.36230811845672 -1063.5187680145009 172.71501208013152 491.60204105540134 -1062.9531449811439 173.08663142020106 490.86166540651953 -1062.3478700555072 173.41111524864556 490.14042137892454 -1061.6922170194225 173.68505155548812 489.43299573470227 -1061.0153108754876 173.9202843419971 488.7482877684584 -1060.3108808241091 174.12213740208264 488.07722298706454 -1059.5882336626805 174.29536352408948 487.4224224207772 -1058.8484477153527 174.44126856280167 486.78294110318944 -1058.0945209048957 174.56365784361259 486.15782174523429
+6 0 8 -1049.1207867878595 176.01677785876024 478.78580774805306 -1050.245903234357 175.83374681468848 479.70272161515152 -1051.3702254075911 175.65143053229176 480.6207690044514 -1052.4936717695375 175.46968227497337 481.54003730006582 -1053.6161544112085 175.28834664717982 482.46061398421688 -1054.7375807403603 175.10725868454628 483.38258774132237 -1055.8578542383523 174.92624317611495 484.30604895959232 -1056.9768746640125 174.74511413139248 485.23108986958925 -1058.0945379032166 174.56367431195883 486.15780446873356
+6 0 7 -990.75582897676838 187.2012193948342 432.10588064175687 -999.15797985146514 185.40879956017824 438.65299049687354 -1007.4871050055364 183.61066762319865 445.29773365833154 -1015.8078096030599 181.88112126082305 451.96954749317655 -1024.141693528238 180.25816259880904 458.64710731111012 -1032.4866913870014 178.75124996951027 465.33423120889807 -1040.8270869412215 177.3487231158982 472.04347066855985 -1049.1444766448062 176.02328600584735 478.79472919085487
+6 0 5 -980.79218587889761 189.29743652653508 424.45763435929945 -982.79864942049585 188.88472830897831 425.96960572513052 -984.79672987615243 188.46709778507901 427.4921902324765 -986.78810206977846 188.04635153163181 429.02339863747875 -988.77407965217367 187.6239962384137 430.56164528350348 -990.75564218545139 187.20123482450518 432.10576511670246
+6 0 6 -962.75722820414126 108.65464220286081 638.67004920255079 -962.49351185110504 109.82452017179855 638.26747147540857 -962.05693200486189 110.93513138474889 637.80590121770695 -961.4550921754709 111.95276793475104 637.29694010749199 -960.70389986758084 112.84656564859274 636.75502452075318 -959.82674879301101 113.59186770357043 636.19624265768095 -958.8517310144174 114.17195471901805 635.63671697516838
+6 0 6 -978.37243039195926 126.19521749710296 521.78813449148879 -985.94127760619506 105.54849376731522 522.75592506739838 -992.38196145832205 84.664138459913858 523.58513772831429 -997.5077076175055 63.57307967892919 524.25008803620801 -1001.1075308116812 42.339267605180787 524.72065180237007 -1002.9679797412697 21.095335912161843 524.96541502081209 -1002.9679796950105 -1.8829382497642655e-13 524.96541501340016
+6 0 8 -962.75721946759234 108.65467445857597 638.67001256198557 -968.60800926145407 105.26361004264258 624.93244697858756 -973.26582471891982 104.22777313819907 610.1194882359614 -976.60099768409032 105.27655370195789 594.94912899907513 -978.78398992507334 107.74230504597581 579.90607817964781 -979.96050852921394 111.31301648707492 564.99583060251723 -980.22339296492612 115.70749483798284 550.33925004153969 -979.67069691013148 120.7178764190121 535.93587235210953 -978.37243942293401 126.1951919717666 521.78818977107437
+6 0 9 -1186.1770003279307 -177.44160625633293 500.81840824793966 -1204.5059739056264 -178.94020976274808 503.83674859834628 -1223.0783564396397 -180.59400948512248 506.75732128477358 -1241.9465521715781 -182.14630133955882 509.5635015125107 -1261.1142868878146 -183.21149096947056 512.26460670088466 -1280.6850965738815 -183.57161795201293 514.89891511686619 -1300.5107702354421 -182.49287559305856 517.37775473825548 -1319.9715244404931 -180.17961036838523 519.69384538909844 -1338.9332805738366 -177.18956376494131 521.96032239228396 -1357.299804659863 -174.27152335269221 524.23884393582318
+6 0 1 -1395.9209712992026 -121.09636869200389 563.16809104774381 -1395.9209712992028 2.0605739337042905e-12 563.16809104774381
+6 0 8 -1395.9209712992026 2.0463630789890885e-12 563.16809104774393 -1394.9535928138582 2.0463630789890885e-12 558.6496740216553 -1393.190832975665 2.0463630789890885e-12 554.30154557316973 -1390.6676638596191 2.0463630789890885e-12 550.28705274948129 -1387.4593105392951 2.0463630789890885e-12 546.76092138833451 -1383.6786162184358 2.0463630789890885e-12 543.85687527018843 -1379.4682244830537 2.0463630789890885e-12 541.67624773339082 -1374.9885803101877 2.0463630789890885e-12 540.28113793979651 -1370.4053730055327 2.0463630789890885e-12 539.69281459493311
+6 0 5 -1370.405373005176 152.68650657912542 539.69281459488718 -1366.8450959183133 153.25645274458819 539.23579967385911 -1363.2848546361661 153.82662698435121 538.77878965536991 -1359.724655180695 154.39706590356141 538.32178468170594 -1356.1645033312855 154.96780613699241 537.86478554809855 -1352.6044047102887 155.53888434028462 537.40779353585242
+6 0 8 -1185.9733651957097 158.12825347020944 516.01820231548049 -1206.8040238862932 160.01300703638483 518.69212966544887 -1227.6196448246747 162.06405234607666 521.36406167864686 -1248.4667566776841 163.827272052551 524.04037981680688 -1269.3501131497667 164.84164561962808 526.72053561715074 -1290.4734802168275 164.41662477013566 529.43261333000396 -1311.296162543666 162.17447906784747 532.105169531667 -1331.9498602988165 158.85199323245183 534.75647312243245 -1352.6044387496568 155.53877091903684 537.40779781425567
+6 0 7 -1185.9733651955637 158.12825347019623 516.01820231546162 -1168.1708721452994 156.51748768685363 513.73298542569307 -1150.3576891818993 155.03105380881436 511.44637040685973 -1132.505993773756 153.96393647356896 509.15490954078842 -1114.6117253728255 153.56864409544755 506.85783765302597 -1096.6968201055454 154.02013949510217 504.55822566319006 -1078.8539757173899 155.50247844647143 502.26782234014723 -1061.1536102145137 158.0083928177134 499.99571480509206
+6 0 5 -1007.8562696243526 143.11770120665915 493.15420312502943 -1018.874454470975 144.51727633428595 494.56855255311888 -1029.8037822015742 146.62766296726656 495.97149562798825 -1040.5739527925557 149.52041084882674 497.35400737009149 -1051.0824460769163 153.29006153622899 498.7029297509992 -1061.1536165933521 158.00837873365032 499.99571574534872
+6 0 6 -1007.8562700676007 143.11769534628456 493.15420432650012 -1016.5653615745774 120.26700448616192 494.27214610537368 -1024.0729561247333 96.950345968257153 495.23585526569411 -1030.137457794282 73.169605050985012 496.01433403981565 -1034.4744619292644 48.959904773659645 496.57104454957346 -1036.7420384830159 24.479627809520899 496.86212508283512 -1036.7420384614413 9.7380592478657491e-10 496.86212508240686
+6 0 1 -1370.4053730055325 -2.0463630789890885e-12 539.692814594933 -1370.4053730055323 152.68650658282161 539.692814594933
+6 0 8 -978.37243039195926 126.19521749710296 521.78813449148879 -977.51669609663122 129.33101355103301 515.8900989618586 -978.05038460950027 132.29204972830729 509.87155532835618 -980.15250695984707 135.02981418764685 504.06373531653207 -983.95012334531179 137.49806561850193 498.98547764858597 -989.04951472222331 139.76523471914933 495.18996857102326 -995.06156985758298 141.63145330793267 492.94929154660497 -1001.474059686519 142.7989061480618 492.33495592109301 -1007.8562700675745 143.11769534635374 493.15420484729123
+6 0 7 -1400.5857799393234 -44.057864555294501 584.95640978986728 -1401.3463768670397 -44.338932973356961 588.50899459536868 -1402.8643808467286 -44.620001392405307 591.89942101146733 -1405.0985376629424 -44.885831346017355 594.93508508097602 -1407.9461057890171 -45.121177099688744 597.43645100502488 -1411.2478991124415 -45.312882242768275 599.26368623183612 -1414.8123479349656 -45.451868281515928 600.33779716380741 -1418.4426334328041 -45.533697426557097 600.64225921004186
+6 0 9 -1418.9463723592617 -2.3696600237599341e-11 602.33725485102548 -1418.9463724262741 -4.9002487004883086 602.33725485315961 -1418.9461801216878 -9.9664511453718045 602.33744641484134 -1418.9245991858595 -15.224831070222123 602.28146235089741 -1418.8656394032664 -20.245035687603995 602.10765783647901 -1418.8054972325076 -25.379678339044688 601.92200455690624 -1418.7247851989846 -30.414831263588496 601.6600079367056 -1418.6387101460195 -35.466259498579944 601.36470413004224 -1418.543436395769 -40.501022322309716 601.02462656436956 -1418.4426334328152 -45.533697432695739 600.64225920858462
+6 0 7 -1400.934251173238 -6.2124503946107273e-12 586.58404404085229 -1401.7014216683604 -5.8304821280706734e-12 590.16733256629357 -1403.2345633728767 -5.2175931272005427e-12 593.58662913982153 -1405.4915946644078 -4.3950968489520485e-12 596.64546905933423 -1408.3675506685131 -3.4045650686442264e-12 599.16074978147583 -1411.6997784966611 -2.3040557753935968e-12 600.99021680918486 -1415.2928255249401 -1.158539780514203e-12 602.05423071719667 -1418.9463723720812 -3.0250650075169199e-14 602.33725485201671
+6 0 7 -1400.9342511658822 -1.5791812302268227e-11 586.58404400650647 -1400.9342511960938 -6.3003241001471189 586.58404414760821 -1400.9347174306145 -12.600548609707399 586.5862218913087 -1400.9006981139737 -18.901723042766459 586.42732403695447 -1400.8447823882564 -25.197456608128899 586.16615617013906 -1400.7738440155633 -31.488950066666185 585.83481571059406 -1400.687517344197 -37.776310279583399 585.43160334422907 -1400.5857799393225 -44.057864555272424 584.95640978986887
+6 0 7 -1400.1445548699571 -66.006651378195727 582.89554230532735 -1400.9012263700292 -66.430448373948082 586.42979228410343 -1402.4132921065575 -66.854245371364684 589.80231481186092 -1404.6398198710972 -67.255126750222544 592.82200906099592 -1407.4787160268081 -67.610166036751153 595.31077400621336 -1410.7717151458803 -67.899570170024532 597.12986366063001 -1414.3282325609393 -68.109662560294751 598.20079780676599 -1417.9523082137794 -68.233732502367118 598.50700177558883
+6 0 5 -1418.4426334328136 -45.53369743255449 600.64225920859508 -1418.3519107663351 -50.06310502290291 600.29812858907326 -1418.2560399598669 -54.589609395703491 599.91578492128167 -1418.156096341341 -59.12116153288386 599.49385406438773 -1418.0541069437315 -63.660818587809125 599.03038963063159 -1417.9523082141275 -68.233732482122448 598.50700175363761
+6 0 5 -1400.5857799393225 -44.057864555294486 584.95640978986683 -1400.5145637555306 -48.454952557247132 584.62377430113588 -1400.4353296810068 -52.849082889782828 584.25369003317962 -1400.3480596226118 -57.239752496948505 583.84607134699422 -1400.2520780667821 -61.626432422228937 583.39776005183671 -1400.1445548699571 -66.006651378195727 582.89554230532724
+6 0 7 -1399.8411147814288 -76.936017147650674 581.47823885938817 -1400.5965704793964 -77.483142709451158 585.00681010474909 -1402.1118579553715 -78.030268273422067 588.37270383419866 -1404.3458704118784 -78.547635816432106 591.38400573617071 -1407.1956202802514 -79.005473002264594 593.86195343197778 -1410.5012722609376 -79.378100895180069 595.66756507039406 -1414.0703867774334 -79.647828882360812 596.72271977808077 -1417.7052652315911 -79.806048816100684 597.01168301769974
+6 0 5 -1417.9523082137798 -68.233732502345674 598.50700175133238 -1417.9014088490994 -70.52018944403568 598.24530781336148 -1417.8506927687092 -72.814818920133604 597.96854849448721 -1417.8003390977333 -75.122555268090025 597.67419968968898 -1417.7511768746272 -77.445633883054811 597.35914784198098 -1417.7052652316211 -79.80604881311659 597.01168291186639
+6 0 5 -1400.1445548699576 -66.006651378195713 582.89554230532792 -1400.0907932715445 -68.196760856179125 582.64443343207313 -1400.0340615877806 -70.385177677221535 582.37945325135649 -1399.9742168625012 -72.57180058321579 582.0999319077838 -1399.9103185418926 -74.755820978991821 581.80147475525462 -1399.8411147814279 -76.936017147650716 581.4782388593884
+6 0 8 -1399.6519034768448 -82.373981269430587 580.59447350783876 -1400.3122423271191 -82.954953387399669 583.67877444748001 -1401.5473550358554 -83.535925506356961 586.64001817060807 -1403.3313555356394 -84.094132925919411 589.3573524759629 -1405.6068840128826 -84.606801986811305 591.71661384780418 -1408.2870211112715 -85.053052126183672 593.62047823564728 -1411.2621345372631 -85.415731245477474 594.99718556014318 -1414.4095806615944 -85.682782413640595 595.80605085051616 -1417.6041837107787 -85.847739928508474 596.0379749189708
+6 0 5 -1417.7052652315915 -79.806048816037787 597.01168291143881 -1417.6823094095926 -80.986256306570866 596.83795044261387 -1417.6601154980822 -82.175677048574144 596.65605546320592 -1417.6391466081793 -83.378426216306124 596.46422362352155 -1417.6200008258086 -84.596737089650418 596.26064792345619 -1417.6041837108096 -85.84773992605983 596.03797503558201
+6 0 5 -1399.8411147814288 -76.936017147650674 581.47823885938817 -1399.8065129011966 -78.026115231980143 581.31662091145517 -1399.7705274165401 -79.115197001145916 581.14854155749526 -1399.7330860937045 -80.203205276687939 580.97366099677288 -1399.6937173771789 -81.289665533083962 580.78977745536633 -1399.6519034768437 -82.373981269430658 580.59447350783921
+6 0 6 -1417.6346471032389 -93.034909135287762 594.49851707066045 -1417.5827211528849 -91.851873841368644 594.81920125480917 -1417.5725471392268 -90.658960570147528 595.09861711159363 -1417.570598201524 -89.461368082922647 595.35686945584678 -1417.5768819959103 -88.259834447900559 595.59674115937332 -1417.5889199839096 -87.054974349338963 595.82309272853036 -1417.6041837105106 -85.84773994967469 596.03797503137889
+6 0 8 -1399.4047774058015 -87.75710987207303 579.44020074020409 -1399.4442903381378 -87.093821462887945 579.62474346774502 -1399.4782948832947 -86.42405576099236 579.7836215845316 -1399.5110276609282 -85.753250118707484 579.93644817064933 -1399.5416192880991 -85.08009498934581 580.07934742430848 -1399.5705458035013 -84.40494591995467 580.21449402559767 -1399.5987924493982 -83.729098361391209 580.34639380351916 -1399.625754956478 -83.052063244283275 580.47233926040826 -1399.6519034768448 -82.373981269430587 580.59447350783876
+6 0 1 -1400.9342511585271 -6.1934390196836825e-12 586.58404397216066 -1395.9209712992028 -6.1959326558280736e-12 563.16809104774427
+6 0 5 -991.70873241065112 190.27257572426066 420.84514780642047 -992.72738694329144 190.07732681267055 421.61191409268628 -993.74280264911658 189.88191627387013 422.38080376433129 -994.75524335394834 189.68652297894323 423.15163329394881 -995.76495524143206 189.49130579221674 423.92424809473692 -996.77216635302932 189.29640386740135 424.6985221216429
+6 0 5 -986.58041744691218 191.24530150125463 417.03458331173488 -987.61366569570873 191.05185529954679 417.79162834317503 -988.64283133987203 190.85765057124527 418.55143447589052 -989.66821297661897 190.66290648736771 419.31375991332675 -990.69009206194494 190.46782191716883 420.0783921967502 -991.70873241065112 190.27257572426066 420.84514780642047
+6 0 6 -996.77226793690636 189.29639490612192 424.6984683660055 -995.84876733389888 189.77968832293547 426.04305221291241 -994.82420378957568 189.93428284722197 427.43637249424648 -993.74666005054303 189.7349888645125 428.80841559529932 -992.67321689465894 189.18521930694678 430.08465777328848 -991.66057138090184 188.32118344067322 431.19954001591901 -990.75582897676838 187.2012193948342 432.10588064175693
+6 0 6 -978.37243038513066 126.19521751422829 521.78813449874497 -977.74949268844659 127.79007125879392 522.46272530721103 -976.74571579379506 129.24440344046377 523.11786028395284 -975.39900231417175 130.46104196773643 523.71244238117822 -973.78642511337455 131.35671123512094 524.20716018711983 -972.01448029168125 131.88365742398332 524.57375430811044 -970.19406942959313 132.03283789677462 524.79854772238514
+6 0 6 -1061.1536100771793 158.00839316453602 499.99571324713463 -1060.5783849379336 159.25641994260278 499.9218746104346 -1060.0320944862524 160.50445003840537 499.62261523299094 -1059.5343498991708 161.70993416248777 499.10045343066201 -1059.1031363320083 162.83027746562183 498.37074092712828 -1058.7524609525085 163.82797579354343 497.46123920789398 -1058.491230325594 164.67417872184134 496.40786078227336
+6 0 6 -1007.8562700524346 143.11769561694484 493.15420469747363 -1007.6524988890427 144.74832591562108 493.12804645923353 -1007.4899965944252 146.37896451783052 492.78038232823246 -1007.3786706743861 147.93033532123775 492.11247784605439 -1007.3250962922909 149.32295705501068 491.1517615925971 -1007.330829362728 150.49114550207531 489.95111073626782 -1007.3928533894436 151.39115042443945 488.57731807678499
+6 0 6 -1066.2730847791713 164.3049678928335 499.41187802731213 -1065.656305182669 164.92387772558223 499.13561296737839 -1065.0471543063725 165.50826465710986 498.7649794563506 -1064.4549620873263 166.04876194523766 498.3041398425766 -1063.8888445915179 166.53691357494114 497.75969419750072 -1063.357274008639 166.96555612894733 497.14030711847681 -1062.867648646848 167.32920065833201 496.4563345315816
+6 0 7 -1061.1536100771793 158.00839316453602 499.99571324713463 -1061.9139842056077 158.75715664960234 500.09331896751206 -1062.6705476500833 159.54667732102277 500.1481524761025 -1063.4213066148964 160.38182772135241 500.15302741399535 -1064.1638154781758 161.26724619966396 500.09904507433765 -1064.8936214820314 162.21166728875119 499.97244816771041 -1065.6034904918779 163.22351910339282 499.75340440859014 -1066.2730847791709 164.30496789283347 499.41187802731213
+6 0 6 -1069.0502061463187 172.3932246873602 493.95994249952633 -1068.2780705334378 172.3121542496404 494.06625039915451 -1067.5050996246982 172.1755501816555 494.12413112767757 -1066.7398307284141 171.98430380370354 494.13240483989705 -1065.990807447869 171.74034975312046 494.09080365550653 -1065.2662784936349 171.44657942436112 493.99996503036817 -1064.5738964958907 171.10675440908062 493.86142512778906
+6 0 10 -1066.2730847791713 164.30496789283359 499.41187802731179 -1066.7418007802764 165.06198204544205 499.17280956041708 -1067.1919938826329 165.85161026281321 498.87693954281582 -1067.6161372960942 166.6719687973463 498.51498954591915 -1068.0101641372125 167.52574370549291 498.07985028297725 -1068.3551810423919 168.39830787428295 497.56145718181187 -1068.6485919632603 169.29032103253502 496.94809823987902 -1068.853028873355 170.14952931558381 496.25754338527344 -1068.9863944471902 170.95976607825193 495.51592834186806 -1069.0482721174649 171.70798391953932 494.74574181228564 -1069.0502061463194 172.39322468736029 493.95994249952622
+6 0 6 -1063.9324841412592 178.18354221590403 479.57442086582898 -1062.9130416845039 178.35246962054509 480.86415107861853 -1061.8446853727571 178.19734484950732 482.15766329128019 -1060.777506131303 177.7098464522949 483.39158213447757 -1059.7657902613187 176.90830625490739 484.50200828810796 -1058.8589439609818 175.83868794721943 485.43590828873323 -1058.0945209048959 174.56365784361262 486.15782174523423
+6 0 11 -1069.0502061463187 172.3932246873602 493.95994249952633 -1069.053722562418 173.63911699248925 492.53121647632736 -1068.8595626515723 174.67793652927509 491.05127628895349 -1068.5195940840208 175.49461872932616 489.6108701490071 -1068.1045078789653 176.15902848504376 488.21746685993929 -1067.6169123158554 176.69690238062825 486.86870035982469 -1067.0867001650108 177.13194411933964 485.56350618495458 -1066.5095304137938 177.47675765392975 484.29439701542299 -1065.9076273228086 177.74751691681894 483.06570459828009 -1065.2711572025382 177.95059430439332 481.86951085151748 -1064.6130087712545 178.09403184685675 480.70648097427335 -1063.9324841412592 178.18354221590403 479.57442086582887
+6 0 1 -1395.9209712992026 121.09636869200389 563.16809104774381 -1395.9209712992028 -2.0605739337042905e-12 563.16809104774381
+6 0 6 -1389.6898951605569 141.19233153083741 550.31233862385852 -1391.4753175927187 138.75422015603306 552.46795924441142 -1392.9456610264747 135.94744486590599 554.73443762356612 -1394.0848682555936 132.73769109999427 557.01794441668289 -1394.9205370037776 129.14833937680834 559.21374677717108 -1395.5149748647354 125.25101233385644 561.27176887373093 -1395.9209712952011 121.09636873290609 563.16809102905245
+6 0 6 -1370.405373006176 152.68650658282942 539.69281459316312 -1374.2700757451669 151.65537266979217 540.18890706659693 -1378.0266006930281 150.29649396643862 541.28354688743093 -1381.5516919659301 148.66295424920466 542.93918037393951 -1384.7375528156622 146.70837417074009 545.09976489970438 -1387.459560990116 144.23799901000604 547.61955612184227 -1389.6898950735572 141.19233164964075 550.31233851882007
+6 0 7 -1185.9733651956262 158.12825347020191 516.01820227193969 -1185.6381426846974 161.89420672683994 515.97517107106876 -1185.4091015091103 165.66016104711525 515.10495613464536 -1185.3058066832402 169.2062868517167 513.41009185359724 -1185.3385589874915 172.31261130248586 510.96538463140638 -1185.5053822630664 174.79170971189484 507.91833949997783 -1185.7923462790131 176.51932719919591 504.4650605817011 -1186.1770003278455 177.44160575830938 500.81840824792567
+6 0 7 -1063.9324841405937 178.1835498900883 479.57442086676792 -1080.9469243398116 175.64790242742492 482.36559733504691 -1098.0763729117332 174.10753448664042 485.32727545916629 -1115.3777504744135 173.54575193569195 488.44319184807193 -1132.8141310276469 173.77804943710436 491.63632760310014 -1150.3916198915085 174.65154294392639 494.78686884085448 -1168.1627796476289 175.96873740435072 497.85190011612627 -1186.1770002819585 177.4416062525741 500.81840824036914
+6 0 7 -1352.6044047102887 155.53888434028465 537.40779353585242 -1353.160219613598 159.06092611664886 537.47914070878142 -1353.810497265388 162.5829678952789 536.81459602739449 -1354.526371163003 165.9221032208041 535.41046954440174 -1355.2716185906684 168.89534940536342 533.32028305535084 -1356.0063898248279 171.34372161504703 530.65580260017782 -1356.692957327688 173.15516990677958 527.57091376931396 -1357.2998046877181 174.27169649051092 524.23866174257205
+6 0 9 -1186.1770003279307 177.44160625633293 500.81840824793966 -1204.5059739056264 178.94020976274808 503.83674859834628 -1223.0783564396397 180.59400948512248 506.75732128477358 -1241.9465521715781 182.14630133955882 509.5635015125107 -1261.1142868878146 183.21149096947056 512.26460670088466 -1280.6850965738815 183.57161795201293 514.89891511686619 -1300.5107702354421 182.49287559305856 517.37775473825548 -1319.9715244404931 180.17961036838523 519.69384538909844 -1338.9332805738366 177.18956376494131 521.96032239228396 -1357.299804659863 174.27152335269221 524.23884393582318
+6 0 7 -1370.4053730067612 152.68650658283727 539.69281459138551 -1370.9622558650076 156.22250084021897 539.7642988242759 -1371.6143418864347 159.75849531051506 539.09412342303858 -1372.3324825956363 163.10942055100085 537.67856206640033 -1373.0800561515707 166.09012301955977 535.57200321027665 -1373.8167670401797 168.53993767223861 532.88799403852067 -1374.5045028573311 170.34603994945169 529.78273685886847 -1375.1114928763584 171.45060411049039 526.4316198760481
+6 0 5 -1375.1114928778582 171.45060411895486 526.43161987221629 -1371.5482248593382 172.01325159120441 525.99641287690565 -1367.9854370067781 172.57666218767187 525.55943673290153 -1364.4231144288965 173.14085920071892 525.12076856765498 -1360.8612420568463 173.70586398969795 524.68048489251066 -1357.2998046877178 174.27169649051092 524.23866174257205
+6 0 8 -1399.4047774058015 87.75710987207303 579.44020074020409 -1400.0597874986966 88.647719624393943 582.49961212962421 -1401.3060960281753 89.538329377051525 585.43242843558892 -1403.1172866196764 90.393038548744769 588.11532718351737 -1405.4336371219965 91.175931337152974 590.43206187423186 -1408.1641141365039 91.854164875604624 592.28412962014886 -1411.1937558242332 92.400943562078567 593.59987622589927 -1414.3941415725537 92.797713268125804 594.34013768580564 -1417.6346471030986 93.034909135300211 594.49851707064579
+6 0 8 -1399.4047774058015 87.75710987207303 579.44020074020409 -1399.4442903381378 87.093821462887945 579.62474346774502 -1399.4782948832947 86.42405576099236 579.7836215845316 -1399.5110276609282 85.753250118707484 579.93644817064933 -1399.5416192880991 85.08009498934581 580.07934742430848 -1399.5705458035013 84.40494591995467 580.21449402559767 -1399.5987924493982 83.729098361391209 580.34639380351916 -1399.625754956478 83.052063244283275 580.47233926040826 -1399.6519034768448 82.373981269430587 580.59447350783876
+6 0 8 -1399.6519034768448 82.373981269430587 580.59447350783876 -1400.3122423271191 82.954953387399669 583.67877444748001 -1401.5473550358554 83.535925506356961 586.64001817060807 -1403.3313555356394 84.094132925919411 589.3573524759629 -1405.6068840128826 84.606801986811305 591.71661384780418 -1408.2870211112715 85.053052126183672 593.62047823564728 -1411.2621345372631 85.415731245477474 594.99718556014318 -1414.4095806615944 85.682782413640595 595.80605085051616 -1417.6041837107787 85.847739928508474 596.0379749189708
+6 0 6 -1417.6346471032389 93.034909135287762 594.49851707066045 -1417.5827211528849 91.851873841368644 594.81920125480917 -1417.5725471392268 90.658960570147528 595.09861711159363 -1417.570598201524 89.461368082922647 595.35686945584678 -1417.5768819959103 88.259834447900559 595.59674115937332 -1417.5889199839096 87.054974349338963 595.82309272853036 -1417.6041837105106 85.84773994967469 596.03797503137889
+6 0 5 -1399.8411147814288 76.936017147650674 581.47823885938817 -1399.8065129011966 78.026115231980143 581.31662091145517 -1399.7705274165401 79.115197001145916 581.14854155749526 -1399.7330860937045 80.203205276687939 580.97366099677288 -1399.6937173771789 81.289665533083962 580.78977745536633 -1399.6519034768437 82.373981269430658 580.59447350783921
+6 0 7 -1399.8411147814288 76.936017147650674 581.47823885938817 -1400.5965704793964 77.483142709451158 585.00681010474909 -1402.1118579553715 78.030268273422067 588.37270383419866 -1404.3458704118784 78.547635816432106 591.38400573617071 -1407.1956202802514 79.005473002264594 593.86195343197778 -1410.5012722609376 79.378100895180069 595.66756507039406 -1414.0703867774334 79.647828882360812 596.72271977808077 -1417.7052652315911 79.806048816100684 597.01168301769974
+6 0 5 -1417.7052652315915 79.806048816037787 597.01168291143881 -1417.6823094095926 80.986256306570866 596.83795044261387 -1417.6601154980822 82.175677048574144 596.65605546320592 -1417.6391466081793 83.378426216306124 596.46422362352155 -1417.6200008258086 84.596737089650418 596.26064792345619 -1417.6041837108096 85.84773992605983 596.03797503558201
+6 0 5 -1400.1445548699576 66.006651378195713 582.89554230532792 -1400.0907932715445 68.196760856179125 582.64443343207313 -1400.0340615877806 70.385177677221535 582.37945325135649 -1399.9742168625012 72.57180058321579 582.0999319077838 -1399.9103185418926 74.755820978991821 581.80147475525462 -1399.8411147814279 76.936017147650716 581.4782388593884
+6 0 7 -1400.1445548699571 66.006651378195727 582.89554230532735 -1400.9012263700292 66.430448373948082 586.42979228410343 -1402.4132921065575 66.854245371364684 589.80231481186092 -1404.6398198710972 67.255126750222544 592.82200906099592 -1407.4787160268081 67.610166036751153 595.31077400621336 -1410.7717151458803 67.899570170024532 597.12986366063001 -1414.3282325609393 68.109662560294751 598.20079780676599 -1417.9523082137794 68.233732502367118 598.50700177558883
+6 0 5 -1417.9523082137798 68.233732502345674 598.50700175133238 -1417.9014088490994 70.52018944403568 598.24530781336148 -1417.8506927687092 72.814818920133604 597.96854849448721 -1417.8003390977333 75.122555268090025 597.67419968968898 -1417.7511768746272 77.445633883054811 597.35914784198098 -1417.7052652316211 79.80604881311659 597.01168291186639
+6 0 5 -1400.5857799393225 44.057864555294486 584.95640978986683 -1400.5145637555306 48.454952557247132 584.62377430113588 -1400.4353296810068 52.849082889782828 584.25369003317962 -1400.3480596226118 57.239752496948505 583.84607134699422 -1400.2520780667821 61.626432422228937 583.39776005183671 -1400.1445548699571 66.006651378195727 582.89554230532724
+6 0 7 -1400.5857799393234 44.057864555294501 584.95640978986728 -1401.3463768670397 44.338932973356961 588.50899459536868 -1402.8643808467286 44.620001392405307 591.89942101146733 -1405.0985376629424 44.885831346017355 594.93508508097602 -1407.9461057890171 45.121177099688744 597.43645100502488 -1411.2478991124415 45.312882242768275 599.26368623183612 -1414.8123479349656 45.451868281515928 600.33779716380741 -1418.4426334328041 45.533697426557097 600.64225921004186
+6 0 5 -1418.4426334328136 45.53369743255449 600.64225920859508 -1418.3519107663351 50.06310502290291 600.29812858907326 -1418.2560399598669 54.589609395703491 599.91578492128167 -1418.156096341341 59.12116153288386 599.49385406438773 -1418.0541069437315 63.660818587809125 599.03038963063159 -1417.9523082141275 68.233732482122448 598.50700175363761
+6 0 7 -1400.9342511658822 1.5791812302268227e-11 586.58404400650647 -1400.9342511960938 6.3003241001471189 586.58404414760821 -1400.9347174306145 12.600548609707399 586.5862218913087 -1400.9006981139737 18.901723042766459 586.42732403695447 -1400.8447823882564 25.197456608128899 586.16615617013906 -1400.7738440155633 31.488950066666185 585.83481571059406 -1400.687517344197 37.776310279583399 585.43160334422907 -1400.5857799393225 44.057864555272424 584.95640978986887
+6 0 9 -1418.9463723592617 2.3696600237599341e-11 602.33725485102548 -1418.9463724262741 4.9002487004883086 602.33725485315961 -1418.9461801216878 9.9664511453718045 602.33744641484134 -1418.9245991858595 15.224831070222123 602.28146235089741 -1418.8656394032664 20.245035687603995 602.10765783647901 -1418.8054972325076 25.379678339044688 601.92200455690624 -1418.7247851989846 30.414831263588496 601.6600079367056 -1418.6387101460195 35.466259498579944 601.36470413004224 -1418.543436395769 40.501022322309716 601.02462656436956 -1418.4426334328152 45.533697432695739 600.64225920858462
+6 0 5 -1395.9209712992051 121.09636869193949 563.16809104775484 -1396.8848122767597 115.17825502685025 567.66998511452812 -1397.7165423468177 108.76915809723417 571.55484206886706 -1398.4122300464967 101.99916705632705 574.80424522918747 -1398.9750205621842 94.968623225499655 577.43289887213928 -1399.4047780076592 87.757099786813541 579.44020354862323
+6 0 7 -1395.9209712992035 121.09636869195513 563.1680910477437 -1396.5876571290305 123.57371806182394 566.2820372953089 -1398.1828734827841 126.05106743369528 569.19718816060845 -1400.6622735741812 128.36376756055674 571.70659303538355 -1403.889179020875 130.3470288403808 573.62288469942473 -1407.6407354615881 131.86388462413964 574.81372151401081 -1411.6499829512641 132.83104774836096 575.22677084608176 -1415.6510057403023 133.22247960627203 574.88473448687955
+6 0 9 -1375.1114928765742 171.45060411215067 526.43161987682822 -1382.8496167280186 170.22873479698939 527.37673857826496 -1390.2688506548632 168.44391256710912 530.0349494130752 -1397.0730184230824 166.16004962984306 534.39316194359162 -1403.0017287576431 163.27690393065961 540.16644076783746 -1407.8445371067467 159.58487800588645 547.45619644752367 -1411.2591064607436 154.27802217333345 555.15935075600385 -1413.5275458045908 147.98983038286448 562.41225094766833 -1414.9218398531452 140.90264784130133 569.03719974989565 -1415.6510057301159 133.22247971356467 574.88473440518135
+6 0 5 -1415.6510057727119 133.22247977053127 574.88473436128106 -1416.344103383266 125.92646557018485 580.44018728830099 -1416.9106076887376 118.11817792231388 585.15187939055033 -1417.3246543849561 109.97131680757097 589.03725694817172 -1417.5713164188262 101.58659656907173 592.14895302667617 -1417.6346486032351 93.034909092643929 594.49851718514151
+6 0 7 -986.58389113763712 -174.18268314342851 336.76440334201646 -986.58399832246937 -173.09681918789153 332.67584834618305 -986.58408627256256 -172.01527304739301 328.70988591101434 -986.58415536369705 -170.93785674777411 324.85919911131032 -986.5842066680367 -169.86319799150601 321.11348854173252 -986.58424204344431 -168.78863799942047 317.4592027922584 -986.5842642227974 -167.71012935244025 313.87926892363566 -986.58427690330393 -166.62213383330948 310.35282294283678
+6 0 7 -986.58389113763712 -174.18268314342851 336.76440334201646 -986.58404389406326 -172.63514424627712 330.93752433297351 -986.5841575827202 -171.09637528358101 325.35964365112909 -986.5842332913669 -169.56583213292183 320.00958124142443 -986.58427498061269 -168.03808488043236 314.85385316598689 -986.58429000903709 -166.50221719454456 309.84508696963752 -986.58428965830956 -164.9412256997376 304.92043704539839 -986.58428965830956 -163.33141935028598 300
+6 0 5 -1357.2998046875 -84.409924081361908 345.59766085132873 -1288.5895156016561 -90.84143661235909 316.90508590023308 -1219.8792265158122 -97.272949143356271 288.21251094913742 -1119.297486687376 -110.65238789245011 299.99999999999784 -1057.7877453620679 -140.62019012631396 300.00000000000034 -986.58428965830933 -163.33141935028601 300
+6 0 8 -1357.2998046875 -140.31946347921908 362.68733259059042 -1357.2998046875 -134.17068609663113 358.54098194815077 -1357.2998046875 -127.6704780677867 354.91577780328328 -1357.2998046875 -120.87037155895334 351.84647041221638 -1357.2998046875 -113.82602280983821 349.36169597515538 -1357.2998046875 -106.59630531220986 347.4833649787617 -1357.2998046875 -99.242281104680416 346.22622889380648 -1357.2998046875 -91.82610259302119 345.59766085132873 -1357.2998046875 -84.409924081361908 345.59766085132878
+6 0 11 -716.28679956583983 -163.89201846883103 635.79360142414157 -733.90560105491136 -163.73326936460256 638.19592425710596 -751.53798172973063 -163.18443216579251 640.2925652823568 -769.19133734723994 -162.25053920930361 642.08908817388237 -786.8743315217182 -160.93717609103061 643.58105296522695 -804.59611678953479 -159.25077512861347 644.75421105107944 -822.36557039025809 -157.19864644814314 645.58488710942197 -840.19047621602931 -154.78866765043131 646.04064666914019 -858.07673604671311 -152.02867688109302 646.08112852543491 -876.02758173911877 -148.92571718121224 645.65859739135624 -894.04223541407725 -145.48536137979784 644.71803451940787 -912.11385975545829 -141.7113257661573 643.19695647031654
+6 0 5 -724.71402236592746 -213.97360179557134 353.35225906002546 -721.66076191524803 -228.57806306267594 400.93954784862063 -714.17443277814573 -246.9737017275599 462.66199666596361 -704.25360245442369 -262.43300358692289 543.45809480873345 -716.60261155500439 -217.44498184819253 597.71612547062205 -716.28679955432904 -163.89201846893445 635.79360142257349
+6 0 8 -986.58427690304677 -166.62213383354137 310.35282294332467 -954.43607697853361 -177.73959034842727 313.31370072537015 -921.92663800106186 -187.12539275269427 316.65826961239611 -889.26851923771665 -194.86177364604924 320.54756338581473 -856.45974106070878 -201.06121773791367 324.96887189265664 -823.56129181186282 -205.91709619778771 330.35076730138377 -790.5396383601925 -209.50193146717288 336.65553317284588 -757.52187366607802 -212.07921558525251 344.23698915727863 -724.71402236618974 -213.97360179555599 353.35225905995259
+6 0 8 -1736.5007975787805 -82.450978932827212 508.33286599485535 -1736.2077980590575 -89.544394195646021 510.1064590269005 -1735.67792529031 -95.541600494736841 513.32018484184005 -1735.034163146368 -100.41936855984204 517.20351229734217 -1734.3211220538856 -104.51845135154316 521.51863353106432 -1733.5268841423911 -107.98620805537908 526.35376810060939 -1732.6129384186199 -110.88734576032732 531.85693067291447 -1731.5522059652394 -112.92912977127422 538.28782159516618 -1730.3751551638882 -113.45645912842529 545.4127790067472
+6 0 3 -1729.9308261422793 -113.52876006177419 548.83165220120759 -1730.0397963386411 -113.56471612164528 547.68679833759552 -1730.1879060125077 -113.54029697196361 546.54497997678618 -1730.3751551638793 -113.45645912842978 545.41277900680745
+6 0 3 -1729.9308261422743 -113.5287600617749 548.83165220121009 -1605.7204856573494 -137.08365051327186 516.61252165964129 -1481.5101451724242 -160.63854096476882 484.39339111807249 -1357.2998046874998 -184.19343141626578 452.17426057650374
+6 0 4 -1357.2998046875 -140.31946347921911 362.68733259059042 -1452.1000529103201 -125.852342342607 399.09871594165287 -1546.9003011331401 -111.38522120599495 435.51009929271532 -1641.7005493559602 -96.918100069382888 471.92148264377772 -1736.5007975787805 -82.450978932770823 508.33286599484018
+6 0 11 -504.08517894042558 -138.77628526665427 580.39872152394537 -523.13336469565957 -143.65680432654449 588.84487636083213 -542.34175356079948 -147.98182590828841 596.31276856525994 -561.63207540601968 -151.76358064397476 602.931624529852 -580.95897411691101 -155.01787467551119 608.81860289691053 -600.29750740486861 -157.75886630165539 614.07182153008705 -619.63458143072501 -159.99745595774036 618.77260018968889 -638.96492085419698 -161.74158606423393 622.98721459793751 -658.28903211357454 -162.99737080071421 626.76725867485959 -677.61177674268106 -163.77033198803261 630.14949059341711 -696.94110237970222 -164.06632726621885 633.15581643639996 -716.28679956583971 -163.89201846883105 635.79360142414157
+6 0 11 -962.79144938972593 3.1072363857067117e-14 669.33533617967908 -947.69280247531026 3.286091671511048e-14 673.78320852319644 -932.44625502745441 3.2558412458504289e-14 677.74104225686574 -917.04408179372876 3.0125611658825144e-14 681.22960810642871 -901.47540996217379 2.8279507266409177e-14 684.26370957877828 -885.72804190421937 2.8188428315200387e-14 686.85240798035807 -869.78966002501329 2.9534349902887216e-14 688.99932676553669 -853.64901698611891 3.1478793765704687e-14 690.70297532433653 -837.29710179547192 3.3321531074768545e-14 691.95712054380454 -820.7281149993147 3.4712738050735429e-14 692.75120418776385 -803.94017651262038 3.5599980687186041e-14 693.07074623129211 -786.93581954035517 3.6092090222609754e-14 692.89767965465057
+6 0 6 -771.78136046056238 -37.001293834053612 690.30790513833813 -776.79733425584902 -31.90544113064459 691.11280916804651 -780.71111111380185 -26.229925117601947 691.79349306900508 -783.68667445831511 -20.298303831905852 692.31292660517454 -785.75660540207275 -13.913969088940082 692.69053766842762 -786.93581715109815 -7.1867753628248048 692.89767923072543 -786.93581954549529 -1.7631039517240765e-05 692.89767965470253
+6 0 5 -771.78136046056238 -37.001293834053044 690.30790513833358 -768.35776868427718 -40.479405984844725 689.75852770362189 -764.83395698792515 -43.237750162211086 689.21843056231069 -761.33988357627209 -45.482903337033406 688.70633475727038 -757.84099361181495 -47.29096258080083 688.22311600119588 -754.36687927734192 -48.726769868387329 687.77071642917304
+6 0 6 -754.36687773316589 -48.726770507622739 687.77071622791732 -743.33743251818032 -53.285099595236822 686.33446062122266 -732.54771221003239 -54.241565018458829 685.1964075192966 -722.52670074975651 -53.160309584128768 684.40900313770726 -713.0793617833416 -49.80224170921025 683.90000583129768 -704.41800267262261 -44.714374969927924 683.57754537720416 -697.08250584199266 -37.428371506755184 683.40278405244067
+6 0 6 -697.08250045573777 -37.428366276491225 683.40278390880792 -692.89902150488831 -33.27311247540095 683.30311649271175 -689.16146664866494 -28.388025627657548 683.25560352360196 -685.82593818614976 -22.830010228372025 683.21723555914184 -683.31642941961854 -16.286743748574708 683.2193891790788 -681.50648876033222 -8.8838880586035778 683.20443336954816 -681.50648883854626 4.4439598667622704e-09 683.20443338734515
+6 0 11 -681.50648887093121 -3.6957037620727299e-14 683.20443339015185 -665.02631892622867 -3.7236875374439659e-14 680.31263105251321 -648.41982898710262 -3.7564513893348632e-14 676.90754489688936 -631.70576602668473 -3.7838460469356839e-14 672.96498420930061 -614.90681110382195 -3.7897309794586906e-14 668.45871279423136 -598.04986233221609 -3.7587230417453738e-14 663.36044576694928 -581.16648602223552 -3.6879431176812435e-14 657.63981280783185 -564.29367973685612 -3.5980470121241022e-14 651.26435611834813 -547.47509530536229 -3.5311649610805901e-14 644.19972283334687 -530.76279186532258 -3.5233018583307303e-14 636.41037450929184 -514.21934542800454 -3.5625251093438768e-14 627.86140694589631 -497.91964895786396 -3.6091463170377259e-14 618.5224884320794
+6 0 11 -517.16342521475042 -208.22457291448259 514.29852713637217 -518.43969213919593 -211.47288555501285 508.29769812371114 -519.78959744183362 -214.37989711405197 501.99604225396342 -521.20730749951485 -216.87319652457955 495.41997264922117 -522.6829213747003 -218.8984015462475 488.6120135564812 -524.19211952206717 -220.3698113915826 481.6662599252727 -525.70441452319324 -221.29141878342762 474.72780275061763 -527.20880404845286 -221.72070409983368 467.89181954464578 -528.70877553096864 -221.7292093999107 461.21077676641306 -530.21441809687747 -221.38689890604809 454.71162081856795 -531.73857544437215 -220.75765429171057 448.40556698455953 -533.29518179659124 -219.89824201450531 442.29410862037622
+6 0 10 -724.71402236571794 -213.97360179559382 353.35225906011323 -704.14664749962776 -215.16120018392968 359.0666586829791 -683.78844412528565 -216.0805146440029 365.32882766067354 -663.71006471445139 -216.80759225096966 372.20431429861679 -643.89847384040752 -217.43060800675084 379.64586917656158 -624.4994000973652 -218.03840999916673 387.9684236789563 -605.30809030778528 -218.65257747861594 396.69192617145802 -586.74912862441113 -219.49686561810134 406.84015838351473 -568.32868109094295 -220.24446132985261 417.39897593451178 -550.56389405749667 -220.83595549630493 429.29839972382115 -533.29516479252709 -219.89822451210577 442.29410401478941
+6 0 6 -1055.0462684070008 -179.43451516282818 471.93073950569567 -1054.0330764133366 -179.67172790762928 473.25333697562212 -1052.9614686881696 -179.57449295023372 474.59117272332941 -1051.8830703348306 -179.13070236874128 475.87685280689232 -1050.8546722581946 -178.35676692747069 477.04145046045852 -1049.9284936774757 -177.29928359410764 478.02710987308427 -1049.144476644806 -176.02328600584738 478.79472919085487
+6 0 7 -996.77226793690636 -189.29639490612192 424.6984683660055 -1001.0427414894895 -188.47009783327178 427.98110045275013 -1005.2708602108546 -187.64939459255598 431.29091519733174 -1009.4694005667006 -186.84279801123472 434.61974446781767 -1013.6476043825555 -186.05635642330094 437.96259450936924 -1017.8119346264484 -185.2940507178036 441.31677058465925 -1021.9666956622623 -184.55811572853861 444.68120194814696 -1026.1145179737666 -183.84928596510744 448.05596715421086
+6 0 7 -1026.1145179737664 -183.84928596510744 448.0559671542108 -1030.2623396861645 -183.14045630405874 451.43073187282783 -1034.4032226762574 -182.45873186101377 454.81583043103581 -1038.539797426675 -181.80484714525574 458.21134138317916 -1042.6730205409008 -181.17803634274023 461.61849258285741 -1046.8026594669552 -180.5762790469764 465.03918649140064 -1050.9276416918767 -179.99647033134141 468.47572582002891 -1055.0462684070008 -179.43451516282812 471.93073950569556
+6 0 4 -1357.2998046875 -179.24521158881782 503.46067502661873 -1452.8820651785772 -161.80997517955458 523.4601366398814 -1548.4643256696545 -144.37473877029134 543.45959825314378 -1644.0465861607317 -126.9395023610281 563.45905986640616 -1739.628846651809 -109.50426595176488 583.45852147966866
+6 0 3 -1357.2998046875 -184.19343141626578 452.17426057650368 -1357.2998046875 -183.06357321272759 469.31704241688135 -1357.2998046874998 -181.43454567138528 486.43861627674681 -1357.2998046875 -179.24521158881782 503.46067502661867
+6 0 6 -1739.6288466518536 -109.50426595175895 583.45852147965229 -1735.8178291081906 -110.58468273943616 578.34960649080824 -1732.997573181704 -111.5055624622893 572.93893263077132 -1730.9730306452868 -112.27786644785462 567.29495196096411 -1729.7447849091043 -112.88904562994605 561.41345864965149 -1729.3183919923313 -113.32621571238377 555.27557500426713 -1729.9308261422741 -113.528760061773 548.83165220124965
+6 0 5 -1737.1785352811744 -48.852006212354915 504.23036484517149 -1737.1785352811739 -55.672886972695267 504.23036484517303 -1737.1101423069399 -62.446704630601502 504.64443462058784 -1736.9756583065825 -69.162797870262139 505.45835406586218 -1736.7740197399835 -75.836366559856998 506.67898983229907 -1736.5007975787842 -82.450978932737343 508.3328659948329
+6 0 4 -1737.1785352811744 -48.852006212320823 504.23036484517155 -1642.2088526327557 -57.741485679581089 464.57218884671084 -1547.239169984337 -66.630965146841348 424.91401284825014 -1452.2694873359183 -75.520444614101621 385.25583684978943 -1357.2998046875 -84.409924081361908 345.59766085132884
+6 0 10 -754.3655100556889 48.72427271624646 687.77104973123039 -750.12390100353025 50.480151568989143 687.21823158857478 -745.71005114470154 51.829561594231826 686.67916797870987 -741.0330245752582 52.813943512999309 686.14360071284148 -736.17352854806416 53.307944858241584 685.66296883390783 -730.429465692382 53.58776454411791 685.04744409581815 -725.17136693163388 52.675262688825242 684.74867780318141 -717.95202006117995 51.432233663694213 684.13418140738167 -711.59791513410232 48.800988338027238 683.85340383665869 -704.129215114879 44.421383246266849 683.57148711355865 -697.08558817311439 37.425096352637055 683.40366558692699
+6 0 10 -786.93581954021079 -1.8247092725687253e-10 692.89767965486396 -786.93837785522624 8.5295642813742436 692.89770569283212 -785.40990431513058 15.773429366259329 692.6286401452254 -783.05764322551465 22.27286455089742 692.20529865842843 -780.12852338922426 27.711597382107467 691.68842802661663 -776.60810857339823 32.878726433685408 691.07147275915372 -772.8249390120701 37.062190030554895 690.43967474459021 -768.60388484550799 40.853221797000565 689.76745546798008 -764.11388434689388 44.02726406463492 689.09165566146658 -759.35647065947501 46.657864786130538 688.42157061691489 -754.36547006468561 48.724157813031837 687.77106907302289
+6 0 11 -716.28679956583983 163.89201846883103 635.79360142414157 -733.90560105491136 163.73326936460256 638.19592425710596 -751.53798172973063 163.18443216579251 640.2925652823568 -769.19133734723994 162.25053920930361 642.08908817388237 -786.8743315217182 160.93717609103061 643.58105296522695 -804.59611678953479 159.25077512861347 644.75421105107944 -822.36557039025809 157.19864644814314 645.58488710942197 -840.19047621602931 154.78866765043131 646.04064666914019 -858.07673604671311 152.02867688109302 646.08112852543491 -876.02758173911877 148.92571718121224 645.65859739135624 -894.04223541407725 145.48536137979784 644.71803451940787 -912.11385975545829 141.7113257661573 643.19695647031654
+6 0 11 -504.08517894042558 138.77628526665427 580.39872152394537 -523.13336469565957 143.65680432654449 588.84487636083213 -542.34175356079948 147.98182590828841 596.31276856525994 -561.63207540601968 151.76358064397476 602.931624529852 -580.95897411691101 155.01787467551119 608.81860289691053 -600.29750740486861 157.75886630165539 614.07182153008705 -619.63458143072501 159.99745595774036 618.77260018968889 -638.96492085419698 161.74158606423393 622.98721459793751 -658.28903211357454 162.99737080071421 626.76725867485959 -677.61177674268106 163.77033198803261 630.14949059341711 -696.94110237970222 164.06632726621885 633.15581643639996 -716.28679956583971 163.89201846883105 635.79360142414157
+6 0 11 -505.07062827091778 -200.00431643961156 465.64803441254969 -504.35300869243559 -199.75203399848641 469.06538180410178 -503.66316448325136 -199.38436269765 472.47405943857683 -502.99957882466936 -198.8957543829884 475.86719416733206 -502.36069229786057 -198.28185061452913 479.2372400182781 -501.7449366964259 -197.53991452276281 482.57621979796977 -501.15077934103959 -196.6692300346478 485.87612336356125 -500.57676725354059 -195.67131542738554 489.12945295234482 -500.02155708700263 -194.54975208855112 492.32981571718136 -499.48393044262411 -193.30954358997576 495.47232276171258 -498.96281945937773 -191.95640594531406 498.55347869842973 -498.45723017994965 -190.49714574828155 501.57074294508828
+6 0 9 -533.29516487621709 -219.89823787247084 442.29410448599054 -529.24954609632368 -219.67849880414082 445.33848319205754 -525.35618590130366 -218.98103995508851 448.33141995791499 -521.71952413659938 -217.82653770308892 451.27290520081522 -518.30908186789554 -216.27933785747751 454.10011129442097 -515.16482457055918 -214.26149774168451 456.73225682502954 -512.15365190846876 -211.86194587219791 459.30923908555582 -509.42799992982106 -208.81567950130261 461.69499176868317 -506.84846522560878 -205.07731651473 464.02594321916433 -505.07062827092886 -200.00431643965578 465.64803441255589
+6 0 5 -1055.0284409624755 -179.42753570106885 471.9578545332414 -1056.8135668938012 -179.17784850945969 473.46802834504831 -1058.5969180401528 -178.92960332672291 474.9841222665396 -1060.3781480667919 -178.68189077565501 476.50679625920151 -1062.1568241739978 -178.43362593148836 478.0366858391684 -1063.9324957130996 -178.18354326159221 479.57442316600134
+6 0 5 -1357.2998046875 -184.19343141626578 452.17426057650368 -1287.5542899104139 -197.23905236797893 436.82478580842292 -1217.808775133328 -210.22876082014855 421.94380252006067 -1132.2344387927712 -147.34245946186576 414.46025386544636 -1065.6986747967708 -167.62875623995268 421.49083381166133 -996.77226794992077 -189.29639490038221 424.69846834733244
+6 0 5 -1055.0462684002837 -179.43451516736255 471.93073951498263 -1113.5914228886079 -169.05763810513847 468.60453701049124 -1174.5007387431972 -173.26594961892161 470.27296655030347 -1239.7078260853891 -199.84210200789656 485.1613701728599 -1298.5038153864446 -189.5916746774883 494.10161062410202 -1357.2998046875 -179.24521158881782 503.46067502661873
+6 0 4 -1743.8466817834424 -108.09754436052548 588.40590622181469 -1742.7217821590455 -108.51054877687456 587.24819563001506 -1741.6428791306639 -108.89002194996776 586.03869683882078 -1740.6113924767224 -109.22571593415444 584.77568757366714 -1739.628846651809 -109.50426595176447 583.45852147967344
+6 0 9 -1743.8466817834001 -108.09754435933688 588.40590622711511 -1749.025156564247 -106.19627876290214 593.7354262777294 -1753.9940988534161 -103.67458727709059 598.84687945551809 -1758.6839099363008 -100.60205362223084 603.6823523897425 -1763.0893666663194 -97.011158974806733 608.20342038999706 -1767.2079415081262 -93.009110215086508 612.45017011564835 -1771.0597688281302 -88.385284471046049 616.41442264269995 -1774.6636200430819 -83.217718960476986 620.12064692098556 -1777.9299835983436 -76.974091125127927 623.48334661280978 -1780.2887832032843 -69.668141750821874 625.91094746478439
+6 0 4 -1417.6346486124239 -93.034909038050671 594.49851720138304 -1508.2981822601387 -87.193217216227382 602.35162476723849 -1598.9617159078539 -81.351525394404092 610.20473233309394 -1689.6252495555689 -75.509833572580803 618.05783989894928 -1780.2887832032839 -69.668141750757513 625.91094746480462
+6 0 8 -1357.2998046875002 -174.27169648302382 524.23866175760577 -1357.2998046875002 -175.16899091079054 521.71787701485937 -1357.2998046875002 -175.98920051391841 519.1696532984995 -1357.2998046875002 -176.73134636597331 516.59674071566053 -1357.2998046875002 -177.39456727972984 514.00193127991133 -1357.2998046875002 -177.9781220513766 511.38805260883197 -1357.2998046875002 -178.48139125403381 508.75796146249655 -1357.2998046875002 -178.90387856124494 506.11453717350645 -1357.2998046875002 -179.24521158881782 503.46067502661862
+6 0 3 -1737.1785352811744 -4.8871129365579691e-11 504.23036484517155 -1737.1785352811792 -16.284000528668315 504.2303648451736 -1737.1785352811792 -32.568005682024911 504.2303648451736 -1737.1785352811744 -48.852006212271966 504.23036484517155
+6 0 2 -1357.2998046875 -84.409924081361908 345.59766085132878 -1357.2998046875002 -42.204962040680968 345.59766085132873 -1357.2998046875 0 345.59766085132884
+6 0 4 -1357.2998046875 0 345.59766085132884 -1452.2694873359185 0 385.25583684978955 -1547.239169984337 0 424.9140128482502 -1642.2088526327555 0 464.57218884671084 -1737.1785352811739 0 504.23036484517149
+6 0 5 -724.71402236592746 213.97360179557134 353.35225906002546 -721.66076191524803 228.57806306267594 400.93954784862063 -714.17443277814573 246.9737017275599 462.66199666596361 -704.25360245442369 262.43300358692289 543.45809480873345 -716.60261155500439 217.44498184819253 597.71612547062205 -716.28679955432904 163.89201846893445 635.79360142257349
+6 0 10 -724.71402236571794 213.97360179559382 353.35225906011323 -704.14664749962776 215.16120018392968 359.0666586829791 -683.78844412528565 216.0805146440029 365.32882766067354 -663.71006471445139 216.80759225096966 372.20431429861679 -643.89847384040752 217.43060800675084 379.64586917656158 -624.4994000973652 218.03840999916673 387.9684236789563 -605.30809030778528 218.65257747861594 396.69192617145802 -586.74912862441113 219.49686561810134 406.84015838351473 -568.32868109094295 220.24446132985261 417.39897593451178 -550.56389405749667 220.83595549630493 429.29839972382115 -533.29516479252709 219.89822451210577 442.29410401478941
+6 0 11 -517.16342521475042 208.22457291448259 514.29852713637217 -518.43969213919593 211.47288555501285 508.29769812371114 -519.78959744183362 214.37989711405197 501.99604225396342 -521.20730749951485 216.87319652457955 495.41997264922117 -522.6829213747003 218.8984015462475 488.6120135564812 -524.19211952206717 220.3698113915826 481.6662599252727 -525.70441452319324 221.29141878342762 474.72780275061763 -527.20880404845286 221.72070409983368 467.89181954464578 -528.70877553096864 221.7292093999107 461.21077676641306 -530.21441809687747 221.38689890604809 454.71162081856795 -531.73857544437215 220.75765429171057 448.40556698455953 -533.29518179659124 219.89824201450531 442.29410862037622
+6 0 5 -986.58041745656942 191.24530150611923 417.03458335149816 -986.58129058014867 188.29597008571699 398.46124527657935 -986.58219187473605 184.85514502485722 380.79709940325097 -986.58298396780742 181.24403164837815 364.54027181741873 -986.5835450084104 177.68923573821047 349.96746902643747 -986.58389113763769 174.18268314257679 336.76440333881135
+6 0 7 -986.58389113763712 174.18268314342851 336.76440334201646 -986.58399832246937 173.09681918789153 332.67584834618305 -986.58408627256256 172.01527304739301 328.70988591101434 -986.58415536369705 170.93785674777411 324.85919911131032 -986.5842066680367 169.86319799150601 321.11348854173252 -986.58424204344431 168.78863799942047 317.4592027922584 -986.5842642227974 167.71012935244025 313.87926892363566 -986.58427690330393 166.62213383330948 310.35282294283678
+6 0 8 -986.58427690304677 166.62213383354137 310.35282294332467 -954.43607697853361 177.73959034842727 313.31370072537015 -921.92663800106186 187.12539275269427 316.65826961239611 -889.26851923771665 194.86177364604924 320.54756338581473 -856.45974106070878 201.06121773791367 324.96887189265664 -823.56129181186282 205.91709619778771 330.35076730138377 -790.5396383601925 209.50193146717288 336.65553317284588 -757.52187366607802 212.07921558525251 344.23698915727863 -724.71402236618974 213.97360179555599 353.35225905995259
+6 0 9 -727.39767350204045 50.662042190126613 686.72030233475675 -724.26742690293372 50.243847108056102 686.465449494219 -721.08825605178583 49.596785042890772 686.22910677869299 -717.86788995047914 48.702148385957045 686.01178292556062 -714.58767268273289 47.559705460949544 685.81328091172998 -711.34183616955488 46.081612298144556 685.63856317862439 -708.00198662312164 44.341709944359494 685.48598215158802 -704.78639892556873 42.1312622585599 685.37911940410629 -701.4252133632998 39.48362906096348 685.26996885523886 -698.19874408851854 36.266876322375573 685.191437021875
+6 0 6 -753.60951397737904 47.161823021583714 689.58145052093505 -749.60729781183488 48.838730871614139 689.03729739615494 -745.436285383165 50.107974305132245 688.50716671821954 -741.11693098661681 50.96113761963025 687.99994086507081 -736.67099509445939 51.367346676907978 687.52928515640508 -732.09304340069764 51.28933481323223 687.10258159556565 -727.3976735020367 50.662042190128062 686.72030233475425
+6 0 10 -784.92315203001772 0.00059619169871538702 694.72239467648319 -784.92570001610045 8.2361454531363449 694.72144427053934 -783.45713577103902 15.247980228654875 694.45648196898935 -781.20368202736188 21.492609880868919 694.0231503713776 -778.37481463032657 26.834829305980364 693.53559823740898 -775.00574830771336 31.755784070892744 692.86606260903568 -771.3562306311884 35.85522607613391 692.26694769262872 -767.31042633538777 39.51252219082258 691.58044055064943 -762.98977109051816 42.593691626161032 690.90611461620051 -758.41217337603268 45.149533601547368 690.23443427067127 -753.60951397737949 47.161823021584041 689.58145052093505
+6 0 9 -784.92315203079806 0.00059618319304277634 694.72239466921019 -784.95221794699091 0.00058849909165006561 694.39183214777483 -785.04298627474441 0.00056235105664173243 694.06669503651403 -785.19429964183621 0.00051804505994113015 693.76014596470895 -785.40172536470641 0.00045686718495790361 693.48505898789438 -785.65763814485615 0.0003810618693525687 693.25304456422566 -785.95167894666281 0.00029369761899644681 693.07349435315018 -786.27154770867355 0.00019843219469903612 692.95286253127642 -786.60399881635954 9.9216097220041391e-05 692.89430245732945 -786.93581954022682 2.8421722982931164e-14 692.89767965507815
+6 0 14 -786.93581954022682 2.8421709430404007e-14 692.89767965507815 -786.93946598632306 12.157453842999534 692.89771676779856 -783.93340088497871 21.783287972272259 692.37075800094635 -779.69846632528981 30.341754614534011 691.58271495629401 -775.05225723312458 35.876337716217435 690.86667875295393 -767.37923606404945 44.789927276119073 689.26272550260649 -765.05738645782867 43.127999951955545 689.59176577305357 -751.18791840725066 55.628278244858109 686.45036283123045 -752.32415043425181 47.851521768464238 688.16502724329871 -736.14264523904274 58.442908477567045 684.69194191136171 -734.47040294095962 52.581209469181303 685.79176439775802 -722.34867758004725 54.102780866197918 684.2234291644063 -714.90196643649335 50.629899945815538 683.99003466344755 -705.70277825074152 45.984370679467673 683.60897881760093 -697.08558784254387 37.425096618158094 683.40366555654202
+6 0 2 -498.45723043216913 -190.49714556166353 501.57074281662966 -486.20940450243808 -144.99057254258034 494.7777132341605 -479.64241311860428 -100.71592261161595 491.13545321232959
+6 0 7 -471.21778651128233 -3.4147374454727185e-14 500.77993194646211 -470.83758938456657 -3.3041725674151747e-14 511.57399945276831 -470.97081101815564 -2.9136687156024286e-14 521.48476038472654 -471.45648930996737 -1.7764695151965299e-14 530.46440739255047 -472.15077007584091 -8.6860896894948537e-15 538.65882790083515 -473.00039839228594 -2.1922140162145026e-14 546.16788531712893 -473.94408857114934 -1.7274780021564071e-14 553.07995507849216 -474.94942832544325 -1.5936470892932242e-14 559.45782159448618
+6 0 13 -479.64241311860138 -100.71592261161007 491.13545321235608 -478.35301273172684 -93.022132600043719 492.56343519580452 -477.17221087513133 -85.324645132001365 493.88359900561363 -476.10295383901695 -77.648819602413937 495.11338869270168 -475.13670399915304 -69.93884642278779 496.1170570933038 -474.28177361706139 -62.282614801918278 497.31532592503089 -473.52964953700268 -54.5921083639087 497.81364755444145 -472.87490791303429 -46.857004184617431 499.04645377626753 -472.33830279610419 -39.243935677182016 499.38017129739205 -471.89481591310465 -31.433840887253275 500.00038059446393 -471.5624256624767 -23.693671740581664 500.32900810312486 -471.33389368227245 -15.857065654483876 500.64068369982647 -471.21778651128426 -7.9716732494617268 500.77993194644137 -471.21778651128301 -1.0128609062576288e-10 500.77993194644068
+6 0 8 -505.07062456209349 -200.00429901910661 465.64803780937808 -500.87174157313774 -188.02286014202951 469.47908165079951 -496.96823617919847 -175.93085385639353 473.18672787932138 -493.36751993635193 -163.68461625425709 476.59206462154469 -490.03031902658631 -151.3879290861112 480.08282272959929 -487.00526477530644 -138.91744896845103 483.16489686615324 -484.25596868101582 -126.32116575159804 486.06861979962133 -481.80071386695244 -113.59439923426787 488.74518358415281 -479.6424131186875 -100.71592261216244 491.13545321234693
+6 0 5 -1357.2998046875 -179.24521158881782 503.46067502661873 -1298.5002346050705 -189.59230479567753 494.1010406402666 -1239.7006645226411 -199.69875971478334 485.53248622009585 -1174.4888249855726 -173.17806538106026 470.48397712783981 -1113.5765850372302 -169.02482862980256 468.68595113270777 -1055.0284409625497 -179.42753570113976 471.95785453447701
+6 0 11 -1418.9463723464421 0 602.33725485003424 -1452.2176925047802 0 604.91463704614932 -1485.4890126631183 0 607.4920192422644 -1518.7603328214564 0 610.06940143837949 -1552.0316529797944 0 612.64678363449457 -1585.3029731381325 0 615.22416583060965 -1618.5742932964706 0 617.80154802672473 -1651.8456134548087 0 620.37893022283981 -1685.1169336131468 0 622.95631241895489 -1718.3882537714849 0 625.53369461506998 -1751.659573929823 0 628.11107681118506 -1784.930894088161 0 630.68845900730014
+6 0 9 -1780.2887832033275 -69.668141750689841 625.91094746482884 -1782.665860656389 -62.305589341968307 628.35735929149473 -1783.7591393765535 -54.350310513917456 629.48062405002429 -1784.4197940567124 -46.73647527687681 630.16976402864725 -1784.7814515874131 -39.025178147307926 630.52170454220391 -1784.925808386628 -31.27549298967697 630.69613110029388 -1784.9554366976949 -23.357183158542504 630.70648238739898 -1784.9292084195663 -15.571736129644293 630.68859421959928 -1784.9308940881601 -7.8546474627664882 630.68845900729991 -1784.9308940881601 -7.071232488442547e-11 630.68845900729991
+6 0 2 -1357.2998046875 84.409924081361908 345.59766085132878 -1357.2998046875002 42.204962040680968 345.59766085132873 -1357.2998046875 0 345.59766085132884
+6 0 3 -1357.2998046875 84.409924081361908 345.59766085132878 -1483.9260482187244 72.557284791681539 398.47522884927628 -1610.5522917499495 60.704645502001185 451.35279684722389 -1737.1785352811744 48.852006212320823 504.23036484517149
+6 0 3 -1737.1785352811744 4.8871129365579691e-11 504.23036484517155 -1737.1785352811792 16.284000528668315 504.2303648451736 -1737.1785352811792 32.568005682024911 504.2303648451736 -1737.1785352811744 48.852006212271966 504.23036484517155
+6 0 9 -533.29516487621709 219.89823787247084 442.29410448599054 -529.24954609632368 219.67849880414082 445.33848319205754 -525.35618590130366 218.98103995508851 448.33141995791499 -521.71952413659938 217.82653770308892 451.27290520081522 -518.30908186789554 216.27933785747751 454.10011129442097 -515.16482457055918 214.26149774168451 456.73225682502954 -512.15365190846876 211.86194587219791 459.30923908555582 -509.42799992982106 208.81567950130261 461.69499176868317 -506.84846522560878 205.07731651473 464.02594321916433 -505.07062827092886 200.00431643965578 465.64803441255589
+6 0 9 -498.45723043216924 190.49714556166361 501.57074281662955 -499.07515196327944 192.28068887899863 497.88297756510639 -499.71679801526761 193.90155836542033 494.09745352455622 -500.38415841820637 195.34822789365296 490.21970406239075 -501.07932743368946 196.60820129560119 486.25648807788093 -501.80485741589507 197.67281769647806 482.21982945822197 -502.56367278622031 198.53943108700861 478.12505225593713 -503.35886696201436 199.2112144911668 473.9882895577594 -504.19352701091032 199.69589400571152 469.82478761432577 -505.07062456211679 200.00429901919884 465.6480378093965
+6 0 5 -996.77216635433797 189.2964038667937 424.69852211975831 -1065.6985963393074 167.62829912229193 421.49186914531657 -1132.2343631122703 147.33400929148314 414.47817006493057 -1217.8087340121583 210.13110685848255 422.152306463532 -1287.5542693498292 197.23905621375533 436.82478128348419 -1357.2998046875 184.193431416267 452.17426057650363
+6 0 9 -1357.2998046875 184.19343141626581 452.17426057650368 -1357.2998046875002 184.95581682942503 440.6069623304524 -1357.2998046875 184.20965948514214 428.94023801541454 -1357.2998046875 181.94007573749803 417.39877933963572 -1357.2998046875 178.1714737530508 406.21035096683613 -1357.2998046875 172.96778981351804 395.59673333232303 -1357.2998046875 166.43084112273939 385.76559407814432 -1357.2998046875 158.69679511791949 376.90328810728369 -1357.2998046875002 149.93075528515118 369.16858625689707 -1357.2998046875 140.31946347921908 362.68733259059042
+6 0 5 -1357.2998046875 140.31946347921908 362.68733259059036 -1288.3392033724342 149.74517052458046 335.46007510878678 -1219.3786020573682 158.98223078947794 308.0007268572129 -1120.0058707994283 121.89706507359358 334.64601007881816 -1057.8249739693031 151.60668166320417 335.8901544314902 -986.58389113763735 174.18268314342859 336.76440334201646
+6 0 7 -1357.2998046875 140.31946347921908 362.68733259059036 -1357.2998046875 133.29228932768999 357.94864614208791 -1357.2998046875 125.79654098115226 353.90482169034834 -1357.2998046875 117.9146129265856 350.61162245930888 -1357.2998046875 109.73733300936307 348.11210111262369 -1357.2998046875 101.36118925086875 346.43575157463243 -1357.2998046875 92.885556666115363 345.59766085132873 -1357.2998046875 84.409924081361893 345.59766085132878
+6 0 5 -1357.2998046875 84.409924081361908 345.59766085132873 -1288.5895156016561 90.84143661235909 316.90508590023308 -1219.8792265158122 97.272949143356271 288.21251094913742 -1119.297486687376 110.65238789245011 299.99999999999784 -1057.7877453620679 140.62019012631396 300.00000000000034 -986.58428965830933 163.33141935028601 300
+6 0 7 -986.58389113763712 174.18268314342851 336.76440334201646 -986.58404389406326 172.63514424627712 330.93752433297351 -986.5841575827202 171.09637528358101 325.35964365112909 -986.5842332913669 169.56583213292183 320.00958124142443 -986.58427498061269 168.03808488043236 314.85385316598689 -986.58429000903709 166.50221719454456 309.84508696963752 -986.58428965830956 164.9412256997376 304.92043704539839 -986.58428965830956 163.33141935028598 300
+6 0 14 -769.93390378594336 -35.46828313822391 698.10032640057511 -788.33283209965691 -17.069354824559884 698.10032640059364 -786.23297685181569 1.1619713824269908 698.12994846630068 -788.83890743181905 9.9629167131155114 697.88121467049496 -778.67173600052968 22.993906749788749 698.86960915239308 -782.92361416079063 24.050938236699938 696.43853957512681 -771.48810653427745 34.05010808061342 700.59303107562687 -771.5472998693923 36.999002444711849 695.28303626734021 -767.60104906771255 37.873115109782134 700.5846152806771 -758.32369923138458 48.376384707963325 696.44265394764523 -756.73865975994761 44.652925044901394 698.8722193942491 -744.01785558984238 54.315846892022705 697.87840834485462 -735.11288241407021 51.793257211010918 698.13067198851707 -717.14911054834738 53.620056174624395 698.10032638530311 -698.99733766956649 35.468283257977362 698.10032635111065
+6 0 1 -770.30404092203162 -35.838420274289483 692.11723171514188 -769.9339037859545 -35.468283138212783 698.10032640057455
+6 0 8 -770.30404092198626 -35.838420274340329 692.1172317151412 -773.92653166591219 -32.140759116691704 692.72477910666498 -777.00416340102436 -28.102426664153931 693.2721329075415 -779.53461890909739 -24.023364272126706 693.70223411951929 -781.58638415303608 -19.545081595681445 694.11591756961411 -783.19216337111766 -14.990691019135555 694.40121322469213 -784.30986428487699 -10.195841963740293 694.61365158291551 -784.92153785105506 -5.2167200945939936 694.72299675888803 -784.92315203051464 0.00059618311145293035 694.72239466913356
+6 0 1 -698.99733750931227 35.468283138285187 698.10032640036661 -698.1987442049392 36.266876442455938 685.19143698548089
+6 0 9 -770.30404092198626 -35.838420274340329 692.1172317151412 -770.34844891562352 -35.832661892294574 691.80485521577737 -770.43231559872936 -35.866362199717791 691.49736084751157 -770.55404182184759 -35.939728558230335 691.20599741192598 -770.71013415551045 -36.051073988927754 690.94177895234805 -770.89531074808178 -36.196801974360426 690.714730800805 -771.1028036495893 -36.37158635693315 690.53315125520601 -771.32482618157599 -36.568739143852824 690.40303852926343 -771.55313472219041 -36.780710634484898 690.32776957674957 -771.77957506491975 -36.999617891711971 690.30805435076843
+6 0 14 -769.9339037859545 -35.468283138212726 698.10032640057477 -751.66970673766514 -53.732480186501341 698.10032640058012 -733.58567018765734 -51.780919309234946 698.13030702241008 -724.72628173243243 -54.345930844636896 697.87996987008046 -711.85674744348216 -44.44683999589229 698.8698431357202 -710.51546328651204 -48.421824530148783 696.44405100804443 -700.87747806816503 -37.459361647978895 700.58219651022387 -697.42451897995807 -37.044828985910556 695.29124994739232 -696.99554106165363 -33.57765989122052 700.58211101299503 -686.0468858374021 -23.949693888642209 696.44409881545073 -690.01302050976744 -22.601566993940409 698.86986115179434 -680.12107806553195 -9.7356201981059023 697.87994575414723 -682.68398493924815 -0.87508447086164409 698.13031350998642 -680.73570629013557 17.206651960220761 698.1003263991206 -698.99733757135982 35.468283229448225 698.10032639715234
+6 0 14 -770.30404092207141 -35.838420274242154 692.11723171518258 -762.08253320887786 -44.230532739857125 690.73835847055022 -753.16499456761676 -49.002488767871199 689.43858182728331 -746.02878212414419 -51.697186700097319 688.11676227571456 -734.69363912175174 -52.680754393055885 687.98897519633874 -731.47310952894065 -53.452843343235912 685.45726444251909 -718.86942234355024 -50.893183456636066 687.42373845076588 -716.14192663850281 -49.666203638360109 684.41701872647445 -705.9905119509549 -45.430156200930959 686.24137447196358 -701.39375335759951 -41.453267092449622 684.63631439959511 -695.08838193272709 -36.001991718155743 685.21553957121228 -690.20399929821815 -29.290903800406198 685.01299616573419 -686.10978260936031 -21.264738720337757 685.02703326526148 -683.14282544299431 -11.848187746260486 684.9959150664331 -683.15313923601593 -0.0016866233825361121 684.99915579957531
+6 0 13 -479.64241311860138 100.71592261161007 491.13545321235608 -478.35301273172684 93.022132600043719 492.56343519580452 -477.17221087513133 85.324645132001365 493.88359900561363 -476.10295383901695 77.648819602413937 495.11338869270168 -475.13670399915304 69.93884642278779 496.1170570933038 -474.28177361706139 62.282614801918278 497.31532592503089 -473.52964953700268 54.5921083639087 497.81364755444145 -472.87490791303429 46.857004184617431 499.04645377626753 -472.33830279610419 39.243935677182016 499.38017129739205 -471.89481591310465 31.433840887253275 500.00038059446393 -471.5624256624767 23.693671740581664 500.32900810312486 -471.33389368227245 15.857065654483876 500.64068369982647 -471.21778651128426 7.9716732494617268 500.77993194644137 -471.21778651128301 1.0128609062576288e-10 500.77993194644068
+6 0 3 -479.6424131186846 100.71592261215638 491.13545321237405 -484.02040737457014 130.23235589929089 493.56362656025925 -490.29201314573169 160.15943021579332 497.04205642834438 -498.45723043216924 190.49714556166367 501.57074281662949
+6 0 9 -1780.2887832033275 69.668141750689841 625.91094746482884 -1782.665860656389 62.305589341968307 628.35735929149473 -1783.7591393765535 54.350310513917456 629.48062405002429 -1784.4197940567124 46.73647527687681 630.16976402864725 -1784.7814515874131 39.025178147307926 630.52170454220391 -1784.925808386628 31.27549298967697 630.69613110029388 -1784.9554366976949 23.357183158542504 630.70648238739898 -1784.9292084195663 15.571736129644293 630.68859421959928 -1784.9308940881601 7.8546474627664882 630.68845900729991 -1784.9308940881601 7.071232488442547e-11 630.68845900729991
+6 0 4 -1417.6346486124239 93.034909038050671 594.49851720138304 -1508.2981822601387 87.193217216227382 602.35162476723849 -1598.9617159078539 81.351525394404092 610.20473233309394 -1689.6252495555689 75.509833572580803 618.05783989894928 -1780.2887832032839 69.668141750757513 625.91094746480462
+6 0 4 -1357.2998046875 140.31946347921911 362.68733259059042 -1452.1000529103201 125.852342342607 399.09871594165287 -1546.9003011331401 111.38522120599495 435.51009929271532 -1641.7005493559602 96.918100069382888 471.92148264377772 -1736.5007975787805 82.450978932770823 508.33286599484018
+6 0 5 -1737.1785352811744 48.852006212354915 504.23036484517149 -1737.1785352811739 55.672886972695267 504.23036484517303 -1737.1101423069399 62.446704630601502 504.64443462058784 -1736.9756583065825 69.162797870262139 505.45835406586218 -1736.7740197399835 75.836366559856998 506.67898983229907 -1736.5007975787842 82.450978932737343 508.3328659948329
+6 0 8 -505.07062456209349 200.00429901910661 465.64803780937808 -500.87174157313774 188.02286014202951 469.47908165079951 -496.96823617919847 175.93085385639353 473.18672787932138 -493.36751993635193 163.68461625425709 476.59206462154469 -490.03031902658631 151.3879290861112 480.08282272959929 -487.00526477530644 138.91744896845103 483.16489686615324 -484.25596868101582 126.32116575159804 486.06861979962133 -481.80071386695244 113.59439923426787 488.74518358415281 -479.6424131186875 100.71592261216244 491.13545321234693
+6 0 3 -1729.9308261422743 113.5287600617749 548.83165220121009 -1605.7204856573494 137.08365051327186 516.61252165964129 -1481.5101451724242 160.63854096476882 484.39339111807249 -1357.2998046874998 184.19343141626578 452.17426057650374
+6 0 3 -1729.9308261422793 113.52876006177419 548.83165220120759 -1730.0397963386411 113.56471612164528 547.68679833759552 -1730.1879060125077 113.54029697196361 546.54497997678618 -1730.3751551638793 113.45645912842978 545.41277900680745
+6 0 8 -1736.5007975787805 82.450978932827212 508.33286599485535 -1736.2077980590575 89.544394195646021 510.1064590269005 -1735.67792529031 95.541600494736841 513.32018484184005 -1735.034163146368 100.41936855984204 517.20351229734217 -1734.3211220538856 104.51845135154316 521.51863353106432 -1733.5268841423911 107.98620805537908 526.35376810060939 -1732.6129384186199 110.88734576032732 531.85693067291447 -1731.5522059652394 112.92912977127422 538.28782159516618 -1730.3751551638882 113.45645912842529 545.4127790067472
+6 0 5 -1055.0284409624755 179.42753570106885 471.9578545332414 -1056.8135668938012 179.17784850945969 473.46802834504831 -1058.5969180401528 178.92960332672291 474.9841222665396 -1060.3781480667919 178.68189077565501 476.50679625920151 -1062.1568241739978 178.43362593148836 478.0366858391684 -1063.9324957130996 178.18354326159221 479.57442316600134
+6 0 6 -1055.0284409624016 179.42753570099757 471.95785453199767 -1054.0149030268874 179.66048515445206 473.2755856288357 -1052.9430150045596 179.56064600340486 474.60726827752126 -1051.8641569454744 179.11618505282348 475.88609742072288 -1050.8348500349948 178.34350634183514 477.04384485404893 -1049.9071083487943 177.28886818117297 478.0232958120161 -1049.1207867878597 176.01677785876026 478.78580774805306
+6 0 7 -1026.1145179737664 183.84928596510744 448.0559671542108 -1030.2623396861645 183.14045630405874 451.43073187282783 -1034.4032226762574 182.45873186101377 454.81583043103581 -1038.539797426675 181.80484714525574 458.21134138317916 -1042.6730205409008 181.17803634274023 461.61849258285741 -1046.8026594669552 180.5762790469764 465.03918649140064 -1050.9276416918767 179.99647033134141 468.47572582002891 -1055.0462684070008 179.43451516282812 471.93073950569556
+6 0 7 -996.77226793690636 189.29639490612192 424.6984683660055 -1001.0427414894895 188.47009783327178 427.98110045275013 -1005.2708602108546 187.64939459255598 431.29091519733174 -1009.4694005667006 186.84279801123472 434.61974446781767 -1013.6476043825555 186.05635642330094 437.96259450936924 -1017.8119346264484 185.2940507178036 441.31677058465925 -1021.9666956622623 184.55811572853861 444.68120194814696 -1026.1145179737666 183.84928596510744 448.05596715421086
+6 0 4 -1357.2998046875 179.24521158881782 503.46067502661873 -1452.8820651785772 161.80997517955458 523.4601366398814 -1548.4643256696545 144.37473877029134 543.45959825314378 -1644.0465861607317 126.9395023610281 563.45905986640616 -1739.628846651809 109.50426595176488 583.45852147966866
+6 0 8 -1357.2998046875002 174.27169648302382 524.23866175760577 -1357.2998046875002 175.16899091079054 521.71787701485937 -1357.2998046875002 175.98920051391841 519.1696532984995 -1357.2998046875002 176.73134636597331 516.59674071566053 -1357.2998046875002 177.39456727972984 514.00193127991133 -1357.2998046875002 177.9781220513766 511.38805260883197 -1357.2998046875002 178.48139125403381 508.75796146249655 -1357.2998046875002 178.90387856124494 506.11453717350645 -1357.2998046875002 179.24521158881782 503.46067502661862
+6 0 9 -1743.8466817834001 108.09754435933688 588.40590622711511 -1749.025156564247 106.19627876290214 593.7354262777294 -1753.9940988534161 103.67458727709059 598.84687945551809 -1758.6839099363008 100.60205362223084 603.6823523897425 -1763.0893666663194 97.011158974806733 608.20342038999706 -1767.2079415081262 93.009110215086508 612.45017011564835 -1771.0597688281302 88.385284471046049 616.41442264269995 -1774.6636200430819 83.217718960476986 620.12064692098556 -1777.9299835983436 76.974091125127927 623.48334661280978 -1780.2887832032843 69.668141750821874 625.91094746478439
+6 0 4 -1743.8466817834424 108.09754436052548 588.40590622181469 -1742.7217821590455 108.51054877687456 587.24819563001506 -1741.6428791306639 108.89002194996776 586.03869683882078 -1740.6113924767224 109.22571593415444 584.77568757366714 -1739.628846651809 109.50426595176447 583.45852147967344
+6 0 6 -1739.6288466518536 109.50426595175895 583.45852147965229 -1735.8178291081906 110.58468273943616 578.34960649080824 -1732.997573181704 111.5055624622893 572.93893263077132 -1730.9730306452868 112.27786644785462 567.29495196096411 -1729.7447849091043 112.88904562994605 561.41345864965149 -1729.3183919923313 113.32621571238377 555.27557500426713 -1729.9308261422741 113.528760061773 548.83165220124965
+6 0 3 -1357.2998046875 184.19343141626578 452.17426057650368 -1357.2998046875 183.06357321272759 469.31704241688135 -1357.2998046874998 181.43454567138528 486.43861627674681 -1357.2998046875 179.24521158881782 503.46067502661867
+6 0 5 -1357.2998046875 179.24521158881782 503.46067502661873 -1298.5002346050705 189.59230479567753 494.1010406402666 -1239.7006645226411 199.69875971478334 485.53248622009585 -1174.4888249855726 173.17806538106026 470.48397712783981 -1113.5765850372302 169.02482862980256 468.68595113270777 -1055.0284409625497 179.42753570113976 471.95785453447701
+6 0 5 -1055.0462684002837 179.43451516736255 471.93073951498263 -1113.5914228886079 169.05763810513847 468.60453701049124 -1174.5007387431972 173.26594961892161 470.27296655030347 -1239.7078260853891 199.84210200789656 485.1613701728599 -1298.5038153864446 189.5916746774883 494.10161062410202 -1357.2998046875 179.24521158881782 503.46067502661873
+6 0 5 -1357.2998046875 184.19343141626578 452.17426057650368 -1287.5542899104139 197.23905236797893 436.82478580842292 -1217.808775133328 210.22876082014855 421.94380252006067 -1132.2344387927712 147.34245946186576 414.46025386544636 -1065.6986747967708 167.62875623995268 421.49083381166133 -996.77226794992077 189.29639490038221 424.69846834733244
+6 0 14 -768.52507173324011 -34.059451084925982 699.92601491507935 -786.19484127425187 -16.389681544230875 699.92601491507435 -784.17104185594701 1.1039223269087763 699.92601491506207 -786.67925515774459 9.5998830498552863 699.92601491511846 -776.95907751467212 22.051509255189558 699.92601491493747 -780.86358576825614 23.043940009861473 699.92601491535447 -770.25619561851659 32.878532682178886 699.92601491464279 -769.79105626392129 35.276215185037046 699.9260149155582 -766.50202067523401 36.589859920617798 699.9260149146802 -757.29428921831152 46.325779907079173 699.92601491532014 -755.84128259894896 42.922277027192891 699.92601491497635 -743.66569953138105 52.157574288289453 699.92601491511562 -735.0762323332483 49.73068412427039 699.92601491508037 -717.83854282847528 51.491824352060441 699.92601491509276 -700.40616956141048 34.059451084811158 699.92601491509743
+6 0 9 -768.52507173324011 -34.059451084925982 699.92601491507935 -768.75818596146473 -34.292565313217978 699.92601491507935 -768.99130018968958 -34.525679541509973 699.86487989124714 -769.21525277540798 -34.74963212729547 699.74260984358284 -769.42088246316303 -34.955261815117346 699.56240783434714 -769.59969808147321 -35.134077433493928 699.33068282501472 -769.74455707292611 -35.27893642501251 699.0566907698402 -769.85020480798812 -35.384584160140264 698.75183572557478 -769.91358654224655 -35.447965894463216 698.42874519727991 -769.93390378594336 -35.46828313822391 698.10032640057511
+6 0 9 -700.40616956181395 34.059451085141148 699.92601491509845 -700.17305533363344 34.292565313479564 699.92601491507708 -699.93994110544872 34.525679541867248 699.86487989122827 -699.71598851959016 34.749632127615072 699.74260984355089 -699.51035883202212 34.955261815696851 699.56240783429052 -699.33154321358006 35.134077433961771 699.33068282485465 -699.186684222194 35.278936426846329 699.05669076937181 -699.08103649086229 35.384584169699643 698.75183572414289 -699.0176547837533 35.447965924107201 698.42874519527879 -698.9973376715127 35.468283223760864 698.10032639985263
+6 0 14 -768.52507173317406 -34.059451085299941 699.92601491507958 -750.98471981093587 -51.599803007575773 699.92601491508458 -733.63194869624942 -49.718721276015167 699.92601491499693 -725.08361281727889 -52.186548449502162 699.92601491552875 -712.77424616716075 -42.725579389308436 699.92601491376172 -711.5363773699255 -46.364010493042969 699.92601491785456 -702.00843066276025 -36.205091714761927 699.92601491086634 -699.16850601449937 -35.3004042832709 699.92601491990445 -698.25041339204893 -32.447459631857015 699.9260149109632 -688.10451039713166 -22.928524786600505 699.92601491773394 -691.73451534868184 -21.684506355073005 699.92601491385904 -682.28041338020023 -9.37838758709443 699.92601491549817 -684.74620767589749 -0.82900806234665936 699.92601491502012 -682.86828212104001 16.521563644189769 699.92601491510334 -700.40616956197482 34.059451085125907 699.92601491509845
+6 0 11 -439.01302916064793 -374.19863857327982 571.49855790492745 -444.15928475616067 -372.31994216072962 569.88201383510091 -448.69710163844599 -370.2128429003763 566.5932152269587 -452.06083287685004 -368.08338083607828 561.80795872129568 -453.77140921456254 -366.16908066949139 555.9357936410272 -453.53022316917253 -364.70174804053613 549.57840892119862 -451.30117165551383 -363.86554080178757 543.45432072361325 -447.34018580781628 -363.75614392720769 538.26532866671448 -442.14410919268028 -364.3629691560472 534.56176123646333 -436.34471144907133 -365.57889334253468 532.65601646482969 -430.58973729210845 -367.22920584556437 532.60004933387677 -425.44350576948045 -369.10789570302541 534.21659498635415
+6 0 8 -439.01302916064793 -374.19863857327982 571.49855790492745 -439.27862910467894 -375.11730691068658 571.27644597004155 -439.46949346902534 -376.00793745057979 570.8489997174338 -439.57001888237806 -376.81656059130614 570.22926770027641 -439.57074845784069 -377.49151593262053 569.44718197940301 -439.47029786059323 -377.99008506615968 568.54798132524513 -439.27601753155216 -378.28477681560236 567.58701491475199 -439.00257098544307 -378.36597959380742 566.62213390744125 -438.66952395130266 -378.24103367905883 565.70709470200813
+6 0 11 -438.66952395130272 -378.24103367905877 565.70709470200813 -442.52921107272925 -376.83201303219215 564.49468812085308 -445.93265184585437 -375.25166007995142 562.02806432499369 -448.45529984874855 -373.6546170087837 558.43916379137966 -449.7382766661641 -372.21887750086768 554.03503358192245 -449.5574486030572 -371.11835882359668 549.26698893941216 -447.88566195638936 -370.49120461144832 544.67393023736372 -444.91489725402107 -370.40916631841196 540.7821947282979 -441.01782247740988 -370.86429070955535 538.0045211038464 -436.66827309095771 -371.77623337029047 536.575209241111 -432.35205060976932 -373.01396434296845 536.53322951859673 -428.49238605924194 -374.42297841220159 537.745635868764
+6 0 8 -425.44350576948045 -369.10789570302541 534.2165949863537 -425.70910567633211 -370.02656405390775 533.99448306274485 -426.04944100675954 -370.97327015414186 533.97770506962695 -426.44890839163781 -371.89404440128283 534.17930955950953 -426.8857601218254 -372.73261536816671 534.59545982653367 -427.33401129407764 -373.4370354948976 535.20380512213933 -427.76669290354874 -373.96693831965655 535.96540270718799 -428.15933972131546 -374.29803271394633 536.83059838851113 -428.49238605924194 -374.42297841220147 537.74563586876377
+6 0 3 -439.01302916133767 -374.19863857565849 571.49855790435322 -427.8069404213785 -335.43854412239892 580.86981763264953 -416.60085168141927 -296.67844966913947 590.24107736094572 -405.3947629414601 -257.9183552158799 599.61233708924203
+6 0 3 -425.44353144330626 -369.10788440174957 534.21657892462156 -414.23743754993262 -330.34778496322639 543.58781187114903 -403.03132958270032 -291.58771125854014 552.95913442495078 -391.82523568938126 -252.82761182000314 562.33036737148643
+6 0 11 -405.394762941458 -257.91835521587984 599.61233708924135 -410.54102582541486 -256.03965394279516 597.99578171924111 -415.07861166674252 -253.93263929591581 594.70705661526256 -418.44283844569571 -251.80299248185045 589.92162870704396 -420.15325735382004 -249.8887473458885 584.04950288777263 -419.9118653681586 -248.42148779283559 577.69217413971455 -417.6827894852604 -247.58528903343756 571.56809192326057 -413.72186127837114 -247.47587297952865 566.37908948675852 -408.52582896286418 -248.08268505576206 562.67552061348488 -402.72644423559137 -249.29860711632611 560.7697825917553 -396.97146856103848 -250.94892150324659 560.7138214290153 -391.82523568938115 -252.82761182000309 562.33036737148632
+6 0 11 -425.44350576948045 -369.10789570302541 534.2165949863537 -420.29727424685245 -370.98658556048645 535.83314063883108 -415.75978535855927 -373.0936527723789 539.12219907473889 -412.39535815228965 -375.22308637659194 543.90650543682671 -410.68488600830193 -377.13757509000988 549.77957502853042 -410.92643589584014 -378.60479448284167 556.13692652456507 -413.1553978821774 -379.44103393759258 562.26104098802637 -417.11669978312023 -379.55029413732143 567.44984577491471 -422.31221679586673 -378.9434462382597 571.15265002993317 -428.11162295865273 -377.72780833913902 573.05958835191768 -433.866865332229 -376.07730391671782 573.11508373443075 -439.01302916133585 -374.19863857565832 571.49855790435265
+6 0 11 -428.49224274817487 -374.42302552956227 537.74565937860541 -424.63256395655941 -375.83205554684133 538.95811467704561 -421.22946124549281 -377.41236384069163 541.42495781593504 -418.70618972174105 -379.00943446925044 545.01322713897571 -417.42342810825704 -380.44527805250925 549.41804502164109 -417.60469751228891 -381.54565911798187 554.18604808154976 -419.27645018227031 -382.17282588759042 558.77911808995862 -422.24730865889416 -382.25480530303599 562.67072227831352 -426.14387726765358 -381.79967892682112 565.4477824639639 -430.49382312367737 -380.88778804860965 566.87778260211167 -434.80988856155301 -379.6500371535742 566.91949211763631 -438.66952395044086 -378.24103367873494 565.70709469963811
+6 0 3 -428.49224274817476 -374.42302552956232 537.74565937860541 -430.18852038062681 -375.05933410305397 542.40586722184275 -431.88475283399782 -375.69565917070577 547.06608926108129 -433.58094010803086 -376.33200073242182 551.72632549561706
+6 0 3 -438.66952395216515 -378.24103367938221 565.70709470437737 -436.97332933745372 -377.60468936372877 561.04683830145723 -435.27713472274229 -376.96834504807532 556.3865818985372 -433.58094010803086 -376.33200073242188 551.72632549561706
+6 0 11 -391.82523568938132 -252.82761182000309 562.33036737148643 -386.67900281772398 -254.70630213675958 563.94691331395745 -382.14151274896216 -256.8133683833521 567.23596636163938 -378.77709923327149 -258.9427941632602 572.0202567607538 -377.06666830651739 -260.85726434141731 577.89329899629809 -377.30826080831076 -262.32446581782699 584.2506273116918 -379.53717113196416 -263.16072501649347 590.37476153397824 -383.49825899144327 -263.27006766339395 595.56365126615685 -388.69368310261967 -262.66325696434802 599.26649854895277 -394.49366249334469 -261.44740701969647 601.17324594095442 -400.2485000575025 -259.79705648896459 601.22889245924227 -405.39476294146016 -257.91835521587984 599.61233708924215
+6 0 1 -388.43285051863887 -251.55492471135057 553.00986571677913 -391.82522850662997 -252.82760912532234 562.33034763703949
+6 0 14 -388.43285051863893 -251.55492471135057 553.00986571677913 -394.49805619676215 -249.34075301317847 551.10465002333069 -401.11515240854931 -247.33362854939449 550.71574110913468 -407.90042042447806 -245.67363216738548 551.96367354204483 -414.42887753856945 -244.48536412249319 554.85561004636349 -420.26870165149722 -243.86537699592569 559.27452797738852 -425.02018041987122 -243.87130604876509 564.98083693935632 -428.35447023717683 -244.51441817905132 571.62790854951697 -430.04665358405867 -245.75700174854794 578.7908103594533 -429.99788727857714 -247.51531881491405 586.00500119233027 -428.24309928088752 -249.66783643907485 592.80958011252699 -424.94345924749689 -252.06743194419064 598.78876445149263 -420.36573545775332 -254.55562820925468 603.60608299202238 -414.85239056983016 -256.97686020390836 607.02762392329635 -408.7871521708808 -259.19104384718685 608.93284989508243
+6 0 1 -408.78715217088092 -259.1910438471869 608.9328498950822 -405.394762941458 -257.9183552158799 599.61233708924169
+6 0 14 -408.78715217088092 -259.1910438471869 608.9328498950822 -402.72191377193167 -261.40522749046539 610.83807586686817 -396.10478186195627 -263.41236278236863 611.22698687916625 -389.31948402810804 -265.07236564193175 609.97904558174434 -382.79101278652035 -266.26063293758364 607.08708908495817 -376.95119613246123 -266.88061134589236 602.66814401395447 -372.19974288465818 -266.87466853424132 596.96180866203895 -368.86549878846881 -266.23153775014816 590.31471457161012 -367.17336646597738 -264.98893751642078 583.15180485203166 -367.22217029449422 -263.2306111940872 575.9376206057068 -368.97698194976277 -261.07809092877528 569.13305905112213 -372.27662381478353 -258.67850066164442 563.15389856702848 -376.85432969605648 -256.19031534208295 558.33660388292867 -382.36764484051571 -253.76909640952275 554.91508141022769 -388.43285051863893 -251.55492471135065 553.00986571677925
+6 0 1 -374.20263638495641 -202.33485723634897 564.91009564807439 -388.43285051863904 -251.55492471135062 553.00986571677925
+6 0 14 -374.20263638495641 -202.33485723634891 564.91009564807428 -380.26784206307963 -200.12068553817682 563.00487995462584 -386.88493827486678 -198.11356107439283 562.61597104042994 -393.67020629079553 -196.45356469238382 563.86390347334009 -400.19866340488693 -195.26529664749154 566.75583997765875 -406.0384875178147 -194.64530952092403 571.17475790868377 -410.7899662861887 -194.65123857376344 576.88106687065158 -414.1242561034943 -195.29435070404963 583.52813848081223 -415.81643945037615 -196.53693427354625 590.69104029074856 -415.76767314489462 -198.29525133991237 597.90523112362553 -414.01288514720494 -200.44776896407313 604.70981004382224 -410.71324511381425 -202.8473644691889 610.68899438278788 -406.13552132407062 -205.33556073425294 615.50631292331775 -400.62217643614736 -207.75679272890662 618.92785385459183 -394.55693803719782 -209.97097637218508 620.83307982637791
+6 0 1 -394.55693803719839 -209.97097637218519 620.83307982637734 -408.78715217088103 -259.19104384718685 608.9328498950822
+6 0 14 -394.55693803719839 -209.97097637218519 620.83307982637734 -388.49169963824914 -212.18516001546365 622.73830579816331 -381.87456772827375 -214.19229530736689 623.12721681046139 -375.08926989442551 -215.85229816693004 621.87927551303949 -368.56079865283783 -217.04056546258192 618.98731901625331 -362.72098199877871 -217.66054387089068 614.56837394524962 -357.96952875097566 -217.65460105923967 608.86203859333409 -354.63528465478629 -217.01147027514654 602.21494450290527 -352.94315233229486 -215.76887004141915 595.0520347833268 -352.9919561608117 -214.01054371908555 587.83785053700194 -354.74676781608025 -211.85802345377363 581.03328898241728 -358.04640968110101 -209.45843318664276 575.05412849832362 -362.62411556237396 -206.97024786708127 570.23683381422381 -368.13743070683319 -204.54902893452106 566.81531134152283 -374.20263638495641 -202.33485723634897 564.91009564807439
+6 0 14 -379.1301750852636 -205.61691521356025 584.37720235859888 -380.94103560755468 -204.83472398732533 583.30742706780245 -383.03657371607449 -204.08159897106012 582.69828689571079 -385.30222427720179 -203.40702594307197 582.6174617920642 -387.6021372674698 -202.85831744742944 583.09819075222163 -389.78945576278153 -202.47617327314407 584.13320004146851 -391.71892780091838 -202.29047922696739 585.6724078458974 -393.2604444607731 -202.31695222930276 587.6252369303154 -394.31168553157124 -202.55519780177053 589.86770189523565 -394.80797181229718 -202.98856210101084 592.2535784925193 -394.72780371104 -203.58584850128298 594.62812653384117 -394.09338873894671 -204.30460900140827 596.84233412165736 -392.96644446961028 -205.09545026040902 598.76570887920184 -391.44025330005712 -205.90671207326301 600.29612754503034 -389.62938300849322 -206.68890751935442 601.36590860710339
+6 0 1 -394.55693803719782 -209.97097637218513 620.83307982637803 -389.62938300849322 -206.68890751935444 601.36590860710328
+6 0 1 -374.20263638495641 -202.33485723634897 564.9100956480745 -379.1301750852636 -205.6169152135603 584.37720235859911
+6 0 14 -389.62938300835083 -206.68890751911749 601.36590860707906 -387.81851271675487 -207.47110296515197 602.43568966914427 -385.72296330313998 -208.22423204440969 603.04483312745106 -383.45730254570958 -208.89880783627078 603.12565746995858 -381.15738360384574 -209.44751670452047 602.64492293403032 -378.97006557585479 -209.8296584457994 601.60990414051685 -377.04059985347112 -210.01534811075041 600.07068576737743 -375.49909626827809 -209.98886873044287 598.11784593783182 -374.44787100769156 -209.75061705931117 595.87537465415892 -373.95159723386524 -209.31724901098281 593.48949750601537 -374.0317741581112 -208.71996103085007 591.11495348067228 -374.66619141069776 -208.00120174386686 588.90075363736275 -375.79313162691011 -207.21036387599986 586.97738805889674 -377.31931456297247 -206.39910643979522 585.44697764939542 -379.13017508526355 -205.6169152135603 584.37720235859899
+6 0 11 -439.01302916064793 374.19863857327982 571.49855790492745 -444.15928475616067 372.31994216072962 569.88201383510091 -448.69710163844599 370.2128429003763 566.5932152269587 -452.06083287685004 368.08338083607828 561.80795872129568 -453.77140921456254 366.16908066949139 555.9357936410272 -453.53022316917253 364.70174804053613 549.57840892119862 -451.30117165551383 363.86554080178757 543.45432072361325 -447.34018580781628 363.75614392720769 538.26532866671448 -442.14410919268028 364.3629691560472 534.56176123646333 -436.34471144907133 365.57889334253468 532.65601646482969 -430.58973729210845 367.22920584556437 532.60004933387677 -425.44350576948045 369.10789570302541 534.21659498635415
+6 0 8 -439.01302916064793 374.19863857327982 571.49855790492745 -439.27862910467894 375.11730691068658 571.27644597004155 -439.46949346902534 376.00793745057979 570.8489997174338 -439.57001888237806 376.81656059130614 570.22926770027641 -439.57074845784069 377.49151593262053 569.44718197940301 -439.47029786059323 377.99008506615968 568.54798132524513 -439.27601753155216 378.28477681560236 567.58701491475199 -439.00257098544307 378.36597959380742 566.62213390744125 -438.66952395130266 378.24103367905883 565.70709470200813
+6 0 11 -438.66952395216515 378.24103367938221 565.70709470437737 -442.52920871402176 376.83201224175713 564.49468203107631 -445.93239732062597 375.25175375363187 562.0281476049646 -448.45557746118982 373.65451666784861 558.43908052942652 -449.73840519655278 372.21882687891201 554.0349778174309 -449.55736619372146 371.11837520672873 549.26695823610635 -447.88554575690881 370.49122309110822 544.67386780235745 -444.91481758705334 370.40916544917832 540.78209588450204 -441.01775225790198 370.86428624930159 538.00441866092979 -436.66817641195468 371.77624377157548 536.57513662217389 -432.35192153979028 373.01399551228332 536.53320408016498 -428.49224274817482 374.42302552956238 537.74565937860518
+6 0 8 -425.44350576948045 369.10789570302541 534.2165949863537 -425.70910567633211 370.02656405390775 533.99448306274485 -426.04944100675954 370.97327015414186 533.97770506962695 -426.44890839163781 371.89404440128283 534.17930955950953 -426.8857601218254 372.73261536816671 534.59545982653367 -427.33401129407764 373.4370354948976 535.20380512213933 -427.76669290354874 373.96693831965655 535.96540270718799 -428.15933972131546 374.29803271394633 536.83059838851113 -428.49238605924194 374.42297841220147 537.74563586876377
+6 0 3 -439.01302916133767 374.19863857565849 571.49855790435322 -427.8069404213785 335.43854412239892 580.86981763264953 -416.60085168141927 296.67844966913947 590.24107736094572 -405.3947629414601 257.9183552158799 599.61233708924203
+6 0 3 -425.4435314433062 369.10788440174952 534.21657892462144 -414.23743754993257 330.34778496322633 543.58781187114892 -403.03132958270027 291.58771125854008 552.95913442495066 -391.8252356893812 252.82761182000309 562.33036737148632
+6 0 14 -391.82522850662997 252.82760912532234 562.33034763703949 -395.86869895871212 251.35149465987428 561.0602038414072 -400.28009643323691 250.01341168401828 560.8009312319432 -404.80360844385609 248.90674742934561 561.63288618721663 -409.15591318658369 248.11456873275077 563.5608438567624 -413.04912926186887 247.70124398170577 566.50678914411242 -416.2167817741182 247.7051966835987 570.31099511875766 -418.43964165232194 248.13393810378952 574.74237619219809 -419.5677638835765 248.96232715012061 579.51764406548898 -419.53525301325544 250.13453852769806 584.32710462074033 -418.36539434812897 251.5695502771386 588.86349056753818 -416.1656343258685 253.16928061388248 592.8496134601819 -413.11381846603939 254.8280781239252 596.0611591538684 -409.43825520742394 256.44223278702771 598.34218644138446 -405.39476294145777 257.91835521588001 599.61233708924192
+6 0 11 -425.44353144330626 369.10788440174957 534.21657892462156 -420.29726814542971 370.98658347458837 535.83312469931184 -415.75974599721019 373.09366384850574 539.12219781806425 -412.39531203333939 375.22310613273783 543.90653202826331 -410.68488836216585 377.13758908535851 549.7796357759338 -410.92652684490821 378.60479175651955 556.13702401659896 -413.15551645434209 379.4410350132066 562.26118711129686 -417.11668738234607 379.5503471674927 567.45005005696305 -422.31215402287955 378.94350534073442 571.15281944998094 -428.112108308948 377.72764218707817 573.05948218876563 -433.86686487687814 376.07730385388425 573.11508230206312 -439.01302916133773 374.19863857565855 571.49855790435311
+6 0 11 -428.49238605924194 374.42297841220153 537.74563586876388 -424.63272150871455 375.83199248143467 538.95804221893115 -421.22961488884823 377.41228964722296 541.42483464177997 -418.70629722504009 379.00936469417877 545.01306706977061 -417.42342905297977 380.4452371491758 549.41787698931898 -417.60456387823871 381.54566156667141 554.18589849334842 -419.2762765276903 382.17284246275676 558.77897907046065 -422.24730274618065 382.25476641933335 562.67055429777065 -426.14399101352598 381.79961029158545 565.44763438817324 -430.49341289131104 380.88793114438693 566.87788410137057 -434.80988886605354 379.65003727606461 566.91949298836835 -438.66952395043973 378.24103367873499 565.70709469963913
+6 0 3 -428.49224274817487 374.42302552956227 537.74565937860541 -430.18852038062693 375.05933410305391 542.40586722184275 -431.88475283399794 375.69565917070571 547.06608926108129 -433.58094010803097 376.33200073242176 551.72632549561706
+6 0 3 -438.66952395216515 378.24103367938221 565.70709470437737 -436.97332933745372 377.60468936372877 561.04683830145723 -435.27713472274229 376.96834504807532 556.3865818985372 -433.58094010803086 376.33200073242188 551.72632549561706
+6 0 14 -405.394762941458 257.9183552158799 599.61233708924169 -401.35127067549183 259.39447764473221 600.88248773709904 -396.9398494021749 260.73256783933437 601.1417617452978 -392.41631751294273 261.83923641237647 600.30980088034983 -388.06400335188425 262.6314146094777 598.38182988249241 -384.17079224917813 263.04473354835022 595.43586650182328 -381.00315675064275 263.0407716739162 591.63164293387956 -378.78032735318317 262.61201781785411 587.20024687359364 -377.65223913818886 261.78361766203585 582.424973727208 -377.68477502386679 260.61140011381343 577.61551756299139 -378.85464946071249 259.17638660360547 573.07914319326824 -381.05441070405971 257.57665975885158 569.09303620387243 -384.10621462490832 255.91786954581059 565.8815064144726 -387.78175805454782 254.30372359077043 563.60049143267202 -391.82522850662997 252.82760912532237 562.33034763703972
+6 0 1 -388.43285051863893 251.55492471135065 553.00986571677925 -391.82522850663003 252.82760912532243 562.33034763703961
+6 0 14 -388.43285051863887 251.55492471135057 553.00986571677913 -394.49805619676209 249.34075301317847 551.10465002333069 -401.11515240854925 247.33362854939449 550.71574110913468 -407.900420424478 245.67363216738548 551.96367354204483 -414.4288775385694 244.48536412249319 554.85561004636349 -420.26870165149717 243.86537699592569 559.27452797738852 -425.02018041987117 243.87130604876509 564.98083693935632 -428.35447023717677 244.51441817905132 571.62790854951697 -430.04665358405862 245.75700174854794 578.7908103594533 -429.99788727857708 247.51531881491405 586.00500119233027 -428.24309928088746 249.66783643907485 592.80958011252699 -424.94345924749683 252.06743194419062 598.78876445149263 -420.36573545775326 254.55562820925465 603.60608299202238 -414.85239056983011 256.9768602039083 607.02762392329635 -408.78715217088074 259.19104384718673 608.93284989508243
+6 0 1 -408.78715217088092 259.1910438471869 608.9328498950822 -405.394762941458 257.9183552158799 599.61233708924169
+6 0 14 -408.78715217088103 259.19104384718685 608.9328498950822 -402.72191377193178 261.40522749046534 610.83807586686817 -396.10478186195638 263.41236278236858 611.22698687916625 -389.31948402810815 265.0723656419317 609.97904558174434 -382.79101278652047 266.26063293758358 607.08708908495817 -376.95119613246135 266.88061134589231 602.66814401395447 -372.19974288465829 266.87466853424127 596.96180866203895 -368.86549878846893 266.23153775014811 590.31471457161012 -367.17336646597749 264.98893751642072 583.15180485203166 -367.22217029449433 263.23061119408715 575.9376206057068 -368.97698194976289 261.07809092877523 569.13305905112213 -372.27662381478365 258.67850066164436 563.15389856702848 -376.8543296960566 256.1903153420829 558.33660388292867 -382.36764484051582 253.76909640952269 554.91508141022769 -388.43285051863904 251.55492471135059 553.00986571677925
+6 0 1 -374.20263638495641 202.33485723634897 564.91009564807439 -388.43285051863904 251.55492471135062 553.00986571677925
+6 0 14 -374.20263638495641 202.33485723634891 564.91009564807428 -380.26784206307963 200.12068553817682 563.00487995462584 -386.88493827486678 198.11356107439283 562.61597104042994 -393.67020629079553 196.45356469238382 563.86390347334009 -400.19866340488693 195.26529664749154 566.75583997765875 -406.0384875178147 194.64530952092403 571.17475790868377 -410.7899662861887 194.65123857376344 576.88106687065158 -414.1242561034943 195.29435070404963 583.52813848081223 -415.81643945037615 196.53693427354625 590.69104029074856 -415.76767314489462 198.29525133991237 597.90523112362553 -414.01288514720494 200.44776896407313 604.70981004382224 -410.71324511381425 202.8473644691889 610.68899438278788 -406.13552132407062 205.33556073425294 615.50631292331775 -400.62217643614736 207.75679272890662 618.92785385459183 -394.55693803719782 209.97097637218508 620.83307982637791
+6 0 1 -394.55693803719817 209.97097637218505 620.83307982637757 -408.7871521708808 259.19104384718679 608.93284989508243
+6 0 14 -394.55693803719839 209.97097637218519 620.83307982637734 -388.49169963824914 212.18516001546365 622.73830579816331 -381.87456772827375 214.19229530736689 623.12721681046139 -375.08926989442551 215.85229816693004 621.87927551303949 -368.56079865283783 217.04056546258192 618.98731901625331 -362.72098199877871 217.66054387089068 614.56837394524962 -357.96952875097566 217.65460105923967 608.86203859333409 -354.63528465478629 217.01147027514654 602.21494450290527 -352.94315233229486 215.76887004141915 595.0520347833268 -352.9919561608117 214.01054371908555 587.83785053700194 -354.74676781608025 211.85802345377363 581.03328898241728 -358.04640968110101 209.45843318664276 575.05412849832362 -362.62411556237396 206.97024786708127 570.23683381422381 -368.13743070683319 204.54902893452106 566.81531134152283 -374.20263638495641 202.33485723634897 564.91009564807439
+6 0 14 -379.1301750852636 205.61691521356025 584.37720235859888 -380.94103560755468 204.83472398732533 583.30742706780245 -383.03657371607449 204.08159897106012 582.69828689571079 -385.30222427720179 203.40702594307197 582.6174617920642 -387.6021372674698 202.85831744742944 583.09819075222163 -389.78945576278153 202.47617327314407 584.13320004146851 -391.71892780091838 202.29047922696739 585.6724078458974 -393.2604444607731 202.31695222930276 587.6252369303154 -394.31168553157124 202.55519780177053 589.86770189523565 -394.80797181229718 202.98856210101084 592.2535784925193 -394.72780371104 203.58584850128298 594.62812653384117 -394.09338873894671 204.30460900140827 596.84233412165736 -392.96644446961028 205.09545026040902 598.76570887920184 -391.44025330005712 205.90671207326301 600.29612754503034 -389.62938300849322 206.68890751935442 601.36590860710339
+6 0 1 -394.55693803719839 209.97097637218519 620.83307982637734 -389.62938300835083 206.68890751911749 601.36590860707906
+6 0 1 -374.20263638495641 202.33485723634897 564.9100956480745 -379.1301750852636 205.6169152135603 584.37720235859911
+6 0 14 -389.62938300835083 206.68890751911749 601.36590860707906 -387.81851271675487 207.47110296515197 602.43568966914427 -385.72296330313998 208.22423204440969 603.04483312745106 -383.45730254570958 208.89880783627078 603.12565746995858 -381.15738360384574 209.44751670452047 602.64492293403032 -378.97006557585479 209.8296584457994 601.60990414051685 -377.04059985347112 210.01534811075041 600.07068576737743 -375.49909626827809 209.98886873044287 598.11784593783182 -374.44787100769156 209.75061705931117 595.87537465415892 -373.95159723386524 209.31724901098281 593.48949750601537 -374.0317741581112 208.71996103085007 591.11495348067228 -374.66619141069776 208.00120174386686 588.90075363736275 -375.79313162691011 207.21036387599986 586.97738805889674 -377.31931456297247 206.39910643979522 585.44697764939542 -379.13017508526355 205.6169152135603 584.37720235859899
+6 0 1 -3.8851285998385532e-14 96.877250000000004 79.430370256358998 -2.6645352591003757e-14 96.877250000000004 0
+6 0 9 4.6179304158400214e-08 96.877250000000004 79.430370314596729 -2.6939936152818289 96.877250000000004 75.897204077415509 -5.2665533547279253 96.877250000000004 72.249970220334731 -7.7779399966721847 96.877250000000004 68.539497120961329 -10.271856569622736 96.877250000000004 64.81140945905085 -12.783366889868061 96.877250000000004 61.113730768509811 -15.342826832401434 96.877250000000004 57.488324295806009 -17.974684798765086 96.877250000000004 53.952129163130806 -20.73123841870563 96.877250000000004 50.507641357526069 -23.712902722072293 96.877250000000004 47.117377925939572
+6 0 10 -23.712902711687523 96.877250000000004 47.117377921124685 -25.384844582615344 96.877250000000004 45.216317705089843 -27.110927635312862 96.877250000000004 44.32641697136917 -28.741075207396225 96.877250000000004 43.639783050868523 -30.385443760346881 96.877250000000004 43.492331663676637 -31.965172234982951 96.877250000000004 43.358767003757052 -33.518252217001013 96.877250000000004 43.706812758662252 -35.098219790034399 96.877250000000004 44.119404186012574 -36.617483128207262 96.877250000000004 44.974097517103118 -38.227498259090986 96.877250000000004 46.151132522751396 -39.605267905408908 96.877250000000004 48.269802002230371
+6 0 10 -39.605267905536735 96.877250000000004 48.269802002301041 -48.699967963835064 96.877250000000004 62.255204779946098 -58.71282799094881 96.877250000000004 74.036014256755692 -69.820613951627621 96.877250000000004 84.701970134129425 -81.726348807798985 96.877250000000004 93.658271994592823 -94.449226952201286 96.877250000000004 101.67675158346211 -107.74769418857389 96.877250000000004 108.26289643145471 -121.63504166034039 96.877250000000004 113.93180975984993 -136.08540287673748 96.877250000000004 118.53586045810573 -151.15492184444059 96.877250000000004 122.19927212781197 -166.9623274146708 96.877250000000004 124.87886611257689
+6 0 10 -166.96232741497784 96.877250000000004 124.87886611232784 -170.05530006623755 96.877250000000004 125.40317169015331 -171.88770981134394 96.877250000000004 126.81457086296859 -173.40167297525826 96.877250000000004 128.062599145174 -174.21726040123542 96.877250000000004 129.71237723222012 -175.16106738916105 96.877250000000004 131.12112936236119 -175.35881622942597 96.877250000000004 132.82514810960129 -175.77616484718143 96.877250000000004 134.58595812772612 -175.45606075077657 96.877250000000004 136.50160463065757 -174.96339060171528 96.877250000000004 138.7763772528601 -172.94088795731412 96.877250000000004 141.17867200059302
+6 0 7 -172.94088795711386 96.877250000000004 141.17867200085126 -153.07869170825805 96.877250000000004 164.77065585249011 -128.44104953965194 96.877250000000004 181.86996805468297 -103.98943401345741 96.877250000000004 194.22504955507284 -79.043773708148549 96.877250000000004 203.92005070759976 -53.757142967739199 96.877250000000004 210.90336858618292 -27.426207545250804 96.877250000000004 215.57732801049252 5.9790431382822362e-05 96.877250000000004 216.92189114572454
+6 0 1 -6.3234140146306572e-14 96.877250000000004 238.10231022490632 -5.9979379068269366e-14 96.877250000000004 216.92188355076667
+6 0 10 -207.14999310678726 96.877250000000004 117.39517952366697 -194.76231526490679 96.877250000000004 139.25385712230045 -179.81179528180479 96.877250000000004 159.66013433928919 -162.49000748472383 96.877250000000004 178.27596904353672 -143.03948908495403 96.877250000000004 194.79219784326392 -121.7486618676236 96.877250000000004 208.93749884479064 -98.944856646029777 96.877250000000004 220.48628267441833 -74.985724705851126 96.877250000000004 229.26501126788364 -50.24951054810623 96.877250000000004 235.15654390434148 -25.124755281485584 96.877250000000004 238.10231022335705 -1.4683287474781537e-08 96.877250000000004 238.1023102249064
+6 0 13 -207.1499931070648 96.877250000000004 117.39517952386814 -187.38211895259266 96.877250000000004 113.353033380893 -168.86546846829523 96.877250000000004 108.88237693347 -151.4392077035381 96.877250000000004 103.66968283443408 -134.73317015917289 96.877250000000004 99.160757343765653 -118.53800238208279 96.877250000000004 90.25988695792843 -102.8672399136582 96.877250000000004 88.360944312248364 -86.822450957495164 96.877250000000004 72.867198025501011 -72.293832925855924 96.877250000000004 70.942702536379969 -56.43617285639759 96.877250000000004 53.05187683665384 -45.348368444248948 96.877250000000004 42.510374563577038 -38.43385774188198 96.877250000000004 25.628344669423072 -33.579139914626552 96.877250000000004 15.434579211907192 -30.478609236961049 96.877250000000004 1.6287565074435406e-08
+6 0 1 -30.478609236858247 96.877250000000004 2.1288733411893723e-14 -19.999741854713879 96.877250000000004 1.5190902725924488e-14
+6 0 1 -30.478609236858247 96.877250000000004 2.1288733411893723e-14 -2.4868995751603507e-14 96.877250000000004 3.5527136788005009e-15
+6 0 1 -2.6645352591003757e-14 96.877250000000004 0 28.951074458388987 96.877250000000004 0
+6 0 1 19.999755667948612 96.877250000000004 0 28.951074458388995 96.877250000000004 0
+6 0 9 28.951074458388991 96.877250000000004 6.1387339655993856e-11 29.25211047033175 96.877250000000004 6.8206223139093254 29.576735787250918 96.877250000000004 12.811526757463181 29.958853157277897 96.877250000000004 18.993072764736574 30.396925497980973 96.877250000000004 25.264956503236299 30.950318207297268 96.877250000000004 31.861971145775762 31.559773384293671 96.877250000000004 38.208585435646022 32.244199014515331 96.877250000000004 44.422145941188973 32.995440554768273 96.877250000000004 50.555987586299885 33.894878791186187 96.877250000000004 56.984042206709773
+6 0 9 33.894878787710368 96.877250000000004 56.984042181716092 36.674568210603098 96.877250000000004 76.849770271176141 40.458083436907074 96.877250000000004 96.608953899692892 45.484575061403419 96.877250000000004 115.97565787536438 51.987876512438973 96.877250000000004 134.31180089009251 60.144682122533453 96.877250000000004 151.64256433349362 70.387538126012856 96.877250000000004 167.56038520600981 83.021366472842118 96.877250000000004 182.22639593183919 99.445035781564172 96.877250000000004 195.1304226863395 121.14729241502182 96.877250000000004 204.97813888088527
+6 0 10 -1.4683248810180502e-08 96.877250000000004 238.10231022490646 12.709756974226821 96.877250000000004 238.10231022569022 25.419513963183373 96.877250000000004 237.34848770987554 38.078973823233838 96.877250000000004 235.84084267745934 50.637839425425398 96.877250000000004 233.58321060668248 63.046154732542334 96.877250000000004 230.58326245402992 75.254645890843378 96.877250000000004 226.85246823962896 87.21505749535082 96.877250000000004 222.40602421804621 98.880479202243237 96.877250000000004 217.26274449326041 110.20565806807716 96.877250000000004 211.44491879536685 121.14729240791053 96.877250000000004 204.97813888529205
+6 0 6 76.240055769969757 96.877250000000004 207.53308363520037 63.859019028947806 96.877250000000004 211.74002413520859 51.290121683984879 96.877250000000004 214.60997217227936 38.631388413705686 96.877250000000004 216.45589707612774 25.852913711313985 96.877250000000004 217.41445965349823 12.964746689092621 96.877250000000004 217.5574850638281 7.772982257847616e-11 96.877250000000004 216.92188355076664
+6 0 10 76.240055770239849 96.877250000000004 207.53308363461534 79.040303028874703 96.877250000000004 206.58159032681527 80.638963764052093 96.877250000000004 205.0174264550476 81.884753795346526 96.877250000000004 203.591508729846 82.53170834278383 96.877250000000004 201.94482427023073 83.217982955444114 96.877250000000004 200.42184031659073 83.266131196368235 96.877250000000004 198.74373291426809 83.427058938279146 96.877250000000004 196.97193320111992 82.901081026572726 96.877250000000004 195.1266695441777 82.157557946166989 96.877250000000004 193.02858053627318 80.044668797467736 96.877250000000004 190.94480195377551
+6 0 7 34.100002901893468 96.877250000000004 106.84266089693415 37.21372380305867 96.877250000000004 120.73529656427537 41.623891000498439 96.877250000000004 133.88906644617038 47.0991766451911 96.877250000000004 146.52749625965183 53.617683033443498 96.877250000000004 158.57587299072381 61.159172735940587 96.877250000000004 170.03247137130685 69.847995950771576 96.877250000000004 180.88861378182841 80.044669468701699 96.877250000000004 190.94480149156587
+6 0 6 26.529913647444488 96.877250000000004 99.271942258781138 28.585405475295232 96.877250000000004 99.732813860772268 30.210616892381267 96.877250000000004 100.63938929240619 31.61678819015572 96.877250000000004 101.75756683761813 32.728569915425261 96.877250000000004 103.15604034862113 33.63875080472441 96.877250000000004 104.78467062108508 34.100002901815841 96.877250000000004 106.84266089672319
+6 0 6 26.529913647060212 96.877250000000004 99.271942259138683 20.589609699605514 96.877250000000004 97.940038449307153 15.48812726621053 96.877250000000004 95.47864700192676 11.079974611979502 96.877250000000004 92.179338887219274 7.116563305871205 96.877250000000004 88.284197860119434 3.4599134931072113 96.877250000000004 83.968038524217874 2.0730972494220623e-11 96.877250000000004 79.430370256358984
+6 0 10 121.14729240795077 96.87725000000006 204.97813888535947 129.86431465906185 96.877250000000004 208.93361516043319 138.47581394105845 96.879423347434496 211.9771044186447 147.15783397992345 95.802316028250615 214.09852138016385 155.61772834237297 94.042147546638944 215.51448660521584 163.48624284683405 91.773683029824838 216.40627104143624 171.6022786654022 88.608414786330911 217.29595935529497 178.73095675033994 84.778062275135014 217.36222025769928 186.64335730872966 79.713989337369156 217.81672879128959 192.67192728650289 72.669871688449845 217.14737062450394 198.52132377028602 63.786359537609528 216.49756803016427
+6 0 10 -265.19488801433613 63.786359537519886 126.30771015045154 -241.59535782512785 63.786359537519886 175.85707445346904 -207.70927250272302 63.786359537519886 220.50714154118339 -164.68086177958861 63.786359537519886 257.8554694230354 -114.29565868354504 63.786359537519886 285.80502953632998 -58.885446641443011 63.786359537519886 302.76391000879471 -1.1583648342019401 63.786359537519886 307.80949930291939 56.029368023305082 63.786359537519886 300.7821914133433 109.91946728635878 63.786359537519886 282.2839052573126 158.0705644941674 63.786359537519886 253.5895552365352 198.5213237703276 63.786359537519886 216.49756803019997
+6 0 10 -265.19488801433613 63.786359537519886 126.30771015045154 -241.6098092391062 63.786359537519886 175.82673239283616 -207.75076962812233 63.786359537519886 220.45245585239479 -164.75989815841393 63.786359537519886 257.7868493163445 -114.41905771008975 63.786359537519886 285.7365475944784 -59.055082846870619 63.786359537519886 302.71194407843404 -1.3704504080269189 63.786359537519886 307.79089398792746 55.784227342199245 63.786359537519886 300.81221905198822 109.65543146496532 63.786359537519886 282.37440572875528 157.80511471069605 63.786359537519886 253.74755908225001 198.27348951964018 63.786359537519886 216.7245628581768
+6 0 10 -265.19488801430748 63.786359537602031 126.30771015043803 -261.77991620415708 72.002397010478276 126.00499279389224 -258.25799398387238 78.748517869363639 125.78030274499888 -253.10938362644785 84.105396405774556 124.93631084721669 -247.98893636789427 88.196187382785354 124.30289716212006 -242.08671457769887 91.586147795003015 123.39080532365139 -236.00573851119512 94.095329679671863 122.52812357152293 -229.2645100857699 95.957376381112198 121.53704866022102 -222.14878861867186 96.877213362390549 120.35667274571082 -214.85968018248153 96.877250000000416 118.97166071900881 -207.14999310685349 96.877250000000288 117.39517952370532
+6 0 11 -30.478609236805365 96.877250000000004 -6.2438942904918804e-11 -28.076611977980306 96.877250000000004 -11.957248868108753 -28.003886675229911 96.877250000000004 -19.635953839736789 -22.195588048808165 96.877250000000004 -23.55452383400802 -20.638138624519264 96.877250000000004 -27.464872195806034 -16.074554254648277 96.877250000000004 -28.700617420730772 -13.336522741542552 96.877250000000004 -30.478407113468904 -10.224501796632357 96.877250000000004 -31.163169199249054 -7.6917354720439928 96.877250000000004 -31.785941365945508 -5.2241169141322672 96.877250000000004 -32.103021484448604 -2.8468046540065579 96.877250000000004 -32.252197997488345 -0.46941580927526516 96.877250000000004 -32.226526045191427
+6 0 11 -0.46941580927518523 96.877250000000004 -32.226526045192863 1.9079730354561044 96.877250000000004 -32.200854092896549 4.2854384647928949 96.877250000000004 -32.000333675263754 6.7602642610310655 96.877250000000004 -31.63660569463395 9.2547633887382741 96.877250000000004 -30.991386148143381 12.525330884940166 96.877250000000004 -30.251520879000253 15.048515188185057 96.877250000000004 -28.536205960369969 20.256907031197414 96.877250000000004 -27.128329244699792 21.56486374022618 96.877250000000004 -23.636113241952163 27.986740154356699 96.877250000000004 -19.35128942757094 28.403726757726879 96.877250000000004 -12.401365991895327 28.951075308923613 96.877250000000004 -5.7034876377315413e-08
+6 0 11 19.999755667948524 96.877250000000004 3.3400030009745826e-08 19.999605948645446 96.877250000000004 -7.9206011328033377 16.553214075619124 96.877250000000004 -13.770413487173597 12.61204779347819 96.877250000000004 -17.776470029345006 7.4223592786046027 96.877250000000004 -20.358032507270437 2.879428058859407 96.877250000000004 -21.575937535748949 -2.7843798367163579 96.877250000000004 -21.587061263833366 -7.3132359998255492 96.877250000000004 -20.3975123970467 -12.556242469963417 96.877250000000004 -17.833733931181364 -16.489854276156933 96.877250000000004 -13.837661165912159 -19.999579302188486 96.877250000000004 -7.9933727969212427 -19.999741854722821 96.877250000000004 4.9775934485296602e-09
+6 0 6 198.27348951408203 63.786359537462104 216.72456286329256 204.84358046463674 54.155122885073737 215.81914638814374 209.72711260499253 44.049699141940962 215.27770225926895 213.09421067827307 33.543722873111804 214.99509920939079 215.01496885942277 22.664591551431513 215.00701221836582 215.43795393152669 11.403558038038337 215.43805015498876 215.43795393152882 6.844302902209165e-11 215.43805015499092
+6 0 10 -276.45164444452996 0 128.06875179941898 -251.83207226106589 0 181.21296309859423 -215.86104172750117 0 229.09851816738149 -169.80217487580049 0 268.99770533705623 -115.66824823027977 0 298.52983408355516 -56.110080343579845 0 315.90126027503334 5.7871257207104492 0 320.1026915847969 66.779673783687116 0 311.01929663070388 123.76138981780559 0 289.4221565942666 174.02273467875244 0 256.85317781177861 215.43795393152877 0 215.43805015499066
+6 0 6 -276.45164444453007 6.6073368998331716e-11 128.06875179941895 -276.45164444452752 11.005704289110191 128.06875179941775 -275.94198263112582 21.871546292096145 127.83186506690305 -274.68126380763914 32.582429357496224 127.53803629996249 -272.54529726615749 43.143650189515384 127.17532762906038 -269.43655528572924 53.5506623711576 126.71169982832225 -265.19315993829264 63.786359537458452 126.31133833971272
+6 0 10 -265.19488801433613 -63.786359537519886 126.30771015045154 -241.6098092391062 -63.786359537519886 175.82673239283616 -207.75076962812233 -63.786359537519886 220.45245585239479 -164.75989815841393 -63.786359537519886 257.7868493163445 -114.41905771008975 -63.786359537519886 285.7365475944784 -59.055082846870619 -63.786359537519886 302.71194407843404 -1.3704504080269189 -63.786359537519886 307.79089398792746 55.784227342199245 -63.786359537519886 300.81221905198822 109.65543146496532 -63.786359537519886 282.37440572875528 157.80511471069605 -63.786359537519886 253.74755908225001 198.27348951964018 -63.786359537519886 216.7245628581768
+6 0 6 -276.45164444453007 -6.6073368998331716e-11 128.06875179941895 -276.45164444452752 -11.005704289110191 128.06875179941775 -275.94198263112582 -21.871546292096145 127.83186506690305 -274.68126380763914 -32.582429357496224 127.53803629996249 -272.54529726615749 -43.143650189515384 127.17532762906038 -269.43655528572924 -53.5506623711576 126.71169982832225 -265.19315993829264 -63.786359537458452 126.31133833971272
+6 0 6 198.27348951408203 -63.786359537462104 216.72456286329256 204.84358046463674 -54.155122885073737 215.81914638814374 209.72711260499253 -44.049699141940962 215.27770225926895 213.09421067827307 -33.543722873111804 214.99509920939079 215.01496885942277 -22.664591551431513 215.00701221836582 215.43795393152669 -11.403558038038337 215.43805015498876 215.43795393152882 -6.844302902209165e-11 215.43805015499092
+6 0 10 -1.4683248810180502e-08 -96.877250000000004 238.10231022490646 12.709756974226821 -96.877250000000004 238.10231022569022 25.419513963183373 -96.877250000000004 237.34848770987554 38.078973823233838 -96.877250000000004 235.84084267745934 50.637839425425398 -96.877250000000004 233.58321060668248 63.046154732542334 -96.877250000000004 230.58326245402992 75.254645890843378 -96.877250000000004 226.85246823962896 87.21505749535082 -96.877250000000004 222.40602421804621 98.880479202243237 -96.877250000000004 217.26274449326041 110.20565806807716 -96.877250000000004 211.44491879536685 121.14729240791053 -96.877250000000004 204.97813888529205
+6 0 10 -207.14999310678726 -96.877250000000004 117.39517952366697 -194.76231526490679 -96.877250000000004 139.25385712230045 -179.81179528180479 -96.877250000000004 159.66013433928919 -162.49000748472383 -96.877250000000004 178.27596904353672 -143.03948908495403 -96.877250000000004 194.79219784326392 -121.7486618676236 -96.877250000000004 208.93749884479064 -98.944856646029777 -96.877250000000004 220.48628267441833 -74.985724705851126 -96.877250000000004 229.26501126788364 -50.24951054810623 -96.877250000000004 235.15654390434148 -25.124755281485584 -96.877250000000004 238.10231022335705 -1.4683287474781537e-08 -96.877250000000004 238.1023102249064
+6 0 10 -265.19488801430748 -63.786359537602031 126.30771015043803 -261.77991620415708 -72.002397010478276 126.00499279389224 -258.25799398387238 -78.748517869363639 125.78030274499888 -253.10938362644785 -84.105396405774556 124.93631084721669 -247.98893636789427 -88.196187382785354 124.30289716212006 -242.08671457769887 -91.586147795003015 123.39080532365139 -236.00573851119512 -94.095329679671863 122.52812357152293 -229.2645100857699 -95.957376381112198 121.53704866022102 -222.14878861867186 -96.877213362390549 120.35667274571082 -214.85968018248153 -96.877250000000416 118.97166071900881 -207.14999310685349 -96.877250000000288 117.39517952370532
+6 0 10 -265.19488801433613 -63.786359537519886 126.30771015045154 -241.59535782512785 -63.786359537519886 175.85707445346904 -207.70927250272302 -63.786359537519886 220.50714154118339 -164.68086177958861 -63.786359537519886 257.8554694230354 -114.29565868354504 -63.786359537519886 285.80502953632998 -58.885446641443011 -63.786359537519886 302.76391000879471 -1.1583648342019401 -63.786359537519886 307.80949930291939 56.029368023305082 -63.786359537519886 300.7821914133433 109.91946728635878 -63.786359537519886 282.2839052573126 158.0705644941674 -63.786359537519886 253.5895552365352 198.5213237703276 -63.786359537519886 216.49756803019997
+6 0 10 121.14729240795077 -96.87725000000006 204.97813888535947 129.86431465906185 -96.877250000000004 208.93361516043319 138.47581394105845 -96.879423347434496 211.9771044186447 147.15783397992345 -95.802316028250615 214.09852138016385 155.61772834237297 -94.042147546638944 215.51448660521584 163.48624284683405 -91.773683029824838 216.40627104143624 171.6022786654022 -88.608414786330911 217.29595935529497 178.73095675033994 -84.778062275135014 217.36222025769928 186.64335730872966 -79.713989337369156 217.81672879128959 192.67192728650289 -72.669871688449845 217.14737062450394 198.52132377028602 -63.786359537609528 216.49756803016427
+6 0 1 -2.6645352591003757e-14 -96.877250000000004 0 -3.8851286040423488e-14 -96.877250000000004 79.430370529921902
+6 0 6 26.529913647060212 -96.877250000000004 99.271942259138683 20.589609699605514 -96.877250000000004 97.940038449307153 15.48812726621053 -96.877250000000004 95.47864700192676 11.079974611979502 -96.877250000000004 92.179338887219274 7.116563305871205 -96.877250000000004 88.284197860119434 3.4599134931072113 -96.877250000000004 83.968038524217874 2.0730972494220623e-11 -96.877250000000004 79.430370256358984
+6 0 6 26.529913647444488 -96.877250000000004 99.271942258781138 28.585405475295232 -96.877250000000004 99.732813860772268 30.210616892381267 -96.877250000000004 100.63938929240619 31.61678819015572 -96.877250000000004 101.75756683761813 32.728569915425261 -96.877250000000004 103.15604034862113 33.63875080472441 -96.877250000000004 104.78467062108508 34.100002901815841 -96.877250000000004 106.84266089672319
+6 0 7 34.100002901893468 -96.877250000000004 106.84266089693415 37.21372380305867 -96.877250000000004 120.73529656427537 41.623891000498439 -96.877250000000004 133.88906644617038 47.0991766451911 -96.877250000000004 146.52749625965183 53.617683033443498 -96.877250000000004 158.57587299072381 61.159172735940587 -96.877250000000004 170.03247137130685 69.847995950771576 -96.877250000000004 180.88861378182841 80.044669468701699 -96.877250000000004 190.94480149156587
+6 0 10 76.240055770239849 -96.877250000000004 207.53308363461534 79.040303028874703 -96.877250000000004 206.58159032681527 80.638963764052093 -96.877250000000004 205.0174264550476 81.884753795346526 -96.877250000000004 203.591508729846 82.53170834278383 -96.877250000000004 201.94482427023073 83.217982955444114 -96.877250000000004 200.42184031659073 83.266131196368235 -96.877250000000004 198.74373291426809 83.427058938279146 -96.877250000000004 196.97193320111992 82.901081026572726 -96.877250000000004 195.1266695441777 82.157557946166989 -96.877250000000004 193.02858053627318 80.044668797467736 -96.877250000000004 190.94480195377551
+6 0 6 76.240055769969757 -96.877250000000004 207.53308363520037 63.859019028947806 -96.877250000000004 211.74002413520859 51.290121683984879 -96.877250000000004 214.60997217227936 38.631388413705686 -96.877250000000004 216.45589707612774 25.852913711313985 -96.877250000000004 217.41445965349823 12.964746689092621 -96.877250000000004 217.5574850638281 7.772982257847616e-11 -96.877250000000004 216.92188355076664
+6 0 1 -6.3234140146306572e-14 -96.877250000000004 238.10231022490632 -5.9979379068269366e-14 -96.877250000000004 216.92188355076667
+6 0 9 33.894878787710368 -96.877250000000004 56.984042181716092 36.674568210603098 -96.877250000000004 76.849770271176141 40.458083436907074 -96.877250000000004 96.608953899692892 45.484575061403419 -96.877250000000004 115.97565787536438 51.987876512438973 -96.877250000000004 134.31180089009251 60.144682122533453 -96.877250000000004 151.64256433349362 70.387538126012856 -96.877250000000004 167.56038520600981 83.021366472842118 -96.877250000000004 182.22639593183919 99.445035781564172 -96.877250000000004 195.1304226863395 121.14729241502182 -96.877250000000004 204.97813888088527
+6 0 9 28.951074458388991 -96.877250000000004 6.1387339655993856e-11 29.25211047033175 -96.877250000000004 6.8206223139093254 29.576735787250918 -96.877250000000004 12.811526757463181 29.958853157277897 -96.877250000000004 18.993072764736574 30.396925497980973 -96.877250000000004 25.264956503236299 30.950318207297268 -96.877250000000004 31.861971145775762 31.559773384293671 -96.877250000000004 38.208585435646022 32.244199014515331 -96.877250000000004 44.422145941188973 32.995440554768273 -96.877250000000004 50.555987586299885 33.894878791186187 -96.877250000000004 56.984042206709773
+6 0 1 19.999755667948612 -96.877250000000004 0 28.951074458388995 -96.877250000000004 0
+6 0 1 -2.6645352591003757e-14 -96.877250000000004 0 28.951074458388987 -96.877250000000004 0
+6 0 1 -30.478609236858247 -96.877250000000004 2.1288733411893723e-14 -2.4868995751603507e-14 -96.877250000000004 3.5527136788005009e-15
+6 0 1 -30.478609236858247 -96.877250000000004 2.1288733411893723e-14 -19.999741854713879 -96.877250000000004 1.5190902725924488e-14
+6 0 13 -207.1499931070648 -96.877250000000004 117.39517952386814 -187.38211895259266 -96.877250000000004 113.353033380893 -168.86546846829523 -96.877250000000004 108.88237693347 -151.4392077035381 -96.877250000000004 103.66968283443408 -134.73317015917289 -96.877250000000004 99.160757343765653 -118.53800238208279 -96.877250000000004 90.25988695792843 -102.8672399136582 -96.877250000000004 88.360944312248364 -86.822450957495164 -96.877250000000004 72.867198025501011 -72.293832925855924 -96.877250000000004 70.942702536379969 -56.43617285639759 -96.877250000000004 53.05187683665384 -45.348368444248948 -96.877250000000004 42.510374563577038 -38.43385774188198 -96.877250000000004 25.628344669423072 -33.579139914626552 -96.877250000000004 15.434579211907192 -30.478609236961049 -96.877250000000004 1.6287565074435406e-08
+6 0 7 -172.94088795711386 -96.877250000000004 141.17867200085126 -153.07869170825805 -96.877250000000004 164.77065585249011 -128.44104953965194 -96.877250000000004 181.86996805468297 -103.98943401345741 -96.877250000000004 194.22504955507284 -79.043773708148549 -96.877250000000004 203.92005070759976 -53.757142967739199 -96.877250000000004 210.90336858618292 -27.426207545250804 -96.877250000000004 215.57732801049252 5.9790431382822362e-05 -96.877250000000004 216.92189114572454
+6 0 10 -166.96232741497784 -96.877250000000004 124.87886611232784 -170.05530006623755 -96.877250000000004 125.40317169015331 -171.88770981134394 -96.877250000000004 126.81457086296859 -173.40167297525826 -96.877250000000004 128.062599145174 -174.21726040123542 -96.877250000000004 129.71237723222012 -175.16106738916105 -96.877250000000004 131.12112936236119 -175.35881622942597 -96.877250000000004 132.82514810960129 -175.77616484718143 -96.877250000000004 134.58595812772612 -175.45606075077657 -96.877250000000004 136.50160463065757 -174.96339060171528 -96.877250000000004 138.7763772528601 -172.94088795731412 -96.877250000000004 141.17867200059302
+6 0 10 -39.605267905536735 -96.877250000000004 48.269802002301041 -48.699967963835064 -96.877250000000004 62.255204779946098 -58.71282799094881 -96.877250000000004 74.036014256755692 -69.820613951627621 -96.877250000000004 84.701970134129425 -81.726348807798985 -96.877250000000004 93.658271994592823 -94.449226952201286 -96.877250000000004 101.67675158346211 -107.74769418857389 -96.877250000000004 108.26289643145471 -121.63504166034039 -96.877250000000004 113.93180975984993 -136.08540287673748 -96.877250000000004 118.53586045810573 -151.15492184444059 -96.877250000000004 122.19927212781197 -166.9623274146708 -96.877250000000004 124.87886611257689
+6 0 10 -23.712902711687523 -96.877250000000004 47.117377921124685 -25.384844582615344 -96.877250000000004 45.216317705089843 -27.110927635312862 -96.877250000000004 44.32641697136917 -28.741075207396225 -96.877250000000004 43.639783050868523 -30.385443760346881 -96.877250000000004 43.492331663676637 -31.965172234982951 -96.877250000000004 43.358767003757052 -33.518252217001013 -96.877250000000004 43.706812758662252 -35.098219790034399 -96.877250000000004 44.119404186012574 -36.617483128207262 -96.877250000000004 44.974097517103118 -38.227498259090986 -96.877250000000004 46.151132522751396 -39.605267905408908 -96.877250000000004 48.269802002230371
+6 0 9 4.6179304158400214e-08 -96.877250000000004 79.430370314596729 -2.6939936152818289 -96.877250000000004 75.897204077415509 -5.2665533547279253 -96.877250000000004 72.249970220334731 -7.7779399966721847 -96.877250000000004 68.539497120961329 -10.271856569622736 -96.877250000000004 64.81140945905085 -12.783366889868061 -96.877250000000004 61.113730768509811 -15.342826832401434 -96.877250000000004 57.488324295806009 -17.974684798765086 -96.877250000000004 53.952129163130806 -20.73123841870563 -96.877250000000004 50.507641357526069 -23.712902722072293 -96.877250000000004 47.117377925939572
+6 0 11 19.999755667948524 -96.877250000000004 3.3400030009745826e-08 19.999605948645446 -96.877250000000004 -7.9206011328033377 16.553214075619124 -96.877250000000004 -13.770413487173597 12.61204779347819 -96.877250000000004 -17.776470029345006 7.4223592786046027 -96.877250000000004 -20.358032507270437 2.879428058859407 -96.877250000000004 -21.575937535748949 -2.7843798367163579 -96.877250000000004 -21.587061263833366 -7.3132359998255492 -96.877250000000004 -20.3975123970467 -12.556242469963417 -96.877250000000004 -17.833733931181364 -16.489854276156933 -96.877250000000004 -13.837661165912159 -19.999579302188486 -96.877250000000004 -7.9933727969212427 -19.999741854722821 -96.877250000000004 4.9775934485296602e-09
+6 0 11 -0.46941580927518523 -96.877250000000004 -32.226526045192863 1.9079730354561044 -96.877250000000004 -32.200854092896549 4.2854384647928949 -96.877250000000004 -32.000333675263754 6.7602642610310655 -96.877250000000004 -31.63660569463395 9.2547633887382741 -96.877250000000004 -30.991386148143381 12.525330884940166 -96.877250000000004 -30.251520879000253 15.048515188185057 -96.877250000000004 -28.536205960369969 20.256907031197414 -96.877250000000004 -27.128329244699792 21.56486374022618 -96.877250000000004 -23.636113241952163 27.986740154356699 -96.877250000000004 -19.35128942757094 28.403726757726879 -96.877250000000004 -12.401365991895327 28.951075308923613 -96.877250000000004 -5.7034876377315413e-08
+6 0 11 -30.478609236805365 -96.877250000000004 -6.2438942904918804e-11 -28.076611977980306 -96.877250000000004 -11.957248868108753 -28.003886675229911 -96.877250000000004 -19.635953839736789 -22.195588048808165 -96.877250000000004 -23.55452383400802 -20.638138624519264 -96.877250000000004 -27.464872195806034 -16.074554254648277 -96.877250000000004 -28.700617420730772 -13.336522741542552 -96.877250000000004 -30.478407113468904 -10.224501796632357 -96.877250000000004 -31.163169199249054 -7.6917354720439928 -96.877250000000004 -31.785941365945508 -5.2241169141322672 -96.877250000000004 -32.103021484448604 -2.8468046540065579 -96.877250000000004 -32.252197997488345 -0.46941580927526516 -96.877250000000004 -32.226526045191427
+6 0 1 -36.580711403588857 -161.76571710853617 59.141833312423458 -317.95612366386723 -137.00035321456423 508.88103729930583
+6 0 14 -317.72805508480741 -87.068959206329524 506.27420151203739 -322.48589798846109 -87.202252645703737 503.30483852096188 -327.24992482173332 -88.689403015197641 500.40615816886287 -331.71912258935743 -91.521977279453012 497.76602223808106 -335.59201592531701 -95.590314885566528 495.56700758910324 -338.59367508541732 -100.68428440602507 493.96955051080045 -340.50277464448328 -106.50514102111522 493.09567062719964 -341.1749877967423 -112.68838076031103 493.01559295031586 -340.5590574499787 -118.83552598660333 493.73944344143723 -338.70262638700586 -124.55087458631543 495.21562505434571 -335.74672740253936 -129.47792015590642 497.33627044917085 -331.91001763609313 -133.33024965576476 499.94880705648558 -327.46557423957302 -135.91308902881119 502.8716610978131 -322.71394089984881 -137.13364593484522 505.91169032738787 -317.95612366386717 -137.00035321456429 508.88103729930577
+6 0 1 -317.72805508480758 -87.068959206329964 506.27420151203728 -37.628079805108143 -111.72206502951265 58.573604977644095
+6 0 11 -52.582146625490694 -128.32696533203122 39.472133636474616 -53.269901568714559 -126.03846911203719 42.104708609174679 -53.609298302996905 -123.90909924182573 44.554232305457148 -53.641518609584693 -121.90258870935652 46.862424759579426 -53.358173288766622 -120.03634683800523 49.009258928747066 -52.762996663296626 -118.29030516404177 51.017820468254271 -51.83966434383413 -116.64408712257713 52.911549758175269 -50.521576782152664 -115.11348445146311 54.672281034504444 -48.695474889232059 -113.73898516288062 56.253438803893751 -46.206777746712859 -112.56085987260404 57.608697047386698 -42.770556191555293 -111.69707521718013 58.602352044798778 -37.628079805108463 -111.72206502951197 58.573604977645068
+6 0 2 -52.582146643129917 -128.32696534470011 39.472133654881254 -28.314642164420341 -131.00941971279468 0.30801392338103994 -4.024043062844548 -133.69089831808577 -38.841853031216033
+6 0 14 -3.3360746421511216 -152.47187100095445 -37.377237505308138 -3.8237787305474749 -151.23538315415882 -37.750453824726023 -4.2481750497060888 -149.96257353763721 -38.086062286803319 -4.6073948203716482 -148.65817993132373 -38.382632815238459 -4.8998559396265868 -147.32710459710177 -38.638905632909299 -5.124273138474849 -145.97438853399706 -38.853799034541801 -5.2796662354343438 -144.60518464068787 -39.02641602833291 -5.3653664016257299 -143.22472999906026 -39.156049781884015 -5.3810203731689441 -141.83831750422428 -39.242187819873195 -5.3265925682478734 -140.45126707505244 -39.284514933900368 -5.2023650885746537 -139.06889668467014 -39.282914778640034 -5.0089356077335978 -137.6964934522706 -39.237470142561783 -4.7472131715425636 -136.33928503610272 -39.148461895738308 -4.4184119576692034 -135.00241156255356 -39.016366631358409 -4.0240430628445365 -133.69089831808566 -38.841853031216047
+6 0 2 -53.718859973047316 -147.14730833922454 42.338142407021046 -28.536989646899976 -149.80998995184265 2.4744607648094004 -3.3360746421511323 -152.47187100095445 -37.37723750530813
+6 0 8 -53.718859960515061 -147.14730834960818 42.338142395020974 -54.25174126502872 -150.28789228221973 45.94820711369583 -53.968945734940938 -153.07839015925794 49.155854356240852 -52.990209822453565 -155.56461266881541 52.013736247443241 -51.324210287709285 -157.71678747572315 54.487634050211476 -48.947141428710026 -159.50102766241886 56.538598382195765 -45.813662476278651 -160.88006185769356 58.123784136419957 -41.800215154063935 -161.74322605331619 59.115980105924919 -36.580711403588829 -161.76571710853622 59.141833312423387
+6 0 14 -317.95612366386729 -137.00035321456423 508.88103729930594 -313.19830642788571 -136.86706049428329 511.85038427122379 -308.43430529564671 -135.37991814768739 514.74904898548482 -303.96512631409701 -132.54735901547397 517.38917399618481 -300.09223789026015 -128.47904111923836 519.58818665728108 -297.09056661634952 -123.38509112549288 521.1856523897427 -295.18144239742185 -117.56424853935842 522.05954847409021 -294.50919132913396 -111.38101424185739 522.13965017245948 -295.12508370044583 -105.23386144773112 521.41582302361758 -296.9814899690702 -99.518497433577977 519.93965607426458 -299.9373766582209 -94.591431653439642 517.81901725898149 -303.77409115796888 -90.739082713925029 515.20647661985254 -308.21855320711882 -88.156229257701469 512.28361013316476 -312.9702121811539 -86.935665766955864 509.24356450311274 -317.72805508480752 -87.068959206329993 506.27420151203722
+6 0 8 0.83290000390049812 -147.14730817897004 42.338142147271491 -2.7743736677558748 -150.16439255472346 45.806245561121514 -6.712897372829822 -152.87026691110825 48.916616352546548 -10.890638376563537 -155.29679274776197 51.705881345443231 -15.366241928180244 -157.39845160727168 54.121713348555694 -20.094137583570514 -159.31083655259528 56.319974670899462 -25.137136337149428 -160.67317602423276 57.885970903497203 -30.511671135611437 -161.79186885136943 59.171894436774814 -36.580711403588857 -161.76571710853617 59.141833312423444
+6 0 2 0.8328997750186744 -147.14730834336387 42.338142385954562 18.083069816065425 -149.00456678056571 14.532655028233378 35.323945228076511 -150.8622084965489 -13.278570866444518
+6 0 14 35.323945228076532 -150.86220849654893 -13.278570866444529 35.799530731295462 -149.58270097014659 -13.051482374644317 36.21115882744671 -148.27201426148591 -12.866125191586898 36.556998717114681 -146.9350737361375 -12.723373520513109 36.835510563296644 -145.57694660947175 -12.623911715457808 37.045455488775559 -144.20281505813094 -12.568229507125865 37.185903632028129 -142.81794838475989 -12.556618495562002 37.256240178098253 -141.42767446026957 -12.589169949549293 37.256169301689845 -140.03735067808458 -12.665773939082515 37.185715981774898 -138.65233466179441 -12.786119813088551 37.045225669856904 -137.27795497118072 -12.949698020077996 36.835361817219358 -135.91948205161739 -13.155803254902525 36.557101289543276 -134.58209966833417 -13.403538900561886 36.211727719718802 -133.27087706010414 -13.691822720345957 35.800822871059587 -131.99074203677043 -14.019393742777458
+6 0 2 1.9786697182190593 -128.32696533498142 39.472133633061794 18.895118456674822 -130.15862210512128 12.729750856423649 35.800822871059552 -131.99074203677037 -14.019393742777453
+6 0 11 1.9786697146595955 -128.32696533203264 39.472133636473053 -0.83085623189387237 -125.99198095556739 42.158186327940548 -3.7873049551784423 -123.79374446125742 44.686930399067464 -6.8764340889687343 -121.73494652163259 47.055275143561566 -10.108198423162015 -119.78157058502053 49.302331980697382 -13.468408246969798 -118.02160233640217 51.326940128540322 -16.978061864498162 -116.30984241869248 53.296026556088904 -20.652516478539859 -114.89017245146843 54.929188398155866 -24.480912301400163 -113.52574235883753 56.498729076248502 -28.554615266253833 -112.53016055507113 57.644017657921673 -32.846499359622968 -111.74530107164554 58.546875362602897 -37.628079805108122 -111.72206502951259 58.573604977644194
+6 0 1 -52.582146643129917 -128.32696534470011 39.472133654881254 1.9786697182190593 -128.32696533498142 39.472133633061794
+6 0 1 -4.024043062844548 -133.69089831808577 -38.84185303121604 35.800822871059559 -131.99074203677037 -14.019393742777456
+6 0 1 -53.718859973047316 -147.14730833922454 42.338142407021046 0.8328997750186744 -147.14730834336387 42.338142385954562
+6 0 1 -3.3360746421511323 -152.47187100095445 -37.377237505308138 35.323945228076511 -150.86220849654893 -13.278570866444525
+6 0 8 -321.26229099653301 85.808423460865313 516.97454777311566 -321.26229099653256 91.722950801222765 516.97454777311577 -321.19759221459492 97.184776577843223 516.87763498559889 -321.20728569240822 102.39124429323917 516.89215491825519 -322.59879960126943 105.98965022602982 518.97651396993058 -322.70019967049734 107.14533148570506 519.12840188912617 -324.09641914018334 110.36356468426878 521.21980943543929 -326.15851166810626 112.75344085099135 524.30863319683419 -328.7536245490536 115.88319926304489 528.19587211634337
+6 0 14 -321.26229099653318 85.808423460865313 516.97454777311577 -319.15362568646634 85.808423460865313 517.74203918000978 -316.85948765596942 85.808423460865313 517.99994847559719 -314.5132851898158 85.808423460865313 517.69971901521603 -312.26229431806564 85.808423460865313 516.83089547123802 -310.25568893429715 85.808423460865313 515.42548051374024 -308.63105014539462 85.808423460865313 513.55811321421788 -307.50100137752435 85.808423460865313 511.34146988638207 -306.9418557989701 85.808423460865313 508.91703756367775 -306.98609372822608 85.808423460865313 506.44225508928741 -307.61986744180086 85.808423460865313 504.07582920228651 -308.78575802578928 85.808423460865313 501.96337085825127 -310.39006331502873 85.808423460865313 500.22528039123989 -312.31324552940134 85.808423460865313 498.94821376261189 -314.42189946361344 85.808423460865313 498.18072649619035
+6 0 8 -314.4218994636135 85.808423460865313 498.1807264961904 -314.42189946361395 91.14389707992072 498.18072649619023 -314.27383490273894 98.272446118137168 497.95893948729389 -314.72191688045143 105.39021916981103 498.63012482017041 -315.00288677461333 112.79665198252397 499.05099171804756 -317.99369875503191 120.82638625544614 503.53095126684582 -320.97532043699891 125.02738694612012 507.99714459912758 -324.10345190468269 128.8970251517419 512.6827960310228 -326.6985647856261 132.02678356379579 516.5700349505305
+6 0 14 -328.75362454904928 115.8831992630459 528.19587211634348 -326.77611274795356 116.3256529591324 529.15981934149738 -324.74287935210202 117.20582933283808 529.80853963321579 -322.77903499723379 118.49573580117465 530.08104723652559 -321.01385660770035 120.13465137459708 529.93992582925353 -319.56956201027367 122.03163825446057 529.37680038816882 -318.54962766328288 124.07164250187061 528.41522437759568 -318.02819361615269 126.12483829355516 527.11022957450018 -318.04215349383776 128.05824159591219 525.54425618467508 -318.58729477946281 129.74806707710832 523.81978057981951 -319.6191528180957 131.09102680695364 522.04964816928953 -321.0583330174972 132.01298460579707 520.34655237635263 -322.79928381419541 132.47396586587203 518.81314423305446 -324.72106365283679 132.46923487292767 517.53397697537014 -326.69856478562644 132.02678356379604 516.57003495053107
+6 0 14 -314.42189946361344 85.808423460865313 498.1807264961904 -316.53055339782554 85.808423460865313 497.41323922976886 -318.82467905187718 85.808423460865313 497.15533132555379 -321.17087122047468 85.808423460865313 497.45555830736822 -323.42185727314859 85.808423460865313 498.3243752614988 -325.42846534403304 85.808423460865313 499.72978077185786 -327.05311307512221 85.808423460865313 501.59713854148885 -328.18317776933407 85.808423460865313 503.81377329992017 -328.74234105648077 85.808423460865313 506.23820194991407 -328.69811610303321 85.808423460865313 508.71298597669795 -328.0643505204124 85.808423460865313 511.07941737338206 -326.89846048066966 85.808423460865313 513.1918838631758 -325.29414889623655 85.808423460865313 514.92998284802093 -323.37095630659985 85.808423460865313 516.20705636622154 -321.26229099653307 85.808423460865313 516.97454777311555
+6 0 14 -326.69856478562627 132.02678356379602 516.57003495053095 -328.67606591841593 131.58433225466439 515.60609292569188 -330.7092883453538 130.70416062934552 514.95737613369806 -332.67312431864497 129.41426062467147 514.68486892178089 -334.43829989805306 127.77535182855718 514.82598674842802 -335.88259875034032 125.87837023756764 515.38910509071036 -336.90254276879671 123.83836845042087 516.35067266378439 -337.42399231967016 121.78517123307734 517.65565826446232 -337.41004848117029 119.85176229888145 519.22162548095935 -336.86491807883237 118.16192975844758 520.94609950380516 -335.833065930553 116.8189624698114 522.71623406780634 -334.39388453232965 115.89699879063221 524.41933539554805 -332.65292655648466 115.43601454849205 525.95275073260007 -330.73113635014477 115.44074556695935 527.23192489118958 -328.75362454904905 115.88319926304581 528.19587211634359
+6 0 1 -328.75362454904905 115.88319926304581 528.19587211634359 -371.07764211713874 166.92681705260793 591.59333337082262
+6 0 1 -326.69856478562627 132.02678356379602 516.57003495053095 -369.02258235371596 183.07040135335814 579.96749620500998
+6 0 14 -371.07764211713879 166.92681705260799 591.59333337082239 -369.10013031604308 167.36927074869448 592.55728059597629 -367.06689692019154 168.24944712240014 593.2060008876947 -365.10305256532331 169.53935359073671 593.4785084910045 -363.33787417578986 171.17826916415916 593.33738708373244 -361.89357957836319 173.07525604402264 592.77426164264773 -360.87364523137239 175.11526029143269 591.8126856320747 -360.35221118424221 177.16845608311723 590.50769082897921 -360.36617106192728 179.10185938547426 588.9417174391541 -360.91131234755233 180.79168486667038 587.21724183429853 -361.94317038618522 182.13464459651573 585.44710942376855 -363.38235058558672 183.05660239535916 583.74401363083166 -365.12330138228492 183.51758365543412 582.21060548753348 -367.04508122092631 183.51285266248976 580.93143822984916 -369.02258235371596 183.07040135335814 579.96749620501009
+6 0 14 -369.0225823537159 183.07040135335816 579.96749620500987 -371.00008348650556 182.62795004422657 579.0035541801708 -373.03330591344343 181.7477784189077 578.35483738817697 -374.9971418867346 180.45787841423365 578.0823301762598 -376.76231746614269 178.81896961811935 578.22344800290693 -378.20661631842995 176.9219880271298 578.78656634518927 -379.22656033688634 174.88198623998304 579.74813391826331 -379.74800988775979 172.82878902263951 581.05311951894123 -379.73406604925987 170.89538008844363 582.61908673543826 -379.18893564692189 169.20554754800975 584.34356075828407 -378.15708349864252 167.86258025937357 586.11369532228514 -376.71790210041917 166.94061658019439 587.81679665002673 -374.97694412457417 166.47963233805424 589.35021198707875 -373.05515391823428 166.48436335652156 590.62938614566826 -371.07764211713857 166.92681705260802 591.59333337082217
+6 0 10 -371.07764211713862 166.92681705260802 591.59333337082217 -372.23328097527201 168.32054079545514 593.32437342662058 -374.07571901394812 170.6024385450184 596.02213243089079 -376.56936080670755 173.50446051539095 599.86654191395542 -379.05498308634469 179.80592586821822 600.16671945162705 -380.26084016129147 180.82722208841588 602.42160893953951 -383.3293070640396 189.49227265742684 601.87420378389572 -384.71137271901256 191.76340251892566 603.31825677979703 -387.11226448155162 199.16981245612573 602.24079460149153 -388.37407264473012 202.34698685523037 602.41568072010216 -389.62938300838272 206.68890751919167 601.36590860675108
+6 0 10 -369.02258235371596 183.07040135335814 579.96749620500998 -370.17822121184929 184.46412509620521 581.6985362608084 -370.64706316530084 184.9696777754971 582.46286057157204 -370.72924976885218 185.844539942745 581.78221265205423 -371.22379113115181 184.89741542114248 584.12227940905723 -373.41746053513145 190.99448386001291 583.83210077386195 -374.05816794647734 190.99704262134975 585.58977875987659 -376.46043004520459 198.32648038280036 584.59583321821719 -377.55978858486128 200.43597682507419 585.43062485900668 -379.03014904584228 205.27094091105167 584.4608506338044 -379.13017508526355 205.61691521355979 584.37720235858262
+6 0 14 -389.62938300835151 206.68890751911803 601.36590860707759 -387.81851271675555 207.47110296515251 602.43568966914279 -385.72296330314066 208.22423204441026 603.04483312744958 -383.45730254571026 208.89880783627146 603.1256574699571 -381.15738360384648 209.44751670452129 602.64492293402884 -378.97006557585553 209.82965844580042 601.60990414051525 -377.04059985347186 210.01534811075169 600.07068576737572 -375.49909626827883 209.98886873044447 598.11784593782988 -374.44787100769224 209.75061705931316 595.87537465415653 -373.95159723386581 209.31724901098528 593.48949750601219 -374.0317741581116 208.71996103085311 591.11495348066785 -374.66619141069793 208.00120174387052 588.90075363735639 -375.79313162690988 207.21036387600421 586.97738805888741 -377.31931456297167 206.39910643980028 585.44697764938178 -379.13017508526201 205.61691521356602 584.37720235857932
+6 0 14 -379.13017508526275 205.61691521355698 584.37720235858035 -380.94103560755326 204.83472398732448 583.30742706777914 -383.03657371607227 204.08159897106086 582.69828689568135 -385.30222427719849 203.40702594307325 582.6174617920268 -387.60213726746503 202.85831744742998 583.09819075217399 -389.78945576277488 202.47617327314225 584.13320004140803 -391.71892780090923 202.29047922696122 585.67240784582089 -393.26044446076065 202.31695222928983 587.62523693021956 -394.31168553155442 202.55519780174802 589.86770189511662 -394.80797181227456 202.98856210097549 592.25357849237287 -394.72780371100953 203.58584850123111 594.62812653366291 -394.09338873890545 204.30460900133582 596.84233412144306 -392.96644446955378 205.09545026031162 598.76570887894729 -391.44025329997862 205.90671207313602 600.29612754473192 -389.62938300838221 206.68890751919304 601.36590860675813
+6 0 8 -321.26229099653301 -85.808423460865313 516.97454777311566 -321.26229099653256 -91.722950801222765 516.97454777311577 -321.19759221459492 -97.184776577843223 516.87763498559889 -321.20728569240822 -102.39124429323917 516.89215491825519 -322.59879960126943 -105.98965022602982 518.97651396993058 -322.70019967049734 -107.14533148570506 519.12840188912617 -324.09641914018334 -110.36356468426878 521.21980943543929 -326.15851166810626 -112.75344085099135 524.30863319683419 -328.7536245490536 -115.88319926304489 528.19587211634337
+6 0 14 -321.26229099653318 -85.808423460865313 516.97454777311577 -319.15362568646634 -85.808423460865313 517.74203918000978 -316.85948765596942 -85.808423460865313 517.99994847559719 -314.5132851898158 -85.808423460865313 517.69971901521603 -312.26229431806564 -85.808423460865313 516.83089547123802 -310.25568893429715 -85.808423460865313 515.42548051374024 -308.63105014539462 -85.808423460865313 513.55811321421788 -307.50100137752435 -85.808423460865313 511.34146988638207 -306.9418557989701 -85.808423460865313 508.91703756367775 -306.98609372822608 -85.808423460865313 506.44225508928741 -307.61986744180086 -85.808423460865313 504.07582920228651 -308.78575802578928 -85.808423460865313 501.96337085825127 -310.39006331502873 -85.808423460865313 500.22528039123989 -312.31324552940134 -85.808423460865313 498.94821376261189 -314.42189946361344 -85.808423460865313 498.18072649619035
+6 0 8 -314.4218994636135 -85.808423460865313 498.1807264961904 -314.42189946361395 -91.14389707992072 498.18072649619023 -314.27383490273894 -98.272446118137168 497.95893948729389 -314.72191688045143 -105.39021916981103 498.63012482017041 -315.00288677461333 -112.79665198252397 499.05099171804756 -317.99369875503191 -120.82638625544614 503.53095126684582 -320.97532043699891 -125.02738694612012 507.99714459912758 -324.10345190468269 -128.8970251517419 512.6827960310228 -326.6985647856261 -132.02678356379579 516.5700349505305
+6 0 14 -328.75362454904905 -115.88319926304597 528.19587211634314 -326.77611274795333 -116.32565295913247 529.15981934149704 -324.7428793521018 -117.20582933283815 529.80853963321545 -322.77903499723357 -118.4957358011747 530.08104723652525 -321.01385660770012 -120.13465137459713 529.93992582925318 -319.56956201027344 -122.0316382544606 529.37680038816848 -318.54962766328265 -124.07164250187063 528.41522437759545 -318.02819361615246 -126.12483829355516 527.11022957449995 -318.04215349383753 -128.05824159591216 525.54425618467496 -318.58729477946258 -129.74806707710826 523.81978057981939 -319.61915281809547 -131.09102680695358 522.04964816928941 -321.05833301749698 -132.01298460579699 520.34655237635252 -322.79928381419518 -132.47396586587192 518.81314423305435 -324.72106365283656 -132.46923487292753 517.53397697537002 -326.69856478562622 -132.0267835637959 516.57003495053095
+6 0 14 -314.42189946361344 -85.808423460865313 498.1807264961904 -316.53055339782554 -85.808423460865313 497.41323922976886 -318.82467905187718 -85.808423460865313 497.15533132555379 -321.17087122047468 -85.808423460865313 497.45555830736822 -323.42185727314859 -85.808423460865313 498.3243752614988 -325.42846534403304 -85.808423460865313 499.72978077185786 -327.05311307512221 -85.808423460865313 501.59713854148885 -328.18317776933407 -85.808423460865313 503.81377329992017 -328.74234105648077 -85.808423460865313 506.23820194991407 -328.69811610303321 -85.808423460865313 508.71298597669795 -328.0643505204124 -85.808423460865313 511.07941737338206 -326.89846048066966 -85.808423460865313 513.1918838631758 -325.29414889623655 -85.808423460865313 514.92998284802093 -323.37095630659985 -85.808423460865313 516.20705636622154 -321.26229099653307 -85.808423460865313 516.97454777311555
+6 0 14 -326.69856478562627 -132.02678356379602 516.57003495053095 -328.67606591841593 -131.58433225466439 515.60609292569188 -330.7092883453538 -130.70416062934552 514.95737613369806 -332.67312431864497 -129.41426062467147 514.68486892178089 -334.43829989805306 -127.77535182855718 514.82598674842802 -335.88259875034032 -125.87837023756764 515.38910509071036 -336.90254276879671 -123.83836845042087 516.35067266378439 -337.42399231967016 -121.78517123307734 517.65565826446232 -337.41004848117029 -119.85176229888145 519.22162548095935 -336.86491807883237 -118.16192975844758 520.94609950380516 -335.833065930553 -116.8189624698114 522.71623406780634 -334.39388453232965 -115.89699879063221 524.41933539554805 -332.65292655648466 -115.43601454849205 525.95275073260007 -330.73113635014477 -115.44074556695935 527.23192489118958 -328.75362454904905 -115.88319926304581 528.19587211634359
+6 0 1 -328.75362454904928 -115.8831992630459 528.19587211634348 -371.07764211713896 -166.92681705260799 591.59333337082251
+6 0 1 -326.69856478562627 -132.02678356379602 516.57003495053095 -369.02258235371596 -183.07040135335814 579.96749620500998
+6 0 14 -371.07764211713879 -166.92681705260799 591.59333337082239 -369.10013031604308 -167.36927074869448 592.55728059597629 -367.06689692019154 -168.24944712240014 593.2060008876947 -365.10305256532331 -169.53935359073671 593.4785084910045 -363.33787417578986 -171.17826916415916 593.33738708373244 -361.89357957836319 -173.07525604402264 592.77426164264773 -360.87364523137239 -175.11526029143269 591.8126856320747 -360.35221118424221 -177.16845608311723 590.50769082897921 -360.36617106192728 -179.10185938547426 588.9417174391541 -360.91131234755233 -180.79168486667038 587.21724183429853 -361.94317038618522 -182.13464459651573 585.44710942376855 -363.38235058558672 -183.05660239535916 583.74401363083166 -365.12330138228492 -183.51758365543412 582.21060548753348 -367.04508122092631 -183.51285266248976 580.93143822984916 -369.02258235371596 -183.07040135335814 579.96749620501009
+6 0 14 -369.02258235371596 -183.07040135335814 579.96749620500998 -371.00008348650562 -182.62795004422651 579.00355418017091 -373.03330591344348 -181.74777841890764 578.35483738817709 -374.99714188673465 -180.45787841423359 578.08233017625992 -376.76231746614275 -178.8189696181193 578.22344800290705 -378.20661631843001 -176.92198802712974 578.78656634518939 -379.22656033688639 -174.88198623998298 579.74813391826342 -379.74800988775985 -172.82878902263946 581.05311951894134 -379.73406604925998 -170.89538008844357 582.61908673543837 -379.18893564692206 -169.20554754800969 584.34356075828418 -378.15708349864269 -167.86258025937352 586.11369532228537 -376.71790210041934 -166.94061658019433 587.81679665002707 -374.97694412457435 -166.47963233805419 589.35021198707909 -373.05515391823445 -166.4843633565215 590.6293861456686 -371.07764211713874 -166.92681705260796 591.59333337082262
+6 0 10 -371.07764211713862 -166.92681705260802 591.59333337082217 -372.23328097527201 -168.32054079545514 593.32437342662058 -374.07571901394812 -170.6024385450184 596.02213243089079 -376.56936080670755 -173.50446051539095 599.86654191395542 -379.05498308634469 -179.80592586821822 600.16671945162705 -380.26084016129147 -180.82722208841588 602.42160893953951 -383.3293070640396 -189.49227265742684 601.87420378389572 -384.71137271901256 -191.76340251892566 603.31825677979703 -387.11226448155162 -199.16981245612573 602.24079460149153 -388.37407264473012 -202.34698685523037 602.41568072010216 -389.62938300838272 -206.68890751919167 601.36590860675108
+6 0 10 -369.02258235371596 -183.07040135335814 579.96749620500998 -370.17822121184929 -184.46412509620521 581.6985362608084 -370.64706316530084 -184.9696777754971 582.46286057157204 -370.72924976885218 -185.844539942745 581.78221265205423 -371.22379113115181 -184.89741542114248 584.12227940905723 -373.41746053513145 -190.99448386001291 583.83210077386195 -374.05816794647734 -190.99704262134975 585.58977875987659 -376.46043004520459 -198.32648038280036 584.59583321821719 -377.55978858486128 -200.43597682507419 585.43062485900668 -379.03014904584228 -205.27094091105167 584.4608506338044 -379.13017508526355 -205.61691521355979 584.37720235858262
+6 0 14 -389.62938300835151 -206.68890751911803 601.36590860707759 -387.81851271675555 -207.47110296515251 602.43568966914279 -385.72296330314066 -208.22423204441026 603.04483312744958 -383.45730254571026 -208.89880783627146 603.1256574699571 -381.15738360384648 -209.44751670452129 602.64492293402884 -378.97006557585553 -209.82965844580042 601.60990414051525 -377.04059985347186 -210.01534811075169 600.07068576737572 -375.49909626827883 -209.98886873044447 598.11784593782988 -374.44787100769224 -209.75061705931316 595.87537465415653 -373.95159723386581 -209.31724901098528 593.48949750601219 -374.0317741581116 -208.71996103085311 591.11495348066785 -374.66619141069793 -208.00120174387052 588.90075363735639 -375.79313162690988 -207.21036387600421 586.97738805888741 -377.31931456297167 -206.39910643980028 585.44697764938178 -379.13017508526201 -205.61691521356602 584.37720235857932
+6 0 14 -379.13017508526275 -205.61691521355698 584.37720235858035 -380.94103560755326 -204.83472398732448 583.30742706777914 -383.03657371607227 -204.08159897106086 582.69828689568135 -385.30222427719849 -203.40702594307325 582.6174617920268 -387.60213726746503 -202.85831744742998 583.09819075217399 -389.78945576277488 -202.47617327314225 584.13320004140803 -391.71892780090923 -202.29047922696122 585.67240784582089 -393.26044446076065 -202.31695222928983 587.62523693021956 -394.31168553155442 -202.55519780174802 589.86770189511662 -394.80797181227456 -202.98856210097549 592.25357849237287 -394.72780371100953 -203.58584850123111 594.62812653366291 -394.09338873890545 -204.30460900133582 596.84233412144306 -392.96644446955378 -205.09545026031162 598.76570887894729 -391.44025329997862 -205.90671207313602 600.29612754473192 -389.62938300838221 -206.68890751919304 601.36590860675813
+6 0 8 -53.718859960515061 147.14730834960818 42.338142395020974 -54.25174126502872 150.28789228221973 45.94820711369583 -53.968945734940938 153.07839015925794 49.155854356240852 -52.990209822453565 155.56461266881541 52.013736247443241 -51.324210287709285 157.71678747572315 54.487634050211476 -48.947141428710026 159.50102766241886 56.538598382195765 -45.813662476278651 160.88006185769356 58.123784136419957 -41.800215154063935 161.74322605331619 59.115980105924919 -36.580711403588829 161.76571710853622 59.141833312423387
+6 0 2 -53.718859973047316 147.14730833922454 42.338142407021046 -28.536989646899976 149.80998995184265 2.4744607648094004 -3.3360746421511323 152.47187100095445 -37.37723750530813
+6 0 14 -3.3360746421511216 152.47187100095445 -37.377237505308138 -3.8237787305474749 151.23538315415882 -37.750453824726023 -4.2481750497060888 149.96257353763721 -38.086062286803319 -4.6073948203716482 148.65817993132373 -38.382632815238459 -4.8998559396265868 147.32710459710177 -38.638905632909299 -5.124273138474849 145.97438853399706 -38.853799034541801 -5.2796662354343438 144.60518464068787 -39.02641602833291 -5.3653664016257299 143.22472999906026 -39.156049781884015 -5.3810203731689441 141.83831750422428 -39.242187819873195 -5.3265925682478734 140.45126707505244 -39.284514933900368 -5.2023650885746537 139.06889668467014 -39.282914778640034 -5.0089356077335978 137.6964934522706 -39.237470142561783 -4.7472131715425636 136.33928503610272 -39.148461895738308 -4.4184119576692034 135.00241156255356 -39.016366631358409 -4.0240430628445365 133.69089831808566 -38.841853031216047
+6 0 2 -52.582146643129917 128.32696534470011 39.472133654881254 -28.314642164420341 131.00941971279468 0.30801392338103994 -4.024043062844548 133.69089831808577 -38.841853031216033
+6 0 11 -52.582146625490694 128.32696533203122 39.472133636474616 -53.269901568714559 126.03846911203719 42.104708609174679 -53.609298302996905 123.90909924182573 44.554232305457148 -53.641518609584693 121.90258870935652 46.862424759579426 -53.358173288766622 120.03634683800523 49.009258928747066 -52.762996663296626 118.29030516404177 51.017820468254271 -51.83966434383413 116.64408712257713 52.911549758175269 -50.521576782152664 115.11348445146311 54.672281034504444 -48.695474889232059 113.73898516288062 56.253438803893751 -46.206777746712859 112.56085987260404 57.608697047386698 -42.770556191555293 111.69707521718013 58.602352044798778 -37.628079805108463 111.72206502951197 58.573604977645068
+6 0 1 -37.628079805108264 111.72206502951219 58.573604977644592 -317.72805508480747 87.068959206329538 506.27420151203745
+6 0 14 -317.72805508480741 87.068959206329524 506.27420151203739 -322.48589798846109 87.202252645703737 503.30483852096188 -327.24992482173332 88.689403015197641 500.40615816886287 -331.71912258935743 91.521977279453012 497.76602223808106 -335.59201592531701 95.590314885566528 495.56700758910324 -338.59367508541732 100.68428440602507 493.96955051080045 -340.50277464448328 106.50514102111522 493.09567062719964 -341.1749877967423 112.68838076031103 493.01559295031586 -340.5590574499787 118.83552598660333 493.73944344143723 -338.70262638700586 124.55087458631543 495.21562505434571 -335.74672740253936 129.47792015590642 497.33627044917085 -331.91001763609313 133.33024965576476 499.94880705648558 -327.46557423957302 135.91308902881119 502.8716610978131 -322.71394089984881 137.13364593484522 505.91169032738787 -317.95612366386717 137.00035321456429 508.88103729930577
+6 0 1 -317.95612366386723 137.00035321456426 508.88103729930589 -36.58071140358885 161.76571710853619 59.141833312423501
+6 0 1 -53.718859960515061 147.14730834960818 42.338142395020974 0.83290000390049812 147.14730817897004 42.338142147271491
+6 0 8 0.83290000390049812 147.14730817897004 42.338142147271491 -2.7743736677558748 150.16439255472346 45.806245561121514 -6.712897372829822 152.87026691110825 48.916616352546548 -10.890638376563537 155.29679274776197 51.705881345443231 -15.366241928180244 157.39845160727168 54.121713348555694 -20.094137583570514 159.31083655259528 56.319974670899462 -25.137136337149428 160.67317602423276 57.885970903497203 -30.511671135611437 161.79186885136943 59.171894436774814 -36.580711403588857 161.76571710853617 59.141833312423444
+6 0 2 0.8328997750186744 147.14730834336387 42.338142385954562 18.083069816065425 149.00456678056571 14.532655028233378 35.323945228076511 150.8622084965489 -13.278570866444518
+6 0 1 -3.3360746421511323 152.47187100095445 -37.377237505308138 35.323945228076511 150.86220849654893 -13.278570866444525
+6 0 1 -52.582146643129917 128.32696534470011 39.472133654881254 1.9786697182190593 128.32696533498142 39.472133633061794
+6 0 1 -4.024043062844548 133.69089831808577 -38.84185303121604 35.800822871059559 131.99074203677037 -14.019393742777456
+6 0 2 1.9786697182190593 128.32696533498142 39.472133633061794 18.895118456674822 130.15862210512128 12.729750856423649 35.800822871059552 131.99074203677037 -14.019393742777453
+6 0 11 1.9786697146595955 128.32696533203264 39.472133636473053 -0.83085623189387237 125.99198095556739 42.158186327940548 -3.7873049551784423 123.79374446125742 44.686930399067464 -6.8764340889687343 121.73494652163259 47.055275143561566 -10.108198423162015 119.78157058502053 49.302331980697382 -13.468408246969798 118.02160233640217 51.326940128540322 -16.978061864498162 116.30984241869248 53.296026556088904 -20.652516478539859 114.89017245146843 54.929188398155866 -24.480912301400163 113.52574235883753 56.498729076248502 -28.554615266253833 112.53016055507113 57.644017657921673 -32.846499359622968 111.74530107164554 58.546875362602897 -37.628079805108122 111.72206502951259 58.573604977644194
+6 0 14 35.323945228076532 150.86220849654893 -13.278570866444529 35.799530731295462 149.58270097014659 -13.051482374644317 36.21115882744671 148.27201426148591 -12.866125191586898 36.556998717114681 146.9350737361375 -12.723373520513109 36.835510563296644 145.57694660947175 -12.623911715457808 37.045455488775559 144.20281505813094 -12.568229507125865 37.185903632028129 142.81794838475989 -12.556618495562002 37.256240178098253 141.42767446026957 -12.589169949549293 37.256169301689845 140.03735067808458 -12.665773939082515 37.185715981774898 138.65233466179441 -12.786119813088551 37.045225669856904 137.27795497118072 -12.949698020077996 36.835361817219358 135.91948205161739 -13.155803254902525 36.557101289543276 134.58209966833417 -13.403538900561886 36.211727719718802 133.27087706010414 -13.691822720345957 35.800822871059587 131.99074203677043 -14.019393742777458
+6 0 14 -317.95612366386729 137.00035321456423 508.88103729930594 -313.19830642788571 136.86706049428329 511.85038427122379 -308.43430529564671 135.37991814768739 514.74904898548482 -303.96512631409701 132.54735901547397 517.38917399618481 -300.09223789026015 128.47904111923836 519.58818665728108 -297.09056661634952 123.38509112549288 521.1856523897427 -295.18144239742185 117.56424853935842 522.05954847409021 -294.50919132913396 111.38101424185739 522.13965017245948 -295.12508370044583 105.23386144773112 521.41582302361758 -296.9814899690702 99.518497433577977 519.93965607426458 -299.9373766582209 94.591431653439642 517.81901725898149 -303.77409115796888 90.739082713925029 515.20647661985254 -308.21855320711882 88.156229257701469 512.28361013316476 -312.9702121811539 86.935665766955864 509.24356450311274 -317.72805508480752 87.068959206329993 506.27420151203722
+6 0 5 -1441.7071518996195 152.03266906738276 -20.511722161563757 -1416.9138083885648 152.03266906738273 46.404991940992716 -1392.1204648775101 152.0326690673827 113.32170604354918 -1065.9434218602289 142.72430078638223 51.543080022375989 -1065.9434218602296 71.362150393190973 51.543080022375975 -1065.9434218602307 -5.4001247917767614e-13 51.543080022375989
+6 0 2 -1441.7071518996181 139.16561062894533 -20.5117221615637 -1441.7071518996181 145.59913984816407 -20.5117221615637 -1441.7071518996181 152.03266906738281 -20.511722161563696
+6 0 5 -1441.7071518996195 139.16561062894533 -20.51172216156375 -1417.5358339084542 139.16561062894533 44.72615810963083 -1393.3645159172888 139.16561062894533 109.96403838082541 -1141.0044211429417 139.14357528407479 85.396924447050139 -1141.0044211429417 69.571787642037378 85.39692444705004 -1141.0044211429413 -1.4210854715202004e-14 85.396924447049827
+6 0 5 -1065.9434218602282 0 51.54308002237569 -1078.9327345519466 1.0658141036401502e-15 58.146524041321648 -1092.7775583358348 2.1316282072803005e-15 65.487362908352125 -1107.7902749616997 3.1974423109204505e-15 72.822451737826967 -1123.9375894002671 4.263256414560601e-15 79.590405408702892 -1141.0044211429415 5.3290705182007514e-15 85.396924447049855
+6 0 5 -1445.4409330821863 160.01900526917987 -19.128317122986797 -1420.2004112613995 160.01900526917973 48.995321858090023 -1394.9598894406126 160.01900526917959 117.11896083916685 -1022.0206181698181 145.2985083173217 34.624557835768314 -1022.0206181698188 72.64925415866071 34.624557835768201 -1022.0206181698201 -5.2580162446247414e-13 34.624557835768002
+6 0 5 -1445.4409330821863 160.01900526917987 -19.128317122986797 -1444.3015899030725 159.10340679071746 -19.550455705186952 -1443.3255229777035 157.95674148791102 -19.912098725096204 -1442.5680584521783 156.62291865641313 -20.192747266057108 -1442.0669233165386 155.16941014136606 -20.378423083078445 -1441.8334959429988 153.66854010836573 -20.46491037006907
+6 0 5 -1441.833495942999 153.6685401083657 -20.46491037006907 -1441.7830705045108 153.34431922381376 -20.48359352322294 -1441.7451377790392 153.01788819097479 -20.497647995346078 -1441.7198124693359 152.68997609311702 -20.507031287867537 -1441.7071518996197 152.36132258024989 -20.511722161563753 -1441.7071518996197 152.03266906738276 -20.511722161563753
+6 0 5 -1022.02061816982 5.1159076974727213e-13 34.624557835767973 -1030.6873172359267 5.1070259132757201e-13 35.993684849228032 -1039.1394980926279 5.1008086643378188e-13 38.720731724643585 -1047.7093652750987 5.0985882182885685e-13 42.429665257210317 -1056.605318023117 5.1016968427575191e-13 46.795819917474176 -1065.9434218602305 5.1116055832522989e-13 51.543080022375626
+6 0 5 -1502.5509308422741 150.57549851337501 2.0315352602512222 -1508.4506530584213 150.57549851337504 -13.891691256027187 -1514.3503752745685 150.57549851337507 -29.814917772305595 -1453.5065963319139 152.03266906738284 -52.358175194120506 -1447.6068741157662 152.03266906738284 -36.434948677842087 -1441.7071518996177 152.03266906738284 -20.511722161563675
+6 0 5 -1502.5509308422741 139.16561062894533 2.0315352602512222 -1502.5509308422741 141.44758820583127 2.0315352602512222 -1502.5509308422741 143.7295657827172 2.0315352602512222 -1502.5509308422741 146.01154335960314 2.0315352602512222 -1502.5509308422741 148.29352093648907 2.0315352602512222 -1502.5509308422741 150.57549851337501 2.0315352602512222
+6 0 5 -1502.5509308422741 139.16561062894533 2.0315352602512222 -1508.8046687234907 139.16561062894533 -14.847172110665397 -1515.0584066047074 139.16561062894533 -31.725879481582016 -1454.2146276620529 139.16561062894533 -54.269136903396934 -1447.9608897808357 139.16561062894533 -37.390429532480312 -1441.7071518996177 139.16561062894533 -20.511722161563707
+6 0 5 -1441.7071518996195 -139.16561062894533 -20.51172216156375 -1417.5358339084542 -139.16561062894533 44.72615810963083 -1393.3645159172888 -139.16561062894533 109.96403838082541 -1141.0044211429417 -139.14357528407479 85.396924447050139 -1141.0044211429417 -69.571787642037378 85.39692444705004 -1141.0044211429413 1.4210854715202004e-14 85.396924447049827
+6 0 2 -1441.7071518996181 -139.16561062894533 -20.5117221615637 -1441.7071518996181 -145.59913984816407 -20.5117221615637 -1441.7071518996181 -152.03266906738281 -20.511722161563696
+6 0 5 -1441.7071518996195 -152.03266906738281 -20.51172216156375 -1416.9138083885648 -152.03266906738281 46.404991940992673 -1392.1204648775101 -152.03266906738281 113.3217060435491 -1065.9434218602289 -142.72430078638229 51.543080022375946 -1065.9434218602289 -71.362150393191129 51.543080022375861 -1065.9434218602287 1.4210854715202004e-14 51.543080022375662
+6 0 5 -1500.4972255084424 158.27814053730592 1.2706159220102435 -1505.7049744668823 158.27814053730583 -12.784989285670319 -1510.9127234253222 158.27814053730575 -26.840594493350892 -1455.8564309990657 160.01900526918013 -47.239527538347943 -1450.6486820406253 160.01900526917993 -33.183922330667343 -1445.4409330821868 160.01900526917967 -19.128317122986786
+6 0 6 -1502.5509308422741 152.03266906738284 2.031535260251212 -1502.5509308422741 153.15691477026752 2.031535260251212 -1502.4087076582136 154.2811604731522 1.9788400808040838 -1502.1242073500516 155.37989791521611 1.8734297365595689 -1501.7029149051623 156.42741458625153 1.717336472793668 -1501.155600222944 157.40014714504935 1.5145506500455965 -1500.497225508484 158.27814053725072 1.2706159220255706
+6 0 5 -1502.5509308422741 152.03266906738284 2.031535260251212 -1508.3544554731698 152.03266906738304 -13.632055991152242 -1514.1579801040655 152.03266906738324 -29.29564724255571 -1453.4405452047902 153.66854010836553 -51.792092872875827 -1447.6370205738938 153.66854010836553 -36.128501621472424 -1441.8334959429994 153.66854010836551 -20.464910370069045
+6 0 5 -1502.5509308422741 150.57549851337501 2.0315352602512222 -1502.5509308422741 150.86693262417657 2.0315352602512222 -1502.5509308422741 151.15836673497813 2.0315352602512222 -1502.5509308422741 151.44980084577969 2.0315352602512222 -1502.5509308422741 151.74123495658125 2.0315352602512222 -1502.5509308422741 152.03266906738281 2.0315352602512222
+6 0 5 -1451.0842115501287 162.03266906738281 -17.03742333866554 -1425.5315061332506 162.03266906738281 51.928792620293741 -1399.9788007163725 162.03266906738281 120.89500857925302 -991.69577860506479 147.09561105375715 36.509706380313503 -991.69577860506467 73.547805526878562 36.509706380313588 -991.69577860506502 1.2789769243681803e-13 36.509706380314014
+6 0 5 -1445.4409330821836 160.01900526917962 -19.128317122986829 -1446.4081532045227 160.7962822903495 -18.769951936268257 -1447.4930430035408 161.40703443182477 -18.367988901779242 -1448.6620237099669 161.82415646750817 -17.934869305264034 -1449.8731176300464 162.03266906738247 -17.48614632196481 -1451.0842115501259 162.03266906738247 -17.037423338665587
+6 0 5 -991.69577860506183 2.8421709430404007e-14 36.509706380313304 -997.58120453697882 2.8517047531998514e-14 34.811901376914882 -1003.6523384855433 2.8479158870638003e-14 33.757862113331669 -1009.8152986791113 2.8308043446322474e-14 33.374740699306471 -1015.9702324024023 2.7981496798559423e-14 33.668744494052362 -1022.0206181698152 2.7450773197673904e-14 34.624557835768009
+6 0 5 -1441.833495942999 -153.6685401083657 -20.46491037006907 -1441.7830705045108 -153.34431922381376 -20.48359352322294 -1441.7451377790392 -153.01788819097479 -20.497647995346078 -1441.7198124693359 -152.68997609311702 -20.507031287867537 -1441.7071518996197 -152.36132258024989 -20.511722161563753 -1441.7071518996197 -152.03266906738276 -20.511722161563753
+6 0 5 -1445.4409330821863 -160.01900526917987 -19.128317122986797 -1444.3015899030725 -159.10340679071746 -19.550455705186952 -1443.3255229777035 -157.95674148791102 -19.912098725096204 -1442.5680584521783 -156.62291865641313 -20.192747266057108 -1442.0669233165386 -155.16941014136606 -20.378423083078445 -1441.8334959429988 -153.66854010836573 -20.46491037006907
+6 0 5 -1445.4409330821863 -160.01900526917987 -19.128317122986797 -1420.2004112613995 -160.01900526917976 48.995321858089994 -1394.9598894406126 -160.01900526917964 117.11896083916679 -1022.0206181698178 -145.29850831732176 34.624557835768201 -1022.020618169817 -72.649254158660838 34.624557835768087 -1022.0206181698157 -1.4210854715202004e-14 34.624557835767689
+6 0 5 -1502.5509308422741 139.16561062894533 2.0315352602512222 -1473.4469482682052 139.16561062894533 80.582573779376276 -1444.3429656941364 139.16561062894533 159.13361229850133 -1180.2082742306768 167.53874124040402 230.41899310211653 -1180.2082742306761 83.769370620201869 230.4189931021165 -1180.2082742306757 -2.8421709430404007e-13 230.41899310211625
+6 0 5 -1502.5509308422741 152.03266906738284 2.031535260251212 -1474.0689737880946 152.03266906738298 78.903739948014461 -1445.5870167339151 152.03266906738313 155.77594463577771 -1110.6572987550728 163.95801573809652 221.7191604266979 -1110.6572987550724 81.97900786904809 221.71916042669778 -1110.6572987550721 -5.6843418860808015e-13 221.71916042669756
+6 0 5 -1180.2082742306752 -2.8421709430404007e-13 230.41899310211622 -1166.7383445952412 -2.8776980798284058e-13 229.82950381865149 -1153.0195748516041 -2.9132252166164108e-13 228.65393467808116 -1139.0622373593919 -2.9487523534044158e-13 226.907098610676 -1124.9088408305449 -2.9842794901924208e-13 224.59760090083503 -1110.6572987550712 -3.0198066269804258e-13 221.71916042669761
+6 0 5 -1502.5509308422741 -139.16561062894533 2.0315352602512222 -1508.8046687234907 -139.16561062894533 -14.847172110665397 -1515.0584066047074 -139.16561062894533 -31.725879481582016 -1454.2146276620529 -139.16561062894533 -54.269136903396934 -1447.9608897808357 -139.16561062894533 -37.390429532480312 -1441.7071518996177 -139.16561062894533 -20.511722161563707
+6 0 5 -1502.5509308422741 -139.16561062894533 2.0315352602512222 -1502.5509308422741 -141.44758820583127 2.0315352602512222 -1502.5509308422741 -143.7295657827172 2.0315352602512222 -1502.5509308422741 -146.01154335960314 2.0315352602512222 -1502.5509308422741 -148.29352093648907 2.0315352602512222 -1502.5509308422741 -150.57549851337501 2.0315352602512222
+6 0 5 -1502.5509308422741 -150.57549851337501 2.0315352602512222 -1508.4506530584213 -150.57549851337504 -13.891691256027187 -1514.3503752745685 -150.57549851337507 -29.814917772305595 -1453.5065963319139 -152.03266906738281 -52.358175194120513 -1447.6068741157665 -152.03266906738284 -36.434948677842129 -1441.7071518996199 -152.03266906738293 -20.511722161563757
+6 0 6 -1500.497225508484 158.27814053725075 1.2706159220255708 -1499.9383128967395 159.0234935545401 1.0635329449025717 -1499.2993617136285 159.70057009654161 0.82679483870407156 -1498.5895258958055 160.29716158153411 0.56379323284576099 -1497.8201367688437 160.80293349051664 0.27872650214525746 -1497.0042213018669 161.21006871261326 -0.023578724882655056 -1496.1557064741439 161.51357615011028 -0.33796235653732842
+6 0 6 -1496.1557064741437 161.51357615011031 -0.33796235653732831 -1495.6762006738284 161.6850918054221 -0.5156242782590259 -1495.1862842212149 161.82351378008556 -0.69714345570614045 -1494.6884705082321 161.92794133428731 -0.88158865084201876 -1494.185364714642 161.99776194010573 -1.0679946172761392 -1493.6796179532034 162.03266906738284 -1.2553790899615684 -1493.1738711917649 162.03266906738284 -1.4427635626469977
