[cgma-dev] r3201 - cgm/trunk/itaps
jvporter at wisc.edu
Mon Oct 12 16:48:56 CDT 2009
Author: jvporter
Date: 2009-10-12 16:48:56 -0500 (Mon, 12 Oct 2009)
New Revision: 3201
Modified:
cgm/trunk/itaps/iGeom_CGMA.cc
Log:
Fix iGeom_getNumOfType when type is iBase_ALL_TYPES
Modified: cgm/trunk/itaps/iGeom_CGMA.cc
--- cgm/trunk/itaps/iGeom_CGMA.cc 2009-10-12 19:06:45 UTC (rev 3200)
+++ cgm/trunk/itaps/iGeom_CGMA.cc 2009-10-12 21:48:56 UTC (rev 3201)
@@ -849,8 +849,18 @@
if (NULL == dim_entities) dim_entities = new DLIList<RefEntity*>();
dim_entities->clean_out();
if (0 == this_set) {
- RefEntityFactory::instance()->ref_entity_list(iGeom_entity_type_names[gentity_type],
- *dim_entities, CUBIT_FALSE);
+ if (gentity_type == iBase_ALL_TYPES) {
+ for (int i = 0; i < 4; i++) {
+ static DLIList<RefEntity*> temp_entities;
+ RefEntityFactory::instance()->ref_entity_list(iGeom_entity_type_names[i],
+ temp_entities, CUBIT_FALSE);
+ *dim_entities += temp_entities;
+ else {
+ RefEntityFactory::instance()->ref_entity_list(iGeom_entity_type_names[gentity_type],
+ *dim_entities, CUBIT_FALSE);
else {
static DLIList<CubitEntity*> centities;
@@ -859,16 +869,21 @@
entities.clean_out();
const_cast<RefGroup*>(this_set)->get_child_entities(centities);
CAST_LIST(centities, entities, RefEntity);
- entities.reset();
- int num_ents = entities.size();
- for (int i = 0; i < num_ents; i++) {
- if (entities.get()->dimension() == gentity_type)
- dim_entities->append(entities.get_and_step());
- else
- entities.step();
+ if (gentity_type == 4) {
+ *dim_entities += entities;
+ else {
+ entities.reset();
+ int num_ents = entities.size();
+ for (int i = 0; i < num_ents; i++) {
+ if (entities.get()->dimension() == gentity_type)
+ dim_entities->append(entities.get_and_step());
+ else
+ entities.step();
*count = dim_entities->size();
RETURN (iBase_SUCCESS);
More information about the cgma-dev
