[cgma-dev] CGMA check for *64-occ* failed.
    Nightly Test
    kraftche at cae.wisc.edu
    Sun Aug 23 02:11:20 CDT 2009
Making check in compat
make[1]: Entering directory `/home/jason/cgm/test/64-occ/compat'
make[1]: Nothing to be done for `check'.
make[1]: Leaving directory `/home/jason/cgm/test/64-occ/compat'
Making check in util
make[1]: Entering directory `/home/jason/cgm/test/64-occ/util'
make[1]: Leaving directory `/home/jason/cgm/test/64-occ/util'
Making check in geom
make[1]: Entering directory `/home/jason/cgm/test/64-occ/geom'
Making check in .
make[2]: Entering directory `/home/jason/cgm/test/64-occ/geom'
make[2]: Nothing to be done for `check-am'.
make[2]: Leaving directory `/home/jason/cgm/test/64-occ/geom'
Making check in Cholla
make[2]: Entering directory `/home/jason/cgm/test/64-occ/geom/Cholla'
make[2]: Nothing to be done for `check'.
make[2]: Leaving directory `/home/jason/cgm/test/64-occ/geom/Cholla'
Making check in facetbool
make[2]: Entering directory `/home/jason/cgm/test/64-occ/geom/facetbool'
make[2]: Leaving directory `/home/jason/cgm/test/64-occ/geom/facetbool'
make[2]: Entering directory `/home/jason/cgm/test/64-occ/geom/facet'
make[2]: Leaving directory `/home/jason/cgm/test/64-occ/geom/facet'
Making check in virtual
make[2]: Entering directory `/home/jason/cgm/test/64-occ/geom/virtual'
make[2]: Leaving directory `/home/jason/cgm/test/64-occ/geom/virtual'
Making check in OCC
make[2]: Entering directory `/home/jason/cgm/test/64-occ/geom/OCC'
make[2]: Leaving directory `/home/jason/cgm/test/64-occ/geom/OCC'
make[1]: Leaving directory `/home/jason/cgm/test/64-occ/geom'
Making check in init
make[1]: Entering directory `/home/jason/cgm/test/64-occ/init'
make[1]: Leaving directory `/home/jason/cgm/test/64-occ/init'
Making check in .
make[1]: Entering directory `/home/jason/cgm/test/64-occ'
make[1]: Leaving directory `/home/jason/cgm/test/64-occ'
Making check in itaps
make[1]: Entering directory `/home/jason/cgm/test/64-occ/itaps'
make  check-recursive
make[2]: Entering directory `/home/jason/cgm/test/64-occ/itaps'
Making check in .
make[3]: Entering directory `/home/jason/cgm/test/64-occ/itaps'
make  chaman   testgeom_occ
make[4]: Entering directory `/home/jason/cgm/test/64-occ/itaps'
/bin/sh ../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -Wno-long-long  -L/opt/OpenCascade6.3/lib  -o chaman chaman-chaman.o libiGeom.la -lm
c++ -Wall -pipe -pedantic -g -Wno-long-long -o chaman chaman-chaman.o  -L/opt/OpenCascade6.3/lib ./.libs/libiGeom.a /home/jason/cgm/test/64-occ/.libs/libcgm.a /opt/OpenCascade6.3//lib/libTKFeat.so /opt/OpenCascade6.3//lib/libTKIGES.so /opt/OpenCascade6.3//lib/libTKOffset.so /opt/OpenCascade6.3//lib/libTKFillet.so /opt/OpenCascade6.3//lib/libTKBool.so /opt/OpenCascade6.3//lib/libTKBO.so /opt/OpenCascade6.3//lib/libTKPrim.so /opt/OpenCascade6.3//lib/libTKSTEP.so /opt/OpenCascade6.3//lib/libTKSTEPAttr.so /opt/OpenCascade6.3//lib/libTKSTEP209.so /opt/OpenCascade6.3//lib/libTKSTEPBase.so /opt/OpenCascade6.3//lib/libTKSTL.so /opt/OpenCascade6.3//lib/libTKXSBase.so /opt/OpenCascade6.3//lib/libTKShHealing.so /opt/OpenCascade6.3//lib/libTKBin.so /opt/OpenCascade6.3//lib/libTKBinL.so /opt/OpenCascade6.3//lib/libTKCAF.so /opt/OpenCascade6.3//lib/libTKLCAF.so /opt/OpenCascade6.3//lib/libTKV3d.so /opt/OpenCascade6.3//lib/libTKMesh.so /opt/OpenCascade6.3//lib/libTKV2d.so /opt/OpenCascade6!
 .3//lib/libTKService.so -lXt -lX11 -lXmu /opt/OpenCascade6.3//lib/libTKHLR.so /opt/OpenCascade6.3//lib/libTKTopAlgo.so /opt/OpenCascade6.3//lib/libTKGeomAlgo.so /opt/OpenCascade6.3//lib/libTKBRep.so /opt/OpenCascade6.3//lib/libTKGeomBase.so /opt/OpenCascade6.3//lib/libTKG3d.so /opt/OpenCascade6.3//lib/libTKG2d.so /opt/OpenCascade6.3//lib/libTKMath.so /opt/OpenCascade6.3//lib/libTKCDF.so /opt/OpenCascade6.3//lib/libTKernel.so -lpthread -ldl -lm   -Wl,--rpath -Wl,/opt/OpenCascade6.3//lib -Wl,--rpath -Wl,/opt/OpenCascade6.3//lib
/usr/bin/ld: cannot find -lXt
collect2: ld returned 1 exit status
make[4]: *** [chaman] Error 1
make[4]: Leaving directory `/home/jason/cgm/test/64-occ/itaps'
make[3]: *** [check-am] Error 2
make[3]: Leaving directory `/home/jason/cgm/test/64-occ/itaps'
make[2]: *** [check-recursive] Error 1
make[2]: Leaving directory `/home/jason/cgm/test/64-occ/itaps'
make[1]: *** [check] Error 2
make[1]: Leaving directory `/home/jason/cgm/test/64-occ/itaps'
make: *** [check-recursive] Error 1
More information about the cgma-dev