+6 0 5 -1493.1738711917649 162.03266906738284 -1.4427635626469977 -1465.4512760434081 162.03266906738298 73.379939268713201 -1437.7286808950514 162.03266906738313 148.2026421000734 -1024.6635039472537 159.58670547072177 195.36708971175767 -1024.6635039472533 79.793352735360699 195.36708971175756 -1024.663503947253 -6.8212102632969618e-13 195.36708971175727
+6 0 6 -1110.6572987550726 -6.2527760746888816e-13 221.71916042669753 -1096.1588607150029 -6.3593574850528967e-13 218.79085339540924 -1081.5629101175707 -6.4659388954169117e-13 215.29727299363987 -1066.9585175562399 -6.573408484200627e-13 211.23270536876601 -1052.4757729371852 -6.682654429823742e-13 206.58041541377435 -1038.2962555181414 -6.794564910705958e-13 201.30872475031541 -1024.6635039472537 -6.9089178822423492e-13 195.36708971175722
+6 0 5 -1496.1557064744031 161.51357615001749 -0.33796235644116868 -1500.6634731746178 161.51357615001751 -12.504330131114449 -1505.1712398748325 161.51357615001754 -24.670697905787719 -1460.0997449505583 162.0326690673825 -41.37015888801205 -1455.5919782503429 162.03266906738259 -29.203791113338799 -1451.0842115501262 162.0326690673825 -17.037423338665572
+6 0 5 -1456.9180966352831 162.03266906738284 -14.875907806110028 -1431.0646311873504 162.0326690673829 54.902053168304455 -1405.2111657394178 162.03266906738295 124.68001414271893 -965.87586040883616 148.82695338431611 50.335242535564092 -965.87586040883684 74.413476692158028 50.335242535564021 -965.87586040883843 -1.9895196601282805e-13 50.335242535563836
+6 0 5 -1456.9180966352831 162.03266906738281 -14.875907806110028 -1456.4357231672768 162.03266906738281 -15.054632228749329 -1455.9533496992706 162.03266906738281 -15.233356651388629 -1455.4709762312643 162.03266906738281 -15.412081074027929 -1454.9886027632581 162.03266906738281 -15.59080549666723 -1454.5062292952518 162.03266906738281 -15.76952991930653
+6 0 5 -1454.5062292952516 162.03266906738281 -15.76952991930653 -1453.821825746227 162.03266906738281 -16.023108603178333 -1453.1374221972023 162.03266906738281 -16.276687287050134 -1452.4530186481777 162.03266906738281 -16.530265970921935 -1451.7686150991531 162.03266906738281 -16.783844654793736 -1451.0842115501284 162.03266906738281 -17.037423338665537
+6 0 5 -965.87586040883593 -1.1368683772161603e-13 50.335242535564596 -970.38038681845785 -1.1439738045737614e-13 46.522832935564743 -975.28666243976409 -1.1510792319313625e-13 43.185112306711012 -980.528016795893 -1.1581846592889636e-13 40.378576477602991 -986.02571487264356 -1.1652900866465647e-13 38.145384525932371 -991.69577860506456 -1.1723955140041658e-13 36.509706380313965
+6 0 5 -1451.0842115501287 -162.03266906738276 -17.037423338665548 -1449.8731176300491 -162.03266906738276 -17.486146321964771 -1448.6620237099696 -161.82415646750846 -17.934869305263994 -1447.4930430035436 -161.40703443182505 -18.367988901779206 -1446.4081532045254 -160.79628229034978 -18.769951936268225 -1445.4409330821863 -160.0190052691799 -19.128317122986797
+6 0 5 -1451.0842115501287 -162.03266906738281 -17.03742333866554 -1425.5315061332506 -162.03266906738281 51.928792620293741 -1399.9788007163725 -162.03266906738281 120.89500857925302 -991.69577860506479 -147.09561105375715 36.509706380313503 -991.69577860506467 -73.547805526878562 36.509706380313588 -991.69577860506502 -1.2789769243681803e-13 36.509706380314014
+6 0 5 -1502.5509308422741 -152.03266906738284 2.031535260251212 -1508.3544554731698 -152.03266906738304 -13.632055991152242 -1514.1579801040655 -152.03266906738324 -29.29564724255571 -1453.4405452047902 -153.66854010836553 -51.792092872875827 -1447.6370205738938 -153.66854010836553 -36.128501621472424 -1441.8334959429994 -153.66854010836551 -20.464910370069045
+6 0 6 -1502.5509308422741 -152.03266906738284 2.031535260251212 -1502.5509308422741 -153.15691477026752 2.031535260251212 -1502.4087076582136 -154.2811604731522 1.9788400808040838 -1502.1242073500516 -155.37989791521611 1.8734297365595689 -1501.7029149051623 -156.42741458625153 1.717336472793668 -1501.155600222944 -157.40014714504935 1.5145506500455965 -1500.497225508484 -158.27814053725072 1.2706159220255706
+6 0 5 -1500.4972255084424 -158.27814053730592 1.2706159220102433 -1505.7049744668823 -158.27814053730577 -12.784989285670328 -1510.9127234253222 -158.27814053730563 -26.840594493350892 -1455.8564309990657 -160.01900526917993 -47.239527538348149 -1450.6486820406253 -160.01900526917984 -33.183922330667471 -1445.4409330821838 -160.01900526917959 -19.128317122986836
+6 0 5 -1502.5509308422741 -150.57549851337501 2.0315352602512222 -1502.5509308422741 -150.86693262417657 2.0315352602512222 -1502.5509308422741 -151.15836673497813 2.0315352602512222 -1502.5509308422741 -151.44980084577969 2.0315352602512222 -1502.5509308422741 -151.74123495658125 2.0315352602512222 -1502.5509308422741 -152.03266906738281 2.0315352602512222
+6 0 5 -1502.5509308422741 -152.03266906738281 2.0315352602512222 -1474.0689737880946 -152.03266906738281 78.903739948014419 -1445.5870167339151 -152.03266906738281 155.77594463577762 -1110.6572987550728 -163.95801573809649 221.7191604266979 -1110.6572987550721 -81.979007869048104 221.71916042669784 -1110.6572987550715 2.7000623958883807e-13 221.71916042669756
+6 0 5 -1502.5509308422741 -139.16561062894533 2.0315352602512222 -1473.4469482682052 -139.16561062894533 80.582573779376276 -1444.3429656941364 -139.16561062894533 159.13361229850133 -1180.2082742306768 -167.53874124040402 230.41899310211653 -1180.2082742306761 -83.769370620201869 230.4189931021165 -1180.2082742306757 2.8421709430404007e-13 230.41899310211625
+6 0 5 -1493.1738711917649 162.03266906738284 -1.4427635626469977 -1497.2072006619264 162.03266906738281 -12.32863520460096 -1501.240530132088 162.03266906738278 -23.214506846554919 -1462.5728882355766 162.03266906738281 -37.541273203213784 -1458.5395587654148 162.03266906738276 -26.655401561259808 -1454.5062292952516 162.03266906738259 -15.769529919305857
+6 0 5 -1493.1738711917649 162.03266906738281 -1.4427635626469988 -1492.7461256262416 162.03266906738281 -1.6012477752025502 -1492.3183800607183 162.03266906738281 -1.7597319877581017 -1491.8906344951949 162.03266906738281 -1.9182162003136531 -1491.4628889296716 162.03266906738281 -2.0767004128692048 -1491.0351433641483 162.03266906738281 -2.2351846254247563
+6 0 5 -1491.0351433641486 162.03266906738281 -2.2351846254247563 -1490.296111912641 162.03266906738281 -2.5090035193803049 -1489.5570804611334 162.03266906738281 -2.7828224133358535 -1488.8180490096258 162.03266906738281 -3.056641307291402 -1488.0790175581183 162.03266906738281 -3.3304602012469506 -1487.3399861066107 162.03266906738281 -3.6042790952024992
+6 0 5 -1487.3399861066105 162.03266906738281 -3.6042790952025001 -1459.9181509893085 162.03266906738281 70.406678720702558 -1432.4963158720066 162.03266906738281 144.41763653660763 -993.87909632559013 157.85536314016264 179.6008670132361 -993.8790963255899 78.927681570081248 179.60086701323621 -993.87909632558853 -9.9475983006414026e-14 179.60086701323672
+6 0 5 -1024.6635039472519 -1.1368683772161603e-13 195.3670897117583 -1018.1840847068931 -1.1368683772161603e-13 192.54312976590001 -1011.8333230138944 -1.1368683772161603e-13 189.56152756703972 -1005.6414818579594 -1.1368683772161603e-13 186.41600237709119 -999.6433984129867 -1.1368683772161603e-13 183.09888071825728 -993.87909632558808 -1.1368683772161603e-13 179.60086701323661
+6 0 5 -1493.1738711917649 -162.03266906738281 -1.4427635626469988 -1465.4512760434084 -162.03266906738281 73.37993926871323 -1437.7286808950519 -162.03266906738281 148.20264210007346 -1024.663503947254 -159.58670547072177 195.3670897117577 -1024.6635039472535 -79.793352735360799 195.36708971175781 -1024.6635039472517 1.4210854715202004e-13 195.3670897117583
+6 0 6 -1496.1557064741437 -161.51357615011031 -0.33796235653732831 -1495.6762006738284 -161.6850918054221 -0.5156242782590259 -1495.1862842212149 -161.82351378008556 -0.69714345570614045 -1494.6884705082321 -161.92794133428731 -0.88158865084201876 -1494.185364714642 -161.99776194010573 -1.0679946172761392 -1493.6796179532034 -162.03266906738284 -1.2553790899615684 -1493.1738711917649 -162.03266906738284 -1.4427635626469977
+6 0 6 -1500.497225508484 -158.27814053725075 1.2706159220255708 -1499.9383128967395 -159.0234935545401 1.0635329449025717 -1499.2993617136285 -159.70057009654161 0.82679483870407156 -1498.5895258958055 -160.29716158153411 0.56379323284576099 -1497.8201367688437 -160.80293349051664 0.27872650214525746 -1497.0042213018669 -161.21006871261326 -0.023578724882655056 -1496.1557064741439 -161.51357615011028 -0.33796235653732842
+6 0 5 -1491.0351433641483 162.03266906738281 -2.2351846254248589 -1494.6998684268999 162.03266906738281 -12.126200703159057 -1498.3645934896515 162.03266906738281 -22.01721678089325 -1464.2475467607862 162.03266906738281 -34.657939961578357 -1460.5828216980344 162.03266906738281 -24.766923883844179 -1456.9180966352808 162.03266906738281 -14.875907806109979
+6 0 5 -1475.0005205187892 154.20556922667876 -8.1761803483455751 -1448.2148340398685 154.20556922667873 64.117825635617635 -1421.4291475609477 154.2055692266787 136.41183161958085 -947.70885205711068 154.19333709802555 133.46256790041281 -947.70885205711011 77.096668549012634 133.46256790041286 -947.70885205710726 -2.8421709430404007e-13 133.46256790041292
+6 0 7 -1475.0005205187892 154.20556922667879 -8.1761803483455751 -1473.0126128570059 153.40461122838457 -8.9127209598782144 -1471.0247051952226 153.20275617487675 -9.6492615714108538 -1469.0367975334393 153.73902341071505 -10.385802182943493 -1467.048889871656 154.98400833919897 -11.122342794476133 -1465.0609822098727 156.73988242236786 -11.858883406008772 -1463.0730745480894 158.64039318100092 -12.595424017541411 -1461.0851668863061 160.15086419461718 -13.331964629074051
+6 0 7 -1461.0851668863058 160.15086419461721 -13.331964629074054 -1460.4898711361598 160.60318750540824 -13.552527940079193 -1459.8945753860137 161.0205338600195 -13.773091251084331 -1459.2992796358676 161.38854503342245 -13.993654562089469 -1458.7039838857215 161.69150839067433 -14.214217873094608 -1458.1086881355754 161.91235688691819 -14.434781184099746 -1457.5133923854294 162.03266906738284 -14.655344495104885 -1456.9180966352833 162.03266906738284 -14.875907806110023
+6 0 7 -947.70885205711318 -1.9895196601282805e-13 133.46256790041193 -942.16625979093226 -1.9945949653837099e-13 121.631211300369 -939.20001152870987 -2.006437344313045e-13 108.59292923189994 -939.12539148480232 -2.0220016137630281e-13 95.020920300834149 -942.03848556132573 -2.0402727126825735e-13 81.691486675156426 -947.76808159171856 -2.0622657021227671e-13 69.38796276637936 -955.90299685340699 -2.0910257652368664e-13 58.775783738074672 -965.87586040883798 -2.1316282072803008e-13 50.33524253556341
+6 0 5 -1454.5062292952516 -162.03266906738281 -15.76952991930653 -1453.821825746227 -162.03266906738281 -16.023108603178333 -1453.1374221972023 -162.03266906738281 -16.276687287050134 -1452.4530186481777 -162.03266906738281 -16.530265970921935 -1451.7686150991531 -162.03266906738281 -16.783844654793736 -1451.0842115501284 -162.03266906738281 -17.037423338665537
+6 0 5 -1456.9180966352831 -162.03266906738281 -14.875907806110028 -1456.4357231672768 -162.03266906738281 -15.054632228749329 -1455.9533496992706 -162.03266906738281 -15.233356651388629 -1455.4709762312643 -162.03266906738281 -15.412081074027929 -1454.9886027632581 -162.03266906738281 -15.59080549666723 -1454.5062292952518 -162.03266906738281 -15.76952991930653
+6 0 5 -1456.9180966352831 -162.03266906738284 -14.875907806110028 -1431.0646311873504 -162.0326690673829 54.902053168304455 -1405.2111657394178 -162.03266906738295 124.68001414271893 -965.87586040883616 -148.82695338431611 50.335242535564092 -965.87586040883684 -74.413476692158028 50.335242535564021 -965.87586040883843 1.9895196601282805e-13 50.335242535563836
+6 0 5 -1496.1557064744031 -161.51357615001749 -0.33796235644116868 -1500.6634731746178 -161.51357615001751 -12.504330131114449 -1505.1712398748325 -161.51357615001754 -24.670697905787719 -1460.0997449505583 -162.0326690673825 -41.37015888801205 -1455.5919782503429 -162.03266906738259 -29.203791113338799 -1451.0842115501262 -162.0326690673825 -17.037423338665572
+6 0 5 -1487.3399861066107 162.03266906738281 -3.6042790952025001 -1490.3011920714926 162.03266906738281 -11.59651188391209 -1493.2623980363744 162.03266906738281 -19.588744672621676 -1467.0075788161787 160.15086419453445 -29.316430206452857 -1464.0463728512973 160.15086419453448 -21.324197417743292 -1461.0851668864152 160.15086419453451 -13.331964629033701
+6 0 4 -1487.3399861066107 162.03266906738281 -3.6042790952025001 -1484.2551197096554 162.03266906738281 -4.7472544084882689 -1481.1702533127 158.34026942535007 -5.8902297217740376 -1478.0853869157445 155.44850845459735 -7.0332050350598063 -1475.0005205187892 154.20556922667873 -8.1761803483455751
+6 0 5 -993.87909632558615 2.5579538487363607e-13 179.60086701323632 -981.68680830361859 2.5369543159091505e-13 172.20208916471992 -970.54041227457924 2.501743928366738e-13 163.99403574070695 -960.81864032294379 2.4523226861091239e-13 154.88874540669167 -953.00403138522472 2.3922433028151084e-13 144.76579063148142 -947.7088520571067 2.328611205842292e-13 133.46256790041301
+6 0 5 -1487.3399861066105 -162.03266906738281 -3.6042790952025001 -1459.9181509893085 -162.03266906738281 70.406678720702558 -1432.4963158720066 -162.03266906738281 144.41763653660763 -993.87909632559013 -157.85536314016264 179.6008670132361 -993.8790963255899 -78.927681570081248 179.60086701323621 -993.87909632558853 9.9475983006414026e-14 179.60086701323672
+6 0 5 -1491.0351433641486 -162.03266906738281 -2.2351846254247563 -1490.296111912641 -162.03266906738281 -2.5090035193803049 -1489.5570804611334 -162.03266906738281 -2.7828224133358535 -1488.8180490096258 -162.03266906738281 -3.056641307291402 -1488.0790175581183 -162.03266906738281 -3.3304602012469506 -1487.3399861066107 -162.03266906738281 -3.6042790952024992
+6 0 5 -1493.1738711917649 -162.03266906738281 -1.4427635626469988 -1492.7461256262416 -162.03266906738281 -1.6012477752025502 -1492.3183800607183 -162.03266906738281 -1.7597319877581017 -1491.8906344951949 -162.03266906738281 -1.9182162003136531 -1491.4628889296716 -162.03266906738281 -2.0767004128692048 -1491.0351433641483 -162.03266906738281 -2.2351846254247563
+6 0 5 -1493.1738711917649 -162.03266906738281 -1.4427635626469986 -1497.2072006619264 -162.03266906738281 -12.328635204601003 -1501.240530132088 -162.03266906738281 -23.214506846555004 -1462.5728882355766 -162.03266906738281 -37.541273203213791 -1458.5395587654148 -162.03266906738281 -26.655401561259815 -1454.5062292952512 -162.03266906738281 -15.769529919305821
+6 0 7 -1461.0851668863058 -160.15086419461721 -13.331964629074054 -1460.4898711361598 -160.60318750540824 -13.552527940079193 -1459.8945753860137 -161.0205338600195 -13.773091251084331 -1459.2992796358676 -161.38854503342245 -13.993654562089469 -1458.7039838857215 -161.69150839067433 -14.214217873094608 -1458.1086881355754 -161.91235688691819 -14.434781184099746 -1457.5133923854294 -162.03266906738284 -14.655344495104885 -1456.9180966352833 -162.03266906738284 -14.875907806110023
+6 0 7 -1475.0005205187892 -154.20556922667879 -8.1761803483455751 -1473.0126128570059 -153.40461122838457 -8.9127209598782144 -1471.0247051952226 -153.20275617487675 -9.6492615714108538 -1469.0367975334393 -153.73902341071505 -10.385802182943493 -1467.048889871656 -154.98400833919897 -11.122342794476133 -1465.0609822098727 -156.73988242236786 -11.858883406008772 -1463.0730745480894 -158.64039318100092 -12.595424017541411 -1461.0851668863061 -160.15086419461718 -13.331964629074051
+6 0 5 -1475.0005205187892 -154.20556922667879 -8.1761803483455751 -1448.2148340398685 -154.20556922667879 64.117825635617606 -1421.4291475609477 -154.20556922667879 136.41183161958077 -947.70885205711124 -154.19333709802558 133.46256790041235 -947.70885205711193 -77.096668549012733 133.46256790041218 -947.70885205711375 2.8421709430404007e-13 133.46256790041178
+6 0 5 -1491.0351433641486 -162.03266906738281 -2.2351846254248589 -1494.6998684269001 -162.03266906738281 -12.126200703159059 -1498.3645934896517 -162.03266906738281 -22.017216780893257 -1464.2475467607862 -162.03266906738281 -34.657939961578371 -1460.5828216980351 -162.03266906738281 -24.766923883844196 -1456.9180966352833 -162.03266906738281 -14.875907806109996
+6 0 4 -1487.3399861066107 -162.03266906738281 -3.6042790952025001 -1484.2551197096554 -162.03266906738281 -4.7472544084882689 -1481.1702533127 -158.34026942535007 -5.8902297217740376 -1478.0853869157445 -155.44850845459735 -7.0332050350598063 -1475.0005205187892 -154.20556922667873 -8.1761803483455751
+6 0 5 -1487.3399861066107 -162.03266906738281 -3.6042790952025001 -1490.3011920714926 -162.03266906738284 -11.596511883912081 -1493.2623980363744 -162.03266906738287 -19.588744672621662 -1467.0075788161787 -160.15086419453448 -29.31643020645285 -1464.0463728512962 -160.15086419453453 -21.324197417743292 -1461.0851668864118 -160.15086419453462 -13.331964629033747
+6 0 1 -14.722431864335487 -52.78125 -8.4999999999999947 -80.973375253845049 -52.78125 -46.75
+6 0 8 -80.973375253845035 -52.78125 -46.750000000000014 -68.734253874234795 -52.78125 -67.948780069487441 -50.152472329732419 -52.78125 -85.48562358539607 -26.506287617519583 -52.78125 -97.146524483476824 -3.5527136788005009e-15 -52.78125 -101.25291173838005 26.506287617519583 -52.78125 -97.146524483476824 50.152472329732412 -52.78125 -85.48562358539607 68.734253874234781 -52.78125 -67.948780069487441 80.97337525384502 -52.78125 -46.750000000000028
+6 0 1 14.722431864335435 -52.78125 -8.5000000000000178 80.973375253844992 -52.78125 -46.750000000000014
+6 0 8 14.722431864335432 -52.78125 -8.4999999999999964 12.497137068042662 -52.78125 -12.35432364899771 9.1186313326785964 -52.78125 -15.542840651890188 4.819325021367173 -52.78125 -17.663004451541237 -2.3980817331903381e-14 -52.78125 -18.409620316069098 -4.8193250213672192 -52.78125 -17.663004451541241 -9.1186313326786426 -52.78125 -15.542840651890197 -12.497137068042711 -52.78125 -12.354323648997722 -14.722431864335483 -52.78125 -8.5000000000000124
+6 0 5 25.806575201703126 -52.78125 -38.859020570241043 30.811719210463643 -52.78125 -41.748741811031763 35.823367691252983 -52.78125 -44.642218803291613 40.825835651255034 -52.78125 -47.530394720270792 45.835512478872467 -52.78125 -50.42273305411544 50.842166737969336 -52.78125 -53.313326238344402
+6 0 10 50.842166738034273 -52.78125 -53.313326238346029 52.899090852098141 -52.78125 -54.500891929311045 53.966020339367141 -52.78125 -55.963462756297147 54.801280163383041 -52.78125 -57.322256754356715 55.111951242602601 -52.78125 -58.767836906617163 55.438138973761816 -52.78125 -60.118663371545082 55.28920405219818 -52.78125 -61.50907543100535 55.134421669819353 -52.78125 -62.949505880436305 54.527012824617593 -52.78125 -64.388109988236522 53.636338431028229 -52.78125 -65.982287420677679 51.769107567896192 -52.78125 -67.416150550800239
+6 0 8 51.76910757101993 -52.78125 -67.416150555130315 38.413225334849059 -52.78125 -77.672250904933378 24.289905435490731 -52.78125 -83.709637934276799 10.63373891132604 -52.78125 -86.54744246652929 -2.6122230769890002 -52.78125 -87.194494811110616 -15.803202296550385 -52.78125 -85.759032342770709 -29.288049543309594 -52.78125 -82.105834260754236 -43.062527154343485 -52.78125 -75.208525458000864 -55.811215946987737 -52.78125 -64.110125360657264
+6 0 10 -55.811215946873176 -52.78125 -64.110125360285494 -57.507315151767912 -52.78125 -62.633582330093247 -58.312262274433138 -52.78125 -61.05888577382548 -58.836622214973971 -52.78125 -59.624814511613515 -58.95498559206375 -52.78125 -58.208830702663143 -59.025969789724662 -52.78125 -56.84333102342066 -58.688806880000634 -52.78125 -55.518457083168251 -58.315370196291923 -52.78125 -54.132665966998374 -57.48673240282281 -52.78125 -52.824100706118259 -56.415406922066886 -52.78125 -51.455250079460178 -54.480094377646211 -52.78125 -50.337896860966111
+6 0 5 -54.480094359665927 -52.78125 -50.337896885374576 -49.662610658302711 -52.78125 -47.55652137357589 -44.842788296843104 -52.78125 -44.773795946185949 -40.028378752329012 -52.78125 -41.994194676535081 -35.207200980592596 -52.78125 -39.210686698282771 -30.390737347995838 -52.78125 -36.429900123460989
+6 0 6 -30.390737344689413 -52.78125 -36.429900127375028 -28.942803657204202 -52.78125 -35.593935223138992 -27.488983650081149 -52.78125 -35.210440596455349 -26.061493808880236 -52.78125 -35.07577832632014 -24.644359998184321 -52.78125 -35.247916886058647 -23.231458522755112 -52.78125 -35.628517408923003 -21.783947885827992 -52.78125 -36.4925966455029
+6 0 6 -21.783947886687663 -52.78125 -36.492596647049801 -15.382592051727595 -52.78125 -40.313831891781746 -8.7448524062295299 -52.78125 -42.448854541204113 -2.1993502104915326 -52.78125 -43.307173989348712 4.3982503007192904 -52.78125 -43.115758746088964 11.213827403926311 -52.78125 -41.664988789565832 17.963793053663515 -52.78125 -38.516866101098806
+6 0 6 17.963793053708894 -52.78125 -38.51686610106924 19.325050135922247 -52.78125 -37.881988158317171 20.632317934975134 -52.78125 -37.62154483343199 21.928205733347475 -52.78125 -37.551694951930187 23.219010125237126 -52.78125 -37.725755088530484 24.518670083034959 -52.78125 -38.115448355532784 25.806575110505548 -52.78125 -38.859020669831779
+6 0 1 -2.9309887850104115e-15 -52.78125 16.999999999999996 -2.9309887850104115e-15 -52.78125 93.500000000000014
+6 0 8 -2.9309887850104115e-15 -52.78125 93.500000000000014 -24.478242759220478 -52.78125 93.500000000000014 -48.956485518440957 -52.78125 86.176126892842433 -70.878214283298092 -52.78125 71.52838067852727 -87.687593772580726 -52.78125 50.626455869190032 -97.384501900817682 -52.78125 25.618143804949558 -99.108957848173404 -52.78125 -0.69050330744635247 -93.212496633455316 -52.78125 -25.551219930512556 -80.973375253845106 -52.78125 -46.749999999999972
+6 0 8 -14.722431864335466 -52.78125 -8.5 -16.947726660628234 -52.78125 -4.6456763510022876 -18.019810517849706 -52.78125 -0.12554605589934109 -17.706273072875941 -52.78125 4.6578443281726427 -15.943198867741952 -52.78125 9.2048101580345474 -12.88694805150875 -52.78125 13.00516012336859 -8.9011791851710917 -52.78125 15.668386707789526 -4.4505895925855539 -52.78125 16.999999999999996 -1.5987211554602254e-14 -52.78125 16.999999999999996
+6 0 5 -46.556186580862395 -52.78125 -2.9196394242279222 -51.561330589622912 -52.78125 -5.809360665018648 -56.572979410580402 -52.78125 -8.7028370680899769 -61.575447105283807 -52.78125 -11.591013444579879 -66.58512399254154 -52.78125 -14.483351675124487 -71.591778251638402 -52.78125 -17.37394485935345
+6 0 10 -71.591778251672267 -52.78125 -17.373944859408873 -73.648702365742722 -52.78125 -18.56151055036247 -75.448790600381201 -52.78125 -18.754213176891081 -77.043170633218566 -52.78125 -18.798172404219585 -78.45041530789247 -52.78125 -18.344431374914624 -79.78335920820399 -52.78125 -17.951505004037354 -80.913023912642998 -52.78125 -17.12731754872247 -82.083082083045426 -52.78125 -16.273056848808654 -83.025245363788187 -52.78125 -15.027723304480451 -83.960506321627406 -52.78125 -13.459287936911174 -84.268652786297366 -52.78125 -11.12528700964716
+6 0 8 -84.268652791609227 -52.78125 -11.125287010187407 -86.472755120215709 -52.78125 5.5692964711914108 -84.639625710426614 -52.78125 20.819143804481719 -80.269153264249539 -52.78125 34.064633198845229 -74.206536038077729 -52.78125 45.859498950579749 -66.367899464535569 -52.78125 56.565490821342593 -56.46171349707312 -52.78125 66.417112062180479 -43.601230050625716 -52.78125 74.897505195819136 -27.61538922864035 -52.78125 80.388993506519228
+6 0 10 -27.615389228375658 -52.78125 80.388993506234087 -25.488615852000951 -52.78125 81.119586989915391 -23.72241506968858 -52.78125 81.029343368712773 -22.218292955505387 -52.78125 80.766416766842042 -20.932833317062023 -52.78125 80.16093055380432 -19.714783807148077 -52.78125 79.539654832624691 -18.73599077293952 -52.78125 78.5852262174636 -17.72257880385197 -52.78125 77.568925004581899 -17.003646942154539 -52.78125 76.19702099446171 -16.353850265860359 -52.78125 74.584800599076473 -16.353850265854504 -52.78125 72.350094162098515
+6 0 5 -16.353850295982998 -52.78125 72.350094158731281 -16.353850295982998 -52.78125 66.787343135133909 -16.353850564836204 -52.78125 61.221891814686614 -16.353850025184119 -52.78125 55.662690210089707 -16.353850290249166 -52.78125 50.095673794478962 -16.353850290249166 -52.78125 44.534100644835398
+6 0 6 -16.35385029529203 -52.78125 44.534100643928966 -16.353850295294002 -52.78125 42.862170835453476 -16.748644209932667 -52.78125 41.411378463413016 -17.345768183664752 -52.78125 40.107804862221208 -18.20341145471712 -52.78125 38.966600261465949 -19.239471913925897 -52.78125 37.933291952131917 -20.711541802150315 -52.78125 37.111750586594788
+6 0 6 -20.711541803060143 -52.78125 37.111750588112741 -27.221506516314491 -52.78125 33.478631438739555 -32.389360191118456 -52.78125 28.797691606742305 -36.40543773564292 -52.78125 23.558280148778675 -39.538467527913809 -52.78125 17.748882880419032 -41.689852442121044 -52.78125 11.121034989328631 -42.338481044547038 -52.78125 3.7013319177503679
+6 0 6 -42.33848104454411 -52.78125 3.701331917696264 -42.469289158925093 -52.78125 2.2050097320419835 -42.89737252285488 -52.78125 0.94266094607022155 -43.484824650209156 -52.78125 -0.21453574852541446 -44.280967346236025 -52.78125 -1.2453750749182297 -45.268281594042683 -52.78125 -2.1760669811514148 -46.556186621511692 -52.78125 -2.9196392954531456
+6 0 1 -80.973375253845035 -52.78125 -46.750000000000014 -80.973375253845035 -51.04045 -46.750000000000014
+6 0 8 -80.973375253845035 -51.04045 -46.750000000000014 -68.734253874234795 -51.04045 -67.948780069487441 -50.152472329732419 -51.04045 -85.48562358539607 -26.506287617519583 -51.04045 -97.146524483476824 -3.5527136788005009e-15 -51.04045 -101.25291173838005 26.506287617519583 -51.04045 -97.146524483476824 50.152472329732412 -51.04045 -85.48562358539607 68.734253874234781 -51.04045 -67.948780069487441 80.97337525384502 -51.04045 -46.750000000000028
+6 0 1 80.973375253845006 -52.78125 -46.750000000000014 80.973375253845006 -51.04045 -46.750000000000014
+6 0 8 80.973375253845006 -52.78125 -46.750000000000014 93.212496633455245 -52.78125 -25.551219930512591 99.108957848173347 -52.78125 -0.69050330744637733 97.384501900817639 -52.78125 25.61814380494954 87.687593772580698 -52.78125 50.626455869190011 70.878214283298064 -52.78125 71.52838067852727 48.956485518440942 -52.78125 86.176126892842433 24.478242759220471 -52.78125 93.500000000000014 -3.5527136788005009e-15 -52.78125 93.500000000000028
+6 0 8 -2.0834168544185351e-14 -52.78125 16.999999999999986 4.4505895925855201 -52.78125 16.999999999999986 8.9011791851710598 -52.78125 15.668386707789518 12.886948051508719 -52.78125 13.005160123368579 15.943198867741927 -52.78125 9.204810158034535 17.70627307287592 -52.78125 4.6578443281726329 18.019810517849685 -52.78125 -0.12554605589934997 16.947726660628213 -52.78125 -4.6456763510022965 14.722431864335444 -52.78125 -8.5000000000000089
+6 0 5 20.749611379159216 -52.78125 41.77865999446896 20.749611379159216 -52.78125 47.558102476050408 20.749611719327365 -52.78125 53.345055871381589 20.749611454028724 -52.78125 59.121408164850671 20.749611513669027 -52.78125 64.906084729239922 20.749611513669024 -52.78125 70.687271097697845
+6 0 10 20.749611513637966 -52.78125 70.687271097754902 20.749611513644556 -52.78125 73.062402479673523 21.482770261014036 -52.78125 74.717675933188232 22.241890469835496 -52.78125 76.1204291585763 23.338464065289845 -52.78125 77.112268281531783 24.345220234442145 -52.78125 78.070168375582426 25.623819860444794 -52.78125 78.636392979727802 26.948660413226051 -52.78125 79.222562729244942 28.498232539170569 -52.78125 79.415833292716968 30.32416789059916 -52.78125 79.44157535758886 32.499545218401209 -52.78125 78.541437560447406
+6 0 8 32.499545220589269 -52.78125 78.541437565317736 48.059529785366614 -52.78125 72.102954433741971 60.349720274935848 -52.78125 62.890494129795087 69.635414352923462 -52.78125 52.482809267684068 76.818759115066683 -52.78125 41.334995860530867 82.171101761085907 -52.78125 29.193541521428131 85.749763040382661 -52.78125 15.68872219857378 86.663757204969144 -52.78125 0.31102026218176171 83.426605175628026 -52.78125 -16.278868145861914
+6 0 10 83.426605175248795 -52.78125 -16.278868145948593 82.995931003768817 -52.78125 -18.486004659822143 82.034677344121675 -52.78125 -19.9704575948873 81.054915170479319 -52.78125 -21.141602255228541 79.887818909125741 -52.78125 -21.952099851141195 78.740753596872707 -52.78125 -22.696323809204042 77.424797652940114 -52.78125 -23.066769134295356 76.037949000143854 -52.78125 -23.436259037583536 74.490379344977299 -52.78125 -23.372920288343455 72.769257187927181 -52.78125 -23.129550519616281 70.833944643500658 -52.78125 -22.012197301132318
+6 0 5 70.833944655648878 -52.78125 -22.012197273356715 66.016460954285662 -52.78125 -19.23082176155803 61.196638861679261 -52.78125 -16.44809586850068 56.382228777513085 -52.78125 -13.668495533554644 51.561051270841716 -52.78125 -10.884987096196209 46.744587638244958 -52.78125 -8.1042005213744286
+6 0 6 46.744587639981411 -52.78125 -8.1042005165539575 45.296653952498175 -52.78125 -7.2682356123145055 44.237627860013788 -52.78125 -6.2009378669576893 43.40726199254496 -52.78125 -5.0320265359010889 42.847771452901412 -52.78125 -3.7186833754073261 42.47093043668098 -52.78125 -2.3047745432089384 42.495489687978278 -52.78125 -0.61915394109190913
+6 0 6 42.495489689747764 -52.78125 -0.61915394106294519 42.604098568042048 -52.78125 6.8352004530421926 41.134212597347947 -52.78125 13.651162934461816 38.604787946134408 -52.78125 19.748893840570044 35.140217227194476 -52.78125 25.366875865669943 30.476025038194685 -52.78125 30.543953800237212 24.374687990883473 -52.78125 34.815534183348447
+6 0 6 24.374687990835163 -52.78125 34.815534183372968 23.144239023002793 -52.78125 35.676978426275184 22.265054587879696 -52.78125 36.678883887361764 21.55661891686163 -52.78125 37.766230700455594 21.061957220998849 -52.78125 38.971130163448706 20.749611511007675 -52.78125 40.291515336684192 20.749611511006094 -52.78125 41.778659965284916
+6 0 1 25.806575110505548 -56.26285 -38.859020669831764 25.806575110505548 -52.78125 -38.859020669831764
+6 0 5 25.806575201703126 -56.26285 -38.859020570241043 30.811719210463643 -56.26285 -41.748741811031763 35.823367691252983 -56.26285 -44.642218803291613 40.825835651255034 -56.26285 -47.530394720270792 45.835512478872467 -56.26285 -50.42273305411544 50.842166737969336 -56.26285 -53.313326238344402
+6 0 1 50.842166738034273 -56.26285 -53.313326238346029 50.842166738034273 -52.78125 -53.313326238346029
+6 0 1 -55.81121594698773 -56.26285 -64.110125360657278 -55.81121594698773 -52.78125 -64.110125360657278
+6 0 10 -55.811215946873176 -56.26285 -64.110125360285494 -57.507315151767912 -56.26285 -62.633582330093247 -58.312262274433138 -56.26285 -61.05888577382548 -58.836622214973971 -56.26285 -59.624814511613515 -58.95498559206375 -56.26285 -58.208830702663143 -59.025969789724662 -56.26285 -56.84333102342066 -58.688806880000634 -56.26285 -55.518457083168251 -58.315370196291923 -56.26285 -54.132665966998374 -57.48673240282281 -56.26285 -52.824100706118259 -56.415406922066886 -56.26285 -51.455250079460178 -54.480094377646211 -56.26285 -50.337896860966111
+6 0 1 -54.480094359665927 -56.26285 -50.337896885374576 -54.480094359665927 -52.78125 -50.337896885374576
+6 0 10 50.842166738034273 -56.26285 -53.313326238346029 52.899090852098141 -56.26285 -54.500891929311045 53.966020339367141 -56.26285 -55.963462756297147 54.801280163383041 -56.26285 -57.322256754356715 55.111951242602601 -56.26285 -58.767836906617163 55.438138973761816 -56.26285 -60.118663371545082 55.28920405219818 -56.26285 -61.50907543100535 55.134421669819353 -56.26285 -62.949505880436305 54.527012824617593 -56.26285 -64.388109988236522 53.636338431028229 -56.26285 -65.982287420677679 51.769107567896192 -56.26285 -67.416150550800239
+6 0 1 51.769107567896185 -56.26285 -67.416150550800268 51.769107567896185 -52.78125 -67.416150550800268
+6 0 5 -54.480094359665927 -56.26285 -50.337896885374576 -49.662610658302711 -56.26285 -47.55652137357589 -44.842788296843104 -56.26285 -44.773795946185949 -40.028378752329012 -56.26285 -41.994194676535081 -35.207200980592596 -56.26285 -39.210686698282771 -30.390737347995838 -56.26285 -36.429900123460989
+6 0 1 -30.390737347995842 -56.26285 -36.429900123460989 -30.390737347995842 -52.78125 -36.429900123460989
+6 0 8 51.76910757101993 -56.26285 -67.416150555130315 38.413225334849059 -56.26285 -77.672250904933378 24.289905435490731 -56.26285 -83.709637934276799 10.63373891132604 -56.26285 -86.54744246652929 -2.6122230769890002 -56.26285 -87.194494811110616 -15.803202296550385 -56.26285 -85.759032342770709 -29.288049543309594 -56.26285 -82.105834260754236 -43.062527154343485 -56.26285 -75.208525458000864 -55.811215946987737 -56.26285 -64.110125360657264
+6 0 6 -30.390737344689413 -56.26285 -36.429900127375028 -28.942803657204202 -56.26285 -35.593935223138992 -27.488983650081149 -56.26285 -35.210440596455349 -26.061493808880236 -56.26285 -35.07577832632014 -24.644359998184321 -56.26285 -35.247916886058647 -23.231458522755112 -56.26285 -35.628517408923003 -21.783947885827992 -56.26285 -36.4925966455029
+6 0 1 -21.783947886687663 -56.26285 -36.492596647049801 -21.783947886687663 -52.78125 -36.492596647049801
+6 0 6 -21.783947886687663 -56.26285 -36.492596647049801 -15.382592051727595 -56.26285 -40.313831891781746 -8.7448524062295299 -56.26285 -42.448854541204113 -2.1993502104915326 -56.26285 -43.307173989348712 4.3982503007192904 -56.26285 -43.115758746088964 11.213827403926311 -56.26285 -41.664988789565832 17.963793053663515 -56.26285 -38.516866101098806
+6 0 1 17.963793053663508 -56.26285 -38.516866101098806 17.963793053663508 -52.78125 -38.516866101098806
+6 0 6 17.963793053708894 -56.26285 -38.51686610106924 19.325050135922247 -56.26285 -37.881988158317171 20.632317934975134 -56.26285 -37.62154483343199 21.928205733347475 -56.26285 -37.551694951930187 23.219010125237126 -56.26285 -37.725755088530484 24.518670083034959 -56.26285 -38.115448355532784 25.806575110505548 -56.26285 -38.859020669831779
+6 0 1 -1.4210854715202004e-14 -52.78125 93.499999999999986 -1.4210854715202004e-14 -51.04045 93.499999999999986
+6 0 8 -2.9309887850104115e-15 -51.04045 93.500000000000014 -24.478242759220478 -51.04045 93.500000000000014 -48.956485518440957 -51.04045 86.176126892842433 -70.878214283298092 -51.04045 71.52838067852727 -87.687593772580726 -51.04045 50.626455869190032 -97.384501900817682 -51.04045 25.618143804949558 -99.108957848173404 -51.04045 -0.69050330744635247 -93.212496633455316 -51.04045 -25.551219930512556 -80.973375253845106 -51.04045 -46.749999999999972
+6 0 1 -46.556186580862395 -56.26285 -2.9196394242279222 -46.556186580862395 -52.78125 -2.9196394242279222
+6 0 5 -46.556186580862395 -56.26285 -2.9196394242279222 -51.561330589622912 -56.26285 -5.809360665018648 -56.572979410580402 -56.26285 -8.7028370680899769 -61.575447105283807 -56.26285 -11.591013444579879 -66.58512399254154 -56.26285 -14.483351675124487 -71.591778251638402 -56.26285 -17.37394485935345
+6 0 1 -71.591778251672267 -56.26285 -17.373944859408873 -71.591778251672267 -52.78125 -17.373944859408873
+6 0 10 -71.591778251672267 -56.26285 -17.373944859408873 -73.648702365742722 -56.26285 -18.56151055036247 -75.448790600381201 -56.26285 -18.754213176891081 -77.043170633218566 -56.26285 -18.798172404219585 -78.45041530789247 -56.26285 -18.344431374914624 -79.78335920820399 -56.26285 -17.951505004037354 -80.913023912642998 -56.26285 -17.12731754872247 -82.083082083045426 -56.26285 -16.273056848808654 -83.025245363788187 -56.26285 -15.027723304480451 -83.960506321627406 -56.26285 -13.459287936911174 -84.268652786297366 -56.26285 -11.12528700964716
+6 0 1 -84.268652791609227 -56.26285 -11.125287010187407 -84.268652791609227 -52.78125 -11.125287010187407
+6 0 8 -84.268652791609227 -56.26285 -11.125287010187407 -86.472755120215709 -56.26285 5.5692964711914108 -84.639625710426614 -56.26285 20.819143804481719 -80.269153264249539 -56.26285 34.064633198845229 -74.206536038077729 -56.26285 45.859498950579749 -66.367899464535569 -56.26285 56.565490821342593 -56.46171349707312 -56.26285 66.417112062180479 -43.601230050625716 -56.26285 74.897505195819136 -27.61538922864035 -56.26285 80.388993506519228
+6 0 1 -27.615389228640339 -56.26285 80.388993506519199 -27.615389228640339 -52.78125 80.388993506519199
+6 0 10 -27.615389228375658 -56.26285 80.388993506234087 -25.488615852000951 -56.26285 81.119586989915391 -23.72241506968858 -56.26285 81.029343368712773 -22.218292955505387 -56.26285 80.766416766842042 -20.932833317062023 -56.26285 80.16093055380432 -19.714783807148077 -56.26285 79.539654832624691 -18.73599077293952 -56.26285 78.5852262174636 -17.72257880385197 -56.26285 77.568925004581899 -17.003646942154539 -56.26285 76.19702099446171 -16.353850265860359 -56.26285 74.584800599076473 -16.353850265854504 -56.26285 72.350094162098515
+6 0 1 -16.353850295982998 -56.26285 72.350094158731281 -16.353850295982998 -52.78125 72.350094158731281
+6 0 5 -16.353850295982998 -56.26285 72.350094158731281 -16.353850295982998 -56.26285 66.787343135133909 -16.353850564836204 -56.26285 61.221891814686614 -16.353850025184119 -56.26285 55.662690210089707 -16.353850290249166 -56.26285 50.095673794478962 -16.353850290249166 -56.26285 44.534100644835398
+6 0 1 -16.353850290249166 -56.26285 44.534100644835405 -16.353850290249166 -52.78125 44.534100644835405
+6 0 6 -16.35385029529203 -56.26285 44.534100643928966 -16.353850295294002 -56.26285 42.862170835453476 -16.748644209932667 -56.26285 41.411378463413016 -17.345768183664752 -56.26285 40.107804862221208 -18.20341145471712 -56.26285 38.966600261465949 -19.239471913925897 -56.26285 37.933291952131917 -20.711541802150315 -56.26285 37.111750586594788
+6 0 1 -20.711541803060143 -56.26285 37.111750588112741 -20.711541803060143 -52.78125 37.111750588112741
+6 0 6 -20.711541803060143 -56.26285 37.111750588112741 -27.221506516314491 -56.26285 33.478631438739555 -32.389360191118456 -56.26285 28.797691606742305 -36.40543773564292 -56.26285 23.558280148778675 -39.538467527913809 -56.26285 17.748882880419032 -41.689852442121044 -56.26285 11.121034989328631 -42.338481044547038 -56.26285 3.7013319177503679
+6 0 1 -42.338481044547038 -56.26285 3.7013319177503661 -42.338481044547038 -52.78125 3.7013319177503661
+6 0 6 -42.33848104454411 -56.26285 3.701331917696264 -42.469289158925093 -56.26285 2.2050097320419835 -42.89737252285488 -56.26285 0.94266094607022155 -43.484824650209156 -56.26285 -0.21453574852541446 -44.280967346236025 -56.26285 -1.2453750749182297 -45.268281594042683 -56.26285 -2.1760669811514148 -46.556186621511692 -56.26285 -2.9196392954531456
+6 0 1 -80.973375253845063 -51.040450000000007 -46.749999999999986 -110.41823898251599 -51.040450000000007 -63.749999999999986
+6 0 8 -110.41823898251594 -51.04045 -63.750000000000021 -93.728528010320161 -51.04045 -92.657427367482867 -68.38973499508964 -51.04045 -116.57130488917645 -36.144937660253959 -51.04045 -132.47253338655929 7.1054273576010019e-15 -51.04045 -138.07215237051824 36.144937660253987 -51.04045 -132.47253338655929 68.389734995089668 -51.04045 -116.57130488917645 93.728528010320176 -51.04045 -92.657427367482867 110.41823898251596 -51.04045 -63.750000000000036
+6 0 1 80.973375253845035 -51.040450000000007 -46.750000000000014 110.41823898251594 -51.040450000000007 -63.750000000000028
+6 0 8 80.973375253845006 -51.040450000000007 -46.750000000000014 93.212496633455245 -51.040450000000007 -25.551219930512591 99.108957848173347 -51.040450000000007 -0.69050330744637733 97.384501900817639 -51.040450000000007 25.61814380494954 87.687593772580698 -51.040450000000007 50.626455869190011 70.878214283298064 -51.040450000000007 71.52838067852727 48.956485518440942 -51.040450000000007 86.176126892842433 24.478242759220471 -51.040450000000007 93.500000000000014 -3.5527136788005009e-15 -51.040450000000007 93.500000000000028
+6 0 1 20.749611511006094 -56.26285 41.778659965284902 20.749611511006094 -52.78125 41.778659965284902
+6 0 5 20.749611379159216 -56.26285 41.77865999446896 20.749611379159216 -56.26285 47.558102476050408 20.749611719327365 -56.26285 53.345055871381589 20.749611454028724 -56.26285 59.121408164850671 20.749611513669027 -56.26285 64.906084729239922 20.749611513669024 -56.26285 70.687271097697845
+6 0 1 20.749611513669027 -56.26285 70.687271097697845 20.749611513669027 -52.78125 70.687271097697845
+6 0 10 20.749611513637966 -56.26285 70.687271097754902 20.749611513644556 -56.26285 73.062402479673523 21.482770261014036 -56.26285 74.717675933188232 22.241890469835496 -56.26285 76.1204291585763 23.338464065289845 -56.26285 77.112268281531783 24.345220234442145 -56.26285 78.070168375582426 25.623819860444794 -56.26285 78.636392979727802 26.948660413226051 -56.26285 79.222562729244942 28.498232539170569 -56.26285 79.415833292716968 30.32416789059916 -56.26285 79.44157535758886 32.499545218401209 -56.26285 78.541437560447406
+6 0 1 32.499545220589269 -56.26285 78.541437565317736 32.499545220589269 -52.78125 78.541437565317736
+6 0 8 32.499545220589269 -56.26285 78.541437565317736 48.059529785366614 -56.26285 72.102954433741971 60.349720274935848 -56.26285 62.890494129795087 69.635414352923462 -56.26285 52.482809267684068 76.818759115066683 -56.26285 41.334995860530867 82.171101761085907 -56.26285 29.193541521428131 85.749763040382661 -56.26285 15.68872219857378 86.663757204969144 -56.26285 0.31102026218176171 83.426605175628026 -56.26285 -16.278868145861914
+6 0 1 83.426605175248795 -56.26285 -16.278868145948593 83.426605175248795 -52.78125 -16.278868145948593
+6 0 10 83.426605175248795 -56.26285 -16.278868145948593 82.995931003768817 -56.26285 -18.486004659822143 82.034677344121675 -56.26285 -19.9704575948873 81.054915170479319 -56.26285 -21.141602255228541 79.887818909125741 -56.26285 -21.952099851141195 78.740753596872707 -56.26285 -22.696323809204042 77.424797652940114 -56.26285 -23.066769134295356 76.037949000143854 -56.26285 -23.436259037583536 74.490379344977299 -56.26285 -23.372920288343455 72.769257187927181 -56.26285 -23.129550519616281 70.833944643500658 -56.26285 -22.012197301132318
+6 0 1 70.833944655648878 -56.26285 -22.012197273356715 70.833944655648878 -52.78125 -22.012197273356715
+6 0 5 70.833944655648878 -56.26285 -22.012197273356715 66.016460954285662 -56.26285 -19.23082176155803 61.196638861679261 -56.26285 -16.44809586850068 56.382228777513085 -56.26285 -13.668495533554644 51.561051270841716 -56.26285 -10.884987096196209 46.744587638244958 -56.26285 -8.1042005213744286
+6 0 1 46.744587639981411 -56.26285 -8.1042005165539575 46.744587639981411 -52.78125 -8.1042005165539575
+6 0 6 46.744587639981411 -56.26285 -8.1042005165539575 45.296653952498175 -56.26285 -7.2682356123145055 44.237627860013788 -56.26285 -6.2009378669576893 43.40726199254496 -56.26285 -5.0320265359010889 42.847771452901412 -56.26285 -3.7186833754073261 42.47093043668098 -56.26285 -2.3047745432089384 42.495489687978278 -56.26285 -0.61915394109190913
+6 0 1 42.495489687978271 -56.26285 -0.61915394109190824 42.495489687978271 -52.78125 -0.61915394109190824
+6 0 6 42.495489689747764 -56.26285 -0.61915394106294519 42.604098568042048 -56.26285 6.8352004530421926 41.134212597347947 -56.26285 13.651162934461816 38.604787946134408 -56.26285 19.748893840570044 35.140217227194476 -56.26285 25.366875865669943 30.476025038194685 -56.26285 30.543953800237212 24.374687990883473 -56.26285 34.815534183348447
+6 0 1 24.374687990835163 -56.26285 34.815534183372968 24.374687990835163 -52.78125 34.815534183372968
+6 0 6 24.374687990835163 -56.26285 34.815534183372968 23.144239023002793 -56.26285 35.676978426275184 22.265054587879696 -56.26285 36.678883887361764 21.55661891686163 -56.26285 37.766230700455594 21.061957220998849 -56.26285 38.971130163448706 20.749611511007675 -56.26285 40.291515336684192 20.749611511006094 -56.26285 41.778659965284916
+6 0 8 14.722431864335432 -56.26285 -8.4999999999999964 12.497137068042662 -56.26285 -12.35432364899771 9.1186313326785964 -56.26285 -15.542840651890188 4.819325021367173 -56.26285 -17.663004451541237 -2.3980817331903381e-14 -56.26285 -18.409620316069098 -4.8193250213672192 -56.26285 -17.663004451541241 -9.1186313326786426 -56.26285 -15.542840651890197 -12.497137068042711 -56.26285 -12.354323648997722 -14.722431864335483 -56.26285 -8.5000000000000124
+6 0 1 14.722431864335435 -56.26285 -8.5000000000000178 80.973375253844992 -56.26285 -46.750000000000014
+6 0 8 -80.973375253845035 -56.26285 -46.750000000000014 -68.734253874234795 -56.26285 -67.948780069487441 -50.152472329732419 -56.26285 -85.48562358539607 -26.506287617519583 -56.26285 -97.146524483476824 -3.5527136788005009e-15 -56.26285 -101.25291173838005 26.506287617519583 -56.26285 -97.146524483476824 50.152472329732412 -56.26285 -85.48562358539607 68.734253874234781 -56.26285 -67.948780069487441 80.97337525384502 -56.26285 -46.750000000000028
+6 0 1 -14.722431864335487 -56.26285 -8.4999999999999947 -80.973375253845049 -56.26285 -46.75
+6 0 1 -2.9309887850104115e-15 -51.040450000000007 93.500000000000014 -2.9309887850104115e-15 -51.040450000000007 127.50000000000001
+6 0 8 -2.9309887850104115e-15 -51.04045 127.50000000000001 -33.379421944391552 -51.04045 127.50000000000001 -66.758843888783105 -51.04045 117.51290030842149 -96.652110386315556 -51.04045 97.538700925264465 -119.57399150806459 -51.04045 69.036076185259134 -132.79704804656953 -51.04045 34.933832461294855 -135.14857888387277 -51.04045 -0.94159541924501866 -127.10794995471173 -51.04045 -34.842572632517111 -110.41823898251596 -51.04045 -63.749999999999943
+6 0 8 -14.722431864335466 -56.26285 -8.5 -16.947726660628234 -56.26285 -4.6456763510022876 -18.019810517849706 -56.26285 -0.12554605589934109 -17.706273072875941 -56.26285 4.6578443281726427 -15.943198867741952 -56.26285 9.2048101580345474 -12.88694805150875 -56.26285 13.00516012336859 -8.9011791851710917 -56.26285 15.668386707789526 -4.4505895925855539 -56.26285 16.999999999999996 -1.5987211554602254e-14 -56.26285 16.999999999999996
+6 0 8 -2.9309887850104115e-15 -56.26285 93.500000000000014 -24.478242759220478 -56.26285 93.500000000000014 -48.956485518440957 -56.26285 86.176126892842433 -70.878214283298092 -56.26285 71.52838067852727 -87.687593772580726 -56.26285 50.626455869190032 -97.384501900817682 -56.26285 25.618143804949558 -99.108957848173404 -56.26285 -0.69050330744635247 -93.212496633455316 -56.26285 -25.551219930512556 -80.973375253845106 -56.26285 -46.749999999999972
+6 0 1 -2.989358842512663e-14 -56.26285 93.5 -2.3853975171165778e-14 -56.26285 16.999999999999986
+6 0 1 110.41823898251592 -54.52205 -63.750000000000007 110.41823898251592 -51.04045 -63.750000000000007
+6 0 1 -110.41823898251596 -54.52205 -63.749999999999929 -110.41823898251596 -51.04045 -63.749999999999929
+6 0 8 -110.41823898251594 -54.52205 -63.750000000000021 -93.728528010320161 -54.52205 -92.657427367482867 -68.38973499508964 -54.52205 -116.57130488917645 -36.144937660253959 -54.52205 -132.47253338655929 7.1054273576010019e-15 -54.52205 -138.07215237051824 36.144937660253987 -54.52205 -132.47253338655929 68.389734995089668 -54.52205 -116.57130488917645 93.728528010320176 -54.52205 -92.657427367482867 110.41823898251596 -54.52205 -63.750000000000036
+6 0 8 110.41823898251593 -51.040450000000007 -63.750000000000014 127.1079499547117 -51.040450000000007 -34.842572632517161 135.14857888387274 -51.040450000000007 -0.94159541924504708 132.7970480465695 -51.040450000000007 34.933832461294841 119.57399150806457 -51.040450000000007 69.03607618525912 96.652110386315513 -51.040450000000007 97.538700925264465 66.758843888783076 -51.040450000000007 117.51290030842151 33.379421944391524 -51.040450000000007 127.50000000000003 -2.8421709430404007e-14 -51.040450000000007 127.50000000000004
+6 0 8 -2.0834168544185351e-14 -56.26285 16.999999999999986 4.4505895925855201 -56.26285 16.999999999999986 8.9011791851710598 -56.26285 15.668386707789518 12.886948051508719 -56.26285 13.005160123368579 15.943198867741927 -56.26285 9.204810158034535 17.70627307287592 -56.26285 4.6578443281726329 18.019810517849685 -56.26285 -0.12554605589934997 16.947726660628213 -56.26285 -4.6456763510022965 14.722431864335444 -56.26285 -8.5000000000000089
+6 0 8 80.973375253845006 -56.26285 -46.750000000000014 93.212496633455245 -56.26285 -25.551219930512591 99.108957848173347 -56.26285 -0.69050330744637733 97.384501900817639 -56.26285 25.61814380494954 87.687593772580698 -56.26285 50.626455869190011 70.878214283298064 -56.26285 71.52838067852727 48.956485518440942 -56.26285 86.176126892842433 24.478242759220471 -56.26285 93.500000000000014 -3.5527136788005009e-15 -56.26285 93.500000000000028
+6 0 1 80.973375253845006 -56.26285 -46.750000000000014 80.973375253845006 -58.00365 -46.750000000000014
+6 0 8 -80.973375253845035 -58.00365 -46.750000000000014 -68.734253874234795 -58.00365 -67.948780069487441 -50.152472329732419 -58.00365 -85.48562358539607 -26.506287617519583 -58.00365 -97.146524483476824 -3.5527136788005009e-15 -58.00365 -101.25291173838005 26.506287617519583 -58.00365 -97.146524483476824 50.152472329732412 -58.00365 -85.48562358539607 68.734253874234781 -58.00365 -67.948780069487441 80.97337525384502 -58.00365 -46.750000000000028
+6 0 1 -80.973375253845063 -56.26285 -46.749999999999986 -80.973375253845063 -58.00365 -46.749999999999986
+6 0 1 -1.4210854715202004e-14 -54.52205 127.50000000000006 -1.4210854715202004e-14 -51.04045 127.50000000000006
+6 0 8 -2.9309887850104115e-15 -54.52205 127.50000000000001 -33.379421944391552 -54.52205 127.50000000000001 -66.758843888783105 -54.52205 117.51290030842149 -96.652110386315556 -54.52205 97.538700925264465 -119.57399150806459 -54.52205 69.036076185259134 -132.79704804656953 -54.52205 34.933832461294855 -135.14857888387277 -54.52205 -0.94159541924501866 -127.10794995471173 -54.52205 -34.842572632517111 -110.41823898251596 -54.52205 -63.749999999999943
+6 0 8 -2.9309887850104115e-15 -58.00365 93.500000000000014 -24.478242759220478 -58.00365 93.500000000000014 -48.956485518440957 -58.00365 86.176126892842433 -70.878214283298092 -58.00365 71.52838067852727 -87.687593772580726 -58.00365 50.626455869190032 -97.384501900817682 -58.00365 25.618143804949558 -99.108957848173404 -58.00365 -0.69050330744635247 -93.212496633455316 -58.00365 -25.551219930512556 -80.973375253845106 -58.00365 -46.749999999999972
+6 0 1 -2.9309887850104115e-15 -56.26285 93.500000000000014 -2.9309887850104115e-15 -58.00365 93.500000000000014
+6 0 1 -110.41823898251596 -54.52205 -63.749999999999929 -110.41823898251596 -58.00365 -63.749999999999929
+6 0 8 -110.41823898251594 -58.00365 -63.750000000000021 -93.728528010320161 -58.00365 -92.657427367482867 -68.38973499508964 -58.00365 -116.57130488917645 -36.144937660253959 -58.00365 -132.47253338655929 7.1054273576010019e-15 -58.00365 -138.07215237051824 36.144937660253987 -58.00365 -132.47253338655929 68.389734995089668 -58.00365 -116.57130488917645 93.728528010320176 -58.00365 -92.657427367482867 110.41823898251596 -58.00365 -63.750000000000036
+6 0 1 110.41823898251592 -54.52205 -63.750000000000007 110.41823898251592 -58.00365 -63.750000000000007
+6 0 8 110.41823898251592 -54.52205 -63.750000000000007 127.10794995471169 -54.52205 -34.842572632517161 135.14857888387272 -54.52205 -0.94159541924504708 132.79704804656947 -54.52205 34.933832461294841 119.57399150806454 -54.52205 69.03607618525912 96.652110386315499 -54.52205 97.538700925264465 66.758843888783062 -54.52205 117.51290030842151 33.379421944391524 -54.52205 127.50000000000003 -1.4210854715202004e-14 -54.52205 127.50000000000004
+6 0 8 80.973375253845006 -58.00365 -46.750000000000014 93.212496633455245 -58.00365 -25.551219930512591 99.108957848173347 -58.00365 -0.69050330744637733 97.384501900817639 -58.00365 25.61814380494954 87.687593772580698 -58.00365 50.626455869190011 70.878214283298064 -58.00365 71.52838067852727 48.956485518440942 -58.00365 86.176126892842433 24.478242759220471 -58.00365 93.500000000000014 -3.5527136788005009e-15 -58.00365 93.500000000000028
+6 0 1 80.973375253845035 -58.00365 -46.750000000000014 110.41823898251594 -58.00365 -63.750000000000028
+6 0 1 -80.973375253845035 -58.00365 -46.750000000000014 -110.41823898251594 -58.00365 -63.750000000000021
+6 0 1 -1.4210854715202004e-14 -54.52205 127.50000000000006 -1.4210854715202004e-14 -58.00365 127.50000000000006
+6 0 8 -2.9309887850104115e-15 -58.00365 127.50000000000001 -33.379421944391552 -58.00365 127.50000000000001 -66.758843888783105 -58.00365 117.51290030842149 -96.652110386315556 -58.00365 97.538700925264465 -119.57399150806459 -58.00365 69.036076185259134 -132.79704804656953 -58.00365 34.933832461294855 -135.14857888387277 -58.00365 -0.94159541924501866 -127.10794995471173 -58.00365 -34.842572632517111 -110.41823898251596 -58.00365 -63.749999999999943
+6 0 1 -2.9309887850104115e-15 -58.00365 93.500000000000014 -2.9309887850104115e-15 -58.00365 127.50000000000001
+6 0 8 110.41823898251593 -58.00365 -63.750000000000014 127.1079499547117 -58.00365 -34.842572632517161 135.14857888387274 -58.00365 -0.94159541924504708 132.7970480465695 -58.00365 34.933832461294841 119.57399150806457 -58.00365 69.03607618525912 96.652110386315513 -58.00365 97.538700925264465 66.758843888783076 -58.00365 117.51290030842151 33.379421944391524 -58.00365 127.50000000000003 -2.8421709430404007e-14 -58.00365 127.50000000000004
+6 0 8 14.722431864335434 53.395649999999996 -8.4999999999999947 12.497137068042665 53.395649999999996 -12.354323648997708 9.1186313326785999 53.395649999999996 -15.542840651890188 4.8193250213671766 53.395649999999996 -17.663004451541237 -2.042810365310288e-14 53.395649999999996 -18.409620316069098 -4.8193250213672156 53.395649999999996 -17.663004451541241 -9.118631332678639 53.395649999999996 -15.542840651890197 -12.497137068042708 53.395649999999996 -12.354323648997722 -14.72243186433548 53.395649999999996 -8.5000000000000124
+6 0 1 80.973375253845006 53.395649999999996 -46.749999999999979 14.722431864335448 53.395649999999996 -8.4999999999999858
+6 0 8 -80.973375253845035 53.395649999999996 -46.750000000000014 -68.734253874234795 53.395649999999996 -67.948780069487441 -50.152472329732419 53.395649999999996 -85.48562358539607 -26.506287617519583 53.395649999999996 -97.146524483476824 -3.5527136788005009e-15 53.395649999999996 -101.25291173838005 26.506287617519583 53.395649999999996 -97.146524483476824 50.152472329732412 53.395649999999996 -85.48562358539607 68.734253874234781 53.395649999999996 -67.948780069487441 80.97337525384502 53.395649999999996 -46.750000000000028
+6 0 1 -80.973375253845035 53.395649999999996 -46.750000000000007 -14.722431864335476 53.395649999999996 -8.5
+6 0 6 17.963793053708894 53.395649999999996 -38.51686610106924 19.325050135922247 53.395649999999996 -37.881988158317171 20.632317934975134 53.395649999999996 -37.62154483343199 21.928205733347475 53.395649999999996 -37.551694951930187 23.219010125237126 53.395649999999996 -37.725755088530484 24.518670083034959 53.395649999999996 -38.115448355532784 25.806575110505548 53.395649999999996 -38.859020669831779
+6 0 6 -21.783947886687663 53.395649999999996 -36.492596647049801 -15.382592051727595 53.395649999999996 -40.313831891781746 -8.7448524062295299 53.395649999999996 -42.448854541204113 -2.1993502104915326 53.395649999999996 -43.307173989348712 4.3982503007192904 53.395649999999996 -43.115758746088964 11.213827403926311 53.395649999999996 -41.664988789565832 17.963793053663515 53.395649999999996 -38.516866101098806
+6 0 6 -30.390737344689413 53.395649999999996 -36.429900127375028 -28.942803657204202 53.395649999999996 -35.593935223138992 -27.488983650081149 53.395649999999996 -35.210440596455349 -26.061493808880236 53.395649999999996 -35.07577832632014 -24.644359998184321 53.395649999999996 -35.247916886058647 -23.231458522755112 53.395649999999996 -35.628517408923003 -21.783947885827992 53.395649999999996 -36.4925966455029
+6 0 5 -54.480094359665927 53.395649999999996 -50.337896885374576 -49.662610658302711 53.395649999999996 -47.55652137357589 -44.842788296843104 53.395649999999996 -44.773795946185949 -40.028378752329012 53.395649999999996 -41.994194676535081 -35.207200980592596 53.395649999999996 -39.210686698282771 -30.390737347995838 53.395649999999996 -36.429900123460989
+6 0 10 -55.811215946873176 53.395649999999996 -64.110125360285494 -57.507315151767912 53.395649999999996 -62.633582330093247 -58.312262274433138 53.395649999999996 -61.05888577382548 -58.836622214973971 53.395649999999996 -59.624814511613515 -58.95498559206375 53.395649999999996 -58.208830702663143 -59.025969789724662 53.395649999999996 -56.84333102342066 -58.688806880000634 53.395649999999996 -55.518457083168251 -58.315370196291923 53.395649999999996 -54.132665966998374 -57.48673240282281 53.395649999999996 -52.824100706118259 -56.415406922066886 53.395649999999996 -51.455250079460178 -54.480094377646211 53.395649999999996 -50.337896860966111
+6 0 8 51.76910757101993 53.395649999999996 -67.416150555130315 38.413225334849059 53.395649999999996 -77.672250904933378 24.289905435490731 53.395649999999996 -83.709637934276799 10.63373891132604 53.395649999999996 -86.54744246652929 -2.6122230769890002 53.395649999999996 -87.194494811110616 -15.803202296550385 53.395649999999996 -85.759032342770709 -29.288049543309594 53.395649999999996 -82.105834260754236 -43.062527154343485 53.395649999999996 -75.208525458000864 -55.811215946987737 53.395649999999996 -64.110125360657264
+6 0 10 50.842166738034273 53.395649999999996 -53.313326238346029 52.899090852098141 53.395649999999996 -54.500891929311045 53.966020339367141 53.395649999999996 -55.963462756297147 54.801280163383041 53.395649999999996 -57.322256754356715 55.111951242602601 53.395649999999996 -58.767836906617163 55.438138973761816 53.395649999999996 -60.118663371545082 55.28920405219818 53.395649999999996 -61.50907543100535 55.134421669819353 53.395649999999996 -62.949505880436305 54.527012824617593 53.395649999999996 -64.388109988236522 53.636338431028229 53.395649999999996 -65.982287420677679 51.769107567896192 53.395649999999996 -67.416150550800239
+6 0 5 25.806575201703126 53.395649999999996 -38.859020570241043 30.811719210463643 53.395649999999996 -41.748741811031763 35.823367691252983 53.395649999999996 -44.642218803291613 40.825835651255034 53.395649999999996 -47.530394720270792 45.835512478872467 53.395649999999996 -50.42273305411544 50.842166737969336 53.395649999999996 -53.313326238344402
+6 0 8 -14.722431864335464 53.395649999999996 -8.4999999999999982 -16.947726660628234 53.395649999999996 -4.6456763510022858 -18.019810517849706 53.395649999999996 -0.12554605589933931 -17.706273072875941 53.395649999999996 4.6578443281726445 -15.943198867741952 53.395649999999996 9.2048101580345492 -12.88694805150875 53.395649999999996 13.005160123368594 -8.9011791851710917 53.395649999999996 15.66838670778953 -4.4505895925855539 53.395649999999996 17 -1.5987211554602254e-14 53.395649999999996 17
+6 0 8 -2.6645352591003741e-15 53.395649999999996 93.500000000000014 -24.478242759220478 53.395649999999996 93.500000000000014 -48.956485518440957 53.395649999999996 86.176126892842433 -70.878214283298092 53.395649999999996 71.52838067852727 -87.687593772580726 53.395649999999996 50.626455869190032 -97.384501900817682 53.395649999999996 25.618143804949558 -99.108957848173404 53.395649999999996 -0.69050330744635247 -93.212496633455316 53.395649999999996 -25.551219930512556 -80.973375253845106 53.395649999999996 -46.749999999999972
+6 0 1 -2.9627134899216595e-14 53.395649999999996 93.5 -2.3587521645255743e-14 53.395649999999996 16.999999999999986
+6 0 6 -42.33848104454411 53.395649999999996 3.7013319176962658 -42.469289158925093 53.395649999999996 2.2050097320419852 -42.89737252285488 53.395649999999996 0.94266094607022333 -43.484824650209156 53.395649999999996 -0.21453574852541268 -44.280967346236025 53.395649999999996 -1.245375074918228 -45.268281594042683 53.395649999999996 -2.1760669811514131 -46.556186621511692 53.395649999999996 -2.9196392954531438
+6 0 6 -20.711541803060143 53.395649999999996 37.111750588112741 -27.221506516314491 53.395649999999996 33.478631438739555 -32.389360191118456 53.395649999999996 28.797691606742305 -36.40543773564292 53.395649999999996 23.558280148778675 -39.538467527913809 53.395649999999996 17.748882880419032 -41.689852442121044 53.395649999999996 11.121034989328631 -42.338481044547038 53.395649999999996 3.7013319177503679
+6 0 6 -16.35385029529203 53.395649999999996 44.534100643928966 -16.353850295294002 53.395649999999996 42.862170835453476 -16.748644209932667 53.395649999999996 41.411378463413016 -17.345768183664752 53.395649999999996 40.107804862221208 -18.20341145471712 53.395649999999996 38.966600261465949 -19.239471913925897 53.395649999999996 37.933291952131917 -20.711541802150315 53.395649999999996 37.111750586594788
+6 0 5 -16.353850295982998 53.395649999999996 72.350094158731281 -16.353850295982998 53.395649999999996 66.787343135133909 -16.353850564836204 53.395649999999996 61.221891814686614 -16.353850025184119 53.395649999999996 55.662690210089707 -16.353850290249166 53.395649999999996 50.095673794478962 -16.353850290249166 53.395649999999996 44.534100644835398
+6 0 10 -27.615389228375658 53.395649999999996 80.388993506234087 -25.488615852000951 53.395649999999996 81.119586989915391 -23.72241506968858 53.395649999999996 81.029343368712773 -22.218292955505387 53.395649999999996 80.766416766842042 -20.932833317062023 53.395649999999996 80.16093055380432 -19.714783807148077 53.395649999999996 79.539654832624691 -18.73599077293952 53.395649999999996 78.5852262174636 -17.72257880385197 53.395649999999996 77.568925004581899 -17.003646942154539 53.395649999999996 76.19702099446171 -16.353850265860359 53.395649999999996 74.584800599076473 -16.353850265854504 53.395649999999996 72.350094162098515
+6 0 8 -84.268652791609227 53.395649999999996 -11.125287010187405 -86.472755120215709 53.395649999999996 5.5692964711914126 -84.639625710426614 53.395649999999996 20.819143804481723 -80.269153264249539 53.395649999999996 34.064633198845229 -74.206536038077729 53.395649999999996 45.859498950579749 -66.367899464535569 53.395649999999996 56.565490821342593 -56.46171349707312 53.395649999999996 66.417112062180479 -43.601230050625716 53.395649999999996 74.897505195819136 -27.61538922864035 53.395649999999996 80.388993506519228
+6 0 10 -71.591778251672267 53.395649999999996 -17.373944859408869 -73.648702365742722 53.395649999999996 -18.56151055036247 -75.448790600381201 53.395649999999996 -18.754213176891081 -77.043170633218566 53.395649999999996 -18.798172404219585 -78.45041530789247 53.395649999999996 -18.344431374914624 -79.78335920820399 53.395649999999996 -17.951505004037354 -80.913023912642998 53.395649999999996 -17.12731754872247 -82.083082083045426 53.395649999999996 -16.273056848808654 -83.025245363788187 53.395649999999996 -15.027723304480451 -83.960506321627406 53.395649999999996 -13.459287936911174 -84.268652786297366 53.395649999999996 -11.12528700964716
+6 0 5 -46.556186580862395 53.395649999999996 -2.9196394242279204 -51.561330589622912 53.395649999999996 -5.8093606650186462 -56.572979410580402 53.395649999999996 -8.7028370680899751 -61.575447105283807 53.395649999999996 -11.591013444579877 -66.58512399254154 53.395649999999996 -14.483351675124485 -71.591778251638402 53.395649999999996 -17.373944859353447
+6 0 8 -2.0567715018275316e-14 53.395649999999996 16.999999999999989 4.4505895925855201 53.395649999999996 16.999999999999989 8.9011791851710598 53.395649999999996 15.668386707789521 12.886948051508719 53.395649999999996 13.005160123368583 15.943198867741927 53.395649999999996 9.2048101580345385 17.70627307287592 53.395649999999996 4.6578443281726365 18.019810517849685 53.395649999999996 -0.12554605589934642 16.947726660628213 53.395649999999996 -4.6456763510022929 14.722431864335444 53.395649999999996 -8.5000000000000053
+6 0 8 80.973375253845006 53.395649999999996 -46.750000000000014 93.212496633455245 53.395649999999996 -25.551219930512591 99.108957848173347 53.395649999999996 -0.69050330744637733 97.384501900817639 53.395649999999996 25.61814380494954 87.687593772580698 53.395649999999996 50.626455869190011 70.878214283298064 53.395649999999996 71.52838067852727 48.956485518440942 53.395649999999996 86.176126892842433 24.478242759220471 53.395649999999996 93.500000000000014 -3.5527136788005009e-15 53.395649999999996 93.500000000000028
+6 0 6 24.374687990835163 53.395649999999996 34.815534183372968 23.144239023002793 53.395649999999996 35.676978426275184 22.265054587879696 53.395649999999996 36.678883887361764 21.55661891686163 53.395649999999996 37.766230700455594 21.061957220998849 53.395649999999996 38.971130163448706 20.749611511007675 53.395649999999996 40.291515336684192 20.749611511006094 53.395649999999996 41.778659965284916
+6 0 6 42.495489689747764 53.395649999999996 -0.61915394106294341 42.604098568042048 53.395649999999996 6.8352004530421944 41.134212597347947 53.395649999999996 13.651162934461819 38.604787946134408 53.395649999999996 19.748893840570048 35.140217227194476 53.395649999999996 25.366875865669947 30.476025038194685 53.395649999999996 30.543953800237215 24.374687990883473 53.395649999999996 34.815534183348454
+6 0 6 46.744587639981411 53.395649999999996 -8.1042005165539557 45.296653952498175 53.395649999999996 -7.2682356123145038 44.237627860013788 53.395649999999996 -6.2009378669576876 43.40726199254496 53.395649999999996 -5.0320265359010872 42.847771452901412 53.395649999999996 -3.7186833754073243 42.47093043668098 53.395649999999996 -2.3047745432089366 42.495489687978278 53.395649999999996 -0.61915394109190736
+6 0 5 70.833944655648878 53.395649999999996 -22.012197273356712 66.016460954285662 53.395649999999996 -19.230821761558026 61.196638861679261 53.395649999999996 -16.448095868500673 56.382228777513085 53.395649999999996 -13.668495533554637 51.561051270841716 53.395649999999996 -10.884987096196202 46.744587638244958 53.395649999999996 -8.1042005213744215
+6 0 10 83.426605175248795 53.395649999999996 -16.278868145948589 82.995931003768817 53.395649999999996 -18.486004659822139 82.034677344121675 53.395649999999996 -19.970457594887296 81.054915170479319 53.395649999999996 -21.141602255228538 79.887818909125741 53.395649999999996 -21.952099851141192 78.740753596872707 53.395649999999996 -22.696323809204038 77.424797652940114 53.395649999999996 -23.066769134295352 76.037949000143854 53.395649999999996 -23.436259037583532 74.490379344977299 53.395649999999996 -23.372920288343451 72.769257187927181 53.395649999999996 -23.129550519616277 70.833944643500658 53.395649999999996 -22.012197301132318
+6 0 8 32.499545220589269 53.395649999999996 78.541437565317736 48.059529785366614 53.395649999999996 72.102954433741971 60.349720274935848 53.395649999999996 62.890494129795087 69.635414352923462 53.395649999999996 52.482809267684068 76.818759115066683 53.395649999999996 41.334995860530867 82.171101761085907 53.395649999999996 29.193541521428131 85.749763040382661 53.395649999999996 15.68872219857378 86.663757204969144 53.395649999999996 0.31102026218176171 83.426605175628026 53.395649999999996 -16.278868145861914
+6 0 10 20.749611513637966 53.395649999999996 70.687271097754902 20.749611513644556 53.395649999999996 73.062402479673523 21.482770261014036 53.395649999999996 74.717675933188232 22.241890469835496 53.395649999999996 76.1204291585763 23.338464065289845 53.395649999999996 77.112268281531783 24.345220234442145 53.395649999999996 78.070168375582426 25.623819860444794 53.395649999999996 78.636392979727802 26.948660413226051 53.395649999999996 79.222562729244942 28.498232539170569 53.395649999999996 79.415833292716968 30.32416789059916 53.395649999999996 79.44157535758886 32.499545218401209 53.395649999999996 78.541437560447406
+6 0 5 20.749611379159216 53.395649999999996 41.77865999446896 20.749611379159216 53.395649999999996 47.558102476050408 20.749611719327365 53.395649999999996 53.345055871381589 20.749611454028724 53.395649999999996 59.121408164850671 20.749611513669027 53.395649999999996 64.906084729239922 20.749611513669024 53.395649999999996 70.687271097697845
+6 0 1 80.973375253845006 53.395649999999996 -46.750000000000014 80.973375253845006 51.654849999999996 -46.750000000000014
+6 0 8 -80.973375253845035 51.654849999999996 -46.750000000000014 -68.734253874234795 51.654849999999996 -67.948780069487441 -50.152472329732419 51.654849999999996 -85.48562358539607 -26.506287617519583 51.654849999999996 -97.146524483476824 -3.5527136788005009e-15 51.654849999999996 -101.25291173838005 26.506287617519583 51.654849999999996 -97.146524483476824 50.152472329732412 51.654849999999996 -85.48562358539607 68.734253874234781 51.654849999999996 -67.948780069487441 80.97337525384502 51.654849999999996 -46.750000000000028
+6 0 1 -80.973375253845035 53.395649999999996 -46.750000000000014 -80.973375253845035 51.654849999999996 -46.750000000000014
+6 0 1 25.806575110505548 56.877249999999997 -38.859020669831764 25.806575110505548 53.395649999999996 -38.859020669831764
+6 0 6 17.963793053708894 56.877249999999997 -38.51686610106924 19.325050135922247 56.877249999999997 -37.881988158317171 20.632317934975134 56.877249999999997 -37.62154483343199 21.928205733347475 56.877249999999997 -37.551694951930187 23.219010125237126 56.877249999999997 -37.725755088530484 24.518670083034959 56.877249999999997 -38.115448355532784 25.806575110505548 56.877249999999997 -38.859020669831779
+6 0 1 17.963793053663508 56.877249999999997 -38.516866101098806 17.963793053663508 53.395649999999996 -38.516866101098806
+6 0 1 -21.783947885827992 56.877249999999997 -36.4925966455029 -21.783947885827992 53.395649999999996 -36.4925966455029
+6 0 6 -30.390737344689413 56.877249999999997 -36.429900127375028 -28.942803657204202 56.877249999999997 -35.593935223138992 -27.488983650081149 56.877249999999997 -35.210440596455349 -26.061493808880236 56.877249999999997 -35.07577832632014 -24.644359998184321 56.877249999999997 -35.247916886058647 -23.231458522755112 56.877249999999997 -35.628517408923003 -21.783947885827992 56.877249999999997 -36.4925966455029
+6 0 1 -30.390737344689413 56.877249999999997 -36.429900127375028 -30.390737344689413 53.395649999999996 -36.429900127375028
+6 0 6 -21.783947886687663 56.877249999999997 -36.492596647049801 -15.382592051727595 56.877249999999997 -40.313831891781746 -8.7448524062295299 56.877249999999997 -42.448854541204113 -2.1993502104915326 56.877249999999997 -43.307173989348712 4.3982503007192904 56.877249999999997 -43.115758746088964 11.213827403926311 56.877249999999997 -41.664988789565832 17.963793053663515 56.877249999999997 -38.516866101098806
+6 0 5 -54.480094359665927 56.877249999999997 -50.337896885374576 -49.662610658302711 56.877249999999997 -47.55652137357589 -44.842788296843104 56.877249999999997 -44.773795946185949 -40.028378752329012 56.877249999999997 -41.994194676535081 -35.207200980592596 56.877249999999997 -39.210686698282771 -30.390737347995838 56.877249999999997 -36.429900123460989
+6 0 1 -54.480094377646296 56.877249999999997 -50.337896860966111 -54.480094377646296 53.395649999999996 -50.337896860966111
+6 0 10 -55.811215946873176 56.877249999999997 -64.110125360285494 -57.507315151767912 56.877249999999997 -62.633582330093247 -58.312262274433138 56.877249999999997 -61.05888577382548 -58.836622214973971 56.877249999999997 -59.624814511613515 -58.95498559206375 56.877249999999997 -58.208830702663143 -59.025969789724662 56.877249999999997 -56.84333102342066 -58.688806880000634 56.877249999999997 -55.518457083168251 -58.315370196291923 56.877249999999997 -54.132665966998374 -57.48673240282281 56.877249999999997 -52.824100706118259 -56.415406922066886 56.877249999999997 -51.455250079460178 -54.480094377646211 56.877249999999997 -50.337896860966111
+6 0 1 -55.811215946873176 56.877249999999997 -64.110125360285494 -55.811215946873176 53.395649999999996 -64.110125360285494
+6 0 8 51.76910757101993 56.877249999999997 -67.416150555130315 38.413225334849059 56.877249999999997 -77.672250904933378 24.289905435490731 56.877249999999997 -83.709637934276799 10.63373891132604 56.877249999999997 -86.54744246652929 -2.6122230769890002 56.877249999999997 -87.194494811110616 -15.803202296550385 56.877249999999997 -85.759032342770709 -29.288049543309594 56.877249999999997 -82.105834260754236 -43.062527154343485 56.877249999999997 -75.208525458000864 -55.811215946987737 56.877249999999997 -64.110125360657264
+6 0 1 51.769107567896185 56.877249999999997 -67.416150550800268 51.769107567896185 53.395649999999996 -67.416150550800268
+6 0 10 50.842166738034273 56.877249999999997 -53.313326238346029 52.899090852098141 56.877249999999997 -54.500891929311045 53.966020339367141 56.877249999999997 -55.963462756297147 54.801280163383041 56.877249999999997 -57.322256754356715 55.111951242602601 56.877249999999997 -58.767836906617163 55.438138973761816 56.877249999999997 -60.118663371545082 55.28920405219818 56.877249999999997 -61.50907543100535 55.134421669819353 56.877249999999997 -62.949505880436305 54.527012824617593 56.877249999999997 -64.388109988236522 53.636338431028229 56.877249999999997 -65.982287420677679 51.769107567896192 56.877249999999997 -67.416150550800239
+6 0 1 50.842166738034273 56.877249999999997 -53.313326238346029 50.842166738034273 53.395649999999996 -53.313326238346029
+6 0 5 25.806575201703126 56.877249999999997 -38.859020570241043 30.811719210463643 56.877249999999997 -41.748741811031763 35.823367691252983 56.877249999999997 -44.642218803291613 40.825835651255034 56.877249999999997 -47.530394720270792 45.835512478872467 56.877249999999997 -50.42273305411544 50.842166737969336 56.877249999999997 -53.313326238344402
+6 0 8 -2.6645352591003741e-15 51.654849999999996 93.500000000000014 -24.478242759220478 51.654849999999996 93.500000000000014 -48.956485518440957 51.654849999999996 86.176126892842433 -70.878214283298092 51.654849999999996 71.52838067852727 -87.687593772580726 51.654849999999996 50.626455869190032 -97.384501900817682 51.654849999999996 25.618143804949558 -99.108957848173404 51.654849999999996 -0.69050330744635247 -93.212496633455316 51.654849999999996 -25.551219930512556 -80.973375253845106 51.654849999999996 -46.749999999999972
+6 0 1 -1.4210854715202004e-14 53.395649999999996 93.499999999999986 -1.4210854715202004e-14 51.654849999999996 93.499999999999986
+6 0 1 -46.556186580862395 56.877249999999997 -2.9196394242279204 -46.556186580862395 53.395649999999996 -2.9196394242279204
+6 0 6 -42.33848104454411 56.877249999999997 3.7013319176962658 -42.469289158925093 56.877249999999997 2.2050097320419852 -42.89737252285488 56.877249999999997 0.94266094607022333 -43.484824650209156 56.877249999999997 -0.21453574852541268 -44.280967346236025 56.877249999999997 -1.245375074918228 -45.268281594042683 56.877249999999997 -2.1760669811514131 -46.556186621511692 56.877249999999997 -2.9196392954531438
+6 0 1 -42.338481044547038 56.877249999999997 3.7013319177503661 -42.338481044547038 53.395649999999996 3.7013319177503661
+6 0 6 -20.711541803060143 56.877249999999997 37.111750588112741 -27.221506516314491 56.877249999999997 33.478631438739555 -32.389360191118456 56.877249999999997 28.797691606742305 -36.40543773564292 56.877249999999997 23.558280148778675 -39.538467527913809 56.877249999999997 17.748882880419032 -41.689852442121044 56.877249999999997 11.121034989328631 -42.338481044547038 56.877249999999997 3.7013319177503679
+6 0 1 -20.711541802150311 56.877249999999997 37.111750586594795 -20.711541802150311 53.395649999999996 37.111750586594795
+6 0 6 -16.35385029529203 56.877249999999997 44.534100643928966 -16.353850295294002 56.877249999999997 42.862170835453476 -16.748644209932667 56.877249999999997 41.411378463413016 -17.345768183664752 56.877249999999997 40.107804862221208 -18.20341145471712 56.877249999999997 38.966600261465949 -19.239471913925897 56.877249999999997 37.933291952131917 -20.711541802150315 56.877249999999997 37.111750586594788
+6 0 1 -16.35385029529203 56.877249999999997 44.534100643928966 -16.35385029529203 53.395649999999996 44.534100643928966
+6 0 5 -16.353850295982998 56.877249999999997 72.350094158731281 -16.353850295982998 56.877249999999997 66.787343135133909 -16.353850564836204 56.877249999999997 61.221891814686614 -16.353850025184119 56.877249999999997 55.662690210089707 -16.353850290249166 56.877249999999997 50.095673794478962 -16.353850290249166 56.877249999999997 44.534100644835398
+6 0 1 -16.353850295982998 56.877249999999997 72.350094158731281 -16.353850295982998 53.395649999999996 72.350094158731281
+6 0 10 -27.615389228375658 56.877249999999997 80.388993506234087 -25.488615852000951 56.877249999999997 81.119586989915391 -23.72241506968858 56.877249999999997 81.029343368712773 -22.218292955505387 56.877249999999997 80.766416766842042 -20.932833317062023 56.877249999999997 80.16093055380432 -19.714783807148077 56.877249999999997 79.539654832624691 -18.73599077293952 56.877249999999997 78.5852262174636 -17.72257880385197 56.877249999999997 77.568925004581899 -17.003646942154539 56.877249999999997 76.19702099446171 -16.353850265860359 56.877249999999997 74.584800599076473 -16.353850265854504 56.877249999999997 72.350094162098515
+6 0 1 -27.615389228375658 56.877249999999997 80.388993506234087 -27.615389228375658 53.395649999999996 80.388993506234087
+6 0 8 -84.268652791609227 56.877249999999997 -11.125287010187405 -86.472755120215709 56.877249999999997 5.5692964711914126 -84.639625710426614 56.877249999999997 20.819143804481723 -80.269153264249539 56.877249999999997 34.064633198845229 -74.206536038077729 56.877249999999997 45.859498950579749 -66.367899464535569 56.877249999999997 56.565490821342593 -56.46171349707312 56.877249999999997 66.417112062180479 -43.601230050625716 56.877249999999997 74.897505195819136 -27.61538922864035 56.877249999999997 80.388993506519228
+6 0 1 -84.268652791609227 56.877249999999997 -11.125287010187405 -84.268652791609227 53.395649999999996 -11.125287010187405
+6 0 10 -71.591778251672267 56.877249999999997 -17.373944859408869 -73.648702365742722 56.877249999999997 -18.56151055036247 -75.448790600381201 56.877249999999997 -18.754213176891081 -77.043170633218566 56.877249999999997 -18.798172404219585 -78.45041530789247 56.877249999999997 -18.344431374914624 -79.78335920820399 56.877249999999997 -17.951505004037354 -80.913023912642998 56.877249999999997 -17.12731754872247 -82.083082083045426 56.877249999999997 -16.273056848808654 -83.025245363788187 56.877249999999997 -15.027723304480451 -83.960506321627406 56.877249999999997 -13.459287936911174 -84.268652786297366 56.877249999999997 -11.12528700964716
+6 0 1 -71.591778251638402 56.877249999999997 -17.373944859353447 -71.591778251638402 53.395649999999996 -17.373944859353447
+6 0 5 -46.556186580862395 56.877249999999997 -2.9196394242279204 -51.561330589622912 56.877249999999997 -5.8093606650186462 -56.572979410580402 56.877249999999997 -8.7028370680899751 -61.575447105283807 56.877249999999997 -11.591013444579877 -66.58512399254154 56.877249999999997 -14.483351675124485 -71.591778251638402 56.877249999999997 -17.373944859353447
+6 0 8 80.973375253845006 51.654850000000003 -46.750000000000014 93.212496633455245 51.654850000000003 -25.551219930512591 99.108957848173347 51.654850000000003 -0.69050330744637733 97.384501900817639 51.654850000000003 25.61814380494954 87.687593772580698 51.654850000000003 50.626455869190011 70.878214283298064 51.654850000000003 71.52838067852727 48.956485518440942 51.654850000000003 86.176126892842433 24.478242759220471 51.654850000000003 93.500000000000014 -3.5527136788005009e-15 51.654850000000003 93.500000000000028
+6 0 1 20.749611379159216 56.877249999999997 41.77865999446896 20.749611379159216 53.395649999999996 41.77865999446896
+6 0 6 24.374687990835163 56.877249999999997 34.815534183372968 23.144239023002793 56.877249999999997 35.676978426275184 22.265054587879696 56.877249999999997 36.678883887361764 21.55661891686163 56.877249999999997 37.766230700455594 21.061957220998849 56.877249999999997 38.971130163448706 20.749611511007675 56.877249999999997 40.291515336684192 20.749611511006094 56.877249999999997 41.778659965284916
+6 0 1 24.374687990883476 56.877249999999997 34.815534183348454 24.374687990883476 53.395649999999996 34.815534183348454
+6 0 6 42.495489689747764 56.877249999999997 -0.61915394106294341 42.604098568042048 56.877249999999997 6.8352004530421944 41.134212597347947 56.877249999999997 13.651162934461819 38.604787946134408 56.877249999999997 19.748893840570048 35.140217227194476 56.877249999999997 25.366875865669947 30.476025038194685 56.877249999999997 30.543953800237215 24.374687990883473 56.877249999999997 34.815534183348454
+6 0 1 42.495489687978271 56.877249999999997 -0.61915394109190647 42.495489687978271 53.395649999999996 -0.61915394109190647
+6 0 6 46.744587639981411 56.877249999999997 -8.1042005165539557 45.296653952498175 56.877249999999997 -7.2682356123145038 44.237627860013788 56.877249999999997 -6.2009378669576876 43.40726199254496 56.877249999999997 -5.0320265359010872 42.847771452901412 56.877249999999997 -3.7186833754073243 42.47093043668098 56.877249999999997 -2.3047745432089366 42.495489687978278 56.877249999999997 -0.61915394109190736
+6 0 1 46.744587639981411 56.877249999999997 -8.1042005165539557 46.744587639981411 53.395649999999996 -8.1042005165539557
+6 0 5 70.833944655648878 56.877249999999997 -22.012197273356712 66.016460954285662 56.877249999999997 -19.230821761558026 61.196638861679261 56.877249999999997 -16.448095868500673 56.382228777513085 56.877249999999997 -13.668495533554637 51.561051270841716 56.877249999999997 -10.884987096196202 46.744587638244958 56.877249999999997 -8.1042005213744215
+6 0 1 70.833944655648878 56.877249999999997 -22.012197273356712 70.833944655648878 53.395649999999996 -22.012197273356712
+6 0 10 83.426605175248795 56.877249999999997 -16.278868145948589 82.995931003768817 56.877249999999997 -18.486004659822139 82.034677344121675 56.877249999999997 -19.970457594887296 81.054915170479319 56.877249999999997 -21.141602255228538 79.887818909125741 56.877249999999997 -21.952099851141192 78.740753596872707 56.877249999999997 -22.696323809204038 77.424797652940114 56.877249999999997 -23.066769134295352 76.037949000143854 56.877249999999997 -23.436259037583532 74.490379344977299 56.877249999999997 -23.372920288343451 72.769257187927181 56.877249999999997 -23.129550519616277 70.833944643500658 56.877249999999997 -22.012197301132318
+6 0 1 83.426605175248795 56.877249999999997 -16.278868145948589 83.426605175248795 53.395649999999996 -16.278868145948589
+6 0 1 32.499545220589269 56.877249999999997 78.541437565317736 32.499545220589269 53.395649999999996 78.541437565317736
+6 0 10 20.749611513637966 56.877249999999997 70.687271097754902 20.749611513644556 56.877249999999997 73.062402479673523 21.482770261014036 56.877249999999997 74.717675933188232 22.241890469835496 56.877249999999997 76.1204291585763 23.338464065289845 56.877249999999997 77.112268281531783 24.345220234442145 56.877249999999997 78.070168375582426 25.623819860444794 56.877249999999997 78.636392979727802 26.948660413226051 56.877249999999997 79.222562729244942 28.498232539170569 56.877249999999997 79.415833292716968 30.32416789059916 56.877249999999997 79.44157535758886 32.499545218401209 56.877249999999997 78.541437560447406
+6 0 1 20.749611513637966 56.877249999999997 70.687271097754902 20.749611513637966 53.395649999999996 70.687271097754902
+6 0 8 32.499545220589269 56.877249999999997 78.541437565317736 48.059529785366614 56.877249999999997 72.102954433741971 60.349720274935848 56.877249999999997 62.890494129795087 69.635414352923462 56.877249999999997 52.482809267684068 76.818759115066683 56.877249999999997 41.334995860530867 82.171101761085907 56.877249999999997 29.193541521428131 85.749763040382661 56.877249999999997 15.68872219857378 86.663757204969144 56.877249999999997 0.31102026218176171 83.426605175628026 56.877249999999997 -16.278868145861914
+6 0 5 20.749611379159216 56.877249999999997 41.77865999446896 20.749611379159216 56.877249999999997 47.558102476050408 20.749611719327365 56.877249999999997 53.345055871381589 20.749611454028724 56.877249999999997 59.121408164850671 20.749611513669027 56.877249999999997 64.906084729239922 20.749611513669024 56.877249999999997 70.687271097697845
+6 0 1 80.973375253845006 51.654850000000003 -46.750000000000014 110.41823898251593 51.654850000000003 -63.750000000000014
+6 0 8 -110.41823898251594 51.654850000000003 -63.750000000000021 -93.728528010320161 51.654850000000003 -92.657427367482867 -68.38973499508964 51.654850000000003 -116.57130488917645 -36.144937660253952 51.654850000000003 -132.47253338655929 2.1316282072803006e-14 51.654850000000003 -138.07215237051824 36.144937660254008 51.654850000000003 -132.47253338655929 68.389734995089697 51.654850000000003 -116.57130488917645 93.728528010320218 51.654850000000003 -92.657427367482867 110.41823898251602 51.654850000000003 -63.750000000000028
+6 0 1 -80.973375253845063 51.654850000000003 -46.749999999999986 -110.41823898251599 51.654850000000003 -63.749999999999986
+6 0 1 -80.973375253845035 56.877249999999997 -46.750000000000007 -14.722431864335476 56.877249999999997 -8.5
+6 0 8 -80.973375253845035 56.877249999999997 -46.750000000000014 -68.734253874234795 56.877249999999997 -67.948780069487441 -50.152472329732419 56.877249999999997 -85.48562358539607 -26.506287617519583 56.877249999999997 -97.146524483476824 -3.5527136788005009e-15 56.877249999999997 -101.25291173838005 26.506287617519583 56.877249999999997 -97.146524483476824 50.152472329732412 56.877249999999997 -85.48562358539607 68.734253874234781 56.877249999999997 -67.948780069487441 80.97337525384502 56.877249999999997 -46.750000000000028
+6 0 1 14.722431864335437 56.877249999999997 -8.500000000000016 80.973375253844992 56.877249999999997 -46.750000000000014
+6 0 8 14.722431864335434 56.877249999999997 -8.4999999999999947 12.497137068042665 56.877249999999997 -12.354323648997708 9.1186313326785999 56.877249999999997 -15.542840651890188 4.8193250213671766 56.877249999999997 -17.663004451541237 -2.042810365310288e-14 56.877249999999997 -18.409620316069098 -4.8193250213672156 56.877249999999997 -17.663004451541241 -9.118631332678639 56.877249999999997 -15.542840651890197 -12.497137068042708 56.877249999999997 -12.354323648997722 -14.72243186433548 56.877249999999997 -8.5000000000000124
+6 0 8 -2.6645352591003741e-15 51.654849999999996 127.50000000000001 -33.379421944391552 51.654849999999996 127.50000000000001 -66.758843888783105 51.654849999999996 117.51290030842149 -96.652110386315556 51.654849999999996 97.538700925264465 -119.57399150806459 51.654849999999996 69.036076185259134 -132.79704804656953 51.654849999999996 34.933832461294855 -135.14857888387277 51.654849999999996 -0.94159541924501866 -127.10794995471173 51.654849999999996 -34.842572632517111 -110.41823898251596 51.654849999999996 -63.749999999999943
+6 0 1 -2.6645352591003741e-15 51.654850000000003 93.500000000000014 -2.6645352591003741e-15 51.654850000000003 127.50000000000001
+6 0 1 -2.9627134899216595e-14 56.877249999999997 93.5 -2.3587521645255743e-14 56.877249999999997 16.999999999999986
+6 0 8 -2.6645352591003741e-15 56.877249999999997 93.500000000000014 -24.478242759220478 56.877249999999997 93.500000000000014 -48.956485518440957 56.877249999999997 86.176126892842433 -70.878214283298092 56.877249999999997 71.52838067852727 -87.687593772580726 56.877249999999997 50.626455869190032 -97.384501900817682 56.877249999999997 25.618143804949558 -99.108957848173404 56.877249999999997 -0.69050330744635247 -93.212496633455316 56.877249999999997 -25.551219930512556 -80.973375253845106 56.877249999999997 -46.749999999999972
+6 0 8 -14.722431864335464 56.877249999999997 -8.4999999999999982 -16.947726660628234 56.877249999999997 -4.6456763510022858 -18.019810517849706 56.877249999999997 -0.12554605589933931 -17.706273072875941 56.877249999999997 4.6578443281726445 -15.943198867741952 56.877249999999997 9.2048101580345492 -12.88694805150875 56.877249999999997 13.005160123368594 -8.9011791851710917 56.877249999999997 15.66838670778953 -4.4505895925855539 56.877249999999997 17 -1.5987211554602254e-14 56.877249999999997 17
+6 0 8 110.41823898251592 51.654849999999996 -63.750000000000007 127.10794995471169 51.654849999999996 -34.842572632517161 135.14857888387272 51.654849999999996 -0.94159541924504708 132.79704804656947 51.654849999999996 34.933832461294841 119.57399150806454 51.654849999999996 69.03607618525912 96.652110386315499 51.654849999999996 97.538700925264465 66.758843888783062 51.654849999999996 117.51290030842151 33.379421944391524 51.654849999999996 127.50000000000003 -1.4210854715202004e-14 51.654849999999996 127.50000000000004
+6 0 8 80.973375253845006 56.877249999999997 -46.750000000000014 93.212496633455245 56.877249999999997 -25.551219930512591 99.108957848173347 56.877249999999997 -0.69050330744637733 97.384501900817639 56.877249999999997 25.61814380494954 87.687593772580698 56.877249999999997 50.626455869190011 70.878214283298064 56.877249999999997 71.52838067852727 48.956485518440942 56.877249999999997 86.176126892842433 24.478242759220471 56.877249999999997 93.500000000000014 -3.5527136788005009e-15 56.877249999999997 93.500000000000028
+6 0 8 -2.0567715018275316e-14 56.877249999999997 16.999999999999989 4.4505895925855201 56.877249999999997 16.999999999999989 8.9011791851710598 56.877249999999997 15.668386707789521 12.886948051508719 56.877249999999997 13.005160123368583 15.943198867741927 56.877249999999997 9.2048101580345385 17.70627307287592 56.877249999999997 4.6578443281726365 18.019810517849685 56.877249999999997 -0.12554605589934642 16.947726660628213 56.877249999999997 -4.6456763510022929 14.722431864335444 56.877249999999997 -8.5000000000000053
+6 0 8 -110.41823898251594 55.136449999999996 -63.750000000000021 -93.728528010320161 55.136449999999996 -92.657427367482867 -68.38973499508964 55.136449999999996 -116.57130488917645 -36.144937660253959 55.136449999999996 -132.47253338655929 7.1054273576010019e-15 55.136449999999996 -138.07215237051824 36.144937660253987 55.136449999999996 -132.47253338655929 68.389734995089668 55.136449999999996 -116.57130488917645 93.728528010320176 55.136449999999996 -92.657427367482867 110.41823898251596 55.136449999999996 -63.750000000000036
+6 0 1 -110.41823898251596 55.136449999999996 -63.749999999999929 -110.41823898251596 51.654849999999996 -63.749999999999929
+6 0 1 110.41823898251592 55.136449999999996 -63.750000000000007 110.41823898251592 51.654849999999996 -63.750000000000007
+6 0 1 -80.973375253845063 56.877249999999997 -46.749999999999986 -80.973375253845063 58.618049999999997 -46.749999999999986
+6 0 8 -80.973375253845035 58.618049999999997 -46.750000000000014 -68.734253874234795 58.618049999999997 -67.948780069487441 -50.152472329732419 58.618049999999997 -85.48562358539607 -26.506287617519583 58.618049999999997 -97.146524483476824 -3.5527136788005009e-15 58.618049999999997 -101.25291173838005 26.506287617519583 58.618049999999997 -97.146524483476824 50.152472329732412 58.618049999999997 -85.48562358539607 68.734253874234781 58.618049999999997 -67.948780069487441 80.97337525384502 58.618049999999997 -46.750000000000028
+6 0 1 80.973375253845006 56.877249999999997 -46.750000000000014 80.973375253845006 58.618049999999997 -46.750000000000014
+6 0 8 -2.6645352591003741e-15 55.136449999999996 127.50000000000001 -33.379421944391552 55.136449999999996 127.50000000000001 -66.758843888783105 55.136449999999996 117.51290030842149 -96.652110386315556 55.136449999999996 97.538700925264465 -119.57399150806459 55.136449999999996 69.036076185259134 -132.79704804656953 55.136449999999996 34.933832461294855 -135.14857888387277 55.136449999999996 -0.94159541924501866 -127.10794995471173 55.136449999999996 -34.842572632517111 -110.41823898251596 55.136449999999996 -63.749999999999943
+6 0 1 -1.4210854715202004e-14 55.136449999999996 127.50000000000006 -1.4210854715202004e-14 51.654849999999996 127.50000000000006
+6 0 1 -2.6645352591003741e-15 56.877249999999997 93.500000000000014 -2.6645352591003741e-15 58.618049999999997 93.500000000000014
+6 0 8 -2.6645352591003741e-15 58.618049999999997 93.500000000000014 -24.478242759220478 58.618049999999997 93.500000000000014 -48.956485518440957 58.618049999999997 86.176126892842433 -70.878214283298092 58.618049999999997 71.52838067852727 -87.687593772580726 58.618049999999997 50.626455869190032 -97.384501900817682 58.618049999999997 25.618143804949558 -99.108957848173404 58.618049999999997 -0.69050330744635247 -93.212496633455316 58.618049999999997 -25.551219930512556 -80.973375253845106 58.618049999999997 -46.749999999999972
+6 0 8 110.41823898251592 55.136449999999996 -63.750000000000007 127.10794995471169 55.136449999999996 -34.842572632517161 135.14857888387272 55.136449999999996 -0.94159541924504708 132.79704804656947 55.136449999999996 34.933832461294841 119.57399150806454 55.136449999999996 69.03607618525912 96.652110386315499 55.136449999999996 97.538700925264465 66.758843888783062 55.136449999999996 117.51290030842151 33.379421944391524 55.136449999999996 127.50000000000003 -1.4210854715202004e-14 55.136449999999996 127.50000000000004
+6 0 8 80.973375253845006 58.618049999999997 -46.750000000000014 93.212496633455245 58.618049999999997 -25.551219930512591 99.108957848173347 58.618049999999997 -0.69050330744637733 97.384501900817639 58.618049999999997 25.61814380494954 87.687593772580698 58.618049999999997 50.626455869190011 70.878214283298064 58.618049999999997 71.52838067852727 48.956485518440942 58.618049999999997 86.176126892842433 24.478242759220471 58.618049999999997 93.500000000000014 -3.5527136788005009e-15 58.618049999999997 93.500000000000028
+6 0 1 110.41823898251597 55.136449999999996 -63.750000000000021 110.41823898251597 58.618049999999997 -63.750000000000021
+6 0 8 -110.41823898251594 58.618049999999997 -63.750000000000021 -93.728528010320161 58.618049999999997 -92.657427367482867 -68.38973499508964 58.618049999999997 -116.57130488917645 -36.144937660253952 58.618049999999997 -132.47253338655929 2.1316282072803006e-14 58.618049999999997 -138.07215237051824 36.144937660254008 58.618049999999997 -132.47253338655929 68.389734995089697 58.618049999999997 -116.57130488917645 93.728528010320218 58.618049999999997 -92.657427367482867 110.41823898251602 58.618049999999997 -63.750000000000028
+6 0 1 -110.41823898251594 55.136449999999996 -63.750000000000021 -110.41823898251594 58.618049999999997 -63.750000000000021
+6 0 1 -80.973375253845035 58.618049999999997 -46.750000000000014 -110.41823898251594 58.618049999999997 -63.750000000000021
+6 0 1 80.973375253845006 58.618049999999997 -46.750000000000014 110.41823898251593 58.618049999999997 -63.750000000000014
+6 0 8 -2.6645352591003741e-15 58.618049999999997 127.50000000000001 -33.379421944391552 58.618049999999997 127.50000000000001 -66.758843888783105 58.618049999999997 117.51290030842149 -96.652110386315556 58.618049999999997 97.538700925264465 -119.57399150806459 58.618049999999997 69.036076185259134 -132.79704804656953 58.618049999999997 34.933832461294841 -135.14857888387277 58.618049999999997 -0.94159541924504708 -127.10794995471173 58.618049999999997 -34.842572632517154 -110.41823898251596 58.618049999999997 -63.75
+6 0 1 -2.6645352591003741e-15 55.136449999999996 127.50000000000001 -2.6645352591003741e-15 58.618049999999997 127.50000000000001
+6 0 1 -2.6645352591003741e-15 58.618049999999997 93.500000000000014 -2.6645352591003741e-15 58.618049999999997 127.50000000000001
+6 0 8 110.41823898251593 58.618049999999997 -63.750000000000014 127.1079499547117 58.618049999999997 -34.842572632517161 135.14857888387274 58.618049999999997 -0.94159541924504708 132.7970480465695 58.618049999999997 34.933832461294841 119.57399150806457 58.618049999999997 69.03607618525912 96.652110386315513 58.618049999999997 97.538700925264465 66.758843888783076 58.618049999999997 117.51290030842151 33.379421944391524 58.618049999999997 127.50000000000003 -2.8421709430404007e-14 58.618049999999997 127.50000000000004
+6 0 4 -401.10223388647694 226.09456080824324 760.89099450041851 -401.10223388647239 170.01658653797091 778.63138073645473 -428.12601638766785 104.7680994357133 820.07150468099292 -428.12601638766785 52.384049717856698 820.07150468099292 -428.12601638766785 2.1316282072803006e-13 820.0715046809928
+6 0 8 -401.10223388647694 226.09456080824324 760.89099450041851 -370.87192438948159 216.25112405895413 751.52782175009872 -340.89745863027935 206.53517861453827 741.03702854003211 -311.44606397593424 197.14726097639058 729.46849554928974 -282.44905649651145 188.12977664097926 716.82376279524124 -253.87238541698233 179.47823215055962 703.00622184046358 -225.71073783479289 171.19068463811016 687.88437205409502 -198.07711023188489 163.30552960136956 671.27830339979027 -171.24821807098903 155.88520260558568 652.982055780476
+6 0 4 -171.24821807098903 155.8852026055857 652.98205578047589 -167.85129951810006 114.11857811845341 666.8947674846994 -160.76586835588944 78.648864859896861 683.7630044758871 -160.76586835588949 39.324432429948487 683.7630044758871 -160.76586835588964 2.0605739337042905e-13 683.76300447588699
+6 0 8 -428.1260163876679 1.9895196601282805e-13 820.0715046809928 -388.71884237974234 1.9895196601282805e-13 807.12873664893323 -349.31166837181678 2.0079176416792118e-13 794.18596861687365 -311.16418198278279 2.0418587455748953e-13 779.72946144348998 -275.17774385825658 2.0900107041857807e-13 763.17990988556403 -241.93891669741782 2.1508192052773927e-13 744.65302586759276 -211.7629942798485 2.2213976689857064e-13 724.72012175139685 -184.73753049237152 2.2967738821932931e-13 704.16869360572991 -160.76586835588967 2.3722690478678037e-13 683.7630044758871
+6 0 11 -171.24821807292994 155.88520260010867 652.98205578418992 -161.46508784404722 153.17938735945037 646.31034634125058 -151.99837117002707 150.59060614611693 639.56845827345398 -142.85133599585845 147.93918877558596 632.83301067480295 -134.02424886652145 145.04368637347005 626.18920448016024 -125.49524693795669 141.81827247730681 619.67514548577219 -117.24585889462355 138.21431417874206 613.314736066661 -109.27129636201785 134.18622578439107 607.13485229681419 -101.57392640333696 129.70059380521948 601.15778345235276 -94.161777701188313 124.73804985854521 595.3998854347127 -87.062528047836693 119.25946728372337 589.89208849031763 -80.317168800975836 113.22176793223963 584.66730272526434
+6 0 4 -80.31716880097585 113.22176793223966 584.66730272526422 -85.625458262792037 92.56319279591952 599.11675593107225 -84.688062748027946 45.890661537100179 607.80583425270845 -84.688062748028344 22.945330768550136 607.80583425270788 -84.688062748030504 1.9184653865522705e-13 607.80583425270675
+6 0 11 -160.76586835588961 1.4210854715202004e-13 683.76300447588642 -152.02462436071153 1.446923389184204e-13 676.32208917522189 -143.67421384006158 1.4756680725854082e-13 668.89982593269292 -135.71050183996704 1.5064582578016792e-13 661.52890967157225 -128.12688389800539 1.5384326809108836e-13 654.24172385604766 -120.9144532347199 1.5719604550225075e-13 647.06942091123221 -114.0621679450351 1.6083334760197508e-13 640.04100264317424 -107.55701818967239 1.6421073255376984e-13 633.18240065886789 -101.3841933865655 1.6355401881314307e-13 626.51555678626301 -95.527249402276084 1.4706619760380075e-13 620.05750349427547 -89.968275743409222 8.3973232408011841e-14 613.81944431279715 -84.688062748029154 -1.1635137298071641e-13 607.80583425270618
+6 0 4 -171.24821807098903 -155.8852026055857 652.98205578047589 -167.85129951810006 -114.11857811845341 666.8947674846994 -160.76586835588944 -78.648864859896861 683.7630044758871 -160.76586835588949 -39.324432429948487 683.7630044758871 -160.76586835588964 -2.0605739337042905e-13 683.76300447588699
+6 0 8 -401.10223388647694 -226.09456080824324 760.89099450041851 -370.87192438948159 -216.25112405895413 751.52782175009872 -340.89745863027935 -206.53517861453827 741.03702854003211 -311.44606397593424 -197.14726097639058 729.46849554928974 -282.44905649651145 -188.12977664097926 716.82376279524124 -253.87238541698233 -179.47823215055962 703.00622184046358 -225.71073783479289 -171.19068463811016 687.88437205409502 -198.07711023188489 -163.30552960136956 671.27830339979027 -171.24821807098903 -155.88520260558568 652.982055780476
+6 0 4 -401.10223388647694 -226.09456080824324 760.89099450041851 -401.10223388647239 -170.01658653797091 778.63138073645473 -428.12601638766785 -104.7680994357133 820.07150468099292 -428.12601638766785 -52.384049717856698 820.07150468099292 -428.12601638766785 -2.1316282072803006e-13 820.0715046809928
+6 0 12 -80.317168800975878 113.22176793223966 584.66730272526456 -74.133922824686749 107.68721019337957 579.8779157739657 -68.245585520473256 101.68672180730124 575.3243714721184 -62.684068029539013 95.184424011185584 571.03417924489224 -57.487000677884218 88.155193512565447 567.02520868952797 -52.722082068796766 80.510653763540688 563.36201759685775 -48.445053433215492 72.220219684059217 560.06374441829689 -44.753270306349741 63.189397565290065 557.19001667253508 -41.775219899383394 53.239331534113887 554.85002884100038 -39.611996198262105 42.23638377808156 553.11026865944325 -38.412836085193852 29.981492819445318 552.07925640417091 -38.416478880319474 15.819327589650856 552.08404482506558 -38.416478878765751 -5.4045958819415318e-09 552.08404482302308
+6 0 12 -84.688062748028003 2.8421709430404007e-14 607.80583425270879 -79.847867502262417 2.960594732333751e-14 602.29335836429334 -75.239972809402204 3.0790185216271012e-14 596.96792341036803 -70.849971422995353 3.2039017903364522e-14 591.832870649092 -66.662589984229172 3.33883313813736e-14 586.88704232594841 -62.661786550255989 3.5132390823693844e-14 582.12424525208428 -58.830848122518887 3.7741815444919608e-14 577.53271438264926 -55.152488175077423 4.1412440255916953e-14 573.09457639513528 -51.608944182933385 4.0192316366227896e-14 568.78531326771576 -48.182075150356489 -3.5527136788004946e-15 564.57322585758493 -44.853459139210159 -2.2984980921936571e-13 560.41889747929679 -41.604490797277236 -1.1096309056786897e-12 556.27465748310487 -38.416478886585843 -4.7108983380894642e-12 552.08404483330082
+6 0 4 -80.31716880097585 -113.22176793223966 584.66730272526422 -85.625458262792037 -92.56319279591952 599.11675593107225 -84.688062748027946 -45.890661537100179 607.80583425270845 -84.688062748028344 -22.945330768550136 607.80583425270788 -84.688062748030504 -1.9184653865522705e-13 607.80583425270675
+6 0 11 -171.24821807292994 -155.88520260010867 652.98205578418992 -161.46508784404722 -153.17938735945037 646.31034634125058 -151.99837117002707 -150.59060614611693 639.56845827345398 -142.85133599585845 -147.93918877558596 632.83301067480295 -134.02424886652145 -145.04368637347005 626.18920448016024 -125.49524693795669 -141.81827247730681 619.67514548577219 -117.24585889462355 -138.21431417874206 613.314736066661 -109.27129636201785 -134.18622578439107 607.13485229681419 -101.57392640333696 -129.70059380521948 601.15778345235276 -94.161777701188313 -124.73804985854521 595.3998854347127 -87.062528047836693 -119.25946728372337 589.89208849031763 -80.317168800975836 -113.22176793223963 584.66730272526434
+6 0 12 -80.317168800975878 -113.22176793223966 584.66730272526456 -74.133922824686749 -107.68721019337957 579.8779157739657 -68.245585520473256 -101.68672180730124 575.3243714721184 -62.684068029539013 -95.184424011185584 571.03417924489224 -57.487000677884218 -88.155193512565447 567.02520868952797 -52.722082068796766 -80.510653763540688 563.36201759685775 -48.445053433215492 -72.220219684059217 560.06374441829689 -44.753270306349741 -63.189397565290065 557.19001667253508 -41.775219899383394 -53.239331534113887 554.85002884100038 -39.611996198262105 -42.23638377808156 553.11026865944325 -38.412836085193852 -29.981492819445318 552.07925640417091 -38.416478880319474 -15.819327589650856 552.08404482506558 -38.416478878765751 5.4045958819415318e-09 552.08404482302308
+6 0 11 -65.154678575381226 1.1640743924345998e-09 -179.01139996344745 -65.154678575081974 5.3874646923965983 -179.01139996361397 -64.70899669391541 10.120641762283968 -179.46681427486831 -63.964574526024379 14.305161879442473 -180.20533001024415 -63.003423506373842 18.02061450500781 -181.11733196564251 -61.873508256492919 21.329720794301576 -182.13206882627048 -60.606985717779786 24.284158255985911 -183.20212882746225 -59.229075534261909 26.927861768554184 -184.294292539342 -57.760837146703992 29.298625554005511 -185.3848304447894 -56.219129059956025 31.428830708550993 -186.45731298016707 -54.617025745433857 33.346122890199482 -187.50100070827037 -52.967967640624643 35.074864763070728 -188.50788229295952
+6 0 7 -52.967967640624643 35.074864763070721 -188.50788229295955 -50.376590618781592 37.791459134725535 -190.09012478318539 -47.662236765234375 40.014231269106624 -191.57597023113607 -44.88498631213853 41.857378155518383 -192.92926706440085 -42.090754902379558 43.400579875824064 -194.14491603903076 -39.311249679984243 44.701481722758139 -195.22907638954229 -36.565752249582395 45.803837878130871 -196.18973550523469 -33.864728504919007 46.741316650925199 -197.03764213282102
+6 0 8 -33.864728504919007 46.741316650925199 -197.03764213282102 -29.137936951758071 48.381904503315276 -198.52147873109709 -24.544566455812507 49.527860207970136 -199.66705786505491 -20.137923140620636 50.347113313562076 -200.52694035942054 -15.900592229324799 50.931898896315623 -201.16132574770378 -11.810785699463041 51.338930921432265 -201.61169562545982 -7.8365053748880626 51.601783045068579 -201.90214902129594 -3.9180834967263549 51.732932495885372 -202.04754019490406 0.00033718470958454816 51.732922675185293 -202.04752927139805
+6 0 8 0.00033718470959342994 51.7329226751853 -202.04752927139802 3.9187578661455338 51.732912854485221 -202.04751834789201 7.8371773508557059 51.601743762268278 -201.9021053272719 11.811452896245369 51.338871386050798 -201.61162983698813 15.901251587188682 50.931817831051113 -201.16123738714785 20.138570378159493 50.347008529168264 -200.52682875771185 24.545195137132755 49.527728575566378 -199.66692263301226 29.138537542344174 48.381742547318986 -198.52132092848203 33.865288682995704 46.741122158567315 -197.03746625448818
+6 0 7 33.865288682995711 46.741122158567293 -197.03746625448818 36.566289334796586 45.803624793566335 -196.18954929792025 39.311759565077494 44.701249308397287 -195.22888135153113 42.091232921807368 43.400327669690427 -194.14471439458939 44.885427317771622 41.857106180759281 -192.92906184219314 47.662635270567748 40.013940530783486 -191.57576587519003 50.376941403521066 37.791152818129198 -190.08992749869267 52.968267207520562 35.074550547807057 -188.50769932918945
+6 0 11 52.968267207520569 35.074550547807057 -188.50769932918945 54.617292719156609 33.345803648511151 -187.5008268576874 56.219362105192097 31.428509372651153 -186.45715101067401 57.761035342732015 29.298305985021017 -185.38468338759205 59.229238363955609 26.927549047880522 -184.29416340587102 60.607113383755369 24.283858876432117 -183.20202054599201 61.873602013174668 21.329442866843618 -182.13198401144356 63.003485879346108 18.020367948515887 -181.11727230882525 63.964609472632581 14.304958412294658 -180.20529525335556 64.709009941673102 10.120494366325628 -179.46680090504049 65.154678557035353 5.3873860712519752 -179.0113999407595 65.154678564177075 -5.9354655679300095e-07 -179.01139996752548
+6 0 8 65.154678564177061 0 -179.01139996752551 80.776374151246898 0 -173.32558164952434 95.831029613511632 0 -166.08176320216793 110.13735909492458 0 -157.34592273989023 123.52327792308111 0 -147.20935065771818 135.83032360413381 0 -135.78704372177606 146.91771762390655 0 -123.21507034755703 156.66570886140698 0 -109.64703244825144 164.97783942093645 0 -95.250000000000497
+6 0 2 164.97783942093645 0 -95.250000000000483 164.97783942093645 29.765624999999996 -95.250000000000483 178.22061023130041 59.531249999999993 -102.89571729218063
+6 0 8 178.22061023130038 59.531249999999993 -102.89571729218062 151.28257443705314 59.531249999999993 -149.5537639439259 110.38448372928468 59.531249999999993 -188.15196913344772 58.339753522086077 59.531249999999993 -213.81735442074299 4.9737991503207013e-14 59.531249999999993 -222.8554220586625 -58.339753522085999 59.531249999999993 -213.81735442074302 -110.3844837292846 59.531249999999993 -188.15196913344778 -151.28257443705303 59.531249999999993 -149.55376394392596 -178.22061023130024 59.531249999999993 -102.89571729218071
+6 0 2 -164.97783942093642 0 -95.25000000000054 -164.97783942093642 29.765624999999996 -95.25000000000054 -178.22061023130038 59.531249999999993 -102.89571729218069
+6 0 8 -164.97783942093639 0 -95.250000000000512 -156.66570886215214 0 -109.64703244696071 -146.91771762565438 0 -123.2150703451242 -135.83032360711582 0 -135.78704371839473 -123.52327792749452 0 -147.20935065362201 -110.13735910092498 0 -157.34592273534636 -95.831029621207222 0 -166.08176319746877 -80.776374160694715 0 -173.32558164497831 -65.154678575381269 0 -179.0113999634475
+6 0 3 -65.154678575381226 1.1640743924345998e-09 -179.01139996344745 -37.308459979088596 -3.3769783266042923e-09 -189.14656992180639 6.1279924190896651 -8.7222081409284604e-10 -69.805636611560303 -21.718226179321377 -9.9198427250257737e-12 -59.670466659021685
+6 0 11 -21.718226179321388 -9.9198427250257737e-12 -59.670466659021734 -21.718226179288528 2.9543441753943656 -59.67046665903441 -21.567852619788425 5.7018281013995908 -59.489824888829524 -21.300377947937061 8.2090288677152099 -59.17146331146369 -20.942526101246614 10.466929390129854 -58.754898464350916 -20.515474102874645 12.482011776612122 -58.273428978755277 -20.035864211941941 14.269641999487902 -57.753244245032811 -19.516765285742473 15.849413818208667 -57.2138869453414 -18.968522010668845 17.242119897225191 -56.669502175537495 -18.39943065867671 18.468018063481122 -56.130305877978493 -17.8161800261115 19.546060648040854 -55.603705306949522 -17.223996211720966 20.493754856366113 -55.094504248433481
+6 0 3 -52.967967640624629 35.074864763070714 -188.50788229295952 -34.42314212055237 0.10887999428432948 -182.72533809383452 5.7449248006476381 7.4290882403051199 -71.847099309408449 -17.223996211720987 20.493754856366067 -55.094504248433481
+6 0 7 -17.223996211720717 20.493754856367339 -55.094504248433466 -16.29342164624962 21.982988612308382 -54.294331156479743 -15.339450652188081 23.130833763827287 -53.539728216345679 -14.386795797295949 24.020002530741696 -52.853527663311084 -13.44782827922818 24.715691744074448 -52.237838245565356 -12.528444015123595 25.265351615179682 -51.688310740711962 -11.631396878521171 25.702022091243354 -51.20061712403146 -10.75709908360383 26.051236797158204 -50.769143388503011
+6 0 3 -33.864728504919007 46.741316650925199 -197.03764213282102 -24.112678297387802 8.7643922643020815 -183.17089076648134 3.4796688611140851 13.736076359857449 -75.534578203011677 -10.757099083603833 26.051236797158204 -50.769143388502954
+6 0 8 -10.757099083603849 26.051236797158221 -50.769143388502982 -9.2270779424985001 26.662362532509217 -50.014064351328187 -7.7653048264483981 27.011120957413748 -49.427644957609559 -6.3740348890822069 27.223676017445488 -48.982590625764175 -5.0394227541872381 27.356567859469344 -48.6503679657025 -3.7483640584805769 27.439229691629617 -48.412003346615485 -2.4884133301984073 27.489226236304017 -48.257065601766129 -1.2435722861652707 27.514152342148886 -48.17958397064703 0.0012573699950078066 27.514130321361055 -48.179652378865292
+6 0 3 0.00033718470957921909 51.732922675185293 -202.04752927139805 0.00025094806636142647 13.757130667893669 -185.09393067749795 -0.00040184977152080142 21.108731711322541 -77.528042884001039 0.0012573699950166881 27.514130321361066 -48.179652378865299
+6 0 8 0.0012573699949562922 27.514130321361051 -48.179652378865399 1.2460870261552333 27.514108300573216 -48.179720787083667 2.4909052944426509 27.489138153152677 -48.257339234639296 3.7508105666377527 27.439090443654631 -48.41241121743019 5.0418001140130126 27.356362693520051 -48.650904820567028 6.3763188695425121 27.223383713014776 -48.98324826437841 7.767470093605354 27.010712894337082 -49.428410803925459 9.2290964123698327 26.661803827144681 -50.01491815179034 10.758939718045374 26.050501597752074 -50.77005159390314
+6 0 3 33.865288682995711 46.741122158567308 -197.03746625448815 24.11303667459071 8.7642115648255796 -183.17084133792238 -3.4803195714526112 13.734061870832015 -75.533793457050351 10.758939718045362 26.050501597752053 -50.77005159390319
+6 0 7 10.758939718045394 26.050501597752049 -50.770051593903119 11.633135892717132 25.701186038099131 -51.201556417967581 12.530071063025892 25.264406091046144 -51.689269940114677 13.449332426734363 24.714630031565918 -52.238803395409697 14.388165675741812 24.018821526364665 -52.854481924436932 15.340674655216485 23.129537747766257 -53.540650137226258 16.294489214048852 21.981595656129571 -54.295194480325804 17.224901246625645 20.492306450798917 -55.095282407020747
+6 0 3 52.968267207520555 35.074550547807057 -188.50769932918945 34.423261391255195 0.10870904567454431 -182.72537851481249 -5.7451756233202502 7.42837265688744 -71.846526695197724 17.224901246625649 20.492306450798921 -55.09528240702079
+6 0 11 17.224901246625659 20.492306450798914 -55.095282407020733 17.816981630992711 19.54457695649759 -55.604429269462969 18.400126505334907 18.466514927876752 -56.130965500187081 18.969110703063713 17.240618138524496 -56.670087191539132 19.517246803425923 15.847940047192708 -57.214387830674283 20.036240361648545 14.268229597291736 -57.753652828715133 20.515749128987824 12.480701786314627 -58.27373962093418 20.942707567091318 10.465770809900821 -58.75511016129736 21.300477961081899 8.2080775852491978 -59.17158263470558 21.567889435772585 5.7011434585903764 -59.489869210271252 21.718226179421094 2.9539819014281479 -59.670466658966674 21.718226179433014 2.599400694691667e-10 -59.670466658981319
+6 0 3 65.154678564177061 -5.9354654524668149e-07 -179.01139996752545 37.308459967250073 -5.9354648603478688e-07 -189.14656992414155 -6.1279924189589678 1.0424994201219632e-10 -69.805636611571828 21.718226179432989 2.5995872121576865e-10 -59.670466658981212
+6 0 11 -122.45108064767162 1.1640743924345998e-09 145.93130680341355 -122.45108064796545 5.3874646923965983 145.93130680323765 -123.068321951342 10.120641762283968 145.77304212776815 -124.08010642321753 14.305161879442473 145.49761148692215 -125.35049879471885 18.02061450500781 145.12123126473065 -126.79424431911961 21.329720794301576 144.65006438452434 -128.35420473308184 24.284158255985911 144.08825369212909 -129.98900134442016 26.927861768554184 143.44103032500919 -131.66755406810643 29.298625554005511 142.71476753529623 -133.36720523223261 31.428830708550993 141.91585043464141 -135.07211697564924 33.346122890199482 141.05023212882961 -136.76863105899739 35.074864763070728 140.12554671009278
+6 0 7 -136.76863105899741 35.074864763070721 140.12554671009281 -139.43458176140166 37.791459134725535 138.67246962350637 -142.07853859219804 40.014231269106624 137.06469295544966 -144.6391532552143 41.857378155518383 135.3361719270292 -147.08905185420778 43.400579875824064 133.52412102944049 -149.41771487072427 44.701481722758139 131.6590790721504 -151.62241878449191 45.803837878130871 129.76173810924371 -153.70723933635057 46.741316650925199 127.8465362439334
+6 0 8 -153.70723933635054 46.741316650925199 127.84653624393336 -157.35567530210315 48.381904503315276 124.49493297964031 -160.64446118212877 49.527860207970136 121.08974700813643 -163.59246292411487 50.347113313562076 117.7034231989462 -166.26052224180575 50.931898896315623 114.35097967966456 -168.69545726197262 51.338930921432265 111.03428826711881 -170.93413744366967 51.601783045068579 107.73768724219428 -173.01926083258118 51.732932495885372 104.41692993976557 -174.97846171326546 51.732922675185293 101.0234726251747
+6 0 8 -174.97846171326546 51.7329226751853 101.0234726251747 -176.93766259394974 51.732912854485221 97.630015310583843 -178.77094096640676 51.601743762268278 94.163857983830837 -180.50651958533911 51.338871386050798 90.576796654742253 -182.16136762757637 50.931817831051113 86.809730867100853 -183.73061303359012 50.347008529168264 82.822900835468971 -185.18922486421707 49.527728575566378 78.576698786902838 -186.49377588808085 48.381742547318986 74.025946723444321 -187.57209561520366 46.741122158567315 69.190532821276094
+6 0 7 -187.57209561520369 46.741122158567293 69.190532821276122 -188.18827831641673 45.803624793566335 66.427439162894274 -188.72905058538277 44.701249308397287 63.56945822494253 -189.17987113709248 43.400327669690427 60.620280210401575 -189.52418234252406 41.857106180759281 57.592610604186298 -189.74079763265843 40.013940530783486 54.510829981971128 -189.81117691917055 37.791152818129198 51.417252728936965 -189.73659003179716 35.074550547807057 48.381984668439657
+6 0 11 -189.73659003179714 35.074550547807057 48.381984668439664 -189.68912564892315 33.345803648511151 46.450450448123192 -189.58631054511108 31.428509372651153 44.541179737684431 -189.42836295755575 29.298305985021017 42.669817738099276 -189.21804646066261 26.927549047880522 40.853056632946064 -188.96116050934546 24.283858876432117 39.113710432619982 -188.66772600215867 21.329442866843618 37.481880838664502 -188.35390182325958 18.020367948515887 35.996016855924701 -188.04466832219754 14.304958412294658 34.707670880227184 -187.77731369052572 10.120494366325628 33.693753989291508 -187.60575919423158 5.3873860712519752 33.080093164577875 -187.60575922098246 -5.9354655679300095e-07 33.08009317177595
+6 0 8 -187.60575922098246 0 33.080093171775985 -190.49254390982546 0 16.708398784185654 -191.74654084514484 0 0.048775484964032501 -191.33424582211083 0 -16.708789511988691 -189.24867630573598 0 -33.369621311254697 -185.51019116991327 0 -49.73898898455294 -180.16623986202441 0 -65.626940554553315 -173.28996998046594 0 -80.852967551749586 -164.97783942093648 0 -95.250000000000512
+6 0 8 -178.22061023130036 59.531249999999993 -102.89571729218069 -205.15864602554763 59.531249999999993 -56.237670640435439 -218.13662690627365 59.531249999999993 -1.5197825264667415 -214.34113745938743 59.531249999999993 56.384968609722236 -192.99845687390473 59.531249999999993 111.42771102933118 -156.00138393730143 59.531249999999993 157.43238581102065 -107.75214317698908 59.531249999999993 189.67175165991438 -53.876071588494604 59.531249999999993 205.79143458436124 -1.2079226507921703e-13 59.531249999999993 205.79143458436124
+6 0 2 -2.8421709430404007e-14 59.531249999999993 205.79143458436127 -2.5757174171303632e-14 29.765624999999996 190.50000000000097 -2.5757174171303632e-14 0 190.50000000000097
+6 0 8 -4.2632564145606011e-14 0 190.50000000000099 -16.624261117568533 0 190.50000000000099 -33.248522235137024 0 188.84201090240759 -49.679867561360112 0 185.52603270722082 -65.725398376900756 0 180.57897197074689 -81.19688672025093 0 174.05471225480346 -95.915511223715797 0 166.03298772151888 -109.71616974991767 0 156.61718287124771 -122.45108064767162 0 145.93130680341363
+6 0 2 -164.97783942093642 0 -95.25000000000054 -164.97783942093642 -29.765624999999996 -95.25000000000054 -178.22061023130038 -59.531249999999993 -102.89571729218069
+6 0 8 178.22061023130038 -59.531249999999993 -102.89571729218062 151.28257443705314 -59.531249999999993 -149.5537639439259 110.38448372928468 -59.531249999999993 -188.15196913344772 58.339753522086077 -59.531249999999993 -213.81735442074299 4.9737991503207013e-14 -59.531249999999993 -222.8554220586625 -58.339753522085999 -59.531249999999993 -213.81735442074302 -110.3844837292846 -59.531249999999993 -188.15196913344778 -151.28257443705303 -59.531249999999993 -149.55376394392596 -178.22061023130024 -59.531249999999993 -102.89571729218071
+6 0 2 164.97783942093645 0 -95.250000000000483 164.97783942093645 -29.765624999999996 -95.250000000000483 178.22061023130041 -59.531249999999993 -102.89571729218063
+6 0 11 52.968267207520569 -35.074550547807057 -188.50769932918945 54.617292719156609 -33.345803648511151 -187.5008268576874 56.219362105192097 -31.428509372651153 -186.45715101067401 57.761035342732015 -29.298305985021017 -185.38468338759205 59.229238363955609 -26.927549047880522 -184.29416340587102 60.607113383755369 -24.283858876432117 -183.20202054599201 61.873602013174668 -21.329442866843618 -182.13198401144356 63.003485879346108 -18.020367948515887 -181.11727230882525 63.964609472632581 -14.304958412294658 -180.20529525335556 64.709009941673102 -10.120494366325628 -179.46680090504049 65.154678557035353 -5.3873860712519752 -179.0113999407595 65.154678564177075 5.9354655679300095e-07 -179.01139996752548
+6 0 7 33.865288682995711 -46.741122158567293 -197.03746625448818 36.566289334796586 -45.803624793566335 -196.18954929792025 39.311759565077494 -44.701249308397287 -195.22888135153113 42.091232921807368 -43.400327669690427 -194.14471439458939 44.885427317771622 -41.857106180759281 -192.92906184219314 47.662635270567748 -40.013940530783486 -191.57576587519003 50.376941403521066 -37.791152818129198 -190.08992749869267 52.968267207520562 -35.074550547807057 -188.50769932918945
+6 0 8 0.00033718470959342994 -51.7329226751853 -202.04752927139802 3.9187578661455338 -51.732912854485221 -202.04751834789201 7.8371773508557059 -51.601743762268278 -201.9021053272719 11.811452896245369 -51.338871386050798 -201.61162983698813 15.901251587188682 -50.931817831051113 -201.16123738714785 20.138570378159493 -50.347008529168264 -200.52682875771185 24.545195137132755 -49.527728575566378 -199.66692263301226 29.138537542344174 -48.381742547318986 -198.52132092848203 33.865288682995704 -46.741122158567315 -197.03746625448818
+6 0 8 -33.864728504919007 -46.741316650925199 -197.03764213282102 -29.137936951758071 -48.381904503315276 -198.52147873109709 -24.544566455812507 -49.527860207970136 -199.66705786505491 -20.137923140620636 -50.347113313562076 -200.52694035942054 -15.900592229324799 -50.931898896315623 -201.16132574770378 -11.810785699463041 -51.338930921432265 -201.61169562545982 -7.8365053748880626 -51.601783045068579 -201.90214902129594 -3.9180834967263549 -51.732932495885372 -202.04754019490406 0.00033718470958454816 -51.732922675185293 -202.04752927139805
+6 0 7 -52.967967640624643 -35.074864763070721 -188.50788229295955 -50.376590618781592 -37.791459134725535 -190.09012478318539 -47.662236765234375 -40.014231269106624 -191.57597023113607 -44.88498631213853 -41.857378155518383 -192.92926706440085 -42.090754902379558 -43.400579875824064 -194.14491603903076 -39.311249679984243 -44.701481722758139 -195.22907638954229 -36.565752249582395 -45.803837878130871 -196.18973550523469 -33.864728504919007 -46.741316650925199 -197.03764213282102
+6 0 11 -65.154678575381226 -1.1640743924345998e-09 -179.01139996344745 -65.154678575081974 -5.3874646923965983 -179.01139996361397 -64.70899669391541 -10.120641762283968 -179.46681427486831 -63.964574526024379 -14.305161879442473 -180.20533001024415 -63.003423506373842 -18.02061450500781 -181.11733196564251 -61.873508256492919 -21.329720794301576 -182.13206882627048 -60.606985717779786 -24.284158255985911 -183.20212882746225 -59.229075534261909 -26.927861768554184 -184.294292539342 -57.760837146703992 -29.298625554005511 -185.3848304447894 -56.219129059956025 -31.428830708550993 -186.45731298016707 -54.617025745433857 -33.346122890199482 -187.50100070827037 -52.967967640624643 -35.074864763070728 -188.50788229295952
+6 0 11 187.60575922305284 1.1640743924345998e-09 33.080093160033869 187.60575922304741 5.3874646923965983 33.080093160376286 187.7773186452574 10.120641762283968 33.693772147100141 188.04468094924189 14.305161879442473 34.707718523321972 188.35392230109267 18.02061450500781 35.996100700911825 188.66775257561252 21.329720794301576 37.482004441746142 188.96119045086164 24.284158255985911 39.113875135333153 189.21807687868207 26.927861768554184 40.853262214332794 189.42839121481043 29.298625554005511 42.670062909493154 189.58633429218864 31.428830708550993 44.541462545525626 189.68914272108307 33.346122890199482 46.450768579440734 189.73659869962202 35.074864763070728 48.382335582866716
+6 0 7 189.73659869962205 35.074864763070721 48.382335582866716 189.81117238018325 37.791459134725535 51.417655159678979 189.74077535743243 40.014231269106624 54.511277275686403 189.52413956735285 41.857378155518383 57.593095137371634 189.17980675658737 43.400579875824064 60.62079500959026 188.72896455070853 44.701481722758139 63.569997317391881 188.18817103407432 45.803837878130871 66.427997395990985 187.57196784126955 46.741316650925199 69.19110588888762
+6 0 8 187.57196784126955 46.741316650925199 69.19110588888762 186.49361225386124 48.381904503315276 74.026545751456723 185.18902763794131 49.527860207970136 78.577310856918416 183.73038606473554 50.347113313562076 82.823517160474267 182.16111447113059 50.931898896315623 86.810346068039152 180.5062429614357 51.338930921432265 90.57740735834092 178.77064281855777 51.601783045068579 94.164461779101586 176.93734432930759 51.732932495885372 97.630610255138421 174.97812452855592 51.732922675185293 101.02405664622327
+6 0 8 174.97812452855587 51.7329226751853 101.02405664622327 173.0189047278042 51.732912854485221 104.41750303730812 170.93376361555104 51.601743762268278 107.738247343441 168.69506668909372 51.338871386050798 111.03483318224582 166.26011604038766 50.931817831051113 114.35150652004693 163.59204265543062 50.347008529168264 117.70392792224281 160.6440297270843 49.527728575566378 121.09022384610934 157.35523834573667 48.381742547318986 124.49537420503763 153.70680693220794 46.741122158567315 127.846933433212
+6 0 7 153.706806932208 46.741122158567293 127.84693343321202 151.62198898162015 45.803624793566335 129.76211013502595 149.41729102030527 44.701249308397287 131.65942312658856 147.0886382152851 43.400327669690427 133.52443418418775 144.63875502475244 41.857106180759281 135.33645123800679 142.07816236209067 40.013940530783486 137.06493589321886 139.43423551564945 37.791152818129198 138.67267476975564 136.76832282427657 35.074550547807057 140.12571466074974
+6 0 11 136.76832282427657 35.074550547807057 140.12571466074974 135.07183292976654 33.345803648511151 141.05037640956417 133.36694843991896 31.428509372651153 141.91597127298954 131.66732761482371 29.298305985021017 142.71486564949274 129.98880809670695 26.927549047880522 143.44110677292491 128.35404712559006 24.283858876432117 144.08831011337199 126.79412398898398 21.329442866843618 144.65010317277901 125.35041594391345 18.020367948515887 145.1212554529005 124.08005884956494 14.304958412294658 145.49762437312833 123.06830374885259 10.120494366325628 145.77304691574895 122.4510806371962 5.3873860712519752 145.9313067761816 122.45108065680535 -5.9354655679300095e-07 145.93130679574949
+6 0 8 122.45108065680543 0 145.93130679574949 109.71616975857859 0 156.61718286533866 95.915511231633232 0 166.03298771720389 81.196886727186268 0 174.05471225187893 65.725398382654873 0 180.57897196897287 49.67986756577946 0 185.526032706329 33.248522238117836 0 188.84201090211036 16.624261119058925 0 190.50000000000105 1.4210854715202004e-14 0 190.50000000000105
+6 0 8 0 59.531249999999993 205.7914345843613 53.87607158849449 59.531249999999993 205.7914345843613 107.75214317698898 59.531249999999993 189.67175165991443 156.00138393730134 59.531249999999993 157.43238581102071 192.99845687390464 59.531249999999993 111.42771102933125 214.34113745938737 59.531249999999993 56.384968609722286 218.13662690627362 59.531249999999993 -1.5197825264666989 205.15864602554757 59.531249999999993 -56.237670640435411 178.2206102313003 59.531249999999993 -102.89571729218071
+6 0 8 164.97783942093639 0 -95.250000000000469 173.28996997972064 0 -80.852967553040273 180.16623986079136 0 -65.626940557283376 185.5101911684759 0 -49.73898898882608 189.24867630439525 0 -33.369621317124881 191.33424582117587 0 -16.708789519457088 191.74654084492298 0 0.048775475949909719 190.49254391061234 0 16.708398773730632 187.60575922305284 0 33.08009316003389
+6 0 5 -186.97488467706117 59.531249999999993 -107.95000000000059 -186.97488467706117 63.387277307658351 -107.95000000000059 -186.97488467706117 67.243304615316703 -107.95000000000059 -180.1042333386952 63.673414194443438 -103.98322760028692 -179.15002519555344 61.62028542102334 -103.4323152719811 -178.22061023130038 59.531249999999986 -102.89571729218071
+6 0 5 186.97488467706117 59.531249999999993 -107.95000000000047 186.97488467706117 63.387277307658351 -107.95000000000047 186.97488467706117 67.243304615316703 -107.95000000000047 180.1042333386952 63.673414194443438 -103.98322760028681 179.15002519555344 61.62028542102334 -103.43231527198098 178.22061023130038 59.531249999999986 -102.89571729218062
+6 0 8 186.97488467706117 59.531249999999993 -107.95000000000047 158.71364076414287 59.531249999999993 -156.89991034227165 115.80661792501901 59.531249999999993 -197.3940762790063 61.205427771363688 59.531249999999993 -224.32015653457472 2.8421709430404007e-14 59.531249999999993 -233.80217801407858 -61.205427771363659 59.531249999999993 -224.32015653457472 -115.806617925019 59.531249999999993 -197.39407627900633 -158.71364076414287 59.531249999999993 -156.89991034227168 -186.9748846770612 59.531249999999993 -107.95000000000053
+6 0 8 -21.718226179321405 -2.5123963424448521e-15 -59.670466659021706 -26.925458043047691 -2.5123963424448521e-15 -57.775193886719627 -31.943676531835699 -2.5123963424448521e-15 -55.36058773772028 -36.712453026961967 -2.5123963424448521e-15 -52.448640916839956 -41.174425970918378 -2.5123963424448521e-15 -49.069783555766826 -45.27677453238551 -2.5123963424448521e-15 -45.262347909895361 -48.972572539938866 -2.5123963424448521e-15 -41.071690117749355 -52.221902953220905 -2.5123963424448521e-15 -36.549010817090199 -54.992613140311846 -2.5123963424448521e-15 -31.750000000000014
+6 0 8 -39.594681461024443 27.781250000000011 -22.859999999999957 -42.61805827628239 27.781250000000011 -24.605547418150806 -45.64143509154033 26.557187735411777 -26.351094836301652 -48.4871956382148 24.109063206235312 -27.994095453973376 -50.977735779705242 20.537529609657629 -29.432009475090453 -52.957280627773009 16.044048293666783 -30.574900225995314 -54.314168969465577 10.90967136344268 -31.358300075331783 -54.99261314031186 5.454835681721339 -31.750000000000018 -54.99261314031186 -1.7763568394002505e-15 -31.750000000000018
+6 0 8 -39.59468146102445 27.78125 -22.859999999999985 -33.609947455935909 27.78125 -33.22586336659851 -24.52375438412151 27.78125 -41.801098506142253 -12.961149410406342 27.78125 -47.503091972027285 -5.3290705182007514e-15 27.78125 -49.511049461804561 12.961149410406327 27.78125 -47.503091972027285 24.523754384121492 27.78125 -41.801098506142246 33.609947455935895 27.78125 -33.225863366598496 39.594681461024436 27.78125 -22.859999999999967
+6 0 8 39.59468146102445 27.781250000000011 -22.859999999999946 42.618058276282397 27.781250000000011 -24.605547418150795 45.641435091540338 26.557187735411777 -26.351094836301638 48.487195638214807 24.109063206235312 -27.994095453973358 50.977735779705249 20.537529609657629 -29.432009475090432 52.957280627773017 16.044048293666783 -30.574900225995293 54.314168969465584 10.90967136344268 -31.358300075331762 54.992613140311867 5.454835681721339 -31.749999999999996 54.992613140311867 -1.7763568394002505e-15 -31.749999999999996
+6 0 8 54.992613140311867 2.5123963424448521e-15 -31.749999999999996 52.221902953228359 2.5123963424448521e-15 -36.54901081707731 48.972572539956317 2.5123963424448521e-15 -41.071690117725076 45.276774532415267 2.5123963424448521e-15 -45.262347909861624 41.17442597096241 2.5123963424448521e-15 -49.069783555725962 36.71245302702183 2.5123963424448521e-15 -52.448640916794623 31.94367653191247 2.5123963424448521e-15 -55.360587737673399 26.925458043141937 2.5123963424448521e-15 -57.775193886674273 21.718226179433167 2.5123963424448521e-15 -59.67046665898102
+6 0 3 -52.967967640624629 -35.074864763070714 -188.50788229295952 -34.42314212055237 -0.10887999428432948 -182.72533809383452 5.7449248006476381 -7.4290882403051199 -71.847099309408449 -17.223996211720987 -20.493754856366067 -55.094504248433481
+6 0 11 -21.718226179321388 9.9198427250257737e-12 -59.670466659021734 -21.718226179288528 -2.9543441753943656 -59.67046665903441 -21.567852619788425 -5.7018281013995908 -59.489824888829524 -21.300377947937061 -8.2090288677152099 -59.17146331146369 -20.942526101246614 -10.466929390129854 -58.754898464350916 -20.515474102874645 -12.482011776612122 -58.273428978755277 -20.035864211941941 -14.269641999487902 -57.753244245032811 -19.516765285742473 -15.849413818208667 -57.2138869453414 -18.968522010668845 -17.242119897225191 -56.669502175537495 -18.39943065867671 -18.468018063481122 -56.130305877978493 -17.8161800261115 -19.546060648040854 -55.603705306949522 -17.223996211720966 -20.493754856366113 -55.094504248433481
+6 0 11 17.224901246625659 -20.492306450798914 -55.095282407020733 17.816981630992711 -19.54457695649759 -55.604429269462969 18.400126505334907 -18.466514927876752 -56.130965500187081 18.969110703063713 -17.240618138524496 -56.670087191539132 19.517246803425923 -15.847940047192708 -57.214387830674283 20.036240361648545 -14.268229597291736 -57.753652828715133 20.515749128987824 -12.480701786314627 -58.27373962093418 20.942707567091318 -10.465770809900821 -58.75511016129736 21.300477961081899 -8.2080775852491978 -59.17158263470558 21.567889435772585 -5.7011434585903764 -59.489869210271252 21.718226179421094 -2.9539819014281479 -59.670466658966674 21.718226179433014 -2.599400694691667e-10 -59.670466658981319
+6 0 3 52.968267207520555 -35.074550547807057 -188.50769932918945 34.423261391255195 -0.10870904567454431 -182.72537851481249 -5.7451756233202502 -7.42837265688744 -71.846526695197724 17.224901246625649 -20.492306450798921 -55.09528240702079
+6 0 3 -122.45108064767162 -1.1640743924345998e-09 145.93130680341355 -145.15150460142965 3.3769783266042923e-09 126.88335907886896 -63.51745084250112 8.7222081409284604e-10 29.595821196650078 -40.8170268927244 9.9198427250257737e-12 48.643768925939497
+6 0 11 -40.817026892724499 -9.9198427250257737e-12 48.643768925939433 -40.817026892751905 2.9543441753943656 48.643768925917314 -40.735773310519939 5.7018281013995908 48.423220718230297 -40.593801432857923 8.2090288677152099 48.032400068855189 -40.411971616279899 10.466929390129854 47.514208855273701 -40.208532809793034 12.482011776612122 46.903636233148845 -39.997844561194889 14.269641999487902 46.228189516833609 -39.790296901045281 15.849413818208667 45.508958009821939 -39.592967498498574 17.242119897225191 44.761973021252246 -39.410555483182037 18.468018063481122 43.999527304573526 -39.246131327306159 19.546060648040854 43.231117154484224 -39.101242182192607 20.493754856366113 42.463670398254031
+6 0 3 -136.76863105899739 35.074864763070714 140.12554671009278 -141.03321364408492 0.10887999428432948 121.17398460139775 -65.093875590494918 7.4290882403051199 30.94829883451213 -39.101242182192564 20.493754856366067 42.463670398254067
+6 0 7 -39.101242182192706 20.493754856367339 42.463670398253804 -38.873559239871589 21.982988612308382 41.257682638463308 -38.697039420975834 23.130833763827287 40.05421805306549 -38.579099737403006 24.020002530741696 38.886094471173031 -38.51538081982784 24.715691744074448 37.765080038325053 -38.499168172598814 25.265351615179682 36.694106157344123 -38.525336679591199 25.702022091243354 35.673393740314083 -38.588818361016465 26.051236797158204 34.700492771678725
+6 0 3 -153.70723933635054 46.741316650925199 127.84653624393336 -146.57430548890341 8.7643922643020815 112.46763734206019 -67.154698018507474 13.736076359857449 34.753807471023364 -38.588818361016394 26.051236797158204 34.700492771678682
+6 0 8 -38.588818361016436 26.051236797158221 34.700492771678725 -38.699911303510646 26.662362532509217 32.997916076566845 -38.922943769303494 27.011120957413748 31.438773726639003 -39.233150380544181 27.223676017445488 30.011371451435604 -39.612743184665419 27.356567859469344 28.689452108386742 -40.051842717025991 27.439229691629617 27.452180170584462 -40.547638058122459 27.489226236304017 26.28356195995072 -41.102957519263228 27.514152342148886 25.16675717658493 -41.725431590598212 27.514130321361055 24.088737275075012
+6 0 3 -174.97846171326549 51.732922675185293 101.02347262517473 -160.29617152706226 13.757130667893669 92.546748011348456 -67.14105371834853 21.108731711322541 38.764369454111154 -41.725431590598248 27.514130321361066 24.088737275075019
+6 0 8 -41.725431590598276 27.514130321361051 24.088737275075104 -42.347905661933261 27.514108300573216 23.010717373565189 -43.037534343462461 27.489138153152677 21.971482353911149 -43.801783256072149 27.439090443654631 20.957908373223688 -44.653819548716363 27.356362693520051 19.959125430744958 -45.608896791602973 27.223383713014776 18.96957000853531 -46.689994471695336 27.010712894337082 17.987378977764596 -47.9287378938348 26.661803827144681 17.014827128807067 -49.34762429078944 26.050501597752074 16.067510683338885
+6 0 3 -187.57209561520366 46.741122158567308 69.190532821276108 -170.68712016850492 8.7642115648255796 70.702918346379761 -63.674024192286112 13.734061870832015 40.780941890691281 -49.347624290789483 26.050501597752053 16.067510683338902
+6 0 7 -49.347624290789433 26.050501597752049 16.067510683338856 -50.158416517620658 25.701186038099131 15.526187000214181 -51.029256402723611 25.264406091046144 14.993275118252622 -51.964797017092778 24.714630031565918 14.47193815221107 -52.967406888298726 24.018821526364665 13.966723973166758 -54.037900481580984 23.129537747766257 13.484911106003562 -55.168262330403216 21.981595656129571 13.036155639105059 -56.326364816470651 20.492306450798917 12.630439146254313
+6 0 3 -189.73659003179711 35.074550547807057 48.381984668439678 -175.45645040558244 0.10870904567454431 61.551270411467165 -59.348329480057899 7.42837265688744 40.898731386597284 -56.32636481647063 20.492306450798921 12.630439146254311
+6 0 11 -56.326364816470644 20.492306450798914 12.630439146254291 -57.063339125786285 19.54457695649759 12.372255923531089 -57.810905314777372 18.466514927876752 12.130505763626122 -58.562290494083882 17.240618138524496 11.907311839717094 -59.307736725052131 15.847940047192708 11.704762371639658 -60.034250691838579 14.268229597291736 11.524933264838815 -60.72441344974267 12.480701786314627 11.36970988709516 -61.354771785382368 10.465770809900821 11.240638303518997 -61.894332724326119 8.2080775852491978 11.139036290305299 -62.303682721794885 5.7011434585903764 11.066594447742542 -62.535253072048036 2.9539819014281479 11.026697732968417 -62.535253072066673 2.599400694691667e-10 11.026697732965417
+6 0 3 -187.60575922098241 -5.9354654524668149e-07 33.080093171775957 -182.45996457662127 -5.9354648603478688e-07 62.263210854357439 -57.389458423486815 1.0424994201219632e-10 40.209815414802833 -62.535253072066638 2.5995872121576865e-10 11.026697732965392
+6 0 2 -2.8421709430404007e-14 -59.531249999999993 205.79143458436127 -2.5757174171303632e-14 -29.765624999999996 190.50000000000097 -2.5757174171303632e-14 0 190.50000000000097
+6 0 8 -178.22061023130036 -59.531249999999993 -102.89571729218068 -205.15864602554763 -59.531249999999993 -56.237670640435425 -218.13662690627365 -59.531249999999993 -1.5197825264667273 -214.34113745938743 -59.531249999999993 56.38496860972225 -192.9984568739047 -59.531249999999993 111.42771102933119 -156.0013839373014 -59.531249999999993 157.43238581102065 -107.75214317698905 -59.531249999999993 189.67175165991438 -53.876071588494568 -59.531249999999993 205.79143458436124 -7.815970093361102e-14 -59.531249999999993 205.79143458436124
+6 0 11 -189.73659003179714 -35.074550547807057 48.381984668439664 -189.68912564892315 -33.345803648511151 46.450450448123192 -189.58631054511108 -31.428509372651153 44.541179737684431 -189.42836295755575 -29.298305985021017 42.669817738099276 -189.21804646066261 -26.927549047880522 40.853056632946064 -188.96116050934546 -24.283858876432117 39.113710432619982 -188.66772600215867 -21.329442866843618 37.481880838664502 -188.35390182325958 -18.020367948515887 35.996016855924701 -188.04466832219754 -14.304958412294658 34.707670880227184 -187.77731369052572 -10.120494366325628 33.693753989291508 -187.60575919423158 -5.3873860712519752 33.080093164577875 -187.60575922098246 5.9354655679300095e-07 33.08009317177595
+6 0 7 -187.57209561520369 -46.741122158567293 69.190532821276122 -188.18827831641673 -45.803624793566335 66.427439162894274 -188.72905058538277 -44.701249308397287 63.56945822494253 -189.17987113709248 -43.400327669690427 60.620280210401575 -189.52418234252406 -41.857106180759281 57.592610604186298 -189.74079763265843 -40.013940530783486 54.510829981971128 -189.81117691917055 -37.791152818129198 51.417252728936965 -189.73659003179716 -35.074550547807057 48.381984668439657
+6 0 8 -174.97846171326546 -51.7329226751853 101.0234726251747 -176.93766259394974 -51.732912854485221 97.630015310583843 -178.77094096640676 -51.601743762268278 94.163857983830837 -180.50651958533911 -51.338871386050798 90.576796654742253 -182.16136762757637 -50.931817831051113 86.809730867100853 -183.73061303359012 -50.347008529168264 82.822900835468971 -185.18922486421707 -49.527728575566378 78.576698786902838 -186.49377588808085 -48.381742547318986 74.025946723444321 -187.57209561520366 -46.741122158567315 69.190532821276094
+6 0 8 -153.70723933635054 -46.741316650925199 127.84653624393336 -157.35567530210315 -48.381904503315276 124.49493297964031 -160.64446118212877 -49.527860207970136 121.08974700813643 -163.59246292411487 -50.347113313562076 117.7034231989462 -166.26052224180575 -50.931898896315623 114.35097967966456 -168.69545726197262 -51.338930921432265 111.03428826711881 -170.93413744366967 -51.601783045068579 107.73768724219428 -173.01926083258118 -51.732932495885372 104.41692993976557 -174.97846171326546 -51.732922675185293 101.0234726251747
+6 0 7 -136.76863105899741 -35.074864763070721 140.12554671009281 -139.43458176140166 -37.791459134725535 138.67246962350637 -142.07853859219804 -40.014231269106624 137.06469295544966 -144.6391532552143 -41.857378155518383 135.3361719270292 -147.08905185420778 -43.400579875824064 133.52412102944049 -149.41771487072427 -44.701481722758139 131.6590790721504 -151.62241878449191 -45.803837878130871 129.76173810924371 -153.70723933635057 -46.741316650925199 127.8465362439334
+6 0 11 -122.45108064767162 -1.1640743924345998e-09 145.93130680341355 -122.45108064796545 -5.3874646923965983 145.93130680323765 -123.068321951342 -10.120641762283968 145.77304212776815 -124.08010642321753 -14.305161879442473 145.49761148692215 -125.35049879471885 -18.02061450500781 145.12123126473065 -126.79424431911961 -21.329720794301576 144.65006438452434 -128.35420473308184 -24.284158255985911 144.08825369212909 -129.98900134442016 -26.927861768554184 143.44103032500919 -131.66755406810643 -29.298625554005511 142.71476753529623 -133.36720523223261 -31.428830708550993 141.91585043464141 -135.07211697564924 -33.346122890199482 141.05023212882961 -136.76863105899739 -35.074864763070728 140.12554671009278
+6 0 5 0 59.531249999999993 215.900000000001 0 63.387277307658351 215.900000000001 0 67.243304615316703 215.900000000001 0 63.673414194443438 207.96645520057368 0 61.62028542102334 206.86463054396202 0 59.531249999999986 205.7914345843613
+6 0 8 -186.97488467706114 59.531249999999993 -107.95000000000053 -215.23612858997947 59.531249999999993 -59.000089657729362 -228.85159357669224 59.531249999999993 -1.5944349099216666 -224.86966802552544 59.531249999999993 59.154622967792818 -202.47862562032367 59.531249999999993 116.90108900703926 -163.6642402541618 59.531249999999993 165.16553356678187 -113.0449756516733 59.531249999999993 198.98851118892796 -56.522487825836677 59.531249999999993 215.90000000000103 -4.2632564145606011e-14 59.531249999999993 215.90000000000106
+6 0 7 10.758939718045394 -26.050501597752049 -50.770051593903119 11.633135892717132 -25.701186038099131 -51.201556417967581 12.530071063025892 -25.264406091046144 -51.689269940114677 13.449332426734363 -24.714630031565918 -52.238803395409697 14.388165675741812 -24.018821526364665 -52.854481924436932 15.340674655216485 -23.129537747766257 -53.540650137226258 16.294489214048852 -21.981595656129571 -54.295194480325804 17.224901246625645 -20.492306450798917 -55.095282407020747
+6 0 3 33.865288682995711 -46.741122158567308 -197.03746625448815 24.11303667459071 -8.7642115648255796 -183.17084133792238 -3.4803195714526112 -13.734061870832015 -75.533793457050351 10.758939718045362 -26.050501597752053 -50.77005159390319
+6 0 8 0.0012573699949562922 -27.514130321361051 -48.179652378865399 1.2460870261552333 -27.514108300573216 -48.179720787083667 2.4909052944426509 -27.489138153152677 -48.257339234639296 3.7508105666377527 -27.439090443654631 -48.41241121743019 5.0418001140130126 -27.356362693520051 -48.650904820567028 6.3763188695425121 -27.223383713014776 -48.98324826437841 7.767470093605354 -27.010712894337082 -49.428410803925459 9.2290964123698327 -26.661803827144681 -50.01491815179034 10.758939718045374 -26.050501597752074 -50.77005159390314
+6 0 3 0.00033718470957921909 -51.732922675185293 -202.04752927139805 0.00025094806636142647 -13.757130667893669 -185.09393067749795 -0.00040184977152080142 -21.108731711322541 -77.528042884001039 0.0012573699950166881 -27.514130321361066 -48.179652378865299
+6 0 8 186.97488467706117 -59.531249999999993 -107.95000000000047 158.71364076414287 -59.531249999999993 -156.89991034227165 115.80661792501901 -59.531249999999993 -197.3940762790063 61.205427771363688 -59.531249999999993 -224.32015653457472 2.8421709430404007e-14 -59.531249999999993 -233.80217801407858 -61.205427771363659 -59.531249999999993 -224.32015653457472 -115.806617925019 -59.531249999999993 -197.39407627900633 -158.71364076414287 -59.531249999999993 -156.89991034227168 -186.9748846770612 -59.531249999999993 -107.95000000000053
+6 0 5 186.9748846770612 -59.531249999999993 -107.9500000000005 186.9748846770612 -63.387277307658351 -107.9500000000005 186.9748846770612 -67.243304615316703 -107.9500000000005 180.10423333869522 -63.673414194443438 -103.98322760028684 179.15002519555347 -61.62028542102334 -103.43231527198101 178.22061023130038 -59.531249999999986 -102.89571729218063
+6 0 5 -186.97488467706117 -59.531249999999993 -107.95000000000059 -186.97488467706117 -63.387277307658351 -107.95000000000059 -186.97488467706117 -67.243304615316703 -107.95000000000059 -180.1042333386952 -63.673414194443438 -103.98322760028692 -179.15002519555344 -61.62028542102334 -103.4323152719811 -178.22061023130038 -59.531249999999986 -102.89571729218071
+6 0 8 -10.757099083603849 -26.051236797158221 -50.769143388502982 -9.2270779424985001 -26.662362532509217 -50.014064351328187 -7.7653048264483981 -27.011120957413748 -49.427644957609559 -6.3740348890822069 -27.223676017445488 -48.982590625764175 -5.0394227541872381 -27.356567859469344 -48.6503679657025 -3.7483640584805769 -27.439229691629617 -48.412003346615485 -2.4884133301984073 -27.489226236304017 -48.257065601766129 -1.2435722861652707 -27.514152342148886 -48.17958397064703 0.0012573699950078066 -27.514130321361055 -48.179652378865292
+6 0 3 -33.864728504919007 -46.741316650925199 -197.03764213282102 -24.112678297387802 -8.7643922643020815 -183.17089076648134 3.4796688611140851 -13.736076359857449 -75.534578203011677 -10.757099083603833 -26.051236797158204 -50.769143388502954
+6 0 7 -17.223996211720717 -20.493754856367339 -55.094504248433466 -16.29342164624962 -21.982988612308382 -54.294331156479743 -15.339450652188081 -23.130833763827287 -53.539728216345679 -14.386795797295949 -24.020002530741696 -52.853527663311084 -13.44782827922818 -24.715691744074448 -52.237838245565356 -12.528444015123595 -25.265351615179682 -51.688310740711962 -11.631396878521171 -25.702022091243354 -51.20061712403146 -10.75709908360383 -26.051236797158204 -50.769143388503011
+6 0 8 0 -59.531249999999993 205.7914345843613 53.876071588494497 -59.531249999999993 205.7914345843613 107.75214317698899 -59.531249999999993 189.67175165991443 156.00138393730137 -59.531249999999993 157.43238581102071 192.99845687390467 -59.531249999999993 111.42771102933125 214.34113745938743 -59.531249999999993 56.384968609722286 218.13662690627368 -59.531249999999993 -1.5197825264666989 205.15864602554765 -59.531249999999993 -56.237670640435404 178.22061023130038 -59.531249999999993 -102.89571729218068
+6 0 11 136.76832282427657 -35.074550547807057 140.12571466074974 135.07183292976654 -33.345803648511151 141.05037640956417 133.36694843991896 -31.428509372651153 141.91597127298954 131.66732761482371 -29.298305985021017 142.71486564949274 129.98880809670695 -26.927549047880522 143.44110677292491 128.35404712559006 -24.283858876432117 144.08831011337199 126.79412398898398 -21.329442866843618 144.65010317277901 125.35041594391345 -18.020367948515887 145.1212554529005 124.08005884956494 -14.304958412294658 145.49762437312833 123.06830374885259 -10.120494366325628 145.77304691574895 122.4510806371962 -5.3873860712519752 145.9313067761816 122.45108065680535 5.9354655679300095e-07 145.93130679574949
+6 0 7 153.706806932208 -46.741122158567293 127.84693343321202 151.62198898162015 -45.803624793566335 129.76211013502595 149.41729102030527 -44.701249308397287 131.65942312658856 147.0886382152851 -43.400327669690427 133.52443418418775 144.63875502475244 -41.857106180759281 135.33645123800679 142.07816236209067 -40.013940530783486 137.06493589321886 139.43423551564945 -37.791152818129198 138.67267476975564 136.76832282427657 -35.074550547807057 140.12571466074974
+6 0 8 174.97812452855587 -51.7329226751853 101.02405664622327 173.0189047278042 -51.732912854485221 104.41750303730812 170.93376361555104 -51.601743762268278 107.738247343441 168.69506668909372 -51.338871386050798 111.03483318224582 166.26011604038766 -50.931817831051113 114.35150652004693 163.59204265543062 -50.347008529168264 117.70392792224281 160.6440297270843 -49.527728575566378 121.09022384610934 157.35523834573667 -48.381742547318986 124.49537420503763 153.70680693220794 -46.741122158567315 127.846933433212
+6 0 8 187.57196784126955 -46.741316650925199 69.19110588888762 186.49361225386124 -48.381904503315276 74.026545751456723 185.18902763794131 -49.527860207970136 78.577310856918416 183.73038606473554 -50.347113313562076 82.823517160474267 182.16111447113059 -50.931898896315623 86.810346068039152 180.5062429614357 -51.338930921432265 90.57740735834092 178.77064281855777 -51.601783045068579 94.164461779101586 176.93734432930759 -51.732932495885372 97.630610255138421 174.97812452855592 -51.732922675185293 101.02405664622327
+6 0 7 189.73659869962205 -35.074864763070721 48.382335582866716 189.81117238018325 -37.791459134725535 51.417655159678979 189.74077535743243 -40.014231269106624 54.511277275686403 189.52413956735285 -41.857378155518383 57.593095137371634 189.17980675658737 -43.400579875824064 60.62079500959026 188.72896455070853 -44.701481722758139 63.569997317391881 188.18817103407432 -45.803837878130871 66.427997395990985 187.57196784126955 -46.741316650925199 69.19110588888762
+6 0 11 187.60575922305284 -1.1640743924345998e-09 33.080093160033869 187.60575922304741 -5.3874646923965983 33.080093160376286 187.7773186452574 -10.120641762283968 33.693772147100141 188.04468094924189 -14.305161879442473 34.707718523321972 188.35392230109267 -18.02061450500781 35.996100700911825 188.66775257561252 -21.329720794301576 37.482004441746142 188.96119045086164 -24.284158255985911 39.113875135333153 189.21807687868207 -26.927861768554184 40.853262214332794 189.42839121481043 -29.298625554005511 42.670062909493154 189.58633429218864 -31.428830708550993 44.541462545525626 189.68914272108307 -33.346122890199482 46.450768579440734 189.73659869962202 -35.074864763070728 48.382335582866716
+6 0 3 187.60575922305284 1.1640743924345998e-09 33.080093160033869 182.45996458051826 -3.3769783266042923e-09 62.263210842937411 57.389458423411511 -8.7222081409284604e-10 40.20981541491026 62.53525307204589 -9.9198427250257737e-12 11.02669773308228
+6 0 11 62.535253072045876 -9.9198427250257737e-12 11.026697733082287 62.535253072040426 2.9543441753943656 11.026697733117082 62.303625930308357 5.7018281013995908 11.06660417059922 61.894179380794981 8.2090288677152099 11.139063242608492 61.354497717526513 10.466929390129854 11.240689609077204 60.724006912667683 12.482011776612122 11.369792745606421 60.03370877313683 14.269641999487902 11.525054728199192 59.307062186787753 15.849413818208667 11.704928935519449 58.561489509167416 17.242119897225191 11.907529154285237 57.809986141858744 18.468018063481122 12.130778573404958 57.062311353417655 19.546060648040854 12.372588152465287 56.325238393913565 20.493754856366113 12.630833850179437
+6 0 3 189.73659869962202 35.074864763070714 48.382335582866716 175.45635576463732 0.10887999428432948 61.551353492436768 59.348950789847322 7.4290882403051199 40.898800474896341 56.325238393913608 20.493754856366067 12.630833850179428
+6 0 7 56.325238393913423 20.493754856367339 12.630833850179648 55.166980886121209 21.982988612308382 13.036648518016424 54.036490073163911 23.130833763827287 13.485510163280178 52.965895534698952 24.020002530741696 13.967433192138044 51.963209099056016 24.715691744074448 14.472758207240291 51.027612187722411 25.265351615179682 14.994204583367827 50.156733558112371 25.702022091243354 15.527223383717363 49.345917444620291 26.051236797158204 16.068650616824272
+6 0 3 187.57196784126955 46.741316650925199 69.19110588888762 170.68698378629119 8.7643922643020815 70.703253424421106 63.675029157393396 13.736076359857449 40.780770731988291 49.34591744462027 26.051236797158204 16.068650616824254
+6 0 8 49.345917444620284 26.051236797158221 16.068650616824243 47.926989246009143 26.662362532509217 17.016148274761335 46.688248595751887 27.011120957413748 17.988871230970545 45.607185269626385 27.223676017445488 18.97121917432856 44.652165938852647 27.356567859469344 19.960915857315751 43.80020677550656 27.439229691629617 20.959823176031012 43.036051388320857 27.489226236304017 21.973503641815398 42.346529805428489 27.514152342148886 23.012826794062086 41.724174220603196 27.514130321361055 24.090915103790266
+6 0 3 174.9781245285559 51.732922675185293 101.02405664622327 160.29592057899589 13.757130667893669 92.547182666149467 67.141455568120037 21.108731711322541 38.763673429889877 41.724174220603203 27.514130321361066 24.090915103790287
+6 0 8 41.724174220603317 27.514130321361051 24.09091510379028 41.101818635778024 27.514108300573216 25.16900341351846 40.546629049019806 27.489138153152677 26.285856880728133 40.050972689434388 27.439090443654631 27.454502844206484 39.612019434703342 27.356362693520051 28.691779389822052 39.232577922060457 27.223383713014776 30.013678255843086 38.922524378089975 27.010712894337082 31.441031826160849 38.699641481464965 26.661803827144681 33.000091022983263 38.588684572744064 26.050501597752074 34.702540910564245
+6 0 3 153.70680693220797 46.741122158567308 127.846933433212 146.57408349391423 8.7642115648255796 112.46792299154257 67.154343763738723 13.734061870832015 34.752851566359027 38.588684572744086 26.050501597752053 34.702540910564238
+6 0 7 38.588684572744043 26.050501597752049 34.702540910564252 38.52528062490353 25.701186038099131 35.675369417753387 38.499185339697725 25.264406091046144 36.695994821862044 38.51546459035842 24.714630031565918 37.766865243198616 38.579241212556916 24.018821526364665 38.887757951270167 38.697225826364502 23.129537747766257 40.055739031222686 38.873773116354364 21.981595656129571 41.259038841220736 39.101463569845009 20.492306450798917 42.464843260766422
+6 0 3 136.76832282427659 35.074550547807057 140.12571466074974 141.03318901432729 0.10870904567454431 121.17410810334528 65.093505103378178 7.42837265688744 30.947795308600405 39.101463569844995 20.492306450798921 42.464843260766415
+6 0 11 39.101463569844981 20.492306450798914 42.464843260766429 39.246357494793571 19.54457695649759 43.232173345931869 39.410778809442462 18.466514927876752 44.000459736560956 39.593179791020169 17.240618138524496 44.762775351822036 39.790489921626211 15.847940047192708 45.509625459034623 39.998010330190041 14.268229597291736 46.228719563876318 40.208664320754856 12.480701786314627 46.904029733839018 40.412064218291064 10.465770809900821 47.514471857778361 40.593854763244231 8.2080775852491978 48.032546344400281 40.735793286022314 5.7011434585903764 48.423274762528706 40.817026892626956 2.9539819014281479 48.643768925998252 40.817026892633677 2.599400694691667e-10 48.643768926015895
+6 0 3 122.45108065680537 5.9354654524668149e-07 145.93130679574946 145.15150460937122 5.9354648603478688e-07 126.88335906978408 63.517450842445783 -1.0424994201219632e-10 29.595821196769023 40.817026892633621 -2.5995872121576865e-10 48.643768926015895
+6 0 8 0 59.531249999999993 215.900000000001 56.52248782583662 59.531249999999993 215.900000000001 113.04497565167324 59.531249999999993 198.98851118892796 163.66424025416174 59.531249999999993 165.1655335667819 202.47862562032361 59.531249999999993 116.90108900703933 224.86966802552541 59.531249999999993 59.154622967792882 228.85159357669227 59.531249999999993 -1.5944349099215884 215.2361285899795 59.531249999999993 -59.000089657729269 186.9748846770612 59.531249999999993 -107.95000000000044
+6 0 8 39.59468146102445 -27.781250000000011 -22.859999999999946 42.618058276282397 -27.781250000000011 -24.605547418150795 45.641435091540338 -26.557187735411777 -26.351094836301638 48.487195638214807 -24.109063206235312 -27.994095453973358 50.977735779705249 -20.537529609657629 -29.432009475090432 52.957280627773017 -16.044048293666783 -30.574900225995293 54.314168969465584 -10.90967136344268 -31.358300075331762 54.992613140311867 -5.454835681721339 -31.749999999999996 54.992613140311867 1.7763568394002505e-15 -31.749999999999996
+6 0 8 39.59468146102455 -27.78125 -22.860000000000003 33.609947455935995 -27.78125 -33.22586336659856 24.52375438412157 -27.78125 -41.801098506142338 12.961149410406374 -27.78125 -47.503091972027391 8.8817841970012523e-15 -27.78125 -49.511049461804674 -12.961149410406362 -27.78125 -47.503091972027399 -24.52375438412156 -27.78125 -41.801098506142353 -33.609947455935981 -27.78125 -33.225863366598588 -39.594681461024543 -27.78125 -22.860000000000039
+6 0 8 -54.992613140311853 -2.5123963424448521e-15 -31.750000000000028 -54.992613140311853 -5.4548356817213426 -31.750000000000028 -54.31416896946557 -10.909671363442683 -31.358300075331794 -52.957280627773002 -16.044048293666787 -30.574900225995325 -50.977735779705235 -20.537529609657629 -29.432009475090464 -48.487195638214793 -24.109063206235309 -27.994095453973387 -45.641435091540323 -26.55718773541177 -26.351094836301662 -42.618058276282383 -27.78125 -24.605547418150817 -39.594681461024436 -27.78125 -22.859999999999967
+6 0 8 62.535253072045862 2.5123963424448521e-15 11.026697733082258 63.497514635994442 2.5123963424448521e-15 5.5694662695484674 63.915513615220895 2.5123963424448521e-15 0.016258502017621801 63.778081941432333 2.5123963424448521e-15 -5.5695964981720056 63.08289210295716 2.5123963424448521e-15 -11.12320709917366 61.836730391091628 2.5123963424448521e-15 -16.579662991518482 60.05541328830266 2.5123963424448521e-15 -21.875646849388609 57.763323327402816 2.5123963424448521e-15 -26.950989182909822 54.992613140311875 2.5123963424448521e-15 -31.750000000000007
+6 0 8 0 27.78125 45.720000000000013 11.969468010177115 27.78125 45.720000000000013 23.93893602035423 27.78125 42.138743545890442 34.658309700881162 27.78125 34.976230637671307 42.877826601950702 27.78125 24.755524730902334 47.619459111287533 27.78125 12.526861334356077 48.462690404475801 27.78125 -0.33764503974811078 45.579415466113112 27.78125 -12.494136633401453 39.594681461024557 27.78125 -22.860000000000014
+6 0 8 -3.5527136788005009e-14 2.5123963424448521e-15 63.500000000000014 -3.5527136788005009e-14 5.4548356817213426 63.500000000000014 -3.5273371525233546e-14 10.909671363442683 62.716600150663545 -3.4765840999690619e-14 16.044048293666787 61.149800451990608 -3.4029921737653372e-14 20.537529609657629 58.864018950180885 -3.3116421001784728e-14 24.109063206235309 55.988190907946731 -3.2096674648453486e-14 26.55718773541177 52.702189672603282 -3.1053339153569454e-14 27.78125 49.211094836301598 -3.007273249866494e-14 27.78125 45.719999999999899
+6 0 8 0 2.5123963424448521e-15 63.500000000000007 5.5414203741670232 2.5123963424448521e-15 63.500000000000007 11.082840748334046 2.5123963424448521e-15 62.947336967140913 16.559955858662029 2.5123963424448521e-15 61.842010901422725 21.908466131981388 2.5123963424448521e-15 60.192990654958173 27.065628914401191 2.5123963424448521e-15 58.018237415041121 31.971837083306227 2.5123963424448521e-15 55.34432923574569 36.572056592860363 2.5123963424448521e-15 52.205727617230089 40.817026892633351 2.5123963424448521e-15 48.643768926015881
+6 0 8 -40.817026892724456 2.5123963424448521e-15 48.643768925939433 -36.572056592946751 2.5123963424448521e-15 52.205727617171149 -31.971837083385196 2.5123963424448521e-15 55.344329235702645 -27.065628914470366 2.5123963424448521e-15 58.018237415011946 -21.908466132038782 2.5123963424448521e-15 60.192990654940473 -16.559955858706111 2.5123963424448521e-15 61.842010901413829 -11.082840748363783 2.5123963424448521e-15 62.94733696713795 -5.5414203741818957 2.5123963424448521e-15 63.500000000000014 -8.8817841970012523e-15 2.5123963424448521e-15 63.500000000000021
+6 0 8 -3.5527136788005009e-14 27.78125 45.719999999999921 -11.969468010177117 27.78125 45.719999999999914 -23.938936020354198 27.78125 42.13874354589035 -34.658309700881098 27.78125 34.976230637671229 -42.877826601950616 27.78125 24.755524730902277 -47.619459111287426 27.78125 12.526861334356058 -48.462690404475687 27.78125 -0.33764503974809479 -45.579415466113005 27.78125 -12.494136633401402 -39.594681461024464 27.78125 -22.859999999999928
+6 0 8 -54.992613140311853 -2.5123963424448521e-15 -31.750000000000021 -57.763323327395369 -2.5123963424448521e-15 -26.950989182922712 -60.055413288290353 -2.5123963424448521e-15 -21.875646849415855 -61.836730391077289 -2.5123963424448521e-15 -16.579662991561122 -63.082892102943788 -2.5123963424448521e-15 -11.12320709923223 -63.778081941423011 -2.5123963424448521e-15 -5.5695964982465158 -63.915513615218686 -2.5123963424448521e-15 0.016258501927695512 -63.497514636002293 -2.5123963424448521e-15 5.5694662694441703 -62.535253072066517 -2.5123963424448521e-15 11.026697732965125
+6 0 1 0 27.78125 0 39.594681461024564 27.78125 -22.859999999999999
+6 0 1 0 27.78125 0 -39.59468146102455 27.78125 -22.860000000000046
+6 0 3 -136.76863105899739 -35.074864763070714 140.12554671009278 -141.03321364408492 -0.10887999428432948 121.17398460139775 -65.093875590494918 -7.4290882403051199 30.94829883451213 -39.101242182192564 -20.493754856366067 42.463670398254067
+6 0 11 -40.817026892724499 9.9198427250257737e-12 48.643768925939433 -40.817026892751905 -2.9543441753943656 48.643768925917314 -40.735773310519939 -5.7018281013995908 48.423220718230297 -40.593801432857923 -8.2090288677152099 48.032400068855189 -40.411971616279899 -10.466929390129854 47.514208855273701 -40.208532809793034 -12.482011776612122 46.903636233148845 -39.997844561194889 -14.269641999487902 46.228189516833609 -39.790296901045281 -15.849413818208667 45.508958009821939 -39.592967498498574 -17.242119897225191 44.761973021252246 -39.410555483182037 -18.468018063481122 43.999527304573526 -39.246131327306159 -19.546060648040854 43.231117154484224 -39.101242182192607 -20.493754856366113 42.463670398254031
+6 0 11 -56.326364816470644 -20.492306450798914 12.630439146254291 -57.063339125786285 -19.54457695649759 12.372255923531089 -57.810905314777372 -18.466514927876752 12.130505763626122 -58.562290494083882 -17.240618138524496 11.907311839717094 -59.307736725052131 -15.847940047192708 11.704762371639658 -60.034250691838579 -14.268229597291736 11.524933264838815 -60.72441344974267 -12.480701786314627 11.36970988709516 -61.354771785382368 -10.465770809900821 11.240638303518997 -61.894332724326119 -8.2080775852491978 11.139036290305299 -62.303682721794885 -5.7011434585903764 11.066594447742542 -62.535253072048036 -2.9539819014281479 11.026697732968417 -62.535253072066673 -2.599400694691667e-10 11.026697732965417
+6 0 3 -189.73659003179711 -35.074550547807057 48.381984668439678 -175.45645040558244 -0.10870904567454431 61.551270411467165 -59.348329480057899 -7.42837265688744 40.898731386597284 -56.32636481647063 -20.492306450798921 12.630439146254311
+6 0 8 -186.97488467706114 -59.531249999999993 -107.95000000000053 -215.23612858997947 -59.531249999999993 -59.000089657729362 -228.85159357669224 -59.531249999999993 -1.5944349099216666 -224.86966802552544 -59.531249999999993 59.154622967792818 -202.47862562032367 -59.531249999999993 116.90108900703926 -163.6642402541618 -59.531249999999993 165.16553356678187 -113.0449756516733 -59.531249999999993 198.98851118892796 -56.522487825836677 -59.531249999999993 215.90000000000103 -4.2632564145606011e-14 -59.531249999999993 215.90000000000106
+6 0 5 0 -59.531249999999993 215.900000000001 0 -63.387277307658351 215.900000000001 0 -67.243304615316703 215.900000000001 0 -63.673414194443438 207.96645520057368 0 -61.62028542102334 206.86463054396202 0 -59.531249999999986 205.7914345843613
+6 0 7 -49.347624290789433 -26.050501597752049 16.067510683338856 -50.158416517620658 -25.701186038099131 15.526187000214181 -51.029256402723611 -25.264406091046144 14.993275118252622 -51.964797017092778 -24.714630031565918 14.47193815221107 -52.967406888298726 -24.018821526364665 13.966723973166758 -54.037900481580984 -23.129537747766257 13.484911106003562 -55.168262330403216 -21.981595656129571 13.036155639105059 -56.326364816470651 -20.492306450798917 12.630439146254313
+6 0 3 -187.57209561520366 -46.741122158567308 69.190532821276108 -170.68712016850492 -8.7642115648255796 70.702918346379761 -63.674024192286112 -13.734061870832015 40.780941890691281 -49.347624290789483 -26.050501597752053 16.067510683338902
+6 0 8 -41.725431590598276 -27.514130321361051 24.088737275075104 -42.347905661933261 -27.514108300573216 23.010717373565189 -43.037534343462461 -27.489138153152677 21.971482353911149 -43.801783256072149 -27.439090443654631 20.957908373223688 -44.653819548716363 -27.356362693520051 19.959125430744958 -45.608896791602973 -27.223383713014776 18.96957000853531 -46.689994471695336 -27.010712894337082 17.987378977764596 -47.9287378938348 -26.661803827144681 17.014827128807067 -49.34762429078944 -26.050501597752074 16.067510683338885
+6 0 3 -174.97846171326549 -51.732922675185293 101.02347262517473 -160.29617152706226 -13.757130667893669 92.546748011348456 -67.14105371834853 -21.108731711322541 38.764369454111154 -41.725431590598248 -27.514130321361066 24.088737275075019
+6 0 8 -38.588818361016436 -26.051236797158221 34.700492771678725 -38.699911303510646 -26.662362532509217 32.997916076566845 -38.922943769303494 -27.011120957413748 31.438773726639003 -39.233150380544181 -27.223676017445488 30.011371451435604 -39.612743184665419 -27.356567859469344 28.689452108386742 -40.051842717025991 -27.439229691629617 27.452180170584462 -40.547638058122459 -27.489226236304017 26.28356195995072 -41.102957519263228 -27.514152342148886 25.16675717658493 -41.725431590598212 -27.514130321361055 24.088737275075012
+6 0 3 -153.70723933635054 -46.741316650925199 127.84653624393336 -146.57430548890341 -8.7643922643020815 112.46763734206019 -67.154698018507474 -13.736076359857449 34.753807471023364 -38.588818361016394 -26.051236797158204 34.700492771678682
+6 0 7 -39.101242182192706 -20.493754856367339 42.463670398253804 -38.873559239871589 -21.982988612308382 41.257682638463308 -38.697039420975834 -23.130833763827287 40.05421805306549 -38.579099737403006 -24.020002530741696 38.886094471173031 -38.51538081982784 -24.715691744074448 37.765080038325053 -38.499168172598814 -25.265351615179682 36.694106157344123 -38.525336679591199 -25.702022091243354 35.673393740314083 -38.588818361016465 -26.051236797158204 34.700492771678725
+6 0 8 0 -59.531249999999993 215.900000000001 56.52248782583662 -59.531249999999993 215.900000000001 113.04497565167324 -59.531249999999993 198.98851118892796 163.66424025416174 -59.531249999999993 165.1655335667819 202.47862562032361 -59.531249999999993 116.90108900703933 224.86966802552541 -59.531249999999993 59.154622967792882 228.85159357669227 -59.531249999999993 -1.5944349099215884 215.2361285899795 -59.531249999999993 -59.000089657729269 186.9748846770612 -59.531249999999993 -107.95000000000044
+6 0 11 39.101463569844981 -20.492306450798914 42.464843260766429 39.246357494793571 -19.54457695649759 43.232173345931869 39.410778809442462 -18.466514927876752 44.000459736560956 39.593179791020169 -17.240618138524496 44.762775351822036 39.790489921626211 -15.847940047192708 45.509625459034623 39.998010330190041 -14.268229597291736 46.228719563876318 40.208664320754856 -12.480701786314627 46.904029733839018 40.412064218291064 -10.465770809900821 47.514471857778361 40.593854763244231 -8.2080775852491978 48.032546344400281 40.735793286022314 -5.7011434585903764 48.423274762528706 40.817026892626956 -2.9539819014281479 48.643768925998252 40.817026892633677 -2.599400694691667e-10 48.643768926015895
+6 0 3 136.76832282427659 -35.074550547807057 140.12571466074974 141.03318901432729 -0.10870904567454431 121.17410810334528 65.093505103378178 -7.42837265688744 30.947795308600405 39.101463569844995 -20.492306450798921 42.464843260766415
+6 0 7 38.588684572744043 -26.050501597752049 34.702540910564252 38.52528062490353 -25.701186038099131 35.675369417753387 38.499185339697725 -25.264406091046144 36.695994821862044 38.51546459035842 -24.714630031565918 37.766865243198616 38.579241212556916 -24.018821526364665 38.887757951270167 38.697225826364502 -23.129537747766257 40.055739031222686 38.873773116354364 -21.981595656129571 41.259038841220736 39.101463569845009 -20.492306450798917 42.464843260766422
+6 0 3 153.70680693220797 -46.741122158567308 127.846933433212 146.57408349391423 -8.7642115648255796 112.46792299154257 67.154343763738723 -13.734061870832015 34.752851566359027 38.588684572744086 -26.050501597752053 34.702540910564238
+6 0 8 41.724174220603317 -27.514130321361051 24.09091510379028 41.101818635778024 -27.514108300573216 25.16900341351846 40.546629049019806 -27.489138153152677 26.285856880728133 40.050972689434388 -27.439090443654631 27.454502844206484 39.612019434703342 -27.356362693520051 28.691779389822052 39.232577922060457 -27.223383713014776 30.013678255843086 38.922524378089975 -27.010712894337082 31.441031826160849 38.699641481464965 -26.661803827144681 33.000091022983263 38.588684572744064 -26.050501597752074 34.702540910564245
+6 0 3 174.9781245285559 -51.732922675185293 101.02405664622327 160.29592057899589 -13.757130667893669 92.547182666149467 67.141455568120037 -21.108731711322541 38.763673429889877 41.724174220603203 -27.514130321361066 24.090915103790287
+6 0 8 49.345917444620284 -26.051236797158221 16.068650616824243 47.926989246009143 -26.662362532509217 17.016148274761335 46.688248595751887 -27.011120957413748 17.988871230970545 45.607185269626385 -27.223676017445488 18.97121917432856 44.652165938852647 -27.356567859469344 19.960915857315751 43.80020677550656 -27.439229691629617 20.959823176031012 43.036051388320857 -27.489226236304017 21.973503641815398 42.346529805428489 -27.514152342148886 23.012826794062086 41.724174220603196 -27.514130321361055 24.090915103790266
+6 0 3 187.57196784126955 -46.741316650925199 69.19110588888762 170.68698378629119 -8.7643922643020815 70.703253424421106 63.675029157393396 -13.736076359857449 40.780770731988291 49.34591744462027 -26.051236797158204 16.068650616824254
+6 0 7 56.325238393913423 -20.493754856367339 12.630833850179648 55.166980886121209 -21.982988612308382 13.036648518016424 54.036490073163911 -23.130833763827287 13.485510163280178 52.965895534698952 -24.020002530741696 13.967433192138044 51.963209099056016 -24.715691744074448 14.472758207240291 51.027612187722411 -25.265351615179682 14.994204583367827 50.156733558112371 -25.702022091243354 15.527223383717363 49.345917444620291 -26.051236797158204 16.068650616824272
+6 0 3 189.73659869962202 -35.074864763070714 48.382335582866716 175.45635576463732 -0.10887999428432948 61.551353492436768 59.348950789847322 -7.4290882403051199 40.898800474896341 56.325238393913608 -20.493754856366067 12.630833850179428
+6 0 11 62.535253072045876 9.9198427250257737e-12 11.026697733082287 62.535253072040426 -2.9543441753943656 11.026697733117082 62.303625930308357 -5.7018281013995908 11.06660417059922 61.894179380794981 -8.2090288677152099 11.139063242608492 61.354497717526513 -10.466929390129854 11.240689609077204 60.724006912667683 -12.482011776612122 11.369792745606421 60.03370877313683 -14.269641999487902 11.525054728199192 59.307062186787753 -15.849413818208667 11.704928935519449 58.561489509167416 -17.242119897225191 11.907529154285237 57.809986141858744 -18.468018063481122 12.130778573404958 57.062311353417655 -19.546060648040854 12.372588152465287 56.325238393913565 -20.493754856366113 12.630833850179437
+6 0 8 -3.5527136788005009e-14 -27.78125 45.719999999999921 -11.969468010177117 -27.78125 45.719999999999914 -23.938936020354198 -27.78125 42.13874354589035 -34.658309700881098 -27.78125 34.976230637671229 -42.877826601950616 -27.78125 24.755524730902277 -47.619459111287426 -27.78125 12.526861334356058 -48.462690404475687 -27.78125 -0.33764503974809479 -45.579415466113005 -27.78125 -12.494136633401402 -39.594681461024464 -27.78125 -22.859999999999928
+6 0 8 -3.5527136788005009e-14 -2.5123963424448521e-15 63.500000000000014 -3.5527136788005009e-14 -5.4548356817213426 63.500000000000014 -3.5273371525233546e-14 -10.909671363442683 62.716600150663545 -3.4765840999690619e-14 -16.044048293666787 61.149800451990608 -3.4029921737653372e-14 -20.537529609657629 58.864018950180885 -3.3116421001784728e-14 -24.109063206235309 55.988190907946731 -3.2096674648453486e-14 -26.55718773541177 52.702189672603282 -3.1053339153569454e-14 -27.78125 49.211094836301598 -3.007273249866494e-14 -27.78125 45.719999999999899
+6 0 1 0 -27.78125 0 -39.594681461024543 -27.78125 -22.860000000000014
+6 0 1 0 -27.78125 0 39.594681461024564 -27.78125 -22.859999999999999
+6 0 8 0 -27.78125 45.720000000000013 11.969468010177115 -27.78125 45.720000000000013 23.93893602035423 -27.78125 42.138743545890442 34.658309700881162 -27.78125 34.976230637671307 42.877826601950702 -27.78125 24.755524730902334 47.619459111287533 -27.78125 12.526861334356077 48.462690404475801 -27.78125 -0.33764503974811078 45.579415466113112 -27.78125 -12.494136633401453 39.594681461024557 -27.78125 -22.860000000000014
+6 0 1 0 27.78125 0 0 27.78125 45.720000000000013
+6 0 1 0 -27.78125 0 -3.5527136788005009e-14 -27.78125 45.720000000000041
+6 0 11 -1529.1546415418891 1.5212731515907442e-09 -166.31141681056172 -1529.1546415415899 7.040608759378097 -166.31141681072825 -1528.7089596604233 13.226161675384731 -166.76683112198259 -1527.9645374925321 18.694702199137865 -167.50534685735843 -1527.0033864728816 23.550241825695096 -168.41734881275679 -1525.8734712230007 27.874747703013561 -169.43208567338476 -1524.6069486842875 31.73575458833502 -170.50214567457652 -1523.2290385007698 35.190678781909035 -171.59430938645627 -1521.7608001132119 38.288911666446005 -172.68484729190368 -1520.2190920264638 41.072770480691617 -173.75732982728135 -1518.6169887119418 43.578383955514511 -174.80101755538465 -1516.9679306071325 45.837590440898751 -175.8078991400738
+6 0 7 -1516.9679306071325 45.837590440898758 -175.80789914007383 -1514.3765535852895 49.387772060788272 -177.39014163029967 -1511.6621997317422 52.292602041671785 -178.87598707825035 -1508.8849492786464 54.701318730173803 -180.22928391151513 -1506.0907178688874 56.718052049058578 -181.44493288614504 -1503.3112126464921 58.418135754765565 -182.52909323665656 -1500.5657152160902 59.858750004066387 -183.48975235234897 -1497.8646914714268 61.083894229843317 -184.3376589799353
+6 0 8 -1497.8646914714268 61.083894229843331 -184.3376589799353 -1493.1378999182659 63.227896624952955 -185.82149557821137 -1488.5445294223205 64.725488949490895 -186.96707471216919 -1484.1378861071287 65.796129950538912 -187.82695720653481 -1479.9005551958328 66.560357046468354 -188.46134259481806 -1475.810748665971 67.092286888241262 -188.9117124725741 -1471.8364683413961 67.435795211684535 -189.20216586841022 -1467.9180464632343 67.607187884292017 -189.34755704201834 -1463.9996257817984 67.607175050109163 -189.34754611851233
+6 0 8 -1463.9996257817982 67.607175050109149 -189.3475461185123 -1460.0812051003622 67.607162215926294 -189.34753519500629 -1456.162785615652 67.435743874953104 -189.20212217438618 -1452.1885100702623 67.092209084422151 -188.91164668410241 -1448.098711379319 66.560251106319498 -188.46125423426213 -1443.8613925883481 65.795993013043613 -187.82684560482613 -1439.4547678293748 64.72531692567118 -186.96693948012654 -1434.8614254241634 63.227684972743376 -185.82133777559631 -1430.1346742835119 61.083640057486413 -184.33748310160246
+6 0 7 -1430.1346742835121 61.083640057486399 -184.33748310160246 -1427.4336736317114 59.858471534482419 -183.48956614503453 -1424.6882034014304 58.417832024035391 -182.52889819864541 -1421.9087300447006 56.717722453448197 -181.44473124170366 -1419.1145356487364 54.700963299933299 -180.22907868930741 -1416.3373276959403 52.292222090265781 -178.87578272230431 -1413.6230215629869 49.387371750914411 -177.38994434580695 -1411.0316957589873 45.837179808650731 -175.80771617630373
+6 0 11 -1411.0316957589873 45.83717980865076 -175.80771617630373 -1409.3826702473514 43.577966754482965 -174.80084370480168 -1407.7806008613159 41.072350542839558 -173.75716785778829 -1406.2389276237759 38.288494037687443 -172.68470023470633 -1404.7707246025523 35.190270102866158 -171.5941802529853 -1403.3928495827524 31.735363344135941 -170.50203739310629 -1402.1263609533332 27.874384493488019 -169.43200085855784 -1400.9964770871618 23.549919613319577 -168.41728915593953 -1400.0353534938754 18.6944362980759 -167.50531210046984 -1399.2909530248348 13.225969050962204 -166.76681775215476 -1398.8452844094727 7.0405060133275912 -166.31141678787378 -1398.8452844023309 -7.7567635159425663e-07 -166.31141681463976
+6 0 8 -1398.8452844023307 0 -166.31141681463978 -1383.2235888152609 0 -160.62559849663862 -1368.1689333529962 0 -153.38178004928221 -1353.8626038715831 0 -144.64593958700451 -1340.4766850434266 0 -134.50936750483245 -1328.169639362374 0 -123.08706056889034 -1317.0822453426013 0 -110.51508719467131 -1307.3342541051009 0 -96.947049295365716 -1299.0221235455715 0 -82.550016847114776
+6 0 2 -1285.7793527352076 77.798419876098649 -90.195734139294899 -1299.0221235455715 38.899209938049324 -82.550016847114748 -1299.0221235455715 0 -82.550016847114748
+6 0 8 -1285.7793527352076 77.798419876098649 -90.195734139294885 -1312.7173885294549 77.798419876098649 -136.85378079104015 -1353.6154792372233 77.798419876098649 -175.45198598056197 -1405.660209444422 77.798419876098649 -201.11737126785724 -1463.9999629665081 77.798419876098649 -210.15543890577675 -1522.3397164885941 77.798419876098649 -201.11737126785727 -1574.3844466957928 77.798419876098649 -175.45198598056203 -1615.2825374035613 77.798419876098649 -136.85378079104021 -1642.2205731978086 77.798419876098649 -90.195734139294927
+6 0 2 -1628.9778023874442 0 -82.550016847114804 -1628.9778023874442 38.899209938049324 -82.550016847114804 -1642.2205731978081 77.798419876098649 -90.195734139294956
+6 0 8 -1628.9778023874442 0 -82.550016847114776 -1620.6656718286599 0 -96.947049294074972 -1610.9176805921622 0 -110.51508719223847 -1599.8302865736237 0 -123.08706056550898 -1587.5232408940024 0 -134.50936750073626 -1574.1373220674327 0 -144.64593958246061 -1559.8309925877149 0 -153.38178004458302 -1544.7763371272024 0 -160.62559849209256 -1529.1546415418889 0 -166.31141681056175
+6 0 3 -1529.1546415418891 -1.5212731515907442e-09 -166.31141681056172 -1501.3084229455965 4.4132020377474123e-09 -176.44658676892067 -1457.8719705474182 1.1398594379166007e-09 -57.105653458674581 -1485.7181891458292 1.2961329275482691e-11 -46.970483506135963
+6 0 11 -1485.7181891458292 -1.2961329275487656e-11 -46.970483506136006 -1485.7181891457963 3.8608849741243039 -46.970483506148682 -1485.5678155862961 7.4514346111332106 -46.789841735943796 -1485.3003409144446 10.727970177436603 -46.471480158577961 -1484.9424890677542 13.678707695652278 -46.054915311465187 -1484.5154370693822 16.312118309212018 -45.573445825869548 -1484.0358271784494 18.648283040550496 -45.053261092147082 -1483.51672825225 20.712807996120318 -44.513903792455672 -1482.9684849771763 22.532866071489515 -43.969519022651767 -1482.3993936251843 24.134931209777697 -43.430322725092765 -1481.816142992619 25.543771266687177 -42.903722154063793 -1481.2239591782284 26.782265535385307 -42.394521095547745
+6 0 3 -1516.9679306071325 45.837590440898744 -175.8078991400738 -1498.4231050870603 0.1422898311632963 -170.0253549409488 -1458.2550381658602 9.7087046923396514 -59.147116156522728 -1481.2239591782288 26.782265535385235 -42.394521095547759
+6 0 7 -1481.2239591782286 26.782265535386912 -42.394521095547738 -1480.2933846127576 28.728470814771448 -41.594348003594014 -1479.339413618696 30.228532363128181 -40.839745063459951 -1478.3867587638038 31.390542653003166 -40.153544510425355 -1477.447791245736 32.299704169385478 -39.537855092679621 -1476.5284069816314 33.018027225617075 -38.988327587826227 -1475.631359845029 33.588690079904488 -38.500633971145724 -1474.7570620501117 34.045061352432313 -38.069160235617275
+6 0 3 -1497.8646914714268 61.083894229843331 -184.3376589799353 -1488.1126412638955 11.453746886500895 -170.47090761359561 -1460.5202941053935 17.950992732293471 -62.834595050125955 -1474.7570620501115 34.045061352432356 -38.069160235617233
