[cgma-dev] r3162 - cgm/trunk/itaps
sjackson at cae.wisc.edu sjackson at cae.wisc.edu
Tue Sep 22 17:44:57 CDT 2009
Author: sjackson
Date: 2009-09-22 17:44:57 -0500 (Tue, 22 Sep 2009)
New Revision: 3162
Modified:
   cgm/trunk/itaps/testgeom.cc
Log:
Skip the save/load entity set test when running under OCC
Modified: cgm/trunk/itaps/testgeom.cc
--- cgm/trunk/itaps/testgeom.cc	2009-09-22 21:13:48 UTC (rev 3161)
+++ cgm/trunk/itaps/testgeom.cc	2009-09-22 22:44:57 UTC (rev 3162)
@@ -198,7 +198,7 @@
   number_tests++;
   std::cout << "\n";
-    // gentitysets test
+    // topology adjacencies test
   std::cout << "   topology adjacencies: ";
   result = topology_adjacencies_test(geom);
   handle_error_code(result, number_tests_failed,
@@ -251,7 +251,6 @@
                     number_tests_successful);
   number_tests++;
   std::cout << "\n";
-#endif
     // save entset test
   std::cout << "   save entset: ";
@@ -261,6 +260,7 @@
   number_tests++;
   std::cout << "\n";
+#endif
     // shutdown test
   std::cout << "   shutdown: ";
More information about the cgma-dev mailing list
