[cgma-dev] CGMA check for *64-acis* failed.
Nightly Test kraftche at cae.wisc.edu
Thu Sep 24 02:18:10 CDT 2009
Making check in compat
make[1]: Entering directory `/home/jason/cgm/test/64-acis/compat'
make[1]: Nothing to be done for `check'.
make[1]: Leaving directory `/home/jason/cgm/test/64-acis/compat'
Making check in util
make[1]: Entering directory `/home/jason/cgm/test/64-acis/util'
make[1]: Leaving directory `/home/jason/cgm/test/64-acis/util'
Making check in geom
make[1]: Entering directory `/home/jason/cgm/test/64-acis/geom'
Making check in .
make[2]: Entering directory `/home/jason/cgm/test/64-acis/geom'
make[2]: Nothing to be done for `check-am'.
make[2]: Leaving directory `/home/jason/cgm/test/64-acis/geom'
Making check in Cholla
make[2]: Entering directory `/home/jason/cgm/test/64-acis/geom/Cholla'
make[2]: Nothing to be done for `check'.
make[2]: Leaving directory `/home/jason/cgm/test/64-acis/geom/Cholla'
Making check in facetbool
make[2]: Entering directory `/home/jason/cgm/test/64-acis/geom/facetbool'
make[2]: Leaving directory `/home/jason/cgm/test/64-acis/geom/facetbool'
make[2]: Entering directory `/home/jason/cgm/test/64-acis/geom/facet'
make[2]: Leaving directory `/home/jason/cgm/test/64-acis/geom/facet'
Making check in virtual
make[2]: Entering directory `/home/jason/cgm/test/64-acis/geom/virtual'
make[2]: Leaving directory `/home/jason/cgm/test/64-acis/geom/virtual'
Making check in ACIS
make[2]: Entering directory `/home/jason/cgm/test/64-acis/geom/ACIS'
make[2]: Leaving directory `/home/jason/cgm/test/64-acis/geom/ACIS'
make[1]: Leaving directory `/home/jason/cgm/test/64-acis/geom'
Making check in init
make[1]: Entering directory `/home/jason/cgm/test/64-acis/init'
make[1]: Leaving directory `/home/jason/cgm/test/64-acis/init'
Making check in .
make[1]: Entering directory `/home/jason/cgm/test/64-acis'
make[1]: Leaving directory `/home/jason/cgm/test/64-acis'
Making check in itaps
make[1]: Entering directory `/home/jason/cgm/test/64-acis/itaps'
make  check-recursive
make[2]: Entering directory `/home/jason/cgm/test/64-acis/itaps'
Making check in .
make[3]: Entering directory `/home/jason/cgm/test/64-acis/itaps'
make  chaman testgeom
make[4]: Entering directory `/home/jason/cgm/test/64-acis/itaps'
make[4]: `testgeom' is up to date.
make[4]: Leaving directory `/home/jason/cgm/test/64-acis/itaps'
make  check-TESTS
Using default input file: ../../trunk/itaps/testgeom.sat
Geometry engine set to: ACIS Version 16.0.7.0
ITAPS GEOMETRY INTERFACE TEST PROGRAM:
   gLoad: Read 1 ACIS Entities from the input file
Constructed 1 Volume: 1
Model contents:
vertices: 36
edges: 60
faces: 33
regions: 1
Success
   tags: Tags defined on model: GLOBAL_ID, NAME
/bin/sh: line 4: 23144 Segmentation fault      /home/jason/bin/timeout 600 ${dir}$tst
FAIL: testgeom
1 of 1 tests failed
make[4]: *** [check-TESTS] Error 1
make[3]: *** [check-am] Error 2
make[3]: Leaving directory `/home/jason/cgm/test/64-acis/itaps'
make[2]: *** [check-recursive] Error 1
make[2]: Leaving directory `/home/jason/cgm/test/64-acis/itaps'
make[1]: *** [check] Error 2
make[1]: Leaving directory `/home/jason/cgm/test/64-acis/itaps'
make: *** [check-recursive] Error 1
More information about the cgma-dev mailing list
