[cgma-dev] CGMA check for *32-occ* failed.
Nightly Test kraftche at cae.wisc.edu
Tue Sep 8 02:44:55 CDT 2009
Making check in compat
make[1]: Entering directory `/home/jason/cgm/test/32-occ/compat'
make[1]: Nothing to be done for `check'.
make[1]: Leaving directory `/home/jason/cgm/test/32-occ/compat'
Making check in util
make[1]: Entering directory `/home/jason/cgm/test/32-occ/util'
make[1]: Leaving directory `/home/jason/cgm/test/32-occ/util'
Making check in geom
make[1]: Entering directory `/home/jason/cgm/test/32-occ/geom'
Making check in .
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom'
make[2]: Nothing to be done for `check-am'.
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom'
Making check in Cholla
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/Cholla'
make[2]: Nothing to be done for `check'.
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/Cholla'
Making check in facetbool
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/facetbool'
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/facetbool'
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/facet'
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/facet'
Making check in virtual
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/virtual'
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/virtual'
Making check in OCC
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/OCC'
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/OCC'
make[1]: Leaving directory `/home/jason/cgm/test/32-occ/geom'
Making check in init
make[1]: Entering directory `/home/jason/cgm/test/32-occ/init'
make[1]: Leaving directory `/home/jason/cgm/test/32-occ/init'
Making check in .
make[1]: Entering directory `/home/jason/cgm/test/32-occ'
make[1]: Leaving directory `/home/jason/cgm/test/32-occ'
Making check in itaps
make[1]: Entering directory `/home/jason/cgm/test/32-occ/itaps'
make  check-recursive
make[2]: Entering directory `/home/jason/cgm/test/32-occ/itaps'
Making check in .
make[3]: Entering directory `/home/jason/cgm/test/32-occ/itaps'
make  chaman   testgeom_occ
make[4]: Entering directory `/home/jason/cgm/test/32-occ/itaps'
make[4]: `testgeom_occ' is up to date.
make[4]: Leaving directory `/home/jason/cgm/test/32-occ/itaps'
make  check-TESTS
Using default input file: ../../trunk/itaps/../test/LeverArm.brep
Geometry engine set to: OCC Geometry Engine version 6.2.0
ITAPS GEOMETRY INTERFACE TEST PROGRAM:
   gLoad:
Constructed 1 Volume: 1
Model contents:
vertices: 99
edges: 159
faces: 63
regions: 1
Success
   tags: Tags defined on model: GLOBAL_ID, NAME
Success
   gentity sets: Success
   topology adjacencies: Success
   construct: Created swept volume 4
Success
   primitives: Success
   transforms: Success
   booleans: Updated volume(s): 11
Destroyed volume(s): 12
Updated volume(s): 13
Destroyed volume(s): 14
*** glibc detected *** ./testgeom_occ: double free or corruption (!prev): 0x9ba00f88 ***
======= Backtrace: =========
/lib32/libc.so.6[0x58e7ad74]
/lib32/libc.so.6(cfree+0x85)[0x58e7cb86]
/usr/lib32/libstdc++.so.6(_ZdlPv+0x21)[0x58da56b1]