+6 0 8 -1474.7570620501117 34.045061352432327 -38.069160235617254 -1473.2270409090063 34.843711079356019 -37.314081198442459 -1471.7652677929561 35.299486061000948 -36.72766180472383 -1470.37399785559 35.577263661960757 -36.282607472878446 -1469.039385720695 35.75093337868735 -35.950384812816772 -1467.7483270249884 35.858960002118444 -35.712020193729757 -1466.4883762967063 35.924297991408658 -35.557082448880401 -1465.2435352526732 35.956872675266212 -35.479600817761302 -1463.9987055965128 35.956843897397484 -35.479669225979563
+6 0 3 -1463.9996257817982 67.607175050109134 -189.34754611851233 -1463.9997120184414 17.978507556806619 -172.39394752461223 -1464.0003648162792 27.585948098341412 -64.828059731115317 -1463.9987055965128 35.956843897397434 -35.479669225979578
+6 0 8 -1463.998705596513 35.956843897397505 -35.47966922597967 -1462.7538759403528 35.95681511952877 -35.479737634197939 -1461.5090576720654 35.924182879933745 -35.557356081753568 -1460.2491523998704 35.858778025888753 -35.712428064544461 -1458.9581628524952 35.750665257546494 -35.9509216676813 -1457.6236440969658 35.576881663886944 -36.283265111492682 -1456.2324928729029 35.298952783729362 -36.728427651039731 -1454.7708665541384 34.842980935195818 -37.314934998904612 -1453.2410232484629 34.044100557016606 -38.070068441017412
+6 0 3 -1430.1346742835121 61.08364005748642 -184.33748310160243 -1439.8869262919172 11.453510739372341 -170.47085818503666 -1467.4802825379606 17.948360097113778 -62.833810304164629 -1453.2410232484626 34.044100557016513 -38.070068441017469
+6 0 7 -1453.2410232484624 34.044100557016577 -38.070068441017391 -1452.3668270737905 33.587597483771312 -38.501573265081852 -1451.4698919034818 33.016791567310825 -38.989286787228949 -1450.5506305397732 32.298316670290021 -39.538820242523968 -1449.6117972907657 31.388999257317714 -40.154498771551204 -1448.659288311291 30.226838664412266 -40.84066698434053 -1447.7054737524586 28.726650429853141 -41.595211327440076 -1446.7750617198817 26.780372686428379 -42.395299254135018
+6 0 3 -1411.0316957589873 45.837179808650738 -175.80771617630373 -1429.5767015752526 0.14206642695590688 -170.02539536192677 -1469.745138589828 9.7077695320803983 -59.146543542312003 -1446.7750617198822 26.780372686428407 -42.395299254135068
+6 0 11 -1446.7750617198822 26.780372686428375 -42.395299254135004 -1446.182981335515 25.541832304248981 -42.90444611657724 -1445.5998364611728 24.132966836866345 -43.430982347301352 -1445.0308522634441 22.530903497984863 -43.970104038653403 -1444.4827161630819 20.710881998324194 -44.514404677788555 -1443.9637226048594 18.646437242602509 -45.053669675829404 -1443.4842138375202 16.310406348263811 -45.573756468048451 -1443.0572553994168 13.677193604966824 -46.055127008411631 -1442.6994850054261 10.726726993852996 -46.471599481819851 -1442.4320735307354 7.4505398856111285 -46.789886057385523 -1442.2817367870869 3.8604115363561724 -46.970483506080946 -1442.281736787075 3.397033765395463e-10 -46.97048350609559
+6 0 3 -1398.8452844023307 7.7567636061915573e-07 -166.31141681463973 -1426.6915029992576 7.7567628323808538e-07 -176.44658677125582 -1470.1279553854667 -1.3623904689964729e-10 -57.105653458686106 -1442.2817367870748 -3.3972708020790962e-10 -46.970483506095491
+6 0 11 -1586.4510436141795 1.5212731515907442e-09 158.63128995629927 -1586.4510436144733 7.040608759378097 158.63128995612337 -1587.0682849178497 13.226161675384731 158.47302528065387 -1588.0800693897252 18.694702199137865 158.19759463980787 -1589.3504617612266 23.550241825695096 157.82121441761637 -1590.7942072856274 27.874747703013561 157.35004753741006 -1592.3541676995897 31.73575458833502 156.78823684501481 -1593.9889643109279 35.190678781909035 156.14101347789492 -1595.6675170346143 38.288911666446005 155.41475068818195 -1597.3671681987405 41.072770480691617 154.61583358752713 -1599.0720799421572 43.578383955514511 153.75021528171533 -1600.7685940255053 45.837590440898751 152.8255298629785
+6 0 7 -1600.7685940255053 45.837590440898758 152.82552986297853 -1603.4345447279095 49.387772060788272 151.37245277639209 -1606.078501558706 52.292602041671785 149.76467610833538 -1608.6391162217221 54.701318730173803 148.03615507991492 -1611.0890148207156 56.718052049058578 146.22410418232622 -1613.4176778372321 58.418135754765565 144.35906222503613 -1615.6223817509997 59.858750004066387 142.46172126212943 -1617.7072023028584 61.083894229843317 140.54651939681912
+6 0 8 -1617.7072023028584 61.083894229843331 140.54651939681909 -1621.3556382686111 63.227896624952955 137.19491613252606 -1624.6444241486367 64.725488949490895 133.78973016102219 -1627.5924258906227 65.796129950538912 130.40340635183196 -1630.2604852083136 66.560357046468354 127.05096283255033 -1632.6954202284805 67.092286888241262 123.73427142000457 -1634.9341004101775 67.435795211684535 120.43767039508005 -1637.0192237990891 67.607187884292017 117.11691309265133 -1638.9784246797733 67.607175050109163 113.72345577806047
+6 0 8 -1638.9784246797733 67.607175050109149 113.72345577806044 -1640.9376255604575 67.607162215926294 110.32999846346958 -1642.7709039329145 67.435743874953104 106.86384113671657 -1644.5064825518468 67.092209084422151 103.27677980762799 -1646.1613305940841 66.560251106319498 99.509714019986589 -1647.7305760000979 65.795993013043613 95.522883988354707 -1649.1891878307249 64.72531692567118 91.276681939788574 -1650.4937388545886 63.227684972743376 86.725929876330056 -1651.5720585817114 61.083640057486413 81.890515974161829
+6 0 7 -1651.5720585817114 61.083640057486399 81.890515974161858 -1652.1882412829245 59.858471534482419 79.127422315780009 -1652.7290135518906 58.417832024035391 76.269441377828258 -1653.1798341036003 56.717722453448197 73.320263363287296 -1653.5241453090318 54.700963299933299 70.292593757072012 -1653.7407605991662 52.292222090265781 67.210813134856849 -1653.8111398856784 49.387371750914411 64.117235881822694 -1653.7365529983049 45.837179808650731 61.081967821325385
+6 0 11 -1653.7365529983049 45.83717980865076 61.081967821325392 -1653.6890886154308 43.577966754482965 59.15043360100892 -1653.5862735116186 41.072350542839558 57.241162890570159 -1653.4283259240633 38.288494037687443 55.369800890985005 -1653.21800942717 35.190270102866158 53.553039785831793 -1652.9611234758529 31.735363344135941 51.813693585505703 -1652.6676889686662 27.874384493488019 50.181863991550223 -1652.3538647897672 23.549919613319577 48.696000008810422 -1652.0446312887052 18.6944362980759 47.407654033112905 -1651.7772766570333 13.225969050962204 46.39373714217723 -1651.6057221607391 7.0405060133275912 45.780076317463596 -1651.6057221874901 -7.7567635159425663e-07 45.780076324661671
+6 0 8 -1651.6057221874903 0 45.780076324661714 -1654.4925068763332 0 29.408381937071383 -1655.7465038116527 0 12.748758637849761 -1655.3342087886188 0 -4.0088063591029623 -1653.248639272244 0 -20.669638158368969 -1649.5101541364213 0 -37.039005831667211 -1644.1662028285325 0 -52.926957401667593 -1637.289932946974 0 -68.152984398863865 -1628.9778023874446 0 -82.55001684711479
+6 0 8 -1642.2205731978083 77.798419876098606 -90.195734139294927 -1669.1586089920556 77.798419876098606 -43.537687487549675 -1682.1365898727818 77.798419876098606 11.180200626419023 -1678.3411004258955 77.798419876098606 69.084951762608 -1656.9984198404129 77.798419876098606 124.12769418221694 -1620.0013469038097 77.798419876098606 170.1323689639064 -1571.7521061434973 77.798419876098606 202.37173481280013 -1517.8760345550027 77.798419876098606 218.49141773724699 -1463.9999629665081 77.798419876098606 218.49141773724699
+6 0 2 -1463.9999629665078 77.798419876098649 218.49141773724699 -1463.9999629665078 38.899209938049324 203.19998315288669 -1463.9999629665078 0 203.19998315288669
+6 0 8 -1463.9999629665078 0 203.19998315288672 -1480.6242240840763 0 203.19998315288672 -1497.2484852016448 0 201.54199405529332 -1513.6798305278678 0 198.22601586010654 -1529.7253613434084 0 193.27895512363261 -1545.1968496867585 0 186.75469540768918 -1559.9154741902234 0 178.7329708744046 -1573.7161327164254 0 169.31716602413343 -1586.4510436141793 0 158.63128995629936
+6 0 2 -1642.2205731978081 -77.798419876098649 -90.195734139294913 -1628.9778023874442 -38.899209938049324 -82.550016847114762 -1628.9778023874442 0 -82.550016847114762
+6 0 8 -1285.7793527352073 -77.798419876098606 -90.195734139294871 -1312.7173885294546 -77.798419876098606 -136.85378079104015 -1353.6154792372231 -77.798419876098606 -175.45198598056197 -1405.6602094444218 -77.798419876098606 -201.11737126785724 -1463.9999629665078 -77.798419876098606 -210.15543890577675 -1522.3397164885939 -77.798419876098606 -201.11737126785727 -1574.3844466957926 -77.798419876098606 -175.45198598056203 -1615.282537403561 -77.798419876098606 -136.85378079104021 -1642.2205731978083 -77.798419876098606 -90.195734139294956
+6 0 2 -1299.0221235455713 0 -82.550016847114748 -1299.0221235455713 -38.899209938049324 -82.550016847114748 -1285.7793527352073 -77.798419876098649 -90.195734139294899
+6 0 11 -1411.0316957589873 -45.83717980865076 -175.80771617630373 -1409.3826702473514 -43.577966754482965 -174.80084370480168 -1407.7806008613159 -41.072350542839558 -173.75716785778829 -1406.2389276237759 -38.288494037687443 -172.68470023470633 -1404.7707246025523 -35.190270102866158 -171.5941802529853 -1403.3928495827524 -31.735363344135941 -170.50203739310629 -1402.1263609533332 -27.874384493488019 -169.43200085855784 -1400.9964770871618 -23.549919613319577 -168.41728915593953 -1400.0353534938754 -18.6944362980759 -167.50531210046984 -1399.2909530248348 -13.225969050962204 -166.76681775215476 -1398.8452844094727 -7.0405060133275912 -166.31141678787378 -1398.8452844023309 7.7567635159425663e-07 -166.31141681463976
+6 0 7 -1430.1346742835121 -61.083640057486399 -184.33748310160246 -1427.4336736317114 -59.858471534482419 -183.48956614503453 -1424.6882034014304 -58.417832024035391 -182.52889819864541 -1421.9087300447006 -56.717722453448197 -181.44473124170366 -1419.1145356487364 -54.700963299933299 -180.22907868930741 -1416.3373276959403 -52.292222090265781 -178.87578272230431 -1413.6230215629869 -49.387371750914411 -177.38994434580695 -1411.0316957589873 -45.837179808650731 -175.80771617630373
+6 0 8 -1463.9996257817982 -67.607175050109149 -189.3475461185123 -1460.0812051003622 -67.607162215926294 -189.34753519500629 -1456.162785615652 -67.435743874953104 -189.20212217438618 -1452.1885100702623 -67.092209084422151 -188.91164668410241 -1448.098711379319 -66.560251106319498 -188.46125423426213 -1443.8613925883481 -65.795993013043613 -187.82684560482613 -1439.4547678293748 -64.72531692567118 -186.96693948012654 -1434.8614254241634 -63.227684972743376 -185.82133777559631 -1430.1346742835119 -61.083640057486413 -184.33748310160246
+6 0 8 -1497.8646914714268 -61.083894229843331 -184.3376589799353 -1493.1378999182659 -63.227896624952955 -185.82149557821137 -1488.5445294223205 -64.725488949490895 -186.96707471216919 -1484.1378861071287 -65.796129950538912 -187.82695720653481 -1479.9005551958328 -66.560357046468354 -188.46134259481806 -1475.810748665971 -67.092286888241262 -188.9117124725741 -1471.8364683413961 -67.435795211684535 -189.20216586841022 -1467.9180464632343 -67.607187884292017 -189.34755704201834 -1463.9996257817984 -67.607175050109163 -189.34754611851233
+6 0 7 -1516.9679306071325 -45.837590440898758 -175.80789914007383 -1514.3765535852895 -49.387772060788272 -177.39014163029967 -1511.6621997317422 -52.292602041671785 -178.87598707825035 -1508.8849492786464 -54.701318730173803 -180.22928391151513 -1506.0907178688874 -56.718052049058578 -181.44493288614504 -1503.3112126464921 -58.418135754765565 -182.52909323665656 -1500.5657152160902 -59.858750004066387 -183.48975235234897 -1497.8646914714268 -61.083894229843317 -184.3376589799353
+6 0 11 -1529.1546415418891 -1.5212731515907442e-09 -166.31141681056172 -1529.1546415415899 -7.040608759378097 -166.31141681072825 -1528.7089596604233 -13.226161675384731 -166.76683112198259 -1527.9645374925321 -18.694702199137865 -167.50534685735843 -1527.0033864728816 -23.550241825695096 -168.41734881275679 -1525.8734712230007 -27.874747703013561 -169.43208567338476 -1524.6069486842875 -31.73575458833502 -170.50214567457652 -1523.2290385007698 -35.190678781909035 -171.59430938645627 -1521.7608001132119 -38.288911666446005 -172.68484729190368 -1520.2190920264638 -41.072770480691617 -173.75732982728135 -1518.6169887119418 -43.578383955514511 -174.80101755538465 -1516.9679306071325 -45.837590440898751 -175.8078991400738
+6 0 11 -1276.3942037434549 1.5212731515907442e-09 45.780076312919597 -1276.3942037434604 7.040608759378097 45.780076313262015 -1276.2226443212503 13.226161675384731 46.39375529998587 -1275.9552820172657 18.694702199137865 47.407701676207701 -1275.6460406654151 23.550241825695096 48.696083853797553 -1275.3322103908952 27.874747703013561 50.18198759463187 -1275.0387725156461 31.73575458833502 51.813858288218881 -1274.7818860878256 35.190678781909035 53.553245367218523 -1274.5715717516973 38.288911666446005 55.370046062378883 -1274.4136286743192 41.072770480691617 57.241445698411354 -1274.3108202454248 43.578383955514511 59.150751732326462 -1274.2633642668859 45.837590440898751 61.082318735752445
+6 0 7 -1274.2633642668859 45.837590440898758 61.082318735752445 -1274.1887905863248 49.387772060788272 64.117638312564708 -1274.2591876090755 52.292602041671785 67.211260428572132 -1274.4758233991552 54.701318730173803 70.29307829025737 -1274.8201562099207 56.718052049058578 73.320778162476003 -1275.2709984157996 58.418135754765565 76.269980470277631 -1275.8117919324338 59.858750004066387 79.127980548876735 -1276.4279951252386 61.083894229843317 81.89108904177337
+6 0 8 -1276.4279951252383 61.083894229843331 81.891089041773355 -1277.5063507126467 63.227896624952955 86.726528904342459 -1278.8109353285668 64.725488949490895 91.277294009804152 -1280.2695769017726 65.796129950538912 95.523500313360003 -1281.8388484953775 66.560357046468354 99.510329220924888 -1283.4937200050724 67.092286888241262 103.27739051122666 -1285.2293201479504 67.435795211684535 106.86444493198732 -1287.0626186372006 67.607187884292017 110.33059340802416 -1289.0218384379523 67.607175050109163 113.72403979910901
+6 0 8 -1289.0218384379521 67.607175050109149 113.72403979910901 -1290.9810582387038 67.607162215926294 117.11748619019386 -1293.0661993509568 67.435743874953104 120.43823049632674 -1295.3048962774142 67.092209084422151 123.73481633513155 -1297.7398469261202 66.560251106319498 127.05148967293266 -1300.4079203110773 65.795993013043613 130.40391107512855 -1303.3559332394236 64.72531692567118 133.79020699899507 -1306.6447246207713 63.227684972743376 137.19535735792337 -1310.2931560343 61.083640057486413 140.54691658609775
+6 0 7 -1310.2931560342997 61.083640057486399 140.54691658609775 -1312.3779739848876 59.858471534482419 142.46209328791167 -1314.5826719462025 58.417832024035391 144.35940627947429 -1316.9113247512225 56.717722453448197 146.22441733707348 -1319.3612079417553 54.700963299933299 148.03643439089251 -1321.9218006044171 52.292222090265781 149.76491904610458 -1324.5657274508583 49.387371750914411 151.37265792264137 -1327.2316401422311 45.837179808650731 152.82569781363546
+6 0 11 -1327.2316401422313 45.83717980865076 152.82569781363546 -1328.9281300367413 43.577966754482965 153.75035956244989 -1330.6330145265888 41.072350542839558 154.61595442587526 -1332.3326353516841 38.288494037687443 155.41484880237846 -1334.0111548698007 35.190270102866158 156.14108992581063 -1335.6459158409177 31.735363344135941 156.78829326625771 -1337.2058389775239 27.874384493488019 157.35008632566473 -1338.6495470225943 23.549919613319577 157.82123860578622 -1339.9199041169429 18.6944362980759 158.19760752601405 -1340.9316592176554 13.225969050962204 158.47303006863467 -1341.5488823293117 7.0405060133275912 158.63128992906732 -1341.5488823097025 -7.7567635159425663e-07 158.63128994863521
+6 0 8 -1341.5488823097023 0 158.63128994863521 -1354.2837932079292 0 169.31716601822438 -1368.0844517348746 0 178.73297087008962 -1382.8030762393216 0 186.75469540476462 -1398.2745645838529 0 193.27895512185856 -1414.3200954007284 0 198.2260158592147 -1430.75144072839 0 201.54199405499605 -1447.3757018474489 0 203.19998315288674 -1463.9999629665078 0 203.19998315288674
+6 0 8 -1463.9999629665078 77.798419876098606 218.49141773724702 -1410.1238913780132 77.798419876098606 218.49141773724702 -1356.2478197895186 77.798419876098606 202.37173481280016 -1307.9985790292062 77.798419876098606 170.13236896390643 -1271.001506092603 77.798419876098606 124.12769418221697 -1249.6588255071204 77.798419876098606 69.084951762608 -1245.8633360602341 77.798419876098606 11.180200626419015 -1258.8413169409603 77.798419876098606 -43.53768748754969 -1285.7793527352076 77.798419876098606 -90.195734139294956
+6 0 8 -1299.0221235455715 0 -82.550016847114733 -1290.7099929867873 0 -68.152984400154537 -1283.8337231057164 0 -52.926957404397641 -1278.4897717980318 0 -37.039005835940344 -1274.7512866621125 0 -20.669638164239142 -1272.6657171453319 0 -4.0088063665713491 -1272.2534221215847 0 12.748758628835649 -1273.5074190558953 0 29.408381926616372 -1276.3942037434549 0 45.780076312919633
+6 0 5 -1650.9748476435691 77.798419876098649 -95.250016847114793 -1650.9748476435691 82.837669539677151 -95.250016847114793 -1650.9748476435691 87.876919203255639 -95.250016847114793 -1644.104196305203 83.21160755811529 -91.283244447401131 -1643.1499881620612 80.528476020070357 -90.732332119095304 -1642.2205731978081 77.798419876098592 -90.195734139294927
+6 0 5 -1277.0250782894466 77.798419876098649 -95.250016847114736 -1277.0250782894466 82.837669539677151 -95.250016847114736 -1277.0250782894466 87.876919203255639 -95.250016847114736 -1283.8957296278127 83.21160755811529 -91.283244447401074 -1284.8499377709545 80.528476020070357 -90.732332119095247 -1285.7793527352076 77.798419876098592 -90.195734139294885
+6 0 8 -1277.0250782894466 77.798419876098649 -95.250016847114736 -1305.2863222023648 77.798419876098649 -144.1999271893859 -1348.1933450414886 77.798419876098649 -184.69409312612055 -1402.7945351951439 77.798419876098649 -211.62017338168897 -1463.9999629665076 77.798419876098649 -221.10219486119283 -1525.2053907378713 77.798419876098649 -211.62017338168897 -1579.8065808915267 77.798419876098649 -184.69409312612058 -1622.7136037306504 77.798419876098649 -144.19992718938593 -1650.9748476435689 77.798419876098649 -95.250016847114779
+6 0 8 -1485.7181891458292 0 -46.970483506135977 -1490.9254210095555 0 -45.075210733833899 -1495.9436394983436 0 -42.660604584834552 -1500.7124159934699 0 -39.748657763954228 -1505.1743889374263 0 -36.369800402881097 -1509.2767374988935 0 -32.562364757009632 -1512.9725355064468 0 -28.371706964863627 -1516.2218659197288 0 -23.849027664204474 -1518.9925761068198 0 -19.050016847114293
+6 0 8 -1503.5946444275323 36.305929275512725 -10.160016847114226 -1506.6180212427903 36.305929275512725 -11.905564265265077 -1509.6413980580483 34.706263385498261 -13.651111683415921 -1512.4871586047227 31.50693160546934 -15.294112301087644 -1514.977698746213 26.839472575999217 -16.732026322204721 -1516.9572435942807 20.967166079380046 -17.874917073109582 -1518.3141319359734 14.257305086712677 -18.658316922446051 -1518.9925761068196 7.1286525433563437 -19.050016847114286 -1518.9925761068196 1.1546319456101628e-14 -19.050016847114286
+6 0 8 -1503.5946444275323 36.305929275512717 -10.160016847114255 -1497.6099104224438 36.305929275512717 -20.525880213712782 -1488.5237173506293 36.305929275512717 -29.101115353256528 -1476.9611123769141 36.305929275512717 -34.803108819141563 -1463.9999629665078 36.305929275512717 -36.811066308918839 -1451.0388135561016 36.305929275512717 -34.803108819141563 -1439.4762085823863 36.305929275512717 -29.101115353256525 -1430.3900155105719 36.305929275512717 -20.525880213712774 -1424.4052815054833 36.305929275512717 -10.160016847114246
+6 0 8 -1424.4052815054833 36.305929275512725 -10.160016847114216 -1421.3819046902254 36.305929275512725 -11.905564265265065 -1418.3585278749674 34.706263385498261 -13.651111683415909 -1415.512767328293 31.50693160546934 -15.294112301087631 -1413.0222271868024 26.839472575999217 -16.732026322204707 -1411.0426823387347 20.967166079380046 -17.874917073109568 -1409.6857939970421 14.257305086712677 -18.658316922446037 -1409.0073498261959 7.1286525433563437 -19.050016847114271 -1409.0073498261959 1.1546319456101628e-14 -19.050016847114271
+6 0 8 -1409.0073498261959 0 -19.050016847114264 -1411.7780600132794 0 -23.849027664191574 -1415.0273904265514 0 -28.371706964839341 -1418.7231884340924 0 -32.562364756975889 -1422.8255369955452 0 -36.369800402840227 -1427.2875099394857 0 -39.748657763908888 -1432.056286434595 0 -42.660604584787663 -1437.0745049233656 0 -45.075210733788538 -1442.2817367870744 0 -46.970483506095285
+6 0 3 -1516.9679306071325 -45.837590440898744 -175.8078991400738 -1498.4231050870603 -0.1422898311632963 -170.0253549409488 -1458.2550381658602 -9.7087046923396514 -59.147116156522728 -1481.2239591782288 -26.782265535385235 -42.394521095547759
+6 0 11 -1485.7181891458292 1.2961329275487656e-11 -46.970483506136006 -1485.7181891457963 -3.8608849741243039 -46.970483506148682 -1485.5678155862961 -7.4514346111332106 -46.789841735943796 -1485.3003409144446 -10.727970177436603 -46.471480158577961 -1484.9424890677542 -13.678707695652278 -46.054915311465187 -1484.5154370693822 -16.312118309212018 -45.573445825869548 -1484.0358271784494 -18.648283040550496 -45.053261092147082 -1483.51672825225 -20.712807996120318 -44.513903792455672 -1482.9684849771763 -22.532866071489515 -43.969519022651767 -1482.3993936251843 -24.134931209777697 -43.430322725092765 -1481.816142992619 -25.543771266687177 -42.903722154063793 -1481.2239591782284 -26.782265535385307 -42.394521095547745
+6 0 11 -1446.7750617198822 -26.780372686428375 -42.395299254135004 -1446.182981335515 -25.541832304248981 -42.90444611657724 -1445.5998364611728 -24.132966836866345 -43.430982347301352 -1445.0308522634441 -22.530903497984863 -43.970104038653403 -1444.4827161630819 -20.710881998324194 -44.514404677788555 -1443.9637226048594 -18.646437242602509 -45.053669675829404 -1443.4842138375202 -16.310406348263811 -45.573756468048451 -1443.0572553994168 -13.677193604966824 -46.055127008411631 -1442.6994850054261 -10.726726993852996 -46.471599481819851 -1442.4320735307354 -7.4505398856111285 -46.789886057385523 -1442.2817367870869 -3.8604115363561724 -46.970483506080946 -1442.281736787075 -3.397033765395463e-10 -46.97048350609559
+6 0 3 -1411.0316957589873 -45.837179808650738 -175.80771617630373 -1429.5767015752526 -0.14206642695590688 -170.02539536192677 -1469.745138589828 -9.7077695320803983 -59.146543542312003 -1446.7750617198822 -26.780372686428407 -42.395299254135068
+6 0 3 -1586.4510436141795 -1.5212731515907442e-09 158.63128995629927 -1609.1514675679375 4.4132020377474123e-09 139.58334223175467 -1527.517413809009 1.1398594379166007e-09 42.295804349535786 -1504.8169898592323 1.2961329275482691e-11 61.343752078825204
+6 0 11 -1504.8169898592323 -1.2961329275487656e-11 61.343752078825162 -1504.8169898592598 3.8608849741243039 61.343752078803043 -1504.7357362770279 7.4514346111332106 61.123203871116026 -1504.5937643993659 10.727970177436603 60.732383221740918 -1504.4119345827878 13.678707695652278 60.214192008159429 -1504.2084957763009 16.312118309212018 59.603619386034573 -1503.9978075277027 18.648283040550496 58.928172669719338 -1503.790259867553 20.712807996120318 58.208941162707667 -1503.5929304650062 22.532866071489515 57.461956174137974 -1503.4105184496898 24.134931209777697 56.699510457459255 -1503.2460942938139 25.543771266687177 55.931100307369952 -1503.1012051487003 26.782265535385307 55.16365355113976
+6 0 3 -1600.7685940255053 45.837590440898744 152.8255298629785 -1605.0331766105928 0.1422898311632963 133.87396775428346 -1529.0938385570028 9.7087046923396514 43.648281987397837 -1503.1012051487005 26.782265535385235 55.163653551139774
+6 0 7 -1503.1012051487005 26.782265535386912 55.163653551139532 -1502.8735222063794 28.728470814771448 53.957665791349037 -1502.6970023874837 30.228532363128181 52.754201205951219 -1502.5790627039109 31.390542653003166 51.58607762405876 -1502.5153437863357 32.299704169385478 50.465063191210781 -1502.4991311391068 33.018027225617075 49.394089310229852 -1502.5252996460993 33.588690079904488 48.373376893199811 -1502.5887813275244 34.045061352432313 47.400475924564454
+6 0 3 -1617.7072023028584 61.083894229843331 140.54651939681909 -1610.5742684554111 11.453746886500895 125.16762049494592 -1531.1546609850152 17.950992732293471 47.4537906239091 -1502.5887813275242 34.045061352432356 47.400475924564418
+6 0 8 -1502.5887813275242 34.045061352432327 47.400475924564454 -1502.6998742700184 34.843711079356019 45.697899229452574 -1502.9229067358112 35.299486061000948 44.138756879524735 -1503.2331133470518 35.577263661960757 42.711354604321336 -1503.6127061511731 35.75093337868735 41.389435261272475 -1504.0518056835338 35.858960002118444 40.152163323470191 -1504.5476010246302 35.924297991408658 38.983545112836445 -1505.1029204857709 35.956872675266212 37.866740329470659 -1505.725394557106 35.956843897397484 36.78872042796074
+6 0 3 -1638.9784246797733 67.607175050109134 113.72345577806047 -1624.29613449357 17.978507556806619 105.24673116423419 -1531.1410166848564 27.585948098341412 51.46435260699689 -1505.725394557106 35.956843897397434 36.788720427960754
+6 0 8 -1505.725394557106 35.956843897397505 36.788720427960833 -1506.3478686284411 35.95681511952877 35.710700526450921 -1507.0374973099704 35.924182879933745 34.671465506796878 -1507.8017462225801 35.858778025888753 33.657891526109417 -1508.6537825152243 35.750665257546494 32.659108583630683 -1509.6088597581108 35.576881663886944 31.669553161421035 -1510.6899574382032 35.298952783729362 30.687362130650321 -1511.9287008603428 34.842980935195818 29.714810281692792 -1513.3475872572974 34.044100557016606 28.76749383622461
+6 0 3 -1651.5720585817114 61.08364005748642 81.890515974161843 -1634.6870831350127 11.453510739372341 83.402901499265496 -1527.6739871587938 17.948360097113778 53.480925043577017 -1513.3475872572972 34.044100557016513 28.767493836224638
+6 0 7 -1513.3475872572972 34.044100557016577 28.767493836224588 -1514.1583794841283 33.587597483771312 28.226170153099915 -1515.0292193692312 33.016791567310825 27.693258271138355 -1515.9647599836003 32.298316670290021 27.171921305096802 -1516.9673698548063 31.388999257317714 26.66670712605249 -1518.0378634480885 30.226838664412266 26.184894258889294 -1519.1682252969108 28.726650429853141 25.73613879199079 -1520.3263277829783 26.780372686428379 25.330422299140043
+6 0 3 -1653.7365529983049 45.837179808650738 61.081967821325406 -1639.4564133720903 0.14206642695590688 74.251253564352893 -1523.3482924465657 9.7077695320803983 53.598714539483012 -1520.3263277829783 26.780372686428407 25.330422299140039
+6 0 11 -1520.3263277829785 26.780372686428375 25.330422299140022 -1521.0633020922942 25.541832304248981 25.072239076416821 -1521.8108682812854 24.132966836866345 24.830488916511854 -1522.5622534605918 22.530903497984863 24.607294992602824 -1523.3076996915602 20.710881998324194 24.404745524525389 -1524.0342136583465 18.646437242602509 24.224916417724543 -1524.7243764162506 16.310406348263811 24.069693039980891 -1525.3547347518904 13.677193604966824 23.940621456404727 -1525.8942956908343 10.726726993852996 23.839019443191031 -1526.303645688303 7.4505398856111285 23.766577600628274 -1526.5352160385562 3.8604115363561724 23.726680885854147 -1526.5352160385748 3.397033765395463e-10 23.726680885851145
+6 0 3 -1651.6057221874903 7.7567636061915573e-07 45.780076324661685 -1646.4599275431292 7.7567628323808538e-07 74.963194007243175 -1521.3894213899948 -1.3623904689964729e-10 52.909798567688568 -1526.5352160385746 -3.3972708020790962e-10 23.726680885851128
+6 0 2 -1463.9999629665078 0 203.19998315288672 -1463.9999629665078 -38.899209938049324 203.19998315288672 -1463.9999629665078 -77.798419876098649 218.49141773724702
+6 0 8 -1642.2205731978081 -77.798419876098649 -90.195734139294956 -1669.1586089920554 -77.798419876098649 -43.537687487549704 -1682.1365898727815 -77.798419876098649 11.180200626418994 -1678.3411004258953 -77.798419876098649 69.084951762607972 -1656.9984198404127 -77.798419876098649 124.12769418221691 -1620.0013469038095 -77.798419876098649 170.1323689639064 -1571.752106143497 -77.798419876098649 202.37173481280013 -1517.8760345550027 -77.798419876098649 218.49141773724699 -1463.9999629665081 -77.798419876098649 218.49141773724699
+6 0 11 -1653.7365529983049 -45.83717980865076 61.081967821325392 -1653.6890886154308 -43.577966754482965 59.15043360100892 -1653.5862735116186 -41.072350542839558 57.241162890570159 -1653.4283259240633 -38.288494037687443 55.369800890985005 -1653.21800942717 -35.190270102866158 53.553039785831793 -1652.9611234758529 -31.735363344135941 51.813693585505703 -1652.6676889686662 -27.874384493488019 50.181863991550223 -1652.3538647897672 -23.549919613319577 48.696000008810422 -1652.0446312887052 -18.6944362980759 47.407654033112905 -1651.7772766570333 -13.225969050962204 46.39373714217723 -1651.6057221607391 -7.0405060133275912 45.780076317463596 -1651.6057221874901 7.7567635159425663e-07 45.780076324661671
+6 0 7 -1651.5720585817114 -61.083640057486399 81.890515974161858 -1652.1882412829245 -59.858471534482419 79.127422315780009 -1652.7290135518906 -58.417832024035391 76.269441377828258 -1653.1798341036003 -56.717722453448197 73.320263363287296 -1653.5241453090318 -54.700963299933299 70.292593757072012 -1653.7407605991662 -52.292222090265781 67.210813134856849 -1653.8111398856784 -49.387371750914411 64.117235881822694 -1653.7365529983049 -45.837179808650731 61.081967821325385
+6 0 8 -1638.9784246797733 -67.607175050109149 113.72345577806044 -1640.9376255604575 -67.607162215926294 110.32999846346958 -1642.7709039329145 -67.435743874953104 106.86384113671657 -1644.5064825518468 -67.092209084422151 103.27677980762799 -1646.1613305940841 -66.560251106319498 99.509714019986589 -1647.7305760000979 -65.795993013043613 95.522883988354707 -1649.1891878307249 -64.72531692567118 91.276681939788574 -1650.4937388545886 -63.227684972743376 86.725929876330056 -1651.5720585817114 -61.083640057486413 81.890515974161829
+6 0 8 -1617.7072023028584 -61.083894229843331 140.54651939681909 -1621.3556382686111 -63.227896624952955 137.19491613252606 -1624.6444241486367 -64.725488949490895 133.78973016102219 -1627.5924258906227 -65.796129950538912 130.40340635183196 -1630.2604852083136 -66.560357046468354 127.05096283255033 -1632.6954202284805 -67.092286888241262 123.73427142000457 -1634.9341004101775 -67.435795211684535 120.43767039508005 -1637.0192237990891 -67.607187884292017 117.11691309265133 -1638.9784246797733 -67.607175050109163 113.72345577806047
+6 0 7 -1600.7685940255053 -45.837590440898758 152.82552986297853 -1603.4345447279095 -49.387772060788272 151.37245277639209 -1606.078501558706 -52.292602041671785 149.76467610833538 -1608.6391162217221 -54.701318730173803 148.03615507991492 -1611.0890148207156 -56.718052049058578 146.22410418232622 -1613.4176778372321 -58.418135754765565 144.35906222503613 -1615.6223817509997 -59.858750004066387 142.46172126212943 -1617.7072023028584 -61.083894229843317 140.54651939681912
+6 0 11 -1586.4510436141795 -1.5212731515907442e-09 158.63128995629927 -1586.4510436144733 -7.040608759378097 158.63128995612337 -1587.0682849178497 -13.226161675384731 158.47302528065387 -1588.0800693897252 -18.694702199137865 158.19759463980787 -1589.3504617612266 -23.550241825695096 157.82121441761637 -1590.7942072856274 -27.874747703013561 157.35004753741006 -1592.3541676995897 -31.73575458833502 156.78823684501481 -1593.9889643109279 -35.190678781909035 156.14101347789492 -1595.6675170346143 -38.288911666446005 155.41475068818195 -1597.3671681987405 -41.072770480691617 154.61583358752713 -1599.0720799421572 -43.578383955514511 153.75021528171533 -1600.7685940255053 -45.837590440898751 152.8255298629785
+6 0 5 -1463.9999629665081 77.798419876098649 228.59998315288681 -1463.9999629665081 82.837669539677151 228.59998315288681 -1463.9999629665081 87.876919203255639 228.59998315288681 -1463.9999629665081 83.21160755811529 220.66643835345948 -1463.9999629665081 80.528476020070357 219.56461369684783 -1463.9999629665081 77.798419876098592 218.49141773724708
+6 0 8 -1650.9748476435691 77.798419876098649 -95.250016847114793 -1679.2360915564875 77.798419876098649 -46.300106504843626 -1692.8515565432003 77.798419876098649 11.105548242964069 -1688.8696309920335 77.798419876098649 71.854606120678554 -1666.4785885868318 77.798419876098649 129.601072159925 -1627.6642032206701 77.798419876098649 177.8655167196676 -1577.0449386181815 77.798419876098649 211.68849434181368 -1520.5224507923449 77.798419876098649 228.59998315288675 -1463.9999629665083 77.798419876098649 228.59998315288678
+6 0 7 -1453.2410232484624 -34.044100557016577 -38.070068441017391 -1452.3668270737905 -33.587597483771312 -38.501573265081852 -1451.4698919034818 -33.016791567310825 -38.989286787228949 -1450.5506305397732 -32.298316670290021 -39.538820242523968 -1449.6117972907657 -31.388999257317714 -40.154498771551204 -1448.659288311291 -30.226838664412266 -40.84066698434053 -1447.7054737524586 -28.726650429853141 -41.595211327440076 -1446.7750617198817 -26.780372686428379 -42.395299254135018
+6 0 3 -1430.1346742835121 -61.08364005748642 -184.33748310160243 -1439.8869262919172 -11.453510739372341 -170.47085818503666 -1467.4802825379606 -17.948360097113778 -62.833810304164629 -1453.2410232484626 -34.044100557016513 -38.070068441017469
+6 0 8 -1463.998705596513 -35.956843897397505 -35.47966922597967 -1462.7538759403528 -35.95681511952877 -35.479737634197939 -1461.5090576720654 -35.924182879933745 -35.557356081753568 -1460.2491523998704 -35.858778025888753 -35.712428064544461 -1458.9581628524952 -35.750665257546494 -35.9509216676813 -1457.6236440969658 -35.576881663886944 -36.283265111492682 -1456.2324928729029 -35.298952783729362 -36.728427651039731 -1454.7708665541384 -34.842980935195818 -37.314934998904612 -1453.2410232484629 -34.044100557016606 -38.070068441017412
+6 0 3 -1463.9996257817982 -67.607175050109134 -189.34754611851233 -1463.9997120184414 -17.978507556806619 -172.39394752461223 -1464.0003648162792 -27.585948098341412 -64.828059731115317 -1463.9987055965128 -35.956843897397434 -35.479669225979578
+6 0 8 -1277.0250782894466 -77.798419876098649 -95.250016847114736 -1305.2863222023648 -77.798419876098649 -144.1999271893859 -1348.1933450414886 -77.798419876098649 -184.69409312612055 -1402.7945351951439 -77.798419876098649 -211.62017338168897 -1463.9999629665076 -77.798419876098649 -221.10219486119283 -1525.2053907378713 -77.798419876098649 -211.62017338168897 -1579.8065808915267 -77.798419876098649 -184.69409312612058 -1622.7136037306504 -77.798419876098649 -144.19992718938593 -1650.9748476435689 -77.798419876098649 -95.250016847114779
+6 0 5 -1277.0250782894466 -77.798419876098649 -95.250016847114736 -1277.0250782894466 -82.837669539677151 -95.250016847114736 -1277.0250782894466 -87.876919203255639 -95.250016847114736 -1283.8957296278127 -83.21160755811529 -91.283244447401074 -1284.8499377709545 -80.528476020070357 -90.732332119095247 -1285.7793527352076 -77.798419876098592 -90.195734139294885
+6 0 5 -1650.9748476435691 -77.798419876098649 -95.250016847114793 -1650.9748476435691 -82.837669539677151 -95.250016847114793 -1650.9748476435691 -87.876919203255639 -95.250016847114793 -1644.104196305203 -83.21160755811529 -91.283244447401131 -1643.1499881620612 -80.528476020070357 -90.732332119095304 -1642.2205731978081 -77.798419876098592 -90.195734139294927
+6 0 8 -1474.7570620501117 -34.045061352432327 -38.069160235617254 -1473.2270409090063 -34.843711079356019 -37.314081198442459 -1471.7652677929561 -35.299486061000948 -36.72766180472383 -1470.37399785559 -35.577263661960757 -36.282607472878446 -1469.039385720695 -35.75093337868735 -35.950384812816772 -1467.7483270249884 -35.858960002118444 -35.712020193729757 -1466.4883762967063 -35.924297991408658 -35.557082448880401 -1465.2435352526732 -35.956872675266212 -35.479600817761302 -1463.9987055965128 -35.956843897397484 -35.479669225979563
+6 0 3 -1497.8646914714268 -61.083894229843331 -184.3376589799353 -1488.1126412638955 -11.453746886500895 -170.47090761359561 -1460.5202941053935 -17.950992732293471 -62.834595050125955 -1474.7570620501115 -34.045061352432356 -38.069160235617233
+6 0 7 -1481.2239591782286 -26.782265535386912 -42.394521095547738 -1480.2933846127576 -28.728470814771448 -41.594348003594014 -1479.339413618696 -30.228532363128181 -40.839745063459951 -1478.3867587638038 -31.390542653003166 -40.153544510425355 -1477.447791245736 -32.299704169385478 -39.537855092679621 -1476.5284069816314 -33.018027225617075 -38.988327587826227 -1475.631359845029 -33.588690079904488 -38.500633971145724 -1474.7570620501117 -34.045061352432313 -38.069160235617275
+6 0 8 -1463.9999629665078 -77.798419876098606 218.49141773724702 -1410.1238913780132 -77.798419876098606 218.49141773724702 -1356.2478197895186 -77.798419876098606 202.37173481280016 -1307.9985790292062 -77.798419876098606 170.13236896390643 -1271.001506092603 -77.798419876098606 124.12769418221697 -1249.6588255071204 -77.798419876098606 69.084951762608 -1245.8633360602341 -77.798419876098606 11.180200626419015 -1258.8413169409603 -77.798419876098606 -43.53768748754969 -1285.7793527352076 -77.798419876098606 -90.195734139294956
+6 0 11 -1327.2316401422313 -45.83717980865076 152.82569781363546 -1328.9281300367413 -43.577966754482965 153.75035956244989 -1330.6330145265888 -41.072350542839558 154.61595442587526 -1332.3326353516841 -38.288494037687443 155.41484880237846 -1334.0111548698007 -35.190270102866158 156.14108992581063 -1335.6459158409177 -31.735363344135941 156.78829326625771 -1337.2058389775239 -27.874384493488019 157.35008632566473 -1338.6495470225943 -23.549919613319577 157.82123860578622 -1339.9199041169429 -18.6944362980759 158.19760752601405 -1340.9316592176554 -13.225969050962204 158.47303006863467 -1341.5488823293117 -7.0405060133275912 158.63128992906732 -1341.5488823097025 7.7567635159425663e-07 158.63128994863521
+6 0 7 -1310.2931560342997 -61.083640057486399 140.54691658609775 -1312.3779739848876 -59.858471534482419 142.46209328791167 -1314.5826719462025 -58.417832024035391 144.35940627947429 -1316.9113247512225 -56.717722453448197 146.22441733707348 -1319.3612079417553 -54.700963299933299 148.03643439089251 -1321.9218006044171 -52.292222090265781 149.76491904610458 -1324.5657274508583 -49.387371750914411 151.37265792264137 -1327.2316401422311 -45.837179808650731 152.82569781363546
+6 0 8 -1289.0218384379521 -67.607175050109149 113.72403979910901 -1290.9810582387038 -67.607162215926294 117.11748619019386 -1293.0661993509568 -67.435743874953104 120.43823049632674 -1295.3048962774142 -67.092209084422151 123.73481633513155 -1297.7398469261202 -66.560251106319498 127.05148967293266 -1300.4079203110773 -65.795993013043613 130.40391107512855 -1303.3559332394236 -64.72531692567118 133.79020699899507 -1306.6447246207713 -63.227684972743376 137.19535735792337 -1310.2931560343 -61.083640057486413 140.54691658609775
+6 0 8 -1276.4279951252383 -61.083894229843331 81.891089041773355 -1277.5063507126467 -63.227896624952955 86.726528904342459 -1278.8109353285668 -64.725488949490895 91.277294009804152 -1280.2695769017726 -65.796129950538912 95.523500313360003 -1281.8388484953775 -66.560357046468354 99.510329220924888 -1283.4937200050724 -67.092286888241262 103.27739051122666 -1285.2293201479504 -67.435795211684535 106.86444493198732 -1287.0626186372006 -67.607187884292017 110.33059340802416 -1289.0218384379523 -67.607175050109163 113.72403979910901
+6 0 7 -1274.2633642668859 -45.837590440898758 61.082318735752445 -1274.1887905863248 -49.387772060788272 64.117638312564708 -1274.2591876090755 -52.292602041671785 67.211260428572132 -1274.4758233991552 -54.701318730173803 70.29307829025737 -1274.8201562099207 -56.718052049058578 73.320778162476003 -1275.2709984157996 -58.418135754765565 76.269980470277631 -1275.8117919324338 -59.858750004066387 79.127980548876735 -1276.4279951252386 -61.083894229843317 81.89108904177337
+6 0 11 -1276.3942037434549 -1.5212731515907442e-09 45.780076312919597 -1276.3942037434604 -7.040608759378097 45.780076313262015 -1276.2226443212503 -13.226161675384731 46.39375529998587 -1275.9552820172657 -18.694702199137865 47.407701676207701 -1275.6460406654151 -23.550241825695096 48.696083853797553 -1275.3322103908952 -27.874747703013561 50.18198759463187 -1275.0387725156461 -31.73575458833502 51.813858288218881 -1274.7818860878256 -35.190678781909035 53.553245367218523 -1274.5715717516973 -38.288911666446005 55.370046062378883 -1274.4136286743192 -41.072770480691617 57.241445698411354 -1274.3108202454248 -43.578383955514511 59.150751732326462 -1274.2633642668859 -45.837590440898751 61.082318735752445
+6 0 3 -1276.3942037434549 -1.5212731515907442e-09 45.780076312919597 -1281.5399983859895 4.4132020377474123e-09 74.963193995823133 -1406.6105045430963 1.1398594379166007e-09 52.909798567795981 -1401.464709894462 1.2961329275482691e-11 23.726680885968001
+6 0 11 -1401.464709894462 -1.2961329275487656e-11 23.726680885968015 -1401.4647098944674 3.8608849741243039 23.726680886002811 -1401.6963370361996 7.4514346111332106 23.766587323484949 -1402.105783585713 10.727970177436603 23.839046395494222 -1402.6454652489815 13.678707695652278 23.940672761962936 -1403.2759560538404 16.312118309212018 24.069775898492153 -1403.9662541933712 18.648283040550496 24.225037881084926 -1404.6929007797203 20.712807996120318 24.404912088405183 -1405.4384734573407 22.532866071489515 24.607512307170971 -1406.1899768246494 24.134931209777697 24.830761726290692 -1406.9376516130906 25.543771266687177 25.072571305351019 -1407.6747245725946 26.782265535385307 25.330817003065171
+6 0 3 -1274.2633642668859 45.837590440898744 61.082318735752445 -1288.5436072018706 0.1422898311632963 74.251336645322496 -1404.6510121766605 9.7087046923396514 53.598783627782069 -1407.6747245725942 26.782265535385235 25.330817003065157
+6 0 7 -1407.6747245725944 26.782265535386912 25.330817003065377 -1408.8329820803867 28.728470814771448 25.736631670902153 -1409.963472893344 30.228532363128181 26.185493316165907 -1411.034067431809 31.390542653003166 26.667416345023771 -1412.036753867452 32.299704169385478 27.172741360126018 -1412.9723507787855 33.018027225617075 27.694187736253554 -1413.8432294083955 33.588690079904488 28.227206536603092 -1414.6540455218876 34.045061352432313 28.76863376971
+6 0 3 -1276.4279951252383 61.083894229843331 81.891089041773355 -1293.3129791802166 11.453746886500895 83.403236577306842 -1400.3249338091146 17.950992732293471 53.480753884874026 -1414.6540455218876 34.045061352432356 28.768633769709989
+6 0 8 -1414.6540455218876 34.045061352432327 28.768633769709972 -1416.0729737204988 34.843711079356019 29.716131427647063 -1417.3117143707561 35.299486061000948 30.688854383856274 -1418.3927776968817 35.577263661960757 31.671202327214289 -1419.3477970276554 35.75093337868735 32.660899010201483 -1420.1997561910014 35.858960002118444 33.659806328916744 -1420.963911578187 35.924297991408658 34.673486794701127 -1421.6534331610794 35.956872675266212 35.712809946947814 -1422.2757887459047 35.956843897397484 36.790898256675995
+6 0 3 -1289.0218384379521 67.607175050109134 113.72403979910901 -1303.7040423875121 17.978507556806619 105.24716581903519 -1396.8585073983879 27.585948098341412 51.463656582775599 -1422.2757887459047 35.956843897397434 36.790898256676009
+6 0 8 -1422.2757887459045 35.956843897397505 36.790898256676009 -1422.8981443307298 35.95681511952877 37.868986566404189 -1423.453333917488 35.924182879933745 38.985840033613862 -1423.9489902770733 35.858778025888753 40.154485997092216 -1424.3879435318045 35.750665257546494 41.391762542707781 -1424.7673850444473 35.576881663886944 42.713661408728811 -1425.0774385884179 35.298952783729362 44.141014979046574 -1425.3003214850428 34.842980935195818 45.700074175868984 -1425.4112783937637 34.044100557016606 47.402524063449967
+6 0 3 -1310.2931560343 61.08364005748642 140.54691658609772 -1317.4258794725938 11.453510739372341 125.16790614442829 -1396.8456192027693 17.948360097113778 47.452834719244748 -1425.411278393764 34.044100557016513 47.40252406344996
+6 0 7 -1425.4112783937637 34.044100557016577 47.402524063449981 -1425.4746823416042 33.587597483771312 48.375352570639116 -1425.5007776268101 33.016791567310825 49.395977974747773 -1425.4844983761493 32.298316670290021 50.466848396084345 -1425.4207217539508 31.388999257317714 51.587741104155896 -1425.3027371401433 30.226838664412266 52.755722184108421 -1425.1261898501534 28.726650429853141 53.959021994106472 -1424.8984993966628 26.780372686428379 55.164826413652158
+6 0 3 -1327.2316401422313 45.837179808650738 152.82569781363546 -1322.9667739521806 0.14206642695590688 133.874091256231 -1398.9064578631296 9.7077695320803983 43.647778461486126 -1424.8984993966628 26.780372686428407 55.164826413652136
+6 0 11 -1424.8984993966628 26.780372686428375 55.164826413652158 -1424.7536054717143 25.541832304248981 55.932156498817598 -1424.5891841570653 24.132966836866345 56.700442889446677 -1424.4067831754876 22.530903497984863 57.462758504707757 -1424.2094730448816 20.710881998324194 58.209608611920345 -1424.0019526363178 18.646437242602509 58.928702716762039 -1423.7912986457529 16.310406348263811 59.604012886724739 -1423.5878987482167 13.677193604966824 60.214455010664082 -1423.4061082032636 10.726726993852996 60.732529497286002 -1423.2641696804856 7.4505398856111285 61.123257915414428 -1423.1829360738809 3.8604115363561724 61.343752078883973 -1423.1829360738741 3.397033765395463e-10 61.343752078901616
+6 0 3 -1341.5488823097025 7.7567636061915573e-07 158.63128994863519 -1318.8484583571367 7.7567628323808538e-07 139.58334222266978 -1400.4825121240622 -1.3623904689964729e-10 42.29580434965473 -1423.1829360738743 -3.3972708020790962e-10 61.343752078901602
+6 0 8 -1463.9999629665078 77.798419876098649 228.59998315288672 -1407.4774751406712 77.798419876098649 228.59998315288672 -1350.9549873148346 77.798419876098649 211.68849434181368 -1300.3357227123461 77.798419876098649 177.86551671966762 -1261.5213373461843 77.798419876098649 129.60107215992505 -1239.1302949409826 77.798419876098649 71.854606120678596 -1235.1483693898158 77.798419876098649 11.105548242964126 -1248.7638343765286 77.798419876098649 -46.300106504843555 -1277.0250782894468 77.798419876098649 -95.250016847114722
+6 0 8 -1409.0073498261959 0 -19.050016847114264 -1409.0073498261959 -7.1286525433563304 -19.050016847114264 -1409.6857939970421 -14.257305086712661 -18.65831692244603 -1411.0426823387347 -20.967166079380029 -17.874917073109561 -1413.0222271868024 -26.839472575999196 -16.7320263222047 -1415.512767328293 -31.506931605469319 -15.294112301087624 -1418.3585278749674 -34.706263385498239 -13.651111683415902 -1421.3819046902254 -36.305929275512703 -11.905564265265058 -1424.4052815054833 -36.305929275512703 -10.160016847114209
+6 0 8 -1503.5946444275323 -36.305929275512717 -10.160016847114255 -1497.6099104224438 -36.305929275512717 -20.525880213712782 -1488.5237173506293 -36.305929275512717 -29.101115353256528 -1476.9611123769141 -36.305929275512717 -34.803108819141563 -1463.9999629665078 -36.305929275512717 -36.811066308918839 -1451.0388135561016 -36.305929275512717 -34.803108819141563 -1439.4762085823863 -36.305929275512717 -29.101115353256525 -1430.3900155105719 -36.305929275512717 -20.525880213712774 -1424.4052815054833 -36.305929275512717 -10.160016847114246
+6 0 8 -1518.9925761068198 0 -19.0500168471143 -1518.9925761068198 -7.1286525433563304 -19.0500168471143 -1518.3141319359736 -14.257305086712661 -18.658316922446065 -1516.957243594281 -20.967166079380029 -17.874917073109597 -1514.9776987462133 -26.839472575999196 -16.732026322204735 -1512.4871586047227 -31.506931605469319 -15.294112301087658 -1509.6413980580483 -34.706263385498239 -13.651111683415934 -1506.6180212427903 -36.305929275512703 -11.905564265265088 -1503.5946444275323 -36.305929275512703 -10.160016847114237
+6 0 8 -1401.464709894462 0 23.726680885967987 -1400.5024483305133 0 18.269449422434196 -1400.0844493512868 0 12.716241654903349 -1400.2218810250754 0 7.130386654713722 -1400.9170708635506 0 1.5767760537120674 -1402.1632325754163 0 -3.8796798386327529 -1403.9445496782052 0 -9.1756636965028768 -1406.2366396391051 0 -14.25100603002409 -1409.0073498261961 0 -19.050016847114275
+6 0 8 -1424.4052815054833 36.305929275512717 -10.160016847114205 -1418.4205475003948 36.305929275512717 0.20584651948432331 -1415.5372725620321 36.305929275512717 12.362338113137632 -1416.3805038552202 36.305929275512717 25.226844487241785 -1421.122136364557 36.305929275512717 37.455507883788009 -1429.3416532656265 36.305929275512717 47.676213790556957 -1440.0610269461533 36.305929275512717 54.838726698776071 -1452.0304949563304 36.305929275512717 58.419983152885635 -1463.9999629665074 36.305929275512717 58.419983152885635
+6 0 8 -1463.9999629665078 0 76.19998315288575 -1463.9999629665078 7.1286525433563304 76.19998315288575 -1463.9999629665078 14.257305086712661 75.416583303549288 -1463.9999629665078 20.967166079380029 73.84978360487635 -1463.9999629665078 26.839472575999196 71.564002103066628 -1463.9999629665078 31.506931605469319 68.68817406083248 -1463.9999629665078 34.706263385498239 65.402172825489032 -1463.9999629665078 36.305929275512703 61.911077989187348 -1463.9999629665078 36.305929275512703 58.419983152885649
+6 0 8 -1463.9999629665078 0 76.199983152885736 -1458.4585425923408 0 76.199983152885736 -1452.9171222181737 0 75.647320120026649 -1447.4400071078458 0 74.541994054308461 -1442.0914968345264 0 72.892973807843902 -1436.9343340521066 0 70.718220567926849 -1432.0281258832015 0 68.044312388631411 -1427.4279063736474 0 64.905710770115817 -1423.1829360738743 0 61.343752078901609
+6 0 8 -1504.8169898592323 0 61.343752078825162 -1500.5720195594547 0 64.905710770056871 -1495.9718000498931 0 68.044312388588367 -1491.0655918809782 0 70.718220567897674 -1485.9084290985465 0 72.892973807826209 -1480.5599188252138 0 74.541994054299565 -1475.0828037148715 0 75.647320120023679 -1469.5413833406897 0 76.199983152885736 -1463.9999629665078 0 76.199983152885736
+6 0 8 -1463.9999629665078 36.305929275512717 58.419983152885649 -1475.9694309766849 36.305929275512717 58.419983152885642 -1487.9388989868619 36.305929275512717 54.838726698776078 -1498.6582726673887 36.305929275512717 47.676213790556957 -1506.8777895684582 36.305929275512717 37.455507883788002 -1511.619422077795 36.305929275512717 25.226844487241785 -1512.4626533709832 36.305929275512717 12.362338113137632 -1509.5793784326204 36.305929275512717 0.20584651948432509 -1503.5946444275319 36.305929275512717 -10.160016847114202
+6 0 8 -1518.9925761068198 0 -19.050016847114293 -1521.7632862939033 0 -14.251006030036983 -1524.0553762547984 0 -9.1756636965301261 -1525.8366933575853 0 -3.8796798386753917 -1527.0828550694519 0 1.5767760536535 -1527.778044907931 0 7.1303866546392145 -1527.9154765817266 0 12.716241654813427 -1527.4974776025101 0 18.269449422329902 -1526.5352160385744 0 23.726680885850858
+6 0 1 -1463.9999629665078 36.305929275512717 12.69998315288573 -1424.4052815054833 36.305929275512717 -10.160016847114273
+6 0 1 -1463.9999629665078 36.305929275512717 12.69998315288573 -1503.5946444275323 36.305929275512717 -10.160016847114315
+6 0 3 -1600.7685940255053 -45.837590440898744 152.8255298629785 -1605.0331766105928 -0.1422898311632963 133.87396775428346 -1529.0938385570028 -9.7087046923396514 43.648281987397837 -1503.1012051487005 -26.782265535385235 55.163653551139774
+6 0 11 -1504.8169898592323 1.2961329275487656e-11 61.343752078825162 -1504.8169898592598 -3.8608849741243039 61.343752078803043 -1504.7357362770279 -7.4514346111332106 61.123203871116026 -1504.5937643993659 -10.727970177436603 60.732383221740918 -1504.4119345827878 -13.678707695652278 60.214192008159429 -1504.2084957763009 -16.312118309212018 59.603619386034573 -1503.9978075277027 -18.648283040550496 58.928172669719338 -1503.790259867553 -20.712807996120318 58.208941162707667 -1503.5929304650062 -22.532866071489515 57.461956174137974 -1503.4105184496898 -24.134931209777697 56.699510457459255 -1503.2460942938139 -25.543771266687177 55.931100307369952 -1503.1012051487003 -26.782265535385307 55.16365355113976
+6 0 11 -1520.3263277829785 -26.780372686428375 25.330422299140022 -1521.0633020922942 -25.541832304248981 25.072239076416821 -1521.8108682812854 -24.132966836866345 24.830488916511854 -1522.5622534605918 -22.530903497984863 24.607294992602824 -1523.3076996915602 -20.710881998324194 24.404745524525389 -1524.0342136583465 -18.646437242602509 24.224916417724543 -1524.7243764162506 -16.310406348263811 24.069693039980891 -1525.3547347518904 -13.677193604966824 23.940621456404727 -1525.8942956908343 -10.726726993852996 23.839019443191031 -1526.303645688303 -7.4505398856111285 23.766577600628274 -1526.5352160385562 -3.8604115363561724 23.726680885854147 -1526.5352160385748 -3.397033765395463e-10 23.726680885851145
+6 0 3 -1653.7365529983049 -45.837179808650738 61.081967821325406 -1639.4564133720903 -0.14206642695590688 74.251253564352893 -1523.3482924465657 -9.7077695320803983 53.598714539483012 -1520.3263277829783 -26.780372686428407 25.330422299140039
+6 0 8 -1650.9748476435691 -77.798419876098649 -95.250016847114793 -1679.2360915564875 -77.798419876098649 -46.300106504843626 -1692.8515565432003 -77.798419876098649 11.105548242964069 -1688.8696309920335 -77.798419876098649 71.854606120678554 -1666.4785885868318 -77.798419876098649 129.601072159925 -1627.6642032206701 -77.798419876098649 177.8655167196676 -1577.0449386181815 -77.798419876098649 211.68849434181368 -1520.5224507923449 -77.798419876098649 228.59998315288675 -1463.9999629665083 -77.798419876098649 228.59998315288678
+6 0 5 -1463.9999629665081 -77.798419876098649 228.59998315288681 -1463.9999629665081 -82.837669539677151 228.59998315288681 -1463.9999629665081 -87.876919203255639 228.59998315288681 -1463.9999629665081 -83.21160755811529 220.66643835345948 -1463.9999629665081 -80.528476020070357 219.56461369684783 -1463.9999629665081 -77.798419876098592 218.49141773724708
+6 0 7 -1513.3475872572972 -34.044100557016577 28.767493836224588 -1514.1583794841283 -33.587597483771312 28.226170153099915 -1515.0292193692312 -33.016791567310825 27.693258271138355 -1515.9647599836003 -32.298316670290021 27.171921305096802 -1516.9673698548063 -31.388999257317714 26.66670712605249 -1518.0378634480885 -30.226838664412266 26.184894258889294 -1519.1682252969108 -28.726650429853141 25.73613879199079 -1520.3263277829783 -26.780372686428379 25.330422299140043
+6 0 3 -1651.5720585817114 -61.08364005748642 81.890515974161843 -1634.6870831350127 -11.453510739372341 83.402901499265496 -1527.6739871587938 -17.948360097113778 53.480925043577017 -1513.3475872572972 -34.044100557016513 28.767493836224638
+6 0 8 -1505.725394557106 -35.956843897397505 36.788720427960833 -1506.3478686284411 -35.95681511952877 35.710700526450921 -1507.0374973099704 -35.924182879933745 34.671465506796878 -1507.8017462225801 -35.858778025888753 33.657891526109417 -1508.6537825152243 -35.750665257546494 32.659108583630683 -1509.6088597581108 -35.576881663886944 31.669553161421035 -1510.6899574382032 -35.298952783729362 30.687362130650321 -1511.9287008603428 -34.842980935195818 29.714810281692792 -1513.3475872572974 -34.044100557016606 28.76749383622461
+6 0 3 -1638.9784246797733 -67.607175050109134 113.72345577806047 -1624.29613449357 -17.978507556806619 105.24673116423419 -1531.1410166848564 -27.585948098341412 51.46435260699689 -1505.725394557106 -35.956843897397434 36.788720427960754
+6 0 8 -1502.5887813275242 -34.045061352432327 47.400475924564454 -1502.6998742700184 -34.843711079356019 45.697899229452574 -1502.9229067358112 -35.299486061000948 44.138756879524735 -1503.2331133470518 -35.577263661960757 42.711354604321336 -1503.6127061511731 -35.75093337868735 41.389435261272475 -1504.0518056835338 -35.858960002118444 40.152163323470191 -1504.5476010246302 -35.924297991408658 38.983545112836445 -1505.1029204857709 -35.956872675266212 37.866740329470659 -1505.725394557106 -35.956843897397484 36.78872042796074
+6 0 3 -1617.7072023028584 -61.083894229843331 140.54651939681909 -1610.5742684554111 -11.453746886500895 125.16762049494592 -1531.1546609850152 -17.950992732293471 47.4537906239091 -1502.5887813275242 -34.045061352432356 47.400475924564418
+6 0 7 -1503.1012051487005 -26.782265535386912 55.163653551139532 -1502.8735222063794 -28.728470814771448 53.957665791349037 -1502.6970023874837 -30.228532363128181 52.754201205951219 -1502.5790627039109 -31.390542653003166 51.58607762405876 -1502.5153437863357 -32.299704169385478 50.465063191210781 -1502.4991311391068 -33.018027225617075 49.394089310229852 -1502.5252996460993 -33.588690079904488 48.373376893199811 -1502.5887813275244 -34.045061352432313 47.400475924564454
+6 0 8 -1463.9999629665078 -77.798419876098649 228.59998315288672 -1407.4774751406712 -77.798419876098649 228.59998315288672 -1350.9549873148346 -77.798419876098649 211.68849434181368 -1300.3357227123461 -77.798419876098649 177.86551671966762 -1261.5213373461843 -77.798419876098649 129.60107215992505 -1239.1302949409826 -77.798419876098649 71.854606120678596 -1235.1483693898158 -77.798419876098649 11.105548242964126 -1248.7638343765286 -77.798419876098649 -46.300106504843555 -1277.0250782894468 -77.798419876098649 -95.250016847114722
+6 0 11 -1424.8984993966628 -26.780372686428375 55.164826413652158 -1424.7536054717143 -25.541832304248981 55.932156498817598 -1424.5891841570653 -24.132966836866345 56.700442889446677 -1424.4067831754876 -22.530903497984863 57.462758504707757 -1424.2094730448816 -20.710881998324194 58.209608611920345 -1424.0019526363178 -18.646437242602509 58.928702716762039 -1423.7912986457529 -16.310406348263811 59.604012886724739 -1423.5878987482167 -13.677193604966824 60.214455010664082 -1423.4061082032636 -10.726726993852996 60.732529497286002 -1423.2641696804856 -7.4505398856111285 61.123257915414428 -1423.1829360738809 -3.8604115363561724 61.343752078883973 -1423.1829360738741 -3.397033765395463e-10 61.343752078901616
+6 0 3 -1327.2316401422313 -45.837179808650738 152.82569781363546 -1322.9667739521806 -0.14206642695590688 133.874091256231 -1398.9064578631296 -9.7077695320803983 43.647778461486126 -1424.8984993966628 -26.780372686428407 55.164826413652136
+6 0 7 -1425.4112783937637 -34.044100557016577 47.402524063449981 -1425.4746823416042 -33.587597483771312 48.375352570639116 -1425.5007776268101 -33.016791567310825 49.395977974747773 -1425.4844983761493 -32.298316670290021 50.466848396084345 -1425.4207217539508 -31.388999257317714 51.587741104155896 -1425.3027371401433 -30.226838664412266 52.755722184108421 -1425.1261898501534 -28.726650429853141 53.959021994106472 -1424.8984993966628 -26.780372686428379 55.164826413652158
+6 0 3 -1310.2931560343 -61.08364005748642 140.54691658609772 -1317.4258794725938 -11.453510739372341 125.16790614442829 -1396.8456192027693 -17.948360097113778 47.452834719244748 -1425.411278393764 -34.044100557016513 47.40252406344996
+6 0 8 -1422.2757887459045 -35.956843897397505 36.790898256676009 -1422.8981443307298 -35.95681511952877 37.868986566404189 -1423.453333917488 -35.924182879933745 38.985840033613862 -1423.9489902770733 -35.858778025888753 40.154485997092216 -1424.3879435318045 -35.750665257546494 41.391762542707781 -1424.7673850444473 -35.576881663886944 42.713661408728811 -1425.0774385884179 -35.298952783729362 44.141014979046574 -1425.3003214850428 -34.842980935195818 45.700074175868984 -1425.4112783937637 -34.044100557016606 47.402524063449967
+6 0 3 -1289.0218384379521 -67.607175050109134 113.72403979910901 -1303.7040423875121 -17.978507556806619 105.24716581903519 -1396.8585073983879 -27.585948098341412 51.463656582775599 -1422.2757887459047 -35.956843897397434 36.790898256676009
+6 0 8 -1414.6540455218876 -34.045061352432327 28.768633769709972 -1416.0729737204988 -34.843711079356019 29.716131427647063 -1417.3117143707561 -35.299486061000948 30.688854383856274 -1418.3927776968817 -35.577263661960757 31.671202327214289 -1419.3477970276554 -35.75093337868735 32.660899010201483 -1420.1997561910014 -35.858960002118444 33.659806328916744 -1420.963911578187 -35.924297991408658 34.673486794701127 -1421.6534331610794 -35.956872675266212 35.712809946947814 -1422.2757887459047 -35.956843897397484 36.790898256675995
+6 0 3 -1276.4279951252383 -61.083894229843331 81.891089041773355 -1293.3129791802166 -11.453746886500895 83.403236577306842 -1400.3249338091146 -17.950992732293471 53.480753884874026 -1414.6540455218876 -34.045061352432356 28.768633769709989
+6 0 7 -1407.6747245725944 -26.782265535386912 25.330817003065377 -1408.8329820803867 -28.728470814771448 25.736631670902153 -1409.963472893344 -30.228532363128181 26.185493316165907 -1411.034067431809 -31.390542653003166 26.667416345023771 -1412.036753867452 -32.299704169385478 27.172741360126018 -1412.9723507787855 -33.018027225617075 27.694187736253554 -1413.8432294083955 -33.588690079904488 28.227206536603092 -1414.6540455218876 -34.045061352432313 28.76863376971
+6 0 3 -1274.2633642668859 -45.837590440898744 61.082318735752445 -1288.5436072018706 -0.1422898311632963 74.251336645322496 -1404.6510121766605 -9.7087046923396514 53.598783627782069 -1407.6747245725942 -26.782265535385235 25.330817003065157
+6 0 11 -1401.464709894462 1.2961329275487656e-11 23.726680885968015 -1401.4647098944674 -3.8608849741243039 23.726680886002811 -1401.6963370361996 -7.4514346111332106 23.766587323484949 -1402.105783585713 -10.727970177436603 23.839046395494222 -1402.6454652489815 -13.678707695652278 23.940672761962936 -1403.2759560538404 -16.312118309212018 24.069775898492153 -1403.9662541933712 -18.648283040550496 24.225037881084926 -1404.6929007797203 -20.712807996120318 24.404912088405183 -1405.4384734573407 -22.532866071489515 24.607512307170971 -1406.1899768246494 -24.134931209777697 24.830761726290692 -1406.9376516130906 -25.543771266687177 25.072571305351019 -1407.6747245725946 -26.782265535385307 25.330817003065171
+6 0 8 -1503.5946444275323 -36.305929275512717 -10.160016847114283 -1509.5793784326208 -36.305929275512717 0.20584651948427357 -1512.4626533709836 -36.305929275512717 12.362338113137616 -1511.6194220777954 -36.305929275512717 25.226844487241806 -1506.8777895684586 -36.305929275512717 37.455507883788059 -1498.6582726673892 -36.305929275512717 47.676213790557036 -1487.9388989868623 -36.305929275512717 54.838726698776178 -1475.9694309766853 -36.305929275512717 58.419983152885749 -1463.9999629665083 -36.305929275512717 58.419983152885749
+6 0 8 -1463.9999629665078 0 76.19998315288575 -1463.9999629665078 -7.1286525433563304 76.19998315288575 -1463.9999629665078 -14.257305086712661 75.416583303549288 -1463.9999629665078 -20.967166079380029 73.84978360487635 -1463.9999629665078 -26.839472575999196 71.564002103066628 -1463.9999629665078 -31.506931605469319 68.68817406083248 -1463.9999629665078 -34.706263385498239 65.402172825489032 -1463.9999629665078 -36.305929275512703 61.911077989187348 -1463.9999629665078 -36.305929275512703 58.419983152885649
+6 0 1 -1463.9999629665078 -36.305929275512717 12.69998315288573 -1503.5946444275323 -36.305929275512717 -10.160016847114283
+6 0 1 -1463.9999629665078 -36.305929275512717 12.69998315288573 -1424.4052815054833 -36.305929275512717 -10.160016847114269
+6 0 8 -1463.9999629665078 -36.305929275512717 58.419983152885742 -1452.0304949563308 -36.305929275512717 58.419983152885742 -1440.0610269461538 -36.305929275512717 54.838726698776171 -1429.3416532656267 -36.305929275512717 47.676213790557036 -1421.1221363645573 -36.305929275512717 37.455507883788059 -1416.3805038552205 -36.305929275512717 25.226844487241802 -1415.5372725620323 -36.305929275512717 12.362338113137614 -1418.4205475003951 -36.305929275512717 0.20584651948427179 -1424.4052815054836 -36.305929275512717 -10.160016847114289
+6 0 1 -1463.9999629665078 36.305929275512717 12.69998315288573 -1463.9999629665078 36.305929275512717 58.41998315288577
+6 0 1 -1463.9999629665078 -36.305929275512717 12.69998315288573 -1463.9999629665078 -36.305929275512717 58.41998315288577
+6 0 11 -1156.7942868145544 106.83992330447676 299.02003863765981 -1145.5551634012716 113.8865691237189 293.46093539793003 -1136.0723615348604 120.81200677104478 288.78550426182653 -1126.1115814857753 126.5059839230953 283.77983266707918 -1114.980527407949 131.65781829019221 278.46754359946192 -1105.0444891500208 137.30711649768841 273.27067730307897 -1093.8298650894706 142.0795902638323 267.98522593674568 -1083.3808703355628 147.1716596925622 262.66416671834401 -1072.4806261816527 151.88430318487272 257.32524226432037 -1061.6750844650512 156.57965819005668 251.97174124788447 -1050.8307643900316 161.16019278301698 246.60820494824267 -1039.9544555542996 165.59503908472286 241.22870372460591
+6 0 10 -915.06469021165935 196.8898645095656 179.45557345883842 -928.22048465554872 196.17781388160395 185.96270187921002 -941.13613425647532 194.83934328340081 192.34797675145643 -954.09796937092835 192.97988495008968 198.76683468946493 -966.46590390738891 190.4402996834315 204.87676858566593 -979.24472475088828 187.53719025186206 211.20284241411599 -991.3736580785818 183.84223706750731 217.19702532004479 -1003.6561191297519 179.74929358413266 223.27533210021699 -1015.7855848611541 175.2532500244036 229.27458149321978 -1027.8870937953998 170.5161255975288 235.2600705633464 -1039.9545018751178 165.59515284785488 241.22870455206808
+6 0 7 -915.06469001674441 196.88986462861226 179.45557372016714 -926.19335750254697 193.39704234266964 175.42969061750799 -937.03203637264767 189.62337823901774 171.10375159253033 -947.50566185193054 185.54754376694527 166.36485749075146 -957.49081595424445 181.06374088915535 161.09952572956621 -966.78706060252966 176.20568603149792 154.98951013193104 -974.83721210126134 170.56077056926614 147.47942863784797 -982.75132550390583 164.42895241064846 139.8758047561472
+6 0 10 -982.75132553955712 164.42895236742814 139.87580469076318 -988.38213011596758 160.06623123608387 134.46590998849283 -993.74491304515686 155.62376256782605 129.20170147799359 -999.16126405338127 151.29843081026996 124.61781022743996 -1004.9422377963185 146.92903255402359 120.36481241904265 -1010.3214599635726 142.79548329790964 116.54682031939709 -1016.1077705921815 138.67196266060188 113.03660152806209 -1021.6670622283934 134.80577913672053 109.89838232520755 -1027.2677175164417 131.16121194016054 107.12132443276343 -1032.7935548119967 127.83284932685395 104.75512565290902 -1038.2016536546298 124.90288454739014 102.87137936997595
+6 0 10 -1038.2016536546294 124.90288454739024 102.87137936997594 -1043.6097524972622 121.9729197679265 100.98763308704287 -1048.9001128869731 119.44135282230557 99.586339301031117 -1053.9925991210807 117.40194185848701 98.740752192451154 -1059.0157197651311 115.89504565014182 98.549566754863093 -1063.1421452348786 115.26855068417946 99.172356774649657 -1067.937628928345 115.15516763085971 100.75656764764656 -1070.5064522785815 116.56761195145869 103.63292592636698 -1073.8939151030127 118.72144228465804 108.07585224183839 -1074.7145145855593 122.76808006132605 114.71645761845586 -1076.2581798537074 127.52263452310029 124.19433544481056
+6 0 8 -1076.2581796552126 127.52263458129373 124.1943354506702 -1078.5039230617331 134.43961977886167 137.9828704030445 -1081.3859637020464 139.74020034736083 151.69822507466688 -1084.9714511918755 143.49957483952321 165.26883579268855 -1089.3338647495782 145.76023147148069 178.68322485773984 -1094.64260796751 146.63579692668534 191.89574661102085 -1101.2255761687104 145.87021112226671 204.76228790272768 -1109.3463310831341 143.64342874201219 217.2693521926862 -1120.533082140277 139.35046000946033 228.56714516301673
+6 0 11 -1120.5330821384018 139.35046001174723 228.56714516338067 -1125.9549924074067 137.26977625124854 234.04287439028695 -1131.9228169394528 134.77837597419608 239.09793288987456 -1138.1579534792206 131.97513291665993 243.89303847611598 -1144.1699617101126 128.88023473197981 248.6070807288456 -1150.0069849627812 125.7948367886377 253.46567314804506 -1154.4750581300782 122.00322654370703 258.67429823808595 -1158.8508971699105 119.02351909366425 264.40669557995005 -1161.3237119279088 116.13670626645954 271.32787410952972 -1162.015790403959 113.19125907417077 279.31280768358369 -1160.5531157881962 110.14638428763648 288.51433370993215 -1156.79428636492 106.83992345506319 299.02003869267321
+6 0 1 -915.06469021165981 196.88986450956594 179.45557345883191 -879.5084372893632 272.33972282567686 175.44214357515688
+6 0 14 -915.06469021165981 196.88986450956594 179.45557345883191 -933.8059722541708 195.87550222957768 188.72539973448352 -952.07288549398811 193.61230241810756 197.75779839617491 -970.70642844893393 190.57337085756902 206.94572014464475 -986.50930966680119 184.96566827223029 214.99223896133461 -1008.689471739351 183.01601358026164 225.22494968310954 -1017.161013928576 168.66285271563152 230.85823269515504 -1046.3764477872942 173.20210152082956 243.36075804209887 -1050.0113106925719 150.30388175309525 247.07655344432749 -1079.4107819189496 158.85791890594732 260.20977711982198 -1088.2032883665468 140.42444637118308 265.32776999388221 -1108.6459663262233 136.11068241593159 275.13672712619638 -1125.1481694856325 128.82369163084974 283.37767333551784 -1140.5156151336696 117.04623829246098 290.96827043884031 -1156.7942868151069 106.8399233043308 299.0200386375177
+6 0 1 -1156.7942868149009 106.8399233040933 299.02003863764151 -1129.3521898468025 118.21116861770855 299.02003869306634
+6 0 14 -879.5084372893632 272.33972282567686 175.44214357515688 -897.3544196148946 261.33054038225055 184.26913608357899 -915.20040194042599 250.32135793882424 193.09612859200109 -933.04638426595739 239.31217549539792 201.9231211004232 -950.89236659148878 228.30299305197161 210.75011360884531 -968.73834891702018 217.2938106085453 219.57710611726742 -986.58433124255157 206.28462816511899 228.40409862568953 -1004.430313568083 195.27544572169268 237.23109113411164 -1022.2762958936144 184.26626327826636 246.05808364253375 -1040.1222782191458 173.25708083484005 254.88507615095585 -1057.9682605446772 162.24789839141374 263.71206865937796 -1075.8142428702085 151.23871594798743 272.53906116780007 -1093.6602251957399 140.22953350456112 281.36605367622218 -1111.5062075212713 129.22035106113481 290.19304618464429 -1129.3521898468027 118.21116861770849 299.0200386930664
+6 0 14 -1129.3521898468025 118.21116861770855 299.02003869306634 -1084.6406125967312 133.81526515622693 302.38472736753846 -1037.4808566215042 144.95449774878941 305.87989231436654 -1000.4920521972031 156.59694851330548 307.83321783179429 -932.00262240686493 189.37221542972273 317.22465463699206 -971.63061219905228 220.30681843209015 305.09026978074149 -766.95596711998394 123.93269871684973 342.11574352384656 -938.58509010106809 313.98338251719542 303.84578573925933 -685.65915873111976 119.50991392578024 359.22657330186956 -795.97726214515956 272.3284698460692 329.93207217447593 -668.49179189632537 191.95535529014299 366.54882021936481 -660.88168263716511 223.84316295189706 369.42253526820321 -609.44338596049829 215.97916447072819 391.96998484932305 -571.57176896512101 221.97673052847915 413.48877494585383 -533.29516479805034 219.89822451184139 442.29410401461951
+6 0 4 -549.6173095703025 227.91457393853963 370.28786144860095 -545.53677337723946 225.91048658186506 388.28942209010557 -541.45623718417642 223.90639922519051 406.29098273161014 -537.37570099111338 221.90231186851599 424.29254337311482 -533.29516479805034 219.89822451184142 442.29410401461939
+6 0 14 -879.5084372893632 272.33972282567686 175.44214357515688 -858.21468278909708 268.9178938369152 192.34314214549954 -836.53236473724201 265.37013080344371 208.76561986819189 -814.47666885680349 261.75044521813692 224.71832989083484 -792.0604878603574 258.10627658454899 240.20879258408453 -769.29460672570758 254.47983490795372 255.24323974660743 -746.18788181761647 250.90919746611314 269.82649795218276 -722.74749363052683 247.429217509409 283.96178765024263 -698.97930281978461 244.07200975198725 297.65053982817233 -674.88816295087884 240.8666509351026 310.89244696056863 -650.47774525012949 237.83822260646673 323.68588318486871 -625.74926781471311 235.00777006268669 336.02832464300207 -600.69932155360141 232.39570919098458 347.91570657993134 -575.32046207657527 230.02676259960151 359.339954798419 -549.61730957658722 227.9145739405725 370.28786144775711
+6 0 14 -549.6173095703025 227.91457393853963 370.28786144860095 -527.69641686094837 226.11319720096583 379.62476621246037 -507.03951520169551 221.02850359951989 388.04120199817464 -487.7169765035444 212.92446713145418 395.5708763948723 -469.79917267749533 202.06506179402106 402.24749699168183 -453.3564756345491 188.71426158447287 408.10477137773188 -438.45925728570592 173.13604050006197 413.17640714215111 -425.17788954196647 155.59437253804072 417.49611187406799 -413.58274431433119 136.35323169566146 421.09759316261096 -403.7441935138005 115.67659197017659 424.01455859690878 -395.73260905137505 93.828427358838411 426.28071576608988 -389.61836283805519 71.072711858899311 427.9297722592828 -385.47182678484148 47.673419467611637 428.99543566561624 -383.36337280273438 23.894524182227752 429.51141357421858 -383.36337280273438 0 429.51141357421875
+6 0 14 -533.29516479805034 219.89822451184142 442.29410401461939 -513.47055506230151 218.82180893211418 457.21237066780668 -516.63502481740625 211.56018178413558 456.35909802166395 -443.44889436653864 172.58265476799079 514.78416986097068 -635.61074308214324 294.98633642680267 366.98261906780829 -298.7780519827956 -102.06609069360445 613.75244135101298 -670.02715108637005 526.40627727993399 372.65004874615454 -367.14872142134942 -270.34584216383598 533.37551396453591 -524.57154079257771 418.08963273806933 496.69880674036665 -475.28525022063485 -85.599699451780793 468.04925795049303 -466.89900151669906 151.61538361456462 515.17325013308107 -478.14547650520745 34.138926774362631 490.69030796137054 -470.74766277174126 43.292155971452871 501.49330933485192 -471.21783003833792 19.194056003647461 500.7787018240158 -471.21782954912226 -1.1300320466034464e-06 500.77870143818438
+6 0 4 -383.36337280273438 0 429.51141357421875 -410.97587932240947 -2.4458773850710713e-07 435.62606621908867 -437.91355509849507 -5.4117357702517422e-07 452.04965464509019 -459.53975391594884 -8.3775941554225186e-07 475.02094450214759 -471.21782955972787 -1.0823471540463905e-06 500.77870144018482
+6 0 14 -533.29516479805034 -219.89822451184142 442.29410401461939 -513.47055506230151 -218.82180893211418 457.21237066780668 -516.63502481740625 -211.56018178413558 456.35909802166395 -443.44889436653864 -172.58265476799079 514.78416986097068 -635.61074308214324 -294.98633642680267 366.98261906780829 -298.7780519827956 102.06609069360445 613.75244135101298 -670.02715108637005 -526.40627727993399 372.65004874615454 -367.14872142134942 270.34584216383598 533.37551396453591 -524.57154079257771 -418.08963273806933 496.69880674036665 -475.28525022063485 85.599699451780793 468.04925795049303 -466.89900151669906 -151.61538361456462 515.17325013308107 -478.14547650520745 -34.138926774362631 490.69030796137054 -470.74766277174126 -43.292155971452871 501.49330933485192 -471.21783003833792 -19.194056003647461 500.7787018240158 -471.21782954912226 1.1300320466034464e-06 500.77870143818438
+6 0 4 -549.6173095703025 -227.91457393853963 370.28786144860095 -545.53677337723946 -225.91048658186506 388.28942209010557 -541.45623718417642 -223.90639922519051 406.29098273161014 -537.37570099111338 -221.90231186851599 424.29254337311482 -533.29516479805034 -219.89822451184142 442.29410401461939
+6 0 14 -549.6173095703025 -227.91457393853963 370.28786144860095 -527.69641686094837 -226.11319720096583 379.62476621246037 -507.03951520169551 -221.02850359951989 388.04120199817464 -487.7169765035444 -212.92446713145418 395.5708763948723 -469.79917267749533 -202.06506179402106 402.24749699168183 -453.3564756345491 -188.71426158447287 408.10477137773188 -438.45925728570592 -173.13604050006197 413.17640714215111 -425.17788954196647 -155.59437253804072 417.49611187406799 -413.58274431433119 -136.35323169566146 421.09759316261096 -403.7441935138005 -115.67659197017659 424.01455859690878 -395.73260905137505 -93.828427358838411 426.28071576608988 -389.61836283805519 -71.072711858899311 427.9297722592828 -385.47182678484148 -47.673419467611637 428.99543566561624 -383.36337280273438 -23.894524182227752 429.51141357421858 -383.36337280273438 0 429.51141357421875
+6 0 14 -879.5084372893632 -272.33972282567686 175.44214357515688 -858.21468278909708 -268.9178938369152 192.34314214549954 -836.53236473724201 -265.37013080344371 208.76561986819189 -814.47666885680349 -261.75044521813692 224.71832989083484 -792.0604878603574 -258.10627658454899 240.20879258408453 -769.29460672570758 -254.47983490795372 255.24323974660743 -746.18788181761647 -250.90919746611314 269.82649795218276 -722.74749363052683 -247.429217509409 283.96178765024263 -698.97930281978461 -244.07200975198725 297.65053982817233 -674.88816295087884 -240.8666509351026 310.89244696056863 -650.47774525012949 -237.83822260646673 323.68588318486871 -625.74926781471311 -235.00777006268669 336.02832464300207 -600.69932155360141 -232.39570919098458 347.91570657993134 -575.32046207657527 -230.02676259960151 359.339954798419 -549.61730957658722 -227.9145739405725 370.28786144775711
+6 0 14 -1129.3521898468025 -118.21116861770855 299.02003869306634 -1084.6406125967312 -133.81526515622693 302.38472736753846 -1037.4808566215042 -144.95449774878941 305.87989231436654 -1000.4920521972031 -156.59694851330548 307.83321783179429 -932.00262240686493 -189.37221542972273 317.22465463699206 -971.63061219905228 -220.30681843209015 305.09026978074149 -766.95596711998394 -123.93269871684973 342.11574352384656 -938.58509010106809 -313.98338251719542 303.84578573925933 -685.65915873111976 -119.50991392578024 359.22657330186956 -795.97726214515956 -272.3284698460692 329.93207217447593 -668.49179189632537 -191.95535529014299 366.54882021936481 -660.88168263716511 -223.84316295189706 369.42253526820321 -609.44338596049829 -215.97916447072819 391.96998484932305 -571.57176896512101 -221.97673052847915 413.48877494585383 -533.29516479805034 -219.89822451184139 442.29410401461951
+6 0 14 -879.5084372893632 -272.33972282567686 175.44214357515688 -897.3544196148946 -261.33054038225055 184.26913608357899 -915.20040194042599 -250.32135793882424 193.09612859200109 -933.04638426595739 -239.31217549539792 201.9231211004232 -950.89236659148878 -228.30299305197161 210.75011360884531 -968.73834891702018 -217.2938106085453 219.57710611726742 -986.58433124255157 -206.28462816511899 228.40409862568953 -1004.430313568083 -195.27544572169268 237.23109113411164 -1022.2762958936144 -184.26626327826636 246.05808364253375 -1040.1222782191458 -173.25708083484005 254.88507615095585 -1057.9682605446772 -162.24789839141374 263.71206865937796 -1075.8142428702085 -151.23871594798743 272.53906116780007 -1093.6602251957399 -140.22953350456112 281.36605367622218 -1111.5062075212713 -129.22035106113481 290.19304618464429 -1129.3521898468027 -118.21116861770849 299.0200386930664
+6 0 1 -1156.7942868149009 -106.8399233040933 299.02003863764151 -1129.3521898468025 -118.21116861770855 299.02003869306634
+6 0 14 -915.06469021165981 -196.88986450956594 179.45557345883191 -933.8059722541708 -195.87550222957768 188.72539973448352 -952.07288549398811 -193.61230241810756 197.75779839617491 -970.70642844893393 -190.57337085756902 206.94572014464475 -986.50930966680119 -184.96566827223029 214.99223896133461 -1008.689471739351 -183.01601358026164 225.22494968310954 -1017.161013928576 -168.66285271563152 230.85823269515504 -1046.3764477872942 -173.20210152082956 243.36075804209887 -1050.0113106925719 -150.30388175309525 247.07655344432749 -1079.4107819189496 -158.85791890594732 260.20977711982198 -1088.2032883665468 -140.42444637118308 265.32776999388221 -1108.6459663262233 -136.11068241593159 275.13672712619638 -1125.1481694856325 -128.82369163084974 283.37767333551784 -1140.5156151336696 -117.04623829246098 290.96827043884031 -1156.7942868151069 -106.8399233043308 299.0200386375177
+6 0 10 -915.06469021165935 -196.8898645095656 179.45557345883842 -928.22048465554872 -196.17781388160395 185.96270187921002 -941.13613425647532 -194.83934328340081 192.34797675145643 -954.09796937092835 -192.97988495008968 198.76683468946493 -966.46590390738891 -190.4402996834315 204.87676858566593 -979.24472475088828 -187.53719025186206 211.20284241411599 -991.3736580785818 -183.84223706750731 217.19702532004479 -1003.6561191297519 -179.74929358413266 223.27533210021699 -1015.7855848611541 -175.2532500244036 229.27458149321978 -1027.8870937953998 -170.5161255975288 235.2600705633464 -1039.9545018751178 -165.59515284785488 241.22870455206808
+6 0 1 -915.06469021165981 -196.88986450956594 179.45557345883191 -879.5084372893632 -272.33972282567686 175.44214357515688
+6 0 11 -1120.5330821384018 -139.35046001174723 228.56714516338067 -1125.9549924074067 -137.26977625124854 234.04287439028695 -1131.9228169394528 -134.77837597419608 239.09793288987456 -1138.1579534792206 -131.97513291665993 243.89303847611598 -1144.1699617101126 -128.88023473197981 248.6070807288456 -1150.0069849627812 -125.7948367886377 253.46567314804506 -1154.4750581300782 -122.00322654370703 258.67429823808595 -1158.8508971699105 -119.02351909366425 264.40669557995005 -1161.3237119279088 -116.13670626645954 271.32787410952972 -1162.015790403959 -113.19125907417077 279.31280768358369 -1160.5531157881962 -110.14638428763648 288.51433370993215 -1156.79428636492 -106.83992345506319 299.02003869267321
+6 0 8 -1076.2581796552126 -127.52263458129373 124.1943354506702 -1078.5039230617331 -134.43961977886167 137.9828704030445 -1081.3859637020464 -139.74020034736083 151.69822507466688 -1084.9714511918755 -143.49957483952321 165.26883579268855 -1089.3338647495782 -145.76023147148069 178.68322485773984 -1094.64260796751 -146.63579692668534 191.89574661102085 -1101.2255761687104 -145.87021112226671 204.76228790272768 -1109.3463310831341 -143.64342874201219 217.2693521926862 -1120.533082140277 -139.35046000946033 228.56714516301673
+6 0 10 -1038.2016536546294 -124.90288454739024 102.87137936997594 -1043.6097524972622 -121.9729197679265 100.98763308704287 -1048.9001128869731 -119.44135282230557 99.586339301031117 -1053.9925991210807 -117.40194185848701 98.740752192451154 -1059.0157197651311 -115.89504565014182 98.549566754863093 -1063.1421452348786 -115.26855068417946 99.172356774649657 -1067.937628928345 -115.15516763085971 100.75656764764656 -1070.5064522785815 -116.56761195145869 103.63292592636698 -1073.8939151030127 -118.72144228465804 108.07585224183839 -1074.7145145855593 -122.76808006132605 114.71645761845586 -1076.2581798537074 -127.52263452310029 124.19433544481056
+6 0 10 -982.75132553955712 -164.42895236742814 139.87580469076318 -988.38213011596758 -160.06623123608387 134.46590998849283 -993.74491304515686 -155.62376256782605 129.20170147799359 -999.16126405338127 -151.29843081026996 124.61781022743996 -1004.9422377963185 -146.92903255402359 120.36481241904265 -1010.3214599635726 -142.79548329790964 116.54682031939709 -1016.1077705921815 -138.67196266060188 113.03660152806209 -1021.6670622283934 -134.80577913672053 109.89838232520755 -1027.2677175164417 -131.16121194016054 107.12132443276343 -1032.7935548119967 -127.83284932685395 104.75512565290902 -1038.2016536546298 -124.90288454739014 102.87137936997595
+6 0 7 -915.06469001674441 -196.88986462861226 179.45557372016714 -926.19335750254697 -193.39704234266964 175.42969061750799 -937.03203637264767 -189.62337823901774 171.10375159253033 -947.50566185193054 -185.54754376694527 166.36485749075146 -957.49081595424445 -181.06374088915535 161.09952572956621 -966.78706060252966 -176.20568603149792 154.98951013193104 -974.83721210126134 -170.56077056926614 147.47942863784797 -982.75132550390583 -164.42895241064846 139.8758047561472
+6 0 11 -1156.7942868145544 -106.83992330447676 299.02003863765981 -1145.5551634012716 -113.8865691237189 293.46093539793003 -1136.0723615348604 -120.81200677104478 288.78550426182653 -1126.1115814857753 -126.5059839230953 283.77983266707918 -1114.980527407949 -131.65781829019221 278.46754359946192 -1105.0444891500208 -137.30711649768841 273.27067730307897 -1093.8298650894706 -142.0795902638323 267.98522593674568 -1083.3808703355628 -147.1716596925622 262.66416671834401 -1072.4806261816527 -151.88430318487272 257.32524226432037 -1061.6750844650512 -156.57965819005668 251.97174124788447 -1050.8307643900316 -161.16019278301698 246.60820494824267 -1039.9544555542996 -165.59503908472286 241.22870372460591
+6 0 1 -1544.9733382203528 -119.25657072448729 -34.050016847114279 -1478.7223948308433 -119.25657072448729 4.1999831528857285
+6 0 8 -1544.9733382203528 -119.25657072448729 -34.050016847114286 -1532.7342168407426 -119.25657072448729 -55.248796916601705 -1514.1524352962404 -119.25657072448729 -72.785640432510334 -1490.5062505840276 -119.25657072448729 -84.446541330591089 -1463.9999629665081 -119.25657072448729 -88.552928585494314 -1437.4936753489885 -119.25657072448729 -84.446541330591089 -1413.8474906367758 -119.25657072448729 -72.785640432510334 -1395.2657090922735 -119.25657072448729 -55.248796916601705 -1383.0265877126633 -119.25657072448729 -34.050016847114293
+6 0 1 -1449.2775311021724 -119.25657072448729 4.1999831528857126 -1383.0265877126628 -119.25657072448729 -34.050016847114286
+6 0 8 -1449.2775311021724 -119.25657072448729 4.1999831528857339 -1451.5028258984651 -119.25657072448729 0.34565950388802058 -1454.8813316338292 -119.25657072448729 -2.8428574990044586 -1459.1806379451407 -119.25657072448729 -4.9630212986555069 -1463.9999629665078 -119.25657072448729 -5.7096371631833689 -1468.819287987875 -119.25657072448729 -4.9630212986555122 -1473.1185942991865 -119.25657072448729 -2.8428574990044684 -1476.4971000345506 -119.25657072448729 0.34565950388800637 -1478.7223948308433 -119.25657072448729 4.1999831528857161
+6 0 5 -1438.1933877648048 -119.25657072448729 -26.159037417355311 -1433.1882437560444 -119.25657072448729 -29.048758658146035 -1428.1765952752551 -119.25657072448729 -31.942235650405884 -1423.1741273152529 -119.25657072448729 -34.830411567385063 -1418.1644504876356 -119.25657072448729 -37.722749901229712 -1413.1577962285387 -119.25657072448729 -40.613343085458666
+6 0 10 -1413.1577962284734 -119.25657072448729 -40.613343085460301 -1411.1008721144096 -119.25657072448729 -41.800908776425317 -1410.0339426271407 -119.25657072448729 -43.263479603411419 -1409.1986828031249 -119.25657072448729 -44.622273601470987 -1408.8880117239055 -119.25657072448729 -46.067853753731441 -1408.5618239927462 -119.25657072448729 -47.418680218659361 -1408.71075891431 -119.25657072448729 -48.809092278119628 -1408.8655412966889 -119.25657072448729 -50.249522727550584 -1409.4729501418906 -119.25657072448729 -51.688126835350801 -1410.3636245354799 -119.25657072448729 -53.282304267791964 -1412.230855398612 -119.25657072448729 -54.716167397914525
+6 0 8 -1412.2308553954881 -119.25657072448729 -54.716167402244587 -1425.5867376316589 -119.25657072448729 -64.972267752047642 -1439.7100575310174 -119.25657072448729 -71.009654781391077 -1453.3662240551821 -119.25657072448729 -73.847459313643569 -1466.6121860434971 -119.25657072448729 -74.494511658224894 -1479.8031652630584 -119.25657072448729 -73.059049189884988 -1493.2880125098177 -119.25657072448729 -69.405851107868514 -1507.0624901208516 -119.25657072448729 -62.508542305115142 -1519.811178913496 -119.25657072448729 -51.410142207771543
+6 0 10 -1519.8111789133811 -119.25657072448729 -51.410142207399772 -1521.507278118276 -119.25657072448729 -49.933599177207526 -1522.3122252409412 -119.25657072448729 -48.358902620939759 -1522.836585181482 -119.25657072448729 -46.924831358727793 -1522.9549485585717 -119.25657072448729 -45.508847549777421 -1523.0259327562326 -119.25657072448729 -44.143347870534939 -1522.6887698465086 -119.25657072448729 -42.818473930282529 -1522.3153331628 -119.25657072448729 -41.432682814112653 -1521.4866953693308 -119.25657072448729 -40.124117553232537 -1520.415369888575 -119.25657072448729 -38.755266926574457 -1518.4800573441544 -119.25657072448729 -37.63791370808039
+6 0 5 -1518.4800573261739 -119.25657072448729 -37.637913732488855 -1513.6625736248106 -119.25657072448729 -34.856538220690169 -1508.8427512633511 -119.25657072448729 -32.073812793300227 -1504.0283417188371 -119.25657072448729 -29.294211523649359 -1499.2071639471005 -119.25657072448729 -26.51070354539705 -1494.3907003145039 -119.25657072448729 -23.729916970575267
+6 0 6 -1494.3907003111972 -119.25657072448729 -23.729916974489296 -1492.942766623712 -119.25657072448729 -22.89395207025326 -1491.4889466165889 -119.25657072448729 -22.510457443569617 -1490.061456775388 -119.25657072448729 -22.375795173434408 -1488.644322964692 -119.25657072448729 -22.547933733172911 -1487.2314214892629 -119.25657072448729 -22.928534256037267 -1485.7839108523358 -119.25657072448729 -23.792613492617168
+6 0 6 -1485.7839108531955 -119.25657072448729 -23.792613494164076 -1479.3825550182355 -119.25657072448729 -27.613848738896024 -1472.7448153727375 -119.25657072448729 -29.748871388318396 -1466.1993131769996 -119.25657072448729 -30.607190836462994 -1459.6017126657887 -119.25657072448729 -30.415775593203247 -1452.7861355625816 -119.25657072448729 -28.965005636680111 -1446.0361699128443 -119.25657072448729 -25.816882948213085
+6 0 6 -1446.0361699127991 -119.25657072448729 -25.816882948183508 -1444.6749128305858 -119.25657072448729 -25.182005005431442 -1443.3676450315329 -119.25657072448729 -24.921561680546258 -1442.0717572331605 -119.25657072448729 -24.851711799044452 -1440.7809528412708 -119.25657072448729 -25.025771935644745 -1439.4812928834731 -119.25657072448729 -25.415465202647042 -1438.1933878560026 -119.25657072448729 -26.159037516946036
+6 0 1 -1463.9999629665078 -119.25657072448729 106.19998315288574 -1463.9999629665078 -119.25657072448729 29.699983152885721
+6 0 8 -1463.9999629665078 -119.25657072448729 106.19998315288574 -1488.4782057257282 -119.25657072448729 106.19998315288574 -1512.9564484849486 -119.25657072448729 98.876110045728154 -1534.8781772498057 -119.25657072448729 84.228363831412992 -1551.6875567390884 -119.25657072448729 63.326439022075753 -1561.3844648673255 -119.25657072448729 38.318126957835275 -1563.1089208146811 -119.25657072448729 12.009479845439365 -1557.212459599963 -119.25657072448729 -12.851236777626838 -1544.9733382203528 -119.25657072448729 -34.05001684711425
+6 0 8 -1478.7223948308435 -119.25657072448729 4.1999831528857312 -1480.9476896271362 -119.25657072448729 8.0543068018834436 -1482.0197734843578 -119.25657072448729 12.57443709698639 -1481.7062360393841 -119.25657072448729 17.357827481058372 -1479.9431618342501 -119.25657072448729 21.904793310920276 -1476.8869110180169 -119.25657072448729 25.705143276254319 -1472.9011421516793 -119.25657072448729 28.368369860675255 -1468.4505525590937 -119.25657072448729 29.699983152885725 -1463.9999629665081 -119.25657072448729 29.699983152885725
+6 0 5 -1510.5561495473703 -119.25657072448729 9.7803437286578081 -1515.5612935561307 -119.25657072448729 6.8906224878670823 -1520.5729423770883 -119.25657072448729 3.997146084795753 -1525.5754100717918 -119.25657072448729 1.1089697083058514 -1530.5850869590495 -119.25657072448729 -1.7833685222387565 -1535.5917412181464 -119.25657072448729 -4.6739617064677184
+6 0 10 -1535.5917412181802 -119.25657072448729 -4.6739617065231407 -1537.6486653322506 -119.25657072448729 -5.8615273974767401 -1539.4487535668891 -119.25657072448729 -6.0542300240053502 -1541.0431335997264 -119.25657072448729 -6.098189251333852 -1542.4503782744002 -119.25657072448729 -5.6444482220288901 -1543.7833221747117 -119.25657072448729 -5.2515218511516206 -1544.9129868791506 -119.25657072448729 -4.4273343958367368 -1546.083045049553 -119.25657072448729 -3.5730736959229206 -1547.0252083302958 -119.25657072448729 -2.3277401515947185 -1547.9604692881351 -119.25657072448729 -0.75930478402544166 -1548.2686157528051 -119.25657072448729 1.5746961432385733
+6 0 8 -1548.2686157581172 -119.25657072448729 1.5746961426983237 -1550.4727180867237 -119.25657072448729 18.269279624077143 -1548.6395886769346 -119.25657072448729 33.519126957367455 -1544.2691162307576 -119.25657072448729 46.764616351730965 -1538.2064990045858 -119.25657072448729 58.559482103465484 -1530.3678624310437 -119.25657072448729 69.265473974228328 -1520.4616764635812 -119.25657072448729 79.117095215066215 -1507.6011930171337 -119.25657072448729 87.597488348704871 -1491.6153521951483 -119.25657072448729 93.088976659404963
+6 0 10 -1491.6153521948836 -119.25657072448729 93.088976659119808 -1489.4885788185088 -119.25657072448729 93.819570142801112 -1487.7223780361965 -119.25657072448729 93.729326521598495 -1486.2182559220132 -119.25657072448729 93.466399919727763 -1484.9327962835698 -119.25657072448729 92.860913706690042 -1483.7147467736559 -119.25657072448729 92.239637985510413 -1482.7359537394473 -119.25657072448729 91.285209370349321 -1481.7225417703596 -119.25657072448729 90.268908157467621 -1481.0036099086622 -119.25657072448729 88.897004147347431 -1480.3538132323679 -119.25657072448729 87.284783751962195 -1480.353813232362 -119.25657072448729 85.050077314984236
+6 0 5 -1480.3538132624908 -119.25657072448729 85.050077311617017 -1480.3538132624908 -119.25657072448729 79.487326288019645 -1480.353813531344 -119.25657072448729 73.92187496757235 -1480.3538129916919 -119.25657072448729 68.362673362975443 -1480.3538132567569 -119.25657072448729 62.795656947364698 -1480.3538132567569 -119.25657072448729 57.234083797721134
+6 0 6 -1480.3538132618 -119.25657072448729 57.234083796814687 -1480.3538132618021 -119.25657072448729 55.562153988339197 -1480.7486071764408 -119.25657072448729 54.111361616298737 -1481.3457311501729 -119.25657072448729 52.807788015106929 -1482.2033744212254 -119.25657072448729 51.66658341435167 -1483.2394348804341 -119.25657072448729 50.633275105017638 -1484.7115047686586 -119.25657072448729 49.811733739480509
+6 0 6 -1484.7115047695681 -119.25657072448729 49.811733740998463 -1491.2214694828224 -119.25657072448729 46.178614591625276 -1496.3893231576264 -119.25657072448729 41.497674759628026 -1500.4054007021509 -119.25657072448729 36.2582633016644 -1503.5384304944218 -119.25657072448729 30.448866033304753 -1505.6898154086291 -119.25657072448729 23.821018142214353 -1506.3384440110551 -119.25657072448729 16.401315070636088
+6 0 6 -1506.3384440110519 -119.25657072448729 16.401315070581994 -1506.4692521254328 -119.25657072448729 14.904992884927713 -1506.8973354893626 -119.25657072448729 13.642644098955952 -1507.4847876167169 -119.25657072448729 12.485447404360315 -1508.2809303127437 -119.25657072448729 11.454608077967499 -1509.2682445605503 -119.25657072448729 10.523916171734314 -1510.5561495880193 -119.25657072448729 9.7803438574325838
+6 0 1 -1544.9733382203528 -119.25657072448729 -34.050016847114286 -1544.9733382203528 -117.51577072448728 -34.050016847114286
+6 0 8 -1544.9733382203528 -117.51577072448728 -34.050016847114286 -1532.7342168407426 -117.51577072448728 -55.248796916601705 -1514.1524352962404 -117.51577072448728 -72.785640432510334 -1490.5062505840276 -117.51577072448728 -84.446541330591089 -1463.9999629665081 -117.51577072448728 -88.552928585494314 -1437.4936753489885 -117.51577072448728 -84.446541330591089 -1413.8474906367758 -117.51577072448728 -72.785640432510334 -1395.2657090922735 -117.51577072448728 -55.248796916601705 -1383.0265877126633 -117.51577072448728 -34.050016847114293
+6 0 1 -1383.0265877126628 -119.25657072448729 -34.050016847114286 -1383.0265877126628 -117.51577072448728 -34.050016847114286
+6 0 8 -1383.0265877126628 -119.25657072448729 -34.050016847114286 -1370.7874663330526 -119.25657072448729 -12.851236777626863 -1364.8910051183345 -119.25657072448729 12.009479845439351 -1366.6154610656902 -119.25657072448729 38.318126957835268 -1376.3123691939272 -119.25657072448729 63.326439022075739 -1393.1217486832099 -119.25657072448729 84.228363831412992 -1415.0434774480671 -119.25657072448729 98.876110045728154 -1439.5217202072874 -119.25657072448729 106.19998315288574 -1463.9999629665078 -119.25657072448729 106.19998315288575
+6 0 8 -1463.9999629665078 -119.25657072448729 29.699983152885718 -1459.5493733739222 -119.25657072448729 29.699983152885718 -1455.0987837813366 -119.25657072448729 28.368369860675251 -1451.113014914999 -119.25657072448729 25.705143276254315 -1448.0567640987658 -119.25657072448729 21.904793310920269 -1446.2936898936318 -119.25657072448729 17.357827481058365 -1445.9801524486581 -119.25657072448729 12.574437096986383 -1447.0522363058797 -119.25657072448729 8.0543068018834365 -1449.2775311021724 -119.25657072448729 4.1999831528857241
+6 0 5 -1443.2503515873489 -119.25657072448729 54.478643147354688 -1443.2503515873489 -119.25657072448729 60.258085628936136 -1443.2503512471808 -119.25657072448729 66.045039024267311 -1443.2503515124795 -119.25657072448729 71.821391317736385 -1443.2503514528391 -119.25657072448729 77.606067882125643 -1443.2503514528391 -119.25657072448729 83.387254250583567
+6 0 10 -1443.2503514528698 -119.25657072448729 83.387254250640623 -1443.2503514528632 -119.25657072448729 85.762385632559244 -1442.5171927054937 -119.25657072448729 87.417659086073954 -1441.7580724966722 -119.25657072448729 88.820412311462022 -1440.6614989012178 -119.25657072448729 89.812251434417504 -1439.6547427320654 -119.25657072448729 90.770151528468148 -1438.3761431060627 -119.25657072448729 91.336376132613523 -1437.0513025532814 -119.25657072448729 91.922545882130663 -1435.501730427337 -119.25657072448729 92.11581644560269 -1433.6757950759084 -119.25657072448729 92.141558510474582 -1431.5004177481062 -119.25657072448729 91.241420713333127
+6 0 8 -1431.5004177459186 -119.25657072448729 91.241420718203486 -1415.9404331811413 -119.25657072448729 84.802937586627721 -1403.650242691572 -119.25657072448729 75.590477282680837 -1394.3645486135842 -119.25657072448729 65.182792420569825 -1387.1812038514411 -119.25657072448729 54.034979013416624 -1381.8288612054218 -119.25657072448729 41.893524674313888 -1378.2501999261251 -119.25657072448729 28.388705351459535 -1377.3362057615386 -119.25657072448729 13.011003415067517 -1380.5733577908798 -119.25657072448729 -3.5788849929761568
+6 0 10 -1380.5733577912592 -119.25657072448729 -3.5788849930628595 -1381.0040319627392 -119.25657072448729 -5.7860215069364109 -1381.9652856223863 -119.25657072448729 -7.2704744420015679 -1382.9450477960286 -119.25657072448729 -8.4416191023428109 -1384.1121440573822 -119.25657072448729 -9.2521166982554632 -1385.2592093696353 -119.25657072448729 -9.9963406563183099 -1386.5751653135678 -119.25657072448729 -10.366785981409624 -1387.9620139663641 -119.25657072448729 -10.736275884697804 -1389.5095836215307 -119.25657072448729 -10.672937135457722 -1391.2307057785808 -119.25657072448729 -10.429567366730549 -1393.1660183230074 -119.25657072448729 -9.3122141482465874
+6 0 5 -1393.166018310859 -119.25657072448729 -9.3122141204709834 -1397.9835020122223 -119.25657072448729 -6.5308386086722958 -1402.8033241048288 -119.25657072448729 -3.7481127156149441 -1407.617734188995 -119.25657072448729 -0.96851238066890843 -1412.4389116956663 -119.25657072448729 1.8149960566895271 -1417.255375328263 -119.25657072448729 4.5957826315113071
+6 0 6 -1417.2553753265265 -119.25657072448729 4.5957826363317729 -1418.7033090140098 -119.25657072448729 5.4317475405712248 -1419.7623351064942 -119.25657072448729 6.499045285928041 -1420.592700973963 -119.25657072448729 7.6679566169846414 -1421.1521915136066 -119.25657072448729 8.9812997774784034 -1421.529032529827 -119.25657072448729 10.395208609676791 -1421.5044732785298 -119.25657072448729 12.080829211793819
+6 0 6 -1421.5044732767601 -119.25657072448729 12.080829211822786 -1421.3958643984658 -119.25657072448729 19.535183605927926 -1422.86575036916 -119.25657072448729 26.351146087347551 -1425.3951750203735 -119.25657072448729 32.448876993455784 -1428.8597457393134 -119.25657072448729 38.066859018555682 -1433.5239379283132 -119.25657072448729 43.243936953122954 -1439.6252749756245 -119.25657072448729 47.515517336234197
+6 0 6 -1439.6252749756727 -119.25657072448729 47.515517336258689 -1440.8557239435052 -119.25657072448729 48.376961579160906 -1441.7349083786282 -119.25657072448729 49.378867040247485 -1442.4433440496464 -119.25657072448729 50.466213853341316 -1442.9380057455091 -119.25657072448729 51.671113316334427 -1443.2503514555003 -119.25657072448729 52.991498489569913 -1443.2503514555019 -119.25657072448729 54.478643118170638
+6 0 1 -1438.1933877648048 -122.73817072448729 -26.159037417355311 -1438.1933877648048 -119.25657072448729 -26.159037417355311
+6 0 5 -1438.1933877648048 -122.73817072448729 -26.159037417355311 -1433.1882437560444 -122.73817072448729 -29.048758658146035 -1428.1765952752551 -122.73817072448729 -31.942235650405884 -1423.1741273152529 -122.73817072448729 -34.830411567385063 -1418.1644504876356 -122.73817072448729 -37.722749901229712 -1413.1577962285387 -122.73817072448729 -40.613343085458666
+6 0 1 -1413.1577962285387 -122.73817072448729 -40.613343085458666 -1413.1577962285387 -119.25657072448729 -40.613343085458666
+6 0 1 -1519.8111789133811 -122.73817072448729 -51.410142207399772 -1519.8111789133811 -119.25657072448729 -51.410142207399772
+6 0 10 -1519.8111789133811 -122.73817072448729 -51.410142207399772 -1521.507278118276 -122.73817072448729 -49.933599177207526 -1522.3122252409412 -122.73817072448729 -48.358902620939759 -1522.836585181482 -122.73817072448729 -46.924831358727793 -1522.9549485585717 -122.73817072448729 -45.508847549777421 -1523.0259327562326 -122.73817072448729 -44.143347870534939 -1522.6887698465086 -122.73817072448729 -42.818473930282529 -1522.3153331628 -122.73817072448729 -41.432682814112653 -1521.4866953693308 -122.73817072448729 -40.124117553232537 -1520.415369888575 -122.73817072448729 -38.755266926574457 -1518.4800573441544 -122.73817072448729 -37.63791370808039
+6 0 1 -1518.4800573261739 -122.73817072448729 -37.637913732488855 -1518.4800573261739 -119.25657072448729 -37.637913732488855
+6 0 10 -1413.1577962284734 -122.73817072448729 -40.613343085460301 -1411.1008721144096 -122.73817072448729 -41.800908776425317 -1410.0339426271407 -122.73817072448729 -43.263479603411419 -1409.1986828031249 -122.73817072448729 -44.622273601470987 -1408.8880117239055 -122.73817072448729 -46.067853753731441 -1408.5618239927462 -122.73817072448729 -47.418680218659361 -1408.71075891431 -122.73817072448729 -48.809092278119628 -1408.8655412966889 -122.73817072448729 -50.249522727550584 -1409.4729501418906 -122.73817072448729 -51.688126835350801 -1410.3636245354799 -122.73817072448729 -53.282304267791964 -1412.230855398612 -122.73817072448729 -54.716167397914525
+6 0 1 -1412.2308553986115 -122.73817072448729 -54.716167397914532 -1412.2308553986115 -119.25657072448729 -54.716167397914532
+6 0 5 -1518.4800573261739 -122.73817072448729 -37.637913732488855 -1513.6625736248106 -122.73817072448729 -34.856538220690169 -1508.8427512633511 -122.73817072448729 -32.073812793300227 -1504.0283417188371 -122.73817072448729 -29.294211523649359 -1499.2071639471005 -122.73817072448729 -26.51070354539705 -1494.3907003145039 -122.73817072448729 -23.729916970575267
+6 0 1 -1494.3907003111972 -122.73817072448729 -23.729916974489296 -1494.3907003111972 -119.25657072448729 -23.729916974489296
+6 0 8 -1412.2308553954881 -122.73817072448729 -54.716167402244587 -1425.5867376316589 -122.73817072448729 -64.972267752047642 -1439.7100575310174 -122.73817072448729 -71.009654781391077 -1453.3662240551821 -122.73817072448729 -73.847459313643569 -1466.6121860434971 -122.73817072448729 -74.494511658224894 -1479.8031652630584 -122.73817072448729 -73.059049189884988 -1493.2880125098177 -122.73817072448729 -69.405851107868514 -1507.0624901208516 -122.73817072448729 -62.508542305115142 -1519.811178913496 -122.73817072448729 -51.410142207771543
+6 0 6 -1494.3907003111972 -122.73817072448729 -23.729916974489296 -1492.942766623712 -122.73817072448729 -22.89395207025326 -1491.4889466165889 -122.73817072448729 -22.510457443569617 -1490.061456775388 -122.73817072448729 -22.375795173434408 -1488.644322964692 -122.73817072448729 -22.547933733172911 -1487.2314214892629 -122.73817072448729 -22.928534256037267 -1485.7839108523358 -122.73817072448729 -23.792613492617168
+6 0 1 -1485.7839108523358 -122.73817072448729 -23.792613492617171 -1485.7839108523358 -119.25657072448729 -23.792613492617171
+6 0 6 -1485.7839108531955 -122.73817072448729 -23.792613494164076 -1479.3825550182355 -122.73817072448729 -27.613848738896024 -1472.7448153727375 -122.73817072448729 -29.748871388318396 -1466.1993131769996 -122.73817072448729 -30.607190836462994 -1459.6017126657887 -122.73817072448729 -30.415775593203247 -1452.7861355625816 -122.73817072448729 -28.965005636680111 -1446.0361699128443 -122.73817072448729 -25.816882948213085
+6 0 1 -1446.0361699128443 -122.73817072448729 -25.816882948213081 -1446.0361699128443 -119.25657072448729 -25.816882948213081
+6 0 6 -1446.0361699127991 -122.73817072448729 -25.816882948183508 -1444.6749128305858 -122.73817072448729 -25.182005005431442 -1443.3676450315329 -122.73817072448729 -24.921561680546258 -1442.0717572331605 -122.73817072448729 -24.851711799044452 -1440.7809528412708 -122.73817072448729 -25.025771935644745 -1439.4812928834731 -122.73817072448729 -25.415465202647042 -1438.1933878560026 -122.73817072448729 -26.159037516946036
+6 0 1 -1463.9999629665078 -119.25657072448729 106.19998315288572 -1463.9999629665078 -117.51577072448728 106.19998315288572
+6 0 8 -1463.9999629665078 -117.51577072448728 106.19998315288574 -1488.4782057257282 -117.51577072448728 106.19998315288574 -1512.9564484849486 -117.51577072448728 98.876110045728154 -1534.8781772498057 -117.51577072448728 84.228363831412992 -1551.6875567390884 -117.51577072448728 63.326439022075753 -1561.3844648673255 -117.51577072448728 38.318126957835275 -1563.1089208146811 -117.51577072448728 12.009479845439365 -1557.212459599963 -117.51577072448728 -12.851236777626838 -1544.9733382203528 -117.51577072448728 -34.05001684711425
+6 0 1 -1510.5561495880195 -122.73817072448729 9.7803438574325856 -1510.5561495880195 -119.25657072448729 9.7803438574325856
+6 0 5 -1510.5561495473703 -122.73817072448729 9.7803437286578081 -1515.5612935561307 -122.73817072448729 6.8906224878670823 -1520.5729423770883 -122.73817072448729 3.997146084795753 -1525.5754100717918 -122.73817072448729 1.1089697083058514 -1530.5850869590495 -122.73817072448729 -1.7833685222387565 -1535.5917412181464 -122.73817072448729 -4.6739617064677184
+6 0 1 -1535.5917412181464 -122.73817072448729 -4.6739617064677184 -1535.5917412181464 -119.25657072448729 -4.6739617064677184
+6 0 10 -1535.5917412181802 -122.73817072448729 -4.6739617065231407 -1537.6486653322506 -122.73817072448729 -5.8615273974767401 -1539.4487535668891 -122.73817072448729 -6.0542300240053502 -1541.0431335997264 -122.73817072448729 -6.098189251333852 -1542.4503782744002 -122.73817072448729 -5.6444482220288901 -1543.7833221747117 -122.73817072448729 -5.2515218511516206 -1544.9129868791506 -122.73817072448729 -4.4273343958367368 -1546.083045049553 -122.73817072448729 -3.5730736959229206 -1547.0252083302958 -122.73817072448729 -2.3277401515947185 -1547.9604692881351 -122.73817072448729 -0.75930478402544166 -1548.2686157528051 -122.73817072448729 1.5746961432385733
+6 0 1 -1548.2686157581172 -122.73817072448729 1.5746961426983237 -1548.2686157581172 -119.25657072448729 1.5746961426983237
+6 0 8 -1548.2686157581172 -122.73817072448729 1.5746961426983237 -1550.4727180867237 -122.73817072448729 18.269279624077143 -1548.6395886769346 -122.73817072448729 33.519126957367455 -1544.2691162307576 -122.73817072448729 46.764616351730965 -1538.2064990045858 -122.73817072448729 58.559482103465484 -1530.3678624310437 -122.73817072448729 69.265473974228328 -1520.4616764635812 -122.73817072448729 79.117095215066215 -1507.6011930171337 -122.73817072448729 87.597488348704871 -1491.6153521951483 -122.73817072448729 93.088976659404963
+6 0 1 -1491.6153521951483 -122.73817072448729 93.088976659404935 -1491.6153521951483 -119.25657072448729 93.088976659404935
+6 0 10 -1491.6153521948836 -122.73817072448729 93.088976659119808 -1489.4885788185088 -122.73817072448729 93.819570142801112 -1487.7223780361965 -122.73817072448729 93.729326521598495 -1486.2182559220132 -122.73817072448729 93.466399919727763 -1484.9327962835698 -122.73817072448729 92.860913706690042 -1483.7147467736559 -122.73817072448729 92.239637985510413 -1482.7359537394473 -122.73817072448729 91.285209370349321 -1481.7225417703596 -122.73817072448729 90.268908157467621 -1481.0036099086622 -122.73817072448729 88.897004147347431 -1480.3538132323679 -122.73817072448729 87.284783751962195 -1480.353813232362 -122.73817072448729 85.050077314984236
+6 0 1 -1480.3538132624908 -122.73817072448729 85.050077311617017 -1480.3538132624908 -119.25657072448729 85.050077311617017
+6 0 5 -1480.3538132624908 -122.73817072448729 85.050077311617017 -1480.3538132624908 -122.73817072448729 79.487326288019645 -1480.353813531344 -122.73817072448729 73.92187496757235 -1480.3538129916919 -122.73817072448729 68.362673362975443 -1480.3538132567569 -122.73817072448729 62.795656947364698 -1480.3538132567569 -122.73817072448729 57.234083797721134
+6 0 1 -1480.3538132567569 -122.73817072448729 57.234083797721141 -1480.3538132567569 -119.25657072448729 57.234083797721141
+6 0 6 -1480.3538132618 -122.73817072448729 57.234083796814687 -1480.3538132618021 -122.73817072448729 55.562153988339197 -1480.7486071764408 -122.73817072448729 54.111361616298737 -1481.3457311501729 -122.73817072448729 52.807788015106929 -1482.2033744212254 -122.73817072448729 51.66658341435167 -1483.2394348804341 -122.73817072448729 50.633275105017638 -1484.7115047686586 -122.73817072448729 49.811733739480509
+6 0 1 -1484.7115047695681 -122.73817072448729 49.811733740998463 -1484.7115047695681 -119.25657072448729 49.811733740998463
+6 0 6 -1484.7115047695681 -122.73817072448729 49.811733740998463 -1491.2214694828224 -122.73817072448729 46.178614591625276 -1496.3893231576264 -122.73817072448729 41.497674759628026 -1500.4054007021509 -122.73817072448729 36.2582633016644 -1503.5384304944218 -122.73817072448729 30.448866033304753 -1505.6898154086291 -122.73817072448729 23.821018142214353 -1506.3384440110551 -122.73817072448729 16.401315070636088
+6 0 1 -1506.3384440110551 -122.73817072448729 16.401315070636088 -1506.3384440110551 -119.25657072448729 16.401315070636088
+6 0 6 -1506.3384440110519 -122.73817072448729 16.401315070581994 -1506.4692521254328 -122.73817072448729 14.904992884927713 -1506.8973354893626 -122.73817072448729 13.642644098955952 -1507.4847876167169 -122.73817072448729 12.485447404360315 -1508.2809303127437 -122.73817072448729 11.454608077967499 -1509.2682445605503 -122.73817072448729 10.523916171734314 -1510.5561495880193 -122.73817072448729 9.7803438574325838
+6 0 1 -1544.9733382203528 -117.51577072448728 -34.050016847114264 -1574.4182019490238 -117.51577072448728 -51.050016847114264
+6 0 8 -1574.4182019490238 -117.51577072448728 -51.050016847114293 -1557.728490976828 -117.51577072448728 -79.957444214597132 -1532.3896979615974 -117.51577072448728 -103.87132173629072 -1500.1449006267617 -117.51577072448728 -119.77255023367357 -1463.9999629665076 -117.51577072448728 -125.37216921763252 -1427.8550253062535 -117.51577072448728 -119.77255023367357 -1395.6102279714178 -117.51577072448728 -103.87132173629072 -1370.2714349561872 -117.51577072448728 -79.957444214597146 -1353.5817239839914 -117.51577072448728 -51.050016847114307
+6 0 1 -1383.0265877126628 -117.51577072448728 -34.050016847114286 -1353.5817239839919 -117.51577072448728 -51.0500168471143
+6 0 8 -1383.0265877126628 -117.51577072448728 -34.050016847114286 -1370.7874663330526 -117.51577072448728 -12.851236777626863 -1364.8910051183345 -117.51577072448728 12.009479845439351 -1366.6154610656902 -117.51577072448728 38.318126957835268 -1376.3123691939272 -117.51577072448728 63.326439022075739 -1393.1217486832099 -117.51577072448728 84.228363831412992 -1415.0434774480671 -117.51577072448728 98.876110045728154 -1439.5217202072874 -117.51577072448728 106.19998315288574 -1463.9999629665078 -117.51577072448728 106.19998315288575
+6 0 1 -1443.2503515873489 -122.73817072448729 54.478643147354688 -1443.2503515873489 -119.25657072448729 54.478643147354688
+6 0 5 -1443.2503515873489 -122.73817072448729 54.478643147354688 -1443.2503515873489 -122.73817072448729 60.258085628936136 -1443.2503512471808 -122.73817072448729 66.045039024267311 -1443.2503515124795 -122.73817072448729 71.821391317736385 -1443.2503514528391 -122.73817072448729 77.606067882125643 -1443.2503514528391 -122.73817072448729 83.387254250583567
+6 0 1 -1443.2503514528698 -122.73817072448729 83.387254250640623 -1443.2503514528698 -119.25657072448729 83.387254250640623
+6 0 10 -1443.2503514528698 -122.73817072448729 83.387254250640623 -1443.2503514528632 -122.73817072448729 85.762385632559244 -1442.5171927054937 -122.73817072448729 87.417659086073954 -1441.7580724966722 -122.73817072448729 88.820412311462022 -1440.6614989012178 -122.73817072448729 89.812251434417504 -1439.6547427320654 -122.73817072448729 90.770151528468148 -1438.3761431060627 -122.73817072448729 91.336376132613523 -1437.0513025532814 -122.73817072448729 91.922545882130663 -1435.501730427337 -122.73817072448729 92.11581644560269 -1433.6757950759084 -122.73817072448729 92.141558510474582 -1431.5004177481062 -122.73817072448729 91.241420713333127
+6 0 1 -1431.5004177459186 -122.73817072448729 91.241420718203486 -1431.5004177459186 -119.25657072448729 91.241420718203486
+6 0 8 -1431.5004177459186 -122.73817072448729 91.241420718203486 -1415.9404331811413 -122.73817072448729 84.802937586627721 -1403.650242691572 -122.73817072448729 75.590477282680837 -1394.3645486135842 -122.73817072448729 65.182792420569825 -1387.1812038514411 -122.73817072448729 54.034979013416624 -1381.8288612054218 -122.73817072448729 41.893524674313888 -1378.2501999261251 -122.73817072448729 28.388705351459535 -1377.3362057615386 -122.73817072448729 13.011003415067517 -1380.5733577908798 -122.73817072448729 -3.5788849929761568
+6 0 1 -1380.5733577912592 -122.73817072448729 -3.5788849930628595 -1380.5733577912592 -119.25657072448729 -3.5788849930628595
+6 0 10 -1380.5733577912592 -122.73817072448729 -3.5788849930628595 -1381.0040319627392 -122.73817072448729 -5.7860215069364109 -1381.9652856223863 -122.73817072448729 -7.2704744420015679 -1382.9450477960286 -122.73817072448729 -8.4416191023428109 -1384.1121440573822 -122.73817072448729 -9.2521166982554632 -1385.2592093696353 -122.73817072448729 -9.9963406563183099 -1386.5751653135678 -122.73817072448729 -10.366785981409624 -1387.9620139663641 -122.73817072448729 -10.736275884697804 -1389.5095836215307 -122.73817072448729 -10.672937135457722 -1391.2307057785808 -122.73817072448729 -10.429567366730549 -1393.1660183230074 -122.73817072448729 -9.3122141482465874
+6 0 1 -1393.166018310859 -122.73817072448729 -9.3122141204709834 -1393.166018310859 -119.25657072448729 -9.3122141204709834
+6 0 5 -1393.166018310859 -122.73817072448729 -9.3122141204709834 -1397.9835020122223 -122.73817072448729 -6.5308386086722958 -1402.8033241048288 -122.73817072448729 -3.7481127156149441 -1407.617734188995 -122.73817072448729 -0.96851238066890843 -1412.4389116956663 -122.73817072448729 1.8149960566895271 -1417.255375328263 -122.73817072448729 4.5957826315113071
+6 0 1 -1417.255375328263 -122.73817072448729 4.5957826315113071 -1417.255375328263 -119.25657072448729 4.5957826315113071
+6 0 6 -1417.2553753265265 -122.73817072448729 4.5957826363317729 -1418.7033090140098 -122.73817072448729 5.4317475405712248 -1419.7623351064942 -122.73817072448729 6.499045285928041 -1420.592700973963 -122.73817072448729 7.6679566169846414 -1421.1521915136066 -122.73817072448729 8.9812997774784034 -1421.529032529827 -122.73817072448729 10.395208609676791 -1421.5044732785298 -122.73817072448729 12.080829211793819
+6 0 1 -1421.5044732767601 -122.73817072448729 12.080829211822786 -1421.5044732767601 -119.25657072448729 12.080829211822786
+6 0 6 -1421.5044732767601 -122.73817072448729 12.080829211822786 -1421.3958643984658 -122.73817072448729 19.535183605927926 -1422.86575036916 -122.73817072448729 26.351146087347551 -1425.3951750203735 -122.73817072448729 32.448876993455784 -1428.8597457393134 -122.73817072448729 38.066859018555682 -1433.5239379283132 -122.73817072448729 43.243936953122954 -1439.6252749756245 -122.73817072448729 47.515517336234197
+6 0 1 -1439.6252749756727 -122.73817072448729 47.515517336258689 -1439.6252749756727 -119.25657072448729 47.515517336258689
+6 0 6 -1439.6252749756727 -122.73817072448729 47.515517336258689 -1440.8557239435052 -122.73817072448729 48.376961579160906 -1441.7349083786282 -122.73817072448729 49.378867040247485 -1442.4433440496464 -122.73817072448729 50.466213853341316 -1442.9380057455091 -122.73817072448729 51.671113316334427 -1443.2503514555003 -122.73817072448729 52.991498489569913 -1443.2503514555019 -122.73817072448729 54.478643118170638
+6 0 8 -1449.2775311021724 -122.73817072448729 4.1999831528857339 -1451.5028258984651 -122.73817072448729 0.34565950388802058 -1454.8813316338292 -122.73817072448729 -2.8428574990044586 -1459.1806379451407 -122.73817072448729 -4.9630212986555069 -1463.9999629665078 -122.73817072448729 -5.7096371631833689 -1468.819287987875 -122.73817072448729 -4.9630212986555122 -1473.1185942991865 -122.73817072448729 -2.8428574990044684 -1476.4971000345506 -122.73817072448729 0.34565950388800637 -1478.7223948308433 -122.73817072448729 4.1999831528857161
+6 0 1 -1383.0265877126628 -122.73817072448729 -34.050016847114257 -1449.2775311021724 -122.73817072448729 4.1999831528857356
+6 0 8 -1544.9733382203528 -122.73817072448729 -34.050016847114286 -1532.7342168407426 -122.73817072448729 -55.248796916601705 -1514.1524352962404 -122.73817072448729 -72.785640432510334 -1490.5062505840276 -122.73817072448729 -84.446541330591089 -1463.9999629665081 -122.73817072448729 -88.552928585494314 -1437.4936753489885 -122.73817072448729 -84.446541330591089 -1413.8474906367758 -122.73817072448729 -72.785640432510334 -1395.2657090922735 -122.73817072448729 -55.248796916601705 -1383.0265877126633 -122.73817072448729 -34.050016847114293
+6 0 1 -1478.7223948308435 -122.73817072448729 4.1999831528857356 -1544.9733382203531 -122.73817072448729 -34.050016847114271
+6 0 1 -1463.9999629665078 -117.51577072448728 106.19998315288574 -1463.9999629665078 -117.51577072448728 140.19998315288575
+6 0 8 -1463.9999629665078 -117.51577072448728 140.19998315288572 -1497.3793849108995 -117.51577072448728 140.19998315288572 -1530.7588068552911 -117.51577072448728 130.2128834613072 -1560.6520733528237 -117.51577072448728 110.23868407815017 -1583.5739544745727 -117.51577072448728 81.736059338144855 -1596.7970110130777 -117.51577072448728 47.633815614180577 -1599.148541850381 -117.51577072448728 11.758387733640703 -1591.1079129212198 -117.51577072448728 -22.14258947963139 -1574.418201949024 -117.51577072448728 -51.050016847114222
+6 0 8 -1478.7223948308435 -122.73817072448729 4.1999831528857312 -1480.9476896271362 -122.73817072448729 8.0543068018834436 -1482.0197734843578 -122.73817072448729 12.57443709698639 -1481.7062360393841 -122.73817072448729 17.357827481058372 -1479.9431618342501 -122.73817072448729 21.904793310920276 -1476.8869110180169 -122.73817072448729 25.705143276254319 -1472.9011421516793 -122.73817072448729 28.368369860675255 -1468.4505525590937 -122.73817072448729 29.699983152885725 -1463.9999629665081 -122.73817072448729 29.699983152885725
+6 0 8 -1463.9999629665078 -122.73817072448729 106.19998315288574 -1488.4782057257282 -122.73817072448729 106.19998315288574 -1512.9564484849486 -122.73817072448729 98.876110045728154 -1534.8781772498057 -122.73817072448729 84.228363831412992 -1551.6875567390884 -122.73817072448729 63.326439022075753 -1561.3844648673255 -122.73817072448729 38.318126957835275 -1563.1089208146811 -122.73817072448729 12.009479845439365 -1557.212459599963 -122.73817072448729 -12.851236777626838 -1544.9733382203528 -122.73817072448729 -34.05001684711425
+6 0 1 -1463.9999629665078 -122.73817072448729 29.699983152885732 -1463.9999629665078 -122.73817072448729 106.19998315288575
+6 0 1 -1353.5817239839921 -120.99737072448728 -51.050016847114279 -1353.5817239839921 -117.51577072448728 -51.050016847114279
+6 0 1 -1574.4182019490238 -120.99737072448728 -51.050016847114222 -1574.4182019490238 -117.51577072448728 -51.050016847114222
+6 0 8 -1574.4182019490238 -120.99737072448728 -51.050016847114293 -1557.728490976828 -120.99737072448728 -79.957444214597132 -1532.3896979615974 -120.99737072448728 -103.87132173629071 -1500.1449006267617 -120.99737072448728 -119.77255023367356 -1463.9999629665076 -120.99737072448728 -125.37216921763249 -1427.8550253062535 -120.99737072448728 -119.77255023367354 -1395.6102279714178 -120.99737072448728 -103.8713217362907 -1370.2714349561872 -120.99737072448728 -79.957444214597118 -1353.5817239839914 -120.99737072448728 -51.050016847114286
+6 0 8 -1353.5817239839919 -117.51577072448728 -51.050016847114286 -1336.8920130117961 -117.51577072448728 -22.142589479631436 -1328.8513840826349 -117.51577072448728 11.758387733640678 -1331.2029149199382 -117.51577072448728 47.633815614180563 -1344.4259714584432 -117.51577072448728 81.736059338144841 -1367.3478525801922 -117.51577072448728 110.23868407815019 -1397.2411190777248 -117.51577072448728 130.21288346130723 -1430.6205410221164 -117.51577072448728 140.19998315288575 -1463.9999629665081 -117.51577072448728 140.19998315288575
+6 0 8 -1463.9999629665078 -122.73817072448729 29.699983152885718 -1459.5493733739222 -122.73817072448729 29.699983152885718 -1455.0987837813366 -122.73817072448729 28.368369860675251 -1451.113014914999 -122.73817072448729 25.705143276254315 -1448.0567640987658 -122.73817072448729 21.904793310920269 -1446.2936898936318 -122.73817072448729 17.357827481058365 -1445.9801524486581 -122.73817072448729 12.574437096986383 -1447.0522363058797 -122.73817072448729 8.0543068018834365 -1449.2775311021724 -122.73817072448729 4.1999831528857241
+6 0 8 -1383.0265877126628 -122.73817072448729 -34.050016847114286 -1370.7874663330526 -122.73817072448729 -12.851236777626863 -1364.8910051183345 -122.73817072448729 12.009479845439351 -1366.6154610656902 -122.73817072448729 38.318126957835268 -1376.3123691939272 -122.73817072448729 63.326439022075739 -1393.1217486832099 -122.73817072448729 84.228363831412992 -1415.0434774480671 -122.73817072448729 98.876110045728154 -1439.5217202072874 -122.73817072448729 106.19998315288574 -1463.9999629665078 -122.73817072448729 106.19998315288575
+6 0 1 -1383.0265877126628 -122.73817072448729 -34.050016847114286 -1383.0265877126628 -124.4789707244873 -34.050016847114286
+6 0 8 -1544.9733382203528 -124.4789707244873 -34.050016847114286 -1532.7342168407426 -124.4789707244873 -55.248796916601705 -1514.1524352962404 -124.4789707244873 -72.785640432510334 -1490.5062505840276 -124.4789707244873 -84.446541330591089 -1463.9999629665081 -124.4789707244873 -88.552928585494314 -1437.4936753489885 -124.4789707244873 -84.446541330591089 -1413.8474906367758 -124.4789707244873 -72.785640432510334 -1395.2657090922735 -124.4789707244873 -55.248796916601705 -1383.0265877126633 -124.4789707244873 -34.050016847114293
+6 0 1 -1544.9733382203528 -122.73817072448729 -34.050016847114264 -1544.9733382203528 -124.4789707244873 -34.050016847114264
+6 0 1 -1463.9999629665078 -120.99737072448728 140.19998315288572 -1463.9999629665078 -117.51577072448728 140.19998315288572
+6 0 8 -1463.9999629665078 -120.99737072448728 140.19998315288572 -1497.3793849108995 -120.99737072448728 140.19998315288572 -1530.7588068552911 -120.99737072448728 130.2128834613072 -1560.6520733528237 -120.99737072448728 110.23868407815017 -1583.5739544745727 -120.99737072448728 81.736059338144855 -1596.7970110130777 -120.99737072448728 47.633815614180577 -1599.148541850381 -120.99737072448728 11.758387733640703 -1591.1079129212198 -120.99737072448728 -22.14258947963139 -1574.418201949024 -120.99737072448728 -51.050016847114222
+6 0 8 -1463.9999629665078 -124.4789707244873 106.19998315288574 -1488.4782057257282 -124.4789707244873 106.19998315288574 -1512.9564484849486 -124.4789707244873 98.876110045728154 -1534.8781772498057 -124.4789707244873 84.228363831412992 -1551.6875567390884 -124.4789707244873 63.326439022075753 -1561.3844648673255 -124.4789707244873 38.318126957835275 -1563.1089208146811 -124.4789707244873 12.009479845439365 -1557.212459599963 -124.4789707244873 -12.851236777626838 -1544.9733382203528 -124.4789707244873 -34.05001684711425
+6 0 1 -1463.9999629665078 -122.73817072448729 106.19998315288572 -1463.9999629665078 -124.4789707244873 106.19998315288572
+6 0 1 -1574.4182019490238 -120.99737072448728 -51.050016847114222 -1574.4182019490238 -124.47897072448728 -51.050016847114222
+6 0 8 -1574.4182019490238 -124.4789707244873 -51.050016847114293 -1557.728490976828 -124.4789707244873 -79.957444214597132 -1532.3896979615974 -124.4789707244873 -103.87132173629072 -1500.1449006267617 -124.4789707244873 -119.77255023367357 -1463.9999629665076 -124.4789707244873 -125.37216921763252 -1427.8550253062535 -124.4789707244873 -119.77255023367357 -1395.6102279714178 -124.4789707244873 -103.87132173629072 -1370.2714349561872 -124.4789707244873 -79.957444214597146 -1353.5817239839914 -124.4789707244873 -51.050016847114307
+6 0 1 -1353.5817239839921 -120.99737072448728 -51.050016847114279 -1353.5817239839921 -124.47897072448728 -51.050016847114279
+6 0 8 -1353.5817239839921 -120.99737072448728 -51.050016847114279 -1336.8920130117963 -120.99737072448728 -22.142589479631429 -1328.8513840826351 -120.99737072448728 11.758387733640685 -1331.2029149199384 -120.99737072448728 47.633815614180577 -1344.4259714584434 -120.99737072448728 81.736059338144855 -1367.3478525801925 -120.99737072448728 110.2386840781502 -1397.241119077725 -120.99737072448728 130.21288346130723 -1430.6205410221164 -120.99737072448728 140.19998315288575 -1463.9999629665081 -120.99737072448728 140.19998315288575
+6 0 8 -1383.0265877126628 -124.4789707244873 -34.050016847114286 -1370.7874663330526 -124.4789707244873 -12.851236777626863 -1364.8910051183345 -124.4789707244873 12.009479845439351 -1366.6154610656902 -124.4789707244873 38.318126957835268 -1376.3123691939272 -124.4789707244873 63.326439022075739 -1393.1217486832099 -124.4789707244873 84.228363831412992 -1415.0434774480671 -124.4789707244873 98.876110045728154 -1439.5217202072874 -124.4789707244873 106.19998315288574 -1463.9999629665078 -124.4789707244873 106.19998315288575
+6 0 1 -1383.0265877126628 -124.4789707244873 -34.050016847114286 -1353.5817239839919 -124.4789707244873 -51.0500168471143
+6 0 1 -1544.9733382203528 -124.4789707244873 -34.050016847114286 -1574.4182019490238 -124.4789707244873 -51.050016847114293
+6 0 1 -1463.9999629665078 -120.99737072448728 140.19998315288572 -1463.9999629665078 -124.47897072448728 140.19998315288572
+6 0 8 -1463.9999629665078 -124.47897072448728 140.19998315288572 -1497.3793849108995 -124.47897072448728 140.19998315288572 -1530.7588068552911 -124.47897072448728 130.2128834613072 -1560.6520733528237 -124.47897072448728 110.23868407815017 -1583.5739544745727 -124.47897072448728 81.736059338144855 -1596.7970110130777 -124.47897072448728 47.633815614180577 -1599.148541850381 -124.47897072448728 11.758387733640703 -1591.1079129212198 -124.47897072448728 -22.14258947963139 -1574.418201949024 -124.47897072448728 -51.050016847114222
+6 0 1 -1463.9999629665078 -124.4789707244873 106.19998315288572 -1463.9999629665078 -124.4789707244873 140.19998315288572
+6 0 8 -1353.5817239839919 -124.4789707244873 -51.050016847114286 -1336.8920130117961 -124.4789707244873 -22.142589479631436 -1328.8513840826349 -124.4789707244873 11.758387733640678 -1331.2029149199382 -124.4789707244873 47.633815614180563 -1344.4259714584432 -124.4789707244873 81.736059338144841 -1367.3478525801922 -124.4789707244873 110.23868407815019 -1397.2411190777248 -124.4789707244873 130.21288346130723 -1430.6205410221164 -124.4789707244873 140.19998315288575 -1463.9999629665081 -124.4789707244873 140.19998315288575
+6 0 1 -1077.2827051235111 -6.192602565414833e-12 522.06612722068019 -1335.4777734828861 -6.1955358524516293e-12 555.20933374554102
+6 0 3 -1077.2827051235108 118.33457946760313 522.06612722068019 -1077.2827051235108 78.889719653974112 522.06612722068019 -1077.2827051235111 39.444859843978783 522.06612722068019 -1077.2827051235111 -6.1959326558280736e-12 522.06612722068019
+6 0 8 -1077.2827051217648 118.33457946760321 522.06612721863462 -1077.2827047986618 119.32036120631383 522.06612719813938 -1077.3928229653943 120.30626064801827 522.08026240661081 -1077.616372090436 121.2769278198347 522.10895876012751 -1077.947751731338 122.21823563748185 522.1514951184239 -1078.3799887289226 123.11557003431321 522.20698083792183 -1078.9119736586551 123.9561757718178 522.27526787523561 -1079.5305452334298 124.72725847934797 522.35467120295812 -1080.2261511819472 125.42002093264763 522.44396263447777
+6 0 8 -1080.226151181947 125.42002093264746 522.44396263447732 -1080.9217571304644 126.11278338594714 522.53325406599697 -1081.6941614242326 126.72710680300402 522.63240062765306 -1082.5338621064839 127.25266446043474 522.74019673480882 -1083.4274724347786 127.68122290286873 522.85489990098074 -1084.3639575914854 128.00549134276005 522.97510773115528 -1085.3269364298772 128.22641864445052 523.09872778298234 -1086.3049453920396 128.33458060582345 523.22426706102465 -1087.2827051234726 128.33457946777381 523.34977708801955
+6 0 3 -1087.2827051234751 128.33457946776153 523.3497770879967 -1166.6810612429906 128.33457946777673 533.54174601803345 -1246.0794172918013 128.33457946560307 543.73371493457557 -1325.4777734825277 128.33457946777332 553.92568387815049
+6 0 8 -1325.477773482909 128.33457947068379 553.92568387517713 -1326.4555331692638 128.3345805413378 554.05119390722791 -1327.4333519361385 128.22640827905445 554.1767148184116 -1328.3970886349769 128.00592688469902 554.30041737582928 -1329.3321755831691 127.67998599177625 554.42045353308436 -1330.227294298641 127.25403341614653 554.53536120452782 -1331.0660741559034 126.72652025537462 554.64302275276191 -1331.8387143706898 126.11278034348052 554.74220597985573 -1332.5343283677953 125.42002016153714 554.83149845235266
+6 0 8 -1332.5343283677955 125.42002016153705 554.83149845235278 -1333.2299423649013 124.72725997959367 554.92079092484948 -1333.8483159879836 123.95584176522395 555.00016819029202 -1334.3803415787816 123.11608750558 555.06846255902906 -1334.8138015600452 122.21805830843311 555.1241023485486 -1335.1428311614256 121.2767765353459 555.16633916834849 -1335.3681801648652 120.30636679139101 555.19526578536954 -1335.4777738267499 119.32036094294311 555.20933376648111 -1335.4777734828874 118.33457946781606 555.20933374554056
+6 0 3 -1335.4777734828861 118.33457946781601 555.2093337455409 -1335.4777734828858 78.889719645322529 555.20933374554102 -1335.4777734828861 39.444859885548965 555.20933374554113 -1335.4777734828858 -6.7927885538665578e-12 555.20933374554113
+6 0 3 -1335.4777734828856 6.1888272284704726e-12 555.20933374554102 -1335.4777734828856 -39.44485988554996 555.20933374554102 -1335.4777734828858 -78.889719645322671 555.20933374554102 -1335.4777734828858 -118.33457946781604 555.20933374554102
+6 0 8 -1332.5343283677955 -125.42002016153705 554.83149845235278 -1333.2299423649013 -124.72725997959367 554.92079092484948 -1333.8483159879836 -123.95584176522395 555.00016819029202 -1334.3803415787816 -123.11608750558 555.06846255902906 -1334.8138015600452 -122.21805830843311 555.1241023485486 -1335.1428311614256 -121.2767765353459 555.16633916834849 -1335.3681801648652 -120.30636679139101 555.19526578536954 -1335.4777738267499 -119.32036094294311 555.20933376648111 -1335.4777734828874 -118.33457946781606 555.20933374554056
+6 0 8 -1325.477773482909 -128.33457947068379 553.92568387517713 -1326.4555331692638 -128.3345805413378 554.05119390722791 -1327.4333519361385 -128.22640827905445 554.1767148184116 -1328.3970886349769 -128.00592688469902 554.30041737582928 -1329.3321755831691 -127.67998599177625 554.42045353308436 -1330.227294298641 -127.25403341614653 554.53536120452782 -1331.0660741559034 -126.72652025537462 554.64302275276191 -1331.8387143706898 -126.11278034348052 554.74220597985573 -1332.5343283677953 -125.42002016153714 554.83149845235266
+6 0 3 -1087.2827051234751 -128.33457946776153 523.3497770879967 -1166.6810612429906 -128.33457946777673 533.54174601803345 -1246.0794172918013 -128.33457946560307 543.73371493457557 -1325.4777734825277 -128.33457946777332 553.92568387815049
+6 0 8 -1080.226151181947 -125.42002093264746 522.44396263447732 -1080.9217571304644 -126.11278338594714 522.53325406599697 -1081.6941614242326 -126.72710680300402 522.63240062765306 -1082.5338621064839 -127.25266446043474 522.74019673480882 -1083.4274724347786 -127.68122290286873 522.85489990098074 -1084.3639575914854 -128.00549134276005 522.97510773115528 -1085.3269364298772 -128.22641864445052 523.09872778298234 -1086.3049453920396 -128.33458060582345 523.22426706102465 -1087.2827051234726 -128.33457946777381 523.34977708801955
+6 0 8 -1077.2827051217648 -118.33457946760321 522.06612721863462 -1077.2827047986618 -119.32036120631383 522.06612719813938 -1077.3928229653943 -120.30626064801827 522.08026240661081 -1077.616372090436 -121.2769278198347 522.10895876012751 -1077.947751731338 -122.21823563748185 522.1514951184239 -1078.3799887289226 -123.11557003431321 522.20698083792183 -1078.9119736586551 -123.9561757718178 522.27526787523561 -1079.5305452334298 -124.72725847934797 522.35467120295812 -1080.2261511819472 -125.42002093264763 522.44396263447777
+6 0 3 -1077.2827051235108 -118.33457946760313 522.06612722068019 -1077.2827051235108 -78.889719653974112 522.06612722068019 -1077.2827051235111 -39.444859843978783 522.06612722068019 -1077.2827051235111 6.1959326558280736e-12 522.06612722068019
+6 0 1 -1068.5559082031252 118.33457946762087 512.14751068821647 -1068.5559082031245 1.0723510968091432e-10 512.14751068821647
+6 0 7 -1068.5559082049322 118.33457946783038 512.14751069020917 -1068.5559082243167 118.33457946778672 514.20912428034035 -1069.051770975467 118.3345794677421 516.2707380561219 -1070.0434749590777 118.33457946769953 518.18925416019692 -1071.4795289123833 118.33457946766214 519.82143015933002 -1073.2561674105511 118.33457946763266 521.04932937324577 -1075.2378696603703 118.3345794676128 521.80364192221498 -1077.282705121765 118.33457946760322 522.06612721863473
+6 0 8 -1068.5559082031248 1.1122835985588608e-10 512.14751068821647 -1068.5559082031248 8.9704196973216587e-11 513.95142256103793 -1068.9278051225426 6.8179995561564059e-11 515.75533443385939 -1069.6715989613783 4.7723058270143551e-11 517.46979707089372 -1070.7614758007253 2.9400643672761443e-11 519.00536515439012 -1072.1457834438686 1.4169191184081096e-11 520.28188119938613 -1073.7515931288463 2.7617768473553406e-12 521.23790769698371 -1075.4934741110235 -4.3802037745115377e-12 521.83645260549758 -1077.2827051235108 -7.1208521879000209e-12 522.06612722068041
+6 0 7 -1074.4427811716037 132.50555380886181 512.52534610351984 -1074.3070092560754 132.37033680437614 514.63212203508601 -1074.5396676462319 131.86517746125034 516.73889808643708 -1075.1506604811423 130.99997640351373 518.69170472100802 -1076.1096498903378 129.82506437563939 520.336394268807 -1077.3435004984758 128.43004365199187 521.5475378291078 -1078.751588317346 126.92503224955067 522.25468038280042 -1080.2261511819474 125.42002093264759 522.44396263447754
+6 0 8 -1068.5559082049322 118.33457946783038 512.14751069020917 -1068.555907503174 120.29587356654628 512.14751067142174 -1068.7737428062085 122.29042793099693 512.16137391742097 -1069.2334936408683 124.23160886740119 512.19104225740352 -1069.8760855983755 126.07928033548967 512.23230874183344 -1070.7503018084203 127.90308804714799 512.28835682236138 -1071.8166948267362 129.578607889832 512.35682070427777 -1073.0526458713675 131.1210998977821 512.43605472595755 -1074.4427811716037 132.50555380886183 512.52534610351972
+6 0 7 -1088.555908203067 138.33457946777318 513.43116055555652 -1088.2702021001019 138.33457946773262 515.65689290075011 -1087.9844959966376 137.74710301129852 517.88262524983872 -1087.7222829116224 136.57219163106072 519.9253402587251 -1087.5070928855773 134.88204471346936 521.60173217463682 -1087.3575028068224 132.822568976908 522.7670817186571 -1087.2827051234735 130.57857422037739 523.34977708797908 -1087.2827051234729 128.33457946777384 523.34977708801932
+6 0 7 -1088.555908203067 138.33457946777352 513.43116055555652 -1086.3321237532084 138.33457946776917 513.28772073669688 -1084.0608924335934 138.04665067765995 513.14373957024236 -1081.9105819958547 137.44893270970269 513.00506229286862 -1079.800075295153 136.60810570766387 512.8676257031043 -1077.8239464535991 135.45819683188037 512.7431012869248 -1076.0315069451085 134.08778618982885 512.6273933523438 -1074.4427811723554 132.50555381190151 512.52534610311261
+6 0 7 -1326.7509765621874 138.33457946477373 544.00706734862422 -1326.4652704548646 138.33457942988645 546.23279972705689 -1326.179564306773 137.74710260443365 548.45853242308294 -1325.9173509446359 136.57218831002075 550.50124959014386 -1325.7021616675634 134.88204727559091 552.1776356707644 -1325.55257121772 132.82256936313689 553.34298810523831 -1325.4777734873555 130.57857425681081 553.92568384057336 -1325.4777734829092 128.33457947068376 553.92568387517713
+6 0 3 -1088.5559082034817 138.33457946777338 513.43116055559528 -1167.954264323037 138.33457946777312 523.62312948562192 -1247.3526204428633 138.33457946777298 533.81509841347122 -1326.7509765621419 138.33457946777335 544.00706734568678
+6 0 7 -1340.8640514182771 132.505605946088 544.9128819203205 -1340.711780020303 132.65725270634624 547.27564527404456 -1340.0961088071256 132.34359091533267 549.63840869365947 -1339.0310753564636 131.55072568554795 551.78401431102941 -1337.5943218996069 130.32856742072758 553.4948282844681 -1335.9253787365863 128.79580601061093 554.60470492915101 -1334.1880480733032 127.10791306254995 555.0437781576843 -1332.5343283677955 125.42002016153707 554.83149845235266
+6 0 7 -1340.8640514168687 132.5056059498263 544.91288191997683 -1339.2753062504919 134.0878339153474 544.81083338737778 -1337.483166491875 135.4579237387523 544.69512638206936 -1335.5069267474914 136.60820472008612 544.57059926498687 -1333.3961612458131 137.44908099912806 544.433174904775 -1331.2456808871502 138.0465639021686 544.29448241962257 -1328.9749904808298 138.33457946776923 544.15050718832208 -1326.7509765625584 138.33457946777352 544.00706734574032
+6 0 8 -1346.7509765625002 118.33457946758776 545.29071721307707 -1346.7509765625002 118.33457946763662 547.41379615724293 -1346.2358377964249 118.33457946768547 549.53687510140878 -1345.205560264274 118.33457946773098 551.5141300098976 -1343.709662495477 118.33457946776977 553.19975164675486 -1341.8473008673939 118.33457946779897 554.4688614148904 -1339.7549622922916 118.3345794678167 555.23900948736525 -1337.5835740744192 118.33457946782224 555.47964481053862 -1335.4777734828863 118.33457946781601 555.20933374554102
+6 0 8 -1340.8640514182771 132.505605946088 544.9128819203205 -1342.2542033048678 131.12115678429848 545.00217436753042 -1343.4902155555978 129.5786310276971 545.08140608589338 -1344.5569403092518 127.90270847741962 545.14988799986838 -1345.4304632773853 126.07910749310174 545.20589510738705 -1346.0733448648848 124.23233223194123 545.24718450702017 -1346.5332360750031 122.29032182348665 545.27686681772911 -1346.7509771926743 120.29566425946744 545.29071723536538 -1346.7509765625 118.33457946783592 545.2907172130781
+6 0 8 -1346.7509765624998 1.1156942036905093e-10 545.29071721307696 -1346.7509765624998 8.6235337722978041e-11 547.41379615724281 -1346.2358377964244 6.0901459759712569e-11 549.53687510140867 -1345.2055602642736 3.730786222244791e-11 551.51413000989749 -1343.7096624954766 1.7194424578137877e-11 553.19975164675475 -1341.8473008673934 2.0512473538232383e-12 554.46886141489028 -1339.7549622922911 -7.1378739120732305e-12 555.23900948736514 -1337.5835740744187 -1.000844236388212e-11 555.4796448105385 -1335.4777734828858 -6.7820624505929896e-12 555.20933374554102
+6 0 3 -1346.7509765625002 118.33457946758776 545.29071721307707 -1346.7509765625 78.889719645095695 545.29071721307719 -1346.7509765624998 39.444859822603625 545.29071721307696 -1346.7509765624998 1.1156942036905093e-10 545.29071721307696
+6 0 3 -1346.7509765625002 -118.33457946758776 545.29071721307707 -1346.7509765625 -78.889719645095695 545.29071721307719 -1346.7509765624998 -39.444859822603625 545.29071721307696 -1346.7509765624998 -1.1156942036905093e-10 545.29071721307696
+6 0 8 -1346.7509765625002 -118.33457946758776 545.29071721307707 -1346.7509765625002 -118.33457946763662 547.41379615724293 -1346.2358377964249 -118.33457946768547 549.53687510140878 -1345.205560264274 -118.33457946773098 551.5141300098976 -1343.709662495477 -118.33457946776977 553.19975164675486 -1341.8473008673939 -118.33457946779897 554.4688614148904 -1339.7549622922916 -118.3345794678167 555.23900948736525 -1337.5835740744192 -118.33457946782224 555.47964481053862 -1335.4777734828863 -118.33457946781601 555.20933374554102
+6 0 8 -1340.8640514182771 -132.505605946088 544.9128819203205 -1342.2542033048678 -131.12115678429848 545.00217436753042 -1343.4902155555978 -129.5786310276971 545.08140608589338 -1344.5569403092518 -127.90270847741962 545.14988799986838 -1345.4304632773853 -126.07910749310174 545.20589510738705 -1346.0733448648848 -124.23233223194123 545.24718450702017 -1346.5332360750031 -122.29032182348665 545.27686681772911 -1346.7509771926743 -120.29566425946744 545.29071723536538 -1346.7509765625 -118.33457946783592 545.2907172130781
+6 0 7 -1340.8640514182771 -132.50560594608802 544.9128819203205 -1340.7117800203027 -132.6572527063463 547.27564527404468 -1340.0961088071253 -132.3435909153327 549.63840869365958 -1339.0310753564636 -131.55072568554795 551.78401431102941 -1337.5943218996063 -130.32856742072761 553.49482828446821 -1335.9253787365863 -128.79580601061096 554.60470492915101 -1334.1880480733032 -127.10791306254998 555.0437781576843 -1332.5343283677953 -125.42002016153712 554.83149845235278
+6 0 8 -1326.7509765621874 -138.33457946477373 544.00706734862422 -1328.6969891903962 -138.33458008407138 544.13257734798788 -1330.6745318679571 -138.11997026318394 544.258075289153 -1332.5995897975947 -137.66840705411099 544.38209570439449 -1334.4394019552333 -137.0354757645232 544.50111893093117 -1336.2555773454219 -136.17189832256093 544.61747319994095 -1337.9291647871896 -135.11694825072016 544.72411169103646 -1339.4738995316866 -133.89005510787754 544.82358947311059 -1340.8640514182771 -132.50560594608802 544.9128819203205
+6 0 8 -1326.7509765621419 -138.33457946777335 544.00706734568678 -1326.5009837220516 -138.33457946777335 545.95458314769689 -1326.2509908819613 -137.893972128439 547.90209894970701 -1326.0156845325544 -137.01275744977031 549.73520278427247 -1325.8097501613613 -135.72716605392682 551.33949049879584 -1325.6460682689299 -134.10971496155665 552.61461930607652 -1325.5338717446616 -132.26157028476055 553.48866235412584 -1325.4777734825275 -130.29807487626692 553.92568387815049 -1325.4777734825275 -128.3345794677733 553.92568387815049
+6 0 1 -1326.7509765625668 -138.33457946777332 544.00706734244159 -1088.5559082034554 -138.33457946777335 513.43116055557402
+6 0 8 -1088.5559082034817 -138.33457946777338 513.43116055559528 -1088.3059153633142 -138.33457946777108 515.37867635759551 -1088.0559225231466 -137.89397212843443 517.32619215959517 -1087.8206161736671 -137.01275744976354 519.15929599415017 -1087.6146818024104 -135.72716605391813 520.76358370866387 -1087.4509999099287 -134.10971496154644 522.03871251593614 -1087.3388033856261 -132.26157028474933 522.91275556397886 -1087.2827051234749 -130.29807487625519 523.34977708799897 -1087.2827051234751 -128.33457946776156 523.3497770879967
+6 0 8 -1074.4427811716032 -132.50555380886166 512.52534610351961 -1075.8329164718393 -133.89000771994139 512.61463748108167 -1077.3777216694425 -135.11699901714854 512.71410598964042 -1079.0516496143812 -136.17221703150364 512.82076408752516 -1080.8676720108679 -137.03516896182435 512.93712878644328 -1082.706590950384 -137.66835912118484 513.05609713668946 -1084.632452704386 -138.12005905039601 513.18016982490963 -1086.6100963847098 -138.33458004944308 513.30565057399167 -1088.5559082030675 -138.33457946777321 513.43116055555663
+6 0 7 -1074.4427811716032 -132.50555380886166 512.52534610351961 -1074.3070092560752 -132.37033680437597 514.63212203508579 -1074.5396676462317 -131.8651774612502 516.73889808643685 -1075.150660481142 -130.99997640351356 518.6917047210078 -1076.1096498903376 -129.82506437563936 520.33639426880666 -1077.3435004984756 -128.43004365199175 521.54753782910757 -1078.7515883173457 -126.92503224955055 522.25468038280019 -1080.2261511819472 -125.42002093264746 522.44396263447732
+6 0 8 -1068.5559082049322 -118.33457946783038 512.14751069020917 -1068.555907503174 -120.29587356654628 512.14751067142174 -1068.7737428062085 -122.29042793099693 512.16137391742097 -1069.2334936408683 -124.23160886740119 512.19104225740352 -1069.8760855983755 -126.07928033548967 512.23230874183344 -1070.7503018084203 -127.90308804714799 512.28835682236138 -1071.8166948267362 -129.578607889832 512.35682070427777 -1073.0526458713675 -131.1210998977821 512.43605472595755 -1074.4427811716037 -132.50555380886183 512.52534610351972
+6 0 7 -1068.5559082049322 -118.33457946783038 512.14751069020917 -1068.5559082243167 -118.33457946778672 514.20912428034035 -1069.051770975467 -118.3345794677421 516.2707380561219 -1070.0434749590777 -118.33457946769953 518.18925416019692 -1071.4795289123833 -118.33457946766214 519.82143015933002 -1073.2561674105511 -118.33457946763266 521.04932937324577 -1075.2378696603703 -118.3345794676128 521.80364192221498 -1077.282705121765 -118.33457946760322 522.06612721863473
+6 0 3 -1068.5559082031252 -118.33457946760316 512.14751068821624 -1068.555908203125 -78.889719645105856 512.14751068821624 -1068.5559082031248 -39.444859822608556 512.14751068821647 -1068.5559082031248 -1.1122835985588608e-10 512.14751068821647
+6 0 1 -1068.5559082031252 118.33457946762087 512.14751068821647 -1068.555908203125 118.33457946755453 500.94591204976018
+6 0 1 -1068.5559082031245 1.0723510968091432e-10 512.14751068821647 -1068.555908203125 1.0726988495083688e-10 500.94591204976018
+6 0 1 -1068.555908203125 118.33457946755453 500.94591204976018 -1068.5559082031252 1.0727774224505993e-10 500.94591204976018
+6 0 3 -1074.4427811723556 132.50555381190145 512.52534610311238 -1074.4427811723556 132.50555381190151 508.91742420886249 -1074.4427811723554 132.50555381190159 505.30950231461264 -1074.4427811723554 132.50555381190165 501.70158042036275
+6 0 7 -1074.4427811723551 132.50555381190165 501.7015804203628 -1073.0129207303246 131.0815374548327 501.51803640368939 -1071.7495573269475 129.48850686931209 501.35586477717447 -1070.6513624932086 127.72306169090105 501.21489501190842 -1069.728674614011 125.76989372344762 501.09645419453693 -1069.0174555896824 123.59194765727935 501.00515857391224 -1068.5559082031316 121.15511600452206 500.94591204976081 -1068.5559082031261 118.33457946785239 500.94591204976007
+6 0 1 -1088.5559082034554 138.33457946777335 513.43116055557402 -1088.5559082035736 138.33457946777335 503.5132117845078
+6 0 7 -1088.5559082030479 138.33457946777364 503.51321178444005 -1085.7684993136388 138.33457946776818 503.15540607932741 -1083.3500690227995 137.88369517477642 502.84496430712557 -1081.1820163276107 137.1835022916309 502.56666225166782 -1079.2335027054598 136.27208225304096 502.31654132640836 -1077.4683920913678 135.18409490465959 502.0899629258459 -1075.8723697189355 133.92929938480387 501.88508953518038 -1074.4427811723551 132.50555381190162 501.7015804203628
+6 0 1 -1326.7509765625668 138.33457946777332 544.00706734244159 -1326.7509765624486 138.33457946777332 534.08911857461442
+6 0 1 -1326.7509765624486 138.33457946777332 534.08911857461442 -1088.5559082035738 138.33457946777335 503.5132117845078
+6 0 3 -1340.8640514168683 132.50560594982628 544.91288191997626 -1340.8640514168685 132.50560594982636 541.90883569367907 -1340.8640514168687 132.50560594982639 538.90478946738176 -1340.864051416869 132.50560594982647 535.90074324108457
+6 0 7 -1340.8640514168692 132.50560594982645 535.90074324108514 -1339.4304294946423 133.93334700316601 535.71671638205623 -1337.830771032269 135.18985897390655 535.51137624475348 -1336.0629386918165 136.27789822101363 535.28444846982427 -1334.113130889069 137.18811203817128 535.03416141708726 -1331.9453731649037 137.88625396085007 534.75589722558277 -1329.530321137205 138.33457946776812 534.4458891040839 -1326.7509765625769 138.33457946777349 534.08911857463124
+6 0 3 -1346.7509765625002 118.33457946783582 545.29071721307719 -1346.7509765625 118.33457946784158 542.41261757848827 -1346.7509765625 118.33457946784735 539.53451794389935 -1346.7509765624998 118.3345794678531 536.65641830931042
+6 0 7 -1346.7509765625 118.33457946785312 536.65641830931042 -1346.7509765624945 121.16331861055616 536.65641830930974 -1346.2867903213594 123.60359076081527 536.59683304862494 -1345.5734660426788 125.78181360984416 536.50526718705271 -1344.6495743040693 127.73361245786693 536.38667183628411 -1343.5514699263731 129.4962706816691 536.24571368240709 -1342.2898803239434 131.08562594386581 536.08376974982696 -1340.8640514168687 132.50560594982645 535.90074324108468
+6 0 1 -1346.7509765625 1.1256326182685042e-10 545.29071721307753 -1346.7509765625 1.1259352028081014e-10 536.65641830931099
+6 0 1 -1346.7509765625 1.1259352028081014e-10 536.65641830931099 -1346.7509765625002 118.33457946753646 536.65641830931099
+6 0 1 -1346.7509765625 -1.1259352028081014e-10 536.65641830931099 -1346.7509765625002 -118.33457946753646 536.65641830931099
+6 0 3 -1346.7509765625002 -118.33457946783582 545.29071721307719 -1346.7509765625 -118.33457946784158 542.41261757848827 -1346.7509765625 -118.33457946784735 539.53451794389935 -1346.7509765624998 -118.3345794678531 536.65641830931042
+6 0 7 -1346.7509765625 -118.33457946785312 536.65641830931042 -1346.7509765624945 -121.16331861055616 536.65641830930974 -1346.2867903213594 -123.60359076081527 536.59683304862494 -1345.5734660426788 -125.78181360984416 536.50526718705271 -1344.6495743040693 -127.73361245786693 536.38667183628411 -1343.5514699263731 -129.4962706816691 536.24571368240709 -1342.2898803239434 -131.08562594386581 536.08376974982696 -1340.8640514168687 -132.50560594982645 535.90074324108468
+6 0 3 -1340.8640514168687 -132.5056059498263 544.91288191997683 -1340.864051416869 -132.50560594982636 541.90883569367952 -1340.864051416869 -132.50560594982642 538.90478946738233 -1340.8640514168692 -132.50560594982647 535.90074324108514
+6 0 7 -1340.8640514168692 -132.50560594982645 535.90074324108514 -1339.4304294946423 -133.93334700316601 535.71671638205623 -1337.830771032269 -135.18985897390655 535.51137624475348 -1336.0629386918165 -136.27789822101363 535.28444846982427 -1334.113130889069 -137.18811203817128 535.03416141708726 -1331.9453731649037 -137.88625396085007 534.75589722558277 -1329.530321137205 -138.33457946776812 534.4458891040839 -1326.7509765625769 -138.33457946777349 534.08911857463124
+6 0 1 -1326.7509765625668 -138.33457946777332 544.00706734244159 -1326.7509765624486 -138.33457946777332 534.08911857461442
+6 0 1 -1326.7509765624486 -138.33457946777332 534.08911857461442 -1088.5559082035738 -138.33457946777335 503.5132117845078
+6 0 1 -1088.5559082034554 -138.33457946777335 513.43116055557402 -1088.5559082035736 -138.33457946777335 503.5132117845078
+6 0 7 -1088.5559082030479 -138.33457946777364 503.51321178444005 -1085.7684993136388 -138.33457946776818 503.15540607932741 -1083.3500690227995 -137.88369517477642 502.84496430712557 -1081.1820163276107 -137.1835022916309 502.56666225166782 -1079.2335027054598 -136.27208225304096 502.31654132640836 -1077.4683920913678 -135.18409490465959 502.0899629258459 -1075.8723697189355 -133.92929938480387 501.88508953518038 -1074.4427811723551 -132.50555381190162 501.7015804203628
+6 0 3 -1074.4427811723556 -132.50555381190145 512.52534610311238 -1074.4427811723556 -132.50555381190151 508.91742420886249 -1074.4427811723554 -132.50555381190159 505.30950231461264 -1074.4427811723554 -132.50555381190165 501.70158042036275
+6 0 7 -1074.4427811723551 -132.50555381190165 501.7015804203628 -1073.0129207303246 -131.0815374548327 501.51803640368939 -1071.7495573269475 -129.48850686931209 501.35586477717447 -1070.6513624932086 -127.72306169090105 501.21489501190842 -1069.728674614011 -125.76989372344762 501.09645419453693 -1069.0174555896824 -123.59194765727935 501.00515857391224 -1068.5559082031316 -121.15511600452206 500.94591204976081 -1068.5559082031261 -118.33457946785239 500.94591204976007
+6 0 3 -1068.5559082031257 -118.33457946783031 512.14751068821624 -1068.5559082031259 -118.33457946783768 508.41364447539752 -1068.5559082031259 -118.33457946784503 504.67977826257885 -1068.5559082031261 -118.33457946785241 500.94591204976012
+6 0 1 -1068.555908203125 -118.33457946755453 500.94591204976018 -1068.5559082031252 -1.0727774224505993e-10 500.94591204976018
+6 0 3 -1389.210458712615 -6.1959326558280736e-12 579.59107000977065 -1389.210458712615 13.658652830286821 579.59107000977065 -1389.210458712615 27.31730564536069 579.59107000977053 -1389.210458712615 40.975958468020309 579.59107000977053
+6 0 5 -1389.1747236682122 43.352322344930421 579.42415929642812 -1389.1889881867207 42.880253007946685 579.49076968185886 -1389.1997278159388 42.405761495825423 579.54095331924168 -1389.206885068098 41.929629984246631 579.5743913842731 -1389.2104496726583 41.452665422390631 579.5910277860163 -1389.2104587151352 40.975692694059219 579.59107002154337
+6 0 6 -1389.1747289508553 43.352147514554325 579.42418397051483 -1388.9152370884374 51.938270634037508 578.21215324312857 -1388.5677037567366 60.463757762777469 576.58890146984811 -1388.1258342715637 68.897504795324181 574.52501876996484 -1387.582770680134 77.201616282773301 571.98849118993212 -1386.9254087759518 85.315853853178282 568.91809279227891 -1386.1425687883655 93.143701549738296 565.26161542927082
+6 0 1 -1386.1425687883655 93.143701549738239 565.26161542927082 -1386.1425687883655 -6.2101435105432756e-12 565.26161542927093
+6 0 1 -1386.1425687883655 -6.1959326558280736e-12 565.26161542927093 -1389.210458712615 -6.1944066685668808e-12 579.59107000977065
+6 0 6 -1392.1439794683847 40.975958468074538 581.96301269531205 -1391.4640376426369 40.97594554835316 581.96301269645096 -1390.7840958162221 40.975916253379552 581.77808434314886 -1390.1669210464058 40.975871769540895 581.40815690378508 -1389.6759840614618 40.975815859574539 580.88210378616463 -1389.3528061936049 40.975754272917705 580.25594450454685 -1389.2104587151352 40.975692694059241 579.59107002154326
+6 0 8 -1392.1439794658666 -3.464816475425419e-11 581.96301269531261 -1391.6340230967835 -2.75488996585242e-11 581.96301269531261 -1391.1240667277004 -2.044933054104358e-11 581.86394393402941 -1390.6365640234144 -1.3662042023614643e-11 581.66580641146288 -1390.1939679336238 -7.4996275118938036e-12 581.37470642374115 -1389.8166600780251 -2.2458635181140537e-12 581.00286064434738 -1389.5208533534612 1.8734917427657645e-12 580.56764145102318 -1389.3172193218345 4.7098126037731343e-12 580.08972587375661 -1389.2104587126155 6.1975913334363787e-12 579.59107000977053
+6 0 1 -1392.1439794658663 3.4648555734097252e-11 581.9630126953125 -1392.1439794658972 40.975958468018995 581.96301269531261
+6 0 4 -1392.1439794683836 40.97595846807458 581.96301269531239 -1392.143968165602 41.676555758012348 581.96295065800427 -1392.1380625616764 42.378426494002632 581.93038137575832 -1392.1260738087467 43.077905437414636 581.86453992370514 -1392.1082444214628 43.771474993259154 581.76667617855219
+6 0 6 -1392.1082444214626 43.771474993259133 581.76667617855219 -1391.4275573049079 43.751313265187243 581.76952102979863 -1390.7468701878472 43.705233957379747 581.58868555870413 -1390.1292125320515 43.635093979204562 581.22383545230525 -1389.6383243498344 43.546840694512241 580.70347370626473 -1389.3158294156196 43.449581519685204 580.0832339204851 -1389.1747236682122 43.352322344930421 579.42415929642812
+6 0 6 -1389.0760895416129 94.413350596820706 567.3516440768808 -1388.388924195699 94.356938046780343 567.37799502434473 -1387.7017588492229 94.219932752350317 567.23181167383018 -1387.0799085551323 94.007663150993366 566.91051749178382 -1386.5894602046253 93.738521835921432 566.4393386601887 -1386.2729098354982 93.441111692708219 565.87041045154854 -1386.1425687883652 93.143701549738296 565.26161542927093
+6 0 6 -1392.1082497041041 43.771474993333761 581.76667617854093 -1391.8487578373838 52.476305632840287 580.53788848831164 -1391.5012212682323 61.127300692039903 578.89104185591111 -1391.059357659768 69.694005008116193 576.79556986897455 -1390.5162917599273 78.142160228902611 574.21645354726559 -1389.8589295014883 86.414561322993535 571.08797005021154 -1389.0760895416131 94.413350596820692 567.3516440768808
+6 0 7 -1386.1425687883655 93.143701549739177 565.26161542927093 -1386.0899885295594 93.748341332767353 565.01602082032002 -1386.0328917187301 94.350951007632574 564.76762719544286 -1385.9720424854395 94.951550020970132 564.51637364099372 -1385.9044980352176 95.549696422708848 564.26245752308398 -1385.8346106524186 96.145857335166994 564.00561871002162 -1385.7573186050154 96.739294513652467 563.74620356484252 -1385.6756259165422 97.330286016201413 563.48400704881192
+6 0 5 -1385.6756259167871 97.330286016172664 563.4840070486797 -1385.5674970376776 98.110090171841975 563.13806040432257 -1385.4492669561339 98.885126182045795 562.78704793004454 -1385.3201435043541 99.654920519032558 562.43115448703611 -1385.1793235030289 100.41900329302241 562.0705561064517 -1385.0259911798944 101.1769081830119 561.70542026617159
+6 0 5 -1385.0259659970127 101.17703284141002 561.70536019834196 -1384.9029992156497 101.78493019967044 561.41252768239519 -1384.7720218764919 102.38866858921392 561.1168221063881 -1384.6325118035434 102.9881399119692 560.81833419342263 -1384.483992628871 103.58306881923779 560.51724066459042 -1384.3260275004516 104.17302296983024 560.2137980968256
+6 0 13 -1384.3260616652933 104.17290383016213 560.21386049580804 -1384.301652750449 104.26405721092591 560.16697075190905 -1384.2727563771682 104.3483962518378 560.11176941361055 -1384.2399038925817 104.42274056711554 560.04962046277717 -1384.2020678577194 104.48788979326665 559.97817491551439 -1384.1641292334023 104.54588357841331 559.90838823172021 -1384.1207243816875 104.5898445206854 559.82794032109371 -1384.0766959909556 104.62694495664705 559.74811723779783 -1384.0322348659686 104.65394420030317 559.66908970156658 -1383.9834087808979 104.66566976615266 559.58157292360443 -1383.9369342809543 104.67514542982236 559.50105808033936 -1383.88860402927 104.67060752692402 559.41726807134694 -1383.8406221357277 104.65704460002758 559.3353936818288 -1383.7931454208451 104.63404281447391 559.25524874769553
+6 0 9 -1383.7931454208433 104.63404281448292 559.25524874770372 -1383.7588566823172 104.61743041381027 559.19736629527767 -1383.7247041830196 104.59611417057906 559.14016742924809 -1383.6914933377609 104.56815061567467 559.08516434531441 -1383.6582520332786 104.5373182914156 559.03046903492771 -1383.6262649121024 104.50016807378373 558.97818240341167 -1383.5957919493517 104.45675432179493 558.92884865041628 -1383.5660263517123 104.41072402034389 558.88105747898283 -1383.5383790718379 104.35858332810223 558.83683794278011 -1383.5127094954148 104.30210318729469 558.79604898435298
+6 0 9 -1383.5127094954148 104.30210318729466 558.79604898435275 -1383.4870399189917 104.24562304648711 558.75526002592574 -1383.4633677674701 104.18461075856465 558.71780847940192 -1383.4426152026538 104.11812680709143 558.68564974283231 -1383.4235123752633 104.05075124010045 558.65493008521003 -1383.4095819696768 103.97433517611569 558.63442208106562 -1383.3962168331529 103.90125387124351 558.61280530916792 -1383.3889736909446 103.8218059751505 558.60199899635086 -1383.3850686987525 103.74288628636614 558.59587326990027 -1383.3850686068145 103.66375609359731 558.59587343391934
+6 0 3 -1383.3850686068131 103.66375609359739 558.59587343392081 -1383.3850686068131 69.109170729041182 558.59587343392081 -1383.3850686068133 34.554585356213181 558.59587343392081 -1383.3850686068133 -2.0818902157770935e-12 558.59587343392081
+6 0 6 -1383.3850686068126 2.0682905351086602e-12 558.59587343392081 -1384.0410519609195 2.0710576796648226e-12 559.611288433558 -1384.6233888332365 2.0736533917739474e-12 560.67428741037145 -1385.1277641676529 2.0761632686603789e-12 561.77819194126528 -1385.5506673884352 2.0787677235292175e-12 562.91579929102966 -1385.8894879180143 2.0817522997040679e-12 564.07952906815092 -1386.1425687883641 2.085442929455894e-12 565.26161542927059
+6 0 1 -1386.1425687883648 2.0747847884194925e-12 565.26161542927059 -1386.1425687883645 -93.143701549739149 565.26161542927059
+6 0 6 -1389.1747289508553 -43.352147514554325 579.42418397051483 -1388.9152370884374 -51.938270634037508 578.21215324312857 -1388.5677037567366 -60.463757762777469 576.58890146984811 -1388.1258342715637 -68.897504795324181 574.52501876996484 -1387.582770680134 -77.201616282773301 571.98849118993212 -1386.9254087759518 -85.315853853178282 568.91809279227891 -1386.1425687883655 -93.143701549738296 565.26161542927082
+6 0 5 -1389.1747236682122 -43.352322344930421 579.42415929642812 -1389.1889881867207 -42.880253007946685 579.49076968185886 -1389.1997278159388 -42.405761495825423 579.54095331924168 -1389.206885068098 -41.929629984246631 579.5743913842731 -1389.2104496726583 -41.452665422390631 579.5910277860163 -1389.2104587151352 -40.975692694059219 579.59107002154337
+6 0 3 -1389.2104587126155 6.1975913334363763e-12 579.59107000977053 -1389.2104587126266 -13.658652830287217 579.59107000977042 -1389.2104587126335 -27.317305645360968 579.59107000975018 -1389.2104587126491 -40.975958468021481 579.59107000977042
+6 0 1 -1399.9449032936627 3.4764364122306929e-11 581.96301269531261 -1399.9449032936627 40.975958467987716 581.96301269531261
+6 0 3 -1392.1439794683836 40.97595846807458 581.96301269531239 -1394.7442874101432 40.975958468075284 581.96301269531239 -1397.3445953519029 40.975958468076001 581.96301269531216 -1399.9449032936625 40.975958468076705 581.96301269531216
+6 0 1 -1392.1439794658663 3.4648555734097252e-11 581.9630126953125 -1399.9449032936627 3.4764364122306929e-11 581.96301269531261
+6 0 1 -1392.1439794658663 -3.4648555734097252e-11 581.9630126953125 -1392.1439794658972 -40.975958468018995 581.96301269531261
+6 0 8 -1392.1439794659004 -40.975958468021517 581.9630126953125 -1391.6340230968174 -40.97595846802151 581.9630126953125 -1391.1240667277343 -40.975958468021503 581.86394393402929 -1390.6365640234483 -40.975958468021496 581.66580641146288 -1390.1939679336576 -40.975958468021489 581.37470642374126 -1389.8166600780589 -40.975958468021481 581.00286064434749 -1389.5208533534951 -40.975958468021474 580.56764145102329 -1389.3172193218684 -40.975958468021474 580.08972587375672 -1389.2104587126494 -40.975958468021474 579.59107000977065
+6 0 4 -1399.9449032936625 40.975958468076705 581.96301269531205 -1399.9448899761451 41.678429901336621 581.96295049204991 -1399.9378797013335 42.378506466619967 581.93020700483589 -1399.9238724692277 43.076188163926759 581.86478223366998 -1399.902868279828 43.771474993257002 581.76667617855219
+6 0 3 -1392.1082444214628 43.771474993259154 581.76667617855219 -1394.7064523742513 43.771474993258444 581.76667617855219 -1397.3046603270398 43.771474993257726 581.76667617855219 -1399.9028682798282 43.771474993257016 581.76667617855219
+6 0 5 -1399.902868279826 43.77147499337768 581.76667617853548 -1399.5834139516171 54.341649027161552 580.27457365868031 -1399.1298606842613 64.716499057628013 578.15612381045116 -1398.5336010495903 74.877060971762759 575.37112318651498 -1397.7779224272629 84.801368808934853 571.84151072861641 -1396.8166564848207 94.413350596781385 567.3516440769065
+6 0 3 -1389.0760895416124 94.413350596820607 567.3516440768808 -1391.6562785226818 94.413350596807533 567.35164407688944 -1394.2364675037511 94.413350596794459 567.35164407689786 -1396.8166564848204 94.413350596781385 567.3516440769065
+6 0 6 -1388.5391038307139 98.693647293179481 565.26161544627587 -1387.8946139019481 98.612128725252262 565.30320457630273 -1387.2501239877324 98.453581662594175 565.19381091411458 -1386.6601768389328 98.224882122704685 564.92987002264135 -1386.1798374901741 97.943996043310065 564.52939151816224 -1385.8468399336252 97.637141029731424 564.03197416632952 -1385.6756259167871 97.330286016172678 563.4840070486797
+6 0 7 -1389.076089541612 94.413350596820564 567.35164407688148 -1389.0156214603878 95.031194101013881 567.06304230812111 -1388.9500639968549 95.64707899831518 566.77108850621835 -1388.8799090623895 96.261007763437064 566.47574993209366 -1388.8023088218447 96.87253577732038 566.17721026742993 -1388.7217912566105 97.482148416107492 565.87518880733808 -1388.633247697916 98.089119378472191 565.57003388443297 -1388.539103830577 98.693647295757401 565.2616154462595
+6 0 3 -1383.3850686068131 -103.66375609359739 558.59587343392081 -1383.3850686068131 -69.109170729041182 558.59587343392081 -1383.3850686068133 -34.554585356213181 558.59587343392081 -1383.3850686068133 2.0818902157770935e-12 558.59587343392081
+6 0 9 -1383.5127094954148 -104.30210318729466 558.79604898435275 -1383.4870399189917 -104.24562304648711 558.75526002592574 -1383.4633677674701 -104.18461075856465 558.71780847940192 -1383.4426152026538 -104.11812680709143 558.68564974283231 -1383.4235123752633 -104.05075124010045 558.65493008521003 -1383.4095819696768 -103.97433517611569 558.63442208106562 -1383.3962168331529 -103.90125387124351 558.61280530916792 -1383.3889736909446 -103.8218059751505 558.60199899635086 -1383.3850686987525 -103.74288628636614 558.59587326990027 -1383.3850686068145 -103.66375609359731 558.59587343391934
+6 0 9 -1383.7931454208433 -104.63404281448292 559.25524874770372 -1383.7588566823172 -104.61743041381027 559.19736629527767 -1383.7247041830196 -104.59611417057906 559.14016742924809 -1383.6914933377609 -104.56815061567467 559.08516434531441 -1383.6582520332786 -104.5373182914156 559.03046903492771 -1383.6262649121024 -104.50016807378373 558.97818240341167 -1383.5957919493517 -104.45675432179493 558.92884865041628 -1383.5660263517123 -104.41072402034389 558.88105747898283 -1383.5383790718379 -104.35858332810223 558.83683794278011 -1383.5127094954148 -104.30210318729469 558.79604898435298
+6 0 13 -1384.3260616652933 -104.17290383016213 560.21386049580804 -1384.301652750449 -104.26405721092591 560.16697075190905 -1384.2727563771682 -104.3483962518378 560.11176941361055 -1384.2399038925817 -104.42274056711554 560.04962046277717 -1384.2020678577194 -104.48788979326665 559.97817491551439 -1384.1641292334023 -104.54588357841331 559.90838823172021 -1384.1207243816875 -104.5898445206854 559.82794032109371 -1384.0766959909556 -104.62694495664705 559.74811723779783 -1384.0322348659686 -104.65394420030317 559.66908970156658 -1383.9834087808979 -104.66566976615266 559.58157292360443 -1383.9369342809543 -104.67514542982236 559.50105808033936 -1383.88860402927 -104.67060752692402 559.41726807134694 -1383.8406221357277 -104.65704460002758 559.3353936818288 -1383.7931454208451 -104.63404281447391 559.25524874769553
+6 0 5 -1385.0259659970127 -101.17703284141002 561.70536019834196 -1384.9029992156497 -101.78493019967044 561.41252768239519 -1384.7720218764919 -102.38866858921392 561.1168221063881 -1384.6325118035434 -102.9881399119692 560.81833419342263 -1384.483992628871 -103.58306881923779 560.51724066459042 -1384.3260275004516 -104.17302296983024 560.2137980968256
+6 0 5 -1385.6756259167871 -97.330286016172664 563.4840070486797 -1385.5674970376776 -98.110090171841975 563.13806040432257 -1385.4492669561339 -98.885126182045795 562.78704793004454 -1385.3201435043541 -99.654920519032558 562.43115448703611 -1385.1793235030289 -100.41900329302241 562.0705561064517 -1385.0259911798944 -101.1769081830119 561.70542026617159
+6 0 7 -1386.1425687883655 -93.143701549739177 565.26161542927093 -1386.0899885295594 -93.748341332767353 565.01602082032002 -1386.0328917187301 -94.350951007632574 564.76762719544286 -1385.9720424854395 -94.951550020970132 564.51637364099372 -1385.9044980352176 -95.549696422708848 564.26245752308398 -1385.8346106524186 -96.145857335166994 564.00561871002162 -1385.7573186050154 -96.739294513652467 563.74620356484252 -1385.6756259165422 -97.330286016201413 563.48400704881192
+6 0 8 -1385.9049667391048 -1.028155338644865e-10 553.96795654323034 -1385.1008272354297 -6.612261060521173e-11 553.96795654320067 -1384.2966877317456 -3.0030099989654612e-11 554.21429572083593 -1383.5805887009694 1.4447070747113214e-12 554.70697407613955 -1383.0405449262421 2.437760678649667e-11 555.40828048448418 -1382.7445201508986 3.585206294909968e-11 556.24245510013122 -1382.7192702976249 3.4886542328312356e-11 557.11130044227957 -1382.948711179894 2.2445034953900249e-11 557.92042355613 -1383.3850686067301 8.8772324338984992e-13 558.59587343392673
+6 0 8 -1385.9049667389818 103.66375609374523 553.96795654299058 -1385.1008272353067 103.66375609369466 553.96795654304447 -1384.2966877316483 103.66375609364465 554.2142957207634 -1383.5805887009233 103.66375609360075 554.70697407614148 -1383.0405449262689 103.66375609356841 555.40828048454227 -1382.744520151012 103.66375609355173 556.24245510022001 -1382.7192702978289 103.66375609355215 557.11130044237098 -1382.948711180182 103.66375609356845 557.92042355619753 -1383.3850686070884 103.66375609359746 558.59587343394878
+6 0 3 -1385.9049667389818 103.66375609374523 553.96795654299058 -1385.9049667389847 69.109170729197899 553.9679565430705 -1385.9049667391325 34.554585364719927 553.96795654315042 -1385.9049667391048 1.028297447192017e-10 553.96795654323034
+6 0 7 -1386.0517534322823 106.21878517446201 554.89027360929072 -1385.2592791538045 106.46390792012764 555.09384648477521 -1384.4668043778211 106.52776902190189 555.51567753046686 -1383.7791579874365 106.37797953783799 556.12879466263132 -1383.301823444338 106.01764763994372 556.86307163871186 -1383.1033961197031 105.49855483165298 557.61298916946225 -1383.1879934335516 104.90032882145972 558.28007601133561 -1383.5127094954148 104.30210318729468 558.79604898435298
+6 0 9 -1386.0517534322837 106.21878517446191 554.8902736092906 -1386.0222336509969 105.99138051778765 554.70141412199916 -1385.9950983965787 105.74299057189948 554.52722689828693 -1385.9709511744597 105.47652279879682 554.37217632223633 -1385.9492881861829 105.19955126346974 554.24474858660881 -1385.9332554975019 104.92182696027189 554.14479787159871 -1385.9176293953665 104.63232175762785 554.05327619851573 -1385.909518933187 104.29345160855742 553.99298610697986 -1385.9049665498437 103.96626208755515 553.96795561847409 -1385.9049667391591 103.6637560934972 553.96795654334221
+6 0 7 -1386.3742536064578 107.54476062711666 556.99979351846162 -1385.7446168513643 107.63239015368512 557.35091132157163 -1385.1149789911176 107.52102033731714 557.75169508355259 -1384.5455845782519 107.20228577196882 558.16854457653085 -1384.096838439604 106.69623438427546 558.56067336472313 -1383.814197368313 106.05412783705093 558.88835984236005 -1383.7154390644648 105.34408470323383 559.12407204223859 -1383.7931454208447 104.63404281447515 559.2552487476994
+6 0 7 -1386.3742537494102 107.54476081564833 556.99979335353123 -1386.3235550441252 107.45991989419612 556.65985207912661 -1386.2734057616171 107.34001621133172 556.33150725807116 -1386.2242024396005 107.1913231408768 556.00226571638734 -1386.1768305252419 106.97736976895607 555.6738935262656 -1386.1317906946317 106.76927325058588 555.403703193502 -1386.0897062118029 106.51116355023215 555.13309176796599 -1386.0517533922261 106.21878521334916 554.89027357708699
+6 0 6 -1386.9870667421328 105.70034328970409 561.41067532277305 -1386.4254125458735 105.57222742788926 561.48645596331573 -1385.8637583443406 105.37535937821974 561.44600315033335 -1385.3399931028448 105.11837131276275 561.28418704788214 -1384.8922446391302 104.81775293643508 561.00903754296894 -1384.549242847834 104.49538795161881 560.6425958847334 -1384.3260275004513 104.17302296983023 560.21379809682571
+6 0 12 -1386.9871037630069 105.70034328974337 561.41067541092661 -1386.9566941253613 106.08043897496212 561.18582463010171 -1386.9200797093449 106.47078312439166 560.89273459117589 -1386.8795948685699 106.79114844783807 560.56923168540084 -1386.8252751921118 107.06153417552618 560.16896995110028 -1386.7905300942796 107.16001137683523 559.99586055834834 -1386.7151843227907 107.60754389105131 559.37974092337288 -1386.6795252056345 107.49426061240337 559.01349879808993 -1386.6072471508453 107.69539677958986 558.6755924751734 -1386.5548887193158 107.70531958519052 558.23407446430485 -1386.4929092963566 107.69976041532242 557.80491875821087 -1386.4334022389073 107.64374189067641 557.39639150700339 -1386.3742537494081 107.54476081565024 556.99979335353169
+6 0 6 -1387.7919944204509 102.63078816844751 563.16809105028244 -1387.1916518999953 102.52392850425228 563.22728843615005 -1386.5913093806259 102.34431627798776 563.15515715844003 -1386.0359818330053 102.09994893019683 562.94723116477167 -1385.5710294752973 101.80808268947052 562.61561284917218 -1385.2292853497304 101.49255774830692 562.18954996912441 -1385.0259659970125 101.17703284141001 561.70536019834196
+6 0 5 -1387.7919944204509 102.63078816844751 563.16809105028244 -1387.6505548422472 103.2534078515243 562.82317642088663 -1387.4999246916211 103.87198687318033 562.47475515922918 -1387.339525973952 104.4862095382243 562.12305057667982 -1387.1687698549902 105.095769902531 561.76828099344675 -1386.9870667421326 105.70034328970411 561.41067532277305
+6 0 5 -1388.5391038307139 98.693647293179481 565.26161544627587 -1388.4147868382061 99.491366921444211 564.85463433794371 -1388.27883187364 100.28442014888326 564.44159525075827 -1388.1303216432532 101.07232956043087 564.02269017188576 -1387.9683502086118 101.85461385743945 563.5981192819163 -1387.792023564283 102.63078817300472 563.16809104772358
+6 0 5 -1392.1082497041052 -43.771474993333783 581.76667617854162 -1391.7968594641197 -54.217271760740807 580.2921309507426 -1391.3533664139902 -64.577516686241083 578.19033107703331 -1390.7660724708192 -74.810531666295446 575.40418526178382 -1390.0154974925551 -84.814803469095082 571.83523524513566 -1389.0760895416126 -94.413350596820607 567.35164407688092
+6 0 6 -1392.1082444214626 -43.771474993259133 581.76667617855219 -1391.4275573049079 -43.751313265187243 581.76952102979863 -1390.7468701878472 -43.705233957379747 581.58868555870413 -1390.1292125320515 -43.635093979204562 581.22383545230525 -1389.6383243498344 -43.546840694512241 580.70347370626473 -1389.3158294156196 -43.449581519685204 580.0832339204851 -1389.1747236682122 -43.352322344930421 579.42415929642812
+6 0 6 -1389.076089541612 -94.413350596820564 567.35164407688148 -1388.3889241956983 -94.356938046780343 567.37799502434518 -1387.7017588492224 -94.219932752350516 567.23181167383041 -1387.0799085551321 -94.007663150993778 566.91051749178416 -1386.5894602046258 -93.738521835922043 566.43933866018858 -1386.2729098354987 -93.441111692709001 565.87041045154842 -1386.1425687883657 -93.143701549739163 565.26161542927093
+6 0 4 -1392.1439794683836 -40.97595846807458 581.96301269531239 -1392.143968165602 -41.676555758012348 581.96295065800427 -1392.1380625616764 -42.378426494002632 581.93038137575832 -1392.1260738087467 -43.077905437414636 581.86453992370514 -1392.1082444214628 -43.771474993259154 581.76667617855219
+6 0 3 -1392.1439794683836 -40.97595846807458 581.96301269531239 -1394.7442874101432 -40.975958468075284 581.96301269531239 -1397.3445953519029 -40.975958468076001 581.96301269531216 -1399.9449032936625 -40.975958468076705 581.96301269531216
+6 0 1 -1399.9449032936627 -3.4764364122306929e-11 581.96301269531261 -1399.9449032936627 -40.975958467987716 581.96301269531261
+6 0 3 -1396.8166564848195 94.413350596781456 567.35164407690661 -1396.6731152702678 95.848661554092914 566.68119390915717 -1396.5240762753517 97.275621419279958 565.98506479073956 -1396.3691881046873 98.69364732905629 565.2616154293238
+6 0 2 -1388.5391040942998 98.693647326519326 565.26161542926661 -1392.4541460994876 98.693647326520832 565.26161542926582 -1396.3691881046755 98.693647326522338 565.26161542926502
+6 0 7 -1389.076089541612 -94.413350596820564 567.35164407688148 -1389.0156214603878 -95.031194101013881 567.06304230812111 -1388.9500639968549 -95.64707899831518 566.77108850621835 -1388.8799090623895 -96.261007763437064 566.47574993209366 -1388.8023088218447 -96.87253577732038 566.17721026742993 -1388.7217912566105 -97.482148416107492 565.87518880733808 -1388.633247697916 -98.089119378472191 565.57003388443297 -1388.539103830577 -98.693647295757401 565.2616154462595
+6 0 6 -1388.5391038305772 -98.693647295757387 565.2616154462595 -1387.894613900572 -98.612128726852674 565.3032045758905 -1387.2501239687242 -98.453581655153386 565.19381090262902 -1386.6601768556618 -98.224882115586965 564.92987000167204 -1386.1798375086555 -97.943996052785636 564.52939153003069 -1385.8468399342801 -97.637141030512879 564.03197416733281 -1385.6756259165425 -97.330286016201427 563.4840070488118
+6 0 3 -1388.5391040942998 -98.693647326519326 565.26161542926661 -1388.3318649768596 -100.02317446105354 564.58331642937173 -1388.0859088165371 -101.33716565057341 563.88480403087328 -1387.7920235643392 -102.63078817302959 563.16809104774427
+6 0 6 -1387.792023564283 -102.63078817300472 563.16809104772358 -1387.1916768129558 -102.52392250022477 563.22729843861191 -1386.5913300509965 -102.34429652372781 563.1551779944466 -1386.0359995124695 -102.09990830596092 562.9472628277282 -1385.5710466075816 -101.80801586017743 562.61565474446354 -1385.229305011655 -101.49246201880024 562.18960129793368 -1385.0259911798946 -101.17690818301192 561.7054202661717
+6 0 3 -1387.791994446198 -102.63078817303041 563.1680910477437 -1387.5562602050329 -103.66848736566446 562.59323348712553 -1387.2899097713384 -104.69272200577429 562.00668416586791 -1386.9870667421521 -105.70034328971414 561.41067532278032
+6 0 6 -1386.9870667421328 -105.70034328970409 561.41067532277305 -1386.4254125458735 -105.57222742788926 561.48645596331573 -1385.8637583443406 -105.37535937821974 561.44600315033335 -1385.3399931028448 -105.11837131276275 561.28418704788214 -1384.8922446391302 -104.81775293643508 561.00903754296894 -1384.549242847834 -104.49538795161881 560.6425958847334 -1384.3260275004513 -104.17302296983023 560.21379809682571
+6 0 13 -1386.987102130114 -105.70034215739022 561.41067434677007 -1386.9590322141969 -106.05120209177549 561.2031208297692 -1386.9261205294529 -106.40838828756874 560.94007302509124 -1386.8865618858449 -106.72763281468802 560.63237277122596 -1386.8476586781949 -106.95675824318432 560.31820763233759 -1386.7972145061124 -107.14571630669504 560.03205160694495 -1386.7525420750324 -107.39283616433136 559.67628703286243 -1386.7021691607799 -107.54183231808733 559.22625976075597 -1386.6456031043497 -107.59344753607584 558.85488398793041 -1386.5958443316777 -107.68389548903195 558.56174966934952 -1386.5384808278525 -107.70876475393088 558.12565706469229 -1386.4842310230906 -107.69060502828771 557.74399100696837 -1386.4288512924738 -107.63612732527977 557.36588213955702 -1386.3742536064576 -107.54476062711636 556.99979351846173
+6 0 7 -1386.3742536064569 -107.54476062711652 556.99979351846343 -1385.7446168513636 -107.63239015368519 557.35091132157345 -1385.1149789911167 -107.52102033731744 557.7516950835543 -1384.545584578251 -107.20228577196949 558.1685445765329 -1384.0968384396028 -106.69623438427692 558.56067336472427 -1383.8141973683116 -106.05412783705371 558.88835984236164 -1383.7154390644635 -105.34408470323871 559.12407204224087 -1383.7931454208435 -104.63404281448291 559.25524874770372
+6 0 9 -1386.3742536064569 -107.54476062711652 556.99979351846343 -1386.334821944334 -107.47877356733203 556.73539618100631 -1386.2953225679573 -107.39242228543978 556.47627444578097 -1386.2578978991821 -107.28833449852432 556.22495198931017 -1386.2187894774231 -107.15610420123592 555.96407516365036 -1386.1820198772816 -107.00199602780376 555.71816334068637 -1386.1478565738955 -106.8352114737672 555.49693416846765 -1386.1128242315974 -106.65320055209942 555.28278958167107 -1386.0812732135694 -106.44618983113624 555.07913309658215 -1386.0517534322826 -106.218785174462 554.8902736092906
+6 0 7 -1386.0517534322823 -106.21878517446201 554.89027360929072 -1385.2592791538045 -106.46390792012764 555.09384648477521 -1384.4668043778211 -106.52776902190189 555.51567753046686 -1383.7791579874365 -106.37797953783799 556.12879466263132 -1383.301823444338 -106.01764763994372 556.86307163871186 -1383.1033961197031 -105.49855483165298 557.61298916946225 -1383.1879934335516 -104.90032882145972 558.28007601133561 -1383.5127094954148 -104.30210318729468 558.79604898435298
+6 0 8 -1386.0517533922255 -106.21878521334898 554.89027357708699 -1386.0185446750957 -105.96295416857627 554.67780766006786 -1385.9892236093233 -105.68030430206106 554.48487688436262 -1385.9594186645304 -105.37483980841627 554.31357639564192 -1385.9437159310503 -105.05708573937709 554.193210943292 -1385.9199436417937 -104.75757370475009 554.08097354392919 -1385.9112111209245 -104.37682525196054 553.9999171704585 -1385.9049677797402 -104.00407474236174 553.96795654332914 -1385.9049667391596 -103.66375609349684 553.96795654334039
+6 0 7 -1385.9049667391594 -103.66375609349721 553.96795654334221 -1384.9859501634355 -103.66375609347743 553.96795654357834 -1384.0669335749617 -103.66375609346859 554.29640880429395 -1383.2885983230224 -103.66375609347372 554.95321584399665 -1382.7929095184816 -103.66375609349342 555.86357271976112 -1382.6635689419825 -103.66375609352431 556.87375699358711 -1382.8863744048999 -103.66375609356081 557.82393071620493 -1383.3850686068142 -103.66375609359731 558.59587343391945
