[cgma-dev] CGMA check for *32-occ* failed.
    Nightly Test
    kraftche at cae.wisc.edu
    Thu Sep 10 02:45:10 CDT 2009
Making check in compat
make[1]: Entering directory `/home/jason/cgm/test/32-occ/compat'
make[1]: Nothing to be done for `check'.
make[1]: Leaving directory `/home/jason/cgm/test/32-occ/compat'
Making check in util
make[1]: Entering directory `/home/jason/cgm/test/32-occ/util'
make[1]: Leaving directory `/home/jason/cgm/test/32-occ/util'
Making check in geom
make[1]: Entering directory `/home/jason/cgm/test/32-occ/geom'
Making check in .
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom'
make[2]: Nothing to be done for `check-am'.
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom'
Making check in Cholla
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/Cholla'
make[2]: Nothing to be done for `check'.
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/Cholla'
Making check in facetbool
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/facetbool'
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/facetbool'
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/facet'
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/facet'
Making check in virtual
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/virtual'
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/virtual'
Making check in OCC
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/OCC'
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/OCC'
make[1]: Leaving directory `/home/jason/cgm/test/32-occ/geom'
Making check in init
make[1]: Entering directory `/home/jason/cgm/test/32-occ/init'
make[1]: Leaving directory `/home/jason/cgm/test/32-occ/init'
Making check in .
make[1]: Entering directory `/home/jason/cgm/test/32-occ'
make[1]: Leaving directory `/home/jason/cgm/test/32-occ'
Making check in itaps
make[1]: Entering directory `/home/jason/cgm/test/32-occ/itaps'
make  check-recursive
make[2]: Entering directory `/home/jason/cgm/test/32-occ/itaps'
Making check in .
make[3]: Entering directory `/home/jason/cgm/test/32-occ/itaps'
make  chaman   testgeom_occ
make[4]: Entering directory `/home/jason/cgm/test/32-occ/itaps'
make[4]: `testgeom_occ' is up to date.
make[4]: Leaving directory `/home/jason/cgm/test/32-occ/itaps'
make  check-TESTS
Using default input file: ../../trunk/itaps/../test/LeverArm.brep
Geometry engine set to: OCC Geometry Engine version 6.2.0
ITAPS GEOMETRY INTERFACE TEST PROGRAM:
   gLoad:
Constructed 1 Volume: 1
Model contents:
vertices: 99
edges: 159
faces: 63
regions: 1
Success
   tags: Tags defined on model: GLOBAL_ID, NAME
Success
   gentity sets: Success
   topology adjacencies: Success
   construct: Created swept volume 4
Success
   primitives: Success
   transforms: Success
   booleans: Updated volume(s): 11
Destroyed volume(s): 12
Updated volume(s): 13
Destroyed volume(s): 14
*** glibc detected *** ./testgeom_occ: corrupted double-linked list: 0x9c0fc2c0 ***
======= Backtrace: =========
/lib32/libc.so.6[0x58673d74]
/lib32/libc.so.6[0x58675985]
/lib32/libc.so.6(cfree+0x85)[0x58675b86]
/usr/lib32/libstdc++.so.6(_ZdlPv+0x21)[0x5859f6b1]
/usr/lib32/libstdc++.so.6(_ZdaPv+0x1d)[0x5859f70d]
./testgeom_occ[0x8084805]
./testgeom_occ[0x808484d]
./testgeom_occ[0x8109aa9]
./testgeom_occ[0x82043cd]
./testgeom_occ[0x82041f2]
./testgeom_occ[0x83a86d3]
./testgeom_occ[0x83a899f]
======= Memory map: ========
08048000-08483000 r-xp 00000000 08:06 23691296                           /home/jason/cgm/test/32-occ/itaps/testgeom_occ
08483000-08485000 rw-p 0043b000 08:06 23691296                           /home/jason/cgm/test/32-occ/itaps/testgeom_occ
08485000-08488000 rw-p 08485000 00:00 0
09d4c000-1fff9000 rw-p 09d4c000 00:00 0                                  [heap]
