[cgma-dev] r3264 - in cgm/trunk: . m4
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Mon Nov 2 16:23:20 CST 2009
Author: kraftche
Date: 2009-11-02 16:23:19 -0600 (Mon, 02 Nov 2009)
New Revision: 3264
Modified:
   cgm/trunk/configure.ac
   cgm/trunk/m4/acis.m4
   cgm/trunk/m4/boost.m4
   cgm/trunk/m4/compiler.m4
   cgm/trunk/m4/cplusplus.m4
   cgm/trunk/m4/hdf5.m4
   cgm/trunk/m4/makevar.m4
   cgm/trunk/m4/netcdf.m4
Log:
s/SNL_/FATHOM_/ in autoconf macros
Modified: cgm/trunk/configure.ac
--- cgm/trunk/configure.ac	2009-11-02 22:18:42 UTC (rev 3263)
+++ cgm/trunk/configure.ac	2009-11-02 22:23:19 UTC (rev 3264)
@@ -9,13 +9,13 @@
 AC_DISABLE_SHARED
 EXTRA_GNU_FLAGS="-Wall -pipe -pedantic"
-SNL_CHECK_COMPILERS
+FATHOM_CHECK_COMPILERS
 AC_PROG_LIBTOOL
 LIBS="-lm"
 AC_PROG_SED
 AC_C_BIGENDIAN( [LITTLE_ENDIAN=], [LITTLE_ENDIAN=-DLITTLE_ENDIAN=BYTE_ORDER] )
 AC_SUBST(LITTLE_ENDIAN)
-SNL_COMPILER_FLAGS
+FATHOM_COMPILER_FLAGS
 #                Fortran Stuff for ITAPS C bindings
@@ -65,8 +65,8 @@
 #                           CGM-specific Checks
-SNL_CANT_USE_STD
-SNL_TEMPLATE_DEFS_INCLUDED
+FATHOM_CANT_USE_STD
+FATHOM_TEMPLATE_DEFS_INCLUDED
 AC_SUBST(CANT_USE_STD)
 AC_SUBST(CANT_USE_STD_IO)
 AC_SUBST(TEMPLATE_DEFS_INCLUDED)
@@ -209,9 +209,9 @@
                  [AC_MSG_ERROR([ACIS source not present.  Checkout ACIS_SRC and move to ACIS])] )
   if test "$ACIS_DIR" == "yes"; then ACIS_DIR=.; fi
-  SNL_ACIS_ENV
+  FATHOM_ACIS_ENV
-  SNL_ACIS_TRANSLATOR
+  FATHOM_ACIS_TRANSLATOR
   if test x$ACIS_STEP_TRANSLATOR != x; then
     ACIS_LIBS="$ACIS_LIBS $ACIS_STEP_LIBS"
     ACIS_XLIBS="$ACIS_XLATE_LIBS"
Modified: cgm/trunk/m4/acis.m4
--- cgm/trunk/m4/acis.m4	2009-11-02 22:18:42 UTC (rev 3263)
+++ cgm/trunk/m4/acis.m4	2009-11-02 22:23:19 UTC (rev 3264)
@@ -11,7 +11,7 @@
 # If ACIS_VERSION is set, the corresponding test
 # will be skipped.
-AC_DEFUN([SNL_ACIS_ENV], [
+AC_DEFUN([FATHOM_ACIS_ENV], [
 AC_CHECK_FILE([$ACIS_DIR/include/acis.hxx], [], [AC_MSG_ERROR("Invalid ACIS path")])
@@ -32,13 +32,13 @@
     *_debug)
-      SNL_ACIS_LIBDIR( [$dir] )
+      FATHOM_ACIS_LIBDIR( [$dir] )
   esac
     # next try debug libraries
   case "$dir" in
     *_debug)
   esac
 done
@@ -104,8 +104,8 @@
 # Macro to check for ACIS translators.
-AC_DEFUN([SNL_ACIS_TRANSLATOR], [
-AC_REQUIRE([SNL_ACIS_ENV])
+AC_DEFUN([FATHOM_ACIS_TRANSLATOR], [
+AC_REQUIRE([FATHOM_ACIS_ENV])
 case "$ACIS_VERSION" in
   11??)
