[cgma-dev] r3118 - cgm/trunk/geom/ACIS_SRC
Tim Tautges tautges at mcs.anl.gov
Tue Aug 25 10:50:23 CDT 2009
Thanks.
- tim
hongjun at mcs.anl.gov wrote:
> Author: hongjun
> Date: 2009-08-25 09:38:58 -0500 (Tue, 25 Aug 2009)
> New Revision: 3118
> Modified:
>    cgm/trunk/geom/ACIS_SRC/AcisQueryEngine.cpp
>    cgm/trunk/geom/ACIS_SRC/AcisQueryEngine.hpp
> Log:
> o "export_solid_model" and "import_solid_model" functions are added.
> o They are pure virtual functions in GeometryQueryEngine.
> o Dummy implementation for the functions.
> Modified: cgm/trunk/geom/ACIS_SRC/AcisQueryEngine.cpp
> --- cgm/trunk/geom/ACIS_SRC/AcisQueryEngine.cpp	2009-08-24 20:58:43 UTC (rev 3117)
> +++ cgm/trunk/geom/ACIS_SRC/AcisQueryEngine.cpp	2009-08-25 14:38:58 UTC (rev 3118)
> @@ -758,6 +758,14 @@
>    return status;
> +CubitStatus AcisQueryEngine::export_solid_model( DLIList<TopologyBridge*>& bridge_list,
> +						 char*& p_buffer,
> +						 int& n_buffer_size,
> +						 bool b_export_buffer)
> +  return CUBIT_FAILURE;
>  CubitStatus
>  AcisQueryEngine::remove_refinements( ENTITY_LIST& list )
> @@ -967,6 +975,13 @@
>    return status;
> +CubitStatus AcisQueryEngine::import_solid_model(DLIList<TopologyBridge*> &imported_entities,
> +						const char* pBuffer,
> +						const int n_buffer_size)
>  CubitStatus AcisQueryEngine::restore_entity_list(
>                                        ENTITY_LIST &entity_list,
>                                        DLIList<TopologyBridge*> &bridge_list,
> Modified: cgm/trunk/geom/ACIS_SRC/AcisQueryEngine.hpp
> --- cgm/trunk/geom/ACIS_SRC/AcisQueryEngine.hpp	2009-08-24 20:58:43 UTC (rev 3117)
> +++ cgm/trunk/geom/ACIS_SRC/AcisQueryEngine.hpp	2009-08-25 14:38:58 UTC (rev 3118)
> @@ -203,6 +203,11 @@
>      //- the underlying representation and file type. It returns
>      //- CUBIT_SUCCESS if everything goes well.
> +  virtual CubitStatus export_solid_model( DLIList<TopologyBridge*>& bridge_list,
> +					  char*& p_buffer,
> +					  bool b_export_buffer);
>    virtual CubitStatus save_temp_geom_file(DLIList<TopologyBridge*> &ref_entity_list,
>                                            const char *filename,
>                                            const CubitString &cubit_version,
> @@ -252,6 +257,10 @@
> +  virtual CubitStatus import_solid_model(DLIList<TopologyBridge*> &imported_entities,
> +					const int n_buffer_size);
>    CubitStatus restore_entity_list(ENTITY_LIST &entity_list,
>                                    CubitBoolean print_results = CUBIT_TRUE,
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the cgma-dev mailing list