+6 0 1 -1385.9049667391596 -103.66375609374263 553.96795654299069 -1385.9049667391603 -1.539177674203529e-10 553.96795654323023
+6 0 1 -1392.2829948716233 103.66375609369189 553.96795654299069 -1392.2829948718856 1.539319782750681e-10 553.96795654342566
+6 0 1 -1385.9049667391603 1.539177674203529e-10 553.96795654323023 -1392.2829948718859 1.5393258267237111e-10 553.96795654342566
+6 0 3 -1385.9049667391598 103.66375609349683 553.96795654334028 -1388.0309761168749 103.66375609346096 553.96795654334699 -1390.1569854945903 103.66375609342508 553.96795654335358 -1392.2829948723054 103.66375609338921 553.96795654336029
+6 0 8 -1392.8165344524716 106.21878515330815 554.8902735221792 -1392.7277720699258 106.0262050995366 554.73033715048359 -1392.640007599668 105.81027233999259 554.57481308269098 -1392.5534885534237 105.56784617631449 554.42401550906629 -1392.4711942413423 105.29261820507399 554.28287795849735 -1392.3955046629778 104.9779389209063 554.15505836253328 -1392.3295148802301 104.6153163131942 554.045001174454 -1392.2829948722499 104.1885864563063 553.96795654337109 -1392.2829948723056 103.66375609338922 553.96795654336017
+6 0 3 -1386.0517533922261 106.21878521334915 554.89027357708699 -1388.3066804123077 106.21878519333555 554.89027355878443 -1390.5616074323896 106.21878517332193 554.89027354048176 -1392.8165344524712 106.21878515330833 554.8902735221792
+6 0 7 -1393.8809193304976 107.5447607612969 556.99979319466706 -1393.7329087307046 107.46376930883379 556.67527654384821 -1393.5849684336511 107.35216236916932 556.36280535762762 -1393.4358776271695 107.21100886462634 556.05849579378344 -1393.2848635675289 107.03622264863661 555.75989216764196 -1393.1303938836988 106.82157729183176 555.46408044389432 -1392.9722003964757 106.55652006991423 555.17075998014298 -1392.8165344524709 106.21878515330835 554.89027352217897
+6 0 3 -1386.3742537494084 107.54476081564984 556.99979335353225 -1388.8764756097712 107.54476079753202 556.99979330057715 -1391.3786974701338 107.54476077941479 556.99979324762239 -1393.8809193304967 107.5447607612974 556.99979319466797
+6 0 12 -1395.4888905233965 105.70034328976098 561.41067541097232 -1395.3766586497331 106.38254402424118 561.0071102725243 -1395.2434776950859 106.82068853540085 560.55219416683713 -1395.1042539485825 107.13366313774671 560.10922402398933 -1394.963498269459 107.35745227471783 559.68867308542531 -1394.8226382696814 107.50960195709943 559.28899221385984 -1394.6827278712055 107.60753177706707 558.90980623183623 -1394.5447691253812 107.66651996636146 558.55194811830825 -1394.4092454064835 107.69466687664108 558.21432358909692 -1394.2758493158419 107.69362316960525 557.89314828355305 -1394.1437728575163 107.66534991402699 557.58464947623906 -1394.0123116709474 107.61665869638097 557.28787392892445 -1393.8809193304969 107.54476076129804 556.99979319466888
+6 0 3 -1386.9871037630069 105.70034328974337 561.41067541092661 -1389.8210326831368 105.70034328974924 561.41067541094174 -1392.6549616032667 105.70034328975511 561.41067541095708 -1395.4888905233965 105.70034328976098 561.4106754109722
+6 0 3 -1395.9209712992028 102.63078817303284 563.168091047742 -1395.7980424406455 103.6676820146006 562.59391676547693 -1395.6548745557454 104.69086705349353 562.00752340090867 -1395.4888904988975 105.7003432897117 561.41067532286854
+6 0 2 -1387.7920235643394 102.63078817302959 563.16809104774427 -1391.8564974317715 102.63078817302834 563.16809104774529 -1395.9209712992035 102.63078817302709 563.16809104774632
+6 0 3 -1396.3691881046755 98.693647326522353 565.26161542926513 -1396.2239794606778 100.02305562566353 564.58337705688677 -1396.0744809780608 101.33662824962084 563.88510177015519 -1395.9209712992033 102.63078817302709 563.16809104774654
+6 0 3 -1392.1082497041052 -43.771474993333783 581.76667617854162 -1394.7064558960121 -43.77147499334842 581.76667617853968 -1397.304662087919 -43.77147499336305 581.76667617853752 -1399.902868279826 -43.771474993377687 581.76667617853559
+6 0 1 -1389.0760895416115 -94.413350596820649 567.35164407688114 -1396.8166564848195 -94.413350596781456 567.35164407690661
+6 0 5 -1399.902868279826 -43.77147499337768 581.76667617853548 -1399.5834139516171 -54.341649027161552 580.27457365868031 -1399.1298606842613 -64.716499057628013 578.15612381045116 -1398.5336010495903 -74.877060971762759 575.37112318651498 -1397.7779224272629 -84.801368808934853 571.84151072861641 -1396.8166564848207 -94.413350596781385 567.3516440769065
+6 0 4 -1399.9449032936625 -40.975958468076705 581.96301269531205 -1399.9448899761451 -41.678429901336621 581.96295049204991 -1399.9378797013335 -42.378506466619967 581.93020700483589 -1399.9238724692277 -43.076188163926759 581.86478223366998 -1399.902868279828 -43.771474993257002 581.76667617855219
+6 0 2 -1388.5391040942998 -98.693647326519326 565.26161542926661 -1392.4541460994876 -98.693647326520832 565.26161542926582 -1396.3691881046755 -98.693647326522338 565.26161542926502
+6 0 3 -1396.8166564848195 -94.413350596781456 567.35164407690661 -1396.6731152702678 -95.848661554092914 566.68119390915717 -1396.5240762753517 -97.275621419279958 565.98506479073956 -1396.3691881046873 -98.69364732905629 565.2616154293238
+6 0 2 -1387.791994446198 -102.63078817303041 563.1680910477437 -1391.8564828727003 -102.63078817303162 563.16809104774291 -1395.9209712992026 -102.63078817303283 563.16809104774211
+6 0 3 -1396.3691881046755 -98.693647326522353 565.26161542926513 -1396.2239794606778 -100.02305562566353 564.58337705688677 -1396.0744809780608 -101.33662824962084 563.88510177015519 -1395.9209712992033 -102.63078817302709 563.16809104774654
+6 0 3 -1386.9871037630069 -105.70034328974337 561.41067541092661 -1389.8210326831368 -105.70034328974924 561.41067541094174 -1392.6549616032667 -105.70034328975511 561.41067541095708 -1395.4888905233965 -105.70034328976098 561.4106754109722
+6 0 3 -1395.9209712992028 -102.63078817303284 563.168091047742 -1395.7980424406455 -103.6676820146006 562.59391676547693 -1395.6548745557454 -104.69086705349353 562.00752340090867 -1395.4888904988975 -105.7003432897117 561.41067532286854
+6 0 3 -1386.3742537494084 -107.54476081564984 556.99979335353225 -1388.8764756097712 -107.54476079753202 556.99979330057715 -1391.3786974701338 -107.54476077941479 556.99979324762239 -1393.8809193304967 -107.5447607612974 556.99979319466797
+6 0 12 -1395.4888905233965 -105.70034328976098 561.41067541097232 -1395.3766586497331 -106.38254402424118 561.0071102725243 -1395.2434776950859 -106.82068853540085 560.55219416683713 -1395.1042539485825 -107.13366313774671 560.10922402398933 -1394.963498269459 -107.35745227471783 559.68867308542531 -1394.8226382696814 -107.50960195709943 559.28899221385984 -1394.6827278712055 -107.60753177706707 558.90980623183623 -1394.5447691253812 -107.66651996636146 558.55194811830825 -1394.4092454064835 -107.69466687664108 558.21432358909692 -1394.2758493158419 -107.69362316960525 557.89314828355305 -1394.1437728575163 -107.66534991402699 557.58464947623906 -1394.0123116709474 -107.61665869638097 557.28787392892445 -1393.8809193304969 -107.54476076129804 556.99979319466888
+6 0 3 -1386.0517533922261 -106.21878521334915 554.89027357708699 -1388.3066804123077 -106.21878519333555 554.89027355878443 -1390.5616074323896 -106.21878517332193 554.89027354048176 -1392.8165344524712 -106.21878515330833 554.8902735221792
+6 0 7 -1393.8809193304976 -107.5447607612969 556.99979319466706 -1393.7329087307046 -107.46376930883379 556.67527654384821 -1393.5849684336511 -107.35216236916932 556.36280535762762 -1393.4358776271695 -107.21100886462634 556.05849579378344 -1393.2848635675289 -107.03622264863661 555.75989216764196 -1393.1303938836988 -106.82157729183176 555.46408044389432 -1392.9722003964757 -106.55652006991423 555.17075998014298 -1392.8165344524709 -106.21878515330835 554.89027352217897
+6 0 1 -1385.9049667391596 -103.66375609374263 553.96795654299069 -1392.2829948716233 -103.66375609369189 553.96795654299069
+6 0 8 -1392.8165344524716 -106.21878515330815 554.8902735221792 -1392.7277720699258 -106.0262050995366 554.73033715048359 -1392.640007599668 -105.81027233999259 554.57481308269098 -1392.5534885534237 -105.56784617631449 554.42401550906629 -1392.4711942413423 -105.29261820507399 554.28287795849735 -1392.3955046629778 -104.9779389209063 554.15505836253328 -1392.3295148802301 -104.6153163131942 554.045001174454 -1392.2829948722499 -104.1885864563063 553.96795654337109 -1392.2829948723056 -103.66375609338922 553.96795654336017
+6 0 1 -1392.2829948716233 -103.66375609369189 553.96795654299069 -1392.2829948718856 -1.539319782750681e-10 553.96795654342566
+6 0 1 -1449.2775311021724 139.16561062894533 4.1999831528857214 -1449.2775311021724 0 4.1999831528857214
+6 0 14 -1449.2775311021724 139.16561062894533 4.1999831528857214 -1451.1849266418519 139.16561062894533 0.89627716803053437 -1453.8906989855038 139.16561062894533 -1.9464857541364169 -1457.2741735215061 139.16561062894533 -4.1192910551021065 -1461.1549812199171 139.16561062894533 -5.4475887648395656 -1465.3038860022746 139.16561062894533 -5.8100470564132607 -1469.4601583368824 139.16561062894533 -5.1535263355377712 -1473.3540056939055 139.16561062894533 -3.5016942080652074 -1476.7314389094422 139.16561062894533 -0.95541540841121808 -1479.3781201046961 139.16561062894533 2.315773815494913 -1481.1386577981718 139.16561062894533 6.090061610570273 -1481.9287124770105 139.16561062894533 10.115078506161325 -1481.7387440472062 139.16561062894533 14.131638086310055 -1480.6297312944475 139.16561062894533 17.89626682427642 -1478.7223460448099 139.16561062894533 21.19995498625611
+6 0 1 -1478.7223460448099 139.16561062894533 21.19995498625611 -1478.7223460448099 0 21.19995498625611
+6 0 14 -1449.2775311021724 0 4.1999831528857214 -1451.1849266418519 0 0.89627716803053437 -1453.8906989855038 0 -1.9464857541364169 -1457.2741735215061 0 -4.1192910551021065 -1461.1549812199171 0 -5.4475887648395656 -1465.3038860022746 0 -5.8100470564132607 -1469.4601583368824 0 -5.1535263355377712 -1473.3540056939055 0 -3.5016942080652074 -1476.7314389094422 0 -0.95541540841121808 -1479.3781201046961 0 2.315773815494913 -1481.1386577981718 0 6.090061610570273 -1481.9287124770105 0 10.115078506161325 -1481.7387440472062 0 14.131638086310055 -1480.6297312944475 0 17.89626682427642 -1478.7223460448099 0 21.19995498625611
+6 0 14 -1478.7223460448097 139.16561062894533 21.199954986256117 -1476.8149607951721 139.16561062894533 24.50364314823581 -1474.1092030486554 139.16561062894533 27.346390734228823 -1470.7257446313351 139.16561062894533 29.519188010430845 -1466.8449504096723 139.16561062894533 30.84748903597329 -1462.6960524512056 139.16561062894533 31.209962566641064 -1458.5397788850901 139.16561062894533 30.553464027785651 -1454.6459201517036 139.16561062894533 28.901660463372561 -1451.2684678880137 139.16561062894533 26.355405797468052 -1448.6217680983207 139.16561062894533 23.084228731088892 -1446.8612137954572 139.16561062894533 19.309942645897763 -1446.071149506673 139.16561062894533 15.284915737003008 -1446.2611168267856 139.16561062894533 11.268338185284389 -1447.3701355624928 139.16561062894533 7.5036891377410004 -1449.2775311021724 139.16561062894533 4.1999831528858973
+6 0 14 -1478.7223460448097 0 21.199954986256117 -1476.8149607951721 0 24.50364314823581 -1474.1092030486554 0 27.346390734228823 -1470.7257446313351 0 29.519188010430845 -1466.8449504096723 0 30.84748903597329 -1462.6960524512056 0 31.209962566641064 -1458.5397788850901 0 30.553464027785651 -1454.6459201517036 0 28.901660463372561 -1451.2684678880137 0 26.355405797468052 -1448.6217680983207 0 23.084228731088892 -1446.8612137954572 0 19.309942645897763 -1446.071149506673 0 15.284915737003008 -1446.2611168267856 0 11.268338185284389 -1447.3701355624928 0 7.5036891377410004 -1449.2775311021724 0 4.1999831528858973
+6 0 1 -1478.7223460448099 -139.16561062894533 21.19995498625611 -1478.7223460448099 0 21.19995498625611
+6 0 14 -1449.2775311021724 -139.16561062894533 4.1999831528857214 -1451.1849266418519 -139.16561062894533 0.89627716803053437 -1453.8906989855038 -139.16561062894533 -1.9464857541364169 -1457.2741735215061 -139.16561062894533 -4.1192910551021065 -1461.1549812199171 -139.16561062894533 -5.4475887648395656 -1465.3038860022746 -139.16561062894533 -5.8100470564132607 -1469.4601583368824 -139.16561062894533 -5.1535263355377712 -1473.3540056939055 -139.16561062894533 -3.5016942080652074 -1476.7314389094422 -139.16561062894533 -0.95541540841121808 -1479.3781201046961 -139.16561062894533 2.315773815494913 -1481.1386577981718 -139.16561062894533 6.090061610570273 -1481.9287124770105 -139.16561062894533 10.115078506161325 -1481.7387440472062 -139.16561062894533 14.131638086310055 -1480.6297312944475 -139.16561062894533 17.89626682427642 -1478.7223460448099 -139.16561062894533 21.19995498625611
+6 0 1 -1449.2775311021724 -139.16561062894533 4.1999831528857214 -1449.2775311021724 0 4.1999831528857214
+6 0 14 -1478.7223460448097 -139.16561062894533 21.199954986256117 -1476.8149607951721 -139.16561062894533 24.50364314823581 -1474.1092030486554 -139.16561062894533 27.346390734228823 -1470.7257446313351 -139.16561062894533 29.519188010430845 -1466.8449504096723 -139.16561062894533 30.84748903597329 -1462.6960524512056 -139.16561062894533 31.209962566641064 -1458.5397788850901 -139.16561062894533 30.553464027785651 -1454.6459201517036 -139.16561062894533 28.901660463372561 -1451.2684678880137 -139.16561062894533 26.355405797468052 -1448.6217680983207 -139.16561062894533 23.084228731088892 -1446.8612137954572 -139.16561062894533 19.309942645897763 -1446.071149506673 -139.16561062894533 15.284915737003008 -1446.2611168267856 -139.16561062894533 11.268338185284389 -1447.3701355624928 -139.16561062894533 7.5036891377410004 -1449.2775311021724 -139.16561062894533 4.1999831528858973
+6 0 1 14.706079115662444 131.02765425327448 -8.458196391553285 14.706079115662444 -8.1379563756708535 -8.458196391553285
+6 0 14 14.706079115662444 131.02765425327448 -8.458196391553285 12.79868357598294 131.02765425327448 -11.761902376408472 10.092911232331 131.02765425327448 -14.604665298575423 6.709436696328666 131.02765425327448 -16.777470599541111 2.8286289979177885 131.02765425327448 -18.10576830927857 -1.3202757844396604 131.02765425327448 -18.468226600852265 -5.4765481190475924 131.02765425327448 -17.811705879976778 -9.3703954760706019 131.02765425327448 -16.159873752504215 -12.747828691607271 131.02765425327448 -13.613594952850224 -15.394509886861256 131.02765425327448 -10.342405728944094 -17.15504758033687 131.02765425327448 -6.5681179338687343 -17.945102259175624 131.02765425327448 -2.5431010382776833 -17.755133829371253 131.02765425327448 1.4734585418710475 -16.646121076612715 131.02765425327448 5.2380872798374138 -14.73873582697518 131.02765425327448 8.5417754418171015
+6 0 1 -14.738735826975105 131.02765425327448 8.5417754418171032 -14.738735826975105 -8.1379563756708535 8.5417754418171032
+6 0 14 14.706079115662444 -8.1379563756708393 -8.458196391553285 12.79868357598294 -8.1379563756708393 -11.761902376408472 10.092911232331 -8.1379563756708393 -14.604665298575423 6.709436696328666 -8.1379563756708393 -16.777470599541111 2.8286289979177885 -8.1379563756708393 -18.10576830927857 -1.3202757844396604 -8.1379563756708393 -18.468226600852265 -5.4765481190475924 -8.1379563756708393 -17.811705879976778 -9.3703954760706019 -8.1379563756708393 -16.159873752504215 -12.747828691607271 -8.1379563756708393 -13.613594952850224 -15.394509886861256 -8.1379563756708393 -10.342405728944094 -17.15504758033687 -8.1379563756708393 -6.5681179338687343 -17.945102259175624 -8.1379563756708393 -2.5431010382776833 -17.755133829371253 -8.1379563756708393 1.4734585418710475 -16.646121076612715 -8.1379563756708393 5.2380872798374138 -14.73873582697518 -8.1379563756708393 8.5417754418171015
+6 0 14 -14.738735826974878 131.02765425327448 8.5417754418171103 -12.831350577337346 131.02765425327448 11.845463603796802 -10.125592830820818 131.02765425327448 14.688211189789815 -6.7421344135004659 131.02765425327448 16.861008465991837 -2.8613401918376802 131.02765425327448 18.189309491534281 1.2875577666289315 131.02765425327448 18.551783022202056 5.4438313327445291 131.02765425327448 17.895284483346643 9.3376900661309641 131.02765425327448 16.243480918933553 12.715142329821004 131.02765425327448 13.697226253029044 15.361842119514019 131.02765425327448 10.426049186649886 17.122396422377616 131.02765425327448 6.6517631014587568 17.912460711161721 131.02765425327448 2.6267361925640014 17.722493391049095 131.02765425327448 -1.3898413591546177 16.613474655341982 131.02765425327448 -5.154490406698006 14.706079115662423 131.02765425327448 -8.4581963915531091
+6 0 14 -14.738735826974878 -8.1379563756708393 8.5417754418171103 -12.831350577337346 -8.1379563756708393 11.845463603796802 -10.125592830820818 -8.1379563756708393 14.688211189789815 -6.7421344135004659 -8.1379563756708393 16.861008465991837 -2.8613401918376802 -8.1379563756708393 18.189309491534281 1.2875577666289315 -8.1379563756708393 18.551783022202056 5.4438313327445291 -8.1379563756708393 17.895284483346643 9.3376900661309641 -8.1379563756708393 16.243480918933553 12.715142329821004 -8.1379563756708393 13.697226253029044 15.361842119514019 -8.1379563756708393 10.426049186649886 17.122396422377616 -8.1379563756708393 6.6517631014587568 17.912460711161721 -8.1379563756708393 2.6267361925640014 17.722493391049095 -8.1379563756708393 -1.3898413591546177 16.613474655341982 -8.1379563756708393 -5.154490406698006 14.706079115662423 -8.1379563756708393 -8.4581963915531091
+6 0 1 -14.738735826975105 -147.30356700461618 8.5417754418171032 -14.738735826975105 -8.1379563756708535 8.5417754418171032
+6 0 14 14.706079115662444 -147.30356700461618 -8.458196391553285 12.79868357598294 -147.30356700461618 -11.761902376408472 10.092911232331 -147.30356700461618 -14.604665298575423 6.709436696328666 -147.30356700461618 -16.777470599541111 2.8286289979177885 -147.30356700461618 -18.10576830927857 -1.3202757844396604 -147.30356700461618 -18.468226600852265 -5.4765481190475924 -147.30356700461618 -17.811705879976778 -9.3703954760706019 -147.30356700461618 -16.159873752504215 -12.747828691607271 -147.30356700461618 -13.613594952850224 -15.394509886861256 -147.30356700461618 -10.342405728944094 -17.15504758033687 -147.30356700461618 -6.5681179338687343 -17.945102259175624 -147.30356700461618 -2.5431010382776833 -17.755133829371253 -147.30356700461618 1.4734585418710475 -16.646121076612715 -147.30356700461618 5.2380872798374138 -14.73873582697518 -147.30356700461618 8.5417754418171015
+6 0 1 14.706079115662444 -147.30356700461618 -8.458196391553285 14.706079115662444 -8.1379563756708535 -8.458196391553285
+6 0 14 -14.738735826974878 -147.30356700461618 8.5417754418171103 -12.831350577337346 -147.30356700461618 11.845463603796802 -10.125592830820818 -147.30356700461618 14.688211189789815 -6.7421344135004659 -147.30356700461618 16.861008465991837 -2.8613401918376802 -147.30356700461618 18.189309491534281 1.2875577666289315 -147.30356700461618 18.551783022202056 5.4438313327445291 -147.30356700461618 17.895284483346643 9.3376900661309641 -147.30356700461618 16.243480918933553 12.715142329821004 -147.30356700461618 13.697226253029044 15.361842119514019 -147.30356700461618 10.426049186649886 17.122396422377616 -147.30356700461618 6.6517631014587568 17.912460711161721 -147.30356700461618 2.6267361925640014 17.722493391049095 -147.30356700461618 -1.3898413591546177 16.613474655341982 -147.30356700461618 -5.154490406698006 14.706079115662423 -147.30356700461618 -8.4581963915531091
+Polygon3D 0
+PolygonOnTriangulations 0
+Surfaces 713
+8 0 0 1 8 -1255.4487902081337 100.94413300620994 -107.70704981638073 -1286.9712777261996 100.94413300620994 -162.30561916931777 -1334.8296189943321 100.94413300620994 -207.47268231181363 -1395.7315972766414 100.94413300620994 -237.50595056260985 -1463.9999228622414 100.94413300620994 -248.08217576251849 -1532.2682517007584 100.94413300620994 -237.50597155983743 -1593.1702392203699 100.94413300620994 -207.47272204060894 -1641.0285943804929 100.94413300620994 -162.30567361786188 -1672.5510986913898 100.94413300620994 -107.70711396027038
+-1277.0249585801328 80.646240234375028 -95.250043198726644 -1305.2862093918868 80.646240234375028 -144.19998488082297 -1348.1932485067002 80.646240234375028 -184.69418009325588 -1402.7944635923825 80.646240234375028 -211.62028428725628 -1463.9999228622416 80.646240234375028 -221.10232139713321 -1525.2053853850175 80.646240234375028 -211.62030528448375 -1579.8066097080023 80.646240234375028 -184.694219822051 -1622.7136627148059 80.646240234375028 -144.2000393293668 -1650.974930319391 80.646240234375028 -95.250107342615962
+8 0 0 6 8 -1255.4487902081305 100.94413300620994 -107.70704981638278 -1286.9712777261971 100.94413300620994 -162.30561916932061 -1334.8296189943305 100.94413300620994 -207.47268231181715 -1395.731597276641 100.94413300620994 -237.5059505626138 -1463.9999228622421 100.94413300620994 -248.08217576252255 -1532.2682517007599 100.94413300620994 -237.50597155984127 -1593.1702392203724 100.94413300620994 -207.47272204061227 -1641.0285943804961 100.94413300620994 -162.30567361786447 -1672.5510986913935 100.94413300620994 -107.7071139602721
+-1254.2783646185317 102.04521697559167 -108.38279534560409 -1285.9777619024565 102.04521697559167 -163.28778140136336 -1334.1046925995452 102.04521697559167 -208.70832996851294 -1395.3484634722818 102.04521697559167 -238.91015012623089 -1463.9999228622421 102.04521697559167 -249.54573089466911 -1532.6513855051192 102.04521697559167 -238.91017112345835 -1593.8951656151578 102.04521697559167 -208.70836969730806 -1642.0221102042367 102.04521697559167 -163.28783584990722 -1673.7215242809923 102.04521697559167 -108.38285948949343
+-1253.0082968419144 102.86508422575187 -109.11606931832307 -1284.8996648029861 102.86508422575187 -164.35355834046413 -1333.3180508321248 102.86508422575187 -210.049172381707 -1394.9327122247239 102.86508422575187 -240.43389382556435 -1463.9999228622421 102.86508422575187 -251.13388329765874 -1533.067136752677 102.86508422575187 -240.43391482279182 -1594.6818073825782 102.86508422575187 -210.04921211050211 -1643.1002073037068 102.86508422575187 -164.353612789008 -1674.9915920576095 102.86508422575187 -109.1161334622124
+-1251.6703912972944 103.37381023676267 -109.88850944465973 -1283.7639836105525 103.37381023676267 -165.4762613193154 -1332.4893923922857 103.37381023676267 -211.4616328283866 -1394.4947545743282 103.37381023676267 -242.0390248126271 -1463.9999228622421 103.37381023676267 -252.80686323210043 -1533.5050944030727 103.37381023676267 -242.0390458098546 -1595.5104658224172 103.37381023676267 -211.46167255718171 -1644.2358884961404 103.37381023676267 -165.47631576785926 -1676.3294976022296 103.37381023676267 -109.88857358854906
+-1250.3010079196172 103.55419576962458 -110.67912330638545 -1282.6015824578606 103.55419576962458 -166.62537891097932 -1331.6412375297466 103.55419576962458 -212.90732521308993 -1394.0464927900864 103.55419576962458 -243.68192083134613 -1463.9999228622421 103.55419576962458 -254.51920452751122 -1533.9533561873143 103.55419576962458 -243.68194182857363 -1596.3586206849563 103.55419576962458 -212.90736494188505 -1645.3982896488324 103.55419576962458 -166.62543335952321 -1677.6988809799068 103.55419576962458 -110.6791874502748
+-1248.9379935726811 103.40455151353103 -111.46606000649838 -1281.4445876572506 103.40455151353103 -167.76915193268161 -1330.797027453219 103.40455151353103 -214.34629365226399 -1393.6003158807821 103.40455151353103 -245.31717570630801 -1463.9999228622421 103.40455151353103 -256.22358168772996 -1534.3995330966186 103.40455151353103 -245.3171967035355 -1597.2028307614839 103.40455151353103 -214.34633338105911 -1646.5552844494423 103.40455151353103 -167.7692063812255 -1679.0618953268429 103.40455151353103 -111.46612415038773
+-1247.617238450626 102.93757104604563 -112.22859833175046 -1280.3234646019198 102.93757104604563 -168.87746314032032 -1329.9789914691 102.93757104604563 -215.74064796759959 -1393.1679723477657 102.93757104604563 -246.90173074553135 -1463.9999228622421 102.93757104604563 -257.8751159282408 -1534.831876629635 102.93757104604563 -246.90175174275885 -1598.0208667456029 102.93757104604563 -215.7406876963947 -1647.6764075047729 102.93757104604563 -168.87751758886421 -1680.3826504488979 102.93757104604563 -112.22866247563982
+8 0 0 1 8 -1463.9999999999998 100.94413300620994 253.51411323530817 -1400.9550081710368 100.94413300620994 253.51412293065368 -1337.9100134412333 100.94413300620994 234.65111518071362 -1281.4494510362165 100.94413300620994 196.92508897290361 -1238.1560085441504 100.94413300620994 143.09109734190113 -1213.1811056400254 100.94413300620994 78.680888192495232 -1208.7396689220682 100.94413300620994 10.921595099934464 -1223.9263026900676 100.94413300620994 -53.108480463443684 -1255.4487902081335 100.94413300620994 -107.7070498163807
+-1463.9999999999995 80.646240234375028 228.60009999999966 -1407.4774815836602 80.646240234375028 228.60010969534511 -1350.9549602664806 80.646240234375028 211.68862142696057 -1300.3356624666883 80.646240234375028 177.8656341822616 -1261.5212478149783 80.646240234375028 129.60117015920832 -1239.1301833862381 80.646240234375028 71.85467670778327 -1235.1482452596833 80.646240234375028 11.105586635129381 -1248.7637077683785 80.646240234375028 -46.300101516630299 -1277.0249585801325 80.646240234375028 -95.250043198726601
+8 0 0 1 8 -1672.5510986913901 100.94413300620994 -107.70711396027036 -1704.073603002287 100.94413300620994 -53.108554302678868 -1719.2602564639578 100.94413300620994 10.921516589757061 -1714.8188405866654 100.94413300620994 78.680811048363296 -1689.8439574931315 100.94413300620994 143.09102787927441 -1646.5505315587395 100.94413300620994 196.92503282599927 -1590.089980757085 100.94413300620994 234.65107639933154 -1527.0449918289626 100.94413300620994 253.5141035399626 -1463.9999999999995 100.94413300620994 253.51411323530812
+-1650.9749303193912 80.646240234375028 -95.250107342615934 -1679.2361979239763 80.646240234375028 -46.300175355865107 -1692.8516801263427 80.646240234375028 11.105508124952378 -1688.8697628404525 80.646240234375028 71.854599563651732 -1666.4787182223033 80.646240234375028 129.60110069658194 -1627.6643201282675 80.646240234375028 177.86557803535754 -1577.0450339318375 80.646240234375028 211.68858264557866 -1520.5225184163387 80.646240234375028 228.60009030465415 -1463.9999999999993 80.646240234375028 228.6000999999996
+8 0 0 6 8 -1672.5510986913935 100.94413300620994 -107.70711396027218 -1704.0736030022908 100.94413300620994 -53.108554302679806 -1719.2602564639619 100.94413300620994 10.921516589757147 -1714.8188405866692 100.94413300620994 78.680811048364447 -1689.8439574931349 100.94413300620994 143.09102787927654 -1646.5505315587423 100.94413300620994 196.92503282600219 -1590.0899807570868 100.94413300620994 234.65107639933501 -1527.0449918289635 100.94413300620994 253.51410353996636 -1463.9999999999995 100.94413300620994 253.51411323531184
+-1673.7215242809923 102.04521697559167 -108.38285948949351 -1705.4209383577479 102.04521697559167 -53.477883129079693 -1720.6928219221797 102.04521697559167 10.911535744347102 -1716.2264799829243 102.04521697559167 79.051107222549334 -1691.1114334174129 102.04521697559167 143.82280544534981 -1647.5750371506381 102.04521697559167 197.95893621543439 -1590.7976198205195 102.04521697559167 235.89670490144084 -1527.3988113606797 102.04521697559167 254.86559459840899 -1463.9999999999995 102.04521697559167 254.86560429375447
+-1674.9915920576095 102.86508422575187 -109.11613346221249 -1706.882976811512 102.86508422575187 -53.878654135416873 -1722.2473463981876 102.86508422575187 10.900705196680214 -1717.7539563591824 102.86508422575187 79.452927930175875 -1692.4868137434833 102.86508422575187 144.61688164684463 -1648.6867622793384 102.86508422575187 199.08085920714132 -1591.5655025291069 102.86508422575187 237.24837786230177 -1527.7827527149734 102.86508422575187 256.33214254384694 -1463.9999999999995 102.86508422575187 256.3321522391924
+-1676.3294976022296 103.37381023676267 -109.88857358854915 -1708.4231067083185 103.37381023676267 -54.300831409238931 -1723.8849022467723 103.37381023676267 10.889296160059038 -1719.3630193955782 103.37381023676267 79.876210972682955 -1693.9356568667313 103.37381023676267 145.45337161406547 -1649.8578676653385 103.37381023676267 200.26270715169699 -1592.3743999378526 103.37381023676267 238.67224734560253 -1528.1872014193464 103.37381023676267 257.87702279652024 -1463.9999999999995 103.37381023676267 257.87703249186569
+-1677.6988809799068 103.55419576962458 -110.67918745027488 -1709.999472310981 103.55419576962458 -54.732941541026442 -1725.5609860092527 103.55419576962458 10.877618695108561 -1721.0099399756862 103.55419576962458 80.309452889343405 -1695.4185879285062 103.55419576962458 146.30954226177087 -1651.0565264612046 103.55419576962458 201.47236125375554 -1593.2023288377939 103.55419576962458 240.12961719525634 -1528.6011658693169 103.55419576962458 259.45825051997167 -1463.9999999999995 103.55419576962458 259.45826021531713
+-1679.0618953268429 103.40455151353103 -111.46612415038781 -1711.5685062042435 103.40455151353103 -55.163041919550025 -1727.2292742710854 103.40455151353103 10.865995542291895 -1722.6492006937176 103.40455151353103 80.740679788784803 -1696.8946218468857 103.40455151353103 147.16173084188026 -1652.2496102699317 103.40455151353103 202.676389229276 -1594.026407023099 103.40455151353103 241.58020878724707 -1529.0132049619694 103.40455151353103 261.03212392019753 -1463.9999999999995 103.40455151353103 261.03213361554299
+-1680.3826504488979 102.93757104604563 -112.22866247563991 -1713.088893393023 102.93757104604563 -55.579807362415501 -1728.845838522102 102.93757104604563 10.854732756502774 -1724.2376373778879 102.93757104604563 81.158536825642415 -1698.324892454388 102.93757104604563 147.98749796213568 -1653.4057034210857 102.93757104604563 203.84308723164173 -1594.8249352899966 102.93757104604563 242.98582588837178 -1529.4124690954181 102.93757104604563 262.5572005707017 -1463.9999999999995 102.93757104604563 262.55721026604715
+8 0 0 3 8 -1247.6172384506317 102.93757104604559 -112.22859833174789 -1280.323464601925 102.93757104604559 -168.87746314031622 -1329.9789914691039 102.93757104604559 -215.74064796759416 -1393.1679723477682 102.93757104604559 -246.90173074552496 -1463.9999228622426 102.93757104604559 -257.87511592823392 -1534.8318766296336 102.93757104604559 -246.90175174275203 -1598.0208667456 102.93757104604559 -215.74068769638851 -1647.676407504769 102.93757104604559 -168.87751758885901 -1680.3826504488929 102.93757104604559 -112.22866247563593
+-1200.0353001836986 86.113986261320491 -139.70004319872612 -1239.9335337831249 86.113986261320491 -208.80583031587446 -1300.5081705375771 86.113986261320491 -265.9740938551974 -1377.5922286277053 86.113986261320491 -303.987407566196 -1463.9999228622428 86.113986261320491 -317.37380646175058 -1550.407620349697 86.113986261320491 -303.98742856342295 -1627.4916876771272 86.113986261320491 -265.97413358399155 -1688.0663383235694 86.113986261320491 -208.80588476441696 -1727.9645887158263 86.113986261320491 -139.70010734261382
+-1200.0353001836986 43.056993130660238 -139.70004319872612 -1239.9335337831249 43.056993130660238 -208.80583031587446 -1300.5081705375771 43.056993130660238 -265.9740938551974 -1377.5922286277053 43.056993130660238 -303.987407566196 -1463.9999228622428 43.056993130660238 -317.37380646175058 -1550.407620349697 43.056993130660238 -303.98742856342295 -1627.4916876771272 43.056993130660238 -265.97413358399155 -1688.0663383235694 43.056993130660238 -208.80588476441696 -1727.9645887158263 43.056993130660238 -139.70010734261382
+-1200.0353001836986 -7.1054273576010019e-15 -139.70004319872612 -1239.9335337831249 -7.1054273576010019e-15 -208.80583031587446 -1300.5081705375771 -7.1054273576010019e-15 -265.9740938551974 -1377.5922286277053 -7.1054273576010019e-15 -303.987407566196 -1463.9999228622428 -7.1054273576010019e-15 -317.37380646175058 -1550.407620349697 -7.1054273576010019e-15 -303.98742856342295 -1627.4916876771272 -7.1054273576010019e-15 -265.97413358399155 -1688.0663383235694 -7.1054273576010019e-15 -208.80588476441696 -1727.9645887158263 -7.1054273576010019e-15 -139.70010734261382
+8 0 0 6 8 -1463.9999999999995 100.94413300620994 253.51411323531192 -1400.9550081710356 100.94413300620994 253.51412293065738 -1337.9100134412311 100.94413300620994 234.65111518071697 -1281.4494510362133 100.94413300620994 196.92508897290634 -1238.1560085441467 100.94413300620994 143.09109734190298 -1213.1811056400215 100.94413300620994 78.68088819249607 -1208.7396689220643 100.94413300620994 10.921595099934265 -1223.9263026900639 100.94413300620994 -53.108480463444849 -1255.4487902081305 100.94413300620994 -107.70704981638266
+-1463.9999999999995 102.04521697559167 254.86560429375456 -1400.6011886393194 102.04521697559167 254.86561398910001 -1337.2023743777984 102.04521697559167 235.8967436828228 -1280.4249454443175 102.04521697559167 197.95899236233853 -1236.8885326198688 102.04521697559167 143.82287490797626 -1211.7734662437665 102.04521697559167 79.051184366680957 -1207.3071034638465 102.04521697559167 10.911614254524228 -1222.5789673346069 102.04521697559167 -53.477809289844728 -1254.2783646185317 102.04521697559167 -108.38279534560398
+-1463.9999999999995 102.86508422575187 256.33215223919251 -1400.2172472850257 102.86508422575187 256.33216193453796 -1336.434491669211 102.86508422575187 237.24841664368375 -1279.3132203156172 102.86508422575187 199.08091535404546 -1235.5131522937984 102.86508422575187 144.61695110947107 -1210.2459898675083 102.86508422575187 79.453005074307512 -1205.7525789878387 102.86508422575187 10.900783706857348 -1221.1169288808428 102.86508422575187 -53.878580296181902 -1253.0082968419144 102.86508422575187 -109.11606931832296
+-1463.9999999999995 103.37381023676267 257.8770324918658 -1399.8127985806527 103.37381023676267 257.87704218721126 -1335.6255942604653 103.37381023676267 238.67228612698455 -1278.142114929617 103.37381023676267 200.26276329860116 -1234.0643091705504 103.37381023676267 145.45344107669192 -1208.6369268311125 103.37381023676267 79.876288116814592 -1204.1150231392539 103.37381023676267 10.889374670236181 -1219.5767989840363 103.37381023676267 -54.300757570003952 -1251.6703912972944 103.37381023676267 -109.88850944465962
+-1463.9999999999995 103.55419576962458 259.45826021531724 -1399.3988341306822 103.55419576962458 259.45826991066269 -1334.797665360524 103.55419576962458 240.12965597663836 -1276.9434561337509 103.55419576962458 201.47241740065974 -1232.5813781087754 103.55419576962458 146.30961172439731 -1206.9900062510046 103.55419576962458 80.309530033475042 -1202.4389393767735 103.55419576962458 10.877697205285713 -1218.0004333813738 103.55419576962458 -54.732867701791449 -1250.3010079196172 103.55419576962458 -110.67912330638534
+-1463.9999999999995 103.40455151353103 261.0321336155431 -1398.9867950380296 103.40455151353103 261.03214331088856 -1333.9735871752189 103.40455151353103 241.58024756862909 -1275.7503723250238 103.40455151353103 202.6764453761802 -1231.105344190396 103.40455151353103 147.1618003045067 -1205.3507455329732 103.40455151353103 80.740756932916455 -1200.7706511149408 103.40455151353103 10.866074052469056 -1216.4313994881113 103.40455151353103 -55.162968080315025 -1248.9379935726811 103.40455151353103 -111.46606000649827
+-1463.9999999999995 102.93757104604563 262.55721026604726 -1398.5875309045809 102.93757104604563 262.55721996139272 -1333.1750589083213 102.93757104604563 242.98586466975379 -1274.5942791738698 102.93757104604563 203.84314337854593 -1229.6750735828937 102.93757104604563 147.98756742476212 -1203.7623088488031 102.93757104604563 81.158613969774066 -1199.1540868639242 102.93757104604563 10.854811266679944 -1214.9110122993318 102.93757104604563 -55.579733523180494 -1247.617238450626 102.93757104604563 -112.22859833175035
+8 0 0 3 8 -1463.9999999999989 102.93757104604559 262.5572102660409 -1398.5875309045819 102.93757104604559 262.55721996138618 -1333.1750589083242 102.93757104604559 242.98586466974749 -1274.5942791738742 102.93757104604559 203.84314337854047 -1229.6750735828994 102.93757104604559 147.98756742475797 -1203.7623088488094 102.93757104604559 81.158613969771537 -1199.1540868639311 102.93757104604559 10.854811266679164 -1214.9110122993386 102.93757104604559 -55.57973352317957 -1247.6172384506317 102.93757104604559 -112.22859833174792
+-1463.9999999999986 86.113986261320491 317.50009999999702 -1384.2035160083158 86.113986261320491 317.50010969534225 -1304.4070291157923 86.113986261320491 293.62506721063352 -1232.9445047149761 86.113986261320491 245.87497153328644 -1178.1476960889652 86.113986261320491 177.7369126915161 -1146.5367906698482 86.113986261320491 96.212462635696184 -1140.9152361398724 86.113986261320491 10.449054613395978 -1160.1370665842726 86.113986261320491 -70.594256081577797 -1200.0353001836986 86.113986261320491 -139.70004319872615
+-1463.9999999999986 43.056993130660238 317.50009999999702 -1384.2035160083158 43.056993130660238 317.50010969534225 -1304.4070291157923 43.056993130660238 293.62506721063352 -1232.9445047149761 43.056993130660238 245.87497153328644 -1178.1476960889652 43.056993130660238 177.7369126915161 -1146.5367906698482 43.056993130660238 96.212462635696184 -1140.9152361398724 43.056993130660238 10.449054613395978 -1160.1370665842726 43.056993130660238 -70.594256081577797 -1200.0353001836986 43.056993130660238 -139.70004319872615
+-1463.9999999999986 -7.1054273576010019e-15 317.50009999999702 -1384.2035160083158 -7.1054273576010019e-15 317.50010969534225 -1304.4070291157923 -7.1054273576010019e-15 293.62506721063352 -1232.9445047149761 -7.1054273576010019e-15 245.87497153328644 -1178.1476960889652 -7.1054273576010019e-15 177.7369126915161 -1146.5367906698482 -7.1054273576010019e-15 96.212462635696184 -1140.9152361398724 -7.1054273576010019e-15 10.449054613395981 -1160.1370665842726 -7.1054273576010019e-15 -70.594256081577782 -1200.0353001836986 -7.1054273576010019e-15 -139.70004319872615
+8 0 0 3 8 -1680.3826504488929 102.93757104604559 -112.22866247563616 -1713.0888933930169 102.93757104604559 -55.579807362413121 -1728.8458385220956 102.93757104604559 10.854732756503495 -1724.2376373778814 102.93757104604559 81.158536825641306 -1698.3248924543818 102.93757104604559 147.98749796213275 -1653.4057034210807 102.93757104604559 203.84308723163733 -1594.8249352899929 102.93757104604559 242.98582588836621 -1529.4124690954163 102.93757104604559 262.5572005706955 -1463.9999999999993 102.93757104604559 262.55721026604084
+-1727.9645887158263 86.113986261320491 -139.70010734261405 -1767.8628391080831 86.113986261320491 -70.594329920810964 -1787.0846892461543 86.113986261320491 10.448976103220714 -1781.4631555568424 86.113986261320491 96.212385491566351 -1749.8522699483158 86.113986261320491 177.73684322889122 -1695.0554778799785 86.113986261320491 245.87491538638355 -1623.5929650825246 86.113986261320491 293.62502842925238 -1543.796483991682 86.113986261320491 317.50009030465162 -1463.9999999999991 86.113986261320491 317.50009999999696
+-1727.9645887158263 43.056993130660238 -139.70010734261405 -1767.8628391080831 43.056993130660238 -70.594329920810964 -1787.0846892461543 43.056993130660238 10.448976103220714 -1781.4631555568424 43.056993130660238 96.212385491566351 -1749.8522699483158 43.056993130660238 177.73684322889122 -1695.0554778799785 43.056993130660238 245.87491538638355 -1623.5929650825246 43.056993130660238 293.62502842925238 -1543.796483991682 43.056993130660238 317.50009030465162 -1463.9999999999991 43.056993130660238 317.50009999999696
+-1727.9645887158263 -7.1054273576010019e-15 -139.70010734261405 -1767.8628391080831 -7.1054273576010019e-15 -70.594329920810964 -1787.0846892461543 -7.1054273576010019e-15 10.448976103220712 -1781.4631555568424 -7.1054273576010019e-15 96.212385491566351 -1749.8522699483158 -7.1054273576010019e-15 177.73684322889122 -1695.0554778799785 -7.1054273576010019e-15 245.87491538638355 -1623.5929650825246 -7.1054273576010019e-15 293.62502842925238 -1543.796483991682 -7.1054273576010019e-15 317.50009030465162 -1463.9999999999991 -7.1054273576010019e-15 317.50009999999696
+8 0 0 3 8 -1247.6172384506317 -102.93757104604559 -112.22859833174789 -1280.323464601925 -102.93757104604559 -168.87746314031622 -1329.9789914691039 -102.93757104604559 -215.74064796759416 -1393.1679723477682 -102.93757104604559 -246.90173074552496 -1463.9999228622426 -102.93757104604559 -257.87511592823392 -1534.8318766296336 -102.93757104604559 -246.90175174275203 -1598.0208667456 -102.93757104604559 -215.74068769638851 -1647.676407504769 -102.93757104604559 -168.87751758885901 -1680.3826504488929 -102.93757104604559 -112.22866247563593
+-1200.0353001836986 -86.113986261320491 -139.70004319872612 -1239.9335337831249 -86.113986261320491 -208.80583031587446 -1300.5081705375771 -86.113986261320491 -265.9740938551974 -1377.5922286277053 -86.113986261320491 -303.987407566196 -1463.9999228622428 -86.113986261320491 -317.37380646175058 -1550.407620349697 -86.113986261320491 -303.98742856342295 -1627.4916876771272 -86.113986261320491 -265.97413358399155 -1688.0663383235694 -86.113986261320491 -208.80588476441696 -1727.9645887158263 -86.113986261320491 -139.70010734261382
+-1200.0353001836986 -43.056993130660238 -139.70004319872612 -1239.9335337831249 -43.056993130660238 -208.80583031587446 -1300.5081705375771 -43.056993130660238 -265.9740938551974 -1377.5922286277053 -43.056993130660238 -303.987407566196 -1463.9999228622428 -43.056993130660238 -317.37380646175058 -1550.407620349697 -43.056993130660238 -303.98742856342295 -1627.4916876771272 -43.056993130660238 -265.97413358399155 -1688.0663383235694 -43.056993130660238 -208.80588476441696 -1727.9645887158263 -43.056993130660238 -139.70010734261382
+-1200.0353001836986 7.1054273576010019e-15 -139.70004319872612 -1239.9335337831249 7.1054273576010019e-15 -208.80583031587446 -1300.5081705375771 7.1054273576010019e-15 -265.9740938551974 -1377.5922286277053 7.1054273576010019e-15 -303.987407566196 -1463.9999228622428 7.1054273576010019e-15 -317.37380646175058 -1550.407620349697 7.1054273576010019e-15 -303.98742856342295 -1627.4916876771272 7.1054273576010019e-15 -265.97413358399155 -1688.0663383235694 7.1054273576010019e-15 -208.80588476441696 -1727.9645887158263 7.1054273576010019e-15 -139.70010734261382
+8 0 0 3 8 -1463.9999999999989 -102.93757104604559 262.5572102660409 -1398.5875309045819 -102.93757104604559 262.55721996138618 -1333.1750589083242 -102.93757104604559 242.98586466974749 -1274.5942791738742 -102.93757104604559 203.84314337854047 -1229.6750735828994 -102.93757104604559 147.98756742475797 -1203.7623088488094 -102.93757104604559 81.158613969771537 -1199.1540868639311 -102.93757104604559 10.854811266679164 -1214.9110122993386 -102.93757104604559 -55.57973352317957 -1247.6172384506317 -102.93757104604559 -112.22859833174792
+-1463.9999999999986 -86.113986261320491 317.50009999999702 -1384.2035160083158 -86.113986261320491 317.50010969534225 -1304.4070291157923 -86.113986261320491 293.62506721063352 -1232.9445047149761 -86.113986261320491 245.87497153328644 -1178.1476960889652 -86.113986261320491 177.7369126915161 -1146.5367906698482 -86.113986261320491 96.212462635696184 -1140.9152361398724 -86.113986261320491 10.449054613395978 -1160.1370665842726 -86.113986261320491 -70.594256081577797 -1200.0353001836986 -86.113986261320491 -139.70004319872615
+-1463.9999999999986 -43.056993130660238 317.50009999999702 -1384.2035160083158 -43.056993130660238 317.50010969534225 -1304.4070291157923 -43.056993130660238 293.62506721063352 -1232.9445047149761 -43.056993130660238 245.87497153328644 -1178.1476960889652 -43.056993130660238 177.7369126915161 -1146.5367906698482 -43.056993130660238 96.212462635696184 -1140.9152361398724 -43.056993130660238 10.449054613395978 -1160.1370665842726 -43.056993130660238 -70.594256081577797 -1200.0353001836986 -43.056993130660238 -139.70004319872615
+-1463.9999999999986 7.1054273576010019e-15 317.50009999999702 -1384.2035160083158 7.1054273576010019e-15 317.50010969534225 -1304.4070291157923 7.1054273576010019e-15 293.62506721063352 -1232.9445047149761 7.1054273576010019e-15 245.87497153328644 -1178.1476960889652 7.1054273576010019e-15 177.7369126915161 -1146.5367906698482 7.1054273576010019e-15 96.212462635696184 -1140.9152361398724 7.1054273576010019e-15 10.449054613395981 -1160.1370665842726 7.1054273576010019e-15 -70.594256081577782 -1200.0353001836986 7.1054273576010019e-15 -139.70004319872615
+8 0 0 3 8 -1680.3826504488929 -102.93757104604559 -112.22866247563616 -1713.0888933930169 -102.93757104604559 -55.579807362413121 -1728.8458385220956 -102.93757104604559 10.854732756503495 -1724.2376373778814 -102.93757104604559 81.158536825641306 -1698.3248924543818 -102.93757104604559 147.98749796213275 -1653.4057034210807 -102.93757104604559 203.84308723163733 -1594.8249352899929 -102.93757104604559 242.98582588836621 -1529.4124690954163 -102.93757104604559 262.5572005706955 -1463.9999999999993 -102.93757104604559 262.55721026604084
+-1727.9645887158263 -86.113986261320491 -139.70010734261405 -1767.8628391080831 -86.113986261320491 -70.594329920810964 -1787.0846892461543 -86.113986261320491 10.448976103220714 -1781.4631555568424 -86.113986261320491 96.212385491566351 -1749.8522699483158 -86.113986261320491 177.73684322889122 -1695.0554778799785 -86.113986261320491 245.87491538638355 -1623.5929650825246 -86.113986261320491 293.62502842925238 -1543.796483991682 -86.113986261320491 317.50009030465162 -1463.9999999999991 -86.113986261320491 317.50009999999696
+-1727.9645887158263 -43.056993130660238 -139.70010734261405 -1767.8628391080831 -43.056993130660238 -70.594329920810964 -1787.0846892461543 -43.056993130660238 10.448976103220714 -1781.4631555568424 -43.056993130660238 96.212385491566351 -1749.8522699483158 -43.056993130660238 177.73684322889122 -1695.0554778799785 -43.056993130660238 245.87491538638355 -1623.5929650825246 -43.056993130660238 293.62502842925238 -1543.796483991682 -43.056993130660238 317.50009030465162 -1463.9999999999991 -43.056993130660238 317.50009999999696
+-1727.9645887158263 7.1054273576010019e-15 -139.70010734261405 -1767.8628391080831 7.1054273576010019e-15 -70.594329920810964 -1787.0846892461543 7.1054273576010019e-15 10.448976103220712 -1781.4631555568424 7.1054273576010019e-15 96.212385491566351 -1749.8522699483158 7.1054273576010019e-15 177.73684322889122 -1695.0554778799785 7.1054273576010019e-15 245.87491538638355 -1623.5929650825246 7.1054273576010019e-15 293.62502842925238 -1543.796483991682 7.1054273576010019e-15 317.50009030465162 -1463.9999999999991 7.1054273576010019e-15 317.50009999999696
+8 0 0 6 8 -1255.4487902081305 -100.94413300620994 -107.70704981638278 -1286.9712777261971 -100.94413300620994 -162.30561916932061 -1334.8296189943305 -100.94413300620994 -207.47268231181715 -1395.731597276641 -100.94413300620994 -237.5059505626138 -1463.9999228622421 -100.94413300620994 -248.08217576252255 -1532.2682517007599 -100.94413300620994 -237.50597155984127 -1593.1702392203724 -100.94413300620994 -207.47272204061227 -1641.0285943804961 -100.94413300620994 -162.30567361786447 -1672.5510986913935 -100.94413300620994 -107.7071139602721
+-1254.2783646185317 -102.04521697559167 -108.38279534560409 -1285.9777619024565 -102.04521697559167 -163.28778140136336 -1334.1046925995452 -102.04521697559167 -208.70832996851294 -1395.3484634722818 -102.04521697559167 -238.91015012623089 -1463.9999228622421 -102.04521697559167 -249.54573089466911 -1532.6513855051192 -102.04521697559167 -238.91017112345835 -1593.8951656151578 -102.04521697559167 -208.70836969730806 -1642.0221102042367 -102.04521697559167 -163.28783584990722 -1673.7215242809923 -102.04521697559167 -108.38285948949343
+-1253.0082968419144 -102.86508422575187 -109.11606931832307 -1284.8996648029861 -102.86508422575187 -164.35355834046413 -1333.3180508321248 -102.86508422575187 -210.049172381707 -1394.9327122247239 -102.86508422575187 -240.43389382556435 -1463.9999228622421 -102.86508422575187 -251.13388329765874 -1533.067136752677 -102.86508422575187 -240.43391482279182 -1594.6818073825782 -102.86508422575187 -210.04921211050211 -1643.1002073037068 -102.86508422575187 -164.353612789008 -1674.9915920576095 -102.86508422575187 -109.1161334622124
+-1251.6703912972944 -103.37381023676267 -109.88850944465973 -1283.7639836105525 -103.37381023676267 -165.4762613193154 -1332.4893923922857 -103.37381023676267 -211.4616328283866 -1394.4947545743282 -103.37381023676267 -242.0390248126271 -1463.9999228622421 -103.37381023676267 -252.80686323210043 -1533.5050944030727 -103.37381023676267 -242.0390458098546 -1595.5104658224172 -103.37381023676267 -211.46167255718171 -1644.2358884961404 -103.37381023676267 -165.47631576785926 -1676.3294976022296 -103.37381023676267 -109.88857358854906
+-1250.3010079196172 -103.55419576962458 -110.67912330638545 -1282.6015824578606 -103.55419576962458 -166.62537891097932 -1331.6412375297466 -103.55419576962458 -212.90732521308993 -1394.0464927900864 -103.55419576962458 -243.68192083134613 -1463.9999228622421 -103.55419576962458 -254.51920452751122 -1533.9533561873143 -103.55419576962458 -243.68194182857363 -1596.3586206849563 -103.55419576962458 -212.90736494188505 -1645.3982896488324 -103.55419576962458 -166.62543335952321 -1677.6988809799068 -103.55419576962458 -110.6791874502748
+-1248.9379935726811 -103.40455151353103 -111.46606000649838 -1281.4445876572506 -103.40455151353103 -167.76915193268161 -1330.797027453219 -103.40455151353103 -214.34629365226399 -1393.6003158807821 -103.40455151353103 -245.31717570630801 -1463.9999228622421 -103.40455151353103 -256.22358168772996 -1534.3995330966186 -103.40455151353103 -245.3171967035355 -1597.2028307614839 -103.40455151353103 -214.34633338105911 -1646.5552844494423 -103.40455151353103 -167.7692063812255 -1679.0618953268429 -103.40455151353103 -111.46612415038773
+-1247.617238450626 -102.93757104604563 -112.22859833175046 -1280.3234646019198 -102.93757104604563 -168.87746314032032 -1329.9789914691 -102.93757104604563 -215.74064796759959 -1393.1679723477657 -102.93757104604563 -246.90173074553135 -1463.9999228622421 -102.93757104604563 -257.8751159282408 -1534.831876629635 -102.93757104604563 -246.90175174275885 -1598.0208667456029 -102.93757104604563 -215.7406876963947 -1647.6764075047729 -102.93757104604563 -168.87751758886421 -1680.3826504488979 -102.93757104604563 -112.22866247563982
+8 0 0 6 8 -1463.9999999999995 -100.94413300620994 253.51411323531192 -1400.9550081710356 -100.94413300620994 253.51412293065738 -1337.9100134412311 -100.94413300620994 234.65111518071697 -1281.4494510362133 -100.94413300620994 196.92508897290634 -1238.1560085441467 -100.94413300620994 143.09109734190298 -1213.1811056400215 -100.94413300620994 78.68088819249607 -1208.7396689220643 -100.94413300620994 10.921595099934265 -1223.9263026900639 -100.94413300620994 -53.108480463444849 -1255.4487902081305 -100.94413300620994 -107.70704981638266
+-1463.9999999999995 -102.04521697559167 254.86560429375456 -1400.6011886393194 -102.04521697559167 254.86561398910001 -1337.2023743777984 -102.04521697559167 235.8967436828228 -1280.4249454443175 -102.04521697559167 197.95899236233853 -1236.8885326198688 -102.04521697559167 143.82287490797626 -1211.7734662437665 -102.04521697559167 79.051184366680957 -1207.3071034638465 -102.04521697559167 10.911614254524228 -1222.5789673346069 -102.04521697559167 -53.477809289844728 -1254.2783646185317 -102.04521697559167 -108.38279534560398
+-1463.9999999999995 -102.86508422575187 256.33215223919251 -1400.2172472850257 -102.86508422575187 256.33216193453796 -1336.434491669211 -102.86508422575187 237.24841664368375 -1279.3132203156172 -102.86508422575187 199.08091535404546 -1235.5131522937984 -102.86508422575187 144.61695110947107 -1210.2459898675083 -102.86508422575187 79.453005074307512 -1205.7525789878387 -102.86508422575187 10.900783706857348 -1221.1169288808428 -102.86508422575187 -53.878580296181902 -1253.0082968419144 -102.86508422575187 -109.11606931832296
+-1463.9999999999995 -103.37381023676267 257.8770324918658 -1399.8127985806527 -103.37381023676267 257.87704218721126 -1335.6255942604653 -103.37381023676267 238.67228612698455 -1278.142114929617 -103.37381023676267 200.26276329860116 -1234.0643091705504 -103.37381023676267 145.45344107669192 -1208.6369268311125 -103.37381023676267 79.876288116814592 -1204.1150231392539 -103.37381023676267 10.889374670236181 -1219.5767989840363 -103.37381023676267 -54.300757570003952 -1251.6703912972944 -103.37381023676267 -109.88850944465962
+-1463.9999999999995 -103.55419576962458 259.45826021531724 -1399.3988341306822 -103.55419576962458 259.45826991066269 -1334.797665360524 -103.55419576962458 240.12965597663836 -1276.9434561337509 -103.55419576962458 201.47241740065974 -1232.5813781087754 -103.55419576962458 146.30961172439731 -1206.9900062510046 -103.55419576962458 80.309530033475042 -1202.4389393767735 -103.55419576962458 10.877697205285713 -1218.0004333813738 -103.55419576962458 -54.732867701791449 -1250.3010079196172 -103.55419576962458 -110.67912330638534
+-1463.9999999999995 -103.40455151353103 261.0321336155431 -1398.9867950380296 -103.40455151353103 261.03214331088856 -1333.9735871752189 -103.40455151353103 241.58024756862909 -1275.7503723250238 -103.40455151353103 202.6764453761802 -1231.105344190396 -103.40455151353103 147.1618003045067 -1205.3507455329732 -103.40455151353103 80.740756932916455 -1200.7706511149408 -103.40455151353103 10.866074052469056 -1216.4313994881113 -103.40455151353103 -55.162968080315025 -1248.9379935726811 -103.40455151353103 -111.46606000649827
+-1463.9999999999995 -102.93757104604563 262.55721026604726 -1398.5875309045809 -102.93757104604563 262.55721996139272 -1333.1750589083213 -102.93757104604563 242.98586466975379 -1274.5942791738698 -102.93757104604563 203.84314337854593 -1229.6750735828937 -102.93757104604563 147.98756742476212 -1203.7623088488031 -102.93757104604563 81.158613969774066 -1199.1540868639242 -102.93757104604563 10.854811266679944 -1214.9110122993318 -102.93757104604563 -55.579733523180494 -1247.617238450626 -102.93757104604563 -112.22859833175035
+8 0 0 6 8 -1672.5510986913935 -100.94413300620994 -107.70711396027218 -1704.0736030022908 -100.94413300620994 -53.108554302679806 -1719.2602564639619 -100.94413300620994 10.921516589757147 -1714.8188405866692 -100.94413300620994 78.680811048364447 -1689.8439574931349 -100.94413300620994 143.09102787927654 -1646.5505315587423 -100.94413300620994 196.92503282600219 -1590.0899807570868 -100.94413300620994 234.65107639933501 -1527.0449918289635 -100.94413300620994 253.51410353996636 -1463.9999999999995 -100.94413300620994 253.51411323531184
+-1673.7215242809923 -102.04521697559167 -108.38285948949351 -1705.4209383577479 -102.04521697559167 -53.477883129079693 -1720.6928219221797 -102.04521697559167 10.911535744347102 -1716.2264799829243 -102.04521697559167 79.051107222549334 -1691.1114334174129 -102.04521697559167 143.82280544534981 -1647.5750371506381 -102.04521697559167 197.95893621543439 -1590.7976198205195 -102.04521697559167 235.89670490144084 -1527.3988113606797 -102.04521697559167 254.86559459840899 -1463.9999999999995 -102.04521697559167 254.86560429375447
+-1674.9915920576095 -102.86508422575187 -109.11613346221249 -1706.882976811512 -102.86508422575187 -53.878654135416873 -1722.2473463981876 -102.86508422575187 10.900705196680214 -1717.7539563591824 -102.86508422575187 79.452927930175875 -1692.4868137434833 -102.86508422575187 144.61688164684463 -1648.6867622793384 -102.86508422575187 199.08085920714132 -1591.5655025291069 -102.86508422575187 237.24837786230177 -1527.7827527149734 -102.86508422575187 256.33214254384694 -1463.9999999999995 -102.86508422575187 256.3321522391924
+-1676.3294976022296 -103.37381023676267 -109.88857358854915 -1708.4231067083185 -103.37381023676267 -54.300831409238931 -1723.8849022467723 -103.37381023676267 10.889296160059038 -1719.3630193955782 -103.37381023676267 79.876210972682955 -1693.9356568667313 -103.37381023676267 145.45337161406547 -1649.8578676653385 -103.37381023676267 200.26270715169699 -1592.3743999378526 -103.37381023676267 238.67224734560253 -1528.1872014193464 -103.37381023676267 257.87702279652024 -1463.9999999999995 -103.37381023676267 257.87703249186569
+-1677.6988809799068 -103.55419576962458 -110.67918745027488 -1709.999472310981 -103.55419576962458 -54.732941541026442 -1725.5609860092527 -103.55419576962458 10.877618695108561 -1721.0099399756862 -103.55419576962458 80.309452889343405 -1695.4185879285062 -103.55419576962458 146.30954226177087 -1651.0565264612046 -103.55419576962458 201.47236125375554 -1593.2023288377939 -103.55419576962458 240.12961719525634 -1528.6011658693169 -103.55419576962458 259.45825051997167 -1463.9999999999995 -103.55419576962458 259.45826021531713
+-1679.0618953268429 -103.40455151353103 -111.46612415038781 -1711.5685062042435 -103.40455151353103 -55.163041919550025 -1727.2292742710854 -103.40455151353103 10.865995542291895 -1722.6492006937176 -103.40455151353103 80.740679788784803 -1696.8946218468857 -103.40455151353103 147.16173084188026 -1652.2496102699317 -103.40455151353103 202.676389229276 -1594.026407023099 -103.40455151353103 241.58020878724707 -1529.0132049619694 -103.40455151353103 261.03212392019753 -1463.9999999999995 -103.40455151353103 261.03213361554299
+-1680.3826504488979 -102.93757104604563 -112.22866247563991 -1713.088893393023 -102.93757104604563 -55.579807362415501 -1728.845838522102 -102.93757104604563 10.854732756502774 -1724.2376373778879 -102.93757104604563 81.158536825642415 -1698.324892454388 -102.93757104604563 147.98749796213568 -1653.4057034210857 -102.93757104604563 203.84308723164173 -1594.8249352899966 -102.93757104604563 242.98582588837178 -1529.4124690954181 -102.93757104604563 262.5572005707017 -1463.9999999999995 -102.93757104604563 262.55721026604715
+8 0 0 1 8 -1255.4487902081337 -100.94413300620994 -107.70704981638073 -1286.9712777261996 -100.94413300620994 -162.30561916931777 -1334.8296189943321 -100.94413300620994 -207.47268231181363 -1395.7315972766414 -100.94413300620994 -237.50595056260985 -1463.9999228622414 -100.94413300620994 -248.08217576251849 -1532.2682517007584 -100.94413300620994 -237.50597155983743 -1593.1702392203699 -100.94413300620994 -207.47272204060894 -1641.0285943804929 -100.94413300620994 -162.30567361786188 -1672.5510986913898 -100.94413300620994 -107.70711396027038
+-1277.0249585801328 -80.646240234375028 -95.250043198726644 -1305.2862093918868 -80.646240234375028 -144.19998488082297 -1348.1932485067002 -80.646240234375028 -184.69418009325588 -1402.7944635923825 -80.646240234375028 -211.62028428725628 -1463.9999228622416 -80.646240234375028 -221.10232139713321 -1525.2053853850175 -80.646240234375028 -211.62030528448375 -1579.8066097080023 -80.646240234375028 -184.694219822051 -1622.7136627148059 -80.646240234375028 -144.2000393293668 -1650.974930319391 -80.646240234375028 -95.250107342615962
+8 0 0 1 8 -1463.9999999999998 -100.94413300620994 253.51411323530817 -1400.9550081710368 -100.94413300620994 253.51412293065368 -1337.9100134412333 -100.94413300620994 234.65111518071362 -1281.4494510362165 -100.94413300620994 196.92508897290361 -1238.1560085441504 -100.94413300620994 143.09109734190113 -1213.1811056400254 -100.94413300620994 78.680888192495232 -1208.7396689220682 -100.94413300620994 10.921595099934464 -1223.9263026900676 -100.94413300620994 -53.108480463443684 -1255.4487902081335 -100.94413300620994 -107.7070498163807
+-1463.9999999999995 -80.646240234375028 228.60009999999966 -1407.4774815836602 -80.646240234375028 228.60010969534511 -1350.9549602664806 -80.646240234375028 211.68862142696057 -1300.3356624666883 -80.646240234375028 177.8656341822616 -1261.5212478149783 -80.646240234375028 129.60117015920832 -1239.1301833862381 -80.646240234375028 71.85467670778327 -1235.1482452596833 -80.646240234375028 11.105586635129381 -1248.7637077683785 -80.646240234375028 -46.300101516630299 -1277.0249585801325 -80.646240234375028 -95.250043198726601
+8 0 0 1 8 -1672.5510986913901 -100.94413300620994 -107.70711396027036 -1704.073603002287 -100.94413300620994 -53.108554302678868 -1719.2602564639578 -100.94413300620994 10.921516589757061 -1714.8188405866654 -100.94413300620994 78.680811048363296 -1689.8439574931315 -100.94413300620994 143.09102787927441 -1646.5505315587395 -100.94413300620994 196.92503282599927 -1590.089980757085 -100.94413300620994 234.65107639933154 -1527.0449918289626 -100.94413300620994 253.5141035399626 -1463.9999999999995 -100.94413300620994 253.51411323530812
+-1650.9749303193912 -80.646240234375028 -95.250107342615934 -1679.2361979239763 -80.646240234375028 -46.300175355865107 -1692.8516801263427 -80.646240234375028 11.105508124952378 -1688.8697628404525 -80.646240234375028 71.854599563651732 -1666.4787182223033 -80.646240234375028 129.60110069658194 -1627.6643201282675 -80.646240234375028 177.86557803535754 -1577.0450339318375 -80.646240234375028 211.68858264557866 -1520.5225184163387 -80.646240234375028 228.60009030465415 -1463.9999999999993 -80.646240234375028 228.6000999999996
+8 0 0 3 8 186.97488467706268 59.531249999999993 -107.95000000000199 158.71364076414397 59.531249999999993 -156.89991034227356 115.80661792501961 59.531249999999993 -197.39407627900849 61.205427771363695 59.531249999999993 -224.32015653457702 -5.6843418860808015e-13 59.531249999999993 -233.80217801408082 -61.20542777136481 59.531249999999993 -224.32015653457671 -115.80661792502059 59.531249999999993 -197.39407627900792 -158.71364076414474 59.531249999999993 -156.89991034227276 -186.97488467706322 59.531249999999993 -107.95000000000104
+252.96602044543698 109.6472266284147 -146.05000000000192 214.73021985737074 109.6472266284147 -212.27634928660441 156.67954189855567 109.6472266284147 -267.06257378924568 82.807343455374451 109.6472266284147 -303.49197648795598 -4.3106259302779415e-13 109.6472266284147 -316.32059378375527 -82.807343455375303 109.6472266284147 -303.49197648795575 -156.67954189855644 109.6472266284147 -267.06257378924522 -214.73021985737131 109.6472266284147 -212.27634928660379 -252.96602044543741 109.6472266284147 -146.05000000000115
+252.96602044543698 54.823613314207357 -146.05000000000192 214.73021985737074 54.823613314207357 -212.27634928660441 156.67954189855567 54.823613314207357 -267.06257378924568 82.807343455374451 54.823613314207357 -303.49197648795598 -4.3106259302779415e-13 54.823613314207357 -316.32059378375527 -82.807343455375303 54.823613314207357 -303.49197648795575 -156.67954189855644 54.823613314207357 -267.06257378924522 -214.73021985737131 54.823613314207357 -212.27634928660379 -252.96602044543741 54.823613314207357 -146.05000000000115
+252.96602044543698 2.8421709430404007e-14 -146.05000000000192 214.73021985737074 2.8421709430404007e-14 -212.27634928660441 156.67954189855567 2.8421709430404007e-14 -267.06257378924568 82.807343455374451 2.8421709430404007e-14 -303.49197648795598 -4.3343106881366111e-13 2.8421709430404007e-14 -316.32059378375527 -82.807343455375303 2.8421709430404007e-14 -303.49197648795575 -156.67954189855644 2.8421709430404007e-14 -267.06257378924522 -214.73021985737131 2.8421709430404007e-14 -212.27634928660379 -252.96602044543741 2.8421709430404007e-14 -146.05000000000115
+8 0 0 3 8 5.6843418860808015e-13 59.531249999999993 215.90000000000305 56.522487825837722 59.531249999999993 215.9000000000029 113.04497565167483 59.531249999999993 198.98851118892955 163.66424025416373 59.531249999999993 165.16553356678304 202.47862562032583 59.531249999999993 116.9010890070399 224.86966802552769 59.531249999999993 59.154622967792839 228.8515935766944 59.531249999999993 -1.5944349099222208 215.23612858998132 59.531249999999993 -59.00008965773042 186.97488467706259 59.531249999999993 -107.95000000000199
+4.5474735088646412e-13 109.6472266284147 292.10000000000309 76.471601176132808 109.6472266284147 292.10000000000298 152.94320235226513 109.6472266284147 269.21975043208039 221.42808975563227 109.6472266284147 223.45925129623532 273.94166995691029 109.6472266284147 158.16029689187724 304.23543321100692 109.6472266284147 80.032725191719763 309.62274425082074 109.6472266284147 -2.1571766428356085 291.20182103350322 109.6472266284147 -79.823650713399388 252.9660204454369 109.6472266284147 -146.05000000000192
+4.5474735088646412e-13 54.823613314207357 292.10000000000309 76.471601176132808 54.823613314207357 292.10000000000298 152.94320235226513 54.823613314207357 269.21975043208039 221.42808975563227 54.823613314207357 223.45925129623532 273.94166995691029 54.823613314207357 158.16029689187724 304.23543321100692 54.823613314207357 80.032725191719763 309.62274425082074 54.823613314207357 -2.1571766428356085 291.20182103350322 54.823613314207357 -79.823650713399388 252.9660204454369 54.823613314207357 -146.05000000000192
+4.5474735088646412e-13 2.8421709430404007e-14 292.10000000000309 76.471601176132808 2.8421709430404007e-14 292.10000000000298 152.94320235226513 2.8421709430404007e-14 269.21975043208039 221.42808975563227 2.8421709430404007e-14 223.45925129623532 273.94166995691029 2.8421709430404007e-14 158.16029689187724 304.23543321100692 2.8421709430404007e-14 80.032725191719763 309.62274425082074 2.8421709430404007e-14 -2.1571766428356085 291.20182103350322 2.8421709430404007e-14 -79.823650713399388 252.96602044543693 2.8421709430404007e-14 -146.05000000000192
+8 0 0 3 8 186.97488467706268 -59.531249999999993 -107.95000000000199 158.71364076414397 -59.531249999999993 -156.89991034227356 115.80661792501961 -59.531249999999993 -197.39407627900849 61.205427771363695 -59.531249999999993 -224.32015653457702 -5.6843418860808015e-13 -59.531249999999993 -233.80217801408082 -61.20542777136481 -59.531249999999993 -224.32015653457671 -115.80661792502059 -59.531249999999993 -197.39407627900792 -158.71364076414474 -59.531249999999993 -156.89991034227276 -186.97488467706322 -59.531249999999993 -107.95000000000104
+252.96602044543698 -109.6472266284147 -146.05000000000192 214.73021985737074 -109.6472266284147 -212.27634928660441 156.67954189855567 -109.6472266284147 -267.06257378924568 82.807343455374451 -109.6472266284147 -303.49197648795598 -4.3106259302779415e-13 -109.6472266284147 -316.32059378375527 -82.807343455375303 -109.6472266284147 -303.49197648795575 -156.67954189855644 -109.6472266284147 -267.06257378924522 -214.73021985737131 -109.6472266284147 -212.27634928660379 -252.96602044543741 -109.6472266284147 -146.05000000000115
+252.96602044543698 -54.823613314207357 -146.05000000000192 214.73021985737074 -54.823613314207357 -212.27634928660441 156.67954189855567 -54.823613314207357 -267.06257378924568 82.807343455374451 -54.823613314207357 -303.49197648795598 -4.3106259302779415e-13 -54.823613314207357 -316.32059378375527 -82.807343455375303 -54.823613314207357 -303.49197648795575 -156.67954189855644 -54.823613314207357 -267.06257378924522 -214.73021985737131 -54.823613314207357 -212.27634928660379 -252.96602044543741 -54.823613314207357 -146.05000000000115
+252.96602044543698 -2.8421709430404007e-14 -146.05000000000192 214.73021985737074 -2.8421709430404007e-14 -212.27634928660441 156.67954189855567 -2.8421709430404007e-14 -267.06257378924568 82.807343455374451 -2.8421709430404007e-14 -303.49197648795598 -4.3343106881366111e-13 -2.8421709430404007e-14 -316.32059378375527 -82.807343455375303 -2.8421709430404007e-14 -303.49197648795575 -156.67954189855644 -2.8421709430404007e-14 -267.06257378924522 -214.73021985737131 -2.8421709430404007e-14 -212.27634928660379 -252.96602044543741 -2.8421709430404007e-14 -146.05000000000115
+8 0 0 3 8 -186.97488467706319 59.531249999999993 -107.95000000000107 -215.23612858998166 59.531249999999993 -59.000089657729362 -228.85159357669443 59.531249999999993 -1.594434909921091 -224.86966802552743 59.531249999999993 59.154622967793955 -202.47862562032532 59.531249999999993 116.90108900704088 -163.66424025416296 59.531249999999993 165.16553356678384 -113.04497565167392 59.531249999999993 198.98851118893009 -56.522487825836748 59.531249999999993 215.90000000000313 3.836930773104541e-13 59.531249999999993 215.90000000000296
+-252.96602044543738 109.6472266284147 -146.05000000000121 -291.20182103350351 109.6472266284147 -79.823650713398578 -309.62274425082074 109.6472266284147 -2.1571766428347465 -304.23543321100669 109.6472266284147 80.032725191720615 -273.94166995690989 109.6472266284147 158.16029689187798 -221.42808975563167 109.6472266284147 223.45925129623592 -152.94320235226445 109.6472266284147 269.21975043208079 -76.471601176132083 109.6472266284147 292.10000000000315 2.463214817301681e-13 109.6472266284147 292.10000000000298
+-252.96602044543738 54.823613314207357 -146.05000000000121 -291.20182103350351 54.823613314207357 -79.823650713398578 -309.62274425082074 54.823613314207357 -2.1571766428347465 -304.23543321100669 54.823613314207357 80.032725191720615 -273.94166995690989 54.823613314207357 158.16029689187798 -221.42808975563167 54.823613314207357 223.45925129623592 -152.94320235226445 54.823613314207357 269.21975043208079 -76.471601176132083 54.823613314207357 292.10000000000315 2.463214817301681e-13 54.823613314207357 292.10000000000298
+-252.96602044543738 2.8421709430404007e-14 -146.05000000000121 -291.20182103350351 2.8421709430404007e-14 -79.823650713398578 -309.62274425082074 2.8421709430404007e-14 -2.1571766428347452 -304.23543321100669 2.8421709430404007e-14 80.032725191720615 -273.94166995690989 2.8421709430404007e-14 158.16029689187798 -221.42808975563167 2.8421709430404007e-14 223.45925129623592 -152.94320235226445 2.8421709430404007e-14 269.21975043208079 -76.471601176132083 2.8421709430404007e-14 292.10000000000309 2.5579538487363607e-13 2.8421709430404007e-14 292.10000000000292
+8 0 0 3 8 5.6843418860808015e-13 -59.531249999999993 215.90000000000305 56.522487825837722 -59.531249999999993 215.9000000000029 113.04497565167483 -59.531249999999993 198.98851118892955 163.66424025416373 -59.531249999999993 165.16553356678304 202.47862562032583 -59.531249999999993 116.9010890070399 224.86966802552769 -59.531249999999993 59.154622967792839 228.8515935766944 -59.531249999999993 -1.5944349099222208 215.23612858998132 -59.531249999999993 -59.00008965773042 186.97488467706259 -59.531249999999993 -107.95000000000199
+4.5474735088646412e-13 -109.6472266284147 292.10000000000309 76.471601176132808 -109.6472266284147 292.10000000000298 152.94320235226513 -109.6472266284147 269.21975043208039 221.42808975563227 -109.6472266284147 223.45925129623532 273.94166995691029 -109.6472266284147 158.16029689187724 304.23543321100692 -109.6472266284147 80.032725191719763 309.62274425082074 -109.6472266284147 -2.1571766428356085 291.20182103350322 -109.6472266284147 -79.823650713399388 252.9660204454369 -109.6472266284147 -146.05000000000192
+4.5474735088646412e-13 -54.823613314207357 292.10000000000309 76.471601176132808 -54.823613314207357 292.10000000000298 152.94320235226513 -54.823613314207357 269.21975043208039 221.42808975563227 -54.823613314207357 223.45925129623532 273.94166995691029 -54.823613314207357 158.16029689187724 304.23543321100692 -54.823613314207357 80.032725191719763 309.62274425082074 -54.823613314207357 -2.1571766428356085 291.20182103350322 -54.823613314207357 -79.823650713399388 252.9660204454369 -54.823613314207357 -146.05000000000192
+4.5474735088646412e-13 -2.8421709430404007e-14 292.10000000000309 76.471601176132808 -2.8421709430404007e-14 292.10000000000298 152.94320235226513 -2.8421709430404007e-14 269.21975043208039 221.42808975563227 -2.8421709430404007e-14 223.45925129623532 273.94166995691029 -2.8421709430404007e-14 158.16029689187724 304.23543321100692 -2.8421709430404007e-14 80.032725191719763 309.62274425082074 -2.8421709430404007e-14 -2.1571766428356085 291.20182103350322 -2.8421709430404007e-14 -79.823650713399388 252.96602044543693 -2.8421709430404007e-14 -146.05000000000192
+8 0 0 3 8 -186.97488467706319 -59.531249999999993 -107.95000000000107 -215.23612858998166 -59.531249999999993 -59.000089657729362 -228.85159357669443 -59.531249999999993 -1.594434909921091 -224.86966802552743 -59.531249999999993 59.154622967793955 -202.47862562032532 -59.531249999999993 116.90108900704088 -163.66424025416296 -59.531249999999993 165.16553356678384 -113.04497565167392 -59.531249999999993 198.98851118893009 -56.522487825836748 -59.531249999999993 215.90000000000313 3.836930773104541e-13 -59.531249999999993 215.90000000000296
+-252.96602044543738 -109.6472266284147 -146.05000000000121 -291.20182103350351 -109.6472266284147 -79.823650713398578 -309.62274425082074 -109.6472266284147 -2.1571766428347465 -304.23543321100669 -109.6472266284147 80.032725191720615 -273.94166995690989 -109.6472266284147 158.16029689187798 -221.42808975563167 -109.6472266284147 223.45925129623592 -152.94320235226445 -109.6472266284147 269.21975043208079 -76.471601176132083 -109.6472266284147 292.10000000000315 2.463214817301681e-13 -109.6472266284147 292.10000000000298
+-252.96602044543738 -54.823613314207357 -146.05000000000121 -291.20182103350351 -54.823613314207357 -79.823650713398578 -309.62274425082074 -54.823613314207357 -2.1571766428347465 -304.23543321100669 -54.823613314207357 80.032725191720615 -273.94166995690989 -54.823613314207357 158.16029689187798 -221.42808975563167 -54.823613314207357 223.45925129623592 -152.94320235226445 -54.823613314207357 269.21975043208079 -76.471601176132083 -54.823613314207357 292.10000000000315 2.463214817301681e-13 -54.823613314207357 292.10000000000298
+-252.96602044543738 -2.8421709430404007e-14 -146.05000000000121 -291.20182103350351 -2.8421709430404007e-14 -79.823650713398578 -309.62274425082074 -2.8421709430404007e-14 -2.1571766428347452 -304.23543321100669 -2.8421709430404007e-14 80.032725191720615 -273.94166995690989 -2.8421709430404007e-14 158.16029689187798 -221.42808975563167 -2.8421709430404007e-14 223.45925129623592 -152.94320235226445 -2.8421709430404007e-14 269.21975043208079 -76.471601176132083 -2.8421709430404007e-14 292.10000000000309 2.5579538487363607e-13 -2.8421709430404007e-14 292.10000000000292
+8 0 0 19 19 -274.87688738836022 -111.94971943911496 -171.84071215593281 -319.68849308365657 -128.47909263569738 -171.84062651825414 -364.93330292522137 -143.87901990887821 -171.84062729352274 -410.56936435229733 -158.10073562141636 -171.84064786422363 -456.58122113399423 -171.10682776857533 -171.84066303164317 -502.9461751903205 -182.85845060483254 -171.84066601075216 -549.63396068535781 -193.31528368665698 -171.84065946661849 -596.61155705149554 -202.43755318507402 -171.84065005581195 -643.8446426908838 -210.18697927054154 -171.84064396877125 -691.29614058760922 -216.52687175766374 -171.84064401566019 -738.92461174807431 -221.42240042745328 -171.84064901382891 -786.68422655335337 -224.84161036631957 -171.84065528043698 -834.52613553085405 -226.75698855691201 -171.84065907573978 -882.39985099752903 -227.14692654669045 -171.84065855347825 -930.25345424649595 -225.99653446303788 -171.8406543330629 -978.03290768575948 -223.2978715333989 -171.84064889796809 -1025
.6824593235283 -219.05035363693611 -171.84064583593954 -1073.1481934503131 -213.26212372927944 -171.84064916509462 -1120.3824550037175 -205.9514291499265 -171.84065883742238 -1167.3345381169636 -197.14210218568488 -171.8406486850613
+-274.87689543049083 -119.73367071307578 -171.84070119088986 -319.72093217984263 -136.06843813837156 -171.84062753793876 -364.98852469234163 -151.28438717756981 -171.84063367119842 -410.63943149341185 -165.33537266823458 -171.8406498122859 -456.65799963984449 -178.18596323796652 -171.84065955498829 -503.02175426220384 -189.7992626013924 -171.84066188628395 -549.70127409444171 -200.13681461936156 -171.84065832341366 -596.66471792386699 -209.16046411840892 -171.84065352304341 -643.87912294596731 -216.83326565718315 -171.84064681134129 -691.30888503361882 -223.11956180131207 -171.84064650774235 -738.91424599792083 -227.98533357541442 -171.84064542873523 -786.65114210386548 -231.39915410565698 -171.84065239422853 -834.4726113036495 -233.33378462909883 -171.84065616305489 -882.3299637053459 -233.76751680796409 -171.84066075920654 -930.17303644017375 -232.68499671872053 -171.84065818509006 -977.94940039438018 -230.07738616772497 -171.84065082883563 -1025.60472370941
47 -225.94276020066263 -171.84064259857848 -1073.0860795932542 -220.28741303344691 -171.8406452597132 -1120.3461695011017 -213.12724290748909 -171.840663335823 -1167.3345370278648 -204.48359982785576 -171.8406463963733
+-275.42743867618276 -127.104253821437 -171.08977489834598 -320.25688769065107 -143.23626652554492 -171.11777234910281 -365.50303774759749 -158.25419911224205 -171.13693185562471 -411.11466102150513 -172.13993911366913 -171.1734327426297 -457.11295424826062 -184.80111171823611 -171.15783205014523 -503.38438921365213 -196.31144209681267 -171.24417917713518 -550.09567634836719 -206.48217590456412 -171.13863812249679 -596.85147642783818 -215.40776928311038 -171.32100368523274 -644.21623280578672 -223.08650907938744 -171.11823325567218 -691.30148461537181 -229.08964340827083 -171.33965082102787 -739.14362450189265 -234.29565762967741 -171.15392591743688 -786.5134825317532 -237.23304204248225 -171.28451674776124 -834.5170129161412 -239.66484095807792 -171.20603619350456 -882.12776239164998 -239.73748927267138 -171.2269515590603 -930.02782182244027 -239.01166649333774 -171.21156553943345 -977.68989795153482 -236.3256899511307 -171.19275658924889 -1025.3322649408392
-232.39462429197584 -171.1800103571166 -1072.7690154306551 -226.84078082478092 -171.1565855029298 -1120.0106259439874 -219.8512686747456 -171.13433353798115 -1166.9860246545456 -211.37832885782382 -171.10779751374571
+-276.39015652051188 -134.04603212608691 -169.77651176171591 -321.17005870944359 -149.96924767160758 -169.84673194517745 -366.35168897143046 -164.80271379039502 -169.91565211657689 -411.90761989933355 -178.48324520636123 -169.96405982796517 -457.79898306847269 -191.03807828733591 -170.03953022716951 -504.0548141287216 -202.30038166831108 -170.03604631280152 -550.54854692725587 -212.49412406941806 -170.1504349724454 -597.41544937101287 -221.15154876387555 -170.06893401974517 -644.3878816941891 -228.86334815192447 -170.21547226246543 -691.72806355168007 -234.81492404387575 -170.10554884591281 -739.08213798555141 -239.81840456051052 -170.20007330551084 -786.70359570817561 -243.05487252453307 -170.14452154485065 -834.31475142333238 -245.13246197541756 -170.14248757557257 -882.02983600043854 -245.59190937353668 -170.13058577024384 -929.71040245622441 -244.67371128707765 -170.08090570481471 -977.35100454525139 -242.24135742596764 -170.05569753413081 -1024.8834835051
775 -238.341599611785 -169.99723274238139 -1072.2619009724824 -232.96128600448799 -169.94403979939526 -1119.4390549718994 -226.11564641775223 -169.87669543427651 -1166.3654371093417 -217.8212337010587 -169.80420163190163
+-277.65847562448454 -140.57663375077726 -168.02657305847885 -322.35891736087865 -156.29623286573167 -168.15390141040839 -367.45071590382292 -170.93964479711039 -168.27654304863663 -412.91393836070444 -184.44153982018773 -168.36841036680434 -458.69260214949639 -196.83489603634354 -168.49409035456659 -504.86132751956046 -207.96833091370931 -168.50630588393287 -551.18806725293496 -217.98348918347389 -168.68446903205827 -598.02504927582447 -226.67395093687145 -168.56871803665456 -644.72466257764245 -234.03977744026955 -168.80707717129383 -692.13562962187859 -240.3483397555066 -168.61360347315272 -739.12212172865395 -244.77287718144655 -168.8041051302159 -786.85357308555751 -248.59839068411765 -168.65707035655706 -834.12272061752935 -250.12918300150253 -168.70897444460951 -881.87266630960494 -251.07472916191074 -168.63096861993267 -929.32588800959093 -249.91645841000033 -168.58064463328776 -976.91011837060626 -247.74771682453979 -168.50640043798276 -1024.305995850
0035 -243.87201838362876 -168.411624019318 -1071.5965651929505 -238.66005957721279 -168.30642688525197 -1118.6792346216034 -231.95371001041184 -168.18340787394766 -1165.5259840637682 -223.83263113878652 -168.04800169346305
+-279.15406105182581 -146.72789025608753 -165.92317826120004 -323.75074197273307 -162.25136205799993 -166.11854429133652 -368.73404348211301 -176.70130828880653 -166.29722529418174 -414.07073284882659 -190.05073592134406 -166.45709479262325 -459.74545087204586 -202.24026153795464 -166.59865324622882 -505.73901545593884 -213.32727269775262 -166.71395287408112 -552.00603716099852 -223.06385405817912 -166.82034922234709 -598.58138888430994 -231.8758253646233 -166.87580192021863 -645.29187780671054 -238.89450485789791 -166.95966445564855 -692.37422505402208 -245.41023647598229 -166.94061225115564 -739.38627783855043 -249.58200390010057 -167.00354671017095 -786.81629094308744 -253.53463268674216 -166.92240215411579 -834.04605038974898 -255.01420706229021 -166.93523771008867 -881.57881108744812 -256.00517712093131 -166.8235277838823 -928.92740805305959 -254.92020322056885 -166.76015463694051 -976.35620208096702 -252.81646269882367 -166.62581880196359 -1023.628763610
1426 -249.05741280094244 -166.49163660346906 -1070.7940316815384 -243.96481065647421 -166.32184672844701 -1117.7628808079528 -237.40556298123352 -166.13380669475686 -1164.5037209934846 -229.44576298032752 -165.92322388710852
+-280.82170220357955 -152.53557839760234 -163.52017375972704 -325.29572779075249 -167.86827438959671 -163.79041738175525 -370.15116408807131 -182.13327878898153 -164.03190651833492 -415.34551207060025 -195.32662906366417 -164.26439741195338 -460.89468583102433 -207.34234747241754 -164.42856627660922 -506.70164679150287 -218.32563526756599 -164.64891312255287 -552.88944764893108 -227.9154822376538 -164.68676204690726 -599.17881265669291 -236.61897444323756 -164.92287852822099 -645.9154328758525 -243.65481127029062 -164.83305195398111 -692.59016055143604 -249.88839759388082 -165.02802813764421 -739.70684531075233 -254.37888015680346 -164.90612787505847 -786.70575371215523 -257.87897690431737 -164.9567943931913 -833.99287333972529 -259.81005191785795 -164.86213298674556 -881.19817826819019 -260.46107152114956 -164.76807900742841 -928.49104361146999 -259.69330300178376 -164.64924093103519 -975.70769942251104 -257.50958197189647 -164.47215790189537 -1022.8582920466
409 -253.92727687743439 -164.28110797281954 -1069.8708183771473 -248.91924307722587 -164.04439004849633 -1116.7088306956337 -242.50826651764257 -163.78167699789327 -1163.3220545477841 -234.69827182705001 -163.4876306394421
+-282.62388459051726 -158.0343564927781 -160.85023455750976 -326.95958347014056 -173.18081496594999 -161.19965812984279 -371.66858033185412 -187.27371170000094 -161.51351740527127 -416.71333962885183 -200.29774497658369 -161.81066081218032 -462.10260796438672 -212.18938146824212 -162.03080609954088 -507.74925232864024 -222.98418848828138 -162.30140717207794 -553.77194902334782 -232.58056009653805 -162.37006395931365 -599.87186364597528 -240.96532239280833 -162.65329538472085 -646.47635252399323 -248.27456511592763 -162.55007485536629 -692.89523035422837 -253.97219759761552 -162.80504004436972 -739.94153366293779 -258.98953509469243 -162.61927292697916 -786.63340299106824 -261.90078650319958 -162.72882252895232 -833.86393680668891 -264.34235255606706 -162.55069868375375 -880.79161741450457 -264.63932600704339 -162.47594260347691 -927.97971592625026 -264.17098999123226 -162.28292146843864 -974.98583395918831 -261.91809760735902 -162.07380051086892 -1021.99218659
1556 -258.49408461002218 -161.81187828252351 -1068.837993465927 -253.56886003498275 -161.5075129512403 -1115.5272708462865 -247.29526497290243 -161.16240223553595 -1161.9950127692612 -239.62667881846656 -160.77893981393427
+-284.53583936423911 -163.25546706573562 -157.9300104148405 -328.71889228987067 -178.22117176005264 -158.3622774416942 -373.26573916744684 -192.15152739149161 -158.75694152590771 -418.152362984869 -205.0034475879923 -159.11111145942479 -463.35506746320385 -216.79243521238791 -159.41864900909493 -508.85992412937611 -227.3796062837483 -159.68509726527981 -554.6436288137686 -237.00416668199867 -159.88697866604031 -600.6475560012799 -245.08834489339995 -160.07002956781088 -646.95233176437614 -252.58299740987755 -160.14445929260353 -693.30442289866664 -257.94145975436828 -160.25369422606224 -740.04413280598885 -263.18145809251831 -160.19494812859017 -786.63653422949051 -265.87326116968433 -160.21323994690641 -833.61284567245036 -268.45170794069878 -160.0487907492101 -880.38741442835396 -268.70081328697142 -159.93800387502529 -927.37126709555059 -268.30964445840453 -159.69189112197267 -974.20128775501894 -266.11088808219944 -159.43994702472398 -1021.0271808184125 -2
62.77376425283177 -159.10536907405086 -1067.7006414103435 -257.9509516740585 -158.72939630076948 -1114.2227188403758 -251.79659141790628 -158.29731136277127 -1160.529575233141 -244.26306231206951 -157.81972791813124
+-286.54147951824177 -168.22558986543862 -154.76342801152134 -330.55782747870006 -183.01770054084008 -155.28301529913998 -374.93037250868946 -196.78890302400296 -155.7626721719943 -419.64375975957597 -209.48276600357636 -156.17729265796427 -464.65283936797562 -221.15010294586514 -156.57652930054903 -509.99621938947666 -231.59093322219553 -156.83859335602179 -555.53785381030866 -241.12831906674953 -157.18357268947562 -601.43402333115944 -249.12686365935633 -157.25258573207952 -647.41019465796148 -256.47919065519761 -157.53380160636081 -693.7316080246062 -261.94013728004063 -157.45610864568525 -740.0778462432354 -266.8904801644523 -157.5789584300525 -786.65510668071011 -269.87566863046879 -157.44584581197074 -833.27030764821291 -272.14083777061143 -157.35086415754023 -879.96104376846313 -272.6755200955534 -157.15736691245698 -926.67216232828571 -272.13767605494661 -156.88765647281511 -973.3477272634334 -270.11006592736959 -156.57261466619076 -1019.9632122090026
-266.79427978250851 -156.17186886508577 -1066.4579410692925 -262.09030373058573 -155.71769000552138 -1112.7958384026424 -256.03846079706983 -155.19679716231406 -1158.9273215266001 -248.63325650010182 -154.62129973691384
+-288.63032477011615 -172.96587406139554 -151.34388908104245 -332.46608846057325 -187.59220689730495 -151.95638468201432 -376.65372025226407 -201.2050269871313 -152.52168947849006 -421.17594055884712 -213.76109123901605 -153.01048043124808 -465.99331323825828 -225.27471364260566 -153.48170577622091 -511.13675472152079 -235.64963861438866 -153.78772775499493 -556.4718587242503 -244.96640076099786 -154.20351167749308 -602.18189391239059 -253.09073710954195 -154.26444237163088 -647.9039364065776 -260.02555935838598 -154.63350523028313 -694.09413151553611 -265.90501145579782 -154.48576433720535 -740.11746170696074 -270.25321889155987 -154.70158977786977 -786.60948740465517 -273.79665315343863 -154.46905994516308 -832.8884991595404 -275.5491256484836 -154.42620733610414 -879.46875543192903 -276.49089390012529 -154.14466095414096 -925.90005429532664 -275.73321740716062 -153.86309804974161 -972.40981874348847 -273.90307003176696 -153.4720483515714 -1018.8011003410504
-270.58906331841149 -153.01088035339933 -1065.1048061523552 -266.00071653996065 -152.4730927448806 -1111.2441576351134 -260.04166808471859 -151.86276709151798 -1157.1856198328603 -252.75600901312686 -151.18677136189373
+-290.79528634542521 -177.49065541216544 -147.65576112779485 -334.43691202468773 -191.9585040966823 -148.36739415910273 -378.42827275691701 -205.41588754902008 -149.01852621148109 -422.74352815343758 -217.84699309539593 -149.59847355830195 -467.36735348976879 -229.19560174977121 -150.11468619040406 -512.27768199563047 -239.53430783248814 -150.5313851295559 -557.43812208083682 -248.60235386802668 -150.91048061145429 -602.88051206846546 -256.8738376920341 -151.13059182586755 -648.44043904311798 -263.41150035438375 -151.38012389446092 -694.36093480209013 -269.62648277227856 -151.39131346916989 -740.19192968757829 -273.52576744572713 -151.49188896542631 -786.45315044915276 -277.42109774603551 -151.32397595253855 -832.4992589638905 -278.87278092784931 -151.2273862465577 -878.87480616529115 -280.03302642677687 -150.91499158434925 -925.06810515331631 -279.18298475917641 -150.59696893055693 -971.3711627506284 -277.46488347392801 -150.13726842660134 -1017.5395495385585
-274.1860255899681 -149.61365485614419 -1063.6335666430132 -269.68847869263288 -148.99134259868407 -1109.5623545451433 -263.81976788313153 -148.29103177320027 -1155.2985407217363 -256.64265658716226 -147.51357808966779
+-293.03102820270067 -181.80567347554492 -143.67534227814713 -336.46526349409226 -196.12130252900752 -144.49214924069389 -380.24690758811477 -209.43120877694179 -145.23327484332293 -424.3444446575034 -221.73652845652728 -145.91283523456914 -468.76034795273091 -232.94313464133555 -146.4699770501413 -513.42883099253254 -243.20294686582781 -147.01995740719613 -558.4055687494573 -252.12600981537895 -147.33222143293489 -603.55450058102451 -260.35883254634712 -147.76895756561026 -648.98177925644347 -266.80080771429039 -147.82650064600051 -694.54987822915552 -272.93754245829871 -148.09091728389248 -740.28058261243632 -276.87802597080486 -147.9802684430343 -786.18258270521574 -280.62040278942953 -147.97038356296696 -832.09844835261833 -282.21260416128251 -147.74643310862061 -878.16660429416572 -283.24847817829715 -147.45767159043322 -924.17345531365299 -282.52345910321463 -147.07100289672894 -970.22111032752514 -280.78575849523554 -146.56097260802773 -1016.17221267418
1 -277.59555083252678 -145.96736983413339 -1062.0355957838547 -273.15598675666052 -145.26428528008228 -1107.7424145379898 -267.37746090880495 -144.47350705861894 -1153.2576446388082 -260.2969978150818 -143.59558314210517
+-295.33254266738447 -185.90574548537347 -139.37139503538353 -338.5459203585151 -200.0753871593958 -140.29902086402302 -382.1028351500467 -213.24939532600808 -141.14040078694916 -425.97490718694206 -225.42073584514236 -141.91484539010409 -470.15950743919075 -236.5265559670033 -142.54388710219277 -514.59613235182371 -246.63287805404013 -143.18231592265988 -559.3436962286255 -255.56203521828672 -143.51601264223007 -604.23336100914184 -263.51779443860067 -144.05644688622229 -649.46955516432024 -270.20475357700496 -144.06438226751453 -694.71322315584996 -275.8460298671763 -144.44976775854312 -740.31432198140214 -280.27327782902842 -144.23942738954349 -785.84255997281809 -283.44392419782906 -144.32358450817298 -831.6380254101382 -285.51193698649195 -144.00180101553016 -877.36075626145646 -286.1800101324759 -143.73853129948614 -923.19314737030606 -285.72122726475891 -143.27475541395555 -968.95711794660099 -283.87983690098451 -142.72748932796534 -1014.6869027033896 -
280.80644965504621 -142.05869177154261 -1060.3021129644821 -276.40269080842984 -141.28064277555697 -1105.7740770216431 -270.7099762211887 -140.40031247287072 -1151.0527551370978 -263.71516179021455 -139.42492787568514
+-297.69357598042569 -189.77182735841274 -134.70538520753743 -340.67168766871794 -203.80364336489964 -135.75027109727566 -383.98888543196756 -216.85334188202185 -136.70562982492237 -427.62564092014799 -228.88873400595543 -137.56549381741632 -471.55807084989709 -239.92073558303898 -138.31417667211525 -515.76903110514422 -249.83931068429141 -138.96472742129808 -560.24216024225166 -258.83936398981029 -139.46991665741112 -604.91598340747635 -266.44402838844297 -139.90702814851414 -649.87412026284835 -273.45222733992341 -140.13944352253924 -694.87515475022917 -278.54926699240389 -140.36134764750364 -740.23795771671234 -283.46810877382916 -140.32098970562177 -785.47238194411477 -286.10347205291328 -140.2983101040833 -831.06312298418743 -288.57762961178366 -140.01572986484106 -876.48073132343768 -288.94448197406479 -139.71105048864982 -922.09528432921991 -288.68891746153355 -139.20399729795054 -967.57993368060852 -286.77466898473847 -138.614110158822 -1013.0677860386
24 -283.79054418530825 -137.87563640617873 -1058.4240579848235 -279.42292177902505 -137.02722004382665 -1103.6456819140767 -273.803523968268 -136.06150733676128 -1148.6727933798472 -266.88539098680832 -134.99373072214794
+-300.10461291463218 -193.36719841573077 -129.63173205605028 -342.8315651275966 -207.27352303471093 -130.80329425175913 -385.89520584317756 -220.20774201299875 -131.88351911277795 -429.28111702798645 -232.12293048078769 -132.83389253343688 -472.95171054849084 -243.07013285256244 -133.72131869961888 -516.92112622408786 -252.8558569774728 -134.37011628747052 -561.10808922449303 -261.82685217573646 -135.0963175580963 -605.56750398499912 -269.28069794143659 -135.37070098341354 -650.20041327497074 -276.29726830690879 -135.92864782918519 -695.01636655374739 -281.28650348113007 -135.87947261226302 -740.03169489435004 -286.17851879063829 -136.13719472665949 -785.07737216480132 -288.8086531967777 -135.90136590460094 -830.33954085603671 -291.215326425184 -135.75492982006696 -875.5336396350566 -291.63588546105728 -135.35110829606293 -920.85418844312346 -291.34222986431087 -134.84571245542338 -966.08537027112379 -289.48151119685321 -134.19890711976274 -1011.2994522151824
-286.51492810920473 -133.40657947532563 -1056.3912345533713 -282.20114531299373 -132.49100008226728 -1101.3453915637913 -276.6366275785096 -131.44842642105755 -1146.1067113877748 -269.787775814263 -130.29571777748498
+-302.55027936875945 -196.63214480646297 -124.09867377195116 -345.00878809130762 -210.43085157350311 -125.41080151011678 -387.80531893574806 -223.25836012175242 -126.61948707979882 -430.92113037747998 -235.08386037329655 -127.6938294717588 -474.32791280719306 -245.91219895084063 -128.67780053880304 -518.02283684533188 -255.67410511266675 -129.44236136645196 -561.94298936484859 -264.43417621645398 -130.21711499624141 -606.14074420511167 -272.05534131292711 -130.6036670075614 -650.46846418835707 -278.63761024502935 -131.17020640292952 -695.07801865587794 -284.0781061087086 -131.19930271915885 -739.71888014212323 -288.34059146742419 -131.46647105012423 -784.60845263498106 -291.5352304410597 -131.24163690969576 -829.47551477024581 -293.40309923110266 -131.11486062108622 -874.4901409641601 -294.20936992188877 -130.6749500927767 -919.46365761920197 -293.66447251100561 -130.16663281691447 -964.45651307731998 -291.96287915857414 -129.46935460371637 -1009.370818234104
-288.95486768158133 -128.63803231951098 -1054.1914258773397 -284.70711695138061 -127.66188475084866 -1098.8624703660591 -279.18149824535084 -126.55469086998417 -1143.3445177916442 -272.39409662133403 -125.32787458551151
+-305.00624771570477 -199.47598730771287 -118.05077872487934 -347.17809328300928 -213.19116244047339 -119.51897960268985 -389.69199766363192 -225.92910689512476 -120.86179015612063 -432.52073770346897 -237.69336887095687 -122.09558946300646 -475.65639135874301 -248.39670715508728 -123.13584561419917 -519.0511281584744 -258.19009008960933 -124.13899167676438 -562.72017920196015 -266.68840193148992 -124.7832428957051 -606.60042644865564 -274.56118704150731 -125.58152224711722 -650.68086402926122 -280.65072274196126 -125.80127487092584 -694.98802482861754 -286.57762543207934 -126.32465283536213 -739.34274307013811 -290.23734434237923 -126.23324898282306 -783.97285108190476 -293.92413986084955 -126.33666140541574 -828.51597127298203 -295.35422639070833 -126.0326000177779 -873.28341218294918 -296.44402735986114 -125.6892982161248 -917.93777997269797 -295.72226655405825 -125.13199865420822 -962.66209212884462 -294.12512387605409 -124.42021305239054 -1007.27585142119
72 -291.09552735984016 -123.55572286368255 -1051.8104588332285 -286.89502685927448 -122.53479280755825 -1096.1881116070658 -281.40421706802744 -121.37745141352976 -1140.3783307323024 -274.66804642777186 -120.09228887079669
+-307.43603165705963 -201.76460214271575 -111.43468754876397 -349.30237258689334 -215.42653140485939 -113.06868003954642 -391.51352614221599 -228.11609034153105 -114.57523888129914 -434.04760022890764 -239.8135528736658 -115.94122388213175 -476.88233380650672 -250.50061507366703 -117.15486011098942 -519.99475837733303 -260.15943500128378 -118.20661412751234 -563.3613140126979 -268.77188059293593 -119.08938010168092 -606.95783535979717 -276.31902031667721 -119.79825113036223 -650.75930312133016 -282.78091158574961 -120.33009537857801 -694.73949645057883 -288.13666784115378 -120.68307429124538 -738.87059305812465 -292.36479704127652 -120.85623831738249 -783.12290288420377 -295.44367390019954 -120.84925225426473 -827.46457937649279 -297.35214389149894 -120.66232927219782 -871.86149717112733 -298.07011826711766 -120.29637592287433 -916.27707982047218 -297.57923519198022 -119.75336029960069 -960.67231850589008 -295.86355002363877 -119.03685765431705 -1005.005919001
5718 -292.91035683392221 -118.1527024729882 -1049.234807339968 -288.71111482643607 -117.10963260273053 -1093.3150452231505 -283.26236759440428 -115.91975654559899 -1137.2032898211221 -276.56622702286194 -114.59854612020514
+-309.78843542165504 -203.30071871020056 -104.21035402633338 -351.32682673173264 -216.95911893096147 -106.02351146323429 -393.21758022323519 -229.64039633093631 -107.70197092189674 -435.43815106938808 -241.32529955413222 -109.23089566500914 -477.96509807912111 -251.99605017103431 -110.59702354546528 -520.77439092287398 -261.63564364049728 -111.78959393289615 -563.8414969076747 -270.22702217583264 -112.80056668457216 -607.14129261965434 -277.75244628593714 -113.62440421670533 -650.64784922289891 -284.19319030100087 -114.25762857408408 -694.33413909928731 -289.52956082954842 -114.69831678410007 -738.17170752377933 -293.74117173617492 -114.94565728820807 -782.13034782669104 -296.80739075191514 -114.99965538390028 -826.1778136906488 -298.70788699589997 -114.86104383378957 -870.27959935176909 -299.4232411397964 -114.53142351061675 -914.3988182405858 -298.93561593887824 -114.01362652974376 -958.49621348253879 -297.22950922210691 -113.31226403658852 -1002.53034293278
57 -294.29260832046498 -112.43440763793781 -1046.4580068705322 -290.11671693663777 -111.39038195851553 -1090.2350546661914 -284.698610137358 -110.19471288544827 -1133.8179128028266 -278.04044934552792 -108.86726666671444
+8 0 0 7 5 -309.78843540966716 -195.40683228639682 -104.2103540631517 -310.02293610882492 -195.61649367693423 -103.49019229246917 -310.25545286292714 -195.81421813519194 -102.76617629847468 -310.48587793622721 -195.99980297750787 -102.03850117763828 -310.71410231934794 -196.17304467643444 -101.30736697321541 -310.9400159218917 -196.33373964713471 -100.57297897111363
+-309.638159749078 -197.23535506427714 -104.67185710321915 -309.88156625385858 -197.44402944122237 -103.92943769234809 -310.12282405710079 -197.64058470890896 -103.18306130914027 -310.36182224815497 -197.82481853503893 -102.43292578901864 -310.59844899456647 -197.99652786382308 -101.67923281513632 -310.83259166177231 -198.15550952005086 -100.92218808162499
+-309.88492271052507 -199.06387784316118 -105.26264475463886 -310.13467877958971 -199.27156531455654 -104.49570831315815 -310.38219062962986 -199.46695149299603 -103.72475593114692 -310.62734606164634 -199.64983433485949 -102.94998827734194 -310.8700323305705 -199.82001123244481 -102.1716084206561 -311.11013619393276 -199.97727939930718 -101.38982190415815
+-310.5374969776384 -200.78551791125903 -105.95573705527222 -310.79045800384591 -200.99307416681575 -105.16352345366589 -311.04117158153633 -201.18813378281706 -104.36725467957403 -311.28953202025542 -201.37051117685621 -103.56715460552222 -311.53540678066548 -201.53997375184059 -102.76339089824978 -311.77869657572285 -201.6963311568129 -101.95618768496952
+-311.5699311651955 -202.29332980718351 -106.71282959672202 -311.82285786351969 -202.50248372598926 -105.89638163362162 -312.0736261161781 -202.69892200575683 -105.07582522669313 -312.32211015355693 -202.88242747813581 -104.25135295879505 -312.56821985651163 -203.05282454973397 -103.42321092012835 -312.81183657544437 -203.20989180953845 -102.59158859939325
+-312.91983400027681 -203.49619459604827 -107.4881703417654 -313.16996059632066 -203.70926798173747 -106.65032682333336 -313.41809171053279 -203.90937915785099 -105.80827360254519 -313.66411696176704 -204.09631869666362 -104.96222971501115 -313.90792650421406 -204.26987782429677 -104.11241183376397 -314.14941099475902 -204.42984802755822 -103.25903419692642
+-314.49861099167993 -204.33376994774403 -108.23606625882728 -314.74409524341081 -204.55323773809963 -107.38117669171795 -314.98778933998824 -204.75947573653198 -106.52190361543192 -315.22958507227486 -204.95226665251653 -105.65847792838142 -315.46937500938702 -205.13139458683727 -104.79112709216864 -315.70705247713283 -205.29664440532443 -103.92007497036968
+-316.20643815364701 -204.7799632831003 -108.91672863601242 -316.44650053897624 -205.00799258105653 -108.0501217353475 -316.684980422693 -205.22252443519886 -107.17887935483917 -316.92177285913164 -205.4233299383408 -106.30324647768508 -317.15677382223839 -205.61018242650161 -105.42346415393793 -317.38988019336449 -205.78285668776229 -104.53976920003481
+8 0 0 8 10 -309.78843825184066 -195.40683554247929 -104.21035585324884 -306.79940777454573 -192.7342321189457 -113.38979684553559 -303.52290483565531 -188.33838763545199 -122.01482760372051 -300.11378234986734 -182.50046532951472 -129.83029844028346 -296.74162182167026 -175.5619699255854 -136.744446326081 -293.52693037017974 -167.67742022719204 -142.7766563546478 -290.60836293192568 -159.01633891935919 -147.87114421310346 -288.12340079086658 -149.64102798294996 -151.97438329033983 -286.25703316904452 -139.63693106647753 -154.95362204791721 -285.26768795752696 -129.21818042464182 -156.53412216112531 -285.26768282411314 -118.80075657039086 -156.53413046669147
+-309.65695002083908 -197.00679595927855 -104.61417282244714 -306.5685425003212 -194.34521801769444 -114.04188952207167 -303.17183398390034 -189.93757412731259 -122.9022117950819 -299.62586892386435 -184.06403719313954 -130.93843749573537 -296.10474189141036 -177.06514943285001 -138.06024020270871 -292.73233782370664 -169.08953174402191 -144.29091380805855 -289.6519913917719 -160.29231480015829 -149.57813738218013 -287.0065416241643 -150.7333675726922 -153.86402905865947 -284.98550642693482 -140.45993772370599 -157.02261937811974 -283.88839784652174 -129.66464827995907 -158.73719020108328 -283.85470005730917 -118.80075924973931 -158.79101375780368
+-309.82324200664073 -198.60675669714399 -105.11495374663804 -306.65989827068051 -195.95620482315951 -114.81257139431955 -303.17498980676891 -191.53676000285668 -123.93455005089726 -299.52974401985995 -185.62766261999792 -132.22274823172737 -295.90100443279243 -178.56814021428724 -139.58824931795792 -292.41461918657143 -170.50198773728221 -146.0567652615386 -289.21741931765422 -161.5679470828911 -151.57851805041579 -286.45732627663756 -151.82590367948788 -156.08949546164359 -284.32691925012 -141.28289292291115 -159.46813623507987 -283.16314743864655 -130.11111613634637 -161.34973762154056 -283.12850969968173 -118.8007619290878 -161.47788203039045
+-310.29279476507986 -200.13991152092638 -105.69583410953841 -307.08362737586469 -197.49354209180609 -115.67299875902823 -303.54910825001548 -193.05433173061022 -125.06886137971826 -299.85121489779499 -187.10132563889945 -133.6231595169414 -296.16831560229514 -179.97325197624571 -141.24793699583438 -292.62735612091637 -171.8108116828279 -147.96974711356367 -289.3774115379025 -162.73837339365184 -153.74011886967318 -286.5707905078911 -152.81769426910756 -158.48831072730101 -284.40190185030798 -142.02199415635528 -162.09341727462876 -283.23367961042783 -130.50934851253268 -164.14538717745467 -283.24177064400726 -118.80076431896485 -164.35090803710236
+-311.0537201002785 -201.53941938083318 -106.33428402420074 -307.82943594835655 -198.88353056909304 -116.5868532582171 -304.28615123960037 -194.40860518651164 -126.25216459818122 -300.58560959146865 -188.39492023093476 -135.06614403469874 -296.90687818216236 -181.18273644578537 -142.94068435094508 -293.37758282151083 -172.91191366820345 -149.90129461665649 -290.1478824216772 -163.6987334793622 -155.89928273512032 -287.37335240869606 -153.60775212616815 -160.85776521020074 -285.24951924026385 -142.59345657330726 -164.65172951814984 -284.14780483613112 -130.81112201454235 -166.83899644524303 -284.24333667329694 -118.80076612997154 -167.10135958350745
+-312.07614116940402 -202.74438835574628 -107.0035768122432 -308.86545084288809 -200.05961070717825 -117.51301180061623 -305.35135387650348 -195.52664205011095 -127.42581248607181 -301.69462531671104 -189.42908036743501 -136.4714158756733 -298.07427929884773 -182.11184504148528 -144.55982267100626 -294.61824084644644 -173.71683769978651 -151.71333721265697 -291.47646108206806 -164.36171962201925 -157.88167810928076 -288.80620982140766 -154.11422334093112 -162.98334162063105 -286.80332868355305 -142.93122340777126 -166.8847968288336 -285.82853793348892 -130.97905824603848 -169.13459002557127 -286.043101693898 -118.80076713779218 -169.40981449768125
+-313.31452285215556 -203.70557544819854 -107.67513893429675 -310.14089550888167 -200.96916694184137 -118.40943455065171 -306.68639996336253 -196.35252625845291 -128.53156016072833 -303.10998869622608 -190.14542368205301 -137.7611842016762 -299.58954134756351 -182.70138597674219 -146.00451793758893 -296.25248173427582 -174.16833876790551 -153.2787317987322 -293.24681462316738 -164.67523301039884 -159.53197195770971 -290.72966385958068 -154.29414210792172 -164.68011640012202 -288.89521192944721 -143.00550753567722 -168.58021346641917 -288.07835497325226 -130.99804880276793 -170.79853250167889 -288.41814241714405 -118.80076725175797 -171.03039712120912
+-314.71208561862443 -204.38953636763728 -108.32114566471583 -311.59146290155951 -201.57834136953684 -119.2371963359747 -308.21623130897115 -196.85300654697645 -129.51760503103333 -304.74247728725385 -190.5130025496143 -138.86901021474225 -301.34544758482775 -182.92485754191787 -147.19245025991327 -298.15067809641835 -174.24761377336955 -154.49919533831414 -295.3022954496372 -164.62929129710903 -160.73800717794927 -292.95530246498282 -154.14879113044083 -165.82474099235381 -291.29960236710951 -142.82563089953743 -169.61111553033686 -290.63641994077773 -130.87628522953139 -171.70542707252892 -291.08085657987874 -118.80076652102827 -171.84068524115366
+-316.20643612917337 -204.77995943860239 -108.91672690359877 -313.14627347795641 -201.87325046549111 -119.96358682453244 -309.85799625667289 -197.01841110676284 -130.34283569124273 -306.49361632869153 -190.52864205028081 -139.74549144009268 -303.22396178258151 -182.78790678286026 -148.06714178687773 -300.1709205421966 -173.97193947631848 -155.31434776600543 -297.47313996001134 -164.25186153349105 -161.44075398218138 -295.28171513788851 -153.71661711905449 -166.36554430275751 -293.78009071594613 -142.43146799987045 -169.94319216265518 -293.23564142193169 -130.63936447650835 -171.8406732716131 -293.74356994954235 -118.80076509921588 -171.84068273570816
+8 0 0 19 1 -274.87688738836022 -111.94971943911496 -171.84071215593281 -274.87688738836022 0 -171.84071215593281
+-319.68849308365657 -128.47909263569738 -171.84062651825414 -319.68849308365657 0 -171.84062651825414
+-364.93330292522137 -143.87901990887821 -171.84062729352274 -364.93330292522137 0 -171.84062729352274
+-410.56936435229733 -158.10073562141636 -171.84064786422363 -410.56936435229733 0 -171.84064786422363
+-456.58122113399423 -171.10682776857533 -171.84066303164317 -456.58122113399423 0 -171.84066303164317
+-502.9461751903205 -182.85845060483254 -171.84066601075216 -502.9461751903205 0 -171.84066601075216
+-549.63396068535781 -193.31528368665698 -171.84065946661849 -549.63396068535781 0 -171.84065946661849
+-596.61155705149554 -202.43755318507402 -171.84065005581195 -596.61155705149554 0 -171.84065005581195
+-643.8446426908838 -210.18697927054154 -171.84064396877125 -643.8446426908838 0 -171.84064396877125
+-691.29614058760922 -216.52687175766374 -171.84064401566019 -691.29614058760922 0 -171.84064401566019
+-738.92461174807431 -221.42240042745328 -171.84064901382891 -738.92461174807431 0 -171.84064901382891
+-786.68422655335337 -224.84161036631957 -171.84065528043698 -786.68422655335337 0 -171.84065528043698
+-834.52613553085405 -226.75698855691201 -171.84065907573978 -834.52613553085405 0 -171.84065907573978
+-882.39985099752903 -227.14692654669045 -171.84065855347825 -882.39985099752903 0 -171.84065855347825
+-930.25345424649595 -225.99653446303788 -171.8406543330629 -930.25345424649595 0 -171.8406543330629
+-978.03290768575948 -223.2978715333989 -171.84064889796809 -978.03290768575948 0 -171.84064889796809
+-1025.6824593235283 -219.05035363693611 -171.84064583593954 -1025.6824593235283 0 -171.84064583593954
+-1073.1481934503131 -213.26212372927944 -171.84064916509462 -1073.1481934503131 0 -171.84064916509462
+-1120.3824550037175 -205.9514291499265 -171.84065883742238 -1120.3824550037175 0 -171.84065883742238
+-1167.3345381169636 -197.14210218568488 -171.8406486850613 -1167.3345381169636 0 -171.8406486850613
+8 0 0 8 12 -309.78843540950083 -203.30071870226513 -104.21035406366235 -310.52914727135419 -203.78440257587008 -101.93559595813468 -311.24070386885188 -204.25575524539352 -99.663853806702747 -311.92357930627918 -204.71490663178449 -97.395159230131156 -312.57823455083769 -205.16198496993292 -95.129542458118593 -313.20511796409806 -205.59711681107845 -92.867032392589735 -313.8046658034001 -206.02042702797314 -90.60765666849656 -314.37730269516356 -206.43203882249446 -88.351441712174704 -314.92344208194589 -206.83207373543053 -86.098412797307361 -315.44348664496425 -207.22065165818304 -83.848594098554372 -315.93782870368608 -207.59789084615605 -81.602008742909121 -316.40685059398669 -207.96390793361891 -79.3586788588497 -316.8509250262718 -208.31881794985134 -77.118625623353978
+-408.44211372167547 -235.7394223154067 -108.51656988974794 -408.91874156831568 -236.23712887252583 -106.15535821862657 -409.36783671381636 -236.7197743754908 -103.79779457431343 -409.78984075189118 -237.18757556997286 -101.44391302113775 -410.18518316736549 -237.6407437539452 -99.093745711354487 -410.55428182203644 -238.07948500949993 -96.747322995180483 -410.89754341321435 -238.50400041809746 -94.404673523373816 -411.21536390670565 -238.91448626092995 -92.065824342991078 -411.50812894588853 -239.31113420588662 -89.730800986894351 -411.77621423843004 -239.69413148243652 -87.399627557522678 -412.01998592209702 -240.06366104559416 -85.072326805392862 -412.2398009110189 -240.41990172999948 -82.748920202749574 -412.43600722367319 -240.7630283950252 -80.429428012745007
+-509.24720071456915 -262.21064090687588 -112.00398108336306 -509.43950628719313 -262.73243425528716 -109.55918447701511 -509.60625679041254 -263.23637401839005 -107.1186823708378 -509.74785237698643 -263.722768527119 -104.68251118205148 -509.86468245050855 -264.19191658923421 -102.25070486498491 -509.95712608861572 -264.64410797631206 -99.823295072660827 -510.02555244271252 -265.07962387229486 -97.400311305303674 -510.07032111568805 -265.49873728754125 -94.981781047075089 -510.0917825190175 -265.90171344187513 -92.567729892200333 -510.09027821056179 -266.28881011973704 -90.15818166152188 -510.06614121430164 -266.66027800019538 -87.753158510403438 -510.01969632316673 -267.0163609642637 -85.352681028807808 -509.9512603860494 -267.35729638169829 -82.956768334283197
+-611.81594590816087 -282.38032312586131 -114.39250372827716 -611.70611114653661 -282.93239000674657 -111.86931389238514 -611.57302700663547 -283.46392933051749 -109.35107517788627 -611.4170441829524 -283.97533994775733 -106.83782557771298 -611.23850427163461 -284.46700714006943 -104.3296001081097 -611.03774011639894 -284.93930336212952 -101.8264310201351 -610.81507613570852 -285.39258892333373 -99.328347992516342 -610.57082863233666 -285.82721261525705 -96.835378307834333 -610.30530608639936 -286.24351229044646 -94.347547013795577 -610.01880943287927 -286.64181539745033 -91.864877071148712 -609.71163232461447 -287.02243947644456 -89.387389489627935 -609.38406138166852 -287.38569261932548 -86.915103453149811 -609.03637642794763 -287.73187389771078 -84.448036435351938
+-715.70508605939642 -296.00766836846685 -115.57715938061038 -715.28210172683657 -296.59160726612288 -112.98226121287689 -714.83837554630452 -297.1526879564895 -110.39297750469764 -714.37420456184373 -297.69139015980693 -107.80934611619618 -713.8898784997325 -298.2081765520731 -105.23140155377175 -713.38568003143837 -298.70349371993558 -102.65917521966945 -712.86188502286643 -299.17777303709721 -100.0926956385165 -712.3187627706717 -299.63143147033361 -97.53198866335164 -711.75657622639471 -300.06487232232053 -94.977077663384975 -711.17558220914248 -300.47848591765711 -92.427983695468328 -710.57603160751057 -300.8726502377645 -89.884725661028085 -709.95816957141005 -301.24773150970037 -87.347320450010017 -709.32223569442681 -301.60408475337039 -84.815783073206987
+-820.48854529918901 -302.72191885517935 -115.56218437390983 -819.74900369706916 -303.33731329719132 -112.90306795260423 -818.99127438648065 -303.92802025352194 -110.25022956888196 -818.21560120729441 -304.4945851530685 -107.60370487628616 -817.42222239667115 -305.03753383659068 -104.96352598964295 -816.61137077415322 -305.5573736540191 -102.3297217545711 -815.78327391766925 -306.05459447176418 -99.702317991495605 -814.93815433091049 -306.52966959933718 -97.081337717031403 -814.07622960254878 -306.9830566435549 -94.466801345268422 -813.19771255775174 -307.41519829765934 -91.858726871192587 -812.30281140244199 -307.82652307186856 -89.257130038214896 -811.39172986073436 -308.2174459711382 -86.662024491547754 -810.46466730596501 -308.58836912526664 -84.07342191896258
+-925.61317617241252 -302.09510597814835 -114.36525827105994 -924.55966843034116 -302.74188404671958 -111.65016004387761 -923.49047504007547 -303.36271354889323 -108.94199097299526 -922.40578967838269 -303.95819030226801 -106.24078290785742 -921.3058019731144 -304.52888891554949 -103.54656413954501 -920.19069762031506 -305.07536396073084 -100.85935967420593 -919.06065849615652 -305.59815105013234 -98.179191480324675 -917.91586276390819 -306.09776782815243 -95.506078712828028 -916.75648497617885 -306.57471488647241 -92.840037916667526 -915.5826961726674 -307.02947661045772 -90.181083212203561 -914.39466397366414 -307.4625219636286 -87.529226464438068 -913.19255266954781 -307.87430521629341 -84.884477437895669 -911.97652330651158 -308.26526662374874 -82.246843938736248
+-1030.3081554903308 -293.8505094713114 -112.02674348886961 -1028.9492977426287 -294.5307816716799 -109.26467783165276 -1027.577118339467 -295.18445059221051 -106.51016733692579 -1026.1917657339036 -295.8121485334953 -103.76323904602746 -1024.7933856635407 -296.41448578647152 -101.02391654970489 -1023.3821212122338 -296.99205182190627 -98.292220252933163 -1021.9581128696725 -297.54541638504941 -95.568167614383114 -1020.5214985888642 -298.07513050525159 -92.851773363485023 -1019.0724138415881 -298.58172742923409 -90.143049697678236 -1017.6109916718942 -299.06572348569256 -87.442006462121881 -1016.137362747741 -299.52761888805094 -84.748651313864102 -1014.65165541087 -299.96789848140105 -82.062989872221593 -1013.1539957250176 -300.38703243897697 -79.385025856905543
+-1133.8186489049076 -278.0465879563987 -108.85882812117912 -1132.1670464295735 -278.76743667731029 -106.05757924703558 -1130.5043010459965 -279.4615667094281 -103.26448365212751 -1128.8305215080713 -280.12963731353034 -100.47956327246229 -1127.1458149643395 -280.77228552290472 -97.702836776530546 -1125.4502869765563 -281.39012731051844 -94.93431981375879 -1123.7440415383319 -281.98375866549782 -92.174025239405992 -1122.0271810937641 -282.55375658822118 -89.421963318671445 -1120.2998065560262 -283.10068001226568 -86.678141912439727 -1118.5620173258803 -283.62507066048948 -83.942566646787526 -1116.813911310109 -284.12745384170478 -81.215241068113528 -1115.0555849398686 -284.60833919365621 -78.496166785518696 -1113.2871331889703 -285.06822137736327 -75.785343601860276
+8 0 0 5 1 -309.78843540966716 -195.40683228639682 -104.2103540631517 -309.78843540966716 0 -104.2103540631517
+-310.02293610882492 -195.61649367693423 -103.49019229246917 -310.02293610882492 0 -103.49019229246917
+-310.25545286292714 -195.81421813519194 -102.76617629847468 -310.25545286292714 0 -102.76617629847468
+-310.48587793622721 -195.99980297750787 -102.03850117763828 -310.48587793622721 0 -102.03850117763828
+-310.71410231934794 -196.17304467643444 -101.30736697321541 -310.71410231934794 0 -101.30736697321541
+-310.9400159218917 -196.33373964713471 -100.57297897111363 -310.9400159218917 0 -100.57297897111363
+8 0 0 7 5 -316.85092502631062 -200.870823904182 -77.118625623185864 -315.90595761020541 -200.06724247449421 -81.885343012204387 -314.84159249818191 -199.21031476064593 -86.61841401977162 -313.65828291428062 -198.30129262103424 -91.313409021742515 -312.35715933820734 -197.34178174731645 -95.966204582687709 -310.94001361478712 -196.33373916212486 -100.57298647091373
+-316.7955605635878 -202.66468060997531 -77.397901651739289 -315.84174667737977 -201.86585952930048 -82.179436543078893 -314.76772252723555 -201.01409429827143 -86.926987776010108 -313.57395934951467 -200.11064527354796 -91.636047004356215 -312.26162860562772 -199.15712747205026 -96.30241295371718 -310.83258940908922 -198.15550870655824 -100.9221953681013
+-317.11773026744555 -204.4585373231059 -77.752021112893004 -316.15655995399663 -203.66447658480229 -82.556656911590963 -315.07437699640661 -202.81787389614817 -87.327185572678843 -313.87165831806254 -201.91999802422072 -92.059023430825363 -312.54960489532874 -200.9724732486392 -96.747893497829281 -311.11013383651795 -199.97727825135166 -101.38982894126188
+-317.82040857848722 -206.15574161205336 -78.165935001874772 -316.85387380165679 -205.36541623678917 -83.001040108002073 -315.76559210208541 -204.52285905139888 -87.802122479293999 -314.55602153590837 -203.6293311898371 -92.564505187664707 -313.22640118588794 -202.68650119755043 -97.283881574912598 -311.77869386571172 -201.69632962914847 -101.95619441020864
+-318.87612185914992 -207.65959570658401 -78.618550865604689 -317.90634600228998 -206.87093970576041 -83.489843610685483 -316.8141836721307 -206.03018399875123 -88.327359941050574 -315.60010122032435 -205.13862599913739 -93.126401154490594 -314.2653100739372 -204.19786271920813 -97.882507906956192 -312.81183363252205 -203.2098903765615 -102.59159518027157
+-320.22623175555788 -208.88656979781163 -79.084728687685015 -319.25504452918926 -208.09675259308992 -83.995731697556423 -318.16092614752858 -207.25472546229759 -88.873295894743066 -316.94432142620821 -206.36175785021692 -93.712639374232751 -315.60646868186871 -205.41947249646788 -98.509281794571592 -314.14940748817327 -204.42984647839094 -103.25904052398431
+-321.78973846881991 -209.77884221916116 -79.539055114143949 -320.81833894880663 -208.98471315535309 -84.490841819197755 -319.7235369161308 -208.13799456267583 -89.409538667323076 -318.50575783840083 -207.23994520977902 -94.29029603712857 -317.16624049164221 -206.29217428188363 -99.128563187195809 -315.70704844364479 -205.29664303957429 -103.92008115635038
+-323.47580030578422 -210.30789928940203 -79.95890783014994 -322.50465082332346 -209.5064758779821 -84.950243843897596 -321.40966236848391 -208.65183966083711 -89.908776467310219 -320.19123968248903 -207.74523695069215 -94.829580906345427 -318.85061776719846 -206.78826126621848 -99.708028234820617 -317.38987567278053 -205.78285568131903 -104.5397753315341
+8 0 0 8 1 -285.26768282415264 7.1054273528455211e-15 -156.5341304666162 -285.26768282415264 -118.80076617477651 -156.5341304666162
+-283.85469985729651 7.3479838357848286e-13 -158.79101407592057 -283.85469985729651 -118.80076617477579 -158.79101407592057
+-283.12850946284374 1.4624913398045055e-12 -161.47788273299992 -283.12850946284374 -118.80076617477506 -161.47788273299992
+-283.24176858707142 2.111565241781529e-12 -164.35090550147311 -283.24176858707142 -118.80076617477441 -164.35090550147311
+-284.2433356272025 2.60342338177202e-12 -167.1013620306027 -284.2433356272025 -118.80076617477391 -167.1013620306027
+-286.04310502937312 2.8771406731661983e-12 -169.40981990405825 -286.04310502937312 -118.80076617477364 -169.40981990405825
+-288.41814446144531 2.9080922804021624e-12 -171.03039855179134 -288.41814446144531 -118.80076617477361 -171.03039855179134
+-291.08085921344997 2.7096308181274956e-12 -171.84068604327041 -291.08085921344997 -118.80076617477381 -171.84068604327041
+-293.74357295896624 2.3234759811865555e-12 -171.84068273582758 -293.74357295896624 -118.8007661747742 -171.84068273582758
+8 0 0 10 1 -309.78843825184066 -195.40683554247929 -104.21035585324884 -309.78843825184066 0 -104.21035585324884
+-306.79940777454573 -192.7342321189457 -113.38979684553559 -306.79940777454573 0 -113.38979684553559
+-303.52290483565531 -188.33838763545199 -122.01482760372051 -303.52290483565531 0 -122.01482760372051
+-300.11378234986734 -182.50046532951472 -129.83029844028346 -300.11378234986734 0 -129.83029844028346
+-296.74162182167026 -175.5619699255854 -136.744446326081 -296.74162182167026 0 -136.744446326081
+-293.52693037017974 -167.67742022719204 -142.7766563546478 -293.52693037017974 0 -142.7766563546478
+-290.60836293192568 -159.01633891935919 -147.87114421310346 -290.60836293192568 0 -147.87114421310346
+-288.12340079086658 -149.64102798294996 -151.97438329033983 -288.12340079086658 0 -151.97438329033983
+-286.25703316904452 -139.63693106647753 -154.95362204791721 -286.25703316904452 0 -154.95362204791721
+-285.26768795752696 -129.21818042464182 -156.53412216112531 -285.26768795752696 0 -156.53412216112531
+-285.26768282411314 -118.80075657039086 -156.53413046669147 -285.26768282411314 0 -156.53413046669147
+8 0 0 5 1 -316.85092502631062 -200.870823904182 -77.118625623185864 -316.85092502631062 0 -77.118625623185864
+-315.90595761020541 -200.06724247449421 -81.885343012204387 -315.90595761020541 0 -81.885343012204387
+-314.84159249818191 -199.21031476064593 -86.61841401977162 -314.84159249818191 0 -86.61841401977162
+-313.65828291428062 -198.30129262103424 -91.313409021742515 -313.65828291428062 0 -91.313409021742515
+-312.35715933820734 -197.34178174731645 -95.966204582687709 -312.35715933820734 0 -95.966204582687709
+-310.94001361478712 -196.33373916212486 -100.57298647091373 -310.94001361478712 0 -100.57298647091373
+8 0 0 5 1 -309.78843540966716 195.40683228639682 -104.2103540631517 -309.78843540966716 0 -104.2103540631517
+-310.02293610882492 195.61649367693423 -103.49019229246917 -310.02293610882492 0 -103.49019229246917
+-310.25545286292714 195.81421813519194 -102.76617629847468 -310.25545286292714 0 -102.76617629847468
+-310.48587793622721 195.99980297750787 -102.03850117763828 -310.48587793622721 0 -102.03850117763828
+-310.71410231934794 196.17304467643444 -101.30736697321541 -310.71410231934794 0 -101.30736697321541
+-310.9400159218917 196.33373964713471 -100.57297897111363 -310.9400159218917 0 -100.57297897111363
+8 0 0 7 5 -317.32883271750575 -201.28241763603086 -74.639313893226401 -317.23582959584058 -201.2012553474305 -75.135882817809232 -317.14153684372849 -201.11951346696316 -75.632103391089956 -317.04595488332063 -201.03719335784982 -76.127970672294197 -316.94908413681367 -200.95429638284139 -76.623479726236738 -316.85092502630562 -200.87082390417442 -77.118625623183547
+-317.27797470018066 -203.07384551199317 -74.910858659893165 -317.1840879875777 -202.99316032437133 -75.408980717063713 -317.08890279450316 -202.91190002220884 -75.906751025823894 -316.99241954386116 -202.83006582389689 -76.404164602137385 -316.89463865896386 -202.74765894730402 -76.901216468054884 -316.79556056340783 -202.66468060972139 -77.397901651662423
+-317.60387824191906 -204.86527338890807 -75.252967651296373 -317.50926218816875 -204.78506530203342 -75.753494091647127 -317.41333901197089 -204.70428657527754 -76.253667687466489 -317.3161090644499 -204.62293828493955 -76.75348340656258 -317.21757269723093 -204.5410215067833 -77.252936221725392 -317.11773026235596 -204.45853731597583 -77.752021110730269
+-318.30926384509888 -206.56057291323782 -75.651068123647704 -318.21412531095018 -206.48073683535034 -76.154757561000409 -318.11767183929697 -206.40033358142966 -76.658095285726517 -318.01988821903382 -206.31937526176245 -77.161063808537975 -317.92080550125542 -206.23784052805001 -77.663682861990424 -317.82040847540509 -206.15574148974628 -78.165934961649711
+-319.36658991103582 -208.06357169701383 -76.08491259101848 -319.27114233853024 -207.9839032678789 -76.592349946398443 -319.17437311079033 -207.90366917374541 -77.099438455584718 -319.07626856230343 -207.82288442182795 -77.606164346846342 -318.97685606042899 -207.74152164332654 -78.112539754375547 -318.87612193941959 -207.65959584545999 -78.618550903988037
+-320.71737529113199 -209.29113824651054 -76.53050493378025 -320.6218016206754 -209.21135645458853 -77.042050072898036 -320.52490065188323 -209.13100784881968 -77.553250214222842 -320.42667216554673 -209.05009329450334 -78.064100164314681 -320.3271159418664 -208.96861365764173 -78.574594724296901 -320.22623176053594 -208.88656980502304 -79.084728689838613
+-322.28094166047379 -210.18560932718779 -76.963687589480628 -322.18536619464555 -210.10539592091911 -77.47945365372118 -322.08845860155958 -210.02461158872546 -77.994878700387957 -321.9902184226753 -209.94325724802457 -78.509957472221913 -321.89064519854952 -209.86133381792271 -79.024684702346448 -321.78973846899765 -209.77884221941704 -79.539055114220488
+-323.96682687943911 -210.71838774356593 -77.363030951164234 -323.87129609353866 -210.63744343677175 -77.88289238208344 -323.77442872279289 -210.5559213979102 -78.402416121201853 -323.67622408804976 -210.47382266557375 -78.921596839380754 -323.57668150927117 -210.39114828120029 -79.440429194251394 -323.47580030578973 -210.30789928940956 -79.958907830152157
+8 0 0 10 1 -309.78843825184066 195.40683554247929 -104.21035585324884 -309.78843825184066 0 -104.21035585324884
+-306.79940777454573 192.7342321189457 -113.38979684553559 -306.79940777454573 0 -113.38979684553559
+-303.52290483565531 188.33838763545199 -122.01482760372051 -303.52290483565531 0 -122.01482760372051
+-300.11378234986734 182.50046532951472 -129.83029844028346 -300.11378234986734 0 -129.83029844028346
+-296.74162182167026 175.5619699255854 -136.744446326081 -296.74162182167026 0 -136.744446326081
+-293.52693037017974 167.67742022719204 -142.7766563546478 -293.52693037017974 0 -142.7766563546478
+-290.60836293192568 159.01633891935919 -147.87114421310346 -290.60836293192568 0 -147.87114421310346
+-288.12340079086658 149.64102798294996 -151.97438329033983 -288.12340079086658 0 -151.97438329033983
+-286.25703316904452 139.63693106647753 -154.95362204791721 -286.25703316904452 0 -154.95362204791721
+-285.26768795752696 129.21818042464182 -156.53412216112531 -285.26768795752696 0 -156.53412216112531
+-285.26768282411314 118.80075657039086 -156.53413046669147 -285.26768282411314 0 -156.53413046669147
+8 0 0 8 1 -285.26768282415264 -7.1054273528455211e-15 -156.5341304666162 -285.26768282415264 118.80076617477651 -156.5341304666162
+-283.85469985729651 -7.3479838357848286e-13 -158.79101407592057 -283.85469985729651 118.80076617477579 -158.79101407592057
+-283.12850946284374 -1.4624913398045055e-12 -161.47788273299992 -283.12850946284374 118.80076617477506 -161.47788273299992
+-283.24176858707142 -2.111565241781529e-12 -164.35090550147311 -283.24176858707142 118.80076617477441 -164.35090550147311
+-284.2433356272025 -2.60342338177202e-12 -167.1013620306027 -284.2433356272025 118.80076617477391 -167.1013620306027
+-286.04310502937312 -2.8771406731661983e-12 -169.40981990405825 -286.04310502937312 118.80076617477364 -169.40981990405825
+-288.41814446144531 -2.9080922804021624e-12 -171.03039855179134 -288.41814446144531 118.80076617477361 -171.03039855179134
+-291.08085921344997 -2.7096308181274956e-12 -171.84068604327041 -291.08085921344997 118.80076617477381 -171.84068604327041
+-293.74357295896624 -2.3234759811865555e-12 -171.84068273582758 -293.74357295896624 118.8007661747742 -171.84068273582758
+8 0 0 5 1 -316.85092502631062 200.870823904182 -77.118625623185864 -316.85092502631062 0 -77.118625623185864
+-315.90595761020541 200.06724247449421 -81.885343012204387 -315.90595761020541 0 -81.885343012204387
+-314.84159249818191 199.21031476064593 -86.61841401977162 -314.84159249818191 0 -86.61841401977162
+-313.65828291428062 198.30129262103424 -91.313409021742515 -313.65828291428062 0 -91.313409021742515
+-312.35715933820734 197.34178174731645 -95.966204582687709 -312.35715933820734 0 -95.966204582687709
+-310.94001361478712 196.33373916212486 -100.57298647091373 -310.94001361478712 0 -100.57298647091373
+8 0 0 5 1 -317.32883271750575 -201.28241763603086 -74.639313893226401 -317.32883271750575 0 -74.639313893226401
+-317.23582959584058 -201.2012553474305 -75.135882817809232 -317.23582959584058 0 -75.135882817809232
+-317.14153684372849 -201.11951346696316 -75.632103391089956 -317.14153684372849 0 -75.632103391089956
+-317.04595488332063 -201.03719335784982 -76.127970672294197 -317.04595488332063 0 -76.127970672294197
+-316.94908413681367 -200.95429638284139 -76.623479726236738 -316.94908413681367 0 -76.623479726236738
+-316.85092502630562 -200.87082390417442 -77.118625623183547 -316.85092502630562 0 -77.118625623183547
+8 0 0 7 5 -309.78843540966716 195.40683228639682 -104.2103540631517 -310.02293610882492 195.61649367693423 -103.49019229246917 -310.25545286292714 195.81421813519194 -102.76617629847468 -310.48587793622721 195.99980297750787 -102.03850117763828 -310.71410231934794 196.17304467643444 -101.30736697321541 -310.9400159218917 196.33373964713471 -100.57297897111363
+-309.638159749078 197.23535506427714 -104.67185710321915 -309.88156625385858 197.44402944122237 -103.92943769234809 -310.12282405710079 197.64058470890896 -103.18306130914027 -310.36182224815497 197.82481853503893 -102.43292578901864 -310.59844899456647 197.99652786382308 -101.67923281513632 -310.83259166177231 198.15550952005086 -100.92218808162499
+-309.88492271052507 199.06387784316118 -105.26264475463886 -310.13467877958971 199.27156531455654 -104.49570831315815 -310.38219062962986 199.46695149299603 -103.72475593114692 -310.62734606164634 199.64983433485949 -102.94998827734194 -310.8700323305705 199.82001123244481 -102.1716084206561 -311.11013619393276 199.97727939930718 -101.38982190415815
+-310.5374969776384 200.78551791125903 -105.95573705527222 -310.79045800384591 200.99307416681575 -105.16352345366589 -311.04117158153633 201.18813378281706 -104.36725467957403 -311.28953202025542 201.37051117685621 -103.56715460552222 -311.53540678066548 201.53997375184059 -102.76339089824978 -311.77869657572285 201.6963311568129 -101.95618768496952
+-311.5699311651955 202.29332980718351 -106.71282959672202 -311.82285786351969 202.50248372598926 -105.89638163362162 -312.0736261161781 202.69892200575683 -105.07582522669313 -312.32211015355693 202.88242747813581 -104.25135295879505 -312.56821985651163 203.05282454973397 -103.42321092012835 -312.81183657544437 203.20989180953845 -102.59158859939325
+-312.91983400027681 203.49619459604827 -107.4881703417654 -313.16996059632066 203.70926798173747 -106.65032682333336 -313.41809171053279 203.90937915785099 -105.80827360254519 -313.66411696176704 204.09631869666362 -104.96222971501115 -313.90792650421406 204.26987782429677 -104.11241183376397 -314.14941099475902 204.42984802755822 -103.25903419692642
+-314.49861099167993 204.33376994774403 -108.23606625882728 -314.74409524341081 204.55323773809963 -107.38117669171795 -314.98778933998824 204.75947573653198 -106.52190361543192 -315.22958507227486 204.95226665251653 -105.65847792838142 -315.46937500938702 205.13139458683727 -104.79112709216864 -315.70705247713283 205.29664440532443 -103.92007497036968
+-316.20643815364701 204.7799632831003 -108.91672863601242 -316.44650053897624 205.00799258105653 -108.0501217353475 -316.684980422693 205.22252443519886 -107.17887935483917 -316.92177285913164 205.4233299383408 -106.30324647768508 -317.15677382223839 205.61018242650161 -105.42346415393793 -317.38988019336449 205.78285668776229 -104.53976920003481
+8 0 0 7 9 -273.13409248915633 -194.82218095784921 140.86584214689375 -285.2493475660101 -199.26352300438296 119.09128230012169 -296.09354029987423 -203.05785911199212 96.52349583539177 -305.49475470310466 -206.09210185932895 73.19949474775153 -313.24109198563792 -208.24130601273563 49.164299892548875 -319.05706525379736 -209.36476850345596 24.538321739078381 -322.64432543680834 -209.31092543701226 -0.53981765980208607 -323.62095023305426 -207.93018742008687 -25.716488820016988 -321.8411622882212 -205.22024849027659 -50.546760922325404 -317.32883271750728 -201.2824176360331 -74.639313893227083
+-272.98032926594055 -196.63452061040437 141.14219839851404 -285.13239998422642 -201.05768732943517 119.33618943490494 -296.01235306957926 -204.83634999996551 96.73009291759459 -305.4472782636218 -207.85780557083248 73.360302506534182 -313.22320262629302 -209.99708670487377 49.270462835911189 -319.06295903991054 -211.11448717306655 24.580799101351435 -322.66377413932094 -211.05967995944815 -0.5711215947433983 -323.63706282828434 -209.68446038704508 -25.83030636488645 -321.83317729810017 -206.98854171645837 -50.742945847247789 -317.27797470024967 -203.07384551209043 -74.910858659921388
+-273.17162057074614 -198.44686026367236 141.61054124784906 -285.36111178272375 -202.85185163668234 119.74930026328354 -296.27759568832215 -206.61483243967857 97.08100337108857 -305.74747063567781 -209.62352277284475 73.641046312409642 -313.55479015877268 -211.75286592197719 49.47126825322627 -319.42102018964096 -212.86419617840031 24.691233098412727 -323.03949264258091 -212.80843970172322 -0.56325280069831241 -324.01528270680109 -211.43873417573496 -25.936931716553278 -322.19447513477337 -208.75683454870722 -50.968394883946736 -317.60387824430933 -204.86527339226024 -75.252967652270058
+-273.71645757114021 -200.1590180708636 142.25558964627004 -285.94169886429944 -204.54962671453674 120.31748647818942 -296.89342479844049 -208.30016574731434 97.565470775035848 -306.39774870980835 -211.29877485571336 74.033468328818117 -314.23648474182949 -213.42013305046041 49.761774967305733 -320.13112451299276 -214.52670429713635 24.867316747922896 -323.77045517643313 -214.47014365226619 -0.51455111263691045 -324.75475147230037 -213.10480840644971 -26.030786993585878 -322.92536216990595 -210.4339755299761 -51.213130590984008 -318.309263901625 -206.56057298046409 -75.651068144782229
+-274.59478689967352 -201.6707622009298 143.04617052851108 -286.85259242195866 -206.05463474497893 121.01420656996146 -297.83686130451213 -209.79927083950062 98.161625920727857 -307.37378754768099 -212.79316333081968 74.520465943729818 -315.24291923892775 -214.91058761637962 50.129550835354202 -321.16667465595253 -216.01491903277181 25.102034187058329 -324.82931432812012 -215.95790840530779 -0.42664897573101507 -325.82745898693588 -214.59458945226382 -26.107116802283812 -323.99769928026421 -211.92884622608767 -51.465131213119427 -319.36658986674161 -208.06357162092291 -76.084912570784169
+-275.75651308586788 -202.89587040103328 143.93719315245468 -288.0432678440053 -207.28346442847047 121.80094716493775 -299.05689536068201 -211.03117452998563 98.837414686226339 -308.62389563375228 -214.02769097710689 75.076622965693858 -316.52196255647095 -216.14683537183811 50.555524426633909 -322.47429867539614 -217.25230675912997 25.383903934696395 -326.16189388518063 -217.19542302475207 -0.30400860941627061 -327.17786068852297 -215.83088584206908 -26.16213805815708 -325.35448374793521 -213.16203306504454 -51.711319784562306 -320.71737528878413 -209.29113824312742 -76.530504932809805
+-277.1292330395861 -203.77544226958398 144.87661087814604 -289.44187430074402 -208.1783561917135 122.63321439103328 -300.48203370123815 -211.93916695453544 99.555698014101978 -310.07663382122576 -214.94654465464879 75.672077768373043 -318.00213581656328 -217.0738291186367 51.016890230322403 -323.98176397768788 -218.18424164087605 25.69787694111611 -327.6949796937692 -218.12815751082169 -0.15392031753303606 -328.73092004079166 -216.75868746967583 -26.194205113590197 -326.91815686945267 -214.07743878523408 -51.939710306295119 -322.28094166040546 -210.18560932708985 -76.963687589452576
+-278.62999153678902 -204.2814951977212 145.81267994068594 -290.96645396379665 -208.71064843613351 123.46638482495297 -302.03107826544056 -212.49410308192984 100.27883354692054 -311.6513054962748 -215.52026448077444 76.276043766949428 -319.60255991177195 -217.66184053810537 51.490351175850442 -325.60817999570043 -218.78099435832587 26.027422659949575 -329.34635838196851 -218.72631600187748 0.015263917360958834 -330.4026223311879 -217.34829406035394 -26.203215694098375 -328.6018918695583 -214.6456663472143 -52.140353529954325 -323.96682687943746 -210.71838774356362 -77.36303095116368
+8 0 0 8 10 -309.78843825184066 195.40683554247929 -104.21035585324884 -306.79940777454573 192.7342321189457 -113.38979684553559 -303.52290483565531 188.33838763545199 -122.01482760372051 -300.11378234986734 182.50046532951472 -129.83029844028346 -296.74162182167026 175.5619699255854 -136.744446326081 -293.52693037017974 167.67742022719204 -142.7766563546478 -290.60836293192568 159.01633891935919 -147.87114421310346 -288.12340079086658 149.64102798294996 -151.97438329033983 -286.25703316904452 139.63693106647753 -154.95362204791721 -285.26768795752696 129.21818042464182 -156.53412216112531 -285.26768282411314 118.80075657039086 -156.53413046669147
+-309.65695002083908 197.00679595927855 -104.61417282244714 -306.5685425003212 194.34521801769444 -114.04188952207167 -303.17183398390034 189.93757412731259 -122.9022117950819 -299.62586892386435 184.06403719313954 -130.93843749573537 -296.10474189141036 177.06514943285001 -138.06024020270871 -292.73233782370664 169.08953174402191 -144.29091380805855 -289.6519913917719 160.29231480015829 -149.57813738218013 -287.0065416241643 150.7333675726922 -153.86402905865947 -284.98550642693482 140.45993772370599 -157.02261937811974 -283.88839784652174 129.66464827995907 -158.73719020108328 -283.85470005730917 118.80075924973931 -158.79101375780368
+-309.82324200664073 198.60675669714399 -105.11495374663804 -306.65989827068051 195.95620482315951 -114.81257139431955 -303.17498980676891 191.53676000285668 -123.93455005089726 -299.52974401985995 185.62766261999792 -132.22274823172737 -295.90100443279243 178.56814021428724 -139.58824931795792 -292.41461918657143 170.50198773728221 -146.0567652615386 -289.21741931765422 161.5679470828911 -151.57851805041579 -286.45732627663756 151.82590367948788 -156.08949546164359 -284.32691925012 141.28289292291115 -159.46813623507987 -283.16314743864655 130.11111613634637 -161.34973762154056 -283.12850969968173 118.8007619290878 -161.47788203039045
+-310.29279476507986 200.13991152092638 -105.69583410953841 -307.08362737586469 197.49354209180609 -115.67299875902823 -303.54910825001548 193.05433173061022 -125.06886137971826 -299.85121489779499 187.10132563889945 -133.6231595169414 -296.16831560229514 179.97325197624571 -141.24793699583438 -292.62735612091637 171.8108116828279 -147.96974711356367 -289.3774115379025 162.73837339365184 -153.74011886967318 -286.5707905078911 152.81769426910756 -158.48831072730101 -284.40190185030798 142.02199415635528 -162.09341727462876 -283.23367961042783 130.50934851253268 -164.14538717745467 -283.24177064400726 118.80076431896485 -164.35090803710236
+-311.0537201002785 201.53941938083318 -106.33428402420074 -307.82943594835655 198.88353056909304 -116.5868532582171 -304.28615123960037 194.40860518651164 -126.25216459818122 -300.58560959146865 188.39492023093476 -135.06614403469874 -296.90687818216236 181.18273644578537 -142.94068435094508 -293.37758282151083 172.91191366820345 -149.90129461665649 -290.1478824216772 163.6987334793622 -155.89928273512032 -287.37335240869606 153.60775212616815 -160.85776521020074 -285.24951924026385 142.59345657330726 -164.65172951814984 -284.14780483613112 130.81112201454235 -166.83899644524303 -284.24333667329694 118.80076612997154 -167.10135958350745
+-312.07614116940402 202.74438835574628 -107.0035768122432 -308.86545084288809 200.05961070717825 -117.51301180061623 -305.35135387650348 195.52664205011095 -127.42581248607181 -301.69462531671104 189.42908036743501 -136.4714158756733 -298.07427929884773 182.11184504148528 -144.55982267100626 -294.61824084644644 173.71683769978651 -151.71333721265697 -291.47646108206806 164.36171962201925 -157.88167810928076 -288.80620982140766 154.11422334093112 -162.98334162063105 -286.80332868355305 142.93122340777126 -166.8847968288336 -285.82853793348892 130.97905824603848 -169.13459002557127 -286.043101693898 118.80076713779218 -169.40981449768125
+-313.31452285215556 203.70557544819854 -107.67513893429675 -310.14089550888167 200.96916694184137 -118.40943455065171 -306.68639996336253 196.35252625845291 -128.53156016072833 -303.10998869622608 190.14542368205301 -137.7611842016762 -299.58954134756351 182.70138597674219 -146.00451793758893 -296.25248173427582 174.16833876790551 -153.2787317987322 -293.24681462316738 164.67523301039884 -159.53197195770971 -290.72966385958068 154.29414210792172 -164.68011640012202 -288.89521192944721 143.00550753567722 -168.58021346641917 -288.07835497325226 130.99804880276793 -170.79853250167889 -288.41814241714405 118.80076725175797 -171.03039712120912
+-314.71208561862443 204.38953636763728 -108.32114566471583 -311.59146290155951 201.57834136953684 -119.2371963359747 -308.21623130897115 196.85300654697645 -129.51760503103333 -304.74247728725385 190.5130025496143 -138.86901021474225 -301.34544758482775 182.92485754191787 -147.19245025991327 -298.15067809641835 174.24761377336955 -154.49919533831414 -295.3022954496372 164.62929129710903 -160.73800717794927 -292.95530246498282 154.14879113044083 -165.82474099235381 -291.29960236710951 142.82563089953743 -169.61111553033686 -290.63641994077773 130.87628522953139 -171.70542707252892 -291.08085657987874 118.80076652102827 -171.84068524115366
+-316.20643612917337 204.77995943860239 -108.91672690359877 -313.14627347795641 201.87325046549111 -119.96358682453244 -309.85799625667289 197.01841110676284 -130.34283569124273 -306.49361632869153 190.52864205028081 -139.74549144009268 -303.22396178258151 182.78790678286026 -148.06714178687773 -300.1709205421966 173.97193947631848 -155.31434776600543 -297.47313996001134 164.25186153349105 -161.44075398218138 -295.28171513788851 153.71661711905449 -166.36554430275751 -293.78009071594613 142.43146799987045 -169.94319216265518 -293.23564142193169 130.63936447650835 -171.8406732716131 -293.74356994954235 118.80076509921588 -171.84068273570816
+8 0 0 19 1 -274.87688738836022 111.94971943911496 -171.84071215593281 -274.87688738836022 0 -171.84071215593281
+-319.68849308365657 128.47909263569738 -171.84062651825414 -319.68849308365657 0 -171.84062651825414
+-364.93330292522137 143.87901990887821 -171.84062729352274 -364.93330292522137 0 -171.84062729352274
+-410.56936435229733 158.10073562141636 -171.84064786422363 -410.56936435229733 0 -171.84064786422363
+-456.58122113399423 171.10682776857533 -171.84066303164317 -456.58122113399423 0 -171.84066303164317
+-502.9461751903205 182.85845060483254 -171.84066601075216 -502.9461751903205 0 -171.84066601075216
+-549.63396068535781 193.31528368665698 -171.84065946661849 -549.63396068535781 0 -171.84065946661849
+-596.61155705149554 202.43755318507402 -171.84065005581195 -596.61155705149554 0 -171.84065005581195
+-643.8446426908838 210.18697927054154 -171.84064396877125 -643.8446426908838 0 -171.84064396877125
+-691.29614058760922 216.52687175766374 -171.84064401566019 -691.29614058760922 0 -171.84064401566019
+-738.92461174807431 221.42240042745328 -171.84064901382891 -738.92461174807431 0 -171.84064901382891
+-786.68422655335337 224.84161036631957 -171.84065528043698 -786.68422655335337 0 -171.84065528043698
+-834.52613553085405 226.75698855691201 -171.84065907573978 -834.52613553085405 0 -171.84065907573978
+-882.39985099752903 227.14692654669045 -171.84065855347825 -882.39985099752903 0 -171.84065855347825
+-930.25345424649595 225.99653446303788 -171.8406543330629 -930.25345424649595 0 -171.8406543330629
+-978.03290768575948 223.2978715333989 -171.84064889796809 -978.03290768575948 0 -171.84064889796809
+-1025.6824593235283 219.05035363693611 -171.84064583593954 -1025.6824593235283 0 -171.84064583593954
+-1073.1481934503131 213.26212372927944 -171.84064916509462 -1073.1481934503131 0 -171.84064916509462
+-1120.3824550037175 205.9514291499265 -171.84065883742238 -1120.3824550037175 0 -171.84065883742238
+-1167.3345381169636 197.14210218568488 -171.8406486850613 -1167.3345381169636 0 -171.8406486850613
+8 0 0 5 1 -317.32883271750575 201.28241763603086 -74.639313893226401 -317.32883271750575 0 -74.639313893226401
+-317.23582959584058 201.2012553474305 -75.135882817809232 -317.23582959584058 0 -75.135882817809232
+-317.14153684372849 201.11951346696316 -75.632103391089956 -317.14153684372849 0 -75.632103391089956
+-317.04595488332063 201.03719335784982 -76.127970672294197 -317.04595488332063 0 -76.127970672294197
+-316.94908413681367 200.95429638284139 -76.623479726236738 -316.94908413681367 0 -76.623479726236738
+-316.85092502630562 200.87082390417442 -77.118625623183547 -316.85092502630562 0 -77.118625623183547
+8 0 0 9 1 -273.13409248915633 -194.82218095784921 140.86584214689375 -273.13409248915633 0 140.86584214689375
+-285.2493475660101 -199.26352300438296 119.09128230012169 -285.2493475660101 0 119.09128230012169
+-296.09354029987423 -203.05785911199212 96.52349583539177 -296.09354029987423 0 96.52349583539177
+-305.49475470310466 -206.09210185932895 73.19949474775153 -305.49475470310466 0 73.19949474775153
+-313.24109198563792 -208.24130601273563 49.164299892548875 -313.24109198563792 0 49.164299892548875
+-319.05706525379736 -209.36476850345596 24.538321739078381 -319.05706525379736 0 24.538321739078381
+-322.64432543680834 -209.31092543701226 -0.53981765980208607 -322.64432543680834 0 -0.53981765980208607
+-323.62095023305426 -207.93018742008687 -25.716488820016988 -323.62095023305426 0 -25.716488820016988
+-321.8411622882212 -205.22024849027659 -50.546760922325404 -321.8411622882212 0 -50.546760922325404
+-317.32883271750728 -201.2824176360331 -74.639313893227083 -317.32883271750728 0 -74.639313893227083
+8 0 0 7 5 -316.85092502631062 200.870823904182 -77.118625623185864 -315.90595761020541 200.06724247449421 -81.885343012204387 -314.84159249818191 199.21031476064593 -86.61841401977162 -313.65828291428062 198.30129262103424 -91.313409021742515 -312.35715933820734 197.34178174731645 -95.966204582687709 -310.94001361478712 196.33373916212486 -100.57298647091373
+-316.7955605635878 202.66468060997531 -77.397901651739289 -315.84174667737977 201.86585952930048 -82.179436543078893 -314.76772252723555 201.01409429827143 -86.926987776010108 -313.57395934951467 200.11064527354796 -91.636047004356215 -312.26162860562772 199.15712747205026 -96.30241295371718 -310.83258940908922 198.15550870655824 -100.9221953681013
+-317.11773026744555 204.4585373231059 -77.752021112893004 -316.15655995399663 203.66447658480229 -82.556656911590963 -315.07437699640661 202.81787389614817 -87.327185572678843 -313.87165831806254 201.91999802422072 -92.059023430825363 -312.54960489532874 200.9724732486392 -96.747893497829281 -311.11013383651795 199.97727825135166 -101.38982894126188
+-317.82040857848722 206.15574161205336 -78.165935001874772 -316.85387380165679 205.36541623678917 -83.001040108002073 -315.76559210208541 204.52285905139888 -87.802122479293999 -314.55602153590837 203.6293311898371 -92.564505187664707 -313.22640118588794 202.68650119755043 -97.283881574912598 -311.77869386571172 201.69632962914847 -101.95619441020864
+-318.87612185914992 207.65959570658401 -78.618550865604689 -317.90634600228998 206.87093970576041 -83.489843610685483 -316.8141836721307 206.03018399875123 -88.327359941050574 -315.60010122032435 205.13862599913739 -93.126401154490594 -314.2653100739372 204.19786271920813 -97.882507906956192 -312.81183363252205 203.2098903765615 -102.59159518027157
+-320.22623175555788 208.88656979781163 -79.084728687685015 -319.25504452918926 208.09675259308992 -83.995731697556423 -318.16092614752858 207.25472546229759 -88.873295894743066 -316.94432142620821 206.36175785021692 -93.712639374232751 -315.60646868186871 205.41947249646788 -98.509281794571592 -314.14940748817327 204.42984647839094 -103.25904052398431
+-321.78973846881991 209.77884221916116 -79.539055114143949 -320.81833894880663 208.98471315535309 -84.490841819197755 -319.7235369161308 208.13799456267583 -89.409538667323076 -318.50575783840083 207.23994520977902 -94.29029603712857 -317.16624049164221 206.29217428188363 -99.128563187195809 -315.70704844364479 205.29664303957429 -103.92008115635038
+-323.47580030578422 210.30789928940203 -79.95890783014994 -322.50465082332346 209.5064758779821 -84.950243843897596 -321.40966236848391 208.65183966083711 -89.908776467310219 -320.19123968248903 207.74523695069215 -94.829580906345427 -318.85061776719846 206.78826126621848 -99.708028234820617 -317.38987567278053 205.78285568131903 -104.5397753315341
+8 0 0 19 19 -274.87688738836022 111.94971943911496 -171.84071215593281 -319.68849308365657 128.47909263569738 -171.84062651825414 -364.93330292522137 143.87901990887821 -171.84062729352274 -410.56936435229733 158.10073562141636 -171.84064786422363 -456.58122113399423 171.10682776857533 -171.84066303164317 -502.9461751903205 182.85845060483254 -171.84066601075216 -549.63396068535781 193.31528368665698 -171.84065946661849 -596.61155705149554 202.43755318507402 -171.84065005581195 -643.8446426908838 210.18697927054154 -171.84064396877125 -691.29614058760922 216.52687175766374 -171.84064401566019 -738.92461174807431 221.42240042745328 -171.84064901382891 -786.68422655335337 224.84161036631957 -171.84065528043698 -834.52613553085405 226.75698855691201 -171.84065907573978 -882.39985099752903 227.14692654669045 -171.84065855347825 -930.25345424649595 225.99653446303788 -171.8406543330629 -978.03290768575948 223.2978715333989 -171.84064889796809 -1025.6824593235283 2
19.05035363693611 -171.84064583593954 -1073.1481934503131 213.26212372927944 -171.84064916509462 -1120.3824550037175 205.9514291499265 -171.84065883742238 -1167.3345381169636 197.14210218568488 -171.8406486850613
+-274.87689543049083 119.73367071307578 -171.84070119088986 -319.72093217984263 136.06843813837156 -171.84062753793876 -364.98852469234163 151.28438717756981 -171.84063367119842 -410.63943149341185 165.33537266823458 -171.8406498122859 -456.65799963984449 178.18596323796652 -171.84065955498829 -503.02175426220384 189.7992626013924 -171.84066188628395 -549.70127409444171 200.13681461936156 -171.84065832341366 -596.66471792386699 209.16046411840892 -171.84065352304341 -643.87912294596731 216.83326565718315 -171.84064681134129 -691.30888503361882 223.11956180131207 -171.84064650774235 -738.91424599792083 227.98533357541442 -171.84064542873523 -786.65114210386548 231.39915410565698 -171.84065239422853 -834.4726113036495 233.33378462909883 -171.84065616305489 -882.3299637053459 233.76751680796409 -171.84066075920654 -930.17303644017375 232.68499671872053 -171.84065818509006 -977.94940039438018 230.07738616772497 -171.84065082883563 -1025.6047237094147 225.942760200
66263 -171.84064259857848 -1073.0860795932542 220.28741303344691 -171.8406452597132 -1120.3461695011017 213.12724290748909 -171.840663335823 -1167.3345370278648 204.48359982785576 -171.8406463963733
+-275.42743867618276 127.104253821437 -171.08977489834598 -320.25688769065107 143.23626652554492 -171.11777234910281 -365.50303774759749 158.25419911224205 -171.13693185562471 -411.11466102150513 172.13993911366913 -171.1734327426297 -457.11295424826062 184.80111171823611 -171.15783205014523 -503.38438921365213 196.31144209681267 -171.24417917713518 -550.09567634836719 206.48217590456412 -171.13863812249679 -596.85147642783818 215.40776928311038 -171.32100368523274 -644.21623280578672 223.08650907938744 -171.11823325567218 -691.30148461537181 229.08964340827083 -171.33965082102787 -739.14362450189265 234.29565762967741 -171.15392591743688 -786.5134825317532 237.23304204248225 -171.28451674776124 -834.5170129161412 239.66484095807792 -171.20603619350456 -882.12776239164998 239.73748927267138 -171.2269515590603 -930.02782182244027 239.01166649333774 -171.21156553943345 -977.68989795153482 236.3256899511307 -171.19275658924889 -1025.3322649408392 232.394624291975
84 -171.1800103571166 -1072.7690154306551 226.84078082478092 -171.1565855029298 -1120.0106259439874 219.8512686747456 -171.13433353798115 -1166.9860246545456 211.37832885782382 -171.10779751374571
+-276.39015652051188 134.04603212608691 -169.77651176171591 -321.17005870944359 149.96924767160758 -169.84673194517745 -366.35168897143046 164.80271379039502 -169.91565211657689 -411.90761989933355 178.48324520636123 -169.96405982796517 -457.79898306847269 191.03807828733591 -170.03953022716951 -504.0548141287216 202.30038166831108 -170.03604631280152 -550.54854692725587 212.49412406941806 -170.1504349724454 -597.41544937101287 221.15154876387555 -170.06893401974517 -644.3878816941891 228.86334815192447 -170.21547226246543 -691.72806355168007 234.81492404387575 -170.10554884591281 -739.08213798555141 239.81840456051052 -170.20007330551084 -786.70359570817561 243.05487252453307 -170.14452154485065 -834.31475142333238 245.13246197541756 -170.14248757557257 -882.02983600043854 245.59190937353668 -170.13058577024384 -929.71040245622441 244.67371128707765 -170.08090570481471 -977.35100454525139 242.24135742596764 -170.05569753413081 -1024.8834835051775 238.34159961
1785 -169.99723274238139 -1072.2619009724824 232.96128600448799 -169.94403979939526 -1119.4390549718994 226.11564641775223 -169.87669543427651 -1166.3654371093417 217.8212337010587 -169.80420163190163
+-277.65847562448454 140.57663375077726 -168.02657305847885 -322.35891736087865 156.29623286573167 -168.15390141040839 -367.45071590382292 170.93964479711039 -168.27654304863663 -412.91393836070444 184.44153982018773 -168.36841036680434 -458.69260214949639 196.83489603634354 -168.49409035456659 -504.86132751956046 207.96833091370931 -168.50630588393287 -551.18806725293496 217.98348918347389 -168.68446903205827 -598.02504927582447 226.67395093687145 -168.56871803665456 -644.72466257764245 234.03977744026955 -168.80707717129383 -692.13562962187859 240.3483397555066 -168.61360347315272 -739.12212172865395 244.77287718144655 -168.8041051302159 -786.85357308555751 248.59839068411765 -168.65707035655706 -834.12272061752935 250.12918300150253 -168.70897444460951 -881.87266630960494 251.07472916191074 -168.63096861993267 -929.32588800959093 249.91645841000033 -168.58064463328776 -976.91011837060626 247.74771682453979 -168.50640043798276 -1024.3059958500035 243.8720183
8362876 -168.411624019318 -1071.5965651929505 238.66005957721279 -168.30642688525197 -1118.6792346216034 231.95371001041184 -168.18340787394766 -1165.5259840637682 223.83263113878652 -168.04800169346305
+-279.15406105182581 146.72789025608753 -165.92317826120004 -323.75074197273307 162.25136205799993 -166.11854429133652 -368.73404348211301 176.70130828880653 -166.29722529418174 -414.07073284882659 190.05073592134406 -166.45709479262325 -459.74545087204586 202.24026153795464 -166.59865324622882 -505.73901545593884 213.32727269775262 -166.71395287408112 -552.00603716099852 223.06385405817912 -166.82034922234709 -598.58138888430994 231.8758253646233 -166.87580192021863 -645.29187780671054 238.89450485789791 -166.95966445564855 -692.37422505402208 245.41023647598229 -166.94061225115564 -739.38627783855043 249.58200390010057 -167.00354671017095 -786.81629094308744 253.53463268674216 -166.92240215411579 -834.04605038974898 255.01420706229021 -166.93523771008867 -881.57881108744812 256.00517712093131 -166.8235277838823 -928.92740805305959 254.92020322056885 -166.76015463694051 -976.35620208096702 252.81646269882367 -166.62581880196359 -1023.6287636101426 249.0574128
0094244 -166.49163660346906 -1070.7940316815384 243.96481065647421 -166.32184672844701 -1117.7628808079528 237.40556298123352 -166.13380669475686 -1164.5037209934846 229.44576298032752 -165.92322388710852
+-280.82170220357955 152.53557839760234 -163.52017375972704 -325.29572779075249 167.86827438959671 -163.79041738175525 -370.15116408807131 182.13327878898153 -164.03190651833492 -415.34551207060025 195.32662906366417 -164.26439741195338 -460.89468583102433 207.34234747241754 -164.42856627660922 -506.70164679150287 218.32563526756599 -164.64891312255287 -552.88944764893108 227.9154822376538 -164.68676204690726 -599.17881265669291 236.61897444323756 -164.92287852822099 -645.9154328758525 243.65481127029062 -164.83305195398111 -692.59016055143604 249.88839759388082 -165.02802813764421 -739.70684531075233 254.37888015680346 -164.90612787505847 -786.70575371215523 257.87897690431737 -164.9567943931913 -833.99287333972529 259.81005191785795 -164.86213298674556 -881.19817826819019 260.46107152114956 -164.76807900742841 -928.49104361146999 259.69330300178376 -164.64924093103519 -975.70769942251104 257.50958197189647 -164.47215790189537 -1022.8582920466409 253.92727687
743439 -164.28110797281954 -1069.8708183771473 248.91924307722587 -164.04439004849633 -1116.7088306956337 242.50826651764257 -163.78167699789327 -1163.3220545477841 234.69827182705001 -163.4876306394421
+-282.62388459051726 158.0343564927781 -160.85023455750976 -326.95958347014056 173.18081496594999 -161.19965812984279 -371.66858033185412 187.27371170000094 -161.51351740527127 -416.71333962885183 200.29774497658369 -161.81066081218032 -462.10260796438672 212.18938146824212 -162.03080609954088 -507.74925232864024 222.98418848828138 -162.30140717207794 -553.77194902334782 232.58056009653805 -162.37006395931365 -599.87186364597528 240.96532239280833 -162.65329538472085 -646.47635252399323 248.27456511592763 -162.55007485536629 -692.89523035422837 253.97219759761552 -162.80504004436972 -739.94153366293779 258.98953509469243 -162.61927292697916 -786.63340299106824 261.90078650319958 -162.72882252895232 -833.86393680668891 264.34235255606706 -162.55069868375375 -880.79161741450457 264.63932600704339 -162.47594260347691 -927.97971592625026 264.17098999123226 -162.28292146843864 -974.98583395918831 261.91809760735902 -162.07380051086892 -1021.992186591556 258.4940846
1002218 -161.81187828252351 -1068.837993465927 253.56886003498275 -161.5075129512403 -1115.5272708462865 247.29526497290243 -161.16240223553595 -1161.9950127692612 239.62667881846656 -160.77893981393427
+-284.53583936423911 163.25546706573562 -157.9300104148405 -328.71889228987067 178.22117176005264 -158.3622774416942 -373.26573916744684 192.15152739149161 -158.75694152590771 -418.152362984869 205.0034475879923 -159.11111145942479 -463.35506746320385 216.79243521238791 -159.41864900909493 -508.85992412937611 227.3796062837483 -159.68509726527981 -554.6436288137686 237.00416668199867 -159.88697866604031 -600.6475560012799 245.08834489339995 -160.07002956781088 -646.95233176437614 252.58299740987755 -160.14445929260353 -693.30442289866664 257.94145975436828 -160.25369422606224 -740.04413280598885 263.18145809251831 -160.19494812859017 -786.63653422949051 265.87326116968433 -160.21323994690641 -833.61284567245036 268.45170794069878 -160.0487907492101 -880.38741442835396 268.70081328697142 -159.93800387502529 -927.37126709555059 268.30964445840453 -159.69189112197267 -974.20128775501894 266.11088808219944 -159.43994702472398 -1021.0271808184125 262.77376425283177
-159.10536907405086 -1067.7006414103435 257.9509516740585 -158.72939630076948 -1114.2227188403758 251.79659141790628 -158.29731136277127 -1160.529575233141 244.26306231206951 -157.81972791813124
+-286.54147951824177 168.22558986543862 -154.76342801152134 -330.55782747870006 183.01770054084008 -155.28301529913998 -374.93037250868946 196.78890302400296 -155.7626721719943 -419.64375975957597 209.48276600357636 -156.17729265796427 -464.65283936797562 221.15010294586514 -156.57652930054903 -509.99621938947666 231.59093322219553 -156.83859335602179 -555.53785381030866 241.12831906674953 -157.18357268947562 -601.43402333115944 249.12686365935633 -157.25258573207952 -647.41019465796148 256.47919065519761 -157.53380160636081 -693.7316080246062 261.94013728004063 -157.45610864568525 -740.0778462432354 266.8904801644523 -157.5789584300525 -786.65510668071011 269.87566863046879 -157.44584581197074 -833.27030764821291 272.14083777061143 -157.35086415754023 -879.96104376846313 272.6755200955534 -157.15736691245698 -926.67216232828571 272.13767605494661 -156.88765647281511 -973.3477272634334 270.11006592736959 -156.57261466619076 -1019.9632122090026 266.794279782508
51 -156.17186886508577 -1066.4579410692925 262.09030373058573 -155.71769000552138 -1112.7958384026424 256.03846079706983 -155.19679716231406 -1158.9273215266001 248.63325650010182 -154.62129973691384
+-288.63032477011615 172.96587406139554 -151.34388908104245 -332.46608846057325 187.59220689730495 -151.95638468201432 -376.65372025226407 201.2050269871313 -152.52168947849006 -421.17594055884712 213.76109123901605 -153.01048043124808 -465.99331323825828 225.27471364260566 -153.48170577622091 -511.13675472152079 235.64963861438866 -153.78772775499493 -556.4718587242503 244.96640076099786 -154.20351167749308 -602.18189391239059 253.09073710954195 -154.26444237163088 -647.9039364065776 260.02555935838598 -154.63350523028313 -694.09413151553611 265.90501145579782 -154.48576433720535 -740.11746170696074 270.25321889155987 -154.70158977786977 -786.60948740465517 273.79665315343863 -154.46905994516308 -832.8884991595404 275.5491256484836 -154.42620733610414 -879.46875543192903 276.49089390012529 -154.14466095414096 -925.90005429532664 275.73321740716062 -153.86309804974161 -972.40981874348847 273.90307003176696 -153.4720483515714 -1018.8011003410504 270.58906331841
149 -153.01088035339933 -1065.1048061523552 266.00071653996065 -152.4730927448806 -1111.2441576351134 260.04166808471859 -151.86276709151798 -1157.1856198328603 252.75600901312686 -151.18677136189373
+-290.79528634542521 177.49065541216544 -147.65576112779485 -334.43691202468773 191.9585040966823 -148.36739415910273 -378.42827275691701 205.41588754902008 -149.01852621148109 -422.74352815343758 217.84699309539593 -149.59847355830195 -467.36735348976879 229.19560174977121 -150.11468619040406 -512.27768199563047 239.53430783248814 -150.5313851295559 -557.43812208083682 248.60235386802668 -150.91048061145429 -602.88051206846546 256.8738376920341 -151.13059182586755 -648.44043904311798 263.41150035438375 -151.38012389446092 -694.36093480209013 269.62648277227856 -151.39131346916989 -740.19192968757829 273.52576744572713 -151.49188896542631 -786.45315044915276 277.42109774603551 -151.32397595253855 -832.4992589638905 278.87278092784931 -151.2273862465577 -878.87480616529115 280.03302642677687 -150.91499158434925 -925.06810515331631 279.18298475917641 -150.59696893055693 -971.3711627506284 277.46488347392801 -150.13726842660134 -1017.5395495385585 274.18602558996
81 -149.61365485614419 -1063.6335666430132 269.68847869263288 -148.99134259868407 -1109.5623545451433 263.81976788313153 -148.29103177320027 -1155.2985407217363 256.64265658716226 -147.51357808966779
+-293.03102820270067 181.80567347554492 -143.67534227814713 -336.46526349409226 196.12130252900752 -144.49214924069389 -380.24690758811477 209.43120877694179 -145.23327484332293 -424.3444446575034 221.73652845652728 -145.91283523456914 -468.76034795273091 232.94313464133555 -146.4699770501413 -513.42883099253254 243.20294686582781 -147.01995740719613 -558.4055687494573 252.12600981537895 -147.33222143293489 -603.55450058102451 260.35883254634712 -147.76895756561026 -648.98177925644347 266.80080771429039 -147.82650064600051 -694.54987822915552 272.93754245829871 -148.09091728389248 -740.28058261243632 276.87802597080486 -147.9802684430343 -786.18258270521574 280.62040278942953 -147.97038356296696 -832.09844835261833 282.21260416128251 -147.74643310862061 -878.16660429416572 283.24847817829715 -147.45767159043322 -924.17345531365299 282.52345910321463 -147.07100289672894 -970.22111032752514 280.78575849523554 -146.56097260802773 -1016.172212674181 277.5955508325
2678 -145.96736983413339 -1062.0355957838547 273.15598675666052 -145.26428528008228 -1107.7424145379898 267.37746090880495 -144.47350705861894 -1153.2576446388082 260.2969978150818 -143.59558314210517
+-295.33254266738447 185.90574548537347 -139.37139503538353 -338.5459203585151 200.0753871593958 -140.29902086402302 -382.1028351500467 213.24939532600808 -141.14040078694916 -425.97490718694206 225.42073584514236 -141.91484539010409 -470.15950743919075 236.5265559670033 -142.54388710219277 -514.59613235182371 246.63287805404013 -143.18231592265988 -559.3436962286255 255.56203521828672 -143.51601264223007 -604.23336100914184 263.51779443860067 -144.05644688622229 -649.46955516432024 270.20475357700496 -144.06438226751453 -694.71322315584996 275.8460298671763 -144.44976775854312 -740.31432198140214 280.27327782902842 -144.23942738954349 -785.84255997281809 283.44392419782906 -144.32358450817298 -831.6380254101382 285.51193698649195 -144.00180101553016 -877.36075626145646 286.1800101324759 -143.73853129948614 -923.19314737030606 285.72122726475891 -143.27475541395555 -968.95711794660099 283.87983690098451 -142.72748932796534 -1014.6869027033896 280.8064496550462
1 -142.05869177154261 -1060.3021129644821 276.40269080842984 -141.28064277555697 -1105.7740770216431 270.7099762211887 -140.40031247287072 -1151.0527551370978 263.71516179021455 -139.42492787568514
+-297.69357598042569 189.77182735841274 -134.70538520753743 -340.67168766871794 203.80364336489964 -135.75027109727566 -383.98888543196756 216.85334188202185 -136.70562982492237 -427.62564092014799 228.88873400595543 -137.56549381741632 -471.55807084989709 239.92073558303898 -138.31417667211525 -515.76903110514422 249.83931068429141 -138.96472742129808 -560.24216024225166 258.83936398981029 -139.46991665741112 -604.91598340747635 266.44402838844297 -139.90702814851414 -649.87412026284835 273.45222733992341 -140.13944352253924 -694.87515475022917 278.54926699240389 -140.36134764750364 -740.23795771671234 283.46810877382916 -140.32098970562177 -785.47238194411477 286.10347205291328 -140.2983101040833 -831.06312298418743 288.57762961178366 -140.01572986484106 -876.48073132343768 288.94448197406479 -139.71105048864982 -922.09528432921991 288.68891746153355 -139.20399729795054 -967.57993368060852 286.77466898473847 -138.614110158822 -1013.067786038624 283.790544185
30825 -137.87563640617873 -1058.4240579848235 279.42292177902505 -137.02722004382665 -1103.6456819140767 273.803523968268 -136.06150733676128 -1148.6727933798472 266.88539098680832 -134.99373072214794
+-300.10461291463218 193.36719841573077 -129.63173205605028 -342.8315651275966 207.27352303471093 -130.80329425175913 -385.89520584317756 220.20774201299875 -131.88351911277795 -429.28111702798645 232.12293048078769 -132.83389253343688 -472.95171054849084 243.07013285256244 -133.72131869961888 -516.92112622408786 252.8558569774728 -134.37011628747052 -561.10808922449303 261.82685217573646 -135.0963175580963 -605.56750398499912 269.28069794143659 -135.37070098341354 -650.20041327497074 276.29726830690879 -135.92864782918519 -695.01636655374739 281.28650348113007 -135.87947261226302 -740.03169489435004 286.17851879063829 -136.13719472665949 -785.07737216480132 288.8086531967777 -135.90136590460094 -830.33954085603671 291.215326425184 -135.75492982006696 -875.5336396350566 291.63588546105728 -135.35110829606293 -920.85418844312346 291.34222986431087 -134.84571245542338 -966.08537027112379 289.48151119685321 -134.19890711976274 -1011.2994522151824 286.514928109204
73 -133.40657947532563 -1056.3912345533713 282.20114531299373 -132.49100008226728 -1101.3453915637913 276.6366275785096 -131.44842642105755 -1146.1067113877748 269.787775814263 -130.29571777748498
+-302.55027936875945 196.63214480646297 -124.09867377195116 -345.00878809130762 210.43085157350311 -125.41080151011678 -387.80531893574806 223.25836012175242 -126.61948707979882 -430.92113037747998 235.08386037329655 -127.6938294717588 -474.32791280719306 245.91219895084063 -128.67780053880304 -518.02283684533188 255.67410511266675 -129.44236136645196 -561.94298936484859 264.43417621645398 -130.21711499624141 -606.14074420511167 272.05534131292711 -130.6036670075614 -650.46846418835707 278.63761024502935 -131.17020640292952 -695.07801865587794 284.0781061087086 -131.19930271915885 -739.71888014212323 288.34059146742419 -131.46647105012423 -784.60845263498106 291.5352304410597 -131.24163690969576 -829.47551477024581 293.40309923110266 -131.11486062108622 -874.4901409641601 294.20936992188877 -130.6749500927767 -919.46365761920197 293.66447251100561 -130.16663281691447 -964.45651307731998 291.96287915857414 -129.46935460371637 -1009.370818234104 288.954867681581
33 -128.63803231951098 -1054.1914258773397 284.70711695138061 -127.66188475084866 -1098.8624703660591 279.18149824535084 -126.55469086998417 -1143.3445177916442 272.39409662133403 -125.32787458551151
+-305.00624771570477 199.47598730771287 -118.05077872487934 -347.17809328300928 213.19116244047339 -119.51897960268985 -389.69199766363192 225.92910689512476 -120.86179015612063 -432.52073770346897 237.69336887095687 -122.09558946300646 -475.65639135874301 248.39670715508728 -123.13584561419917 -519.0511281584744 258.19009008960933 -124.13899167676438 -562.72017920196015 266.68840193148992 -124.7832428957051 -606.60042644865564 274.56118704150731 -125.58152224711722 -650.68086402926122 280.65072274196126 -125.80127487092584 -694.98802482861754 286.57762543207934 -126.32465283536213 -739.34274307013811 290.23734434237923 -126.23324898282306 -783.97285108190476 293.92413986084955 -126.33666140541574 -828.51597127298203 295.35422639070833 -126.0326000177779 -873.28341218294918 296.44402735986114 -125.6892982161248 -917.93777997269797 295.72226655405825 -125.13199865420822 -962.66209212884462 294.12512387605409 -124.42021305239054 -1007.2758514211972 291.095527359
84016 -123.55572286368255 -1051.8104588332285 286.89502685927448 -122.53479280755825 -1096.1881116070658 281.40421706802744 -121.37745141352976 -1140.3783307323024 274.66804642777186 -120.09228887079669
+-307.43603165705963 201.76460214271575 -111.43468754876397 -349.30237258689334 215.42653140485939 -113.06868003954642 -391.51352614221599 228.11609034153105 -114.57523888129914 -434.04760022890764 239.8135528736658 -115.94122388213175 -476.88233380650672 250.50061507366703 -117.15486011098942 -519.99475837733303 260.15943500128378 -118.20661412751234 -563.3613140126979 268.77188059293593 -119.08938010168092 -606.95783535979717 276.31902031667721 -119.79825113036223 -650.75930312133016 282.78091158574961 -120.33009537857801 -694.73949645057883 288.13666784115378 -120.68307429124538 -738.87059305812465 292.36479704127652 -120.85623831738249 -783.12290288420377 295.44367390019954 -120.84925225426473 -827.46457937649279 297.35214389149894 -120.66232927219782 -871.86149717112733 298.07011826711766 -120.29637592287433 -916.27707982047218 297.57923519198022 -119.75336029960069 -960.67231850589008 295.86355002363877 -119.03685765431705 -1005.0059190015718 292.9103568
3392221 -118.1527024729882 -1049.234807339968 288.71111482643607 -117.10963260273053 -1093.3150452231505 283.26236759440428 -115.91975654559899 -1137.2032898211221 276.56622702286194 -114.59854612020514
+-309.78843542165504 203.30071871020056 -104.21035402633338 -351.32682673173264 216.95911893096147 -106.02351146323429 -393.21758022323519 229.64039633093631 -107.70197092189674 -435.43815106938808 241.32529955413222 -109.23089566500914 -477.96509807912111 251.99605017103431 -110.59702354546528 -520.77439092287398 261.63564364049728 -111.78959393289615 -563.8414969076747 270.22702217583264 -112.80056668457216 -607.14129261965434 277.75244628593714 -113.62440421670533 -650.64784922289891 284.19319030100087 -114.25762857408408 -694.33413909928731 289.52956082954842 -114.69831678410007 -738.17170752377933 293.74117173617492 -114.94565728820807 -782.13034782669104 296.80739075191514 -114.99965538390028 -826.1778136906488 298.70788699589997 -114.86104383378957 -870.27959935176909 299.4232411397964 -114.53142351061675 -914.3988182405858 298.93561593887824 -114.01362652974376 -958.49621348253879 297.22950922210691 -113.31226403658852 -1002.5303429327857 294.292608320
46498 -112.43440763793781 -1046.4580068705322 290.11671693663777 -111.39038195851553 -1090.2350546661914 284.698610137358 -110.19471288544827 -1133.8179128028266 278.04044934552792 -108.86726666671444
+8 0 0 8 12 -316.85092502627174 -208.31881794985125 -77.118625623353978 -320.84759491683792 -211.51300809594298 -56.958146503892507 -322.82352070815193 -213.80752547236713 -37.063075918091045 -323.05040828601051 -215.28622642400643 -17.448851882819767 -321.73681083024599 -216.02243695848344 1.8753303779846462 -319.04927558987248 -216.0799060941909 20.903742239954017 -315.12284318205565 -215.51444055583218 39.632480681038025 -310.06758590601783 -214.37530164311525 58.058629207223206 -303.9735581630174 -212.70627419035435 76.17974897201681 -296.91459277743979 -210.54658849881682 93.993368917483323 -288.95094157660964 -207.93183093751955 111.49638120772363 -280.13095676297559 -204.8948595496463 128.68440042795461 -270.49197115662889 -201.4667894486349 145.55102985683811
+-412.43600722367307 -240.76302839502512 -80.429428012745007 -414.20186403756145 -243.85116838025661 -59.553998302703903 -414.05541807377244 -245.87707279574096 -38.995636016398649 -412.2503748023596 -246.96821412421735 -18.769112991762267 -408.98207532027436 -247.22598312094073 1.1187317893407354 -404.40686355425856 -246.73425727238265 20.664907216469661 -398.65173998456044 -245.56320107437583 39.868560903554439 -391.82037763233075 -243.77266830905788 58.729827753807214 -383.99777414079449 -241.41450905506591 77.249134265446415 -375.25381820202256 -238.53412857109223 95.426678027100422 -365.64574900721283 -235.17176453594232 113.26189108664207 -355.21972058797405 -231.36366320038334 130.7528735106724 -344.01164028500529 -227.1432505654615 147.89573196042167
+-509.95126038604923 -267.35729638169823 -82.956768334283183 -509.33533695199327 -270.42571513860941 -61.393554083561611 -506.93813879336471 -272.26718261818388 -40.200087585590985 -502.99064875272512 -273.05474137268726 -19.390305532981085 -497.67172884404869 -272.91871359468649 1.0315158944159144 -491.12506812594103 -271.96363621833154 21.065270289666831 -483.46772554502274 -270.27429085998051 40.713299124390986 -474.79547698375762 -267.92122468678946 59.97892604182087 -465.18707527598281 -264.96437776298279 78.865561586056003 -454.70751657218761 -261.45531601993423 97.376168953339075 -443.4102654825216 -257.43888852161655 115.51280074659562 -431.33866452528622 -252.95466957455508 133.27611511178796 -418.52670654317825 -248.0383180086254 150.66479498023324
+-609.0363764279474 -287.73187389771078 -84.448036435351924 -605.90721184445874 -290.84750540317839 -62.244433275170948 -601.14881238819476 -292.2465805074001 -40.5755289032587 -594.96516968674302 -292.34736364584461 -19.386886636286654 -587.51568577906687 -291.46443915477607 1.372223580004992 -578.92914512053289 -289.83398429335455 21.742002738391939 -569.31090909776913 -287.62198722318942 41.75043320320426 -558.74747110320084 -284.93186702244367 61.411517250458523 -547.31024001148614 -281.80940505379687 80.724190755703518 -535.05844003558832 -278.24563789972927 99.671781231022692 -522.04105183782565 -274.1788831857142 118.22162423096403 -508.29803276147095 -269.49643817065936 136.32466843564006 -493.86100149838239 -264.03611820140225 153.9149820891374
+-709.32223569442658 -301.60408475337039 -84.815783073206973 -703.59883080157692 -304.81126394640046 -62.031946681979576 -696.41160679722111 -305.16653134151107 -40.171237962849567 -687.9352274054072 -303.72966135487911 -18.975899923366228 -678.30790130047274 -301.30890607657466 1.7644424718050389 -667.64215025506348 -298.49330755660367 22.204968494370551 -656.03054620854573 -295.66290046455401 42.444021832156274 -643.54942657861955 -292.99823497597112 62.521090002836274 -630.2621558698653 -290.48645977963395 82.415562780782111 -616.22161733905534 -287.92478769154548 102.0462018945942 -601.47183984167532 -284.92284345479328 121.27084471949439 -586.0490099332701 -280.90458993165123 139.88610131868415 -569.98205779335819 -275.11002343295399 157.62695067289604
+-810.46466730596467 -308.58836912526664 -84.073421918962552 -802.1211043130395 -311.92667751242232 -60.77599876569586 -792.48307926209873 -310.30765277218188 -39.124899264770747 -781.69593531497992 -306.02685978998647 -18.456894150509225 -769.87647017238487 -300.85040904036532 1.7548109132712124 -757.1206732006965 -296.05216366074035 21.892263744974379 -743.50805719404661 -292.42562002525665 42.19116028418744 -729.10457071528572 -290.29501271152662 62.738609984962821 -713.96533810508072 -289.52230316555432 83.471791846873288 -698.13673225020841 -289.51108243340042 104.17746300279208 -681.65768124507406 -289.20917214247902 124.49175695414542 -664.56047203261153 -287.11073730670523 143.89997205997739 -646.87123929559061 -281.25810789653548 161.73625635276863
+-911.97652330651124 -308.26526662374874 -82.24684393873622 -901.0322590391844 -311.78391929084665 -58.508142446301321 -888.9606319993311 -306.9412949540731 -37.584964175294012 -875.87904486158573 -298.06316424971493 -18.139500514219563 -861.88361519789544 -288.49338431642428 0.88035057916398785 -847.05423752746128 -280.63394585308487 20.232592975820001 -831.45764201573286 -275.95821836841532 40.379526576975927 -815.14958234059111 -275.02324877222543 61.485357150603747 -798.17707927753156 -277.47737121420715 83.414811650841585 -780.58008403455381 -282.06439977519256 105.73271279254614 -762.39247580905101 -286.62641114923423 127.70387497589716 -743.64266946288137 -288.10600068054754 148.29297955818328 -724.35401737373729 -282.54819648642058 166.16434390693135
+-1013.1539957250172 -300.38703243897697 -79.385025856905514 -999.67505855234538 -304.15923805716005 -55.283349719060965 -985.22798111217071 -294.53790897930656 -35.723704744621244 -969.90466386817718 -278.87424441200795 -18.357678824464397 -953.78206129139073 -262.86574974445267 -1.3468684885464182 -936.92502872796899 -250.59736269949136 16.628964895309068 -919.38828595445091 -244.55576087412493 36.370250991136743 -901.21798295238227 -245.64244400533735 58.155131634610228 -882.45349070295072 -253.18168264098003 81.738095959831398 -863.12868207045199 -264.92486430106476 106.349641928086 -843.27264586512854 -277.05339334075887 130.69626722844774 -822.91012115399417 -284.18104869810162 152.96042286115244 -802.06182787573835 -279.35595652849474 170.80035971815821
+-1113.2871331889701 -285.06822137736327 -75.785343601860248 -1097.3710674308868 -289.20716103072647 -51.387934948934401 -1080.6348458395191 -272.95566293897588 -33.928528719397768 -1063.1477043231891 -247.88784365568395 -19.645183150475162 -1044.9693171487404 -222.98766662689201 -5.6000608359102628 -1026.1508764447838 -204.68994247222986 10.312832663020199 -1006.7361339954552 -196.89548323461432 29.365929439703642 -986.76244720545742 -200.98462341530006 51.995591884835832 -966.26216896734104 -215.8252827768697 77.80081494873896 -945.26358298070136 -237.77736646755332 105.54298581823754 -923.79136690071573 -260.69573715392357 133.14596238486263 -901.86687951464262 -275.93264326387663 157.69609507629701 -879.5084372893632 -272.33972282567686 175.44214357515679
+8 0 0 7 5 -270.49197115662895 -193.84990937058819 145.551029856838 -271.02558562556226 -194.04699351326767 144.61729285660672 -271.5566244256525 -194.24277570467757 143.68190184134107 -272.0850681270411 -194.4372429843589 142.74486055323121 -272.6108972948428 -194.63038239007531 141.80617273828958 -273.13409248915667 -194.82218095784944 140.86584214689373
+-270.33023893567878 -195.66622490056895 145.83403447464693 -270.86545099836866 -195.86250356255073 144.89899587108562 -271.3980856128041 -196.0574853289157 143.96228930347607 -271.9281232310226 -196.25115733605824 143.02391842779559 -272.45554430085417 -196.44350671879525 142.08388690440154 -272.9803292659463 -196.63452061041397 141.14219839851893
+-270.51343370011176 -197.48254043130819 146.31415887053672 -271.05026826393595 -197.67801361266888 145.37679234440807 -271.58452384693072 -197.87219495553563 144.43774377314088 -272.11618083650256 -198.06507169165155 143.4970167008363 -272.64521961726598 -198.25663105147132 142.55461467524819 -273.17162057106492 -198.44686026421596 141.61054124813478
+-271.05054154637412 -199.19784160160361 146.97565881007458 -271.58891966433259 -199.39268183801769 146.03502531177836 -272.12471797945926 -199.58623415065742 145.09269603048261 -272.65793654555387 -199.77846729779355 144.148696464897 -273.18851639631851 -199.96940569146764 143.20298583950117 -273.71645758350451 -200.15901808849722 142.25558965667068
+-271.92184140946694 -200.71106274876576 147.78637381094185 -272.46162552227872 -200.90560502127701 146.84174174360891 -272.99882988087313 -201.09886109154749 145.89540051529394 -273.53345309527577 -201.29079485558523 144.9473695579384 -274.065439227794 -201.48144058661748 143.99761974928188 -274.59478689021489 -201.67076218100249 143.04617051926897
+-273.07732495295198 -201.93535240473267 148.69977281048679 -273.61835941846562 -202.13005614936716 147.75069564079786 -274.15681494869682 -202.32347246609069 146.79989601961225 -274.69267205803345 -202.51558870931029 145.8473770194646 -275.22591126366319 -202.70639223497244 144.89314170891348 -275.75651308555331 -202.8958704004869 143.93719315217049
+-274.44446884525416 -202.81157171763221 149.66218600547714 -274.98661575517207 -203.0069549348529 148.70853730220642 -275.52618500177755 -203.20104629771006 147.75315255251854 -276.06315721054426 -203.3938331055229 146.79603464519059 -276.59751301157883 -203.58530266090307 145.83718646221374 -277.12923303958075 -203.77544226957463 144.87661087814115