20000000-203e8000 rw-p 00000000 00:0d 1114                               /dev/zero
55555000-55574000 r-xp 00000000 08:02 457085                             /emul/ia32-linux/lib/ld-2.9.so
55574000-55575000 r--p 0001e000 08:02 457085                             /emul/ia32-linux/lib/ld-2.9.so
55575000-55576000 rw-p 0001f000 08:02 457085                             /emul/ia32-linux/lib/ld-2.9.so
55576000-55577000 r-xp 55576000 00:00 0                                  [vdso]
55577000-5557a000 rw-p 55577000 00:00 0
5557a000-5564b000 r-xp 00000000 08:02 799734                             /opt/OpenCascade6.3-32bit/lib/libTKFeat.so.0.0.0
5564b000-5564e000 rw-p 000d0000 08:02 799734                             /opt/OpenCascade6.3-32bit/lib/libTKFeat.so.0.0.0
5564e000-5574e000 r-xp 00000000 08:02 408636                             /opt/OpenCascade6.3-32bit/lib/libTKHLR.so.0.0.0
5574e000-55751000 rw-p 00100000 08:02 408636                             /opt/OpenCascade6.3-32bit/lib/libTKHLR.so.0.0.0
55751000-55752000 rw-p 55751000 00:00 0
55752000-55aef000 r-xp 00000000 08:02 799974                             /opt/OpenCascade6.3-32bit/lib/libTKIGES.so.0.0.0
55aef000-55afc000 rw-p 0039c000 08:02 799974                             /opt/OpenCascade6.3-32bit/lib/libTKIGES.so.0.0.0
55afc000-55b03000 rw-p 55afc000 00:00 0
55b03000-55be4000 r-xp 00000000 08:02 799738                             /opt/OpenCascade6.3-32bit/lib/libTKOffset.so.0.0.0
55be4000-55be7000 rw-p 000e1000 08:02 799738                             /opt/OpenCascade6.3-32bit/lib/libTKOffset.so.0.0.0
55be7000-55deb000 r-xp 00000000 08:02 799730                             /opt/OpenCascade6.3-32bit/lib/libTKFillet.so.0.0.0
55deb000-55df0000 rw-p 00204000 08:02 799730                             /opt/OpenCascade6.3-32bit/lib/libTKFillet.so.0.0.0
55df0000-55df1000 rw-p 55df0000 00:00 0
55df1000-56131000 r-xp 00000000 08:02 799720                             /opt/OpenCascade6.3-32bit/lib/libTKBool.so.0.0.0
56131000-56139000 rw-p 0033f000 08:02 799720                             /opt/OpenCascade6.3-32bit/lib/libTKBool.so.0.0.0
56139000-5613b000 rw-p 56139000 00:00 0
5613b000-562f4000 r-xp 00000000 08:02 408632                             /opt/OpenCascade6.3-32bit/lib/libTKBO.so.0.0.0
562f4000-562fa000 rw-p 001b8000 08:02 408632                             /opt/OpenCascade6.3-32bit/lib/libTKBO.so.0.0.0
562fa000-562fb000 rw-p 562fa000 00:00 0
562fb000-56349000 r-xp 00000000 08:02 408628                             /opt/OpenCascade6.3-32bit/lib/libTKPrim.so.0.0.0
56349000-5634b000 rw-p 0004d000 08:02 408628                             /opt/OpenCascade6.3-32bit/lib/libTKPrim.so.0.0.0
5634b000-5634c000 rw-p 5634b000 00:00 0
5634c000-565df000 r-xp 00000000 08:02 799990                             /opt/OpenCascade6.3-32bit/lib/libTKSTEP.so.0.0.0
565df000-565e8000 rw-p 00292000 08:02 799990                             /opt/OpenCascade6.3-32bit/lib/libTKSTEP.so.0.0.0
565e8000-565eb000 rw-p 565e8000 00:00 0
565eb000-56697000 r-xp 00000000 08:02 799978                             /opt/OpenCascade6.3-32bit/lib/libTKSTEPAttr.so.0.0.0
56697000-5669a000 rw-p 000ac000 08:02 799978                             /opt/OpenCascade6.3-32bit/lib/libTKSTEPAttr.so.0.0.0
5669a000-5669d000 rw-p 5669a000 00:00 0
5669d000-56764000 r-xp 00000000 08:02 799982                             /opt/OpenCascade6.3-32bit/lib/libTKSTEP209.so.0.0.0
56764000-56768000 rw-p 000c6000 08:02 799982                             /opt/OpenCascade6.3-32bit/lib/libTKSTEP209.so.0.0.0
56768000-5676a000 rw-p 56768000 00:00 0
5676a000-56a03000 r-xp 00000000 08:02 799970                             /opt/OpenCascade6.3-32bit/lib/libTKSTEPBase.so.0.0.0