     ACIS_XLATE_LIBS='-lxacis2k -lxcore2k -lxutil'
@@ -143,7 +143,7 @@
 #  If ACIS_VERSION is alreay set, it will NOT be modified by
 #  this function.
-AC_DEFUN([SNL_ACIS_LIBDIR], [
+AC_DEFUN([FATHOM_ACIS_LIBDIR], [
 AC_REQUIRE([AC_PROG_LIBTOOL])
 AC_LANG_PUSH([C++])
 snl_acis_libdir=$1
@@ -185,4 +185,4 @@
  fi
 ], [snl_acis_link_success=no])
 AC_LANG_POP
-]) # SNL_ACIS_LIBDIR
+]) # FATHOM_ACIS_LIBDIR
Modified: cgm/trunk/m4/boost.m4
--- cgm/trunk/m4/boost.m4	2009-11-02 22:18:42 UTC (rev 3263)
+++ cgm/trunk/m4/boost.m4	2009-11-02 22:23:19 UTC (rev 3264)
@@ -4,9 +4,9 @@
 # Unless user specified --without-boost, will check for any passed headers.
 # For any found headers, -DHAVE_[header] will be added to DEFINES
-AC_DEFUN([SNL_CHECK_BOOST],[
+AC_DEFUN([FATHOM_CHECK_BOOST],[
 AC_MSG_CHECKING([if boost library is enabled])
-SNL_BOOST_OPT_HEADER_LIST="$1"
+FATHOM_BOOST_OPT_HEADER_LIST="$1"
 AC_ARG_WITH(boost,
 [AC_HELP_STRING([--with-boost=DIR], [Specify directory where boost is installed])
 AC_HELP_STRING([--without-boost], [Disable support for boost libraries])],
@@ -27,4 +27,4 @@
   AC_CHECK_HEADERS( [$SNL_BOOST_OPT_HEADER_LIST],[def=`echo "$ac_header" | $as_tr_cpp`; DEFINES="$DEFINES -DHAVE_$def"] )
   AC_LANG_RESTORE
 fi
-]) # SNL_CHECK_BOOST
+]) # FATHOM_CHECK_BOOST
Modified: cgm/trunk/m4/compiler.m4
--- cgm/trunk/m4/compiler.m4	2009-11-02 22:18:42 UTC (rev 3263)
+++ cgm/trunk/m4/compiler.m4	2009-11-02 22:23:19 UTC (rev 3264)
@@ -30,7 +30,7 @@
 #             - test for C++ compiler
 #             - test for Fortran compiler
-AC_DEFUN([SNL_CHECK_COMPILERS], [
+AC_DEFUN([FATHOM_CHECK_COMPILERS], [
 CHECK_CC="$1"
 CHECK_CXX="$2"
@@ -123,7 +123,7 @@
   AC_PROG_F77( [$F77_LIST] )
