[cgma-dev] r3198 - cgm/trunk/geom/OCC
kraftche at cae.wisc.edu
Mon Oct 12 14:05:31 CDT 2009
Author: kraftche
Date: 2009-10-12 14:05:29 -0500 (Mon, 12 Oct 2009)
New Revision: 3198
Removed:
cgm/trunk/geom/OCC/OCCParamTool.cpp
cgm/trunk/geom/OCC/OCCParamTool.hpp
Modified:
cgm/trunk/geom/OCC/Makefile.am
Log:
remove unused code that depends on Cholla stuff (and is probably an artifact of the original OCC port using FacetGeometryEngine as a template)
Modified: cgm/trunk/geom/OCC/Makefile.am
--- cgm/trunk/geom/OCC/Makefile.am 2009-10-11 06:04:10 UTC (rev 3197)
+++ cgm/trunk/geom/OCC/Makefile.am 2009-10-12 19:05:29 UTC (rev 3198)
@@ -29,7 +29,6 @@
OCCLoop.cpp \
OCCLump.cpp \
OCCModifyEngine.cpp \
- OCCParamTool.cpp \
OCCPoint.cpp \
OCCQueryEngine.cpp \
OCCShell.cpp \
@@ -49,7 +48,6 @@
OCCLoop.hpp \
OCCLump.hpp \
OCCModifyEngine.hpp \
- OCCParamTool.hpp \
OCCPoint.hpp \
OCCQueryEngine.hpp \
OCCShell.hpp \
Deleted: cgm/trunk/geom/OCC/OCCParamTool.cpp
--- cgm/trunk/geom/OCC/OCCParamTool.cpp 2009-10-11 06:04:10 UTC (rev 3197)
+++ cgm/trunk/geom/OCC/OCCParamTool.cpp 2009-10-12 19:05:29 UTC (rev 3198)
@@ -1,441 +0,0 @@
-// File: OCCParamTool.cpp
-// Descripiton: interface for 3D-2D parameterization algorithms
-#include "OCCParamTool.hpp"
-#include "CastTo.hpp"
-#include "Surface.hpp"
-#include "OCCSurface.hpp"
-#include "FacetEvalTool.hpp"
-#include "FacetorTool.hpp"
-#include "CubitPoint.hpp"
-#include "CubitPointData.hpp"
-#include "CubitFacet.hpp"
-#include "CubitFacetData.hpp"
-#include "CubitBox.hpp"
-#include "TDFacetBoundaryPoint.hpp"
-#ifdef ROADKILL
-#include "ParamManager.hpp"
-#endif
-#define DETERM(p1,q1,p2,q2,p3,q3)\
- ((q3)*((p2)-(p1)) + (q2)*((p1)-(p3)) + (q1)*((p3)-(p2)))
-#define INSIDE_TOL 1.0e-6
-// Function: OCCParamTool (Public)
-// Description: Constructor
-// Author: chynes
-// Date: 1/02
-OCCParamTool::OCCParamTool(int numn, int nume, double* nodes, int* tri)
-// Description: constructor
-// Author: chynes
-// Date: 7/10/2002
-OCCParamTool::OCCParamTool(Surface *surf)
- refSurf = surf;
-// Function: ~OCCParamTool
-// Description: Deconstructor
-// Author: chynes
-// Date: 1/02
-OCCParamTool::~OCCParamTool() {}
-// Function: set_up_space (Public)
-// Description: sets up space of flattening, flattens, and then updates surface
-// Author: chynes
-// Date: 7/10/02
-CubitStatus OCCParamTool::set_up_space()
-#ifdef ROADKILL
- FacetEvalTool *fetool = CAST_TO(refSurf, OCCSurface)->get_eval_tool();
- if ((fetool->loops())->size() != 1)
- PRINT_WARNING("Cannot parameterize surface. Multiple loops detected\n");
- return CUBIT_FAILURE;
- DLIList<CubitPoint *> my_point_list;
- fetool->get_points(my_point_list);
- DLIList<CubitFacet *> my_facet_list;
- fetool->get_facets(my_facet_list);
- // make arrays out of the points and facets
- double *points = new double [3 * my_point_list.size()];
- int *facets = new int [3 * my_facet_list.size()];