/usr/lib32/libstdc++.so.6(_ZdaPv+0x1d)[0x58da570d]
./testgeom_occ[0x808451a]
./testgeom_occ[0x8204421]
./testgeom_occ[0x83a87b3]
./testgeom_occ[0x83a8a7f]
======= Memory map: ========
08048000-08483000 r-xp 00000000 08:06 23691296                           /home/jason/cgm/test/32-occ/itaps/testgeom_occ
08483000-08485000 rw-p 0043b000 08:06 23691296                           /home/jason/cgm/test/32-occ/itaps/testgeom_occ
08485000-08488000 rw-p 08485000 00:00 0
089f2000-1fffc000 rw-p 089f2000 00:00 0                                  [heap]
20000000-203e8000 rw-p 00000000 00:0d 1044                               /dev/zero
55555000-55574000 r-xp 00000000 08:02 457085                             /emul/ia32-linux/lib/ld-2.9.so
55574000-55575000 r--p 0001e000 08:02 457085                             /emul/ia32-linux/lib/ld-2.9.so
55575000-55576000 rw-p 0001f000 08:02 457085                             /emul/ia32-linux/lib/ld-2.9.so
55576000-55577000 r-xp 55576000 00:00 0                                  [vdso]
55577000-5557a000 rw-p 55577000 00:00 0
5557a000-5564b000 r-xp 00000000 08:02 799734                             /opt/OpenCascade6.3-32bit/lib/libTKFeat.so.0.0.0
5564b000-5564e000 rw-p 000d0000 08:02 799734                             /opt/OpenCascade6.3-32bit/lib/libTKFeat.so.0.0.0
5564e000-559eb000 r-xp 00000000 08:02 799974                             /opt/OpenCascade6.3-32bit/lib/libTKIGES.so.0.0.0
559eb000-559f8000 rw-p 0039c000 08:02 799974                             /opt/OpenCascade6.3-32bit/lib/libTKIGES.so.0.0.0
559f8000-559fe000 rw-p 559f8000 00:00 0
559fe000-55adf000 r-xp 00000000 08:02 799738                             /opt/OpenCascade6.3-32bit/lib/libTKOffset.so.0.0.0
55adf000-55ae2000 rw-p 000e1000 08:02 799738                             /opt/OpenCascade6.3-32bit/lib/libTKOffset.so.0.0.0
55ae2000-55ae3000 rw-p 55ae2000 00:00 0
55ae3000-55ce7000 r-xp 00000000 08:02 799730                             /opt/OpenCascade6.3-32bit/lib/libTKFillet.so.0.0.0
55ce7000-55cec000 rw-p 00204000 08:02 799730                             /opt/OpenCascade6.3-32bit/lib/libTKFillet.so.0.0.0
55cec000-55ced000 rw-p 55cec000 00:00 0
55ced000-5602d000 r-xp 00000000 08:02 799720                             /opt/OpenCascade6.3-32bit/lib/libTKBool.so.0.0.0
5602d000-56035000 rw-p 0033f000 08:02 799720                             /opt/OpenCascade6.3-32bit/lib/libTKBool.so.0.0.0
56035000-56037000 rw-p 56035000 00:00 0
56037000-561f0000 r-xp 00000000 08:02 408632                             /opt/OpenCascade6.3-32bit/lib/libTKBO.so.0.0.0
561f0000-561f6000 rw-p 001b8000 08:02 408632                             /opt/OpenCascade6.3-32bit/lib/libTKBO.so.0.0.0
561f6000-561f7000 rw-p 561f6000 00:00 0
561f7000-56245000 r-xp 00000000 08:02 408628                             /opt/OpenCascade6.3-32bit/lib/libTKPrim.so.0.0.0
56245000-56247000 rw-p 0004d000 08:02 408628                             /opt/OpenCascade6.3-32bit/lib/libTKPrim.so.0.0.0
56247000-564da000 r-xp 00000000 08:02 799990                             /opt/OpenCascade6.3-32bit/lib/libTKSTEP.so.0.0.0