56a03000-56a0d000 rw-p 00298000 08:02 799970                             /opt/OpenCascade6.3-32bit/lib/libTKSTEPBase.so.0.0.0
56a0d000-56a17000 rw-p 56a0d000 00:00 0
56a17000-56a30000 r-xp 00000000 08:02 799950                             /opt/OpenCascade6.3-32bit/lib/libTKSTL.so.0.0.0
56a30000-56a31000 rw-p 00019000 08:02 799950                             /opt/OpenCascade6.3-32bit/lib/libTKSTL.so.0.0.0
56a31000-56a32000 rw-p 56a31000 00:00 0
56a32000-56ace000 r-xp 00000000 08:02 408642                             /opt/OpenCascade6.3-32bit/lib/libTKMesh.so.0.0.0
56ace000-56ad1000 rw-p 0009c000 08:02 408642                             /opt/OpenCascade6.3-32bit/lib/libTKMesh.so.0.0.0
56ad1000-56d44000 r-xp 00000000 08:02 799954                             /opt/OpenCascade6.3-32bit/lib/libTKXSBase.so.0.0.0
56d44000-56d4d000 rw-p 00273000 08:02 799954                             /opt/OpenCascade6.3-32bit/lib/libTKXSBase.so.0.0.0
56d4d000-56d61000 rw-p 56d4d000 00:00 0
56d61000-56f3e000 r-xp 00000000 08:02 408647                             /opt/OpenCascade6.3-32bit/lib/libTKShHealing.so.0.0.0
56f3e000-56f43000 rw-p 001dd000 08:02 408647                             /opt/OpenCascade6.3-32bit/lib/libTKShHealing.so.0.0.0
56f43000-56f44000 rw-p 56f43000 00:00 0
56f44000-56fbe000 r-xp 00000000 08:02 799862                             /opt/OpenCascade6.3-32bit/lib/libTKBinL.so.0.0.0
56fbe000-56fc1000 rw-p 00079000 08:02 799862                             /opt/OpenCascade6.3-32bit/lib/libTKBinL.so.0.0.0
56fc1000-56fc2000 rw-p 56fc1000 00:00 0
56fc2000-570da000 r-xp 00000000 08:02 799846                             /opt/OpenCascade6.3-32bit/lib/libTKLCAF.so.0.0.0
570da000-570e0000 rw-p 00118000 08:02 799846                             /opt/OpenCascade6.3-32bit/lib/libTKLCAF.so.0.0.0
570e0000-570e3000 rw-p 570e0000 00:00 0
570e3000-572f3000 r-xp 00000000 08:02 408622                             /opt/OpenCascade6.3-32bit/lib/libTKTopAlgo.so.0.0.0
572f3000-572f8000 rw-p 00210000 08:02 408622                             /opt/OpenCascade6.3-32bit/lib/libTKTopAlgo.so.0.0.0
572f8000-572fa000 rw-p 572f8000 00:00 0
572fa000-5777d000 r-xp 00000000 08:02 408604                             /opt/OpenCascade6.3-32bit/lib/libTKGeomAlgo.so.0.0.0
5777d000-57785000 rw-p 00483000 08:02 408604                             /opt/OpenCascade6.3-32bit/lib/libTKGeomAlgo.so.0.0.0
57785000-579bf000 rw-p 57785000 00:00 0
579bf000-57a82000 r-xp 00000000 08:02 408596                             /opt/OpenCascade6.3-32bit/lib/libTKBRep.so.0.0.0
57a82000-57a86000 rw-p 000c2000 08:02 408596                             /opt/OpenCascade6.3-32bit/lib/libTKBRep.so.0.0.0
57a86000-57a87000 rw-p 57a86000 00:00 0
57a87000-57e8a000 r-xp 00000000 08:02 408182                             /opt/OpenCascade6.3-32bit/lib/libTKGeomBase.so.0.0.0
57e8a000-57ed0000 rw-p 00403000 08:02 408182                             /opt/OpenCascade6.3-32bit/lib/libTKGeomBase.so.0.0.0
57ed0000-57f22000 rw-p 57ed0000 00:00 0
57f22000-58026000 r-xp 00000000 08:02 408174                             /opt/OpenCascade6.3-32bit/lib/libTKG3d.so.0.0.0
58026000-5802a000 rw-p 00103000 08:02 408174                             /opt/OpenCascade6.3-32bit/lib/libTKG3d.so.0.0.0
5802a000-5802d000 rw-p 5802a000 00:00 0
5802d000-58098000 r-xp 00000000 08:02 408165                             /opt/OpenCascade6.3-32bit/lib/libTKG2d.so.0.0.0
58098000-5809a000 rw-p 0006b000 08:02 408165                             /opt/OpenCascade6.3-32bit/lib/libTKG2d.so.0.0.0
5809a000-5809b000 rw-p 5809a000 00:00 0
5809b000-581f3000 r-xp 00000000 08:02 318420                             /opt/OpenCascade6.3-32bit/lib/libTKMath.so.0.0.0
581f3000-581f7000 rw-p 00157000 08:02 318420                             /opt/OpenCascade6.3-32bit/lib/libTKMath.so.0.0.0
