[cgma-dev] r3269 - in cgm/trunk: geom/parallel itaps
kraftche at cae.wisc.edu
Tue Nov 3 10:05:08 CST 2009
Author: kraftche
Date: 2009-11-03 10:05:07 -0600 (Tue, 03 Nov 2009)
New Revision: 3269
Modified:
cgm/trunk/geom/parallel/CGMParallelComm.cpp
cgm/trunk/geom/parallel/CGMParallelComm.hpp
cgm/trunk/geom/parallel/ParallelGeomTool.cpp
cgm/trunk/geom/parallel/ParallelGeomTool.hpp
cgm/trunk/itaps/CATag.hpp
Log:
o Move vector of CGMParallelComm instances from member of CGMTagManager
to static member of CGMParallelComm
o Remove all dependencies on CGMTagManager from geom/parallel code
o Remove some unnecessary #includes and unused definitions
Modified: cgm/trunk/geom/parallel/CGMParallelComm.cpp
--- cgm/trunk/geom/parallel/CGMParallelComm.cpp 2009-11-03 16:03:06 UTC (rev 3268)
+++ cgm/trunk/geom/parallel/CGMParallelComm.cpp 2009-11-03 16:05:07 UTC (rev 3269)
@@ -1,18 +1,11 @@
#include "CGMParallelComm.hpp"
-//#include "CubitAttrib.hpp"
-//#include "OCCQueryEngine.hpp"
#include "TopologyEntity.hpp"
#include "GeometryQueryEngine.hpp"
#include "RefEntity.hpp"
+#include "GeometryQueryTool.hpp"
-//#include <iostream>
-#include <sstream>
-#include <algoritm>
+#include <algorithm>
-#ifdef USE_MPI
-#include "CGMmpi.h"
-#endif
#define INITIAL_BUFF_SIZE 1024
#define RRA(a) if (CUBIT_SUCCESS != result) { \
std::string tmp_str; \
@@ -20,9 +13,10 @@
PRINT_ERROR(tmp_str.c_str()); \
return result;}
-CGMParallelComm::CGMParallelComm(CGMTagManager *impl,
- MPI_Comm comm, int* id )
- : cgmImpl(impl), procConfig(comm)
+std::vector<CGMParallelComm*> CGMParallelComm::instanceList;
+CGMParallelComm::CGMParallelComm(MPI_Comm comm, int* id )
+ : procConfig(comm)
myBuffer.resize(INITIAL_BUFF_SIZE);
@@ -45,11 +39,10 @@
m_currentPosition = 0;
- std::vector<unsigned char> &tmp_buff,
+CGMParallelComm::CGMParallelComm(std::vector<unsigned char> &tmp_buff,
MPI_Comm comm,
int* id)
myBuffer.swap(tmp_buff);
int flag = 1;
@@ -79,48 +72,34 @@
int CGMParallelComm::add_pcomm(CGMParallelComm *pc)
- // add this pcomm to instance tag
- std::vector<CGMParallelComm *> pc_array;
- pc_array = cgmImpl->get_pc_array();
- pc_array.push_back(pc);
- return pc_array.size() - 1;
+ instanceList.push_back(pc);
+ return instanceList.size() - 1;
void CGMParallelComm::remove_pcomm(CGMParallelComm *pc)
- // remove this pcomm from instance tag
std::vector<CGMParallelComm*>::iterator pc_it =
- std::find(pc_array.begin(), pc_array.end(), pc);
- assert(pc_it != pc_array.end());
- pc_array.erase(pc_it);
+ std::find(instanceList.begin(), instanceList.end(), pc);
+ assert(pc_it != instanceList.end());
+ instanceList.erase(pc_it);
//! get the indexed pcomm object from the interface
-CGMParallelComm *CGMParallelComm::get_pcomm(CGMTagManager *impl,
- const int index)
+CGMParallelComm *CGMParallelComm::get_pcomm(const int index)
- pc_array = impl->get_pc_array();
- if (pc_array.size() < (unsigned int) (index + 1)) return NULL;
- else return pc_array[index];
+ if (instanceList.size() < (unsigned int) (index + 1)) return NULL;
+ else return instanceList[index];
-CubitStatus CGMParallelComm::get_all_pcomm(CGMTagManager *impl,
- std::vector<CGMParallelComm*>& list )
+CubitStatus CGMParallelComm::get_all_pcomm(std::vector<CGMParallelComm*>& list )
- list = impl->get_pc_array();
+ list = instanceList;
return CUBIT_SUCCESS;
- //MBEntityHandle prtn,