564da000-564e3000 rw-p 00292000 08:02 799990                             /opt/OpenCascade6.3-32bit/lib/libTKSTEP.so.0.0.0
564e3000-564e7000 rw-p 564e3000 00:00 0
564e7000-56593000 r-xp 00000000 08:02 799978                             /opt/OpenCascade6.3-32bit/lib/libTKSTEPAttr.so.0.0.0
56593000-56596000 rw-p 000ac000 08:02 799978                             /opt/OpenCascade6.3-32bit/lib/libTKSTEPAttr.so.0.0.0
56596000-56599000 rw-p 56596000 00:00 0
56599000-56660000 r-xp 00000000 08:02 799982                             /opt/OpenCascade6.3-32bit/lib/libTKSTEP209.so.0.0.0
56660000-56664000 rw-p 000c6000 08:02 799982                             /opt/OpenCascade6.3-32bit/lib/libTKSTEP209.so.0.0.0
56664000-56666000 rw-p 56664000 00:00 0
56666000-568ff000 r-xp 00000000 08:02 799970                             /opt/OpenCascade6.3-32bit/lib/libTKSTEPBase.so.0.0.0
568ff000-56909000 rw-p 00298000 08:02 799970                             /opt/OpenCascade6.3-32bit/lib/libTKSTEPBase.so.0.0.0
56909000-56913000 rw-p 56909000 00:00 0
56913000-5692c000 r-xp 00000000 08:02 799950                             /opt/OpenCascade6.3-32bit/lib/libTKSTL.so.0.0.0
5692c000-5692d000 rw-p 00019000 08:02 799950                             /opt/OpenCascade6.3-32bit/lib/libTKSTL.so.0.0.0
5692d000-56ba0000 r-xp 00000000 08:02 799954                             /opt/OpenCascade6.3-32bit/lib/libTKXSBase.so.0.0.0
56ba0000-56ba9000 rw-p 00273000 08:02 799954                             /opt/OpenCascade6.3-32bit/lib/libTKXSBase.so.0.0.0
56ba9000-56bbe000 rw-p 56ba9000 00:00 0
56bbe000-56d9b000 r-xp 00000000 08:02 408647                             /opt/OpenCascade6.3-32bit/lib/libTKShHealing.so.0.0.0
56d9b000-56da0000 rw-p 001dd000 08:02 408647                             /opt/OpenCascade6.3-32bit/lib/libTKShHealing.so.0.0.0
56da0000-56da1000 rw-p 56da0000 00:00 0
56da1000-56db0000 r-xp 00000000 08:02 799882                             /opt/OpenCascade6.3-32bit/lib/libTKBin.so.0.0.0
56db0000-56db1000 rw-p 0000f000 08:02 799882                             /opt/OpenCascade6.3-32bit/lib/libTKBin.so.0.0.0
56db1000-56e2b000 r-xp 00000000 08:02 799862                             /opt/OpenCascade6.3-32bit/lib/libTKBinL.so.0.0.0
56e2b000-56e2e000 rw-p 00079000 08:02 799862                             /opt/OpenCascade6.3-32bit/lib/libTKBinL.so.0.0.0
56e2e000-56e2f000 rw-p 56e2e000 00:00 0
56e2f000-56e79000 r-xp 00000000 08:02 799858                             /opt/OpenCascade6.3-32bit/lib/libTKCAF.so.0.0.0
56e79000-56e7b000 rw-p 0004a000 08:02 799858                             /opt/OpenCascade6.3-32bit/lib/libTKCAF.so.0.0.0
56e7b000-56e7c000 rw-p 56e7b000 00:00 0
56e7c000-56f94000 r-xp 00000000 08:02 799846                             /opt/OpenCascade6.3-32bit/lib/libTKLCAF.so.0.0.0
56f94000-56f9a000 rw-p 00118000 08:02 799846                             /opt/OpenCascade6.3-32bit/lib/libTKLCAF.so.0.0.0
56f9a000-56f9d000 rw-p 56f9a000 00:00 0
56f9d000-572d7000 r-xp 00000000 08:02 799822                             /opt/OpenCascade6.3-32bit/lib/libTKV3d.so.0.0.0
