[cgma-dev] Finding ACIS in Cubit
    Tim Tautges
    tautges at mcs.anl.gov
    Mon Oct 19 17:53:29 CDT 2009
Note that if you use the CGM_LIBS_LINK make variable from cgm.make (or IGEOM_LIBS from iGeom-Defs.inc), you'll pull in
the right libraries to resolve what's in CGM or iGeom.
- tim
Jason Kraftcheck wrote:
> Jed Brown wrote:
>> Jed Brown wrote:
>>> After fixing my CC, the build completes (very quickly) with no errors
>> In fact, it builds nothing except libcgma_init and libiGeom.  Autotools
>> are still opaque to me, everything in geom/.deps/*.Plo has just one line
>>   # dummy
>> where as init/.deps/InitCGMA.Plo and itaps/.deps/*.Plo has correct
>> dependencies.  Any ideas what is causing this?  The treatment looks the
>> same in Makefile.in so I'm suspicious of configure.
> When building with libcubit, the correct behavior is to build almost
> nothing.  The cubit library already contains most of CGM.  The CGM build
> just provides the headers an a bit of initialization code (and stuff
> like the iGeom API.)
> - jason
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the cgma-dev