+-275.94009696839419 -203.31188628574657 150.62032632904629 -276.48326725231078 -203.50843174974958 149.66229222932975 -277.02386110699689 -203.70367818268895 148.70250784212999 -277.56185927339487 -203.89761277223897 147.74097587049718 -278.09724249879952 -204.09022271130286 146.77769900857569 -278.62999153678908 -204.28149519772123 145.81267994068594
+8 0 0 9 1 -273.13409248915633 194.82218095784921 140.86584214689375 -273.13409248915633 0 140.86584214689375
+-285.2493475660101 199.26352300438296 119.09128230012169 -285.2493475660101 0 119.09128230012169
+-296.09354029987423 203.05785911199212 96.52349583539177 -296.09354029987423 0 96.52349583539177
+-305.49475470310466 206.09210185932895 73.19949474775153 -305.49475470310466 0 73.19949474775153
+-313.24109198563792 208.24130601273563 49.164299892548875 -313.24109198563792 0 49.164299892548875
+-319.05706525379736 209.36476850345596 24.538321739078381 -319.05706525379736 0 24.538321739078381
+-322.64432543680834 209.31092543701226 -0.53981765980208607 -322.64432543680834 0 -0.53981765980208607
+-323.62095023305426 207.93018742008687 -25.716488820016988 -323.62095023305426 0 -25.716488820016988
+-321.8411622882212 205.22024849027659 -50.546760922325404 -321.8411622882212 0 -50.546760922325404
+-317.32883271750728 201.2824176360331 -74.639313893227083 -317.32883271750728 0 -74.639313893227083
+8 0 0 7 5 -317.32883271750575 201.28241763603086 -74.639313893226401 -317.23582959584058 201.2012553474305 -75.135882817809232 -317.14153684372849 201.11951346696316 -75.632103391089956 -317.04595488332063 201.03719335784982 -76.127970672294197 -316.94908413681367 200.95429638284139 -76.623479726236738 -316.85092502630562 200.87082390417442 -77.118625623183547
+-317.27797470018066 203.07384551199317 -74.910858659893165 -317.1840879875777 202.99316032437133 -75.408980717063713 -317.08890279450316 202.91190002220884 -75.906751025823894 -316.99241954386116 202.83006582389689 -76.404164602137385 -316.89463865896386 202.74765894730402 -76.901216468054884 -316.79556056340783 202.66468060972139 -77.397901651662423
+-317.60387824191906 204.86527338890807 -75.252967651296373 -317.50926218816875 204.78506530203342 -75.753494091647127 -317.41333901197089 204.70428657527754 -76.253667687466489 -317.3161090644499 204.62293828493955 -76.75348340656258 -317.21757269723093 204.5410215067833 -77.252936221725392 -317.11773026235596 204.45853731597583 -77.752021110730269
+-318.30926384509888 206.56057291323782 -75.651068123647704 -318.21412531095018 206.48073683535034 -76.154757561000409 -318.11767183929697 206.40033358142966 -76.658095285726517 -318.01988821903382 206.31937526176245 -77.161063808537975 -317.92080550125542 206.23784052805001 -77.663682861990424 -317.82040847540509 206.15574148974628 -78.165934961649711
+-319.36658991103582 208.06357169701383 -76.08491259101848 -319.27114233853024 207.9839032678789 -76.592349946398443 -319.17437311079033 207.90366917374541 -77.099438455584718 -319.07626856230343 207.82288442182795 -77.606164346846342 -318.97685606042899 207.74152164332654 -78.112539754375547 -318.87612193941959 207.65959584545999 -78.618550903988037
+-320.71737529113199 209.29113824651054 -76.53050493378025 -320.6218016206754 209.21135645458853 -77.042050072898036 -320.52490065188323 209.13100784881968 -77.553250214222842 -320.42667216554673 209.05009329450334 -78.064100164314681 -320.3271159418664 208.96861365764173 -78.574594724296901 -320.22623176053594 208.88656980502304 -79.084728689838613
+-322.28094166047379 210.18560932718779 -76.963687589480628 -322.18536619464555 210.10539592091911 -77.47945365372118 -322.08845860155958 210.02461158872546 -77.994878700387957 -321.9902184226753 209.94325724802457 -78.509957472221913 -321.89064519854952 209.86133381792271 -79.024684702346448 -321.78973846899765 209.77884221941704 -79.539055114220488
+-323.96682687943911 210.71838774356593 -77.363030951164234 -323.87129609353866 210.63744343677175 -77.88289238208344 -323.77442872279289 210.5559213979102 -78.402416121201853 -323.67622408804976 210.47382266557375 -78.921596839380754 -323.57668150927117 210.39114828120029 -79.440429194251394 -323.47580030578973 210.30789928940956 -79.958907830152157
+8 0 0 8 12 -309.78843540950083 203.30071870226513 -104.21035406366235 -310.52914727135419 203.78440257587008 -101.93559595813468 -311.24070386885188 204.25575524539352 -99.663853806702747 -311.92357930627918 204.71490663178449 -97.395159230131156 -312.57823455083769 205.16198496993292 -95.129542458118593 -313.20511796409806 205.59711681107845 -92.867032392589735 -313.8046658034001 206.02042702797314 -90.60765666849656 -314.37730269516356 206.43203882249446 -88.351441712174704 -314.92344208194589 206.83207373543053 -86.098412797307361 -315.44348664496425 207.22065165818304 -83.848594098554372 -315.93782870368608 207.59789084615605 -81.602008742909121 -316.40685059398669 207.96390793361891 -79.3586788588497 -316.8509250262718 208.31881794985134 -77.118625623353978
+-408.44211372167547 235.7394223154067 -108.51656988974794 -408.91874156831568 236.23712887252583 -106.15535821862657 -409.36783671381636 236.7197743754908 -103.79779457431343 -409.78984075189118 237.18757556997286 -101.44391302113775 -410.18518316736549 237.6407437539452 -99.093745711354487 -410.55428182203644 238.07948500949993 -96.747322995180483 -410.89754341321435 238.50400041809746 -94.404673523373816 -411.21536390670565 238.91448626092995 -92.065824342991078 -411.50812894588853 239.31113420588662 -89.730800986894351 -411.77621423843004 239.69413148243652 -87.399627557522678 -412.01998592209702 240.06366104559416 -85.072326805392862 -412.2398009110189 240.41990172999948 -82.748920202749574 -412.43600722367319 240.7630283950252 -80.429428012745007
+-509.24720071456915 262.21064090687588 -112.00398108336306 -509.43950628719313 262.73243425528716 -109.55918447701511 -509.60625679041254 263.23637401839005 -107.1186823708378 -509.74785237698643 263.722768527119 -104.68251118205148 -509.86468245050855 264.19191658923421 -102.25070486498491 -509.95712608861572 264.64410797631206 -99.823295072660827 -510.02555244271252 265.07962387229486 -97.400311305303674 -510.07032111568805 265.49873728754125 -94.981781047075089 -510.0917825190175 265.90171344187513 -92.567729892200333 -510.09027821056179 266.28881011973704 -90.15818166152188 -510.06614121430164 266.66027800019538 -87.753158510403438 -510.01969632316673 267.0163609642637 -85.352681028807808 -509.9512603860494 267.35729638169829 -82.956768334283197
+-611.81594590816087 282.38032312586131 -114.39250372827716 -611.70611114653661 282.93239000674657 -111.86931389238514 -611.57302700663547 283.46392933051749 -109.35107517788627 -611.4170441829524 283.97533994775733 -106.83782557771298 -611.23850427163461 284.46700714006943 -104.3296001081097 -611.03774011639894 284.93930336212952 -101.8264310201351 -610.81507613570852 285.39258892333373 -99.328347992516342 -610.57082863233666 285.82721261525705 -96.835378307834333 -610.30530608639936 286.24351229044646 -94.347547013795577 -610.01880943287927 286.64181539745033 -91.864877071148712 -609.71163232461447 287.02243947644456 -89.387389489627935 -609.38406138166852 287.38569261932548 -86.915103453149811 -609.03637642794763 287.73187389771078 -84.448036435351938
+-715.70508605939642 296.00766836846685 -115.57715938061038 -715.28210172683657 296.59160726612288 -112.98226121287689 -714.83837554630452 297.1526879564895 -110.39297750469764 -714.37420456184373 297.69139015980693 -107.80934611619618 -713.8898784997325 298.2081765520731 -105.23140155377175 -713.38568003143837 298.70349371993558 -102.65917521966945 -712.86188502286643 299.17777303709721 -100.0926956385165 -712.3187627706717 299.63143147033361 -97.53198866335164 -711.75657622639471 300.06487232232053 -94.977077663384975 -711.17558220914248 300.47848591765711 -92.427983695468328 -710.57603160751057 300.8726502377645 -89.884725661028085 -709.95816957141005 301.24773150970037 -87.347320450010017 -709.32223569442681 301.60408475337039 -84.815783073206987
+-820.48854529918901 302.72191885517935 -115.56218437390983 -819.74900369706916 303.33731329719132 -112.90306795260423 -818.99127438648065 303.92802025352194 -110.25022956888196 -818.21560120729441 304.4945851530685 -107.60370487628616 -817.42222239667115 305.03753383659068 -104.96352598964295 -816.61137077415322 305.5573736540191 -102.3297217545711 -815.78327391766925 306.05459447176418 -99.702317991495605 -814.93815433091049 306.52966959933718 -97.081337717031403 -814.07622960254878 306.9830566435549 -94.466801345268422 -813.19771255775174 307.41519829765934 -91.858726871192587 -812.30281140244199 307.82652307186856 -89.257130038214896 -811.39172986073436 308.2174459711382 -86.662024491547754 -810.46466730596501 308.58836912526664 -84.07342191896258
+-925.61317617241252 302.09510597814835 -114.36525827105994 -924.55966843034116 302.74188404671958 -111.65016004387761 -923.49047504007547 303.36271354889323 -108.94199097299526 -922.40578967838269 303.95819030226801 -106.24078290785742 -921.3058019731144 304.52888891554949 -103.54656413954501 -920.19069762031506 305.07536396073084 -100.85935967420593 -919.06065849615652 305.59815105013234 -98.179191480324675 -917.91586276390819 306.09776782815243 -95.506078712828028 -916.75648497617885 306.57471488647241 -92.840037916667526 -915.5826961726674 307.02947661045772 -90.181083212203561 -914.39466397366414 307.4625219636286 -87.529226464438068 -913.19255266954781 307.87430521629341 -84.884477437895669 -911.97652330651158 308.26526662374874 -82.246843938736248
+-1030.3081554903308 293.8505094713114 -112.02674348886961 -1028.9492977426287 294.5307816716799 -109.26467783165276 -1027.577118339467 295.18445059221051 -106.51016733692579 -1026.1917657339036 295.8121485334953 -103.76323904602746 -1024.7933856635407 296.41448578647152 -101.02391654970489 -1023.3821212122338 296.99205182190627 -98.292220252933163 -1021.9581128696725 297.54541638504941 -95.568167614383114 -1020.5214985888642 298.07513050525159 -92.851773363485023 -1019.0724138415881 298.58172742923409 -90.143049697678236 -1017.6109916718942 299.06572348569256 -87.442006462121881 -1016.137362747741 299.52761888805094 -84.748651313864102 -1014.65165541087 299.96789848140105 -82.062989872221593 -1013.1539957250176 300.38703243897697 -79.385025856905543
+-1133.8186489049076 278.0465879563987 -108.85882812117912 -1132.1670464295735 278.76743667731029 -106.05757924703558 -1130.5043010459965 279.4615667094281 -103.26448365212751 -1128.8305215080713 280.12963731353034 -100.47956327246229 -1127.1458149643395 280.77228552290472 -97.702836776530546 -1125.4502869765563 281.39012731051844 -94.93431981375879 -1123.7440415383319 281.98375866549782 -92.174025239405992 -1122.0271810937641 282.55375658822118 -89.421963318671445 -1120.2998065560262 283.10068001226568 -86.678141912439727 -1118.5620173258803 283.62507066048948 -83.942566646787526 -1116.813911310109 284.12745384170478 -81.215241068113528 -1115.0555849398686 284.60833919365621 -78.496166785518696 -1113.2871331889703 285.06822137736327 -75.785343601860276
+8 0 0 7 9 -273.13409248915633 194.82218095784921 140.86584214689375 -285.2493475660101 199.26352300438296 119.09128230012169 -296.09354029987423 203.05785911199212 96.52349583539177 -305.49475470310466 206.09210185932895 73.19949474775153 -313.24109198563792 208.24130601273563 49.164299892548875 -319.05706525379736 209.36476850345596 24.538321739078381 -322.64432543680834 209.31092543701226 -0.53981765980208607 -323.62095023305426 207.93018742008687 -25.716488820016988 -321.8411622882212 205.22024849027659 -50.546760922325404 -317.32883271750728 201.2824176360331 -74.639313893227083
+-272.98032926594055 196.63452061040437 141.14219839851404 -285.13239998422642 201.05768732943517 119.33618943490494 -296.01235306957926 204.83634999996551 96.73009291759459 -305.4472782636218 207.85780557083248 73.360302506534182 -313.22320262629302 209.99708670487377 49.270462835911189 -319.06295903991054 211.11448717306655 24.580799101351435 -322.66377413932094 211.05967995944815 -0.5711215947433983 -323.63706282828434 209.68446038704508 -25.83030636488645 -321.83317729810017 206.98854171645837 -50.742945847247789 -317.27797470024967 203.07384551209043 -74.910858659921388
+-273.17162057074614 198.44686026367236 141.61054124784906 -285.36111178272375 202.85185163668234 119.74930026328354 -296.27759568832215 206.61483243967857 97.08100337108857 -305.74747063567781 209.62352277284475 73.641046312409642 -313.55479015877268 211.75286592197719 49.47126825322627 -319.42102018964096 212.86419617840031 24.691233098412727 -323.03949264258091 212.80843970172322 -0.56325280069831241 -324.01528270680109 211.43873417573496 -25.936931716553278 -322.19447513477337 208.75683454870722 -50.968394883946736 -317.60387824430933 204.86527339226024 -75.252967652270058
+-273.71645757114021 200.1590180708636 142.25558964627004 -285.94169886429944 204.54962671453674 120.31748647818942 -296.89342479844049 208.30016574731434 97.565470775035848 -306.39774870980835 211.29877485571336 74.033468328818117 -314.23648474182949 213.42013305046041 49.761774967305733 -320.13112451299276 214.52670429713635 24.867316747922896 -323.77045517643313 214.47014365226619 -0.51455111263691045 -324.75475147230037 213.10480840644971 -26.030786993585878 -322.92536216990595 210.4339755299761 -51.213130590984008 -318.309263901625 206.56057298046409 -75.651068144782229
+-274.59478689967352 201.6707622009298 143.04617052851108 -286.85259242195866 206.05463474497893 121.01420656996146 -297.83686130451213 209.79927083950062 98.161625920727857 -307.37378754768099 212.79316333081968 74.520465943729818 -315.24291923892775 214.91058761637962 50.129550835354202 -321.16667465595253 216.01491903277181 25.102034187058329 -324.82931432812012 215.95790840530779 -0.42664897573101507 -325.82745898693588 214.59458945226382 -26.107116802283812 -323.99769928026421 211.92884622608767 -51.465131213119427 -319.36658986674161 208.06357162092291 -76.084912570784169
+-275.75651308586788 202.89587040103328 143.93719315245468 -288.0432678440053 207.28346442847047 121.80094716493775 -299.05689536068201 211.03117452998563 98.837414686226339 -308.62389563375228 214.02769097710689 75.076622965693858 -316.52196255647095 216.14683537183811 50.555524426633909 -322.47429867539614 217.25230675912997 25.383903934696395 -326.16189388518063 217.19542302475207 -0.30400860941627061 -327.17786068852297 215.83088584206908 -26.16213805815708 -325.35448374793521 213.16203306504454 -51.711319784562306 -320.71737528878413 209.29113824312742 -76.530504932809805
+-277.1292330395861 203.77544226958398 144.87661087814604 -289.44187430074402 208.1783561917135 122.63321439103328 -300.48203370123815 211.93916695453544 99.555698014101978 -310.07663382122576 214.94654465464879 75.672077768373043 -318.00213581656328 217.0738291186367 51.016890230322403 -323.98176397768788 218.18424164087605 25.69787694111611 -327.6949796937692 218.12815751082169 -0.15392031753303606 -328.73092004079166 216.75868746967583 -26.194205113590197 -326.91815686945267 214.07743878523408 -51.939710306295119 -322.28094166040546 210.18560932708985 -76.963687589452576
+-278.62999153678902 204.2814951977212 145.81267994068594 -290.96645396379665 208.71064843613351 123.46638482495297 -302.03107826544056 212.49410308192984 100.27883354692054 -311.6513054962748 215.52026448077444 76.276043766949428 -319.60255991177195 217.66184053810537 51.490351175850442 -325.60817999570043 218.78099435832587 26.027422659949575 -329.34635838196851 218.72631600187748 0.015263917360958834 -330.4026223311879 217.34829406035394 -26.203215694098375 -328.6018918695583 214.6456663472143 -52.140353529954325 -323.96682687943746 210.71838774356362 -77.36303095116368
+8 0 0 10 3 -77.897694326963673 -133.71402774466296 339.24594116210591 -53.824054812146429 -126.75501237563977 352.97958499446725 -28.184642875191344 -115.8072201649571 364.89078166365181 -7.3705776691133451 -95.886390529956685 374.73750698637451
+-101.48367508913071 -139.35160047496035 341.25988311767287 -73.014807885901405 -130.69495303096861 357.28796521179851 -28.833840530480998 -129.07524353238128 386.28183306007691 -7.5245475736574345 -105.95592937329612 399.77718696775378
+-125.06965585129765 -144.36040778182155 343.27382507323995 -92.174998593045174 -133.87441042471451 361.48351787078832 -32.34743429435072 -142.70315187949706 406.43397290544692 -10.926077346678102 -116.02546821663555 423.96238053887402
+-148.65563661346451 -148.83901931921159 345.27814523836452 -111.29675630838354 -136.44086877836347 365.55208657233771 -38.560556201128371 -156.75272027291817 425.80364503012811 -17.461791815036115 -126.09500705997498 447.54084104322294
+-172.24161737563134 -152.88600474109549 347.26322182260401 -130.37998389060286 -138.55088521214122 369.50072798571642 -47.410971499618597 -171.31624263391862 444.70482101035049 -27.004587291398956 -136.1645459033144 470.59831988722709
+-195.82759813779813 -156.59993370143829 349.21943303551592 -149.43269684189764 -140.35084394522676 373.35520193207924 -58.96950222391753 -186.42630708339246 463.19478322437959 -39.400745934363812 -146.23408474665385 493.11443780085312
+-219.41357889996493 -160.07937585420501 351.13715708665757 -168.46686288931917 -141.97413649433031 377.14899023589101 -73.095310646737175 -202.04498926005792 481.10176844125328 -54.461619727766987 -156.30362358999329 515.0101130313351
+-242.99955966213173 -163.42290085336066 353.00677218558644 -187.49434301216505 -143.54877627302869 380.91604633580613 -89.631365904391018 -218.17617022095325 498.32754619836004 -71.960321920183404 -166.37316243333271 536.18482238493016
+-266.58554042429859 -166.72907835287029 354.81865654185992 -206.52428476789154 -145.21064670091766 384.68977571184712 -108.34473308550473 -234.7962130623105 514.71084954961987 -91.633863765619878 -176.44270127667212 556.5419710316047
+-290.1715211864655 -170.09647800669893 356.56318836503544 -225.56006859719326 -147.11877263830934 388.50104525102711 -128.95689136196475 -251.90081974211185 530.14125281563452 -113.19117440640579 -186.51224012001154 576.00064698755205
+-313.75750194863252 -173.62366946881161 358.23074586467044 -244.59065761705639 -149.47019566886993 392.35831773885997 -151.15496347301408 -269.48678633711415 544.52165163321911 -136.32744173928484 -196.58177896335098 594.49203619044465
+8 0 0 8 5 -40.021144853065948 -128.79173811216748 475.37790691687883 -39.900397710009635 -128.92405438820785 474.51796769214792 -39.780934831392052 -129.02575047854174 473.65182101904088 -39.659584862579131 -129.09659186898381 472.78184227483069 -39.532959251891633 -129.13654483453928 471.91006743790132 -39.397452399782757 -129.14574677916761 471.03845732912373
+-38.116506372608491 -128.759074002912 475.5901950688197 -37.984083140533279 -128.89755066309823 474.73064077359288 -37.853584396425454 -129.00489726425431 473.86789787112951 -37.722045842794344 -129.08124487528261 473.00479527889308 -37.586344015945805 -129.12706687962441 472.1435735165494 -37.443178541311539 -129.14313268161987 471.28606518882486
+-36.21186753071612 -129.31923504576693 475.89369949697561 -36.067763272100564 -129.4736279407754 475.01861738900152 -35.926236928446912 -129.59572323777479 474.14285505729003 -35.784508946674812 -129.68587233278467 473.2696783932505 -35.639720515590334 -129.74489534680518 472.40157998839805 -35.488904652022164 -129.77403482219498 471.54036134354573
+-34.524823455975834 -130.47596446818065 476.26416914701952 -34.372971741180571 -130.65536396030785 475.35731531642648 -34.224291416355463 -130.80067827580282 474.45143292164857 -34.076176228442279 -130.91230908533964 473.55011467765468 -33.925770914673741 -130.99118085940279 472.65618267394291 -33.770463620516423 -131.03877291662755 471.77146564691765
+-33.272931250328064 -132.13827010287048 476.66278065121298 -33.121293511741023 -132.34844471269028 475.70991811213116 -32.97328578060884 -132.52223479692725 474.75865258389751 -32.825989545042106 -132.65984793328315 473.812881455774 -32.67702122162499 -132.76223012101153 472.87542100492277 -32.52361593065627 -132.83079378180764 471.94837882623807
+-32.622002397967087 -134.11868512051598 477.04177040834071 -32.480787626664643 -134.3593884024769 476.03327764562647 -32.34344494215263 -134.56108241204464 475.02604482641141 -32.207009312412183 -134.7238225395925 474.02388502822856 -32.068411889117399 -134.84815317975878 473.02994958569883 -31.924967454387566 -134.93537621150949 472.04645540049012
+-32.63148623909423 -136.17344176128165 477.35684759314483 -32.510208739636141 -136.43780150990344 476.2893707128834 -32.39275006219021 -136.66045409043056 475.22212761472912 -32.275609577088858 -136.84118923450649 474.15885021717958 -32.155451236729498 -136.98037198350889 473.10262004756521 -32.029157790985494 -137.07898688094213 472.05588391910067
+-33.25254624419069 -138.07053707367757 477.57788672009457 -33.157153108269561 -138.34687977169679 476.45450341324323 -33.065178578666426 -138.57903046935164 475.33002099760949 -32.972569816882199 -138.76664497104139 474.20790987562543 -32.875460662598371 -138.90991389743914 473.09115748019036 -32.770256670980395 -139.00959737054563 471.98235795668313
+-34.358790302547511 -139.6316306891415 477.69186808626966 -34.29061420731658 -139.90632791864553 476.52092667548976 -34.225124143408365 -140.13482995498285 475.34755783281093 -34.157713885738467 -140.31680235270321 474.17488607618344 -34.083990611446545 -140.45239752428279 473.00572230601568 -33.999875944408345 -140.54225606832352 471.84272788063907
+8 0 0 8 6 -39.397452338435848 -129.14574688288408 471.03845733812932 -38.959211285482795 -129.18047845662304 467.74866610985998 -38.656084324560254 -129.12002251494496 464.43785229895951 -38.473134722766801 -128.96416668325045 461.11924240231639 -38.384677846596539 -128.71547298816981 457.80284446842131 -38.36118750567028 -128.37381202973322 454.49536570065686 -38.370950400308594 -127.93964850496354 451.20106442617322
+-37.443178046916806 -129.14313378470939 471.28606526321067 -36.959432643421842 -129.18441679771271 467.93733595475271 -36.615804835342018 -129.12716270275203 464.57007987803121 -36.398111634950567 -128.97106353990321 461.20095206195009 -36.279642631375552 -128.72018709435301 457.84360147046931 -36.229841319936725 -128.37538169143878 454.50642080416674 -36.216373164531142 -127.93885680805236 451.19505725618797
+-35.488900755181533 -129.77404400857898 471.54036193436554 -34.959631785848018 -129.84630436644005 468.11762314065879 -34.575540334277093 -129.81542120828701 464.67767629478175 -34.323089361171242 -129.68028101061805 461.24070305215412 -34.174609282682809 -129.44598873354153 457.82415486638126 -34.098484267060343 -129.11445636818135 454.43821138059582 -34.061795875985695 -128.68948427583365 451.09001883137506
+-33.77044267076559 -131.03882651985739 471.77146886748022 -33.210088994015209 -131.16569433834113 468.26561567962779 -32.799622115451626 -131.18388423365579 464.74308483905816 -32.525774509682783 -131.09090907757508 461.22721965462432 -32.359579298327553 -130.89226821931166 457.73870675490599 -32.268157149944841 -130.5908406737542 454.28911846298701 -32.218260852147559 -130.19165496283171 450.88681508123034
+-32.523640781885192 -132.83080576746195 471.94837580373382 -31.961471109756776 -133.02703419262878 468.35877706262141 -31.553168573598619 -133.10843484415662 464.75307418824525 -31.28377210694368 -133.07070579674246 461.15691509955695 -31.123572030164194 -132.91949854028863 457.59290472237706 -31.039357954932481 -132.65876391525711 454.07309402874819 -30.996686922431152 -132.29398455272212 450.60627922056693
+-31.924995632949617 -134.93532609775036 472.04645130073789 -31.398300244181453 -135.1982807803557 468.3822463688399 -31.028083803939804 -135.33981968287392 464.70356150110183 -30.797667392998104 -135.35455903808 461.03718833611327 -30.675009615376595 -135.2479896529465 457.40571761302897 -30.625491165101735 -135.0248016049423 453.82036441273385 -30.6148212494024 -134.69074268414695 450.28932179973367
+-32.029162436178993 -137.07897805619481 472.05588323727972 -31.572188445897453 -137.386953201913 468.33490565901036 -31.272073109520349 -137.56685802136892 464.60277460594227 -31.10847730681488 -137.61311274357013 460.88602590978462 -31.047927915133158 -137.53169952064633 457.20519898182272 -31.055691087298172 -137.32828976166908 453.56943703644112 -31.097004975383733 -137.00838466617486 449.98524217429434
+-32.770257225248962 -139.00959629273393 471.98235787504478 -32.403666466898315 -139.32805786547664 468.22790323354002 -32.191307520826527 -139.51257027164439 464.4672376225148 -32.108992654065453 -139.55886003127765 460.72527109478585 -32.122186145791773 -139.47394756481069 457.01873490311698 -32.196474814759462 -139.26439896409912 453.35384386585503 -32.297312100679086 -138.93534179025815 449.73468877619217
+-33.999876004040829 -140.54225595501973 471.84272787188684 -33.727360011400862 -140.83295726634026 468.07976308763205 -33.603294679633443 -140.98564025288579 464.3165061081209 -33.600003724464557 -140.99873569956756 460.57505204249924 -33.682950665646075 -140.88073394593209 456.86717328572973 -33.818783225007877 -140.63889286956299 453.1958554876876 -33.973723777458744 -140.27781719733818 449.56251604563425
+8 0 0 8 5 -38.442757260314359 -125.68180366155485 438.57205112811948 -38.456928426054965 -126.25011636973501 441.07114846769633 -38.438931908052112 -126.7594268491807 443.58632756419536 -38.406946079737899 -127.21052087623191 446.11470172711472 -38.378552067822078 -127.60393548243539 448.6537674808219 -38.370950384253881 -127.93965552933948 451.20111679305325
+-36.216036898575041 -125.68439606255414 438.58345093702485 -36.240975227249379 -126.24778053684062 441.06192792830012 -36.235851636402991 -126.75517756420746 443.56500687122775 -36.218343120052147 -127.2064579170376 446.09015845168022 -36.205995102329986 -127.60128286904383 448.63458420285122 -36.216373463337646 -127.93886402336064 451.1951098688553
+-33.989316474635281 -126.47637281921821 438.41533906681519 -34.025018224505779 -127.03053977586963 440.89000305530107 -34.032775891239126 -127.52999038900838 443.39749683176041 -34.029740947278306 -127.97380500460804 445.93556643714487 -34.033432767415512 -128.36082098905234 448.50107614164983 -34.061795577271297 -128.68949419361149 451.09007164153763
+-32.105947164549242 -128.05734722123555 438.06595475105718 -32.147437151987937 -128.59877926737596 440.55679055529197 -32.162297515111234 -129.08454290436049 443.08700838671155 -32.167003442778913 -129.51317300596656 445.6545763475836 -32.179637989845631 -129.88295877584051 448.25602324108087 -32.218249687519041 -130.19169943865003 450.88686410776904
+-30.909135323291522 -130.25700572496632 437.57218058703012 -30.946217749296547 -130.78548957003693 440.09846833075113 -30.956331976606048 -131.25524779495439 442.66769138740085 -30.956579041438086 -131.66478377260216 445.27780160820237 -30.963650926075786 -132.01186756810199 447.92559518273066 -30.996706951403809 -132.29399721076362 450.60633348039909
+-30.632284885224887 -132.73148559802397 437.01095671526139 -30.652839683266887 -133.25265484213318 439.58587332042123 -30.644055568406689 -133.71090216662591 442.20359515949315 -30.622470333433562 -134.10481449557301 444.86231478817638 -30.606506415883295 -134.43235292844588 447.55895731948465 -30.614836236261901 -134.69071101581758 450.28938284502982
+-31.280335663378118 -135.06867469837456 436.47597380315705 -31.275110479531616 -135.59334041979884 439.10345192272439 -31.236485989739275 -136.05110289365703 441.77012315636057 -31.181707536932613 -136.44096005255957 444.47430561341952 -31.12886883012532 -136.76099513750782 447.21374460585963 -31.097005601303042 -137.00838687552928 449.98529953350146
+-32.667314470592551 -136.94017693034399 436.04291282077298 -32.633714709306552 -137.480534533423 438.71804850704046 -32.561929383239935 -137.95131609696415 441.42624991440704 -32.46970141679963 -138.35196465033712 444.16605528284009 -32.375209905396481 -138.68089153734383 446.9361305370229 -32.297310708485782 -138.93534699030883 449.73474631652982
+-34.509202236337352 -138.15819038376185 435.75601051812765 -34.451133927598903 -138.72430240742327 438.46782843902986 -34.35040414701789 -139.21999231783093 441.20527944425453 -34.225157574300631 -139.64515378151995 443.96713003981301 -34.093471508258837 -139.9986136132614 446.75296638660456 -33.973721473615825 -140.27782305619021 449.56257379590983
+8 0 0 8 10 -38.442757264327575 -125.6818036630418 438.57205112772903 -38.428996387602155 -125.20950437432514 436.4951629594101 -38.158386177464244 -124.57356159603573 434.4658379931272 -37.597891705482354 -123.78348845842 432.52675448743287 -36.71938779371385 -122.85598465167342 430.73401967986177 -35.586360592705162 -121.83852342527601 429.12833517647721 -34.266120368585234 -120.76170160484016 427.70422969756379 -32.818352668715519 -119.63424623121455 426.42969801063794 -31.262504640727791 -118.46926626821933 425.31391794523392 -29.639872858913748 -117.26993646768705 424.33450494942468 -27.971565508486457 -116.03315610316052 423.48472978526206
+-36.21603690141206 -125.68439606531021 438.58345093637519 -36.192900740086877 -125.25612309972753 436.69657078105973 -35.941807554059444 -124.70101284234222 434.8770381518907 -35.438230568039501 -124.02950253914108 433.14360598769161 -34.665172603940803 -123.26000876545736 431.52435296986033 -33.656011836545666 -122.39328760356285 429.98779945800561 -32.439461387036602 -121.44484501483288 428.59753221582929 -31.095090878995784 -120.43092075056435 427.30906211695668 -29.628181233795246 -119.35657629585327 426.15010273494897 -28.084449057229566 -118.22657646235909 425.1049538205358 -26.484556867557107 -117.03715922808674 424.17456165867418
+-33.98931643791714 -126.4763729470238 438.41533903796369 -33.956789540170526 -126.08660844682288 436.66010503048761 -33.725261600237694 -125.59500701858489 434.99243442748633 -33.278532286078573 -125.01200733136973 433.40954128243942 -32.611009581615775 -124.35646526233776 431.91472838434635 -31.725557328363717 -123.58696538916371 430.40951794083185 -30.61294306022689 -122.70953498221937 429.02461024844115 -29.371723450776955 -121.74908780073395 427.7025686990346 -27.993887848849734 -120.70432822488574 426.48922136527597 -26.529021040566047 -119.58323349815424 425.37477953244644 -24.997543329640706 -118.38280900260983 424.36716067641385
+-32.10594602893373 -128.05735102285848 438.06595389268773 -32.068667242588404 -127.69377925177186 436.35468937393858 -31.854028295470371 -127.23575647197367 434.74799159992267 -31.452044087410016 -126.69272138832051 433.22847903297281 -30.866183810914904 -126.08263719870479 431.78347342279199 -30.075645496355754 -125.33616602434712 430.26710652779781 -29.042470698713675 -124.45772417517307 428.85934868231732 -27.879313443162204 -123.47982662184386 427.4921112993448 -26.568577153204661 -122.39773045436176 426.22459754678516 -25.162466581558927 -121.22315593896499 425.05071159969862 -23.68138965019261 -119.95475884652826 423.98323488907363
+-30.909137322329531 -130.25700632081544 437.57218044081037 -30.876389401246094 -129.90015253680642 435.80082303375872 -30.673227970582886 -129.4368096738653 434.14401948028581 -30.291884555831537 -128.87479227171036 432.58032082950939 -29.739878801349303 -128.23027995749061 431.09415590211933 -28.986889528561417 -127.42794622383914 429.52445364393287 -27.983910683086581 -126.47797355209859 428.06806827699182 -26.848949572506402 -125.41702164228022 426.6516012723398 -25.561223506638683 -124.24017311597282 425.33901254639102 -24.173701179156076 -122.96191488461126 424.12479480685232 -22.707003372673011 -121.58262980311363 423.02352576460652
+-30.632286134923476 -132.7314818281678 437.01095756586915 -30.61551491570382 -132.35636878234402 435.08167319325139 -30.416436510744489 -131.84761007698322 433.26728763879476 -30.024517392090139 -131.21166242074872 431.55364102843595 -29.444764705161802 -130.46300006351154 429.93616820162759 -28.655474464425385 -129.54366889630259 428.27564728674611 -27.618830594688784 -128.47304252026296 426.7476983368278 -26.447531315496175 -127.28716033965988 425.28086554339012 -25.125329895771465 -125.98335649330775 423.93376090021826 -23.703888477808075 -124.57663899971206 422.69849369653855 -22.204251439466827 -123.06847064961185 421.58827263528258
+-31.280335703970501 -135.06867457034636 436.4759738320887 -31.287842038825005 -134.65028850385846 434.32163258492028 -31.085034026555846 -134.06486618680194 432.27307832348635 -30.654507460086066 -133.31859204812056 430.33194585649244 -29.993094266351338 -132.4252323068315 428.51473510883386 -29.102689893228259 -131.36070033568043 426.73364921390356 -27.975290239227188 -130.15254732548237 425.11395443700906 -26.709656996512464 -128.83194926557306 423.59239192990253 -25.300402139291116 -127.39950929883652 422.21442370261559 -23.796313495230226 -125.86819606433041 420.96789409995512 -22.21909523751075 -124.23959786359896 419.86231593240069
+-32.667314470533896 -136.94017692837051 436.04291282124188 -32.701328790775705 -136.45947875553057 433.63657857973328 -32.488074828938991 -135.78039787547922 431.31990125948334 -32.001104093682407 -134.91012106199267 429.11442577398986 -31.22579148615603 -133.86299357960567 427.06208051302696 -30.195527356940175 -132.65567858592394 425.1423179241724 -28.942295569414647 -131.32070033949302 423.41607673274819 -27.546269022368868 -129.88148911371189 421.83211168734562 -26.016291847305581 -128.34192077562741 420.41882067139437 -24.397435666977334 -126.71080123893009 419.15931436906862 -22.712254065940986 -124.98892953157528 418.0583277449216
+-34.50920223565398 -138.15819038472253 435.75601051791261 -34.565818843014235 -137.60548484491247 433.10836972845806 -34.337450478221051 -136.83061147776348 430.53066931435751 -33.788492238002718 -135.84272002842636 428.06424651737251 -32.892258084382988 -134.65778400262863 425.77545611268181 -31.714010937693793 -133.33139483679938 423.71261348331166 -30.326733495434187 -131.89764017981327 421.87296950909848 -28.791377134001124 -130.37094714051656 420.21845971537869 -27.131261673376066 -128.75797394095386 418.76026658815664 -25.387516004644986 -127.06211288351352 417.47751759619149 -23.58358700973918 -125.28273095270242 416.3702683227948
+8 0 0 8 7 -16.606510416298104 -106.93972081519725 420.34682756863407 -18.129299969016753 -108.36069700311045 420.4120804182956 -19.73035212167353 -109.73363261080091 420.61925575394793 -21.376158737823776 -111.06564374117559 420.95251786891919 -23.043510014834915 -112.36051952050786 421.40625243962398 -24.712290949630912 -113.61842738904079 421.97698079378489 -26.364181228949956 -114.84212415831502 422.66638498543034 -27.971618437120828 -116.03319449333357 423.48475709689359
+-15.417302751776987 -107.83146666514131 420.38777510721138 -16.916086524269996 -109.32857499287763 420.53390598795994 -18.488051492064191 -110.75861686941491 420.83495138566354 -20.099455191179995 -112.12743093854671 421.26903514163854 -21.726518156669812 -113.43887662769964 421.82522509088005 -23.3479180661428 -114.6931868073049 422.49624126167913 -24.94320428032967 -115.89186739816179 423.27847332534026 -26.484608964888121 -117.03719301430604 424.17459410543029
+-14.22809301143799 -108.73977402534631 420.06810329209867 -15.702870601599825 -110.34573546806715 420.2640086234087 -17.245752645339973 -111.87119577282036 420.62971339492805 -18.822758326510897 -113.32032125325833 421.13887766335853 -20.409498188798981 -114.6961674979927 421.7763200488551 -21.983562967583257 -115.99850770571834 422.53155780307662 -23.522227266061755 -117.22693540286599 423.39660169241773 -24.997599471477663 -118.38282809419137 424.36720847126657
+-13.120624788566353 -109.60334482049026 419.38502734220486 -14.580412671146174 -111.34012016704231 419.59379805154344 -16.104270711950505 -112.9885005860214 419.98707401613808 -17.657994380255555 -114.55116789123234 420.53557855675911 -19.216711245933592 -116.0302326186214 421.22121211716029 -20.757170631913592 -117.4249854025324 422.03126117632104 -22.25473633557765 -118.73332444818742 422.95497046623933 -23.6814613882927 -119.95473273584794 423.98332862104439
+-12.17681919057903 -110.35916117185424 418.37030910795767 -13.639713505882472 -112.23461811933751 418.5552895232679 -15.164745761343779 -114.01806008109726 418.93779640847623 -16.717428619135383 -115.71136069718081 419.48702559887687 -18.272637800894426 -117.31605315370346 420.18317296937596 -19.806775134862061 -118.83132477931619 421.01227693347317 -21.294198411149996 -120.25431832707623 421.96261848050648 -22.70701804078794 -121.58268282640459 423.02359239133494
+-11.46639333680381 -110.95174083716721 417.09131539990415 -12.957064742208226 -112.9587872198109 417.22329888775749 -14.510578721863554 -114.87237938218115 417.56378858640284 -16.09224648818687 -116.69417837318989 418.08124436929313 -17.67694882699978 -118.42580773043694 418.75511030228643 -19.241295928618342 -120.06714636099093 419.57122198346195 -20.759681583331844 -121.61588458091076 420.51863298733662 -22.204258918296784 -123.06858880673605 421.58826258678732
+-11.035799924005067 -111.34187379716087 415.64175728702969 -12.58088569693752 -113.46066740339296 415.70433075868357 -14.191790925267091 -115.48466495806909 415.98494341188763 -15.833377810724597 -117.41602104998186 416.45203543888829 -17.480625233455367 -119.2570125725755 417.08482557604952 -19.110943775815613 -121.00883990418289 417.86955256551346 -20.699726382812347 -122.67077676878985 418.79714754739803 -22.219134659187038 -124.23966877732671 419.8623373825294
+-10.901990530060871 -111.51198489451453 414.1269670714729 -12.524715182115745 -113.71449879995025 414.11847061053169 -14.217236830024532 -115.81964353859381 414.33704236690465 -15.943622642035995 -117.83059603539702 414.75131361955795 -17.678890568686679 -119.75083008792956 415.34043913253674 -19.401633336723169 -121.58346185292686 416.09140898072786 -21.088752888951138 -123.3300695964119 416.99757041710029 -22.712305270011452 -124.98898770739086 418.05835978142017
+-11.054505326196169 -111.46526743086993 412.64856964631474 -12.770727059096899 -113.72015824878396 412.58059164315307 -14.560099477561346 -115.87342273089919 412.7488608247134 -16.385425707706759 -117.92973773788434 413.12205410782877 -18.221695688633258 -119.89426672994468 413.67909376005963 -20.048859229583151 -121.77238432549201 414.40765358217817 -21.845533310462741 -123.5683295464374 415.30344782211665 -23.583643625726864 -125.28278775010696 416.37030282037574
+8 0 0 4 8 24.11799430847168 0 389.38369750976562 21.81732280654278 0 461.8703617886959 -5.0416867080167833 0 528.76164612448792 -51.444416232101666 0 589.54854911693701 -112.37624776260652 0 643.72206936583848 -182.82256329642601 0 690.7732054709877 -257.76874483045481 0 730.19295603217995 -332.20017436158753 0 761.47231964921059 -401.10223388671886 0 784.10229492187489
+24.11799430847168 -26.975478546922869 389.38369750976562 21.81732280654278 -33.11239536335669 461.8703617886959 -5.0416867080167833 -39.249312179790508 528.76164612448792 -51.444416232101666 -45.386228996224325 589.54854911693701 -112.37624776260652 -51.523145812658143 643.72206936583848 -182.82256329642601 -57.660062629091961 690.7732054709877 -257.76874483045481 -63.796979445525778 730.19295603217995 -332.20017436158753 -69.933896261959603 761.47231964921059 -401.10223388671886 -76.070813078393428 784.10229492187489
+24.11799430847168 -53.950957093845737 389.38369750976562 21.81732280654278 -66.22479072671338 461.8703617886959 -5.0416867080167833 -78.498624359581015 528.76164612448792 -51.444416232101666 -90.772457992448651 589.54854911693701 -112.37624776260652 -103.04629162531629 643.72206936583848 -182.82256329642601 -115.32012525818392 690.7732054709877 -257.76874483045481 -127.59395889105156 730.19295603217995 -332.20017436158753 -139.86779252391921 761.47231964921059 -401.10223388671886 -152.14162615678686 784.10229492187489
+11.960574875000637 -77.384834362685382 383.88269546296056 11.223193285585003 -96.019344818096371 452.84916379613202 -12.853054427669095 -114.65385527350735 516.83582778767754 -56.787640732225732 -133.28836572891831 577.02608368446795 -116.24770281204781 -151.92287618432928 630.81616335017304 -185.7269083771377 -170.55738663974026 677.39006332003578 -259.50427092947939 -189.19189709515123 716.76833996061475 -333.13892060363059 -207.82640755056224 747.91050592496686 -401.10223388671881 -226.46091800597321 770.5038922138699
+-7.3705776691133327 -95.886390529956657 374.73750698637423 -7.7555024304735607 -121.06023763830527 437.33670693982236 -29.017597774897517 -146.23408474665388 494.44277997017684 -69.219206589313671 -171.40793185500243 550.29568865729505 -125.6947244591118 -196.58177896335104 601.44367227183807 -193.6718315188204 -221.75562607169962 644.20556499628492 -264.55692543616175 -246.92947318004821 681.17399660370347 -336.08659476929216 -272.10332028839684 709.55305130764214 -401.10223388671875 -297.27716739674543 729.70868408985484
+8 0 0 7 12 -10.592833236353517 -91.66817574232924 373.21445633981972 -15.285575703057653 -96.347069627771646 370.99772609837277 -20.318674854527945 -100.5948555265075 368.62244144069115 -25.616884369370727 -104.42830574731289 366.11863751524407 -31.110578397597017 -107.85419734039846 363.49852657410258 -36.796987997190712 -110.8779917083708 360.77104474156391 -42.592860933889227 -113.50527415614201 357.94145655030241 -48.468587396053351 -115.76193976295055 355.02200263942979 -54.398597975204659 -117.72103923362781 352.02312154947026 -60.311906069096075 -119.46809153089103 348.94547248926062 -66.224966066929198 -121.04845931528966 345.79081896436526 -72.093343284370007 -122.55047809436093 342.55723483369781 -77.897694258123948 -124.06131943780454 339.24594120137806
+-9.7134465678229773 -92.746116233835423 373.62985598996841 -14.499441844877762 -97.47569267666276 371.36862852716638 -19.597310396399376 -101.78322891793343 368.9638255313875 -24.947654493443181 -105.69238681840527 366.43707987928599 -30.48852186988189 -109.20237727383311 363.79790427720758 -36.21494564797807 -112.33012913406587 361.05396743085748 -42.058437690274665 -115.07049102036761 358.20581649844883 -47.984141473819172 -117.42927337016931 355.26656130067136 -53.954148760740537 -119.47580773449735 352.25114842364133 -59.901196880273638 -121.30283201452558 349.1613331314382 -65.836590632540094 -122.95457312766708 345.99955154443842 -71.713231861699654 -124.5220133706041 342.76699104152124 -77.507084710327788 -126.09106597953124 339.46877807302383
+-8.9390942630097303 -93.824056812245544 374.26760999177503 -13.813680126257294 -98.60431609357245 371.95225402745899 -18.977497661907208 -102.9716007038529 369.51987286389135 -24.384723076727681 -106.95648010983214 366.97937042178961 -29.981013274101844 -110.55052308012061 364.33599981595256 -35.75858806260009 -113.78231038721545 361.59725095673218 -41.665434192707323 -116.63569592113488 358.75886192799663 -47.658179502624151 -119.09656879975012 355.82880675527269 -53.684320075605733 -121.23063227156551 352.82291886107134 -59.682931972366752 -123.13754018116994 349.74640564966364 -65.658438537880315 -124.86069292166694 346.60131665707127 -71.56252007286335 -126.49355046625304 343.39278279171907 -77.366339232018888 -128.12081250526549 340.12960048672693
+-8.3000407728263905 -94.864906681332343 375.11343691067987 -13.254030099265979 -99.695717265752251 372.7364714177674 -18.483330702337163 -104.12051578606577 370.27918805305683 -23.95155569946505 -108.1770310043178 367.7343895903478 -29.611308675911044 -111.84923431832013 365.10150088877123 -35.452309913267527 -115.17716752278979 362.38939350324785 -41.438285698888265 -118.13227665994737 359.58819301142341 -47.515761427452674 -120.68226200720032 356.69645594784458 -53.613359925511361 -122.89177649829013 353.72589604569066 -59.681333327608606 -124.86606176860623 350.68802822507109 -65.714809035971399 -126.64839153058476 347.58307816206246 -71.666432505211276 -128.33422569374122 344.42069915530055 -77.503016715928638 -130.00729149391807 341.21265892867837
+-7.8211850196509483 -95.831469731575538 376.14147420828988 -12.841327306724754 -100.71257663710442 373.69858485940563 -18.133853302327729 -105.1904294394147 371.21957966895275 -23.666108894124402 -109.31035081636951 368.67937784487998 -29.396493098692243 -113.04928112037614 366.06995289893308 -35.312854838010175 -116.45675679620317 363.4034444962312 -41.392633496528916 -119.49222204739536 360.66275643872012 -47.570255670953024 -122.10423404064184 357.83408360667664 -53.751847213129174 -124.36568564298626 354.92024334272651 -59.904097667753277 -126.38213120469031 351.94169564352188 -66.010606858464527 -128.19915886607637 348.89535918553986 -72.027523861162109 -129.91306446324904 345.79557297265876 -77.918335924990643 -131.60709005711146 342.65596739954071
+-7.5192642799076106 -96.689962025231736 377.31578925915284 -12.589258961932016 -101.62084160314416 374.80654998530485 -17.940933672619561 -106.145270398844 372.30917720131197 -23.538722266469097 -110.31665914031957 369.78099158294242 -29.34523704153159 -114.10608913286531 367.20489093054181 -35.346861654135068 -117.56880448653725 364.59805667881585 -41.532476028239586 -120.65487786582827 361.93425198440139 -47.820130228877815 -123.29014607143436 359.18444232836345 -54.093224932100604 -125.57124623253816 356.34032517291416 -60.338635555216456 -127.59482958885536 353.43257795353537 -66.527249897502458 -129.41299192922514 350.45384029235788 -72.621089429922634 -131.12108497860379 347.42272495867661 -78.581754413211527 -132.8025595040304 344.35338544141712
+-7.4014972029741877 -97.412750842018383 378.59329260211979 -12.503309895524549 -102.39237502455899 376.02145245166355 -17.908283067221074 -106.95533522681106 373.50904344877205 -23.571189575800023 -111.16351030749662 370.99821113473104 -29.456881791779534 -114.98367417459808 368.46133542886929 -35.550128922673366 -118.47243448699372 365.92177209929628 -41.849435115658999 -121.57325283381519 363.34267114924501 -48.248931894643931 -124.18724210806845 360.67588425580436 -54.614555400766179 -126.45139421283643 357.90423498713852 -60.953935444499464 -128.44315650395154 355.06743037709668 -67.225794859232465 -130.22577811104236 352.15395476773068 -73.399753174602864 -131.89175826124585 349.1856879203421 -79.437127520723919 -133.525539626794 346.17602174630082
+-7.4656659664160214 -97.980315285412004 379.92805342629583 -12.580898769473119 -103.00688835936555 377.30124891242787 -18.031766428146806 -107.59929465435192 374.77694060095001 -23.757280325266674 -111.828009597529 372.28636919676012 -29.722263347304764 -115.65689975398683 369.79042996637997 -35.908977289554592 -119.14128450888998 367.31856916122285 -42.324638791008987 -122.21683198146665 364.82332359144687 -48.828632224781252 -124.76641587356896 362.23161525447381 -55.281142888494131 -126.97674196703851 359.52540742430818 -61.706875775586226 -128.89983507675879 356.74879879526924 -68.055066671082045 -130.6128015206088 353.88787929200015 -74.303712981984219 -132.20398448020313 350.96622120301998 -80.415410045478353 -133.75949378479842 347.99545348933435
+8 0 0 7 6 -77.897694258319675 -124.06131943852613 339.24594120204245 -80.235318351649198 -124.67125335161347 337.91236233863145 -82.563351364034901 -125.28263456767996 336.5613315531333 -84.880085390590764 -125.90412726530943 335.19411251546728 -87.183800503910362 -126.54510351362271 333.81205210564485 -89.472210694914267 -127.21630074138861 332.41697364931122 -91.74190981369739 -127.93047920613498 331.01157015328675
+-77.507084713274978 -126.09106599032039 339.46877808301292 -79.840757903423111 -126.7243295581964 338.14063797020867 -82.161267920718799 -127.35786906068086 336.79717619106839 -84.466473380602366 -128.00011777940176 335.43999949115317 -86.754186552255604 -128.66020075782822 334.07087981970267 -89.021525867697392 -129.34812656865319 332.69219661746041 -91.264546832466323 -130.07496161270504 331.30715453096451
+-77.366339270060379 -128.12081264203016 340.1296006145588 -79.704555888683046 -128.7774074873123 338.81551412397715 -82.02617223123589 -129.43310264487056 337.48818559584043 -84.328578632168771 -130.09610789377808 336.1495201322586 -86.609110067694985 -130.77529915588119 334.80169851587931 -88.864184935817519 -131.47995263560833 333.44749852670691 -91.089000639529516 -132.21944402283654 332.09016711185143
+-77.503017128516078 -130.00729259468807 341.21266014407377 -79.855197079094069 -130.6822733700532 339.9205136674405 -82.187745180880654 -131.35515374195555 338.6169828511774 -84.497579336883447 -132.03391374677545 337.30410679271205 -86.781624390087686 -132.72723896260686 335.98449378376534 -89.035611501685779 -133.44389925976486 334.66117555824212 -91.253557534950133 -134.1918408841442 333.33685614810975
+-77.918335701606068 -131.60708870813431 342.65596640481976 -80.293278963424683 -132.29044704299287 341.39083340583653 -82.646166931258549 -132.97045200714786 340.11572164701391 -84.973612004054715 -133.65514660248562 338.8329350573643 -87.272150155561519 -134.35287633325808 337.54515380614282 -89.536823511643291 -135.07196482995235 336.25517780308843 -91.760376837403911 -135.81981383840025 334.96499979655243
+-78.581754378954003 -132.80255936230199 344.35338531799812 -80.985898244289331 -133.48093755991763 343.11590655642652 -83.366250281737209 -134.15470079730545 341.86917788536874 -85.719161958983392 -134.8318604318699 340.6154114234194 -88.041024742992676 -135.52074443092852 339.35745416642953 -90.326440522579517 -136.2297330831889 338.09790495398317 -92.566816655513165 -136.96639129524627 336.83761210524688
+-79.437127517994753 -133.52553961571934 346.17602173656536 -81.873271392784531 -134.18484384827605 344.96181816970261 -84.284534527213907 -134.83839559094619 343.73826656863002 -86.667189085555847 -135.49435155424524 342.50746890740527 -89.017640116438315 -136.16110865826209 341.27221310294021 -91.330243944081829 -136.84734460958015 340.03468430351762 -93.595335681765334 -137.56177434925436 338.79475226545065
+-80.415410045294976 -133.75949378406153 347.99545348868349 -82.88257264357226 -134.38747653318055 346.79613985540391 -85.324323194752665 -135.0088744829678 345.58655032813846 -87.737014643962979 -135.63210494608242 344.36860607764635 -90.117239598417868 -136.26573334960074 343.14493153870694 -92.459360791011946 -136.91904992138967 341.91724537727271 -94.753041543911706 -137.60264637648007 340.68475145762187
+8 0 0 8 12 -270.49197115662901 -201.46678944863487 145.5510298568382 -259.78198714957711 -197.65782266973332 164.29172922226428 -248.06089105275649 -193.3660179733773 182.63565106750826 -235.37989386766401 -188.6340572710042 200.57402074052874 -221.77341131709289 -183.50196597390527 218.0949980405035 -207.26055454356703 -178.0087817701521 235.18243464357579 -191.84511334097033 -172.19435472309956 251.81445667052461 -175.51436242111797 -166.10141413881939 267.96175386673599 -158.23693188224419 -159.77815019469256 283.58518932877399 -139.95928292374671 -153.28210400136496 298.63138605280494 -120.59652310216644 -146.68783257093773 313.02277646314406 -100.0038862084289 -140.10430907121548 326.63469616929916 -77.897694326964327 -133.71402774466341 339.24594116210568
+-344.01164028500534 -227.1432505654615 147.89573196042173 -331.55821772615116 -222.45390319332611 166.94335246014313 -318.13929901454389 -217.25552952568103 185.56119027556693 -303.8041397615678 -211.59398141581315 203.74390474994445 -288.58637800368001 -205.51081221110951 221.48311696197777 -272.50545415648219 -199.04526015382146 238.76628959830006 -255.56666511142686 -192.23622242325297 255.57542809758775 -237.76020630641551 -185.12442077128816 271.88546680317603 -219.05945656705998 -177.75476354279883 287.66208424345876 -199.41794953949454 -170.17923278588947 302.8579806303045 -178.7606336215697 -162.46320930946675 317.40443757670391 -156.95696061179802 -154.70501023275355 331.18991414001772 -133.75598694346095 -147.06539906947629 344.01552696822813
+-418.52670654317831 -248.03831800862537 150.6647949802333 -404.2911976741695 -242.57570515759238 169.98555038961692 -389.14166778679942 -236.57959524622828 188.84379407462146 -373.1247462949184 -230.09890299315521 207.23771935666954 -356.27281223041518 -223.17657531231652 225.16250901817267 -338.6053023369081 -215.85189326694299 242.6093517842971 -320.12882047487284 -208.16261816584927 259.56427648150651 -300.83642187662707 -200.14725846356458 276.00664439902715 -280.70633691838162 -191.84720395117088 291.90717602808559 -259.69946431909216 -183.30853696121133 307.22495151401512 -237.75109788588856 -174.5868765756 321.90058967130182 -214.74576358331706 -165.76923538074831 335.8365035162131 -190.46779628562683 -156.9929479016414 348.85802517619726
+-493.86100149838245 -264.03611820140219 153.91498208913745 -477.81985565050627 -257.96909601333874 173.45977503746778 -460.92190463382275 -251.35375335971059 192.50978739813345 -443.21052113949554 -244.2422940444882 211.06672453353335 -424.71636843723581 -236.67932567930737 229.12931563474592 -405.45855986594796 -228.70446506966638 246.6924778706418 -385.44481056628251 -220.35464227709014 263.74629491960718 -364.67096890373443 -211.66645271517137 280.27462731556034 -343.12019295405838 -202.67804064221011 296.25336338993174 -320.76097182243996 -193.42979906133363 311.64816527401831 -297.53934225874639 -183.96768763290893 326.40932820371904 -273.3556800567406 -174.36734514822618 340.45386962902768 -248.03168466420678 -164.74184855237627 353.63287989315529
+-569.98205779335831 -275.11002343295394 157.6269506728961 -552.12988874901168 -268.67161621217923 177.33900551090926 -533.48250707317516 -261.68830594550843 196.52442560287741 -514.07959751141607 -254.21628085771846 215.18825737011935 -493.94978494643459 -246.30262332032922 233.33262084715599 -473.11162666535824 -237.98818090678645 250.95602589291036 -451.57380269900762 -229.31000303869459 268.0524987067069 -429.33489848144052 -220.30374202357811 284.61032178228703 -406.38303119640909 -211.00524306899169 300.61053072639055 -382.69437916416393 -201.45014260365579 316.0254189822989 -358.22591233855479 -191.67575828072879 330.81506472204944 -332.89439839602267 -181.74711370140679 344.91140249049357 -306.55999038153919 -171.75353199707675 358.19207343459868
+-646.87123929559084 -281.25810789653542 161.73625635276878 -627.2165362544564 -274.75518632968016 181.5543500114257 -606.83093997312653 -267.73764648696368 200.81398927337 -585.75030049655311 -260.26686317363357 219.52326423942856 -564.00109085373902 -252.39376379261185 237.68741083219885 -541.60123499946064 -244.16191318935307 255.30827702887058 -518.56034349910169 -235.61005048646584 272.38359401454409 -494.87975058454134 -226.77448966288998 288.90585587790076 -470.55257240920099 -217.69036315820338 304.86108878176918 -445.56270515786258 -208.39016898101917 320.22811801723276 -419.8780982570126 -198.90443746006167 334.97669156061676 -393.43225602935638 -189.28911603795297 349.0536471863075 -366.12394111236716 -179.61153779798312 362.3632204422517
+-724.35401737373741 -282.54819648642058 166.16434390693144 -702.92218171913282 -276.37285849294619 186.02141540554038 -680.82510440653527 -269.74975977904774 205.28765390398758 -658.09481887585218 -262.74728531375973 223.97378185710315 -634.75564254174219 -255.42222698374954 242.08776514403135 -610.82485733243925 -247.82302517727356 259.63442195767777 -586.3130029349694 -239.99236699656103 276.61483182501473 -561.22416756656139 -231.96952732548056 293.02536586133726 -535.55644774696304 -223.79121601500955 308.85675507948332 -509.30136525296058 -215.48916884892813 324.09410742645338 -482.43771834952889 -207.0898434524492 338.71651746667158 -454.91584118901255 -198.64247733166962 352.68540943416014 -426.67242935319666 -190.19539362107577 365.93101430821088
+-802.06182787573835 -279.3559565284948 170.80035971815823 -778.89705756656519 -273.99474300670937 190.62251178149796 -755.13257297699511 -268.29771549896071 209.82036860442207 -730.79679651949664 -262.34247218685829 228.40678981729479 -705.91202482033952 -256.19408111504822 246.39200106559568 -680.49498861883899 -249.90842086504477 263.7833341927514 -654.55721754442789 -243.53479657058435 280.58476607829459 -628.10557786111224 -237.11815952679373 296.79611043610737 -601.14309338041164 -230.69952290125806 312.41240683364322 -573.6687274451773 -224.31273341001477 327.42465509914007 -545.67185030525252 -217.98346078923498 341.820770248526 -517.11946073540832 -211.75716600972717 355.57614332231458 -487.98471368202985 -205.66707199234003 368.64577675842833
+-879.50843728936331 -272.3397228256768 175.44214357515688 -854.66572370571942 -268.34758900545484 195.15997524055661 -829.28726340700598 -264.18181885086028 214.21802816146879 -803.39818186219577 -259.93177683192181 232.63078481846949 -777.01896756361486 -255.67353739582035 250.41023474320198 -750.16594036263245 -251.47327848590669 267.56573348090228 -722.85169980508977 -247.3898764698377 284.10366376490293 -695.08589915777202 -243.47695229191044 300.02679755204241 -666.87638683230705 -239.78284241757552 315.33401709656101 -638.22930513955976 -236.34670437943169 330.0217192193133 -609.14420078717444 -233.19702886980104 344.08597195093222 -579.60432082572265 -230.3787940422138 357.51530369025886 -549.61730957030238 -227.91457393853946 370.28786144860078
+8 0 0 11 3 -313.75750194863338 -173.62366946880474 358.2307458646697 -244.59065761705727 -149.470195668863 392.35831773885906 -151.15496347301416 -269.48678633711415 544.52165163321888 -136.32744173928498 -196.58177896335113 594.49203619044442
+-335.19930264151157 -176.83020716164128 359.74670722797543 -261.89119308965923 -151.60785296937945 395.86492909143556 -171.33502902851356 -285.47402869620714 557.59474146738671 -157.36041204190235 -205.73590518456879 611.30239001125585
+-356.64110333439044 -180.16748360670493 361.19968959929292 -279.18747826363017 -154.1082078915743 399.40917922018207 -192.81266044867692 -301.85511098591905 569.80873675283897 -179.68525600168687 -214.89003140578646 627.32132739774977
+-378.08290402726982 -183.70718582506245 362.58269531284594 -296.47192594270871 -157.11370330521811 402.99860274253552 -215.35960090874946 -318.62785746755605 581.09409508289309 -203.07979001644975 -224.04415762700413 642.49941585804584
+-399.5247047201496 -187.52100083778055 363.88872670285821 -313.72410895512115 -160.79861811175576 406.61422900545767 -238.72709478480056 -335.7935774157753 591.39465809810815 -227.31308605499328 -233.19828384822179 656.79492157756852
+-420.96650541302961 -191.68061566592598 365.11078610355355 -330.92737149396845 -165.32828095581436 410.26391151326214 -262.64632860362576 -353.35326134202029 600.6677380216712 -252.14968209927503 -242.35241006943943 670.17627175786299
+-442.40830610590973 -196.2577173305655 366.24187584915569 -347.9981535442908 -171.02587770827017 413.7773004238079 -286.83985353904461 -371.3074671811645 608.87932947199636 -277.35666576075465 -251.5065362906571 682.61754449756302
+-463.85010679878985 -201.32399285276583 367.2749982738884 -364.92252360803406 -177.94240932398327 417.13838882027585 -311.0236421569881 -389.64833397213704 615.98845570316405 -302.70948680685137 -260.66066251187476 694.09162298036028
+-485.2919074916698 -206.95112925359373 368.20315571197546 -381.51776467294047 -186.62124649365566 419.94623991584433 -334.90075994681195 -408.35151888147288 621.93312220212795 -327.99235433344074 -269.81478873309243 704.56565073482614
+-506.73370818454947 -213.21081355411593 369.01935049764057 -397.72475149090582 -196.60847526997176 421.64993288680176 -358.14979144218137 -427.3814369459497 626.63837429328032 -352.989074319319 -278.96891495431009 714.00342473093531
+-528.17550887742868 -220.17473277539915 369.71658496510759 -413.61105155318393 -207.26468393016037 422.13556816086952 -380.39415143165229 -446.71499164674498 630.06453906599006 -377.46018329856372 -288.12304117552765 722.37936307814141
+-549.61730957030727 -227.91457393851016 370.28786144860027 -429.29915942228911 -218.02727967284113 421.5357337041192 -401.10223388671852 -466.36701837287137 632.3008755491129 -401.10223388671886 -297.27716739674491 729.70868408985507
+8 0 0 7 5 -270.49197115662895 193.84990937058819 145.551029856838 -271.02558562556226 194.04699351326767 144.61729285660672 -271.5566244256525 194.24277570467757 143.68190184134107 -272.0850681270411 194.4372429843589 142.74486055323121 -272.6108972948428 194.63038239007531 141.80617273828958 -273.13409248915667 194.82218095784944 140.86584214689373
+-270.33023893567878 195.66622490056895 145.83403447464693 -270.86545099836866 195.86250356255073 144.89899587108562 -271.3980856128041 196.0574853289157 143.96228930347607 -271.9281232310226 196.25115733605824 143.02391842779559 -272.45554430085417 196.44350671879525 142.08388690440154 -272.9803292659463 196.63452061041397 141.14219839851893
+-270.51343370011176 197.48254043130819 146.31415887053672 -271.05026826393595 197.67801361266888 145.37679234440807 -271.58452384693072 197.87219495553563 144.43774377314088 -272.11618083650256 198.06507169165155 143.4970167008363 -272.64521961726598 198.25663105147132 142.55461467524819 -273.17162057106492 198.44686026421596 141.61054124813478
+-271.05054154637412 199.19784160160361 146.97565881007458 -271.58891966433259 199.39268183801769 146.03502531177836 -272.12471797945926 199.58623415065742 145.09269603048261 -272.65793654555387 199.77846729779355 144.148696464897 -273.18851639631851 199.96940569146764 143.20298583950117 -273.71645758350451 200.15901808849722 142.25558965667068
+-271.92184140946694 200.71106274876576 147.78637381094185 -272.46162552227872 200.90560502127701 146.84174174360891 -272.99882988087313 201.09886109154749 145.89540051529394 -273.53345309527577 201.29079485558523 144.9473695579384 -274.065439227794 201.48144058661748 143.99761974928188 -274.59478689021489 201.67076218100249 143.04617051926897
+-273.07732495295198 201.93535240473267 148.69977281048679 -273.61835941846562 202.13005614936716 147.75069564079786 -274.15681494869682 202.32347246609069 146.79989601961225 -274.69267205803345 202.51558870931029 145.8473770194646 -275.22591126366319 202.70639223497244 144.89314170891348 -275.75651308555331 202.8958704004869 143.93719315217049
+-274.44446884525416 202.81157171763221 149.66218600547714 -274.98661575517207 203.0069549348529 148.70853730220642 -275.52618500177755 203.20104629771006 147.75315255251854 -276.06315721054426 203.3938331055229 146.79603464519059 -276.59751301157883 203.58530266090307 145.83718646221374 -277.12923303958075 203.77544226957463 144.87661087814115
+-275.94009696839419 203.31188628574657 150.62032632904629 -276.48326725231078 203.50843174974958 149.66229222932975 -277.02386110699689 203.70367818268895 148.70250784212999 -277.56185927339487 203.89761277223897 147.74097587049718 -278.09724249879952 204.09022271130286 146.77769900857569 -278.62999153678908 204.28149519772123 145.81267994068594
+8 0 0 8 12 -316.85092502627174 208.31881794985125 -77.118625623353978 -320.84759491683792 211.51300809594298 -56.958146503892507 -322.82352070815193 213.80752547236713 -37.063075918091045 -323.05040828601051 215.28622642400643 -17.448851882819767 -321.73681083024599 216.02243695848344 1.8753303779846462 -319.04927558987248 216.0799060941909 20.903742239954017 -315.12284318205565 215.51444055583218 39.632480681038025 -310.06758590601783 214.37530164311525 58.058629207223206 -303.9735581630174 212.70627419035435 76.17974897201681 -296.91459277743979 210.54658849881682 93.993368917483323 -288.95094157660964 207.93183093751955 111.49638120772363 -280.13095676297559 204.8948595496463 128.68440042795461 -270.49197115662889 201.4667894486349 145.55102985683811
+-412.43600722367307 240.76302839502512 -80.429428012745007 -414.20186403756145 243.85116838025661 -59.553998302703903 -414.05541807377244 245.87707279574096 -38.995636016398649 -412.2503748023596 246.96821412421735 -18.769112991762267 -408.98207532027436 247.22598312094073 1.1187317893407354 -404.40686355425856 246.73425727238265 20.664907216469661 -398.65173998456044 245.56320107437583 39.868560903554439 -391.82037763233075 243.77266830905788 58.729827753807214 -383.99777414079449 241.41450905506591 77.249134265446415 -375.25381820202256 238.53412857109223 95.426678027100422 -365.64574900721283 235.17176453594232 113.26189108664207 -355.21972058797405 231.36366320038334 130.7528735106724 -344.01164028500529 227.1432505654615 147.89573196042167
+-509.95126038604923 267.35729638169823 -82.956768334283183 -509.33533695199327 270.42571513860941 -61.393554083561611 -506.93813879336471 272.26718261818388 -40.200087585590985 -502.99064875272512 273.05474137268726 -19.390305532981085 -497.67172884404869 272.91871359468649 1.0315158944159144 -491.12506812594103 271.96363621833154 21.065270289666831 -483.46772554502274 270.27429085998051 40.713299124390986 -474.79547698375762 267.92122468678946 59.97892604182087 -465.18707527598281 264.96437776298279 78.865561586056003 -454.70751657218761 261.45531601993423 97.376168953339075 -443.4102654825216 257.43888852161655 115.51280074659562 -431.33866452528622 252.95466957455508 133.27611511178796 -418.52670654317825 248.0383180086254 150.66479498023324
+-609.0363764279474 287.73187389771078 -84.448036435351924 -605.90721184445874 290.84750540317839 -62.244433275170948 -601.14881238819476 292.2465805074001 -40.5755289032587 -594.96516968674302 292.34736364584461 -19.386886636286654 -587.51568577906687 291.46443915477607 1.372223580004992 -578.92914512053289 289.83398429335455 21.742002738391939 -569.31090909776913 287.62198722318942 41.75043320320426 -558.74747110320084 284.93186702244367 61.411517250458523 -547.31024001148614 281.80940505379687 80.724190755703518 -535.05844003558832 278.24563789972927 99.671781231022692 -522.04105183782565 274.1788831857142 118.22162423096403 -508.29803276147095 269.49643817065936 136.32466843564006 -493.86100149838239 264.03611820140225 153.9149820891374
+-709.32223569442658 301.60408475337039 -84.815783073206973 -703.59883080157692 304.81126394640046 -62.031946681979576 -696.41160679722111 305.16653134151107 -40.171237962849567 -687.9352274054072 303.72966135487911 -18.975899923366228 -678.30790130047274 301.30890607657466 1.7644424718050389 -667.64215025506348 298.49330755660367 22.204968494370551 -656.03054620854573 295.66290046455401 42.444021832156274 -643.54942657861955 292.99823497597112 62.521090002836274 -630.2621558698653 290.48645977963395 82.415562780782111 -616.22161733905534 287.92478769154548 102.0462018945942 -601.47183984167532 284.92284345479328 121.27084471949439 -586.0490099332701 280.90458993165123 139.88610131868415 -569.98205779335819 275.11002343295399 157.62695067289604
+-810.46466730596467 308.58836912526664 -84.073421918962552 -802.1211043130395 311.92667751242232 -60.77599876569586 -792.48307926209873 310.30765277218188 -39.124899264770747 -781.69593531497992 306.02685978998647 -18.456894150509225 -769.87647017238487 300.85040904036532 1.7548109132712124 -757.1206732006965 296.05216366074035 21.892263744974379 -743.50805719404661 292.42562002525665 42.19116028418744 -729.10457071528572 290.29501271152662 62.738609984962821 -713.96533810508072 289.52230316555432 83.471791846873288 -698.13673225020841 289.51108243340042 104.17746300279208 -681.65768124507406 289.20917214247902 124.49175695414542 -664.56047203261153 287.11073730670523 143.89997205997739 -646.87123929559061 281.25810789653548 161.73625635276863
+-911.97652330651124 308.26526662374874 -82.24684393873622 -901.0322590391844 311.78391929084665 -58.508142446301321 -888.9606319993311 306.9412949540731 -37.584964175294012 -875.87904486158573 298.06316424971493 -18.139500514219563 -861.88361519789544 288.49338431642428 0.88035057916398785 -847.05423752746128 280.63394585308487 20.232592975820001 -831.45764201573286 275.95821836841532 40.379526576975927 -815.14958234059111 275.02324877222543 61.485357150603747 -798.17707927753156 277.47737121420715 83.414811650841585 -780.58008403455381 282.06439977519256 105.73271279254614 -762.39247580905101 286.62641114923423 127.70387497589716 -743.64266946288137 288.10600068054754 148.29297955818328 -724.35401737373729 282.54819648642058 166.16434390693135
+-1013.1539957250172 300.38703243897697 -79.385025856905514 -999.67505855234538 304.15923805716005 -55.283349719060965 -985.22798111217071 294.53790897930656 -35.723704744621244 -969.90466386817718 278.87424441200795 -18.357678824464397 -953.78206129139073 262.86574974445267 -1.3468684885464182 -936.92502872796899 250.59736269949136 16.628964895309068 -919.38828595445091 244.55576087412493 36.370250991136743 -901.21798295238227 245.64244400533735 58.155131634610228 -882.45349070295072 253.18168264098003 81.738095959831398 -863.12868207045199 264.92486430106476 106.349641928086 -843.27264586512854 277.05339334075887 130.69626722844774 -822.91012115399417 284.18104869810162 152.96042286115244 -802.06182787573835 279.35595652849474 170.80035971815821
+-1113.2871331889701 285.06822137736327 -75.785343601860248 -1097.3710674308868 289.20716103072647 -51.387934948934401 -1080.6348458395191 272.95566293897588 -33.928528719397768 -1063.1477043231891 247.88784365568395 -19.645183150475162 -1044.9693171487404 222.98766662689201 -5.6000608359102628 -1026.1508764447838 204.68994247222986 10.312832663020199 -1006.7361339954552 196.89548323461432 29.365929439703642 -986.76244720545742 200.98462341530006 51.995591884835832 -966.26216896734104 215.8252827768697 77.80081494873896 -945.26358298070136 237.77736646755332 105.54298581823754 -923.79136690071573 260.69573715392357 133.14596238486263 -901.86687951464262 275.93264326387663 157.69609507629701 -879.5084372893632 272.33972282567686 175.44214357515679
+8 0 0 5 1 -16.606510994248268 -106.93972034396965 420.34682837281952 -87.806808471679688 -106.93972034396965 420.34682837281952
+-18.738408156836872 -108.92909308502851 420.4381820900731 -87.806808471679688 -108.92909308502851 420.4381820900731
+-21.0348405277464 -110.81767455324831 420.82656237463061 -87.806808471679688 -110.81767455324831 420.82656237463061
+-23.37788980764363 -112.6301242247303 421.46332404163712 -87.806808471679688 -112.6301242247303 421.46332404163712
+-25.721207449671255 -114.36569527554879 422.33903563084675 -87.806808471679688 -114.36569527554879 422.33903563084675
+-27.971618427495201 -116.03319449982922 423.48475710136421 -87.806808471679688 -116.03319449982922 423.48475710136421
+8 0 0 7 5 -15.799640019991951 -106.18558153288312 420.32952844003808 -15.960898412836441 -106.33659744999154 420.32952844019195 -16.122250044865815 -106.48751522092711 420.33125985588339 -16.283664830585931 -106.63834064755412 420.33472089378978 -16.445112581361943 -106.7890793691422 420.33991065751547 -16.60656305100165 -106.93973691840851 420.34682913393937
+-14.465032505747359 -107.18554930657885 420.32952844811547 -14.621545521916506 -107.34083910777753 420.3386999140659 -14.778078489947987 -107.4958130143046 420.34970615552538 -14.93459883846762 -107.65047447867522 420.36253647097999 -15.091073843211275 -107.8048268722811 420.37718081591811 -15.247470656095761 -107.95887351819775 420.39362978882735
+-13.130424959200477 -108.18551710447767 419.86600962025818 -13.282192792561007 -108.3493323176085 419.88081690792143 -13.433906991626168 -108.51269706014156 419.8975990004692 -13.585532692905417 -108.67561152533115 419.91633733101293 -13.737034852636937 -108.83807588205742 419.93701368335627 -13.888378257903423 -109.00009028635482 419.95961017748061
+-11.919500368674774 -109.0928142341417 418.93901553806228 -12.067897207394791 -109.26831477294357 418.95506191025856 -12.216187048983123 -109.44332461525062 418.97323154773989 -12.364373504605588 -109.61777942238706 418.99356859003979 -12.512330924546079 -109.79179595036767 419.01591879492207 -12.660072685030379 -109.96531236349998 419.04031712423193
+-10.956218829556493 -109.81456237794762 417.61270488847958 -11.104043579531261 -110.00316609657735 417.62576608793216 -11.251742992156256 -110.19131786566557 417.64109275768203 -11.399232790723012 -110.37907051904067 417.65859455382503 -11.546564569247874 -110.56629682098367 417.67837132711827 -11.693664103654603 -110.75305213267792 417.7003230949648
+-10.33495763956476 -110.28004841965671 416.01702266678052 -10.485781288122411 -110.48138097662414 416.02414791934615 -10.636501685164824 -110.68234924782953 416.03367009001641 -10.787085498849537 -110.88294362145295 416.04555619354244 -10.93749964755988 -111.08315449677366 416.05977295481995 -11.087711295544942 -111.28297227746012 416.0762868297266
+-10.094831956559974 -110.45996494348869 414.31234313539449 -10.252071351742963 -110.67225603332545 414.31253761365127 -10.409262341867063 -110.88428655892594 414.31525201602625 -10.566375499602897 -111.09604340572838 414.32045228460328 -10.723381932807097 -111.30751341636226 414.3281041545676 -10.880253281264524 -111.51868338857544 414.33817320497218
+-10.223913988498131 -110.3632489646543 412.65249476461565 -10.390061809216249 -110.5840209756356 412.64649754193408 -10.556224424654879 -110.80462841530678 412.64314057286055 -10.722377015984886 -111.02505430351087 412.64239057910191 -10.888495547882368 -111.24528154249579 412.64421432477695 -11.05455675672766 -111.46529292133577 412.64857869602383
+8 0 0 8 3 -27.97156577868795 -116.0331554894704 423.48473028757149 -47.916646676351867 -116.03315548947042 423.48473028757149 -67.861727574015788 -116.03315548947042 423.48473028757149 -87.806808471679702 -116.03315548947043 423.48473028757149
+-30.05694981259122 -117.57913133100853 424.54694879536265 -49.363645763282655 -117.68125120619801 424.61711394188376 -68.613598649645482 -117.78337108138749 424.68727908840486 -87.806808471679702 -117.88549095657697 424.75744423492591
+-32.073220905452914 -119.06461139277904 425.81676023551421 -50.735309426371984 -119.2156029926029 425.95325452922373 -69.312191896218678 -119.36486314670053 426.09113076150237 -87.806808471679716 -119.51132277726764 426.23187681427311
+-33.947937084578676 -120.49951637861221 427.31615272351837 -51.985879960238584 -120.65472385170803 427.49992773657453 -69.937689891677564 -120.80608195871906 427.68780818359767 -87.806808471679702 -120.95721782677442 427.8748807693554
+-35.654661170034124 -121.85539123947756 429.06941991354267 -53.107308038000518 -121.98640965349861 429.26847710578704 -70.489100151136967 -122.11647727110346 429.46805545877749 -87.806808471679688 -122.24061040417105 429.67501500135376
+-37.066608783696736 -123.13785339465556 431.09648418395869 -54.016928424832273 -123.21446067030611 431.27498854480166 -70.930363751173914 -123.28912731284737 431.45584499154586 -87.806808471679688 -123.36533239671024 431.63421483385747
+-38.000290756379819 -124.23900231328859 433.45822106002299 -54.616774512717015 -124.26863777391358 433.55928546610295 -71.218783525845495 -124.29854430085419 433.65992101995539 -87.806808471679688 -124.32764032457196 433.7616325655834
+-38.425388369842892 -125.09142976885845 435.97594196404935 -54.889324321358224 -125.09853293457977 436.00717741298092 -71.349797688637153 -125.1056361003011 436.03841286191238 -87.806808471679673 -125.1127392660224 436.06964831084389
+-38.442757260272018 -125.68180366298387 438.57205112776415 -54.897440997407919 -125.68180366298388 438.57205112776415 -71.352124734543807 -125.68180366298391 438.5720511277641 -87.806808471679673 -125.68180366298391 438.5720511277641
+8 0 0 4 3 -38.442757260272202 -125.68180366153105 438.57205112812494 -54.897440997408026 -125.68180366153103 438.57205112812488 -71.35212473454385 -125.68180366153102 438.57205112812488 -87.806808471679673 -125.68180366153101 438.57205112812483
+-38.460431416844095 -126.392194592227 441.69592300551955 -54.909552941491313 -126.39286985973281 441.6988924257077 -71.35834529310317 -126.39354512723861 441.70186184589591 -87.806808471679673 -126.39422039474441 441.70483126608406
+-38.424666048076759 -127.00422243447639 444.84657340882222 -54.885858757306309 -127.00501015484386 444.85086321224202 -71.346572964822201 -127.00579755318485 444.85515305949463 -87.806808471679688 -127.00658462950693 444.85944295053804
+-38.380397833878241 -127.52000545261599 448.01693000072908 -54.856367552605782 -127.52050458661432 448.02071728923511 -71.331837765206259 -127.52100372061263 448.02450457774114 -87.806808471679688 -127.52150285461094 448.02829186624717
+-38.370950386165184 -127.93965552230544 451.20111679398542 -54.849569748003354 -127.93965552230547 451.20111679398536 -71.328189109841517 -127.93965552230547 451.20111679398536 -87.806808471679688 -127.93965552230547 451.20111679398536
+8 0 0 4 3 -38.370950400291015 -127.93964850494571 451.20106442617521 -54.849569757420589 -127.93964850494571 451.20106442617521 -71.328189114550142 -127.93964850494571 451.20106442617521 -87.806808471679716 -127.93964850494571 451.20106442617521
+-38.356157776164906 -128.59089372857511 456.14251592591535 -54.839922090185034 -128.59110765408269 456.1441391278704 -71.323472322023292 -128.59132157959024 456.14576232982546 -87.806808471679716 -128.59153550509782 456.14738553178051
+-38.423243595654313 -129.01109458944777 461.11665005440176 -54.884032066724167 -129.01031328662415 461.11318088445677 -71.345220424911261 -129.00953152800327 461.10971172413548 -87.806808471679716 -129.00874931360187 461.1062425734562
+-38.739759850992421 -129.19784384377382 466.10381238421468 -55.093832613305054 -129.19795306010974 466.09346739158696 -71.449515486867469 -129.19806227644563 466.08312239895923 -87.806808471679702 -129.19817149278151 466.07277740633151
+-39.397452398214767 -129.1457467704075 471.03845732936662 -55.533904422703074 -129.1457467704075 471.03845732936662 -71.670356447191381 -129.14574677040747 471.03845732936662 -87.806808471679702 -129.14574677040744 471.03845732936662
+8 0 0 8 10 -35.568095630307504 -112.64804701144766 495.28009490391821 -36.886033560129007 -114.96625309318358 494.74068336270517 -38.041207852907689 -117.26030456497163 493.82394541675473 -39.000850671402553 -119.49378269080151 492.52090674725429 -39.753918132534565 -121.62592371477916 490.80061710357245 -40.277463727707662 -123.49631371991134 488.78231171513517 -40.598175635169355 -125.18006222006457 486.40009288541796 -40.721773783866247 -126.52974101221413 483.83887513801301 -40.661575949602963 -127.5961151562741 481.10066830396147 -40.426143296962643 -128.34796117273453 478.2620512576803 -40.021106745728879 -128.7917345555492 475.37793002302698
+-33.913544349038077 -113.27907805914285 495.13326374904437 -35.167860290829616 -115.51993504790164 494.51819376923356 -36.261869506677144 -117.70986846965654 493.55035148269769 -37.168637085481912 -119.82274539328651 492.23539186525949 -37.881474204244547 -121.84132539222672 490.53899838855375 -38.376144428799677 -123.60771770396234 488.58656857307813 -38.68247680024691 -125.22766208426795 486.27498760816565 -38.797697930157341 -126.52491749999815 483.79728986362642 -38.73789621646489 -127.5645506506833 481.14495121303071 -38.508842600410361 -128.30711604265076 478.39158157337437 -38.116468662328238 -128.75907084366335 475.59021428542565
+-32.258991978526112 -114.02693296021725 495.48849955542289 -33.449686157406411 -116.26612859979562 494.80281056384922 -34.482547518474831 -118.43142506585141 493.77404200304369 -35.336420067867891 -120.50063986632257 492.41986790257283 -36.008926382601473 -122.47220931349042 490.70795085900596 -36.475039641612874 -124.19321093369248 488.76732158343367 -36.76659111000847 -125.7898650800693 486.47322925972185 -36.873694829585965 -127.06888081479605 484.02072928232292 -36.814208631435875 -128.10455255478198 481.39593999983509 -36.591541879648872 -128.85251611647229 478.66972210597032 -36.211830545778149 -129.31923105558334 475.89371506551231
+-30.766732190161584 -114.82969365084996 496.36011587290011 -31.906973183064704 -117.14784498411333 495.61687290587992 -32.891489287994908 -119.37653635248657 494.52361438648632 -33.703708893956673 -121.49067914324033 493.10543041116273 -34.344613195174844 -123.49402799132454 491.33683261019939 -34.788821769622309 -125.23997587274748 489.34681969556215 -35.068836911663752 -126.86117248489802 487.00911682211876 -35.17017686038907 -128.16218503890931 484.51392817396459 -35.111300612055373 -129.21975934528905 481.84848221428194 -34.894087799516029 -129.98884397543847 479.08155612360616 -34.524791046298091 -130.47595060049017 476.26418015035733
+-29.599959064768321 -115.60917858807434 497.69408715337596 -30.71625686367604 -118.08083578655524 496.91086330623739 -31.678199148941346 -120.45712560416976 495.75456381101378 -32.471291772834896 -122.70358549857032 494.25196129925865 -33.097987875267329 -124.81800915390993 492.38840269585046 -33.532901311974015 -126.66056262169771 490.28835872719964 -33.807975298367118 -128.35414152456076 487.8459448848181 -33.907673079572696 -129.71746256021547 485.23963692255978 -33.849949423147201 -130.82205062127272 482.46461282908587 -33.636303118235503 -131.62678712327394 479.58854740836802 -33.272889332256071 -132.1382624426343 476.66279245661781
+-28.886364408126546 -116.28427714557363 499.36245769804185 -30.014023653010163 -118.96607210617667 498.55555940051835 -30.98752310275902 -121.55599984139822 497.33946660525777 -31.791462256877253 -124.00535653994309 495.73726855196952 -32.427413307808209 -126.2959798536519 493.74817754069426 -32.870144842008365 -128.2949574147604 491.48755225043084 -33.149853496957704 -130.09984145103255 488.88965642188589 -33.253706174158104 -131.55850991842232 486.11521480756744 -33.198103421337976 -132.72985615945024 483.173238570352 -32.985488299114209 -133.58097672856994 480.13127391814209 -32.621958675774472 -134.11868785871724 477.04178425685183
+-28.688594371545452 -116.78886149267396 501.18927478154512 -29.863801614249912 -119.71203475728767 500.3693016976253 -30.883411052472947 -122.55379334971775 499.09588945688529 -31.72788303437083 -125.24819946296574 497.38470641105454 -32.395733323512374 -127.75417479681653 495.25094273621789 -32.862285269214112 -129.94625134834652 492.7971648142173 -33.15533140759517 -131.88485794419063 490.01161281587378 -33.268316325192416 -133.4583146835154 487.03296458788571 -33.215411685709284 -134.7071541786691 483.88789350684993 -33.001172803876862 -135.60984205660216 480.6445251786522 -32.631446055314086 -136.17343439174115 477.35686112385275
+-28.992900505838975 -117.08550751731231 502.98994740327811 -30.244293791482189 -120.25475761286835 502.1603974609871 -31.336670449182257 -123.35640656723638 500.8306614559437 -32.244048546369442 -126.30647597866046 499.00744184042719 -32.960580242531378 -129.03784581095695 496.72305461852415 -33.462741875194418 -131.43342626329778 494.06501406390629 -33.775532854495488 -133.51004978965571 491.08177774270945 -33.901208322687054 -135.2025931825614 487.88779901458429 -33.851250132675432 -136.52987707608202 484.5287409448494 -33.633169960793154 -137.48341332579278 481.0735997311516 -33.25250474110895 -138.07052826522406 477.57790294238316
+-29.727320377057943 -117.16625635375637 504.60593211599007 -31.071383854858112 -120.5635661920174 503.76468087945887 -32.251025263755494 -123.90701465989967 502.37914598106772 -33.232671712223549 -127.0956031899827 500.4474894114818 -34.005854308953133 -130.03665500610524 498.01923337544173 -34.548974446302417 -132.62256630264548 495.16610985272195 -34.884156989860323 -134.82559794303816 491.99571566895639 -35.023794172750037 -136.628058900582 488.5982722456863 -34.976472534500317 -138.02625613639242 485.03747530142198 -34.753069622074989 -139.02491896288993 481.38311758727093 -34.35874715064628 -139.6316217605432 477.69188796372202
+8 0 0 4 3 -39.397452398193927 -129.14574677915778 471.03845732932473 -55.53390442268919 -129.14574677915775 471.03845732932479 -71.670356447184446 -129.14574677915775 471.03845732932479 -87.806808471679716 -129.14574677915772 471.03845732932484
+-39.566722640578973 -129.13424419522499 472.12798432163459 -55.649246859820501 -129.13407491421586 472.14401865181753 -71.729275470187403 -129.13390563320672 472.16005298200048 -87.806808471679716 -129.13373635219756 472.17608731218348
+-39.721473822523471 -129.07133678121539 473.21792289352874 -55.752410289322775 -129.06963741873449 473.23729912978456 -71.780819514247398 -129.06805283982447 473.25663530948287 -87.806808471679673 -129.06630040048765 473.2759746721627
+-39.870137406189016 -128.95713219910371 474.3029910801402 -55.850424485917976 -128.95509586979117 474.31622542635915 -71.829314841081541 -128.95305954047859 474.32945977257828 -87.806808471679716 -128.95102321116599 474.34269411879728
+-40.021144853737212 -128.79173811086466 475.377906916602 -55.949699393051354 -128.79173811086471 475.37790691660183 -71.878253932365524 -128.79173811086471 475.37790691660194 -87.806808471679716 -128.79173811086469 475.37790691660183
+8 0 0 7 7 -19.323704752184224 -37.19422992968795 502.60592506491372 -20.323551678060465 -48.246590580238419 503.10653838988878 -21.480321293091507 -59.324737256134902 503.03186583247219 -23.001532805420723 -70.366134600355878 502.4084618023864 -25.080050330638596 -81.319211284189421 501.26614427711854 -27.887241884327569 -92.065241174870096 499.65039788167593 -31.4041981702442 -102.52028670986658 497.63667217944118 -35.568095716008983 -112.648046997639 495.2800949963202
+-17.249101191335377 -37.376383355431699 502.61417553973627 -18.250882506614744 -48.45363632490875 503.10777785682615 -19.415586846092847 -59.583051234128149 503.02496374278553 -20.951107566729267 -70.700532496608275 502.38787100995302 -23.053619805422827 -81.751567050621063 501.22151856779249 -25.898950193137836 -92.602654133305265 499.57012983439188 -29.462948354920336 -103.15567503300048 497.51436792070302 -33.677180111598318 -113.36922521805062 495.11228769763903
+-15.174497568434361 -37.525828083819789 503.3445569831897 -16.178214672189299 -48.660180574252315 503.83276169524652 -17.350854749873573 -59.871908162103196 503.73940695913581 -18.900632769031407 -71.094982641878957 503.08298118074572 -21.027275560456594 -82.271387150174036 501.88391534560492 -23.910614064799262 -93.2526908910354 500.18578571501217 -27.521693657768399 -103.92626477749232 498.0750546541048 -31.786264266506297 -114.24616759161175 495.61390087562472
+-13.399495254580749 -37.616267299798309 504.79568689201545 -14.40493401853168 -48.836317600848147 505.28111908823081 -15.58349194618356 -60.15406502750001 505.17600665774222 -17.143800022880956 -71.501432959283363 504.49657659960144 -19.288960839086943 -82.816910007732432 503.25957664586383 -22.201857817737945 -93.939431052581725 501.50860310579662 -25.850244037539817 -104.74353813747899 499.33565249952926 -30.155020928942804 -115.17980161458181 496.80782569740541
+-12.22602155152655 -37.62822226902783 506.81113767776935 -13.232751633894427 -48.952018534297196 507.29706307360641 -14.413157121305902 -60.385411753930313 507.18112685856755 -15.976542468470141 -71.85859460170991 506.47904894746847 -18.128742665412172 -83.307318674062827 505.20540127952694 -21.054339058291418 -94.562738890199839 503.4043324512312 -24.720305414151511 -105.4903407590419 501.17198973127086 -29.044891695574822 -116.0385568285898 498.58034454251276
+-11.839850285577045 -37.559800388059777 509.07184125803383 -12.84728070621855 -48.988966194943004 509.56137227761741 -14.024571969541473 -60.529320225186915 509.43828827151259 -15.581990185169889 -72.110155209420199 508.71940806322823 -17.727059931217635 -83.665889469358362 507.41886044896097 -20.644505936239241 -95.026320587317869 505.58157767508743 -24.303369650602544 -106.05307376641339 503.30542842200464 -28.62212967468222 -116.69382593343215 500.66600474235025
+-12.228066974027675 -37.427536022433884 511.23784331535791 -13.23555337989761 -48.948693175785365 511.73324707365413 -14.405703267173937 -60.572918792686984 511.60834405551685 -15.949855825393184 -72.229693775889501 510.88216324728421 -18.07600412470201 -83.853667839686366 509.56994052294607 -20.96750611512892 -95.279444150162703 507.71741354410472 -24.597727373773314 -106.37014952053281 505.42142584545024 -28.88798319693645 -117.07397210495056 502.75909270827066
+-13.244107433710264 -37.256166894002412 513.04768371761452 -14.251052356417212 -48.846016205985187 513.55015173013442 -15.41181489804722 -60.523279677135406 513.42898251464669 -16.93868348642669 -72.218682409168352 512.70597254154359 -19.038946537067989 -83.868454267182756 511.39862702386182 -21.893340045145315 -95.316741093693395 509.55342204775781 -25.480815111292447 -106.4327529676558 507.26376557929763 -29.727320322740713 -117.16625638448777 504.60593215421267
+8 0 0 8 3 -40.021106745724808 -128.79173455553911 475.37793002302612 -55.949673987709772 -128.79173455553911 475.37793002302612 -71.878241229694723 -128.79173455553911 475.37793002302607 -87.806808471679688 -128.79173455553911 475.37793002302607
+-40.527402413834629 -128.23701781508848 478.98308155309326 -56.285342227751038 -128.23973280221415 478.96543661960465 -72.045144247032709 -128.24244778933985 478.94779168611598 -87.806808471679688 -128.24516277646552 478.93014675262731
+-40.761835254206503 -127.18538099758963 482.51647275348313 -56.433043971818861 -127.20849659616202 482.40000800180712 -72.114489189495799 -127.23179001980893 482.28301115120422 -87.806808471679588 -127.25480677223288 482.16499985203262
+-40.70770276214904 -125.64179000561398 485.84463959098696 -56.400055552278012 -125.73336789864858 485.60341257140476 -72.100377884517883 -125.82342877425855 485.36417197628117 -87.806808471680043 -125.91392211109702 485.12881185937511
+-40.356665031807694 -123.60132397424952 488.87890870272912 -56.190294845248559 -123.81466906182352 488.53838682452408 -72.002618868225056 -124.0245629752168 488.18790984954751 -87.806808471679176 -124.22706388475075 487.82422676563885
+-39.659850961439524 -121.16806698419215 491.39886333564607 -55.764031793996544 -121.51821656788934 491.03551380773786 -71.812390912372436 -121.85740333073954 490.67488838856224 -87.806808471680057 -122.18942895009801 490.31897425549442
+-38.600669138128339 -118.40132247662251 493.32817987217788 -55.114304465523567 -118.85846848545154 493.06310106869245 -71.50165230512512 -119.28988499396658 492.77357037382677 -87.806808471679588 -119.69655740519025 492.46162178464283
+-37.215515892960688 -115.54580528055598 494.60583020127854 -54.201284740908058 -115.91759512307496 494.51932030800066 -71.065048933814396 -116.28938496559398 494.43281041472272 -87.806808471679688 -116.66117480811299 494.34630052144485
+-35.568095680464978 -112.64804698697162 495.28009488539317 -52.980999944203198 -112.64804698697159 495.28009488539317 -70.393904207941446 -112.64804698697161 495.28009488539311 -87.806808471679688 -112.64804698697161 495.28009488539317
+8 0 0 7 9 -14.037858895078896 -24.607201894381969 496.44272783807361 -14.891619296528024 -25.705564968610005 497.62843243564259 -15.70784160895187 -26.894615842663907 498.71828189185089 -16.478217809351801 -28.17145084177335 499.70078090671331 -17.183681533967214 -29.52755316142748 500.56033393163625 -17.821323143937633 -30.961861732637477 501.28903670362149 -18.363191088736162 -32.465012631003233 501.86959847486241 -18.80251885874404 -34.01559554263261 502.28703652004015 -19.123469384950106 -35.595504107172026 502.53351124620576 -19.323704737760007 -37.194229928492085 502.6059250478105
+-12.291458844587387 -25.084394172509725 496.95786614299305 -13.107500444429771 -26.208916727851651 498.09695726778432 -13.88356053487392 -27.415790665569535 499.13168631366517 -14.611307320397984 -28.699273322285521 500.05110314388151 -15.273197628265287 -30.046553511672187 500.84000718389649 -15.866642928946776 -31.453159758657016 501.49585887037512 -16.367228154539735 -32.905894740819178 502.00389579469692 -16.770936279531927 -34.383584007107466 502.36062970267687 -17.065082775311676 -35.873400628796901 502.56368983101714 -17.249101176890917 -37.376383355160833 502.6141755268676
+-10.545057436481205 -25.128389679734248 497.87429224248996 -11.323380437129341 -26.294852522499273 499.01046067112713 -12.059293344175909 -27.54106473165222 500.03519333773079 -12.744356570150616 -28.859287793977703 500.93743111861141 -13.362733758542781 -30.234080010771628 501.7013701878717 -13.912028884122808 -31.65774680714674 502.32743229192704 -14.37112687547204 -33.113751558863932 502.80143367983504 -14.739469373307118 -34.580814099474658 503.12782985028895 -15.006653113785557 -36.048744691466716 503.30748941890459 -15.174497555438139 -37.52582808434093 503.34455697459623
+-9.0047694840459105 -24.682935195908033 499.1311467255091 -9.7561372323220343 -25.90230980961314 500.31171159338226 -10.463364814127624 -27.205312320759184 501.37655537784326 -11.117815822575167 -28.583502170679782 502.31394794845198 -11.705203644164088 -30.021263968250796 503.106534771241 -12.222902086754045 -31.508502402522584 503.75492293890386 -12.652197001980083 -33.026902666951102 504.24299908064648 -12.995515965310952 -34.554945587900548 504.57791315949436 -13.243232426163519 -36.081624958665437 504.76037593928658 -13.399495245129744 -37.616267300855384 504.79568688568054
+-7.8776560916867453 -23.767722928008396 500.59670032189723 -8.6237202002830209 -25.045661254213748 501.86277928365888 -9.3253108062252004 -26.417162844988063 503.01219918754333 -9.9735318445562982 -27.87455550578845 504.03214295312796 -10.555033747380811 -29.404722599049837 504.90326287408601 -11.06644936785394 -30.996512610190184 505.62328080855701 -11.489703278485942 -32.631959951669643 506.17237210701524 -11.828560555670974 -34.2895232042383 506.55420697311928 -12.072128050645153 -35.953790196504251 506.765697921259 -12.226021544516946 -37.628222270247178 506.81113767691232
+-7.3067796499822846 -22.498919054008262 502.08493306024729 -8.074613455191276 -23.837495452517398 503.46061523158517 -8.7992251648231701 -25.283888582055674 504.72123208626283 -9.4714154278262619 -26.832369460786886 505.85260525531652 -10.077824439670581 -28.474289369441774 506.83359205734581 -10.61392480702666 -30.198753671619201 507.656346453617 -11.060075193614784 -31.989808917487164 508.29702894048927 -11.419217753056042 -33.826202416368069 508.75091326472165 -11.677224195855379 -35.685493487458963 509.00859199641883 -11.839850284279397 -37.559800388993771 509.07184125683165
+-7.3204997481477134 -21.047992175043881 503.42146335572653 -8.1334724517759511 -22.447302299948419 504.9112770491609 -8.9054898955441626 -23.970634756850625 506.28875709430753 -9.6270003533074142 -25.614803499206424 507.53823665155807 -10.283695953577073 -27.376423807604144 508.63734981897164 -10.869662527054478 -29.245681837044586 509.57110162980587 -11.361879990128289 -31.209291640690065 510.31240081527028 -11.760832284621593 -33.246406506423675 510.84581033827749 -12.047967148542959 -35.326487339228876 511.1547002892907 -12.228066977321459 -37.427536022783407 511.23784331340624
+-7.8557272118926758 -19.587331847074168 504.48117843502439 -8.7282533636212687 -21.045771211874865 506.07369581108918 -9.5623034892277108 -22.644109973602706 507.55654504232393 -10.347916438771367 -24.381725824092044 508.91263809360441 -11.069251500686972 -26.260254606204271 510.11884797354429 -11.718777342724213 -28.271120194011726 511.15326518382926 -12.269400884835925 -30.403612372531509 511.98608136291728 -12.718200563845393 -32.637092576756515 512.59187382779157 -13.04204127332099 -34.933354424619743 512.94702109518187 -13.244107440865722 -37.256166893556724 513.04768371355533
+8 0 0 7 3 -35.568095680177201 -112.64804701119002 495.28009499264584 -52.980999944011359 -112.64804701119002 495.28009499264579 -70.393904207845523 -112.64804701119 495.28009499264579 -87.806808471679673 -112.64804701119 495.28009499264573
+-31.404150312257478 -102.52030498666238 497.6366679311152 -50.190296356645632 -102.47538714701838 497.64711963546375 -68.991182409786376 -102.43046930737437 497.65757133981242 -87.806808471679673 -102.38555146773037 497.66802304416103
+-27.886051806627044 -92.066268688744842 499.65040637546912 -47.849917566124503 -92.021848441263472 499.65704706587735 -67.823594479167298 -91.977483320784728 499.66375413236915 -87.806808471679673 -91.932970182812639 499.67025220486869
+-25.082860670677391 -81.316632334211505 501.26610014175031 -45.995132365384272 -81.309829314551422 501.26300471200307 -66.902926463292616 -81.302873249280779 501.25970461521382 -87.806808471679673 -81.296276061431755 501.25689377526669
+-22.999028001290661 -70.368679364247072 502.40853460218671 -44.608843419124241 -70.40666639979986 502.40226946140541 -66.211598651930061 -70.444816537975626 502.39624365776444 -87.806808471679673 -70.482617865293435 502.38976325855555
+-21.481166441887193 -59.323739225861388 503.03182647252794 -43.59571155900538 -59.384593462944899 503.02945254849874 -65.704217139819391 -59.44537410912605 503.02694963255396 -87.806808471679673 -59.506284292140137 503.02459311340306
+-20.32356487529162 -48.246589412635942 503.10653832959105 -42.821732473814748 -48.295948960116306 503.10877405529692 -65.316147005944089 -48.345308507596627 503.11100978100285 -87.806808471679673 -48.394668055076977 503.11324550670878
+-19.323704385339358 -37.194229961897641 502.60592506636868 -42.151405747452806 -37.194229961897662 502.60592506636863 -64.979107109566229 -37.194229961897648 502.60592506636863 -87.806808471679673 -37.194229961897655 502.60592506636863
+8 0 0 7 7 -5.7181836133926129 -18.199086884286448 483.21112311235152 -6.9181489100715332 -18.59730675769686 485.35480471481736 -8.135180571372425 -19.172687841589958 487.44513591622575 -9.3598407891388113 -19.925064533204015 489.47171361377264 -10.579109129142731 -20.848058013593569 491.40755245894115 -11.778458804727677 -21.938433322174838 493.22927283717098 -12.940166950358586 -23.195020798945951 494.91825049834222 -14.037858895078891 -24.607201894381998 496.44272783807378
+-4.2208538601678702 -18.321230187626764 483.86864773078503 -5.3964203436608686 -18.770811479258526 486.02398493258505 -6.5859960070579318 -19.400784310280283 488.11794822664478 -7.7799606785855122 -20.209312914499939 490.13883426219382 -8.9646828378697023 -21.188889638475217 492.05806735396641 -10.124821246673994 -22.334092411233065 493.84971946622392 -11.242262501932894 -23.638579458498707 495.49332041111887 -12.291458844587385 -25.084394172509754 496.9578661429934
+-2.7235219390497338 -18.002700997021226 484.60803460867146 -3.8746895806269004 -18.493023735222625 486.8099714668935 -5.036827532505308 -19.169149166743036 488.94579954339764 -6.2000674256883901 -20.028188437218013 491.00236280298975 -7.3502289782876176 -21.062465798503112 492.95020897093656 -8.4712070733162648 -22.265777452286553 494.76158356315005 -9.544356435647888 -23.628651739036389 496.41350426281389 -10.545057436481205 -25.128389679734276 497.87429224249036
+-1.3603730044777855 -17.232589539201808 485.3703520862237 -2.4943601026470938 -17.748024123070994 487.65057511451124 -3.6371235919442797 -18.456132054352409 489.86371122446485 -4.7785409178009903 -19.353614349075137 491.99521722503238 -5.9041242958778195 -20.433737815707847 494.01580089834323 -6.9972309085893363 -21.690878282559105 495.89699541299626 -8.0387252362623194 -23.115167835430071 497.61327760967242 -9.0047694840459069 -24.682935195908062 499.13114672550944
+-0.26588967089578497 -16.058960300145301 486.08557805237893 -1.3971788450853202 -16.582473600847589 488.46740915108143 -2.5367293854903243 -17.306252223453772 490.78452160783655 -3.6742364146387323 -18.227171832356373 493.02117729583694 -4.7952933961517701 -19.340363283390907 495.14935476989302 -5.8831569170807319 -20.642041587258081 497.14112388278789 -6.9184308092058284 -22.124659365744403 498.96888451391834 -7.8776560916867542 -23.767722928008425 500.59670032189769
+0.45650248846224173 -14.592717916851875 486.6861256803013 -0.69093923777438926 -15.110923719027445 489.18059735910305 -1.8481970075610794 -15.837261395010334 491.61474223351058 -3.004878787518801 -16.769231803733451 493.97177923547991 -4.147069018112548 -17.904351592250663 496.22579225848983 -5.2584314499762961 -19.24166031956257 498.35032903503287 -6.319564757570733 -20.777892255925117 500.31619883995609 -7.3067796499822935 -22.49891905400829 502.08493306024775
+0.7613944194240293 -12.978698165662523 487.12446098079948 -0.4202597138278113 -13.484752278903759 489.73032916563659 -1.6150014209602093 -14.206853801734656 492.2807643429785 -2.8123754417556324 -15.143395901244572 494.75799888647384 -3.9992235788342434 -16.294389468881683 497.13863105798544 -5.1599639482412876 -17.662246399863193 499.39813034423167 -6.2752491291971344 -19.248879157309503 501.50598860702559 -7.320499748147725 -21.047992175043909 503.42146335572698
+0.65801684601483679 -11.361801140743037 487.37786005027613 -0.57129492912020452 -11.855408378330562 490.08403767571508 -1.8179071266544415 -12.572820160116732 492.73895593497235 -3.0712270670804878 -13.513367553184201 495.32385328691822 -4.3189461876058823 -14.679412220814113 497.81786340124404 -5.5463137992638867 -16.076662425365821 500.19837465515695 -6.7339078739559302 -17.712195520901876 502.43365609437024 -7.8557272118926917 -19.5873318470742 504.48117843502502
+8 0 0 7 3 -19.323704384938566 -37.194229959470533 502.60592504921021 -42.151405747185606 -37.194229959470533 502.60592504921021 -64.979107109432647 -37.194229959470533 502.60592504921033 -87.806808471679688 -37.194229959470533 502.60592504921033
+-19.065723885319635 -35.138772347224396 502.51282372117896 -41.96455887921875 -34.943338455531624 502.50397160243398 -64.878253741338767 -34.747904563838851 502.49511948368905 -87.806808471679688 -34.552470672146079 502.48626736494407
+-18.602378714149225 -33.114982945151425 502.12191162959812 -41.627879967225972 -32.854300314533099 502.05252439221726 -64.693506752283838 -32.600936404831543 501.97572186577491 -87.806808471679702 -32.354174367661763 501.89166341787632
+-17.93802626013786 -31.149664147616122 501.43685339830654 -41.167851831843763 -30.905049856762403 501.32341941557576 -64.456723731346244 -30.664972484848064 501.20717708014956 -87.806808471679702 -30.429979576684079 501.08943066124698
+-17.11354846251308 -29.298079249980244 500.49337894767342 -40.615743188008061 -29.106047990006392 500.36720848632689 -64.179368369126692 -28.917143723643836 500.23880887548353 -87.806808471679673 -28.730304385379966 500.1072782517486
+-16.169898178112717 -27.588594285674791 499.32773335600422 -39.997186214142829 -27.460676096001489 499.21845894027825 -63.875957795597571 -27.333662996670025 499.10836807468291 -87.806808471679716 -27.207989880539536 498.99779181739535
+-15.13555048412608 -26.01938399324164 497.96720440490304 -39.329606985009207 -25.959328269984617 497.90237314420148 -63.553359647527088 -25.899272546727591 497.83754188349985 -87.806808471679702 -25.839216823470579 497.77271062279817
+-14.037858916483017 -24.607201913344849 496.44272780859097 -38.627508768215236 -24.607201913344849 496.44272780859103 -63.217158619947476 -24.607201913344845 496.44272780859103 -87.806808471679702 -24.607201913344852 496.44272780859092
+8 0 0 7 6 -5.7181839263646301 -18.199087263369609 483.21112289684015 -2.6155665943422681 -16.981888936021772 476.65874725421008 0.29029118954656496 -16.066592452889239 469.96892968491636 2.9776430867361356 -15.478561261332059 463.15681192665454 5.4219910559138764 -15.244600028524658 456.25473696035095 7.6031662675656335 -15.427208255963787 449.30479390142165 9.4995959555508005 -16.095088723516607 442.37551491903065
+-4.2208551753306303 -18.321231821939769 483.86864682750257 -1.1204894379307315 -17.069633218979842 477.27855861893818 1.7839451082025966 -16.122764962190566 470.54736864103847 4.4705919644224243 -15.506419083343545 463.69057821471608 6.9145956834062918 -15.247139294326089 456.74082718250867 9.0954848233614012 -15.407660055104969 449.74024430164246 10.991743333277233 -16.058240517059936 442.75781600733171
+-2.7235264206194643 -18.002706893633409 484.60803147583971 0.37459090533990613 -16.724018431087412 477.96050571140205 3.2776004153406242 -15.753093671812522 471.16872229799031 5.9635362761294006 -15.115999247445588 464.248463363496 8.4071980444548906 -14.839038980358596 457.23173624337869 10.587809138880267 -14.985448774856655 450.15996170315447 12.483890835387598 -15.627548099200299 443.10215634450878
+-1.3603815553147931 -17.232605191170968 485.37034529320999 1.738920232700123 -15.937479994971865 478.65045633984784 4.643618635571654 -14.952904309195029 471.78369493840449 7.3316418260768792 -14.305061830521689 464.78601153258739 9.7774924699489372 -14.020141159217243 457.68780535459206 11.960101592744337 -14.162179271399898 450.52901480920286 13.857984004082724 -14.805950943038054 443.37829168296935
+-0.26587511423412358 -16.058951173144237 486.08558636030722 2.8414972196038235 -14.759009544735074 479.28612507459576 5.7541203676982606 -13.771842183459036 472.33748511044064 8.4497745524602479 -13.123692443663456 465.25557662876139 10.902847430334932 -12.840710198129456 458.06852108146524 13.092081080556092 -12.98792283338639 450.81421956154082 14.995796558283017 -13.6429553296073 443.56042169819818
+0.45650798005283222 -14.592713117692586 486.68612906647337 3.5807152046828286 -13.297198419315567 479.80913588215566 6.5092555384726936 -12.316081686579082 472.78062896426314 9.2197618962780261 -11.675564925183384 465.61641715781025 11.686591490394745 -11.401991562062713 458.34171716295401 13.888327396120484 -11.561614947909947 450.99182723970517 15.803020594931455 -12.234956466679513 443.6334504943419
+0.76139594104049313 -12.978696755838602 487.12446193399131 3.9102854609412732 -11.692534963868999 480.17985836567328 6.8619724585056217 -10.721985972971957 473.08110342112059 9.5938815169014919 -10.093209274077758 465.84380027655362 12.080471884942192 -9.8328255331817545 458.49011514591825 14.300247610035198 -10.008359453982438 451.05250983058994 16.230803596063431 -10.703224805880488 443.5964340397353
+0.65801719783327794 -11.361800804120907 487.37786027263405 3.8365592271244964 -10.085544594252918 480.3808160925301 6.8160799422998517 -9.1259143880355733 473.22664245139623 9.5737318030555461 -8.509045337928832 465.93067969178611 12.084133007297586 -8.2618924592265142 458.51213805366359 14.325751737508606 -8.453215696085369 451.00057688828332 16.275579533502995 -9.1691331706917811 443.46014875233544
+8 0 0 6 3 -14.037858916483001 -24.607201913344849 496.44272780859092 -38.627508768215222 -24.607201913344852 496.44272780859092 -63.217158619947426 -24.607201913344852 496.44272780859092 -87.806808471679645 -24.607201913344856 496.44272780859092
+-12.75721875423276 -22.959656153465261 494.66417177956021 -37.778011700389008 -22.968277468707232 494.67347864834358 -62.794541606204625 -22.976898783949203 494.68278551712689 -87.806808471679645 -22.985520099191174 494.69209238591026
+-11.387382874737684 -21.52987317593514 492.65520971436752 -36.875443731954654 -21.555760957037972 492.68845675484204 -62.34858103712758 -21.581682410965904 492.72168154095459 -87.806808471679673 -21.607637324764355 492.75488395541271
+-9.9724715970274467 -20.336841171800661 490.47196605748155 -35.942794568112362 -20.368974234950521 490.53079918892792 -61.887538201067301 -20.401224066660994 490.58953120185288 -87.806808471679616 -20.43359259590229 490.64816161654142
+-8.5424047025254541 -19.376145166617878 488.13819948220754 -34.996280495958871 -19.403990896062094 488.21593339756282 -61.417670275676087 -19.43225056780669 488.29330786083005 -87.806808471679659 -19.460921100289553 488.37032497400924
+-7.1181433853642488 -18.663676983021482 485.71208458176068 -34.039263774308466 -18.675309827418712 485.77470606641924 -60.935485469746929 -18.686942671815938 485.83732755107781 -87.806808471679645 -18.698575516213168 485.89994903573648
+-5.7181839255993552 -18.199087262065969 483.2111229003425 -33.081058774292785 -18.199087262065976 483.21112290034245 -60.443933622986215 -18.19908726206598 483.21112290034245 -87.806808471679645 -18.199087262065984 483.2111229003425
+8 0 0 6 3 -5.7181839244957891 -18.199087263522426 483.21112289766074 -33.081058773557082 -18.199087263522426 483.21112289766074 -60.443933622618374 -18.199087263522426 483.2111228976608 -87.806808471679673 -18.199087263522426 483.2111228976608
+-2.6155170149532725 -16.98189298213785 476.65876902649694 -31.009140775506896 -16.980270189157391 476.65003326916531 -59.406237927749032 -16.978647396176932 476.64129751183373 -87.806808471679673 -16.977024603196469 476.63256175450215
+0.29031446989240361 -16.066717345411782 469.96866245150119 -29.075126428116175 -16.067018819468078 469.966797249183 -58.440895188449936 -16.068152226675096 469.9648868907168 -87.806808471679673 -16.068435072039211 469.96302579506226
+2.9770512264784337 -15.478337232002151 463.15736418107821 -27.29049543472183 -15.481321361324078 463.17324228732065 -57.551666772051476 -15.482797219691225 463.18920396935232 -87.806808471679673 -15.485793313548701 463.20507927216914
+5.4225267926886662 -15.24472522131073 456.2543570893809 -25.664487260941389 -15.24632379134618 456.28873174524415 -56.741006946992549 -15.248780915287943 456.32305526845602 -87.806808471679673 -15.25041406672964 456.35742207975483
+7.6032663617241854 -15.427205780110409 449.30481955033105 -24.208815551464394 -15.423631585580479 449.34190192071713 -56.012173829265663 -15.420057391050548 449.37898429110311 -87.806808471679673 -15.41648319652062 449.41606666148931
+9.4995959567733923 -16.095088724221359 442.37551491941457 -22.935872186044303 -16.095088724221359 442.37551491941463 -55.371340328861976 -16.095088724221359 442.37551491941457 -87.806808471679673 -16.095088724221359 442.37551491941468
+8 0 0 7 7 9.4995959541939978 -16.095088726156845 442.37551492134628 10.273279310117296 -16.329780144514896 439.94058470467183 10.995521346832287 -16.792143235244975 437.51953789951114 11.657099341450385 -17.483378483371308 435.15642020013502 12.253674863398192 -18.404609138551088 432.86967872732373 12.776885770877136 -19.553201292345076 430.71371829366615 13.219003225081831 -20.915390194584539 428.72832346642679 13.569119665290897 -22.470019828989127 426.95722234941474
+10.991743322032354 -16.058240530604269 442.75781600761252 11.752410836682859 -16.264945057967477 440.29322348014699 12.463492601598681 -16.704370650573463 437.8384677581696 13.115457575608577 -17.377911179889292 435.43852786965363 13.703566091482147 -18.28760409692898 433.11282305545512 14.219226609923453 -19.43099777309957 430.91633555860341 14.654698774753262 -20.796094323705603 428.88980443986543 14.999290021244205 -22.362910715498295 427.07924568538306
+12.483890692255907 -15.627548253557167 443.10215632372791 13.231542366335489 -15.819164910281494 440.57736753493595 13.931446729969117 -16.25027684717848 438.06008646075423 14.573840100328351 -16.922540088506903 435.59518809877403 15.153451723515913 -17.839109025123076 433.20371108606969 15.661562456410204 -18.998186120809496 430.94037291266773 16.090394399246545 -20.390116165015026 428.84738231770854 16.429460462399547 -21.996300434853158 426.97348524176573
+13.85798283934483 -14.805952450525027 443.37829152794581 14.596603776188593 -14.997518834974077 440.76587829285108 15.288779966293289 -15.436556974955426 438.16046837377814 15.924671409301629 -16.125091702063955 435.60572289791145 16.498431739156402 -17.06759191570702 433.1248870301157 17.001363524061091 -18.263426714438062 430.77153803426677 17.42562875823868 -19.70578617404427 428.58981487095969 17.760879996538208 -21.377595885764617 426.63152531844253
+14.995798030502488 -13.642954141570595 443.56042196484896 15.733374974595105 -13.848967503930414 440.83956695452275 16.424736916403134 -14.311124153727759 438.12671495236231 17.060192277719072 -15.032009137929348 435.46330474589672 17.633403297715688 -16.01750090800838 432.87531602721788 18.135909160168517 -17.268538546801828 430.41444891347061 18.559801012457982 -18.781503656142732 428.12715619230465 18.894700172739938 -20.541006513530974 426.06846211459828
+15.803020744840405 -12.234956320918162 443.63345051922937 16.550112404186567 -12.466175941028389 440.79272317876462 17.249868197390295 -12.962528624715761 437.96185404948676 17.892992968045235 -13.727270126336503 435.17936381197052 18.472791056513334 -14.767748142506354 432.47431018760483 18.981222355341693 -16.086871773317178 429.89594692423174 19.410295481391326 -17.68442709317069 427.4933010564983 19.749439394791853 -19.546653525072966 425.32475997332807
+16.230803607885143 -10.703224794913663 443.59643404175318 16.997924204022791 -10.964940951794478 440.63432470431485 17.715323806292016 -11.500849343366442 437.68400757680752 18.374286690908598 -12.31499440628334 434.78076756677996 18.967933413104024 -13.416087064356324 431.95694578877539 19.488810088979584 -14.809178661416322 429.25909872117882 19.928829263075119 -16.497458988374341 426.73896293430818 20.277007277985547 -18.46874631507724 424.45829357151257
+16.275579534266285 -9.1691331699569663 443.46014875246169 17.071088320257548 -9.4611967344734236 440.38390853301894 17.81360980363727 -10.036340322689341 437.3208683531185 18.495088374932887 -10.899453675499686 434.30312034261772 19.10860063209045 -12.060419026246617 431.36629697938753 19.647367225078387 -13.526458622666222 428.55426453170452 20.103180530579714 -15.304000911476285 425.92146323073518 20.464446763912168 -17.382301785281587 423.53295362568275
+8 0 0 7 3 9.4995959561621337 -16.095088726108443 442.37551492185059 -22.935872186451817 -16.095088726108447 442.37551492185059 -55.37134032906576 -16.095088726108443 442.37551492185059 -87.806808471679716 -16.095088726108447 442.37551492185059
+10.27327923367112 -16.329780159547088 439.94058459330108 -22.394781198691771 -16.340146795975851 439.83303044411213 -55.088143767142043 -16.350513432404608 439.72547629492317 -87.806808471679716 -16.360880068833367 439.61792214573421
+10.995197313642704 -16.792287365228333 437.5203818796785 -21.90745021231529 -16.826295715374243 437.37560997837124 -54.841862804214522 -16.861820494629388 437.23267635782923 -87.806808471679673 -16.898102890754345 437.08989772988616
+11.65754127297798 -17.483142672887336 435.15431402244383 -21.470114207921505 -17.534892169254071 435.01719634696735 -54.625217753171604 -17.586649217697953 434.87880637445028 -87.806808471679844 -17.640267814592793 434.74334300883214
+12.253608090455561 -18.404715757177655 432.87175835145064 -21.081726435595815 -18.459202607409686 432.77028128258581 -54.435295019231816 -18.514948272047452 432.67119035762568 -87.806808471679574 -18.570099661978347 432.57027796403156
+12.776763158541312 -19.55321111065631 430.71290648344973 -20.742211877207282 -19.594151204427398 430.65675084658426 -54.270106582784457 -19.634855464744394 430.59984767902444 -87.806808471679787 -19.676062003112456 430.54386925787708
+13.21900321085867 -20.915390416286314 428.72832353454908 -20.45343136840977 -20.932865514264122 428.70841514562733 -54.128701929255875 -20.95034061224192 428.68850675670558 -87.806808471679702 -20.967815710219714 428.66859836778383
+13.569119665319541 -22.47001981945666 426.95722234662929 -20.222856380346879 -22.47001981945667 426.95722234662929 -54.014832426013271 -22.47001981945667 426.95722234662929 -87.806808471679702 -22.470019819456663 426.95722234662929
+8 0 0 7 7 13.569119665290897 -22.470019828989134 426.95722234941513 13.91923610549996 -24.024649463393718 425.18612123240308 14.177166153290989 -25.771261497735555 423.62907278740505 14.332636252411508 -27.687824551852213 422.33052864091883 14.37095093592982 -29.729863529004835 421.33284388591176 14.276869180631051 -31.876943078403258 420.66079027120691 14.044308563135919 -34.040369124664394 420.32952872938404 13.68630496254543 -36.203227399723716 420.32952878093175
+14.999290021244205 -22.362910715498302 427.07924568538346 15.343881267735146 -23.929727107290994 425.26868693090103 15.597443531400483 -25.697838261942792 423.67387363105001 15.749951534946755 -27.646388752628656 422.34146860417206 15.787541033807384 -29.732285105831249 421.31724201521922 15.696150562411578 -31.934128913300871 420.63260741761752 15.471334898351204 -34.155137927748029 420.30755465773416 15.125812182472654 -36.370381998721491 420.3295287785661
+16.429460462399547 -21.996300434853165 426.97348524176613 16.768526525552549 -23.602484704691296 425.09958816582326 17.017720123373056 -25.422543446663745 423.44457745466332 17.167269803377408 -27.436947731918245 422.0575864432289 17.204127754719195 -29.604759867803129 420.98866205799629 17.115433731820453 -31.901317634811427 420.27601250117891 16.898361288669776 -34.22389362638922 419.94446782904106 16.565319478026755 -36.537536606500069 419.97950842708735
+17.760879996538208 -21.377595885764617 426.63152531844293 18.096131234837735 -23.049405597484963 424.67323576592565 18.34230051345148 -24.950341235670138 422.93819668814098 18.489801553567357 -27.062255935005222 421.47818061871732 18.526174745424669 -29.347088376746264 420.34813450271497 18.439480773269096 -31.774721820688068 419.59292624031872 18.228053348172772 -34.23887189896741 419.24183448855814 17.904070484960624 -36.692991462593454 419.27948340870563
+18.894700172739942 -20.541006513530991 426.06846211459867 19.229599333021898 -22.300509370919233 424.00976803689213 19.475465986497806 -24.306289212326902 422.17951689846512 19.622766900673298 -26.541757458587742 420.63211068339717 19.659179507730915 -28.972199049048704 419.42783975571376 19.573082143557063 -31.559965626782692 418.61805579050588 19.36305763886952 -34.19727175462689 418.2359272653116 19.041205784008987 -36.825034839857253 418.26610326590782
+19.749439394791853 -19.546653525072969 425.32475997332841 20.08858330819238 -21.408879956975245 423.15621889015802 20.337770160220892 -23.535586664983828 421.22165763190139 20.487316584807377 -25.911583424037953 419.57818497920482 20.52445059926907 -28.505877174851275 418.29160879066683 20.437048028082106 -31.272006601059601 417.41945429589725 20.222758541217441 -34.102200538556922 416.99818753288793 19.893835911803027 -36.924041670199664 417.01323654916047
+20.277007277985543 -18.468746315077244 424.45829357151291 20.625185292895971 -20.44003364178014 422.17762420871713 20.881487655102678 -22.694211765115959 420.13633078237132 21.035859940815627 -25.217447729942283 418.39418682441715 21.074461287582917 -27.982502913484645 417.02257743403686 20.983727959165751 -30.933282531568548 416.08507879813959 20.759184200410683 -33.962581098018298 415.62111287309165 20.413588862428313 -36.984395029204506 415.61722419044816
+20.464446763912161 -17.382301785281587 423.53295362568309 20.825712997244612 -19.460602659086891 421.14444402063049 21.092373516632822 -21.839623300245343 419.00017405671696 21.253787147383999 -24.506753793506387 417.16253409711334 21.294512106866634 -27.438336634538967 415.708382080609 21.19865232052625 -30.568526589119603 414.70729385388967 20.958655172469346 -33.790464369858775 414.20151699403721 20.588225703657937 -37.004673740388704 414.17874845420977
+8 0 0 7 3 13.569119665319601 -22.47001981945666 426.95722234662952 -20.222856380346837 -22.470019819456656 426.95722234662941 -54.014832426013257 -22.470019819456656 426.95722234662946 -87.806808471679688 -22.470019819456652 426.95722234662935
+13.919236119780468 -24.024649222627005 425.18612115870968 -20.00271623894184 -23.942875410875978 425.27928142882774 -53.911397769428547 -23.86110159912495 425.37244169894598 -87.806808471679688 -23.779327787373919 425.46560196906404
+14.177309577877114 -25.771202377572614 423.6289904091384 -19.83533358625715 -25.595185215167572 423.78425704331704 -53.83048592138924 -25.420929486438755 423.9406901454052 -87.806808471679659 -25.248288657239257 424.09805912693594
+14.332285693252963 -27.688018014826458 422.33066555660429 -19.726933899874489 -27.418210680864149 422.50523117358733 -53.775164265274753 -27.154269374550392 422.68508356833769 -87.806808471679688 -26.896613343817201 422.87095918300759
+14.371291247885832 -29.729627186050074 421.33277181360324 -19.688106167405078 -29.393049018370458 421.47998768224647 -53.74930002531292 -29.065063765106025 421.63226436181901 -87.806808471679716 -28.74410136610085 421.78775859741057
+14.276739134122421 -31.877055663682142 420.66079128950548 -19.733918328723206 -31.52497704490235 420.74017623200399 -53.766062887558348 -31.184961840188706 420.83339284441018 -87.806808471679659 -30.856560928122612 420.93959764737559
+14.044307756684708 -34.040369081702316 420.32952878131897 -19.880291683815738 -33.782780899955647 420.3295287813196 -53.830663759937202 -33.525192718208984 420.32952878132039 -87.806808471679673 -33.267604536462308 420.32952878132107
+13.686304977682807 -36.203227401481442 420.32952878131317 -20.144732838771354 -36.203227401481442 420.32952878131312 -53.975770655225517 -36.203227401481449 420.32952878131323 -87.806808471679673 -36.203227401481442 420.32952878131329
+8 0 0 7 9 13.686304969104579 -36.203227412627321 420.32952879794681 12.700262730534627 -44.694864286920563 420.32952879866531 11.214731091279502 -53.128795244400536 420.32953283575284 9.1142241216476556 -61.455224183097549 420.32952207832437 6.3020289993312488 -69.609149352762088 420.32953112358126 2.7947580594995536 -77.477278748059589 420.32953408856031 -1.2868376816841263 -85.03174222962086 420.32952079238459 -5.8057968637457478 -92.309014368970438 420.32953288625151 -10.673666874359112 -99.344195616476043 420.32952880770461 -15.799640023409573 -106.18558160289922 420.32952880859352
+15.125812257636801 -36.370382017055647 420.329528734782 14.14000979258134 -44.938209806065466 420.32952994270732 12.652805899681493 -53.465870149510948 420.32949380844963 10.547555759959879 -61.900328328312888 420.32960860808629 7.7232225871899152 -70.171780934918303 420.3294850002622 4.1973866401335203 -78.154450697437227 420.3294690274447 0.09461932423691688 -85.809070079636342 420.32962713120202 -4.4433405746004189 -93.174003983532856 420.32948040740081 -9.3271537902784836 -100.28295082781375 420.32953430146955 -14.465032464268191 -107.18554939286349 420.32952880854356
+16.565319887591933 -36.537536661129771 419.97950805500437 15.579757469867848 -45.18155542945901 419.97515020464562 14.090869479521579 -53.802935219675234 419.96841694479593 11.980912486593528 -62.345443141876913 419.95910567338291 9.1444023687121714 -70.734417719776275 419.94593740033861 5.600001171849434 -78.831613748973624 419.93028232395585 1.4761007604511729 -86.586394261346953 419.91389424612942 -3.0808960330633606 -94.038999866136237 419.89712292244235 -7.9806394592292662 -101.22170695240493 419.8811280893093 -13.130424901558563 -108.18551718550131 419.86600998393061
+17.904071637580145 -36.692991601149714 419.2794819987347 16.917484556298771 -45.407733675112844 419.26639716977093 15.425111472649025 -54.115904997447316 419.24630077067189 13.308059362835493 -62.758074901432735 419.21799340097618 10.456561317293183 -71.254915022707536 419.17889449919846 6.890432460215373 -79.455563789770522 419.13197514402538 2.7426180257699802 -87.299793368821256 419.08233478478672 -1.8363241006912259 -94.829659393917581 419.03249607135064 -6.754882793114807 -102.07648368976832 418.98434828312884 -11.919500759094387 -109.09281396368934 418.93901667721371
+19.041204243361939 -36.82503466367271 418.26610425269138 18.05102595932885 -45.59950431556878 418.24086831476524 16.551523325576046 -54.380542428626377 418.20220059316443 14.422567978915687 -63.105610126480933 418.14740249051124 11.550348393620085 -71.690746380796881 418.07227859356141 7.9564000902616598 -79.973137597020724 417.98206901582256 3.7789273110334944 -87.885145292967948 417.88646746665484 -0.82769957865187815 -95.471509186627031 417.79131717356876 -5.7708876010313404 -102.76313168063798 417.69918608309206 -10.956218058192766 -109.81456296543409 417.61270435899189
+19.893835480389264 -36.924041621319915 417.01323691657296 18.896719632578115 -45.742827788767009 416.97422456265559 17.385377878657039 -54.577261574957966 416.9145503381751 15.238304831014792 -63.361811541399895 416.82987854181863 12.337906433994172 -72.007707183375672 416.71434946421397 8.7086183279118838 -80.341981253460048 416.5761996584435 4.4942949168468935 -88.291798008871979 416.430273548792 -0.14695008928074071 -95.906438145458111 416.28621737705464 -5.1217952704604564 -103.216823489452 416.14705881542142 -10.334957512026476 -110.28004851666358 416.01702273392226
+20.413588790452515 -36.984395021150576 415.61722426196923 19.40619341770735 -45.829487289299998 415.56505863238596 17.878399601752257 -54.694654617114971 415.48540121690041 15.707287567789548 -63.511663330214809 415.37244137114976 12.771927816287297 -72.186888626547798 415.21891227801041 9.1010568724337055 -80.539671583181956 415.03664472164377 4.8443017752975557 -88.494555228352695 414.8455152348472 0.16327265063748242 -96.107218953642217 414.65858659197454 -4.848464726382856 -103.40900052961602 414.47904482834264 -10.094831910002394 -110.45996497669348 414.3123431757096
+20.588225694904036 -37.004673739372237 414.17874846422012 19.56796303802453 -45.8575118138207 414.11603636342568 18.020296718846566 -54.730195421727096 414.02045540160441 15.820932269577018 -63.552141527511658 413.885157010066 12.846497497858957 -72.225533437320536 413.70208285524131 9.1308320890922516 -80.563894706114837 413.48673874995438 4.8298574045697888 -88.493365345953677 413.26352167775025 0.10753781981495814 -96.076317838275855 413.04752956366764 -4.9425939531873091 -103.34525640479106 412.84186156191873 -10.223914016867196 -110.36324894339859 412.65249476803064
+8 0 0 3 1 -15.799639988582662 -106.18558155641682 420.3295284400715 -87.806808471679688 -106.18558155641682 420.3295284400715
+-16.06840867657246 -106.43727123033514 420.32952843986419 -87.806808471679688 -106.43727123033514 420.32952843986419
+-16.337472981393091 -106.68864546708754 420.33529854477837 -87.806808471679688 -106.68864546708754 420.33529854477837
+-16.606563063487162 -106.939736909046 420.34682913351037 -87.806808471679688 -106.939736909046 420.34682913351037
+8 0 0 7 3 13.686304975710939 -36.203227413394352 420.32952880859307 -20.144732840085936 -36.203227413394337 420.32952880859307 -53.975770655882812 -36.203227413394345 420.32952880859307 -87.806808471679688 -36.20322741339433 420.32952880859307
+12.418543614771419 -47.121047048457882 420.32952880859307 -20.992314785100209 -47.14511118393515 420.32952880859307 -54.400765480583914 -47.169175319412439 420.32952880859307 -87.806808471679688 -47.193239454889707 420.32952880859307
+10.293672678766825 -57.935923620035581 420.32952954297508 -22.407882001081195 -57.922511130668809 420.32952953520754 -55.108081129443725 -57.909077519395552 420.3295288575145 -87.806808471679688 -57.895632002658751 420.32952884978044
+7.0403839252150018 -68.558774651835392 420.32952819415453 -24.563476828616885 -68.449476680030372 420.32952821922532 -56.178968323422232 -68.340281392978525 420.32952880687787 -87.806808471679688 -68.231181763762933 420.32952883159106
+2.4282691448990814 -78.699127628000483 420.32952829237161 -27.579289353863039 -78.528107260900839 420.32952826705002 -57.658248198053279 -78.356847705170637 420.32952880490029 -87.806808471679688 -78.185340037588489 420.32952878045188
+-3.0613866820009532 -88.257852934395459 420.32952941465794 -31.226969895789036 -88.101720204187117 420.32952942154202 -59.475590437691892 -87.945518101369018 420.32952875821536 -87.806808471679688 -87.789255753406991 420.32952876454874
+-9.2090792109000574 -97.389531824623191 420.32952880859381 -35.350268166768053 -97.29328738572741 420.32952880859375 -61.54951125369459 -97.197042946831644 420.32952880859381 -87.806808471679673 -97.100798507935878 420.32952880859386
+-15.799640023409868 -106.18558160289895 420.32952880859381 -39.80202950616647 -106.18558160289894 420.32952880859375 -63.804418988923068 -106.18558160289895 420.32952880859381 -87.806808471679673 -106.18558160289895 420.32952880859386
+8 0 0 10 3 -77.897694326963673 133.71402774466296 339.24594116210591 -53.824054812146429 126.75501237563977 352.97958499446725 -28.184642875191344 115.8072201649571 364.89078166365181 -7.3705776691133451 95.886390529956685 374.73750698637451
+-101.48367508913071 139.35160047496035 341.25988311767287 -73.014807885901405 130.69495303096861 357.28796521179851 -28.833840530480998 129.07524353238128 386.28183306007691 -7.5245475736574345 105.95592937329612 399.77718696775378
+-125.06965585129765 144.36040778182155 343.27382507323995 -92.174998593045174 133.87441042471451 361.48351787078832 -32.34743429435072 142.70315187949706 406.43397290544692 -10.926077346678102 116.02546821663555 423.96238053887402
+-148.65563661346451 148.83901931921159 345.27814523836452 -111.29675630838354 136.44086877836347 365.55208657233771 -38.560556201128371 156.75272027291817 425.80364503012811 -17.461791815036115 126.09500705997498 447.54084104322294
+-172.24161737563134 152.88600474109549 347.26322182260401 -130.37998389060286 138.55088521214122 369.50072798571642 -47.410971499618597 171.31624263391862 444.70482101035049 -27.004587291398956 136.1645459033144 470.59831988722709
+-195.82759813779813 156.59993370143829 349.21943303551592 -149.43269684189764 140.35084394522676 373.35520193207924 -58.96950222391753 186.42630708339246 463.19478322437959 -39.400745934363812 146.23408474665385 493.11443780085312
+-219.41357889996493 160.07937585420501 351.13715708665757 -168.46686288931917 141.97413649433031 377.14899023589101 -73.095310646737175 202.04498926005792 481.10176844125328 -54.461619727766987 156.30362358999329 515.0101130313351
+-242.99955966213173 163.42290085336066 353.00677218558644 -187.49434301216505 143.54877627302869 380.91604633580613 -89.631365904391018 218.17617022095325 498.32754619836004 -71.960321920183404 166.37316243333271 536.18482238493016
+-266.58554042429859 166.72907835287029 354.81865654185992 -206.52428476789154 145.21064670091766 384.68977571184712 -108.34473308550473 234.7962130623105 514.71084954961987 -91.633863765619878 176.44270127667212 556.5419710316047
+-290.1715211864655 170.09647800669893 356.56318836503544 -225.56006859719326 147.11877263830934 388.50104525102711 -128.95689136196475 251.90081974211185 530.14125281563452 -113.19117440640579 186.51224012001154 576.00064698755205
+-313.75750194863252 173.62366946881161 358.23074586467044 -244.59065761705639 149.47019566886993 392.35831773885997 -151.15496347301408 269.48678633711415 544.52165163321911 -136.32744173928484 196.58177896335098 594.49203619044465
+8 0 0 4 8 24.11799430847168 0 389.38369750976562 21.81732280654278 0 461.8703617886959 -5.0416867080167833 0 528.76164612448792 -51.444416232101666 0 589.54854911693701 -112.37624776260652 0 643.72206936583848 -182.82256329642601 0 690.7732054709877 -257.76874483045481 0 730.19295603217995 -332.20017436158753 0 761.47231964921059 -401.10223388671886 0 784.10229492187489
+24.11799430847168 26.975478546922869 389.38369750976562 21.81732280654278 33.11239536335669 461.8703617886959 -5.0416867080167833 39.249312179790508 528.76164612448792 -51.444416232101666 45.386228996224325 589.54854911693701 -112.37624776260652 51.523145812658143 643.72206936583848 -182.82256329642601 57.660062629091961 690.7732054709877 -257.76874483045481 63.796979445525778 730.19295603217995 -332.20017436158753 69.933896261959603 761.47231964921059 -401.10223388671886 76.070813078393428 784.10229492187489
+24.11799430847168 53.950957093845737 389.38369750976562 21.81732280654278 66.22479072671338 461.8703617886959 -5.0416867080167833 78.498624359581015 528.76164612448792 -51.444416232101666 90.772457992448651 589.54854911693701 -112.37624776260652 103.04629162531629 643.72206936583848 -182.82256329642601 115.32012525818392 690.7732054709877 -257.76874483045481 127.59395889105156 730.19295603217995 -332.20017436158753 139.86779252391921 761.47231964921059 -401.10223388671886 152.14162615678686 784.10229492187489
+11.960574875000637 77.384834362685382 383.88269546296056 11.223193285585003 96.019344818096371 452.84916379613202 -12.853054427669095 114.65385527350735 516.83582778767754 -56.787640732225732 133.28836572891831 577.02608368446795 -116.24770281204781 151.92287618432928 630.81616335017304 -185.7269083771377 170.55738663974026 677.39006332003578 -259.50427092947939 189.19189709515123 716.76833996061475 -333.13892060363059 207.82640755056224 747.91050592496686 -401.10223388671881 226.46091800597321 770.5038922138699
+-7.3705776691133327 95.886390529956657 374.73750698637423 -7.7555024304735607 121.06023763830527 437.33670693982236 -29.017597774897517 146.23408474665388 494.44277997017684 -69.219206589313671 171.40793185500243 550.29568865729505 -125.6947244591118 196.58177896335104 601.44367227183807 -193.6718315188204 221.75562607169962 644.20556499628492 -264.55692543616175 246.92947318004821 681.17399660370347 -336.08659476929216 272.10332028839684 709.55305130764214 -401.10223388671875 297.27716739674543 729.70868408985484
+8 0 0 11 3 -313.75750194863338 173.62366946880474 358.2307458646697 -244.59065761705727 149.470195668863 392.35831773885906 -151.15496347301416 269.48678633711415 544.52165163321888 -136.32744173928498 196.58177896335113 594.49203619044442
+-335.19930264151157 176.83020716164128 359.74670722797543 -261.89119308965923 151.60785296937945 395.86492909143556 -171.33502902851356 285.47402869620714 557.59474146738671 -157.36041204190235 205.73590518456879 611.30239001125585
+-356.64110333439044 180.16748360670493 361.19968959929292 -279.18747826363017 154.1082078915743 399.40917922018207 -192.81266044867692 301.85511098591905 569.80873675283897 -179.68525600168687 214.89003140578646 627.32132739774977
+-378.08290402726982 183.70718582506245 362.58269531284594 -296.47192594270871 157.11370330521811 402.99860274253552 -215.35960090874946 318.62785746755605 581.09409508289309 -203.07979001644975 224.04415762700413 642.49941585804584
+-399.5247047201496 187.52100083778055 363.88872670285821 -313.72410895512115 160.79861811175576 406.61422900545767 -238.72709478480056 335.7935774157753 591.39465809810815 -227.31308605499328 233.19828384822179 656.79492157756852
+-420.96650541302961 191.68061566592598 365.11078610355355 -330.92737149396845 165.32828095581436 410.26391151326214 -262.64632860362576 353.35326134202029 600.6677380216712 -252.14968209927503 242.35241006943943 670.17627175786299
+-442.40830610590973 196.2577173305655 366.24187584915569 -347.9981535442908 171.02587770827017 413.7773004238079 -286.83985353904461 371.3074671811645 608.87932947199636 -277.35666576075465 251.5065362906571 682.61754449756302
+-463.85010679878985 201.32399285276583 367.2749982738884 -364.92252360803406 177.94240932398327 417.13838882027585 -311.0236421569881 389.64833397213704 615.98845570316405 -302.70948680685137 260.66066251187476 694.09162298036028
+-485.2919074916698 206.95112925359373 368.20315571197546 -381.51776467294047 186.62124649365566 419.94623991584433 -334.90075994681195 408.35151888147288 621.93312220212795 -327.99235433344074 269.81478873309243 704.56565073482614
+-506.73370818454947 213.21081355411593 369.01935049764057 -397.72475149090582 196.60847526997176 421.64993288680176 -358.14979144218137 427.3814369459497 626.63837429328032 -352.989074319319 278.96891495431009 714.00342473093531
+-528.17550887742868 220.17473277539915 369.71658496510759 -413.61105155318393 207.26468393016037 422.13556816086952 -380.39415143165229 446.71499164674498 630.06453906599006 -377.46018329856372 288.12304117552765 722.37936307814141
+-549.61730957030727 227.91457393851016 370.28786144860027 -429.29915942228911 218.02727967284113 421.5357337041192 -401.10223388671852 466.36701837287137 632.3008755491129 -401.10223388671886 297.27716739674491 729.70868408985507
+8 0 0 8 12 -270.49197115662901 201.46678944863487 145.5510298568382 -259.78198714957711 197.65782266973332 164.29172922226428 -248.06089105275649 193.3660179733773 182.63565106750826 -235.37989386766401 188.6340572710042 200.57402074052874 -221.77341131709289 183.50196597390527 218.0949980405035 -207.26055454356703 178.0087817701521 235.18243464357579 -191.84511334097033 172.19435472309956 251.81445667052461 -175.51436242111797 166.10141413881939 267.96175386673599 -158.23693188224419 159.77815019469256 283.58518932877399 -139.95928292374671 153.28210400136496 298.63138605280494 -120.59652310216644 146.68783257093773 313.02277646314406 -100.0038862084289 140.10430907121548 326.63469616929916 -77.897694326964327 133.71402774466341 339.24594116210568
+-344.01164028500534 227.1432505654615 147.89573196042173 -331.55821772615116 222.45390319332611 166.94335246014313 -318.13929901454389 217.25552952568103 185.56119027556693 -303.8041397615678 211.59398141581315 203.74390474994445 -288.58637800368001 205.51081221110951 221.48311696197777 -272.50545415648219 199.04526015382146 238.76628959830006 -255.56666511142686 192.23622242325297 255.57542809758775 -237.76020630641551 185.12442077128816 271.88546680317603 -219.05945656705998 177.75476354279883 287.66208424345876 -199.41794953949454 170.17923278588947 302.8579806303045 -178.7606336215697 162.46320930946675 317.40443757670391 -156.95696061179802 154.70501023275355 331.18991414001772 -133.75598694346095 147.06539906947629 344.01552696822813
+-418.52670654317831 248.03831800862537 150.6647949802333 -404.2911976741695 242.57570515759238 169.98555038961692 -389.14166778679942 236.57959524622828 188.84379407462146 -373.1247462949184 230.09890299315521 207.23771935666954 -356.27281223041518 223.17657531231652 225.16250901817267 -338.6053023369081 215.85189326694299 242.6093517842971 -320.12882047487284 208.16261816584927 259.56427648150651 -300.83642187662707 200.14725846356458 276.00664439902715 -280.70633691838162 191.84720395117088 291.90717602808559 -259.69946431909216 183.30853696121133 307.22495151401512 -237.75109788588856 174.5868765756 321.90058967130182 -214.74576358331706 165.76923538074831 335.8365035162131 -190.46779628562683 156.9929479016414 348.85802517619726
+-493.86100149838245 264.03611820140219 153.91498208913745 -477.81985565050627 257.96909601333874 173.45977503746778 -460.92190463382275 251.35375335971059 192.50978739813345 -443.21052113949554 244.2422940444882 211.06672453353335 -424.71636843723581 236.67932567930737 229.12931563474592 -405.45855986594796 228.70446506966638 246.6924778706418 -385.44481056628251 220.35464227709014 263.74629491960718 -364.67096890373443 211.66645271517137 280.27462731556034 -343.12019295405838 202.67804064221011 296.25336338993174 -320.76097182243996 193.42979906133363 311.64816527401831 -297.53934225874639 183.96768763290893 326.40932820371904 -273.3556800567406 174.36734514822618 340.45386962902768 -248.03168466420678 164.74184855237627 353.63287989315529
+-569.98205779335831 275.11002343295394 157.6269506728961 -552.12988874901168 268.67161621217923 177.33900551090926 -533.48250707317516 261.68830594550843 196.52442560287741 -514.07959751141607 254.21628085771846 215.18825737011935 -493.94978494643459 246.30262332032922 233.33262084715599 -473.11162666535824 237.98818090678645 250.95602589291036 -451.57380269900762 229.31000303869459 268.0524987067069 -429.33489848144052 220.30374202357811 284.61032178228703 -406.38303119640909 211.00524306899169 300.61053072639055 -382.69437916416393 201.45014260365579 316.0254189822989 -358.22591233855479 191.67575828072879 330.81506472204944 -332.89439839602267 181.74711370140679 344.91140249049357 -306.55999038153919 171.75353199707675 358.19207343459868
+-646.87123929559084 281.25810789653542 161.73625635276878 -627.2165362544564 274.75518632968016 181.5543500114257 -606.83093997312653 267.73764648696368 200.81398927337 -585.75030049655311 260.26686317363357 219.52326423942856 -564.00109085373902 252.39376379261185 237.68741083219885 -541.60123499946064 244.16191318935307 255.30827702887058 -518.56034349910169 235.61005048646584 272.38359401454409 -494.87975058454134 226.77448966288998 288.90585587790076 -470.55257240920099 217.69036315820338 304.86108878176918 -445.56270515786258 208.39016898101917 320.22811801723276 -419.8780982570126 198.90443746006167 334.97669156061676 -393.43225602935638 189.28911603795297 349.0536471863075 -366.12394111236716 179.61153779798312 362.3632204422517
+-724.35401737373741 282.54819648642058 166.16434390693144 -702.92218171913282 276.37285849294619 186.02141540554038 -680.82510440653527 269.74975977904774 205.28765390398758 -658.09481887585218 262.74728531375973 223.97378185710315 -634.75564254174219 255.42222698374954 242.08776514403135 -610.82485733243925 247.82302517727356 259.63442195767777 -586.3130029349694 239.99236699656103 276.61483182501473 -561.22416756656139 231.96952732548056 293.02536586133726 -535.55644774696304 223.79121601500955 308.85675507948332 -509.30136525296058 215.48916884892813 324.09410742645338 -482.43771834952889 207.0898434524492 338.71651746667158 -454.91584118901255 198.64247733166962 352.68540943416014 -426.67242935319666 190.19539362107577 365.93101430821088
+-802.06182787573835 279.3559565284948 170.80035971815823 -778.89705756656519 273.99474300670937 190.62251178149796 -755.13257297699511 268.29771549896071 209.82036860442207 -730.79679651949664 262.34247218685829 228.40678981729479 -705.91202482033952 256.19408111504822 246.39200106559568 -680.49498861883899 249.90842086504477 263.7833341927514 -654.55721754442789 243.53479657058435 280.58476607829459 -628.10557786111224 237.11815952679373 296.79611043610737 -601.14309338041164 230.69952290125806 312.41240683364322 -573.6687274451773 224.31273341001477 327.42465509914007 -545.67185030525252 217.98346078923498 341.820770248526 -517.11946073540832 211.75716600972717 355.57614332231458 -487.98471368202985 205.66707199234003 368.64577675842833
+-879.50843728936331 272.3397228256768 175.44214357515688 -854.66572370571942 268.34758900545484 195.15997524055661 -829.28726340700598 264.18181885086028 214.21802816146879 -803.39818186219577 259.93177683192181 232.63078481846949 -777.01896756361486 255.67353739582035 250.41023474320198 -750.16594036263245 251.47327848590669 267.56573348090228 -722.85169980508977 247.3898764698377 284.10366376490293 -695.08589915777202 243.47695229191044 300.02679755204241 -666.87638683230705 239.78284241757552 315.33401709656101 -638.22930513955976 236.34670437943169 330.0217192193133 -609.14420078717444 233.19702886980104 344.08597195093222 -579.60432082572265 230.3787940422138 357.51530369025886 -549.61730957030238 227.91457393853946 370.28786144860078
+8 0 0 7 6 -77.897694258319675 124.06131943852613 339.24594120204245 -80.235318351649198 124.67125335161347 337.91236233863145 -82.563351364034901 125.28263456767996 336.5613315531333 -84.880085390590764 125.90412726530943 335.19411251546728 -87.183800503910362 126.54510351362271 333.81205210564485 -89.472210694914267 127.21630074138861 332.41697364931122 -91.74190981369739 127.93047920613498 331.01157015328675
+-77.507084713274978 126.09106599032039 339.46877808301292 -79.840757903423111 126.7243295581964 338.14063797020867 -82.161267920718799 127.35786906068086 336.79717619106839 -84.466473380602366 128.00011777940176 335.43999949115317 -86.754186552255604 128.66020075782822 334.07087981970267 -89.021525867697392 129.34812656865319 332.69219661746041 -91.264546832466323 130.07496161270504 331.30715453096451
+-77.366339270060379 128.12081264203016 340.1296006145588 -79.704555888683046 128.7774074873123 338.81551412397715 -82.02617223123589 129.43310264487056 337.48818559584043 -84.328578632168771 130.09610789377808 336.1495201322586 -86.609110067694985 130.77529915588119 334.80169851587931 -88.864184935817519 131.47995263560833 333.44749852670691 -91.089000639529516 132.21944402283654 332.09016711185143
+-77.503017128516078 130.00729259468807 341.21266014407377 -79.855197079094069 130.6822733700532 339.9205136674405 -82.187745180880654 131.35515374195555 338.6169828511774 -84.497579336883447 132.03391374677545 337.30410679271205 -86.781624390087686 132.72723896260686 335.98449378376534 -89.035611501685779 133.44389925976486 334.66117555824212 -91.253557534950133 134.1918408841442 333.33685614810975
+-77.918335701606068 131.60708870813431 342.65596640481976 -80.293278963424683 132.29044704299287 341.39083340583653 -82.646166931258549 132.97045200714786 340.11572164701391 -84.973612004054715 133.65514660248562 338.8329350573643 -87.272150155561519 134.35287633325808 337.54515380614282 -89.536823511643291 135.07196482995235 336.25517780308843 -91.760376837403911 135.81981383840025 334.96499979655243
+-78.581754378954003 132.80255936230199 344.35338531799812 -80.985898244289331 133.48093755991763 343.11590655642652 -83.366250281737209 134.15470079730545 341.86917788536874 -85.719161958983392 134.8318604318699 340.6154114234194 -88.041024742992676 135.52074443092852 339.35745416642953 -90.326440522579517 136.2297330831889 338.09790495398317 -92.566816655513165 136.96639129524627 336.83761210524688
+-79.437127517994753 133.52553961571934 346.17602173656536 -81.873271392784531 134.18484384827605 344.96181816970261 -84.284534527213907 134.83839559094619 343.73826656863002 -86.667189085555847 135.49435155424524 342.50746890740527 -89.017640116438315 136.16110865826209 341.27221310294021 -91.330243944081829 136.84734460958015 340.03468430351762 -93.595335681765334 137.56177434925436 338.79475226545065
+-80.415410045294976 133.75949378406153 347.99545348868349 -82.88257264357226 134.38747653318055 346.79613985540391 -85.324323194752665 135.0088744829678 345.58655032813846 -87.737014643962979 135.63210494608242 344.36860607764635 -90.117239598417868 136.26573334960074 343.14493153870694 -92.459360791011946 136.91904992138967 341.91724537727271 -94.753041543911706 137.60264637648007 340.68475145762187
+8 0 0 7 12 -10.592833236353517 91.66817574232924 373.21445633981972 -15.285575703057653 96.347069627771646 370.99772609837277 -20.318674854527945 100.5948555265075 368.62244144069115 -25.616884369370727 104.42830574731289 366.11863751524407 -31.110578397597017 107.85419734039846 363.49852657410258 -36.796987997190712 110.8779917083708 360.77104474156391 -42.592860933889227 113.50527415614201 357.94145655030241 -48.468587396053351 115.76193976295055 355.02200263942979 -54.398597975204659 117.72103923362781 352.02312154947026 -60.311906069096075 119.46809153089103 348.94547248926062 -66.224966066929198 121.04845931528966 345.79081896436526 -72.093343284370007 122.55047809436093 342.55723483369781 -77.897694258123948 124.06131943780454 339.24594120137806
+-9.7134465678229773 92.746116233835423 373.62985598996841 -14.499441844877762 97.47569267666276 371.36862852716638 -19.597310396399376 101.78322891793343 368.9638255313875 -24.947654493443181 105.69238681840527 366.43707987928599 -30.48852186988189 109.20237727383311 363.79790427720758 -36.21494564797807 112.33012913406587 361.05396743085748 -42.058437690274665 115.07049102036761 358.20581649844883 -47.984141473819172 117.42927337016931 355.26656130067136 -53.954148760740537 119.47580773449735 352.25114842364133 -59.901196880273638 121.30283201452558 349.1613331314382 -65.836590632540094 122.95457312766708 345.99955154443842 -71.713231861699654 124.5220133706041 342.76699104152124 -77.507084710327788 126.09106597953124 339.46877807302383
+-8.9390942630097303 93.824056812245544 374.26760999177503 -13.813680126257294 98.60431609357245 371.95225402745899 -18.977497661907208 102.9716007038529 369.51987286389135 -24.384723076727681 106.95648010983214 366.97937042178961 -29.981013274101844 110.55052308012061 364.33599981595256 -35.75858806260009 113.78231038721545 361.59725095673218 -41.665434192707323 116.63569592113488 358.75886192799663 -47.658179502624151 119.09656879975012 355.82880675527269 -53.684320075605733 121.23063227156551 352.82291886107134 -59.682931972366752 123.13754018116994 349.74640564966364 -65.658438537880315 124.86069292166694 346.60131665707127 -71.56252007286335 126.49355046625304 343.39278279171907 -77.366339232018888 128.12081250526549 340.12960048672693
+-8.3000407728263905 94.864906681332343 375.11343691067987 -13.254030099265979 99.695717265752251 372.7364714177674 -18.483330702337163 104.12051578606577 370.27918805305683 -23.95155569946505 108.1770310043178 367.7343895903478 -29.611308675911044 111.84923431832013 365.10150088877123 -35.452309913267527 115.17716752278979 362.38939350324785 -41.438285698888265 118.13227665994737 359.58819301142341 -47.515761427452674 120.68226200720032 356.69645594784458 -53.613359925511361 122.89177649829013 353.72589604569066 -59.681333327608606 124.86606176860623 350.68802822507109 -65.714809035971399 126.64839153058476 347.58307816206246 -71.666432505211276 128.33422569374122 344.42069915530055 -77.503016715928638 130.00729149391807 341.21265892867837
+-7.8211850196509483 95.831469731575538 376.14147420828988 -12.841327306724754 100.71257663710442 373.69858485940563 -18.133853302327729 105.1904294394147 371.21957966895275 -23.666108894124402 109.31035081636951 368.67937784487998 -29.396493098692243 113.04928112037614 366.06995289893308 -35.312854838010175 116.45675679620317 363.4034444962312 -41.392633496528916 119.49222204739536 360.66275643872012 -47.570255670953024 122.10423404064184 357.83408360667664 -53.751847213129174 124.36568564298626 354.92024334272651 -59.904097667753277 126.38213120469031 351.94169564352188 -66.010606858464527 128.19915886607637 348.89535918553986 -72.027523861162109 129.91306446324904 345.79557297265876 -77.918335924990643 131.60709005711146 342.65596739954071
+-7.5192642799076106 96.689962025231736 377.31578925915284 -12.589258961932016 101.62084160314416 374.80654998530485 -17.940933672619561 106.145270398844 372.30917720131197 -23.538722266469097 110.31665914031957 369.78099158294242 -29.34523704153159 114.10608913286531 367.20489093054181 -35.346861654135068 117.56880448653725 364.59805667881585 -41.532476028239586 120.65487786582827 361.93425198440139 -47.820130228877815 123.29014607143436 359.18444232836345 -54.093224932100604 125.57124623253816 356.34032517291416 -60.338635555216456 127.59482958885536 353.43257795353537 -66.527249897502458 129.41299192922514 350.45384029235788 -72.621089429922634 131.12108497860379 347.42272495867661 -78.581754413211527 132.8025595040304 344.35338544141712
+-7.4014972029741877 97.412750842018383 378.59329260211979 -12.503309895524549 102.39237502455899 376.02145245166355 -17.908283067221074 106.95533522681106 373.50904344877205 -23.571189575800023 111.16351030749662 370.99821113473104 -29.456881791779534 114.98367417459808 368.46133542886929 -35.550128922673366 118.47243448699372 365.92177209929628 -41.849435115658999 121.57325283381519 363.34267114924501 -48.248931894643931 124.18724210806845 360.67588425580436 -54.614555400766179 126.45139421283643 357.90423498713852 -60.953935444499464 128.44315650395154 355.06743037709668 -67.225794859232465 130.22577811104236 352.15395476773068 -73.399753174602864 131.89175826124585 349.1856879203421 -79.437127520723919 133.525539626794 346.17602174630082
+-7.4656659664160214 97.980315285412004 379.92805342629583 -12.580898769473119 103.00688835936555 377.30124891242787 -18.031766428146806 107.59929465435192 374.77694060095001 -23.757280325266674 111.828009597529 372.28636919676012 -29.722263347304764 115.65689975398683 369.79042996637997 -35.908977289554592 119.14128450888998 367.31856916122285 -42.324638791008987 122.21683198146665 364.82332359144687 -48.828632224781252 124.76641587356896 362.23161525447381 -55.281142888494131 126.97674196703851 359.52540742430818 -61.706875775586226 128.89983507675879 356.74879879526924 -68.055066671082045 130.6128015206088 353.88787929200015 -74.303712981984219 132.20398448020313 350.96622120301998 -80.415410045478353 133.75949378479842 347.99545348933435
+8 0 0 8 7 -16.606510416298104 106.93972081519725 420.34682756863407 -18.129299969016753 108.36069700311045 420.4120804182956 -19.73035212167353 109.73363261080091 420.61925575394793 -21.376158737823776 111.06564374117559 420.95251786891919 -23.043510014834915 112.36051952050786 421.40625243962398 -24.712290949630912 113.61842738904079 421.97698079378489 -26.364181228949956 114.84212415831502 422.66638498543034 -27.971618437120828 116.03319449333357 423.48475709689359
+-15.417302751776987 107.83146666514131 420.38777510721138 -16.916086524269996 109.32857499287763 420.53390598795994 -18.488051492064191 110.75861686941491 420.83495138566354 -20.099455191179995 112.12743093854671 421.26903514163854 -21.726518156669812 113.43887662769964 421.82522509088005 -23.3479180661428 114.6931868073049 422.49624126167913 -24.94320428032967 115.89186739816179 423.27847332534026 -26.484608964888121 117.03719301430604 424.17459410543029
+-14.22809301143799 108.73977402534631 420.06810329209867 -15.702870601599825 110.34573546806715 420.2640086234087 -17.245752645339973 111.87119577282036 420.62971339492805 -18.822758326510897 113.32032125325833 421.13887766335853 -20.409498188798981 114.6961674979927 421.7763200488551 -21.983562967583257 115.99850770571834 422.53155780307662 -23.522227266061755 117.22693540286599 423.39660169241773 -24.997599471477663 118.38282809419137 424.36720847126657
+-13.120624788566353 109.60334482049026 419.38502734220486 -14.580412671146174 111.34012016704231 419.59379805154344 -16.104270711950505 112.9885005860214 419.98707401613808 -17.657994380255555 114.55116789123234 420.53557855675911 -19.216711245933592 116.0302326186214 421.22121211716029 -20.757170631913592 117.4249854025324 422.03126117632104 -22.25473633557765 118.73332444818742 422.95497046623933 -23.6814613882927 119.95473273584794 423.98332862104439
+-12.17681919057903 110.35916117185424 418.37030910795767 -13.639713505882472 112.23461811933751 418.5552895232679 -15.164745761343779 114.01806008109726 418.93779640847623 -16.717428619135383 115.71136069718081 419.48702559887687 -18.272637800894426 117.31605315370346 420.18317296937596 -19.806775134862061 118.83132477931619 421.01227693347317 -21.294198411149996 120.25431832707623 421.96261848050648 -22.70701804078794 121.58268282640459 423.02359239133494
+-11.46639333680381 110.95174083716721 417.09131539990415 -12.957064742208226 112.9587872198109 417.22329888775749 -14.510578721863554 114.87237938218115 417.56378858640284 -16.09224648818687 116.69417837318989 418.08124436929313 -17.67694882699978 118.42580773043694 418.75511030228643 -19.241295928618342 120.06714636099093 419.57122198346195 -20.759681583331844 121.61588458091076 420.51863298733662 -22.204258918296784 123.06858880673605 421.58826258678732
+-11.035799924005067 111.34187379716087 415.64175728702969 -12.58088569693752 113.46066740339296 415.70433075868357 -14.191790925267091 115.48466495806909 415.98494341188763 -15.833377810724597 117.41602104998186 416.45203543888829 -17.480625233455367 119.2570125725755 417.08482557604952 -19.110943775815613 121.00883990418289 417.86955256551346 -20.699726382812347 122.67077676878985 418.79714754739803 -22.219134659187038 124.23966877732671 419.8623373825294
+-10.901990530060871 111.51198489451453 414.1269670714729 -12.524715182115745 113.71449879995025 414.11847061053169 -14.217236830024532 115.81964353859381 414.33704236690465 -15.943622642035995 117.83059603539702 414.75131361955795 -17.678890568686679 119.75083008792956 415.34043913253674 -19.401633336723169 121.58346185292686 416.09140898072786 -21.088752888951138 123.3300695964119 416.99757041710029 -22.712305270011452 124.98898770739086 418.05835978142017
+-11.054505326196169 111.46526743086993 412.64856964631474 -12.770727059096899 113.72015824878396 412.58059164315307 -14.560099477561346 115.87342273089919 412.7488608247134 -16.385425707706759 117.92973773788434 413.12205410782877 -18.221695688633258 119.89426672994468 413.67909376005963 -20.048859229583151 121.77238432549201 414.40765358217817 -21.845533310462741 123.5683295464374 415.30344782211665 -23.583643625726864 125.28278775010696 416.37030282037574
+8 0 0 8 10 -38.442757264327575 125.6818036630418 438.57205112772903 -38.428996387602155 125.20950437432514 436.4951629594101 -38.158386177464244 124.57356159603573 434.4658379931272 -37.597891705482354 123.78348845842 432.52675448743287 -36.71938779371385 122.85598465167342 430.73401967986177 -35.586360592705162 121.83852342527601 429.12833517647721 -34.266120368585234 120.76170160484016 427.70422969756379 -32.818352668715519 119.63424623121455 426.42969801063794 -31.262504640727791 118.46926626821933 425.31391794523392 -29.639872858913748 117.26993646768705 424.33450494942468 -27.971565508486457 116.03315610316052 423.48472978526206
+-36.21603690141206 125.68439606531021 438.58345093637519 -36.192900740086877 125.25612309972753 436.69657078105973 -35.941807554059444 124.70101284234222 434.8770381518907 -35.438230568039501 124.02950253914108 433.14360598769161 -34.665172603940803 123.26000876545736 431.52435296986033 -33.656011836545666 122.39328760356285 429.98779945800561 -32.439461387036602 121.44484501483288 428.59753221582929 -31.095090878995784 120.43092075056435 427.30906211695668 -29.628181233795246 119.35657629585327 426.15010273494897 -28.084449057229566 118.22657646235909 425.1049538205358 -26.484556867557107 117.03715922808674 424.17456165867418
+-33.98931643791714 126.4763729470238 438.41533903796369 -33.956789540170526 126.08660844682288 436.66010503048761 -33.725261600237694 125.59500701858489 434.99243442748633 -33.278532286078573 125.01200733136973 433.40954128243942 -32.611009581615775 124.35646526233776 431.91472838434635 -31.725557328363717 123.58696538916371 430.40951794083185 -30.61294306022689 122.70953498221937 429.02461024844115 -29.371723450776955 121.74908780073395 427.7025686990346 -27.993887848849734 120.70432822488574 426.48922136527597 -26.529021040566047 119.58323349815424 425.37477953244644 -24.997543329640706 118.38280900260983 424.36716067641385
+-32.10594602893373 128.05735102285848 438.06595389268773 -32.068667242588404 127.69377925177186 436.35468937393858 -31.854028295470371 127.23575647197367 434.74799159992267 -31.452044087410016 126.69272138832051 433.22847903297281 -30.866183810914904 126.08263719870479 431.78347342279199 -30.075645496355754 125.33616602434712 430.26710652779781 -29.042470698713675 124.45772417517307 428.85934868231732 -27.879313443162204 123.47982662184386 427.4921112993448 -26.568577153204661 122.39773045436176 426.22459754678516 -25.162466581558927 121.22315593896499 425.05071159969862 -23.68138965019261 119.95475884652826 423.98323488907363
+-30.909137322329531 130.25700632081544 437.57218044081037 -30.876389401246094 129.90015253680642 435.80082303375872 -30.673227970582886 129.4368096738653 434.14401948028581 -30.291884555831537 128.87479227171036 432.58032082950939 -29.739878801349303 128.23027995749061 431.09415590211933 -28.986889528561417 127.42794622383914 429.52445364393287 -27.983910683086581 126.47797355209859 428.06806827699182 -26.848949572506402 125.41702164228022 426.6516012723398 -25.561223506638683 124.24017311597282 425.33901254639102 -24.173701179156076 122.96191488461126 424.12479480685232 -22.707003372673011 121.58262980311363 423.02352576460652
+-30.632286134923476 132.7314818281678 437.01095756586915 -30.61551491570382 132.35636878234402 435.08167319325139 -30.416436510744489 131.84761007698322 433.26728763879476 -30.024517392090139 131.21166242074872 431.55364102843595 -29.444764705161802 130.46300006351154 429.93616820162759 -28.655474464425385 129.54366889630259 428.27564728674611 -27.618830594688784 128.47304252026296 426.7476983368278 -26.447531315496175 127.28716033965988 425.28086554339012 -25.125329895771465 125.98335649330775 423.93376090021826 -23.703888477808075 124.57663899971206 422.69849369653855 -22.204251439466827 123.06847064961185 421.58827263528258
+-31.280335703970501 135.06867457034636 436.4759738320887 -31.287842038825005 134.65028850385846 434.32163258492028 -31.085034026555846 134.06486618680194 432.27307832348635 -30.654507460086066 133.31859204812056 430.33194585649244 -29.993094266351338 132.4252323068315 428.51473510883386 -29.102689893228259 131.36070033568043 426.73364921390356 -27.975290239227188 130.15254732548237 425.11395443700906 -26.709656996512464 128.83194926557306 423.59239192990253 -25.300402139291116 127.39950929883652 422.21442370261559 -23.796313495230226 125.86819606433041 420.96789409995512 -22.21909523751075 124.23959786359896 419.86231593240069
+-32.667314470533896 136.94017692837051 436.04291282124188 -32.701328790775705 136.45947875553057 433.63657857973328 -32.488074828938991 135.78039787547922 431.31990125948334 -32.001104093682407 134.91012106199267 429.11442577398986 -31.22579148615603 133.86299357960567 427.06208051302696 -30.195527356940175 132.65567858592394 425.1423179241724 -28.942295569414647 131.32070033949302 423.41607673274819 -27.546269022368868 129.88148911371189 421.83211168734562 -26.016291847305581 128.34192077562741 420.41882067139437 -24.397435666977334 126.71080123893009 419.15931436906862 -22.712254065940986 124.98892953157528 418.0583277449216
+-34.50920223565398 138.15819038472253 435.75601051791261 -34.565818843014235 137.60548484491247 433.10836972845806 -34.337450478221051 136.83061147776348 430.53066931435751 -33.788492238002718 135.84272002842636 428.06424651737251 -32.892258084382988 134.65778400262863 425.77545611268181 -31.714010937693793 133.33139483679938 423.71261348331166 -30.326733495434187 131.89764017981327 421.87296950909848 -28.791377134001124 130.37094714051656 420.21845971537869 -27.131261673376066 128.75797394095386 418.76026658815664 -25.387516004644986 127.06211288351352 417.47751759619149 -23.58358700973918 125.28273095270242 416.3702683227948
+8 0 0 8 5 -38.442757260314359 125.68180366155485 438.57205112811948 -38.456928426054965 126.25011636973501 441.07114846769633 -38.438931908052112 126.7594268491807 443.58632756419536 -38.406946079737899 127.21052087623191 446.11470172711472 -38.378552067822078 127.60393548243539 448.6537674808219 -38.370950384253881 127.93965552933948 451.20111679305325
+-36.216036898575041 125.68439606255414 438.58345093702485 -36.240975227249379 126.24778053684062 441.06192792830012 -36.235851636402991 126.75517756420746 443.56500687122775 -36.218343120052147 127.2064579170376 446.09015845168022 -36.205995102329986 127.60128286904383 448.63458420285122 -36.216373463337646 127.93886402336064 451.1951098688553
+-33.989316474635281 126.47637281921821 438.41533906681519 -34.025018224505779 127.03053977586963 440.89000305530107 -34.032775891239126 127.52999038900838 443.39749683176041 -34.029740947278306 127.97380500460804 445.93556643714487 -34.033432767415512 128.36082098905234 448.50107614164983 -34.061795577271297 128.68949419361149 451.09007164153763
+-32.105947164549242 128.05734722123555 438.06595475105718 -32.147437151987937 128.59877926737596 440.55679055529197 -32.162297515111234 129.08454290436049 443.08700838671155 -32.167003442778913 129.51317300596656 445.6545763475836 -32.179637989845631 129.88295877584051 448.25602324108087 -32.218249687519041 130.19169943865003 450.88686410776904
+-30.909135323291522 130.25700572496632 437.57218058703012 -30.946217749296547 130.78548957003693 440.09846833075113 -30.956331976606048 131.25524779495439 442.66769138740085 -30.956579041438086 131.66478377260216 445.27780160820237 -30.963650926075786 132.01186756810199 447.92559518273066 -30.996706951403809 132.29399721076362 450.60633348039909
+-30.632284885224887 132.73148559802397 437.01095671526139 -30.652839683266887 133.25265484213318 439.58587332042123 -30.644055568406689 133.71090216662591 442.20359515949315 -30.622470333433562 134.10481449557301 444.86231478817638 -30.606506415883295 134.43235292844588 447.55895731948465 -30.614836236261901 134.69071101581758 450.28938284502982
+-31.280335663378118 135.06867469837456 436.47597380315705 -31.275110479531616 135.59334041979884 439.10345192272439 -31.236485989739275 136.05110289365703 441.77012315636057 -31.181707536932613 136.44096005255957 444.47430561341952 -31.12886883012532 136.76099513750782 447.21374460585963 -31.097005601303042 137.00838687552928 449.98529953350146
+-32.667314470592551 136.94017693034399 436.04291282077298 -32.633714709306552 137.480534533423 438.71804850704046 -32.561929383239935 137.95131609696415 441.42624991440704 -32.46970141679963 138.35196465033712 444.16605528284009 -32.375209905396481 138.68089153734383 446.9361305370229 -32.297310708485782 138.93534699030883 449.73474631652982
+-34.509202236337352 138.15819038376185 435.75601051812765 -34.451133927598903 138.72430240742327 438.46782843902986 -34.35040414701789 139.21999231783093 441.20527944425453 -34.225157574300631 139.64515378151995 443.96713003981301 -34.093471508258837 139.9986136132614 446.75296638660456 -33.973721473615825 140.27782305619021 449.56257379590983
+8 0 0 8 6 -39.397452338435848 129.14574688288408 471.03845733812932 -38.959211285482795 129.18047845662304 467.74866610985998 -38.656084324560254 129.12002251494496 464.43785229895951 -38.473134722766801 128.96416668325045 461.11924240231639 -38.384677846596539 128.71547298816981 457.80284446842131 -38.36118750567028 128.37381202973322 454.49536570065686 -38.370950400308594 127.93964850496354 451.20106442617322
+-37.443178046916806 129.14313378470939 471.28606526321067 -36.959432643421842 129.18441679771271 467.93733595475271 -36.615804835342018 129.12716270275203 464.57007987803121 -36.398111634950567 128.97106353990321 461.20095206195009 -36.279642631375552 128.72018709435301 457.84360147046931 -36.229841319936725 128.37538169143878 454.50642080416674 -36.216373164531142 127.93885680805236 451.19505725618797
+-35.488900755181533 129.77404400857898 471.54036193436554 -34.959631785848018 129.84630436644005 468.11762314065879 -34.575540334277093 129.81542120828701 464.67767629478175 -34.323089361171242 129.68028101061805 461.24070305215412 -34.174609282682809 129.44598873354153 457.82415486638126 -34.098484267060343 129.11445636818135 454.43821138059582 -34.061795875985695 128.68948427583365 451.09001883137506
+-33.77044267076559 131.03882651985739 471.77146886748022 -33.210088994015209 131.16569433834113 468.26561567962779 -32.799622115451626 131.18388423365579 464.74308483905816 -32.525774509682783 131.09090907757508 461.22721965462432 -32.359579298327553 130.89226821931166 457.73870675490599 -32.268157149944841 130.5908406737542 454.28911846298701 -32.218260852147559 130.19165496283171 450.88681508123034
+-32.523640781885192 132.83080576746195 471.94837580373382 -31.961471109756776 133.02703419262878 468.35877706262141 -31.553168573598619 133.10843484415662 464.75307418824525 -31.28377210694368 133.07070579674246 461.15691509955695 -31.123572030164194 132.91949854028863 457.59290472237706 -31.039357954932481 132.65876391525711 454.07309402874819 -30.996686922431152 132.29398455272212 450.60627922056693
+-31.924995632949617 134.93532609775036 472.04645130073789 -31.398300244181453 135.1982807803557 468.3822463688399 -31.028083803939804 135.33981968287392 464.70356150110183 -30.797667392998104 135.35455903808 461.03718833611327 -30.675009615376595 135.2479896529465 457.40571761302897 -30.625491165101735 135.0248016049423 453.82036441273385 -30.6148212494024 134.69074268414695 450.28932179973367
+-32.029162436178993 137.07897805619481 472.05588323727972 -31.572188445897453 137.386953201913 468.33490565901036 -31.272073109520349 137.56685802136892 464.60277460594227 -31.10847730681488 137.61311274357013 460.88602590978462 -31.047927915133158 137.53169952064633 457.20519898182272 -31.055691087298172 137.32828976166908 453.56943703644112 -31.097004975383733 137.00838466617486 449.98524217429434
+-32.770257225248962 139.00959629273393 471.98235787504478 -32.403666466898315 139.32805786547664 468.22790323354002 -32.191307520826527 139.51257027164439 464.4672376225148 -32.108992654065453 139.55886003127765 460.72527109478585 -32.122186145791773 139.47394756481069 457.01873490311698 -32.196474814759462 139.26439896409912 453.35384386585503 -32.297312100679086 138.93534179025815 449.73468877619217
+-33.999876004040829 140.54225595501973 471.84272787188684 -33.727360011400862 140.83295726634026 468.07976308763205 -33.603294679633443 140.98564025288579 464.3165061081209 -33.600003724464557 140.99873569956756 460.57505204249924 -33.682950665646075 140.88073394593209 456.86717328572973 -33.818783225007877 140.63889286956299 453.1958554876876 -33.973723777458744 140.27781719733818 449.56251604563425
+8 0 0 8 5 -40.021144853065948 128.79173811216748 475.37790691687883 -39.900397710009635 128.92405438820785 474.51796769214792 -39.780934831392052 129.02575047854174 473.65182101904088 -39.659584862579131 129.09659186898381 472.78184227483069 -39.532959251891633 129.13654483453928 471.91006743790132 -39.397452399782757 129.14574677916761 471.03845732912373
+-38.116506372608491 128.759074002912 475.5901950688197 -37.984083140533279 128.89755066309823 474.73064077359288 -37.853584396425454 129.00489726425431 473.86789787112951 -37.722045842794344 129.08124487528261 473.00479527889308 -37.586344015945805 129.12706687962441 472.1435735165494 -37.443178541311539 129.14313268161987 471.28606518882486
+-36.21186753071612 129.31923504576693 475.89369949697561 -36.067763272100564 129.4736279407754 475.01861738900152 -35.926236928446912 129.59572323777479 474.14285505729003 -35.784508946674812 129.68587233278467 473.2696783932505 -35.639720515590334 129.74489534680518 472.40157998839805 -35.488904652022164 129.77403482219498 471.54036134354573
+-34.524823455975834 130.47596446818065 476.26416914701952 -34.372971741180571 130.65536396030785 475.35731531642648 -34.224291416355463 130.80067827580282 474.45143292164857 -34.076176228442279 130.91230908533964 473.55011467765468 -33.925770914673741 130.99118085940279 472.65618267394291 -33.770463620516423 131.03877291662755 471.77146564691765
+-33.272931250328064 132.13827010287048 476.66278065121298 -33.121293511741023 132.34844471269028 475.70991811213116 -32.97328578060884 132.52223479692725 474.75865258389751 -32.825989545042106 132.65984793328315 473.812881455774 -32.67702122162499 132.76223012101153 472.87542100492277 -32.52361593065627 132.83079378180764 471.94837882623807
+-32.622002397967087 134.11868512051598 477.04177040834071 -32.480787626664643 134.3593884024769 476.03327764562647 -32.34344494215263 134.56108241204464 475.02604482641141 -32.207009312412183 134.7238225395925 474.02388502822856 -32.068411889117399 134.84815317975878 473.02994958569883 -31.924967454387566 134.93537621150949 472.04645540049012
+-32.63148623909423 136.17344176128165 477.35684759314483 -32.510208739636141 136.43780150990344 476.2893707128834 -32.39275006219021 136.66045409043056 475.22212761472912 -32.275609577088858 136.84118923450649 474.15885021717958 -32.155451236729498 136.98037198350889 473.10262004756521 -32.029157790985494 137.07898688094213 472.05588391910067
+-33.25254624419069 138.07053707367757 477.57788672009457 -33.157153108269561 138.34687977169679 476.45450341324323 -33.065178578666426 138.57903046935164 475.33002099760949 -32.972569816882199 138.76664497104139 474.20790987562543 -32.875460662598371 138.90991389743914 473.09115748019036 -32.770256670980395 139.00959737054563 471.98235795668313
+-34.358790302547511 139.6316306891415 477.69186808626966 -34.29061420731658 139.90632791864553 476.52092667548976 -34.225124143408365 140.13482995498285 475.34755783281093 -34.157713885738467 140.31680235270321 474.17488607618344 -34.083990611446545 140.45239752428279 473.00572230601568 -33.999875944408345 140.54225606832352 471.84272788063907
+8 0 0 7 5 -15.799640019991951 106.18558153288312 420.32952844003808 -15.960898412836441 106.33659744999154 420.32952844019195 -16.122250044865815 106.48751522092711 420.33125985588339 -16.283664830585931 106.63834064755412 420.33472089378978 -16.445112581361943 106.7890793691422 420.33991065751547 -16.60656305100165 106.93973691840851 420.34682913393937
+-14.465032505747359 107.18554930657885 420.32952844811547 -14.621545521916506 107.34083910777753 420.3386999140659 -14.778078489947987 107.4958130143046 420.34970615552538 -14.93459883846762 107.65047447867522 420.36253647097999 -15.091073843211275 107.8048268722811 420.37718081591811 -15.247470656095761 107.95887351819775 420.39362978882735
+-13.130424959200477 108.18551710447767 419.86600962025818 -13.282192792561007 108.3493323176085 419.88081690792143 -13.433906991626168 108.51269706014156 419.8975990004692 -13.585532692905417 108.67561152533115 419.91633733101293 -13.737034852636937 108.83807588205742 419.93701368335627 -13.888378257903423 109.00009028635482 419.95961017748061
+-11.919500368674774 109.0928142341417 418.93901553806228 -12.067897207394791 109.26831477294357 418.95506191025856 -12.216187048983123 109.44332461525062 418.97323154773989 -12.364373504605588 109.61777942238706 418.99356859003979 -12.512330924546079 109.79179595036767 419.01591879492207 -12.660072685030379 109.96531236349998 419.04031712423193
+-10.956218829556493 109.81456237794762 417.61270488847958 -11.104043579531261 110.00316609657735 417.62576608793216 -11.251742992156256 110.19131786566557 417.64109275768203 -11.399232790723012 110.37907051904067 417.65859455382503 -11.546564569247874 110.56629682098367 417.67837132711827 -11.693664103654603 110.75305213267792 417.7003230949648
+-10.33495763956476 110.28004841965671 416.01702266678052 -10.485781288122411 110.48138097662414 416.02414791934615 -10.636501685164824 110.68234924782953 416.03367009001641 -10.787085498849537 110.88294362145295 416.04555619354244 -10.93749964755988 111.08315449677366 416.05977295481995 -11.087711295544942 111.28297227746012 416.0762868297266
+-10.094831956559974 110.45996494348869 414.31234313539449 -10.252071351742963 110.67225603332545 414.31253761365127 -10.409262341867063 110.88428655892594 414.31525201602625 -10.566375499602897 111.09604340572838 414.32045228460328 -10.723381932807097 111.30751341636226 414.3281041545676 -10.880253281264524 111.51868338857544 414.33817320497218
+-10.223913988498131 110.3632489646543 412.65249476461565 -10.390061809216249 110.5840209756356 412.64649754193408 -10.556224424654879 110.80462841530678 412.64314057286055 -10.722377015984886 111.02505430351087 412.64239057910191 -10.888495547882368 111.24528154249579 412.64421432477695 -11.05455675672766 111.46529292133577 412.64857869602383
+8 0 0 7 9 13.686304969104579 36.203227412627321 420.32952879794681 12.700262730534627 44.694864286920563 420.32952879866531 11.214731091279502 53.128795244400536 420.32953283575284 9.1142241216476556 61.455224183097549 420.32952207832437 6.3020289993312488 69.609149352762088 420.32953112358126 2.7947580594995536 77.477278748059589 420.32953408856031 -1.2868376816841263 85.03174222962086 420.32952079238459 -5.8057968637457478 92.309014368970438 420.32953288625151 -10.673666874359112 99.344195616476043 420.32952880770461 -15.799640023409573 106.18558160289922 420.32952880859352
+15.125812257636801 36.370382017055647 420.329528734782 14.14000979258134 44.938209806065466 420.32952994270732 12.652805899681493 53.465870149510948 420.32949380844963 10.547555759959879 61.900328328312888 420.32960860808629 7.7232225871899152 70.171780934918303 420.3294850002622 4.1973866401335203 78.154450697437227 420.3294690274447 0.09461932423691688 85.809070079636342 420.32962713120202 -4.4433405746004189 93.174003983532856 420.32948040740081 -9.3271537902784836 100.28295082781375 420.32953430146955 -14.465032464268191 107.18554939286349 420.32952880854356
+16.565319887591933 36.537536661129771 419.97950805500437 15.579757469867848 45.18155542945901 419.97515020464562 14.090869479521579 53.802935219675234 419.96841694479593 11.980912486593528 62.345443141876913 419.95910567338291 9.1444023687121714 70.734417719776275 419.94593740033861 5.600001171849434 78.831613748973624 419.93028232395585 1.4761007604511729 86.586394261346953 419.91389424612942 -3.0808960330633606 94.038999866136237 419.89712292244235 -7.9806394592292662 101.22170695240493 419.8811280893093 -13.130424901558563 108.18551718550131 419.86600998393061
+17.904071637580145 36.692991601149714 419.2794819987347 16.917484556298771 45.407733675112844 419.26639716977093 15.425111472649025 54.115904997447316 419.24630077067189 13.308059362835493 62.758074901432735 419.21799340097618 10.456561317293183 71.254915022707536 419.17889449919846 6.890432460215373 79.455563789770522 419.13197514402538 2.7426180257699802 87.299793368821256 419.08233478478672 -1.8363241006912259 94.829659393917581 419.03249607135064 -6.754882793114807 102.07648368976832 418.98434828312884 -11.919500759094387 109.09281396368934 418.93901667721371
+19.041204243361939 36.82503466367271 418.26610425269138 18.05102595932885 45.59950431556878 418.24086831476524 16.551523325576046 54.380542428626377 418.20220059316443 14.422567978915687 63.105610126480933 418.14740249051124 11.550348393620085 71.690746380796881 418.07227859356141 7.9564000902616598 79.973137597020724 417.98206901582256 3.7789273110334944 87.885145292967948 417.88646746665484 -0.82769957865187815 95.471509186627031 417.79131717356876 -5.7708876010313404 102.76313168063798 417.69918608309206 -10.956218058192766 109.81456296543409 417.61270435899189
+19.893835480389264 36.924041621319915 417.01323691657296 18.896719632578115 45.742827788767009 416.97422456265559 17.385377878657039 54.577261574957966 416.9145503381751 15.238304831014792 63.361811541399895 416.82987854181863 12.337906433994172 72.007707183375672 416.71434946421397 8.7086183279118838 80.341981253460048 416.5761996584435 4.4942949168468935 88.291798008871979 416.430273548792 -0.14695008928074071 95.906438145458111 416.28621737705464 -5.1217952704604564 103.216823489452 416.14705881542142 -10.334957512026476 110.28004851666358 416.01702273392226
+20.413588790452515 36.984395021150576 415.61722426196923 19.40619341770735 45.829487289299998 415.56505863238596 17.878399601752257 54.694654617114971 415.48540121690041 15.707287567789548 63.511663330214809 415.37244137114976 12.771927816287297 72.186888626547798 415.21891227801041 9.1010568724337055 80.539671583181956 415.03664472164377 4.8443017752975557 88.494555228352695 414.8455152348472 0.16327265063748242 96.107218953642217 414.65858659197454 -4.848464726382856 103.40900052961602 414.47904482834264 -10.094831910002394 110.45996497669348 414.3123431757096
+20.588225694904036 37.004673739372237 414.17874846422012 19.56796303802453 45.8575118138207 414.11603636342568 18.020296718846566 54.730195421727096 414.02045540160441 15.820932269577018 63.552141527511658 413.885157010066 12.846497497858957 72.225533437320536 413.70208285524131 9.1308320890922516 80.563894706114837 413.48673874995438 4.8298574045697888 88.493365345953677 413.26352167775025 0.10753781981495814 96.076317838275855 413.04752956366764 -4.9425939531873091 103.34525640479106 412.84186156191873 -10.223914016867196 110.36324894339859 412.65249476803064
+8 0 0 3 1 -15.799639988582662 106.18558155641682 420.3295284400715 -87.806808471679688 106.18558155641682 420.3295284400715
+-16.06840867657246 106.43727123033514 420.32952843986419 -87.806808471679688 106.43727123033514 420.32952843986419
+-16.337472981393091 106.68864546708754 420.33529854477837 -87.806808471679688 106.68864546708754 420.33529854477837
+-16.606563063487162 106.939736909046 420.34682913351037 -87.806808471679688 106.939736909046 420.34682913351037
+8 0 0 7 7 13.569119665290897 22.470019828989134 426.95722234941513 13.91923610549996 24.024649463393718 425.18612123240308 14.177166153290989 25.771261497735555 423.62907278740505 14.332636252411508 27.687824551852213 422.33052864091883 14.37095093592982 29.729863529004835 421.33284388591176 14.276869180631051 31.876943078403258 420.66079027120691 14.044308563135919 34.040369124664394 420.32952872938404 13.68630496254543 36.203227399723716 420.32952878093175
+14.999290021244205 22.362910715498302 427.07924568538346 15.343881267735146 23.929727107290994 425.26868693090103 15.597443531400483 25.697838261942792 423.67387363105001 15.749951534946755 27.646388752628656 422.34146860417206 15.787541033807384 29.732285105831249 421.31724201521922 15.696150562411578 31.934128913300871 420.63260741761752 15.471334898351204 34.155137927748029 420.30755465773416 15.125812182472654 36.370381998721491 420.3295287785661
+16.429460462399547 21.996300434853165 426.97348524176613 16.768526525552549 23.602484704691296 425.09958816582326 17.017720123373056 25.422543446663745 423.44457745466332 17.167269803377408 27.436947731918245 422.0575864432289 17.204127754719195 29.604759867803129 420.98866205799629 17.115433731820453 31.901317634811427 420.27601250117891 16.898361288669776 34.22389362638922 419.94446782904106 16.565319478026755 36.537536606500069 419.97950842708735
+17.760879996538208 21.377595885764617 426.63152531844293 18.096131234837735 23.049405597484963 424.67323576592565 18.34230051345148 24.950341235670138 422.93819668814098 18.489801553567357 27.062255935005222 421.47818061871732 18.526174745424669 29.347088376746264 420.34813450271497 18.439480773269096 31.774721820688068 419.59292624031872 18.228053348172772 34.23887189896741 419.24183448855814 17.904070484960624 36.692991462593454 419.27948340870563
+18.894700172739942 20.541006513530991 426.06846211459867 19.229599333021898 22.300509370919233 424.00976803689213 19.475465986497806 24.306289212326902 422.17951689846512 19.622766900673298 26.541757458587742 420.63211068339717 19.659179507730915 28.972199049048704 419.42783975571376 19.573082143557063 31.559965626782692 418.61805579050588 19.36305763886952 34.19727175462689 418.2359272653116 19.041205784008987 36.825034839857253 418.26610326590782
+19.749439394791853 19.546653525072969 425.32475997332841 20.08858330819238 21.408879956975245 423.15621889015802 20.337770160220892 23.535586664983828 421.22165763190139 20.487316584807377 25.911583424037953 419.57818497920482 20.52445059926907 28.505877174851275 418.29160879066683 20.437048028082106 31.272006601059601 417.41945429589725 20.222758541217441 34.102200538556922 416.99818753288793 19.893835911803027 36.924041670199664 417.01323654916047
+20.277007277985543 18.468746315077244 424.45829357151291 20.625185292895971 20.44003364178014 422.17762420871713 20.881487655102678 22.694211765115959 420.13633078237132 21.035859940815627 25.217447729942283 418.39418682441715 21.074461287582917 27.982502913484645 417.02257743403686 20.983727959165751 30.933282531568548 416.08507879813959 20.759184200410683 33.962581098018298 415.62111287309165 20.413588862428313 36.984395029204506 415.61722419044816
+20.464446763912161 17.382301785281587 423.53295362568309 20.825712997244612 19.460602659086891 421.14444402063049 21.092373516632822 21.839623300245343 419.00017405671696 21.253787147383999 24.506753793506387 417.16253409711334 21.294512106866634 27.438336634538967 415.708382080609 21.19865232052625 30.568526589119603 414.70729385388967 20.958655172469346 33.790464369858775 414.20151699403721 20.588225703657937 37.004673740388704 414.17874845420977