+CGMParallelComm *CGMParallelComm::get_pcomm(//MBEntityHandle prtn,
const MPI_Comm* comm )
//MBErrorCode rval;
@@ -139,8 +118,7 @@
int pcomm_id;
//rval = impl->tag_get_data( prtn_tag, &prtn, 1, &pcomm_id );
//if (MB_SUCCESS == rval) {
- result= get_pcomm(impl,
- pcomm_id );
+ result= get_pcomm( pcomm_id );
else if (MB_TAG_NOT_FOUND == rval && comm) {
Modified: cgm/trunk/geom/parallel/CGMParallelComm.hpp
--- cgm/trunk/geom/parallel/CGMParallelComm.hpp 2009-11-03 16:03:06 UTC (rev 3268)
+++ cgm/trunk/geom/parallel/CGMParallelComm.hpp 2009-11-03 16:05:07 UTC (rev 3269)
@@ -10,41 +10,24 @@
#ifndef CGM_PARALLEL_COMM_HPP
#define CGM_PARALLEL_COMM_HPP
-//#include "CGMForward.hpp"
-#include "GeometryQueryTool.hpp"
-//#include "CGMRange.hpp"
#include "CGMProcConfig.hpp"
-#include "CATag.hpp"
-#include <map>
-#include <set>
-#include <vector>
-#include "math.h"
#include "CGMmpi.h"
+#include "DLIList.hpp"
+#include <vector>
+class GeometryQueryTool;
+class RefEntity;
-extern "C" {
- struct tuple_list;
-//class TagServer;
-//class SequenceManager;
-//template <typename KeyType, typename ValType, ValType NullVal> class RangeMap;
-//typedef RangeMap<CGMEntityHandle, CGMEntityHandle, 0> HandleMap;
-#define MAX_SHARING_PROCS 64
class CGMParallelComm
public:
//! constructor
- CGMParallelComm(CGMTagManager *impl,
- MPI_Comm comm = MPI_COMM_WORLD,
+ CGMParallelComm(MPI_Comm comm = MPI_COMM_WORLD,
int* pcomm_id_out = 0);
//! constructor taking buffer, for testing
+ CGMParallelComm(std::vector<unsigned char> &tmp_buff,
@@ -52,18 +35,15 @@
int get_id() const { return pcommID; }
- static CGMParallelComm *get_pcomm(CGMTagManager *impl,
- const int index);
+ static CGMParallelComm *get_pcomm(const int index);
//! Get CGMParallelComm instance associated with partition handle
//! Will create CGMParallelComm instance if a) one does not already
//! exist and b) a valid value for MPI_Comm is passed.
- //CGMEntityHandle partitioning,
+ static CGMParallelComm *get_pcomm(//CGMEntityHandle partitioning,
const MPI_Comm* comm = 0 );
- static CubitStatus get_all_pcomm(CGMTagManager *impl,
- std::vector<CGMParallelComm*>& list );
+ static CubitStatus get_all_pcomm(std::vector<CGMParallelComm*>& list );
//! destructor
~CGMParallelComm();
@@ -129,30 +109,22 @@
private:
+ static std::vector<CGMParallelComm*> instanceList;
//! add a pc to the iface instance tag PARALLEL_COMM
- int add_pcomm(CGMParallelComm *pc);
+ static int add_pcomm(CGMParallelComm *pc);
//! remove a pc from the iface instance tag PARALLEL_COMM
- void remove_pcomm(CGMParallelComm *pc);
+ static void remove_pcomm(CGMParallelComm *pc);
CubitStatus check_size(int& target_size, const CubitBoolean keep = CUBIT_FALSE);
//! CGM query tool interface associated with this writer
GeometryQueryTool *gqt;
- //! CGM tag manager interface associated with this writer
- CGMTagManager *cgmImpl;
//! Proc config object, keeps info on parallel stuff
CGMProcConfig procConfig;
- //! Tag server, so we can get more info about tags
- //TagServer *tagServer;
- //! Sequence manager, to get more efficient access to entities
- //SequenceManager *sequenceManager;
//! data buffer used to communicate
std::vector<unsigned char> myBuffer;
@@ -161,32 +133,7 @@
int m_nBufferSize;
int m_currentPosition;
- //std::ofstream mOfstream;
- //! more data buffers, proc-specific