 fi
-]) # SNL_CHECK_COMPILERS
+]) # FATHOM_CHECK_COMPILERS
@@ -134,14 +134,14 @@
 #  CXXFLAGS - C++ compiler flags
-AC_DEFUN([SNL_COMPILER_FLAGS], [
+AC_DEFUN([FATHOM_COMPILER_FLAGS], [
 if test "xno" != "x$CHECK_CC"; then
-  SNL_CC_FLAGS
+  FATHOM_CC_FLAGS
 fi
 if test "xno" != "x$CHECK_CXX"; then
-  SNL_CXX_FLAGS
+  FATHOM_CXX_FLAGS
 fi
@@ -206,7 +206,7 @@
 fi
   # Check for 32/64 bit.
-  # This requires SNL_CXX_FLAGS and SNL_CC_FLAGS to have been called first
+  # This requires FATHOM_CXX_FLAGS and FATHOM_CC_FLAGS to have been called first
 AC_ARG_ENABLE( 32bit, AC_HELP_STRING([--enable-32bit],[Force 32-bit objects]),
   if test "xyes" != "x$enableval"; then
@@ -220,7 +220,7 @@
   CFLAGS="$CFLAGS $SNL_CC_32BIT"
   enable_32bit=yes
-# This requires SNL_CXX_FLAGS and SNL_CC_FLAGS to have been called first
+# This requires FATHOM_CXX_FLAGS and FATHOM_CC_FLAGS to have been called first
 AC_ARG_ENABLE( 64bit, AC_HELP_STRING([--enable-64bit],[Force 64-bit objects]),
@@ -236,7 +236,7 @@
   CFLAGS="$CFLAGS $SNL_CC_64BIT"
-]) # SNL_COMPILER_FLAGS
+]) # FATHOM_COMPILER_FLAGS
@@ -251,7 +251,7 @@
 #  - action upon success
 #  - action upon failure
-AC_DEFUN([SNL_TRY_COMPILER_DEFINE], [
+AC_DEFUN([FATHOM_TRY_COMPILER_DEFINE], [
  AC_COMPILE_IFELSE([
  AC_LANG_PROGRAM( [[#ifndef $1
    choke me
@@ -263,11 +263,11 @@
 # Check for compiler-specific flags.
 # Sets the following environmental variables:
-#   SNL_CXX_SPECIAL : Any compiler-specific flags which must be specified
-#   SNL_CXX_32BIT   : Flag to force compilation of 32-bit code
-#   SNL_CXX_64BIT   : Flag to force compilation of 64-bit code
+#   FATHOM_CXX_SPECIAL : Any compiler-specific flags which must be specified
+#   FATHOM_CXX_32BIT   : Flag to force compilation of 32-bit code
+#   FATHOM_CXX_64BIT   : Flag to force compilation of 64-bit code
-AC_DEFUN([SNL_CXX_FLAGS], [
+AC_DEFUN([FATHOM_CXX_FLAGS], [
 AC_LANG_PUSH([C++])
 # Detect compiler
@@ -276,41 +276,41 @@
 if test x$GXX = xyes; then
   cxx_compiler=GNU
   # Intel claims to be GCC, check for it here
-  SNL_TRY_COMPILER_DEFINE([__INTEL_COMPILER],[cxx_compiler=Intel])
+  FATHOM_TRY_COMPILER_DEFINE([__INTEL_COMPILER],[cxx_compiler=Intel])
 # Search for other compiler types
 # For efficiency, limit checks to relevant OSs
 else
   cxx_compiler=unknown
   case "$target_os" in
     aix*)
-      SNL_TRY_COMPILER_DEFINE([__IBMCPP__],[cxx_compiler=VisualAge])
