[cgma-dev] [MOAB-dev] Problems with ReadCGM
    Tim Tautges
    tautges at mcs.anl.gov
    Mon Oct 26 22:07:24 CDT 2009
This might be related to calling the wrong overloaded function in CGM, for get_graphics or something related to it.
Could you run the cubit-based code under gdb, stop in GeometryQueryEngine::get_graphics (all instances, if multiple),
and print a stack trace?  That would help determine which variants are being called on the way down to the function.
- tim
Steve Jackson wrote:
> I have an issue with ReadCGM that's been puzzling me for a couple of
> days.  Perhaps someone on this list can help me determine the problem.
> Below is a simple program that loads an acis .sat geometry into MOAB.
> When MOAB is compiled with an acis-based CGM, the code below works
> fine.  However, when MOAB is compiled against a cubit-based CGM, the
> code below fails.
>> #include "MBCore.hpp"
>> #include <iostream>
>> int main(){
>>   MBErrorCode rval;
>>   MBEntityHandle file_set;
>>   MBCore* MBI = new MBCore();
>>   rval = MBI->load_file("geom.sat", file_set, "", NULL, 0, 0);
>>   if (MB_SUCCESS != rval) {
>>     std::cerr << "Couldn't read file. " << std::endl;
>>     return rval;
>>   return 0;
> The initial failure occurs in ReadCGM::load_file, at line 393 of
> ReadCGM.cpp.  The first call to gqe->get_graphics() produces an error
> message (below) and returns failure.  This in turn causes
> ReadCGM::load_file() to fail.
> The error message produced within the get_graphics() call is:
>> ERROR: In AcisQueryEngine::get_Body
>>        Body is not a BodyACIS.
> Note that get_graphics() is being called with a Curve object, not a Body.
> The error happens predictably and seems to occur with any .sat file I
> provide.  My CGM is built against Cubit 10.22, and MOAB is the latest
> revision from SVN.  I also tried compiling MOAB with svn revision 3005,
> just before the last major revision to ReadCGM.cpp, but got the same error.
> Has anyone encountered this issue before?
> Thanks,
> ~S
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the cgma-dev