+8 0 0 7 3 13.686304975710939 36.203227413394352 420.32952880859307 -20.144732840085936 36.203227413394337 420.32952880859307 -53.975770655882812 36.203227413394345 420.32952880859307 -87.806808471679688 36.20322741339433 420.32952880859307
+12.418543614771419 47.121047048457882 420.32952880859307 -20.992314785100209 47.14511118393515 420.32952880859307 -54.400765480583914 47.169175319412439 420.32952880859307 -87.806808471679688 47.193239454889707 420.32952880859307
+10.293672678766825 57.935923620035581 420.32952954297508 -22.407882001081195 57.922511130668809 420.32952953520754 -55.108081129443725 57.909077519395552 420.3295288575145 -87.806808471679688 57.895632002658751 420.32952884978044
+7.0403839252150018 68.558774651835392 420.32952819415453 -24.563476828616885 68.449476680030372 420.32952821922532 -56.178968323422232 68.340281392978525 420.32952880687787 -87.806808471679688 68.231181763762933 420.32952883159106
+2.4282691448990814 78.699127628000483 420.32952829237161 -27.579289353863039 78.528107260900839 420.32952826705002 -57.658248198053279 78.356847705170637 420.32952880490029 -87.806808471679688 78.185340037588489 420.32952878045188
+-3.0613866820009532 88.257852934395459 420.32952941465794 -31.226969895789036 88.101720204187117 420.32952942154202 -59.475590437691892 87.945518101369018 420.32952875821536 -87.806808471679688 87.789255753406991 420.32952876454874
+-9.2090792109000574 97.389531824623191 420.32952880859381 -35.350268166768053 97.29328738572741 420.32952880859375 -61.54951125369459 97.197042946831644 420.32952880859381 -87.806808471679673 97.100798507935878 420.32952880859386
+-15.799640023409868 106.18558160289895 420.32952880859381 -39.80202950616647 106.18558160289894 420.32952880859375 -63.804418988923068 106.18558160289895 420.32952880859381 -87.806808471679673 106.18558160289895 420.32952880859386
+8 0 0 7 7 9.4995959541939978 16.095088726156845 442.37551492134628 10.273279310117296 16.329780144514896 439.94058470467183 10.995521346832287 16.792143235244975 437.51953789951114 11.657099341450385 17.483378483371308 435.15642020013502 12.253674863398192 18.404609138551088 432.86967872732373 12.776885770877136 19.553201292345076 430.71371829366615 13.219003225081831 20.915390194584539 428.72832346642679 13.569119665290897 22.470019828989127 426.95722234941474
+10.991743322032354 16.058240530604269 442.75781600761252 11.752410836682859 16.264945057967477 440.29322348014699 12.463492601598681 16.704370650573463 437.8384677581696 13.115457575608577 17.377911179889292 435.43852786965363 13.703566091482147 18.28760409692898 433.11282305545512 14.219226609923453 19.43099777309957 430.91633555860341 14.654698774753262 20.796094323705603 428.88980443986543 14.999290021244205 22.362910715498295 427.07924568538306
+12.483890692255907 15.627548253557167 443.10215632372791 13.231542366335489 15.819164910281494 440.57736753493595 13.931446729969117 16.25027684717848 438.06008646075423 14.573840100328351 16.922540088506903 435.59518809877403 15.153451723515913 17.839109025123076 433.20371108606969 15.661562456410204 18.998186120809496 430.94037291266773 16.090394399246545 20.390116165015026 428.84738231770854 16.429460462399547 21.996300434853158 426.97348524176573
+13.85798283934483 14.805952450525027 443.37829152794581 14.596603776188593 14.997518834974077 440.76587829285108 15.288779966293289 15.436556974955426 438.16046837377814 15.924671409301629 16.125091702063955 435.60572289791145 16.498431739156402 17.06759191570702 433.1248870301157 17.001363524061091 18.263426714438062 430.77153803426677 17.42562875823868 19.70578617404427 428.58981487095969 17.760879996538208 21.377595885764617 426.63152531844253
+14.995798030502488 13.642954141570595 443.56042196484896 15.733374974595105 13.848967503930414 440.83956695452275 16.424736916403134 14.311124153727759 438.12671495236231 17.060192277719072 15.032009137929348 435.46330474589672 17.633403297715688 16.01750090800838 432.87531602721788 18.135909160168517 17.268538546801828 430.41444891347061 18.559801012457982 18.781503656142732 428.12715619230465 18.894700172739938 20.541006513530974 426.06846211459828
+15.803020744840405 12.234956320918162 443.63345051922937 16.550112404186567 12.466175941028389 440.79272317876462 17.249868197390295 12.962528624715761 437.96185404948676 17.892992968045235 13.727270126336503 435.17936381197052 18.472791056513334 14.767748142506354 432.47431018760483 18.981222355341693 16.086871773317178 429.89594692423174 19.410295481391326 17.68442709317069 427.4933010564983 19.749439394791853 19.546653525072966 425.32475997332807
+16.230803607885143 10.703224794913663 443.59643404175318 16.997924204022791 10.964940951794478 440.63432470431485 17.715323806292016 11.500849343366442 437.68400757680752 18.374286690908598 12.31499440628334 434.78076756677996 18.967933413104024 13.416087064356324 431.95694578877539 19.488810088979584 14.809178661416322 429.25909872117882 19.928829263075119 16.497458988374341 426.73896293430818 20.277007277985547 18.46874631507724 424.45829357151257
+16.275579534266285 9.1691331699569663 443.46014875246169 17.071088320257548 9.4611967344734236 440.38390853301894 17.81360980363727 10.036340322689341 437.3208683531185 18.495088374932887 10.899453675499686 434.30312034261772 19.10860063209045 12.060419026246617 431.36629697938753 19.647367225078387 13.526458622666222 428.55426453170452 20.103180530579714 15.304000911476285 425.92146323073518 20.464446763912168 17.382301785281587 423.53295362568275
+8 0 0 7 3 13.569119665319601 22.47001981945666 426.95722234662952 -20.222856380346837 22.470019819456656 426.95722234662941 -54.014832426013257 22.470019819456656 426.95722234662946 -87.806808471679688 22.470019819456652 426.95722234662935
+13.919236119780468 24.024649222627005 425.18612115870968 -20.00271623894184 23.942875410875978 425.27928142882774 -53.911397769428547 23.86110159912495 425.37244169894598 -87.806808471679688 23.779327787373919 425.46560196906404
+14.177309577877114 25.771202377572614 423.6289904091384 -19.83533358625715 25.595185215167572 423.78425704331704 -53.83048592138924 25.420929486438755 423.9406901454052 -87.806808471679659 25.248288657239257 424.09805912693594
+14.332285693252963 27.688018014826458 422.33066555660429 -19.726933899874489 27.418210680864149 422.50523117358733 -53.775164265274753 27.154269374550392 422.68508356833769 -87.806808471679688 26.896613343817201 422.87095918300759
+14.371291247885832 29.729627186050074 421.33277181360324 -19.688106167405078 29.393049018370458 421.47998768224647 -53.74930002531292 29.065063765106025 421.63226436181901 -87.806808471679716 28.74410136610085 421.78775859741057
+14.276739134122421 31.877055663682142 420.66079128950548 -19.733918328723206 31.52497704490235 420.74017623200399 -53.766062887558348 31.184961840188706 420.83339284441018 -87.806808471679659 30.856560928122612 420.93959764737559
+14.044307756684708 34.040369081702316 420.32952878131897 -19.880291683815738 33.782780899955647 420.3295287813196 -53.830663759937202 33.525192718208984 420.32952878132039 -87.806808471679673 33.267604536462308 420.32952878132107
+13.686304977682807 36.203227401481442 420.32952878131317 -20.144732838771354 36.203227401481442 420.32952878131312 -53.975770655225517 36.203227401481449 420.32952878131323 -87.806808471679673 36.203227401481442 420.32952878131329
+8 0 0 7 6 -5.7181839263646301 18.199087263369609 483.21112289684015 -2.6155665943422681 16.981888936021772 476.65874725421008 0.29029118954656496 16.066592452889239 469.96892968491636 2.9776430867361356 15.478561261332059 463.15681192665454 5.4219910559138764 15.244600028524658 456.25473696035095 7.6031662675656335 15.427208255963787 449.30479390142165 9.4995959555508005 16.095088723516607 442.37551491903065
+-4.2208551753306303 18.321231821939769 483.86864682750257 -1.1204894379307315 17.069633218979842 477.27855861893818 1.7839451082025966 16.122764962190566 470.54736864103847 4.4705919644224243 15.506419083343545 463.69057821471608 6.9145956834062918 15.247139294326089 456.74082718250867 9.0954848233614012 15.407660055104969 449.74024430164246 10.991743333277233 16.058240517059936 442.75781600733171
+-2.7235264206194643 18.002706893633409 484.60803147583971 0.37459090533990613 16.724018431087412 477.96050571140205 3.2776004153406242 15.753093671812522 471.16872229799031 5.9635362761294006 15.115999247445588 464.248463363496 8.4071980444548906 14.839038980358596 457.23173624337869 10.587809138880267 14.985448774856655 450.15996170315447 12.483890835387598 15.627548099200299 443.10215634450878
+-1.3603815553147931 17.232605191170968 485.37034529320999 1.738920232700123 15.937479994971865 478.65045633984784 4.643618635571654 14.952904309195029 471.78369493840449 7.3316418260768792 14.305061830521689 464.78601153258739 9.7774924699489372 14.020141159217243 457.68780535459206 11.960101592744337 14.162179271399898 450.52901480920286 13.857984004082724 14.805950943038054 443.37829168296935
+-0.26587511423412358 16.058951173144237 486.08558636030722 2.8414972196038235 14.759009544735074 479.28612507459576 5.7541203676982606 13.771842183459036 472.33748511044064 8.4497745524602479 13.123692443663456 465.25557662876139 10.902847430334932 12.840710198129456 458.06852108146524 13.092081080556092 12.98792283338639 450.81421956154082 14.995796558283017 13.6429553296073 443.56042169819818
+0.45650798005283222 14.592713117692586 486.68612906647337 3.5807152046828286 13.297198419315567 479.80913588215566 6.5092555384726936 12.316081686579082 472.78062896426314 9.2197618962780261 11.675564925183384 465.61641715781025 11.686591490394745 11.401991562062713 458.34171716295401 13.888327396120484 11.561614947909947 450.99182723970517 15.803020594931455 12.234956466679513 443.6334504943419
+0.76139594104049313 12.978696755838602 487.12446193399131 3.9102854609412732 11.692534963868999 480.17985836567328 6.8619724585056217 10.721985972971957 473.08110342112059 9.5938815169014919 10.093209274077758 465.84380027655362 12.080471884942192 9.8328255331817545 458.49011514591825 14.300247610035198 10.008359453982438 451.05250983058994 16.230803596063431 10.703224805880488 443.5964340397353
+0.65801719783327794 11.361800804120907 487.37786027263405 3.8365592271244964 10.085544594252918 480.3808160925301 6.8160799422998517 9.1259143880355733 473.22664245139623 9.5737318030555461 8.509045337928832 465.93067969178611 12.084133007297586 8.2618924592265142 458.51213805366359 14.325751737508606 8.453215696085369 451.00057688828332 16.275579533502995 9.1691331706917811 443.46014875233544
+8 0 0 7 3 9.4995959561621337 16.095088726108443 442.37551492185059 -22.935872186451817 16.095088726108447 442.37551492185059 -55.37134032906576 16.095088726108443 442.37551492185059 -87.806808471679716 16.095088726108447 442.37551492185059
+10.27327923367112 16.329780159547088 439.94058459330108 -22.394781198691771 16.340146795975851 439.83303044411213 -55.088143767142043 16.350513432404608 439.72547629492317 -87.806808471679716 16.360880068833367 439.61792214573421
+10.995197313642704 16.792287365228333 437.5203818796785 -21.90745021231529 16.826295715374243 437.37560997837124 -54.841862804214522 16.861820494629388 437.23267635782923 -87.806808471679673 16.898102890754345 437.08989772988616
+11.65754127297798 17.483142672887336 435.15431402244383 -21.470114207921505 17.534892169254071 435.01719634696735 -54.625217753171604 17.586649217697953 434.87880637445028 -87.806808471679844 17.640267814592793 434.74334300883214
+12.253608090455561 18.404715757177655 432.87175835145064 -21.081726435595815 18.459202607409686 432.77028128258581 -54.435295019231816 18.514948272047452 432.67119035762568 -87.806808471679574 18.570099661978347 432.57027796403156
+12.776763158541312 19.55321111065631 430.71290648344973 -20.742211877207282 19.594151204427398 430.65675084658426 -54.270106582784457 19.634855464744394 430.59984767902444 -87.806808471679787 19.676062003112456 430.54386925787708
+13.21900321085867 20.915390416286314 428.72832353454908 -20.45343136840977 20.932865514264122 428.70841514562733 -54.128701929255875 20.95034061224192 428.68850675670558 -87.806808471679702 20.967815710219714 428.66859836778383
+13.569119665319541 22.47001981945666 426.95722234662929 -20.222856380346879 22.47001981945667 426.95722234662929 -54.014832426013271 22.47001981945667 426.95722234662929 -87.806808471679702 22.470019819456663 426.95722234662929
+8 0 0 7 7 -5.7181836133926129 18.199086884286448 483.21112311235152 -6.9181489100715332 18.59730675769686 485.35480471481736 -8.135180571372425 19.172687841589958 487.44513591622575 -9.3598407891388113 19.925064533204015 489.47171361377264 -10.579109129142731 20.848058013593569 491.40755245894115 -11.778458804727677 21.938433322174838 493.22927283717098 -12.940166950358586 23.195020798945951 494.91825049834222 -14.037858895078891 24.607201894381998 496.44272783807378
+-4.2208538601678702 18.321230187626764 483.86864773078503 -5.3964203436608686 18.770811479258526 486.02398493258505 -6.5859960070579318 19.400784310280283 488.11794822664478 -7.7799606785855122 20.209312914499939 490.13883426219382 -8.9646828378697023 21.188889638475217 492.05806735396641 -10.124821246673994 22.334092411233065 493.84971946622392 -11.242262501932894 23.638579458498707 495.49332041111887 -12.291458844587385 25.084394172509754 496.9578661429934
+-2.7235219390497338 18.002700997021226 484.60803460867146 -3.8746895806269004 18.493023735222625 486.8099714668935 -5.036827532505308 19.169149166743036 488.94579954339764 -6.2000674256883901 20.028188437218013 491.00236280298975 -7.3502289782876176 21.062465798503112 492.95020897093656 -8.4712070733162648 22.265777452286553 494.76158356315005 -9.544356435647888 23.628651739036389 496.41350426281389 -10.545057436481205 25.128389679734276 497.87429224249036
+-1.3603730044777855 17.232589539201808 485.3703520862237 -2.4943601026470938 17.748024123070994 487.65057511451124 -3.6371235919442797 18.456132054352409 489.86371122446485 -4.7785409178009903 19.353614349075137 491.99521722503238 -5.9041242958778195 20.433737815707847 494.01580089834323 -6.9972309085893363 21.690878282559105 495.89699541299626 -8.0387252362623194 23.115167835430071 497.61327760967242 -9.0047694840459069 24.682935195908062 499.13114672550944
+-0.26588967089578497 16.058960300145301 486.08557805237893 -1.3971788450853202 16.582473600847589 488.46740915108143 -2.5367293854903243 17.306252223453772 490.78452160783655 -3.6742364146387323 18.227171832356373 493.02117729583694 -4.7952933961517701 19.340363283390907 495.14935476989302 -5.8831569170807319 20.642041587258081 497.14112388278789 -6.9184308092058284 22.124659365744403 498.96888451391834 -7.8776560916867542 23.767722928008425 500.59670032189769
+0.45650248846224173 14.592717916851875 486.6861256803013 -0.69093923777438926 15.110923719027445 489.18059735910305 -1.8481970075610794 15.837261395010334 491.61474223351058 -3.004878787518801 16.769231803733451 493.97177923547991 -4.147069018112548 17.904351592250663 496.22579225848983 -5.2584314499762961 19.24166031956257 498.35032903503287 -6.319564757570733 20.777892255925117 500.31619883995609 -7.3067796499822935 22.49891905400829 502.08493306024775
+0.7613944194240293 12.978698165662523 487.12446098079948 -0.4202597138278113 13.484752278903759 489.73032916563659 -1.6150014209602093 14.206853801734656 492.2807643429785 -2.8123754417556324 15.143395901244572 494.75799888647384 -3.9992235788342434 16.294389468881683 497.13863105798544 -5.1599639482412876 17.662246399863193 499.39813034423167 -6.2752491291971344 19.248879157309503 501.50598860702559 -7.320499748147725 21.047992175043909 503.42146335572698
+0.65801684601483679 11.361801140743037 487.37786005027613 -0.57129492912020452 11.855408378330562 490.08403767571508 -1.8179071266544415 12.572820160116732 492.73895593497235 -3.0712270670804878 13.513367553184201 495.32385328691822 -4.3189461876058823 14.679412220814113 497.81786340124404 -5.5463137992638867 16.076662425365821 500.19837465515695 -6.7339078739559302 17.712195520901876 502.43365609437024 -7.8557272118926917 19.5873318470742 504.48117843502502
+8 0 0 6 3 -5.7181839244957891 18.199087263522426 483.21112289766074 -33.081058773557082 18.199087263522426 483.21112289766074 -60.443933622618374 18.199087263522426 483.2111228976608 -87.806808471679673 18.199087263522426 483.2111228976608
+-2.6155170149532725 16.98189298213785 476.65876902649694 -31.009140775506896 16.980270189157391 476.65003326916531 -59.406237927749032 16.978647396176932 476.64129751183373 -87.806808471679673 16.977024603196469 476.63256175450215
+0.29031446989240361 16.066717345411782 469.96866245150119 -29.075126428116175 16.067018819468078 469.966797249183 -58.440895188449936 16.068152226675096 469.9648868907168 -87.806808471679673 16.068435072039211 469.96302579506226
+2.9770512264784337 15.478337232002151 463.15736418107821 -27.29049543472183 15.481321361324078 463.17324228732065 -57.551666772051476 15.482797219691225 463.18920396935232 -87.806808471679673 15.485793313548701 463.20507927216914
+5.4225267926886662 15.24472522131073 456.2543570893809 -25.664487260941389 15.24632379134618 456.28873174524415 -56.741006946992549 15.248780915287943 456.32305526845602 -87.806808471679673 15.25041406672964 456.35742207975483
+7.6032663617241854 15.427205780110409 449.30481955033105 -24.208815551464394 15.423631585580479 449.34190192071713 -56.012173829265663 15.420057391050548 449.37898429110311 -87.806808471679673 15.41648319652062 449.41606666148931
+9.4995959567733923 16.095088724221359 442.37551491941457 -22.935872186044303 16.095088724221359 442.37551491941463 -55.371340328861976 16.095088724221359 442.37551491941457 -87.806808471679673 16.095088724221359 442.37551491941468
+8 0 0 6 3 -14.037858916483001 24.607201913344849 496.44272780859092 -38.627508768215222 24.607201913344852 496.44272780859092 -63.217158619947426 24.607201913344852 496.44272780859092 -87.806808471679645 24.607201913344856 496.44272780859092
+-12.75721875423276 22.959656153465261 494.66417177956021 -37.778011700389008 22.968277468707232 494.67347864834358 -62.794541606204625 22.976898783949203 494.68278551712689 -87.806808471679645 22.985520099191174 494.69209238591026
+-11.387382874737684 21.52987317593514 492.65520971436752 -36.875443731954654 21.555760957037972 492.68845675484204 -62.34858103712758 21.581682410965904 492.72168154095459 -87.806808471679673 21.607637324764355 492.75488395541271
+-9.9724715970274467 20.336841171800661 490.47196605748155 -35.942794568112362 20.368974234950521 490.53079918892792 -61.887538201067301 20.401224066660994 490.58953120185288 -87.806808471679616 20.43359259590229 490.64816161654142
+-8.5424047025254541 19.376145166617878 488.13819948220754 -34.996280495958871 19.403990896062094 488.21593339756282 -61.417670275676087 19.43225056780669 488.29330786083005 -87.806808471679659 19.460921100289553 488.37032497400924
+-7.1181433853642488 18.663676983021482 485.71208458176068 -34.039263774308466 18.675309827418712 485.77470606641924 -60.935485469746929 18.686942671815938 485.83732755107781 -87.806808471679645 18.698575516213168 485.89994903573648
+-5.7181839255993552 18.199087262065969 483.2111229003425 -33.081058774292785 18.199087262065976 483.21112290034245 -60.443933622986215 18.19908726206598 483.21112290034245 -87.806808471679645 18.199087262065984 483.2111229003425
+8 0 0 7 9 -14.037858895078896 24.607201894381969 496.44272783807361 -14.891619296528024 25.705564968610005 497.62843243564259 -15.70784160895187 26.894615842663907 498.71828189185089 -16.478217809351801 28.17145084177335 499.70078090671331 -17.183681533967214 29.52755316142748 500.56033393163625 -17.821323143937633 30.961861732637477 501.28903670362149 -18.363191088736162 32.465012631003233 501.86959847486241 -18.80251885874404 34.01559554263261 502.28703652004015 -19.123469384950106 35.595504107172026 502.53351124620576 -19.323704737760007 37.194229928492085 502.6059250478105
+-12.291458844587387 25.084394172509725 496.95786614299305 -13.107500444429771 26.208916727851651 498.09695726778432 -13.88356053487392 27.415790665569535 499.13168631366517 -14.611307320397984 28.699273322285521 500.05110314388151 -15.273197628265287 30.046553511672187 500.84000718389649 -15.866642928946776 31.453159758657016 501.49585887037512 -16.367228154539735 32.905894740819178 502.00389579469692 -16.770936279531927 34.383584007107466 502.36062970267687 -17.065082775311676 35.873400628796901 502.56368983101714 -17.249101176890917 37.376383355160833 502.6141755268676
+-10.545057436481205 25.128389679734248 497.87429224248996 -11.323380437129341 26.294852522499273 499.01046067112713 -12.059293344175909 27.54106473165222 500.03519333773079 -12.744356570150616 28.859287793977703 500.93743111861141 -13.362733758542781 30.234080010771628 501.7013701878717 -13.912028884122808 31.65774680714674 502.32743229192704 -14.37112687547204 33.113751558863932 502.80143367983504 -14.739469373307118 34.580814099474658 503.12782985028895 -15.006653113785557 36.048744691466716 503.30748941890459 -15.174497555438139 37.52582808434093 503.34455697459623
+-9.0047694840459105 24.682935195908033 499.1311467255091 -9.7561372323220343 25.90230980961314 500.31171159338226 -10.463364814127624 27.205312320759184 501.37655537784326 -11.117815822575167 28.583502170679782 502.31394794845198 -11.705203644164088 30.021263968250796 503.106534771241 -12.222902086754045 31.508502402522584 503.75492293890386 -12.652197001980083 33.026902666951102 504.24299908064648 -12.995515965310952 34.554945587900548 504.57791315949436 -13.243232426163519 36.081624958665437 504.76037593928658 -13.399495245129744 37.616267300855384 504.79568688568054
+-7.8776560916867453 23.767722928008396 500.59670032189723 -8.6237202002830209 25.045661254213748 501.86277928365888 -9.3253108062252004 26.417162844988063 503.01219918754333 -9.9735318445562982 27.87455550578845 504.03214295312796 -10.555033747380811 29.404722599049837 504.90326287408601 -11.06644936785394 30.996512610190184 505.62328080855701 -11.489703278485942 32.631959951669643 506.17237210701524 -11.828560555670974 34.2895232042383 506.55420697311928 -12.072128050645153 35.953790196504251 506.765697921259 -12.226021544516946 37.628222270247178 506.81113767691232
+-7.3067796499822846 22.498919054008262 502.08493306024729 -8.074613455191276 23.837495452517398 503.46061523158517 -8.7992251648231701 25.283888582055674 504.72123208626283 -9.4714154278262619 26.832369460786886 505.85260525531652 -10.077824439670581 28.474289369441774 506.83359205734581 -10.61392480702666 30.198753671619201 507.656346453617 -11.060075193614784 31.989808917487164 508.29702894048927 -11.419217753056042 33.826202416368069 508.75091326472165 -11.677224195855379 35.685493487458963 509.00859199641883 -11.839850284279397 37.559800388993771 509.07184125683165
+-7.3204997481477134 21.047992175043881 503.42146335572653 -8.1334724517759511 22.447302299948419 504.9112770491609 -8.9054898955441626 23.970634756850625 506.28875709430753 -9.6270003533074142 25.614803499206424 507.53823665155807 -10.283695953577073 27.376423807604144 508.63734981897164 -10.869662527054478 29.245681837044586 509.57110162980587 -11.361879990128289 31.209291640690065 510.31240081527028 -11.760832284621593 33.246406506423675 510.84581033827749 -12.047967148542959 35.326487339228876 511.1547002892907 -12.228066977321459 37.427536022783407 511.23784331340624
+-7.8557272118926758 19.587331847074168 504.48117843502439 -8.7282533636212687 21.045771211874865 506.07369581108918 -9.5623034892277108 22.644109973602706 507.55654504232393 -10.347916438771367 24.381725824092044 508.91263809360441 -11.069251500686972 26.260254606204271 510.11884797354429 -11.718777342724213 28.271120194011726 511.15326518382926 -12.269400884835925 30.403612372531509 511.98608136291728 -12.718200563845393 32.637092576756515 512.59187382779157 -13.04204127332099 34.933354424619743 512.94702109518187 -13.244107440865722 37.256166893556724 513.04768371355533
+8 0 0 7 3 -19.323704384938566 37.194229959470533 502.60592504921021 -42.151405747185606 37.194229959470533 502.60592504921021 -64.979107109432647 37.194229959470533 502.60592504921033 -87.806808471679688 37.194229959470533 502.60592504921033
+-19.065723885319635 35.138772347224396 502.51282372117896 -41.96455887921875 34.943338455531624 502.50397160243398 -64.878253741338767 34.747904563838851 502.49511948368905 -87.806808471679688 34.552470672146079 502.48626736494407
+-18.602378714149225 33.114982945151425 502.12191162959812 -41.627879967225972 32.854300314533099 502.05252439221726 -64.693506752283838 32.600936404831543 501.97572186577491 -87.806808471679702 32.354174367661763 501.89166341787632
+-17.93802626013786 31.149664147616122 501.43685339830654 -41.167851831843763 30.905049856762403 501.32341941557576 -64.456723731346244 30.664972484848064 501.20717708014956 -87.806808471679702 30.429979576684079 501.08943066124698
+-17.11354846251308 29.298079249980244 500.49337894767342 -40.615743188008061 29.106047990006392 500.36720848632689 -64.179368369126692 28.917143723643836 500.23880887548353 -87.806808471679673 28.730304385379966 500.1072782517486
+-16.169898178112717 27.588594285674791 499.32773335600422 -39.997186214142829 27.460676096001489 499.21845894027825 -63.875957795597571 27.333662996670025 499.10836807468291 -87.806808471679716 27.207989880539536 498.99779181739535
+-15.13555048412608 26.01938399324164 497.96720440490304 -39.329606985009207 25.959328269984617 497.90237314420148 -63.553359647527088 25.899272546727591 497.83754188349985 -87.806808471679702 25.839216823470579 497.77271062279817
+-14.037858916483017 24.607201913344849 496.44272780859097 -38.627508768215236 24.607201913344849 496.44272780859103 -63.217158619947476 24.607201913344845 496.44272780859103 -87.806808471679702 24.607201913344852 496.44272780859092
+8 0 0 7 7 -19.323704752184224 37.19422992968795 502.60592506491372 -20.323551678060465 48.246590580238419 503.10653838988878 -21.480321293091507 59.324737256134902 503.03186583247219 -23.001532805420723 70.366134600355878 502.4084618023864 -25.080050330638596 81.319211284189421 501.26614427711854 -27.887241884327569 92.065241174870096 499.65039788167593 -31.4041981702442 102.52028670986658 497.63667217944118 -35.568095716008983 112.648046997639 495.2800949963202
+-17.249101191335377 37.376383355431699 502.61417553973627 -18.250882506614744 48.45363632490875 503.10777785682615 -19.415586846092847 59.583051234128149 503.02496374278553 -20.951107566729267 70.700532496608275 502.38787100995302 -23.053619805422827 81.751567050621063 501.22151856779249 -25.898950193137836 92.602654133305265 499.57012983439188 -29.462948354920336 103.15567503300048 497.51436792070302 -33.677180111598318 113.36922521805062 495.11228769763903
+-15.174497568434361 37.525828083819789 503.3445569831897 -16.178214672189299 48.660180574252315 503.83276169524652 -17.350854749873573 59.871908162103196 503.73940695913581 -18.900632769031407 71.094982641878957 503.08298118074572 -21.027275560456594 82.271387150174036 501.88391534560492 -23.910614064799262 93.2526908910354 500.18578571501217 -27.521693657768399 103.92626477749232 498.0750546541048 -31.786264266506297 114.24616759161175 495.61390087562472
+-13.399495254580749 37.616267299798309 504.79568689201545 -14.40493401853168 48.836317600848147 505.28111908823081 -15.58349194618356 60.15406502750001 505.17600665774222 -17.143800022880956 71.501432959283363 504.49657659960144 -19.288960839086943 82.816910007732432 503.25957664586383 -22.201857817737945 93.939431052581725 501.50860310579662 -25.850244037539817 104.74353813747899 499.33565249952926 -30.155020928942804 115.17980161458181 496.80782569740541
+-12.22602155152655 37.62822226902783 506.81113767776935 -13.232751633894427 48.952018534297196 507.29706307360641 -14.413157121305902 60.385411753930313 507.18112685856755 -15.976542468470141 71.85859460170991 506.47904894746847 -18.128742665412172 83.307318674062827 505.20540127952694 -21.054339058291418 94.562738890199839 503.4043324512312 -24.720305414151511 105.4903407590419 501.17198973127086 -29.044891695574822 116.0385568285898 498.58034454251276
+-11.839850285577045 37.559800388059777 509.07184125803383 -12.84728070621855 48.988966194943004 509.56137227761741 -14.024571969541473 60.529320225186915 509.43828827151259 -15.581990185169889 72.110155209420199 508.71940806322823 -17.727059931217635 83.665889469358362 507.41886044896097 -20.644505936239241 95.026320587317869 505.58157767508743 -24.303369650602544 106.05307376641339 503.30542842200464 -28.62212967468222 116.69382593343215 500.66600474235025
+-12.228066974027675 37.427536022433884 511.23784331535791 -13.23555337989761 48.948693175785365 511.73324707365413 -14.405703267173937 60.572918792686984 511.60834405551685 -15.949855825393184 72.229693775889501 510.88216324728421 -18.07600412470201 83.853667839686366 509.56994052294607 -20.96750611512892 95.279444150162703 507.71741354410472 -24.597727373773314 106.37014952053281 505.42142584545024 -28.88798319693645 117.07397210495056 502.75909270827066
+-13.244107433710264 37.256166894002412 513.04768371761452 -14.251052356417212 48.846016205985187 513.55015173013442 -15.41181489804722 60.523279677135406 513.42898251464669 -16.93868348642669 72.218682409168352 512.70597254154359 -19.038946537067989 83.868454267182756 511.39862702386182 -21.893340045145315 95.316741093693395 509.55342204775781 -25.480815111292447 106.4327529676558 507.26376557929763 -29.727320322740713 117.16625638448777 504.60593215421267
+8 0 0 8 10 -35.568095630307504 112.64804701144766 495.28009490391821 -36.886033560129007 114.96625309318358 494.74068336270517 -38.041207852907689 117.26030456497163 493.82394541675473 -39.000850671402553 119.49378269080151 492.52090674725429 -39.753918132534565 121.62592371477916 490.80061710357245 -40.277463727707662 123.49631371991134 488.78231171513517 -40.598175635169355 125.18006222006457 486.40009288541796 -40.721773783866247 126.52974101221413 483.83887513801301 -40.661575949602963 127.5961151562741 481.10066830396147 -40.426143296962643 128.34796117273453 478.2620512576803 -40.021106745728879 128.7917345555492 475.37793002302698
+-33.913544349038077 113.27907805914285 495.13326374904437 -35.167860290829616 115.51993504790164 494.51819376923356 -36.261869506677144 117.70986846965654 493.55035148269769 -37.168637085481912 119.82274539328651 492.23539186525949 -37.881474204244547 121.84132539222672 490.53899838855375 -38.376144428799677 123.60771770396234 488.58656857307813 -38.68247680024691 125.22766208426795 486.27498760816565 -38.797697930157341 126.52491749999815 483.79728986362642 -38.73789621646489 127.5645506506833 481.14495121303071 -38.508842600410361 128.30711604265076 478.39158157337437 -38.116468662328238 128.75907084366335 475.59021428542565
+-32.258991978526112 114.02693296021725 495.48849955542289 -33.449686157406411 116.26612859979562 494.80281056384922 -34.482547518474831 118.43142506585141 493.77404200304369 -35.336420067867891 120.50063986632257 492.41986790257283 -36.008926382601473 122.47220931349042 490.70795085900596 -36.475039641612874 124.19321093369248 488.76732158343367 -36.76659111000847 125.7898650800693 486.47322925972185 -36.873694829585965 127.06888081479605 484.02072928232292 -36.814208631435875 128.10455255478198 481.39593999983509 -36.591541879648872 128.85251611647229 478.66972210597032 -36.211830545778149 129.31923105558334 475.89371506551231
+-30.766732190161584 114.82969365084996 496.36011587290011 -31.906973183064704 117.14784498411333 495.61687290587992 -32.891489287994908 119.37653635248657 494.52361438648632 -33.703708893956673 121.49067914324033 493.10543041116273 -34.344613195174844 123.49402799132454 491.33683261019939 -34.788821769622309 125.23997587274748 489.34681969556215 -35.068836911663752 126.86117248489802 487.00911682211876 -35.17017686038907 128.16218503890931 484.51392817396459 -35.111300612055373 129.21975934528905 481.84848221428194 -34.894087799516029 129.98884397543847 479.08155612360616 -34.524791046298091 130.47595060049017 476.26418015035733
+-29.599959064768321 115.60917858807434 497.69408715337596 -30.71625686367604 118.08083578655524 496.91086330623739 -31.678199148941346 120.45712560416976 495.75456381101378 -32.471291772834896 122.70358549857032 494.25196129925865 -33.097987875267329 124.81800915390993 492.38840269585046 -33.532901311974015 126.66056262169771 490.28835872719964 -33.807975298367118 128.35414152456076 487.8459448848181 -33.907673079572696 129.71746256021547 485.23963692255978 -33.849949423147201 130.82205062127272 482.46461282908587 -33.636303118235503 131.62678712327394 479.58854740836802 -33.272889332256071 132.1382624426343 476.66279245661781
+-28.886364408126546 116.28427714557363 499.36245769804185 -30.014023653010163 118.96607210617667 498.55555940051835 -30.98752310275902 121.55599984139822 497.33946660525777 -31.791462256877253 124.00535653994309 495.73726855196952 -32.427413307808209 126.2959798536519 493.74817754069426 -32.870144842008365 128.2949574147604 491.48755225043084 -33.149853496957704 130.09984145103255 488.88965642188589 -33.253706174158104 131.55850991842232 486.11521480756744 -33.198103421337976 132.72985615945024 483.173238570352 -32.985488299114209 133.58097672856994 480.13127391814209 -32.621958675774472 134.11868785871724 477.04178425685183
+-28.688594371545452 116.78886149267396 501.18927478154512 -29.863801614249912 119.71203475728767 500.3693016976253 -30.883411052472947 122.55379334971775 499.09588945688529 -31.72788303437083 125.24819946296574 497.38470641105454 -32.395733323512374 127.75417479681653 495.25094273621789 -32.862285269214112 129.94625134834652 492.7971648142173 -33.15533140759517 131.88485794419063 490.01161281587378 -33.268316325192416 133.4583146835154 487.03296458788571 -33.215411685709284 134.7071541786691 483.88789350684993 -33.001172803876862 135.60984205660216 480.6445251786522 -32.631446055314086 136.17343439174115 477.35686112385275
+-28.992900505838975 117.08550751731231 502.98994740327811 -30.244293791482189 120.25475761286835 502.1603974609871 -31.336670449182257 123.35640656723638 500.8306614559437 -32.244048546369442 126.30647597866046 499.00744184042719 -32.960580242531378 129.03784581095695 496.72305461852415 -33.462741875194418 131.43342626329778 494.06501406390629 -33.775532854495488 133.51004978965571 491.08177774270945 -33.901208322687054 135.2025931825614 487.88779901458429 -33.851250132675432 136.52987707608202 484.5287409448494 -33.633169960793154 137.48341332579278 481.0735997311516 -33.25250474110895 138.07052826522406 477.57790294238316
+-29.727320377057943 117.16625635375637 504.60593211599007 -31.071383854858112 120.5635661920174 503.76468087945887 -32.251025263755494 123.90701465989967 502.37914598106772 -33.232671712223549 127.0956031899827 500.4474894114818 -34.005854308953133 130.03665500610524 498.01923337544173 -34.548974446302417 132.62256630264548 495.16610985272195 -34.884156989860323 134.82559794303816 491.99571566895639 -35.023794172750037 136.628058900582 488.5982722456863 -34.976472534500317 138.02625613639242 485.03747530142198 -34.753069622074989 139.02491896288993 481.38311758727093 -34.35874715064628 139.6316217605432 477.69188796372202
+8 0 0 8 3 -40.021106745724808 128.79173455553911 475.37793002302612 -55.949673987709772 128.79173455553911 475.37793002302612 -71.878241229694723 128.79173455553911 475.37793002302607 -87.806808471679688 128.79173455553911 475.37793002302607
+-40.527402413834629 128.23701781508848 478.98308155309326 -56.285342227751038 128.23973280221415 478.96543661960465 -72.045144247032709 128.24244778933985 478.94779168611598 -87.806808471679688 128.24516277646552 478.93014675262731
+-40.761835254206503 127.18538099758963 482.51647275348313 -56.433043971818861 127.20849659616202 482.40000800180712 -72.114489189495799 127.23179001980893 482.28301115120422 -87.806808471679588 127.25480677223288 482.16499985203262
+-40.70770276214904 125.64179000561398 485.84463959098696 -56.400055552278012 125.73336789864858 485.60341257140476 -72.100377884517883 125.82342877425855 485.36417197628117 -87.806808471680043 125.91392211109702 485.12881185937511
+-40.356665031807694 123.60132397424952 488.87890870272912 -56.190294845248559 123.81466906182352 488.53838682452408 -72.002618868225056 124.0245629752168 488.18790984954751 -87.806808471679176 124.22706388475075 487.82422676563885
+-39.659850961439524 121.16806698419215 491.39886333564607 -55.764031793996544 121.51821656788934 491.03551380773786 -71.812390912372436 121.85740333073954 490.67488838856224 -87.806808471680057 122.18942895009801 490.31897425549442
+-38.600669138128339 118.40132247662251 493.32817987217788 -55.114304465523567 118.85846848545154 493.06310106869245 -71.50165230512512 119.28988499396658 492.77357037382677 -87.806808471679588 119.69655740519025 492.46162178464283
+-37.215515892960688 115.54580528055598 494.60583020127854 -54.201284740908058 115.91759512307496 494.51932030800066 -71.065048933814396 116.28938496559398 494.43281041472272 -87.806808471679688 116.66117480811299 494.34630052144485
+-35.568095680464978 112.64804698697162 495.28009488539317 -52.980999944203198 112.64804698697159 495.28009488539317 -70.393904207941446 112.64804698697161 495.28009488539311 -87.806808471679688 112.64804698697161 495.28009488539317
+8 0 0 7 3 -35.568095680177201 112.64804701119002 495.28009499264584 -52.980999944011359 112.64804701119002 495.28009499264579 -70.393904207845523 112.64804701119 495.28009499264579 -87.806808471679673 112.64804701119 495.28009499264573
+-31.404150312257478 102.52030498666238 497.6366679311152 -50.190296356645632 102.47538714701838 497.64711963546375 -68.991182409786376 102.43046930737437 497.65757133981242 -87.806808471679673 102.38555146773037 497.66802304416103
+-27.886051806627044 92.066268688744842 499.65040637546912 -47.849917566124503 92.021848441263472 499.65704706587735 -67.823594479167298 91.977483320784728 499.66375413236915 -87.806808471679673 91.932970182812639 499.67025220486869
+-25.082860670677391 81.316632334211505 501.26610014175031 -45.995132365384272 81.309829314551422 501.26300471200307 -66.902926463292616 81.302873249280779 501.25970461521382 -87.806808471679673 81.296276061431755 501.25689377526669
+-22.999028001290661 70.368679364247072 502.40853460218671 -44.608843419124241 70.40666639979986 502.40226946140541 -66.211598651930061 70.444816537975626 502.39624365776444 -87.806808471679673 70.482617865293435 502.38976325855555
+-21.481166441887193 59.323739225861388 503.03182647252794 -43.59571155900538 59.384593462944899 503.02945254849874 -65.704217139819391 59.44537410912605 503.02694963255396 -87.806808471679673 59.506284292140137 503.02459311340306
+-20.32356487529162 48.246589412635942 503.10653832959105 -42.821732473814748 48.295948960116306 503.10877405529692 -65.316147005944089 48.345308507596627 503.11100978100285 -87.806808471679673 48.394668055076977 503.11324550670878
+-19.323704385339358 37.194229961897641 502.60592506636868 -42.151405747452806 37.194229961897662 502.60592506636863 -64.979107109566229 37.194229961897648 502.60592506636863 -87.806808471679673 37.194229961897655 502.60592506636863
+8 0 0 4 3 -39.397452398193927 129.14574677915778 471.03845732932473 -55.53390442268919 129.14574677915775 471.03845732932479 -71.670356447184446 129.14574677915775 471.03845732932479 -87.806808471679716 129.14574677915772 471.03845732932484
+-39.566722640578973 129.13424419522499 472.12798432163459 -55.649246859820501 129.13407491421586 472.14401865181753 -71.729275470187403 129.13390563320672 472.16005298200048 -87.806808471679716 129.13373635219756 472.17608731218348
+-39.721473822523471 129.07133678121539 473.21792289352874 -55.752410289322775 129.06963741873449 473.23729912978456 -71.780819514247398 129.06805283982447 473.25663530948287 -87.806808471679673 129.06630040048765 473.2759746721627
+-39.870137406189016 128.95713219910371 474.3029910801402 -55.850424485917976 128.95509586979117 474.31622542635915 -71.829314841081541 128.95305954047859 474.32945977257828 -87.806808471679716 128.95102321116599 474.34269411879728
+-40.021144853737212 128.79173811086466 475.377906916602 -55.949699393051354 128.79173811086471 475.37790691660183 -71.878253932365524 128.79173811086471 475.37790691660194 -87.806808471679716 128.79173811086469 475.37790691660183
+8 0 0 4 3 -38.370950400291015 127.93964850494571 451.20106442617521 -54.849569757420589 127.93964850494571 451.20106442617521 -71.328189114550142 127.93964850494571 451.20106442617521 -87.806808471679716 127.93964850494571 451.20106442617521
+-38.356157776164906 128.59089372857511 456.14251592591535 -54.839922090185034 128.59110765408269 456.1441391278704 -71.323472322023292 128.59132157959024 456.14576232982546 -87.806808471679716 128.59153550509782 456.14738553178051
+-38.423243595654313 129.01109458944777 461.11665005440176 -54.884032066724167 129.01031328662415 461.11318088445677 -71.345220424911261 129.00953152800327 461.10971172413548 -87.806808471679716 129.00874931360187 461.1062425734562
+-38.739759850992421 129.19784384377382 466.10381238421468 -55.093832613305054 129.19795306010974 466.09346739158696 -71.449515486867469 129.19806227644563 466.08312239895923 -87.806808471679702 129.19817149278151 466.07277740633151
+-39.397452398214767 129.1457467704075 471.03845732936662 -55.533904422703074 129.1457467704075 471.03845732936662 -71.670356447191381 129.14574677040747 471.03845732936662 -87.806808471679702 129.14574677040744 471.03845732936662
+8 0 0 4 3 -38.442757260272202 125.68180366153105 438.57205112812494 -54.897440997408026 125.68180366153103 438.57205112812488 -71.35212473454385 125.68180366153102 438.57205112812488 -87.806808471679673 125.68180366153101 438.57205112812483
+-38.460431416844095 126.392194592227 441.69592300551955 -54.909552941491313 126.39286985973281 441.6988924257077 -71.35834529310317 126.39354512723861 441.70186184589591 -87.806808471679673 126.39422039474441 441.70483126608406
+-38.424666048076759 127.00422243447639 444.84657340882222 -54.885858757306309 127.00501015484386 444.85086321224202 -71.346572964822201 127.00579755318485 444.85515305949463 -87.806808471679688 127.00658462950693 444.85944295053804
+-38.380397833878241 127.52000545261599 448.01693000072908 -54.856367552605782 127.52050458661432 448.02071728923511 -71.331837765206259 127.52100372061263 448.02450457774114 -87.806808471679688 127.52150285461094 448.02829186624717
+-38.370950386165184 127.93965552230544 451.20111679398542 -54.849569748003354 127.93965552230547 451.20111679398536 -71.328189109841517 127.93965552230547 451.20111679398536 -87.806808471679688 127.93965552230547 451.20111679398536
+8 0 0 8 3 -27.97156577868795 116.0331554894704 423.48473028757149 -47.916646676351867 116.03315548947042 423.48473028757149 -67.861727574015788 116.03315548947042 423.48473028757149 -87.806808471679702 116.03315548947043 423.48473028757149
+-30.05694981259122 117.57913133100853 424.54694879536265 -49.363645763282655 117.68125120619801 424.61711394188376 -68.613598649645482 117.78337108138749 424.68727908840486 -87.806808471679702 117.88549095657697 424.75744423492591
+-32.073220905452914 119.06461139277904 425.81676023551421 -50.735309426371984 119.2156029926029 425.95325452922373 -69.312191896218678 119.36486314670053 426.09113076150237 -87.806808471679716 119.51132277726764 426.23187681427311
+-33.947937084578676 120.49951637861221 427.31615272351837 -51.985879960238584 120.65472385170803 427.49992773657453 -69.937689891677564 120.80608195871906 427.68780818359767 -87.806808471679702 120.95721782677442 427.8748807693554
+-35.654661170034124 121.85539123947756 429.06941991354267 -53.107308038000518 121.98640965349861 429.26847710578704 -70.489100151136967 122.11647727110346 429.46805545877749 -87.806808471679688 122.24061040417105 429.67501500135376
+-37.066608783696736 123.13785339465556 431.09648418395869 -54.016928424832273 123.21446067030611 431.27498854480166 -70.930363751173914 123.28912731284737 431.45584499154586 -87.806808471679688 123.36533239671024 431.63421483385747
+-38.000290756379819 124.23900231328859 433.45822106002299 -54.616774512717015 124.26863777391358 433.55928546610295 -71.218783525845495 124.29854430085419 433.65992101995539 -87.806808471679688 124.32764032457196 433.7616325655834
+-38.425388369842892 125.09142976885845 435.97594196404935 -54.889324321358224 125.09853293457977 436.00717741298092 -71.349797688637153 125.1056361003011 436.03841286191238 -87.806808471679673 125.1127392660224 436.06964831084389
+-38.442757260272018 125.68180366298387 438.57205112776415 -54.897440997407919 125.68180366298388 438.57205112776415 -71.352124734543807 125.68180366298391 438.5720511277641 -87.806808471679673 125.68180366298391 438.5720511277641
+8 0 0 5 1 -16.606510994248268 106.93972034396965 420.34682837281952 -87.806808471679688 106.93972034396965 420.34682837281952
+-18.738408156836872 108.92909308502851 420.4381820900731 -87.806808471679688 108.92909308502851 420.4381820900731
+-21.0348405277464 110.81767455324831 420.82656237463061 -87.806808471679688 110.81767455324831 420.82656237463061
+-23.37788980764363 112.6301242247303 421.46332404163712 -87.806808471679688 112.6301242247303 421.46332404163712
+-25.721207449671255 114.36569527554879 422.33903563084675 -87.806808471679688 114.36569527554879 422.33903563084675
+-27.971618427495201 116.03319449982922 423.48475710136421 -87.806808471679688 116.03319449982922 423.48475710136421
+8 0 0 5 1 -270.49197115662895 -193.84990937058819 145.551029856838 -270.49197115662895 0 145.551029856838
+-271.02558562556226 -194.04699351326767 144.61729285660672 -271.02558562556226 0 144.61729285660672
+-271.5566244256525 -194.24277570467757 143.68190184134107 -271.5566244256525 0 143.68190184134107
+-272.0850681270411 -194.4372429843589 142.74486055323121 -272.0850681270411 0 142.74486055323121
+-272.6108972948428 -194.63038239007531 141.80617273828958 -272.6108972948428 0 141.80617273828958
+-273.13409248915667 -194.82218095784944 140.86584214689373 -273.13409248915667 0 140.86584214689373
+8 0 0 9 1 -273.13409248915633 -194.82218095784921 140.86584214689375 -273.13409248915633 0 140.86584214689375
+-285.2493475660101 -199.26352300438296 119.09128230012169 -285.2493475660101 0 119.09128230012169
+-296.09354029987423 -203.05785911199212 96.52349583539177 -296.09354029987423 0 96.52349583539177
+-305.49475470310466 -206.09210185932895 73.19949474775153 -305.49475470310466 0 73.19949474775153
+-313.24109198563792 -208.24130601273563 49.164299892548875 -313.24109198563792 0 49.164299892548875
+-319.05706525379736 -209.36476850345596 24.538321739078381 -319.05706525379736 0 24.538321739078381
+-322.64432543680834 -209.31092543701226 -0.53981765980208607 -322.64432543680834 0 -0.53981765980208607
+-323.62095023305426 -207.93018742008687 -25.716488820016988 -323.62095023305426 0 -25.716488820016988
+-321.8411622882212 -205.22024849027659 -50.546760922325404 -321.8411622882212 0 -50.546760922325404
+-317.32883271750728 -201.2824176360331 -74.639313893227083 -317.32883271750728 0 -74.639313893227083
+8 0 0 7 8 -91.741926937081303 -127.93047339795018 331.01155955044339 -119.23737068512601 -136.58213023278222 313.98630854953871 -145.30929585190469 -145.7730903052325 294.77885814566383 -170.00479376955252 -155.01842650217625 273.78035327995099 -193.35428490192953 -164.05267344281998 251.15775415633223 -215.25870174845909 -172.67163773521077 226.9819541209676 -235.61223966885962 -180.66691000393081 201.30600917941231 -254.15550383477762 -187.81622947588619 174.13714368405769 -270.49197116902383 -193.84990939061379 145.55102986806097
+-91.264563456402598 -130.07495801412153 331.3071442669376 -118.76611276544185 -138.6677929212475 314.32464500470684 -144.86794943636249 -147.80340113321316 295.14311901324629 -169.60295780942593 -157.00081631832853 274.15585993932137 -192.99624175353057 -165.99305585445788 251.53457062166856 -214.94818743765774 -174.57479370452035 227.35047468296898 -235.35122202062027 -182.53687098253567 201.65672489819721 -253.94486174210769 -189.65720416616227 174.45999703879698 -270.33023900545408 -195.66622501116339 145.83403453738239
+-91.08901740908783 -132.21944263373157 332.09015818056611 -118.61671647177161 -140.7534556095116 315.10604843141505 -144.75883408780453 -149.83372722030717 295.90746612873386 -169.53882657375584 -158.98318153581795 274.892733248757 -192.97931607450505 -167.9334412904368 252.23699089336347 -214.9805314897184 -176.47796958722026 228.01094679361262 -235.43379936466312 -184.40681964903845 202.26728981951896 -254.07838413335847 -191.49817910472188 175.01139076767754 -270.51343403112122 -197.48254093819833 146.3141591644771
+-91.253575214234516 -134.19184117171491 333.33684946708206 -118.82516568206952 -142.67990191609465 316.30446713037162 -145.01373017471948 -151.71713224340343 297.04529563743625 -169.83978737987806 -160.82908812343027 275.96503311003386 -193.32674118444842 -169.74651563974675 253.24027913601196 -215.37493806648945 -178.26185483658483 228.94034934176852 -235.87545019427563 -186.16449627133355 203.1167667630146 -254.56811932163239 -193.23298921046586 175.77279041477047 -271.05054274870753 -199.19784306933937 146.97565980056774
+-91.76039615848272 -135.81981473489364 334.96499596750925 -119.39060443127586 -144.28771291256436 317.84344489016343 -145.62832582255905 -153.30651758418773 298.4870018467883 -170.4983657947553 -162.40192305408362 277.30985212911838 -194.02812603223066 -171.30471849530082 254.48784028331195 -216.11834548259111 -179.80685859344601 230.08827546447429 -236.66069668420715 -187.69739610286058 204.1608253190104 -255.39637271282228 -194.75532876389147 176.70591887723202 -271.92184069742154 -200.71106089172426 147.78637302017083
+-92.566838119590926 -136.96639138381843 336.83761119206889 -120.26758628794616 -145.44844714320408 319.60033236620177 -146.55576777266512 -154.48175802136919 300.12422407205611 -171.46697829059045 -163.58896974479276 278.83149719316788 -195.03528438063111 -172.50189913212307 255.89539968982203 -217.16215952452629 -181.01269717374268 231.38091067159479 -237.74055836040364 -188.91041442045588 205.33525391784715 -256.51369470015283 -195.97454506406149 177.75552276368458 -273.0773246756707 -201.93535185518019 148.69977253843336
+-93.595359436491748 -137.56177220325623 338.79475376938251 -121.37610692975322 -146.09279399692579 321.43309529667812 -147.71641345528442 -155.17446295982404 301.83203767946083 -172.66722341803174 -164.32318756338088 280.41978183213223 -196.27108227045349 -173.27245353920188 257.36588717263783 -218.4306471717982 -181.81533962496917 232.73309019401046 -239.0406336343051 -189.74119893375118 206.56592809912598 -257.8467810382482 -196.8299628619599 178.85789243175699 -274.44446878384537 -202.81157160039407 149.66218594615032
+-94.753067378241553 -137.60264083471304 340.68475444739261 -122.62070021536412 -146.21136426856725 323.20659657171922 -149.01567114032426 -155.36991383287764 303.49085598143677 -174.00646150243324 -164.58597985984835 281.9686410715849 -197.64495274077692 -173.59480335021829 258.80544298939077 -219.83540295669525 -182.19092446148116 234.06204181277033 -240.47460187167709 -190.16416578881751 207.780389736719 -259.31107836669685 -197.2946957929318 179.95029046062803 -275.9400969571854 -203.31188626477876 150.62032631830698
+8 0 0 9 1 -273.13409248915633 194.82218095784921 140.86584214689375 -273.13409248915633 0 140.86584214689375
+-285.2493475660101 199.26352300438296 119.09128230012169 -285.2493475660101 0 119.09128230012169
+-296.09354029987423 203.05785911199212 96.52349583539177 -296.09354029987423 0 96.52349583539177
+-305.49475470310466 206.09210185932895 73.19949474775153 -305.49475470310466 0 73.19949474775153
+-313.24109198563792 208.24130601273563 49.164299892548875 -313.24109198563792 0 49.164299892548875
+-319.05706525379736 209.36476850345596 24.538321739078381 -319.05706525379736 0 24.538321739078381
+-322.64432543680834 209.31092543701226 -0.53981765980208607 -322.64432543680834 0 -0.53981765980208607
+-323.62095023305426 207.93018742008687 -25.716488820016988 -323.62095023305426 0 -25.716488820016988
+-321.8411622882212 205.22024849027659 -50.546760922325404 -321.8411622882212 0 -50.546760922325404
+-317.32883271750728 201.2824176360331 -74.639313893227083 -317.32883271750728 0 -74.639313893227083
+8 0 0 5 1 -270.49197115662895 193.84990937058819 145.551029856838 -270.49197115662895 0 145.551029856838
+-271.02558562556226 194.04699351326767 144.61729285660672 -271.02558562556226 0 144.61729285660672
+-271.5566244256525 194.24277570467757 143.68190184134107 -271.5566244256525 0 143.68190184134107
+-272.0850681270411 194.4372429843589 142.74486055323121 -272.0850681270411 0 142.74486055323121
+-272.6108972948428 194.63038239007531 141.80617273828958 -272.6108972948428 0 141.80617273828958
+-273.13409248915667 194.82218095784944 140.86584214689373 -273.13409248915667 0 140.86584214689373
+8 0 0 8 1 -91.741926937081303 -127.93047339795018 331.01155955044339 -91.741926937081303 0 331.01155955044339
+-119.23737068512601 -136.58213023278222 313.98630854953871 -119.23737068512601 0 313.98630854953871
+-145.30929585190469 -145.7730903052325 294.77885814566383 -145.30929585190469 0 294.77885814566383
+-170.00479376955252 -155.01842650217625 273.78035327995099 -170.00479376955252 0 273.78035327995099
+-193.35428490192953 -164.05267344281998 251.15775415633223 -193.35428490192953 0 251.15775415633223
+-215.25870174845909 -172.67163773521077 226.9819541209676 -215.25870174845909 0 226.9819541209676
+-235.61223966885962 -180.66691000393081 201.30600917941231 -235.61223966885962 0 201.30600917941231
+-254.15550383477762 -187.81622947588619 174.13714368405769 -254.15550383477762 0 174.13714368405769
+-270.49197116902383 -193.84990939061379 145.55102986806097 -270.49197116902383 0 145.55102986806097
+8 0 0 6 1 -77.897694258319675 -124.06131943852613 339.24594120204245 -77.897694258319675 0 339.24594120204245
+-80.235318351649198 -124.67125335161347 337.91236233863145 -80.235318351649198 0 337.91236233863145
+-82.563351364034901 -125.28263456767996 336.5613315531333 -82.563351364034901 0 336.5613315531333
+-84.880085390590764 -125.90412726530943 335.19411251546728 -84.880085390590764 0 335.19411251546728
+-87.183800503910362 -126.54510351362271 333.81205210564485 -87.183800503910362 0 333.81205210564485
+-89.472210694914267 -127.21630074138861 332.41697364931122 -89.472210694914267 0 332.41697364931122
+-91.74190981369739 -127.93047920613498 331.01157015328675 -91.74190981369739 0 331.01157015328675
+8 0 0 6 11 -7.3705776686861304 -88.316183198325675 374.73750698739832 -1.7837368076844244 -82.209328387678596 377.38053163661533 3.3152147470705478 -75.544745001581475 379.77548998561161 7.8055812183475259 -68.290481570208357 381.87125582990643 11.520316689468123 -60.478719585693504 383.59533793196982 14.38025128334127 -52.100549736668242 384.9153212096964 16.12304903704683 -43.483855314677136 385.71807667812004 17.266603419322529 -34.830392352875556 386.24464873956094 17.808757556441776 -26.110912108094844 386.49417041270607 18.001522808237727 -17.410625379038329 386.58290296598148 18.001352809715694 -8.7049494548246802 386.5828289401336 18.001352771883859 -4.6185277824406512e-14 386.58282892272018
+-6.2805766605641038 -89.5410706622161 375.25316505503281 -0.57164946102320902 -83.369666286862383 377.95088376684134 4.6577810798782506 -76.611396979393845 380.40405243410657 9.282315122044281 -69.225765489852051 382.56020279704973 13.124708897448759 -61.257677258162332 384.33968553045946 16.10544704363555 -52.663705110625997 385.71400332875436 17.885784483014433 -43.859247888310939 386.53174643470243 19.070000578755582 -35.062052489072322 387.07519526491285 19.619755338806474 -26.226014440517645 387.32834590983566 19.817760547148332 -17.450268579020477 387.41889359310659 19.817312887238927 -8.7049494603544524 387.41877065007191 19.817312855284491 -7.3034171303258219e-14 387.41877063540034
+-5.3421838320956558 -90.76595815786257 376.08929344691069 0.48112755265465856 -84.530004450844359 378.85988983904178 5.8334289540528337 -77.678059624636546 381.38928349034529 10.584657657208066 -70.161022385059795 383.62316566819993 14.547443722357299 -62.03665423897187 385.47567560407504 17.641686893059656 -53.226872332870975 386.92089794339466 19.453980021875473 -44.234619188793999 387.76675763539788 20.675581549506273 -35.293710857844736 388.33535787226742 21.230925345486849 -26.341133782702546 388.59629662178503 21.433461887573198 -17.489902731159024 388.69057554549073 21.432734506307799 -8.7049494658979736 388.69035258633329 21.432734480947484 -8.4816702272672018e-14 388.69035257282769
+-4.6133405973206907 -91.925746897658172 377.21851071676622 1.3069414272127386 -85.625055729634965 380.07574342074304 6.7635859885028164 -78.681261259105867 382.69442532096036 11.622144411604587 -71.037412791343456 385.01796391410005 15.685775964318132 -62.764097004256683 386.95572086078687 18.873270612100999 -53.749744428431974 388.48241507159111 20.704869167231845 -44.58383522598087 389.36660563691339 21.955642961664758 -35.508441402779475 389.96636637048704 22.512600356325965 -26.4480605170329 390.23840332187086 22.718059230146743 -17.526678993118569 390.33794716684207 22.717082297522374 -8.7049494710547464 390.33758222324377 22.717082279535816 -8.5429753549082224e-14 390.33758220933476
+-4.1387126734800566 -92.955075999422476 378.58476982782298 1.852797317316996 -86.589242456516033 381.53471700976002 7.3857756577591562 -79.557217119123337 384.24736400775146 12.32185857710083 -71.79583980428022 386.66354499262906 16.456104024441046 -63.387905070126813 388.68956818030358 19.705001666997195 -54.192159431659242 390.29863899818878 21.537749070991943 -44.880159190743903 391.22503318871185 22.805135232106817 -35.689436142958087 391.85783419495573 23.358304853431704 -26.538464096443576 392.14232843374447 23.564336450761093 -17.557729418737964 392.24783550494072 23.563170677126468 -8.7049494754322687 392.24730712211181 23.563170667128421 -8.2788290112212345e-14 392.2473071066712
+-3.93863435634294 -93.801071116212867 380.10933602664636 2.0939393976533878 -87.370253151011241 383.14846744557104 7.670202350437509 -80.255806022828239 385.94950421053289 12.648510388936238 -72.390639065599473 388.45066605675481 16.817805736179643 -63.868408767527534 390.55700590753406 20.090611940980342 -54.524500805540981 392.23824181627936 21.90534959842995 -45.103677423936894 393.20277212783253 23.175089384256481 -35.82439972506824 393.86541318002094 23.719024510578581 -26.606191147024859 394.16123224617382 23.923105365373548 -17.58094401170138 394.27231377443212 23.921828061415191 -8.7049494787233073 394.27162738707892 23.921828059631476 -8.3945003725993685e-14 394.27162736963703
+-4.0093281353064087 -94.430306724078321 381.70727835321185 2.033798836372581 -87.936170903057516 384.82325836858854 7.6199186604793319 -80.747622460596702 387.69801785418423 12.604874320602674 -72.79614772614002 390.26739483829419 16.773794624074526 -64.184452963200869 392.43692819433619 20.033695154516575 -54.731908657877554 394.17117940192077 21.814040850387773 -45.244631341684737 395.16351336034586 23.072829312979014 -35.907261581781206 395.84858060688765 23.603133808773649 -26.648251355167858 396.15260678341627 23.803079937879676 -17.595293234572164 396.26796243096373 23.801769915735996 -8.7049494807831778 396.26714627255018 23.801769921783176 -9.0436772653967904e-14 396.267146253296
+8 0 0 6 5 -7.3705776691107987 -88.31618319752782 374.73750698645989 -8.0020100576756423 -89.002130814898194 374.43878872901689 -8.6402172324954556 -89.680230795276813 374.13703399381274 -9.2849342459749504 -90.350556305486222 373.83233311886693 -9.9358952267790634 -91.013180290359273 373.5247768308692 -10.592833309239722 -91.668175629322079 373.21445625540161
+-6.2805766589555478 -89.541070664916475 375.25316505784951 -6.9249761616063203 -90.234406197363725 374.94808107649573 -7.5760811295768402 -90.919459410985141 374.64003909414441 -8.2336172053151824 -91.596315145122503 374.32913137820577 -8.8973094401535739 -92.265058085276891 374.01545044623549 -9.5668822484824698 -92.925772864993405 373.6990890750177
+-5.342183437971733 -90.765958875366678 376.08929426551452 -5.9986356299718642 -91.46668252916318 375.77605578233266 -6.6617250755740178 -92.158689185897103 375.45991390209639 -7.3311680507268795 -92.842075344422128 375.14096375287318 -8.0066805967334744 -93.516937426439014 374.8193005626855 -8.6879784984706525 -94.183371817515166 374.49501966629811
+-4.6133432857820109 -91.925745517978527 377.21851322360936 -5.279904477790061 -92.633835638981452 376.89581679560212 -5.9530459789905796 -93.332806784000795 376.57024033247859 -6.6325353948062276 -94.022748921781115 376.24191746581903 -7.3179606926769223 -94.703802571441372 375.91087723439125 -8.0090896336428639 -95.376057695025523 375.57725320001543
+-4.1387130685099063 -92.955075281453475 378.58476901006463 -4.8126115235942084 -93.670479817461398 378.25215098375935 -5.4930537063606808 -94.376428294963404 377.91663938626562 -6.179740198576364 -95.073035229786896 377.57833699662842 -6.8723718621214793 -95.760415218564873 377.23734647143971 -7.5706498617836493 -96.438682889737251 376.89377033880169
+-3.9386343576061011 -93.801071113689758 380.10933602350838 -4.6166105527948424 -94.523655043136429 379.76731426210193 -5.3011199001335996 -95.236536845864265 379.42234656792112 -5.9918577977825729 -95.939835214489065 379.07453946549572 -6.6885199755435973 -96.633668985086032 378.72399934834317 -7.3908025369769579 -97.318157080570458 378.37083246367075
+-4.0093281348429999 -94.430306724896084 381.70727835411492 -4.6881140672097468 -95.159755451881438 381.35728123715865 -5.3734483827265613 -95.879361456446262 381.00425081664952 -6.0650234139663901 -96.589243898034752 380.64829648427229 -6.7625317228970161 -97.289522108951928 380.28952757962287 -7.4656661573385028 -97.980315559149815 379.92805336761398
+8 0 0 12 1 -10.592833236353517 -91.66817574232924 373.21445633981972 -10.592833236353517 0 373.21445633981972
+-15.285575703057653 -96.347069627771646 370.99772609837277 -15.285575703057653 0 370.99772609837277
+-20.318674854527945 -100.5948555265075 368.62244144069115 -20.318674854527945 0 368.62244144069115
+-25.616884369370727 -104.42830574731289 366.11863751524407 -25.616884369370727 0 366.11863751524407
+-31.110578397597017 -107.85419734039846 363.49852657410258 -31.110578397597017 0 363.49852657410258
+-36.796987997190712 -110.8779917083708 360.77104474156391 -36.796987997190712 0 360.77104474156391
+-42.592860933889227 -113.50527415614201 357.94145655030241 -42.592860933889227 0 357.94145655030241
+-48.468587396053351 -115.76193976295055 355.02200263942979 -48.468587396053351 0 355.02200263942979
+-54.398597975204659 -117.72103923362781 352.02312154947026 -54.398597975204659 0 352.02312154947026
+-60.311906069096075 -119.46809153089103 348.94547248926062 -60.311906069096075 0 348.94547248926062
+-66.224966066929198 -121.04845931528966 345.79081896436526 -66.224966066929198 0 345.79081896436526
+-72.093343284370007 -122.55047809436093 342.55723483369781 -72.093343284370007 0 342.55723483369781
+-77.897694258123948 -124.06131943780454 339.24594120137806 -77.897694258123948 0 339.24594120137806
+8 0 0 7 8 -91.741926937081303 127.93047339795018 331.01155955044339 -119.23737068512601 136.58213023278222 313.98630854953871 -145.30929585190469 145.7730903052325 294.77885814566383 -170.00479376955252 155.01842650217625 273.78035327995099 -193.35428490192953 164.05267344281998 251.15775415633223 -215.25870174845909 172.67163773521077 226.9819541209676 -235.61223966885962 180.66691000393081 201.30600917941231 -254.15550383477762 187.81622947588619 174.13714368405769 -270.49197116902383 193.84990939061379 145.55102986806097
+-91.264563456402598 130.07495801412153 331.3071442669376 -118.76611276544185 138.6677929212475 314.32464500470684 -144.86794943636249 147.80340113321316 295.14311901324629 -169.60295780942593 157.00081631832853 274.15585993932137 -192.99624175353057 165.99305585445788 251.53457062166856 -214.94818743765774 174.57479370452035 227.35047468296898 -235.35122202062027 182.53687098253567 201.65672489819721 -253.94486174210769 189.65720416616227 174.45999703879698 -270.33023900545408 195.66622501116339 145.83403453738239
+-91.08901740908783 132.21944263373157 332.09015818056611 -118.61671647177161 140.7534556095116 315.10604843141505 -144.75883408780453 149.83372722030717 295.90746612873386 -169.53882657375584 158.98318153581795 274.892733248757 -192.97931607450505 167.9334412904368 252.23699089336347 -214.9805314897184 176.47796958722026 228.01094679361262 -235.43379936466312 184.40681964903845 202.26728981951896 -254.07838413335847 191.49817910472188 175.01139076767754 -270.51343403112122 197.48254093819833 146.3141591644771
+-91.253575214234516 134.19184117171491 333.33684946708206 -118.82516568206952 142.67990191609465 316.30446713037162 -145.01373017471948 151.71713224340343 297.04529563743625 -169.83978737987806 160.82908812343027 275.96503311003386 -193.32674118444842 169.74651563974675 253.24027913601196 -215.37493806648945 178.26185483658483 228.94034934176852 -235.87545019427563 186.16449627133355 203.1167667630146 -254.56811932163239 193.23298921046586 175.77279041477047 -271.05054274870753 199.19784306933937 146.97565980056774
+-91.76039615848272 135.81981473489364 334.96499596750925 -119.39060443127586 144.28771291256436 317.84344489016343 -145.62832582255905 153.30651758418773 298.4870018467883 -170.4983657947553 162.40192305408362 277.30985212911838 -194.02812603223066 171.30471849530082 254.48784028331195 -216.11834548259111 179.80685859344601 230.08827546447429 -236.66069668420715 187.69739610286058 204.1608253190104 -255.39637271282228 194.75532876389147 176.70591887723202 -271.92184069742154 200.71106089172426 147.78637302017083
+-92.566838119590926 136.96639138381843 336.83761119206889 -120.26758628794616 145.44844714320408 319.60033236620177 -146.55576777266512 154.48175802136919 300.12422407205611 -171.46697829059045 163.58896974479276 278.83149719316788 -195.03528438063111 172.50189913212307 255.89539968982203 -217.16215952452629 181.01269717374268 231.38091067159479 -237.74055836040364 188.91041442045588 205.33525391784715 -256.51369470015283 195.97454506406149 177.75552276368458 -273.0773246756707 201.93535185518019 148.69977253843336
+-93.595359436491748 137.56177220325623 338.79475376938251 -121.37610692975322 146.09279399692579 321.43309529667812 -147.71641345528442 155.17446295982404 301.83203767946083 -172.66722341803174 164.32318756338088 280.41978183213223 -196.27108227045349 173.27245353920188 257.36588717263783 -218.4306471717982 181.81533962496917 232.73309019401046 -239.0406336343051 189.74119893375118 206.56592809912598 -257.8467810382482 196.8299628619599 178.85789243175699 -274.44446878384537 202.81157160039407 149.66218594615032
+-94.753067378241553 137.60264083471304 340.68475444739261 -122.62070021536412 146.21136426856725 323.20659657171922 -149.01567114032426 155.36991383287764 303.49085598143677 -174.00646150243324 164.58597985984835 281.9686410715849 -197.64495274077692 173.59480335021829 258.80544298939077 -219.83540295669525 182.19092446148116 234.06204181277033 -240.47460187167709 190.16416578881751 207.780389736719 -259.31107836669685 197.2946957929318 179.95029046062803 -275.9400969571854 203.31188626477876 150.62032631830698
+8 0 0 5 1 -7.3705776691107987 -88.31618319752782 374.73750698645989 -7.3705776691107987 0 374.73750698645989
+-8.0020100576756423 -89.002130814898194 374.43878872901689 -8.0020100576756423 0 374.43878872901689
+-8.6402172324954556 -89.680230795276813 374.13703399381274 -8.6402172324954556 0 374.13703399381274
+-9.2849342459749504 -90.350556305486222 373.83233311886693 -9.2849342459749504 0 373.83233311886693
+-9.9358952267790634 -91.013180290359273 373.5247768308692 -9.9358952267790634 0 373.5247768308692
+-10.592833309239722 -91.668175629322079 373.21445625540161 -10.592833309239722 0 373.21445625540161
+8 0 0 11 1 -7.3705776686861304 -88.316183198325675 374.73750698739832 -7.3705776686861304 0 374.73750698739832
+-1.7837368076844244 -82.209328387678596 377.38053163661533 -1.7837368076844244 0 377.38053163661533
+3.3152147470705478 -75.544745001581475 379.77548998561161 3.3152147470705478 0 379.77548998561161
+7.8055812183475259 -68.290481570208357 381.87125582990643 7.8055812183475259 0 381.87125582990643
+11.520316689468123 -60.478719585693504 383.59533793196982 11.520316689468123 0 383.59533793196982
+14.38025128334127 -52.100549736668242 384.9153212096964 14.38025128334127 0 384.9153212096964
+16.12304903704683 -43.483855314677136 385.71807667812004 16.12304903704683 0 385.71807667812004
+17.266603419322529 -34.830392352875556 386.24464873956094 17.266603419322529 0 386.24464873956094
+17.808757556441776 -26.110912108094844 386.49417041270607 17.808757556441776 0 386.49417041270607
+18.001522808237727 -17.410625379038329 386.58290296598148 18.001522808237727 0 386.58290296598148
+18.001352809715694 -8.7049494548246802 386.5828289401336 18.001352809715694 0 386.5828289401336
+18.001352771883859 -4.6185277824406512e-14 386.58282892272018 18.001352771883859 0 386.58282892272018
+8 0 0 6 11 -7.3705776686861304 88.316183198325675 374.73750698739832 -1.7837368076844244 82.209328387678596 377.38053163661533 3.3152147470705478 75.544745001581475 379.77548998561161 7.8055812183475259 68.290481570208357 381.87125582990643 11.520316689468123 60.478719585693504 383.59533793196982 14.38025128334127 52.100549736668242 384.9153212096964 16.12304903704683 43.483855314677136 385.71807667812004 17.266603419322529 34.830392352875556 386.24464873956094 17.808757556441776 26.110912108094844 386.49417041270607 18.001522808237727 17.410625379038329 386.58290296598148 18.001352809715694 8.7049494548246802 386.5828289401336 18.001352771883859 4.6185277824406512e-14 386.58282892272018
+-6.2805766605641038 89.5410706622161 375.25316505503281 -0.57164946102320902 83.369666286862383 377.95088376684134 4.6577810798782506 76.611396979393845 380.40405243410657 9.282315122044281 69.225765489852051 382.56020279704973 13.124708897448759 61.257677258162332 384.33968553045946 16.10544704363555 52.663705110625997 385.71400332875436 17.885784483014433 43.859247888310939 386.53174643470243 19.070000578755582 35.062052489072322 387.07519526491285 19.619755338806474 26.226014440517645 387.32834590983566 19.817760547148332 17.450268579020477 387.41889359310659 19.817312887238927 8.7049494603544524 387.41877065007191 19.817312855284491 7.3034171303258219e-14 387.41877063540034
+-5.3421838320956558 90.76595815786257 376.08929344691069 0.48112755265465856 84.530004450844359 378.85988983904178 5.8334289540528337 77.678059624636546 381.38928349034529 10.584657657208066 70.161022385059795 383.62316566819993 14.547443722357299 62.03665423897187 385.47567560407504 17.641686893059656 53.226872332870975 386.92089794339466 19.453980021875473 44.234619188793999 387.76675763539788 20.675581549506273 35.293710857844736 388.33535787226742 21.230925345486849 26.341133782702546 388.59629662178503 21.433461887573198 17.489902731159024 388.69057554549073 21.432734506307799 8.7049494658979736 388.69035258633329 21.432734480947484 8.4816702272672018e-14 388.69035257282769
+-4.6133405973206907 91.925746897658172 377.21851071676622 1.3069414272127386 85.625055729634965 380.07574342074304 6.7635859885028164 78.681261259105867 382.69442532096036 11.622144411604587 71.037412791343456 385.01796391410005 15.685775964318132 62.764097004256683 386.95572086078687 18.873270612100999 53.749744428431974 388.48241507159111 20.704869167231845 44.58383522598087 389.36660563691339 21.955642961664758 35.508441402779475 389.96636637048704 22.512600356325965 26.4480605170329 390.23840332187086 22.718059230146743 17.526678993118569 390.33794716684207 22.717082297522374 8.7049494710547464 390.33758222324377 22.717082279535816 8.5429753549082224e-14 390.33758220933476
+-4.1387126734800566 92.955075999422476 378.58476982782298 1.852797317316996 86.589242456516033 381.53471700976002 7.3857756577591562 79.557217119123337 384.24736400775146 12.32185857710083 71.79583980428022 386.66354499262906 16.456104024441046 63.387905070126813 388.68956818030358 19.705001666997195 54.192159431659242 390.29863899818878 21.537749070991943 44.880159190743903 391.22503318871185 22.805135232106817 35.689436142958087 391.85783419495573 23.358304853431704 26.538464096443576 392.14232843374447 23.564336450761093 17.557729418737964 392.24783550494072 23.563170677126468 8.7049494754322687 392.24730712211181 23.563170667128421 8.2788290112212345e-14 392.2473071066712
+-3.93863435634294 93.801071116212867 380.10933602664636 2.0939393976533878 87.370253151011241 383.14846744557104 7.670202350437509 80.255806022828239 385.94950421053289 12.648510388936238 72.390639065599473 388.45066605675481 16.817805736179643 63.868408767527534 390.55700590753406 20.090611940980342 54.524500805540981 392.23824181627936 21.90534959842995 45.103677423936894 393.20277212783253 23.175089384256481 35.82439972506824 393.86541318002094 23.719024510578581 26.606191147024859 394.16123224617382 23.923105365373548 17.58094401170138 394.27231377443212 23.921828061415191 8.7049494787233073 394.27162738707892 23.921828059631476 8.3945003725993685e-14 394.27162736963703
+-4.0093281353064087 94.430306724078321 381.70727835321185 2.033798836372581 87.936170903057516 384.82325836858854 7.6199186604793319 80.747622460596702 387.69801785418423 12.604874320602674 72.79614772614002 390.26739483829419 16.773794624074526 64.184452963200869 392.43692819433619 20.033695154516575 54.731908657877554 394.17117940192077 21.814040850387773 45.244631341684737 395.16351336034586 23.072829312979014 35.907261581781206 395.84858060688765 23.603133808773649 26.648251355167858 396.15260678341627 23.803079937879676 17.595293234572164 396.26796243096373 23.801769915735996 8.7049494807831778 396.26714627255018 23.801769921783176 9.0436772653967904e-14 396.267146253296
+8 0 0 6 5 -7.3705776691107987 88.31618319752782 374.73750698645989 -8.0020100576756423 89.002130814898194 374.43878872901689 -8.6402172324954556 89.680230795276813 374.13703399381274 -9.2849342459749504 90.350556305486222 373.83233311886693 -9.9358952267790634 91.013180290359273 373.5247768308692 -10.592833309239722 91.668175629322079 373.21445625540161
+-6.2805766589555478 89.541070664916475 375.25316505784951 -6.9249761616063203 90.234406197363725 374.94808107649573 -7.5760811295768402 90.919459410985141 374.64003909414441 -8.2336172053151824 91.596315145122503 374.32913137820577 -8.8973094401535739 92.265058085276891 374.01545044623549 -9.5668822484824698 92.925772864993405 373.6990890750177
+-5.342183437971733 90.765958875366678 376.08929426551452 -5.9986356299718642 91.46668252916318 375.77605578233266 -6.6617250755740178 92.158689185897103 375.45991390209639 -7.3311680507268795 92.842075344422128 375.14096375287318 -8.0066805967334744 93.516937426439014 374.8193005626855 -8.6879784984706525 94.183371817515166 374.49501966629811
+-4.6133432857820109 91.925745517978527 377.21851322360936 -5.279904477790061 92.633835638981452 376.89581679560212 -5.9530459789905796 93.332806784000795 376.57024033247859 -6.6325353948062276 94.022748921781115 376.24191746581903 -7.3179606926769223 94.703802571441372 375.91087723439125 -8.0090896336428639 95.376057695025523 375.57725320001543
+-4.1387130685099063 92.955075281453475 378.58476901006463 -4.8126115235942084 93.670479817461398 378.25215098375935 -5.4930537063606808 94.376428294963404 377.91663938626562 -6.179740198576364 95.073035229786896 377.57833699662842 -6.8723718621214793 95.760415218564873 377.23734647143971 -7.5706498617836493 96.438682889737251 376.89377033880169
+-3.9386343576061011 93.801071113689758 380.10933602350838 -4.6166105527948424 94.523655043136429 379.76731426210193 -5.3011199001335996 95.236536845864265 379.42234656792112 -5.9918577977825729 95.939835214489065 379.07453946549572 -6.6885199755435973 96.633668985086032 378.72399934834317 -7.3908025369769579 97.318157080570458 378.37083246367075
+-4.0093281348429999 94.430306724896084 381.70727835411492 -4.6881140672097468 95.159755451881438 381.35728123715865 -5.3734483827265613 95.879361456446262 381.00425081664952 -6.0650234139663901 96.589243898034752 380.64829648427229 -6.7625317228970161 97.289522108951928 380.28952757962287 -7.4656661573385028 97.980315559149815 379.92805336761398
+8 0 0 1 1 -87.806808471680569 -10.89954452418435 422.59027478868802 -87.806808471678565 -20.143751091312502 508.01398359122697
+-87.806808471680696 -123.63985469393711 410.38997664826923 -87.806808471678679 -132.88406126106526 495.81368545080818
+8 0 0 8 1 -91.741926937081303 127.93047339795018 331.01155955044339 -91.741926937081303 0 331.01155955044339
+-119.23737068512601 136.58213023278222 313.98630854953871 -119.23737068512601 0 313.98630854953871
+-145.30929585190469 145.7730903052325 294.77885814566383 -145.30929585190469 0 294.77885814566383
+-170.00479376955252 155.01842650217625 273.78035327995099 -170.00479376955252 0 273.78035327995099
+-193.35428490192953 164.05267344281998 251.15775415633223 -193.35428490192953 0 251.15775415633223
+-215.25870174845909 172.67163773521077 226.9819541209676 -215.25870174845909 0 226.9819541209676
+-235.61223966885962 180.66691000393081 201.30600917941231 -235.61223966885962 0 201.30600917941231
+-254.15550383477762 187.81622947588619 174.13714368405769 -254.15550383477762 0 174.13714368405769
+-270.49197116902383 193.84990939061379 145.55102986806097 -270.49197116902383 0 145.55102986806097
+8 0 0 11 1 -7.3705776686861304 88.316183198325675 374.73750698739832 -7.3705776686861304 0 374.73750698739832
+-1.7837368076844244 82.209328387678596 377.38053163661533 -1.7837368076844244 0 377.38053163661533
+3.3152147470705478 75.544745001581475 379.77548998561161 3.3152147470705478 0 379.77548998561161
+7.8055812183475259 68.290481570208357 381.87125582990643 7.8055812183475259 0 381.87125582990643
+11.520316689468123 60.478719585693504 383.59533793196982 11.520316689468123 0 383.59533793196982
+14.38025128334127 52.100549736668242 384.9153212096964 14.38025128334127 0 384.9153212096964
+16.12304903704683 43.483855314677136 385.71807667812004 16.12304903704683 0 385.71807667812004
+17.266603419322529 34.830392352875556 386.24464873956094 17.266603419322529 0 386.24464873956094
+17.808757556441776 26.110912108094844 386.49417041270607 17.808757556441776 0 386.49417041270607
+18.001522808237727 17.410625379038329 386.58290296598148 18.001522808237727 0 386.58290296598148
+18.001352809715694 8.7049494548246802 386.5828289401336 18.001352809715694 0 386.5828289401336
+18.001352771883859 4.6185277824406512e-14 386.58282892272018 18.001352771883859 0 386.58282892272018
+8 0 0 5 1 -7.3705776691107987 88.31618319752782 374.73750698645989 -7.3705776691107987 0 374.73750698645989
+-8.0020100576756423 89.002130814898194 374.43878872901689 -8.0020100576756423 0 374.43878872901689
+-8.6402172324954556 89.680230795276813 374.13703399381274 -8.6402172324954556 0 374.13703399381274
+-9.2849342459749504 90.350556305486222 373.83233311886693 -9.2849342459749504 0 373.83233311886693
+-9.9358952267790634 91.013180290359273 373.5247768308692 -9.9358952267790634 0 373.5247768308692
+-10.592833309239722 91.668175629322079 373.21445625540161 -10.592833309239722 0 373.21445625540161
+8 0 0 6 1 -77.897694258319675 124.06131943852613 339.24594120204245 -77.897694258319675 0 339.24594120204245
+-80.235318351649198 124.67125335161347 337.91236233863145 -80.235318351649198 0 337.91236233863145
+-82.563351364034901 125.28263456767996 336.5613315531333 -82.563351364034901 0 336.5613315531333
+-84.880085390590764 125.90412726530943 335.19411251546728 -84.880085390590764 0 335.19411251546728
+-87.183800503910362 126.54510351362271 333.81205210564485 -87.183800503910362 0 333.81205210564485
+-89.472210694914267 127.21630074138861 332.41697364931122 -89.472210694914267 0 332.41697364931122
+-91.74190981369739 127.93047920613498 331.01157015328675 -91.74190981369739 0 331.01157015328675
+8 0 0 12 1 -10.592833236353517 91.66817574232924 373.21445633981972 -10.592833236353517 0 373.21445633981972
+-15.285575703057653 96.347069627771646 370.99772609837277 -15.285575703057653 0 370.99772609837277
+-20.318674854527945 100.5948555265075 368.62244144069115 -20.318674854527945 0 368.62244144069115
+-25.616884369370727 104.42830574731289 366.11863751524407 -25.616884369370727 0 366.11863751524407
+-31.110578397597017 107.85419734039846 363.49852657410258 -31.110578397597017 0 363.49852657410258
+-36.796987997190712 110.8779917083708 360.77104474156391 -36.796987997190712 0 360.77104474156391
+-42.592860933889227 113.50527415614201 357.94145655030241 -42.592860933889227 0 357.94145655030241
+-48.468587396053351 115.76193976295055 355.02200263942979 -48.468587396053351 0 355.02200263942979
+-54.398597975204659 117.72103923362781 352.02312154947026 -54.398597975204659 0 352.02312154947026
+-60.311906069096075 119.46809153089103 348.94547248926062 -60.311906069096075 0 348.94547248926062
+-66.224966066929198 121.04845931528966 345.79081896436526 -66.224966066929198 0 345.79081896436526
+-72.093343284370007 122.55047809436093 342.55723483369781 -72.093343284370007 0 342.55723483369781
+-77.897694258123948 124.06131943780454 339.24594120137806 -77.897694258123948 0 339.24594120137806
+8 0 0 1 1 -87.806808471680569 10.89954452418435 422.59027478868802 -87.806808471678565 20.143751091312502 508.01398359122697
+-87.806808471680696 123.63985469393711 410.38997664826923 -87.806808471678679 132.88406126106526 495.81368545080818
+8 0 0 9 5 -1357.2998046875 -184.19343141626581 452.17426057650368 -1285.496986635655 -197.62386275744996 436.37201798805296 -1213.6941685838101 -210.89152637766256 421.28730809105747 -1124.6200834825863 -141.57753137538003 413.81750790987098 -1057.951186931929 -170.47303057537053 422.39686819190024 -986.58004277728469 -192.48218206907438 425.13348464380817
+-1357.2998046875002 -184.95581682942503 440.6069623304524 -1285.8757123265382 -198.76662089194582 423.40713316323371 -1214.4516199655766 -212.49294018574503 406.72421521562387 -1124.0092503904036 -139.72304653136851 403.87290135479583 -1057.9395533156057 -168.72728927462569 411.31184198013705 -986.58056018226353 -190.81342640950481 413.74620330750253
+-1357.2998046875 -184.20965948514214 428.94023801541454 -1286.2929817843701 -198.24738845715834 410.19683754780431 -1215.2861588812409 -212.29435766801788 391.77933053695506 -1123.3807119265641 -137.68772364719791 394.09517362004084 -1057.9253968483356 -166.79408343193646 400.44097241589344 -986.58109860476782 -188.95549672575723 402.61311761858656
+-1357.2998046875 -181.94007573749803 417.39877933963572 -1286.7252574368888 -195.93472730800249 397.01265380593435 -1216.150710186278 -210.01685257664764 376.78332157739317 -1122.7525476090343 -135.52220024105159 384.56051683931935 -1057.9098307333593 -164.72526513374294 389.87440184371803 -986.5816367985725 -186.95977872774048 391.81571653839427
+-1357.2998046875 -178.1714737530508 406.21035096683613 -1287.1357387339476 -191.78230897195598 384.19955775304038 -1216.9716727803957 -205.50642796035388 362.20483297640976 -1122.1447904059896 -133.27327752092791 375.32932413631733 -1057.8937576213445 -162.56871997729661 379.69007954869318 -986.58215378988712 -184.87309679507817 381.42501230160258
+-1357.2998046875 -172.96778981351804 395.59673333232303 -1287.4880868537834 -185.89147147801242 372.11951803394373 -1217.6763690200673 -198.88183301566528 348.55715537823596 -1121.5780378622505 -130.98120484848258 366.4443816149859 -1057.8778395924564 -160.36593535439206 369.94988612084927 -986.58263034910794 -182.73603060301721 371.49709916405413
+-1357.2998046875 -166.43084112273939 385.76559407814432 -1287.7668889257636 -178.47848227825165 361.06304715317879 -1218.2339731640279 -190.50850310326635 336.21022465837228 -1121.0715717457711 -128.67820835717427 357.93122691085699 -1057.8625827085004 -158.15029170138141 360.69603125335493 -986.58305046257021 -180.58123174833656 362.06871215057987
+-1357.2998046875 -158.69679511791949 376.90328810728369 -1287.9827547608431 -169.81093683082483 351.21272638047662 -1218.6657048341867 -180.81217987764177 325.32408563860162 -1120.6392434194299 -126.38839501251907 349.80048339831848 -1057.8484386668977 -155.94562993112112 351.94713089203958 -986.58340280430036 -178.43174037525586 353.152785802822
+-1357.2998046875002 -149.93075528515118 369.16858625689707 -1288.1615858736086 -160.15418838986875 342.66735642125872 -1219.023367059717 -170.18614801573113 315.93080361076613 -1120.2852585085163 -124.12725368329728 342.04815140924239 -1057.8358260882567 -153.76464826250088 343.69336965380592 -986.58368220776822 -176.299301801344 344.7340129270566
+-1357.2998046875 -140.31946347921908 362.68733259059042 -1288.3392033724342 -149.74517052458046 335.46007510878678 -1219.3786020573682 -158.93938475260344 307.9718341714858 -1120.0058707994285 -121.89706507359359 334.64601007881811 -1057.8249739693033 -151.60668166320397 335.89015443148998 -986.58389113763894 -174.18268314342791 336.76440334201646
+8 0 0 10 5 -986.5842896583099 -163.33141935028576 300.0000000000004 -986.5842896583099 -179.2254357981802 348.58069255164395 -986.58432628967171 -190.02103625043833 397.60139478939027 -986.565089235816 -224.80182550085976 545.1531212872585 -986.58428955079091 -196.85346825527216 593.96894363342835 -986.58428955079114 -123.69451915376982 631.93215431363831
+-963.03329450250976 -170.84330264512693 300.0000000000004 -963.02068516034706 -186.5810697988712 348.63181221916523 -962.75162314083673 -197.15648666319026 397.08909512662001 -956.46429258174715 -234.84400279036061 548.96140686530816 -959.6460959815613 -203.488594444505 598.41040550991693 -959.10682413727864 -131.25749038524086 638.16166749039735
+-938.53964151576463 -177.64952605495995 300.00000000000011 -938.53459908806576 -193.24553114724856 348.67757035246387 -938.12463059870095 -203.60993265211508 396.73213807653997 -926.68326320001438 -243.83087555598036 550.21674754882417 -932.67550125721198 -209.3961540916095 601.13845999534863 -931.61322838294734 -138.05717490948308 642.48165467006493
+-913.24623445111263 -183.6305978982279 300.00000000000034 -913.26754463888824 -199.10238604781296 348.71717931821775 -912.80393277729831 -209.27627646658161 396.47381610054708 -897.06084743087342 -251.97015747069602 549.51601564413863 -905.73563224420741 -214.60611946024449 602.46281422033894 -904.22800562050236 -144.10162406507931 645.19839511477812
+-887.3071007202758 -188.69205894187016 300.00000000000063 -887.37130614593048 -204.0603261135484 348.74982862128593 -886.91614000137508 -214.06949676860287 396.28165066453374 -867.55608886758591 -259.33191681851036 547.18671338412253 -878.81972871500125 -219.13582119480577 602.63512908931796 -876.99980782022374 -149.38905273615964 646.5691369769296
+-860.87767236182333 -192.76923817777782 300.00000000000063 -860.99838082458677 -208.05679722059011 348.77501145513259 -860.59689412465855 -217.9300126713843 396.13494720411825 -838.20381916115332 -265.91054977689714 543.52348576377938 -851.89179250663972 -222.98226106626905 601.85795809063382 -849.93601784961663 -153.90289116201632 646.8112793888406
+-834.10488831384305 -195.82512551918342 300.0000000000004 -834.29238625051482 -211.05571050528579 348.79255905391693 -833.97732641704454 -220.82299899564055 396.01930342157641 -809.1081342012701 -271.6501149528284 538.79824822022579 -824.9200777560892 -226.12351309398352 600.29436363468346 -823.02246863029711 -157.6152768787905 646.10408617912515
+-807.11970681868183 -197.84438100385645 300.00000000000028 -807.38091298798702 -213.04183314979863 348.80251375465213 -807.17510043341338 -222.73292330136613 395.92433033562548 -780.39320580772187 -276.45983149576142 533.34545342339038 -797.89478873738335 -228.52769506990569 598.07093137062611 -796.23328200718777 -160.4947342921713 644.58536853739133
+-780.03461678731605 -198.82650009097699 300.00000000000034 -780.37330178757156 -214.01445660240114 348.80497167783579 -780.29142053707255 -223.65800006808294 395.84243132546908 -752.13012015153515 -280.26867096301714 527.43108186664756 -770.82880727367285 -230.16508373872821 595.27258357770836 -769.53581014509484 -162.51378938004729 642.34557394892852
+-752.94873695091235 -198.78115463855892 300.00000000000034 -753.36582477210925 -213.98293987860777 348.80002593495487 -753.41563501110795 -223.60668221192523 395.76807023076964 -724.37260944904506 -283.04074986430578 521.2293822298833 -743.74772714525022 -231.01603811432429 591.93327337270523 -742.89566226774173 -163.65226702405073 639.4217187210262
+-725.96309162713987 -197.72872914829489 300.00000000000034 -726.45675002995108 -212.96672558929555 348.78794127126775 -726.63931095121268 -222.59673494326083 395.6985453894722 -697.15330811834531 -284.76160633064814 514.81393844208492 -716.68292836261094 -231.06448663989332 588.03232212045441 -716.28679955432995 -163.89201846893476 635.79360142257349
+8 0 0 7 5 -1357.2998046875 -140.31946347921908 362.68733259059036 -1288.3392033724342 -149.74517052458046 335.46007510878678 -1219.3786020573682 -158.98223078947794 308.0007268572129 -1120.0058707994283 -121.89706507359358 334.64601007881816 -1057.8249739693031 -151.60668166320417 335.8901544314902 -986.58389113763735 -174.18268314342859 336.76440334201646
+-1357.2998046875 -133.29228932768999 357.94864614208791 -1288.4690661548582 -142.13474907835902 330.19056275140088 -1219.6383276222164 -150.76022767677586 302.22377749552828 -1119.8016000180182 -120.26649094603754 329.2340282897502 -1057.8170395801139 -150.02891174292324 330.18493255119802 -986.58404389406348 -172.63514424627724 330.93752433297351
+-1357.2998046875 -125.79654098115226 353.90482169034834 -1288.5579691609776 -134.05205044103656 325.74574533459764 -1219.8161336344554 -142.0724506194276 297.41615075048446 -1119.638682968874 -118.65307577946828 324.0161783231294 -1057.8100811200052 -148.46390046494503 324.72947552615108 -986.58415758272042 -171.09637528358112 325.35964365112909
+-1357.2998046875 -117.9146129265856 350.61162245930888 -1288.6076164721503 -125.61770172233588 322.17918368661964 -1219.9154282568009 -133.08462263887407 293.62525677245281 -1119.5154105377128 -117.05771734738703 318.97981398646891 -1057.8041826506767 -146.91129670632628 319.50400366359236 -986.58423329136713 -169.56583213292194 320.00958124142443
+-1357.2998046875 -109.73733300936307 348.11210111262369 -1288.6240662306707 -116.95841291666582 319.51882467895445 -1219.9483277738414 -123.96503672475883 290.8556174455602 -1119.4273235290686 -115.47664802012326 314.10394812171035 -1057.7994101488785 -145.36590579435369 314.47604461430939 -986.58427498061292 -168.03808488043248 314.85385316598689
+-1357.2998046875 -101.36118925086875 346.43575157463243 -1288.6173911551978 -108.19965145298107 317.76846890720628 -1219.9349776228955 -114.87071351601983 289.07511226131629 -1119.3665205754614 -113.89887986788177 309.35386432326686 -1057.7955575754302 -143.81623678957544 309.59689838884015 -986.58429000903732 -166.50221719454467 309.84508696963752
+-1357.2998046875 -92.885556666115363 345.59766085132873 -1288.6008422348059 -99.459177012225538 316.90981576347372 -1219.901879782112 -105.93733427339703 288.22197067561882 -1119.3267199344616 -112.30140905869288 304.67447636376011 -1057.7920130829179 -142.24337648569312 304.7998314668958 -986.58428965830979 -164.94122569973771 304.92043704539839
+-1357.2998046875 -84.409924081361893 345.59766085132878 -1288.5895156016559 -90.841436612359118 316.90508590023308 -1219.879226515812 -97.272949143356271 288.21251094913742 -1119.2974866873762 -110.65238789245011 299.99999999999795 -1057.7877453620681 -140.62019012631399 300.00000000000045 -986.58428965830979 -163.3314193502861 300
+8 0 0 8 4 -1867.4022216796877 -87.459081406549103 584.49059026755504 -1739.8766174316406 -111.64266890897827 551.41150784479214 -1612.3510131835938 -135.82625641140743 518.33242542202925 -1484.8254089355464 -160.00984391383662 485.25334299926652 -1357.2998046875 -184.19343141626584 452.17426057650368
+-1867.402221679688 -87.635825783937264 579.47489093032482 -1739.8766174316406 -111.95372391961236 544.76855733186346 -1612.3510131835933 -136.29557150185951 509.81413931893798 -1484.825408935546 -160.66136853067869 474.61163689154881 -1357.2998046875002 -185.05111500606995 439.16105004969597
+-1867.4022216796877 -86.66181110837816 574.41864087849615 -1739.8766174316406 -110.89497326989414 537.79046581879686 -1612.3510131835931 -135.19059940933977 500.84796832008414 -1484.8254089355455 -159.54868952671498 463.5911483823586 -1357.2998046875 -183.96924362201995 426.02000600561985
+-1867.402221679688 -84.526183170201534 569.62986378475205 -1739.8766174316404 -108.46877502810966 530.87579023375997 -1612.3510131835924 -132.51620658818749 491.86752004480007 -1484.8254089355455 -156.66847785043501 452.60505321787309 -1357.2998046875 -180.9255888148524 413.08838975297846
+-1867.4022216796875 -81.317002603368522 565.42004530019256 -1739.8766174316404 -104.76926235517797 524.42683870572512 -1612.3510131835924 -128.36189483437664 483.31044253561072 -1484.8254089355451 -152.09490004096449 442.07085678985015 -1357.2998046875 -175.96827797494166 400.70808146844314
+-1867.4022216796873 -77.22281112619396 562.06460080926308 -1739.8766174316406 -99.983840978884672 518.8154567531742 -1612.3510131835924 -122.90322999326035 475.58952888071582 -1484.8254089355451 -145.98097816932111 432.38681719188776 -1357.2998046875 -169.21708550706694 389.20732168668997
+-1867.4022216796873 -72.512213530314085 559.76165421118958 -1739.8766174316409 -94.376546854414698 514.34736593919058 -1612.3510131835928 -116.38897529166944 469.0626157427352 -1484.8254089355451 -138.54949884207838 423.90740362182322 -1357.2998046875 -160.85811750564147 378.88172957645463
+-1867.4022216796875 -67.493401079501766 558.61018091215271 -1739.8766174316411 -88.254777465009255 511.24188112175119 -1612.3510131835933 -109.11503054041022 464.01387486712281 -1484.8254089355462 -130.07416030570471 416.92616214826745 -1357.2998046875002 -151.13216676089272 369.9787429651854
+-1867.4022216796877 -62.474588628689446 558.61018091215283 -1739.8766174316406 -81.935807341321862 509.6294688317621 -1612.3510131835938 -101.39702605395428 460.64875675137159 -1484.8254089355469 -120.85824476658665 411.66804467098098 -1357.2998046875 -140.31946347921911 362.68733259059042
+8 0 0 6 5 -986.58041744691218 -191.24530150125463 417.03458331173488 -988.64692833184529 -190.85840640422077 418.54868391599689 -990.6971085708534 -190.46847715856407 420.07382907914734 -992.73334699156646 -190.0772671690475 421.60808438834664 -994.75775815442853 -189.6862050031817 423.14998484896569 -996.77216635302932 -189.29640386740138 424.6985221216429
+-985.69588136895641 -191.7256373103707 418.3686906405747 -987.75312952087927 -191.34127832509316 419.88519922949268 -989.79488133713028 -190.9528657394975 421.41260049243374 -991.82342607022656 -190.56219504717856 422.94895667635274 -993.84077679826157 -190.17074479009625 424.49279247528096 -995.84865596436782 -189.77968249441017 426.04308581660376
+-984.71509578914345 -191.88890543214589 419.75314384344944 -986.76151377223891 -191.50432375157115 421.27185770075505 -988.793587364102 -191.11489904120171 422.80125221318951 -990.81349490191519 -190.72245577226937 424.33938665308949 -992.82312798339183 -190.32850933431743 425.88477446806479 -994.82408219436252 -189.93426836704262 427.43637815076386
+-983.68250445595811 -191.71094868812483 421.12090454887061 -985.71739148290169 -191.32302143097985 422.64088915558318 -987.73933086729176 -190.92976432766983 424.17135040601045 -989.75037468305356 -190.53309068914558 425.71037181189212 -991.75229168145529 -190.13439124714591 427.2563949834099 -993.74652455064677 -189.73497243650985 428.80839145705266
+-982.65080668811504 -191.19422755163262 422.40046767522909 -984.67453841888153 -190.80001219662302 423.92005245179985 -986.68685818850133 -190.40031034487183 425.44999483396322 -988.6896995226839 -189.99696435544649 426.98834163112872 -990.68467113110387 -189.59151671696983 428.53357197327773 -992.67306544517783 -189.18520735139353 430.08460215915647
+-981.6726212988176 -190.37172337608439 423.5282742763261 -983.68661974615964 -189.96891341045253 425.04524224473937 -985.69076350142643 -189.560773306854 426.57260066195141 -987.68685691195856 -189.14913413893501 428.10838255288081 -989.67635937153557 -188.73552776843076 429.65103942614468 -991.66040374271574 -188.32118317582777 431.19945202843667
+-980.7921858788975 -189.29743652653511 424.45763435929939 -982.79864942049585 -188.88472830897834 425.96960572513052 -984.79672987615231 -188.46709778507895 427.4921902324765 -986.78810206977835 -188.04635153163179 429.02339863747881 -988.77407965217367 -187.62399623841367 430.56164528350348 -990.75564218545128 -187.20123482450515 432.10576511670246
+8 0 0 6 7 -996.77226793690636 -189.29639490612192 424.6984683660055 -1005.3132144252506 -187.64380087977094 431.26373206535555 -1013.684741613194 -186.0135821787255 437.93772638034852 -1021.9890612041816 -184.47384140631209 444.65510626968086 -1030.2718306752638 -183.05324928497242 451.40131671088022 -1038.5463383138642 -181.75375019801925 458.18458120378045 -1046.8090143818633 -180.55842558102282 465.02071163532452 -1055.0462684070008 -179.43451516282815 471.93073950569567
+-995.84876733389888 -189.77968832293547 426.04305221291241 -1004.3620812819697 -188.12177157944919 432.61582681569172 -1012.715215392577 -186.47160264982057 439.2945085598177 -1021.0059617893756 -184.90042898116261 446.01341702392324 -1029.2783457711321 -183.44002874603376 452.75750471229571 -1037.5447723291898 -182.09467952089491 459.53444742809432 -1045.8008763372304 -180.84900902327271 466.359531373332 -1054.0330764133366 -179.67172790762925 473.25333697562212
+-994.82420378957568 -189.93428284722197 427.43637249424648 -1003.3082195301292 -188.26289886237382 434.01478989897868 -1011.6457517296091 -186.58781663662509 440.6953035092867 -1019.9290300835804 -184.98273835245007 447.4118978448912 -1028.1990261602768 -183.48220170630142 454.14898331412263 -1036.4663606996287 -182.09261205385354 460.91373966500993 -1044.7251671593019 -180.8000118468583 467.72102782164342 -1052.9614686881696 -179.57449295023369 474.59117272332941
+-993.74666005054303 -189.7349888645125 428.80841559529932 -1002.2022449390374 -188.04169345985682 435.38862237373394 -1010.5284847521261 -186.33753279414535 442.06714207270056 -1018.8111333856567 -184.69778167714529 448.77745891179063 -1027.087017045638 -183.15911480835049 455.50325492798169 -1035.3640333857145 -181.72957212456677 462.25114079269486 -1043.6343079052456 -180.39635674027551 469.03560446222872 -1051.8830703348306 -179.13070236874125 475.87685280689232
+-992.67321689465894 -189.18521930694678 430.08465777328848 -1001.104141254577 -187.46263684570582 436.66085637103373 -1009.4247835348474 -185.72679686116984 443.33278828430241 -1017.7138662080825 -184.05357159463492 450.03310920499172 -1026.003304870306 -182.48091778686322 456.74436633964876 -1034.2977091300509 -181.0179027036761 463.47247060132707 -1042.58678365316 -179.65250318814972 470.23144888577627 -1050.8546722581946 -178.35676692747066 477.04145046045852
+-991.66057138090184 -188.32118344067322 431.19954001591901 -1000.0731463447777 -186.5644957030855 437.76474958596674 -1008.3947141566759 -184.79657831729068 444.42528974158859 -1016.6968234665665 -183.09294172507958 451.11250860468743 -1025.0061328220252 -181.49193013361173 457.80726645949704 -1033.3238647253183 -180.00306561916267 464.5145892648456 -1041.637017489765 -178.61467463424091 471.24784626771248 -1049.9284936774757 -177.29928359410761 478.02710987308427
+-990.75582897676838 -187.2012193948342 432.10588064175693 -999.15797985146537 -185.40879956017824 438.65299049687354 -1007.4871050055363 -183.61066762319862 445.29773365833148 -1015.80780960306 -181.88112126082299 451.96954749317661 -1024.1416935282377 -180.25816259880901 458.64710731111018 -1032.4866913870014 -178.75124996951024 465.33423120889807 -1040.8270869412215 -177.34872311589817 472.04347066855985 -1049.144476644806 -176.02328600584735 478.79472919085487
+8 0 0 14 1 -947.1241613153029 -245.57939292374706 764.42164171888908 -688.35266769269094 -400.32431937638376 440.61985338881095
+-934.06393987170122 -206.44600443851078 756.15707861443968 -675.29244624908927 -361.1909308911475 432.35529028436162
+-930.52830109491811 -165.88549314523021 739.59876731717065 -671.75680747230615 -320.63041959786693 415.79697898709253
+-937.80831580875281 -127.76637801083692 715.56369330123766 -679.03682218614085 -282.51130446347361 391.76190497115954
+-956.08229446322605 -96.123902770140518 685.83780048147696 -697.31080084061409 -250.86882922277721 362.03601215139889
+-984.23475399192534 -74.617674181380096 653.06147204497609 -725.46326036931339 -229.36260063401679 329.25968371489802
+-1019.8660835385303 -65.960725516729099 620.44895527843664 -761.09458991591828 -220.70565196936579 296.64716694835852
+-1059.531775307345 -71.436215704616998 591.36620676509654 -800.76028168473294 -226.18114215725367 267.56441843501835
+-1099.1974670761597 -90.625868062652955 568.83745854719564 -840.4259734535475 -245.37079451528962 245.03567021711746
+-1134.8287966227647 -121.43928956761269 555.08783800014373 -876.05730300015239 -276.18421602024932 231.28604967006561
+-1162.9812561514639 -160.4514381675715 551.23325170533496 -904.20976252885157 -315.19636462020816 227.4314633752569
+-1181.2552348059371 -203.45714113213478 557.18173519390064 -922.48374118332481 -358.20206758477144 233.3799468638226
+-1188.5352495197717 -246.10315577705995 571.74432962227559 -929.7637558971594 -400.84808222969662 247.94254129219752
+-1184.9996107429886 -284.46511636993864 592.90308026734033 -926.22811712037628 -439.2100428225753 269.10129193726226
+-1171.9393892993869 -315.47732483226577 618.16110916773164 -913.16789567677461 -470.22225128490243 294.35932083765357
+8 0 0 6 8 -980.79218590463609 -189.29743651965578 424.45763442256685 -966.7706838287786 -192.18150747722009 413.89175862417375 -952.37633158699896 -194.84572666441844 403.8005575660157 -937.57501781668896 -197.30644877135057 394.28912284700363 -922.32259483518646 -199.56490329165723 385.49978455570186 -906.54613848383235 -201.64200461550232 377.67021730789156 -890.25674511454247 -203.58764725353691 371.064485023891 -873.39670730411865 -205.50764988704108 366.16992597022181 -856.35179034834937 -207.57772114127013 363.77344702748474
+-981.67262127946049 -190.37172335815933 423.52827439040476 -967.59846442922924 -193.18662678876129 412.9274804405502 -953.14363483837565 -195.77452715339362 402.80593968990803 -938.27169533554888 -198.15299505854563 393.2686798605144 -922.93812332081973 -200.32520293382495 384.45954594129631 -907.06785310012879 -202.31271891118288 376.61810391975274 -890.67123934094332 -204.16703902618835 370.01350527098816 -873.68834568313321 -205.99915082515432 365.13732655740768 -856.50625560578681 -207.99416733485916 362.78084304586577
+-982.650805038199 -191.19422700217584 422.40046987616677 -968.50862969233106 -193.94907187627342 411.78138911958411 -953.97757816488411 -196.47201617950651 401.64752207362119 -939.01936683449105 -198.78167384485954 392.10335959125939 -923.58983113946363 -200.88281871501815 383.29354561647085 -907.61190221815843 -202.79746478988906 375.45925263225996 -891.09580607871692 -204.57889705034523 368.8744170607855 -873.98002505808131 -206.34231781471689 364.03380561044997 -856.65276353019192 -208.28040962989118 361.73237385655551
+-983.68250446108743 -191.71095216541224 421.12090550934499 -969.46238212053061 -194.42173277522397 410.49898047139197 -954.84509136191798 -196.89816878529689 400.36883237553184 -939.79083716388391 -199.15940121920141 390.83403679074945 -924.25630427056751 -201.21106383869233 382.03944833265865 -908.16232023634745 -203.0753724129344 374.22757807211985 -891.51949013743308 -204.80733237741731 367.67688046339987 -874.26502076319912 -206.52525506658685 362.88462758999395 -856.78802122124659 -208.4275310307417 360.64916131707071
+-984.71509746784398 -191.88890600887743 419.75314175988251 -970.41439192293706 -194.57643191748241 409.14013611730502 -955.70832049578996 -197.02960647004426 399.02527470049296 -940.55571133291994 -199.26738812032085 389.51108562323952 -924.91406393778209 -201.29530291581847 380.74227399138584 -908.70215987836832 -203.13546096731551 372.96253921460794 -891.93098147351668 -204.84436336403692 366.45458234220223 -874.53666655833877 -206.54225684959459 361.71792349938494 -856.9090371092027 -208.43144302480604 359.55434233321398
+-985.69588141791075 -191.72563732719965 418.36869063633554 -971.31949182580502 -194.41160544004811 407.77109446972804 -956.52977268788027 -196.86551514781885 397.67714632548763 -941.28407900409934 -199.10541909722664 388.18848462914639 -925.54021743094233 -201.13579985243175 379.44960168316493 -909.21506178931713 -202.97835429526347 371.70531259562637 -892.31955361859673 -204.69082761710925 365.24231857984319 -874.78883884702441 -206.39423671135933 360.56251039344158 -857.01331093913484 -208.29299754865204 358.47145421080199
+-986.58041745194168 -191.24530150433361 417.03458335737452 -972.13929821371096 -193.94899028140878 406.45381176038433 -957.27731102775647 -196.42497084994415 396.3808184464641 -941.95002993104265 -198.68987348993929 386.91671828105723 -926.11496493506502 -200.74639102379871 378.20604094075117 -909.6867252722916 -202.61555664645311 370.4945679763963 -892.67594755370817 -204.3560737472211 364.07288807403677 -875.01641511818718 -206.0886638575108 359.44564088410812 -857.09902375519357 -208.01809895417273 357.42282000739374
+8 0 0 5 8 -856.35179034834869 -207.57772114127016 363.77344702748479 -847.82933187046399 -208.61275676838463 362.5752075561162 -839.26033433089663 -209.68500272377526 362.0005061707231 -830.69258250626945 -210.81654527333814 362.14856470896069 -822.20466190618902 -212.03249469785308 363.1284923920428 -813.90420439345212 -213.35921764866552 365.06637207171082 -805.99736522736396 -214.82938669436578 368.08259142975191 -798.71203258547416 -216.4414046699153 372.15452624169706 -792.21411668895166 -218.16627834130929 377.18611263472445
+-856.53714865727363 -208.077456573577 362.58232224954196 -847.9323863064426 -209.06745935397697 361.40808003689051 -839.27686446171879 -210.09857216474981 360.86377218817341 -830.61838178240578 -211.19419598678732 361.04939305010515 -822.0367287419017 -212.38141595679656 362.07428135922169 -813.63987516503005 -213.68877809592183 364.06452390935459 -805.6372530988474 -215.15095431944673 367.14093891903377 -798.25978435493255 -216.7676532579388 371.27922244453191 -791.67606939797292 -218.50937858499361 376.38281001206502
+-856.71057096665015 -208.38188615804836 361.30739966006229 -848.01750599614854 -209.34045362922907 360.16844695096722 -839.27022551957577 -210.34360784512774 359.66501179498727 -830.51650063870079 -211.41575622174707 359.89774518482392 -821.83722873402508 -212.58542480789779 360.97604226564948 -813.34045698860598 -213.88277863703394 363.02593497893201 -805.23847992415699 -215.34407330604293 366.1688005980821 -797.76480857012723 -216.97019523026495 370.3789457357168 -791.09049749017311 -218.7314194519665 375.55963323954393
+-856.8654714758419 -208.47317590343519 359.99092297407913 -848.08153819320705 -209.41690903848905 358.89441291040714 -839.24029491050283 -210.40776569299126 358.43832401175865 -830.38943928268918 -211.4708603138638 358.72393034134348 -821.61092703514009 -212.63562359723656 359.86067510688105 -813.01254470894946 -213.93325160075986 361.97452061051087 -804.80939642761143 -215.40135001556709 365.18762317600959 -797.2371482817689 -217.04176718240868 369.47308651252553 -790.46919290662515 -218.82485323799236 374.7341971776342
+-856.99616837592248 -208.34797726754798 358.68118105148363 -848.12259076748808 -209.29429026025741 357.6288294295714 -839.18843993252858 -210.28911202863375 357.22149707317885 -830.24133878212808 -211.35795867669387 357.56111742960314 -821.36418616870469 -212.53070312159073 358.75726055143804 -812.66456585664525 -213.83893980912023 360.93597200135156 -804.36016880653187 -215.32142254124327 364.22023973123362 -796.68877938833668 -216.98074235716575 368.58214264834277 -789.82606972547558 -218.78758749914803 373.92498741645409
+-857.099023755193 -208.01809895417281 357.42282000739363 -848.1403280736962 -208.98281650250379 356.41140956903661 -839.11720814567218 -209.99644285058272 356.04962917836713 -830.07721407596011 -211.08461202013891 356.44015854961935 -821.10415131088689 -212.27710989752867 357.69291505378845 -812.30543596296673 -213.60544310844045 359.93418099573501 -803.90142279969382 -215.1091429122925 363.28787158546652 -796.13207341203565 -216.79133973181743 367.72509568212081 -789.1754002733644 -218.62325031107309 373.14901685632299
+8 0 0 5 7 -792.214116688952 -218.16627834130932 377.18611263472462 -784.78792709292634 -220.13756253718822 382.93649708389887 -778.41257121774902 -222.25902171818464 389.9655361803828 -773.35776418584032 -224.48385676033297 398.12215060291089 -769.79178934189042 -226.70375695789511 407.07029722219198 -767.63139198970657 -228.75498303676753 416.48758223626584 -766.73046356032535 -230.53807867208135 426.15741255619486 -766.91669454458099 -231.98663959364245 435.92481540532009
+-791.67606939797338 -218.50937858499367 376.38281001206502 -784.15182373287666 -220.4999218159135 382.21548151781712 -777.68679848956322 -222.65695985428849 389.33416350577056 -772.55521438106973 -224.93314201983543 397.58651119510068 -768.92781844033391 -227.21787728399582 406.63415069217092 -766.72134810858245 -229.34290733427298 416.15300263899707 -765.78813986359694 -231.20601720985317 425.92419284797597 -765.95416076865695 -232.73755104712606 435.79194152435855
+-791.09049749017345 -218.73141945196656 375.55963323954393 -783.46271339879718 -220.74424713391119 381.48041895820353 -776.90154229633617 -222.93705565938981 388.69400845024524 -771.68527605191093 -225.26230455587802 397.04731962971584 -767.98692551173338 -227.60768508664327 406.20007061739847 -765.72301124552655 -229.8007397555298 415.82681363864924 -764.744115974897 -231.73658556465688 425.70659934111768 -764.87457711206855 -233.34264701861497 435.68292477208138
+-790.46919290662538 -218.82485323799236 374.73419717763409 -782.73438676360399 -220.86266587294512 380.74689508061545 -776.07267291762287 -223.09055423472878 388.05901193962211 -770.76619404168355 -225.46113134806916 396.5170087497745 -766.98981358960953 -227.86091202686012 405.77903059099975 -764.66004354413144 -230.11335793630471 415.51816714910416 -763.62523242666964 -232.11089072484828 425.51158760047025 -763.70815398187551 -233.77826937605604 435.60195072175918
+-789.8260697254758 -218.78758749914803 373.92498741645392 -781.9829729679202 -220.85255337569919 380.03109572286684 -775.21871296073311 -223.11403005160031 387.44350144445741 -769.81915796163321 -225.52511120123691 396.00825252462147 -765.96108510874774 -227.97142929272394 405.38185432909819 -763.5607227440895 -230.272624639795 415.23580059060902 -762.46417991465171 -232.31813366840495 425.34522473504205 -762.49264318049018 -234.03031900846722 435.551640134477
+-789.17540027336474 -218.62325031107312 373.14901685632265 -781.22491668631187 -220.71686240165099 379.34778391255361 -774.35849339660285 -223.0098198555651 386.86036106739135 -768.86580896812359 -225.45590057837197 395.53217643259683 -764.92559022078376 -227.94019166464093 405.01776355858181 -762.45377921246643 -230.27855973771921 414.98667288141718 -761.29423450626211 -232.35732345337331 425.21164475188459 -761.26658656866266 -234.09677723799669 435.53258027578164
+8 0 0 6 9 -766.91669454458088 -231.9866395936422 435.92481540532015 -767.20638718675639 -234.23995658273728 451.11855317062611 -770.03335145627454 -235.71280962137851 466.54105540329493 -774.83192497018536 -236.18721871468401 481.67965706144196 -780.93928328467814 -235.6242711539669 496.34742183236796 -788.02457277003805 -234.10443426669627 510.55775365366515 -795.83117813022159 -231.62191912752874 524.25200219404826 -804.21100671202191 -228.18978863620615 537.41684644177292 -813.0507976748579 -223.78312233824087 549.95734912758576 -822.27918963051559 -218.41848119959877 561.76339605587032
+-766.11458306464431 -232.61239913821191 435.81408717118563 -766.37807745601071 -234.97327361063711 451.13790286071401 -769.20230274432186 -236.55972017459075 466.6885061267277 -774.01661327190743 -237.14502537746458 481.95032547422733 -780.15268356740467 -236.68546692361429 496.7373609992473 -787.27367588179754 -235.25851526915801 511.06618332001648 -795.12419122875644 -232.85624269703311 524.88211944348416 -803.55169267100837 -229.48887759624336 538.17566747782985 -812.44452936162781 -225.12629358002076 550.855440930692 -821.72952651860851 -219.7788807270727 562.80848004492259
+-765.23443833093143 -233.14094836145182 435.71926368950727 -765.45581627580725 -235.60062222932774 451.18169307974205 -768.25832027715705 -237.29004773818639 466.87049019089881 -773.06649919179313 -237.97441419998248 482.26736982782728 -779.20699754707721 -237.60572234700001 497.18706438155931 -786.33780963659535 -236.25860904964875 511.64883561849342 -794.20531880113765 -233.92280822066812 525.60142261144654 -802.65276881509237 -230.60514856207186 539.03859271998931 -811.57065804213653 -226.26952958380085 551.87184298565535 -820.88558496026963 -220.92015770783462 563.98402276405523
+-764.2913655469722 -233.56045819733535 435.64243774692045 -764.45733637788942 -236.10648117653528 451.24985946607836 -767.22199953206245 -237.88341494154645 467.08411665535061 -772.00506523843569 -238.64889418682026 482.62413654333602 -778.12873509544477 -238.35105229144509 497.68500336422443 -785.24560670460517 -237.06226141138882 512.28795759434831 -793.10530254487765 -234.76976734900336 526.3844780705831 -801.54623155422053 -231.47693797581218 539.97064428246722 -810.46167020824191 -227.14154969159807 552.95962249122124 -819.77941901443626 -221.76288536577781 565.22903672933069
+-763.30298371474737 -233.86228592019296 435.58518052599862 -763.40373516909938 -236.47921914221857 451.3414761922275 -766.11849381080674 -238.32428707880129 467.32514069549865 -770.86210287002041 -239.14800404358257 483.01191486566415 -776.95247622182114 -238.89513286196697 498.21657170992489 -784.03719856466921 -237.63634625067075 512.96140140640603 -791.86943066674803 -235.35689062145667 527.19971960364899 -800.2829100755871 -232.05676068857514 540.92864415684744 -809.17377514585689 -227.68842912550494 554.06124336036783 -818.47206886691288 -222.24872406128443 566.46945969374758
+-762.28830041185267 -234.04139538005535 435.54846349136125 -762.3180292541175 -236.71186439466814 451.45480007089839 -764.97563663447875 -238.60327232994734 467.58821609300833 -769.67116489018474 -239.45947957537916 483.42053694885448 -775.71806518746621 -239.22258546562242 498.76528332642755 -782.75997944148389 -237.9622637619309 513.64474667686022 -790.55281789831531 -235.6628942884833 528.01305961363107 -798.92662643160418 -232.32146642535261 541.86699772718737 -807.78006156176968 -227.88700828317445 555.1176582544133 -817.04586087053997 -222.35709456536472 567.63171515824263
+-761.26658656866323 -234.0967772379966 435.53258027578187 -761.22357866573088 -236.80259423629971 451.58736886851051 -763.8217255510483 -238.71770673456365 467.86728327544057 -768.46631588989987 -239.57995528001817 483.83924696455517 -774.46651587011775 -239.32961788722261 499.31442911889002 -781.46219045710802 -238.03677237043991 514.31413619678494 -789.21222013860017 -235.68604604510111 528.79243992823126 -797.54313150613734 -232.27255440492252 542.74455572908607 -806.3559983327907 -227.74430775105702 556.07817913076053 -815.58600837106655 -222.10287155577728 568.65602872782529
+8 0 0 6 10 -822.27918963051525 -218.41848119959903 561.76339605587066 -830.58474239060718 -213.59030417482111 572.38883829132669 -839.20120428389282 -207.99543264623628 582.42686696399778 -848.07631243023013 -201.64392039841258 591.79337857390419 -857.18437917298593 -194.56698025336294 600.40419098360337 -866.5045417929324 -186.82548199309338 608.13300752521968 -876.03698412798201 -178.57743916937434 614.90817178463431 -885.80392377207397 -170.02685943455339 620.74789371851762 -895.83632990717592 -161.34338909311435 625.71166156958725 -906.16478659258235 -152.67380035295724 629.83650636352866 -916.81364449549096 -144.16254924802371 633.13065659741983
+-821.7295265186084 -219.77888072707293 562.80848004492293 -830.08602395989089 -214.96620915941963 573.56621524773038 -838.75637917800782 -209.36535848889278 583.74281571698407 -847.68735876763446 -202.98271062155513 593.25191285864071 -856.85225363872689 -195.84524748616838 602.0056489826278 -866.22767908868855 -188.010060774735 609.86629715491222 -875.80795202945831 -179.64219407877388 616.74617281108863 -885.61188794820475 -170.95863102798401 622.65619908495012 -895.6734108877647 -162.13704027587548 627.66031586443864 -906.02699895770263 -153.32666737163487 631.79675860736393 -916.70169562890658 -144.67552470894077 635.07807693032294
+-820.88558496026963 -220.92015770783485 563.98402276405568 -829.26901918658928 -216.10572301946522 574.88498456461548 -837.9702759723009 -210.47995433591973 585.20945596332444 -846.93637071026046 -204.04551112284804 594.86795086104303 -856.14071727465353 -196.825543204979 603.76783991225079 -865.56031454342883 -188.87413101154078 611.75849083152309 -875.18665960046417 -180.36615164432163 618.73486696955069 -885.03599427278141 -171.53439741491871 624.70106382990525 -895.14356281465643 -162.56547922214887 629.72769569106606 -905.54586106804413 -153.61173958615427 633.85563562498226 -916.27439130738901 -144.82407932243413 637.10336196363448
+-819.77941901443648 -221.76288536577806 565.22903672933126 -828.16539294001132 -216.9220874725398 576.27150954362969 -836.8734304962129 -211.24629716978072 586.7388082980018 -845.85193418261838 -204.73524084334423 596.53766520171291 -855.07555488541914 -197.40968877732661 605.57047152120367 -864.52465941858304 -189.32265225263171 613.67271979048428 -874.19147315270538 -180.66291706547199 620.72563175397931 -884.09158977204208 -171.6790494769003 626.72791753829642 -894.25952057665529 -162.56623722373871 631.75898732941278 -904.73177691669025 -153.47934586366725 635.86280730580086 -915.53985932403964 -144.57061991889765 639.06407835969753
+-818.47206886691333 -222.24872406128469 566.46945969374826 -826.84053321586362 -217.35298950348621 577.63685439378992 -835.53514482828041 -211.59971441981037 588.22531232818915 -844.50646692445218 -204.98742216212153 598.13761667462279 -853.73131570292117 -197.53624183982879 607.27127591164583 -863.19523766892064 -189.30286665142188 615.4501988380631 -872.89477218134994 -180.49157916318529 622.54738563779631 -882.84652613370065 -171.36565301338834 628.56237504737351 -893.08314260521615 -162.12532438094755 633.58230282820773 -903.63949449152744 -152.92700367640111 637.65411209225408 -914.54515806937604 -143.92219684744322 640.80715168689062
+-817.04586087054054 -222.35709456536495 567.63171515824331 -825.38508024843372 -217.38017221933615 578.89436637168956 -834.05436203389172 -211.52634563823406 589.56836336950664 -843.00669905550399 -204.79522427943019 599.55304365715392 -852.22148215518018 -197.2079701425472 608.74166312291618 -861.68976207630431 -188.83093387274843 616.9516664438986 -871.41443646591404 -179.88192575056257 624.05464306081967 -881.41391115266617 -170.63613189476951 630.05912808687333 -891.71929262275455 -161.29371263472021 635.05652679521563 -902.36316130895636 -152.01172118589747 639.09607303597465 -913.37245293365754 -142.93915648756271 642.20887606708777
+-815.58600837106735 -222.10287155577748 568.65602872782586 -823.89301740551548 -217.0255789800257 579.97609336518394 -832.53386996753636 -211.05707778781556 590.69218493830931 -841.46381355657695 -204.20022437257893 600.70119441711267 -850.66444909334587 -196.47943463174786 609.89423043302293 -860.13201475941798 -187.97357553609439 618.0863605434289 -869.87511482248181 -178.91286995797381 625.15861823976411 -879.91493895210817 -169.57641224229226 631.13151563681947 -890.28180202776014 -160.16164962992968 636.09909955386593 -901.00653016296519 -150.82477068363838 640.11101044015777 -912.1138256171829 -141.71135632112427 643.19704930835417
+8 0 0 6 6 -951.86543925308661 -118.58657615609889 639.53852627889682 -945.76510876377483 -122.54417490935337 639.17252061453723 -939.76813383074091 -126.66796802055839 638.51076244506112 -933.8771247437669 -130.92147079249864 637.56338933130689 -928.09044910795637 -135.27259409172851 636.34218185291638 -922.40438797347338 -139.69404768670682 634.86000657055899 -916.8136519798685 -144.16252437094656 633.13057047999075
+-951.87347687225292 -118.66032210626427 641.39252247562342 -945.7457785649533 -122.68884530007823 641.05143286805242 -939.72475588689633 -126.8853790916762 640.41072467136917 -933.81275543629181 -131.21269225710793 639.48056347336808 -928.00784681132427 -135.63803975345482 638.27285932748191 -922.30600582760371 -140.13357441605777 636.80068589910047 -916.70170614594986 -144.67549572261353 635.07798879159543
+-951.65618496867114 -118.38810337555282 643.26125747829371 -945.48602331553889 -122.4831317485248 642.95503595027526 -939.42580059081365 -126.74852221737045 642.34563130024992 -933.47767628823692 -131.14631516262281 641.44318451443553 -927.63949018430299 -135.64310187584837 640.25967610837529 -921.90696745053083 -140.21045326889603 638.80832987459326 -916.27440597380985 -144.82404723886262 637.10327138717219
+-951.21303919009063 -117.76531255003125 645.02993107482268 -944.98699435243577 -121.91789556904799 644.76357849652914 -938.87400941392787 -126.24329984447716 644.19086520680708 -932.876125222204 -130.70287956781266 643.32190024513432 -926.9910145053741 -135.26258865793955 642.16871387088509 -921.21420547714615 -139.89343260079366 640.7446521220968 -915.53987899860965 -144.57058617777378 639.063985590568
+-950.56695315895934 -116.82330777843097 646.58159315921216 -944.27556708259488 -121.02148308478586 646.3540167911151 -938.10026460050733 -125.3946066831835 645.81726296052511 -932.04302063510909 -129.90339817630402 644.98144629356068 -926.10138839046158 -134.51322225244999 643.85866708170533 -920.27074066015587 -139.19456762358038 642.4624001193007 -914.54518307421165 -143.92216298572657 640.80705757880719
+-949.76371848640815 -115.62943303266088 647.82375789591788 -943.40329151743424 -119.86072386882982 647.62867563261091 -937.16202495075481 -124.26847882603276 647.12191620381213 -931.0418594026404 -128.81284106508656 646.31366852998644 -925.04025390989432 -133.45865169985254 645.21615158993779 -919.15244689762517 -138.17595689740654 643.84299869647214 -913.37248297686074 -142.93912388062896 642.20878193885767
+-948.85934706004525 -114.26800930943244 648.70208134672043 -942.43198796090633 -118.52109627754365 648.53016612242914 -936.1270352378541 -122.95143978395872 648.04440275769502 -929.94640044648236 -127.51867424495674 647.2551373014104 -923.88744745243525 -132.18719970160998 646.17476738955543 -917.94527760296648 -136.92671433426759 644.81712172812252 -912.11385977687496 -141.71132586907811 643.19695664052983
+8 0 0 6 8 -1055.0284409624016 -179.42753570099757 471.95785453199767 -1056.1441447813825 -179.27148118641153 472.90171325904356 -1057.2592059037133 -179.11594064334952 473.84769659576824 -1058.3735718524799 -178.96075182545809 474.79591196762118 -1059.4871790867599 -178.80573990644052 475.74646920235682 -1060.5999559935999 -178.65071770873627 476.6994811779403 -1061.7118245016227 -178.49548568204042 477.65506404099631 -1062.8227008359743 -178.33983169817682 478.61333719368378 -1063.9324957131 -178.18353067905065 479.57442316600691
+-1054.0149030268874 -179.66048515445206 473.2755856288357 -1055.1298245443982 -179.49666206288691 474.21650946117984 -1056.2441184725174 -179.33327907673407 475.15940517262965 -1057.3577304679211 -179.17017753455431 476.10437633675258 -1058.4705958009242 -179.0071861137435 477.05152841604121 -1059.5826421291194 -178.84412107749031 478.00096948215179 -1060.693790967978 -178.68078628458846 478.95281048185495 -1061.803958354466 -178.51697302168327 479.90716524914296 -1062.9130549852234 -178.35245967353075 480.86415038384058
+-1052.9430150045596 -179.56064600340486 474.60726827752126 -1054.0583743309392 -179.38998150828439 475.54406644712157 -1055.1731122247609 -179.21972973033505 476.48266019481099 -1056.2871709674944 -179.04973560303722 477.42314957496677 -1057.4004832882706 -178.87983163523708 478.36563597180873 -1058.5129748890349 -178.7098380874954 479.31022292881897 -1059.6245657515651 -178.53956295343289 480.257016485348 -1060.7351706958902 -178.36880179082019 481.20612522919663 -1061.8446994526394 -178.19733741037101 482.15766019259155
+-1051.8641569454744 -179.11618505282348 475.88609742072288 -1052.9810363562824 -178.94004153055178 476.8179588319997 -1054.0972848595522 -178.76433174371797 477.75142979851154 -1055.2128399457497 -178.58890381650372 478.68660718168786 -1056.3276305021207 -178.41359401699469 479.62358861126143 -1057.441579063252 -178.2382267677504 480.56247345138752 -1058.554602937761 -178.06261453448832 481.50336322414677 -1059.666614651075 -177.88655761404698 482.44636171255411 -1060.7775219457421 -177.70984381500298 483.39157488063682
+-1050.8348500349948 -178.34350634183514 477.04384485404893 -1051.954070659426 -178.16350522976094 477.97044703336485 -1053.0726295760799 -177.98400276344725 478.89847827330323 -1054.1904584434669 -177.80484954288605 479.82803234778851 -1055.3074812232314 -177.62588518909718 480.75920337349675 -1056.4236161862655 -177.44693809907935 481.69208688076588 -1057.5387768784153 -177.26782518107876 482.62678030248014 -1058.6528724594634 -177.08835155942421 483.56338311416056 -1059.765807638267 -176.90831022118402 484.50199677090131
+-1049.9071083487943 -177.28886818117297 478.0232958120161 -1051.029172124104 -177.10663225154647 478.94479357040632 -1052.1505194593265 -176.9249930867951 479.86755866058417 -1053.2710755828357 -176.74380296853209 480.79168167909114 -1054.3907587579251 -176.56290430588771 481.71725336859953 -1055.5094821150799 -176.38212906980712 482.64436572086652 -1056.6271545024247 -176.20129833047798 483.57311248333633 -1057.7436807493425 -176.02022184949118 484.50358930657563 -1058.8589615532831 -175.83869767331262 485.43589368069723
+-1049.1207867878597 -176.01677785876026 478.78580774805306 -1050.2459032343575 -175.83374681468854 479.70272161515157 -1051.3702254075915 -175.65143053229176 480.62076900445146 -1052.493671769538 -175.46968227497339 481.54003730006582 -1053.6161544112085 -175.28834664717988 482.46061398421693 -1054.73758074036 -175.10725868454637 483.38258774132237 -1055.8578542383523 -174.92624317611495 484.30604895959226 -1056.9768746640127 -174.74511413139251 485.23108986958914 -1058.0945379032169 -174.56367431195886 486.1578044687335
+8 0 0 6 11 -1069.0502061463187 -172.3932246873602 493.95994249952633 -1069.053722562418 -173.63911699248925 492.53121647632736 -1068.8595626515723 -174.67793652927509 491.05127628895349 -1068.5195940840208 -175.49461872932616 489.6108701490071 -1068.1045078789653 -176.15902848504376 488.21746685993929 -1067.6169123158554 -176.69690238062825 486.86870035982469 -1067.0867001650108 -177.13194411933964 485.56350618495458 -1066.5095304137938 -177.47675765392975 484.29439701542299 -1065.9076273228086 -177.74751691681894 483.06570459828009 -1065.2711572025382 -177.95059430439332 481.86951085151748 -1064.6130087712545 -178.09403184685675 480.70648097427335 -1063.9324841412592 -178.18354221590403 479.57442086582887
+-1068.2780705334378 -172.3121542496404 494.06625039915451 -1068.2473279323469 -173.48200582809508 492.76418849441404 -1068.0199599205077 -174.47657032052155 491.41923419833591 -1067.6510288314662 -175.27919728336491 490.10947210757331 -1067.2074924398692 -175.94930102410621 488.8408823309943 -1066.6974506087804 -176.50999103110351 487.60913208037289 -1066.1440716298735 -176.98070891653981 486.41328419596641 -1065.5484802021185 -177.37299451742672 485.24728556841308 -1064.9284302048789 -177.70050781798389 484.11340994316424 -1064.2770297848267 -177.96862508795954 483.00505844562571 -1063.6052860194757 -178.18435893771334 481.9227061571238 -1062.9130416845037 -178.35246962054509 480.86415107861842
+-1067.5050996246982 -172.1755501816555 494.12413112767757 -1067.4387010129515 -173.25659744202045 492.9465686303671 -1067.1762985874143 -174.18938661869674 491.73260984973467 -1066.7759313087574 -174.95664478501536 490.55028276698835 -1066.3007159472384 -175.60843506340734 489.40521236659674 -1065.7643716640432 -176.16627464993962 488.29153895049024 -1065.1833685005845 -176.64583873104155 487.20862576678945 -1064.5642390759722 -177.05782297889647 486.15195125962134 -1063.9203333911635 -177.41380744634321 485.12180329424797 -1063.2478461069563 -177.71870766313643 484.11293767004452 -1062.5557964385482 -177.9784886362159 483.12562958727614 -1061.8446853727569 -178.19734484950732 482.15766329128007
+-1066.7398307284141 -171.98430380370354 494.13240483989705 -1066.6380396442594 -172.9647558336564 493.07559852054993 -1066.3411875435022 -173.81921528834425 491.98642435322819 -1065.9098848230633 -174.53082241712863 490.92525175831389 -1065.4031288589151 -175.1409116602714 489.89806924931918 -1064.840575423684 -175.67083788290094 488.89885929670572 -1064.231204299683 -176.1321238262372 487.92619151043829 -1063.5880037251152 -176.53517408162188 486.97853486039821 -1062.9189244692657 -176.88977290114116 486.05346934232864 -1062.2238822863178 -177.20064859329679 485.14763938100174 -1061.5096649371669 -177.47270163921203 484.26104325608054 -1060.7775061313027 -177.7098464522949 483.39158213447746
+-1065.990807447869 -171.74034975312046 494.09080365550653 -1065.8555728035742 -172.60978694689939 493.1496139213088 -1065.5273091285419 -173.37096836325597 492.17708863970927 -1065.068585520019 -174.00857739769424 491.22802904164718 -1064.5341234100308 -174.55565622883302 490.30938686188597 -1063.9491270271467 -175.03476882554813 489.41621924262284 -1063.315314508292 -175.45265972381549 488.54562693315029 -1062.6519305546942 -175.81998294356134 487.69979825405295 -1061.9615513795425 -176.14490844675166 486.87356852935557 -1061.2477779311387 -176.43208589585544 486.06563803304488 -1060.5152080573584 -176.68528692559195 485.27573129596493 -1059.7657902613184 -176.90830625490739 484.50200828810785
+-1065.2662784936349 -171.44657942436112 493.99996503036817 -1065.1011555868031 -172.19628411595963 493.16808311015575 -1064.7468367596921 -172.85140219142843 492.30253360259348 -1064.267033334165 -173.39941877708424 491.4543084185616 -1063.7120997220809 -173.86557599627019 490.63196072581775 -1063.1118045568219 -174.27465303810939 489.83235736801356 -1062.4617112028632 -174.62823842722344 489.05129995154914 -1061.7859738353575 -174.93756884687895 488.29434828325799 -1061.0828087756372 -175.20934579187644 487.55431231534175 -1060.3587899958034 -175.44820674051394 486.83172945647755 -1059.6166518709013 -175.65672983127121 486.1260843171205 -1058.8589439609816 -175.83868794721943 485.43590828873312
+-1064.5738964958907 -171.10675440908062 493.86142512778906 -1064.3838641897851 -171.72997351116939 493.13164528695143 -1064.0108636053869 -172.26883643834958 492.36230811845672 -1063.5187680145011 -172.71501208013152 491.60204105540129 -1062.9531449811439 -173.08663142020106 490.86166540651948 -1062.3478700555074 -173.41111524864553 490.14042137892449 -1061.6922170194227 -173.68505155548812 489.43299573470216 -1061.015310875488 -173.92028434199707 488.74828776845834 -1060.3108808241093 -174.12213740208267 488.07722298706443 -1059.5882336626805 -174.29536352408951 487.42242242077702 -1058.8484477153527 -174.4412685628017 486.78294110318927 -1058.0945209048957 -174.56365784361262 486.15782174523412
+8 0 0 5 10 -1066.2730847791713 -164.30496789283359 499.41187802731179 -1066.7418007802764 -165.06198204544205 499.17280956041708 -1067.1919938826329 -165.85161026281321 498.87693954281582 -1067.6161372960942 -166.6719687973463 498.51498954591915 -1068.0101641372125 -167.52574370549291 498.07985028297725 -1068.3551810423919 -168.39830787428295 497.56145718181187 -1068.6485919632603 -169.29032103253502 496.94809823987902 -1068.853028873355 -170.14952931558381 496.25754338527344 -1068.9863944471902 -170.95976607825193 495.51592834186806 -1069.0482721174649 -171.70798391953932 494.74574181228564 -1069.0502061463194 -172.39322468736029 493.95994249952622
+-1065.5329492633687 -165.04765969213204 499.08035995539143 -1065.9906693782789 -165.71404653830859 498.84210764718785 -1066.4281769916574 -166.41002466624875 498.55504392035812 -1066.8376840692381 -167.13487484633603 498.21136172268359 -1067.214607762043 -167.89017070074925 497.80514113716538 -1067.5422787914317 -168.66734702605251 497.32720297185983 -1067.8121109075589 -169.46343367252524 496.76912379156238 -1067.996156206887 -170.23829895950297 496.14537980815112 -1068.1052392080048 -170.97444837889185 495.47928936686804 -1068.1443203333529 -171.66088627388064 494.78971297365689 -1068.1236434108619 -172.29594016209654 494.08751197908009
+-1064.8042568278745 -165.73856713959884 498.60728920682988 -1065.2488458744408 -166.31336597221446 498.38589921871477 -1065.6717879539506 -166.91536095364143 498.12233062328875 -1066.0650451664994 -167.54472207955635 497.80975040436255 -1066.4235207335685 -168.20169876784672 497.44352406382137 -1066.7327233749372 -168.88312586721898 497.01447245032051 -1066.9780889760477 -169.58176788313529 496.51713560886338 -1067.1409871770486 -170.26880637846085 495.96294246883275 -1067.224933077604 -170.92469882460463 495.37273978178041 -1067.2402681250624 -171.54101814574196 494.76282926496884 -1067.1958277316166 -172.1153551914351 494.14244070197611
+-1064.1056673467785 -166.3589567508765 498.00099047832305 -1064.5334307249686 -166.84533542840617 497.81167617747411 -1064.9385216039288 -167.35654723882749 497.58533544814793 -1065.312764453583 -167.89339498063316 497.31566867746136 -1065.650311384876 -168.45436509603755 496.99951895184211 -1065.939554491538 -169.04189830162386 496.62675706616636 -1066.1591151786606 -169.64253171463537 496.19479590000827 -1066.300525298343 -170.23964831658168 495.71200114316895 -1066.3593614347437 -170.81015594620439 495.19700030476014 -1066.3513635243366 -171.34909222871715 494.66446736610686 -1066.2838337252119 -171.85325241597215 494.12236897781776
+-1063.4551990809973 -166.89282722307036 497.27710163585573 -1063.861064499436 -167.29784303477916 497.13267675675615 -1064.2437477420733 -167.72475489479268 496.95510295401886 -1064.5950561897678 -168.17467179908178 496.73824845524632 -1064.9085496031678 -168.64444289230809 496.48046410950889 -1065.1752335209253 -169.14106669570884 496.1701695073607 -1065.368012496147 -169.64505300592822 495.80693820217692 -1065.4876039333033 -170.15108871221562 495.3965242833458 -1065.5223607779565 -170.63250278331728 494.95503679714261 -1065.4928324580217 -171.08829343219202 494.49643929573193 -1065.404754893184 -171.51454442741729 494.02767301088386
+-1062.8676486468482 -167.32920065833196 496.45633453158155 -1063.2457896464296 -167.66278710900986 496.36620216188447 -1063.6007369706422 -168.01436424520347 496.24593895760751 -1063.9245120374605 -168.38503898155602 496.08924992157023 -1064.2100230064793 -168.77007292433558 495.89604130794299 -1064.4514155314694 -169.18037686625445 495.65261166816521 -1064.6160634114694 -169.59014071506908 495.36035247922916 -1064.7139629733788 -170.00525521223815 495.02226408419398 -1064.7264715425426 -170.39532843795541 494.65177933726648 -1064.6784142642491 -170.7639839029319 494.26280404024976 -1064.5738964958907 -171.10675440908074 493.861425127789
+8 0 0 6 7 -1061.1536100771793 -158.00839316453602 499.99571324713463 -1061.9139842056077 -158.75715664960234 500.09331896751206 -1062.6705476500833 -159.54667732102277 500.1481524761025 -1063.4213066148964 -160.38182772135241 500.15302741399535 -1064.1638154781758 -161.26724619966396 500.09904507433765 -1064.8936214820314 -162.21166728875119 499.97244816771041 -1065.6034904918779 -163.22351910339282 499.75340440859014 -1066.2730847791709 -164.30496789283347 499.41187802731213
+-1060.5783849379336 -159.25641994260278 499.9218746104346 -1061.3384248162936 -159.93300468069421 499.97004705027575 -1062.0931068340328 -160.64488428285432 499.98014858437915 -1062.8404578117638 -161.3965644833078 499.94585175101082 -1063.5775519915535 -162.19258141821717 499.85941614774799 -1064.2999294560861 -163.04104721745 499.7086606878355 -1064.9998012360836 -163.95031858665573 499.4761677311671 -1065.6563051826686 -164.9238777255822 499.13561296737839
+-1060.0320944862524 -160.50445003840537 499.62261523299094 -1060.7878358647372 -161.09931169040709 499.64171289312026 -1061.5369530351898 -161.72560251440169 499.6273160288352 -1062.2775107504751 -162.38747038616125 499.57381016971283 -1063.0061083633245 -163.08933583269533 499.47428338962908 -1063.7182999292336 -163.83861944611709 499.31795509320352 -1064.4057742073037 -164.64351012786804 499.08928054417623 -1065.047154306372 -165.50826465710983 498.7649794563506
+-1059.5343498991708 -161.70993416248777 499.10045343066201 -1060.2800551861624 -162.21986109047614 499.11229244523264 -1061.0182554328496 -162.75849438891879 499.09457621102757 -1061.7470644731429 -163.3295772426963 499.0422921309314 -1062.4625960956682 -163.93737416938197 498.94911997104805 -1063.1604611485927 -164.58847520833038 498.80555106217429 -1063.8318532124997 -165.29077800941957 498.59750004897955 -1064.4549620873258 -166.04876194523763 498.3041398425766
+-1059.1031363320083 -162.83027746562183 498.37074092712828 -1059.8316620568789 -163.25895614653598 498.39626204327936 -1060.5522258721037 -163.71409201005429 498.39530933901972 -1061.2629700857754 -164.19901641919844 498.36345141880378 -1061.9595851505703 -164.71769304334006 498.29473088213712 -1062.6377207538906 -165.27583737650468 498.18083586435245 -1063.2881816511276 -165.88083111457533 498.00876728359481 -1063.8888445915175 -166.53691357494111 497.75969419750072
+-1058.7524609525085 -163.82797579354343 497.46123920789398 -1059.4560643188347 -164.18528483072635 497.5180720204782 -1060.1515757836494 -164.56664629244605 497.55081098853816 -1060.8371571711352 -164.97497691093199 497.55556589507785 -1061.5081889123614 -165.41375730870806 497.5265613254906 -1062.1602971638144 -165.88789086655319 497.45668329676914 -1062.784067320121 -166.40396910294211 497.33370158638041 -1063.3572740086386 -166.9655561289473 497.14030711847681
+-1058.491230325594 -164.67417872184134 496.40786078227336 -1059.1624622915731 -164.97456183602938 496.50886024691846 -1059.8255895695138 -165.2960465176983 496.58779484551417 -1060.4788139729599 -165.64110252376307 496.64127164261924 -1061.1172736659348 -166.01263305989443 496.66360812871579 -1061.7366509623646 -166.41461304254892 496.64877262006371 -1062.3274472188743 -166.85264858593501 496.5850950597204 -1062.8676486468476 -167.32920065833198 496.4563345315816
+8 0 0 6 10 -1007.856269624325 -143.11770120665565 493.15420250124725 -1013.3653617949839 -143.81748873837537 493.86137732106761 -1018.8546995688936 -144.67530141670636 494.56601627436663 -1024.3184296020956 -145.69719345518146 495.26736785033711 -1029.7499255940488 -146.88955748124542 495.9645813760485 -1035.1416515012504 -148.25909616944347 496.65668955642889 -1040.4849802403708 -149.81276951153524 497.34258522927848 -1045.7699701019103 -151.55770084595557 498.02099252255249 -1050.985217014369 -153.50097797852393 498.69044762105938 -1056.1180316356781 -155.64922027266229 499.34932138433186 -1061.1536166606386 -158.00837876517377 499.99571451386782
+-1007.6524994893496 -144.74834032096359 493.12804698799874 -1013.1237034705961 -145.41465189953044 493.83035854522541 -1018.5753097075431 -146.23800276661942 494.53015363395969 -1024.0014624557118 -147.22441852786304 495.22668043106012 -1029.395535493202 -148.3802623649845 495.91908852553138 -1034.7499957311734 -149.71220714458596 496.60641147184879 -1040.0562224258576 -151.22718302782496 497.28754345543513 -1045.30428439497 -152.93228390769912 497.9612103429908 -1050.4827935603832 -154.83456921013843 498.6259504102901 -1055.5790839756783 -156.94063214146337 499.28013707466408 -1060.5783919091807 -159.25640164255961 499.92187441583366
+-1007.4899986966408 -146.37897848616447 492.78038914471199 -1012.921886426844 -147.01181435522875 493.48896332123417 -1018.3343707075181 -147.8007036458516 494.19474794695992 -1023.7215950532244 -148.75164330622593 494.89697789023131 -1029.0769351996962 -149.8709670345647 495.59478805495445 -1034.392863142062 -151.16531787497595 496.28719571404781 -1039.6607668900222 -152.64159617087071 496.97307692684274 -1044.8707285247192 -154.30686640692232 497.65113739860266 -1050.011379061028 -156.16815968007421 498.31989316023828 -1055.0700794557481 -158.23204308645273 498.97769348090418 -1060.0321035141772 -160.50442348883394 499.622616882606
+-1007.3786712638724 -147.93035874948458 492.11248182616083 -1012.7713129401239 -148.53408324682127 492.83864034942565 -1018.1446435571351 -149.29272987998709 493.5614260879471 -1023.4928152695375 -150.21226534354955 494.28004844555244 -1028.8092153047505 -151.29899055250314 494.99361325378084 -1034.0863306999991 -152.55951319192872 495.70110473946556 -1039.3155692793569 -154.00069716089308 496.40136187458381 -1044.4870392967689 -155.62957316380084 497.09304951199351 -1049.5894052626084 -157.45314550823716 497.77463939462808 -1054.6100688739405 -159.47796200194438 498.44443282364125 -1059.5343570716936 -161.70990913671369 499.10045531016505
+-1007.3250971045074 -149.3229836743794 491.15175221348778 -1012.6802977615794 -149.90636228866526 491.90519268571586 -1018.0160208768665 -150.64323039904889 492.65446698862951 -1023.3264452668166 -151.53951974116274 493.39874365295736 -1028.6049884103575 -152.60149389426985 494.13708221900987 -1033.8441721057904 -153.83572088994114 494.86841470718224 -1039.0354449166045 -155.249024387585 495.59152186057685 -1044.1689636615934 -156.84839837027519 496.30500455516557 -1049.2334504692831 -158.64081871789443 497.00726512219757 -1054.2163738847696 -160.63281413612296 497.6965296897335 -1059.1031423109662 -162.83025333190579 498.37074127176339
+-1007.3308317260779 -150.4911669775102 489.95110232344194 -1012.6521589717262 -151.06609635472043 490.73811802202619 -1017.9534561081505 -151.79272919093555 491.52017953908592 -1023.2289497607211 -152.67694846557538 492.29639205409171 -1028.4721105787708 -153.72496875125054 493.06574502278926 -1033.6755199634292 -154.94330963704289 493.8270929879705 -1038.8306937820962 -156.33874797278969 494.57913139134325 -1043.9278654633524 -157.91823403005927 495.3203677462688 -1048.9558451307357 -159.68870507907621 496.04910288042186 -1053.9022034019008 -161.65665900236667 496.76345331960306 -1058.7524682735825 -163.82794497799887 497.46124450550963
+-1007.3928566467803 -151.39117314850978 488.57730488644444 -1012.6853821055233 -151.97082816201632 489.40013897915884 -1017.9568777175823 -152.70012903274099 490.21745830232311 -1023.2016341441076 -153.58488505641395 491.02827980063927 -1028.4131938287921 -154.63123704828081 491.83149618958828 -1033.5842192022794 -155.84563184652424 492.62585590245521 -1038.7063181299891 -157.23477613292889 493.40993830897781 -1043.7698290824217 -158.805554767665 494.18212456475612 -1048.7636827716231 -160.56484723863667 494.94057879984757 -1053.6755889655924 -162.51910494735296 495.68327071714577 -1058.4912369863059 -164.67414646538469 496.40786929271718
+8 0 0 6 10 -978.37243038513066 -126.19521751422829 521.78813449874497 -977.68784325685783 -128.70385323319385 517.06970566589644 -977.86656756359639 -131.10433169529745 512.27528288176677 -978.99917321726264 -133.37097266374082 507.56518364568433 -981.13433430122245 -135.48816211849726 503.14318745850841 -984.24106244245775 -137.45445968055228 499.26931648151771 -988.15150978347697 -139.25670834340758 496.15982104614636 -992.68307246314487 -140.83915594512754 493.95157360305797 -997.62595812690063 -142.07949739969277 492.73604364229305 -1002.7505033759528 -142.86265096230909 492.49880569561248 -1007.8562700524344 -143.11769561694487 493.15420469747369
+-977.74949268844659 -127.79007125879392 522.46272530721103 -976.96702401313325 -130.22253850858732 517.61116505130087 -977.08513317757695 -132.57060222465267 512.66712234144347 -978.1981342978039 -134.80980937376589 507.80592923626295 -980.35516759126983 -136.92243764631834 503.24518608209524 -983.51692533047265 -138.90145518068505 499.26072642755503 -987.50678269516879 -140.72777127007541 496.07219006942182 -992.13804297193008 -142.34199157844981 493.81685569737101 -997.19647273158728 -143.62058648799993 492.59443960950614 -1002.4388191043024 -144.44738519147455 492.39410671350208 -1007.6524988890425 -144.74832591562111 493.12804645923359
+-976.74571579379506 -129.24440344046377 523.11786028395284 -975.90368857408941 -131.60952606343366 518.07274958853429 -975.99954005400343 -133.91527185831524 512.92921075009372 -977.12969153950587 -136.13772631936382 507.87456565927772 -979.34505067532882 -138.25712482771462 503.13732194986648 -982.60065083149618 -140.26173887765199 499.00797670525822 -986.71286173659246 -142.12732754426725 495.7119475195139 -991.48973082430916 -143.79031282672443 493.38925106633229 -996.71005676302912 -145.12461713549072 492.14652120319431 -1002.1178665901965 -146.01315105751871 491.97370544466156 -1007.489996594425 -146.37896451783055 492.78038232823252
+-975.39900231417175 -130.46104196773643 523.71244238117822 -974.53837348246827 -132.78088618732704 518.42510087998028 -974.65039732172716 -135.06298784403347 513.04237435495452 -975.83259026298458 -137.28417919316797 507.76021102087174 -978.14190473738108 -139.42444024232609 502.81465735934677 -981.52411448788257 -141.46750960526595 498.5121429068048 -985.80054140681807 -143.38788311141556 495.08277715241405 -990.76269287572393 -145.11517175851165 492.67497150511798 -996.1866040701907 -146.52086687487827 491.39878206341518 -1001.8024264694243 -147.48587932316386 491.24264139087057 -1007.3786706743858 -147.93033532123778 492.11247784605445
+-973.78642511337455 -131.35671123512094 524.20716018711983 -972.94330629769127 -133.66456595330502 518.64675872057239 -973.10427610888905 -135.94855885054918 512.9991197212604 -974.36792731784726 -138.18758074817387 507.46618418349732 -976.79974287593905 -140.36378904656166 502.28977093071319 -980.33704454612689 -142.45819194066306 497.79241751425025 -984.81000384028516 -144.44680046553117 494.21008208737658 -989.99008102501546 -146.25179121325385 491.70245647021176 -995.6505248115609 -147.74134695590163 490.38122807123551 -1001.5081962787965 -148.79287767467224 490.23065919708921 -1007.3250962922907 -149.3229570550107 491.15176159259715
+-972.01448029168125 -131.88365742398332 524.57375430811044 -971.21333515244942 -134.21696231446342 518.72967273612107 -971.44557125353447 -136.53076338932237 512.80672954777503 -972.81124779109166 -138.80750803223648 507.01174659948339 -975.38403299103811 -141.03374622986829 501.59253598151241 -979.09841206496526 -143.19107394907019 496.88656505649743 -983.78766747239672 -145.25791935238763 493.13931054301003 -989.20879552193287 -147.15076615094094 490.52119611046385 -995.12733920753624 -148.73248075241784 489.1459122128399 -1001.2492308133311 -149.87530605024838 488.9909011428374 -1007.3308293627277 -150.49114550207534 489.95111073626788
+-970.19406942959313 -132.03283789677462 524.79854772238514 -969.44629782627646 -134.42615379854317 518.67819738746232 -969.76057849888105 -136.79558936118258 512.48367803205679 -971.23857445435578 -139.12792143522498 506.42696101094481 -973.96231283265877 -141.41609127965694 500.76269070867221 -977.86415609738708 -143.64467824875004 495.84373799129258 -982.78047352273416 -145.79649906329109 491.92618060705888 -988.45314601693553 -147.7830723324083 489.19206279385293 -994.63980026953243 -149.46094946500344 487.75657099268579 -1001.0360091107659 -150.6949603585941 487.589016658584 -1007.3928533894434 -151.39115042443947 488.57731807678505
+8 0 0 6 11 -962.75720610808764 -108.65467445859073 638.6700125620456 -967.01232975557843 -106.18844614713757 628.67905721099669 -970.65993013548439 -104.92216857591779 618.14031888117131 -973.65760380548022 -104.7601926751444 607.29707893587909 -976.02005930902931 -105.53360009808756 596.34774338758302 -977.79838840759362 -107.06384044559286 585.40236197045215 -979.03562752168648 -109.22343992386644 574.51431759420234 -979.76982499059068 -111.9061452179088 563.72022555968795 -980.04273128033753 -115.00628935338635 553.0483120936824 -979.88139632228547 -118.46563428586501 542.49669389392966 -979.31662668594845 -122.21168972455403 532.07741360408261 -978.37243941871247 -126.19519197464879 521.78818983153269
+-962.49348751615071 -109.82455603070792 638.26743542131203 -966.6838427438762 -107.42335621011958 628.3961268078782 -970.27535003438197 -106.21541859251076 617.9761357868806 -973.22546597757184 -106.10471209369288 607.24813054744629 -975.54788311618267 -106.92287141257903 596.40881829043997 -977.29238332026887 -108.49243208542968 585.56775533729046 -978.50103632522837 -110.6866638454988 574.77818807304141 -979.21105786221813 -113.40042670696906 564.07681478601899 -979.46348988018451 -116.52893144599848 553.49212452929009 -979.28497702999073 -120.01384989241237 543.02242897709289 -978.70572958046637 -123.78397090131033 532.6799770979793 -977.74950219435345 -127.79004615312707 522.46278076256488
+-962.05690654284922 -110.93517056289092 637.80586615544871 -966.17075015255114 -108.59666128428138 628.05580637198466 -969.69119073579873 -107.44324428436062 617.75573479028594 -972.57623530441288 -107.37874440263121 607.14420172163773 -974.8393828223418 -108.23555134597075 596.41663024543982 -976.52978175050566 -109.8374022549752 585.68230195156491 -977.6889955170019 -112.05840675301602 574.99441116857929 -978.35373603464552 -114.79462745734614 564.38976939086808 -978.5646237127097 -117.94221437891635 553.89714173289303 -978.34812372872739 -121.4428067170482 543.51502970519266 -977.73393815812938 -125.22658889688186 533.25586071673001 -976.74572562667049 -129.24437881196579 523.11791598595732
+-961.45506116807314 -111.95279891771908 637.2969055057074 -965.48293958816373 -109.6708803678583 627.66689441933715 -968.91975689624655 -108.56373169446263 617.48492708342394 -971.72482351459473 -108.53529543041726 606.98774404761446 -973.91226044163318 -109.41897669181702 596.36981114609443 -975.53111950548691 -111.04018267659215 585.74021863771941 -976.62277774252846 -113.27459524507091 575.15192234258461 -977.22453922367401 -116.01724509518743 564.64322633897746 -977.37538550303054 -119.16896869077939 554.24129284650508 -977.10311211831583 -122.66858912341368 543.94641433251411 -976.43638171373095 -126.44901759949109 533.77058177392382 -975.39901231058491 -130.46101780568881 523.71249843481883
+-960.70387189788812 -112.84660109448826 636.75499811937982 -964.63966706900339 -110.61167310875085 627.24113285285318 -967.98415068610313 -109.53848535362899 617.17264124104395 -970.69873049594594 -109.53145211477749 606.78449512777718 -972.79893464004476 -110.42543815338703 596.27032635066882 -974.33426485750078 -112.04797033150803 585.73915416456816 -975.34629386548158 -114.2767782663234 575.24376702399161 -975.87319534302605 -117.00550391049096 564.82430497725886 -975.95230813737317 -120.14059803810474 554.50604277501361 -975.61309814290917 -123.61773614156007 544.29148909565606 -974.88311735634147 -127.37282458386595 534.19213588488321 -973.78643511792586 -131.35668747401726 524.20721666595148
+-959.8267198304676 -113.59190062178544 636.19621963118527 -963.66838475344719 -111.39168993569662 626.79217999755713 -966.91672966574288 -110.3372556441731 616.83010621988035 -969.53607496333711 -110.33395796269338 606.54298770687922 -971.54409403979287 -111.21878326773776 596.12354868340003 -972.99127663406966 -112.82180141045086 585.68091119462099 -973.91978864499276 -115.02292245662294 575.2680497404026 -974.3680789374996 -117.71620770867369 564.92612130213047 -974.37311428004125 -120.81146201044551 554.68000945911933 -973.96505961282787 -124.24357053898338 544.53351639749962 -973.17078227251091 -127.95055044854803 534.49818371211552 -972.01449018314224 -131.88363396157447 524.57381124947619
+-958.85170131614746 -114.17198526159044 635.6366978490762 -962.6014171843392 -111.99268458477817 626.33414284186983 -965.75498972136336 -110.94041113185033 616.46946607401208 -968.28045307414243 -110.92201748894537 606.27329618012402 -970.19828761849658 -111.77739832168302 595.93729630523205 -971.56029940235703 -113.33988653647137 585.57076882992294 -972.4093621547953 -115.49205768493763 575.22702371316939 -972.78421233526058 -118.1287154065092 564.9483814277836 -972.72139423083797 -121.16330556105017 554.75949114636933 -972.25168205131524 -124.53014564972689 544.6656201320061 -971.4011735761826 -128.16938558662241 534.67849299400382 -970.19407912982558 -132.0328146171525 524.79860513128028
+8 0 0 6 10 -962.75722820414126 -108.65464220286081 638.67004920255079 -961.96730577277413 -109.14304984400323 640.49404976339838 -960.93840573772923 -109.68545631576251 642.20770326266654 -959.69044967919501 -110.26874310644111 643.74929574535065 -958.27793891934289 -110.87566900919742 645.05584422931281 -956.77731018028283 -111.47737797223284 646.12697937272446 -955.21831668143329 -112.07324984462007 646.98816890643388 -953.63734029059958 -112.6518223562245 647.65635655968413 -952.03975347143285 -113.21252971428657 648.15581300163387 -950.44527914345997 -113.75168371240319 648.49902201684688 -948.85936033769019 -114.26802971900702 648.70208985965314
+-962.49351185110504 -109.82452017179855 638.26747147540857 -961.75755984467082 -110.27010049433633 639.96157584065566 -960.81248517280221 -110.78285133725737 641.55215935080957 -959.67526487005432 -111.35306590787962 642.98552370211519 -958.39356321795458 -111.96264703904362 644.20878633811026 -957.03050318425915 -112.58427725149349 645.22235651471169 -955.6128026030085 -113.211259353847 646.04939424620568 -954.16908603928198 -113.83235356641417 646.70597310008884 -952.70440517123143 -114.44546967389493 647.21269380483 -951.23454838610769 -115.04513276016412 647.58070286372151 -949.76372151367548 -115.62945044752897 647.82376548600757
+-962.05693200486189 -110.93513138474889 637.80590121770695 -961.38520370679407 -111.33377099056375 639.35360515947389 -960.52977411060238 -111.8113947416616 640.80369481017908 -959.50500331963292 -112.36104628791679 642.10852412782037 -958.35373255034654 -112.96350504350129 643.22390172676432 -957.12829990027012 -113.59330389665556 644.15016012111403 -955.8542918936123 -114.23833386266782 644.90919744385258 -954.55373164975617 -114.88808266853864 645.51719540468582 -953.23217019397214 -115.5392123129421 645.99096998600862 -951.90210592030655 -116.18502952996332 646.34182167760196 -950.56694514970854 -116.82332389374487 646.58160009911808
+-961.4550921754709 -111.95276793475104 637.29694010749199 -960.85617816648744 -112.30209700100814 638.685303124406 -960.09401658038428 -112.73922943284668 639.98113524125358 -959.18053562797536 -113.25932427227238 641.1412403443702 -958.1559364508139 -113.84194802321048 642.1285948293206 -957.0625456656494 -114.46397882333621 642.94341463441572 -955.92852421816303 -115.10819873782322 643.60564467570669 -954.76853536313786 -115.76577565804324 644.13342354155714 -953.59056513502719 -116.43182473163969 644.53866234892428 -952.40430135416273 -117.09914768057791 644.83414663978886 -951.21301516401377 -117.76532181445899 645.0299391285555
+-960.70389986758084 -112.84656564859274 636.75502452075318 -960.18408140626275 -113.14610532710698 637.97543990006807 -959.51649802266559 -113.53779550626662 639.10780185611236 -958.71075175805822 -114.01834094607402 640.11223959233052 -957.80582477730184 -114.56639961055834 640.95793947596871 -956.83517121953889 -115.16145149343519 641.64456790684505 -955.83134038532501 -115.78193932938389 642.19021921129081 -954.80222304838287 -116.42130854441181 642.61544406408325 -953.7588829073801 -117.07279429304316 642.92687062865218 -952.70899357430574 -117.72931297746105 643.139383725176 -951.65615226274633 -118.38811822335349 643.26127509647472
+-959.82674879301101 -113.59186770357043 636.19624265768095 -959.3896074794302 -113.84296936878259 637.2448132907499 -958.81575069566736 -114.18507533940357 638.20949668945525 -958.11241898964897 -114.61595909792784 639.05323363246612 -957.31790777579602 -115.11408658629934 639.75114872956749 -956.45848447538071 -115.6617094769402 640.30162323648142 -955.57079759472742 -116.23432452489975 640.72202585943955 -954.65800986633246 -116.82793901937842 641.03437042839846 -953.73352117950833 -117.43385561686912 641.24066371215531 -952.80398163632651 -118.04570760890833 641.35784606651293 -951.87343469321866 -118.66034069873471 641.39254287040444
+-958.8517310144174 -114.17195471901805 635.63671697516838 -958.49801473681271 -114.37753106458074 636.51423692627111 -958.01507669598914 -114.66702945196043 637.31202146244698 -957.40753417780252 -115.03894232850057 637.99597579773524 -956.71333302000903 -115.47245760455641 638.5470724320345 -955.95195602476997 -115.95333874841077 638.96273639560309 -955.16488565355951 -116.45539193911165 639.25951524442723 -954.35099193601366 -116.97798895877051 639.46076505933047 -953.52595826254174 -117.51041706893081 639.56412322248252 -952.6959211493031 -118.04779202353936 639.58837833908922 -951.86538894739692 -118.58659913230451 639.53855077512105
+8 0 0 6 8 -497.91964891133961 -5.8938639559136252e-14 618.52248837093975 -497.91958555148466 -18.026377493136248 618.52245207295516 -498.18918062506941 -36.192220608886743 617.32688696625621 -498.68000452779 -54.381655464953795 614.75636203107717 -499.36217467531071 -72.432595032206407 610.66828042970417 -500.20421714593874 -90.064935497178681 604.98975561795521 -501.23410834370463 -107.04503805719898 597.90567439735491 -502.50162879822699 -123.28912175569887 589.63153574805767 -504.08517894036487 -138.77628526661439 580.39872152386783
+-494.53866015078154 -3.8634713194855382e-14 616.58534900472137 -494.53859955944989 -17.955634644813536 616.58531741346076 -494.79996871687553 -36.029211449191592 615.39228727057628 -495.27099204912469 -54.108094595693103 612.83084441797155 -495.91619355527922 -72.035969822261407 608.76106245754818 -496.70121211994814 -89.548499329461336 603.11343978873845 -497.6557276525549 -106.42726979824302 596.06098050165622 -498.83396209289464 -122.59386993648749 587.81026609618698 -500.31789282448381 -138.03053245948681 578.58367264788535
+-491.45959982832983 -2.8227691529282418e-14 614.12122988956321 -491.45954090429007 -17.850363673676526 614.12120407783596 -491.71309541661037 -35.794328036996816 612.93089758369933 -492.16538049291864 -53.722477219255047 610.37885082116691 -492.77586386665342 -71.484277863214928 606.32709989188663 -493.50762901409774 -88.831090539300348 600.7091348981894 -494.39200839344795 -105.55989005115401 593.68616745472843 -495.4873651400747 -121.59812691893231 585.45608113991136 -496.87913285356456 -136.93126699913671 576.23198668812563
+-488.78513370299237 -1.7031469580295206e-14 611.18894816961313 -488.78507501120669 -17.712712422030066 611.1889289243544 -489.03186242892099 -35.49251958228492 610.0016790473378 -489.46798574323429 -53.233144661863633 607.45960343477316 -490.04881873169467 -70.789724972925754 603.42597798360259 -490.73557259312236 -87.929001006905168 597.83704610645509 -491.56129647807876 -104.46316646485857 590.84239761849472 -492.58811782208801 -120.32577337482776 582.63176442646068 -493.90481798668674 -135.5053840385508 573.40913061124684
+-486.60273669219413 -7.0980039749684864e-15 607.87410451900337 -486.60267655583209 -17.546581676513092 607.8740922207345 -486.84430399451458 -35.132384782132718 606.69046868593364 -487.26816125495964 -52.654154758661882 604.15939820668711 -487.82689651450022 -69.972521267145126 600.14489000734613 -488.48074385697191 -86.869127660846075 594.58567901652225 -489.26472007689199 -103.17101829718088 587.62024642351844 -490.24423101913686 -118.81789362778437 579.43088802209445 -491.51130957198609 -133.80114700494897 570.21305470829179
+-484.97380081675823 -3.9314180155253938e-16 604.28257790811745 -484.97373747231057 -17.357381824086804 604.28257245928421 -485.21218392312642 -34.72561400444323 603.10343123994915 -485.62854210388457 -52.004341036000348 600.58498683710764 -486.17436398205513 -69.059490900339739 596.59179365666319 -486.80990077588598 -85.687072201392766 591.06479923987774 -487.5724830197455 -101.72854777183869 584.1322593589972 -488.53017610892533 -117.12970087293537 575.96982643230228 -489.7780896095328 -131.88449391698455 566.76540753298571
+-483.93001613052223 1.400817349520943e-14 600.52836594660653 -483.92994788629369 -17.151368569347408 600.52836678158155 -484.16734337496968 -34.285569388837295 599.35482299264334 -484.58132372853919 -51.305034558699951 596.85118756283248 -485.12402873121118 -68.080809105477059 592.8826251658802 -485.75677423340125 -84.422728830460272 587.39216966293213 -486.519463011531 -100.18624234665893 580.4988816966827 -487.48209076128489 -115.3230777438549 572.37262963981755 -488.74250075376443 -129.82956305966721 563.19500009910541
+8 0 0 7 11 -452.42272949218778 -3.6351128745028098e-14 588.78063964843682 -500.3789553000201 -3.8528886027802689e-14 624.4820396738146 -552.70749718354909 -3.3513156313298255e-14 652.02292830008491 -606.2924930691438 -1.1953410739100664e-14 671.73223327124754 -659.39303543737708 -1.1035502480418153e-13 685.38757537883646 -711.51184601005696 3.1320693171572862e-14 693.75634262190977 -761.85166482288537 -1.9567532574585459e-14 697.53093256912507 -809.9930573975613 -1.4040556429013084e-13 697.41545069837161 -856.23680637717655 6.2715854679899031e-14 693.82558458335723 -900.86544711243857 -5.6300927215354976e-14 686.90129939711039 -944.29241581442898 -3.5793852216457833e-14 676.40662715376482 -986.58428955311092 -2.6398259527675835e-14 661.70535825646516
+-452.42272949218778 -19.206044668059299 588.78063964843682 -500.3789553000201 -21.722043057582344 624.4820396738146 -552.70749718354898 -23.776843073366486 652.02292830008503 -606.29249306914392 -25.309468243562179 671.73223327124754 -659.39303543737719 -26.361537890331807 685.38757537883635 -711.51184601005684 -26.936588839669813 693.75634262190977 -761.85166482288525 -27.011207722886848 697.53093256912507 -809.99305739756142 -26.584323417607873 697.41545069837161 -856.23680637717666 -25.698512796465803 693.82558458335723 -900.86544711243846 -24.414676571989585 686.90129939711039 -944.29241581442898 -22.768945646504587 676.4066271537647 -986.58428955311092 -20.788181996197373 661.70535825646516
+-452.42272949218778 -37.898242899252715 587.08883067289491 -500.3125106938931 -42.795668485295323 622.4727968954279 -552.50905099993747 -46.77579142507723 649.69206883199729 -605.90933089354769 -49.732847183397169 669.14327233219035 -658.81881541980385 -51.756463404303105 682.65086413845961 -710.78923680433911 -52.861493191560456 690.96798662135257 -761.01740637050216 -53.005015610245863 694.81088001592866 -809.14974718620897 -52.1847954065029 694.86320032478159 -855.47151846953443 -50.481866310286065 691.50446330506884 -900.27880619352084 -48.005345242709609 684.832290128414 -943.96955203401956 -44.821284845330275 674.56644243653716 -986.58488588185753 -40.974465791822624 660.02178168503974
+-452.42272949218784 -56.063636187559837 583.70511458224405 -500.17943887443744 -63.243213329902254 618.45434195322161 -552.1116400990619 -69.041245730942492 645.03044033084336 -605.14149786568305 -73.320400502570749 663.96555481104394 -657.66963733092314 -76.228732917164891 677.17759893995071 -709.34031452928389 -77.798415068554107 685.39179172165041 -759.34761263132179 -77.968939272326082 689.37112161440723 -807.45900630534811 -76.738479128455751 689.75957645873405 -853.9379888964703 -74.227106412251928 686.86335999962773 -899.10205462154101 -70.583658907095085 680.6958337273901 -943.32039543875987 -65.897319582834768 670.88806013571684 -986.58276250595839 -60.22153061048769 656.65717456898653
+-452.4227294921879 -73.695410620655863 578.63649248851323 -499.96031037247928 -83.089068404927815 612.40786708505686 -551.46768309637753 -90.615757215720009 638.00036324837833 -603.90996111448646 -96.118797753014803 656.15759902658249 -655.84405166393844 -99.820124529431013 668.93830527294085 -707.04579335668905 -101.77322447887563 677.02057710292729 -756.72240992587899 -101.90168519613839 681.24230682544589 -804.81252926409229 -100.20606700197234 682.17870297138791 -851.5528169915948 -96.847814299591406 680.01606050770931 -897.2813079685119 -92.009803450901927 674.63800516757567 -942.32400343476343 -85.796148011050207 665.53777900580178 -986.58584087822089 -78.258527662397043 651.78204894054761
+-452.4227294921879 -90.791964409842791 571.89312758060635 -499.61407942883483 -102.35005632658624 604.29119916932257 -550.47540932684319 -111.52349842967072 628.52072153226538 -602.04481030511045 -118.14945172233958 645.62975391697921 -653.11976181470357 -122.5456023782907 657.86743789599564 -703.64448336798046 -124.78811017748207 665.83422672430129 -752.87122772853536 -124.78695403410457 670.48152950647761 -800.96093299578365 -122.54740879431574 672.26855992864114 -848.11437040510907 -118.27499776848424 671.19627658900765 -894.67601245189417 -112.18141665722086 666.96314888640632 -940.90782888664 -104.37353650245208 658.8665992426636 -986.58366415535772 -94.887972875554567 645.76262870052381
+-452.42272949218784 -107.35597541998062 563.48440794958049 -499.08513953273973 -121.03213324687958 594.04507481486712 -548.9977470916557 -131.76662928042199 616.4846969752225 -599.32085934878103 -139.40686360228676 632.27228242903755 -649.20998474759745 -144.39532200920559 643.89639884936378 -698.80772302511605 -146.82787305890193 651.8298682002337 -747.46604688977766 -146.60632831307811 657.19999857586936 -795.62505136342236 -143.74206672453423 660.25882788174783 -843.41327026922977 -138.48455705977139 660.7313368253499 -891.15492799931008 -131.06661941818135 658.07058864443457 -939.02081603194642 -121.57939622738762 651.30954142034454 -986.58428955079171 -110.02754898058956 639.02413792489233
+-452.42272949218784 -123.39346869941853 553.41500941392394 -498.31980392674575 -139.13341428386602 581.61021752362763 -546.90092554068246 -151.33305044265018 601.7905115092401 -595.51920238845776 -159.87063412235526 615.98673870025584 -643.84109560808974 -165.34865263396225 626.97236584928851 -692.22481105570159 -167.87438200681635 635.02060036873024 -740.20723986826329 -167.3530146374153 641.53221122108891 -788.56645283317232 -163.79870141633867 646.38844158985899 -837.27215488288903 -157.49903915674395 648.94048681736092 -886.61344329533893 -148.69820349909736 648.33557169318863 -936.62526152622343 -137.44537593826257 643.25854190774407 -986.58428955079148 -123.69451915376983 631.93215431363626
+8 0 0 6 8 -497.91964891133961 5.8938639559136252e-14 618.52248837093975 -497.91958555148466 18.026377493136248 618.52245207295516 -498.18918062506941 36.192220608886743 617.32688696625621 -498.68000452779 54.381655464953795 614.75636203107717 -499.36217467531071 72.432595032206407 610.66828042970417 -500.20421714593874 90.064935497178681 604.98975561795521 -501.23410834370463 107.04503805719898 597.90567439735491 -502.50162879822699 123.28912175569887 589.63153574805767 -504.08517894036487 138.77628526661439 580.39872152386783
+-494.53866015078154 3.8634713194855382e-14 616.58534900472137 -494.53859955944989 17.955634644813536 616.58531741346076 -494.79996871687553 36.029211449191592 615.39228727057628 -495.27099204912469 54.108094595693103 612.83084441797155 -495.91619355527922 72.035969822261407 608.76106245754818 -496.70121211994814 89.548499329461336 603.11343978873845 -497.6557276525549 106.42726979824302 596.06098050165622 -498.83396209289464 122.59386993648749 587.81026609618698 -500.31789282448381 138.03053245948681 578.58367264788535
+-491.45959982832983 2.8227691529282418e-14 614.12122988956321 -491.45954090429007 17.850363673676526 614.12120407783596 -491.71309541661037 35.794328036996816 612.93089758369933 -492.16538049291864 53.722477219255047 610.37885082116691 -492.77586386665342 71.484277863214928 606.32709989188663 -493.50762901409774 88.831090539300348 600.7091348981894 -494.39200839344795 105.55989005115401 593.68616745472843 -495.4873651400747 121.59812691893231 585.45608113991136 -496.87913285356456 136.93126699913671 576.23198668812563
+-488.78513370299237 1.7031469580295206e-14 611.18894816961313 -488.78507501120669 17.712712422030066 611.1889289243544 -489.03186242892099 35.49251958228492 610.0016790473378 -489.46798574323429 53.233144661863633 607.45960343477316 -490.04881873169467 70.789724972925754 603.42597798360259 -490.73557259312236 87.929001006905168 597.83704610645509 -491.56129647807876 104.46316646485857 590.84239761849472 -492.58811782208801 120.32577337482776 582.63176442646068 -493.90481798668674 135.5053840385508 573.40913061124684
+-486.60273669219413 7.0980039749684864e-15 607.87410451900337 -486.60267655583209 17.546581676513092 607.8740922207345 -486.84430399451458 35.132384782132718 606.69046868593364 -487.26816125495964 52.654154758661882 604.15939820668711 -487.82689651450022 69.972521267145126 600.14489000734613 -488.48074385697191 86.869127660846075 594.58567901652225 -489.26472007689199 103.17101829718088 587.62024642351844 -490.24423101913686 118.81789362778437 579.43088802209445 -491.51130957198609 133.80114700494897 570.21305470829179
+-484.97380081675823 3.9314180155253938e-16 604.28257790811745 -484.97373747231057 17.357381824086804 604.28257245928421 -485.21218392312642 34.72561400444323 603.10343123994915 -485.62854210388457 52.004341036000348 600.58498683710764 -486.17436398205513 69.059490900339739 596.59179365666319 -486.80990077588598 85.687072201392766 591.06479923987774 -487.5724830197455 101.72854777183869 584.1322593589972 -488.53017610892533 117.12970087293537 575.96982643230228 -489.7780896095328 131.88449391698455 566.76540753298571
+-483.93001613052223 -1.400817349520943e-14 600.52836594660653 -483.92994788629369 17.151368569347408 600.52836678158155 -484.16734337496968 34.285569388837295 599.35482299264334 -484.58132372853919 51.305034558699951 596.85118756283248 -485.12402873121118 68.080809105477059 592.8826251658802 -485.75677423340125 84.422728830460272 587.39216966293213 -486.519463011531 100.18624234665893 580.4988816966827 -487.48209076128489 115.3230777438549 572.37262963981755 -488.74250075376443 129.82956305966721 563.19500009910541
+8 0 0 2 7 -483.93001608275335 4.2148359455373985e-15 600.52836588643402 -483.93001073122213 4.5318876379770885e-15 600.52834663841429 -483.46148521658017 7.9107882199256984e-15 598.84467398393554 -482.46063672571609 -2.8074272197650288e-14 595.23692189518954 -480.89288853819238 2.1579715321232556e-14 589.43937858560844 -478.9178052188164 -2.3816798194676232e-14 581.42196561329899 -476.82762070344506 -8.9318898259723177e-15 571.37308927859988 -474.94940661927239 -8.9350185236694071e-15 559.45768389054319
+-483.93001608275335 -9.6482067127312554e-15 600.52836588643402 -483.93001073122213 -9.8007820355221114 600.52834663841429 -483.46148521658012 -19.514812126438414 598.84467398393554 -482.4606367257162 -29.067434192448918 595.23692189518988 -480.8928885381921 -38.35089924103297 589.43937858560798 -478.91780521881645 -47.208094068643035 581.42196561329922 -476.82762070344501 -55.609191269518419 571.37308927859988 -474.94940661927234 -63.559583646673374 559.45768389054319
+-483.93001608275335 -2.824574341780961e-14 600.52836588643402 -483.93001073122213 -19.601564071044233 600.52834663841429 -484.24570150806551 -39.180075536142056 598.96274147634631 -484.78518033085624 -58.580838801491694 595.58807808500853 -485.45862441368553 -77.578979929916187 590.17005928770789 -486.25786693518478 -95.831039826378131 582.76945881637459 -487.30207090151964 -113.25071502664082 573.68371273724642 -488.74250075368985 -129.82956305962392 563.19500009902231
+8 0 0 6 9 -504.08525565637393 -138.77631739686004 580.39886155965166 -504.97126574905735 -147.44167473338314 575.23291171101744 -505.95892464291103 -155.97961153174859 569.70510141708075 -507.06226051143193 -164.37715188409155 563.77031500569592 -508.29256245839099 -172.62008581949428 557.37003370929563 -509.6670542236343 -180.65855411075327 550.40187279727866 -511.20328370154471 -188.4181579808853 542.7693301089954 -512.93944907152218 -195.82458911714704 534.30133491125787 -514.93719419216677 -202.55844286528512 524.76595479850334 -517.16342521475008 -208.22457291448245 514.29852713637297
+-500.31795233433274 -138.03056176346675 578.58380946602165 -501.14822467160803 -146.66766361124633 573.42134300769885 -502.07702986601447 -155.17222782629977 567.89946017059037 -503.11516657135741 -163.5293991127761 561.97542810757272 -504.27082448771154 -171.72528249838231 555.59219511083154 -505.55814600868956 -179.70651487916913 548.65311740401694 -506.99204612509658 -187.40450692952953 541.06146319187758 -508.60465800531364 -194.74059485329587 532.65740175747715 -510.45570879997649 -201.41670108806332 523.21236193078948 -512.5317137012654 -207.046493217674 512.84343797785164
+-496.87916737400673 -136.93128573615127 576.23210666187572 -497.65787193240692 -145.51046464019043 571.07104024323655 -498.53205620678256 -153.94895722455826 565.55456402997606 -499.50924734469794 -162.22884812870834 559.64248044732074 -500.59446497882107 -170.33511261056361 553.27959547812895 -501.7984981310895 -178.20877071904411 546.37625400947525 -503.13291197965287 -185.78601152922158 538.83814019928138 -504.62342618777586 -192.97905807153379 530.51840660595769 -506.32408136142311 -199.51015981622473 521.2044081988056 -508.23969622770329 -205.0145025851082 510.99835000633476
+-493.90487085607322 -135.50541122506789 573.40927221884806 -494.64157452641945 -143.9986894377036 568.24902663890509 -495.47122652529316 -152.34038893444182 562.73895747973836 -496.39833953996697 -160.50844976402851 556.84154267207282 -497.42503129860762 -168.48548479611253 550.5038035559711 -498.55882750395915 -176.20468491850269 543.64423112233158 -499.80765359089787 -183.60624770760845 536.17344263454288 -501.19118624938704 -190.58874294490718 527.95903805441765 -502.75495973174196 -196.89297964325817 518.81615429529234 -504.51852367582842 -202.18735639556621 508.83586102201519
+-491.5113717345651 -133.80118635440655 570.21322282369624 -492.22031057896095 -142.18460153390768 565.05566710388121 -493.0205978398493 -150.40341139830431 559.55544129134569 -493.91426535556462 -158.43063643045798 553.67782828637428 -494.90112232029395 -166.24519174863315 547.37249999075743 -495.98584649946571 -173.77153658733204 540.56688622988986 -497.17294558483331 -180.95209773670715 533.17896286429368 -498.47703426410828 -187.66916749597954 525.09184219512008 -499.93366724989579 -193.67993402544465 516.15825455541574 -501.57165614707998 -198.69535565807971 506.46138377845602
+-489.77812851502568 -131.88452002929546 566.76555491527927 -490.47634113195653 -140.14010731066466 561.61550677578373 -491.26546220324377 -148.21679589906802 556.13143487437674 -492.14576023577047 -156.08229683551204 550.28156495527128 -493.11554647881411 -163.71065703612678 544.01866587317829 -494.17726070654771 -171.01789992959621 537.27964423907031 -495.3326270100888 -177.94653141883583 529.99171266846463 -496.59251202090911 -184.36193488838711 522.05440251666971 -497.98219173845013 -190.036044401108 513.36450527806187 -499.53333756360075 -194.72823363411638 503.99928094807922
+-488.74252946237357 -129.82958003949017 563.19513531416271 -489.44773172367468 -137.94623537921191 558.06007945123042 -490.24458542804467 -145.86936809578594 552.60097033181034 -491.13238579830409 -153.56126473655769 546.78914595278547 -492.10883613705306 -160.9908688133666 540.58070462031594 -493.17480439763926 -168.06554914995164 533.92273744273075 -494.33008537169576 -174.72771794235854 526.75229694226709 -495.58317030297297 -180.82552709643289 518.98648091147834 -496.94949000066225 -186.14542129401869 510.56866026912707 -498.45723017994919 -190.49714574828155 501.57074294508948
+8 0 0 8 6 -962.79144943151505 -9.7170535506840849e-15 669.33533616730335 -962.791450408998 -19.480017334806 669.33533589421972 -961.51907165467196 -39.069064928320913 668.21243256750972 -959.21099962366304 -58.567853369677501 665.71405967518331 -956.18491380718081 -77.759714663620969 661.60194463307289 -952.69236909511494 -96.377122340891745 655.87538023389516 -948.8593603375889 -114.26802971886093 648.70208985990621
+-964.64558926955738 -2.7700606565483898e-14 668.78912978094718 -964.64559023117533 -19.410158836972606 668.78912956861188 -963.38311285649331 -38.90738760070338 667.67756625779464 -961.09312528445957 -58.291928506392232 665.2086881998905 -958.09347741037823 -77.354846366070902 661.155623685563 -954.63415054507448 -95.846174876600642 655.51593948785023 -950.84175885943728 -113.62259722940054 648.44825505517895
+-966.51546744403151 -3.5419715585615396e-14 668.01520938670899 -966.51546839712557 -19.336378029502846 668.01520924017177 -965.26255421330416 -38.736806173017172 666.91552960935599 -962.99016835481166 -58.001185692356195 664.47722729901898 -960.01671375175488 -76.928851885335547 660.48404850286488 -956.59026439497075 -95.286775659986503 654.93108719880229 -952.83808457463988 -112.94053508892985 647.9681227320923
+-968.38823607901259 -3.5858541574740632e-14 666.98926788072936 -968.38823703258288 -19.260111065537682 666.98926780412626 -967.14448685727734 -38.559543288458322 665.90198806288072 -964.88922204337587 -57.698210461345383 663.4952402374837 -961.94159756116642 -76.484376222950999 659.5623496700955 -958.54751329058217 -94.701543171538162 654.0952647698283 -954.83476854342325 -112.2244795882594 647.23505147486708
+-970.22264207093269 -3.1390173663506388e-14 665.66553291447042 -970.22264303589907 -19.181311541572011 665.66553291279172 -968.98732544263282 -38.37653652414506 664.59057949251735 -966.74833664411221 -57.385673220547858 662.21535328414006 -963.82570831983787 -76.026205757576861 658.3416304309311 -960.46301072125584 -94.097397663924539 652.95786294465574 -956.78833067275104 -111.4830920065309 646.19673121393907
+-972.00321051281207 -2.4902838347987529e-14 664.0383434848294 -972.00321150355126 -19.101798027501143 664.03834356245602 -970.77562819490856 -38.191040439602688 662.97591614951978 -968.55217435459826 -57.06790822709744 660.63241733821701 -965.65364356838722 -75.559320806776441 656.81648119362649 -962.32113151461147 -93.4795781395961 651.51255523282555 -958.68256687204405 -110.72142484306465 644.84487978356663
+-973.61726342122506 -1.8129273658932497e-14 661.9979419241746 -973.61726445631007 -19.026119339154636 661.9979420820639 -972.3959002386398 -38.011328092190212 660.94703335694612 -970.18621909118178 -56.756516439636997 658.63318667382998 -967.30970284749083 -75.098668441638537 654.87002464639772 -964.00488420655472 -92.866556950090413 649.63782160722019 -960.39883262267381 -109.96187542126269 643.05277402515162
+-974.90474416436405 -1.9856884962265336e-14 659.69685701869764 -974.90474526443143 -18.959937553317531 659.69685725210093 -973.68764784327186 -37.851690539230852 658.65549301699377 -971.48923189974573 -56.476769648120296 656.36666177514132 -968.63129679880274 -74.681719401958901 652.6465994497911 -965.34973450882751 -92.307984389880957 647.47146605524927 -961.76982697653887 -109.26514912152426 640.95005214449566
+-975.82839307127244 -3.8693630547911893e-14 657.27349502793754 -975.82839425194288 -18.905928765238926 657.27349532653022 -974.61365000493208 -37.717759739167818 656.23920040638598 -972.42401367788261 -56.237833091319168 653.96974112149087 -969.58097602896123 -74.321683767677811 650.2817275473858 -966.31785845510274 -91.821780681923372 645.14775831874056 -962.757230357808 -108.6546395244463 638.67005078496754
+8 0 0 8 5 -929.75115871910702 -228.61001043919126 515.63899645292634 -928.07146661989077 -228.61001043919126 556.27466615542255 -921.66107363495144 -228.61001043919126 597.42381996758786 -909.74053620476002 -228.61001043919126 636.6613646897323 -892.24567570247507 -228.61001043919126 671.77011304740734 -869.82757843394245 -228.61001043919126 700.74078369140625
+-945.23093653834803 -201.41993676228412 517.58513687910568 -943.92548712130713 -200.61770604313728 557.16052288504761 -938.22237369630784 -199.81547532399043 597.01694056950066 -927.58987063565712 -199.01324460484361 635.32783343340895 -911.90499468556243 -198.21101388569679 670.42011994485335 -891.33856407448025 -197.40878316654994 700.74078369140625
+-959.60228982169713 -173.84332955629731 519.39248485370365 -958.46298288659068 -172.46368972142176 558.08439364185926 -953.22480964585043 -171.08525866989174 596.97179999194532 -943.46751370928416 -169.70806948292554 634.59869051946748 -929.00486306345101 -168.33215524173872 669.61475505900171 -909.77655176636972 -166.95754902754931 700.74078369140625
+-972.59039147959493 -145.78682079219016 521.0348640489434 -971.43595204665633 -144.07537225268777 559.05962549453977 -966.40948026197339 -142.36670256583173 597.22121086287643 -957.15901674147665 -140.66070587172558 634.30980327006455 -943.46184827699483 -138.95727631047689 669.18375472147443 -925.14154150961099 -137.25630802218936 700.74078369140625
+-983.8573664640237 -117.23825898094776 522.48458262418444 -982.53227415231163 -115.4448332958324 560.02255018089977 -977.51082074811779 -113.6546523663748 597.64589192343396 -968.48078951478055 -111.8678643964264 634.30773170244379 -955.19788770923424 -110.08461758984052 669.0014286841315 -937.43353330420405 -108.3050601504701 700.74078369140625
+-993.02772625603632 -88.188229021644204 523.66032246324323 -991.4323861025739 -86.565822569068871 560.876144043473 -986.26569484531547 -84.946282841749621 598.12188952592703 -977.24639800066825 -83.329503979794708 634.45874649457107 -964.12441722764413 -81.715380123306744 668.96824435655537 -946.65252715014879 -80.103805412391523 700.74078369140625