- //std::vector<unsigned char> ownerRBuffs[MAX_SHARING_PROCS],
- //ownerSBuffs[MAX_SHARING_PROCS], ghostRBuffs[MAX_SHARING_PROCS],
- // ghostSBuffs[MAX_SHARING_PROCS];
- //! request objects, may be used if store_remote_handles is used
- //MPI_Request sendReqs[2*MAX_SHARING_PROCS];
- //! processor rank for each buffer index
- //std::vector<int> buffProcs;
- //! the partition, interface sets for this comm'n instance
- //CGMRange partitionSets, interfaceSets;
- //! local entities ghosted to other procs
- //std::map<unsigned int, CGMRange> ghostedEnts;
- //! tags used to save sharing procs and handles
- //CGMTag sharedpTag, sharedpsTag, sharedhTag, sharedhsTag, pstatusTag,
- //ifaceSetsTag, partitionTag;
- //int globalPartCount; //!< Cache of global part count
//CGMEntityHandle partitioningSet; //!< entity set containing all parts
DLIList<RefEntity*> partitioningSurfList; // ref entity list containing all parts
DLIList<RefEntity*> partitioningBodyList; // ref entity list containing all parts
Modified: cgm/trunk/geom/parallel/ParallelGeomTool.cpp
--- cgm/trunk/geom/parallel/ParallelGeomTool.cpp 2009-11-03 16:03:06 UTC (rev 3268)
+++ cgm/trunk/geom/parallel/ParallelGeomTool.cpp 2009-11-03 16:05:07 UTC (rev 3269)
@@ -12,7 +12,6 @@
#include "ParallelGeomTool.hpp"
#include "CGMParallelConventions.h"
const bool debug = true;
@@ -45,12 +44,12 @@
//ParallelGeomTool *ParallelGeomTool::instance_ = NULL;
-ParallelGeomTool::ParallelGeomTool(CGMTagManager* impl, CGMParallelComm *pc)
- : cgmImpl(impl), myPcomm(pc)
+ParallelGeomTool::ParallelGeomTool(CGMParallelComm *pc)
+ : myPcomm(pc)
if (!myPcomm) {
- myPcomm = CGMParallelComm::get_pcomm(impl, 0);
- if (NULL == myPcomm) myPcomm = new CGMParallelComm(cgmImpl);
+ myPcomm = CGMParallelComm::get_pcomm(0);
+ if (NULL == myPcomm) myPcomm = new CGMParallelComm();
//gqt = GeometryQueryTool::instfance();
Modified: cgm/trunk/geom/parallel/ParallelGeomTool.hpp
--- cgm/trunk/geom/parallel/ParallelGeomTool.hpp 2009-11-03 16:03:06 UTC (rev 3268)
+++ cgm/trunk/geom/parallel/ParallelGeomTool.hpp 2009-11-03 16:05:07 UTC (rev 3269)
@@ -4,19 +4,13 @@
#include <vector>
#include "CubitDefines.h"
-//#include "ProcData.hpp"
#include "FileOptions.hpp"
-//#include "CATag.hpp"
-//#include "CGMParallelComm.hpp"
-//class CGMTagManager;
-//class CGMParallelComm;
class ParallelGeomTool
public:
- ParallelGeomTool(CGMTagManager* impl = NULL, CGMParallelComm *pc = NULL);
+ ParallelGeomTool(CGMParallelComm *pc = NULL);
//static ParallelGeomTool *instance();
@@ -70,8 +64,6 @@
//static ParallelGeomTool *instance_;
// each reader can keep track of its own pcomm
CGMParallelComm *myPcomm;
Modified: cgm/trunk/itaps/CATag.hpp
--- cgm/trunk/itaps/CATag.hpp 2009-11-03 16:03:06 UTC (rev 3268)
+++ cgm/trunk/itaps/CATag.hpp 2009-11-03 16:05:07 UTC (rev 3269)
@@ -42,7 +42,6 @@
class RefEntity;
class RefGroup;
class CATag;
-class CGMParallelComm;
class CGMTagManager
@@ -117,8 +116,6 @@
return static_instance;
- inline std::vector<CGMParallelComm*>& get_pc_array() { return pc_array; }
private:
CGMTagManager();
@@ -132,9 +129,6 @@
static const char *CATag_NAME_INTERNAL;
RefGroup *interfaceGroup;
- // list of parallel comm
- std::vector<CGMParallelComm*> pc_array;
bool getPresetTagData(const RefEntity *entity, const long tag_num,
char *tag_value, int &tag_size);
More information about the cgma-dev