572d7000-572e3000 rw-p 00339000 08:02 799822                             /opt/OpenCascade6.3-32bit/lib/libTKV3d.so.0.0.0
572e3000-572e9000 rw-p 572e3000 00:00 0
572e9000-57385000 r-xp 00000000 08:02 408642                             /opt/OpenCascade6.3-32bit/lib/libTKMesh.so.0.0.0
57385000-57388000 rw-p 0009c000 08:02 408642                             /opt/OpenCascade6.3-32bit/lib/libTKMesh.so.0.0.0
57388000-574be000 r-xp 00000000 08:02 799818                             /opt/OpenCascade6.3-32bit/lib/libTKV2d.so.0.0.0
574be000-574c3000 rw-p 00136000 08:02 799818                             /opt/OpenCascade6.3-32bit/lib/libTKV2d.so.0.0.0
574c3000-574c6000 rw-p 574c3000 00:00 0
574c6000-5765b000 r-xp 00000000 08:02 799746                             /opt/OpenCascade6.3-32bit/lib/libTKService.so.0.0.0
5765b000-57662000 rw-p 00195000 08:02 799746                             /opt/OpenCascade6.3-32bit/lib/libTKService.so.0.0.0
57662000-57691000 rw-p 57662000 00:00 0
576b2000-576fe000 r-xp 00000000 08:02 459650                             /emul/ia32-linux/usr/lib/libXt.so.6.0.0
576fe000-57701000 rw-p 0004c000 08:02 459650                             /emul/ia32-linux/usr/lib/libXt.so.6.0.0
57701000-57703000 rw-p 57701000 00:00 0
57703000-577ee000 r-xp 00000000 08:02 459615                             /emul/ia32-linux/usr/lib/libX11.so.6.2.0
577ee000-577f1000 rw-p 000eb000 08:02 459615                             /emul/ia32-linux/usr/lib/libX11.so.6.2.0
577f1000-577f2000 rw-p 577f1000 00:00 0
577f2000-57806000 r-xp 00000000 08:02 459646                             /emul/ia32-linux/usr/lib/libXmu.so.6.2.0
57806000-57807000 rw-p 00014000 08:02 459646                             /emul/ia32-linux/usr/lib/libXmu.so.6.2.0
57807000-57907000 r-xp 00000000 08:02 408636                             /opt/OpenCascade6.3-32bit/lib/libTKHLR.so.0.0.0
57907000-5790a000 rw-p 00100000 08:02 408636                             /opt/OpenCascade6.3-32bit/lib/libTKHLR.so.0.0.0
5790a000-5790b000 rw-p 5790a000 00:00 0
5790b000-57b1b000 r-xp 00000000 08:02 408622                             /opt/OpenCascade6.3-32bit/lib/libTKTopAlgo.so.0.0.0
57b1b000-57b20000 rw-p 00210000 08:02 408622                             /opt/OpenCascade6.3-32bit/lib/libTKTopAlgo.so.0.0.0
57b20000-57b22000 rw-p 57b20000 00:00 0
57b22000-57fa5000 r-xp 00000000 08:02 408604                             /opt/OpenCascade6.3-32bit/lib/libTKGeomAlgo.so.0.0.0
57fa5000-57fad000 rw-p 00483000 08:02 408604                             /opt/OpenCascade6.3-32bit/lib/libTKGeomAlgo.so.0.0.0
57fad000-581e8000 rw-p 57fad000 00:00 0
581e8000-582ab000 r-xp 00000000 08:02 408596                             /opt/OpenCascade6.3-32bit/lib/libTKBRep.so.0.0.0
582ab000-582af000 rw-p 000c2000 08:02 408596                             /opt/OpenCascade6.3-32bit/lib/libTKBRep.so.0.0.0
582af000-582b0000 rw-p 582af000 00:00 0
582b0000-586b3000 r-xp 00000000 08:02 408182                             /opt/OpenCascade6.3-32bit/lib/libTKGeomBase.so.0.0.0
586b3000-586f9000 rw-p 00403000 08:02 408182                             /opt/OpenCascade6.3-32bit/lib/libTKGeomBase.so.0.0.0