+      FATHOM_TRY_COMPILER_DEFINE([__IBMCPP__],[cxx_compiler=VisualAge])
     solaris*|sunos*)
-      SNL_TRY_COMPILER_DEFINE([__SUNPRO_CC],[cxx_compiler=SunWorkshop])
+      FATHOM_TRY_COMPILER_DEFINE([__SUNPRO_CC],[cxx_compiler=SunWorkshop])
     irix*)
-      SNL_TRY_COMPILER_DEFINE([__sgi],[cxx_compiler=MIPSpro])
+      FATHOM_TRY_COMPILER_DEFINE([__sgi],[cxx_compiler=MIPSpro])
     linux*)
-      SNL_TRY_COMPILER_DEFINE([__DECCXX_VER],[cxx_compiler=Compaq])
-      SNL_TRY_COMPILER_DEFINE([__PGI],[cxx_cmopiler=PortlandGroup])
+      FATHOM_TRY_COMPILER_DEFINE([__DECCXX_VER],[cxx_compiler=Compaq])
+      FATHOM_TRY_COMPILER_DEFINE([__PGI],[cxx_cmopiler=PortlandGroup])
     hpux*)
-      SNL_TRY_COMPILER_DEFINE([__HP_aCC],[cxx_compiler=HP])
+      FATHOM_TRY_COMPILER_DEFINE([__HP_aCC],[cxx_compiler=HP])
     windows*)
-      SNL_TRY_COMPILER_DEFINE([__MSC_VER],[cxx_compiler=VisualStudio])
-      SNL_TRY_COMPILER_DEFINE([__BORLANDC__],[cxx_compiler=Borland])
-      SNL_TRY_COMPILER_DEFINE([__CYGWIN__],[cxx_compiler=Cygwin])
-      SNL_TRY_COMPILER_DEFINE([__MINGW32__],[cxx_compiler=MinGW])
+      FATHOM_TRY_COMPILER_DEFINE([__MSC_VER],[cxx_compiler=VisualStudio])
+      FATHOM_TRY_COMPILER_DEFINE([__BORLANDC__],[cxx_compiler=Borland])
+      FATHOM_TRY_COMPILER_DEFINE([__CYGWIN__],[cxx_compiler=Cygwin])
+      FATHOM_TRY_COMPILER_DEFINE([__MINGW32__],[cxx_compiler=MinGW])
-      SNL_TRY_COMPILER_DEFINE([__PGI],[cc_cmopiler=PortlandGroup])
+      FATHOM_TRY_COMPILER_DEFINE([__PGI],[cc_cmopiler=PortlandGroup])
   esac
 fi
@@ -325,80 +325,80 @@
 AC_MSG_CHECKING([for known compiler/OS combinations])
 case "$cxx_compiler:$host_cpu" in
   GNU:sparc*)
-    SNL_CXX_32BIT=-m32
-    SNL_CXX_64BIT=-m64
-    SNL_CXX_SPECIAL="$EXTRA_GNU_FLAGS"
+    FATHOM_CXX_32BIT=-m32
+    FATHOM_CXX_64BIT=-m64
+    FATHOM_CXX_SPECIAL="$EXTRA_GNU_FLAGS"
   GNU:powerpc*)
   GNU:i?86|GNU:x86_64)
   GNU:mips*)
-    SNL_CXX_32BIT="-mips32 -mabi=32"
-    SNL_CXX_64BIT="-mips64 -mabi=64"
+    FATHOM_CXX_32BIT="-mips32 -mabi=32"
+    FATHOM_CXX_64BIT="-mips64 -mabi=64"
   GNU:*)
   Intel:*)
-    SNL_CXX_SPECIAL="$EXTRA_GNU_FLAGS -wd981 -wd383"
+    FATHOM_CXX_SPECIAL="$EXTRA_GNU_FLAGS -wd981 -wd383"
   VisualAge:*)
-    SNL_CXX_32BIT=-q32
-    SNL_CXX_64BIT=-q64
+    FATHOM_CXX_32BIT=-q32
+    FATHOM_CXX_64BIT=-q64