- if (!points || !facets)
- PRINT_ERROR("Could not define parameterization for surface (out of memory)\n");
- int ii;
- CubitPoint *pt;
- my_point_list.reset();
- for (ii=0; ii<my_point_list.size(); ii++)
- pt = my_point_list.get_and_step();
- points[ii*3] = pt->x();
- points[ii*3+1] = pt->y();
- points[ii*3+2] = pt->z();
- pt->marked(ii);
- CubitFacet *facet;
- CubitPoint *pts[3];
- for (ii=0; ii<my_facet_list.size(); ii++)
- facet = my_facet_list.get_and_step();
- facet->points( pts[0], pts[1], pts[2] );
- facets[ii*3] = pts[0]->marked();
- facets[ii*3+1] = pts[1]->marked();
- facets[ii*3+2] = pts[2]->marked();
- //debug, export facets
-// export_facets(my_point_list.size(), my_facet_list.size(), points, facets);
-// PRINT_ERROR("Debugging Failure. Please remove export_facets from OCCParamTool\n");
-// return CUBIT_FAILURE;
- // do the parameterization
- ParamManager parammanager( my_point_list.size(), my_facet_list.size(),
- points, facets );
- if(!parammanager.flatten())
- PRINT_ERROR("Surface Parameterizer Failed\n");
- else
- double ratio;
- double *sizes;
- parammanager.build_sizing();
- double *uv = parammanager.get_uvs_sizing( ratio, sizes );
- // update the points with uvs values
- TDFacetBoundaryPoint *td_fbp;
- CubitBoolean on_internal_boundary;
- DLIList <CubitFacet *> facet_list;
- pt->facets_on_surf( fetool->tool_id(), facet_list, on_internal_boundary );
- if (on_internal_boundary)
- td_fbp = TDFacetBoundaryPoint::get_facet_boundary_point( pt );
- if (!td_fbp)
- TDFacetBoundaryPoint::add_facet_boundary_point( pt );
- td_fbp->add_surf_facets( facet_list );
- td_fbp->set_uvs( facet_list.get(), uv[ii*2], uv[ii*2+1], sizes[ii]);
- else
- if (td_fbp->set_uvs( facet_list.get(),
- uv[ii*2], uv[ii*2+1], sizes[ii] ) != CUBIT_SUCCESS)
- else
- pt->set_uvs( uv[ii*2], uv[ii*2+1], sizes[ii]);
- PRINT_INFO("Surface Parameterization succeeded\n");
- delete [] sizes;
- delete [] uv;
- // clean up
- delete [] points;
- delete [] facets;
- return CUBIT_SUCCESS;
-#else
-#endif
-// Function: transform_to_uv (Public)
-// Description: same as title, set_up_space must have been already called
-// the local sizing will be returned in the z coord
-// of the uv location vector
-// Author: chynes
-// Date: 7/10/02
-CubitStatus OCCParamTool::transform_to_uv(CubitVector &xyz_location, CubitVector &uv_location)
- DLIList<CubitFacet *> facet_list;
- FacetEvalTool *fetool;
- CubitFacet *tri_ptr;
- CubitBoolean outside = CUBIT_FALSE;
- CubitVector closest_point;
- CubitVector area_coord;
- double u, v, s;
- double compare_tol;
- // find best compare_tol
- //fetool = CAST_TO(refSurf, OCCSurface)->get_eval_tool();
- compare_tol = 1e-3*(fetool->bounding_box().diagonal().length());
- // locate point
- CubitStatus rv = CUBIT_SUCCESS;
- fetool->get_facets(facet_list);
- rv = FacetEvalTool::project_to_facets(facet_list,
- tri_ptr,
- 0,
- compare_tol,
- xyz_location,
- CUBIT_FALSE,