586f9000-5874b000 rw-p 586f9000 00:00 0
5874b000-5884f000 r-xp 00000000 08:02 408174                             /opt/OpenCascade6.3-32bit/lib/libTKG3d.so.0.0.0
5884f000-58853000 rw-p 00103000 08:02 408174                             /opt/OpenCascade6.3-32bit/lib/libTKG3d.so.0.0.0
58853000-58855000 rw-p 58853000 00:00 0
58855000-588c0000 r-xp 00000000 08:02 408165                             /opt/OpenCascade6.3-32bit/lib/libTKG2d.so.0.0.0
588c0000-588c2000 rw-p 0006b000 08:02 408165                             /opt/OpenCascade6.3-32bit/lib/libTKG2d.so.0.0.0
588c2000-588c3000 rw-p 588c2000 00:00 0
588c3000-58a1b000 r-xp 00000000 08:02 318420                             /opt/OpenCascade6.3-32bit/lib/libTKMath.so.0.0.0
58a1b000-58a1f000 rw-p 00157000 08:02 318420                             /opt/OpenCascade6.3-32bit/lib/libTKMath.so.0.0.0
58a1f000-58a22000 rw-p 58a1f000 00:00 0
58a22000-58a7d000 r-xp 00000000 08:02 799838                             /opt/OpenCascade6.3-32bit/lib/libTKCDF.so.0.0.0
58a7d000-58a80000 rw-p 0005a000 08:02 799838                             /opt/OpenCascade6.3-32bit/lib/libTKCDF.so.0.0.0
58a80000-58a83000 rw-p 58a80000 00:00 0
58a83000-58cc1000 r-xp 00000000 08:02 310332                             /opt/OpenCascade6.3-32bit/lib/libTKernel.so.0.0.0
58cc1000-58cc8000 rw-p 0023e000 08:02 310332                             /opt/OpenCascade6.3-32bit/lib/libTKernel.so.0.0.0
58cc8000-58cd1000 rw-p 58cc8000 00:00 0
58cd1000-58ce5000 r-xp 00000000 08:02 457037                             /emul/ia32-linux/lib/libpthread-2.9.so
58ce5000-58ce6000 r--p 00013000 08:02 457037                             /emul/ia32-linux/lib/libpthread-2.9.so
58ce6000-58ce7000 rw-p 00014000 08:02 457037                             /emul/ia32-linux/lib/libpthread-2.9.so
58ce7000-58ce9000 rw-p 58ce7000 00:00 0
58ce9000-58ceb000 r-xp 00000000 08:02 457092                             /emul/ia32-linux/lib/libdl-2.9.so
58ceb000-58cec000 r--p 00001000 08:02 457092                             /emul/ia32-linux/lib/libdl-2.9.so
58cec000-58ced000 rw-p 00002000 08:02 457092                             /emul/ia32-linux/lib/libdl-2.9.so
58ced000-58dd0000 r-xp 00000000 08:02 457061                             /emul/ia32-linux/usr/lib/libstdc++.so.6.0.10
58dd0000-58dd3000 r--p 000e2000 08:02 457061                             /emul/ia32-linux/usr/lib/libstdc++.so.6.0.10
58dd3000-58dd5000 rw-p 000e5000 08:02 457061                             /emul/ia32-linux/usr/lib/libstdc++.so.6.0.10
58dd5000-58ddc000 rw-p 58dd5000 00:00 0
58ddc000-58dfe000 r-xp 00000000 08:02 457083                             /emul/ia32-linux/lib/libm-2.9.so
58dfe000-58dff000 r--p 00022000 08:02 457083                             /emul/ia32-linux/lib/libm-2.9.so
58dff000-58e00000 rw-p 00023000 08:02 457083                             /emul/ia32-linux/lib/libm-2.9.so
58e00000-58e0c000 r-xp 00000000 08:02 457058                             /emul/ia32-linux/usr/lib/libgcc_s.so.1
58e0c000-58e0d000 rw-p 0000b000 08:02 457058                             /emul/ia32-linux/usr/lib/libgcc_s.so.1