     # Do V5.0 namemangling for compatibility with ACIS, and enable RTTI
     case "$target_vendor" in
       bgp)
-        SNL_CXX_SPECIAL=""
+        FATHOM_CXX_SPECIAL=""
         AR="ar"
         NM="nm -B"
-        SNL_CXX_SPECIAL="-qrtti=all -qnamemangling=v5"
+        FATHOM_CXX_SPECIAL="-qrtti=all -qnamemangling=v5"
         AR="ar"
         NM="nm -B -X 32_64"
     esac
   MIPSpro:mips)
-    SNL_CXX_32BIT=-n32
-    SNL_CXX_64BIT=-64
-    SNL_CXX_SPECIAL=-LANG:std
+    FATHOM_CXX_32BIT=-n32
+    FATHOM_CXX_64BIT=-64
+    FATHOM_CXX_SPECIAL=-LANG:std
   MIPSpro:*)
   SunWorkshop:sparc*)
-    SNL_CXX_32BIT=-xarch=generic
-    SNL_CXX_64BIT=-xarch=generic64
+    FATHOM_CXX_32BIT=-xarch=generic
+    FATHOM_CXX_64BIT=-xarch=generic64
   SunWorkshop:i?86|SunWorkshop:x86_64)
 esac
 AC_MSG_RESULT([$cxx_compiler:$host_cpu])
-]) # end SNL_CXX_FLAGS
+]) # end FATHOM_CXX_FLAGS
-#   SNL_CC_SPECIAL : Any compiler-specific flags which must be specified
-#   SNL_CC_32BIT   : Flag to force compilation of 32-bit code
-#   SNL_CC_64BIT   : Flag to force compilation of 64-bit code
+#   FATHOM_CC_SPECIAL : Any compiler-specific flags which must be specified
+#   FATHOM_CC_32BIT   : Flag to force compilation of 32-bit code
+#   FATHOM_CC_64BIT   : Flag to force compilation of 64-bit code
-AC_DEFUN([SNL_CC_FLAGS], [
+AC_DEFUN([FATHOM_CC_FLAGS], [
 AC_LANG_PUSH([C])
 # Detect compiler
@@ -408,42 +408,42 @@
 if test x$GCC = xyes; then
   cc_compiler=GNU
-  SNL_TRY_COMPILER_DEFINE([__INTEL_COMPILER],[cc_compiler=Intel])
+  FATHOM_TRY_COMPILER_DEFINE([__INTEL_COMPILER],[cc_compiler=Intel])
 else
   cc_compiler=unknown
     aix*)
-      SNL_TRY_COMPILER_DEFINE([__IBMC__],[cc_compiler=VisualAge])
+      FATHOM_TRY_COMPILER_DEFINE([__IBMC__],[cc_compiler=VisualAge])
     solaris*|sunos*)
-      SNL_TRY_COMPILER_DEFINE([__SUNPRO_C],[cc_compiler=SunWorkshop])
+      FATHOM_TRY_COMPILER_DEFINE([__SUNPRO_C],[cc_compiler=SunWorkshop])
     irix*)
-      SNL_TRY_COMPILER_DEFINE([__sgi],[cc_compiler=MIPSpro])
+      FATHOM_TRY_COMPILER_DEFINE([__sgi],[cc_compiler=MIPSpro])
     linux*)
-      SNL_TRY_COMPILER_DEFINE([__DECC_VER],[cc_compiler=Compaq])
+      FATHOM_TRY_COMPILER_DEFINE([__DECC_VER],[cc_compiler=Compaq])
     hpux*)
-      SNL_TRY_COMPILER_DEFINE([__HP_cc],[cc_compiler=HP])
+      FATHOM_TRY_COMPILER_DEFINE([__HP_cc],[cc_compiler=HP])
     windows*)
