[cgma-dev] Finding ACIS in Cubit
Jed Brown jed at 59A2.org
Mon Oct 19 13:03:47 CDT 2009
Jason Kraftcheck wrote:
> I see that in this output the script is no longer trying to use libtool,
> which is a start.  I'm still unsure why the link is failing.  If you
> compile the following (just compile, not link: g++ -c ...):
> class AcisQueryEngine { public: static AcisQueryEngine* instance_; };
> int main()
>   AcisQueryEngine::instance_ = 0;
>   return 0;
> and then run "nm main.o | fgrep instance_".  Is it the same mangled name
> as you see the Cubit library?
$ cat > acis.C
int main()
 return 0;
$ g++ -c acis.C
$ nm acis.o
                 U _ZN15AcisQueryEngine9instance_E
                 U __gxx_personality_v0
0000000000000000 T main
$ nm -D /home/jed/usr/cubit-20091014/bin/libcubiti19.so |grep AcisQueryEngine.*instance_
0000000001da4148 D _ZN15AcisQueryEngine9instance_E
They match.
Jed
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20091019/9fe8fce0/attachment.pgp>
More information about the cgma-dev mailing list