581f7000-581f9000 rw-p 581f7000 00:00 0
581f9000-58254000 r-xp 00000000 08:02 799838                             /opt/OpenCascade6.3-32bit/lib/libTKCDF.so.0.0.0
58254000-58257000 rw-p 0005a000 08:02 799838                             /opt/OpenCascade6.3-32bit/lib/libTKCDF.so.0.0.0
58257000-5825a000 rw-p 58257000 00:00 0
5825a000-58498000 r-xp 00000000 08:02 310332                             /opt/OpenCascade6.3-32bit/lib/libTKernel.so.0.0.0
58498000-5849f000 rw-p 0023e000 08:02 310332                             /opt/OpenCascade6.3-32bit/lib/libTKernel.so.0.0.0
5849f000-584a9000 rw-p 5849f000 00:00 0
584ca000-584de000 r-xp 00000000 08:02 457037                             /emul/ia32-linux/lib/libpthread-2.9.so
584de000-584df000 r--p 00013000 08:02 457037                             /emul/ia32-linux/lib/libpthread-2.9.so
584df000-584e0000 rw-p 00014000 08:02 457037                             /emul/ia32-linux/lib/libpthread-2.9.so
584e0000-584e3000 rw-p 584e0000 00:00 0
584e3000-584e5000 r-xp 00000000 08:02 457092                             /emul/ia32-linux/lib/libdl-2.9.so
584e5000-584e6000 r--p 00001000 08:02 457092                             /emul/ia32-linux/lib/libdl-2.9.so
584e6000-584e7000 rw-p 00002000 08:02 457092                             /emul/ia32-linux/lib/libdl-2.9.so
584e7000-585ca000 r-xp 00000000 08:02 457061                             /emul/ia32-linux/usr/lib/libstdc++.so.6.0.10
585ca000-585cd000 r--p 000e2000 08:02 457061                             /emul/ia32-linux/usr/lib/libstdc++.so.6.0.10
585cd000-585cf000 rw-p 000e5000 08:02 457061                             /emul/ia32-linux/usr/lib/libstdc++.so.6.0.10
585cf000-585d5000 rw-p 585cf000 00:00 0
585d5000-585f7000 r-xp 00000000 08:02 457083                             /emul/ia32-linux/lib/libm-2.9.so
585f7000-585f8000 r--p 00022000 08:02 457083                             /emul/ia32-linux/lib/libm-2.9.so
585f8000-585f9000 rw-p 00023000 08:02 457083                             /emul/ia32-linux/lib/libm-2.9.so
585f9000-58605000 r-xp 00000000 08:02 457058                             /emul/ia32-linux/usr/lib/libgcc_s.so.1
58605000-58606000 rw-p 0000b000 08:02 457058                             /emul/ia32-linux/usr/lib/libgcc_s.so.1
58606000-58757000 r-xp 00000000 08:02 457086                             /emul/ia32-linux/lib/libc-2.9.so
58757000-58758000 ---p 00151000 08:02 457086                             /emul/ia32-linux/lib/libc-2.9.so
58758000-5875a000 r--p 00151000 08:02 457086                             /emul/ia32-linux/lib/libc-2.9.so
5875a000-5875b000 rw-p 00153000 08:02 457086                             /emul/ia32-linux/lib/libc-2.9.so
5875b000-5a362000 rw-p 5875b000 00:00 0
5a44f000-5cf4f000 rw-p 5a44f000 00:00 0
5cfae000-5f0ae000 rw-p 5cfae000 00:00 0
5f0b7000-5f9b7000 rw-p 5f0b7000 00:00 0
5fa15000-656a8000 rw-p 5fa15000 00:00 0
6572f000-6712f000 rw-p 6572f000 00:00 0
67139000-76fcc000 rw-p 67139000 00:00 0
77060000-9c119000 rw-p 77060000 00:00 0
9c119000-ffa1a000 rw-p 7fff9c6fe000 00:00 0                              [stack]
ffb00000-ffb21000 rw-p ffb00000 00:00 0
ffb21000-ffc00000 ---p ffb21000 00:00 0
Success
   save entset: /bin/sh: line 4: 28759 Aborted                 /home/jason/bin/timeout 600 ${dir}$tst
FAIL: testgeom_occ
1 of 1 tests failed
make[4]: *** [check-TESTS] Error 1
make[3]: *** [check-am] Error 2
make[3]: Leaving directory `/home/jason/cgm/test/32-occ/itaps'
make[2]: *** [check-recursive] Error 1
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/itaps'
make[1]: *** [check] Error 2
make[1]: Leaving directory `/home/jason/cgm/test/32-occ/itaps'
make: *** [check-recursive] Error 1
More information about the cgma-dev
