[cgma-dev] Finding ACIS in Cubit
Jason Kraftcheck kraftche at cae.wisc.edu
Mon Oct 19 11:11:23 CDT 2009
Jed Brown wrote:
> I finally have Cubit, but CGM is not picking it up due to what looks
> like C++ name mangling issues.
> checking for AcisQueryEngine::instance_ in /home/jed/usr/cubit-20091014/bin/libcubiti19.so... no
> configure: error: "Cubit library not found in /home/jed/usr/cubit-20091014/bin"
> But I have:
> $ nm -D /home/jed/usr/cubit-20091014/bin/libcubiti19.so |grep 'AcisQueryEngine.*instance'
> 0000000001da4148 D _ZN15AcisQueryEngine9instance_E
> Is this unrecoverable due to Cubit being compiled with a different C++
> ABI?  (Cubit required libg2c.so which means it may have been built with
> a GCC-3 series compiler, despite being almost five years old now.)  I
> know you guys are using more recent compilers, so hopefully this can be
> made to work.
I don't think there have been any significant changes to the C++ ABI for
g++ since 3.3.  Would you mind sending the config.log file for the
failing run of the configure script?
- jason
More information about the cgma-dev mailing list
