[cgma-dev] CGMA check for *32-occ* failed.
    Nightly Test
    kraftche at cae.wisc.edu
    Sun Sep  6 02:45:33 CDT 2009
Making check in compat
make[1]: Entering directory `/home/jason/cgm/test/32-occ/compat'
make[1]: Nothing to be done for `check'.
make[1]: Leaving directory `/home/jason/cgm/test/32-occ/compat'
Making check in util
make[1]: Entering directory `/home/jason/cgm/test/32-occ/util'
make[1]: Leaving directory `/home/jason/cgm/test/32-occ/util'
Making check in geom
make[1]: Entering directory `/home/jason/cgm/test/32-occ/geom'
Making check in .
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom'
make[2]: Nothing to be done for `check-am'.
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom'
Making check in Cholla
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/Cholla'
make[2]: Nothing to be done for `check'.
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/Cholla'
Making check in facetbool
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/facetbool'
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/facetbool'
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/facet'
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/facet'
Making check in virtual
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/virtual'
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/virtual'
Making check in OCC
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/OCC'
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/OCC'
make[1]: Leaving directory `/home/jason/cgm/test/32-occ/geom'
Making check in init
make[1]: Entering directory `/home/jason/cgm/test/32-occ/init'
make[1]: Leaving directory `/home/jason/cgm/test/32-occ/init'
Making check in .
make[1]: Entering directory `/home/jason/cgm/test/32-occ'
make[1]: Leaving directory `/home/jason/cgm/test/32-occ'
Making check in itaps
make[1]: Entering directory `/home/jason/cgm/test/32-occ/itaps'
make  check-recursive
make[2]: Entering directory `/home/jason/cgm/test/32-occ/itaps'
Making check in .
make[3]: Entering directory `/home/jason/cgm/test/32-occ/itaps'
make  chaman   testgeom_occ
make[4]: Entering directory `/home/jason/cgm/test/32-occ/itaps'
make[4]: `testgeom_occ' is up to date.
make[4]: Leaving directory `/home/jason/cgm/test/32-occ/itaps'
make  check-TESTS
Using default input file: ../../trunk/itaps/../test/LeverArm.brep
Geometry engine set to: OCC Geometry Engine version 6.2.0
ITAPS GEOMETRY INTERFACE TEST PROGRAM:
   gLoad:
Constructed 1 Volume: 1
Model contents:
vertices: 99
edges: 159
faces: 63
regions: 1
Success
   tags: Tags defined on model: GLOBAL_ID, NAME
Success
   gentity sets: Success
   topology adjacencies: Success
   construct: Created swept volume 4
Success
   primitives: Success
   transforms: Success
   booleans: Updated volume(s): 11
Destroyed volume(s): 12
Updated volume(s): 13
Destroyed volume(s): 14
/bin/sh: line 4:  3835 Segmentation fault      /home/jason/bin/timeout 600 ${dir}$tst
FAIL: testgeom_occ
1 of 1 tests failed
make[4]: *** [check-TESTS] Error 1
make[3]: *** [check-am] Error 2
make[3]: Leaving directory `/home/jason/cgm/test/32-occ/itaps'
make[2]: *** [check-recursive] Error 1
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/itaps'
make[1]: *** [check] Error 2
make[1]: Leaving directory `/home/jason/cgm/test/32-occ/itaps'
make: *** [check-recursive] Error 1
More information about the cgma-dev
