[cgma-dev] r3204 - cgm/trunk/itaps
jvporter at wisc.edu
Wed Oct 14 15:27:43 CDT 2009
Author: jvporter
Date: 2009-10-14 15:27:42 -0500 (Wed, 14 Oct 2009)
New Revision: 3204
Modified:
cgm/trunk/itaps/iGeom_CGMA.cc
Log:
Add support for iGeom_get(Ent|Arr)UToUV
Modified: cgm/trunk/itaps/iGeom_CGMA.cc
--- cgm/trunk/itaps/iGeom_CGMA.cc 2009-10-14 19:00:07 UTC (rev 3203)
+++ cgm/trunk/itaps/iGeom_CGMA.cc 2009-10-14 20:27:42 UTC (rev 3204)
@@ -4501,9 +4501,28 @@
/*out*/ double* v,
int* err)
- RETURN(iBase_NOT_SUPPORTED);
+ RefEdge* edge = dynamic_cast<RefEdge*>((RefEntity*)edge_handle);
+ RefFace* face = dynamic_cast<RefFace*>((RefEntity*)face_handle);
+ if (!edge || !face) {
+ RETURN(iBase_INVALID_ENTITY_TYPE);
+ CubitVector xyz;
+ CubitStatus s;
+ s = edge->position_from_u( in_u, xyz );
+ if (s != CUBIT_SUCCESS)
+ RETURN(iBase_FAILURE);
+ s = face->u_v_from_position( xyz, *u, *v );
+ RETURN( (s == CUBIT_SUCCESS ? iBase_SUCCESS : iBase_FAILURE) );
+static bool
+iGeom_check_array_size(int size1, int size2)
+ return size1 == 1 || size2 == 1 || size1 == size2;
void
iGeom_getArrUtoUV (iGeom_Instance instance,
/*in*/ iBase_EntityHandle const *edge_handles,
@@ -4518,9 +4537,65 @@
int *uv_size,
int* err)
+ int count;
+ size_t edge_step, face_step, coord_step, in_u_step;
+ if (!(iGeom_check_array_size(edge_handles_size, face_handles_size) &&
+ iGeom_check_array_size(edge_handles_size, in_u_size) &&
+ iGeom_check_array_size(face_handles_size, in_u_size))) {
+ ERROR(iBase_INVALID_ENTITY_COUNT, "Mismatched input array sizes.");
+ edge_step = (edge_handles_size == 1) ? 0:1;
+ face_step = (face_handles_size == 1) ? 0:1;
+ in_u_step = (in_u_size == 1) ? 0:1;
+ count = std::max(edge_handles_size, std::max(face_handles_size, in_u_size));
+ CHECK_SIZE( *uv, double, 2*count );
+ const double *in_u_iter;
+ double *u, *v;
+ in_u_iter = in_u;
+ u = *uv;
+ if (storage_order == iBase_BLOCKED) {
+ v = u + count;
+ coord_step = 1;
+ else {
+ v = u + 1;
+ coord_step = 2;
+ iBase_ErrorType result = iBase_SUCCESS;
+ RefEntity** edge_ent = (RefEntity**)edge_handles;
+ RefEntity** face_ent = (RefEntity**)face_handles;
+ for (int i = 0; i < count; ++i) {
+ RefEdge* edge = dynamic_cast<RefEdge*>(*edge_ent);
+ RefFace* face = dynamic_cast<RefFace*>(*face_ent);
+ CubitVector xyz;
+ CubitStatus s;
+ s = edge->position_from_u( *in_u_iter, xyz );
+ if (CUBIT_SUCCESS != s)
+ result = iBase_FAILURE;
+ edge_ent += edge_step;
+ face_ent += face_step;
+ in_u_iter += in_u_step;
+ u += coord_step;
+ v += coord_step;
+ RETURN(result);
void
iGeom_getVtxToUV (iGeom_Instance instance,
/*in*/ iBase_EntityHandle vertex_handle,
More information about the cgma-dev