58e0d000-58f5e000 r-xp 00000000 08:02 457086                             /emul/ia32-linux/lib/libc-2.9.so
58f5e000-58f5f000 ---p 00151000 08:02 457086                             /emul/ia32-linux/lib/libc-2.9.so
58f5f000-58f61000 r--p 00151000 08:02 457086                             /emul/ia32-linux/lib/libc-2.9.so
58f61000-58f62000 rw-p 00153000 08:02 457086                             /emul/ia32-linux/lib/libc-2.9.so
58f62000-58f66000 rw-p 58f62000 00:00 0
58f66000-58f6d000 r-xp 00000000 08:02 459604                             /emul/ia32-linux/usr/lib/libSM.so.6.0.0
58f6d000-58f6e000 rw-p 00006000 08:02 459604                             /emul/ia32-linux/usr/lib/libSM.so.6.0.0
58f6e000-58f82000 r-xp 00000000 08:02 459640                             /emul/ia32-linux/usr/lib/libICE.so.6.3.0
58f82000-58f83000 rw-p 00014000 08:02 459640                             /emul/ia32-linux/usr/lib/libICE.so.6.3.0
58f83000-58f85000 rw-p 58f83000 00:00 0
58f85000-58f86000 r-xp 00000000 08:02 458617                             /emul/ia32-linux/usr/lib/libxcb-xlib.so.0.0.0
58f86000-58f87000 rw-p 00000000 08:02 458617                             /emul/ia32-linux/usr/lib/libxcb-xlib.so.0.0.0
58f87000-58f9e000 r-xp 00000000 08:02 459647                             /emul/ia32-linux/usr/lib/libxcb.so.1.0.0
58f9e000-58f9f000 rw-p 00016000 08:02 459647                             /emul/ia32-linux/usr/lib/libxcb.so.1.0.0
58f9f000-58fa0000 rw-p 58f9f000 00:00 0
58fa0000-58fad000 r-xp 00000000 08:02 458825                             /emul/ia32-linux/usr/lib/libXext.so.6.4.0
58fad000-58fae000 rw-p 0000c000 08:02 458825                             /emul/ia32-linux/usr/lib/libXext.so.6.4.0
58fae000-58fb0000 r-xp 00000000 08:02 458853                             /emul/ia32-linux/usr/lib/libXau.so.6.0.0
58fb0000-58fb1000 rw-p 00001000 08:02 458853                             /emul/ia32-linux/usr/lib/libXau.so.6.0.0
58fb1000-58fb5000 r-xp 00000000 08:02 459637                             /emul/ia32-linux/usr/lib/libXdmcp.so.6.0.0
58fb5000-58fb6000 rw-p 00003000 08:02 459637                             /emul/ia32-linux/usr/lib/libXdmcp.so.6.0.0
58fb6000-5abb9000 rw-p 58fb6000 00:00 0
5aca6000-5f1a6000 rw-p 5aca6000 00:00 0
5f20e000-64fa1000 rw-p 5f20e000 00:00 0
65028000-66a28000 rw-p 65028000 00:00 0
66a90000-76323000 rw-p 66a90000 00:00 0
763b7000-9ba70000 rw-p 763b7000 00:00 0
9ba70000-ffb8f000 rw-p 7fff9bee0000 00:00 0                              [stack]
ffc00000-ffc21000 rw-p ffc00000 00:00 0
ffc21000-ffd00000 ---p ffc21000 00:00 0
Success
   save entset: /bin/sh: line 4: 20331 Aborted                 /home/jason/bin/timeout 600 ${dir}$tst
FAIL: testgeom_occ
1 of 1 tests failed
make[4]: *** [check-TESTS] Error 1
make[3]: *** [check-am] Error 2
make[3]: Leaving directory `/home/jason/cgm/test/32-occ/itaps'
make[2]: *** [check-recursive] Error 1
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/itaps'
make[1]: *** [check] Error 2
make[1]: Leaving directory `/home/jason/cgm/test/32-occ/itaps'
make: *** [check-recursive] Error 1
More information about the cgma-dev mailing list
