[cgma-dev] r3119 - cgm/trunk/itaps
sjackson at cae.wisc.edu
Wed Aug 26 13:25:54 CDT 2009
Author: sjackson
Date: 2009-08-26 13:25:53 -0500 (Wed, 26 Aug 2009)
New Revision: 3119
Modified:
cgm/trunk/itaps/iGeom.h
cgm/trunk/itaps/iGeom_CGMA.cc
Log:
Add support for creating cones in iGeom by extending the interface
with the new function iGeom_createCone.
Modified: cgm/trunk/itaps/iGeom.h
--- cgm/trunk/itaps/iGeom.h 2009-08-25 14:38:58 UTC (rev 3118)
+++ cgm/trunk/itaps/iGeom.h 2009-08-26 18:25:53 UTC (rev 3119)
@@ -2116,6 +2116,17 @@
/**\brief
+ void iGeom_createCone( iGeom_Instance,
+ double height,
+ double major_rad_base,
+ double minor_rad_base,
+ double rad_top,
+ iBase_EntityHandle* geom_entity,
+ int* err );
+/**\brief
void iGeom_createTorus( iGeom_Instance,
double major_rad,
double minor_rad,
Modified: cgm/trunk/itaps/iGeom_CGMA.cc
--- cgm/trunk/itaps/iGeom_CGMA.cc 2009-08-25 14:38:58 UTC (rev 3118)
+++ cgm/trunk/itaps/iGeom_CGMA.cc 2009-08-26 18:25:53 UTC (rev 3119)
@@ -5305,8 +5305,30 @@
RETURN(iBase_SUCCESS);
void
+iGeom_createCone (iGeom_Instance instance,
+ /*in*/ double height,
+ /*in*/ double major_rad_base,
+ /*in*/ double minor_rad_base,
+ /*in*/ double rad_top,
+ /*out*/ iBase_EntityHandle *geom_entity,
+ int* err)
+ double tmp_minor = (0.0 == minor_rad_base ? major_rad_base : minor_rad_base);
+ RefEntity *temp_body =
+ gmt->cylinder(height, major_rad_base, tmp_minor, rad_top);
+ *geom_entity = reinterpret_cast<iBase_EntityHandle>(temp_body);
+ if (NULL == *geom_entity) {
+ RETURN(iBase_FAILURE);
+ RETURN(iBase_SUCCESS);
+void
iGeom_createTorus (iGeom_Instance instance,
/*in*/ double major_rad,
/*in*/ double minor_rad,
More information about the cgma-dev