+-999.56258272107902 -58.759562455871503 524.51882973841327 -997.69385384812392 -57.535749406150146 561.53779763094587 -992.3410436033364 -56.313107935281224 598.53695287691687 -983.24193425137696 -55.091671124479959 634.64560743816196 -970.14492029726341 -53.871472054965309 669.00039248487383 -952.79852304744531 -52.652543807953641 700.74078369140625
+-1002.9679796958726 -29.243607812800764 524.96541499772707 -1000.9306200887122 -28.585141317671891 561.89478390137765 -995.45313081666905 -27.926674822543049 598.77281296658748 -986.284675478228 -27.268208327414179 634.76369444934005 -973.17441767187472 -26.609741832285351 669.03162060561851 -955.87152099609364 -25.951275337156446 700.74078369140625
+-1002.9679796950066 -3.5527136788005009e-14 524.96541501342267 -1000.9306200868498 -1.0658141036401503e-14 561.89478391391663 -995.45313081433108 -1.4210854715202004e-14 598.77281297576553 -986.28467547599917 1.7763568394002505e-14 634.76369445516582 -973.17441767040395 0 669.03162060831391 -955.87152099609375 6.3948846218409017e-14 700.74078369140625
+8 0 0 8 6 -962.79144943151505 9.7170535506840849e-15 669.33533616730335 -962.791450408998 19.480017334806 669.33533589421972 -961.51907165467196 39.069064928320913 668.21243256750972 -959.21099962366304 58.567853369677501 665.71405967518331 -956.18491380718081 77.759714663620969 661.60194463307289 -952.69236909511494 96.377122340891745 655.87538023389516 -948.8593603375889 114.26802971886093 648.70208985990621
+-964.64558926955738 2.7700606565483898e-14 668.78912978094718 -964.64559023117533 19.410158836972606 668.78912956861188 -963.38311285649331 38.90738760070338 667.67756625779464 -961.09312528445957 58.291928506392232 665.2086881998905 -958.09347741037823 77.354846366070902 661.155623685563 -954.63415054507448 95.846174876600642 655.51593948785023 -950.84175885943728 113.62259722940054 648.44825505517895
+-966.51546744403151 3.5419715585615396e-14 668.01520938670899 -966.51546839712557 19.336378029502846 668.01520924017177 -965.26255421330416 38.736806173017172 666.91552960935599 -962.99016835481166 58.001185692356195 664.47722729901898 -960.01671375175488 76.928851885335547 660.48404850286488 -956.59026439497075 95.286775659986503 654.93108719880229 -952.83808457463988 112.94053508892985 647.9681227320923
+-968.38823607901259 3.5858541574740632e-14 666.98926788072936 -968.38823703258288 19.260111065537682 666.98926780412626 -967.14448685727734 38.559543288458322 665.90198806288072 -964.88922204337587 57.698210461345383 663.4952402374837 -961.94159756116642 76.484376222950999 659.5623496700955 -958.54751329058217 94.701543171538162 654.0952647698283 -954.83476854342325 112.2244795882594 647.23505147486708
+-970.22264207093269 3.1390173663506388e-14 665.66553291447042 -970.22264303589907 19.181311541572011 665.66553291279172 -968.98732544263282 38.37653652414506 664.59057949251735 -966.74833664411221 57.385673220547858 662.21535328414006 -963.82570831983787 76.026205757576861 658.3416304309311 -960.46301072125584 94.097397663924539 652.95786294465574 -956.78833067275104 111.4830920065309 646.19673121393907
+-972.00321051281207 2.4902838347987529e-14 664.0383434848294 -972.00321150355126 19.101798027501143 664.03834356245602 -970.77562819490856 38.191040439602688 662.97591614951978 -968.55217435459826 57.06790822709744 660.63241733821701 -965.65364356838722 75.559320806776441 656.81648119362649 -962.32113151461147 93.4795781395961 651.51255523282555 -958.68256687204405 110.72142484306465 644.84487978356663
+-973.61726342122506 1.8129273658932497e-14 661.9979419241746 -973.61726445631007 19.026119339154636 661.9979420820639 -972.3959002386398 38.011328092190212 660.94703335694612 -970.18621909118178 56.756516439636997 658.63318667382998 -967.30970284749083 75.098668441638537 654.87002464639772 -964.00488420655472 92.866556950090413 649.63782160722019 -960.39883262267381 109.96187542126269 643.05277402515162
+-974.90474416436405 1.9856884962265336e-14 659.69685701869764 -974.90474526443143 18.959937553317531 659.69685725210093 -973.68764784327186 37.851690539230852 658.65549301699377 -971.48923189974573 56.476769648120296 656.36666177514132 -968.63129679880274 74.681719401958901 652.6465994497911 -965.34973450882751 92.307984389880957 647.47146605524927 -961.76982697653887 109.26514912152426 640.95005214449566
+-975.82839307127244 3.8693630547911893e-14 657.27349502793754 -975.82839425194288 18.905928765238926 657.27349532653022 -974.61365000493208 37.717759739167818 656.23920040638598 -972.42401367788261 56.237833091319168 653.96974112149087 -969.58097602896123 74.321683767677811 650.2817275473858 -966.31785845510274 91.821780681923372 645.14775831874056 -962.757230357808 108.6546395244463 638.67005078496754
+8 0 0 11 5 -725.96309162713987 -197.72872914829486 300.00000000000034 -726.45675002995108 -212.96672558929555 348.78794127126775 -726.63931095121268 -222.59673494326088 395.69854538947226 -697.15330811834531 -284.76160633064819 514.81393844208469 -716.68292836261048 -231.06448663989335 588.03232212045395 -716.28679955432983 -163.89201846893482 635.79360142257246
+-701.43068678734676 -196.77197870260028 300.00000000000034 -701.99395480980729 -212.04289441719354 348.77695521337034 -702.29719816948966 -221.67860106265687 395.63534098829274 -672.4084887268001 -286.32602130005034 508.98171681681345 -692.07856583293835 -231.108530754047 584.48600280022595 -692.09692436031901 -164.10997432792027 632.49531296943371
+-676.98029200334281 -194.9912536804863 300.00000000000034 -677.61167054054863 -210.31340160057613 348.76012822026792 -678.03646295091437 -219.97613402636557 395.57609352171482 -648.10402245762896 -287.03034518631461 502.97461361342346 -667.48752440436181 -230.49597917272396 580.48015898679535 -667.93264611862378 -163.59260875126259 628.62081009493556
+-652.6846843164542 -192.40127180580157 300.00000000000028 -653.38068088399245 -207.79231999655187 348.73763720584799 -653.92298448921292 -217.50223906452985 395.51884766699652 -624.26456727855111 -286.86416291256512 496.84531941078575 -642.93302439669083 -229.21527585747816 575.99900243747061 -643.77515709679608 -162.3268657662245 624.15481871437157
+-628.61646930515496 -189.02390517472324 300.00000000000028 -629.37178201734787 -204.50071326746436 348.70969733194335 -630.02320622338516 -214.27671152276548 395.46287131615082 -600.89920353959644 -285.83160348432642 490.5887316069506 -618.43948066286396 -227.25803893426385 570.99731390303282 -619.6086135920267 -160.3018088171242 619.05069742172168
+-604.85244048968491 -184.88751791257803 300.00000000000034 -605.66009202617079 -200.46594295137342 348.67656825190528 -606.40707667131255 -210.32535684199283 395.40988971218536 -578.02036984892538 -283.94478170154929 484.12526451247601 -594.03534774586512 -224.6169352739783 565.38575098125875 -595.4278199952787 -157.50678150742112 613.21845359926181
+-581.4795354179347 -180.02940333870683 300.0000000000004 -582.33102045959799 -195.72405740998693 348.63857047090312 -583.1549267995623 -205.68251072713383 395.36254816067986 -555.62814252272756 -281.20758865951802 477.3283752796533 -569.7443504214084 -221.28070279807244 559.04249276076121 -571.2394336429287 -153.92856565467545 606.53421105340578
+-558.60155106781417 -174.50075671723627 300.00000000000034 -559.48706068307752 -190.32469873190726 348.59611182295015 -560.36308764853084 -200.39559514470474 395.32544472269507 -533.74819251727308 -277.59155734601359 470.05486457817892 -545.59226401504111 -217.22844164325531 551.81578575515084 -547.06467616551504 -149.54724579943428 598.84373015960944
+-536.34578120132096 -168.37361967162124 300.00000000000017 -537.25456766381217 -184.33796366905591 348.54972406465589 -538.14902681576177 -194.53140074921194 395.30673816708469 -512.39496204879515 -273.02937495729407 462.13398985089782 -521.63032483222332 -212.42701821635657 543.51235314040127 -522.95002155920372 -144.33297661016809 589.95157205715236
+-514.86873830552713 -161.74923234082212 300.00000000000011 -515.78968382413336 -177.8626546841403 348.50010958570402 -516.6571404880799 -188.18399551152487 395.31810636169661 -491.65750062653825 -267.4037480479036 453.35650728254603 -497.96518860775734 -206.83598340580306 533.88710185953539 -498.99081572159048 -138.24833692745023 579.60648899260502
+-494.36012275570067 -154.76722935498034 300.00000000000028 -495.2825755980229 -171.03535718702628 348.44819823605627 -496.06107900510193 -181.48352270905463 395.3777062137018 -471.6112157972193 -260.56233579276596 443.45077502734716 -474.78911406665821 -200.42379778990883 522.66010974833512 -475.37126670946674 -131.26344149164234 567.51261346877607
+-475.04420183577815 -147.61511570845639 300.00000000000028 -475.95914332599835 -164.03977903788046 348.39521426988239 -476.54760843271282 -174.6036690376103 395.53476822937932 -452.42272949218926 -252.31412452203577 432.05179298536336 -452.42272949218739 -193.19738259427427 509.58749746371507 -452.42272949218761 -123.39346869941861 553.41500941392439
+8 0 0 2 7 -474.94942832544319 1.5936470892929933e-14 559.45782159448595 -473.76716654909092 1.7510298766509891e-14 551.95756333420002 -472.6701620923501 2.3660327169716666e-14 543.71853702060821 -471.71112726572858 -7.8880354629060392e-17 534.6386359651857 -470.99799497889234 2.9237091418522956e-14 524.56681044483139 -470.61091849934525 3.845278923317976e-14 513.33478653655732 -470.87774187710306 3.2857087586427256e-14 500.66014072078241 -472.05103275240577 3.5063098258180633e-14 486.92503483316381
+-474.94942832544319 -63.55959122098033 559.45782159448606 -473.76716654909097 -68.564034544281185 551.95756333420013 -472.67016209235038 -73.389074399385592 543.71853702060821 -471.71112726572807 -78.005898864016302 534.63863596518627 -470.99799497889285 -82.334457758899447 524.56681044483105 -470.61091849934519 -86.329713415609348 513.33478653655754 -470.87774187710312 -89.751139323114856 500.66014072078252 -472.05103275240583 -92.385401504824188 486.92503483316392
+-488.74252727267918 -129.82957885422601 563.19513301095765 -489.64921526625125 -140.26527835372042 556.59291813495747 -490.71319068404904 -150.36601634048918 549.43511023394024 -491.93146718840222 -160.06711087022444 541.65373353105929 -493.3018915339415 -169.19373947470893 533.12057454310491 -494.82238518695948 -177.6458843967732 523.71385305917966 -496.51877283872568 -184.90206121412228 513.13948770533466 -498.45723043216918 -190.49714556166353 501.57074281662966
+8 0 0 6 11 -517.16342521475042 -208.22457291448259 514.29852713637217 -518.98488696050026 -212.8604975001895 505.73426814008377 -520.95633835766751 -216.80124612605019 496.55727273461355 -523.06082143122262 -219.83632438145062 486.84432220210596 -525.26450405615731 -221.8300344158574 476.73903837643968 -527.45539028225255 -222.42929072579545 466.66183866182388 -529.53922305630999 -222.2110213094862 457.21539157880864 -531.67810966098205 -221.31854891071578 448.0101027403897 -533.85101129202326 -219.92516080416101 439.32865796520065 -536.12184422552855 -218.20279773787939 431.01253262091882 -538.53288917507007 -216.26116521195155 423.07429659480482 -541.11909161919596 -214.20007110643297 415.47512525825664
+-512.53171370126574 -207.04649321767414 512.84343797785061 -514.23026316595656 -211.65268677826469 504.35977292544698 -516.07637948516515 -215.57766702201445 495.26898459002825 -518.06295200514455 -218.61627167578041 485.63733923676938 -520.16931900544603 -220.63022838920702 475.60031041737898 -522.31604561027029 -221.27070454220816 465.53746818261328 -524.41384346601239 -221.04068103670727 456.0668203309728 -526.60299114181851 -220.13524734047945 446.83623786445429 -528.85580023559498 -218.70621925123731 438.10703714130597 -531.23131667156508 -216.93981800736765 429.73925596741947 -533.76116905749245 -214.94784198178453 421.73882776769744 -536.47612370795139 -212.83362593932836 414.06788245627928
+-508.23969622770363 -205.01450258510835 510.99835000633374 -509.80701748193275 -209.51805575964937 502.64793875794862 -511.51524372227436 -213.3530316100057 493.71154791491352 -513.36646256733525 -216.32628549663897 484.24653899435532 -515.35352042618217 -218.30425979919292 474.37835121191057 -517.43024662584128 -218.96528342054569 464.44195707004206 -519.52400654383996 -218.73530529734094 455.03001749127407 -521.74661712887519 -217.84208030035467 445.8469824329282 -524.06694019741099 -216.41411063438846 437.12237989514682 -526.53710940980341 -214.64577796600116 428.74145800776574 -529.1778745922096 -212.64608572599587 420.7052360588055 -532.0153115299089 -210.51969191500558 412.97960319123388
+-504.5185236758287 -202.18735639556633 508.83586102201411 -505.96143963008114 -206.51911919290927 500.67016652569657 -507.53521351810144 -210.19309320913922 491.95460838509314 -509.24933356621705 -213.03431970553189 482.7395034014703 -511.10885998876944 -214.9208946315733 473.13869540089541 -513.09680052945384 -215.58027301631253 463.44006277055178 -515.16638733657885 -215.36221147272985 454.17178647622757 -517.39807263643945 -214.50662311653539 445.10925104512722 -519.76263558447272 -213.11683553673367 436.44304244004104 -522.30380562641415 -211.38917414894684 428.08831910365831 -525.03325093297622 -209.42486149643329 420.04375511860513 -527.97250029784982 -207.32763280101585 412.28178232183092
+-501.57165614708038 -198.69535565807976 506.46138377845494 -502.91182888114008 -202.79888244841754 498.52758041548805 -504.37068828696107 -206.25375472309238 490.09279437143152 -505.96246887730302 -208.90803922044182 481.20200489762453 -507.70089536315453 -210.65750304550903 471.95587604416647 -509.59191339590745 -211.29506433943237 462.59439393074251 -511.61552326940705 -211.09965585910479 453.54757699024583 -513.82725215313678 -210.30253315023782 444.67248354316877 -516.20289937808639 -208.98287582976693 436.11516237101188 -518.7792009632002 -207.33220553771281 427.82411893892203 -521.5618575871016 -205.4402107147144 419.798259710916 -524.56878772888001 -203.40765766718201 412.0190015069374
+-499.53333756360121 -194.72823363411641 503.99928094807814 -500.80245687508801 -198.56729755203239 496.3368246780924 -502.17716037795975 -201.76605856159276 488.23132016940519 -503.67336187709816 -204.19857561453927 479.72352703140893 -505.30857728640336 -205.78222827986295 470.8994788103181 -507.10418616929365 -206.38438737609371 461.95108529960129 -509.06179197876656 -206.21873499514879 453.18795118933963 -511.22394825533974 -205.49297242225418 444.55471298101588 -513.57309569618133 -204.26463192649345 436.14920927092936 -516.14214669305136 -202.71495123034464 427.95502318464571 -518.93485456654696 -200.92007861429911 419.97332029545646 -521.96705223395293 -198.97628579184376 412.1962120140825
+-498.4572301799497 -190.49714574828158 501.57074294508823 -499.69083578118449 -194.05764757449671 494.20881058905752 -501.01684656814695 -196.98637119668939 486.46651254924507 -502.44970041199883 -199.18444645036519 478.38075242162398 -504.00645445328172 -200.59165512535213 470.02227367397285 -505.71341205993093 -201.15373132543351 461.53359669652298 -507.5911811584856 -201.01919851913351 453.09769449332572 -509.67607856051887 -200.37026087271508 444.74411496185468 -511.96322743450366 -199.24166867288196 436.52378626670037 -514.48258379214656 -197.80317822932216 428.45376831810864 -517.24111913591446 -196.11644009077989 420.53917755204333 -520.25425313811252 -194.2724579250625 412.7835607748757
+8 0 0 7 9 -1019.7806953264925 -166.26735848040033 494.68488249587847 -1037.8081286840984 -161.68913237080289 496.99897373505405 -1056.0313992871245 -157.89734617297495 499.33828519221413 -1074.5007342367362 -155.23754074391945 501.7087264915404 -1093.1121690063833 -153.7720289148256 504.09856408583465 -1111.7511771239735 -153.34679729674502 506.49021662018731 -1130.3640988188406 -153.78353417087862 508.8801556973504 -1148.929922409447 -154.90742277694832 511.26306671748114 -1167.4572241624833 -156.45291696921123 513.64137785432433 -1185.9733651956267 -158.12825347020191 516.01820227193957
+-1020.9230714141522 -170.83975235848902 494.83152358708634 -1038.7652882781751 -166.26225602947378 497.12183950605089 -1056.7344414539982 -162.45860373056473 499.42845447935321 -1074.9334669054547 -159.74658845803708 501.76445455336955 -1093.3023827915495 -158.17752783303595 504.12286137093719 -1111.7463795324193 -157.6166831393848 506.48952394193594 -1130.2090938692952 -157.90873304337376 508.8604088927749 -1148.6691170499814 -158.89320946368474 511.22952215529517 -1167.1363685139299 -160.3178263489128 513.60019091757192 -1185.6381426846979 -161.89420672684 515.97517107106876
+-1022.2305747176987 -175.41214624793744 493.69177640994741 -1039.8844299523396 -170.8353797182975 495.98281854735757 -1057.5948367492274 -167.01984081985498 498.29270327010568 -1075.5173505286541 -164.2556900548245 500.64297136331277 -1093.635816118654 -162.58297636795888 503.03099792979435 -1111.8761780633936 -161.88657769646647 505.44066099699864 -1130.1800761533066 -162.03395107805679 507.85900756917061 -1148.5265909962613 -162.87898704642265 510.27458580896626 -1166.9271570222359 -164.18273679588006 512.68926299101065 -1185.4091015091108 -165.66016104711534 515.10495613464548
+-1023.5995098360357 -179.56955626993479 491.25244883580746 -1041.0806426825591 -175.00135137239855 493.5711210322267 -1058.5529164551756 -171.18658143540097 495.92347640024246 -1076.2187011530964 -168.39070608623447 498.34001749083302 -1094.1003102582808 -166.64280954213569 500.82149224519804 -1112.142872842242 -165.84251670688923 503.343974104653 -1130.2888985823063 -165.87483436220313 505.87750590632362 -1148.5196949950139 -166.60639575663026 508.40052149202614 -1166.8493219941472 -167.81073573209656 510.91115406920466 -1185.3058066832411 -169.20628685171681 513.41009185359735
+-1024.9035937101137 -182.89613062766429 487.67459595954529 -1042.2473258940479 -178.35221058334645 490.04360438039743 -1059.5286149454907 -174.56363062551398 492.47131447037452 -1076.9851112134102 -171.77688368126172 494.99681704261513 -1094.6669903167995 -170.01100084002391 497.62309863202108 -1112.5340502129472 -169.17017331533637 500.31444469939737 -1130.5344912098133 -169.14674987328848 503.0182622246831 -1148.6543544160718 -169.81685913192811 505.69871869605839 -1166.9123808217853 -170.9647363317541 508.34811712720335 -1185.3385589874918 -172.31261130248609 510.96538463140649
+-1026.01785714633 -185.07308666979009 483.30108022863237 -1043.2752031295167 -180.57329042294995 485.73137776796341 -1060.4340602128325 -176.84335918837775 488.25016998433989 -1077.7516813450193 -174.11875806451968 490.9040025316682 -1095.2917555602414 -172.41018156844754 493.69746153740311 -1113.0215861002471 -171.61348225135595 496.58348609493555 -1130.9004030516535 -171.6145604129363 499.48563490112747 -1148.92199125049 -172.29415495185131 502.35049852237154 -1167.1124233824371 -173.44444322910175 505.16266222283309 -1185.5053822630673 -174.79170971189495 507.918339499978
+-1026.851885679863 -185.96350467235138 478.56537261700618 -1044.0806835230628 -181.52511748451306 481.05366446188685 -1061.1954079834436 -177.88314842442495 483.65851864055162 -1078.4560313439117 -175.27102830446654 486.43220255992327 -1095.9245057188682 -173.69384571942527 489.38091095167107 -1113.5671310820369 -173.02799657424154 492.45106423066119 -1131.3577830969512 -173.13835585032726 495.54644521461108 -1149.3010058721504 -173.90383186177954 498.59416963749732 -1167.432769024796 -175.1207980203836 501.56965096153135 -1185.7923462790141 -176.51932719919606 504.46506058170127
+-1027.359572733247 -185.60024016296489 473.89165832709529 -1044.6160335636773 -181.23343085284398 476.42269540498631 -1061.763368810904 -177.69839950893956 479.0911313695089 -1079.0487058455151 -175.23537487174013 481.95276938270865 -1096.518493606902 -173.84741396714568 485.01581649611967 -1114.1297275941322 -173.38483139419122 488.22757683946173 -1131.8715680350426 -173.67908496390075 491.48076652850983 -1149.7617434654831 -174.5997798133024 494.68309409804027 -1167.8480260644058 -175.94301068981406 497.80006778459307 -1186.1770003278466 -177.44160575830958 500.81840824792596
+8 0 0 1 1 -1370.4053730055321 -253.96081542968824 539.69281459493288 -744.96835327148426 -253.96081542968821 459.40859985351551
+-1370.4053730055318 6.1959326558280736e-12 539.69281459493288 -744.96835327148426 6.1959326558280736e-12 459.40859985351551
+8 0 0 8 6 -978.37243039195926 -126.19521749710296 521.78813449148879 -985.94127760619506 -105.54849376731522 522.75592506739838 -992.38196145832205 -84.664138459913858 523.58513772831429 -997.5077076175055 -63.57307967892919 524.25008803620801 -1001.1075308116812 -42.339267605180787 524.72065180237007 -1002.9679797412697 -21.095335912161843 524.96541502081209 -1002.9679796950105 1.8829382497642655e-13 524.96541501340016
+-977.51669609663122 -129.33101355103301 515.8900989618586 -985.42966487823855 -108.18632690374019 516.90152435710456 -992.17356163179591 -86.790291366996072 517.76898579520673 -997.54921689887385 -65.174045070997181 518.46536236730753 -1001.3300987840358 -43.404127133566185 518.95867606667241 -1003.2852095219831 -21.622790621424528 519.21527864480061 -1003.2852094759323 1.3363754547413009e-12 519.21527863573715
+-978.05038460950027 -132.29204972830729 509.87155532835618 -986.2685024611385 -110.69474347311304 510.92210960936541 -993.28412635088785 -88.82747975311959 511.82376679136371 -998.88621320193124 -66.720260369867859 512.5481625911832 -1002.833593946782 -44.440781773769217 513.06178819479908 -1004.8764119401347 -22.139809795289668 513.32892208102601 -1004.8764118947357 2.4961005484769316e-12 513.32892207041834
+-980.15250695984707 -135.02981418764685 504.06373531653207 -988.62188379503834 -113.0380011844202 505.14717701421807 -995.86504819248819 -90.750798333103646 506.07750422784932 -1001.6602099296923 -68.195949629577683 506.82534183448587 -1005.7529829303643 -45.440583745377218 507.3560499454984 -1007.8734944805975 -22.642660933382523 507.63203142007421 -1007.873494436264 3.9370282827506331e-12 507.6320314083535
+-983.95012334531179 -137.49806561850193 498.98547764858597 -992.60152672523748 -115.18138627713293 500.09359575432524 -1000.0146513682197 -92.538266688778108 501.04549596329718 -1005.9588070117774 -69.591311105324252 501.81103353882207 -1010.1685732287583 -46.402960300247997 502.35486510550743 -1012.3533266174219 -23.134415834306918 502.63770960552085 -1012.3533265743644 4.5967753413224588e-12 502.63770959361773
+-989.04951472222331 -139.76523471914933 495.18996857102326 -997.82723620183037 -117.17648242802767 496.31556313603255 -1005.3637399480373 -94.222923489654789 497.28316419140322 -1011.4210812447071 -70.92211606964706 498.06201033440442 -1015.724551737839 -47.330681099648125 498.61617668232356 -1017.9625528404624 -23.611961539290171 498.9046319959927 -1017.9625527984379 5.8513214115255386e-12 498.90463198523162
+-995.06156985758298 -141.63145330793267 492.94929154660497 -1003.8990026739527 -118.84455326832017 494.08337417250721 -1011.5007920333591 -95.654269356281148 495.05923190784534 -1017.6241652466006 -72.071630656346045 495.84570375499737 -1021.9875690879459 -48.145142817129553 496.40637653485862 -1024.2615710993914 -24.037414507632445 496.69862654975094 -1024.2615710577247 6.1436114132514947e-12 496.69862654148773
+-1001.474059686519 -142.7989061480618 492.33495592109301 -1010.2890279833607 -119.91999657275504 493.46648430687367 -1017.8819125250307 -96.602528256214384 494.44111864559954 -1024.0085945825397 -72.852257733941016 495.22760782746275 -1028.3842446610056 -48.710461639772447 495.78928979483709 -1030.6688071753008 -24.338146144765155 496.08253482855048 -1030.6688071331796 6.3754210244404362e-12 496.08253482375034
+-1007.8562700675745 -143.11769534635374 493.15420484729123 -1016.5653615832019 -120.26700446354235 494.27214599038638 -1024.0729710762942 -96.950351591731064 495.23585395433844 -1030.1374497241507 -73.169600174584062 496.01433887103929 -1034.4744561566201 -48.959904765140962 496.57104070721726 -1036.7420385056571 -24.479627803762678 496.86212508341066 -1036.7420384623563 6.2387872645785958e-12 496.86212508253482
+8 0 0 6 9 -504.08525565637393 138.77631739686004 580.39886155965166 -504.97126574905735 147.44167473338314 575.23291171101744 -505.95892464291103 155.97961153174859 569.70510141708075 -507.06226051143193 164.37715188409155 563.77031500569592 -508.29256245839099 172.62008581949428 557.37003370929563 -509.6670542236343 180.65855411075327 550.40187279727866 -511.20328370154471 188.4181579808853 542.7693301089954 -512.93944907152218 195.82458911714704 534.30133491125787 -514.93719419216677 202.55844286528512 524.76595479850334 -517.16342521475008 208.22457291448245 514.29852713637297
+-500.31795233433274 138.03056176346675 578.58380946602165 -501.14822467160803 146.66766361124633 573.42134300769885 -502.07702986601447 155.17222782629977 567.89946017059037 -503.11516657135741 163.5293991127761 561.97542810757272 -504.27082448771154 171.72528249838231 555.59219511083154 -505.55814600868956 179.70651487916913 548.65311740401694 -506.99204612509658 187.40450692952953 541.06146319187758 -508.60465800531364 194.74059485329587 532.65740175747715 -510.45570879997649 201.41670108806332 523.21236193078948 -512.5317137012654 207.046493217674 512.84343797785164
+-496.87916737400673 136.93128573615127 576.23210666187572 -497.65787193240692 145.51046464019043 571.07104024323655 -498.53205620678256 153.94895722455826 565.55456402997606 -499.50924734469794 162.22884812870834 559.64248044732074 -500.59446497882107 170.33511261056361 553.27959547812895 -501.7984981310895 178.20877071904411 546.37625400947525 -503.13291197965287 185.78601152922158 538.83814019928138 -504.62342618777586 192.97905807153379 530.51840660595769 -506.32408136142311 199.51015981622473 521.2044081988056 -508.23969622770329 205.0145025851082 510.99835000633476
+-493.90487085607322 135.50541122506789 573.40927221884806 -494.64157452641945 143.9986894377036 568.24902663890509 -495.47122652529316 152.34038893444182 562.73895747973836 -496.39833953996697 160.50844976402851 556.84154267207282 -497.42503129860762 168.48548479611253 550.5038035559711 -498.55882750395915 176.20468491850269 543.64423112233158 -499.80765359089787 183.60624770760845 536.17344263454288 -501.19118624938704 190.58874294490718 527.95903805441765 -502.75495973174196 196.89297964325817 518.81615429529234 -504.51852367582842 202.18735639556621 508.83586102201519
+-491.5113717345651 133.80118635440655 570.21322282369624 -492.22031057896095 142.18460153390768 565.05566710388121 -493.0205978398493 150.40341139830431 559.55544129134569 -493.91426535556462 158.43063643045798 553.67782828637428 -494.90112232029395 166.24519174863315 547.37249999075743 -495.98584649946571 173.77153658733204 540.56688622988986 -497.17294558483331 180.95209773670715 533.17896286429368 -498.47703426410828 187.66916749597954 525.09184219512008 -499.93366724989579 193.67993402544465 516.15825455541574 -501.57165614707998 198.69535565807971 506.46138377845602
+-489.77812851502568 131.88452002929546 566.76555491527927 -490.47634113195653 140.14010731066466 561.61550677578373 -491.26546220324377 148.21679589906802 556.13143487437674 -492.14576023577047 156.08229683551204 550.28156495527128 -493.11554647881411 163.71065703612678 544.01866587317829 -494.17726070654771 171.01789992959621 537.27964423907031 -495.3326270100888 177.94653141883583 529.99171266846463 -496.59251202090911 184.36193488838711 522.05440251666971 -497.98219173845013 190.036044401108 513.36450527806187 -499.53333756360075 194.72823363411638 503.99928094807922
+-488.74252946237357 129.82958003949017 563.19513531416271 -489.44773172367468 137.94623537921191 558.06007945123042 -490.24458542804467 145.86936809578594 552.60097033181034 -491.13238579830409 153.56126473655769 546.78914595278547 -492.10883613705306 160.9908688133666 540.58070462031594 -493.17480439763926 168.06554914995164 533.92273744273075 -494.33008537169576 174.72771794235854 526.75229694226709 -495.58317030297297 180.82552709643289 518.98648091147834 -496.94949000066225 186.14542129401869 510.56866026912707 -498.45723017994919 190.49714574828155 501.57074294508948
+8 0 0 2 7 -483.93001608275335 -4.2148359455373985e-15 600.52836588643402 -483.93001073122213 -4.5318876379770885e-15 600.52834663841429 -483.46148521658017 -7.9107882199256984e-15 598.84467398393554 -482.46063672571609 2.8074272197650288e-14 595.23692189518954 -480.89288853819238 -2.1579715321232556e-14 589.43937858560844 -478.9178052188164 2.3816798194676232e-14 581.42196561329899 -476.82762070344506 8.9318898259723177e-15 571.37308927859988 -474.94940661927239 8.9350185236694071e-15 559.45768389054319
+-483.93001608275335 9.6482067127312554e-15 600.52836588643402 -483.93001073122213 9.8007820355221114 600.52834663841429 -483.46148521658012 19.514812126438414 598.84467398393554 -482.4606367257162 29.067434192448918 595.23692189518988 -480.8928885381921 38.35089924103297 589.43937858560798 -478.91780521881645 47.208094068643035 581.42196561329922 -476.82762070344501 55.609191269518419 571.37308927859988 -474.94940661927234 63.559583646673374 559.45768389054319
+-483.93001608275335 2.824574341780961e-14 600.52836588643402 -483.93001073122213 19.601564071044233 600.52834663841429 -484.24570150806551 39.180075536142056 598.96274147634631 -484.78518033085624 58.580838801491694 595.58807808500853 -485.45862441368553 77.578979929916187 590.17005928770789 -486.25786693518478 95.831039826378131 582.76945881637459 -487.30207090151964 113.25071502664082 573.68371273724642 -488.74250075368985 129.82956305962392 563.19500009902231
+8 0 0 7 11 -452.42272949218778 3.6351128745028098e-14 588.78063964843682 -500.3789553000201 3.8528886027802689e-14 624.4820396738146 -552.70749718354909 3.3513156313298255e-14 652.02292830008491 -606.2924930691438 1.1953410739100664e-14 671.73223327124754 -659.39303543737708 1.1035502480418153e-13 685.38757537883646 -711.51184601005696 -3.1320693171572862e-14 693.75634262190977 -761.85166482288537 1.9567532574585459e-14 697.53093256912507 -809.9930573975613 1.4040556429013084e-13 697.41545069837161 -856.23680637717655 -6.2715854679899031e-14 693.82558458335723 -900.86544711243857 5.6300927215354976e-14 686.90129939711039 -944.29241581442898 3.5793852216457833e-14 676.40662715376482 -986.58428955311092 2.6398259527675835e-14 661.70535825646516
+-452.42272949218778 19.206044668059299 588.78063964843682 -500.3789553000201 21.722043057582344 624.4820396738146 -552.70749718354898 23.776843073366486 652.02292830008503 -606.29249306914392 25.309468243562179 671.73223327124754 -659.39303543737719 26.361537890331807 685.38757537883635 -711.51184601005684 26.936588839669813 693.75634262190977 -761.85166482288525 27.011207722886848 697.53093256912507 -809.99305739756142 26.584323417607873 697.41545069837161 -856.23680637717666 25.698512796465803 693.82558458335723 -900.86544711243846 24.414676571989585 686.90129939711039 -944.29241581442898 22.768945646504587 676.4066271537647 -986.58428955311092 20.788181996197373 661.70535825646516
+-452.42272949218778 37.898242899252715 587.08883067289491 -500.3125106938931 42.795668485295323 622.4727968954279 -552.50905099993747 46.77579142507723 649.69206883199729 -605.90933089354769 49.732847183397169 669.14327233219035 -658.81881541980385 51.756463404303105 682.65086413845961 -710.78923680433911 52.861493191560456 690.96798662135257 -761.01740637050216 53.005015610245863 694.81088001592866 -809.14974718620897 52.1847954065029 694.86320032478159 -855.47151846953443 50.481866310286065 691.50446330506884 -900.27880619352084 48.005345242709609 684.832290128414 -943.96955203401956 44.821284845330275 674.56644243653716 -986.58488588185753 40.974465791822624 660.02178168503974
+-452.42272949218784 56.063636187559837 583.70511458224405 -500.17943887443744 63.243213329902254 618.45434195322161 -552.1116400990619 69.041245730942492 645.03044033084336 -605.14149786568305 73.320400502570749 663.96555481104394 -657.66963733092314 76.228732917164891 677.17759893995071 -709.34031452928389 77.798415068554107 685.39179172165041 -759.34761263132179 77.968939272326082 689.37112161440723 -807.45900630534811 76.738479128455751 689.75957645873405 -853.9379888964703 74.227106412251928 686.86335999962773 -899.10205462154101 70.583658907095085 680.6958337273901 -943.32039543875987 65.897319582834768 670.88806013571684 -986.58276250595839 60.22153061048769 656.65717456898653
+-452.4227294921879 73.695410620655863 578.63649248851323 -499.96031037247928 83.089068404927815 612.40786708505686 -551.46768309637753 90.615757215720009 638.00036324837833 -603.90996111448646 96.118797753014803 656.15759902658249 -655.84405166393844 99.820124529431013 668.93830527294085 -707.04579335668905 101.77322447887563 677.02057710292729 -756.72240992587899 101.90168519613839 681.24230682544589 -804.81252926409229 100.20606700197234 682.17870297138791 -851.5528169915948 96.847814299591406 680.01606050770931 -897.2813079685119 92.009803450901927 674.63800516757567 -942.32400343476343 85.796148011050207 665.53777900580178 -986.58584087822089 78.258527662397043 651.78204894054761
+-452.4227294921879 90.791964409842791 571.89312758060635 -499.61407942883483 102.35005632658624 604.29119916932257 -550.47540932684319 111.52349842967072 628.52072153226538 -602.04481030511045 118.14945172233958 645.62975391697921 -653.11976181470357 122.5456023782907 657.86743789599564 -703.64448336798046 124.78811017748207 665.83422672430129 -752.87122772853536 124.78695403410457 670.48152950647761 -800.96093299578365 122.54740879431574 672.26855992864114 -848.11437040510907 118.27499776848424 671.19627658900765 -894.67601245189417 112.18141665722086 666.96314888640632 -940.90782888664 104.37353650245208 658.8665992426636 -986.58366415535772 94.887972875554567 645.76262870052381
+-452.42272949218784 107.35597541998062 563.48440794958049 -499.08513953273973 121.03213324687958 594.04507481486712 -548.9977470916557 131.76662928042199 616.4846969752225 -599.32085934878103 139.40686360228676 632.27228242903755 -649.20998474759745 144.39532200920559 643.89639884936378 -698.80772302511605 146.82787305890193 651.8298682002337 -747.46604688977766 146.60632831307811 657.19999857586936 -795.62505136342236 143.74206672453423 660.25882788174783 -843.41327026922977 138.48455705977139 660.7313368253499 -891.15492799931008 131.06661941818135 658.07058864443457 -939.02081603194642 121.57939622738762 651.30954142034454 -986.58428955079171 110.02754898058956 639.02413792489233
+-452.42272949218784 123.39346869941853 553.41500941392394 -498.31980392674575 139.13341428386602 581.61021752362763 -546.90092554068246 151.33305044265018 601.7905115092401 -595.51920238845776 159.87063412235526 615.98673870025584 -643.84109560808974 165.34865263396225 626.97236584928851 -692.22481105570159 167.87438200681635 635.02060036873024 -740.20723986826329 167.3530146374153 641.53221122108891 -788.56645283317232 163.79870141633867 646.38844158985899 -837.27215488288903 157.49903915674395 648.94048681736092 -886.61344329533893 148.69820349909736 648.33557169318863 -936.62526152622343 137.44537593826257 643.25854190774407 -986.58428955079148 123.69451915376983 631.93215431363626
+8 0 0 6 6 -951.86543925308661 118.58657615609889 639.53852627889682 -945.76510876377483 122.54417490935337 639.17252061453723 -939.76813383074091 126.66796802055839 638.51076244506112 -933.8771247437669 130.92147079249864 637.56338933130689 -928.09044910795637 135.27259409172851 636.34218185291638 -922.40438797347338 139.69404768670682 634.86000657055899 -916.8136519798685 144.16252437094656 633.13057047999075
+-951.87347687225292 118.66032210626427 641.39252247562342 -945.7457785649533 122.68884530007823 641.05143286805242 -939.72475588689633 126.8853790916762 640.41072467136917 -933.81275543629181 131.21269225710793 639.48056347336808 -928.00784681132427 135.63803975345482 638.27285932748191 -922.30600582760371 140.13357441605777 636.80068589910047 -916.70170614594986 144.67549572261353 635.07798879159543
+-951.65618496867114 118.38810337555282 643.26125747829371 -945.48602331553889 122.4831317485248 642.95503595027526 -939.42580059081365 126.74852221737045 642.34563130024992 -933.47767628823692 131.14631516262281 641.44318451443553 -927.63949018430299 135.64310187584837 640.25967610837529 -921.90696745053083 140.21045326889603 638.80832987459326 -916.27440597380985 144.82404723886262 637.10327138717219
+-951.21303919009063 117.76531255003125 645.02993107482268 -944.98699435243577 121.91789556904799 644.76357849652914 -938.87400941392787 126.24329984447716 644.19086520680708 -932.876125222204 130.70287956781266 643.32190024513432 -926.9910145053741 135.26258865793955 642.16871387088509 -921.21420547714615 139.89343260079366 640.7446521220968 -915.53987899860965 144.57058617777378 639.063985590568
+-950.56695315895934 116.82330777843097 646.58159315921216 -944.27556708259488 121.02148308478586 646.3540167911151 -938.10026460050733 125.3946066831835 645.81726296052511 -932.04302063510909 129.90339817630402 644.98144629356068 -926.10138839046158 134.51322225244999 643.85866708170533 -920.27074066015587 139.19456762358038 642.4624001193007 -914.54518307421165 143.92216298572657 640.80705757880719
+-949.76371848640815 115.62943303266088 647.82375789591788 -943.40329151743424 119.86072386882982 647.62867563261091 -937.16202495075481 124.26847882603276 647.12191620381213 -931.0418594026404 128.81284106508656 646.31366852998644 -925.04025390989432 133.45865169985254 645.21615158993779 -919.15244689762517 138.17595689740654 643.84299869647214 -913.37248297686074 142.93912388062896 642.20878193885767
+-948.85934706004525 114.26800930943244 648.70208134672043 -942.43198796090633 118.52109627754365 648.53016612242914 -936.1270352378541 122.95143978395872 648.04440275769502 -929.94640044648236 127.51867424495674 647.2551373014104 -923.88744745243525 132.18719970160998 646.17476738955543 -917.94527760296648 136.92671433426759 644.81712172812252 -912.11385977687496 141.71132586907811 643.19695664052983
+8 0 0 6 10 -822.27918963051525 218.41848119959903 561.76339605587066 -830.58474239060718 213.59030417482111 572.38883829132669 -839.20120428389282 207.99543264623628 582.42686696399778 -848.07631243023013 201.64392039841258 591.79337857390419 -857.18437917298593 194.56698025336294 600.40419098360337 -866.5045417929324 186.82548199309338 608.13300752521968 -876.03698412798201 178.57743916937434 614.90817178463431 -885.80392377207397 170.02685943455339 620.74789371851762 -895.83632990717592 161.34338909311435 625.71166156958725 -906.16478659258235 152.67380035295724 629.83650636352866 -916.81364449549096 144.16254924802371 633.13065659741983
+-821.7295265186084 219.77888072707293 562.80848004492293 -830.08602395989089 214.96620915941963 573.56621524773038 -838.75637917800782 209.36535848889278 583.74281571698407 -847.68735876763446 202.98271062155513 593.25191285864071 -856.85225363872689 195.84524748616838 602.0056489826278 -866.22767908868855 188.010060774735 609.86629715491222 -875.80795202945831 179.64219407877388 616.74617281108863 -885.61188794820475 170.95863102798401 622.65619908495012 -895.6734108877647 162.13704027587548 627.66031586443864 -906.02699895770263 153.32666737163487 631.79675860736393 -916.70169562890658 144.67552470894077 635.07807693032294
+-820.88558496026963 220.92015770783485 563.98402276405568 -829.26901918658928 216.10572301946522 574.88498456461548 -837.9702759723009 210.47995433591973 585.20945596332444 -846.93637071026046 204.04551112284804 594.86795086104303 -856.14071727465353 196.825543204979 603.76783991225079 -865.56031454342883 188.87413101154078 611.75849083152309 -875.18665960046417 180.36615164432163 618.73486696955069 -885.03599427278141 171.53439741491871 624.70106382990525 -895.14356281465643 162.56547922214887 629.72769569106606 -905.54586106804413 153.61173958615427 633.85563562498226 -916.27439130738901 144.82407932243413 637.10336196363448
+-819.77941901443648 221.76288536577806 565.22903672933126 -828.16539294001132 216.9220874725398 576.27150954362969 -836.8734304962129 211.24629716978072 586.7388082980018 -845.85193418261838 204.73524084334423 596.53766520171291 -855.07555488541914 197.40968877732661 605.57047152120367 -864.52465941858304 189.32265225263171 613.67271979048428 -874.19147315270538 180.66291706547199 620.72563175397931 -884.09158977204208 171.6790494769003 626.72791753829642 -894.25952057665529 162.56623722373871 631.75898732941278 -904.73177691669025 153.47934586366725 635.86280730580086 -915.53985932403964 144.57061991889765 639.06407835969753
+-818.47206886691333 222.24872406128469 566.46945969374826 -826.84053321586362 217.35298950348621 577.63685439378992 -835.53514482828041 211.59971441981037 588.22531232818915 -844.50646692445218 204.98742216212153 598.13761667462279 -853.73131570292117 197.53624183982879 607.27127591164583 -863.19523766892064 189.30286665142188 615.4501988380631 -872.89477218134994 180.49157916318529 622.54738563779631 -882.84652613370065 171.36565301338834 628.56237504737351 -893.08314260521615 162.12532438094755 633.58230282820773 -903.63949449152744 152.92700367640111 637.65411209225408 -914.54515806937604 143.92219684744322 640.80715168689062
+-817.04586087054054 222.35709456536495 567.63171515824331 -825.38508024843372 217.38017221933615 578.89436637168956 -834.05436203389172 211.52634563823406 589.56836336950664 -843.00669905550399 204.79522427943019 599.55304365715392 -852.22148215518018 197.2079701425472 608.74166312291618 -861.68976207630431 188.83093387274843 616.9516664438986 -871.41443646591404 179.88192575056257 624.05464306081967 -881.41391115266617 170.63613189476951 630.05912808687333 -891.71929262275455 161.29371263472021 635.05652679521563 -902.36316130895636 152.01172118589747 639.09607303597465 -913.37245293365754 142.93915648756271 642.20887606708777
+-815.58600837106735 222.10287155577748 568.65602872782586 -823.89301740551548 217.0255789800257 579.97609336518394 -832.53386996753636 211.05707778781556 590.69218493830931 -841.46381355657695 204.20022437257893 600.70119441711267 -850.66444909334587 196.47943463174786 609.89423043302293 -860.13201475941798 187.97357553609439 618.0863605434289 -869.87511482248181 178.91286995797381 625.15861823976411 -879.91493895210817 169.57641224229226 631.13151563681947 -890.28180202776014 160.16164962992968 636.09909955386593 -901.00653016296519 150.82477068363838 640.11101044015777 -912.1138256171829 141.71135632112427 643.19704930835417
+8 0 0 6 10 -962.75722820414126 108.65464220286081 638.67004920255079 -961.96730577277413 109.14304984400323 640.49404976339838 -960.93840573772923 109.68545631576251 642.20770326266654 -959.69044967919501 110.26874310644111 643.74929574535065 -958.27793891934289 110.87566900919742 645.05584422931281 -956.77731018028283 111.47737797223284 646.12697937272446 -955.21831668143329 112.07324984462007 646.98816890643388 -953.63734029059958 112.6518223562245 647.65635655968413 -952.03975347143285 113.21252971428657 648.15581300163387 -950.44527914345997 113.75168371240319 648.49902201684688 -948.85936033769019 114.26802971900702 648.70208985965314
+-962.49351185110504 109.82452017179855 638.26747147540857 -961.75755984467082 110.27010049433633 639.96157584065566 -960.81248517280221 110.78285133725737 641.55215935080957 -959.67526487005432 111.35306590787962 642.98552370211519 -958.39356321795458 111.96264703904362 644.20878633811026 -957.03050318425915 112.58427725149349 645.22235651471169 -955.6128026030085 113.211259353847 646.04939424620568 -954.16908603928198 113.83235356641417 646.70597310008884 -952.70440517123143 114.44546967389493 647.21269380483 -951.23454838610769 115.04513276016412 647.58070286372151 -949.76372151367548 115.62945044752897 647.82376548600757
+-962.05693200486189 110.93513138474889 637.80590121770695 -961.38520370679407 111.33377099056375 639.35360515947389 -960.52977411060238 111.8113947416616 640.80369481017908 -959.50500331963292 112.36104628791679 642.10852412782037 -958.35373255034654 112.96350504350129 643.22390172676432 -957.12829990027012 113.59330389665556 644.15016012111403 -955.8542918936123 114.23833386266782 644.90919744385258 -954.55373164975617 114.88808266853864 645.51719540468582 -953.23217019397214 115.5392123129421 645.99096998600862 -951.90210592030655 116.18502952996332 646.34182167760196 -950.56694514970854 116.82332389374487 646.58160009911808
+-961.4550921754709 111.95276793475104 637.29694010749199 -960.85617816648744 112.30209700100814 638.685303124406 -960.09401658038428 112.73922943284668 639.98113524125358 -959.18053562797536 113.25932427227238 641.1412403443702 -958.1559364508139 113.84194802321048 642.1285948293206 -957.0625456656494 114.46397882333621 642.94341463441572 -955.92852421816303 115.10819873782322 643.60564467570669 -954.76853536313786 115.76577565804324 644.13342354155714 -953.59056513502719 116.43182473163969 644.53866234892428 -952.40430135416273 117.09914768057791 644.83414663978886 -951.21301516401377 117.76532181445899 645.0299391285555
+-960.70389986758084 112.84656564859274 636.75502452075318 -960.18408140626275 113.14610532710698 637.97543990006807 -959.51649802266559 113.53779550626662 639.10780185611236 -958.71075175805822 114.01834094607402 640.11223959233052 -957.80582477730184 114.56639961055834 640.95793947596871 -956.83517121953889 115.16145149343519 641.64456790684505 -955.83134038532501 115.78193932938389 642.19021921129081 -954.80222304838287 116.42130854441181 642.61544406408325 -953.7588829073801 117.07279429304316 642.92687062865218 -952.70899357430574 117.72931297746105 643.139383725176 -951.65615226274633 118.38811822335349 643.26127509647472
+-959.82674879301101 113.59186770357043 636.19624265768095 -959.3896074794302 113.84296936878259 637.2448132907499 -958.81575069566736 114.18507533940357 638.20949668945525 -958.11241898964897 114.61595909792784 639.05323363246612 -957.31790777579602 115.11408658629934 639.75114872956749 -956.45848447538071 115.6617094769402 640.30162323648142 -955.57079759472742 116.23432452489975 640.72202585943955 -954.65800986633246 116.82793901937842 641.03437042839846 -953.73352117950833 117.43385561686912 641.24066371215531 -952.80398163632651 118.04570760890833 641.35784606651293 -951.87343469321866 118.66034069873471 641.39254287040444
+-958.8517310144174 114.17195471901805 635.63671697516838 -958.49801473681271 114.37753106458074 636.51423692627111 -958.01507669598914 114.66702945196043 637.31202146244698 -957.40753417780252 115.03894232850057 637.99597579773524 -956.71333302000903 115.47245760455641 638.5470724320345 -955.95195602476997 115.95333874841077 638.96273639560309 -955.16488565355951 116.45539193911165 639.25951524442723 -954.35099193601366 116.97798895877051 639.46076505933047 -953.52595826254174 117.51041706893081 639.56412322248252 -952.6959211493031 118.04779202353936 639.58837833908922 -951.86538894739692 118.58659913230451 639.53855077512105
+8 0 0 14 1 -947.1241613153029 245.57939292374706 764.42164171888908 -688.35266769269094 400.32431937638376 440.61985338881095
+-934.06393987170122 206.44600443851078 756.15707861443968 -675.29244624908927 361.1909308911475 432.35529028436162
+-930.52830109491811 165.88549314523021 739.59876731717065 -671.75680747230615 320.63041959786693 415.79697898709253
+-937.80831580875281 127.76637801083692 715.56369330123766 -679.03682218614085 282.51130446347361 391.76190497115954
+-956.08229446322605 96.123902770140518 685.83780048147696 -697.31080084061409 250.86882922277721 362.03601215139889
+-984.23475399192534 74.617674181380096 653.06147204497609 -725.46326036931339 229.36260063401679 329.25968371489802
+-1019.8660835385303 65.960725516729099 620.44895527843664 -761.09458991591828 220.70565196936579 296.64716694835852
+-1059.531775307345 71.436215704616998 591.36620676509654 -800.76028168473294 226.18114215725367 267.56441843501835
+-1099.1974670761597 90.625868062652955 568.83745854719564 -840.4259734535475 245.37079451528962 245.03567021711746
+-1134.8287966227647 121.43928956761269 555.08783800014373 -876.05730300015239 276.18421602024932 231.28604967006561
+-1162.9812561514639 160.4514381675715 551.23325170533496 -904.20976252885157 315.19636462020816 227.4314633752569
+-1181.2552348059371 203.45714113213478 557.18173519390064 -922.48374118332481 358.20206758477144 233.3799468638226
+-1188.5352495197717 246.10315577705995 571.74432962227559 -929.7637558971594 400.84808222969662 247.94254129219752
+-1184.9996107429886 284.46511636993864 592.90308026734033 -926.22811712037628 439.2100428225753 269.10129193726226
+-1171.9393892993869 315.47732483226577 618.16110916773164 -913.16789567677461 470.22225128490243 294.35932083765357
+8 0 0 8 5 -929.75115871910702 228.61001043919126 515.63899645292634 -928.07146661989077 228.61001043919126 556.27466615542255 -921.66107363495144 228.61001043919126 597.42381996758786 -909.74053620476002 228.61001043919126 636.6613646897323 -892.24567570247507 228.61001043919126 671.77011304740734 -869.82757843394245 228.61001043919126 700.74078369140625
+-945.23093653834803 201.41993676228412 517.58513687910568 -943.92548712130713 200.61770604313728 557.16052288504761 -938.22237369630784 199.81547532399043 597.01694056950066 -927.58987063565712 199.01324460484361 635.32783343340895 -911.90499468556243 198.21101388569679 670.42011994485335 -891.33856407448025 197.40878316654994 700.74078369140625
+-959.60228982169713 173.84332955629731 519.39248485370365 -958.46298288659068 172.46368972142176 558.08439364185926 -953.22480964585043 171.08525866989174 596.97179999194532 -943.46751370928416 169.70806948292554 634.59869051946748 -929.00486306345101 168.33215524173872 669.61475505900171 -909.77655176636972 166.95754902754931 700.74078369140625
+-972.59039147959493 145.78682079219016 521.0348640489434 -971.43595204665633 144.07537225268777 559.05962549453977 -966.40948026197339 142.36670256583173 597.22121086287643 -957.15901674147665 140.66070587172558 634.30980327006455 -943.46184827699483 138.95727631047689 669.18375472147443 -925.14154150961099 137.25630802218936 700.74078369140625
+-983.8573664640237 117.23825898094776 522.48458262418444 -982.53227415231163 115.4448332958324 560.02255018089977 -977.51082074811779 113.6546523663748 597.64589192343396 -968.48078951478055 111.8678643964264 634.30773170244379 -955.19788770923424 110.08461758984052 669.0014286841315 -937.43353330420405 108.3050601504701 700.74078369140625
+-993.02772625603632 88.188229021644204 523.66032246324323 -991.4323861025739 86.565822569068871 560.876144043473 -986.26569484531547 84.946282841749621 598.12188952592703 -977.24639800066825 83.329503979794708 634.45874649457107 -964.12441722764413 81.715380123306744 668.96824435655537 -946.65252715014879 80.103805412391523 700.74078369140625
+-999.56258272107902 58.759562455871503 524.51882973841327 -997.69385384812392 57.535749406150146 561.53779763094587 -992.3410436033364 56.313107935281224 598.53695287691687 -983.24193425137696 55.091671124479959 634.64560743816196 -970.14492029726341 53.871472054965309 669.00039248487383 -952.79852304744531 52.652543807953641 700.74078369140625
+-1002.9679796958726 29.243607812800764 524.96541499772707 -1000.9306200887122 28.585141317671891 561.89478390137765 -995.45313081666905 27.926674822543049 598.77281296658748 -986.284675478228 27.268208327414179 634.76369444934005 -973.17441767187472 26.609741832285351 669.03162060561851 -955.87152099609364 25.951275337156446 700.74078369140625
+-1002.9679796950066 3.5527136788005009e-14 524.96541501342267 -1000.9306200868498 1.0658141036401503e-14 561.89478391391663 -995.45313081433108 1.4210854715202004e-14 598.77281297576553 -986.28467547599917 -1.7763568394002505e-14 634.76369445516582 -973.17441767040395 0 669.03162060831391 -955.87152099609375 -6.3948846218409017e-14 700.74078369140625
+8 0 0 9 9 -698.1987442049392 36.266876442455938 685.19143698548089 -694.88550000819725 32.963610130248505 685.11079305557553 -692.00091205362298 29.337652962674937 685.07843462053131 -689.54746289269065 25.760794435945339 685.00908451415739 -687.52160821837128 21.795369750114524 685.0307613139438 -685.85996360382273 17.794375595900931 685.01068804720944 -684.56682252954738 13.557434241015553 685.01603291494825 -683.65062602699697 9.2176924866896286 685.00586038640677 -683.15722771473816 4.694372274011875 685.0004404446214 -683.15313923511508 -0.0016866232395491565 684.99915578902937
+-698.18445097914935 36.287889475803468 684.90608235483455 -694.86758112227858 32.98176602863704 684.82471958585973 -691.98339886143219 29.35437607914978 684.79066161494313 -689.52299821589577 25.775103363478824 684.72298156866032 -687.50081625058442 21.806520893798638 684.74171013285752 -685.8344085889006 17.802623141573068 684.72197570390699 -684.54360511577465 13.564863462416625 684.72603568574209 -683.62549915981606 9.2225038615353423 684.71601765158493 -683.13182165819239 4.6970157190503334 684.71051361139337 -683.12765264048289 -0.0016209765113854857 684.7092984731197
+-698.13763759582855 36.341422666684409 684.6247513670022 -694.81372270165048 33.0293347237007 684.54268965994856 -691.92716252536627 29.398304378078166 684.50678976497147 -689.45990453952356 25.813457880125966 684.44090311868081 -687.4327641029754 21.835586805491388 684.45692768596268 -685.76804611448893 17.829286379946272 684.43699051454882 -684.47201257556537 13.583528970062922 684.44019756325781 -683.55381307039681 9.2363187426669082 684.43015977914968 -683.05895566931758 4.7040948768408457 684.42474701771425 -683.05472401150496 -0.0015151669872333073 684.42361265286718
+-698.05872825251174 36.426852385619895 684.3559128402004 -694.72445859537152 33.105774396268409 684.27323407011943 -691.83476738028889 29.46956775746882 684.2357296837389 -689.35295874055623 25.872748573183763 684.17218751434268 -687.32927538608294 21.887559349322181 684.18480224730445 -685.65159084667994 17.868290440748236 684.16558942761128 -684.358699907973 13.616766696805334 684.16734938711568 -683.43531799050334 9.2580028373536685 684.15762157486097 -682.93940792025273 4.7155287997450746 684.1520209314308 -682.93513364912872 -0.0013712045159929034 684.15097263814027
+-697.94943390292963 36.542268250893301 684.10787621620875 -694.60175084807815 33.209373234298724 684.02472266851566 -691.70526471714743 29.565715497747039 683.98534366768433 -689.21189267488387 25.955097393586744 683.92383884201058 -687.17782715868793 21.954358252835277 683.93408439603706 -685.50036530281818 17.926261372235729 683.91468583681342 -684.19815439283866 13.659212201555816 683.91586038776529 -683.27369232390004 9.2883286808765817 683.90618390638065 -682.77589463994616 4.7310555165314474 683.90104553945571 -682.77159834569648 -0.001192738284462881 683.90008227324813
+-697.8127293128365 36.684507096667481 683.88832336943233 -694.44896069080801 33.337279110667581 683.80489052760788 -691.54604013312098 29.684984266231883 683.76483216041697 -689.03347140056781 26.054610094276132 683.7057030614784 -686.9989764331383 22.041414036633501 683.71321137356711 -685.30581785812183 17.993659371036934 683.69468502891107 -684.00408179810051 13.714543028387036 683.69477025619165 -683.07307542199578 9.3251117685337395 683.68549625207015 -682.57302655965123 4.7502365189837628 683.67985433771992 -682.5687277256161 -0.0009849429261045697 683.67896888215864
+-697.6527213590532 36.849295786112691 683.70385010251925 -694.27069820885492 33.485628730211104 683.62037388619251 -691.3577902486511 29.822898357914575 683.57891542737048 -688.82828918141354 26.171361390404815 683.5216561609534 -686.78332793318543 22.1397259995178 683.52770751718401 -685.08400305841496 18.075163279376998 683.50936202610433 -683.77372645972719 13.776847707514891 683.50918707342453 -682.83915418924983 9.3683339979713462 683.50013307056645 -682.33709605866761 4.7724771076893058 683.49530803457606 -682.3328114978633 -0.00075426083419159544 683.49448776447161
+-697.47441619023994 37.031493476738561 683.55959219757779 -694.07255980769048 33.649767826581758 683.476332073447 -691.15040161652564 29.975689913403407 683.43526764281921 -688.60030374674147 26.299630390377917 683.37978904606109 -686.54901830288213 22.250459750142792 683.38474345665634 -684.83618255903036 18.163582335833436 683.36712124698954 -683.52157083042005 13.846995924770582 683.36666527497835 -682.58087904358433 9.4158541746582127 683.35800820633835 -682.07570876376724 4.7970612259408316 683.35269287613164 -682.07145137411271 -0.00050802514462105434 683.35192101445682
+-697.28341477217259 37.225402619977132 683.45898343770443 -693.86078693247691 33.824534377793768 683.37620356637365 -690.92733394551101 30.138120418839865 683.33501830432624 -688.35700404732631 26.436454397951568 683.28083923464135 -686.29646879675045 22.367677927363687 683.28575333732022 -684.57241025883388 18.258505379279985 683.26865043559462 -683.25093009524414 13.921157685826334 683.26843344535462 -682.30480067653332 9.4665230368874589 683.26012743410945 -681.79730768111915 4.8231961941042965 683.25546581502113 -681.79308567003977 -0.00025401257144546611 683.2547229985953
+-697.08558824455179 37.425096651918736 683.40366555920457 -693.64190383117045 34.004557197652019 683.32161629877385 -690.69759245359501 30.305324956399595 683.28151670582122 -688.10655688904285 26.577243740242082 683.22824724118186 -686.03723153155079 22.488638619401172 683.23393523891377 -684.30086340519654 18.35602599518689 683.21739082338172 -682.97309538740672 13.997621554238501 683.21777124621258 -682.02110828370019 9.5186067451911818 683.20979670787835 -681.51067226494979 4.8500595402215509 683.20516745713257 -681.50648887109628 3.7554402946768373e-12 683.20443339018027
+8 0 0 13 1 -769.82095970706894 -35.355339059327413 699.9260149150881 -779.13925690789051 -44.673636260149365 549.30007380992208
+-761.27695405676434 -43.899344709631897 699.9260149150881 -772.84712002913 -50.965773138910102 549.30007380992208
+-750.49613295785764 -50.206534911334174 699.9260149150881 -731.07652987799031 -87.083660338278008 549.30007380992208
+-738.11732940860009 -53.638076666182904 699.9260149150881 -804.28163260242991 -2.5731067254113498 549.30007380992208
+-724.98007171266079 -53.75583228134446 699.9260149150881 -610.70535427830691 -179.69864788343099 549.30007380992208
+-712.05443558636432 -50.392323231554208 699.9260149150881 -823.24479939794901 53.424056542928696 549.30007380992208
+-700.34390017922306 -43.693625665910041 699.9260149150881 -640.12134841283455 -106.44050646451259 549.30007380992208
+-690.77199498183165 -34.121720468518532 699.9260149150881 -628.02511418329368 -94.344272234864007 549.30007380992208
+-684.07329741618753 -22.411185061377218 699.9260149150881 -787.88967719066568 88.779178750163538 549.30007380992208
+-680.70978836639733 -9.4855489350807396 699.9260149150881 -554.76697276438836 -123.76026636946827 549.30007380992208
+-680.82754398155896 3.6517087608586021 699.9260149150881 -731.89251392239271 69.816011954446509 549.30007380992208
+-684.25908573640777 16.030512310116144 699.9260149150881 -647.38196030938934 -3.389090770590343 549.30007380992208
+-690.56627593811015 26.811333409022829 699.9260149150881 -683.49984750808471 38.381499378870132 549.30007380992208
+-699.11028158841475 35.355339059327306 699.9260149150881 -689.79198438474805 44.673636253454418 549.30007380992208
+8 0 0 9 14 -784.92315203079806 0.00059618319304277634 694.72239466921019 -784.92679201334192 11.765670448574999 694.72103695375552 -782.03183013739226 21.110206306989486 694.19775676335814 -777.91271483282219 29.260347798750047 693.3876907799596 -773.59539549669648 35.179933564581354 692.78466543455954 -765.65459340457198 42.391488126909323 690.72609086984539 -764.64302262841147 43.532013366803362 692.0163554599427 -749.21758926401662 51.433876361477374 687.38916303794713 -753.04579916104763 49.076906926689929 690.90520506199243 -734.31538748168873 54.355787440492506 685.67507628431486 -735.56828902626955 52.389629556362543 688.02323529590763 -721.93257570105914 51.788397771162707 685.85775807326013 -715.60123191862408 49.251388231919393 685.79251696338747 -706.495382258218 44.538529047482982 685.39337606930974 -698.19874420461906 36.266876443284637 685.19143698574771
+-784.95221794699091 0.00058849909165006561 694.39183214777483 -784.956073632124 11.758948542381475 694.3906482838097 -782.05888002787049 21.101367182482662 693.87056321453088 -778.00099040869975 29.225870438202875 693.06800313425015 -773.45090929853211 35.212254108176502 692.4559875928785 -766.17861687613026 42.351927077743831 690.46684629741276 -763.89782841509373 43.480668828947884 691.62033568130732 -750.21833625447061 51.66042021957427 687.22834957372743 -752.25196017576422 48.751378815697635 690.46280296560246 -734.89270192504478 54.713939829889505 685.51178014091158 -735.33740335327661 52.215221098294528 687.67152506438481 -722.02987102263762 51.897430829726758 685.59594001808921 -715.58842267414491 49.266365528124631 685.50720176288394 -706.48992638778236 44.566455913141645 685.10981397337696 -698.18445097910444 36.287889476653334 684.90608235502589
+-785.04298627474441 0.00056235105664173243 694.06669503651403 -785.04700089037635 11.766734854867218 694.06572318627127 -782.16077276780675 21.105369208616835 693.54805075222146 -778.00027716983072 29.301017450014385 692.75503725036685 -773.88492522642412 35.081451658487985 692.12949105593464 -765.43042064819326 42.670621817215135 690.20954035360694 -765.37319803572257 43.230557595347726 691.24985829880575 -748.5985710183262 51.911718543255347 687.02789867740137 -753.76379712036351 48.769984291135657 690.07659826172028 -734.05041681014188 54.765066365285442 685.31265297115795 -735.70872656951815 52.315392949424258 687.34413746087944 -721.95724184529058 51.971351154355872 685.33131032030758 -715.57828872488233 49.337102863521338 685.22686562153308 -706.46037008868086 44.634542610146546 684.83022241945935 -698.13763759576807 36.341422667616655 684.62475136725402
+-785.19429964183621 0.00051804505994113015 693.76014596470895 -785.19840890409114 11.789296938220804 693.75940513744513 -782.29165326317161 21.15359425214314 693.24439250234161 -778.25774990622642 29.307999610454491 692.45744454651151 -773.55666405066358 35.271336475663077 691.81935553601363 -766.67189365671288 42.613925323945814 689.98662821915946 -763.57442289846415 43.322395807458356 690.83674780152842 -750.98625646185621 52.336236767944435 686.94131378300017 -751.78389819123709 48.313089825697013 689.58964084570175 -735.42388693444013 55.458670108033644 685.21683066600031 -735.10348399990835 52.080005673098547 686.98152712125261 -722.14983689155406 52.235254173243611 685.09509769567421 -715.51137954699379 49.422920629059334 684.95636475008416 -706.40687015806577 44.741967784243492 684.56291537058951 -698.05872825157678 36.426852386556348 684.35591284028737
+-785.40172536470641 0.00045686718495790361 693.48505898789438 -785.40586352832668 11.826132430003959 693.48454729067146 -782.5048998205956 21.204977710649985 692.97002406752063 -778.31444359253078 29.477551341411491 692.19079038192604 -774.20765487258916 35.152196891836063 691.53655577685583 -765.64375790778331 43.131062879852465 689.76871759843459 -765.66138368166912 43.058057662744162 690.51286261694679 -748.73319322207544 52.724686724523785 686.76321761912141 -753.86981489954383 48.459783835856328 689.25546605595218 -734.26681940452863 55.541185492347701 685.03970143355195 -735.5817008209558 52.30779711017334 686.69247560951476 -722.03720962706223 52.388736304457325 684.86135996813937 -715.46599948739777 49.573844050391493 684.70833861551512 -706.33052163387822 44.886336531322698 684.31605145627168 -697.94943389906712 36.542268252089777 684.10787621631437
+-785.65763814485615 0.0003810618693525687 693.25304456422566 -785.66174455134671 11.875948184855723 693.25273975773132 -782.73314839752629 21.299936287614816 692.73909355925241 -778.64578157915832 29.560325380117277 691.96269388338249 -773.98676061132369 35.387873825273871 691.29370531470681 -766.84410327858359 43.205162515916903 689.60204812765369 -764.05456841560078 43.179732645523359 690.17102193388894 -750.98127988159774 53.278024238075233 686.71309128378596 -752.02724252494932 48.074537512238138 688.84368289320776 -735.59296529104836 56.32037435336553 684.97750026069309 -734.96887752113071 52.153112065160855 686.38821943257278 -722.22088273382144 52.739179259807308 684.6714244256865 -715.36274476964343 49.731001876119365 684.48643869535238 -706.23334964341018 45.063724718762145 684.0971799014618 -697.81272929480997 36.684507098362005 683.88832336952851
+-785.95167894666281 0.00029369761899644681 693.07349435315018 -785.95570400997963 11.936727590288427 693.07335694992219 -783.01732510131819 21.398463050371927 692.5575690999425 -778.82950227819697 29.761578534759138 691.78311704993791 -774.4662997864607 35.403785476743259 691.09985686018763 -766.40932251675679 43.692130667098539 689.45210406705564 -765.23829092631502 43.050158553725431 689.93532947076244 -749.88939277672614 53.802750135821526 686.59390270466474 -753.1049613278243 48.130239349334815 688.5881732009218 -735.09644143114895 56.657054103417977 684.85654818624778 -735.13289293641571 52.33573366728988 686.16659355057186 -722.18202952483898 53.010483792339414 684.49896137967323 -715.27269556269937 49.936478985542053 684.29985944950545 -706.11822347885004 45.268855155331153 683.91279588371845 -697.65272129681443 36.849295787649297 683.70385010231678
+-786.27154770867355 0.00019843219469903612 692.95286253127642 -786.27545729672738 12.005885114314971 692.95284090083317 -783.31278741043309 21.521136144882956 692.43511023970916 -779.13980045086873 29.930495903102525 691.65877988888144 -774.55876661566492 35.585543555360779 690.96207800538866 -766.97284363302458 43.988666793143011 689.35260387572623 -764.77100402014935 43.102564743460974 689.73777031899454 -750.81202280594232 54.407643771506301 686.54458194393123 -752.42271699200205 47.959633001780098 688.34958894781289 -735.71238056790844 57.310618221933979 684.79785568850775 -734.8048403786795 52.356917717917796 685.97644700289891 -722.27415256484392 53.377372420485017 684.37088524813339 -715.15318956872068 50.1519642577246 684.15303659142944 -705.98869683773603 45.495393861049699 683.76797687844703 -697.47441602274557 37.031493479298881 683.5595921968652
+-786.60399881635954 9.9216097220041391e-05 692.89430245732945 -786.60777636628757 12.080482217068775 692.89433896600929 -783.62407455762582 21.649393600859739 692.37219099088202 -779.41237443079933 30.136745136209221 691.59128506168724 -774.83305437619231 35.717389421470422 690.88416050409614 -767.11071962887081 44.400792441988813 689.28554975838767 -765.02644939555296 43.098779037811845 689.62969620789352 -750.86640217933552 55.01264947743686 686.48405634605228 -752.49312237208449 47.915030100081431 688.21992568933751 -735.85446316707123 57.855484981495252 684.73259660502174 -734.67203760723339 52.475700926567804 685.85508168014485 -722.304478069364 53.731760472227414 684.27637155738626 -715.03119455456772 50.38773708318984 684.04886122102403 -705.84879407078324 45.73632914559925 683.66614555811168 -697.28341439480448 37.225402619318601 683.4589834363793
+-786.93581954022682 2.8421722982931164e-14 692.89767965507815 -786.93946598632306 12.157453842999534 692.89771676779856 -783.93340088497871 21.783287972272259 692.37075800094635 -779.69846632528981 30.341754614533983 691.58271495629401 -775.05225723312446 35.876337716217208 690.86667875295393 -767.37923606404684 44.789927276117638 689.26272550260649 -765.05738645781946 43.127999951948382 689.59176577305357 -751.1879184072294 55.628278244827825 686.45036283123022 -752.32415043420428 47.851521768356854 688.16502724329621 -736.14264523902114 58.442908477257326 684.69194191134636 -734.47040294132478 52.581209468473183 685.79176439768958 -722.34867758073142 54.102780864938048 684.22342916418256 -714.90196642809053 50.629899944160577 683.99003466292004 -705.70277817500005 45.984370678184419 683.6089788168747 -697.08558747747065 37.425096618368485 683.40366555739877
+8 0 0 9 14 -770.30404092207141 -35.838420274242154 692.11723171518258 -762.08253320887786 -44.230532739857125 690.73835847055022 -753.16499456761676 -49.002488767871199 689.43858182728331 -746.02878212414419 -51.697186700097319 688.11676227571456 -734.69363912175174 -52.680754393055885 687.98897519633874 -731.47310952894065 -53.452843343235912 685.45726444251909 -718.86942234355024 -50.893183456636066 687.42373845076588 -716.14192663850281 -49.666203638360109 684.41701872647445 -705.9905119509549 -45.430156200930959 686.24137447196358 -701.39375335759951 -41.453267092449622 684.63631439959511 -695.08838193272709 -36.001991718155743 685.21553957121228 -690.20399929821815 -29.290903800406198 685.01299616573419 -686.10978260936031 -21.264738720337757 685.02703326526148 -683.14282544299431 -11.848187746260486 684.9959150664331 -683.15313923601593 -0.0016866233825361121 684.99915579957531
+-770.3484489156956 -35.832661892210005 691.80485521581227 -762.13070061650535 -44.232148493851398 690.43525644884892 -753.2160727305062 -49.003380381010196 689.13786800482114 -746.04367347360278 -51.768563923223248 687.85409103408756 -734.81029539537383 -52.578610515058841 687.62602536897691 -731.30298377001532 -53.682486986691849 685.30561624633356 -719.19624835981699 -50.73620614954352 686.98700744903465 -715.7598834988795 -49.803956740273655 684.27044827536577 -706.32137298307941 -45.436207194330343 685.86335181427421 -701.17629560357216 -41.461636514101734 684.40223173270522 -695.15008302998433 -36.041816403907198 684.91488762688311 -690.163454933352 -29.295389596582886 684.7272842095183 -686.08920816660191 -21.27798347549254 684.73754668411698 -683.11713565133459 -11.854657513304254 684.70623311271379 -683.12765264161408 -0.0016209767991640768 684.70929848326864
+-770.43231559878882 -35.866362199646773 691.49736084753999 -762.20654591449636 -44.280607727389153 690.13677698610456 -753.27655091289694 -49.057960088206485 688.84158877642994 -746.14174163216285 -51.855343504121223 687.59519265957078 -734.64025442323646 -52.613822810403938 687.26723165223837 -731.81149405781014 -53.838441474727112 685.15841858595161 -718.40741452958707 -50.680622067565658 686.55143014152736 -716.62525727358184 -50.07568623581971 684.13543027181345 -705.58063776286951 -45.277251121281402 685.47645701573845 -701.55066881126152 -41.710589858090984 684.18420488021775 -694.92257595517094 -35.993876556526672 684.61139942478769 -690.14805462957816 -29.368139370214109 684.44778066771664 -686.01562620771347 -21.304273717640235 684.45160590478361 -683.04404895806249 -11.872195464382232 684.42075104682942 -683.05472401252803 -0.0015151672821285761 684.42361266255216
+-770.55404182189511 -35.939728558172504 691.20599741194815 -762.30842374302165 -44.375840705192587 689.85320843324416 -753.37577153918153 -49.14900610373428 688.55853068910051 -746.10266387224692 -52.048694577252569 687.35631164342612 -734.9714659839002 -52.5546235889813 686.90122384234667 -731.19771283348609 -54.231972240135526 685.06090052807986 -719.35026567292743 -50.565431965589255 686.08426174627243 -715.50741915337915 -50.281631954527853 684.04668923632062 -706.42633971858163 -45.438882404916853 685.08704746145884 -700.95001696970337 -41.711103359814729 683.97957366746755 -695.04607171482064 -36.145860810186917 684.32416698002748 -689.99348781981689 -29.408460028431403 684.17916536644418 -685.91133337291296 -21.359975706617739 684.17924422830288 -682.92435103531534 -11.900603480899154 684.14832814900114 -682.93513364964406 -0.0013712048740748698 684.15097264734914
+-770.71013415554683 -36.051073988882436 690.94177895236407 -762.43346519849672 -44.515634293286091 689.59463021568899 -753.47055730479906 -49.296571190258696 688.29983642751222 -746.21108538924989 -52.223394846226178 687.13032193045831 -734.77285288300357 -52.706197984197154 686.57930429620126 -731.80819223996048 -54.441989152995575 684.94288222452883 -718.31348452277075 -50.60965413658262 685.68292514112875 -716.61631279313906 -50.666997676699829 683.9438342906268 -705.395790483827 -45.292591724032093 684.73012408234126 -701.41739983462833 -42.092916831988596 683.79663458895561 -694.68917999156145 -36.12190094428145 684.05227774331172 -689.91626328104519 -29.545100549121017 683.93374316222651 -685.75043198847538 -21.422174340241067 683.92736173553521 -682.76076009821213 -11.939231747355729 683.89765226375027 -682.77159834503175 -0.0011927387238615996 683.90008228210911
+-770.89531074810816 -36.196801974326668 690.71473080081512 -762.5776819409964 -44.695636111889058 689.37026460731181 -753.60131233995389 -49.472907552650881 688.07382033292811 -746.16561977007996 -52.502210835644192 686.93771258774677 -735.12910428036423 -52.743129566892527 686.2789124266784 -731.16632774427148 -54.898463877540763 684.87097963234385 -719.22001213483838 -50.584403829420332 685.28969631196094 -715.50421117954579 -50.955801202812289 683.88209490575161 -706.15409284889677 -45.504383979808978 684.40317671947571 -700.79702166329253 -42.179179049439689 683.63406854439938 -694.73733414377523 -36.316759937279514 683.81676084196874 -689.69421063031166 -29.637081485113381 683.71558036077204 -685.56789366195392 -21.512043870653759 683.70649403032064 -682.55788298062134 -11.986989724290867 683.67673514579917 -682.56872772024417 -0.00098494359782328573 683.67896889084227
+-771.10280364960681 -36.371586356909745 690.53315125521067 -762.73618575663863 -44.90956840631803 689.18784269853666 -753.72549178011934 -49.69190617007196 687.88790543054074 -746.22388369716373 -52.768045422426894 686.76943816762366 -735.10001142122564 -52.93613988284752 686.04464020605087 -731.40422859531793 -55.21958595990391 684.77747520997843 -718.69823514774407 -50.680323563100714 684.99399746653546 -715.9929720899886 -51.370706100247375 683.79978865233477 -705.55917867844209 -45.498552018017996 684.13992856523885 -700.94323098413997 -42.539351206090508 683.4941131832494 -694.43758387795094 -36.386475478392867 683.61579465109287 -689.52548008725 -29.79909389576844 683.53296103121568 -685.34235152704036 -21.60711516299849 683.52049942118288 -682.32200265722531 -12.042396693644539 683.49241845084362 -682.33281147843422 -0.00075426152166104194 683.49448777296868
+-771.32482618158633 -36.568739143838386 690.40303852926297 -762.90349929872775 -45.149640664571237 689.05310325392679 -753.86617004193772 -49.93234364184751 687.74905388677746 -746.21189509753663 -53.087871366420664 686.64010697899096 -735.31902369659531 -53.0891769855508 685.86444948152462 -731.07814781594027 -55.653716062568556 684.70631377508857 -719.04452400006687 -50.758502092171575 684.75994306704911 -715.48387292578741 -51.745136878776847 683.73708261839636 -705.76051193220189 -45.662729531577895 683.9363564712794 -700.59831017147428 -42.771898311403802 683.38150933146221 -694.31363858648285 -36.560079593257718 683.46254063538845 -689.28582537701368 -29.94549765321355 683.39101009908256 -685.10053520675297 -21.717867714532495 683.37775727426867 -682.06071096699429 -12.103668491793753 683.34997380003927 -682.07145132446647 -0.00050802605561707363 683.35192102258623
+-771.55313472219507 -36.780710634477899 690.32776957674457 -763.07391493361774 -45.407101399120471 688.96949563208284 -754.00285159250791 -50.192875090215743 687.65914126909263 -746.22340167033587 -53.412284099628756 686.54559258969061 -735.43425040522231 -53.294325848331638 685.75477514905037 -730.97627718369449 -56.056691616280624 684.63003457747334 -719.01390208678436 -50.880882828875158 684.62336142632864 -715.38603773707075 -52.156975773489719 683.66627756728394 -705.60248135796598 -45.779298129409909 683.80841665509047 -700.44647536926084 -43.081597517649364 683.29376237111694 -694.09130452546481 -36.706972512787438 683.35695206498019 -689.05168613486376 -30.114946668682247 683.29179775053728 -684.83868503354142 -21.833395615249412 683.27907816632921 -681.78243440493884 -12.168829005227405 683.25284903509669 -681.79308558203127 -0.00025401488172644484 683.25472300463798
+-771.77957506491987 -36.999617891710855 690.30805435075911 -763.24183981938529 -45.672820899289384 688.93811041819015 -754.13830620055603 -50.461739597795187 687.62092130959809 -746.22375747826766 -53.748088697089685 686.49119539514345 -735.57626140879358 -53.50222191744642 685.71306458129663 -730.80087915125728 -56.475543238919045 684.56326301629201 -719.09004334335305 -51.010874925582485 684.5731373221746 -715.15698595777053 -52.56388307018856 683.60393038414827 -705.54290218366373 -45.926091384103692 683.75171265447966 -700.22774464991141 -43.376345041022766 683.23717119280695 -693.88751283338377 -36.872031406739175 683.30196898124973 -688.80423182888228 -30.284914168360594 683.23864873639707 -684.57032515487322 -21.953028378955988 683.22780987682518 -681.49593495703868 -12.235826965283179 683.2025814695802 -681.50648879638845 -4.4677896936544045e-09 683.2044333852499
+8 0 0 7 5 -1357.2998046875 -152.22468073184598 559.93245673270815 -1283.6655933027223 -163.03339146965652 553.08360843908508 -1209.662765738673 -173.96615769083309 547.69813442913551 -1128.415013762901 -146.52596125584853 508.89153599901374 -1057.8012596275194 -173.64102351793142 530.28227105259521 -986.57797451185866 -194.43240880978578 539.26525452135729
+-1357.2998046875 -158.52184632535329 553.36840639429715 -1283.7300697455803 -169.47766861565998 546.05851915364917 -1209.8349310165379 -180.43029084423611 540.21100444195281 -1128.3520752502718 -147.51188067361639 502.69185418196372 -1057.8442922006413 -174.9135299148723 522.92306431784073 -986.57776895982317 -195.94757028740116 531.00159364622243
+-1357.2998046875 -164.12241870080524 546.13608530547162 -1283.8093829613942 -175.23619315708845 538.26335527120932 -1210.0479324237972 -186.23538320432473 531.8398969545409 -1128.2517472303182 -148.23798979983334 496.0664669711411 -1057.8818044227048 -175.86196999434259 515.18112786228596 -986.57764200693964 -197.06342498507266 522.45960890167237
+-1357.2998046875 -168.94106445767341 538.32407778743209 -1283.9041795315838 -180.23746565084721 529.83217772421767 -1210.2982458127181 -191.32042336084618 522.77344186099606 -1128.1038628542051 -148.67926715508722 489.06011199008833 -1057.9119904128638 -176.48396740439 507.09715365746524 -986.57759578743253 -197.80777176330517 513.67739540956518
+-1357.2998046875 -172.9072534829333 530.03490884053986 -1284.0197242517766 -184.45087606583095 520.89363518395817 -1210.5914277623806 -195.69801475816755 513.17013139869346 -1127.9043297177836 -148.82922570610435 481.74252629771627 -1057.9348667805093 -176.78919512825843 498.73091883900298 -986.57762849455219 -198.21078591935549 504.70009910313388
+-1357.2998046875 -175.9670391052282 521.38132421140483 -1284.1653629501943 -187.86304721396749 511.53597807120957 -1210.9445317414286 -199.39972456742939 503.07446371473662 -1127.6539877628284 -148.70193667083277 474.18377729198306 -1057.9511977260695 -176.79953519376102 490.14538417864719 -986.57773513209247 -198.30415961003311 495.57764890123894
+-1357.2998046875 -178.08483824903294 512.48257045997389 -1284.3526437349112 -190.41900283709421 501.8320666051244 -1211.3736254389007 -202.3668016158889 492.49207192917845 -1127.3558176699846 -148.31827890342356 466.45223219459314 -1057.9618498162215 -176.54098204787871 481.40441261517446 -986.57790826590747 -198.12024227450098 486.36248888262026
+-1357.2998046874998 -179.24521158881785 503.46067502661867 -1284.581194091712 -192.04166980531758 491.8854269881391 -1211.8625834959234 -204.47007738616708 481.5201172646336 -1127.0149440528294 -147.7040937868492 458.61133304318753 -1057.9677225174655 -176.04230709942885 472.57017187666241 -986.57813877542912 -197.69118105707625 477.10731046014922
+8 0 0 7 10 -1185.9733651956262 -158.12825347020191 516.01820227193969 -1202.6378921254554 -159.63605632109352 518.15734424779328 -1219.293054530724 -161.2474734984516 520.29520323788984 -1235.9570903242657 -162.75541046205748 522.43475211215309 -1252.6561536678662 -163.92344231582362 524.57705038752692 -1269.3973700807796 -164.51623472195362 526.7281110666944 -1286.209441642297 -164.27410290328748 528.88402078335321 -1302.9567211615654 -162.99161670631133 531.03525339871294 -1319.557647862955 -160.8455600301856 533.16563241392669 -1336.0807760027183 -158.18934876756472 535.28673796911994 -1352.6044387529221 -155.53877091851305 537.40779772361452
+-1185.6381426846974 -161.89420672683994 515.97517107106876 -1202.2897394383888 -163.31294906697443 518.11265320921586 -1218.9686938814486 -164.85280105776607 520.25346169527279 -1235.6926254249017 -166.3107607036994 522.40108246969396 -1252.4909990036051 -167.44777156732539 524.55565588086506 -1269.3626651497148 -168.02533269746027 526.72339554218593 -1286.3436115600518 -167.7832587224469 528.90184245210469 -1303.2723392081543 -166.49498083527536 531.07530666180571 -1320.0236389357035 -164.34994490396116 533.22558855740363 -1336.6361433118564 -161.70066787122752 535.35802937277504 -1353.1602492735399 -159.06078645248581 537.47914384561329
+-1185.4091015091103 -165.66016104711525 515.10495613464536 -1202.0428515472979 -166.98984287322702 517.27907996391673 -1218.7416300341035 -168.45811965809276 519.45390035030528 -1235.5224051724958 -169.86611268252884 521.63261874721582 -1252.4182367551907 -170.9721913167084 523.81565783638621 -1269.4188579823333 -171.53420450406003 526.00920767493301 -1286.5686996290408 -171.29268274560425 528.2123806960102 -1303.67938641723 -169.99818013942715 530.4026628734922 -1320.5824276678416 -167.85437632292016 532.56271672211358 -1337.285408949306 -165.21198837476391 534.69782766182573 -1353.8105213670499 -162.58280295009973 536.81460847284484
+-1185.3058066832402 -169.2062868517167 513.41009185359724 -1201.9166429034249 -170.46228285937494 515.6591358595507 -1218.629076789698 -171.87086875830275 517.89875168044625 -1235.4598320714304 -173.23722892040132 520.13108107358096 -1252.445929424518 -174.31798591373251 522.35812215991996 -1269.5673348961866 -174.86714916846572 524.58575589777752 -1286.8781893617199 -174.62719576585138 526.81479136771236 -1304.1622823244459 -173.3250033248257 529.01536815730276 -1321.210322030116 -171.18009367076488 531.17398994267819 -1337.9999011130697 -168.5420491067932 533.30247083241306 -1354.5263890988501 -165.92191730891818 535.41050154732318
+-1185.3385589874915 -172.31261130248586 510.96538463140638 -1201.9221193366275 -173.52569877614468 513.32092538518918 -1218.6404865332408 -174.89839135895684 515.65076589377304 -1235.511010605017 -176.23979206295198 517.95514888377704 -1252.5751351534252 -177.30637432662135 520.23863033876762 -1269.8026748586399 -177.84844358215514 522.5064343549252 -1287.2587744505643 -177.61157154469831 524.76107608518487 -1304.698570917679 -176.29922617150098 526.96507175928639 -1321.8765428562988 -174.14829262854775 529.11154599662132 -1338.743681840127 -171.5095245491695 531.22481881456758 -1355.2716275325315 -168.89513970651223 533.32035337293246
+-1185.5053822630664 -174.79170971189484 507.91833949997783 -1202.0590452556337 -176.00424954640874 510.39844904940827 -1218.775166688906 -177.37399347192485 512.83347319519839 -1235.672958674427 -178.71358866752689 515.22075965325052 -1252.7988358046969 -179.78142686652441 517.56766045614961 -1270.1124295517707 -180.32456263993896 519.87833660747003 -1287.6910733382035 -180.09258045741475 522.15674672474915 -1305.2607707122443 -178.76693129601466 524.3578468925981 -1322.5461876427503 -176.60313963316571 526.48365519913239 -1339.4772254078659 -173.9567182162626 528.57528216487947 -1356.0063938276899 -171.34351212336432 530.65590998473738
+-1185.7923462790131 -176.51932719919591 504.4650605817011 -1202.3159658078093 -177.77800346012714 507.07092923985408 -1219.0223953851955 -179.18159799585629 509.61295179071482 -1235.9340807018407 -180.54549278166957 512.08449727605625 -1253.1029780281408 -181.6319808010403 514.4950649872053 -1270.4789213685813 -182.18555261491886 516.84732428557584 -1288.1523291039646 -181.96029474891398 519.14611696744498 -1305.8201963455574 -180.61807278089049 521.33930439066069 -1323.1851800528675 -178.43390401868473 523.43932231837073 -1340.1630859662894 -175.77217481937976 525.50597922106556 -1356.6929581938052 -173.1549727037316 527.57105971224792
+-1186.1770003278455 -177.44160575830938 500.81840824792567 -1202.6730771649422 -178.79034131995533 503.53491466492534 -1219.3639537094598 -180.26311180466689 506.17282733990186 -1236.2765657177381 -181.67670997751003 508.72057755492108 -1253.4689068452201 -182.79877055867215 511.18843353358523 -1270.8818349932778 -183.37204067262175 513.57715659219707 -1288.6193111123105 -183.15507782498892 515.89168626786852 -1306.3502792559473 -181.79345565841982 518.07363546625982 -1323.7640158214194 -179.58197742930798 520.14649280269771 -1340.7699343332081 -176.89776850067648 522.18817481554015 -1357.2998046323969 -174.27152323881714 524.23884403374404
+8 0 0 8 1 -1370.4053730055323 -253.96081542968778 539.692814594933 -1370.4053730055325 2.0463630789890885e-12 539.692814594933
+-1374.9885803101872 -253.96081542968778 540.28113793979639 -1374.9885803101874 2.0463630789890885e-12 540.28113793979639
+-1379.4682244830533 -253.96081542968778 541.67624773339071 -1379.4682244830535 2.0463630789890885e-12 541.67624773339071
+-1383.6786162184353 -253.96081542968778 543.85687527018831 -1383.6786162184355 2.0463630789890885e-12 543.85687527018831
+-1387.4593105392946 -253.96081542968778 546.7609213883344 -1387.4593105392948 2.0463630789890885e-12 546.7609213883344
+-1390.6676638596186 -253.96081542968778 550.28705274948118 -1390.6676638596189 2.0463630789890885e-12 550.28705274948118
+-1393.1908329756645 -253.96081542968778 554.30154557316962 -1393.1908329756648 2.0463630789890885e-12 554.30154557316962
+-1394.9535928138578 -253.96081542968778 558.64967402165519 -1394.953592813858 2.0463630789890885e-12 558.64967402165519
+-1395.9209712992022 -253.96081542968778 563.16809104774381 -1395.9209712992024 2.0463630789890885e-12 563.16809104774381
+8 0 0 1 1 -1370.4053730055321 253.96081542968824 539.69281459493288 -744.96835327148426 253.96081542968821 459.40859985351551
+-1370.4053730055318 -6.1959326558280736e-12 539.69281459493288 -744.96835327148426 -6.1959326558280736e-12 459.40859985351551
+8 0 0 7 5 -1370.405373005176 -152.68650657912542 539.69281459488718 -1366.8450959183133 -153.25645274458819 539.23579967385911 -1363.2848546361661 -153.82662698435121 538.77878965536991 -1359.724655180695 -154.39706590356141 538.32178468170594 -1356.1645033312855 -154.96780613699241 537.86478554809855 -1352.6044047102887 -155.53888434028462 537.40779353585242
+-1370.9622558543178 -156.22250080110337 539.76429885483503 -1367.4016405542372 -156.78914951014096 539.30724048874856 -1363.8411267343874 -157.35629074975614 538.85019546748572 -1360.2807170236474 -157.92395009868238 538.39316350152785 -1356.7204138721088 -158.49215327892429 537.93614496162286 -1353.160219613598 -159.06092611664883 537.47914070878142
+-1371.6143418120757 -159.75849502434227 539.0941236417766 -1368.053212259143 -160.32184627096152 538.63839322231149 -1364.492264509867 -160.8859545064864 538.18257050107934 -1360.9314971238962 -161.45083428480743 537.72665998408399 -1357.3709085715129 -162.01650041560885 537.27066669200144 -1353.810497265388 -162.58296789527887 536.81459602739449
+-1372.3324822259328 -163.10941921668132 537.67856327907521 -1368.7707336428082 -163.66998643238568 537.22554238578914 -1365.2092538377315 -164.23153113879849 536.77220724754909 -1361.6480385609873 -164.79405163818399 536.3185531719887 -1358.0870791059972 -165.35757974855653 535.86464621632967 -1354.526371163003 -165.92210322080408 535.41046954440174
+-1373.0800565159311 -166.09012461205751 535.57200235467735 -1369.5176847126706 -166.64894178901878 535.12286271912058 -1365.9556648700661 -167.20887133336066 534.67309049527569 -1362.3939859365671 -167.76989606860954 534.22270466815246 -1358.832640846925 -168.33206478387655 533.77176680335185 -1355.2716185906684 -168.89534940536339 533.32028305535084
+-1373.8167671141325 -168.53993797735055 532.88799383997389 -1370.253876411557 -169.09843245976148 532.44348777668085 -1366.6914061968025 -169.65805595455976 531.99797001763977 -1363.1293435748817 -170.21881075987713 531.55148642472443 -1359.5676757146036 -170.78069877644811 531.10408231487236 -1356.0063898248279 -171.343721615047 530.65580260017782
+-1374.5045028678853 -170.34603999494499 529.7827368305891 -1370.9412929436053 -170.90582593461414 529.34306066233239 -1367.3785481191851 -171.46662252764756 528.90197793773609 -1363.8162537114838 -172.02843966066251 528.4595513365914 -1360.2543950205725 -172.59128612453338 528.01584281172336 -1356.692957327688 -173.15516990677955 527.57091376931396
+-1375.1114928778582 -171.45060411895486 526.43161987221629 -1371.5482248593382 -172.01325159120435 525.99641287690565 -1367.9854370067778 -172.57666218767181 525.55943673290153 -1364.4231144288965 -173.14085920071886 525.12076856765498 -1360.8612420568465 -173.70586398969786 524.68048489251066 -1357.2998046877181 -174.27169649051089 524.23866174257205
+8 0 0 8 6 -978.37243039195926 126.19521749710296 521.78813449148879 -985.94127760619506 105.54849376731522 522.75592506739838 -992.38196145832205 84.664138459913858 523.58513772831429 -997.5077076175055 63.57307967892919 524.25008803620801 -1001.1075308116812 42.339267605180787 524.72065180237007 -1002.9679797412697 21.095335912161843 524.96541502081209 -1002.9679796950105 -1.8829382497642655e-13 524.96541501340016
+-977.51669609663122 129.33101355103301 515.8900989618586 -985.42966487823855 108.18632690374019 516.90152435710456 -992.17356163179591 86.790291366996072 517.76898579520673 -997.54921689887385 65.174045070997181 518.46536236730753 -1001.3300987840358 43.404127133566185 518.95867606667241 -1003.2852095219831 21.622790621424528 519.21527864480061 -1003.2852094759323 -1.3363754547413009e-12 519.21527863573715
+-978.05038460950027 132.29204972830729 509.87155532835618 -986.2685024611385 110.69474347311304 510.92210960936541 -993.28412635088785 88.82747975311959 511.82376679136371 -998.88621320193124 66.720260369867859 512.5481625911832 -1002.833593946782 44.440781773769217 513.06178819479908 -1004.8764119401347 22.139809795289668 513.32892208102601 -1004.8764118947357 -2.4961005484769316e-12 513.32892207041834
+-980.15250695984707 135.02981418764685 504.06373531653207 -988.62188379503834 113.0380011844202 505.14717701421807 -995.86504819248819 90.750798333103646 506.07750422784932 -1001.6602099296923 68.195949629577683 506.82534183448587 -1005.7529829303643 45.440583745377218 507.3560499454984 -1007.8734944805975 22.642660933382523 507.63203142007421 -1007.873494436264 -3.9370282827506331e-12 507.6320314083535
+-983.95012334531179 137.49806561850193 498.98547764858597 -992.60152672523748 115.18138627713293 500.09359575432524 -1000.0146513682197 92.538266688778108 501.04549596329718 -1005.9588070117774 69.591311105324252 501.81103353882207 -1010.1685732287583 46.402960300247997 502.35486510550743 -1012.3533266174219 23.134415834306918 502.63770960552085 -1012.3533265743644 -4.5967753413224588e-12 502.63770959361773
+-989.04951472222331 139.76523471914933 495.18996857102326 -997.82723620183037 117.17648242802767 496.31556313603255 -1005.3637399480373 94.222923489654789 497.28316419140322 -1011.4210812447071 70.92211606964706 498.06201033440442 -1015.724551737839 47.330681099648125 498.61617668232356 -1017.9625528404624 23.611961539290171 498.9046319959927 -1017.9625527984379 -5.8513214115255386e-12 498.90463198523162
+-995.06156985758298 141.63145330793267 492.94929154660497 -1003.8990026739527 118.84455326832017 494.08337417250721 -1011.5007920333591 95.654269356281148 495.05923190784534 -1017.6241652466006 72.071630656346045 495.84570375499737 -1021.9875690879459 48.145142817129553 496.40637653485862 -1024.2615710993914 24.037414507632445 496.69862654975094 -1024.2615710577247 -6.1436114132514947e-12 496.69862654148773
+-1001.474059686519 142.7989061480618 492.33495592109301 -1010.2890279833607 119.91999657275504 493.46648430687367 -1017.8819125250307 96.602528256214384 494.44111864559954 -1024.0085945825397 72.852257733941016 495.22760782746275 -1028.3842446610056 48.710461639772447 495.78928979483709 -1030.6688071753008 24.338146144765155 496.08253482855048 -1030.6688071331796 -6.3754210244404362e-12 496.08253482375034
+-1007.8562700675745 143.11769534635374 493.15420484729123 -1016.5653615832019 120.26700446354235 494.27214599038638 -1024.0729710762942 96.950351591731064 495.23585395433844 -1030.1374497241507 73.169600174584062 496.01433887103929 -1034.4744561566201 48.959904765140962 496.57104070721726 -1036.7420385056571 24.479627803762678 496.86212508341066 -1036.7420384623563 -6.2387872645785958e-12 496.86212508253482
+8 0 0 7 6 -1395.9209712992024 -121.09636869195451 563.16809104774279 -1396.7241720380409 -116.16460779231224 566.91966906555353 -1397.4392364065109 -110.90530517268765 570.25961376664668 -1398.0643008316213 -105.38382594069456 573.17906945037385 -1398.5997631807461 -99.655568119076534 575.68017883839241 -1399.046646846881 -93.766701948705318 577.76744985433425 -1399.4047780148821 -87.75709967539828 579.44020357963529
+-1396.5876571290294 -123.57371806182337 566.28203729530787 -1397.4180729656982 -118.37956273774357 570.16073121141233 -1398.1540387491164 -112.86467392236698 573.59830969443829 -1398.7944856628681 -107.09614880134846 576.58960629912531 -1399.3404452567725 -101.12924245277006 579.13973744739849 -1399.7933987150122 -95.009234099292968 581.25536734320076 -1400.1533609217586 -88.774941381960815 582.93667341478294
+-1398.1828734827827 -126.05106743369477 569.1971881606072 -1399.0135736228558 -120.59451769068679 573.20876378223852 -1399.74623202562 -114.82404107116928 576.74915856320285 -1400.3794456841629 -108.80847433306315 579.81713981135624 -1400.9139887891811 -102.60291553390206 582.42098235926846 -1401.3510712880136 -96.251766290610291 584.56966944372198 -1401.6903419768596 -89.7927831287072 586.26434989823952
+-1400.6622735741798 -128.36376756055631 571.70659303538207 -1401.465807515285 -122.66703655823798 575.85436755852584 -1402.1708533869851 -116.66104537167651 579.50225009514452 -1402.7744827094398 -110.41675955094146 582.65285132975794 -1403.2762511484304 -103.98936335263674 585.31761801521452 -1403.6763211713342 -97.422559609724459 587.50790300986353 -1403.9734558435778 -90.753184059388332 589.22591757359976
+-1403.8891790208731 -130.34702884038043 573.62288469942348 -1404.6429168308566 -124.45457250631318 577.90659522746625 -1405.3005229257849 -118.25318745788931 581.66516782830183 -1405.8565090009115 -111.81670329042815 584.90444209482666 -1406.308562469038 -105.20106120720209 587.63896482844632 -1406.6552520660016 -98.449719452952408 589.88249024279833 -1406.8938201340734 -91.598671465836077 591.63820904738679
+-1407.640735461586 -131.86388462413933 574.81372151400933 -1408.3322251018171 -125.83781767931822 579.22771911690313 -1408.9316777544639 -119.49744160374156 583.09678404063402 -1409.4306347633367 -112.92040598664441 586.42909819050305 -1409.8243774333878 -106.16406415946885 589.24186916618157 -1410.1094166657556 -99.272071992208936 591.55099972969049 -1410.281271258272 -92.279980544712117 593.36066508223905
+-1411.6499829512616 -132.83104774836067 575.2267708460804 -1412.2790431105329 -126.74240063278076 579.7584337909359 -1412.8204424158785 -120.32820769968333 583.73238361080405 -1413.2629195962249 -113.67068042336084 587.15784769049935 -1413.5993944310783 -106.82935861608269 590.05414079753155 -1413.8242886000621 -99.848626359221768 592.43902782413556 -1413.9312134883103 -92.763827587294614 594.31751257294832
+-1415.6510057402995 -133.22247960627175 574.88473448687841 -1416.2285870597855 -127.14246802283863 579.51427840908036 -1416.7219290622079 -120.72085722107255 583.58118585574675 -1417.1176862275806 -114.04473246215392 587.09432541897991 -1417.4068094502288 -107.1763774715118 590.07437460064341 -1417.5818717794255 -100.16131498397577 592.54054716164012 -1417.6346485948504 -93.034909038664935 594.49851719872981
+8 0 0 1 1 -1395.9209712992028 -253.96081542968824 563.16809104774393 -1410.205932617188 -253.96081542968821 629.8900756835942
+-1395.9209712992028 6.1959326558280736e-12 563.16809104774427 -1410.205932617188 6.1959326558280736e-12 629.89007568359398
+8 0 0 7 12 -1370.4053730067612 -152.68650658283727 539.69281459138551 -1373.8846061556646 -151.75821914990681 540.13942623206071 -1377.2839853209716 -150.58794219878698 541.02714555597879 -1380.5389275752632 -149.20683081100015 542.33646024267716 -1383.586553162791 -147.60127902366418 544.04015777575523 -1386.3716795815526 -145.7522005110846 546.09794542155805 -1388.8260202990364 -143.54833861254932 548.43110332658421 -1390.9179511751972 -140.94770840847892 551.01070157889171 -1392.5676796898986 -137.7772185769708 553.64156577700805 -1393.8458587068999 -134.17382560404832 556.23763365241734 -1394.7910838630708 -130.1449098446933 558.71656510731509 -1395.4643895363656 -125.76866244586476 561.0354955709654 -1395.9209712992038 -121.09636869195506 563.16809104774381
+-1370.9622558650076 -156.22250084021897 539.7642988242759 -1374.5750109402588 -155.33000346652409 540.29423701239239 -1378.0826763660066 -154.17415447291918 541.29827959394675 -1381.4249505231635 -152.78128420546273 542.75157428056627 -1384.5485865798562 -151.13512146598296 544.62198769970814 -1387.4052714054114 -149.21435113020502 546.89038920891005 -1389.930138864587 -146.91070349802521 549.46536341678495 -1392.0731114573091 -144.1906254221239 552.37625809902852 -1393.7155115244536 -140.88241490882831 555.36174872735 -1394.9334013933326 -137.13641113505318 558.33394567668165 -1395.7722278232304 -132.95377601841631 561.17482360775102 -1396.3007770805546 -128.4167270929866 563.83686070553256 -1396.5876571290307 -123.57371806182387 566.28203729530901
+-1371.6143418864347 -159.75849531051506 539.09412342303858 -1375.4504109958266 -158.90178796129538 539.69458193664832 -1379.1593993122403 -157.76037563632471 540.82072025635648 -1382.6802884529986 -156.35568950995241 542.44511428869896 -1385.9631327842371 -154.66908052951698 544.52979070720755 -1388.9619969949022 -152.67636000758222 547.07204631795037 -1391.6122097893474 -150.27311745696619 549.95900656177389 -1393.8530174445398 -147.4336549716233 553.26537615454049 -1395.5397073364838 -143.98741251586495 556.66113711893161 -1396.7570248281784 -140.09915325669181 560.06470548517575 -1397.5518882039407 -135.76257560833196 563.3217207992343 -1398.00136101151 -131.06480455288113 566.38263631459074 -1398.1828734827843 -126.05106743369521 569.19718816060845
+-1372.3324825956363 -163.10942055100085 537.67856206640033 -1376.473726915207 -162.28065775994972 538.33225436467376 -1380.4702405434268 -161.14853543749553 539.5797803456104 -1384.255547266031 -159.73051122899295 541.39414569126427 -1387.7764421753354 -158.0061666674319 543.73106835196143 -1390.9849027066152 -155.94762905878667 546.59892632086166 -1393.8115811218186 -153.45299172820128 549.85489057930295 -1396.1959153169621 -150.50131211433825 553.60406832985302 -1397.9769618084081 -146.9207139246505 557.44722385841465 -1399.2542718673778 -142.89245111510479 561.31283645920769 -1400.070731144818 -138.40295813237199 565.01282262856137 -1400.5129043523777 -133.54574299572829 568.4977634790248 -1400.6622735741814 -128.36376756055668 571.70659303538355
+-1373.0800561515707 -166.09012301955977 535.57200321027665 -1377.5931251935624 -165.27360313587357 536.26003251422981 -1381.9485723495923 -164.14045954347822 537.62270707979292 -1386.0705797230175 -162.70608060883436 539.63611914443675 -1389.896934138764 -160.94940997457849 542.24949660465074 -1393.3733142094998 -158.83718181217426 545.47724254176376 -1396.4208130992324 -156.26801487904277 549.13940496375164 -1398.9891221670514 -153.21771805415918 553.35728066062302 -1400.9087845937377 -149.51088987757831 557.66241235015377 -1402.3004608909819 -145.34656234046983 561.99286846220991 -1403.1987502753545 -140.70647318945643 566.13186975034591 -1403.7011602890839 -135.69226661202794 570.03140856830748 -1403.8891790208752 -130.34702884038074 573.62288469942473
+-1373.8167670401797 -168.53993767223861 532.88799403852067 -1378.74692579148 -167.71394625031525 533.59339579890855 -1383.5109478987702 -166.56563848677376 535.06135156231517 -1388.0211649363059 -165.11092885407902 537.27273138566363 -1392.2023823073989 -163.32968200057462 540.17016840670863 -1395.9904402883562 -161.18051301931973 543.77009802022735 -1399.2935102060596 -158.56099083658432 547.85094709171847 -1402.0770376080557 -155.43105725020763 552.53946364589763 -1404.1697206969545 -151.61045198179147 557.29705977618664 -1405.7170881079608 -147.3161971720115 562.06781955785164 -1406.7435279568672 -142.53012470229939 566.61256255621652 -1407.3584271361397 -137.3638060124176 570.88506931912877 -1407.6407354615883 -131.86388462413956 574.81372151401069
+-1374.5045028573311 -170.34603994945169 529.78273685886847 -1379.8727726673435 -169.48638683061 530.49316103337651 -1385.0698214885444 -168.30748709226191 532.05489393404196 -1389.9951998643226 -166.82854524698297 534.45399505359853 -1394.5589679227442 -165.03196664946273 537.62634184621152 -1398.6846491345912 -162.8649992641744 541.58796742929758 -1402.2663148495906 -160.22335390549782 546.07430929353154 -1405.2847865266936 -157.03674386754656 551.21229546199686 -1407.5724938274993 -153.11842229203029 556.39061392447366 -1409.300018576721 -148.70371874217921 561.55455246336646 -1410.4821673309339 -143.78035143279919 566.44907381215091 -1411.2402701705512 -138.47150572974562 571.02969255068979 -1411.6499829512643 -132.83104774836085 575.22677084608165
+-1375.1114928763584 -171.45060411049039 526.4316198760481 -1380.915085455126 -170.53420196330387 527.14045877896547 -1386.5446389768165 -169.31050164480268 528.7842218051843 -1391.887486386167 -167.80445797645189 531.35332809356271 -1396.8392751718491 -166.00226327292552 534.77670448000038 -1401.310102964748 -163.8369838081878 539.06913763232114 -1405.1805665189336 -161.20175132234274 543.9247226851777 -1408.4418089150438 -157.98400083631324 549.4710237630627 -1410.9333791697097 -153.98649247138678 555.02026900044302 -1412.8482657790976 -149.46503138293849 560.51419399796816 -1414.194341130953 -144.41835252639237 565.68814512577956 -1415.1041693690349 -138.98276349632394 570.49928659623424 -1415.6510057403025 -133.22247960627189 574.88473448687944
+8 0 0 8 4 -1867.4022216796877 -64.055191972119161 633.45655235425136 -1739.8766174316406 -72.272004724019496 622.41052042423678 -1612.3510131835938 -80.488817475919831 611.36448849422231 -1484.8254089355464 -88.705630227820151 600.31845656420751 -1357.2998046875 -96.922442979720472 589.27242463419282
+-1867.402221679688 -68.387079887314997 632.96684914875152 -1739.8616070499525 -78.669028576927786 620.0845803520408 -1612.5160063811613 -89.467319529721181 606.58213160352011 -1485.5038659403945 -100.78195274569518 594.51511969707803 -1357.2998046875002 -112.61292822484981 586.5885506179178
+-1867.4022216796877 -72.621374608419245 631.61384185754673 -1739.8551740292291 -85.362746356204951 616.87991923708853 -1612.5867177515472 -98.808833130164913 601.42899082628855 -1485.7946332281858 -112.9596349302991 588.1976520449881 -1357.2998046875 -127.81515175660761 581.05019715776405
+-1867.402221679688 -76.557353120705727 629.42022144255793 -1739.8551740292289 -91.915821245483045 612.78223093759743 -1612.5867177515474 -107.9296292288804 595.68068299637605 -1485.7946332281863 -124.59877707089781 581.05217303873542 -1357.2998046875 -141.92326477153523 572.7609953292523
+-1867.4022216796875 -80.000629979933478 626.46467495370666 -1739.8594627097111 -97.902271103404246 607.85777980898524 -1612.5395768379562 -116.26235055703205 589.21796985403034 -1485.6007883696577 -135.08086834081689 572.89452142471475 -1357.2998046875 -154.35782445475888 561.97886993269958
+-1867.4022216796873 -82.782636761982843 622.87972741689612 -1739.8658957304347 -102.93433653423108 602.24970339214076 -1612.4688654675706 -123.29026831690373 582.02152153445832 -1485.3100210818657 -143.8504321100009 563.66347955376887 -1357.2998046875 -164.61482791352262 549.10772458236102
+-1867.4022216796873 -84.779329392647213 618.84028241629426 -1739.8723287511584 -106.6879902127712 596.16202842292603 -1612.3981540971847 -128.57959350195648 574.15140800454913 -1485.0192537940741 -150.45413926020314 553.39574024513183 -1357.2998046875 -172.31162748751115 534.66788399758912
+-1867.4022216796877 -85.921710327135486 614.54437199872928 -1739.8766174316411 -108.91773539283999 589.83345776851047 -1612.3510131835942 -131.79855173425122 565.71392303114771 -1484.8254089355471 -154.56415935136926 542.18576778664124 -1357.2998046875002 -177.21455824419422 519.24899203499035
+-1867.4022216796877 -86.197022651859044 610.19359445176713 -1739.8766174316406 -109.45906988609872 583.51036459547981 -1612.3510131835938 -132.72111712033842 556.82713473919284 -1484.8254089355469 -155.98316435457812 530.14390488290599 -1357.2998046875 -179.24521158881782 503.46067502661873
+8 0 0 8 8 -1399.4047774058015 -87.75710987207303 579.44020074020409 -1400.0597874986966 -88.647719624393943 582.49961212962421 -1401.3060960281753 -89.538329377051525 585.43242843558892 -1403.1172866196764 -90.393038548744769 588.11532718351737 -1405.4336371219965 -91.175931337152974 590.43206187423186 -1408.1641141365039 -91.854164875604624 592.28412962014886 -1411.1937558242332 -92.400943562078567 593.59987622589927 -1414.3941415725537 -92.797713268125804 594.34013768580564 -1417.6346471030986 -93.034909135300211 594.49851707064579
+-1399.4442903381378 -87.093821462887945 579.62474346774502 -1400.0999102187525 -87.945924160937921 582.68711319829208 -1401.3436636552042 -88.797275945960592 585.62124538029775 -1403.1478261623085 -89.614228885217898 588.3063625904615 -1405.4527292812138 -90.361947464900638 590.6240780740718 -1408.1678143649244 -91.011524927392117 592.48472559352876 -1411.1813877363095 -91.535274660758901 593.80864494638195 -1414.3667709628126 -91.917659637123535 594.56458481203515 -1417.5957012487856 -92.147600961067653 594.73891269027365
+-1399.4782948832947 -86.42405576099236 579.7836215845316 -1400.1349210921769 -87.237794865336014 582.85005994572145 -1401.3766131261712 -88.050871803983426 585.78824186709471 -1403.1758887949095 -88.830819906568635 588.47689953085944 -1405.4726983589985 -89.545705181595153 590.80228074856711 -1408.178820912859 -90.165675711909884 592.6680826187137 -1411.1821589260471 -90.667498074068263 594.00428551163748 -1414.3582725171862 -91.033407474588017 594.76986479131358 -1417.5792492350913 -91.255110157812439 594.95761207363853
+-1399.5110276609282 -85.753250118707484 579.93644817064933 -1400.1679959156636 -86.528267237043153 583.00599780163566 -1401.4083621048069 -87.302958915009313 585.94932817086033 -1403.2044309529601 -88.044900854942 588.63769531837045 -1405.4954570622078 -88.727429623142299 590.9757850485222 -1408.1945093968463 -89.316511431546374 592.83828762617782 -1411.1895602804832 -89.797125092373079 594.19143589350426 -1414.358509276869 -90.145914089156079 594.9608514597337 -1417.5728690033714 -90.359094976959341 595.16102166154474
+-1399.5416192880991 -85.08009498934581 580.07934742430848 -1400.199845856833 -85.816565326737987 583.15272939604552 -1401.4390454016184 -86.551790033337198 586.0956731191493 -1403.230467535863 -87.259586859541898 588.80078457734032 -1405.5175723694874 -87.903832446406085 591.12305112488934 -1408.2094781162027 -88.470321340647686 593.02135853307857 -1411.2002252249172 -88.922174545257505 594.35644260539652 -1414.3622824529357 -89.258172395621813 595.15110695564385 -1417.5721786441127 -89.460511366415133 595.35285071443354
+-1399.5705458035013 -84.40494591995467 580.21449402559767 -1400.2289718034554 -85.102530303814518 583.29044496705501 -1401.4667631216473 -85.800244027999639 586.24244583020618 -1403.2574129303875 -86.467910105117042 588.9382324135928 -1405.5396422548486 -87.084374022253101 591.29243344723693 -1408.2293035610869 -87.614150586677937 593.16233373108389 -1411.2130812868015 -88.049941099440716 594.53562371042358 -1414.3715075788905 -88.364937123398676 595.3170634616431 -1417.5759336536541 -88.559843354093516 595.53523439850107
+-1399.5987924493982 -83.729098361391209 580.34639380351916 -1400.2580607034943 -84.387952355185362 583.42558575145108 -1401.4950285903155 -85.046222550289656 586.37802170680959 -1403.2822016874211 -85.679168900465129 589.08847977127505 -1405.5624075338699 -86.25796868195485 591.430542184101 -1408.2470321362657 -86.764109382485998 593.33045929866728 -1411.2284419282876 -87.171842404031665 594.6887593233771 -1414.3819777082601 -87.473370425354901 595.49083440783727 -1417.5832189899536 -87.657326556039436 595.70953317983162
+-1399.625754956478 -83.052063244283275 580.47233926040826 -1400.2855508085033 -83.671960419949585 583.55406575461836 -1401.5215297289199 -84.291768826577183 586.51173390748647 -1403.307286502619 -84.886819329847825 589.2232719221289 -1405.5846763722132 -85.433516953662377 591.57825280887198 -1408.2671428618557 -85.908433519719082 593.47453307131082 -1411.2447372115162 -86.294805905815892 594.84736476423245 -1414.3951739819361 -86.578357563026131 595.64972256583712 -1417.5927359274176 -86.753164809152338 595.87680852654705
+-1399.6519034768448 -82.373981269430587 580.59447350783876 -1400.3122423271191 -82.954953387399669 583.67877444748001 -1401.5473550358554 -83.535925506356961 586.64001817060807 -1403.3313555356394 -84.094132925919411 589.3573524759629 -1405.6068840128826 -84.606801986811305 591.71661384780418 -1408.2870211112715 -85.053052126183672 593.62047823564728 -1411.2621345372631 -85.415731245477474 594.99718556014318 -1414.4095806615944 -85.682782413640595 595.80605085051616 -1417.6041837107787 -85.847739928508503 596.0379749189708
+8 0 0 2 7 -474.94942832544319 -1.5936470892929933e-14 559.45782159448595 -473.76716654909092 -1.7510298766509891e-14 551.95756333420002 -472.6701620923501 -2.3660327169716666e-14 543.71853702060821 -471.71112726572858 7.8880354629060392e-17 534.6386359651857 -470.99799497889234 -2.9237091418522956e-14 524.56681044483139 -470.61091849934525 -3.845278923317976e-14 513.33478653655732 -470.87774187710306 -3.2857087586427256e-14 500.66014072078241 -472.05103275240577 -3.5063098258180633e-14 486.92503483316381
+-474.94942832544319 63.55959122098033 559.45782159448606 -473.76716654909097 68.564034544281185 551.95756333420013 -472.67016209235038 73.389074399385592 543.71853702060821 -471.71112726572807 78.005898864016302 534.63863596518627 -470.99799497889285 82.334457758899447 524.56681044483105 -470.61091849934519 86.329713415609348 513.33478653655754 -470.87774187710312 89.751139323114856 500.66014072078252 -472.05103275240583 92.385401504824188 486.92503483316392
+-488.74252727267918 129.82957885422601 563.19513301095765 -489.64921526625125 140.26527835372042 556.59291813495747 -490.71319068404904 150.36601634048918 549.43511023394024 -491.93146718840222 160.06711087022444 541.65373353105929 -493.3018915339415 169.19373947470893 533.12057454310491 -494.82238518695948 177.6458843967732 523.71385305917966 -496.51877283872568 184.90206121412228 513.13948770533466 -498.45723043216918 190.49714556166353 501.57074281662966
+8 0 0 6 11 -517.16342521475042 208.22457291448259 514.29852713637217 -518.98488696050026 212.8604975001895 505.73426814008377 -520.95633835766751 216.80124612605019 496.55727273461355 -523.06082143122262 219.83632438145062 486.84432220210596 -525.26450405615731 221.8300344158574 476.73903837643968 -527.45539028225255 222.42929072579545 466.66183866182388 -529.53922305630999 222.2110213094862 457.21539157880864 -531.67810966098205 221.31854891071578 448.0101027403897 -533.85101129202326 219.92516080416101 439.32865796520065 -536.12184422552855 218.20279773787939 431.01253262091882 -538.53288917507007 216.26116521195155 423.07429659480482 -541.11909161919596 214.20007110643297 415.47512525825664
+-512.53171370126574 207.04649321767414 512.84343797785061 -514.23026316595656 211.65268677826469 504.35977292544698 -516.07637948516515 215.57766702201445 495.26898459002825 -518.06295200514455 218.61627167578041 485.63733923676938 -520.16931900544603 220.63022838920702 475.60031041737898 -522.31604561027029 221.27070454220816 465.53746818261328 -524.41384346601239 221.04068103670727 456.0668203309728 -526.60299114181851 220.13524734047945 446.83623786445429 -528.85580023559498 218.70621925123731 438.10703714130597 -531.23131667156508 216.93981800736765 429.73925596741947 -533.76116905749245 214.94784198178453 421.73882776769744 -536.47612370795139 212.83362593932836 414.06788245627928
+-508.23969622770363 205.01450258510835 510.99835000633374 -509.80701748193275 209.51805575964937 502.64793875794862 -511.51524372227436 213.3530316100057 493.71154791491352 -513.36646256733525 216.32628549663897 484.24653899435532 -515.35352042618217 218.30425979919292 474.37835121191057 -517.43024662584128 218.96528342054569 464.44195707004206 -519.52400654383996 218.73530529734094 455.03001749127407 -521.74661712887519 217.84208030035467 445.8469824329282 -524.06694019741099 216.41411063438846 437.12237989514682 -526.53710940980341 214.64577796600116 428.74145800776574 -529.1778745922096 212.64608572599587 420.7052360588055 -532.0153115299089 210.51969191500558 412.97960319123388
+-504.5185236758287 202.18735639556633 508.83586102201411 -505.96143963008114 206.51911919290927 500.67016652569657 -507.53521351810144 210.19309320913922 491.95460838509314 -509.24933356621705 213.03431970553189 482.7395034014703 -511.10885998876944 214.9208946315733 473.13869540089541 -513.09680052945384 215.58027301631253 463.44006277055178 -515.16638733657885 215.36221147272985 454.17178647622757 -517.39807263643945 214.50662311653539 445.10925104512722 -519.76263558447272 213.11683553673367 436.44304244004104 -522.30380562641415 211.38917414894684 428.08831910365831 -525.03325093297622 209.42486149643329 420.04375511860513 -527.97250029784982 207.32763280101585 412.28178232183092
+-501.57165614708038 198.69535565807976 506.46138377845494 -502.91182888114008 202.79888244841754 498.52758041548805 -504.37068828696107 206.25375472309238 490.09279437143152 -505.96246887730302 208.90803922044182 481.20200489762453 -507.70089536315453 210.65750304550903 471.95587604416647 -509.59191339590745 211.29506433943237 462.59439393074251 -511.61552326940705 211.09965585910479 453.54757699024583 -513.82725215313678 210.30253315023782 444.67248354316877 -516.20289937808639 208.98287582976693 436.11516237101188 -518.7792009632002 207.33220553771281 427.82411893892203 -521.5618575871016 205.4402107147144 419.798259710916 -524.56878772888001 203.40765766718201 412.0190015069374
+-499.53333756360121 194.72823363411641 503.99928094807814 -500.80245687508801 198.56729755203239 496.3368246780924 -502.17716037795975 201.76605856159276 488.23132016940519 -503.67336187709816 204.19857561453927 479.72352703140893 -505.30857728640336 205.78222827986295 470.8994788103181 -507.10418616929365 206.38438737609371 461.95108529960129 -509.06179197876656 206.21873499514879 453.18795118933963 -511.22394825533974 205.49297242225418 444.55471298101588 -513.57309569618133 204.26463192649345 436.14920927092936 -516.14214669305136 202.71495123034464 427.95502318464571 -518.93485456654696 200.92007861429911 419.97332029545646 -521.96705223395293 198.97628579184376 412.1962120140825
+-498.4572301799497 190.49714574828158 501.57074294508823 -499.69083578118449 194.05764757449671 494.20881058905752 -501.01684656814695 196.98637119668939 486.46651254924507 -502.44970041199883 199.18444645036519 478.38075242162398 -504.00645445328172 200.59165512535213 470.02227367397285 -505.71341205993093 201.15373132543351 461.53359669652298 -507.5911811584856 201.01919851913351 453.09769449332572 -509.67607856051887 200.37026087271508 444.74411496185468 -511.96322743450366 199.24166867288196 436.52378626670037 -514.48258379214656 197.80317822932216 428.45376831810864 -517.24111913591446 196.11644009077989 420.53917755204333 -520.25425313811252 194.2724579250625 412.7835607748757
+8 0 0 11 5 -725.96309162713987 197.72872914829486 300.00000000000034 -726.45675002995108 212.96672558929555 348.78794127126775 -726.63931095121268 222.59673494326088 395.69854538947226 -697.15330811834531 284.76160633064819 514.81393844208469 -716.68292836261048 231.06448663989335 588.03232212045395 -716.28679955432983 163.89201846893482 635.79360142257246
+-701.43068678734676 196.77197870260028 300.00000000000034 -701.99395480980729 212.04289441719354 348.77695521337034 -702.29719816948966 221.67860106265687 395.63534098829274 -672.4084887268001 286.32602130005034 508.98171681681345 -692.07856583293835 231.108530754047 584.48600280022595 -692.09692436031901 164.10997432792027 632.49531296943371
+-676.98029200334281 194.9912536804863 300.00000000000034 -677.61167054054863 210.31340160057613 348.76012822026792 -678.03646295091437 219.97613402636557 395.57609352171482 -648.10402245762896 287.03034518631461 502.97461361342346 -667.48752440436181 230.49597917272396 580.48015898679535 -667.93264611862378 163.59260875126259 628.62081009493556
+-652.6846843164542 192.40127180580157 300.00000000000028 -653.38068088399245 207.79231999655187 348.73763720584799 -653.92298448921292 217.50223906452985 395.51884766699652 -624.26456727855111 286.86416291256512 496.84531941078575 -642.93302439669083 229.21527585747816 575.99900243747061 -643.77515709679608 162.3268657662245 624.15481871437157
+-628.61646930515496 189.02390517472324 300.00000000000028 -629.37178201734787 204.50071326746436 348.70969733194335 -630.02320622338516 214.27671152276548 395.46287131615082 -600.89920353959644 285.83160348432642 490.5887316069506 -618.43948066286396 227.25803893426385 570.99731390303282 -619.6086135920267 160.3018088171242 619.05069742172168
+-604.85244048968491 184.88751791257803 300.00000000000034 -605.66009202617079 200.46594295137342 348.67656825190528 -606.40707667131255 210.32535684199283 395.40988971218536 -578.02036984892538 283.94478170154929 484.12526451247601 -594.03534774586512 224.6169352739783 565.38575098125875 -595.4278199952787 157.50678150742112 613.21845359926181
+-581.4795354179347 180.02940333870683 300.0000000000004 -582.33102045959799 195.72405740998693 348.63857047090312 -583.1549267995623 205.68251072713383 395.36254816067986 -555.62814252272756 281.20758865951802 477.3283752796533 -569.7443504214084 221.28070279807244 559.04249276076121 -571.2394336429287 153.92856565467545 606.53421105340578
+-558.60155106781417 174.50075671723627 300.00000000000034 -559.48706068307752 190.32469873190726 348.59611182295015 -560.36308764853084 200.39559514470474 395.32544472269507 -533.74819251727308 277.59155734601359 470.05486457817892 -545.59226401504111 217.22844164325531 551.81578575515084 -547.06467616551504 149.54724579943428 598.84373015960944
+-536.34578120132096 168.37361967162124 300.00000000000017 -537.25456766381217 184.33796366905591 348.54972406465589 -538.14902681576177 194.53140074921194 395.30673816708469 -512.39496204879515 273.02937495729407 462.13398985089782 -521.63032483222332 212.42701821635657 543.51235314040127 -522.95002155920372 144.33297661016809 589.95157205715236
+-514.86873830552713 161.74923234082212 300.00000000000011 -515.78968382413336 177.8626546841403 348.50010958570402 -516.6571404880799 188.18399551152487 395.31810636169661 -491.65750062653825 267.4037480479036 453.35650728254603 -497.96518860775734 206.83598340580306 533.88710185953539 -498.99081572159048 138.24833692745023 579.60648899260502
+-494.36012275570067 154.76722935498034 300.00000000000028 -495.2825755980229 171.03535718702628 348.44819823605627 -496.06107900510193 181.48352270905463 395.3777062137018 -471.6112157972193 260.56233579276596 443.45077502734716 -474.78911406665821 200.42379778990883 522.66010974833512 -475.37126670946674 131.26344149164234 567.51261346877607
+-475.04420183577815 147.61511570845639 300.00000000000028 -475.95914332599835 164.03977903788046 348.39521426988239 -476.54760843271282 174.6036690376103 395.53476822937932 -452.42272949218926 252.31412452203577 432.05179298536336 -452.42272949218739 193.19738259427427 509.58749746371507 -452.42272949218761 123.39346869941861 553.41500941392439
+8 0 0 6 9 -766.91669454458088 231.9866395936422 435.92481540532015 -767.20638718675639 234.23995658273728 451.11855317062611 -770.03335145627454 235.71280962137851 466.54105540329493 -774.83192497018536 236.18721871468401 481.67965706144196 -780.93928328467814 235.6242711539669 496.34742183236796 -788.02457277003805 234.10443426669627 510.55775365366515 -795.83117813022159 231.62191912752874 524.25200219404826 -804.21100671202191 228.18978863620615 537.41684644177292 -813.0507976748579 223.78312233824087 549.95734912758576 -822.27918963051559 218.41848119959877 561.76339605587032
+-766.11458306464431 232.61239913821191 435.81408717118563 -766.37807745601071 234.97327361063711 451.13790286071401 -769.20230274432186 236.55972017459075 466.6885061267277 -774.01661327190743 237.14502537746458 481.95032547422733 -780.15268356740467 236.68546692361429 496.7373609992473 -787.27367588179754 235.25851526915801 511.06618332001648 -795.12419122875644 232.85624269703311 524.88211944348416 -803.55169267100837 229.48887759624336 538.17566747782985 -812.44452936162781 225.12629358002076 550.855440930692 -821.72952651860851 219.7788807270727 562.80848004492259
+-765.23443833093143 233.14094836145182 435.71926368950727 -765.45581627580725 235.60062222932774 451.18169307974205 -768.25832027715705 237.29004773818639 466.87049019089881 -773.06649919179313 237.97441419998248 482.26736982782728 -779.20699754707721 237.60572234700001 497.18706438155931 -786.33780963659535 236.25860904964875 511.64883561849342 -794.20531880113765 233.92280822066812 525.60142261144654 -802.65276881509237 230.60514856207186 539.03859271998931 -811.57065804213653 226.26952958380085 551.87184298565535 -820.88558496026963 220.92015770783462 563.98402276405523
+-764.2913655469722 233.56045819733535 435.64243774692045 -764.45733637788942 236.10648117653528 451.24985946607836 -767.22199953206245 237.88341494154645 467.08411665535061 -772.00506523843569 238.64889418682026 482.62413654333602 -778.12873509544477 238.35105229144509 497.68500336422443 -785.24560670460517 237.06226141138882 512.28795759434831 -793.10530254487765 234.76976734900336 526.3844780705831 -801.54623155422053 231.47693797581218 539.97064428246722 -810.46167020824191 227.14154969159807 552.95962249122124 -819.77941901443626 221.76288536577781 565.22903672933069
+-763.30298371474737 233.86228592019296 435.58518052599862 -763.40373516909938 236.47921914221857 451.3414761922275 -766.11849381080674 238.32428707880129 467.32514069549865 -770.86210287002041 239.14800404358257 483.01191486566415 -776.95247622182114 238.89513286196697 498.21657170992489 -784.03719856466921 237.63634625067075 512.96140140640603 -791.86943066674803 235.35689062145667 527.19971960364899 -800.2829100755871 232.05676068857514 540.92864415684744 -809.17377514585689 227.68842912550494 554.06124336036783 -818.47206886691288 222.24872406128443 566.46945969374758
+-762.28830041185267 234.04139538005535 435.54846349136125 -762.3180292541175 236.71186439466814 451.45480007089839 -764.97563663447875 238.60327232994734 467.58821609300833 -769.67116489018474 239.45947957537916 483.42053694885448 -775.71806518746621 239.22258546562242 498.76528332642755 -782.75997944148389 237.9622637619309 513.64474667686022 -790.55281789831531 235.6628942884833 528.01305961363107 -798.92662643160418 232.32146642535261 541.86699772718737 -807.78006156176968 227.88700828317445 555.1176582544133 -817.04586087053997 222.35709456536472 567.63171515824263
+-761.26658656866323 234.0967772379966 435.53258027578187 -761.22357866573088 236.80259423629971 451.58736886851051 -763.8217255510483 238.71770673456365 467.86728327544057 -768.46631588989987 239.57995528001817 483.83924696455517 -774.46651587011775 239.32961788722261 499.31442911889002 -781.46219045710802 238.03677237043991 514.31413619678494 -789.21222013860017 235.68604604510111 528.79243992823126 -797.54313150613734 232.27255440492252 542.74455572908607 -806.3559983327907 227.74430775105702 556.07817913076053 -815.58600837106655 222.10287155577728 568.65602872782529
+8 0 0 10 5 -986.5842896583099 163.33141935028576 300.0000000000004 -986.5842896583099 179.2254357981802 348.58069255164395 -986.58432628967171 190.02103625043833 397.60139478939027 -986.565089235816 224.80182550085976 545.1531212872585 -986.58428955079091 196.85346825527216 593.96894363342835 -986.58428955079114 123.69451915376982 631.93215431363831
+-963.03329450250976 170.84330264512693 300.0000000000004 -963.02068516034706 186.5810697988712 348.63181221916523 -962.75162314083673 197.15648666319026 397.08909512662001 -956.46429258174715 234.84400279036061 548.96140686530816 -959.6460959815613 203.488594444505 598.41040550991693 -959.10682413727864 131.25749038524086 638.16166749039735
+-938.53964151576463 177.64952605495995 300.00000000000011 -938.53459908806576 193.24553114724856 348.67757035246387 -938.12463059870095 203.60993265211508 396.73213807653997 -926.68326320001438 243.83087555598036 550.21674754882417 -932.67550125721198 209.3961540916095 601.13845999534863 -931.61322838294734 138.05717490948308 642.48165467006493
+-913.24623445111263 183.6305978982279 300.00000000000034 -913.26754463888824 199.10238604781296 348.71717931821775 -912.80393277729831 209.27627646658161 396.47381610054708 -897.06084743087342 251.97015747069602 549.51601564413863 -905.73563224420741 214.60611946024449 602.46281422033894 -904.22800562050236 144.10162406507931 645.19839511477812
+-887.3071007202758 188.69205894187016 300.00000000000063 -887.37130614593048 204.0603261135484 348.74982862128593 -886.91614000137508 214.06949676860287 396.28165066453374 -867.55608886758591 259.33191681851036 547.18671338412253 -878.81972871500125 219.13582119480577 602.63512908931796 -876.99980782022374 149.38905273615964 646.5691369769296
+-860.87767236182333 192.76923817777782 300.00000000000063 -860.99838082458677 208.05679722059011 348.77501145513259 -860.59689412465855 217.9300126713843 396.13494720411825 -838.20381916115332 265.91054977689714 543.52348576377938 -851.89179250663972 222.98226106626905 601.85795809063382 -849.93601784961663 153.90289116201632 646.8112793888406
+-834.10488831384305 195.82512551918342 300.0000000000004 -834.29238625051482 211.05571050528579 348.79255905391693 -833.97732641704454 220.82299899564055 396.01930342157641 -809.1081342012701 271.6501149528284 538.79824822022579 -824.9200777560892 226.12351309398352 600.29436363468346 -823.02246863029711 157.6152768787905 646.10408617912515
+-807.11970681868183 197.84438100385645 300.00000000000028 -807.38091298798702 213.04183314979863 348.80251375465213 -807.17510043341338 222.73292330136613 395.92433033562548 -780.39320580772187 276.45983149576142 533.34545342339038 -797.89478873738335 228.52769506990569 598.07093137062611 -796.23328200718777 160.4947342921713 644.58536853739133
+-780.03461678731605 198.82650009097699 300.00000000000034 -780.37330178757156 214.01445660240114 348.80497167783579 -780.29142053707255 223.65800006808294 395.84243132546908 -752.13012015153515 280.26867096301714 527.43108186664756 -770.82880727367285 230.16508373872821 595.27258357770836 -769.53581014509484 162.51378938004729 642.34557394892852
+-752.94873695091235 198.78115463855892 300.00000000000034 -753.36582477210925 213.98293987860777 348.80002593495487 -753.41563501110795 223.60668221192523 395.76807023076964 -724.37260944904506 283.04074986430578 521.2293822298833 -743.74772714525022 231.01603811432429 591.93327337270523 -742.89566226774173 163.65226702405073 639.4217187210262
+-725.96309162713987 197.72872914829489 300.00000000000034 -726.45675002995108 212.96672558929555 348.78794127126775 -726.63931095121268 222.59673494326083 395.6985453894722 -697.15330811834531 284.76160633064814 514.81393844208492 -716.68292836261094 231.06448663989332 588.03232212045441 -716.28679955432995 163.89201846893476 635.79360142257349
+8 0 0 5 7 -792.214116688952 218.16627834130932 377.18611263472462 -784.78792709292634 220.13756253718822 382.93649708389887 -778.41257121774902 222.25902171818464 389.9655361803828 -773.35776418584032 224.48385676033297 398.12215060291089 -769.79178934189042 226.70375695789511 407.07029722219198 -767.63139198970657 228.75498303676753 416.48758223626584 -766.73046356032535 230.53807867208135 426.15741255619486 -766.91669454458099 231.98663959364245 435.92481540532009
+-791.67606939797338 218.50937858499367 376.38281001206502 -784.15182373287666 220.4999218159135 382.21548151781712 -777.68679848956322 222.65695985428849 389.33416350577056 -772.55521438106973 224.93314201983543 397.58651119510068 -768.92781844033391 227.21787728399582 406.63415069217092 -766.72134810858245 229.34290733427298 416.15300263899707 -765.78813986359694 231.20601720985317 425.92419284797597 -765.95416076865695 232.73755104712606 435.79194152435855
+-791.09049749017345 218.73141945196656 375.55963323954393 -783.46271339879718 220.74424713391119 381.48041895820353 -776.90154229633617 222.93705565938981 388.69400845024524 -771.68527605191093 225.26230455587802 397.04731962971584 -767.98692551173338 227.60768508664327 406.20007061739847 -765.72301124552655 229.8007397555298 415.82681363864924 -764.744115974897 231.73658556465688 425.70659934111768 -764.87457711206855 233.34264701861497 435.68292477208138
+-790.46919290662538 218.82485323799236 374.73419717763409 -782.73438676360399 220.86266587294512 380.74689508061545 -776.07267291762287 223.09055423472878 388.05901193962211 -770.76619404168355 225.46113134806916 396.5170087497745 -766.98981358960953 227.86091202686012 405.77903059099975 -764.66004354413144 230.11335793630471 415.51816714910416 -763.62523242666964 232.11089072484828 425.51158760047025 -763.70815398187551 233.77826937605604 435.60195072175918
+-789.8260697254758 218.78758749914803 373.92498741645392 -781.9829729679202 220.85255337569919 380.03109572286684 -775.21871296073311 223.11403005160031 387.44350144445741 -769.81915796163321 225.52511120123691 396.00825252462147 -765.96108510874774 227.97142929272394 405.38185432909819 -763.5607227440895 230.272624639795 415.23580059060902 -762.46417991465171 232.31813366840495 425.34522473504205 -762.49264318049018 234.03031900846722 435.551640134477
+-789.17540027336474 218.62325031107312 373.14901685632265 -781.22491668631187 220.71686240165099 379.34778391255361 -774.35849339660285 223.0098198555651 386.86036106739135 -768.86580896812359 225.45590057837197 395.53217643259683 -764.92559022078376 227.94019166464093 405.01776355858181 -762.45377921246643 230.27855973771921 414.98667288141718 -761.29423450626211 232.35732345337331 425.21164475188459 -761.26658656866266 234.09677723799669 435.53258027578164
+8 0 0 5 8 -856.35179034834869 207.57772114127016 363.77344702748479 -847.82933187046399 208.61275676838463 362.5752075561162 -839.26033433089663 209.68500272377526 362.0005061707231 -830.69258250626945 210.81654527333814 362.14856470896069 -822.20466190618902 212.03249469785308 363.1284923920428 -813.90420439345212 213.35921764866552 365.06637207171082 -805.99736522736396 214.82938669436578 368.08259142975191 -798.71203258547416 216.4414046699153 372.15452624169706 -792.21411668895166 218.16627834130929 377.18611263472445
+-856.53714865727363 208.077456573577 362.58232224954196 -847.9323863064426 209.06745935397697 361.40808003689051 -839.27686446171879 210.09857216474981 360.86377218817341 -830.61838178240578 211.19419598678732 361.04939305010515 -822.0367287419017 212.38141595679656 362.07428135922169 -813.63987516503005 213.68877809592183 364.06452390935459 -805.6372530988474 215.15095431944673 367.14093891903377 -798.25978435493255 216.7676532579388 371.27922244453191 -791.67606939797292 218.50937858499361 376.38281001206502
+-856.71057096665015 208.38188615804836 361.30739966006229 -848.01750599614854 209.34045362922907 360.16844695096722 -839.27022551957577 210.34360784512774 359.66501179498727 -830.51650063870079 211.41575622174707 359.89774518482392 -821.83722873402508 212.58542480789779 360.97604226564948 -813.34045698860598 213.88277863703394 363.02593497893201 -805.23847992415699 215.34407330604293 366.1688005980821 -797.76480857012723 216.97019523026495 370.3789457357168 -791.09049749017311 218.7314194519665 375.55963323954393
+-856.8654714758419 208.47317590343519 359.99092297407913 -848.08153819320705 209.41690903848905 358.89441291040714 -839.24029491050283 210.40776569299126 358.43832401175865 -830.38943928268918 211.4708603138638 358.72393034134348 -821.61092703514009 212.63562359723656 359.86067510688105 -813.01254470894946 213.93325160075986 361.97452061051087 -804.80939642761143 215.40135001556709 365.18762317600959 -797.2371482817689 217.04176718240868 369.47308651252553 -790.46919290662515 218.82485323799236 374.7341971776342
+-856.99616837592248 208.34797726754798 358.68118105148363 -848.12259076748808 209.29429026025741 357.6288294295714 -839.18843993252858 210.28911202863375 357.22149707317885 -830.24133878212808 211.35795867669387 357.56111742960314 -821.36418616870469 212.53070312159073 358.75726055143804 -812.66456585664525 213.83893980912023 360.93597200135156 -804.36016880653187 215.32142254124327 364.22023973123362 -796.68877938833668 216.98074235716575 368.58214264834277 -789.82606972547558 218.78758749914803 373.92498741645409
+-857.099023755193 208.01809895417281 357.42282000739363 -848.1403280736962 208.98281650250379 356.41140956903661 -839.11720814567218 209.99644285058272 356.04962917836713 -830.07721407596011 211.08461202013891 356.44015854961935 -821.10415131088689 212.27710989752867 357.69291505378845 -812.30543596296673 213.60544310844045 359.93418099573501 -803.90142279969382 215.1091429122925 363.28787158546652 -796.13207341203565 216.79133973181743 367.72509568212081 -789.1754002733644 218.62325031107309 373.14901685632299
+8 0 0 6 8 -980.79218590463609 189.29743651965578 424.45763442256685 -966.7706838287786 192.18150747722009 413.89175862417375 -952.37633158699896 194.84572666441844 403.8005575660157 -937.57501781668896 197.30644877135057 394.28912284700363 -922.32259483518646 199.56490329165723 385.49978455570186 -906.54613848383235 201.64200461550232 377.67021730789156 -890.25674511454247 203.58764725353691 371.064485023891 -873.39670730411865 205.50764988704108 366.16992597022181 -856.35179034834937 207.57772114127013 363.77344702748474
+-981.67262127946049 190.37172335815933 423.52827439040476 -967.59846442922924 193.18662678876129 412.9274804405502 -953.14363483837565 195.77452715339362 402.80593968990803 -938.27169533554888 198.15299505854563 393.2686798605144 -922.93812332081973 200.32520293382495 384.45954594129631 -907.06785310012879 202.31271891118288 376.61810391975274 -890.67123934094332 204.16703902618835 370.01350527098816 -873.68834568313321 205.99915082515432 365.13732655740768 -856.50625560578681 207.99416733485916 362.78084304586577
+-982.650805038199 191.19422700217584 422.40046987616677 -968.50862969233106 193.94907187627342 411.78138911958411 -953.97757816488411 196.47201617950651 401.64752207362119 -939.01936683449105 198.78167384485954 392.10335959125939 -923.58983113946363 200.88281871501815 383.29354561647085 -907.61190221815843 202.79746478988906 375.45925263225996 -891.09580607871692 204.57889705034523 368.8744170607855 -873.98002505808131 206.34231781471689 364.03380561044997 -856.65276353019192 208.28040962989118 361.73237385655551
+-983.68250446108743 191.71095216541224 421.12090550934499 -969.46238212053061 194.42173277522397 410.49898047139197 -954.84509136191798 196.89816878529689 400.36883237553184 -939.79083716388391 199.15940121920141 390.83403679074945 -924.25630427056751 201.21106383869233 382.03944833265865 -908.16232023634745 203.0753724129344 374.22757807211985 -891.51949013743308 204.80733237741731 367.67688046339987 -874.26502076319912 206.52525506658685 362.88462758999395 -856.78802122124659 208.4275310307417 360.64916131707071
+-984.71509746784398 191.88890600887743 419.75314175988251 -970.41439192293706 194.57643191748241 409.14013611730502 -955.70832049578996 197.02960647004426 399.02527470049296 -940.55571133291994 199.26738812032085 389.51108562323952 -924.91406393778209 201.29530291581847 380.74227399138584 -908.70215987836832 203.13546096731551 372.96253921460794 -891.93098147351668 204.84436336403692 366.45458234220223 -874.53666655833877 206.54225684959459 361.71792349938494 -856.9090371092027 208.43144302480604 359.55434233321398
+-985.69588141791075 191.72563732719965 418.36869063633554 -971.31949182580502 194.41160544004811 407.77109446972804 -956.52977268788027 196.86551514781885 397.67714632548763 -941.28407900409934 199.10541909722664 388.18848462914639 -925.54021743094233 201.13579985243175 379.44960168316493 -909.21506178931713 202.97835429526347 371.70531259562637 -892.31955361859673 204.69082761710925 365.24231857984319 -874.78883884702441 206.39423671135933 360.56251039344158 -857.01331093913484 208.29299754865204 358.47145421080199
+-986.58041745194168 191.24530150433361 417.03458335737452 -972.13929821371096 193.94899028140878 406.45381176038433 -957.27731102775647 196.42497084994415 396.3808184464641 -941.95002993104265 198.68987348993929 386.91671828105723 -926.11496493506502 200.74639102379871 378.20604094075117 -909.6867252722916 202.61555664645311 370.4945679763963 -892.67594755370817 204.3560737472211 364.07288807403677 -875.01641511818718 206.0886638575108 359.44564088410812 -857.09902375519357 208.01809895417273 357.42282000739374
+8 0 0 6 5 -986.58041744691218 191.24530150125463 417.03458331173488 -988.64692833184529 190.85840640422077 418.54868391599689 -990.6971085708534 190.46847715856407 420.07382907914734 -992.73334699156646 190.0772671690475 421.60808438834664 -994.75775815442853 189.6862050031817 423.14998484896569 -996.77216635302932 189.29640386740138 424.6985221216429
+-985.69588136895641 191.7256373103707 418.3686906405747 -987.75312952087927 191.34127832509316 419.88519922949268 -989.79488133713028 190.9528657394975 421.41260049243374 -991.82342607022656 190.56219504717856 422.94895667635274 -993.84077679826157 190.17074479009625 424.49279247528096 -995.84865596436782 189.77968249441017 426.04308581660376
+-984.71509578914345 191.88890543214589 419.75314384344944 -986.76151377223891 191.50432375157115 421.27185770075505 -988.793587364102 191.11489904120171 422.80125221318951 -990.81349490191519 190.72245577226937 424.33938665308949 -992.82312798339183 190.32850933431743 425.88477446806479 -994.82408219436252 189.93426836704262 427.43637815076386
+-983.68250445595811 191.71094868812483 421.12090454887061 -985.71739148290169 191.32302143097985 422.64088915558318 -987.73933086729176 190.92976432766983 424.17135040601045 -989.75037468305356 190.53309068914558 425.71037181189212 -991.75229168145529 190.13439124714591 427.2563949834099 -993.74652455064677 189.73497243650985 428.80839145705266
+-982.65080668811504 191.19422755163262 422.40046767522909 -984.67453841888153 190.80001219662302 423.92005245179985 -986.68685818850133 190.40031034487183 425.44999483396322 -988.6896995226839 189.99696435544649 426.98834163112872 -990.68467113110387 189.59151671696983 428.53357197327773 -992.67306544517783 189.18520735139353 430.08460215915647
+-981.6726212988176 190.37172337608439 423.5282742763261 -983.68661974615964 189.96891341045253 425.04524224473937 -985.69076350142643 189.560773306854 426.57260066195141 -987.68685691195856 189.14913413893501 428.10838255288081 -989.67635937153557 188.73552776843076 429.65103942614468 -991.66040374271574 188.32118317582777 431.19945202843667
+-980.7921858788975 189.29743652653511 424.45763435929939 -982.79864942049585 188.88472830897834 425.96960572513052 -984.79672987615231 188.46709778507895 427.4921902324765 -986.78810206977835 188.04635153163179 429.02339863747881 -988.77407965217367 187.62399623841367 430.56164528350348 -990.75564218545128 187.20123482450515 432.10576511670246
+8 0 0 6 11 -962.75720610808764 108.65467445859073 638.6700125620456 -967.01232975557843 106.18844614713757 628.67905721099669 -970.65993013548439 104.92216857591779 618.14031888117131 -973.65760380548022 104.7601926751444 607.29707893587909 -976.02005930902931 105.53360009808756 596.34774338758302 -977.79838840759362 107.06384044559286 585.40236197045215 -979.03562752168648 109.22343992386644 574.51431759420234 -979.76982499059068 111.9061452179088 563.72022555968795 -980.04273128033753 115.00628935338635 553.0483120936824 -979.88139632228547 118.46563428586501 542.49669389392966 -979.31662668594845 122.21168972455403 532.07741360408261 -978.37243941871247 126.19519197464879 521.78818983153269
+-962.49348751615071 109.82455603070792 638.26743542131203 -966.6838427438762 107.42335621011958 628.3961268078782 -970.27535003438197 106.21541859251076 617.9761357868806 -973.22546597757184 106.10471209369288 607.24813054744629 -975.54788311618267 106.92287141257903 596.40881829043997 -977.29238332026887 108.49243208542968 585.56775533729046 -978.50103632522837 110.6866638454988 574.77818807304141 -979.21105786221813 113.40042670696906 564.07681478601899 -979.46348988018451 116.52893144599848 553.49212452929009 -979.28497702999073 120.01384989241237 543.02242897709289 -978.70572958046637 123.78397090131033 532.6799770979793 -977.74950219435345 127.79004615312707 522.46278076256488
+-962.05690654284922 110.93517056289092 637.80586615544871 -966.17075015255114 108.59666128428138 628.05580637198466 -969.69119073579873 107.44324428436062 617.75573479028594 -972.57623530441288 107.37874440263121 607.14420172163773 -974.8393828223418 108.23555134597075 596.41663024543982 -976.52978175050566 109.8374022549752 585.68230195156491 -977.6889955170019 112.05840675301602 574.99441116857929 -978.35373603464552 114.79462745734614 564.38976939086808 -978.5646237127097 117.94221437891635 553.89714173289303 -978.34812372872739 121.4428067170482 543.51502970519266 -977.73393815812938 125.22658889688186 533.25586071673001 -976.74572562667049 129.24437881196579 523.11791598595732
+-961.45506116807314 111.95279891771908 637.2969055057074 -965.48293958816373 109.6708803678583 627.66689441933715 -968.91975689624655 108.56373169446263 617.48492708342394 -971.72482351459473 108.53529543041726 606.98774404761446 -973.91226044163318 109.41897669181702 596.36981114609443 -975.53111950548691 111.04018267659215 585.74021863771941 -976.62277774252846 113.27459524507091 575.15192234258461 -977.22453922367401 116.01724509518743 564.64322633897746 -977.37538550303054 119.16896869077939 554.24129284650508 -977.10311211831583 122.66858912341368 543.94641433251411 -976.43638171373095 126.44901759949109 533.77058177392382 -975.39901231058491 130.46101780568881 523.71249843481883
+-960.70387189788812 112.84660109448826 636.75499811937982 -964.63966706900339 110.61167310875085 627.24113285285318 -967.98415068610313 109.53848535362899 617.17264124104395 -970.69873049594594 109.53145211477749 606.78449512777718 -972.79893464004476 110.42543815338703 596.27032635066882 -974.33426485750078 112.04797033150803 585.73915416456816 -975.34629386548158 114.2767782663234 575.24376702399161 -975.87319534302605 117.00550391049096 564.82430497725886 -975.95230813737317 120.14059803810474 554.50604277501361 -975.61309814290917 123.61773614156007 544.29148909565606 -974.88311735634147 127.37282458386595 534.19213588488321 -973.78643511792586 131.35668747401726 524.20721666595148
+-959.8267198304676 113.59190062178544 636.19621963118527 -963.66838475344719 111.39168993569662 626.79217999755713 -966.91672966574288 110.3372556441731 616.83010621988035 -969.53607496333711 110.33395796269338 606.54298770687922 -971.54409403979287 111.21878326773776 596.12354868340003 -972.99127663406966 112.82180141045086 585.68091119462099 -973.91978864499276 115.02292245662294 575.2680497404026 -974.3680789374996 117.71620770867369 564.92612130213047 -974.37311428004125 120.81146201044551 554.68000945911933 -973.96505961282787 124.24357053898338 544.53351639749962 -973.17078227251091 127.95055044854803 534.49818371211552 -972.01449018314224 131.88363396157447 524.57381124947619
+-958.85170131614746 114.17198526159044 635.6366978490762 -962.6014171843392 111.99268458477817 626.33414284186983 -965.75498972136336 110.94041113185033 616.46946607401208 -968.28045307414243 110.92201748894537 606.27329618012402 -970.19828761849658 111.77739832168302 595.93729630523205 -971.56029940235703 113.33988653647137 585.57076882992294 -972.4093621547953 115.49205768493763 575.22702371316939 -972.78421233526058 118.1287154065092 564.9483814277836 -972.72139423083797 121.16330556105017 554.75949114636933 -972.25168205131524 124.53014564972689 544.6656201320061 -971.4011735761826 128.16938558662241 534.67849299400382 -970.19407912982558 132.0328146171525 524.79860513128028
+8 0 0 6 10 -978.37243038513066 126.19521751422829 521.78813449874497 -977.68784325685783 128.70385323319385 517.06970566589644 -977.86656756359639 131.10433169529745 512.27528288176677 -978.99917321726264 133.37097266374082 507.56518364568433 -981.13433430122245 135.48816211849726 503.14318745850841 -984.24106244245775 137.45445968055228 499.26931648151771 -988.15150978347697 139.25670834340758 496.15982104614636 -992.68307246314487 140.83915594512754 493.95157360305797 -997.62595812690063 142.07949739969277 492.73604364229305 -1002.7505033759528 142.86265096230909 492.49880569561248 -1007.8562700524344 143.11769561694487 493.15420469747369
+-977.74949268844659 127.79007125879392 522.46272530721103 -976.96702401313325 130.22253850858732 517.61116505130087 -977.08513317757695 132.57060222465267 512.66712234144347 -978.1981342978039 134.80980937376589 507.80592923626295 -980.35516759126983 136.92243764631834 503.24518608209524 -983.51692533047265 138.90145518068505 499.26072642755503 -987.50678269516879 140.72777127007541 496.07219006942182 -992.13804297193008 142.34199157844981 493.81685569737101 -997.19647273158728 143.62058648799993 492.59443960950614 -1002.4388191043024 144.44738519147455 492.39410671350208 -1007.6524988890425 144.74832591562111 493.12804645923359
+-976.74571579379506 129.24440344046377 523.11786028395284 -975.90368857408941 131.60952606343366 518.07274958853429 -975.99954005400343 133.91527185831524 512.92921075009372 -977.12969153950587 136.13772631936382 507.87456565927772 -979.34505067532882 138.25712482771462 503.13732194986648 -982.60065083149618 140.26173887765199 499.00797670525822 -986.71286173659246 142.12732754426725 495.7119475195139 -991.48973082430916 143.79031282672443 493.38925106633229 -996.71005676302912 145.12461713549072 492.14652120319431 -1002.1178665901965 146.01315105751871 491.97370544466156 -1007.489996594425 146.37896451783055 492.78038232823252
+-975.39900231417175 130.46104196773643 523.71244238117822 -974.53837348246827 132.78088618732704 518.42510087998028 -974.65039732172716 135.06298784403347 513.04237435495452 -975.83259026298458 137.28417919316797 507.76021102087174 -978.14190473738108 139.42444024232609 502.81465735934677 -981.52411448788257 141.46750960526595 498.5121429068048 -985.80054140681807 143.38788311141556 495.08277715241405 -990.76269287572393 145.11517175851165 492.67497150511798 -996.1866040701907 146.52086687487827 491.39878206341518 -1001.8024264694243 147.48587932316386 491.24264139087057 -1007.3786706743858 147.93033532123778 492.11247784605445
+-973.78642511337455 131.35671123512094 524.20716018711983 -972.94330629769127 133.66456595330502 518.64675872057239 -973.10427610888905 135.94855885054918 512.9991197212604 -974.36792731784726 138.18758074817387 507.46618418349732 -976.79974287593905 140.36378904656166 502.28977093071319 -980.33704454612689 142.45819194066306 497.79241751425025 -984.81000384028516 144.44680046553117 494.21008208737658 -989.99008102501546 146.25179121325385 491.70245647021176 -995.6505248115609 147.74134695590163 490.38122807123551 -1001.5081962787965 148.79287767467224 490.23065919708921 -1007.3250962922907 149.3229570550107 491.15176159259715
+-972.01448029168125 131.88365742398332 524.57375430811044 -971.21333515244942 134.21696231446342 518.72967273612107 -971.44557125353447 136.53076338932237 512.80672954777503 -972.81124779109166 138.80750803223648 507.01174659948339 -975.38403299103811 141.03374622986829 501.59253598151241 -979.09841206496526 143.19107394907019 496.88656505649743 -983.78766747239672 145.25791935238763 493.13931054301003 -989.20879552193287 147.15076615094094 490.52119611046385 -995.12733920753624 148.73248075241784 489.1459122128399 -1001.2492308133311 149.87530605024838 488.9909011428374 -1007.3308293627277 150.49114550207534 489.95111073626788
+-970.19406942959313 132.03283789677462 524.79854772238514 -969.44629782627646 134.42615379854317 518.67819738746232 -969.76057849888105 136.79558936118258 512.48367803205679 -971.23857445435578 139.12792143522498 506.42696101094481 -973.96231283265877 141.41609127965694 500.76269070867221 -977.86415609738708 143.64467824875004 495.84373799129258 -982.78047352273416 145.79649906329109 491.92618060705888 -988.45314601693553 147.7830723324083 489.19206279385293 -994.63980026953243 149.46094946500344 487.75657099268579 -1001.0360091107659 150.6949603585941 487.589016658584 -1007.3928533894434 151.39115042443947 488.57731807678505
+8 0 0 6 10 -1007.856269624325 143.11770120665565 493.15420250124725 -1013.3653617949839 143.81748873837537 493.86137732106761 -1018.8546995688936 144.67530141670636 494.56601627436663 -1024.3184296020956 145.69719345518146 495.26736785033711 -1029.7499255940488 146.88955748124542 495.9645813760485 -1035.1416515012504 148.25909616944347 496.65668955642889 -1040.4849802403708 149.81276951153524 497.34258522927848 -1045.7699701019103 151.55770084595557 498.02099252255249 -1050.985217014369 153.50097797852393 498.69044762105938 -1056.1180316356781 155.64922027266229 499.34932138433186 -1061.1536166606386 158.00837876517377 499.99571451386782
+-1007.6524994893496 144.74834032096359 493.12804698799874 -1013.1237034705961 145.41465189953044 493.83035854522541 -1018.5753097075431 146.23800276661942 494.53015363395969 -1024.0014624557118 147.22441852786304 495.22668043106012 -1029.395535493202 148.3802623649845 495.91908852553138 -1034.7499957311734 149.71220714458596 496.60641147184879 -1040.0562224258576 151.22718302782496 497.28754345543513 -1045.30428439497 152.93228390769912 497.9612103429908 -1050.4827935603832 154.83456921013843 498.6259504102901 -1055.5790839756783 156.94063214146337 499.28013707466408 -1060.5783919091807 159.25640164255961 499.92187441583366
+-1007.4899986966408 146.37897848616447 492.78038914471199 -1012.921886426844 147.01181435522875 493.48896332123417 -1018.3343707075181 147.8007036458516 494.19474794695992 -1023.7215950532244 148.75164330622593 494.89697789023131 -1029.0769351996962 149.8709670345647 495.59478805495445 -1034.392863142062 151.16531787497595 496.28719571404781 -1039.6607668900222 152.64159617087071 496.97307692684274 -1044.8707285247192 154.30686640692232 497.65113739860266 -1050.011379061028 156.16815968007421 498.31989316023828 -1055.0700794557481 158.23204308645273 498.97769348090418 -1060.0321035141772 160.50442348883394 499.622616882606
+-1007.3786712638724 147.93035874948458 492.11248182616083 -1012.7713129401239 148.53408324682127 492.83864034942565 -1018.1446435571351 149.29272987998709 493.5614260879471 -1023.4928152695375 150.21226534354955 494.28004844555244 -1028.8092153047505 151.29899055250314 494.99361325378084 -1034.0863306999991 152.55951319192872 495.70110473946556 -1039.3155692793569 154.00069716089308 496.40136187458381 -1044.4870392967689 155.62957316380084 497.09304951199351 -1049.5894052626084 157.45314550823716 497.77463939462808 -1054.6100688739405 159.47796200194438 498.44443282364125 -1059.5343570716936 161.70990913671369 499.10045531016505
+-1007.3250971045074 149.3229836743794 491.15175221348778 -1012.6802977615794 149.90636228866526 491.90519268571586 -1018.0160208768665 150.64323039904889 492.65446698862951 -1023.3264452668166 151.53951974116274 493.39874365295736 -1028.6049884103575 152.60149389426985 494.13708221900987 -1033.8441721057904 153.83572088994114 494.86841470718224 -1039.0354449166045 155.249024387585 495.59152186057685 -1044.1689636615934 156.84839837027519 496.30500455516557 -1049.2334504692831 158.64081871789443 497.00726512219757 -1054.2163738847696 160.63281413612296 497.6965296897335 -1059.1031423109662 162.83025333190579 498.37074127176339
+-1007.3308317260779 150.4911669775102 489.95110232344194 -1012.6521589717262 151.06609635472043 490.73811802202619 -1017.9534561081505 151.79272919093555 491.52017953908592 -1023.2289497607211 152.67694846557538 492.29639205409171 -1028.4721105787708 153.72496875125054 493.06574502278926 -1033.6755199634292 154.94330963704289 493.8270929879705 -1038.8306937820962 156.33874797278969 494.57913139134325 -1043.9278654633524 157.91823403005927 495.3203677462688 -1048.9558451307357 159.68870507907621 496.04910288042186 -1053.9022034019008 161.65665900236667 496.76345331960306 -1058.7524682735825 163.82794497799887 497.46124450550963
+-1007.3928566467803 151.39117314850978 488.57730488644444 -1012.6853821055233 151.97082816201632 489.40013897915884 -1017.9568777175823 152.70012903274099 490.21745830232311 -1023.2016341441076 153.58488505641395 491.02827980063927 -1028.4131938287921 154.63123704828081 491.83149618958828 -1033.5842192022794 155.84563184652424 492.62585590245521 -1038.7063181299891 157.23477613292889 493.40993830897781 -1043.7698290824217 158.805554767665 494.18212456475612 -1048.7636827716231 160.56484723863667 494.94057879984757 -1053.6755889655924 162.51910494735296 495.68327071714577 -1058.4912369863059 164.67414646538469 496.40786929271718
+8 0 0 6 7 -1061.1536100771793 158.00839316453602 499.99571324713463 -1061.9139842056077 158.75715664960234 500.09331896751206 -1062.6705476500833 159.54667732102277 500.1481524761025 -1063.4213066148964 160.38182772135241 500.15302741399535 -1064.1638154781758 161.26724619966396 500.09904507433765 -1064.8936214820314 162.21166728875119 499.97244816771041 -1065.6034904918779 163.22351910339282 499.75340440859014 -1066.2730847791709 164.30496789283347 499.41187802731213
+-1060.5783849379336 159.25641994260278 499.9218746104346 -1061.3384248162936 159.93300468069421 499.97004705027575 -1062.0931068340328 160.64488428285432 499.98014858437915 -1062.8404578117638 161.3965644833078 499.94585175101082 -1063.5775519915535 162.19258141821717 499.85941614774799 -1064.2999294560861 163.04104721745 499.7086606878355 -1064.9998012360836 163.95031858665573 499.4761677311671 -1065.6563051826686 164.9238777255822 499.13561296737839
+-1060.0320944862524 160.50445003840537 499.62261523299094 -1060.7878358647372 161.09931169040709 499.64171289312026 -1061.5369530351898 161.72560251440169 499.6273160288352 -1062.2775107504751 162.38747038616125 499.57381016971283 -1063.0061083633245 163.08933583269533 499.47428338962908 -1063.7182999292336 163.83861944611709 499.31795509320352 -1064.4057742073037 164.64351012786804 499.08928054417623 -1065.047154306372 165.50826465710983 498.7649794563506
+-1059.5343498991708 161.70993416248777 499.10045343066201 -1060.2800551861624 162.21986109047614 499.11229244523264 -1061.0182554328496 162.75849438891879 499.09457621102757 -1061.7470644731429 163.3295772426963 499.0422921309314 -1062.4625960956682 163.93737416938197 498.94911997104805 -1063.1604611485927 164.58847520833038 498.80555106217429 -1063.8318532124997 165.29077800941957 498.59750004897955 -1064.4549620873258 166.04876194523763 498.3041398425766
+-1059.1031363320083 162.83027746562183 498.37074092712828 -1059.8316620568789 163.25895614653598 498.39626204327936 -1060.5522258721037 163.71409201005429 498.39530933901972 -1061.2629700857754 164.19901641919844 498.36345141880378 -1061.9595851505703 164.71769304334006 498.29473088213712 -1062.6377207538906 165.27583737650468 498.18083586435245 -1063.2881816511276 165.88083111457533 498.00876728359481 -1063.8888445915175 166.53691357494111 497.75969419750072
+-1058.7524609525085 163.82797579354343 497.46123920789398 -1059.4560643188347 164.18528483072635 497.5180720204782 -1060.1515757836494 164.56664629244605 497.55081098853816 -1060.8371571711352 164.97497691093199 497.55556589507785 -1061.5081889123614 165.41375730870806 497.5265613254906 -1062.1602971638144 165.88789086655319 497.45668329676914 -1062.784067320121 166.40396910294211 497.33370158638041 -1063.3572740086386 166.9655561289473 497.14030711847681
+-1058.491230325594 164.67417872184134 496.40786078227336 -1059.1624622915731 164.97456183602938 496.50886024691846 -1059.8255895695138 165.2960465176983 496.58779484551417 -1060.4788139729599 165.64110252376307 496.64127164261924 -1061.1172736659348 166.01263305989443 496.66360812871579 -1061.7366509623646 166.41461304254892 496.64877262006371 -1062.3274472188743 166.85264858593501 496.5850950597204 -1062.8676486468476 167.32920065833198 496.4563345315816
+8 0 0 5 10 -1066.2730847791713 164.30496789283359 499.41187802731179 -1066.7418007802764 165.06198204544205 499.17280956041708 -1067.1919938826329 165.85161026281321 498.87693954281582 -1067.6161372960942 166.6719687973463 498.51498954591915 -1068.0101641372125 167.52574370549291 498.07985028297725 -1068.3551810423919 168.39830787428295 497.56145718181187 -1068.6485919632603 169.29032103253502 496.94809823987902 -1068.853028873355 170.14952931558381 496.25754338527344 -1068.9863944471902 170.95976607825193 495.51592834186806 -1069.0482721174649 171.70798391953932 494.74574181228564 -1069.0502061463194 172.39322468736029 493.95994249952622
+-1065.5329492633687 165.04765969213204 499.08035995539143 -1065.9906693782789 165.71404653830859 498.84210764718785 -1066.4281769916574 166.41002466624875 498.55504392035812 -1066.8376840692381 167.13487484633603 498.21136172268359 -1067.214607762043 167.89017070074925 497.80514113716538 -1067.5422787914317 168.66734702605251 497.32720297185983 -1067.8121109075589 169.46343367252524 496.76912379156238 -1067.996156206887 170.23829895950297 496.14537980815112 -1068.1052392080048 170.97444837889185 495.47928936686804 -1068.1443203333529 171.66088627388064 494.78971297365689 -1068.1236434108619 172.29594016209654 494.08751197908009
+-1064.8042568278745 165.73856713959884 498.60728920682988 -1065.2488458744408 166.31336597221446 498.38589921871477 -1065.6717879539506 166.91536095364143 498.12233062328875 -1066.0650451664994 167.54472207955635 497.80975040436255 -1066.4235207335685 168.20169876784672 497.44352406382137 -1066.7327233749372 168.88312586721898 497.01447245032051 -1066.9780889760477 169.58176788313529 496.51713560886338 -1067.1409871770486 170.26880637846085 495.96294246883275 -1067.224933077604 170.92469882460463 495.37273978178041 -1067.2402681250624 171.54101814574196 494.76282926496884 -1067.1958277316166 172.1153551914351 494.14244070197611
+-1064.1056673467785 166.3589567508765 498.00099047832305 -1064.5334307249686 166.84533542840617 497.81167617747411 -1064.9385216039288 167.35654723882749 497.58533544814793 -1065.312764453583 167.89339498063316 497.31566867746136 -1065.650311384876 168.45436509603755 496.99951895184211 -1065.939554491538 169.04189830162386 496.62675706616636 -1066.1591151786606 169.64253171463537 496.19479590000827 -1066.300525298343 170.23964831658168 495.71200114316895 -1066.3593614347437 170.81015594620439 495.19700030476014 -1066.3513635243366 171.34909222871715 494.66446736610686 -1066.2838337252119 171.85325241597215 494.12236897781776
+-1063.4551990809973 166.89282722307036 497.27710163585573 -1063.861064499436 167.29784303477916 497.13267675675615 -1064.2437477420733 167.72475489479268 496.95510295401886 -1064.5950561897678 168.17467179908178 496.73824845524632 -1064.9085496031678 168.64444289230809 496.48046410950889 -1065.1752335209253 169.14106669570884 496.1701695073607 -1065.368012496147 169.64505300592822 495.80693820217692 -1065.4876039333033 170.15108871221562 495.3965242833458 -1065.5223607779565 170.63250278331728 494.95503679714261 -1065.4928324580217 171.08829343219202 494.49643929573193 -1065.404754893184 171.51454442741729 494.02767301088386
+-1062.8676486468482 167.32920065833196 496.45633453158155 -1063.2457896464296 167.66278710900986 496.36620216188447 -1063.6007369706422 168.01436424520347 496.24593895760751 -1063.9245120374605 168.38503898155602 496.08924992157023 -1064.2100230064793 168.77007292433558 495.89604130794299 -1064.4514155314694 169.18037686625445 495.65261166816521 -1064.6160634114694 169.59014071506908 495.36035247922916 -1064.7139629733788 170.00525521223815 495.02226408419398 -1064.7264715425426 170.39532843795541 494.65177933726648 -1064.6784142642491 170.7639839029319 494.26280404024976 -1064.5738964958907 171.10675440908074 493.861425127789
+8 0 0 6 11 -1069.0502061463187 172.3932246873602 493.95994249952633 -1069.053722562418 173.63911699248925 492.53121647632736 -1068.8595626515723 174.67793652927509 491.05127628895349 -1068.5195940840208 175.49461872932616 489.6108701490071 -1068.1045078789653 176.15902848504376 488.21746685993929 -1067.6169123158554 176.69690238062825 486.86870035982469 -1067.0867001650108 177.13194411933964 485.56350618495458 -1066.5095304137938 177.47675765392975 484.29439701542299 -1065.9076273228086 177.74751691681894 483.06570459828009 -1065.2711572025382 177.95059430439332 481.86951085151748 -1064.6130087712545 178.09403184685675 480.70648097427335 -1063.9324841412592 178.18354221590403 479.57442086582887
+-1068.2780705334378 172.3121542496404 494.06625039915451 -1068.2473279323469 173.48200582809508 492.76418849441404 -1068.0199599205077 174.47657032052155 491.41923419833591 -1067.6510288314662 175.27919728336491 490.10947210757331 -1067.2074924398692 175.94930102410621 488.8408823309943 -1066.6974506087804 176.50999103110351 487.60913208037289 -1066.1440716298735 176.98070891653981 486.41328419596641 -1065.5484802021185 177.37299451742672 485.24728556841308 -1064.9284302048789 177.70050781798389 484.11340994316424 -1064.2770297848267 177.96862508795954 483.00505844562571 -1063.6052860194757 178.18435893771334 481.9227061571238 -1062.9130416845037 178.35246962054509 480.86415107861842
+-1067.5050996246982 172.1755501816555 494.12413112767757 -1067.4387010129515 173.25659744202045 492.9465686303671 -1067.1762985874143 174.18938661869674 491.73260984973467 -1066.7759313087574 174.95664478501536 490.55028276698835 -1066.3007159472384 175.60843506340734 489.40521236659674 -1065.7643716640432 176.16627464993962 488.29153895049024 -1065.1833685005845 176.64583873104155 487.20862576678945 -1064.5642390759722 177.05782297889647 486.15195125962134 -1063.9203333911635 177.41380744634321 485.12180329424797 -1063.2478461069563 177.71870766313643 484.11293767004452 -1062.5557964385482 177.9784886362159 483.12562958727614 -1061.8446853727569 178.19734484950732 482.15766329128007
+-1066.7398307284141 171.98430380370354 494.13240483989705 -1066.6380396442594 172.9647558336564 493.07559852054993 -1066.3411875435022 173.81921528834425 491.98642435322819 -1065.9098848230633 174.53082241712863 490.92525175831389 -1065.4031288589151 175.1409116602714 489.89806924931918 -1064.840575423684 175.67083788290094 488.89885929670572 -1064.231204299683 176.1321238262372 487.92619151043829 -1063.5880037251152 176.53517408162188 486.97853486039821 -1062.9189244692657 176.88977290114116 486.05346934232864 -1062.2238822863178 177.20064859329679 485.14763938100174 -1061.5096649371669 177.47270163921203 484.26104325608054 -1060.7775061313027 177.7098464522949 483.39158213447746
+-1065.990807447869 171.74034975312046 494.09080365550653 -1065.8555728035742 172.60978694689939 493.1496139213088 -1065.5273091285419 173.37096836325597 492.17708863970927 -1065.068585520019 174.00857739769424 491.22802904164718 -1064.5341234100308 174.55565622883302 490.30938686188597 -1063.9491270271467 175.03476882554813 489.41621924262284 -1063.315314508292 175.45265972381549 488.54562693315029 -1062.6519305546942 175.81998294356134 487.69979825405295 -1061.9615513795425 176.14490844675166 486.87356852935557 -1061.2477779311387 176.43208589585544 486.06563803304488 -1060.5152080573584 176.68528692559195 485.27573129596493 -1059.7657902613184 176.90830625490739 484.50200828810785
+-1065.2662784936349 171.44657942436112 493.99996503036817 -1065.1011555868031 172.19628411595963 493.16808311015575 -1064.7468367596921 172.85140219142843 492.30253360259348 -1064.267033334165 173.39941877708424 491.4543084185616 -1063.7120997220809 173.86557599627019 490.63196072581775 -1063.1118045568219 174.27465303810939 489.83235736801356 -1062.4617112028632 174.62823842722344 489.05129995154914 -1061.7859738353575 174.93756884687895 488.29434828325799 -1061.0828087756372 175.20934579187644 487.55431231534175 -1060.3587899958034 175.44820674051394 486.83172945647755 -1059.6166518709013 175.65672983127121 486.1260843171205 -1058.8589439609816 175.83868794721943 485.43590828873312
+-1064.5738964958907 171.10675440908062 493.86142512778906 -1064.3838641897851 171.72997351116939 493.13164528695143 -1064.0108636053869 172.26883643834958 492.36230811845672 -1063.5187680145011 172.71501208013152 491.60204105540129 -1062.9531449811439 173.08663142020106 490.86166540651948 -1062.3478700555074 173.41111524864553 490.14042137892449 -1061.6922170194227 173.68505155548812 489.43299573470216 -1061.015310875488 173.92028434199707 488.74828776845834 -1060.3108808241093 174.12213740208267 488.07722298706443 -1059.5882336626805 174.29536352408951 487.42242242077702 -1058.8484477153527 174.4412685628017 486.78294110318927 -1058.0945209048957 174.56365784361262 486.15782174523412
+8 0 0 6 8 -1055.0284409624016 179.42753570099757 471.95785453199767 -1056.1441447813825 179.27148118641153 472.90171325904356 -1057.2592059037133 179.11594064334952 473.84769659576824 -1058.3735718524799 178.96075182545809 474.79591196762118 -1059.4871790867599 178.80573990644052 475.74646920235682 -1060.5999559935999 178.65071770873627 476.6994811779403 -1061.7118245016227 178.49548568204042 477.65506404099631 -1062.8227008359743 178.33983169817682 478.61333719368378 -1063.9324957131 178.18353067905065 479.57442316600691
+-1054.0149030268874 179.66048515445206 473.2755856288357 -1055.1298245443982 179.49666206288691 474.21650946117984 -1056.2441184725174 179.33327907673407 475.15940517262965 -1057.3577304679211 179.17017753455431 476.10437633675258 -1058.4705958009242 179.0071861137435 477.05152841604121 -1059.5826421291194 178.84412107749031 478.00096948215179 -1060.693790967978 178.68078628458846 478.95281048185495 -1061.803958354466 178.51697302168327 479.90716524914296 -1062.9130549852234 178.35245967353075 480.86415038384058
+-1052.9430150045596 179.56064600340486 474.60726827752126 -1054.0583743309392 179.38998150828439 475.54406644712157 -1055.1731122247609 179.21972973033505 476.48266019481099 -1056.2871709674944 179.04973560303722 477.42314957496677 -1057.4004832882706 178.87983163523708 478.36563597180873 -1058.5129748890349 178.7098380874954 479.31022292881897 -1059.6245657515651 178.53956295343289 480.257016485348 -1060.7351706958902 178.36880179082019 481.20612522919663 -1061.8446994526394 178.19733741037101 482.15766019259155
+-1051.8641569454744 179.11618505282348 475.88609742072288 -1052.9810363562824 178.94004153055178 476.8179588319997 -1054.0972848595522 178.76433174371797 477.75142979851154 -1055.2128399457497 178.58890381650372 478.68660718168786 -1056.3276305021207 178.41359401699469 479.62358861126143 -1057.441579063252 178.2382267677504 480.56247345138752 -1058.554602937761 178.06261453448832 481.50336322414677 -1059.666614651075 177.88655761404698 482.44636171255411 -1060.7775219457421 177.70984381500298 483.39157488063682
+-1050.8348500349948 178.34350634183514 477.04384485404893 -1051.954070659426 178.16350522976094 477.97044703336485 -1053.0726295760799 177.98400276344725 478.89847827330323 -1054.1904584434669 177.80484954288605 479.82803234778851 -1055.3074812232314 177.62588518909718 480.75920337349675 -1056.4236161862655 177.44693809907935 481.69208688076588 -1057.5387768784153 177.26782518107876 482.62678030248014 -1058.6528724594634 177.08835155942421 483.56338311416056 -1059.765807638267 176.90831022118402 484.50199677090131
+-1049.9071083487943 177.28886818117297 478.0232958120161 -1051.029172124104 177.10663225154647 478.94479357040632 -1052.1505194593265 176.9249930867951 479.86755866058417 -1053.2710755828357 176.74380296853209 480.79168167909114 -1054.3907587579251 176.56290430588771 481.71725336859953 -1055.5094821150799 176.38212906980712 482.64436572086652 -1056.6271545024247 176.20129833047798 483.57311248333633 -1057.7436807493425 176.02022184949118 484.50358930657563 -1058.8589615532831 175.83869767331262 485.43589368069723
+-1049.1207867878597 176.01677785876026 478.78580774805306 -1050.2459032343575 175.83374681468854 479.70272161515157 -1051.3702254075915 175.65143053229176 480.62076900445146 -1052.493671769538 175.46968227497339 481.54003730006582 -1053.6161544112085 175.28834664717988 482.46061398421693 -1054.73758074036 175.10725868454637 483.38258774132237 -1055.8578542383523 174.92624317611495 484.30604895959226 -1056.9768746640127 174.74511413139251 485.23108986958914 -1058.0945379032169 174.56367431195886 486.1578044687335
+8 0 0 6 7 -996.77226793690636 189.29639490612192 424.6984683660055 -1005.3132144252506 187.64380087977094 431.26373206535555 -1013.684741613194 186.0135821787255 437.93772638034852 -1021.9890612041816 184.47384140631209 444.65510626968086 -1030.2718306752638 183.05324928497242 451.40131671088022 -1038.5463383138642 181.75375019801925 458.18458120378045 -1046.8090143818633 180.55842558102282 465.02071163532452 -1055.0462684070008 179.43451516282815 471.93073950569567
+-995.84876733389888 189.77968832293547 426.04305221291241 -1004.3620812819697 188.12177157944919 432.61582681569172 -1012.715215392577 186.47160264982057 439.2945085598177 -1021.0059617893756 184.90042898116261 446.01341702392324 -1029.2783457711321 183.44002874603376 452.75750471229571 -1037.5447723291898 182.09467952089491 459.53444742809432 -1045.8008763372304 180.84900902327271 466.359531373332 -1054.0330764133366 179.67172790762925 473.25333697562212
+-994.82420378957568 189.93428284722197 427.43637249424648 -1003.3082195301292 188.26289886237382 434.01478989897868 -1011.6457517296091 186.58781663662509 440.6953035092867 -1019.9290300835804 184.98273835245007 447.4118978448912 -1028.1990261602768 183.48220170630142 454.14898331412263 -1036.4663606996287 182.09261205385354 460.91373966500993 -1044.7251671593019 180.8000118468583 467.72102782164342 -1052.9614686881696 179.57449295023369 474.59117272332941
+-993.74666005054303 189.7349888645125 428.80841559529932 -1002.2022449390374 188.04169345985682 435.38862237373394 -1010.5284847521261 186.33753279414535 442.06714207270056 -1018.8111333856567 184.69778167714529 448.77745891179063 -1027.087017045638 183.15911480835049 455.50325492798169 -1035.3640333857145 181.72957212456677 462.25114079269486 -1043.6343079052456 180.39635674027551 469.03560446222872 -1051.8830703348306 179.13070236874125 475.87685280689232
+-992.67321689465894 189.18521930694678 430.08465777328848 -1001.104141254577 187.46263684570582 436.66085637103373 -1009.4247835348474 185.72679686116984 443.33278828430241 -1017.7138662080825 184.05357159463492 450.03310920499172 -1026.003304870306 182.48091778686322 456.74436633964876 -1034.2977091300509 181.0179027036761 463.47247060132707 -1042.58678365316 179.65250318814972 470.23144888577627 -1050.8546722581946 178.35676692747066 477.04145046045852
+-991.66057138090184 188.32118344067322 431.19954001591901 -1000.0731463447777 186.5644957030855 437.76474958596674 -1008.3947141566759 184.79657831729068 444.42528974158859 -1016.6968234665665 183.09294172507958 451.11250860468743 -1025.0061328220252 181.49193013361173 457.80726645949704 -1033.3238647253183 180.00306561916267 464.5145892648456 -1041.637017489765 178.61467463424091 471.24784626771248 -1049.9284936774757 177.29928359410761 478.02710987308427
+-990.75582897676838 187.2012193948342 432.10588064175693 -999.15797985146537 185.40879956017824 438.65299049687354 -1007.4871050055363 183.61066762319862 445.29773365833148 -1015.80780960306 181.88112126082299 451.96954749317661 -1024.1416935282377 180.25816259880901 458.64710731111018 -1032.4866913870014 178.75124996951024 465.33423120889807 -1040.8270869412215 177.34872311589817 472.04347066855985 -1049.144476644806 176.02328600584735 478.79472919085487
+8 0 0 8 1 -1370.4053730055323 253.96081542968778 539.692814594933 -1370.4053730055325 -2.0463630789890885e-12 539.692814594933
+-1374.9885803101872 253.96081542968778 540.28113793979639 -1374.9885803101874 -2.0463630789890885e-12 540.28113793979639
+-1379.4682244830533 253.96081542968778 541.67624773339071 -1379.4682244830535 -2.0463630789890885e-12 541.67624773339071
+-1383.6786162184353 253.96081542968778 543.85687527018831 -1383.6786162184355 -2.0463630789890885e-12 543.85687527018831
+-1387.4593105392946 253.96081542968778 546.7609213883344 -1387.4593105392948 -2.0463630789890885e-12 546.7609213883344
+-1390.6676638596186 253.96081542968778 550.28705274948118 -1390.6676638596189 -2.0463630789890885e-12 550.28705274948118
+-1393.1908329756645 253.96081542968778 554.30154557316962 -1393.1908329756648 -2.0463630789890885e-12 554.30154557316962
+-1394.9535928138578 253.96081542968778 558.64967402165519 -1394.953592813858 -2.0463630789890885e-12 558.64967402165519
+-1395.9209712992022 253.96081542968778 563.16809104774381 -1395.9209712992024 -2.0463630789890885e-12 563.16809104774381
+8 0 0 7 5 -1370.405373005176 152.68650657912542 539.69281459488718 -1366.8450959183133 153.25645274458819 539.23579967385911 -1363.2848546361661 153.82662698435121 538.77878965536991 -1359.724655180695 154.39706590356141 538.32178468170594 -1356.1645033312855 154.96780613699241 537.86478554809855 -1352.6044047102887 155.53888434028462 537.40779353585242
+-1370.9622558543178 156.22250080110337 539.76429885483503 -1367.4016405542372 156.78914951014096 539.30724048874856 -1363.8411267343874 157.35629074975614 538.85019546748572 -1360.2807170236474 157.92395009868238 538.39316350152785 -1356.7204138721088 158.49215327892429 537.93614496162286 -1353.160219613598 159.06092611664883 537.47914070878142
+-1371.6143418120757 159.75849502434227 539.0941236417766 -1368.053212259143 160.32184627096152 538.63839322231149 -1364.492264509867 160.8859545064864 538.18257050107934 -1360.9314971238962 161.45083428480743 537.72665998408399 -1357.3709085715129 162.01650041560885 537.27066669200144 -1353.810497265388 162.58296789527887 536.81459602739449
+-1372.3324822259328 163.10941921668132 537.67856327907521 -1368.7707336428082 163.66998643238568 537.22554238578914 -1365.2092538377315 164.23153113879849 536.77220724754909 -1361.6480385609873 164.79405163818399 536.3185531719887 -1358.0870791059972 165.35757974855653 535.86464621632967 -1354.526371163003 165.92210322080408 535.41046954440174
+-1373.0800565159311 166.09012461205751 535.57200235467735 -1369.5176847126706 166.64894178901878 535.12286271912058 -1365.9556648700661 167.20887133336066 534.67309049527569 -1362.3939859365671 167.76989606860954 534.22270466815246 -1358.832640846925 168.33206478387655 533.77176680335185 -1355.2716185906684 168.89534940536339 533.32028305535084
+-1373.8167671141325 168.53993797735055 532.88799383997389 -1370.253876411557 169.09843245976148 532.44348777668085 -1366.6914061968025 169.65805595455976 531.99797001763977 -1363.1293435748817 170.21881075987713 531.55148642472443 -1359.5676757146036 170.78069877644811 531.10408231487236 -1356.0063898248279 171.343721615047 530.65580260017782
+-1374.5045028678853 170.34603999494499 529.7827368305891 -1370.9412929436053 170.90582593461414 529.34306066233239 -1367.3785481191851 171.46662252764756 528.90197793773609 -1363.8162537114838 172.02843966066251 528.4595513365914 -1360.2543950205725 172.59128612453338 528.01584281172336 -1356.692957327688 173.15516990677955 527.57091376931396
+-1375.1114928778582 171.45060411895486 526.43161987221629 -1371.5482248593382 172.01325159120435 525.99641287690565 -1367.9854370067778 172.57666218767181 525.55943673290153 -1364.4231144288965 173.14085920071886 525.12076856765498 -1360.8612420568465 173.70586398969786 524.68048489251066 -1357.2998046877181 174.27169649051089 524.23866174257205
+8 0 0 7 10 -1185.9733651956262 158.12825347020191 516.01820227193969 -1202.6378921254554 159.63605632109352 518.15734424779328 -1219.293054530724 161.2474734984516 520.29520323788984 -1235.9570903242657 162.75541046205748 522.43475211215309 -1252.6561536678662 163.92344231582362 524.57705038752692 -1269.3973700807796 164.51623472195362 526.7281110666944 -1286.209441642297 164.27410290328748 528.88402078335321 -1302.9567211615654 162.99161670631133 531.03525339871294 -1319.557647862955 160.8455600301856 533.16563241392669 -1336.0807760027183 158.18934876756472 535.28673796911994 -1352.6044387529221 155.53877091851305 537.40779772361452
+-1185.6381426846974 161.89420672683994 515.97517107106876 -1202.2897394383888 163.31294906697443 518.11265320921586 -1218.9686938814486 164.85280105776607 520.25346169527279 -1235.6926254249017 166.3107607036994 522.40108246969396 -1252.4909990036051 167.44777156732539 524.55565588086506 -1269.3626651497148 168.02533269746027 526.72339554218593 -1286.3436115600518 167.7832587224469 528.90184245210469 -1303.2723392081543 166.49498083527536 531.07530666180571 -1320.0236389357035 164.34994490396116 533.22558855740363 -1336.6361433118564 161.70066787122752 535.35802937277504 -1353.1602492735399 159.06078645248581 537.47914384561329
+-1185.4091015091103 165.66016104711525 515.10495613464536 -1202.0428515472979 166.98984287322702 517.27907996391673 -1218.7416300341035 168.45811965809276 519.45390035030528 -1235.5224051724958 169.86611268252884 521.63261874721582 -1252.4182367551907 170.9721913167084 523.81565783638621 -1269.4188579823333 171.53420450406003 526.00920767493301 -1286.5686996290408 171.29268274560425 528.2123806960102 -1303.67938641723 169.99818013942715 530.4026628734922 -1320.5824276678416 167.85437632292016 532.56271672211358 -1337.285408949306 165.21198837476391 534.69782766182573 -1353.8105213670499 162.58280295009973 536.81460847284484
+-1185.3058066832402 169.2062868517167 513.41009185359724 -1201.9166429034249 170.46228285937494 515.6591358595507 -1218.629076789698 171.87086875830275 517.89875168044625 -1235.4598320714304 173.23722892040132 520.13108107358096 -1252.445929424518 174.31798591373251 522.35812215991996 -1269.5673348961866 174.86714916846572 524.58575589777752 -1286.8781893617199 174.62719576585138 526.81479136771236 -1304.1622823244459 173.3250033248257 529.01536815730276 -1321.210322030116 171.18009367076488 531.17398994267819 -1337.9999011130697 168.5420491067932 533.30247083241306 -1354.5263890988501 165.92191730891818 535.41050154732318
+-1185.3385589874915 172.31261130248586 510.96538463140638 -1201.9221193366275 173.52569877614468 513.32092538518918 -1218.6404865332408 174.89839135895684 515.65076589377304 -1235.511010605017 176.23979206295198 517.95514888377704 -1252.5751351534252 177.30637432662135 520.23863033876762 -1269.8026748586399 177.84844358215514 522.5064343549252 -1287.2587744505643 177.61157154469831 524.76107608518487 -1304.698570917679 176.29922617150098 526.96507175928639 -1321.8765428562988 174.14829262854775 529.11154599662132 -1338.743681840127 171.5095245491695 531.22481881456758 -1355.2716275325315 168.89513970651223 533.32035337293246
+-1185.5053822630664 174.79170971189484 507.91833949997783 -1202.0590452556337 176.00424954640874 510.39844904940827 -1218.775166688906 177.37399347192485 512.83347319519839 -1235.672958674427 178.71358866752689 515.22075965325052 -1252.7988358046969 179.78142686652441 517.56766045614961 -1270.1124295517707 180.32456263993896 519.87833660747003 -1287.6910733382035 180.09258045741475 522.15674672474915 -1305.2607707122443 178.76693129601466 524.3578468925981 -1322.5461876427503 176.60313963316571 526.48365519913239 -1339.4772254078659 173.9567182162626 528.57528216487947 -1356.0063938276899 171.34351212336432 530.65590998473738
+-1185.7923462790131 176.51932719919591 504.4650605817011 -1202.3159658078093 177.77800346012714 507.07092923985408 -1219.0223953851955 179.18159799585629 509.61295179071482 -1235.9340807018407 180.54549278166957 512.08449727605625 -1253.1029780281408 181.6319808010403 514.4950649872053 -1270.4789213685813 182.18555261491886 516.84732428557584 -1288.1523291039646 181.96029474891398 519.14611696744498 -1305.8201963455574 180.61807278089049 521.33930439066069 -1323.1851800528675 178.43390401868473 523.43932231837073 -1340.1630859662894 175.77217481937976 525.50597922106556 -1356.6929581938052 173.1549727037316 527.57105971224792
+-1186.1770003278455 177.44160575830938 500.81840824792567 -1202.6730771649422 178.79034131995533 503.53491466492534 -1219.3639537094598 180.26311180466689 506.17282733990186 -1236.2765657177381 181.67670997751003 508.72057755492108 -1253.4689068452201 182.79877055867215 511.18843353358523 -1270.8818349932778 183.37204067262175 513.57715659219707 -1288.6193111123105 183.15507782498892 515.89168626786852 -1306.3502792559473 181.79345565841982 518.07363546625982 -1323.7640158214194 179.58197742930798 520.14649280269771 -1340.7699343332081 176.89776850067648 522.18817481554015 -1357.2998046323969 174.27152323881714 524.23884403374404
+8 0 0 7 9 -1019.7806953264925 166.26735848040033 494.68488249587847 -1037.8081286840984 161.68913237080289 496.99897373505405 -1056.0313992871245 157.89734617297495 499.33828519221413 -1074.5007342367362 155.23754074391945 501.7087264915404 -1093.1121690063833 153.7720289148256 504.09856408583465 -1111.7511771239735 153.34679729674502 506.49021662018731 -1130.3640988188406 153.78353417087862 508.8801556973504 -1148.929922409447 154.90742277694832 511.26306671748114 -1167.4572241624833 156.45291696921123 513.64137785432433 -1185.9733651956267 158.12825347020191 516.01820227193957
+-1020.9230714141522 170.83975235848902 494.83152358708634 -1038.7652882781751 166.26225602947378 497.12183950605089 -1056.7344414539982 162.45860373056473 499.42845447935321 -1074.9334669054547 159.74658845803708 501.76445455336955 -1093.3023827915495 158.17752783303595 504.12286137093719 -1111.7463795324193 157.6166831393848 506.48952394193594 -1130.2090938692952 157.90873304337376 508.8604088927749 -1148.6691170499814 158.89320946368474 511.22952215529517 -1167.1363685139299 160.3178263489128 513.60019091757192 -1185.6381426846979 161.89420672684 515.97517107106876