- &outside,
- &closest_point,
- NULL);
- // determine barycentric coordinates for in facet
- if(rv == CUBIT_SUCCESS)
- FacetEvalTool::facet_area_coordinate(tri_ptr, closest_point, area_coord);
- // extract data
- double u0, u1, u2, v0, v1, v2, s0, s1, s2;
- CubitPoint *p0, *p1, *p2;
- tri_ptr->points(p0, p1, p2);
- p0->get_uvs(tri_ptr, u0, v0, s0);
- p1->get_uvs(tri_ptr, u1, v1, s1);
- p2->get_uvs(tri_ptr, u2, v2, s2);
- // determine u coordinate
- u = (area_coord.x()*u0) + (area_coord.y()*u1) + (area_coord.z()*u2);
- // determine v coordinate
- v = (area_coord.x()*v0) + (area_coord.y()*v1) + (area_coord.z()*v2);
- // determine sizing
- s = (area_coord.x()*s0) + (area_coord.y()*s1) + (area_coord.z()*s2);
- uv_location.set(u,v,s);
- return rv;
-// Function: transform_to_xyz (Public)
-// Author: chynes
-// Date: 7/10/02
-CubitStatus OCCParamTool::transform_to_xyz(CubitVector &xyz_location, CubitVector &uv_location)
- OCCSurface *facet_surf = CAST_TO(refSurf, OCCSurface);
- double x, y, z;
- //locate point
- rv = locate_point_in_uv(facet_surf, uv_location, tri_ptr);
- // create uv facet
- CubitPoint* uvpoint_array[3];
- DLIList<CubitPoint *> point_list;
- CubitPoint *pt_ptr;
- double u,v;
- int ii;
- tri_ptr->points(point_list);
- for(ii = 0; ii<3; ii++)
- pt_ptr = point_list.get_and_step();
- pt_ptr->get_uv(tri_ptr, u, v);
- uvpoint_array[ii] = (CubitPoint *) new CubitPointData(u, v, 0.0);
- CubitFacet *uvfacet_ptr = (CubitFacet *) new CubitFacetData( uvpoint_array[0],
- uvpoint_array[1],
- uvpoint_array[2] );
- // determine barycentric coordinates of uv point in uv facet
- FacetEvalTool::facet_area_coordinate(uvfacet_ptr, uv_location, area_coord);
- //delete created objects
- delete uvfacet_ptr;
- pt_ptr = uvpoint_array[ii];
- delete pt_ptr;
- CubitVector coord0, coord1, coord2;
- tri_ptr->points(p0,p1,p2);
- coord0 = p0->coordinates();
- coord1 = p1->coordinates();
- coord2 = p2->coordinates();
- //determine x coordinate
- x = (area_coord.x()*coord0.x())
- + (area_coord.y()*coord1.x())
- + (area_coord.z()*coord2.x());
- //determine y coordinate
- y = (area_coord.x()*coord0.y())
- + (area_coord.y()*coord1.y())
- + (area_coord.z()*coord2.y());
- //determine z coordinate
- z = (area_coord.x()*coord0.z())
- + (area_coord.y()*coord1.z())
- + (area_coord.z()*coord2.z());
- xyz_location.set(x,y,z);
- return rv;
-// Function: locate_point_in_uv (Public)
-// Description: same as title (the_point must have coords (u,v,0.0))
-// Author: chynes
-// Date: 7/10/02
-locate_point_in_uv(OCCSurface *surf, CubitVector &the_point, CubitFacet *&tri_ptr)
- int tool_id /*= surf->get_eval_tool()->tool_id()*/;
- //surf->get_eval_tool()->get_facets(facet_list);
- tri_ptr = facet_list.get();
- // loop until we find something
- double aa, bb, cc;
- double u0, u1, u2, v0, v1, v2;
- CubitBoolean found = CUBIT_FALSE;
- while(!found && rv == CUBIT_SUCCESS)
- p0->get_uv(tri_ptr, u0, v0);