-      SNL_TRY_COMPILER_DEFINE([__MSC_VER],[cc_compiler=VisualStudio])
-      SNL_TRY_COMPILER_DEFINE([__BORLANDC__],[cc_compiler=Borland])
-      SNL_TRY_COMPILER_DEFINE([__TURBOC__],[cc_compiler=TurboC])
-      SNL_TRY_COMPILER_DEFINE([__CYGWIN__],[cc_compiler=Cygwin])
-      SNL_TRY_COMPILER_DEFINE([__MINGW32__],[cc_compiler=MinGW])
+      FATHOM_TRY_COMPILER_DEFINE([__MSC_VER],[cc_compiler=VisualStudio])
+      FATHOM_TRY_COMPILER_DEFINE([__BORLANDC__],[cc_compiler=Borland])
+      FATHOM_TRY_COMPILER_DEFINE([__TURBOC__],[cc_compiler=TurboC])
+      FATHOM_TRY_COMPILER_DEFINE([__CYGWIN__],[cc_compiler=Cygwin])
+      FATHOM_TRY_COMPILER_DEFINE([__MINGW32__],[cc_compiler=MinGW])
   esac
 fi
@@ -457,67 +457,67 @@
 case "$cc_compiler:$host_cpu" in
   GNU:sparc*)
-    SNL_CC_32BIT=-m32
-    SNL_CC_64BIT=-m64
-    SNL_CC_SPECIAL="$EXTRA_GNU_FLAGS"
+    FATHOM_CC_32BIT=-m32
+    FATHOM_CC_64BIT=-m64
+    FATHOM_CC_SPECIAL="$EXTRA_GNU_FLAGS"
   GNU:powerpc*)
-    SNL_CC_32BIT=-m32
-    SNL_CC_64BIT=-m64
-    SNL_CC_32BIT=-m32
-    SNL_CC_64BIT=-m64
   Intel:*)
-    SNL_CC_32BIT=-m32
-    SNL_CC_64BIT=-m64
-    SNL_CC_SPECIAL="$EXTRA_GNU_FLAGS -wd981 -wd383"
+    FATHOM_CC_SPECIAL="$EXTRA_GNU_FLAGS -wd981 -wd383"
   GNU:mips*)
-    SNL_CC_32BIT="-mips32 -mabi=32"
-    SNL_CC_64BIT="-mips64 -mabi=64"
+    FATHOM_CC_32BIT="-mips32 -mabi=32"
+    FATHOM_CC_64BIT="-mips64 -mabi=64"
   GNU:*)
   VisualAge:*)
       bgp)
-        SNL_CC_32BIT=-q32
-        SNL_CC_64BIT=-q64
+        FATHOM_CC_32BIT=-q32
+        FATHOM_CC_64BIT=-q64
         AR="ar"
         NM="nm -B"
-        SNL_CC_32BIT=-q32
-        SNL_CC_64BIT=-q64
         AR="ar -X 32_64"
         NM="nm -B -X 32_64"
     esac
   MIPSpro:mips)
-    SNL_CC_32BIT=-n32
-    SNL_CC_64BIT=-64
-    SNL_CC_SPECIAL=-LANG:std
+    FATHOM_CC_32BIT=-n32
+    FATHOM_CC_64BIT=-64
+    FATHOM_CC_SPECIAL=-LANG:std
   MIPSpro:*)
   SunWorkshop:sparc*)
-    SNL_CC_32BIT=-xarch=generic
-    SNL_CC_64BIT=-xarch=generic64
+    FATHOM_CC_32BIT=-xarch=generic
+    FATHOM_CC_64BIT=-xarch=generic64
-    SNL_CC_32BIT=-m32
-    SNL_CC_64BIT=-m64
 esac
 AC_MSG_RESULT([$cc_compiler:$host_cpu])
-]) # end SNL_CC_FLAGS
+]) # end FATHOM_CC_FLAGS
Modified: cgm/trunk/m4/cplusplus.m4
--- cgm/trunk/m4/cplusplus.m4	2009-11-02 22:18:42 UTC (rev 3263)
+++ cgm/trunk/m4/cplusplus.m4	2009-11-02 22:23:19 UTC (rev 3264)
