[cgma-dev] CGMA check for *32-acis* failed.
    Nightly Test
    kraftche at cae.wisc.edu
    Thu Aug 27 02:08:25 CDT 2009
Making check in compat
make[1]: Entering directory `/home/jason/cgm/test/32-acis/compat'
make[1]: Nothing to be done for `check'.
make[1]: Leaving directory `/home/jason/cgm/test/32-acis/compat'
Making check in util
make[1]: Entering directory `/home/jason/cgm/test/32-acis/util'
make[1]: Leaving directory `/home/jason/cgm/test/32-acis/util'
Making check in geom
make[1]: Entering directory `/home/jason/cgm/test/32-acis/geom'
Making check in .
make[2]: Entering directory `/home/jason/cgm/test/32-acis/geom'
make[2]: Nothing to be done for `check-am'.
make[2]: Leaving directory `/home/jason/cgm/test/32-acis/geom'
Making check in Cholla
make[2]: Entering directory `/home/jason/cgm/test/32-acis/geom/Cholla'
make[2]: Nothing to be done for `check'.
make[2]: Leaving directory `/home/jason/cgm/test/32-acis/geom/Cholla'
Making check in facetbool
make[2]: Entering directory `/home/jason/cgm/test/32-acis/geom/facetbool'
make[2]: Leaving directory `/home/jason/cgm/test/32-acis/geom/facetbool'
make[2]: Entering directory `/home/jason/cgm/test/32-acis/geom/facet'
make[2]: Leaving directory `/home/jason/cgm/test/32-acis/geom/facet'
Making check in virtual
make[2]: Entering directory `/home/jason/cgm/test/32-acis/geom/virtual'
make[2]: Leaving directory `/home/jason/cgm/test/32-acis/geom/virtual'
Making check in ACIS
make[2]: Entering directory `/home/jason/cgm/test/32-acis/geom/ACIS'
/bin/sh ../../libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER   -DCUBIT_ACIS_VERSION=1600 -DACIS_VERSION=1600 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1600 -I. -I../../../trunk/geom/ACIS -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/ACIS/gtcAttrib/incl -I/opt/acis16-32bit/include -I../../../trunk/compat/new  -isystem /opt/acis16-32bit/include  -Wall -pipe -pedantic -g -m32 -MT AcisBridge.lo -MD -MP -MF .deps/AcisBridge.Tpo -c -o AcisBridge.lo ../../../trunk/geom/ACIS/AcisBridge.cpp
 c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1600 -DACIS_VERSION=1600 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1600 -I. -I../../../trunk/geom/ACIS -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/ACIS/gtcAttrib/incl -I/opt/acis16-32bit/include -I../../../trunk/compat/new -isystem /opt/acis16-32bit/include -Wall -pipe -pedantic -g -m32 -MT AcisBridge.lo -MD -MP -MF .deps/AcisBridge.Tpo -c ../../../trunk/geom/ACIS/AcisBridge.cpp -o AcisBridge.o
In file included from ../../../trunk/geom/ACIS/AcisBridge.cpp:26:
../../../trunk/geom/ACIS/AcisQueryEngine.hpp: In static member function âstatic AcisQueryEngine* AcisQueryEngine::instance()â:
../../../trunk/geom/ACIS/AcisQueryEngine.hpp:157: error: cannot allocate an object of abstract type âAcisQueryEngineâ
../../../trunk/geom/ACIS/AcisQueryEngine.hpp:117: note:   because the following virtual functions are pure within âAcisQueryEngineâ:
../../../trunk/geom/GeometryQueryEngine.hpp:57: note: 	virtual CubitStatus GeometryQueryEngine::export_solid_model(DLIList<TopologyBridge*>&, char*&, int&, bool)
../../../trunk/geom/GeometryQueryEngine.hpp:114: note: 	virtual CubitStatus GeometryQueryEngine::import_solid_model(DLIList<TopologyBridge*>&, const char*, int)
make[2]: *** [AcisBridge.lo] Error 1
make[2]: Leaving directory `/home/jason/cgm/test/32-acis/geom/ACIS'
make[1]: *** [check-recursive] Error 1
make[1]: Leaving directory `/home/jason/cgm/test/32-acis/geom'
make: *** [check-recursive] Error 1
More information about the cgma-dev