+-1022.2305747176987 175.41214624793744 493.69177640994741 -1039.8844299523396 170.8353797182975 495.98281854735757 -1057.5948367492274 167.01984081985498 498.29270327010568 -1075.5173505286541 164.2556900548245 500.64297136331277 -1093.635816118654 162.58297636795888 503.03099792979435 -1111.8761780633936 161.88657769646647 505.44066099699864 -1130.1800761533066 162.03395107805679 507.85900756917061 -1148.5265909962613 162.87898704642265 510.27458580896626 -1166.9271570222359 164.18273679588006 512.68926299101065 -1185.4091015091108 165.66016104711534 515.10495613464548
+-1023.5995098360357 179.56955626993479 491.25244883580746 -1041.0806426825591 175.00135137239855 493.5711210322267 -1058.5529164551756 171.18658143540097 495.92347640024246 -1076.2187011530964 168.39070608623447 498.34001749083302 -1094.1003102582808 166.64280954213569 500.82149224519804 -1112.142872842242 165.84251670688923 503.343974104653 -1130.2888985823063 165.87483436220313 505.87750590632362 -1148.5196949950139 166.60639575663026 508.40052149202614 -1166.8493219941472 167.81073573209656 510.91115406920466 -1185.3058066832411 169.20628685171681 513.41009185359735
+-1024.9035937101137 182.89613062766429 487.67459595954529 -1042.2473258940479 178.35221058334645 490.04360438039743 -1059.5286149454907 174.56363062551398 492.47131447037452 -1076.9851112134102 171.77688368126172 494.99681704261513 -1094.6669903167995 170.01100084002391 497.62309863202108 -1112.5340502129472 169.17017331533637 500.31444469939737 -1130.5344912098133 169.14674987328848 503.0182622246831 -1148.6543544160718 169.81685913192811 505.69871869605839 -1166.9123808217853 170.9647363317541 508.34811712720335 -1185.3385589874918 172.31261130248609 510.96538463140649
+-1026.01785714633 185.07308666979009 483.30108022863237 -1043.2752031295167 180.57329042294995 485.73137776796341 -1060.4340602128325 176.84335918837775 488.25016998433989 -1077.7516813450193 174.11875806451968 490.9040025316682 -1095.2917555602414 172.41018156844754 493.69746153740311 -1113.0215861002471 171.61348225135595 496.58348609493555 -1130.9004030516535 171.6145604129363 499.48563490112747 -1148.92199125049 172.29415495185131 502.35049852237154 -1167.1124233824371 173.44444322910175 505.16266222283309 -1185.5053822630673 174.79170971189495 507.918339499978
+-1026.851885679863 185.96350467235138 478.56537261700618 -1044.0806835230628 181.52511748451306 481.05366446188685 -1061.1954079834436 177.88314842442495 483.65851864055162 -1078.4560313439117 175.27102830446654 486.43220255992327 -1095.9245057188682 173.69384571942527 489.38091095167107 -1113.5671310820369 173.02799657424154 492.45106423066119 -1131.3577830969512 173.13835585032726 495.54644521461108 -1149.3010058721504 173.90383186177954 498.59416963749732 -1167.432769024796 175.1207980203836 501.56965096153135 -1185.7923462790141 176.51932719919606 504.46506058170127
+-1027.359572733247 185.60024016296489 473.89165832709529 -1044.6160335636773 181.23343085284398 476.42269540498631 -1061.763368810904 177.69839950893956 479.0911313695089 -1079.0487058455151 175.23537487174013 481.95276938270865 -1096.518493606902 173.84741396714568 485.01581649611967 -1114.1297275941322 173.38483139419122 488.22757683946173 -1131.8715680350426 173.67908496390075 491.48076652850983 -1149.7617434654831 174.5997798133024 494.68309409804027 -1167.8480260644058 175.94301068981406 497.80006778459307 -1186.1770003278466 177.44160575830958 500.81840824792596
+8 0 0 7 9 -1400.934251173238 6.2124503946107273e-12 586.58404404085229 -1400.9342511967377 -4.9002520878747218 586.58404415059806 -1400.9343741821726 -9.8004460812720584 586.5846186619832 -1400.922337402892 -14.70102706199151 586.52839630293704 -1400.8879744601245 -19.600540899448429 586.36789865878814 -1400.8499542231777 -24.496839907128354 586.1903065987118 -1400.7960074676598 -29.391611426319123 585.93834075001007 -1400.7351954330798 -34.283225330765333 585.65429632466066 -1400.6649090324254 -39.172211219791571 585.32600477734604 -1400.5857799393232 -44.057864555294493 584.95640978986728
+-1401.7014216683604 5.8304821280706734e-12 590.16733256629357 -1401.7014216891666 -4.9002514416666187 590.16733266345318 -1401.701567937906 -9.8321688940223506 590.16788241223276 -1401.6892444549735 -14.801000659283357 590.11027427356646 -1401.6535409774942 -19.724034799606589 589.94459815958703 -1401.6150415425918 -24.665027753980681 589.76303137679793 -1401.5597546829629 -29.586959289525517 589.50570367467697 -1401.4978856670432 -34.50879052791052 589.21684185567926 -1401.4265380245045 -39.425410250688905 588.88341013373611 -1401.3463768670395 -44.338932973356961 588.50899459536868
+-1403.2345633728767 5.2175931272005427e-12 593.58662913982153 -1403.2345633950827 -4.9002507954719743 593.58662922351834 -1403.2347240348502 -9.8638922938039979 593.5871500089246 -1403.2214763222451 -14.900974602101583 593.52830614807135 -1403.1832530663767 -19.847528218436675 593.35770245962533 -1403.1428619755168 -24.833214855585695 593.17244971142725 -1403.0848171132977 -29.782307207256181 592.91006464448378 -1403.0205103693336 -34.734356557057005 592.61669617146936 -1402.946723688274 -39.678609282739274 592.27841097027158 -1402.8643808467284 -44.620001392405307 591.89942101146733
+-1405.4915946644078 4.3950968489520485e-12 596.64546905933423 -1405.491594692068 -4.9002501850415827 596.64546912830133 -1405.4917599870851 -9.8938791387599068 596.64596005403655 -1405.4769970430928 -14.995464994478422 596.58624386755594 -1405.4352317883115 -19.964262768524534 596.41163980760814 -1405.3916174709514 -24.99220901760777 596.22345491363876 -1405.3295637233557 -29.966998031749384 595.95704131255525 -1405.2615668575527 -34.947644917778028 595.6600746353115 -1405.1840945069673 -39.918055909224044 595.31785080099007 -1405.0985376629421 -44.885831346017355 594.93508508097602
+-1408.3675506685131 3.4045650686442264e-12 599.16074978147583 -1408.3675507048472 -4.9002496452725461 599.16074983428643 -1408.3677114439286 -9.9203804224815073 599.16121356600411 -1408.3509953487128 -15.07897477857261 599.10120435387728 -1408.3049921125996 -20.067462076647583 598.92406546504981 -1408.2571532917455 -25.132820538701129 598.73423383868783 -1408.1902190410556 -30.130387000032453 598.46542152645145 -1408.1176406197264 -35.136388936499984 598.16633455437534 -1408.0355986206644 -40.130000074468391 597.82167505810594 -1407.9461057890169 -45.121177099688744 597.43645100502488
+-1411.6997784966611 2.3040557753935968e-12 600.99021680918486 -1411.6997785435258 -4.9002492064292831 600.99021684455147 -1411.6999274038576 -9.9419102391388865 600.99065900078983 -1411.6810773066534 -15.146799507556663 600.9310902478436 -1411.63063917255 -20.151300469293265 600.75322046334509 -1411.578138486097 -25.247120066671883 600.56344460225148 -1411.5060324193523 -30.263266679353212 600.29424256426444 -1411.4285378268441 -35.289975652751984 599.99490124587794 -1411.341588013931 -40.302562407024453 599.64970082709351 -1411.2478991124412 -45.312882242768275 599.26368623183612
+-1415.2928255249401 1.158539780514203e-12 602.05423071719667 -1415.2928255825691 -4.9002488903645336 602.05423073433815 -1415.2929580751529 -9.9574313223955802 602.05465874909055 -1415.2720767645046 -15.195688028884014 601.99628941757214 -1415.2175452517458 -20.21176624127035 601.81956687944216 -1415.1605726767525 -25.329666471820154 601.63167087406043 -1415.0836453457482 -30.359328926880469 601.36417052765171 -1415.0015303629218 -35.401124470133063 601.066547696464 -1414.90996360129 -40.427567211203701 600.72281957126575 -1414.8123479349654 -45.451868281515935 600.33779716380741
+-1418.9463723720812 3.0250650075169199e-14 602.33725485201671 -1418.9463724390935 -4.9002487067403706 602.3372548510938 -1418.9464870418371 -9.9664511581080149 602.3376766461995 -1418.9239351661031 -15.22408416092645 602.28116819985257 -1418.8661462369553 -20.24693553794329 602.10736519168609 -1418.8054561050785 -25.377825918168195 601.92297393833644 -1418.7246450762011 -30.415505669804567 601.65912131421112 -1418.6387685579462 -35.466284765270551 601.36502154194591 -1418.5434363958764 -40.501022310232173 601.02462657298565 -1418.4426334328039 -45.533697426557111 600.64225921004186
+8 0 0 7 5 -1400.5857799393225 -44.057864555294486 584.95640978986683 -1400.5145637555306 -48.454952557247132 584.62377430113588 -1400.4353296810068 -52.849082889782828 584.25369003317962 -1400.3480596226118 -57.239752496948505 583.84607134699422 -1400.2520780667821 -61.626432422228937 583.39776005183671 -1400.1445548699571 -66.006651378195727 582.89554230532724
+-1401.3463768670388 -44.33893297335694 588.50899459536822 -1401.2742318253204 -48.761103423758193 588.17202061083754 -1401.1940911678964 -53.180320392011311 587.79784563542194 -1401.1060448463618 -57.597718190595835 587.38631388965177 -1401.0093364418815 -62.013454544099147 586.93475119590971 -1400.9012263700292 -66.430448373948082 586.42979228410331
+-1402.8643808467275 -44.620001392405278 591.89942101146698 -1402.7902722893366 -49.067254291104696 591.5583300485431 -1402.7083835887154 -53.511558634063306 591.1802510078229 -1402.6189599472352 -57.955683494906545 590.76492186314704 -1402.5213669649181 -62.400476667315125 590.31014807638974 -1402.4132921065575 -66.854245371364684 589.80231481186081
+-1405.098537662941 -44.885831346017291 594.9350850809758 -1405.0215365033182 -49.356829239131251 594.59059593296308 -1404.9371537744528 -53.824884818202307 594.20923189558061 -1404.8458264452554 -58.294297970694259 593.79058791531827 -1404.7472387968571 -62.766588027661278 593.33285875331251 -1404.6398198710972 -67.255126750222544 592.82200906099581
+-1407.9461057890164 -45.121177099688715 597.43645100502454 -1407.8655622405336 -49.613236422387004 597.08974935725155 -1407.7781715386748 -54.102361451573188 596.70613275313144 -1407.6845813388404 -58.594224114050455 596.28498861433548 -1407.5849634193023 -63.09088052794467 595.82477093064961 -1407.4787160268081 -67.610166036751153 595.31077400621325
+-1411.2478991124406 -45.312882242768204 599.263686231836 -1411.1635791010997 -49.822170094937611 598.91627309610431 -1411.0730112030867 -54.328533702453946 598.53171773758493 -1410.977064731049 -58.838724280039209 598.1091525729928 -1410.8764716441199 -63.355277278874567 597.64707989794397 -1410.7717151458803 -67.899570170024532 597.12986366062989
+-1414.8123479349645 -45.451868281515843 600.33779716380741 -1414.7244938352721 -49.973739244796811 599.99127699709481 -1414.6309746762838 -54.49269797462312 599.60719405232783 -1414.5328485959731 -59.016266073312643 599.18438947158938 -1414.4314274378214 -63.547302247712189 598.72119376179614 -1414.3282325609393 -68.109662560294751 598.20079780676588
+-1418.4426334328029 -45.533697426556998 600.64225921004186 -1418.3519107660372 -50.063105031249385 600.29812858339244 -1418.2560112710237 -54.589613893114674 599.91585136794276 -1418.1561350686241 -59.121173768747219 599.49395353256409 -1418.0541069440567 -63.66081857779092 599.03038952036604 -1417.9523082137794 -68.233732502367133 598.50700177558872
+8 0 0 11 4 -1357.2998046875 0 597.561767578125 -1357.2998046875 -16.039358494386306 597.561767578125 -1357.2998046875 -32.078716988772612 597.561767578125 -1357.2998046874993 -81.112701400872155 591.97669757187452 -1357.2998046874995 -96.922442979720486 589.27242463419293
+-1403.6727516867898 0 601.15407492897725 -1403.6727516867898 -16.039358494386306 601.15407492897725 -1403.6727516867898 -32.078716988772612 601.15407492897725 -1403.5650282222057 -78.354131663728808 597.3343353813799 -1403.6727516867893 -93.934511069938551 593.2891635178346
+-1450.0456986860795 0 604.7463822798295 -1450.0456986860795 -16.039358494386306 604.7463822798295 -1450.0456986860795 -32.078716988772612 604.7463822798295 -1449.8595268592148 -75.677779660134959 602.4151511743504 -1450.045698686079 -90.946579160156617 597.30590240147626
+-1496.4186456853693 0 608.33868963068176 -1496.4186456853693 -16.039358494386306 608.33868963068176 -1496.4186456853693 -32.078716988772612 608.33868963068176 -1496.1791390481094 -72.997891669139577 607.20340012339534 -1496.4186456853688 -87.958647250374682 601.32264128511792
+-1542.791592684659 0 611.93099698153401 -1542.791592684659 -16.039358494386306 611.93099698153401 -1542.791592684659 -32.078716988772612 611.93099698153401 -1542.5170463692398 -70.253298174922989 611.73229821057032 -1542.7915926846586 -84.970715340592747 605.33938016875959
+-1589.1645396839488 0 615.52330433238626 -1589.1645396839488 -16.039358494386306 615.52330433238626 -1589.1645396839488 -32.078716988772612 615.52330433238626 -1588.8677466381937 -67.398070292868795 616.03120263123083 -1589.1645396839483 -81.982783430810812 609.35611905240125
+-1635.5374866832385 0 619.11561168323851 -1635.5374866832385 -16.039358494386306 619.11561168323851 -1635.5374866832385 -32.078716988772612 619.11561168323851 -1635.232312923195 -64.471290648332527 620.11679730518119 -1635.5374866832381 -78.994851521028878 613.37285793604292
+-1681.9104336825283 0 622.70791903409076 -1681.9104336825283 -16.039358494386306 622.70791903409076 -1681.9104336825283 -32.078716988772612 622.70791903409076 -1681.6057513794806 -61.362250950813852 623.9643832225255 -1681.9104336825278 -76.006919611246943 617.38959681968458
+-1728.283380681818 0 626.30022638494302 -1728.283380681818 -16.039358494386306 626.30022638494302 -1728.283380681818 -32.078716988772612 626.30022638494302 -1727.9994951764893 -58.185883146098021 627.52745975783057 -1728.2833806818176 -73.018987701465008 621.40633570332625
+-1774.6563276811078 0 629.89253373579527 -1774.6563276811078 -16.039358494386306 629.89253373579527 -1774.6563276811078 -32.078716988772612 629.89253373579527 -1774.4087778318708 -54.803582434011567 630.75795164019621 -1774.6563276811073 -70.031055791683073 625.42307458696791
+-1821.0292746803975 0 633.48484108664752 -1821.0292746803975 -16.039358494386306 633.48484108664752 -1821.0292746803975 -32.078716988772612 633.48484108664752 -1820.8687814696857 -51.343032055903222 633.34466366437016 -1821.0292746803971 -67.043123881901138 629.43981347060958
+-1867.4022216796873 0 637.07714843749977 -1867.4022216796873 -16.039358494386306 637.07714843749977 -1867.4022216796873 -32.078716988772612 637.07714843749977 -1867.402221679687 -48.117348456469273 635.25826403543113 -1867.4022216796868 -64.055191972119161 633.45655235425124
+8 0 0 7 9 -1400.934251173238 -6.2124503946107273e-12 586.58404404085229 -1400.9342511967377 4.9002520878747218 586.58404415059806 -1400.9343741821726 9.8004460812720584 586.5846186619832 -1400.922337402892 14.70102706199151 586.52839630293704 -1400.8879744601245 19.600540899448429 586.36789865878814 -1400.8499542231777 24.496839907128354 586.1903065987118 -1400.7960074676598 29.391611426319123 585.93834075001007 -1400.7351954330798 34.283225330765333 585.65429632466066 -1400.6649090324254 39.172211219791571 585.32600477734604 -1400.5857799393232 44.057864555294493 584.95640978986728
+-1401.7014216683604 -5.8304821280706734e-12 590.16733256629357 -1401.7014216891666 4.9002514416666187 590.16733266345318 -1401.701567937906 9.8321688940223506 590.16788241223276 -1401.6892444549735 14.801000659283357 590.11027427356646 -1401.6535409774942 19.724034799606589 589.94459815958703 -1401.6150415425918 24.665027753980681 589.76303137679793 -1401.5597546829629 29.586959289525517 589.50570367467697 -1401.4978856670432 34.50879052791052 589.21684185567926 -1401.4265380245045 39.425410250688905 588.88341013373611 -1401.3463768670395 44.338932973356961 588.50899459536868
+-1403.2345633728767 -5.2175931272005427e-12 593.58662913982153 -1403.2345633950827 4.9002507954719743 593.58662922351834 -1403.2347240348502 9.8638922938039979 593.5871500089246 -1403.2214763222451 14.900974602101583 593.52830614807135 -1403.1832530663767 19.847528218436675 593.35770245962533 -1403.1428619755168 24.833214855585695 593.17244971142725 -1403.0848171132977 29.782307207256181 592.91006464448378 -1403.0205103693336 34.734356557057005 592.61669617146936 -1402.946723688274 39.678609282739274 592.27841097027158 -1402.8643808467284 44.620001392405307 591.89942101146733
+-1405.4915946644078 -4.3950968489520485e-12 596.64546905933423 -1405.491594692068 4.9002501850415827 596.64546912830133 -1405.4917599870851 9.8938791387599068 596.64596005403655 -1405.4769970430928 14.995464994478422 596.58624386755594 -1405.4352317883115 19.964262768524534 596.41163980760814 -1405.3916174709514 24.99220901760777 596.22345491363876 -1405.3295637233557 29.966998031749384 595.95704131255525 -1405.2615668575527 34.947644917778028 595.6600746353115 -1405.1840945069673 39.918055909224044 595.31785080099007 -1405.0985376629421 44.885831346017355 594.93508508097602
+-1408.3675506685131 -3.4045650686442264e-12 599.16074978147583 -1408.3675507048472 4.9002496452725461 599.16074983428643 -1408.3677114439286 9.9203804224815073 599.16121356600411 -1408.3509953487128 15.07897477857261 599.10120435387728 -1408.3049921125996 20.067462076647583 598.92406546504981 -1408.2571532917455 25.132820538701129 598.73423383868783 -1408.1902190410556 30.130387000032453 598.46542152645145 -1408.1176406197264 35.136388936499984 598.16633455437534 -1408.0355986206644 40.130000074468391 597.82167505810594 -1407.9461057890169 45.121177099688744 597.43645100502488
+-1411.6997784966611 -2.3040557753935968e-12 600.99021680918486 -1411.6997785435258 4.9002492064292831 600.99021684455147 -1411.6999274038576 9.9419102391388865 600.99065900078983 -1411.6810773066534 15.146799507556663 600.9310902478436 -1411.63063917255 20.151300469293265 600.75322046334509 -1411.578138486097 25.247120066671883 600.56344460225148 -1411.5060324193523 30.263266679353212 600.29424256426444 -1411.4285378268441 35.289975652751984 599.99490124587794 -1411.341588013931 40.302562407024453 599.64970082709351 -1411.2478991124412 45.312882242768275 599.26368623183612
+-1415.2928255249401 -1.158539780514203e-12 602.05423071719667 -1415.2928255825691 4.9002488903645336 602.05423073433815 -1415.2929580751529 9.9574313223955802 602.05465874909055 -1415.2720767645046 15.195688028884014 601.99628941757214 -1415.2175452517458 20.21176624127035 601.81956687944216 -1415.1605726767525 25.329666471820154 601.63167087406043 -1415.0836453457482 30.359328926880469 601.36417052765171 -1415.0015303629218 35.401124470133063 601.066547696464 -1414.90996360129 40.427567211203701 600.72281957126575 -1414.8123479349654 45.451868281515935 600.33779716380741
+-1418.9463723720812 -3.0250650075169199e-14 602.33725485201671 -1418.9463724390935 4.9002487067403706 602.3372548510938 -1418.9464870418371 9.9664511581080149 602.3376766461995 -1418.9239351661031 15.22408416092645 602.28116819985257 -1418.8661462369553 20.24693553794329 602.10736519168609 -1418.8054561050785 25.377825918168195 601.92297393833644 -1418.7246450762011 30.415505669804567 601.65912131421112 -1418.6387685579462 35.466284765270551 601.36502154194591 -1418.5434363958764 40.501022310232173 601.02462657298565 -1418.4426334328039 45.533697426557111 600.64225921004186
+8 0 0 7 5 -1400.1445548699576 -66.006651378195713 582.89554230532792 -1400.0907932715445 -68.196760856179125 582.64443343207313 -1400.0340615877806 -70.385177677221535 582.37945325135649 -1399.9742168625012 -72.57180058321579 582.0999319077838 -1399.9103185418926 -74.755820978991821 581.80147475525462 -1399.8411147814279 -76.936017147650716 581.4782388593884
+-1400.9012263700297 -66.430448373948067 586.429792284104 -1400.847171334103 -68.638945288872549 586.17731282820068 -1400.7901630582335 -70.847664301513362 585.91114264992632 -1400.7301090494718 -73.057498208390015 585.63043968307329 -1400.6659969158868 -75.268208133328841 585.33108606308156 -1400.5965704793957 -77.483142709451172 585.00681010474932
+-1402.4132921065579 -66.854245371364669 589.80231481186149 -1402.3592546773771 -69.081129723389452 589.5483981795968 -1402.3024946893279 -71.310151680322875 589.28093018391417 -1402.2429842836641 -73.543195449636613 588.99887518027549 -1402.1797766664447 -75.780595290064952 588.69839032872778 -1402.1118579553711 -78.030268273422067 588.37270383419889
+-1404.6398198710976 -67.255126750222544 592.82200906099638 -1404.5861130181388 -69.499385879920297 592.56658203534164 -1404.5301175891705 -71.747586759383012 592.29763631691355 -1404.4718632061249 -74.002571593705881 592.01393641989307 -1404.4106306929309 -76.265179016505869 591.71185253615693 -1404.345870411878 -78.54763581643212 591.38400573617105
+-1407.478716026809 -67.610166036751139 595.31077400621371 -1407.4255949404831 -69.869798559571507 595.05377336449919 -1407.3707713179469 -72.134956369498653 594.78312694593421 -1407.3143635693625 -74.409315906757755 594.49738487607215 -1407.2559419946967 -76.694155494036536 594.19303557465923 -1407.195620280251 -79.005473002264594 593.86195343197789
+-1410.771715145881 -67.899570170024546 597.12986366063024 -1410.7193368967605 -70.171716615599522 596.87125554197314 -1410.665916782325 -72.450657220496723 596.59868247878273 -1410.6116560347996 -74.740678604975074 596.31045923046474 -1410.5564892752191 -77.043509775648545 596.00309693145334 -1410.501272260937 -79.37810089518004 595.66756507039406
+-1414.32823256094 -68.109662560294765 598.2007978067661 -1414.2766351224984 -70.390842716586036 597.94059982925091 -1414.2246420438421 -72.67970468711745 597.66592240633213 -1414.1725162005509 -74.980992984155009 597.37487020584319 -1414.1205735112699 -77.296697900026828 597.0638164137689 -1414.070386777433 -79.64782888236077 596.72271977808077
+-1417.9523082137798 -68.233732502367147 598.50700177558895 -1417.9014088486408 -70.520189464655232 598.24530790320011 -1417.8506594246139 -72.814807949947763 597.9684589228433 -1417.8003642472559 -75.122580719142704 597.67436953131721 -1417.7511768748489 -77.445633873059691 597.35914795226211 -1417.7052652315906 -79.806048816100628 597.01168301769985
+8 0 0 7 5 -1399.8411147814288 -76.936017147650674 581.47823885938817 -1399.8065129011966 -78.026115231980143 581.31662091145517 -1399.7705274165401 -79.115197001145916 581.14854155749526 -1399.7330860937045 -80.203205276687939 580.97366099677288 -1399.6937173771789 -81.289665533083962 580.78977745536633 -1399.6519034768437 -82.373981269430658 580.59447350783921
+-1400.5965704793964 -77.483142709451158 585.00681010474909 -1400.5618572611511 -78.590609997512317 584.84467212558297 -1400.5257451215871 -79.699060422569914 584.67607571077394 -1400.4881878837243 -80.809258611294837 584.50050440269695 -1400.4486511697335 -81.921252150699061 584.31591102601965 -1400.4065764485852 -83.037949404252473 584.11938886742917
+-1402.1118579553715 -78.030268273422067 588.37270383419866 -1402.077898599835 -79.155104765100603 588.20986058693427 -1402.0426914891282 -80.282924527802777 588.04052954561996 -1402.0062276519382 -81.415311494160804 587.86400185688058 -1401.9680093174593 -82.552838802713012 587.67838381729155 -1401.9276145649437 -83.701917540391889 587.48022793833491
+-1404.3458704118784 -78.547635816432106 591.38400573617071 -1404.3134902713521 -79.688864216395203 591.22008233617782 -1404.2801734285083 -80.834957567829704 591.04956603931964 -1404.2459457960681 -81.988264500811496 590.87154664867148 -1404.2104626216496 -83.149867994659132 590.68425381905536 -1404.1736001180552 -84.32946215723608 590.4836271985406
+-1407.1956202802514 -79.005473002264594 593.86195343197778 -1407.1654594230286 -80.161131756378595 593.69641236063717 -1407.1347940237149 -81.323302709936684 593.52406378918579 -1407.1037153561249 -82.495024825474374 593.34380207311631 -1407.0720635647961 -83.677778158281214 593.1538952726421 -1407.0401679077081 -84.884141816386702 592.94960049706856
+-1410.5012722609376 -79.378100895180069 595.66756507039406 -1410.4736637537965 -80.545396454945788 595.49979913986454 -1410.4460443952044 -81.720517445595746 595.32488320510265 -1410.4185514195626 -82.9070253278731 595.1415062484092 -1410.3912969578632 -84.10676398696863 594.94791879290267 -1410.3651097838754 -85.334569309178775 594.73860779994561
+-1414.0703867774334 -79.647828882360812 596.72271977808077 -1414.0452934105149 -80.823394373527734 596.55217146023688 -1414.0206754239689 -82.007694559554395 596.37400538427221 -1413.9967111257527 -83.204662940683406 596.18673072961622 -1413.9737811869304 -84.416375249277991 595.98847633804507 -1413.9532087974248 -85.659217054373826 595.77291884073713
+-1417.7052652315911 -79.806048816100684 597.01168301769974 -1417.6823094099618 -80.986256287621089 596.83795055041878 -1417.6602407255775 -82.175676670992601 596.65603672000532 -1417.6392650215487 -83.378440620131755 596.46429616199896 -1417.6200008109672 -84.596738263022814 596.26065427056858 -1417.6041837107789 -85.847739928508588 596.03797491897092
+8 0 0 1 1 -1395.9209712992028 253.96081542968824 563.16809104774393 -1410.205932617188 253.96081542968821 629.8900756835942
+-1395.9209712992028 -6.1959326558280736e-12 563.16809104774427 -1410.205932617188 -6.1959326558280736e-12 629.89007568359398
+8 0 0 9 5 -1357.2998046875 184.19343141626581 452.17426057650368 -1285.496986635655 197.62386275744996 436.37201798805296 -1213.6941685838101 210.89152637766256 421.28730809105747 -1124.6200834825863 141.57753137538003 413.81750790987098 -1057.951186931929 170.47303057537053 422.39686819190024 -986.58004277728469 192.48218206907438 425.13348464380817
+-1357.2998046875002 184.95581682942503 440.6069623304524 -1285.8757123265382 198.76662089194582 423.40713316323371 -1214.4516199655766 212.49294018574503 406.72421521562387 -1124.0092503904036 139.72304653136851 403.87290135479583 -1057.9395533156057 168.72728927462569 411.31184198013705 -986.58056018226353 190.81342640950481 413.74620330750253
+-1357.2998046875 184.20965948514214 428.94023801541454 -1286.2929817843701 198.24738845715834 410.19683754780431 -1215.2861588812409 212.29435766801788 391.77933053695506 -1123.3807119265641 137.68772364719791 394.09517362004084 -1057.9253968483356 166.79408343193646 400.44097241589344 -986.58109860476782 188.95549672575723 402.61311761858656
+-1357.2998046875 181.94007573749803 417.39877933963572 -1286.7252574368888 195.93472730800249 397.01265380593435 -1216.150710186278 210.01685257664764 376.78332157739317 -1122.7525476090343 135.52220024105159 384.56051683931935 -1057.9098307333593 164.72526513374294 389.87440184371803 -986.5816367985725 186.95977872774048 391.81571653839427
+-1357.2998046875 178.1714737530508 406.21035096683613 -1287.1357387339476 191.78230897195598 384.19955775304038 -1216.9716727803957 205.50642796035388 362.20483297640976 -1122.1447904059896 133.27327752092791 375.32932413631733 -1057.8937576213445 162.56871997729661 379.69007954869318 -986.58215378988712 184.87309679507817 381.42501230160258
+-1357.2998046875 172.96778981351804 395.59673333232303 -1287.4880868537834 185.89147147801242 372.11951803394373 -1217.6763690200673 198.88183301566528 348.55715537823596 -1121.5780378622505 130.98120484848258 366.4443816149859 -1057.8778395924564 160.36593535439206 369.94988612084927 -986.58263034910794 182.73603060301721 371.49709916405413
+-1357.2998046875 166.43084112273939 385.76559407814432 -1287.7668889257636 178.47848227825165 361.06304715317879 -1218.2339731640279 190.50850310326635 336.21022465837228 -1121.0715717457711 128.67820835717427 357.93122691085699 -1057.8625827085004 158.15029170138141 360.69603125335493 -986.58305046257021 180.58123174833656 362.06871215057987
+-1357.2998046875 158.69679511791949 376.90328810728369 -1287.9827547608431 169.81093683082483 351.21272638047662 -1218.6657048341867 180.81217987764177 325.32408563860162 -1120.6392434194299 126.38839501251907 349.80048339831848 -1057.8484386668977 155.94562993112112 351.94713089203958 -986.58340280430036 178.43174037525586 353.152785802822
+-1357.2998046875002 149.93075528515118 369.16858625689707 -1288.1615858736086 160.15418838986875 342.66735642125872 -1219.023367059717 170.18614801573113 315.93080361076613 -1120.2852585085163 124.12725368329728 342.04815140924239 -1057.8358260882567 153.76464826250088 343.69336965380592 -986.58368220776822 176.299301801344 344.7340129270566
+-1357.2998046875 140.31946347921908 362.68733259059042 -1288.3392033724342 149.74517052458046 335.46007510878678 -1219.3786020573682 158.93938475260344 307.9718341714858 -1120.0058707994285 121.89706507359359 334.64601007881811 -1057.8249739693033 151.60668166320397 335.89015443148998 -986.58389113763894 174.18268314342791 336.76440334201646
+8 0 0 7 12 -1370.4053730067612 152.68650658283727 539.69281459138551 -1373.8846061556646 151.75821914990681 540.13942623206071 -1377.2839853209716 150.58794219878698 541.02714555597879 -1380.5389275752632 149.20683081100015 542.33646024267716 -1383.586553162791 147.60127902366418 544.04015777575523 -1386.3716795815526 145.7522005110846 546.09794542155805 -1388.8260202990364 143.54833861254932 548.43110332658421 -1390.9179511751972 140.94770840847892 551.01070157889171 -1392.5676796898986 137.7772185769708 553.64156577700805 -1393.8458587068999 134.17382560404832 556.23763365241734 -1394.7910838630708 130.1449098446933 558.71656510731509 -1395.4643895363656 125.76866244586476 561.0354955709654 -1395.9209712992038 121.09636869195506 563.16809104774381
+-1370.9622558650076 156.22250084021897 539.7642988242759 -1374.5750109402588 155.33000346652409 540.29423701239239 -1378.0826763660066 154.17415447291918 541.29827959394675 -1381.4249505231635 152.78128420546273 542.75157428056627 -1384.5485865798562 151.13512146598296 544.62198769970814 -1387.4052714054114 149.21435113020502 546.89038920891005 -1389.930138864587 146.91070349802521 549.46536341678495 -1392.0731114573091 144.1906254221239 552.37625809902852 -1393.7155115244536 140.88241490882831 555.36174872735 -1394.9334013933326 137.13641113505318 558.33394567668165 -1395.7722278232304 132.95377601841631 561.17482360775102 -1396.3007770805546 128.4167270929866 563.83686070553256 -1396.5876571290307 123.57371806182387 566.28203729530901
+-1371.6143418864347 159.75849531051506 539.09412342303858 -1375.4504109958266 158.90178796129538 539.69458193664832 -1379.1593993122403 157.76037563632471 540.82072025635648 -1382.6802884529986 156.35568950995241 542.44511428869896 -1385.9631327842371 154.66908052951698 544.52979070720755 -1388.9619969949022 152.67636000758222 547.07204631795037 -1391.6122097893474 150.27311745696619 549.95900656177389 -1393.8530174445398 147.4336549716233 553.26537615454049 -1395.5397073364838 143.98741251586495 556.66113711893161 -1396.7570248281784 140.09915325669181 560.06470548517575 -1397.5518882039407 135.76257560833196 563.3217207992343 -1398.00136101151 131.06480455288113 566.38263631459074 -1398.1828734827843 126.05106743369521 569.19718816060845
+-1372.3324825956363 163.10942055100085 537.67856206640033 -1376.473726915207 162.28065775994972 538.33225436467376 -1380.4702405434268 161.14853543749553 539.5797803456104 -1384.255547266031 159.73051122899295 541.39414569126427 -1387.7764421753354 158.0061666674319 543.73106835196143 -1390.9849027066152 155.94762905878667 546.59892632086166 -1393.8115811218186 153.45299172820128 549.85489057930295 -1396.1959153169621 150.50131211433825 553.60406832985302 -1397.9769618084081 146.9207139246505 557.44722385841465 -1399.2542718673778 142.89245111510479 561.31283645920769 -1400.070731144818 138.40295813237199 565.01282262856137 -1400.5129043523777 133.54574299572829 568.4977634790248 -1400.6622735741814 128.36376756055668 571.70659303538355
+-1373.0800561515707 166.09012301955977 535.57200321027665 -1377.5931251935624 165.27360313587357 536.26003251422981 -1381.9485723495923 164.14045954347822 537.62270707979292 -1386.0705797230175 162.70608060883436 539.63611914443675 -1389.896934138764 160.94940997457849 542.24949660465074 -1393.3733142094998 158.83718181217426 545.47724254176376 -1396.4208130992324 156.26801487904277 549.13940496375164 -1398.9891221670514 153.21771805415918 553.35728066062302 -1400.9087845937377 149.51088987757831 557.66241235015377 -1402.3004608909819 145.34656234046983 561.99286846220991 -1403.1987502753545 140.70647318945643 566.13186975034591 -1403.7011602890839 135.69226661202794 570.03140856830748 -1403.8891790208752 130.34702884038074 573.62288469942473
+-1373.8167670401797 168.53993767223861 532.88799403852067 -1378.74692579148 167.71394625031525 533.59339579890855 -1383.5109478987702 166.56563848677376 535.06135156231517 -1388.0211649363059 165.11092885407902 537.27273138566363 -1392.2023823073989 163.32968200057462 540.17016840670863 -1395.9904402883562 161.18051301931973 543.77009802022735 -1399.2935102060596 158.56099083658432 547.85094709171847 -1402.0770376080557 155.43105725020763 552.53946364589763 -1404.1697206969545 151.61045198179147 557.29705977618664 -1405.7170881079608 147.3161971720115 562.06781955785164 -1406.7435279568672 142.53012470229939 566.61256255621652 -1407.3584271361397 137.3638060124176 570.88506931912877 -1407.6407354615883 131.86388462413956 574.81372151401069
+-1374.5045028573311 170.34603994945169 529.78273685886847 -1379.8727726673435 169.48638683061 530.49316103337651 -1385.0698214885444 168.30748709226191 532.05489393404196 -1389.9951998643226 166.82854524698297 534.45399505359853 -1394.5589679227442 165.03196664946273 537.62634184621152 -1398.6846491345912 162.8649992641744 541.58796742929758 -1402.2663148495906 160.22335390549782 546.07430929353154 -1405.2847865266936 157.03674386754656 551.21229546199686 -1407.5724938274993 153.11842229203029 556.39061392447366 -1409.300018576721 148.70371874217921 561.55455246336646 -1410.4821673309339 143.78035143279919 566.44907381215091 -1411.2402701705512 138.47150572974562 571.02969255068979 -1411.6499829512643 132.83104774836085 575.22677084608165
+-1375.1114928763584 171.45060411049039 526.4316198760481 -1380.915085455126 170.53420196330387 527.14045877896547 -1386.5446389768165 169.31050164480268 528.7842218051843 -1391.887486386167 167.80445797645189 531.35332809356271 -1396.8392751718491 166.00226327292552 534.77670448000038 -1401.310102964748 163.8369838081878 539.06913763232114 -1405.1805665189336 161.20175132234274 543.9247226851777 -1408.4418089150438 157.98400083631324 549.4710237630627 -1410.9333791697097 153.98649247138678 555.02026900044302 -1412.8482657790976 149.46503138293849 560.51419399796816 -1414.194341130953 144.41835252639237 565.68814512577956 -1415.1041693690349 138.98276349632394 570.49928659623424 -1415.6510057403025 133.22247960627189 574.88473448687944
+8 0 0 7 5 -1357.2998046875 152.22468073184598 559.93245673270815 -1283.6655933027223 163.03339146965652 553.08360843908508 -1209.662765738673 173.96615769083309 547.69813442913551 -1128.415013762901 146.52596125584853 508.89153599901374 -1057.8012596275194 173.64102351793142 530.28227105259521 -986.57797451185866 194.43240880978578 539.26525452135729
+-1357.2998046875 158.52184632535329 553.36840639429715 -1283.7300697455803 169.47766861565998 546.05851915364917 -1209.8349310165379 180.43029084423611 540.21100444195281 -1128.3520752502718 147.51188067361639 502.69185418196372 -1057.8442922006413 174.9135299148723 522.92306431784073 -986.57776895982317 195.94757028740116 531.00159364622243
+-1357.2998046875 164.12241870080524 546.13608530547162 -1283.8093829613942 175.23619315708845 538.26335527120932 -1210.0479324237972 186.23538320432473 531.8398969545409 -1128.2517472303182 148.23798979983334 496.0664669711411 -1057.8818044227048 175.86196999434259 515.18112786228596 -986.57764200693964 197.06342498507266 522.45960890167237
+-1357.2998046875 168.94106445767341 538.32407778743209 -1283.9041795315838 180.23746565084721 529.83217772421767 -1210.2982458127181 191.32042336084618 522.77344186099606 -1128.1038628542051 148.67926715508722 489.06011199008833 -1057.9119904128638 176.48396740439 507.09715365746524 -986.57759578743253 197.80777176330517 513.67739540956518
+-1357.2998046875 172.9072534829333 530.03490884053986 -1284.0197242517766 184.45087606583095 520.89363518395817 -1210.5914277623806 195.69801475816755 513.17013139869346 -1127.9043297177836 148.82922570610435 481.74252629771627 -1057.9348667805093 176.78919512825843 498.73091883900298 -986.57762849455219 198.21078591935549 504.70009910313388
+-1357.2998046875 175.9670391052282 521.38132421140483 -1284.1653629501943 187.86304721396749 511.53597807120957 -1210.9445317414286 199.39972456742939 503.07446371473662 -1127.6539877628284 148.70193667083277 474.18377729198306 -1057.9511977260695 176.79953519376102 490.14538417864719 -986.57773513209247 198.30415961003311 495.57764890123894
+-1357.2998046875 178.08483824903294 512.48257045997389 -1284.3526437349112 190.41900283709421 501.8320666051244 -1211.3736254389007 202.3668016158889 492.49207192917845 -1127.3558176699846 148.31827890342356 466.45223219459314 -1057.9618498162215 176.54098204787871 481.40441261517446 -986.57790826590747 198.12024227450098 486.36248888262026
+-1357.2998046874998 179.24521158881785 503.46067502661867 -1284.581194091712 192.04166980531758 491.8854269881391 -1211.8625834959234 204.47007738616708 481.5201172646336 -1127.0149440528294 147.7040937868492 458.61133304318753 -1057.9677225174655 176.04230709942885 472.57017187666241 -986.57813877542912 197.69118105707625 477.10731046014922
+8 0 0 8 4 -1867.4022216796877 64.055191972119161 633.45655235425136 -1739.8766174316406 72.272004724019496 622.41052042423678 -1612.3510131835938 80.488817475919831 611.36448849422231 -1484.8254089355464 88.705630227820151 600.31845656420751 -1357.2998046875 96.922442979720472 589.27242463419282
+-1867.402221679688 68.387079887314997 632.96684914875152 -1739.8616070499525 78.669028576927786 620.0845803520408 -1612.5160063811613 89.467319529721181 606.58213160352011 -1485.5038659403945 100.78195274569518 594.51511969707803 -1357.2998046875002 112.61292822484981 586.5885506179178
+-1867.4022216796877 72.621374608419245 631.61384185754673 -1739.8551740292291 85.362746356204951 616.87991923708853 -1612.5867177515472 98.808833130164913 601.42899082628855 -1485.7946332281858 112.9596349302991 588.1976520449881 -1357.2998046875 127.81515175660761 581.05019715776405
+-1867.402221679688 76.557353120705727 629.42022144255793 -1739.8551740292289 91.915821245483045 612.78223093759743 -1612.5867177515474 107.9296292288804 595.68068299637605 -1485.7946332281863 124.59877707089781 581.05217303873542 -1357.2998046875 141.92326477153523 572.7609953292523
+-1867.4022216796875 80.000629979933478 626.46467495370666 -1739.8594627097111 97.902271103404246 607.85777980898524 -1612.5395768379562 116.26235055703205 589.21796985403034 -1485.6007883696577 135.08086834081689 572.89452142471475 -1357.2998046875 154.35782445475888 561.97886993269958
+-1867.4022216796873 82.782636761982843 622.87972741689612 -1739.8658957304347 102.93433653423108 602.24970339214076 -1612.4688654675706 123.29026831690373 582.02152153445832 -1485.3100210818657 143.8504321100009 563.66347955376887 -1357.2998046875 164.61482791352262 549.10772458236102
+-1867.4022216796873 84.779329392647213 618.84028241629426 -1739.8723287511584 106.6879902127712 596.16202842292603 -1612.3981540971847 128.57959350195648 574.15140800454913 -1485.0192537940741 150.45413926020314 553.39574024513183 -1357.2998046875 172.31162748751115 534.66788399758912
+-1867.4022216796877 85.921710327135486 614.54437199872928 -1739.8766174316411 108.91773539283999 589.83345776851047 -1612.3510131835942 131.79855173425122 565.71392303114771 -1484.8254089355471 154.56415935136926 542.18576778664124 -1357.2998046875002 177.21455824419422 519.24899203499035
+-1867.4022216796877 86.197022651859044 610.19359445176713 -1739.8766174316406 109.45906988609872 583.51036459547981 -1612.3510131835938 132.72111712033842 556.82713473919284 -1484.8254089355469 155.98316435457812 530.14390488290599 -1357.2998046875 179.24521158881782 503.46067502661873
+8 0 0 8 8 -1399.4047774058015 87.75710987207303 579.44020074020409 -1400.0597874986966 88.647719624393943 582.49961212962421 -1401.3060960281753 89.538329377051525 585.43242843558892 -1403.1172866196764 90.393038548744769 588.11532718351737 -1405.4336371219965 91.175931337152974 590.43206187423186 -1408.1641141365039 91.854164875604624 592.28412962014886 -1411.1937558242332 92.400943562078567 593.59987622589927 -1414.3941415725537 92.797713268125804 594.34013768580564 -1417.6346471030986 93.034909135300211 594.49851707064579
+-1399.4442903381378 87.093821462887945 579.62474346774502 -1400.0999102187525 87.945924160937921 582.68711319829208 -1401.3436636552042 88.797275945960592 585.62124538029775 -1403.1478261623085 89.614228885217898 588.3063625904615 -1405.4527292812138 90.361947464900638 590.6240780740718 -1408.1678143649244 91.011524927392117 592.48472559352876 -1411.1813877363095 91.535274660758901 593.80864494638195 -1414.3667709628126 91.917659637123535 594.56458481203515 -1417.5957012487856 92.147600961067653 594.73891269027365
+-1399.4782948832947 86.42405576099236 579.7836215845316 -1400.1349210921769 87.237794865336014 582.85005994572145 -1401.3766131261712 88.050871803983426 585.78824186709471 -1403.1758887949095 88.830819906568635 588.47689953085944 -1405.4726983589985 89.545705181595153 590.80228074856711 -1408.178820912859 90.165675711909884 592.6680826187137 -1411.1821589260471 90.667498074068263 594.00428551163748 -1414.3582725171862 91.033407474588017 594.76986479131358 -1417.5792492350913 91.255110157812439 594.95761207363853
+-1399.5110276609282 85.753250118707484 579.93644817064933 -1400.1679959156636 86.528267237043153 583.00599780163566 -1401.4083621048069 87.302958915009313 585.94932817086033 -1403.2044309529601 88.044900854942 588.63769531837045 -1405.4954570622078 88.727429623142299 590.9757850485222 -1408.1945093968463 89.316511431546374 592.83828762617782 -1411.1895602804832 89.797125092373079 594.19143589350426 -1414.358509276869 90.145914089156079 594.9608514597337 -1417.5728690033714 90.359094976959341 595.16102166154474
+-1399.5416192880991 85.08009498934581 580.07934742430848 -1400.199845856833 85.816565326737987 583.15272939604552 -1401.4390454016184 86.551790033337198 586.0956731191493 -1403.230467535863 87.259586859541898 588.80078457734032 -1405.5175723694874 87.903832446406085 591.12305112488934 -1408.2094781162027 88.470321340647686 593.02135853307857 -1411.2002252249172 88.922174545257505 594.35644260539652 -1414.3622824529357 89.258172395621813 595.15110695564385 -1417.5721786441127 89.460511366415133 595.35285071443354
+-1399.5705458035013 84.40494591995467 580.21449402559767 -1400.2289718034554 85.102530303814518 583.29044496705501 -1401.4667631216473 85.800244027999639 586.24244583020618 -1403.2574129303875 86.467910105117042 588.9382324135928 -1405.5396422548486 87.084374022253101 591.29243344723693 -1408.2293035610869 87.614150586677937 593.16233373108389 -1411.2130812868015 88.049941099440716 594.53562371042358 -1414.3715075788905 88.364937123398676 595.3170634616431 -1417.5759336536541 88.559843354093516 595.53523439850107
+-1399.5987924493982 83.729098361391209 580.34639380351916 -1400.2580607034943 84.387952355185362 583.42558575145108 -1401.4950285903155 85.046222550289656 586.37802170680959 -1403.2822016874211 85.679168900465129 589.08847977127505 -1405.5624075338699 86.25796868195485 591.430542184101 -1408.2470321362657 86.764109382485998 593.33045929866728 -1411.2284419282876 87.171842404031665 594.6887593233771 -1414.3819777082601 87.473370425354901 595.49083440783727 -1417.5832189899536 87.657326556039436 595.70953317983162
+-1399.625754956478 83.052063244283275 580.47233926040826 -1400.2855508085033 83.671960419949585 583.55406575461836 -1401.5215297289199 84.291768826577183 586.51173390748647 -1403.307286502619 84.886819329847825 589.2232719221289 -1405.5846763722132 85.433516953662377 591.57825280887198 -1408.2671428618557 85.908433519719082 593.47453307131082 -1411.2447372115162 86.294805905815892 594.84736476423245 -1414.3951739819361 86.578357563026131 595.64972256583712 -1417.5927359274176 86.753164809152338 595.87680852654705
+-1399.6519034768448 82.373981269430587 580.59447350783876 -1400.3122423271191 82.954953387399669 583.67877444748001 -1401.5473550358554 83.535925506356961 586.64001817060807 -1403.3313555356394 84.094132925919411 589.3573524759629 -1405.6068840128826 84.606801986811305 591.71661384780418 -1408.2870211112715 85.053052126183672 593.62047823564728 -1411.2621345372631 85.415731245477474 594.99718556014318 -1414.4095806615944 85.682782413640595 595.80605085051616 -1417.6041837107787 85.847739928508503 596.0379749189708
+8 0 0 7 6 -1395.9209712992024 121.09636869195451 563.16809104774279 -1396.7241720380409 116.16460779231224 566.91966906555353 -1397.4392364065109 110.90530517268765 570.25961376664668 -1398.0643008316213 105.38382594069456 573.17906945037385 -1398.5997631807461 99.655568119076534 575.68017883839241 -1399.046646846881 93.766701948705318 577.76744985433425 -1399.4047780148821 87.75709967539828 579.44020357963529
+-1396.5876571290294 123.57371806182337 566.28203729530787 -1397.4180729656982 118.37956273774357 570.16073121141233 -1398.1540387491164 112.86467392236698 573.59830969443829 -1398.7944856628681 107.09614880134846 576.58960629912531 -1399.3404452567725 101.12924245277006 579.13973744739849 -1399.7933987150122 95.009234099292968 581.25536734320076 -1400.1533609217586 88.774941381960815 582.93667341478294
+-1398.1828734827827 126.05106743369477 569.1971881606072 -1399.0135736228558 120.59451769068679 573.20876378223852 -1399.74623202562 114.82404107116928 576.74915856320285 -1400.3794456841629 108.80847433306315 579.81713981135624 -1400.9139887891811 102.60291553390206 582.42098235926846 -1401.3510712880136 96.251766290610291 584.56966944372198 -1401.6903419768596 89.7927831287072 586.26434989823952
+-1400.6622735741798 128.36376756055631 571.70659303538207 -1401.465807515285 122.66703655823798 575.85436755852584 -1402.1708533869851 116.66104537167651 579.50225009514452 -1402.7744827094398 110.41675955094146 582.65285132975794 -1403.2762511484304 103.98936335263674 585.31761801521452 -1403.6763211713342 97.422559609724459 587.50790300986353 -1403.9734558435778 90.753184059388332 589.22591757359976
+-1403.8891790208731 130.34702884038043 573.62288469942348 -1404.6429168308566 124.45457250631318 577.90659522746625 -1405.3005229257849 118.25318745788931 581.66516782830183 -1405.8565090009115 111.81670329042815 584.90444209482666 -1406.308562469038 105.20106120720209 587.63896482844632 -1406.6552520660016 98.449719452952408 589.88249024279833 -1406.8938201340734 91.598671465836077 591.63820904738679
+-1407.640735461586 131.86388462413933 574.81372151400933 -1408.3322251018171 125.83781767931822 579.22771911690313 -1408.9316777544639 119.49744160374156 583.09678404063402 -1409.4306347633367 112.92040598664441 586.42909819050305 -1409.8243774333878 106.16406415946885 589.24186916618157 -1410.1094166657556 99.272071992208936 591.55099972969049 -1410.281271258272 92.279980544712117 593.36066508223905
+-1411.6499829512616 132.83104774836067 575.2267708460804 -1412.2790431105329 126.74240063278076 579.7584337909359 -1412.8204424158785 120.32820769968333 583.73238361080405 -1413.2629195962249 113.67068042336084 587.15784769049935 -1413.5993944310783 106.82935861608269 590.05414079753155 -1413.8242886000621 99.848626359221768 592.43902782413556 -1413.9312134883103 92.763827587294614 594.31751257294832
+-1415.6510057402995 133.22247960627175 574.88473448687841 -1416.2285870597855 127.14246802283863 579.51427840908036 -1416.7219290622079 120.72085722107255 583.58118585574675 -1417.1176862275806 114.04473246215392 587.09432541897991 -1417.4068094502288 107.1763774715118 590.07437460064341 -1417.5818717794255 100.16131498397577 592.54054716164012 -1417.6346485948504 93.034909038664935 594.49851719872981
+8 0 0 7 5 -1399.8411147814288 76.936017147650674 581.47823885938817 -1399.8065129011966 78.026115231980143 581.31662091145517 -1399.7705274165401 79.115197001145916 581.14854155749526 -1399.7330860937045 80.203205276687939 580.97366099677288 -1399.6937173771789 81.289665533083962 580.78977745536633 -1399.6519034768437 82.373981269430658 580.59447350783921
+-1400.5965704793964 77.483142709451158 585.00681010474909 -1400.5618572611511 78.590609997512317 584.84467212558297 -1400.5257451215871 79.699060422569914 584.67607571077394 -1400.4881878837243 80.809258611294837 584.50050440269695 -1400.4486511697335 81.921252150699061 584.31591102601965 -1400.4065764485852 83.037949404252473 584.11938886742917
+-1402.1118579553715 78.030268273422067 588.37270383419866 -1402.077898599835 79.155104765100603 588.20986058693427 -1402.0426914891282 80.282924527802777 588.04052954561996 -1402.0062276519382 81.415311494160804 587.86400185688058 -1401.9680093174593 82.552838802713012 587.67838381729155 -1401.9276145649437 83.701917540391889 587.48022793833491
+-1404.3458704118784 78.547635816432106 591.38400573617071 -1404.3134902713521 79.688864216395203 591.22008233617782 -1404.2801734285083 80.834957567829704 591.04956603931964 -1404.2459457960681 81.988264500811496 590.87154664867148 -1404.2104626216496 83.149867994659132 590.68425381905536 -1404.1736001180552 84.32946215723608 590.4836271985406
+-1407.1956202802514 79.005473002264594 593.86195343197778 -1407.1654594230286 80.161131756378595 593.69641236063717 -1407.1347940237149 81.323302709936684 593.52406378918579 -1407.1037153561249 82.495024825474374 593.34380207311631 -1407.0720635647961 83.677778158281214 593.1538952726421 -1407.0401679077081 84.884141816386702 592.94960049706856
+-1410.5012722609376 79.378100895180069 595.66756507039406 -1410.4736637537965 80.545396454945788 595.49979913986454 -1410.4460443952044 81.720517445595746 595.32488320510265 -1410.4185514195626 82.9070253278731 595.1415062484092 -1410.3912969578632 84.10676398696863 594.94791879290267 -1410.3651097838754 85.334569309178775 594.73860779994561
+-1414.0703867774334 79.647828882360812 596.72271977808077 -1414.0452934105149 80.823394373527734 596.55217146023688 -1414.0206754239689 82.007694559554395 596.37400538427221 -1413.9967111257527 83.204662940683406 596.18673072961622 -1413.9737811869304 84.416375249277991 595.98847633804507 -1413.9532087974248 85.659217054373826 595.77291884073713
+-1417.7052652315911 79.806048816100684 597.01168301769974 -1417.6823094099618 80.986256287621089 596.83795055041878 -1417.6602407255775 82.175676670992601 596.65603672000532 -1417.6392650215487 83.378440620131755 596.46429616199896 -1417.6200008109672 84.596738263022814 596.26065427056858 -1417.6041837107789 85.847739928508588 596.03797491897092
+8 0 0 11 4 -1357.2998046875 0 597.561767578125 -1357.2998046875 16.039358494386306 597.561767578125 -1357.2998046875 32.078716988772612 597.561767578125 -1357.2998046874993 81.112701400872155 591.97669757187452 -1357.2998046874995 96.922442979720486 589.27242463419293
+-1403.6727516867898 0 601.15407492897725 -1403.6727516867898 16.039358494386306 601.15407492897725 -1403.6727516867898 32.078716988772612 601.15407492897725 -1403.5650282222057 78.354131663728808 597.3343353813799 -1403.6727516867893 93.934511069938551 593.2891635178346
+-1450.0456986860795 0 604.7463822798295 -1450.0456986860795 16.039358494386306 604.7463822798295 -1450.0456986860795 32.078716988772612 604.7463822798295 -1449.8595268592148 75.677779660134959 602.4151511743504 -1450.045698686079 90.946579160156617 597.30590240147626
+-1496.4186456853693 0 608.33868963068176 -1496.4186456853693 16.039358494386306 608.33868963068176 -1496.4186456853693 32.078716988772612 608.33868963068176 -1496.1791390481094 72.997891669139577 607.20340012339534 -1496.4186456853688 87.958647250374682 601.32264128511792
+-1542.791592684659 0 611.93099698153401 -1542.791592684659 16.039358494386306 611.93099698153401 -1542.791592684659 32.078716988772612 611.93099698153401 -1542.5170463692398 70.253298174922989 611.73229821057032 -1542.7915926846586 84.970715340592747 605.33938016875959
+-1589.1645396839488 0 615.52330433238626 -1589.1645396839488 16.039358494386306 615.52330433238626 -1589.1645396839488 32.078716988772612 615.52330433238626 -1588.8677466381937 67.398070292868795 616.03120263123083 -1589.1645396839483 81.982783430810812 609.35611905240125
+-1635.5374866832385 0 619.11561168323851 -1635.5374866832385 16.039358494386306 619.11561168323851 -1635.5374866832385 32.078716988772612 619.11561168323851 -1635.232312923195 64.471290648332527 620.11679730518119 -1635.5374866832381 78.994851521028878 613.37285793604292
+-1681.9104336825283 0 622.70791903409076 -1681.9104336825283 16.039358494386306 622.70791903409076 -1681.9104336825283 32.078716988772612 622.70791903409076 -1681.6057513794806 61.362250950813852 623.9643832225255 -1681.9104336825278 76.006919611246943 617.38959681968458
+-1728.283380681818 0 626.30022638494302 -1728.283380681818 16.039358494386306 626.30022638494302 -1728.283380681818 32.078716988772612 626.30022638494302 -1727.9994951764893 58.185883146098021 627.52745975783057 -1728.2833806818176 73.018987701465008 621.40633570332625
+-1774.6563276811078 0 629.89253373579527 -1774.6563276811078 16.039358494386306 629.89253373579527 -1774.6563276811078 32.078716988772612 629.89253373579527 -1774.4087778318708 54.803582434011567 630.75795164019621 -1774.6563276811073 70.031055791683073 625.42307458696791
+-1821.0292746803975 0 633.48484108664752 -1821.0292746803975 16.039358494386306 633.48484108664752 -1821.0292746803975 32.078716988772612 633.48484108664752 -1820.8687814696857 51.343032055903222 633.34466366437016 -1821.0292746803971 67.043123881901138 629.43981347060958
+-1867.4022216796873 0 637.07714843749977 -1867.4022216796873 16.039358494386306 637.07714843749977 -1867.4022216796873 32.078716988772612 637.07714843749977 -1867.402221679687 48.117348456469273 635.25826403543113 -1867.4022216796868 64.055191972119161 633.45655235425124
+8 0 0 7 5 -1400.1445548699576 66.006651378195713 582.89554230532792 -1400.0907932715445 68.196760856179125 582.64443343207313 -1400.0340615877806 70.385177677221535 582.37945325135649 -1399.9742168625012 72.57180058321579 582.0999319077838 -1399.9103185418926 74.755820978991821 581.80147475525462 -1399.8411147814279 76.936017147650716 581.4782388593884
+-1400.9012263700297 66.430448373948067 586.429792284104 -1400.847171334103 68.638945288872549 586.17731282820068 -1400.7901630582335 70.847664301513362 585.91114264992632 -1400.7301090494718 73.057498208390015 585.63043968307329 -1400.6659969158868 75.268208133328841 585.33108606308156 -1400.5965704793957 77.483142709451172 585.00681010474932
+-1402.4132921065579 66.854245371364669 589.80231481186149 -1402.3592546773771 69.081129723389452 589.5483981795968 -1402.3024946893279 71.310151680322875 589.28093018391417 -1402.2429842836641 73.543195449636613 588.99887518027549 -1402.1797766664447 75.780595290064952 588.69839032872778 -1402.1118579553711 78.030268273422067 588.37270383419889
+-1404.6398198710976 67.255126750222544 592.82200906099638 -1404.5861130181388 69.499385879920297 592.56658203534164 -1404.5301175891705 71.747586759383012 592.29763631691355 -1404.4718632061249 74.002571593705881 592.01393641989307 -1404.4106306929309 76.265179016505869 591.71185253615693 -1404.345870411878 78.54763581643212 591.38400573617105
+-1407.478716026809 67.610166036751139 595.31077400621371 -1407.4255949404831 69.869798559571507 595.05377336449919 -1407.3707713179469 72.134956369498653 594.78312694593421 -1407.3143635693625 74.409315906757755 594.49738487607215 -1407.2559419946967 76.694155494036536 594.19303557465923 -1407.195620280251 79.005473002264594 593.86195343197789
+-1410.771715145881 67.899570170024546 597.12986366063024 -1410.7193368967605 70.171716615599522 596.87125554197314 -1410.665916782325 72.450657220496723 596.59868247878273 -1410.6116560347996 74.740678604975074 596.31045923046474 -1410.5564892752191 77.043509775648545 596.00309693145334 -1410.501272260937 79.37810089518004 595.66756507039406
+-1414.32823256094 68.109662560294765 598.2007978067661 -1414.2766351224984 70.390842716586036 597.94059982925091 -1414.2246420438421 72.67970468711745 597.66592240633213 -1414.1725162005509 74.980992984155009 597.37487020584319 -1414.1205735112699 77.296697900026828 597.0638164137689 -1414.070386777433 79.64782888236077 596.72271977808077
+-1417.9523082137798 68.233732502367147 598.50700177558895 -1417.9014088486408 70.520189464655232 598.24530790320011 -1417.8506594246139 72.814807949947763 597.9684589228433 -1417.8003642472559 75.122580719142704 597.67436953131721 -1417.7511768748489 77.445633873059691 597.35914795226211 -1417.7052652315906 79.806048816100628 597.01168301769985
+8 0 0 7 5 -1400.5857799393225 44.057864555294486 584.95640978986683 -1400.5145637555306 48.454952557247132 584.62377430113588 -1400.4353296810068 52.849082889782828 584.25369003317962 -1400.3480596226118 57.239752496948505 583.84607134699422 -1400.2520780667821 61.626432422228937 583.39776005183671 -1400.1445548699571 66.006651378195727 582.89554230532724
+-1401.3463768670388 44.33893297335694 588.50899459536822 -1401.2742318253204 48.761103423758193 588.17202061083754 -1401.1940911678964 53.180320392011311 587.79784563542194 -1401.1060448463618 57.597718190595835 587.38631388965177 -1401.0093364418815 62.013454544099147 586.93475119590971 -1400.9012263700292 66.430448373948082 586.42979228410331
+-1402.8643808467275 44.620001392405278 591.89942101146698 -1402.7902722893366 49.067254291104696 591.5583300485431 -1402.7083835887154 53.511558634063306 591.1802510078229 -1402.6189599472352 57.955683494906545 590.76492186314704 -1402.5213669649181 62.400476667315125 590.31014807638974 -1402.4132921065575 66.854245371364684 589.80231481186081
+-1405.098537662941 44.885831346017291 594.9350850809758 -1405.0215365033182 49.356829239131251 594.59059593296308 -1404.9371537744528 53.824884818202307 594.20923189558061 -1404.8458264452554 58.294297970694259 593.79058791531827 -1404.7472387968571 62.766588027661278 593.33285875331251 -1404.6398198710972 67.255126750222544 592.82200906099581
+-1407.9461057890164 45.121177099688715 597.43645100502454 -1407.8655622405336 49.613236422387004 597.08974935725155 -1407.7781715386748 54.102361451573188 596.70613275313144 -1407.6845813388404 58.594224114050455 596.28498861433548 -1407.5849634193023 63.09088052794467 595.82477093064961 -1407.4787160268081 67.610166036751153 595.31077400621325
+-1411.2478991124406 45.312882242768204 599.263686231836 -1411.1635791010997 49.822170094937611 598.91627309610431 -1411.0730112030867 54.328533702453946 598.53171773758493 -1410.977064731049 58.838724280039209 598.1091525729928 -1410.8764716441199 63.355277278874567 597.64707989794397 -1410.7717151458803 67.899570170024532 597.12986366062989
+-1414.8123479349645 45.451868281515843 600.33779716380741 -1414.7244938352721 49.973739244796811 599.99127699709481 -1414.6309746762838 54.49269797462312 599.60719405232783 -1414.5328485959731 59.016266073312643 599.18438947158938 -1414.4314274378214 63.547302247712189 598.72119376179614 -1414.3282325609393 68.109662560294751 598.20079780676588
+-1418.4426334328029 45.533697426556998 600.64225921004186 -1418.3519107660372 50.063105031249385 600.29812858339244 -1418.2560112710237 54.589613893114674 599.91585136794276 -1418.1561350686241 59.121173768747219 599.49395353256409 -1418.0541069440567 63.66081857779092 599.03038952036604 -1417.9523082137794 68.233732502367133 598.50700177558872
+8 0 0 8 3 -1867.4022216796873 -62.47458862868946 558.61018091215283 -1697.3680826822915 -88.422880245532681 493.3025648049653 -1527.3339436848958 -114.37117186237586 427.99494869777783 -1357.2998046875 -140.31946347921908 362.68733259059042
+-1867.4022216796875 -59.248094332083269 558.61018091215283 -1697.3680826822917 -84.222291586932542 491.92044792415209 -1527.3339436848964 -109.19648884178181 425.23071493615146 -1357.2998046875 -134.17068609663113 358.54098194815077
+-1867.4022216796873 -56.021600035477071 558.61018091215283 -1697.3680826822917 -79.904559379580263 490.71204654252961 -1527.333943684896 -103.78751872368348 422.8139121729065 -1357.2998046875 -127.6704780677867 354.91577780328328
+-1867.4022216796873 -52.79510573887088 558.61018091215283 -1697.368082682292 -75.486861012231714 489.68894407884056 -1527.3339436848962 -98.17861628559254 420.76770724552847 -1357.2998046875 -120.87037155895334 351.84647041221638
+-1867.4022216796873 -49.568611442264697 558.61018091215283 -1697.3680826822917 -70.9877485647892 488.86068593315355 -1527.333943684896 -92.406885687313704 419.11119095415455 -1357.2998046875 -113.82602280983821 349.36169597515538
+-1867.4022216796875 -46.342117145658499 558.61018091215283 -1697.368082682292 -66.426846534508954 488.23457560102241 -1527.3339436848964 -86.511575923359374 417.85897028989211 -1357.2998046875 -106.59630531220986 347.4833649787617
+-1867.4022216796875 -43.115622849052308 558.61018091215283 -1697.368082682292 -61.824508934261686 487.81553023937062 -1527.3339436848964 -80.533395019471044 417.02087956658858 -1357.2998046875 -99.242281104680416 346.22622889380648
+-1867.4022216796875 -39.889128552446117 558.61018091215283 -1697.3680826822917 -57.201453232637803 487.60600755854466 -1527.3339436848958 -74.513777912829497 416.60183420493667 -1357.2998046875 -91.82610259302119 345.59766085132873
+-1867.4022216796877 -36.662634255839919 558.61018091215283 -1697.368082682292 -52.578397531013927 487.60600755854483 -1527.3339436848953 -68.494160806187907 416.60183420493672 -1357.2998046875 -84.409924081361908 345.59766085132878
+8 0 0 3 3 -1867.4022216796873 -86.197022651859044 610.1935944517669 -1697.3680826822915 -117.2130856308453 574.61595464338416 -1527.3339436848958 -148.22914860983153 539.03831483500153 -1357.2998046875 -179.24521158881782 503.46067502661867
+-1867.4022216796875 -86.739101959008309 601.62708192608784 -1697.3680826822917 -118.30424986313399 563.2309267096407 -1527.333943684896 -149.86939776725964 524.83477149319378 -1357.2998046874998 -181.43454567138528 486.43861627674681
+-1867.4022216796875 -87.157245955540873 593.05615763635262 -1697.368082682292 -119.12602170793642 551.80978589652887 -1527.333943684896 -151.09479746033202 510.56341415670516 -1357.2998046875 -183.06357321272759 469.31704241688135
+-1867.4022216796877 -87.459081406549089 584.49059026755504 -1697.368082682292 -119.70386474312131 540.38514703720455 -1527.3339436848953 -151.94864807969353 496.27970380685406 -1357.2998046875 -184.19343141626578 452.17426057650368
+8 0 0 9 8 -770.30404092198626 -35.838420274340329 692.1172317151412 -773.92653166591219 -32.140759116691704 692.72477910666498 -777.00416340102436 -28.102426664153931 693.2721329075415 -779.53461890909739 -24.023364272126706 693.70223411951929 -781.58638415303608 -19.545081595681445 694.11591756961411 -783.19216337111766 -14.990691019135555 694.40121322469213 -784.30986428487699 -10.195841963740293 694.61365158291551 -784.92153785105506 -5.2167200945939936 694.72299675888803 -784.92315203051464 0.00059618311145293035 694.72239466913356
+-770.34844891562352 -35.832661892294574 691.80485521577737 -773.96928653708187 -32.131748230924543 692.40831661970617 -777.04316696440708 -28.092368258458041 692.95161228281086 -779.57459714914592 -24.01223393308706 693.38050595334732 -781.61877675041183 -19.535286423791781 693.78896188423323 -783.22457002514443 -14.981298862984126 694.07289437438749 -784.33935769079835 -10.190113158528773 694.28360222518165 -784.9505081169126 -5.213734752670093 694.39235714149424 -784.95221794673932 0.00058849901912161329 694.3918321476591
+-770.43231559872936 -35.866362199717791 691.49736084751157 -774.05669846131082 -32.158934491680959 692.09685185820763 -777.1313577890071 -28.11483954562955 692.6359662437884 -779.66514072423809 -24.031137523117895 693.06414480036517 -781.71017663405655 -19.545800244771055 693.46711506138865 -783.31391740217293 -14.992608577198769 693.74973850305457 -784.43005091730049 -10.196101337461991 693.95879648484424 -785.04120598226643 -5.2171702198213481 694.06712601105312 -785.04298627452511 0.00056235099316204185 694.06669503635896
+-770.55404182184759 -35.939728558230335 691.20599741192598 -774.18718852960558 -32.2226474743401 691.8020567986523 -777.26570622438919 -28.171945665392137 692.33753762152992 -779.81098464260549 -24.074679997079777 692.76602153722422 -781.85211613498143 -19.58563659924733 693.16315549791898 -783.46430287037163 -15.018546741043576 693.44523867890371 -784.57978075659048 -10.216139511269366 693.65264877940319 -785.19247740586979 -5.2271453221492115 693.76047449039982 -785.19429964164874 0.00051804500552104268 693.760145964515
+-770.71013415551045 -36.051073988927754 690.94177895234805 -774.35698765278164 -32.321432521164326 691.53535721820413 -777.4438949654791 -28.260142808393176 692.06749830039985 -779.9994374465042 -24.149373050308487 692.49685240792132 -782.04928871516597 -19.642776614434581 692.88928029716715 -783.66399043564195 -15.066844947278074 693.17088752122004 -784.78503844695695 -10.247064911536638 693.37726549696447 -785.39989035140252 -5.2434381488485418 693.48528590432238 -785.40172536455088 0.00045686713959778587 693.48505898766143
+-770.89531074808178 -36.196801974360426 690.714730800805 -774.56024319824246 -32.452027009348186 691.30713215740457 -777.65871860142738 -28.378858094455165 691.83791467751121 -780.23347290373579 -24.244792498313014 692.26947778525277 -782.28597891084291 -19.727010722995967 692.65765535930916 -783.91415025183551 -15.127068829666156 692.94006240024044 -785.03811280808645 -10.290673529316514 693.14559627021163 -785.65581726315918 -5.2654767869366825 693.25317973373717 -785.6576381447328 0.00038106183304327111 693.25304456395361
+-771.1028036495893 -36.37158635693315 690.53315125520601 -774.78935782526059 -32.609525234719271 691.1259296519512 -777.9017307319358 -28.52143103648736 691.65559932230747 -780.49482789007709 -24.36395311789531 692.08996023060047 -782.55907790381161 -19.824846863661421 692.47596116610453 -784.19655011330633 -15.204270756961147 692.75934697037758 -785.32789278322298 -10.342715048785415 692.96496729788009 -785.94989419337332 -5.2923690813298991 693.07355528691096 -785.95167894657129 0.00029369759172928486 693.07349435283913
+-771.32482618157599 -36.568739143852824 690.40303852926343 -775.03552594750522 -32.787726391102666 690.99786201145128 -778.16470990101914 -28.683587446479091 691.52920767026342 -780.78063447285945 -24.497424425168344 691.96751505363375 -782.85432879849816 -19.939119589207564 692.35261474256572 -784.50634601506522 -15.290090221722654 692.63814634365997 -785.64410910209824 -10.402691405709103 692.84427481282046 -786.26981422505332 -5.3229710066541047 692.95287212534981 -786.27154770861421 0.00019843217645693702 692.95286253092627
+-771.55313472219041 -36.780710634484898 690.32776957674957 -775.28938503792313 -32.979611835212161 690.92627404301447 -778.4354973829993 -28.857952059023347 691.45976542788526 -781.07443660454862 -24.642169687948407 691.90258496186118 -783.16024914201682 -20.061253040848161 692.28884460659515 -784.82601487387581 -15.383615448280958 692.57692132682564 -785.97153987388901 -10.467109887979491 692.78436163968104 -786.60232394990692 -5.3559822075498795 692.89428626990843 -786.6039988163318 9.9216087910155264e-05 692.89430245694041
+-771.77957506491975 -36.999617891711971 690.30805435076843 -775.54165077742744 -33.177849536783334 690.9117077375214 -778.70560826076451 -29.038073839243854 691.44937559248524 -781.36811792284334 -24.791533171064614 691.89736543841502 -783.46564918591673 -20.187796046671572 692.28627467876743 -785.14586598452991 -15.479957444864207 692.57763821723961 -786.29896639463595 -10.533708877595741 692.78683398464 -786.93420287663503 -5.3900462346049363 692.8976632006063 -786.93581954023125 -6.9810818367418981e-13 692.89767965465012
+8 0 0 6 5 -1357.2998046875 -179.24521158881782 503.46067502661867 -1284.5811940917115 -192.04166980531761 491.88542698813899 -1211.8625834959232 -204.69122568301225 480.95083841966493 -1127.0149440528292 -147.70409378684926 458.61133304318759 -1057.9677225174657 -176.04230709942885 472.57017187666241 -986.57813877543083 -197.69118105707622 477.10731046014951
+-1357.2998046875 -180.33987863010157 494.94964565168277 -1284.7166402509279 -193.28441239490337 482.68718867257587 -1212.1334758143557 -206.09929623002472 471.04611985073711 -1126.6933724506998 -147.12468698620216 451.21442587478947 -1057.9732626762013 -175.57186968789449 464.2361712239005 -986.57835623231938 -197.28641548956071 468.3762077771483
+-1357.2998046875 -181.32248436314026 486.41871325474813 -1284.8589361756433 -194.39795205361827 473.46019882502179 -1212.4180676637864 -207.36009725841237 461.10169448463353 -1126.3327107490909 -146.33425926498845 443.71741781498019 -1057.9744278614219 -174.88162875192182 455.81679351176331 -986.57862620998037 -196.65724926930014 459.60847290950136
+-1357.2998046875 -182.196085648105 477.87179319228881 -1285.0081260070972 -195.38539570099013 464.20988909099145 -1212.7164473266939 -208.47666063112612 451.1246675144655 -1125.9377100117827 -145.35684355294188 436.17906786620591 -1057.9720581187962 -173.9982616008275 447.36959010110053 -986.57894026977351 -195.83342595852471 450.85285763130963
+-1357.2998046875 -182.9637393451668 469.31280082077893 -1285.1642188652052 -196.2499703642037 454.94160305364414 -1213.0286330429099 -209.45229530995425 441.12196624450917 -1125.5149706950106 -144.21997031613699 428.65319341191866 -1057.9669503900309 -172.95043008133845 438.95035027299616 -986.57928829079856 -194.84448732388654 442.15836044038025
+-1357.2998046875 -183.62850231449673 460.74565149669252 -1285.3271907820972 -196.99499674014572 445.6605932168161 -1213.3545768766937 -210.29052643704208 431.10033215412273 -1125.0727120142205 -142.95170831933618 421.1864810717862 -1057.9598074646754 -171.76662833829781 430.61089457909026 -986.57965937916845 -193.71873331934876 433.57148267718316
+-1357.2998046875 -184.19343141626581 452.17426057650368 -1285.4969866356553 -197.62386275744993 436.3720179880529 -1213.6941685838099 -210.99503441641147 421.06631296166324 -1124.6200834825863 -141.57753137538 413.81750790987098 -1057.9511869319285 -170.47303057537067 422.39686819190024 -986.58004277728298 -192.48218206907464 425.13348464380789
+8 0 0 2 4 -1867.4022216796877 -36.662634255839926 558.61018091215283 -1739.8766174316406 -48.59945671222043 505.35705089694682 -1612.3510131835938 -60.536279168600913 452.10392088174081 -1484.8254089355464 -72.473101624981396 398.85079086653468 -1357.2998046875 -84.409924081361908 345.59766085132878
+-1867.402221679688 -18.331317127919974 558.61018091215237 -1739.8766174316415 -24.309610162112381 505.35705089694721 -1612.3510131835919 -30.281315325636619 452.10392088174103 -1484.8254089355444 -36.246432618492776 398.85079086653457 -1357.2998046875002 -42.204962040680968 345.59766085132873
+-1867.4022216796875 0 558.61018091215283 -1739.8766174316406 0 505.35705089694682 -1612.3510131835938 0 452.10392088174081 -1484.8254089355469 0 398.85079086653485 -1357.2998046875 0 345.59766085132884
+8 0 0 3 9 -472.051032752406 1.4921223978614506e-14 486.92503483316398 -472.96359232208584 8.3422851959724653e-15 476.24217469834952 -474.40517900466847 3.8446290903968204e-15 464.93783407571271 -476.47079883457178 8.33328115507335e-16 453.17598041415874 -479.26117847566445 -1.2775136988838402e-15 441.19419930870748 -482.69367305852541 -3.0786385345799818e-15 429.68874103222004 -486.62279027622463 -5.1610088557305223e-15 418.57191818646294 -491.01233270889628 -8.123517290946501e-15 407.95946298837845 -495.80544054793802 -1.2549856986954211e-14 397.79369019423632 -500.98427140239534 -1.905940683055718e-14 388.04157302660883
+-472.05103275240594 -61.590267669882842 486.92503483316398 -472.96359232208579 -62.956181393732123 476.24217469834952 -474.40517900466847 -64.015573351125568 464.93783407571266 -476.47079883457178 -64.721248015807021 453.17598041415874 -479.26117847566445 -64.999398169328742 441.19419930870748 -482.69367305852541 -64.929709940446145 429.68874103222004 -486.62279027622463 -64.615605690292327 418.57191818646294 -491.01233270889628 -64.111341021306643 407.95946298837845 -495.80544054793802 -63.481203405975968 397.79369019423632 -500.98427140239534 -62.774591149532299 388.04157302660883
+-480.8530986456604 -125.08931619043739 491.80693749431919 -481.96403477189523 -127.90580733772327 481.68572650737116 -483.47473528835576 -130.09352621968878 470.95619973252417 -485.45817207517456 -131.54559957819805 459.75446071846551 -487.99236450753608 -132.13304450957165 448.28017007155535 -491.04451234008559 -131.97276094279613 437.16968099133203 -494.53061563094292 -131.33642336472209 426.36178571781386 -498.43394953693689 -130.28942067602952 415.96785540960121 -502.72747419182423 -128.98994188672825 405.95001389086423 -507.40759861821772 -127.53207709065254 396.2889022909286
+-498.45723043216924 -190.49714556166364 501.57074281662955 -499.96491967151411 -194.84887783197348 492.5728301254145 -501.61384785573006 -198.23216566648199 482.99293104614719 -503.43291855638267 -200.47958459554417 472.91142132708103 -505.45473657127371 -201.38933029473694 462.45211159724528 -507.74619090321215 -201.14076173304079 452.13156090956369 -510.34626634037659 -200.15592311491963 441.94152078051093 -513.27718319301857 -198.53593190337543 431.98464025204839 -516.57154147959682 -196.52621544225673 422.26266128412016 -520.25425304986265 -194.27245782336064 412.78356081956821
+8 0 0 2 4 -1867.4022216796877 36.662634255839926 558.61018091215283 -1739.8766174316406 48.59945671222043 505.35705089694682 -1612.3510131835938 60.536279168600913 452.10392088174081 -1484.8254089355464 72.473101624981396 398.85079086653468 -1357.2998046875 84.409924081361908 345.59766085132878
+-1867.402221679688 18.331317127919974 558.61018091215237 -1739.8766174316415 24.309610162112381 505.35705089694721 -1612.3510131835919 30.281315325636619 452.10392088174103 -1484.8254089355444 36.246432618492776 398.85079086653457 -1357.2998046875002 42.204962040680968 345.59766085132873
+8 0 0 7 5 -1357.2998046875 140.31946347921908 362.68733259059036 -1288.3392033724342 149.74517052458046 335.46007510878678 -1219.3786020573682 158.98223078947794 308.0007268572129 -1120.0058707994283 121.89706507359358 334.64601007881816 -1057.8249739693031 151.60668166320417 335.8901544314902 -986.58389113763735 174.18268314342859 336.76440334201646
+-1357.2998046875 133.29228932768999 357.94864614208791 -1288.4690661548582 142.13474907835902 330.19056275140088 -1219.6383276222164 150.76022767677586 302.22377749552828 -1119.8016000180182 120.26649094603754 329.2340282897502 -1057.8170395801139 150.02891174292324 330.18493255119802 -986.58404389406348 172.63514424627724 330.93752433297351
+-1357.2998046875 125.79654098115226 353.90482169034834 -1288.5579691609776 134.05205044103656 325.74574533459764 -1219.8161336344554 142.0724506194276 297.41615075048446 -1119.638682968874 118.65307577946828 324.0161783231294 -1057.8100811200052 148.46390046494503 324.72947552615108 -986.58415758272042 171.09637528358112 325.35964365112909
+-1357.2998046875 117.9146129265856 350.61162245930888 -1288.6076164721503 125.61770172233588 322.17918368661964 -1219.9154282568009 133.08462263887407 293.62525677245281 -1119.5154105377128 117.05771734738703 318.97981398646891 -1057.8041826506767 146.91129670632628 319.50400366359236 -986.58423329136713 169.56583213292194 320.00958124142443
+-1357.2998046875 109.73733300936307 348.11210111262369 -1288.6240662306707 116.95841291666582 319.51882467895445 -1219.9483277738414 123.96503672475883 290.8556174455602 -1119.4273235290686 115.47664802012326 314.10394812171035 -1057.7994101488785 145.36590579435369 314.47604461430939 -986.58427498061292 168.03808488043248 314.85385316598689
+-1357.2998046875 101.36118925086875 346.43575157463243 -1288.6173911551978 108.19965145298107 317.76846890720628 -1219.9349776228955 114.87071351601983 289.07511226131629 -1119.3665205754614 113.89887986788177 309.35386432326686 -1057.7955575754302 143.81623678957544 309.59689838884015 -986.58429000903732 166.50221719454467 309.84508696963752
+-1357.2998046875 92.885556666115363 345.59766085132873 -1288.6008422348059 99.459177012225538 316.90981576347372 -1219.901879782112 105.93733427339703 288.22197067561882 -1119.3267199344616 112.30140905869288 304.67447636376011 -1057.7920130829179 142.24337648569312 304.7998314668958 -986.58428965830979 164.94122569973771 304.92043704539839
+-1357.2998046875 84.409924081361893 345.59766085132878 -1288.5895156016559 90.841436612359118 316.90508590023308 -1219.879226515812 97.272949143356271 288.21251094913742 -1119.2974866873762 110.65238789245011 299.99999999999795 -1057.7877453620681 140.62019012631399 300.00000000000045 -986.58428965830979 163.3314193502861 300
+8 0 0 13 1 -699.11028158841452 35.355339059327335 699.9260149150881 -689.79198438759272 44.673636260149202 549.30007380992208
+-707.65428723871912 43.899344709631876 699.9260149150881 -696.08412126635335 50.965773138910151 549.30007380992208
+-718.43510833762582 50.206534911334209 699.9260149150881 -737.85471141749088 87.083660338277724 549.30007380992208
+-730.81391188688337 53.63807666618299 699.9260149150881 -664.64960869306174 2.5731067254124866 549.30007380992208
+-743.95116958282279 53.755832281344588 699.9260149150881 -858.22588701714903 179.69864788342377 549.30007380992208
+-756.87680570911925 50.392323231554364 699.9260149150881 -645.68644189758629 -53.424056542918237 549.30007380992208
+-768.58734111626052 43.693625665910218 699.9260149150881 -828.8098928825691 106.44050646449162 549.30007380992208
+-778.15924631365203 34.121720468518717 699.9260149150881 -840.90612711226981 94.344272234886517 549.30007380992208
+-784.85794387929616 22.411185061377388 699.9260149150881 -681.04156410471364 -88.779178750175987 549.30007380992208
+-788.22145292908635 9.4855489350808764 699.9260149150881 -914.16426853104235 123.76026636945645 549.30007380992208
+-788.10369731392473 -3.6517087608585133 699.9260149150881 -737.03872737273878 -69.816011954631875 549.30007380992208
+-784.67215555907592 -16.030512310116116 699.9260149150881 -821.54928098505638 3.389090769808405 549.30007380992208
+-778.36496535737353 -26.811333409022861 699.9260149150881 -785.4313937843458 -38.38149938146168 549.30007380992208
+-769.82095970706894 -35.355339059327406 699.9260149150881 -779.13925690237443 -44.67363626076812 549.30007380992208
+8 0 0 8 3 -1867.4022216796873 62.47458862868946 558.61018091215283 -1697.3680826822915 88.422880245532681 493.3025648049653 -1527.3339436848958 114.37117186237586 427.99494869777783 -1357.2998046875 140.31946347921908 362.68733259059042
+-1867.4022216796875 59.248094332083269 558.61018091215283 -1697.3680826822917 84.222291586932542 491.92044792415209 -1527.3339436848964 109.19648884178181 425.23071493615146 -1357.2998046875 134.17068609663113 358.54098194815077
+-1867.4022216796873 56.021600035477071 558.61018091215283 -1697.3680826822917 79.904559379580263 490.71204654252961 -1527.333943684896 103.78751872368348 422.8139121729065 -1357.2998046875 127.6704780677867 354.91577780328328
+-1867.4022216796873 52.79510573887088 558.61018091215283 -1697.368082682292 75.486861012231714 489.68894407884056 -1527.3339436848962 98.17861628559254 420.76770724552847 -1357.2998046875 120.87037155895334 351.84647041221638
+-1867.4022216796873 49.568611442264697 558.61018091215283 -1697.3680826822917 70.9877485647892 488.86068593315355 -1527.333943684896 92.406885687313704 419.11119095415455 -1357.2998046875 113.82602280983821 349.36169597515538
+-1867.4022216796875 46.342117145658499 558.61018091215283 -1697.368082682292 66.426846534508954 488.23457560102241 -1527.3339436848964 86.511575923359374 417.85897028989211 -1357.2998046875 106.59630531220986 347.4833649787617
+-1867.4022216796875 43.115622849052308 558.61018091215283 -1697.368082682292 61.824508934261686 487.81553023937062 -1527.3339436848964 80.533395019471044 417.02087956658858 -1357.2998046875 99.242281104680416 346.22622889380648
+-1867.4022216796875 39.889128552446117 558.61018091215283 -1697.3680826822917 57.201453232637803 487.60600755854466 -1527.3339436848958 74.513777912829497 416.60183420493667 -1357.2998046875 91.82610259302119 345.59766085132873
+-1867.4022216796877 36.662634255839919 558.61018091215283 -1697.368082682292 52.578397531013927 487.60600755854483 -1527.3339436848953 68.494160806187907 416.60183420493672 -1357.2998046875 84.409924081361908 345.59766085132878
+8 0 0 3 9 -472.051032752406 -1.4921223978614506e-14 486.92503483316398 -472.96359232208584 -8.3422851959724653e-15 476.24217469834952 -474.40517900466847 -3.8446290903968204e-15 464.93783407571271 -476.47079883457178 -8.33328115507335e-16 453.17598041415874 -479.26117847566445 1.2775136988838402e-15 441.19419930870748 -482.69367305852541 3.0786385345799818e-15 429.68874103222004 -486.62279027622463 5.1610088557305223e-15 418.57191818646294 -491.01233270889628 8.123517290946501e-15 407.95946298837845 -495.80544054793802 1.2549856986954211e-14 397.79369019423632 -500.98427140239534 1.905940683055718e-14 388.04157302660883
+-472.05103275240594 61.590267669882842 486.92503483316398 -472.96359232208579 62.956181393732123 476.24217469834952 -474.40517900466847 64.015573351125568 464.93783407571266 -476.47079883457178 64.721248015807021 453.17598041415874 -479.26117847566445 64.999398169328742 441.19419930870748 -482.69367305852541 64.929709940446145 429.68874103222004 -486.62279027622463 64.615605690292327 418.57191818646294 -491.01233270889628 64.111341021306643 407.95946298837845 -495.80544054793802 63.481203405975968 397.79369019423632 -500.98427140239534 62.774591149532299 388.04157302660883
+-480.8530986456604 125.08931619043739 491.80693749431919 -481.96403477189523 127.90580733772327 481.68572650737116 -483.47473528835576 130.09352621968878 470.95619973252417 -485.45817207517456 131.54559957819805 459.75446071846551 -487.99236450753608 132.13304450957165 448.28017007155535 -491.04451234008559 131.97276094279613 437.16968099133203 -494.53061563094292 131.33642336472209 426.36178571781386 -498.43394953693689 130.28942067602952 415.96785540960121 -502.72747419182423 128.98994188672825 405.95001389086423 -507.40759861821772 127.53207709065254 396.2889022909286
+-498.45723043216924 190.49714556166364 501.57074281662955 -499.96491967151411 194.84887783197348 492.5728301254145 -501.61384785573006 198.23216566648199 482.99293104614719 -503.43291855638267 200.47958459554417 472.91142132708103 -505.45473657127371 201.38933029473694 462.45211159724528 -507.74619090321215 201.14076173304079 452.13156090956369 -510.34626634037659 200.15592311491963 441.94152078051093 -513.27718319301857 198.53593190337543 431.98464025204839 -516.57154147959682 196.52621544225673 422.26266128412016 -520.25425304986265 194.27245782336064 412.78356081956821
+8 0 0 8 4 -1867.4022216796877 87.459081406549103 584.49059026755504 -1739.8766174316406 111.64266890897827 551.41150784479214 -1612.3510131835938 135.82625641140743 518.33242542202925 -1484.8254089355464 160.00984391383662 485.25334299926652 -1357.2998046875 184.19343141626584 452.17426057650368
+-1867.402221679688 87.635825783937264 579.47489093032482 -1739.8766174316406 111.95372391961236 544.76855733186346 -1612.3510131835933 136.29557150185951 509.81413931893798 -1484.825408935546 160.66136853067869 474.61163689154881 -1357.2998046875002 185.05111500606995 439.16105004969597
+-1867.4022216796877 86.66181110837816 574.41864087849615 -1739.8766174316406 110.89497326989414 537.79046581879686 -1612.3510131835931 135.19059940933977 500.84796832008414 -1484.8254089355455 159.54868952671498 463.5911483823586 -1357.2998046875 183.96924362201995 426.02000600561985
+-1867.402221679688 84.526183170201534 569.62986378475205 -1739.8766174316404 108.46877502810966 530.87579023375997 -1612.3510131835924 132.51620658818749 491.86752004480007 -1484.8254089355455 156.66847785043501 452.60505321787309 -1357.2998046875 180.9255888148524 413.08838975297846
+-1867.4022216796875 81.317002603368522 565.42004530019256 -1739.8766174316404 104.76926235517797 524.42683870572512 -1612.3510131835924 128.36189483437664 483.31044253561072 -1484.8254089355451 152.09490004096449 442.07085678985015 -1357.2998046875 175.96827797494166 400.70808146844314
+-1867.4022216796873 77.22281112619396 562.06460080926308 -1739.8766174316406 99.983840978884672 518.8154567531742 -1612.3510131835924 122.90322999326035 475.58952888071582 -1484.8254089355451 145.98097816932111 432.38681719188776 -1357.2998046875 169.21708550706694 389.20732168668997
+-1867.4022216796873 72.512213530314085 559.76165421118958 -1739.8766174316409 94.376546854414698 514.34736593919058 -1612.3510131835928 116.38897529166944 469.0626157427352 -1484.8254089355451 138.54949884207838 423.90740362182322 -1357.2998046875 160.85811750564147 378.88172957645463
+-1867.4022216796875 67.493401079501766 558.61018091215271 -1739.8766174316411 88.254777465009255 511.24188112175119 -1612.3510131835933 109.11503054041022 464.01387486712281 -1484.8254089355462 130.07416030570471 416.92616214826745 -1357.2998046875002 151.13216676089272 369.9787429651854
+-1867.4022216796877 62.474588628689446 558.61018091215283 -1739.8766174316406 81.935807341321862 509.6294688317621 -1612.3510131835938 101.39702605395428 460.64875675137159 -1484.8254089355469 120.85824476658665 411.66804467098098 -1357.2998046875 140.31946347921911 362.68733259059042
+8 0 0 9 14 -768.52507173324011 -34.059451084925982 699.92601491507935 -786.19484127425187 -16.389681544230875 699.92601491507435 -784.17104185594701 1.1039223269087763 699.92601491506207 -786.67925515774459 9.5998830498552863 699.92601491511846 -776.95907751467212 22.051509255189558 699.92601491493747 -780.86358576825614 23.043940009861473 699.92601491535447 -770.25619561851659 32.878532682178886 699.92601491464279 -769.79105626392129 35.276215185037046 699.9260149155582 -766.50202067523401 36.589859920617798 699.9260149146802 -757.29428921831152 46.325779907079173 699.92601491532014 -755.84128259894896 42.922277027192891 699.92601491497635 -743.66569953138105 52.157574288289453 699.92601491511562 -735.0762323332483 49.73068412427039 699.92601491508037 -717.83854282847528 51.491824352060441 699.92601491509276 -700.40616956141048 34.059451084811158 699.92601491509743
+-768.75818596146473 -34.292565313217978 699.92601491507935 -786.54860670060771 -16.502144574361093 699.92601491507435 -784.51044141524574 1.1132721124105154 699.92600676182371 -787.04992842936679 9.6624165259768287 699.92624732806405 -777.19830048928213 22.196330113278293 699.9252747165109 -781.28933123006175 23.241131265581448 699.92779334208842 -770.35553129993116 33.012641561617599 699.92324617367944 -770.17115908569531 35.651654609622774 699.92919205888768 -766.62662957384339 36.698003205425863 699.92349803857167 -757.49260192664099 46.749818015464051 699.92744625913622 -755.98021858864786 43.164084053198785 699.92554923256478 -743.7259074940057 52.528296250712224 699.92610485408045 -735.08217309969223 50.070094750922166 699.92605555019793 -717.72446500663978 51.843974986763129 699.92601491502933 -700.17305533331626 34.292565313525493 699.92601491509288
+-768.99130018968958 -34.525679541509973 699.86487989124714 -786.90237217583001 -16.614607555616903 699.86487989124294 -784.85149962643789 1.1233250481478434 699.86621890407446 -787.4077828713107 9.7185714352024632 699.85453868253819 -777.4827686459945 22.36868344246497 699.90116048211462 -781.61270723591088 23.36494665612874 699.78546449478335 -770.61339220930779 33.27938909622118 699.98535936628059 -770.3758761228919 35.857482437404109 699.72766248681012 -766.89023849211549 36.961693688649078 699.98542487806947 -757.61255603167626 47.072304470707408 699.78508810329345 -756.14901288890417 43.451484726893852 699.90167162128819 -743.77890530460297 52.88606198695534 699.85423286663945 -735.08881296518382 50.41132498849769 699.86630581860629 -717.61038723308252 52.196125669407884 699.86487989114801 -699.93994110537301 34.525679541540192 699.86487989125362
+-769.21525277540798 -34.74963212729547 699.74260984358284 -787.24223411427465 -16.722650788650252 699.74260984358068 -785.17380213026001 1.1307019596990355 699.74606730169432 -787.79245528962304 9.7931935332792737 699.71812946061368 -777.61119949840725 22.445048801614593 699.82876064631159 -782.25234088361094 23.72158073630742 699.5586709312737 -770.34893967310018 33.106403973740477 700.01599733079559 -771.14171056554289 36.602801731462861 699.4354591231787 -766.69069077337087 36.714863050325292 700.01493844809067 -757.98370445294699 47.707028708953487 699.5591629447714 -756.2131968958588 43.582378886793755 699.82914722447924 -743.85360084682725 53.270901487310908 699.71771657260251 -735.09273697649519 50.733369442038288 699.74619236304466 -717.50079267309877 52.53443628082907 699.74260984346233 -699.71598851992042 34.749632127471834 699.7426098436498
+-769.42088246316303 -34.955261815117346 699.56240783434714 -787.55429008022861 -16.821854198242804 699.5624078343476 -785.48238201865706 1.1426610979049867 699.57017974642395 -788.04944081759868 9.8146881209958785 699.50294271855034 -778.06902646610274 22.718229309346604 699.77097986771798 -782.07386360899204 23.507724213684508 699.10712943135047 -771.28763217832386 33.926846905556573 700.2513547993218 -770.54253076827058 36.032533102974718 698.77933680984313 -767.53796898849419 37.642440367743077 700.25022367361748 -757.7440280806178 47.533556623279324 699.10696030905626 -756.49382531241395 44.043045737076554 699.77242314141188 -743.86862209215383 53.527486804382363 699.50192040353545 -735.10185872116915 51.042622839705679 699.57043887784789 -717.40016485772856 52.845067840861468 699.56240783420731 -699.51035883254474 34.955261815367336 699.56240783439296
+-769.59969808147321 -35.134077433493928 699.33068282501472 -787.82565410884365 -16.908121406278454 699.33068282501904 -785.73099429388481 1.1446639221994048 699.34175791167183 -788.42332832744989 9.9093750576710722 699.25147428857383 -777.934090902501 22.627966968391149 699.6093103866524 -783.12846999226394 24.194975579481774 698.73413489266125 -770.22152122890554 33.063384181846388 700.21923379311045 -772.11173402654993 37.548439906446269 698.3311332186986 -766.61296595431816 36.611078955679787 700.21550103013112 -758.47399103333339 48.576935050287197 698.73624635524618 -756.37899082100967 43.909941146508984 699.61006260748547 -743.96853946453245 53.901686559850575 699.2504322102227 -735.10085196261139 51.290383003538196 699.34205550808588 -717.31265898472191 53.115193204285248 699.33068282478712 -699.33154321431903 35.134077433018255 699.33068282483077
+-769.74455707292611 -35.27893642501251 699.0566907698402 -788.04548668961911 -16.978006808445286 699.05669076984827 -785.95898991205831 1.1571924849373083 699.0739899548546 -788.52388197714572 9.8872364168264593 698.92582696189652 -778.53952230703032 22.981661461353369 699.51596385334028 -782.37281694695105 23.613992788160488 698.05746582144343 -771.8413230033193 34.422083395999394 700.5646399978317 -770.64618503503755 36.139585283602649 697.34583079111053 -768.02846134979711 38.201519707359168 700.56121010641573 -757.84639784981857 47.832642345552429 698.05817520473499 -756.75121337025212 44.517671141358768 699.51848443741619 -743.9372101866719 54.001527064575406 698.92383193744615 -735.11155663354339 51.51955152482936 699.07449173588725 -717.24177013722851 53.334022340641766 699.05669076921572 -699.18668422000383 35.27893642366594 699.0566907684231
+-769.85020480798812 -35.384584160140264 698.75183572557478 -788.20581362980101 -17.028975338433003 698.75183572558683 -786.10072301135688 1.155816033973379 698.77286814505317 -788.78436067414543 9.966300504362092 698.59865928851661 -778.31743377883743 22.828847644778357 699.29018692380441 -783.33043289124544 24.284458801205712 697.5930442297398 -770.67054170215147 33.437682437335773 700.48544957799572 -772.19355704086195 37.629748496389013 696.7960599316167 -766.97880565980563 37.065168532467588 700.47911664535047 -758.56474925503994 48.778758483165426 697.59629523948877 -756.57297721151463 44.296710420226212 699.29194109588002 -744.02315141497252 54.262161264345231 698.59663955127519 -735.10820310366501 51.660367834281715 698.77341342788395 -717.19006977640811 53.493617455338274 698.75183572358526 -699.08103647006044 35.384584158433903 698.75183572012168
+-769.91358654224655 -35.447965894463216 698.42874519727991 -788.30199941670867 -17.059553020074112 698.42874519729548 -786.20653500697551 1.1632693676190702 698.45524510571818 -788.78280782010938 9.9385647037138654 698.23119224114191 -778.74036012068598 23.062084979002979 699.12243579569872 -782.65898517887035 23.820024306277126 696.9256524020833 -771.87789358585599 34.417127679217494 700.68961330944467 -771.02925828654179 36.505865408880595 695.86917041546826 -767.99806467144356 38.249558986262258 700.68317873731894 -758.06932443889002 48.116105100038524 696.92807346266773 -756.81906010153398 44.720907671050078 699.12552781869704 -743.98973674483591 54.259913924691475 698.22839931841565 -735.11488187169334 51.767041334920592 698.45596061447429 -717.1590530276452 53.589364191941932 698.42874519052009 -699.01765469294889 35.447965894782442 698.42874517754217
+-769.93390378594336 -35.46828313822391 698.10032640057511 -788.33283209965691 -17.069354824559881 698.10032640059364 -786.23297685181569 1.1619713824269973 698.12994846630068 -788.83890743181905 9.9629167131155221 697.88121467049496 -778.67173600052979 22.993906749788724 698.86960915239308 -782.92361416079052 24.050938236700397 696.4385395751267 -771.48810653427461 34.050108080613938 700.59303107562653 -771.54729986938378 36.99900244470588 695.28303626734009 -767.60104906768333 37.873115109720317 700.58461528068369 -758.32369923115675 48.37638470764665 696.44265394767672 -756.73865975833598 44.652925043634802 698.87221939428628 -744.01785558154791 54.315846887501245 697.87840834458382 -735.1128823812827 51.793257196510424 698.13067198663225 -717.14911044251949 53.620056133166187 698.10032637837492 -698.99733737554823 35.468283150083181 698.10032633339983
+8 0 0 9 14 -768.52507173317406 -34.059451085299941 699.92601491507958 -750.98471981093587 -51.599803007575773 699.92601491508458 -733.63194869624942 -49.718721276015167 699.92601491499693 -725.08361281727889 -52.186548449502162 699.92601491552875 -712.77424616716075 -42.725579389308436 699.92601491376172 -711.5363773699255 -46.364010493042969 699.92601491785456 -702.00843066276025 -36.205091714761927 699.92601491086634 -699.16850601449937 -35.3004042832709 699.92601491990445 -698.25041339204893 -32.447459631857015 699.9260149109632 -688.10451039713166 -22.928524786600505 699.92601491773394 -691.73451534868184 -21.684506355073005 699.92601491385904 -682.28041338020023 -9.37838758709443 699.92601491549817 -684.74620767589749 -0.82900806234665936 699.92601491502012 -682.86828212104001 16.521563644189769 699.92601491510334 -700.40616956197482 34.059451085125907 699.92601491509845
+-768.758185961408 -34.292565313548565 699.92601491507946 -751.09806207043709 -51.952689204555881 699.92601491508469 -733.62453562542805 -50.058104433126005 699.92600591246583 -725.02224921876541 -52.557310147478923 699.92625243774137 -712.63296777295682 -42.966020539878627 699.92525985270822 -711.3378920343423 -46.789246377212329 699.92781933012054 -701.88033967694992 -36.30840544021062 699.92321795729617 -698.78931355163206 -35.678836291100332 699.92920881372072 -698.14798788695009 -32.575999305586507 699.92349760122181 -687.67852251784814 -23.126839741114878 699.92743800185156 -691.49455444633179 -21.825785908155098 699.9255564395238 -681.90946701687869 -9.4397643134903859 699.92610186123227 -684.40690436074181 -0.8364026274191948 699.92605610567318 -682.51541269276356 16.634922672431422 699.92601491514165 -700.17305533379306 34.292565313471094 699.92601491507719
+-768.99130018964183 -34.525679541797189 699.86487989124737 -751.21140428142905 -52.305575450025358 699.86487989125249 -733.61624986427228 -50.39927981138085 699.86623780402306 -724.96763271952204 -52.915188838078926 699.85446271699777 -712.46247650496844 -43.252152627714835 699.90124134947621 -711.21601567580603 -47.111977407712821 699.78556802934634 -701.61469491696971 -36.569883067291833 699.98504627014006 -698.58454048287695 -35.883423337327216 699.72792210746502 -697.88634212883517 -32.841750290199819 699.98532326251222 -687.35583081762434 -23.248377537457316 699.7851875149629 -691.2082207867976 -21.996321709586155 699.90153950031277 -681.55156099547696 -9.4942043813978216 699.85431081644663 -684.0656353271803 -0.84459742468023868 699.86628832490942 -682.16254321602889 16.748281652224598 699.86487989133752 -699.93994110561198 34.525679541865927 699.86487989121986
+-769.21525277536944 -34.749632127539385 699.74260984358295 -751.32029218826528 -52.644592714692536 699.74260984358841 -733.61105748357352 -50.721332637492502 699.74610285030258 -724.89332515123351 -53.300015698474311 699.71802880617838 -712.39291384632133 -43.381294145019076 699.82863311349104 -710.85175757118486 -47.750225976286437 699.55962865050481 -701.80253676154553 -36.31247565861451 700.01435551854638 -697.82760582419678 -36.640907377619811 699.43665499093311 -698.14375998919354 -32.653594163758633 700.0146229828099 -686.71775467817395 -23.613226212474444 699.55925532497679 -691.07932712030572 -22.065792463894429 699.8289304675377 -681.16688794771142 -9.5687841805533349 699.71787583598041 -683.74378955573457 -0.84993224629860409 699.74615373041479 -681.8235420609567 16.857185668663242 699.74260984369039 -699.71598851973988 34.749632127615143 699.74260984352463
+-769.42088246313347 -34.955261815318103 699.56240783434737 -751.42027116504039 -52.955873113415947 699.56240783435237 -733.60005862955938 -51.030478617358952 699.57028667852967 -724.87464367161817 -53.556780409639181 699.50252187936053 -712.11512169792491 -43.841737125738426 699.7713780776744 -711.07924749945846 -47.572363954698247 699.10787706062274 -700.96557315641041 -37.249243057075098 700.24936002258778 -698.41509878558406 -36.052649587107112 698.78095574440022 -697.20672215005857 -33.490559663987554 700.24962244110009 -686.89520706551082 -23.384953625405085 699.10750262744273 -690.61841179453484 -22.343355154489768 699.77168240576566 -680.90975903091487 -9.5869623745053616 699.50236409145248 -683.43422959106442 -0.86051928304853209 699.57033869205645 -681.51227645392498 16.957179437329472 699.56240783445628 -699.51035883205498 34.955261815775465 699.56240783422845
+-769.59969808145229 -35.13407743365174 699.33068282501495 -751.50721280716607 -53.226562707942904 699.33068282502018 -733.6006387969079 -51.27829018905129 699.34187676298632 -724.7781000066966 -53.931000410698893 699.25111686062405 -712.21972165233808 -43.705855352529632 699.60902244222746 -710.36902287894668 -48.624705924886939 698.73695912298342 -701.86524653027504 -36.194664286313724 700.21426599349888 -696.86778374186906 -37.601132385508109 698.33478098979731 -698.26147769655563 -32.590922115906082 700.21450803510641 -685.84367252733011 -24.096153016193707 698.7366019304128 -690.75483268591188 -22.239158573912945 699.60932225668 -680.53616119552635 -9.6841521117173013 699.25095840104211 -683.18702909091496 -0.86052045381348541 699.34192918607812 -681.24159972212533 17.044133942566518 699.33068282510555 -699.33154321335007 35.134077435171243 699.33068282479189
+-769.74455707291338 -35.278936425127611 699.05669076984009 -751.57764456926839 -53.445848928812495 699.05669076984543 -733.58800524594517 -51.507309540517554 699.07421889144939 -724.80403830388764 -54.031059785954326 698.92495706059469 -711.85482626889484 -44.314646838849484 699.51661050576524 -710.974752887367 -47.871196559298888 698.05962822050094 -700.47249637593234 -37.806140209333847 700.55959407938576 -698.30980958205646 -36.15789779441188 697.34981772796209 -696.64967151758901 -33.9832875941525 700.55983144041534 -686.59618982747304 -23.489494808739835 698.05926656031056 -690.14541112783218 -22.603349355397292 699.51692196667125 -680.43534117162801 -9.6574733369664543 698.92479115647814 -682.9572867139542 -0.87239859672634767 699.07427302503515 -681.02232392126757 17.11457612650803 699.05669076985578 -699.18668422228734 35.278936431801618 699.05669076945117
+-769.85020480798403 -35.384584160212938 698.75183572557467 -751.62901156659279 -53.605777401592263 698.75183572557978 -733.59151509093192 -51.648165340601508 698.77311069626114 -724.72228051481466 -54.29181695102352 698.59785871540771 -712.02272635486997 -44.09095510148029 699.29007038478971 -710.27820285412031 -48.826939351494673 697.59752246767698 -701.49605244622728 -36.645743733838508 700.47708529806198 -696.78526402464365 -37.683586688839654 696.80231203554604 -697.81028523049406 -32.960060379962428 700.47729988874278 -685.64143995371205 -24.186865628311214 697.59718006125854 -690.3696163776234 -22.436096679033216 699.2903768176717 -680.17532544391474 -9.739880712826201 698.5976920541724 -682.81709899167527 -0.86956966559213889 698.77316528740937 -680.86240304910837 17.165950729231305 698.75183572511776 -699.0810364970813 35.384584180232956 698.75183572447349
+-769.91358654225019 -35.447965894493784 698.42874519727957 -751.65982830334735 -53.701724133406323 698.42874519728468 -733.58371308752669 -51.754718169447948 698.4555782679995 -724.75226828700943 -54.289803574328559 698.22998568347089 -711.78177932701226 -44.516023500959541 699.12298371889506 -710.75886783182136 -48.157587485546351 696.92987177813154 -700.49324074591675 -37.845601436054686 700.68079032685557 -697.93213628164619 -36.535913849548479 695.87596647628186 -696.61023844755903 -33.962499357851883 700.68099839416709 -686.31003939972709 -23.705680856829019 696.92952808554014 -689.9441583357218 -22.676474648529762 699.12329894785796 -680.17678771744818 -9.7094181070838879 698.22981292191423 -682.71004813362038 -0.87684081324848451 698.45563429291769 -680.76646088617292 17.196772036047829 698.42874519527118 -699.01765481836185 35.447965926200972 698.42874519430211
+-769.9339037859545 -35.468283138212726 698.10032640057477 -751.66970673766514 -53.732480186501341 698.10032640058012 -733.58567018765734 -51.780919309234946 698.13030702241008 -724.72628173243243 -54.345930844636911 697.87996987008046 -711.85674744348239 -44.446839995892205 698.8698431357202 -710.5154632865125 -48.421824530149493 696.44405100804443 -700.87747806816583 -37.459361647980934 700.58219651022353 -697.42451897995556 -37.044828985910542 695.29124994739084 -696.99554106162157 -33.577659891202984 700.58211101299219 -686.04688583724271 -23.949693888543177 696.444098815443 -690.01302050927688 -22.601566993568294 698.8698611517068 -680.12107806531537 -9.7356201973049554 697.8799457536054 -682.68398494662426 -0.87508447161764114 698.13031350790459 -680.73570634086298 17.206651942973458 698.10032639372514 -698.99733778909194 35.46828312672671 698.10032638890868
+8 0 0 3 3 -1867.4022216796873 86.197022651859044 610.1935944517669 -1697.3680826822915 117.2130856308453 574.61595464338416 -1527.3339436848958 148.22914860983153 539.03831483500153 -1357.2998046875 179.24521158881782 503.46067502661867
+-1867.4022216796875 86.739101959008309 601.62708192608784 -1697.3680826822917 118.30424986313399 563.2309267096407 -1527.333943684896 149.86939776725964 524.83477149319378 -1357.2998046874998 181.43454567138528 486.43861627674681
+-1867.4022216796875 87.157245955540873 593.05615763635262 -1697.368082682292 119.12602170793642 551.80978589652887 -1527.333943684896 151.09479746033202 510.56341415670516 -1357.2998046875 183.06357321272759 469.31704241688135
+-1867.4022216796877 87.459081406549089 584.49059026755504 -1697.368082682292 119.70386474312131 540.38514703720455 -1527.3339436848953 151.94864807969353 496.27970380685406 -1357.2998046875 184.19343141626578 452.17426057650368
+8 0 0 6 5 -1357.2998046875 179.24521158881782 503.46067502661867 -1284.5811940917115 192.04166980531761 491.88542698813899 -1211.8625834959232 204.69122568301225 480.95083841966493 -1127.0149440528292 147.70409378684926 458.61133304318759 -1057.9677225174657 176.04230709942885 472.57017187666241 -986.57813877543083 197.69118105707622 477.10731046014951
+-1357.2998046875 180.33987863010157 494.94964565168277 -1284.7166402509279 193.28441239490337 482.68718867257587 -1212.1334758143557 206.09929623002472 471.04611985073711 -1126.6933724506998 147.12468698620216 451.21442587478947 -1057.9732626762013 175.57186968789449 464.2361712239005 -986.57835623231938 197.28641548956071 468.3762077771483
+-1357.2998046875 181.32248436314026 486.41871325474813 -1284.8589361756433 194.39795205361827 473.46019882502179 -1212.4180676637864 207.36009725841237 461.10169448463353 -1126.3327107490909 146.33425926498845 443.71741781498019 -1057.9744278614219 174.88162875192182 455.81679351176331 -986.57862620998037 196.65724926930014 459.60847290950136
+-1357.2998046875 182.196085648105 477.87179319228881 -1285.0081260070972 195.38539570099013 464.20988909099145 -1212.7164473266939 208.47666063112612 451.1246675144655 -1125.9377100117827 145.35684355294188 436.17906786620591 -1057.9720581187962 173.9982616008275 447.36959010110053 -986.57894026977351 195.83342595852471 450.85285763130963
+-1357.2998046875 182.9637393451668 469.31280082077893 -1285.1642188652052 196.2499703642037 454.94160305364414 -1213.0286330429099 209.45229530995425 441.12196624450917 -1125.5149706950106 144.21997031613699 428.65319341191866 -1057.9669503900309 172.95043008133845 438.95035027299616 -986.57928829079856 194.84448732388654 442.15836044038025
+-1357.2998046875 183.62850231449673 460.74565149669252 -1285.3271907820972 196.99499674014572 445.6605932168161 -1213.3545768766937 210.29052643704208 431.10033215412273 -1125.0727120142205 142.95170831933618 421.1864810717862 -1057.9598074646754 171.76662833829781 430.61089457909026 -986.57965937916845 193.71873331934876 433.57148267718316
+-1357.2998046875 184.19343141626581 452.17426057650368 -1285.4969866356553 197.62386275744993 436.3720179880529 -1213.6941685838099 210.99503441641147 421.06631296166324 -1124.6200834825863 141.57753137538 413.81750790987098 -1057.9511869319285 170.47303057537067 422.39686819190024 -986.58004277728298 192.48218206907464 425.13348464380789
+8 0 0 1 1 -733.57904040895403 -69.433363416319153 699.92601491509993 -665.04225127011387 -1.4494316452920231 699.92601491511311
+-803.89147790140703 1.4508672646702223 699.92601491505616 -735.35468876256698 69.434799035697353 699.92601491506946
+8 0 0 8 11 -439.01302916064793 -374.19863857327982 571.49855790492745 -444.15928475616067 -372.31994216072962 569.88201383510091 -448.69710163844599 -370.2128429003763 566.5932152269587 -452.06083287685004 -368.08338083607828 561.80795872129568 -453.77140921456254 -366.16908066949139 555.9357936410272 -453.53022316917253 -364.70174804053613 549.57840892119862 -451.30117165551383 -363.86554080178757 543.45432072361325 -447.34018580781628 -363.75614392720769 538.26532866671448 -442.14410919268028 -364.3629691560472 534.56176123646333 -436.34471144907133 -365.57889334253468 532.65601646482969 -430.58973729210845 -367.22920584556437 532.60004933387677 -425.44350576948045 -369.10789570302541 534.21659498635415
+-439.27862910467894 -375.11730691068658 571.27644597004155 -444.4248838028995 -373.23861082721908 569.6599021883452 -448.96275018060277 -371.13149355471626 566.37108822796597 -452.32638227762891 -369.00206757559243 561.58586250115525 -454.03698834426524 -367.08775659234226 555.71368820701684 -453.79584178160502 -365.62040959377146 549.35629123449098 -451.56679144309675 -364.78420192619734 543.232202667911 -447.60578999781217 -364.67481072728702 538.04321544738036 -442.40970284696533 -365.2816397893709 534.33965128169916 -436.61030396663796 -366.49756438774682 532.43390685519705 -430.85533346783183 -368.14787555699564 532.37793857898362 -425.70910567633211 -370.02656405390775 533.9944830627453
+-439.46949346902534 -376.00793745057979 570.8489997174338 -444.55906032006607 -374.14993588130147 569.25026275357732 -449.0469836425014 -372.06601346750472 565.99766251165568 -452.37348010075681 -369.96007424766486 561.26517297912778 -454.06526887646299 -368.06684060886357 555.4576742325728 -453.82681235362759 -366.61564455714409 549.1702952471444 -451.62231642560835 -365.7886475867582 543.11366467763787 -447.70493275325884 -365.6804662290827 537.98183928381025 -442.56607240531133 -366.28061421398388 534.31907321077051 -436.83055402607084 -367.48314548269008 532.43432103559451 -431.13897881933315 -369.11527697241803 532.37896816659827 -426.04944100675954 -370.97327015414186 533.9777050696274
+-439.57001888237806 -376.81656059130614 570.22926770027641 -444.546210989065 -374.99994770199078 568.6661440670423 -448.93419579780732 -372.96243407592692 565.4859875161809 -452.18652594422173 -370.90343016956183 560.85893778518118 -453.84064866263947 -369.05236267177497 555.18079988895613 -453.60753041720648 -367.63348372755485 549.03346985023711 -451.45214206597757 -366.82490860556351 543.11175566554959 -447.62201045340674 -366.71914092125587 538.09424880463462 -442.59761486591691 -367.30592269335312 534.51307546052203 -436.98985869234809 -368.48166686663404 532.67030742259112 -431.4250701966825 -370.07744040945761 532.61618658057102 -426.44890839163781 -371.89404440128283 534.17930955950999
+-439.57074845784069 -377.49151593262053 569.44718197940301 -444.38154027678723 -375.73528421125945 567.93601396269707 -448.62369903439162 -373.76548559304308 564.86155290356157 -451.76788348734817 -371.77493511327663 560.38831086908249 -453.36703940396342 -369.98538913384658 554.89890071549428 -453.14168740196556 -368.61366504697679 548.95589279878493 -451.05794074119262 -367.83196552974135 543.23100638640392 -447.35510847087198 -367.72971600040995 538.38027452855624 -442.49770966141108 -368.29699589120889 534.91813384725299 -437.07634455308892 -369.43366053069536 533.13661567250688 -431.69652135326356 -370.97639272152708 533.08429284611509 -426.8857601218254 -372.73261536816671 534.59545982653412
+-439.47029786059323 -377.99008506615968 568.54798132524513 -444.07299367277977 -376.3098210472175 567.10218052210348 -448.13166427720654 -374.42522411247978 564.16070481256872 -451.13982438669188 -372.52078370200411 559.88096230342614 -452.66981314754901 -370.80864439677555 554.62900116769947 -452.45421708082648 -369.49625310127726 548.9430633063389 -450.46060508823575 -368.74836696114892 543.46581348936422 -446.91793888148351 -368.65054158930661 538.82490571617052 -442.27064904701842 -369.19328396366222 535.512523277892 -437.08379001176183 -370.28078100843669 533.80806573771986 -431.93667724065472 -371.75678037999035 533.75800549980022 -427.33401129407764 -373.4370354948976 535.20380512213978
+-439.27601753155216 -378.28477681560236 567.58701491475199 -443.64093731793349 -376.69131551122211 566.21590442456045 -447.48993443140307 -374.90407778516811 563.42638607556398 -450.34269901294709 -373.09801833722685 559.36773230140795 -451.793646555968 -371.47432929208861 554.38708978627642 -451.58918607420696 -370.22973759817677 548.99489099915991 -449.6985641126625 -369.52048769305429 543.80059776512712 -446.33891278086048 -369.42771578789382 539.39943938858733 -441.93170246805215 -369.94241976498887 536.25817391351279 -437.01279694492979 -370.97373642305917 534.64176789782562 -432.13158449744151 -372.37348541552871 534.59429329933835 -427.76669290354874 -373.96693831965655 535.96540270718845
+-439.00257098544307 -378.36597959380742 566.62213390744125 -443.11487433864227 -376.86473865511749 565.33037540410521 -446.74109883528712 -375.18094129502344 562.70230260917879 -449.42879400385078 -373.47939408422798 558.87852890869976 -450.79575951963687 -371.94967859408479 554.18614151264444 -450.60311967715609 -370.7771217962345 549.10601842311723 -448.82191550491399 -370.10891968948965 544.21234241370985 -445.65670573780591 -370.02151522720044 540.06589601357518 -441.50456201102122 -370.50642984140529 537.10642683011679 -436.87033442872701 -371.47805954701499 535.58356792964003 -432.27161737486506 -372.79679937992961 535.53884064064152 -428.15933972131546 -374.29803271394633 536.83059838851159
+-438.66952395130266 -378.24103367905883 565.70709470200813 -442.52921107272931 -376.83201303219215 564.4946881208532 -445.93265184585442 -375.25166007995136 562.02806432499392 -448.45529984874855 -373.6546170087837 558.43916379138 -449.7382766661641 -372.21887750086762 554.03503358192279 -449.55744860305703 -371.11835882359668 549.2669889394125 -447.88566195638924 -370.49120461144832 544.67393023736406 -444.91489725402107 -370.40916631841191 540.78219472829801 -441.01782247740977 -370.86429070955529 538.0045211038464 -436.66827309095777 -371.77623337029047 536.57520924111134 -432.35205060976926 -373.01396434296839 536.53322951859695 -428.49238605924194 -374.42297841220147 537.74563586876423
+8 0 0 11 3 -439.01302916133568 -374.19863857565844 571.49855790435254 -427.80694042137645 -335.43854412239892 580.86981763264873 -416.60085168141728 -296.67844966913935 590.24107736094516 -405.39476294145805 -257.91835521587984 599.61233708924135
+-444.1592816361495 -372.31994110254982 569.882005804095 -432.95319636590466 -333.55984538263164 579.25326444247696 -421.74711109565982 -294.79974966271334 588.62452308085915 -410.54102582541492 -256.03965394279516 597.99578171924111
+-448.696851095309 -370.21293428417113 566.59329348957806 -437.49076134417857 -331.45284023376865 575.96455367496594 -426.28470141791809 -292.69273334629821 585.33579642984523 -415.07861166674257 -253.93263929591581 594.70705661526256
+-452.06106972133836 -368.0832963462563 561.80789254444005 -440.8549726258517 -329.32320485548877 571.17915453430157 -429.64893554128611 -290.56308397257146 580.55036671711366 -418.44283844569577 -251.80299248185045 589.92162870704396
+-453.77149645845697 -366.16905804116817 555.93580433993031 -442.56539249776097 -327.40896868120927 565.30706693357422 -431.35936131467082 -288.6488367057774 574.67824029402391 -420.15325735382009 -249.8887473458885 584.04950288777263
+-453.53013849062938 -364.70179605081285 549.57850618933719 -442.32403002395745 -325.94170768219368 558.94976749500654 -431.11797383501602 -287.18157616136995 568.32091283391583 -419.91186536815866 -248.42148779283559 577.69217413971455
+-451.30110977141209 -363.86558455692807 543.45442770029001 -440.09499985753479 -325.10549581903342 552.82568574805521 -428.88889939932807 -286.34537777124382 562.19683387535702 -417.68278948526046 -247.58528903343756 571.56809192326057
+-447.34021846764443 -363.7561516287588 538.2653995993353 -436.13410996630114 -324.99606131051672 547.6366527997867 -424.92796977988382 -286.23596329769003 557.00783628617569 -413.72186127837119 -247.47587297952865 566.37908948675852
+-442.1441977512153 -364.36295047723263 534.56178988535237 -430.9380927065273 -325.60285776899747 543.93303733409266 -419.73193400767906 -286.84277776393384 553.30427316463386 -408.52582896286424 -248.08268505576206 562.67552061348488
+-436.34479918871642 -365.57886755715049 532.6560147193029 -425.13869849458121 -326.81877218377889 542.02725634723936 -413.93254492979645 -288.05870248965817 551.39854096373881 -402.72644423559143 -249.29860711632611 560.7697825917553
+-430.58979474118286 -367.22918532891072 532.60003314993116 -419.38369808864957 -328.4690875640315 541.97126971936734 -408.17756521357848 -289.7090192681132 551.34258485953478 -396.97146856103853 -250.94892150324659 560.7138214290153
+-425.44353144330631 -369.10788440174952 534.21657892462144 -414.23743754993257 -330.34778496322633 543.58781187114903 -403.03132958270038 -291.58771125854003 552.95913442495043 -391.8252356893812 -252.82761182000309 562.33036737148632
+8 0 0 8 11 -425.44350576948045 -369.10789570302541 534.2165949863537 -420.29727424685245 -370.98658556048645 535.83314063883108 -415.75978535855927 -373.0936527723789 539.12219907473889 -412.39535815228965 -375.22308637659194 543.90650543682671 -410.68488600830193 -377.13757509000988 549.77957502853042 -410.92643589584014 -378.60479448284167 556.13692652456507 -413.1553978821774 -379.44103393759258 562.26104098802637 -417.11669978312023 -379.55029413732143 567.44984577491471 -422.31221679586673 -378.9434462382597 571.15265002993317 -428.11162295865273 -377.72780833913902 573.05958835191768 -433.866865332229 -376.07730391671782 573.11508373443075 -439.01302916133585 -374.19863857565832 571.49855790435265
+-425.70910567633211 -370.02656405390775 533.99448306274485 -420.5628778848324 -371.90525255081991 535.61102754650653 -416.02539280063911 -374.01231837539547 538.90008479024345 -412.66096474953741 -376.1417522844248 543.68439140364194 -410.95048227209571 -378.05624475690826 549.55746419496495 -411.19201620352885 -379.52346995698258 555.91482064284776 -413.42097827337136 -380.35970938345997 562.03893508863962 -417.38231902744462 -380.46895544457936 567.22772782541517 -422.57786788596343 -379.8620959521532 570.93052218539435 -428.37717775618779 -378.64649309294839 572.83749036957602 -434.13246287224348 -376.9959731361223 572.8929725728326 -439.27862910519747 -375.11730691300158 571.27644596900154
+-426.04944100675954 -370.97327015414186 533.97770506962695 -420.95990319418593 -372.83126333586574 535.57644197265597 -416.47240277577635 -374.91511820958567 538.82926864771059 -413.14503397319197 -377.02109624627565 543.56087556063619 -411.45338402595917 -378.91450345066795 549.36925823480749 -411.69224364984342 -380.36557189902175 555.65659147741678 -413.89665296967871 -381.19260003003774 561.71324743277603 -417.81439158488297 -381.30063067030761 566.84487393698669 -422.95273779520733 -380.70044583683949 570.50687253624392 -428.68808560906353 -379.49826280031073 572.39286063159466 -434.38001077269968 -377.86591071883942 572.44772076382867 -439.46949346934417 -376.00793745272648 570.84899971595394
+-426.44890839163781 -371.89404440128283 534.17930955950953 -421.47274658659308 -373.7106483931081 535.74243253844838 -417.08521147216914 -375.7480828339352 538.92279933834652 -413.83196206108346 -377.80714880322296 543.54900658425163 -412.17798811478843 -379.6583814915312 549.22800563653038 -412.4115160170636 -381.07713028803954 555.37528722583488 -414.56681974847351 -381.88573585806728 561.2970262190363 -418.39731295027934 -381.99135062585759 566.31433301614572 -423.42122014757842 -381.4045273847529 569.8947505703087 -429.02874579822117 -380.22914689514778 571.73874687146667 -434.59390580351885 -378.63314701140052 571.79237681516236 -439.57001888247686 -376.81656059318345 570.22926769840933
+-426.8857601218254 -372.73261536816671 534.59545982653367 -422.07499889038723 -374.48883801480639 536.10662680695259 -417.8332996273362 -376.4585511172541 539.18128359418245 -414.68818239256257 -378.44917757997246 543.65372464667882 -413.08917909848844 -380.23888040922975 549.14396603955618 -413.31493739552002 -381.6104753408033 555.08692556945903 -415.39860164574225 -382.39220451762111 560.81183616052306 -419.1017924245823 -382.49430257187782 565.66237020492258 -423.95872869827031 -381.92697873493029 569.12377578455369 -429.37982934191376 -380.79068084321369 570.90649445545353 -434.76003000097955 -379.24772319175395 570.95833693574468 -439.57074845771149 -377.49151593413973 569.44718197722659
+-427.33401129407764 -373.4370354948976 535.20380512213933 -422.73134534750056 -375.11729060980497 536.64960474447867 -418.67312622545342 -377.00180146806599 539.59126422707743 -415.66405448831659 -378.90632148625514 543.87024612794119 -414.13421579190941 -380.61860984116146 549.12300315893629 -414.35020494490868 -381.93087649786241 554.80889549869153 -416.34373682613591 -382.67879148004511 560.28616884950884 -419.88674878976468 -382.77647042029992 564.92688439370181 -424.5336004837082 -382.23368394492752 568.23856028958721 -429.72018953560803 -381.14654397248927 569.94417186222222 -434.86766954218058 -379.67032668572904 569.99377049726786 -439.47029786024183 -377.99008506725249 568.54798132285714
+-427.76669290354874 -373.96693831965655 535.96540270718799 -423.40180130965598 -375.56039122378456 537.33651211503798 -419.55323056935867 -377.34754803957082 540.12620552922556 -416.69960846061787 -379.15368034427456 544.18413553888729 -415.24880225340746 -380.77751163899035 549.16553536448475 -415.45363368646963 -382.02198641777829 554.55769408923572 -417.34417778700953 -382.73126436764943 559.75201023603961 -420.70415334416714 -382.82389813728383 564.15298492383158 -425.1109470123551 -382.30915220507097 567.29357847385529 -430.02960541006917 -381.27817095204188 568.91107638926462 -434.91115952183731 -379.87821771516963 568.95811508920337 -439.27601753099759 -378.28477681622707 567.58701491226157
+-428.15933972131546 -374.29803271394633 536.83059838851113 -424.04706206776586 -375.79926604796321 538.12235613638109 -420.42122381452845 -377.48299288308203 540.75059892111972 -417.73275383348283 -379.1845965931002 544.57368016811608 -416.36591548444625 -380.71444888971206 549.26678539965258 -416.55889682333463 -381.88689913941676 554.34687606960324 -418.34002520768718 -382.55512855921802 559.24057442954449 -421.50553045480001 -382.64240583597461 563.38684803504691 -425.65727499562485 -382.15745350522519 566.3456837450185 -430.29130432934176 -381.18612723658754 567.86956090984177 -434.89032416825989 -379.86720194104339 567.91388322460068 -439.00257098471531 -378.36597959395084 566.62213390495936
+-428.49238605924194 -374.42297841220147 537.74563586876377 -424.63272150871461 -375.83199248143472 538.95804221893093 -421.22961488884829 -377.41228964722291 541.42483464177997 -418.70629722504009 -379.00936469417871 545.01306706977061 -417.42342905297971 -380.4452371491758 549.4178769893191 -417.60456387823865 -381.54566156667147 554.18589849334853 -419.2762765276903 -382.17284246275676 558.77897907046076 -422.24730274618065 -382.25476641933329 562.67055429777065 -426.14399101352598 -381.79961029158545 565.44763438817324 -430.49341289131098 -380.88793114438693 566.87788410137046 -434.80988886605354 -379.65003727606467 566.91949298836846 -438.66952395043973 -378.24103367873516 565.70709469963924
+8 0 0 11 3 -438.66952395216515 -378.24103367938221 565.70709470437737 -436.97332933745372 -377.60468936372877 561.04683830145723 -435.27713472274229 -376.96834504807532 556.3865818985372 -433.58094010803086 -376.33200073242188 551.72632549561706
+-442.52920871402176 -376.83201224175713 564.49468203107631 -439.54645664123569 -376.6653402312304 560.23856188884645 -436.56370043923874 -376.49866972811861 555.98244304369337 -433.58094010803086 -376.33200073242188 551.72632549561706
+-445.93239732062597 -375.25175375363187 562.0281476049646 -441.81524929566524 -375.61183374280682 558.59420247217338 -437.69809689146996 -375.97191606906972 555.16026176905905 -433.58094010803086 -376.33200073242188 551.72632549561706
+-448.45557746118982 -373.65451666784861 558.43908052942652 -443.49736603889824 -374.54700968016766 556.20148981683496 -438.53915358783337 -375.439504368359 553.96390480555215 -433.58094010803086 -376.33200073242188 551.72632549561706
+-449.73840519655278 -372.21882687891201 554.0349778174309 -444.35258002877174 -373.58988513190599 553.2654241405312 -438.9667583325969 -374.96094308307926 552.49587336660613 -433.58094010803086 -376.33200073242188 551.72632549561706
+-449.55736619372146 -371.11837520672873 549.26695823610635 -444.23188573223348 -372.85625301032286 550.0867520956217 -438.90641037035658 -374.59412818555001 550.90654118213297 -433.58094010803086 -376.33200073242188 551.72632549561706
+-447.88554575690881 -370.49122309110822 544.67386780235745 -443.11734331934787 -372.43815259896445 547.02470137347609 -438.34914143639588 -374.3850784793957 549.37552060454391 -433.58094010803086 -376.33200073242188 551.72632549561706
+-444.91481758705334 -370.40916544917832 540.78209588450204 -441.13686856462175 -372.38344602051791 544.43019340961098 -437.35890940491259 -374.35772444827177 548.0782699466323 -433.58094010803086 -376.33200073242188 551.72632549561706
+-441.01775225790198 -370.86428624930159 538.00441866092979 -438.5388387005429 -372.6868559608003 542.57840872263557 -436.05990131718437 -374.5094274552016 547.15237766756513 -433.58094010803086 -376.33200073242188 551.72632549561706
+-436.66817641195468 -371.77624377157548 536.57513662217389 -435.63913386464998 -373.2948223146501 541.62554681612789 -434.61005509661607 -374.81340796831046 546.67594310739048 -433.58094010803086 -376.33200073242188 551.72632549561706
+-432.35192153979028 -373.01399551228332 536.53320408016498 -432.76163826237905 -374.11998483387833 541.59757897712723 -433.17131111845686 -375.22598657397134 546.66195278246892 -433.58094010803086 -376.33200073242188 551.72632549561706
+-428.49224274817482 -374.42302552956238 537.74565937860518 -430.18852038062681 -375.05933410305397 542.40586722184275 -431.88475283399788 -375.69565917070571 547.06608926108129 -433.58094010803086 -376.33200073242188 551.72632549561706
+8 0 0 11 3 -425.44353144330626 -369.10788440174957 534.21657892462156 -414.23743754993262 -330.34778496322639 543.58781187114903 -403.03132958270032 -291.58771125854014 552.95913442495078 -391.82523568938126 -252.82761182000314 562.33036737148643
+-420.29726814542971 -370.98658347458837 535.83312469931184 -409.09117701121562 -332.22648236242122 545.20435402293072 -397.88509395182223 -293.46640324896697 554.57568399036643 -386.67900281772393 -254.70630213675963 563.94691331395745
+-415.75974599721019 -373.09366384850574 539.12219781806425 -404.55365633971326 -334.33356178055834 548.49342495436611 -393.34760240628401 -295.57347045136567 557.86473922540176 -382.1415127489621 -256.81336838335216 567.23596636163938
+-412.39531203333939 -375.22310613273783 543.90653202826331 -401.18922159662583 -336.46300427110879 553.27775908612773 -389.98318966976097 -297.70289602497729 562.64902970298533 -378.77709923327143 -258.94279416326026 572.0202567607538
+-410.68488836216585 -377.13758908535851 549.7796357759338 -399.47879414616705 -338.37748893184431 559.15086537942011 -388.27276252226119 -299.61736449503388 568.52206939293023 -377.06666830651727 -260.85726434141736 577.89329899629809
+-410.92652684490821 -378.60479175651955 556.13702401659896 -399.72042561675897 -339.84469492927082 565.50825899263737 -388.51436203619858 -301.08456264518219 574.87939233578106 -377.30826080831065 -262.32446581782705 584.2506273116918
+-413.15551645434209 -379.4410350132066 562.26118711129686 -401.94940554169989 -340.68094290457759 571.6324300231795 -390.74328204436631 -301.92081712522122 581.00351862221692 -379.53717113196404 -263.16072501649353 590.37476153397824
+-417.11668738234607 -379.5503471674927 567.45005005696305 -405.91056574869162 -340.79026048308418 576.82130258363475 -394.70438062490553 -302.03015434788199 586.19239873958441 -383.49825899144315 -263.270067663394 595.56365126615685
+-422.31215402287955 -378.94350534073442 571.15281944998094 -411.10602362479875 -340.18342351963003 580.5240816111301 -399.89981350057553 -301.42333878550443 589.89523638786932 -388.69368310261956 -262.66325696434808 599.26649854895277
+-428.112108308948 -377.72764218707817 573.05948218876563 -416.90597573539492 -338.96756270327376 582.4307514157141 -405.69979506684467 -300.20748650352306 591.80197671403425 -394.49366249334457 -261.44740701969653 601.17324594095442
+-433.86686487687814 -376.07730385388425 573.11508230206312 -422.66074327041946 -337.31722139891099 582.48635235445624 -411.45462166396095 -298.5571389439379 591.85762240684926 -400.24850005750238 -259.79705648896464 601.22889245924227
+-439.01302916133773 -374.19863857565855 571.49855790435311 -427.80694042137839 -335.43854412239892 580.86981763264953 -416.60085168141921 -296.67844966913952 590.24107736094584 -405.39476294145999 -257.9183552158799 599.61233708924215
+8 0 0 14 1 -388.43285051863887 -251.55492471135057 553.00986571677913 -391.82522850662997 -252.82760912532234 562.33034763703949
+-394.49805619676209 -249.34075301317847 551.10465002333069 -395.86869895871212 -251.35149465987428 561.0602038414072
+-401.11515240854925 -247.33362854939449 550.71574110913468 -400.28009643323691 -250.01341168401828 560.8009312319432
+-407.900420424478 -245.67363216738548 551.96367354204483 -404.80360844385609 -248.90674742934561 561.63288618721663
+-414.4288775385694 -244.48536412249319 554.85561004636349 -409.15591318658369 -248.11456873275077 563.5608438567624
+-420.26870165149717 -243.86537699592569 559.27452797738852 -413.04912926186887 -247.70124398170577 566.50678914411242
+-425.02018041987117 -243.87130604876509 564.98083693935632 -416.2167817741182 -247.7051966835987 570.31099511875766
+-428.35447023717677 -244.51441817905132 571.62790854951697 -418.43964165232194 -248.13393810378952 574.74237619219809
+-430.04665358405862 -245.75700174854794 578.7908103594533 -419.5677638835765 -248.96232715012061 579.51764406548898
+-429.99788727857708 -247.51531881491405 586.00500119233027 -419.53525301325544 -250.13453852769806 584.32710462074033
+-428.24309928088746 -249.66783643907485 592.80958011252699 -418.36539434812897 -251.5695502771386 588.86349056753818
+-424.94345924749683 -252.06743194419062 598.78876445149263 -416.1656343258685 -253.16928061388248 592.8496134601819
+-420.36573545775326 -254.55562820925465 603.60608299202238 -413.11381846603939 -254.8280781239252 596.0611591538684
+-414.85239056983011 -256.9768602039083 607.02762392329635 -409.43825520742394 -256.44223278702771 598.34218644138446
+-408.78715217088074 -259.19104384718673 608.93284989508243 -405.39476294145777 -257.91835521588001 599.61233708924192
+8 0 0 11 3 -428.49224274817487 -374.42302552956227 537.74565937860541 -430.18852038062693 -375.05933410305391 542.40586722184275 -431.88475283399794 -375.69565917070571 547.06608926108129 -433.58094010803097 -376.33200073242176 551.72632549561706
+-424.63256395655941 -375.83205554684133 538.95811467704561 -427.61540249887469 -375.99868337222955 543.21415546655828 -430.59819454953896 -376.16533176744008 547.47022573969366 -433.58094010803097 -376.33200073242176 551.72632549561706
+-421.22946124549281 -377.41236384069163 541.42495781593504 -425.34666233764119 -377.05221939135265 544.85869979499 -429.46382195878027 -376.69209835524794 548.29248902184008 -433.58094010803097 -376.33200073242176 551.72632549561706
+-418.70618972174105 -379.00943446925044 545.01322713897571 -423.66446838382308 -378.1169327449922 547.2508622233471 -428.62271851301301 -377.22445483265074 549.48856167580141 -433.58094010803097 -376.33200073242176 551.72632549561706
+-417.42342810825704 -380.44527805250925 549.41804502164109 -422.80927340577773 -379.0741648504752 550.18739549700888 -428.1951107395704 -377.70307241031833 550.95682232177899 -433.58094010803097 -376.33200073242176 551.72632549561706
+-417.60469751228891 -381.54565911798187 554.18604808154976 -422.93009466688642 -379.80775893367195 553.36606203623307 -428.25550886602531 -378.06987280496958 552.54615450750259 -433.58094010803103 -376.33200073242176 551.72632549561695
+-419.27645018227031 -382.17282588759042 558.77911808995862 -424.04457318983413 -380.22587933261582 556.42811902908136 -428.8127364988685 -378.27893761402771 554.0771881640153 -433.58094010803109 -376.33200073242176 551.72632549561683
+-422.24730865889416 -382.25480530303599 562.67072227831352 -426.02513140654622 -380.28054145473135 559.02254292216071 -429.80300855647835 -378.30627326437269 555.37441066088866 -433.58094010803114 -376.33200073242176 551.72632549561672
+-426.14387726765358 -381.79967892682112 565.4477824639639 -428.62284374141689 -379.97712995906301 560.87394147669568 -431.10186468821581 -378.15457056086052 556.30012248696755 -433.5809401080312 -376.33200073242176 551.72632549561649
+-430.49382312367737 -380.88778804860965 566.87778260211167 -431.52282061992713 -379.36920381178294 561.82729498671085 -432.55185961468004 -377.85060803970413 556.77680928444124 -433.58094010803131 -376.33200073242176 551.72632549561615
+-434.80988856155301 -379.6500371535742 566.91949211763631 -434.40021851825185 -378.54403251840955 561.85510970160306 -433.99056903374463 -377.43802037802521 556.79072082759603 -433.58094010803143 -376.3320007324217 551.7263254956157
+-438.66952395044086 -378.24103367873494 565.70709469963811 -436.9733293363044 -377.60468936329721 561.0468382982973 -435.27713472216794 -376.96834504785926 556.38658189695616 -433.58094010803154 -376.33200073242165 551.72632549561501
+8 0 0 14 1 -408.78715217088092 -259.1910438471869 608.9328498950822 -405.394762941458 -257.9183552158799 599.61233708924169
+-402.72191377193167 -261.40522749046539 610.83807586686817 -401.35127067549183 -259.39447764473221 600.88248773709904
+-396.10478186195627 -263.41236278236863 611.22698687916625 -396.9398494021749 -260.73256783933437 601.1417617452978
+-389.31948402810804 -265.07236564193175 609.97904558174434 -392.41631751294273 -261.83923641237647 600.30980088034983
+-382.79101278652035 -266.26063293758364 607.08708908495817 -388.06400335188425 -262.6314146094777 598.38182988249241
+-376.95119613246123 -266.88061134589236 602.66814401395447 -384.17079224917813 -263.04473354835022 595.43586650182328
+-372.19974288465818 -266.87466853424132 596.96180866203895 -381.00315675064275 -263.0407716739162 591.63164293387956
+-368.86549878846881 -266.23153775014816 590.31471457161012 -378.78032735318317 -262.61201781785411 587.20024687359364
+-367.17336646597738 -264.98893751642078 583.15180485203166 -377.65223913818886 -261.78361766203585 582.424973727208
+-367.22217029449422 -263.2306111940872 575.9376206057068 -377.68477502386679 -260.61140011381343 577.61551756299139
+-368.97698194976277 -261.07809092877528 569.13305905112213 -378.85464946071249 -259.17638660360547 573.07914319326824
+-372.27662381478353 -258.67850066164442 563.15389856702848 -381.05441070405971 -257.57665975885158 569.09303620387243
+-376.85432969605648 -256.19031534208295 558.33660388292867 -384.10621462490832 -255.91786954581059 565.8815064144726
+-382.36764484051571 -253.76909640952275 554.91508141022769 -387.78175805454782 -254.30372359077043 563.60049143267202
+-388.43285051863893 -251.55492471135065 553.00986571677925 -391.82522850662997 -252.82760912532237 562.33034763703972
+8 0 0 14 1 -374.20263638495629 -202.33485723634891 564.91009564807428 -388.43285051863893 -251.55492471135057 553.00986571677913
+-380.26784206307951 -200.12068553817682 563.00487995462584 -394.49805619676215 -249.34075301317847 551.10465002333069
+-386.88493827486667 -198.11356107439283 562.61597104042983 -401.11515240854931 -247.33362854939449 550.71574110913468
+-393.67020629079542 -196.45356469238382 563.86390347333997 -407.90042042447806 -245.67363216738548 551.96367354204483
+-400.19866340488682 -195.26529664749154 566.75583997765864 -414.42887753856945 -244.48536412249319 554.85561004636349
+-406.03848751781459 -194.64530952092403 571.17475790868366 -420.26870165149722 -243.86537699592569 559.27452797738852
+-410.78996628618859 -194.65123857376344 576.88106687065147 -425.02018041987122 -243.87130604876509 564.98083693935632
+-414.12425610349419 -195.29435070404963 583.52813848081212 -428.35447023717683 -244.51441817905132 571.62790854951697
+-415.81643945037604 -196.53693427354625 590.69104029074845 -430.04665358405867 -245.75700174854794 578.7908103594533
+-415.7676731448945 -198.29525133991237 597.90523112362541 -429.99788727857714 -247.51531881491405 586.00500119233027
+-414.01288514720488 -200.44776896407313 604.70981004382213 -428.24309928088752 -249.66783643907485 592.80958011252699
+-410.71324511381425 -202.8473644691889 610.68899438278777 -424.94345924749689 -252.06743194419064 598.78876445149263
+-406.13552132407068 -205.33556073425294 615.50631292331752 -420.36573545775332 -254.55562820925468 603.60608299202238
+-400.62217643614753 -207.75679272890662 618.92785385459149 -414.85239056983016 -256.97686020390836 607.02762392329635
+-394.55693803719817 -209.97097637218508 620.83307982637757 -408.7871521708808 -259.19104384718685 608.93284989508243
+8 0 0 14 1 -394.55693803719839 -209.97097637218519 620.83307982637734 -408.78715217088103 -259.19104384718685 608.9328498950822
+-388.49169963824914 -212.18516001546365 622.73830579816331 -402.72191377193178 -261.40522749046534 610.83807586686817
+-381.87456772827375 -214.19229530736689 623.12721681046139 -396.10478186195638 -263.41236278236858 611.22698687916625
+-375.08926989442551 -215.85229816693004 621.87927551303949 -389.31948402810815 -265.0723656419317 609.97904558174434
+-368.56079865283783 -217.04056546258192 618.98731901625331 -382.79101278652047 -266.26063293758358 607.08708908495817
+-362.72098199877871 -217.66054387089068 614.56837394524962 -376.95119613246135 -266.88061134589231 602.66814401395447
+-357.96952875097566 -217.65460105923967 608.86203859333409 -372.19974288465829 -266.87466853424127 596.96180866203895
+-354.63528465478629 -217.01147027514654 602.21494450290527 -368.86549878846893 -266.23153775014811 590.31471457161012
+-352.94315233229486 -215.76887004141915 595.0520347833268 -367.17336646597749 -264.98893751642072 583.15180485203166
+-352.9919561608117 -214.01054371908555 587.83785053700194 -367.22217029449433 -263.23061119408715 575.9376206057068
+-354.74676781608025 -211.8580234537736 581.03328898241728 -368.97698194976289 -261.07809092877523 569.13305905112213
+-358.04640968110101 -209.45843318664274 575.05412849832362 -372.27662381478365 -258.67850066164436 563.15389856702848
+-362.62411556237396 -206.97024786708124 570.23683381422381 -376.8543296960566 -256.1903153420829 558.33660388292867
+-368.13743070683319 -204.54902893452103 566.81531134152283 -382.36764484051582 -253.76909640952269 554.91508141022769
+-374.20263638495641 -202.33485723634894 564.91009564807439 -388.43285051863904 -251.55492471135059 553.00986571677925
+8 0 0 14 1 -374.20263638495641 -202.33485723634891 564.91009564807428 -379.1301750852636 -205.61691521356025 584.37720235859888
+-380.26784206307963 -200.12068553817682 563.00487995462584 -380.94103560755468 -204.83472398732533 583.30742706780245
+-386.88493827486678 -198.11356107439283 562.61597104042994 -383.03657371607449 -204.08159897106012 582.69828689571079
+-393.67020629079553 -196.45356469238382 563.86390347334009 -385.30222427720179 -203.40702594307197 582.6174617920642
+-400.19866340488693 -195.26529664749154 566.75583997765875 -387.6021372674698 -202.85831744742944 583.09819075222163
+-406.0384875178147 -194.64530952092403 571.17475790868377 -389.78945576278153 -202.47617327314407 584.13320004146851
+-410.7899662861887 -194.65123857376344 576.88106687065158 -391.71892780091838 -202.29047922696739 585.6724078458974
+-414.1242561034943 -195.29435070404963 583.52813848081223 -393.2604444607731 -202.31695222930276 587.6252369303154
+-415.81643945037615 -196.53693427354625 590.69104029074856 -394.31168553157124 -202.55519780177053 589.86770189523565
+-415.76767314489462 -198.29525133991237 597.90523112362553 -394.80797181229718 -202.98856210101084 592.2535784925193
+-414.01288514720494 -200.44776896407313 604.70981004382224 -394.72780371104 -203.58584850128298 594.62812653384117
+-410.71324511381425 -202.8473644691889 610.68899438278788 -394.09338873894671 -204.30460900140827 596.84233412165736
+-406.13552132407062 -205.33556073425294 615.50631292331775 -392.96644446961028 -205.09545026040902 598.76570887920184
+-400.62217643614736 -207.75679272890662 618.92785385459183 -391.44025330005712 -205.90671207326301 600.29612754503034
+-394.55693803719782 -209.97097637218508 620.83307982637791 -389.62938300849322 -206.68890751935442 601.36590860710339
+8 0 0 14 1 -394.55693803719839 -209.97097637218519 620.83307982637734 -389.62938300835083 -206.68890751911749 601.36590860707906
+-388.49169963824914 -212.18516001546365 622.73830579816331 -387.81851271675487 -207.47110296515197 602.43568966914427
+-381.87456772827375 -214.19229530736689 623.12721681046139 -385.72296330313998 -208.22423204440969 603.04483312745106
+-375.08926989442551 -215.85229816693004 621.87927551303949 -383.45730254570958 -208.89880783627078 603.12565746995858
+-368.56079865283783 -217.04056546258192 618.98731901625331 -381.15738360384574 -209.44751670452047 602.64492293403032
+-362.72098199877871 -217.66054387089068 614.56837394524962 -378.97006557585479 -209.8296584457994 601.60990414051685
+-357.96952875097566 -217.65460105923967 608.86203859333409 -377.04059985347112 -210.01534811075041 600.07068576737743
+-354.63528465478629 -217.01147027514654 602.21494450290527 -375.49909626827809 -209.98886873044287 598.11784593783182
+-352.94315233229486 -215.76887004141915 595.0520347833268 -374.44787100769156 -209.75061705931117 595.87537465415892
+-352.9919561608117 -214.01054371908555 587.83785053700194 -373.95159723386524 -209.31724901098281 593.48949750601537
+-354.74676781608025 -211.85802345377363 581.03328898241728 -374.0317741581112 -208.71996103085007 591.11495348067228
+-358.04640968110101 -209.45843318664276 575.05412849832362 -374.66619141069776 -208.00120174386686 588.90075363736275
+-362.62411556237396 -206.97024786708127 570.23683381422381 -375.79313162691011 -207.21036387599986 586.97738805889674
+-368.13743070683319 -204.54902893452106 566.81531134152283 -377.31931456297247 -206.39910643979522 585.44697764939542
+-374.20263638495641 -202.33485723634897 564.91009564807439 -379.13017508526355 -205.6169152135603 584.37720235859899
+8 0 0 8 11 -439.01302916064793 374.19863857327982 571.49855790492745 -444.15928475616067 372.31994216072962 569.88201383510091 -448.69710163844599 370.2128429003763 566.5932152269587 -452.06083287685004 368.08338083607828 561.80795872129568 -453.77140921456254 366.16908066949139 555.9357936410272 -453.53022316917253 364.70174804053613 549.57840892119862 -451.30117165551383 363.86554080178757 543.45432072361325 -447.34018580781628 363.75614392720769 538.26532866671448 -442.14410919268028 364.3629691560472 534.56176123646333 -436.34471144907133 365.57889334253468 532.65601646482969 -430.58973729210845 367.22920584556437 532.60004933387677 -425.44350576948045 369.10789570302541 534.21659498635415
+-439.27862910467894 375.11730691068658 571.27644597004155 -444.4248838028995 373.23861082721908 569.6599021883452 -448.96275018060277 371.13149355471626 566.37108822796597 -452.32638227762891 369.00206757559243 561.58586250115525 -454.03698834426524 367.08775659234226 555.71368820701684 -453.79584178160502 365.62040959377146 549.35629123449098 -451.56679144309675 364.78420192619734 543.232202667911 -447.60578999781217 364.67481072728702 538.04321544738036 -442.40970284696533 365.2816397893709 534.33965128169916 -436.61030396663796 366.49756438774682 532.43390685519705 -430.85533346783183 368.14787555699564 532.37793857898362 -425.70910567633211 370.02656405390775 533.9944830627453
+-439.46949346902534 376.00793745057979 570.8489997174338 -444.55906032006607 374.14993588130147 569.25026275357732 -449.0469836425014 372.06601346750472 565.99766251165568 -452.37348010075681 369.96007424766486 561.26517297912778 -454.06526887646299 368.06684060886357 555.4576742325728 -453.82681235362759 366.61564455714409 549.1702952471444 -451.62231642560835 365.7886475867582 543.11366467763787 -447.70493275325884 365.6804662290827 537.98183928381025 -442.56607240531133 366.28061421398388 534.31907321077051 -436.83055402607084 367.48314548269008 532.43432103559451 -431.13897881933315 369.11527697241803 532.37896816659827 -426.04944100675954 370.97327015414186 533.9777050696274
+-439.57001888237806 376.81656059130614 570.22926770027641 -444.546210989065 374.99994770199078 568.6661440670423 -448.93419579780732 372.96243407592692 565.4859875161809 -452.18652594422173 370.90343016956183 560.85893778518118 -453.84064866263947 369.05236267177497 555.18079988895613 -453.60753041720648 367.63348372755485 549.03346985023711 -451.45214206597757 366.82490860556351 543.11175566554959 -447.62201045340674 366.71914092125587 538.09424880463462 -442.59761486591691 367.30592269335312 534.51307546052203 -436.98985869234809 368.48166686663404 532.67030742259112 -431.4250701966825 370.07744040945761 532.61618658057102 -426.44890839163781 371.89404440128283 534.17930955950999
+-439.57074845784069 377.49151593262053 569.44718197940301 -444.38154027678723 375.73528421125945 567.93601396269707 -448.62369903439162 373.76548559304308 564.86155290356157 -451.76788348734817 371.77493511327663 560.38831086908249 -453.36703940396342 369.98538913384658 554.89890071549428 -453.14168740196556 368.61366504697679 548.95589279878493 -451.05794074119262 367.83196552974135 543.23100638640392 -447.35510847087198 367.72971600040995 538.38027452855624 -442.49770966141108 368.29699589120889 534.91813384725299 -437.07634455308892 369.43366053069536 533.13661567250688 -431.69652135326356 370.97639272152708 533.08429284611509 -426.8857601218254 372.73261536816671 534.59545982653412
+-439.47029786059323 377.99008506615968 568.54798132524513 -444.07299367277977 376.3098210472175 567.10218052210348 -448.13166427720654 374.42522411247978 564.16070481256872 -451.13982438669188 372.52078370200411 559.88096230342614 -452.66981314754901 370.80864439677555 554.62900116769947 -452.45421708082648 369.49625310127726 548.9430633063389 -450.46060508823575 368.74836696114892 543.46581348936422 -446.91793888148351 368.65054158930661 538.82490571617052 -442.27064904701842 369.19328396366222 535.512523277892 -437.08379001176183 370.28078100843669 533.80806573771986 -431.93667724065472 371.75678037999035 533.75800549980022 -427.33401129407764 373.4370354948976 535.20380512213978
+-439.27601753155216 378.28477681560236 567.58701491475199 -443.64093731793349 376.69131551122211 566.21590442456045 -447.48993443140307 374.90407778516811 563.42638607556398 -450.34269901294709 373.09801833722685 559.36773230140795 -451.793646555968 371.47432929208861 554.38708978627642 -451.58918607420696 370.22973759817677 548.99489099915991 -449.6985641126625 369.52048769305429 543.80059776512712 -446.33891278086048 369.42771578789382 539.39943938858733 -441.93170246805215 369.94241976498887 536.25817391351279 -437.01279694492979 370.97373642305917 534.64176789782562 -432.13158449744151 372.37348541552871 534.59429329933835 -427.76669290354874 373.96693831965655 535.96540270718845
+-439.00257098544307 378.36597959380742 566.62213390744125 -443.11487433864227 376.86473865511749 565.33037540410521 -446.74109883528712 375.18094129502344 562.70230260917879 -449.42879400385078 373.47939408422798 558.87852890869976 -450.79575951963687 371.94967859408479 554.18614151264444 -450.60311967715609 370.7771217962345 549.10601842311723 -448.82191550491399 370.10891968948965 544.21234241370985 -445.65670573780591 370.02151522720044 540.06589601357518 -441.50456201102122 370.50642984140529 537.10642683011679 -436.87033442872701 371.47805954701499 535.58356792964003 -432.27161737486506 372.79679937992961 535.53884064064152 -428.15933972131546 374.29803271394633 536.83059838851159
+-438.66952395130266 378.24103367905883 565.70709470200813 -442.52921107272931 376.83201303219215 564.4946881208532 -445.93265184585442 375.25166007995136 562.02806432499392 -448.45529984874855 373.6546170087837 558.43916379138 -449.7382766661641 372.21887750086762 554.03503358192279 -449.55744860305703 371.11835882359668 549.2669889394125 -447.88566195638924 370.49120461144832 544.67393023736406 -444.91489725402107 370.40916631841191 540.78219472829801 -441.01782247740977 370.86429070955529 538.0045211038464 -436.66827309095777 371.77623337029047 536.57520924111134 -432.35205060976926 373.01396434296839 536.53322951859695 -428.49238605924194 374.42297841220147 537.74563586876423
+8 0 0 11 3 -439.01302916133568 374.19863857565844 571.49855790435254 -427.80694042137645 335.43854412239892 580.86981763264873 -416.60085168141728 296.67844966913935 590.24107736094516 -405.39476294145805 257.91835521587984 599.61233708924135
+-444.1592816361495 372.31994110254982 569.882005804095 -432.95319636590466 333.55984538263164 579.25326444247696 -421.74711109565982 294.79974966271334 588.62452308085915 -410.54102582541492 256.03965394279516 597.99578171924111
+-448.696851095309 370.21293428417113 566.59329348957806 -437.49076134417857 331.45284023376865 575.96455367496594 -426.28470141791809 292.69273334629821 585.33579642984523 -415.07861166674257 253.93263929591581 594.70705661526256
+-452.06106972133836 368.0832963462563 561.80789254444005 -440.8549726258517 329.32320485548877 571.17915453430157 -429.64893554128611 290.56308397257146 580.55036671711366 -418.44283844569577 251.80299248185045 589.92162870704396
+-453.77149645845697 366.16905804116817 555.93580433993031 -442.56539249776097 327.40896868120927 565.30706693357422 -431.35936131467082 288.6488367057774 574.67824029402391 -420.15325735382009 249.8887473458885 584.04950288777263
+-453.53013849062938 364.70179605081285 549.57850618933719 -442.32403002395745 325.94170768219368 558.94976749500654 -431.11797383501602 287.18157616136995 568.32091283391583 -419.91186536815866 248.42148779283559 577.69217413971455
+-451.30110977141209 363.86558455692807 543.45442770029001 -440.09499985753479 325.10549581903342 552.82568574805521 -428.88889939932807 286.34537777124382 562.19683387535702 -417.68278948526046 247.58528903343756 571.56809192326057
+-447.34021846764443 363.7561516287588 538.2653995993353 -436.13410996630114 324.99606131051672 547.6366527997867 -424.92796977988382 286.23596329769003 557.00783628617569 -413.72186127837119 247.47587297952865 566.37908948675852
+-442.1441977512153 364.36295047723263 534.56178988535237 -430.9380927065273 325.60285776899747 543.93303733409266 -419.73193400767906 286.84277776393384 553.30427316463386 -408.52582896286424 248.08268505576206 562.67552061348488
+-436.34479918871642 365.57886755715049 532.6560147193029 -425.13869849458121 326.81877218377889 542.02725634723936 -413.93254492979645 288.05870248965817 551.39854096373881 -402.72644423559143 249.29860711632611 560.7697825917553
+-430.58979474118286 367.22918532891072 532.60003314993116 -419.38369808864957 328.4690875640315 541.97126971936734 -408.17756521357848 289.7090192681132 551.34258485953478 -396.97146856103853 250.94892150324659 560.7138214290153
+-425.44353144330631 369.10788440174952 534.21657892462144 -414.23743754993257 330.34778496322633 543.58781187114903 -403.03132958270038 291.58771125854003 552.95913442495043 -391.8252356893812 252.82761182000309 562.33036737148632
+8 0 0 8 11 -425.44350576948045 369.10789570302541 534.2165949863537 -420.29727424685245 370.98658556048645 535.83314063883108 -415.75978535855927 373.0936527723789 539.12219907473889 -412.39535815228965 375.22308637659194 543.90650543682671 -410.68488600830193 377.13757509000988 549.77957502853042 -410.92643589584014 378.60479448284167 556.13692652456507 -413.1553978821774 379.44103393759258 562.26104098802637 -417.11669978312023 379.55029413732143 567.44984577491471 -422.31221679586673 378.9434462382597 571.15265002993317 -428.11162295865273 377.72780833913902 573.05958835191768 -433.866865332229 376.07730391671782 573.11508373443075 -439.01302916133585 374.19863857565832 571.49855790435265
+-425.70910567633211 370.02656405390775 533.99448306274485 -420.5628778848324 371.90525255081991 535.61102754650653 -416.02539280063911 374.01231837539547 538.90008479024345 -412.66096474953741 376.1417522844248 543.68439140364194 -410.95048227209571 378.05624475690826 549.55746419496495 -411.19201620352885 379.52346995698258 555.91482064284776 -413.42097827337136 380.35970938345997 562.03893508863962 -417.38231902744462 380.46895544457936 567.22772782541517 -422.57786788596343 379.8620959521532 570.93052218539435 -428.37717775618779 378.64649309294839 572.83749036957602 -434.13246287224348 376.9959731361223 572.8929725728326 -439.27862910519747 375.11730691300158 571.27644596900154
+-426.04944100675954 370.97327015414186 533.97770506962695 -420.95990319418593 372.83126333586574 535.57644197265597 -416.47240277577635 374.91511820958567 538.82926864771059 -413.14503397319197 377.02109624627565 543.56087556063619 -411.45338402595917 378.91450345066795 549.36925823480749 -411.69224364984342 380.36557189902175 555.65659147741678 -413.89665296967871 381.19260003003774 561.71324743277603 -417.81439158488297 381.30063067030761 566.84487393698669 -422.95273779520733 380.70044583683949 570.50687253624392 -428.68808560906353 379.49826280031073 572.39286063159466 -434.38001077269968 377.86591071883942 572.44772076382867 -439.46949346934417 376.00793745272648 570.84899971595394
+-426.44890839163781 371.89404440128283 534.17930955950953 -421.47274658659308 373.7106483931081 535.74243253844838 -417.08521147216914 375.7480828339352 538.92279933834652 -413.83196206108346 377.80714880322296 543.54900658425163 -412.17798811478843 379.6583814915312 549.22800563653038 -412.4115160170636 381.07713028803954 555.37528722583488 -414.56681974847351 381.88573585806728 561.2970262190363 -418.39731295027934 381.99135062585759 566.31433301614572 -423.42122014757842 381.4045273847529 569.8947505703087 -429.02874579822117 380.22914689514778 571.73874687146667 -434.59390580351885 378.63314701140052 571.79237681516236 -439.57001888247686 376.81656059318345 570.22926769840933
+-426.8857601218254 372.73261536816671 534.59545982653367 -422.07499889038723 374.48883801480639 536.10662680695259 -417.8332996273362 376.4585511172541 539.18128359418245 -414.68818239256257 378.44917757997246 543.65372464667882 -413.08917909848844 380.23888040922975 549.14396603955618 -413.31493739552002 381.6104753408033 555.08692556945903 -415.39860164574225 382.39220451762111 560.81183616052306 -419.1017924245823 382.49430257187782 565.66237020492258 -423.95872869827031 381.92697873493029 569.12377578455369 -429.37982934191376 380.79068084321369 570.90649445545353 -434.76003000097955 379.24772319175395 570.95833693574468 -439.57074845771149 377.49151593413973 569.44718197722659
+-427.33401129407764 373.4370354948976 535.20380512213933 -422.73134534750056 375.11729060980497 536.64960474447867 -418.67312622545342 377.00180146806599 539.59126422707743 -415.66405448831659 378.90632148625514 543.87024612794119 -414.13421579190941 380.61860984116146 549.12300315893629 -414.35020494490868 381.93087649786241 554.80889549869153 -416.34373682613591 382.67879148004511 560.28616884950884 -419.88674878976468 382.77647042029992 564.92688439370181 -424.5336004837082 382.23368394492752 568.23856028958721 -429.72018953560803 381.14654397248927 569.94417186222222 -434.86766954218058 379.67032668572904 569.99377049726786 -439.47029786024183 377.99008506725249 568.54798132285714
+-427.76669290354874 373.96693831965655 535.96540270718799 -423.40180130965598 375.56039122378456 537.33651211503798 -419.55323056935867 377.34754803957082 540.12620552922556 -416.69960846061787 379.15368034427456 544.18413553888729 -415.24880225340746 380.77751163899035 549.16553536448475 -415.45363368646963 382.02198641777829 554.55769408923572 -417.34417778700953 382.73126436764943 559.75201023603961 -420.70415334416714 382.82389813728383 564.15298492383158 -425.1109470123551 382.30915220507097 567.29357847385529 -430.02960541006917 381.27817095204188 568.91107638926462 -434.91115952183731 379.87821771516963 568.95811508920337 -439.27601753099759 378.28477681622707 567.58701491226157
+-428.15933972131546 374.29803271394633 536.83059838851113 -424.04706206776586 375.79926604796321 538.12235613638109 -420.42122381452845 377.48299288308203 540.75059892111972 -417.73275383348283 379.1845965931002 544.57368016811608 -416.36591548444625 380.71444888971206 549.26678539965258 -416.55889682333463 381.88689913941676 554.34687606960324 -418.34002520768718 382.55512855921802 559.24057442954449 -421.50553045480001 382.64240583597461 563.38684803504691 -425.65727499562485 382.15745350522519 566.3456837450185 -430.29130432934176 381.18612723658754 567.86956090984177 -434.89032416825989 379.86720194104339 567.91388322460068 -439.00257098471531 378.36597959395084 566.62213390495936
+-428.49238605924194 374.42297841220147 537.74563586876377 -424.63272150871461 375.83199248143472 538.95804221893093 -421.22961488884829 377.41228964722291 541.42483464177997 -418.70629722504009 379.00936469417871 545.01306706977061 -417.42342905297971 380.4452371491758 549.4178769893191 -417.60456387823865 381.54566156667147 554.18589849334853 -419.2762765276903 382.17284246275676 558.77897907046076 -422.24730274618065 382.25476641933329 562.67055429777065 -426.14399101352598 381.79961029158545 565.44763438817324 -430.49341289131098 380.88793114438693 566.87788410137046 -434.80988886605354 379.65003727606467 566.91949298836846 -438.66952395043973 378.24103367873516 565.70709469963924
+8 0 0 11 3 -438.66952395216515 378.24103367938221 565.70709470437737 -436.97332933745372 377.60468936372877 561.04683830145723 -435.27713472274229 376.96834504807532 556.3865818985372 -433.58094010803086 376.33200073242188 551.72632549561706
+-442.52920871402176 376.83201224175713 564.49468203107631 -439.54645664123569 376.6653402312304 560.23856188884645 -436.56370043923874 376.49866972811861 555.98244304369337 -433.58094010803086 376.33200073242188 551.72632549561706
+-445.93239732062597 375.25175375363187 562.0281476049646 -441.81524929566524 375.61183374280682 558.59420247217338 -437.69809689146996 375.97191606906972 555.16026176905905 -433.58094010803086 376.33200073242188 551.72632549561706
+-448.45557746118982 373.65451666784861 558.43908052942652 -443.49736603889824 374.54700968016766 556.20148981683496 -438.53915358783337 375.439504368359 553.96390480555215 -433.58094010803086 376.33200073242188 551.72632549561706
+-449.73840519655278 372.21882687891201 554.0349778174309 -444.35258002877174 373.58988513190599 553.2654241405312 -438.9667583325969 374.96094308307926 552.49587336660613 -433.58094010803086 376.33200073242188 551.72632549561706
+-449.55736619372146 371.11837520672873 549.26695823610635 -444.23188573223348 372.85625301032286 550.0867520956217 -438.90641037035658 374.59412818555001 550.90654118213297 -433.58094010803086 376.33200073242188 551.72632549561706
+-447.88554575690881 370.49122309110822 544.67386780235745 -443.11734331934787 372.43815259896445 547.02470137347609 -438.34914143639588 374.3850784793957 549.37552060454391 -433.58094010803086 376.33200073242188 551.72632549561706
+-444.91481758705334 370.40916544917832 540.78209588450204 -441.13686856462175 372.38344602051791 544.43019340961098 -437.35890940491259 374.35772444827177 548.0782699466323 -433.58094010803086 376.33200073242188 551.72632549561706
+-441.01775225790198 370.86428624930159 538.00441866092979 -438.5388387005429 372.6868559608003 542.57840872263557 -436.05990131718437 374.5094274552016 547.15237766756513 -433.58094010803086 376.33200073242188 551.72632549561706
+-436.66817641195468 371.77624377157548 536.57513662217389 -435.63913386464998 373.2948223146501 541.62554681612789 -434.61005509661607 374.81340796831046 546.67594310739048 -433.58094010803086 376.33200073242188 551.72632549561706
+-432.35192153979028 373.01399551228332 536.53320408016498 -432.76163826237905 374.11998483387833 541.59757897712723 -433.17131111845686 375.22598657397134 546.66195278246892 -433.58094010803086 376.33200073242188 551.72632549561706
+-428.49224274817482 374.42302552956238 537.74565937860518 -430.18852038062681 375.05933410305397 542.40586722184275 -431.88475283399788 375.69565917070571 547.06608926108129 -433.58094010803086 376.33200073242188 551.72632549561706
+8 0 0 11 3 -425.44353144330626 369.10788440174957 534.21657892462156 -414.23743754993262 330.34778496322639 543.58781187114903 -403.03132958270032 291.58771125854014 552.95913442495078 -391.82523568938126 252.82761182000314 562.33036737148643
+-420.29726814542971 370.98658347458837 535.83312469931184 -409.09117701121562 332.22648236242122 545.20435402293072 -397.88509395182223 293.46640324896697 554.57568399036643 -386.67900281772393 254.70630213675963 563.94691331395745
+-415.75974599721019 373.09366384850574 539.12219781806425 -404.55365633971326 334.33356178055834 548.49342495436611 -393.34760240628401 295.57347045136567 557.86473922540176 -382.1415127489621 256.81336838335216 567.23596636163938
+-412.39531203333939 375.22310613273783 543.90653202826331 -401.18922159662583 336.46300427110879 553.27775908612773 -389.98318966976097 297.70289602497729 562.64902970298533 -378.77709923327143 258.94279416326026 572.0202567607538
+-410.68488836216585 377.13758908535851 549.7796357759338 -399.47879414616705 338.37748893184431 559.15086537942011 -388.27276252226119 299.61736449503388 568.52206939293023 -377.06666830651727 260.85726434141736 577.89329899629809
+-410.92652684490821 378.60479175651955 556.13702401659896 -399.72042561675897 339.84469492927082 565.50825899263737 -388.51436203619858 301.08456264518219 574.87939233578106 -377.30826080831065 262.32446581782705 584.2506273116918
+-413.15551645434209 379.4410350132066 562.26118711129686 -401.94940554169989 340.68094290457759 571.6324300231795 -390.74328204436631 301.92081712522122 581.00351862221692 -379.53717113196404 263.16072501649353 590.37476153397824
+-417.11668738234607 379.5503471674927 567.45005005696305 -405.91056574869162 340.79026048308418 576.82130258363475 -394.70438062490553 302.03015434788199 586.19239873958441 -383.49825899144315 263.270067663394 595.56365126615685
+-422.31215402287955 378.94350534073442 571.15281944998094 -411.10602362479875 340.18342351963003 580.5240816111301 -399.89981350057553 301.42333878550443 589.89523638786932 -388.69368310261956 262.66325696434808 599.26649854895277
+-428.112108308948 377.72764218707817 573.05948218876563 -416.90597573539492 338.96756270327376 582.4307514157141 -405.69979506684467 300.20748650352306 591.80197671403425 -394.49366249334457 261.44740701969653 601.17324594095442
+-433.86686487687814 376.07730385388425 573.11508230206312 -422.66074327041946 337.31722139891099 582.48635235445624 -411.45462166396095 298.5571389439379 591.85762240684926 -400.24850005750238 259.79705648896464 601.22889245924227
+-439.01302916133773 374.19863857565855 571.49855790435311 -427.80694042137839 335.43854412239892 580.86981763264953 -416.60085168141921 296.67844966913952 590.24107736094584 -405.39476294145999 257.9183552158799 599.61233708924215
+8 0 0 14 1 -388.43285051863887 251.55492471135057 553.00986571677913 -391.82522850662997 252.82760912532234 562.33034763703949
+-394.49805619676209 249.34075301317847 551.10465002333069 -395.86869895871212 251.35149465987428 561.0602038414072
+-401.11515240854925 247.33362854939449 550.71574110913468 -400.28009643323691 250.01341168401828 560.8009312319432
+-407.900420424478 245.67363216738548 551.96367354204483 -404.80360844385609 248.90674742934561 561.63288618721663
+-414.4288775385694 244.48536412249319 554.85561004636349 -409.15591318658369 248.11456873275077 563.5608438567624
+-420.26870165149717 243.86537699592569 559.27452797738852 -413.04912926186887 247.70124398170577 566.50678914411242
+-425.02018041987117 243.87130604876509 564.98083693935632 -416.2167817741182 247.7051966835987 570.31099511875766
+-428.35447023717677 244.51441817905132 571.62790854951697 -418.43964165232194 248.13393810378952 574.74237619219809
+-430.04665358405862 245.75700174854794 578.7908103594533 -419.5677638835765 248.96232715012061 579.51764406548898
+-429.99788727857708 247.51531881491405 586.00500119233027 -419.53525301325544 250.13453852769806 584.32710462074033
+-428.24309928088746 249.66783643907485 592.80958011252699 -418.36539434812897 251.5695502771386 588.86349056753818
+-424.94345924749683 252.06743194419062 598.78876445149263 -416.1656343258685 253.16928061388248 592.8496134601819
+-420.36573545775326 254.55562820925465 603.60608299202238 -413.11381846603939 254.8280781239252 596.0611591538684
+-414.85239056983011 256.9768602039083 607.02762392329635 -409.43825520742394 256.44223278702771 598.34218644138446
+-408.78715217088074 259.19104384718673 608.93284989508243 -405.39476294145777 257.91835521588001 599.61233708924192
+8 0 0 11 3 -428.49224274817487 374.42302552956227 537.74565937860541 -430.18852038062693 375.05933410305391 542.40586722184275 -431.88475283399794 375.69565917070571 547.06608926108129 -433.58094010803097 376.33200073242176 551.72632549561706
+-424.63256395655941 375.83205554684133 538.95811467704561 -427.61540249887469 375.99868337222955 543.21415546655828 -430.59819454953896 376.16533176744008 547.47022573969366 -433.58094010803097 376.33200073242176 551.72632549561706
+-421.22946124549281 377.41236384069163 541.42495781593504 -425.34666233764119 377.05221939135265 544.85869979499 -429.46382195878027 376.69209835524794 548.29248902184008 -433.58094010803097 376.33200073242176 551.72632549561706
+-418.70618972174105 379.00943446925044 545.01322713897571 -423.66446838382308 378.1169327449922 547.2508622233471 -428.62271851301301 377.22445483265074 549.48856167580141 -433.58094010803097 376.33200073242176 551.72632549561706
+-417.42342810825704 380.44527805250925 549.41804502164109 -422.80927340577773 379.0741648504752 550.18739549700888 -428.1951107395704 377.70307241031833 550.95682232177899 -433.58094010803097 376.33200073242176 551.72632549561706
+-417.60469751228891 381.54565911798187 554.18604808154976 -422.93009466688642 379.80775893367195 553.36606203623307 -428.25550886602531 378.06987280496958 552.54615450750259 -433.58094010803103 376.33200073242176 551.72632549561695
+-419.27645018227031 382.17282588759042 558.77911808995862 -424.04457318983413 380.22587933261582 556.42811902908136 -428.8127364988685 378.27893761402771 554.0771881640153 -433.58094010803109 376.33200073242176 551.72632549561683
+-422.24730865889416 382.25480530303599 562.67072227831352 -426.02513140654622 380.28054145473135 559.02254292216071 -429.80300855647835 378.30627326437269 555.37441066088866 -433.58094010803114 376.33200073242176 551.72632549561672
+-426.14387726765358 381.79967892682112 565.4477824639639 -428.62284374141689 379.97712995906301 560.87394147669568 -431.10186468821581 378.15457056086052 556.30012248696755 -433.5809401080312 376.33200073242176 551.72632549561649
+-430.49382312367737 380.88778804860965 566.87778260211167 -431.52282061992713 379.36920381178294 561.82729498671085 -432.55185961468004 377.85060803970413 556.77680928444124 -433.58094010803131 376.33200073242176 551.72632549561615
+-434.80988856155301 379.6500371535742 566.91949211763631 -434.40021851825185 378.54403251840955 561.85510970160306 -433.99056903374463 377.43802037802521 556.79072082759603 -433.58094010803143 376.3320007324217 551.7263254956157
+-438.66952395044086 378.24103367873494 565.70709469963811 -436.9733293363044 377.60468936329721 561.0468382982973 -435.27713472216794 376.96834504785926 556.38658189695616 -433.58094010803154 376.33200073242165 551.72632549561501
+8 0 0 14 1 -408.78715217088092 259.1910438471869 608.9328498950822 -405.394762941458 257.9183552158799 599.61233708924169
+-402.72191377193167 261.40522749046539 610.83807586686817 -401.35127067549183 259.39447764473221 600.88248773709904
+-396.10478186195627 263.41236278236863 611.22698687916625 -396.9398494021749 260.73256783933437 601.1417617452978
+-389.31948402810804 265.07236564193175 609.97904558174434 -392.41631751294273 261.83923641237647 600.30980088034983
+-382.79101278652035 266.26063293758364 607.08708908495817 -388.06400335188425 262.6314146094777 598.38182988249241
+-376.95119613246123 266.88061134589236 602.66814401395447 -384.17079224917813 263.04473354835022 595.43586650182328
+-372.19974288465818 266.87466853424132 596.96180866203895 -381.00315675064275 263.0407716739162 591.63164293387956
+-368.86549878846881 266.23153775014816 590.31471457161012 -378.78032735318317 262.61201781785411 587.20024687359364
+-367.17336646597738 264.98893751642078 583.15180485203166 -377.65223913818886 261.78361766203585 582.424973727208
+-367.22217029449422 263.2306111940872 575.9376206057068 -377.68477502386679 260.61140011381343 577.61551756299139
+-368.97698194976277 261.07809092877528 569.13305905112213 -378.85464946071249 259.17638660360547 573.07914319326824
+-372.27662381478353 258.67850066164442 563.15389856702848 -381.05441070405971 257.57665975885158 569.09303620387243
+-376.85432969605648 256.19031534208295 558.33660388292867 -384.10621462490832 255.91786954581059 565.8815064144726
+-382.36764484051571 253.76909640952275 554.91508141022769 -387.78175805454782 254.30372359077043 563.60049143267202
+-388.43285051863893 251.55492471135065 553.00986571677925 -391.82522850662997 252.82760912532237 562.33034763703972
+8 0 0 14 1 -374.20263638495629 202.33485723634891 564.91009564807428 -388.43285051863893 251.55492471135057 553.00986571677913
+-380.26784206307951 200.12068553817682 563.00487995462584 -394.49805619676215 249.34075301317847 551.10465002333069
+-386.88493827486667 198.11356107439283 562.61597104042983 -401.11515240854931 247.33362854939449 550.71574110913468
+-393.67020629079542 196.45356469238382 563.86390347333997 -407.90042042447806 245.67363216738548 551.96367354204483
+-400.19866340488682 195.26529664749154 566.75583997765864 -414.42887753856945 244.48536412249319 554.85561004636349
+-406.03848751781459 194.64530952092403 571.17475790868366 -420.26870165149722 243.86537699592569 559.27452797738852
+-410.78996628618859 194.65123857376344 576.88106687065147 -425.02018041987122 243.87130604876509 564.98083693935632
+-414.12425610349419 195.29435070404963 583.52813848081212 -428.35447023717683 244.51441817905132 571.62790854951697
+-415.81643945037604 196.53693427354625 590.69104029074845 -430.04665358405867 245.75700174854794 578.7908103594533
+-415.7676731448945 198.29525133991237 597.90523112362541 -429.99788727857714 247.51531881491405 586.00500119233027
+-414.01288514720488 200.44776896407313 604.70981004382213 -428.24309928088752 249.66783643907485 592.80958011252699
+-410.71324511381425 202.8473644691889 610.68899438278777 -424.94345924749689 252.06743194419064 598.78876445149263
+-406.13552132407068 205.33556073425294 615.50631292331752 -420.36573545775332 254.55562820925468 603.60608299202238
+-400.62217643614753 207.75679272890662 618.92785385459149 -414.85239056983016 256.97686020390836 607.02762392329635
+-394.55693803719817 209.97097637218508 620.83307982637757 -408.7871521708808 259.19104384718685 608.93284989508243
+8 0 0 14 1 -394.55693803719839 209.97097637218519 620.83307982637734 -408.78715217088103 259.19104384718685 608.9328498950822
+-388.49169963824914 212.18516001546365 622.73830579816331 -402.72191377193178 261.40522749046534 610.83807586686817
+-381.87456772827375 214.19229530736689 623.12721681046139 -396.10478186195638 263.41236278236858 611.22698687916625
+-375.08926989442551 215.85229816693004 621.87927551303949 -389.31948402810815 265.0723656419317 609.97904558174434
+-368.56079865283783 217.04056546258192 618.98731901625331 -382.79101278652047 266.26063293758358 607.08708908495817
+-362.72098199877871 217.66054387089068 614.56837394524962 -376.95119613246135 266.88061134589231 602.66814401395447
+-357.96952875097566 217.65460105923967 608.86203859333409 -372.19974288465829 266.87466853424127 596.96180866203895
+-354.63528465478629 217.01147027514654 602.21494450290527 -368.86549878846893 266.23153775014811 590.31471457161012
+-352.94315233229486 215.76887004141915 595.0520347833268 -367.17336646597749 264.98893751642072 583.15180485203166
+-352.9919561608117 214.01054371908555 587.83785053700194 -367.22217029449433 263.23061119408715 575.9376206057068
+-354.74676781608025 211.8580234537736 581.03328898241728 -368.97698194976289 261.07809092877523 569.13305905112213
+-358.04640968110101 209.45843318664274 575.05412849832362 -372.27662381478365 258.67850066164436 563.15389856702848
+-362.62411556237396 206.97024786708124 570.23683381422381 -376.8543296960566 256.1903153420829 558.33660388292867
+-368.13743070683319 204.54902893452103 566.81531134152283 -382.36764484051582 253.76909640952269 554.91508141022769
+-374.20263638495641 202.33485723634894 564.91009564807439 -388.43285051863904 251.55492471135059 553.00986571677925
+8 0 0 14 1 -374.20263638495641 202.33485723634891 564.91009564807428 -379.1301750852636 205.61691521356025 584.37720235859888
+-380.26784206307963 200.12068553817682 563.00487995462584 -380.94103560755468 204.83472398732533 583.30742706780245
+-386.88493827486678 198.11356107439283 562.61597104042994 -383.03657371607449 204.08159897106012 582.69828689571079
+-393.67020629079553 196.45356469238382 563.86390347334009 -385.30222427720179 203.40702594307197 582.6174617920642
+-400.19866340488693 195.26529664749154 566.75583997765875 -387.6021372674698 202.85831744742944 583.09819075222163
+-406.0384875178147 194.64530952092403 571.17475790868377 -389.78945576278153 202.47617327314407 584.13320004146851
+-410.7899662861887 194.65123857376344 576.88106687065158 -391.71892780091838 202.29047922696739 585.6724078458974
+-414.1242561034943 195.29435070404963 583.52813848081223 -393.2604444607731 202.31695222930276 587.6252369303154
+-415.81643945037615 196.53693427354625 590.69104029074856 -394.31168553157124 202.55519780177053 589.86770189523565
+-415.76767314489462 198.29525133991237 597.90523112362553 -394.80797181229718 202.98856210101084 592.2535784925193
+-414.01288514720494 200.44776896407313 604.70981004382224 -394.72780371104 203.58584850128298 594.62812653384117
+-410.71324511381425 202.8473644691889 610.68899438278788 -394.09338873894671 204.30460900140827 596.84233412165736
+-406.13552132407062 205.33556073425294 615.50631292331775 -392.96644446961028 205.09545026040902 598.76570887920184
+-400.62217643614736 207.75679272890662 618.92785385459183 -391.44025330005712 205.90671207326301 600.29612754503034
+-394.55693803719782 209.97097637218508 620.83307982637791 -389.62938300849322 206.68890751935442 601.36590860710339
+8 0 0 14 1 -394.55693803719839 209.97097637218519 620.83307982637734 -389.62938300835083 206.68890751911749 601.36590860707906
+-388.49169963824914 212.18516001546365 622.73830579816331 -387.81851271675487 207.47110296515197 602.43568966914427
+-381.87456772827375 214.19229530736689 623.12721681046139 -385.72296330313998 208.22423204440969 603.04483312745106
+-375.08926989442551 215.85229816693004 621.87927551303949 -383.45730254570958 208.89880783627078 603.12565746995858
+-368.56079865283783 217.04056546258192 618.98731901625331 -381.15738360384574 209.44751670452047 602.64492293403032
+-362.72098199877871 217.66054387089068 614.56837394524962 -378.97006557585479 209.8296584457994 601.60990414051685
+-357.96952875097566 217.65460105923967 608.86203859333409 -377.04059985347112 210.01534811075041 600.07068576737743
+-354.63528465478629 217.01147027514654 602.21494450290527 -375.49909626827809 209.98886873044287 598.11784593783182
+-352.94315233229486 215.76887004141915 595.0520347833268 -374.44787100769156 209.75061705931117 595.87537465415892
+-352.9919561608117 214.01054371908555 587.83785053700194 -373.95159723386524 209.31724901098281 593.48949750601537
+-354.74676781608025 211.85802345377363 581.03328898241728 -374.0317741581112 208.71996103085007 591.11495348067228
+-358.04640968110101 209.45843318664276 575.05412849832362 -374.66619141069776 208.00120174386686 588.90075363736275
+-362.62411556237396 206.97024786708127 570.23683381422381 -375.79313162691011 207.21036387599986 586.97738805889674
+-368.13743070683319 204.54902893452106 566.81531134152283 -377.31931456297247 206.39910643979522 585.44697764939542
+-374.20263638495641 202.33485723634897 564.91009564807439 -379.13017508526355 205.6169152135603 584.37720235859899
+8 0 0 1 1 -213.37863596065142 96.877250000000103 123.11643572503917 -58.446949886535094 96.877250000000657 291.78815838583722
+-36.309011368107946 96.877249999998966 -39.529057294577683 118.62267470600841 96.87724999999952 129.1426653662204
+8 0 0 1 10 -2.6645352591003757e-14 96.877250000000004 0 -2.6645352591003757e-14 96.877250000000004 0 -2.6645352591003757e-14 96.877250000000004 0 -2.6645352591003757e-14 96.877250000000004 0 -2.6645352591003757e-14 96.877250000000004 0 -2.6645352591003757e-14 96.877250000000004 0 -2.6645352591003757e-14 96.877250000000004 0 -2.6645352591003757e-14 96.877250000000004 0 -2.6645352591003757e-14 96.877250000000004 0 -2.6645352591003757e-14 96.877250000000004 0 -2.6645352591003757e-14 96.877250000000004 0
+238.10241358932879 96.877250000000004 0 238.10241358932879 96.877250000000004 37.401039666711704 231.57470073079756 96.877250000000004 74.802079333423407 218.51927501373513 96.877250000000004 110.92140557756602 199.22375225759507 96.877250000000004 144.47730497657048 174.2632652011481 96.877250000000004 174.26336175332199 144.47712072709629 96.877250000000004 199.22372435122017 110.92120122198274 96.877250000000004 218.51921309037937 74.80192104020864 96.877250000000004 231.57461118006401 37.400960520104277 96.877250000000004 238.10231022490632 -8.3488771451811772e-14 96.877250000000004 238.10231022490632
+8 0 0 5 10 238.10241358932879 96.877250000000004 3.5527136788005009e-15 238.10241358932879 96.877250000000004 74.802079333423393 211.99156215520392 96.877250000000004 149.60415866684679 159.76985928695419 96.877250000000004 214.15253061971754 86.039158095837251 96.877250000000004 258.19348781148301 0 96.877250000000004 273.88284751612827 -86.039158095837251 96.877250000000004 258.19348781148307 -159.76985928695419 96.877250000000004 214.15253061971762 -211.99156215520392 96.877250000000004 149.6041586668469 -238.10241358932882 96.877250000000004 74.802079333423535 -238.10241358932882 96.877250000000004 1.7053025658242404e-13
+252.17404346806288 96.877250000000004 3.5527136788005009e-15 252.17404346806288 96.877250000000004 79.222812238529954 224.52006514303073 96.877250000000004 158.44562447705991 169.21210849296645 96.877250000000004 226.80874482203333 91.123991842590883 96.877250000000004 273.4524813798937 1.4210854715202005e-15 96.877250000000004 290.06906756439679 -91.123991842590883 96.877250000000004 273.45248137989375 -169.21210849296645 96.877250000000004 226.80874482203342 -224.52006514303073 96.877250000000004 158.44562447706002 -252.17404346806291 96.877250000000004 79.222812238530111 -252.17404346806291 96.877250000000004 1.8260948309034574e-13
+266.24567334679693 96.877250000000004 3.5527136788005009e-15 266.24567334679693 96.877250000000004 83.643545143636516 237.04856813085755 96.877250000000004 167.28709028727303 178.65435769897871 96.877250000000004 239.46495902434913 96.208825589344514 96.877250000000004 288.71147494830439 2.8421709430404009e-15 96.877250000000004 306.25528761266531 -96.208825589344514 96.877250000000004 288.71147494830444 -178.65435769897871 96.877250000000004 239.46495902434921 -237.04856813085755 96.877250000000004 167.28709028727314 -266.24567334679699 96.877250000000004 83.643545143636686 -266.24567334679699 96.877250000000004 1.9468870959826744e-13
+282.81166141360126 87.710721797958925 -2.3092638912203256e-14 282.81166141360126 87.710721797958925 88.847903784649347 251.79789232285606 87.710721797958925 177.69580756929872 189.77035414136554 87.710721797958925 254.36463271199619 102.19500458185102 87.710721797958925 306.67530057078983 3.5171865420124961e-14 87.710721797958925 325.31070126958053 -102.19500458185097 87.710721797958925 306.67530057078989 -189.77035414136549 87.710721797958925 254.36463271199634 -251.797892322856 87.710721797958925 177.69580756929889 -282.81166141360131 87.710721797958925 88.847903784649588 -282.81166141360131 87.710721797958925 2.3456792064280304e-13
+288.95541016745557 76.014728031830984 -2.3092638912203256e-14 288.95541016745557 76.014728031830984 90.778019379710358 257.26790363515227 76.014728031830984 181.55603875942074 193.8928905705456 76.014728031830984 259.89040342257334 104.41507015097075 76.014728031830984 313.33745865261028 3.6237679523765107e-14 76.014728031830984 332.37769138431111 -104.41507015097069 76.014728031830984 313.33745865261034 -193.89289057054555 76.014728031830984 259.89040342257346 -257.26790363515221 76.014728031830984 181.55603875942094 -288.95541016745563 76.014728031830984 90.778019379710628 -288.95541016745563 76.014728031830984 2.668087972779176e-13
+293.73793875676444 63.786359537519886 -2.3092638912203256e-14 293.73793875676444 63.786359537519886 92.28049504788595 261.5259692776458 63.786359537519886 184.56099009577193 197.10203031940853 63.786359537519886 264.19187430950075 106.14325394881801 63.786359537519886 318.52353685491511 3.9079850466805504e-14 63.786359537519886 337.87890629692595 -106.14325394881796 63.786359537519886 318.52353685491516 -197.10203031940844 63.786359537519886 264.19187430950086 -261.52596927764574 63.786359537519886 184.56099009577215 -293.73793875676444 63.786359537519886 92.280495047886276 -293.73793875676444 63.786359537519886 3.5615954629975017e-13
+8 0 0 1 1 50.092201232910156 96.877250000000004 8.7642717361450195 51.073661804199219 96.877250000000004 -69.4403076171875
+-60.321983337402344 96.877250000000004 8.7642717361450195 -54.4332275390625 96.877250000000004 -69.926040649414062
+8 0 0 3 10 304.67544555664057 0 -2.3092638912203256e-14 304.67544555664057 0 95.71661414899387 271.26404424142186 0 191.43322829798777 204.44124161098452 0 274.02921583222775 110.09556112010074 0 330.38395013695992 0 0 350.46002826843096 -110.09556112010074 0 330.38395013695998 -204.44124161098455 0 274.02921583222781 -271.26404424142191 0 191.43322829798785 -304.67544555664062 0 95.716614148993983 -304.67544555664068 0 1.2789769243681803e-13
+304.67544555664057 21.262119845839962 -2.3092638912203256e-14 304.67544555664057 21.262119845839962 95.71661414899387 271.26404424142186 21.262119845839962 191.43322829798777 204.44124161098452 21.262119845839962 274.02921583222775 110.09556112010074 21.262119845839962 330.38395013695992 0 21.262119845839962 350.46002826843096 -110.09556112010074 21.262119845839962 330.38395013695998 -204.44124161098455 21.262119845839962 274.02921583222781 -271.26404424142191 21.262119845839962 191.43322829798785 -304.67544555664062 21.262119845839962 95.716614148993983 -304.67544555664068 21.262119845839962 1.2789769243681803e-13
+302.05357759929257 42.524239691679924 -2.3092638912203256e-14 302.05357759929257 42.524239691679924 94.892930037645186 268.92969627886185 42.524239691679924 189.7858600752904 202.68193363800043 42.524239691679924 271.67107233610494 109.14813976351697 42.524239691679924 327.54084904325822 -7.4014868308343773e-16 42.524239691679924 347.4441635774989 -109.14813976351697 42.524239691679924 327.54084904325828 -202.68193363800046 42.524239691679924 271.671072336105 -268.92969627886191 42.524239691679924 189.78586007529049 -302.053