- p1->get_uv(tri_ptr, u1, v1);
- p2->get_uv(tri_ptr, u2, v2);
- aa = DETERM(the_point.x(), the_point.y(), u1, v1, u2, v2);
- bb = DETERM(u0, v0, the_point.x(), the_point.y(), u2, v2);
- cc = DETERM(u0, v0, u1, v1, the_point.x(), the_point.y());
- if (aa > -INSIDE_TOL &&
- bb > -INSIDE_TOL &&
- cc > -INSIDE_TOL)
- found = CUBIT_TRUE; // this is the one
- else
- // set up to check the next logical neighbor
- if (aa <= bb && aa <= cc) {
- int edge_index = 1;
- tri_ptr = tri_ptr->adjacent( edge_index, &tool_id );
- else if (bb <= aa && bb <= cc) {
- int edge_index = 2;
- else {
- int edge_index = 0;
- tri_ptr = tri_ptr->adjacent( edge_index, &tool_id);
- // check to see if we've left the triangulation
- if (tri_ptr == NULL)
- rv = exhaustive_locate_point_in_uv(surf, the_point, tri_ptr );
- return rv;
-// Function: exhaustive_locate_point_in_uv (Public)
-// Author: chynes
-// Date: 7/10/02
-exhaustive_locate_point_in_uv(OCCSurface *surf, CubitVector &the_point, CubitFacet *&tri_ptr)
- int ii;
- for(ii = 0; ii < facet_list.size() && !found; ii++)
- tri_ptr = facet_list.get_and_step();
- cc > -INSIDE_TOL)
- if (!found)
- rv = CUBIT_FAILURE;
- tri_ptr = NULL;
- return rv;
-// Function: flatten
-// Description: accessor function to the parameterization algorithms
-// Author: chynes
-// Date: 1/02
-//EOF
Deleted: cgm/trunk/geom/OCC/OCCParamTool.hpp
--- cgm/trunk/geom/OCC/OCCParamTool.hpp 2009-10-11 06:04:10 UTC (rev 3197)
+++ cgm/trunk/geom/OCC/OCCParamTool.hpp 2009-10-12 19:05:29 UTC (rev 3198)
@@ -1,62 +0,0 @@
-// File:OCCParamTool.hpp
-// Purpose: interface for 3D-2D parameterization algorithms for facets
-#ifndef FACET_PARAM_TOOL_HPP
-#define FACET_PARAM_TOOL_HPP
-#include "ParamTool.hpp"
-class Surface;
-class OCCSurface;
-class CubitFacet;
-class CubitVector;
-class OCCParamTool : public ParamTool
-public:
- OCCParamTool(int numn, int nume, double* nodes, int* tri);
- //~constructor
- OCCParamTool(Surface *surf);
- //- constructor
- ~OCCParamTool();
- //~deconstructor
- CubitStatus set_up_space(void);
- CubitStatus transform_to_uv(CubitVector &xyz_location, CubitVector &uv_location);
- CubitStatus transform_to_xyz(CubitVector &xyz_location, CubitVector &uv_location);
- CubitStatus locate_point_in_uv(OCCSurface *surf, CubitVector &the_point, CubitFacet *&tri_ptr);
- CubitStatus exhaustive_locate_point_in_uv(OCCSurface *surf, CubitVector &the_point, CubitFacet *&tri_ptr);
-#ifdef BOYD14
- CubitStatus export_facets(int numn, int numf, double *points, int *facets);
- // - debug function for testing inputs to roadkill
- int flatten();
- //accessor function to the parameterization algorithms
- double* get_uvs_sizing(double& ratio, double*& sizings);
- //after calling flatten, returns an array of the u,v parameters, accessing
- //d_flat_mesh
-#endif
-private:
- Surface *refSurf;
- //- reference surface
-#endif
More information about the cgma-dev
