[cgma-dev] r3210 - in cgm/trunk: itaps test
tautges at mcs.anl.gov
Sun Oct 18 14:55:17 CDT 2009
Author: tautges
Date: 2009-10-18 14:55:17 -0500 (Sun, 18 Oct 2009)
New Revision: 3210
Modified:
cgm/trunk/itaps/Makefile.am
cgm/trunk/test/brick.cpp
cgm/trunk/test/sheet.cpp
cgm/trunk/test/webcut.cpp
Log:
Updating cgm init process in tests; better reference to .la file in itaps
build.
Modified: cgm/trunk/itaps/Makefile.am
--- cgm/trunk/itaps/Makefile.am 2009-10-16 16:44:15 UTC (rev 3209)
+++ cgm/trunk/itaps/Makefile.am 2009-10-18 19:55:17 UTC (rev 3210)
@@ -35,7 +35,7 @@
libiGeom_la_includedir = $(includedir)
-libiGeom_la_LIBADD = ../libcgm.la
+libiGeom_la_LIBADD = $(top_builddir)/libcgm.la
INCLUDES = -I$(top_srcdir)/util \
-I$(top_srcdir)/geom \
Modified: cgm/trunk/test/brick.cpp
--- cgm/trunk/test/brick.cpp 2009-10-16 16:44:15 UTC (rev 3209)
+++ cgm/trunk/test/brick.cpp 2009-10-18 19:55:17 UTC (rev 3210)
@@ -8,16 +8,8 @@
#include "AppUtil.hpp"
#include "Loop.hpp"
#include "CoEdge.hpp"
+#include "InitCGMA.hpp"
-#ifdef HAVE_OCC
-# include "OCCQueryEngine.hpp"
-# include "OCCModifyEngine.hpp"
-#endif
-#ifdef HAVE_ACIS
-# include "AcisQueryEngine.hpp"
-# include "AcisModifyEngine.hpp"
-#endif
#include <assert.h>
#include <algorithm>
@@ -35,17 +27,8 @@
int main( int argc, char* argv[] )
// Start up CGM
- AppUtil::instance()->startup(argc, argv);
- CGMApp::instance()->startup(argc, argv);
- CubitObserver::init_static_observers();
-#ifdef HAVE_OCC
- OCCQueryEngine::instance();
- OCCModifyEngine::instance();
-#endif
-#ifdef HAVE_ACIS
- AcisQueryEngine::instance();
- AcisModifyEngine::instance();
-#endif
+ CubitStatus result = InitCGMA::initialize_cgma();
+ if (CUBIT_SUCCESS != result) return 1;
// Create a brick
Body* brick = GeometryModifyTool::instance()->brick( 2, 2, 2 );
Modified: cgm/trunk/test/sheet.cpp
--- cgm/trunk/test/sheet.cpp 2009-10-16 16:44:15 UTC (rev 3209)
+++ cgm/trunk/test/sheet.cpp 2009-10-18 19:55:17 UTC (rev 3210)
@@ -14,20 +14,11 @@
#include "RefFace.hpp"
#include "CubitObserver.hpp"
+#include "DLIList.hpp"
#include <typeinfo>
#include <assert.h>
-#ifdef HAVE_ACIS
-//#include "AcisModifyEngine.hpp"
-//#include "AcisQueryEngine.hpp"
-#endif
-#ifdef HAVE_OCC
-#include "OCCModifyEngine.hpp"
-#include "OCCQueryEngine.hpp"
-#endif
int test_sheet_query( GeometryModifyEngine* engine );
// main program - initialize, then send to proper function
@@ -36,18 +27,11 @@
- GeometryModifyEngine* const gme_list[] = {
-#ifdef HAVE_ACIS
-// AcisModifyEngine::instance(),
-#endif
-#ifdef HAVE_OCC
-// OCCModifyEngine::instance(),
-#endif
- NULL
+ DLIList<GeometryModifyEngine*> gme_list;
+ GeometryModifyTool::instance()->get_gme_list(gme_list);
int exit_val = 0;
- for (int i = 0; gme_list[i]; ++i)
+ for (int i = 0; i < gme_list.size(); ++i)
exit_val += test_sheet_query( gme_list[i] );
return exit_val;
@@ -56,9 +40,6 @@
-// CubitStatus rval = GeometryModifyTool::instance()->set_default_gme( engine );
-// assert(rval);
Body *sphere = 0, *sheet = 0;
sphere = GeometryModifyTool::instance()->sphere( 1.0 );
Modified: cgm/trunk/test/webcut.cpp
--- cgm/trunk/test/webcut.cpp 2009-10-16 16:44:15 UTC (rev 3209)
+++ cgm/trunk/test/webcut.cpp 2009-10-18 19:55:17 UTC (rev 3210)
@@ -13,7 +13,6 @@
#include "CpuTimer.hpp"
#include "GeometryModifyTool.hpp"
#include "GeometryQueryTool.hpp"
-#include "AcisQueryEngine.hpp"
#include "MergeTool.hpp"
#include "CubitUtil.hpp"
#include "CubitMessage.hpp"
@@ -26,11 +25,10 @@
#include "RefVertex.hpp"
#include "CastTo.hpp"
-#include "AcisModifyEngine.hpp"
#include "RefEntityFactory.hpp"
#include "RefEdge.hpp"
#define STRINGIFY(S) XSTRINGIFY(S)
#define XSTRINGIFY(S) #S
@@ -59,25 +57,11 @@
int main (int argc, char **argv)
- // Initialize the GeometryTool
- CGMApp::instance()->startup( argc, argv );
- GeometryQueryTool::instance();
- // If there aren't any file arguments, print usage and exit
- //if (argc == 1) {
- // PRINT_INFO("Usage: mergechk <geom_file> [<geom_file> ...]\n");
- // exit(0);
CubitStatus status = CUBIT_SUCCESS;
//Do brick webcut.
status = webcut_with_brick();
status = webcut_with_cylinder();
More information about the cgma-dev