@@ -44,7 +44,7 @@
 #      exist or do not define symbols to be in the "std" namespace.
 #      For example: if this is defined, #include <iostrea.h> rather than <iostream>
-AC_DEFUN([SNL_CANT_USE_STD], [
+AC_DEFUN([FATHOM_CANT_USE_STD], [
 AC_CACHE_CHECK([for C++-standard library in std:: namespace],
                [snl_cv_cxx_stl_in_std],
@@ -85,7 +85,7 @@
   CANT_USE_STD_IO=
 fi
-]) # SNL_CANT_USE_STD
+]) # FATHOM_CANT_USE_STD
@@ -95,7 +95,7 @@
 # included (in the .hpp files).
 # Sets TEMPLATE_DEFS_INCLUDED=-DTEMPLATE_DEFS_INCLUDED
-AC_DEFUN([SNL_TEMPLATE_DEFS_INCLUDED], [
+AC_DEFUN([FATHOM_TEMPLATE_DEFS_INCLUDED], [
 AC_CACHE_CHECK([if C++ template definitions should be included],
                [snl_cv_cxx_template_defs_included],
@@ -125,13 +125,13 @@
 fi
-]) # SNL_TEMPLATE_DEFS_INCLUDED
+]) # FATHOM_TEMPLATE_DEFS_INCLUDED
 # Check if compiler supports template class specialization.
 # Sets TEMPLATE_SPECIALIZATION=-DTEMPLATE_SPECIALIZATION
-AC_DEFUN([SNL_TEMPLATE_SPECIALIZATION], [
+AC_DEFUN([FATHOM_TEMPLATE_SPECIALIZATION], [
 AC_CACHE_CHECK([if C++ compiler supports template class specialization],
                [snl_cv_template_specialization],
                [AC_LANG_SAVE
@@ -148,13 +148,13 @@
 fi
-]) # SNL_TEMPLATE_SPECIALIZATION
+]) # FATHOM_TEMPLATE_SPECIALIZATION
 # Check if compiler supports template function specialization.
 # Sets TEMPLATE_FUNC_SPECIALIZATION=-DTEMPLATE_FUNC_SPECIALIZATION
-AC_DEFUN([SNL_TEMPLATE_FUNC_SPECIALIZATION], [
+AC_DEFUN([FATHOM_TEMPLATE_FUNC_SPECIALIZATION], [
 AC_CACHE_CHECK([if C++ compiler supports template function specialization],
                [snl_cv_template_func_specialization],
                [AC_LANG_SAVE
@@ -172,4 +172,4 @@
 fi
-]) # SNL_TEMPLATE_FUNC_SPECIALIZATION
+]) # FATHOM_TEMPLATE_FUNC_SPECIALIZATION
Modified: cgm/trunk/m4/hdf5.m4
--- cgm/trunk/m4/hdf5.m4	2009-11-02 22:18:42 UTC (rev 3263)
+++ cgm/trunk/m4/hdf5.m4	2009-11-02 22:23:19 UTC (rev 3264)
@@ -6,7 +6,7 @@
 #  HDF5_LDFLAGS
 #  HDF5_LIBS
-AC_DEFUN([SNL_CHECK_HDF5],[
+AC_DEFUN([FATHOM_CHECK_HDF5],[
   # CLI option for linking zlib
 AC_ARG_WITH(zlib,
@@ -184,4 +184,4 @@
 fi
-]) # SNL_CHECK_HDF5
+]) # FATHOM_CHECK_HDF5
Modified: cgm/trunk/m4/makevar.m4
--- cgm/trunk/m4/makevar.m4	2009-11-02 22:18:42 UTC (rev 3263)
+++ cgm/trunk/m4/makevar.m4	2009-11-02 22:23:19 UTC (rev 3264)
@@ -7,7 +7,7 @@
 #         of the variable)
 #   - Action on failure
-AC_DEFUN([SNL_MAKE_INC_VAR], [
+AC_DEFUN([FATHOM_MAKE_INC_VAR], [
 make_val=
 snl_makefile="snl_check.mak"
 rm -f $snl_makefile
@@ -16,12 +16,12 @@
   AC_MSG_WARN([File not found: $1])
   $4
 else
-cat >$snl_makefile <<SNL_END_OF_MAKEFILE
+cat >$snl_makefile <<FATHOM_END_OF_MAKEFILE
 default:
 	@echo "\$($2)"
 include $1
-SNL_END_OF_MAKEFILE
+FATHOM_END_OF_MAKEFILE
 if make -f $snl_makefile > /dev/null 2>&1; then
   make_val=`make -s -f $snl_makefile`
   rm -f $snl_makefile
Modified: cgm/trunk/m4/netcdf.m4
--- cgm/trunk/m4/netcdf.m4	2009-11-02 22:18:42 UTC (rev 3263)
+++ cgm/trunk/m4/netcdf.m4	2009-11-02 22:23:19 UTC (rev 3264)
@@ -6,7 +6,7 @@
 #   NETCDF_LDFLAGS
 #   NETCDF_LIBS
-AC_DEFUN([SNL_CHECK_NETCDF],[
+AC_DEFUN([FATHOM_CHECK_NETCDF],[
 AC_MSG_CHECKING([if NetCDF support is enabled])
 AC_ARG_WITH(netcdf,
@@ -110,4 +110,4 @@
   fi
 fi
-]) # SNL_HAVE_NETCDF
+]) # FATHOM_HAVE_NETCDF
More information about the cgma-dev mailing list
